Hello ARM community.
LibreOffice got a big update this time with improved Dark Mode.
Some highlights:
- Most of our kernels got updated
- LibreOffice updated to 7.5.0
- Thunderbird updated to 102.7.2
- KDE Gear applications updated to 22.12.2
- Mesa updated to 22.3.5
- Many u-boot packages updated to 2023.01
- Waydroid updated to 1.4.0
- Lots of Mobile specific packages got updated
- Many python packages got updated
End Of Life kernels (will be removed from repo soon):
linux60
(EOL on 2023-01-12)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver
. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1
as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
PHP 8.2 update and introduction of legacy branch
The php packages have been updated to the latest version 8.2. In addition to this, a new set of php-legacy packages have been introduced. These will follow the oldest but still actively supported PHP branch. This enables users to install the latest version but also introduces the option to use third party applications that might rely on an older version. Both branches will be kept up to date following our rolling release model. php
and php-legacy
can be installed at the same time as the latter uses a -legacy
suffix for its binaries and configuration files.
In addition to this, the php7 packages have been removed as they reached end of life. The imap
extension will no longer be provided as it relies on the c-client
library which has been abandoned for many years.
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Sat Feb 11 18:22:29 CET 2023)
- arm-testing community aarch64: 370 new and 360 removed package(s)
- arm-testing core aarch64: 49 new and 48 removed package(s)
- arm-testing extra aarch64: 697 new and 691 removed package(s)
- arm-testing kde-unstable aarch64: 49 new and 49 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2023-02-02 2023-02-11
amazfish 2.1.0-1 2.1.2-1
electron 22.0.1-1 22.2.0-1
electron20 20.3.9-1 20.3.11-1
electron21 21.3.4-1 21.4.1-1
gradience 0.3.3-1 0.4.0-1
libglibutil 1.0.67-1 1.0.68-1
obs-studio 29.0.0-1 29.0.2-1
phosh-antispam 3.0.0-1 3.1.0-1
vvmd 0.13-1 0.14-1
waydroid 1.3.4-1 1.4.0-1
:: Different sync package(s) in repository community aarch64
aardvark-dns 1.4.0-1 1.5.0-1
ansible-lint 6.11.0-1 6.12.2-1
arandr 0.1.10-7 0.1.11-1
archlinux-repro 20221114-1 20230206-1
argocd 2.5.9-1 2.6.1-1
bash-language-server 4.6.2-1 4.7.0-1
binwalk 2.3.3-3 2.3.4-1
blender 17:3.4.1-12 17:3.4.1-13
bmake 20230127-1 20230208-1
boinc 7.20.4-1 7.22.0-1
boinc-nox 7.20.4-1 7.22.0-1
broot 1.19.0-1 1.20.1-1
buoh 0.8.2-15 -
cabextract 1.9.1-2 1.10-1
cargo-c 0.9.16-1 0.9.16-2
cargo-edit 0.11.8-1 0.11.8-2
cargo-generate 0.17.6-1 0.17.6-2
cargo-pgx 0.7.0-1 0.7.1-1
cargo-zigbuild 0.15.0-1 0.16.0-1
cawbird 1.5-2 -
ccid 1.5.1-1 1.5.2-1
chezmoi 2.29.4-1 2.30.0-1
cockpit-machines 282-1 283-1
cockpit-podman 61-1 62-1
conmon 1:2.1.5-1 1:2.1.6-1
containers-common 1:0.50.1-2 1:0.51.0-1
dart 2.18.6-1 2.19.1-1
dart-sass 1.57.1-1 1.58.0-1
dbmate 1.16.0-1 1.16.2-1
debian-ports-archive-keyring 2022.02.15-1 2023.02.01-1
devtools-git-poc 20230202-3 20230202-4
diffoscope 234-1 235-1
difftastic 0.42.0-1 0.43.1-1
docker-compose 2.15.1-1 2.16.0-1
dpkg 1.21.19-1 1.21.20-1
dra 0.4.3-1 0.4.5-1
dtkcommon 5.6.3-1 5.6.4-2
dua-cli 2.18.1-1 2.19.1-1
dub 1.30.0-2 1.31.0-1
ejabberd 22.10-2 23.01-1
erlang 25.2-2 25.2-3
erlang-nox 25.2-1 25.2-2
erlang-unixodbc 25.2-2 25.2-3
espup 0.2.6-1 0.2.8-1
faudio 23.01-1 23.02-1
fingerterm 1.4.6-1 1.4.7-1
firefox-noscript 11.4.14-1 11.4.15-1
forgejo 1.18.2.1-1 1.18.3.0-1
fq 0.2.0-1 0.3.0-1
freeciv 3.0.5-1 3.0.6-1
fscrypt 0.3.3-2 0.3.4-1
gdu 5.21.1-2 5.22.0-1
gfold 4.2.0-1 4.3.1-1
gimp-plugin-gmic 3.2.0-1 3.2.0-2
ginac 1.8.4-1 1.8.6-1
github-cli 2.22.1-1 2.23.0-1
gitlab-runner 15.8.0-1 15.8.2-1
glab 1.24.1-1 1.25.3-1
glide 0.5.9-2 0.5.11-2
gnucash-docs 4.12-1 4.13-1
gpxsee 11.11-1 11.12-1
grafana-agent 0.30.1-1 0.31.2-1
grafana-agent-crow 0.30.1-1 0.31.2-1
grafana-agentctl 0.30.1-1 0.31.2-1
gscan2pdf 2.13.0-1 2.13.2-1
hackrf 2022.09.1-1 2023.01.1-1
himalaya 0.6.1-2 0.7.0-1
home-assistant 1:2023.1.7-1 1:2023.2.3-1
homebank 5.6-1 5.6.2-1
hugo 0.109.0-1 0.110.0-1
ibus-libpinyin 1.13.0-1 1.13.1-1
icmake 10.03.02-1 10.03.03-1
ifuse 1.1.4-2 1.1.4-3
ipython 8.9.0-1 8.10.0-1
iwd 2.2-1 2.3-1
jenkins 2.389-1 2.390-1
jmol 16.1.1-1 16.1.3-1
jruby 9.4.0.0-1 9.4.1.0-1
jsmol 16.1.1-1 16.1.3-1
jupyter-notebook 6.5.2-1 6.5.2-2
jupyter-server 2.2.0-1 2.2.1-1
jupyterlab 3.5.3-1 3.6.1-1
kcptun 20221015-1 20230207-1
klayout 0.28.3-1 0.28.5-1
knot-resolver 5.5.3-1 5.6.0-1
kotlin 1.8.0-1 1.8.10-1
kustomize 4.5.7-1 5.0.0-1
kvantum 1.0.7-1 1.0.9-1
libayatana-appindicator 0.5.91-2 0.5.92-1
libbobcat 5.11.00-3 6.02.02-1
libhx 4.9-1 4.10-1
libjxl 0.8.0-1 0.8.1-1
libjxl-doc 0.8.0-1 0.8.1-1
libressl 3.6.1-1 3.6.2-1
libretro-beetle-psx 2646-1 2650-1
libretro-beetle-psx-hw 2646-1 2650-1
libretro-flycast 5390-1 5464-1
libretro-gambatte 982-1 984-1
libretro-genesis-plus-gx 1974-1 1977-1
libretro-mgba 8704-1 8797-1
libretro-picodrive 2270-1 2272-1
libretro-play 7480-1 7605-1
libretro-shaders-slang 1146-1 1175-1
libsemigroups 2.5.1-1 2.6.0-1
libtg_owt 0.git19.9b70d76-1 0.git20.5098730-1
libxdp 1.2.9-1 1.3.0-1
logcli 2.7.1-1 2.7.3-2
logwatch 7.8-1 7.8-2
