Hello ARM community.
Here’s another set up updates, mostly point releases in this one!
Some highlights:
- Most of our kernels got updated
- LibreOffice updated to 7.4.4
- PHP updated to 8.2.1
- Pipewire updated to 0.3.64
- Mesa updated to 22.3.3
- Certbot updated to 2.2.0
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
PHP 8.2 update and introduction of legacy branch
The php packages have been updated to the latest version 8.2. In addition to this, a new set of php-legacy packages have been introduced. These will follow the oldest but still actively supported PHP branch. This enables users to install the latest version but also introduces the option to use third party applications that might rely on an older version. Both branches will be kept up to date following our rolling release model. php and php-legacy can be installed at the same time as the latter uses a -legacy suffix for its binaries and configuration files.
In addition to this, the php7 packages have been removed as they reached end of life. The imap extension will no longer be provided as it relies on the c-client library which has been abandoned for many years.
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sun Jan 15 21:44:44 CET 2023)
- arm-testing community aarch64: 214 new and 209 removed package(s)
- arm-testing core aarch64: 23 new and 23 removed package(s)
- arm-testing extra aarch64: 220 new and 225 removed package(s)
- arm-testing kde-unstable aarch64: 315 new and 315 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2023-01-10 2023-01-15
electron 22.0.0-1 22.0.1-1
electron20 20.3.7-1 20.3.9-1
electron21 21.3.1-1 21.3.4-1
ffmpeg-m2m2_4.3+dev+7044+gd7ca8f8084-1 1:4.4-2
firmware-raspberrypi 20221219-1 20230112-1
kodi-rk 20.0b1-1 20.0b1-2
kodi-rk-dev 20.0b1-1 20.0b1-2
kodi-rk-eventclients 20.0b1-1 20.0b1-2
kodi-rk-tools-texturepacker 20.0b1-1 20.0b1-2
mpv-rk 1:0.35.0-3 -
phosh-tour 0.21.0-1 0.23.0-1
python-tinydb 4.7.0-1 4.7.1-1
waydroid-image 18.1_20221210-1 18.1_20230114-1
kodi-aml - 20.0b1-3
kodi-aml-dev - 20.0b1-3
kodi-aml-eventclients - 20.0b1-3
kodi-aml-tools-texturepacker - 20.0b1-3
mpv-hwdec - 1:0.35.0-6
:: Different sync package(s) in repository community aarch64
abletonlink 3.0.5-1 3.0.6-1
adriconf 2.5.0-1 2.5.1-1
apptainer 1.1.4-2 1.1.5-1
arch-repro-status 1.3.3-1 1.3.4-1
argocd 2.5.5-1 2.5.6-1
bacon 2.3.0-1 2.4.0-1
bash-language-server 4.2.5-1 4.4.0-2
bzip3 1.2.1-1 1.2.2-1
cargo-deny 0.13.5-1 0.13.7-1
cargo-flamegraph 0.5.1-1 0.6.2-1
cargo-nextest 0.9.48-1 0.9.49-1
cargo-release 0.24.3-1 0.24.4-1
cargo-watch 8.2.1-1 8.3.0-1
certbot 2.1.0-1 2.2.0-1
certbot-apache 2.1.0-1 2.2.0-1
certbot-dns-cloudflare 2.1.0-1 2.2.0-1
certbot-dns-digitalocean 2.1.0-1 2.2.0-1
certbot-dns-dnsimple 2.1.0-1 2.2.0-1
certbot-dns-dnsmadeeasy 2.1.0-1 2.2.0-1
certbot-dns-gehirn 2.1.0-1 2.2.0-1
certbot-dns-google 2.1.0-1 2.2.0-1
certbot-dns-linode 2.1.0-1 2.2.0-1
certbot-dns-luadns 2.1.0-1 2.2.0-1
certbot-dns-nsone 2.1.0-1 2.2.0-1
certbot-dns-ovh 2.1.0-1 2.2.0-1
certbot-dns-rfc2136 2.1.0-1 2.2.0-1
certbot-dns-route53 2.1.0-1 2.2.0-1
certbot-dns-sakuracloud 2.1.0-1 2.2.0-1
certbot-nginx 2.1.0-1 2.2.0-1
cinnamon 5.6.5-1 5.6.6-1
cockpit 282.1-1 283-1
cockpit-machines 280-1 281-1
cockpit-packagekit 282.1-1 283-1
cockpit-pcp 282.1-1 283-1
cockpit-storaged 282.1-1 283-1
converseen 0.9.9.8-1 0.9.10.0-1
dagger 0.3.7-1 0.3.9-1
diffoscope 231-1 232-1
dtkcommon 5.5.23-1 5.6.3-1
editorconfig-checker 2.6.0-1 2.7.0-1
espup 0.2.4-1 0.2.6-1
feathernotes 1.0.0-1 1.1.0-1
fragments 2.0.2-2 2.1-1
gajim 1.6.0-1 1.6.1-1
git-warp-time 0.4.8-1 0.4.9-1
gitlab-runner 15.7.1-1 15.7.2-1
globalprotect-openconnect 1.4.8-1 1.4.9-1
gnuradio 3.10.4.0-2 3.10.5.0-1
gnuradio-companion 3.10.4.0-2 3.10.5.0-1
go 2:1.19.4-1 2:1.19.5-1
go-yq 4.30.6-1 4.30.8-1
gpg-tui 0.9.2-1 0.9.3-1
gping 1.6.3-1 1.7.0-1
gpsd 3.24-1 3.25-1
gpxsee 11.10-1 11.11-1
grpc 1.51.1-2 1.51.1-3
grpc-cli 1.51.1-2 1.51.1-3
gum 0.8.0-1 0.9.0-1
helix 22.12-1 22.12-2
i2pd 2.45.0-1 2.45.1-1
i3-wm 4.22-2 4.22-3
jc 1.22.4-1 1.22.5-1
jenkins 2.385-1 2.386-1
jupyter-nbformat 5.7.1-1 5.7.3-1
jupyter-server 2.0.6-1 2.1.0-1
kid3 3.9.2-2 3.9.3-1
kid3-common 3.9.2-2 3.9.3-1
kid3-qt 3.9.2-2 3.9.3-1
libfilezilla 1:0.40.0-1 1:0.41.0-1
libva-utils 2.17.0-1 2.17.1-1
liquidctl 1.11.1-1 1.12.0-1
lxd 5.9-2 5.10-1
maturin 0.14.8-1 0.14.10-1
merkaartor 0.19.0-4 0.19.0-5
metacity 3.46.0-1 3.46.1-1
mididings 20221230-1 20230114-1
mididings-docs 20221230-1 20230114-1
minidlna 1.3.2-2 1.3.2-2.1
navit 0.5.6-4 0.5.6-5
newsflash 2.2.2-1 2.2.4-1
nextcloud 25.0.2-1 25.0.2-4
nextcloud-app-bookmarks 1:12.0.0-1 1:12.0.0-2
nextcloud-app-calendar 1:4.1.2-1 1:4.2.1-1
nextcloud-app-contacts 5.