loki 2.7.1-1 2.7.3-2
loki-canary 2.7.1-1 2.7.3-2
lua-language-server 3.6.8-1 3.6.10-1
man-pages-zh_cn 1.6.4.0-1 1.6.4.0-2
man-pages-zh_tw 1.6.4.0-1 1.6.4.0-2
marked 4.2.6-1 4.2.8-1
marked-man 1.3.1-1 1.3.2-1
matrix-synapse 1.74.0-1 1.75.0-1
mdbook 0.4.25-1 0.4.26-1
mimir 2.5.0-1 2.6.0-1
mod_passenger 6.0.16-1 6.0.17-1
monitoring-plugins 2.3.2-2 2.3.3-1
moosefs 3.0.116-2 3.0.116-3
neovim 0.8.2-1 0.8.3-1
neovim-lspconfig 0.1.5-1 0.1.6-1
nerdctl 1.1.0-1 1.2.0-1
netavark 1.4.0-1 1.5.0-1
netdata 1.37.1-1 1.38.0-1
nextcloud-app-calendar 1:4.2.2-1 1:4.2.3-1
nextcloud-app-contacts 5.0.3-1 5.1.0-1
nextcloud-client 2:3.6.6-1 2:3.7.3-1
nextcloud-client-cloudproviders 2:3.6.6-1 2:3.7.3-1
nginx-mod-passenger 6.0.16-1 6.0.17-1
nodejs 19.5.0-1 19.6.0-1
nodejs-lts-hydrogen 18.13.0-1 18.14.0-1
npm-check-updates 16.6.3-1 16.6.5-1
ocaml-base 0.15.0-2 0.15.1-1
openblas 0.3.21-1 0.3.21-4
openshadinglanguage 1.12.8.0-3 1.12.9.0-1
openttd 12.2-4 13.0-1
osbuild 77-1 78-1
pantheon-files 6.2.1-1 6.2.2-1
paperwork 2.1.1-3 2.1.2-1
pd-lua 0.11.4-1 0.11.5-1
perl-cairo-gobject 1.004-12 1.005-1
perl-config-general 2.64-1 2.65-1
perl-cpanel-json-xs 4.29-2 4.32-1
perl-dbd-sybase 1.22-1 1.23-1
perl-graphics-tiff 12-4 19-1
perl-json-maybexs 1.004003-4 1.004004-1
perl-pdf-api2 2.041-2 2.044-1
perl-pdf-builder 3.022-2 3.025-1
perl-string-util 1.32-1 1.34-1
perl-sys-virt 8.10.0-1 9.0.0-1
perl-test-simple 1.302191-1 1.302192-1
perl-xml-libxslt 2.002000-1 2.002001-1
pgformatter 5.4-1 5.5-1
php-igbinary 3.2.12-2 3.2.13-1
php-legacy-igbinary 3.2.12-2 3.2.13-1
phpldapadmin 1.2.6.4-5 1.2.6.4-7
phpmyadmin 5.2.0-1 5.2.1-1
podman 4.4.0-1 4.4.0-2
podman-docker 4.4.0-1 4.4.0-2
prettier 2.8.3-1 2.8.4-1
privoxy 3.0.33-1 3.0.34-1
promtail 2.7.1-1 2.7.3-2
pueue 3.0.1-1 3.1.0-1
pyright 1.1.292-1 1.1.293-1
python-aiofiles 22.1.0-3 23.1.0-1
python-ansible-compat 3.0.0-1 3.0.1-1
python-argh 0.26.2-10 0.27.0-1
python-autobahn 22.12.1-1 23.1.2-1
python-bleach 5.0.1-2 6.0.0-1
python-blessed 1.19.1-2 1.20.0-1
python-clevercsv 0.7.2-1 0.7.5-1
python-cython-lint 0.11.0-1 0.12.4-1
python-django-modeltranslation 0.18.7-1 0.18.8-1
python-envisage 6.1.0-1 6.1.0-2
python-esbonio 0.15.0-4 0.16.0-1
python-faker 14.0.0-1 15.1.0-1
python-fakeredis 2.6.0-1 2.7.1-1
python-fastnumbers 3.2.1-2 4.0.1-1
python-gdstk 0.9.16-1 0.9.20-1
python-identify 2.5.16-1 2.5.17-1
python-ipykernel 6.21.0-1 6.21.1-2
python-jaraco.context 4.2.1-1 4.3.0-1
python-jaraco.text 3.11.0-1 3.11.1-1
python-jupyter_packaging 0.12.3-1 -
python-octaviaclient 3.0.0-1 3.1.0-1
python-openapi-schema-validator 0.4.2-1 0.4.3-1
python-openapi-spec-validator 0.5.2-1 0.5.5-1
python-openpyxl 3.0.10-2 3.1.0-1
python-oslo-context 5.0.0-2 5.1.0-1
python-oslo-db 12.3.0-1 12.3.1-1
python-oslo-i18n 5.1.0-3 6.0.0-1
python-oslo-log 5.0.2-1 5.1.0-1
python-pdm 2.4.0-1 2.4.3-1
python-pdm-pep517 1:1.0.6-1 1:1.1.2-1
python-phonenumbers 8.13.5-2 8.13.6-1
python-piccata 2.0.2-1 2.0.3-1
python-pikepdf 6.2.9-1 7.0.0-1
python-pipenv 2022.12.19-1 2023.2.4-1
python-pylint 2.15.10-1 2.16.1-1
python-pynitrokey 0.4.32-1 0.4.33-1
python-pytest-socket 0.5.1-2 0.6.0-1
python-pytest-xdist 3.1.0-2 3.2.0-1
python-pythonfinder 1.3.1-1 1.3.2-1
python-rpy2 3.5.7-1 3.5.8-1
python-softlayer 6.1.3-1 6.1.4-1
python-sphinxext-opengraph 0.7.5-2 0.8.1-1
python-spyder-kernels 2.4.2-1 2.4.2-2
python-starlette 0.23.1-1 0.24.0-1
python-sure 2.0.0-5 2.0.1-1
python-sybil 4.0.0-1 4.0.1-1
python-tenacity 8.1.0-2 8.2.1-1
python-testfixtures 7.0.4-1 7.1.0-1
python-testflo 1.4.9-1 1.4.10-1
python-websocket-client 1.5.0-1 1.5.1-1
python-xlsxwriter 3.0.7-1 3.0.8-1
python-xmlschema 2.1.1-1 2.2.0-1
python-z3-solver 4.11.2-1 4.12.0-1
python-zipp 3.12.0-2 3.13.0-1
python-zope-security 5.8-1 6.1-1
qgis 3.28.2-2 3.28.3-1
reaper 6.73-1 6.75-1
restic 0.15.0-1 0.15.1-1
reuse 1.1.0-1 1.1.1-1
rhonabwy 1.1.10-1 1.1.11-1
rime-emoji 0.0.0.20220315-1 0.0.0.20230206-1
rime-essay 0.0.0.20210805-1 0.0.0.20230204-1
rnote 0.5.12-1 0.5.13-1
rssguard 4.3.1-1 4.3.2-1
rssguard-lite 4.3.1-1 4.3.2-1
ruby-async-websocket 0.22.1-2 0.23.1-1
ruby-attr_extras 7.0.0-1 7.1.0-1
ruby-build-environment 1.13.0-2 1.13.0-3
ruby-bump 0.10.0-1 0.10.0-2
ruby-character_set 1.6.0-1 1.6.0-2
ruby-contracts 0.17-1 0.17-2
ruby-cucumber-cucumber-expressions 16.1.2-1 16.1.2-2
ruby-fakefs 2.0.0-1 2.2.0-1
ruby-filelock 1.1.1-1 1.1.1-2
ruby-get_process_mem 0.2.7-1 0.2.7-2
ruby-http 5.1.1-1 5.1.1-2
ruby-listen 3.8.0-1 3.8.0-2
ruby-localhost 1.1.9-1 1.1.10-1
ruby-lumberjack 1.2.8-1 1.2.8-2
ruby-m 1.6.0-1 1.6.1-1
ruby-mapping 1.1.1-1 1.1.1-2
ruby-maxitest 4.4.0-1 4.4.0-2
ruby-multi_test 1.1.0-1 1.1.0-2
ruby-nenv 0.3.0-1 0.3.0-2
ruby-notiffany 0.1.3-1 0.1.3-2
ruby-patron 0.13.3-1 0.13.3-2
ruby-process-metrics 0.2.1-1 0.2.1-2
ruby-protocol-hpack 1.4.2-1 1.4.2-2
ruby-protocol-http2 0.14.2-2 0.15.0-1
ruby-protocol-websocket 0.9.1-2 0.10.0-1
ruby-pry 0.14.2-1 0.14.2-2
ruby-pycall 1.4.2-1 1.4.2-2
ruby-rbnacl 7.1.1-1 7.1.1-2
ruby-regexp_property_values 1.3.0-1 1.3.0-2
ruby-ruby_memcheck 1.2.0-1 1.2.0-2
ruby-rubygems-tasks 0.2.5-1 0.2.5-2
ruby-samovar 2.1.4-2 2.1.4-3
ruby-sequel 5.64.0-1 5.65.0-1
ruby-shellany 0.0.1-1 0.0.1-2
ruby-shoulda-context 2.0.0-3 2.0.0-4
ruby-sorted_set 1.0.3-1 1.0.3-2
ruby-sus-fixtures-async-http 0.2.3-1 0.3.0-1
ruby-warnings_logger 0.1.1-2 0.1.1-3
ruff 0.0.239-1 0.0.244-1
ruff-lsp 0.0.16-1 0.0.17-1
rust-analyzer 20230130-1 20230206-1
rust-bindgen 0.63.0-1 0.64.0-1
rustup 1.25.1-2 1.25.2-1
scite 5.3.2-1 5.3.3-1
sequoia-chameleon-gnupg 0.1.1-1 0.2.0-1
sequoia-wot 0.4.1-1 0.5.0-1
simh 3.11.1-3 3.12.3-2
soft-serve 0.4.4-1 0.4.5-1
soundkonverter 3.0.1-5 3.0.1-6
sox14.4.2+r182+g42b3557e-214.4.2+r182+g42b3557e-3
ssr 0.5.0-4 0.6.0-1
staticcheck 2022.1.3-1 2023.1-1
step-cli 0.23.1-1 0.23.2-1
stylelint 14.16.1-1 15.0.0-1
stylelint-config-recommended 9.0.0-1 10.0.1-1
stylelint-config-standard 29.0.0-1 30.0.1-1
sway 1:1.8-3 1:1.8-5
tailscale 1.36.0-1 1.36.1-1
telegram-desktop 4.5.2-1 4.6.2-2
tellico 3.4.5-1 3.4.6-1
terraform 1.3.7-1 1.3.8-1
texstudio 4.4.1-2 4.5.1-2
tig 2.5.7-1 2.5.8-1
tigervnc 1.12.90-1 1.13.0-1
timescaledb 2.9.2-2 2.9.3-1
timescaledb-old-upgrade 2.9.2-3 2.9.3-1
tmux 3.3_a-2 3.3_a-3
translate-toolkit 3.7.4-2 3.8.3-1
trivy 0.37.1-1 0.37.2-1
ttc-iosevka 17.1.0-1 18.0.0-1
ttc-iosevka-aile 17.1.0-1 18.0.0-1
ttc-iosevka-curly 17.1.0-1 18.0.0-1
ttc-iosevka-curly-slab 17.1.0-1 18.0.0-1
ttc-iosevka-etoile 17.1.0-1 18.0.0-1
ttc-iosevka-slab 17.1.0-1 18.0.0-1
ttc-iosevka-ss01 17.1.0-1 18.0.0-1
ttc-iosevka-ss02 17.1.0-1 18.0.0-1
ttc-iosevka-ss03 17.1.0-1 18.0.0-1
ttc-iosevka-ss04 17.1.0-1 18.0.0-1
ttc-iosevka-ss05 17.1.0-1 18.0.0-1
ttc-iosevka-ss06 17.1.0-1 18.0.0-1
ttc-iosevka-ss07 17.1.0-1 18.0.0-1
ttc-iosevka-ss08 17.1.0-1 18.0.0-1
ttc-iosevka-ss09 17.1.0-1 18.0.0-1
ttc-iosevka-ss10 17.1.0-1 18.0.0-1
ttc-iosevka-ss11 17.1.0-1 18.0.0-1
ttc-iosevka-ss12 17.1.0-1 18.0.0-1
ttc-iosevka-ss13 17.1.0-1 18.0.0-1
ttc-iosevka-ss14 17.1.0-1 18.0.0-1
ttc-iosevka-ss15 17.1.0-1 18.0.0-1
ttc-iosevka-ss16 17.1.0-1 18.0.0-1
ttc-iosevka-ss17 17.1.0-1 18.0.0-1
ttc-iosevka-ss18 17.1.0-1 18.0.0-1
ttf-ionicons 6.1.1-1 6.1.3-1
ttf-sarasa-gothic 0.39.0-1 0.40.0-1
typescript-language-server 3.0.3-1 3.1.0-1
ulfius 2.7.12-1 2.7.13-1
unrealircd 6.0.5-3 6.0.6-1
v2ray-domain-list-community 20230201034244-1 20230210153419-1
v2ray-geoip 202301260045-1 202302090046-1
vscode-css-languageserver 1.74.0-1 1.75.0-1
vscode-html-languageserver 1.74.0-1 1.75.0-1
vscode-json-languageserver 1.74.0-1 1.75.0-1
vtk 9.1.0-25 9.1.0-26
wallabag 2.5.2-1 2.5.3-1
warpinator 1.4.3-1 1.4.4-1
waylock 0.3.5-1 0.6.2-1
wlroots 0.16.1-2 0.16.2-1
x11vnc 1:0.9.16-6 1:0.9.16-7
xdp-tools 1.2.9-1 1.3.0-1
xmldiff 2.4-4 2.5-1
xmrig 6.18.1-2 6.19.0-1
yodl 4.03.03-1 4.03.03-2
z3 4.11.2-1 4.12.0-1
zigbee2mqtt 1.29.2-1 1.30.1-1
zint 2.11.1-1 2.12.0-1
zint-qt 2.11.1-1 2.12.0-1
bingrep - 0.11.0-1
cargo-about - 0.5.4-1
gomuks - 0.3.0-2
openblas64 - 0.3.21-4
openpgp-ca - 0.12.0-1
openpgp-ca-restd - 0.12.0-1
opensnitch - 1.5.5-1
python-jupyter-packaging - 0.12.3-1
python-pyasn - 1.6.1-3
python-qt-material - 2.12.r4.g1f73d3d-2
soju - 0.5.2-2
zycore-c - 1.4.1-3
zydis - 4.0.0-3
:: Different overlay package(s) in repository core aarch64
linux 6.1.9-1 6.1.11-1
linux-clockworkpi-a06 6.1.9-1 6.1.11-1
linux-clockworkpi-a06-headers 6.1.9-1 6.1.11-1
linux-headers 6.1.9-1 6.1.11-1
linux-lts 5.15.85-1 6.1.11-1
linux-lts-headers 5.15.85-1 6.1.11-1
linux-pinephone 6.1.7-1 6.1.9-1
linux-pinephone-headers 6.1.7-1 6.1.9-1
linux-pinephonepro 6.1.7-1 6.1.9-1
linux-pinephonepro-headers 6.1.7-1 6.1.9-1
linux-rc 6.2.rc6-1 6.2.rc7-2
linux-rc-headers 6.2.rc6-1 6.2.rc7-2
linux-rpi4 5.15.91-1 5.15.92-1
linux-rpi4-headers 5.15.91-1 5.15.92-1
linux-rpi4-mainline 6.1.9-1 6.1.11-1
linux-rpi4-mainline-headers 6.1.9-1 6.1.11-1
linux-rpi4-rc 6.2.rc6-1 6.2.rc7-1
linux-rpi4-rc-headers 6.2.rc6-1 6.2.rc7-1
linux61 6.1.9-1 6.1.11-1
linux61-headers 6.1.9-1 6.1.11-1
raspberrypi-bootloader 20230130-1 20230208-1
raspberrypi-bootloader-x 20230130-1 20230208-1
uboot-clockworkpi-a06 2021.10-3 2023.01-1
uboot-nanopc-t4 2022.10-1 2023.01-1
uboot-orangepi4-lts 2022.04-1 2023.01-1
uboot-pinebookpro 1:2021.04-1 1:2023.01-1
uboot-roc-cc 2022.10-1 2023.01-1
uboot-rock64 2022.10-1 2023.01-1
uboot-rockpi4b 2022.10-1 2023.01-1
uboot-rockpi4c 2022.10-1 2023.01-1
uboot-rockpro64 2022.10-1 2023.01-1
uboot-tools 2022.10-1 2023.01-1
:: Different sync package(s) in repository core aarch64
bash 5.1.016-1 5.1.016-3
debuginfod 0.188-2 0.188-3
e2fsprogs 1.46.5-4 1.46.6-1
elfutils 0.188-2 0.188-3
fakeroot 1.30.1-1 1.31-1
fuse2fs 1.46.5-4 1.46.6-1
less 1:608-1 1:608-2
libelf 0.188-2 0.188-3
libnl 3.7.0-2 3.7.0-3
linux-api-headers 5.18.15-1 6.1.9-1
mpfr 4.2.0-2 4.2.0-3
openssh 9.1p1-3 9.2p1-1
openssl-1.1 1.1.1.s-4 1.1.1.t-1
openssl 3.0.7-4 3.0.8-1
sudo 1.9.12.p2-1 1.9.12.p2-2
texinfo 7.0.2-1 7.0.2-2
base-devel - 1-1
:: Different overlay package(s) in repository extra aarch64
elisa-qtmm 22.12.1-1 22.12.2-1
libva-mesa-driver 22.3.4-0.1 22.3.5-0.1
mesa 22.3.4-0.1 22.3.5-0.1
mesa-vdpau 22.3.4-0.1 22.3.5-0.1
okular 22.12.1-1 22.12.2-1
opencl-mesa 22.3.4-0.1 22.3.5-0.1
python-es2-pyqt5 5.15.7-3 5.15.8-1
qt5-es2-base 5.15.8+kde+r177-1 5.15.8+kde+r180-1
qt5-es2-xcb-private-headers 5.15.8+kde+r177-1 5.15.8+kde+r180-1
vulkan-broadcom 22.3.4-0.1 22.3.5-0.1
vulkan-mesa-layers 22.3.4-0.1 22.3.5-0.1
vulkan-panfrost 22.3.4-0.1 22.3.5-0.1
vulkan-radeon 22.3.4-0.1 22.3.5-0.1
vulkan-swrast 22.3.4-0.1 22.3.5-0.1
vulkan-virtio 22.3.4-0.1 22.3.5-0.1
:: Different sync package(s) in repository extra aarch64
akonadi 22.12.1-2 22.12.2-1
akonadi-calendar 22.12.1-1 22.12.2-1
akonadi-calendar-tools 22.12.1-1 22.12.2-1
akonadi-contacts 22.12.1-1 22.12.2-1
akonadi-import-wizard 22.12.1-1 22.12.2-1
akonadi-mime 22.12.1-1 22.12.2-1
akonadi-notes 22.12.1-1 22.12.2-1
akonadi-search 22.12.1-1 22.12.2-1
akonadiconsole 22.12.1-1 22.12.2-1
akregator 22.12.1-1 22.12.2-1
alsa-card-profiles 1:0.3.65-5 1:0.3.65-6
analitza 22.12.1-1 22.12.2-1
aom 3.5.0-1 3.6.0-1
aom-docs 3.5.0-1 3.6.0-1
appstream 0.16.0-1 0.16.1-1
appstream-qt 0.16.0-1 0.16.1-1
ark 22.12.1-1 22.12.2-1
artikulate 22.12.1-1 22.12.2-1
audiocd-kio 22.12.1-1 22.12.2-1
baloo-widgets 22.12.1-1 22.12.2-1
base-devel 1-1 -
blas 3.11.0-1 3.11.0-2
blinken 22.12.1-1 22.12.2-1
bomber 22.12.1-1 22.12.2-1
bovo 22.12.1-1 22.12.2-1
cairo 1.17.6-2 1.17.8-2
calendarsupport 22.12.1-1 22.12.2-1
cantor 22.12.1-1 22.12.2-1
cblas 3.11.0-1 3.11.0-2
cdrdao 1.2.4-2 1.2.5-1
cervisia 22.12.1-1 22.12.2-1
chromium 109.0.5414.119-1 110.0.5481.77-1
colord-kde 22.12.1-1 22.12.2-1
composer 2.5.1-1 2.5.2-1
cups 1:2.4.2-3 1:2.4.2-5
dbus-broker 32-1 33-1
dejagnu 1.6.3-4 1.6.3-5
discount 2.2.7.b-1 2.2.7.c-1
dnsmasq 2.88-1 2.89-1
dolphin 22.12.1-1 22.12.2-1
dolphin-plugins 22.12.1-1 22.12.2-1
dragon 22.12.1-1 22.12.2-1
elisa 22.12.1-1 22.12.2-1
eventviews 22.12.1-1 22.12.2-1
falkon 22.12.1-2 22.12.2-1
ffmpegthumbs 22.12.1-1 22.12.2-1
filelight 22.12.1-1 22.12.2-1
flatpak 1:1.15.1-1 1:1.15.2-1
flatpak-docs 1:1.15.1-1 1:1.15.2-1
fluidsynth 2.3.1-1 2.3.1-1.1
galera 26.4.13-2 26.4.14-1
ghex 43.0-1 43.1-1
ghex-docs 43.0-1 43.1-1
gnome-builder 43.4-4 43.6-1
gnome-contacts 43.0-1 43.1-1
gnome-shell 1:43.2-2 1:43.2-3
gnote 43.0-1 43.1-1
gnumeric 1.12.54-1 1.12.55-1
goffice 0.10.54-1 0.10.55-1
granatier 22.12.1-1 22.12.2-1
grantlee-editor 22.12.1-1 22.12.2-1
grantleetheme 22.12.1-1 22.12.2-1
gst-plugin-libcamera 0.0.3-4 0.0.4-1
gst-plugin-pipewire 1:0.3.65-5 1:0.3.65-6
gwenview 22.12.1-1 22.12.2-1
htop 3.2.1-1 3.2.2-1
imagemagick 7.1.0.60-1 7.1.0.61-1
incidenceeditor 22.12.1-1 22.12.2-1
itinerary 22.12.1-1 22.12.2-1
jack-example-tools 3-1 4-1
juk 22.12.1-1 22.12.2-1
k3b 1:22.12.1-1 1:22.12.2-1
kaccounts-integration 22.12.1-1 22.12.2-1
kaccounts-providers 22.12.1-1 22.12.2-1
kaddressbook 22.12.1-1 22.12.2-1
kajongg 22.12.1-1 22.12.2-1
kalarm 22.12.1-1 22.12.2-1
kalendar 22.12.1-1 22.12.2-1
kalgebra 22.12.1-1 22.12.2-1
kamera 22.12.1-1 22.12.2-1
kamoso 22.12.1-1 22.12.2-1
kanagram 22.12.1-1 22.12.2-1
kapman 22.12.1-1 22.12.2-1
kapptemplate 22.12.1-1 22.12.2-1
kate 22.12.1-1 22.12.2-1
katomic 22.12.1-1 22.12.2-1
kbackup 22.12.1-1 22.12.2-1
kblackbox 22.12.1-1 22.12.2-1
kblocks 22.12.1-1 22.12.2-1
kbounce 22.12.1-1 22.12.2-1
kbreakout 22.12.1-1 22.12.2-1
kbruch 22.12.1-1 22.12.2-1
kcachegrind 22.12.1-1 22.12.2-1
kcachegrind-common 22.12.1-1 22.12.2-1
kcalc 22.12.1-1 22.12.2-1
kcalutils 22.12.1-1 22.12.2-1
kcharselect 22.12.1-1 22.12.2-1
kcolorchooser 22.12.1-1 22.12.2-1
kcron 22.12.1-1 22.12.2-1
kde-dev-scripts 22.12.1-1 22.12.2-1
kde-dev-utils 22.12.1-1 22.12.2-1
kdebugsettings 22.12.1-1 22.12.2-1
kdeconnect 22.12.1-1 22.12.2-1
kdeedu-data 22.12.1-1 22.12.2-1
kdegraphics-mobipocket 22.12.1-1 22.12.2-1
kdegraphics-thumbnailers 22.12.1-1 22.12.2-1
kdenetwork-filesharing 22.12.1-1 22.12.2-1
kdenlive 22.12.1-2 22.12.2-1
kdepim-addons 22.12.1-1 22.12.2-1
kdepim-runtime 22.12.1-1 22.12.2-1
kdesdk-kio 22.12.1-1 22.12.2-1
kdesdk-thumbnailers 22.12.1-1 22.12.2-1
kdevelop 22.12.1-3 22.12.2-1
kdevelop-php 22.12.1-1 22.12.2-1
kdevelop-python 22.12.1-1 22.12.2-1
kdf 22.12.1-1 22.12.2-1
kdialog 22.12.1-1 22.12.2-1
kdiamond 22.12.1-1 22.12.2-1
keditbookmarks 22.12.1-1 22.12.2-1
kexec-tools 2.0.25-1 2.0.26-1
kfind 22.12.1-1 22.12.2-1
kfloppy 22.12.1-1 22.12.2-1
kfourinline 22.12.1-1 22.12.2-1
kgeography 22.12.1-1 22.12.2-1
kget 22.12.1-1 22.12.2-1
kgoldrunner 22.12.1-1 22.12.2-1
kgpg 22.12.1-1 22.12.2-1
khangman 22.12.1-1 22.12.2-1
khelpcenter 22.12.1-1 22.12.2-1
kidentitymanagement 22.12.1-1 22.12.2-1
kig 22.12.1-2 22.12.2-1
kigo 22.12.1-1 22.12.2-1
killbots 22.12.1-1 22.12.2-1
kimagemapeditor 22.12.1-1 22.12.2-1
kimap 22.12.1-1 22.12.2-1
kio-extras 22.12.1-1 22.12.2-1
kio-gdrive 22.12.1-1 22.12.2-1
kio-zeroconf 22.12.1-1 22.12.2-1
kirigami-gallery 22.12.1-1 22.12.2-1
kiriki 22.12.1-1 22.12.2-1
kiten 22.12.1-1 22.12.2-1
kitinerary 22.12.1-2 22.12.2-1
kjumpingcube 22.12.1-1 22.12.2-1
kldap 22.12.1-1 22.12.2-1
kleopatra 22.12.1-1 22.12.2-1
klettres 22.12.1-1 22.12.2-1
klickety 22.12.1-1 22.12.2-1
klines 22.12.1-1 22.12.2-1
kmag 22.12.1-1 22.12.2-1
kmahjongg 22.12.1-1 22.12.2-1
kmail 22.12.1-1 22.12.2-1
kmail-account-wizard 22.12.1-1 22.12.2-1
kmailtransport 22.12.1-1 22.12.2-1
kmbox 22.12.1-1 22.12.2-1
kmime 22.12.1-1 22.12.2-1
kmines 22.12.1-1 22.12.2-1
kmix 22.12.1-1 22.12.2-1
kmousetool 22.12.1-1 22.12.2-1
kmouth 22.12.1-1 22.12.2-1
kmplot 22.12.1-1 22.12.2-1
knavalbattle 22.12.1-1 22.12.2-1
knetwalk 22.12.1-1 22.12.2-1
knights 22.12.1-1 22.12.2-1
knotes 22.12.1-1 22.12.2-1
kolf 22.12.1-1 22.12.2-1
kollision 22.12.1-1 22.12.2-1
kolourpaint 22.12.1-1 22.12.2-1
kompare 22.12.1-1 22.12.2-1
konqueror 22.12.1-1 22.12.2-1
konquest 22.12.1-1 22.12.2-1
konsole 22.12.1-1 22.12.2-1
kontact 22.12.1-1 22.12.2-1
kontactinterface 22.12.1-1 22.12.2-1
kontrast 22.12.1-1 22.12.2-1
konversation 22.12.1-1 22.12.2-1
kopeninghours 22.12.1-2 22.12.2-1
kopete 22.12.1-1 22.12.2-1
korganizer 22.12.1-1 22.12.2-1
kosmindoormap 22.12.1-1 22.12.2-1
kpat 22.12.1-1 22.12.2-1
kpimtextedit 22.12.1-1 22.12.2-1
kpkpass 22.12.1-1 22.12.2-1
kpmcore 22.12.1-1 22.12.2-1
kpublictransport 22.12.1-1 22.12.2-1
kqtquickcharts 22.12.1-1 22.12.2-1
krdc 22.12.1-1 22.12.2-1
kreversi 22.12.1-1 22.12.2-1
krfb 22.12.1-1 22.12.2-1
kruler 22.12.1-1 22.12.2-1
ksanecore 22.12.1-1 22.12.2-1
kshisen 22.12.1-1 22.12.2-1
ksirk 22.12.1-1 22.12.2-1
ksmtp 22.12.1-1 22.12.2-1
ksnakeduel 22.12.1-1 22.12.2-1
kspaceduel 22.12.1-1 22.12.2-1
ksquares 22.12.1-1 22.12.2-1
ksudoku 22.12.1-1 22.12.2-1
ksystemlog 22.12.1-1 22.12.2-1
kteatime 22.12.1-1 22.12.2-1
ktimer 22.12.1-1 22.12.2-1
ktnef 22.12.1-1 22.12.2-1
ktorrent 22.12.1-1 22.12.2-1
ktouch 22.12.1-1 22.12.2-1
ktuberling 22.12.1-1 22.12.2-1
kturtle 22.12.1-1 22.12.2-1
kubrick 22.12.1-1 22.12.2-1
kwalletmanager 22.12.1-1 22.12.2-1
kwave 22.12.1-1 22.12.2-1
kwordquiz 22.12.1-1 22.12.2-1
lapack 3.11.0-1 3.11.0-2
lapack-doc 3.11.0-1 3.11.0-2
lapacke 3.11.0-1 3.11.0-2
libakonadi 22.12.1-2 22.12.2-1
libcamera-docs 0.0.3-4 0.0.4-1
libcamera-tools 0.0.3-4 0.0.4-1
libcups 1:2.4.2-3 1:2.4.2-5
libgphoto2 2.5.30-1 2.5.30-2
libgpod 0.8.3-13 0.8.3-14
libgravatar 22.12.1-1 22.12.2-1
libgusb 0.4.4-1 0.4.5-1
libimobiledevice 1.3.0-5 1.3.0-6
libkcddb 22.12.1-1 22.12.2-1
libkcompactdisc 22.12.1-1 22.12.2-1
libkdcraw 22.12.1-1 22.12.2-1
libkdegames 22.12.1-1 22.12.2-1
libkdepim 22.12.1-1 22.12.2-1
libkeduvocdocument 22.12.1-1 22.12.2-1
libkexiv2 22.12.1-1 22.12.2-1
libkgapi 22.12.1-1 22.12.2-1
libkleo 22.12.1-1 22.12.2-1
libkmahjongg 22.12.1-1 22.12.2-1
libkomparediff2 22.12.1-1 22.12.2-1
libksane 22.12.1-1 22.12.2-1
libksieve 22.12.1-1 22.12.2-1
libktorrent 22.12.1-1 22.12.2-1
libmspack 1:0.10.1alpha-4 1:0.11alpha-1
libreoffice-fresh 7.4.5-1 7.5.0-1
libreoffice-fresh-af 7.4.5-1 7.5.0-1
libreoffice-fresh-am 7.4.5-1 7.5.0-1
libreoffice-fresh-ar 7.4.5-1 7.5.0-1
libreoffice-fresh-as 7.4.5-1 7.5.0-1
libreoffice-fresh-ast 7.4.5-1 7.5.0-1
libreoffice-fresh-be 7.4.5-1 7.5.0-1
libreoffice-fresh-bg 7.4.5-1 7.5.0-1
libreoffice-fresh-bn 7.4.5-1 7.5.0-1
libreoffice-fresh-bn-in 7.4.5-1 7.5.0-1
libreoffice-fresh-bo 7.4.5-1 7.5.0-1
libreoffice-fresh-br 7.4.5-1 7.5.0-1
libreoffice-fresh-brx 7.4.5-1 7.5.0-1
libreoffice-fresh-bs 7.4.5-1 7.5.0-1
libreoffice-fresh-ca 7.4.5-1 7.5.0-1
libreoffice-fresh-ca-valencia 7.4.5-1 7.5.0-1
libreoffice-fresh-ckb 7.4.5-1 7.5.0-1
libreoffice-fresh-cs 7.4.5-1 7.5.0-1
libreoffice-fresh-cy 7.4.5-1 7.5.0-1
libreoffice-fresh-da 7.4.5-1 7.5.0-1
libreoffice-fresh-de 7.4.5-1 7.5.0-1
libreoffice-fresh-dgo 7.4.5-1 7.5.0-1
libreoffice-fresh-dsb 7.4.5-1 7.5.0-1
libreoffice-fresh-dz 7.4.5-1 7.5.0-1
libreoffice-fresh-el 7.4.5-1 7.5.0-1
libreoffice-fresh-en-gb 7.4.5-1 7.5.0-1
libreoffice-fresh-en-za 7.4.5-1 7.5.0-1
libreoffice-fresh-eo 7.4.5-1 7.5.0-1
libreoffice-fresh-es 7.4.5-1 7.5.0-1
libreoffice-fresh-et 7.4.5-1 7.5.0-1
libreoffice-fresh-eu 7.4.5-1 7.5.0-1
libreoffice-fresh-fa 7.4.5-1 7.5.0-1
libreoffice-fresh-fi 7.4.5-1 7.5.0-1
libreoffice-fresh-fr 7.4.5-1 7.5.0-1
libreoffice-fresh-fur 7.4.5-1 7.5.0-1
libreoffice-fresh-fy 7.4.5-1 7.5.0-1
libreoffice-fresh-ga 7.4.5-1 7.5.0-1
libreoffice-fresh-gd 7.4.5-1 7.5.0-1
libreoffice-fresh-gl 7.4.5-1 7.5.0-1
libreoffice-fresh-gu 7.4.5-1 7.5.0-1
libreoffice-fresh-gug 7.4.5-1 7.5.0-1
libreoffice-fresh-he 7.4.5-1 7.5.0-1
libreoffice-fresh-hi 7.4.5-1 7.5.0-1
libreoffice-fresh-hr 7.4.5-1 7.5.0-1
libreoffice-fresh-hsb 7.4.5-1 7.5.0-1
libreoffice-fresh-hu 7.4.5-1 7.5.0-1
libreoffice-fresh-id 7.4.5-1 7.5.0-1
libreoffice-fresh-is 7.4.5-1 7.5.0-1
libreoffice-fresh-it 7.4.5-1 7.5.0-1
libreoffice-fresh-ja 7.4.5-1 7.5.0-1
libreoffice-fresh-ka 7.4.5-1 7.5.0-1
libreoffice-fresh-kab 7.4.5-1 7.5.0-1
libreoffice-fresh-kk 7.4.5-1 7.5.0-1
libreoffice-fresh-km 7.4.5-1 7.5.0-1
libreoffice-fresh-kmr-latn 7.4.5-1 7.5.0-1
libreoffice-fresh-kn 7.4.5-1 7.5.0-1
libreoffice-fresh-ko 7.4.5-1 7.5.0-1
libreoffice-fresh-kok 7.4.5-1 7.5.0-1
libreoffice-fresh-ks 7.4.5-1 7.5.0-1
libreoffice-fresh-lb 7.4.5-1 7.5.0-1
libreoffice-fresh-lo 7.4.5-1 7.5.0-1
libreoffice-fresh-lt 7.4.5-1 7.5.0-1
libreoffice-fresh-lv 7.4.5-1 7.5.0-1
libreoffice-fresh-mai 7.4.5-1 7.5.0-1
libreoffice-fresh-mk 7.4.5-1 7.5.0-1
libreoffice-fresh-ml 7.4.5-1 7.5.0-1
libreoffice-fresh-mn 7.4.5-1 7.5.0-1
libreoffice-fresh-mni 7.4.5-1 7.5.0-1
libreoffice-fresh-mr 7.4.5-1 7.5.0-1
libreoffice-fresh-my 7.4.5-1 7.5.0-1
libreoffice-fresh-nb 7.4.5-1 7.5.0-1
libreoffice-fresh-ne 7.4.5-1 7.5.0-1
libreoffice-fresh-nl 7.4.5-1 7.5.0-1
libreoffice-fresh-nn 7.4.5-1 7.5.0-1
libreoffice-fresh-nr 7.4.5-1 7.5.0-1
libreoffice-fresh-nso 7.4.5-1 7.5.0-1
libreoffice-fresh-oc 7.4.5-1 7.5.0-1
libreoffice-fresh-om 7.4.5-1 7.5.0-1
libreoffice-fresh-or 7.4.5-1 7.5.0-1
libreoffice-fresh-pa-in 7.4.5-1 7.5.0-1
libreoffice-fresh-pl 7.4.5-1 7.5.0-1
libreoffice-fresh-pt 7.4.5-1 7.5.0-1
libreoffice-fresh-pt-br 7.4.5-1 7.5.0-1
libreoffice-fresh-ro 7.4.5-1 7.5.0-1
libreoffice-fresh-ru 7.4.5-1 7.5.0-1
libreoffice-fresh-rw 7.4.5-1 7.5.0-1
libreoffice-fresh-sa-in 7.4.5-1 7.5.0-1
libreoffice-fresh-sat 7.4.5-1 7.5.0-1
libreoffice-fresh-sd 7.4.5-1 7.5.0-1
libreoffice-fresh-sdk 7.4.5-1 7.5.0-1
libreoffice-fresh-si 7.4.5-1 7.5.0-1
libreoffice-fresh-sid 7.4.5-1 7.5.0-1
libreoffice-fresh-sk 7.4.5-1 7.5.0-1
libreoffice-fresh-sl 7.4.5-1 7.5.0-1
libreoffice-fresh-sq 7.4.5-1 7.5.0-1
libreoffice-fresh-sr 7.4.5-1 7.5.0-1
libreoffice-fresh-sr-latn 7.4.5-1 7.5.0-1
libreoffice-fresh-ss 7.4.5-1 7.5.0-1
libreoffice-fresh-st 7.4.5-1 7.5.0-1
libreoffice-fresh-sv 7.4.5-1 7.5.0-1
libreoffice-fresh-sw-tz 7.4.5-1 7.5.0-1
libreoffice-fresh-szl 7.4.5-1 7.5.0-1
libreoffice-fresh-ta 7.4.5-1 7.5.0-1
libreoffice-fresh-te 7.4.5-1 7.5.0-1
libreoffice-fresh-tg 7.4.5-1 7.5.0-1
libreoffice-fresh-th 7.4.5-1 7.5.0-1
libreoffice-fresh-tn 7.4.5-1 7.5.0-1
libreoffice-fresh-tr 7.4.5-1 7.5.0-1
libreoffice-fresh-ts 7.4.5-1 7.5.0-1
libreoffice-fresh-tt 7.4.5-1 7.5.0-1
libreoffice-fresh-ug 7.4.5-1 7.5.0-1
libreoffice-fresh-uk 7.4.5-1 7.5.0-1
libreoffice-fresh-uz 7.4.5-1 7.5.0-1
libreoffice-fresh-ve 7.4.5-1 7.5.0-1
libreoffice-fresh-vec 7.4.5-1 7.5.0-1
libreoffice-fresh-vi 7.4.5-1 7.5.0-1
libreoffice-fresh-xh 7.4.5-1 7.5.0-1
libreoffice-fresh-zh-cn 7.4.5-1 7.5.0-1
libreoffice-fresh-zh-tw 7.4.5-1 7.5.0-1
libreoffice-fresh-zu 7.4.5-1 7.5.0-1
libreoffice-still 7.3.7-3 7.4.5-1
libreoffice-still-af 7.3.7-1 7.4.5-1
libreoffice-still-am 7.3.7-1 7.4.5-1
libreoffice-still-ar 7.3.7-1 7.4.5-1
libreoffice-still-as 7.3.7-1 7.4.5-1
libreoffice-still-ast 7.3.7-1 7.4.5-1
libreoffice-still-be 7.3.7-1 7.4.5-1
libreoffice-still-bg 7.3.7-1 7.4.5-1
libreoffice-still-bn 7.3.7-1 7.4.5-1
libreoffice-still-bn-in 7.3.7-1 7.4.5-1
libreoffice-still-bo 7.3.7-1 7.4.5-1
libreoffice-still-br 7.3.7-1 7.4.5-1
libreoffice-still-brx 7.3.7-1 7.4.5-1
libreoffice-still-bs 7.3.7-1 7.4.5-1
libreoffice-still-ca 7.3.7-1 7.4.5-1
libreoffice-still-ca-valencia 7.3.7-1 7.4.5-1
libreoffice-still-ckb 7.3.7-1 7.4.5-1
libreoffice-still-cs 7.3.7-1 7.4.5-1
libreoffice-still-cy 7.3.7-1 7.4.5-1
libreoffice-still-da 7.3.7-1 7.4.5-1
libreoffice-still-de 7.3.7-1 7.4.5-1
libreoffice-still-dgo 7.3.7-1 7.4.5-1
libreoffice-still-dsb 7.3.7-1 7.4.5-1
libreoffice-still-dz 7.3.7-1 7.4.5-1
libreoffice-still-el 7.3.7-1 7.4.5-1
libreoffice-still-en-gb 7.3.7-1 7.4.5-1
libreoffice-still-en-za 7.3.7-1 7.4.5-1
libreoffice-still-eo 7.3.7-1 7.4.5-1
libreoffice-still-es 7.3.7-1 7.4.5-1
libreoffice-still-et 7.3.7-1 7.4.5-1
libreoffice-still-eu 7.3.7-1 7.4.5-1
libreoffice-still-fa 7.3.7-1 7.4.5-1
libreoffice-still-fi 7.3.7-1 7.4.5-1
libreoffice-still-fr 7.3.7-1 7.4.5-1
libreoffice-still-fur 7.3.7-1 7.4.5-1
libreoffice-still-fy 7.3.7-1 7.4.5-1
libreoffice-still-ga 7.3.7-1 7.4.5-1
libreoffice-still-gd 7.3.7-1 7.4.5-1
libreoffice-still-gl 7.3.7-1 7.4.5-1
libreoffice-still-gu 7.3.7-1 7.4.5-1
libreoffice-still-gug 7.3.7-1 7.4.5-1
libreoffice-still-he 7.3.7-1 7.4.5-1
libreoffice-still-hi 7.3.7-1 7.4.5-1
libreoffice-still-hr 7.3.7-1 7.4.5-1
libreoffice-still-hsb 7.3.7-1 7.4.5-1
libreoffice-still-hu 7.3.7-1 7.4.5-1
libreoffice-still-id 7.3.7-1 7.4.5-1
libreoffice-still-is 7.3.7-1 7.4.5-1
libreoffice-still-it 7.3.7-1 7.4.5-1
libreoffice-still-ja 7.3.7-1 7.4.5-1
libreoffice-still-ka 7.3.7-1 7.4.5-1
libreoffice-still-kab 7.3.7-1 7.4.5-1
libreoffice-still-kk 7.3.7-1 7.4.5-1
libreoffice-still-km 7.3.7-1 7.4.5-1
libreoffice-still-kmr-latn 7.3.7-1 7.4.5-1
libreoffice-still-kn 7.3.7-1 7.4.5-1
libreoffice-still-ko 7.3.7-1 7.4.5-1
libreoffice-still-kok 7.3.7-1 7.4.5-1
libreoffice-still-ks 7.3.7-1 7.4.5-1
libreoffice-still-lb 7.3.7-1 7.4.5-1
libreoffice-still-lo 7.3.7-1 7.4.5-1
libreoffice-still-lt 7.3.7-1 7.4.5-1
libreoffice-still-lv 7.3.7-1 7.4.5-1
libreoffice-still-mai 7.3.7-1 7.4.5-1
libreoffice-still-mk 7.3.7-1 7.4.5-1
libreoffice-still-ml 7.3.7-1 7.4.5-1
libreoffice-still-mn 7.3.7-1 7.4.5-1
libreoffice-still-mni 7.3.7-1 7.4.5-1
libreoffice-still-mr 7.3.7-1 7.4.5-1
libreoffice-still-my 7.3.7-1 7.4.5-1
libreoffice-still-nb 7.3.7-1 7.4.5-1
libreoffice-still-ne 7.3.7-1 7.4.5-1
libreoffice-still-nl 7.3.7-1 7.4.5-1
libreoffice-still-nn 7.3.7-1 7.4.5-1
libreoffice-still-nr 7.3.7-1 7.4.5-1
libreoffice-still-nso 7.3.7-1 7.4.5-1
libreoffice-still-oc 7.3.7-1 7.4.5-1
libreoffice-still-om 7.3.7-1 7.4.5-1
libreoffice-still-or 7.3.7-1 7.4.5-1
libreoffice-still-pa-in 7.3.7-1 7.4.5-1
libreoffice-still-pl 7.3.7-1 7.4.5-1
libreoffice-still-pt 7.3.7-1 7.4.5-1
libreoffice-still-pt-br 7.3.7-1 7.4.5-1
libreoffice-still-ro 7.3.7-1 7.4.5-1
libreoffice-still-ru 7.3.7-1 7.4.5-1
libreoffice-still-rw 7.3.7-1 7.4.5-1
libreoffice-still-sa-in 7.3.7-1 7.4.5-1
libreoffice-still-sat 7.3.7-1 7.4.5-1
libreoffice-still-sd 7.3.7-1 7.4.5-1
libreoffice-still-sdk 7.3.7-3 7.4.5-1
libreoffice-still-si 7.3.7-1 7.4.5-1
libreoffice-still-sid 7.3.7-1 7.4.5-1
libreoffice-still-sk 7.3.7-1 7.4.5-1
libreoffice-still-sl 7.3.7-1 7.4.5-1
libreoffice-still-sq 7.3.7-1 7.4.5-1
libreoffice-still-sr 7.3.7-1 7.4.5-1
libreoffice-still-sr-latn 7.3.7-1 7.4.5-1
libreoffice-still-ss 7.3.7-1 7.4.5-1
libreoffice-still-st 7.3.7-1 7.4.5-1
libreoffice-still-sv 7.3.7-1 7.4.5-1
libreoffice-still-sw-tz 7.3.7-1 7.4.5-1
libreoffice-still-szl 7.3.7-1 7.4.5-1
libreoffice-still-ta 7.3.7-1 7.4.5-1
libreoffice-still-te 7.3.7-1 7.4.5-1
libreoffice-still-tg 7.3.7-1 7.4.5-1
libreoffice-still-th 7.3.7-1 7.4.5-1
libreoffice-still-tn 7.3.7-1 7.4.5-1
libreoffice-still-tr 7.3.7-1 7.4.5-1
libreoffice-still-ts 7.3.7-1 7.4.5-1
libreoffice-still-tt 7.3.7-1 7.4.5-1
libreoffice-still-ug 7.3.7-1 7.4.5-1
libreoffice-still-uk 7.3.7-1 7.4.5-1
libreoffice-still-uz 7.3.7-1 7.4.5-1
libreoffice-still-ve 7.3.7-1 7.4.5-1
libreoffice-still-vec 7.3.7-1 7.4.5-1
libreoffice-still-vi 7.3.7-1 7.4.5-1
libreoffice-still-xh 7.3.7-1 7.4.5-1
libreoffice-still-zh-cn 7.3.7-1 7.4.5-1
libreoffice-still-zh-tw 7.3.7-1 7.4.5-1
libreoffice-still-zu 7.3.7-1 7.4.5-1
libsidplayfp 2.4.1-1 2.4.2-1
libsysprof-capture 3.46.0-3 3.46.0-4
libwpe 1.14.0-1 1.14.1-1
libxfce4ui 4.18.1-1 4.18.2-1
lldb 15.0.7-1 15.0.7-2
lmdb 0.9.29-1 0.9.30-2
lokalize 22.12.1-1 22.12.2-1
lskat 22.12.1-1 22.12.2-1
mailcommon 22.12.1-1 22.12.2-1
mailimporter 22.12.1-1 22.12.2-1
marble 22.12.1-2 22.12.2-1
marble-common 22.12.1-2 22.12.2-1
marble-maps 22.12.1-2 22.12.2-1
marble-qt 22.12.1-2 22.12.2-1
mariadb 10.9.4-2 10.9.5-1
mariadb-clients 10.9.4-2 10.9.5-1
mariadb-libs 10.9.4-2 10.9.5-1
markdownpart 22.12.1-1 22.12.2-1
mbox-importer 22.12.1-1 22.12.2-1
messagelib 22.12.1-1 22.12.2-1
minuet 22.12.1-1 22.12.2-1
mousepad 0.5.10-1 0.6.0-1
mytop 10.9.4-2 10.9.5-1
noto-fonts 20230117-3 20230201-1
noto-fonts-extra 20230117-3 20230201-1
openal 1.22.2-1 1.23.0-1
openal-examples 1.22.2-1 1.23.0-1
opencolorio 2.2.1-2 2.2.1-3
openpmix 4.2.2-1 4.2.3-1
palapeli 22.12.1-1 22.12.2-1
parley 22.12.1-1 22.12.2-1
partitionmanager 22.12.1-1 22.12.2-1
perl-html-parser 3.80-1 3.81-1
picmi 22.12.1-1 22.12.2-1
pim-data-exporter 22.12.1-1 22.12.2-1
pim-sieve-editor 22.12.1-1 22.12.2-1
pimcommon 22.12.1-1 22.12.2-1
pipewire-alsa 1:0.3.65-5 1:0.3.65-6
pipewire-audio 1:0.3.65-5 1:0.3.65-6
pipewire-docs 1:0.3.65-5 1:0.3.65-6
pipewire-jack 1:0.3.65-5 1:0.3.65-6
pipewire-pulse 1:0.3.65-5 1:0.3.65-6
pipewire-roc 1:0.3.65-5 1:0.3.65-6
pipewire-v4l2 1:0.3.65-5 1:0.3.65-6
pipewire-x11-bell 1:0.3.65-5 1:0.3.65-6
pipewire-zeroconf 1:0.3.65-5 1:0.3.65-6
poppler 23.01.0-3 23.02.0-1
poppler-data 0.4.11-3 0.4.12-1
poppler-glib 23.01.0-3 23.02.0-1
poppler-qt5 23.01.0-3 23.02.0-1
poppler-qt6 23.01.0-3 23.02.0-1
postgresql 15.1-1 15.1-3
postgresql-docs 15.1-1 15.1-3
postgresql-libs 15.1-1 15.1-3
poxml 22.12.1-1 22.12.2-1
print-manager 22.12.1-1 22.12.2-1
prometheus 2.41.0-1 2.42.0-1
python-cairo 1.23.0-2 1.23.0-3
python-cryptography 39.0.0-1 39.0.1-1
python-django 4.1.5-1 4.1.6-1
python-merge3 0.0.12-1 0.0.13-1
python-packaging 21.3-1 23.0-1
python-patiencediff 0.2.12-1 0.2.13-1
python-pyqt5 5.15.8-2 5.15.9-1
python-pyqt6 6.4.1-1 6.4.2-1
python-setuptools 1:65.6.3-1 1:67.2.0-1
python-trove-classifiers 2023.1.20-1 2023.2.8-1
qcachegrind 22.12.1-1 22.12.2-1
qt5-base 5.15.8+kde+r177-1 5.15.8+kde+r181-1
qt5-wayland 5.15.8+kde+r57-1 5.15.8+kde+r58-1
qt5-xcb-private-headers 5.15.8+kde+r177-1 5.15.8+kde+r181-1
re2 1:20221201-2 1:20230201-1
ristretto 0.12.4-1 0.13.0-1
rocs 22.12.1-1 22.12.2-1
rust 1:1.67.0-2 1:1.67.1-1
rust-src 1:1.67.0-2 1:1.67.1-1
sdl2 2.26.2-1 2.26.3-1
sdl2_image 2.6.2-4 2.6.3-1
sdl2_mixer 2.6.2-2 2.6.3-1
sdl2_ttf 2.20.1-1 2.20.2-1
signon-kwallet-extension 22.12.1-1 22.12.2-1
sip 6.7.6-1 6.7.7-1
skanlite 22.12.1-1 22.12.2-1
skanpage 22.12.1-1 22.12.2-1
spectacle 22.12.1-1 22.12.2-1
step 22.12.1-1 22.12.2-1
suitesparse 7.0.1-1 7.0.1-2
svgpart 22.12.1-1 22.12.2-1
sweeper 22.12.1-1 22.12.2-1
sysprof 3.46.0-3 3.46.0-4
telepathy-kde-accounts-kcm 22.12.1-1 22.12.2-1
telepathy-kde-approver 22.12.1-1 22.12.2-1
telepathy-kde-auth-handler 22.12.1-1 22.12.2-1
telepathy-kde-call-ui 22.12.1-1 22.12.2-1
telepathy-kde-common-internals 22.12.1-2 22.12.2-1
telepathy-kde-contact-list 22.12.1-1 22.12.2-1
telepathy-kde-contact-runner 22.12.1-1 22.12.2-1
telepathy-kde-desktop-applets 22.12.1-1 22.12.2-1
telepathy-kde-filetransfer-handler 22.12.1-1 22.12.2-1
telepathy-kde-integration-module 22.12.1-1 22.12.2-1
telepathy-kde-send-file 22.12.1-1 22.12.2-1
telepathy-kde-text-ui 22.12.1-1 22.12.2-1
thunar-media-tags-plugin 0.3.0-2 0.4.0-1
thunderbird 102.7.1-1 102.7.2-1
thunderbird-i18n-af 102.7.1-1 102.7.2-1
thunderbird-i18n-ar 102.7.1-1 102.7.2-1
thunderbird-i18n-ast 102.7.1-1 102.7.2-1
thunderbird-i18n-be 102.7.1-1 102.7.2-1
thunderbird-i18n-bg 102.7.1-1 102.7.2-1
thunderbird-i18n-br 102.7.1-1 102.7.2-1
thunderbird-i18n-ca 102.7.1-1 102.7.2-1
thunderbird-i18n-cak 102.7.1-1 102.7.2-1
thunderbird-i18n-cs 102.7.1-1 102.7.2-1
thunderbird-i18n-cy 102.7.1-1 102.7.2-1
thunderbird-i18n-da 102.7.1-1 102.7.2-1
thunderbird-i18n-de 102.7.1-1 102.7.2-1
thunderbird-i18n-dsb 102.7.1-1 102.7.2-1
thunderbird-i18n-el 102.7.1-1 102.7.2-1
thunderbird-i18n-en-gb 102.7.1-1 102.7.2-1
thunderbird-i18n-en-us 102.7.1-1 102.7.2-1
thunderbird-i18n-es-ar 102.7.1-1 102.7.2-1
thunderbird-i18n-es-es 102.7.1-1 102.7.2-1
thunderbird-i18n-et 102.7.1-1 102.7.2-1
thunderbird-i18n-eu 102.7.1-1 102.7.2-1
thunderbird-i18n-fi 102.7.1-1 102.7.2-1
thunderbird-i18n-fr 102.7.1-1 102.7.2-1
thunderbird-i18n-fy-nl 102.7.1-1 102.7.2-1
thunderbird-i18n-ga-ie 102.7.1-1 102.7.2-1
thunderbird-i18n-gd 102.7.1-1 102.7.2-1
thunderbird-i18n-gl 102.7.1-1 102.7.2-1
thunderbird-i18n-he 102.7.1-1 102.7.2-1
thunderbird-i18n-hr 102.7.1-1 102.7.2-1
thunderbird-i18n-hsb 102.7.1-1 102.7.2-1
thunderbird-i18n-hu 102.7.1-1 102.7.2-1
thunderbird-i18n-hy-am 102.7.1-1 102.7.2-1
thunderbird-i18n-id 102.7.1-1 102.7.2-1
thunderbird-i18n-is 102.7.1-1 102.7.2-1
thunderbird-i18n-it 102.7.1-1 102.7.2-1
thunderbird-i18n-ja 102.7.1-1 102.7.2-1
thunderbird-i18n-ka 102.7.1-1 102.7.2-1
thunderbird-i18n-kab 102.7.1-1 102.7.2-1
thunderbird-i18n-kk 102.7.1-1 102.7.2-1
thunderbird-i18n-ko 102.7.1-1 102.7.2-1
thunderbird-i18n-lt 102.7.1-1 102.7.2-1
thunderbird-i18n-ms 102.7.1-1 102.7.2-1
thunderbird-i18n-nb-no 102.7.1-1 102.7.2-1
thunderbird-i18n-nl 102.7.1-1 102.7.2-1
thunderbird-i18n-nn-no 102.7.1-1 102.7.2-1
thunderbird-i18n-pa-in 102.7.1-1 102.7.2-1
thunderbird-i18n-pl 102.7.1-1 102.7.2-1
thunderbird-i18n-pt-br 102.7.1-1 102.7.2-1
thunderbird-i18n-pt-pt 102.7.1-1 102.7.2-1
thunderbird-i18n-rm 102.7.1-1 102.7.2-1
thunderbird-i18n-ro 102.7.1-1 102.7.2-1
thunderbird-i18n-ru 102.7.1-1 102.7.2-1
thunderbird-i18n-sk 102.7.1-1 102.7.2-1
thunderbird-i18n-sl 102.7.1-1 102.7.2-1
thunderbird-i18n-sq 102.7.1-1 102.7.2-1
thunderbird-i18n-sr 102.7.1-1 102.7.2-1
thunderbird-i18n-sv-se 102.7.1-1 102.7.2-1
thunderbird-i18n-th 102.7.1-1 102.7.2-1
thunderbird-i18n-tr 102.7.1-1 102.7.2-1
thunderbird-i18n-uk 102.7.1-1 102.7.2-1
thunderbird-i18n-uz 102.7.1-1 102.7.2-1
thunderbird-i18n-vi 102.7.1-1 102.7.2-1
thunderbird-i18n-zh-cn 102.7.1-1 102.7.2-1
thunderbird-i18n-zh-tw 102.7.1-1 102.7.2-1
tomcat-native 2.0.2-1 2.0.3-1
umbrello 22.12.1-1 22.12.2-1
upower 1.90.0-2 1.90.0-3
webkit2gtk 2.38.3-1 2.38.4-1
webkit2gtk-4.1 2.38.3-1 2.38.4-1
webkit2gtk-4.1-docs 2.38.3-1 2.38.4-1
webkit2gtk-5.0 2.38.3-1 2.38.4-1
webkit2gtk-5.0-docs 2.38.3-1 2.38.4-1
webkit2gtk-docs 2.38.3-1 2.38.4-1
wpewebkit 2.38.3-1 2.38.4-1
wpewebkit-docs 2.38.3-1 2.38.4-1
wxwidgets-common 3.2.1-2 3.2.2-1
wxwidgets-gtk3 3.2.1-2 3.2.2-1
wxwidgets-qt5 3.2.1-2 3.2.2-1
xfce4-notifyd 0.7.2-1 0.7.3-1
xfce4-panel 4.18.1-1 4.18.2-1
xfce4-power-manager 4.18.0-1 4.18.1-1
xfce4-session 4.18.0-1 4.18.1-1
xorg-server 21.1.6-1 21.1.7-1
xorg-server-common 21.1.6-1 21.1.7-1
xorg-server-devel 21.1.6-1 21.1.7-1
xorg-server-xephyr 21.1.6-1 21.1.7-1
xorg-server-xnest 21.1.6-1 21.1.7-1
xorg-server-xvfb 21.1.6-1 21.1.7-1
xorg-xvidtune 1.0.3-5 1.0.4-1
xorg-xwayland 22.1.7-1 22.1.7-2
yakuake 22.12.1-1 22.12.2-1
zanshin 22.12.1-1 22.12.2-1
zsh 5.9-2 5.9-3
zsh-doc 5.9-2 5.9-3
zvbi 0.2.39-1 0.2.40-1
blas64 - 3.11.0-2
cairo-docs - 1.17.8-2
cblas64 - 3.11.0-2
lapack64 - 3.11.0-2
lapacke64 - 3.11.0-2
openpmix-docs - 4.2.3-1
suitesparse64 - 7.0.1-2
:: Different overlay package(s) in repository kde-unstable aarch64
analitza22.12.1.r2380.gf58a9099-122.12.2.r2382.gb66406cf-1
bluez-qt5.102.0.r741.ga7b5802-25.102.0.r742.g6bffe17-1
breeze-grub5.26.5.r11.g63136a9-15.26.5.r11.g63136a9-2
breeze-gtk5.26.5.r496.gbb7d086-15.26.5.r496.gbb7d086-2
breeze-icons5.102.0.r1955.gf3149c56-15.102.0.r1967.ge74b4a2b-1
cask-server r12.g6656c20-1 r14.g7a9096d-1
extra-cmake-modules5.102.0.r3552.g8fae102d-25.102.0.r3555.ged89a119-1
karchive5.102.0.r611.g7bf346e-15.102.0.r612.g3c179ae-1
kbookmarks5.102.0.r499.g62c4d23-15.102.0.r511.g563e17a-1
kcalendarcore5.102.0.r1369.g4af6c7006-25.102.0.r1370.gfdbaae498-1
kcodecs5.102.0.r477.g1c4825d-25.102.0.r478.g2b221bf-1
kcompletion5.102.0.r537.gec9fbb1-15.102.0.r551.g30ca81b-1
kconfig5.102.0.r1042.g107b9754-15.102.0.r1049.g64d21919-1
kconfigwidgets5.102.0.r846.g2f5d6a41-15.102.0.r863.g6b38832a-1
kcontacts1:5.102.0.r3390.g25971668-11:5.102.0.r3399.g839c9827-1
kcoreaddons5.102.0.r1669.g64aab147-15.102.0.r1677.g73ac1311-1
kdbusaddons5.102.0.r465.ge6ddfb6-15.102.0.r467.g455e1e3-1
kde-dev-scripts22.12.1.r4177.g88eafbe-122.12.2.r4177.g88eafbe-1
kded5.102.0.r498.gd0150b4-15.102.0.r499.gd9abab0-1
kdeedu-data22.12.1.r22.g793df3b-122.12.2.r22.g793df3b-1
kdegraphics-mobipocket22.12.1.r286.g8ef6dab-122.12.2.r286.g8ef6dab-1
kfilemetadata5.102.0.r923.ga4f69cd-15.102.0.r924.g995c9d0-1
kglobalaccel5.102.0.r630.gdff6e23-25.102.0.r635.g4bf729c-1
kguiaddons5.102.0.r540.g0553aca-15.102.0.r541.g0aa7ca5-1
kholidays1:5.102.0.r1104.gd5514c1-21:5.102.0.r1105.g9d961eb-1
kiconthemes5.102.0.r664.gb4ac654-15.102.0.r678.g4efd073-1
kimageformats5.102.0.r484.g21211cd-15.102.0.r489.g20cec27-1
knotifications5.102.0.r809.gfe6b64c-15.102.0.r811.gd0655e7-1
kpackage5.102.0.r819.ga553896-15.102.0.r822.g77e31fa-1
kpeople5.102.0.r1411.geb539dc-15.102.0.r1419.gce3d2f2-1
kqtquickcharts22.12.1.r78.g22ff9c9-122.12.2.r78.g22ff9c9-1
krunner5.102.0.r822.g0dbb7ec-15.102.0.r855.g3ac74f7-1
ksanecore r673.g9bb5b42-1 r679.g3b75b4c-1
kservice5.102.0.r1085.ga1fa142-15.102.0.r1093.g850529c-1
ktextwidgets5.102.0.r492.g6655177-15.102.0.r507.g59f216b-1
kunitconversion5.102.0.r478.gff579f9-15.102.0.r479.gaaba6a1-1
kwallet-pam5.26.5.r284.gaf3180a-15.26.5.r284.gaf3180a-2
kwayland5.102.0.r1202.g9ad5a21-15.102.0.r1215.gb1d2718-1
kwidgetsaddons5.102.0.r1043.g3d9d07dc-15.102.0.r1069.g0679c3b1-1
kwindowsystem5.102.0.r751.g7c26e2b-25.102.0.r763.gd3e2209-1
kxmlgui5.102.0.r988.g5856097e-15.102.0.r1003.g6f0c9c72-1
libkdcraw22.12.1.r1157.g79b80f6-122.12.2.r1157.g79b80f6-1
libkexiv222.12.1.r834.g9253280-122.12.2.r834.g9253280-1
plasma-workspace-wallpapers5.26.5.r409.gbdb2f46-15.26.5.r417.g0c0f448-1
prison5.102.0.r424.gd2b0244-25.102.0.r425.gd195b3a-1
sddm0.19.0.r172.g2d7f1f7-10.19.0.r185.gc42bb38-1
signon-kwallet-extension22.12.1.r84.g98ae2e2-122.12.2.r84.g98ae2e2-1
solid5.102.0.r850.g2600c7a-25.102.0.r851.g11b9657-1
sonnet5.102.0.r767.g884a994-15.102.0.r771.g4dc085f-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
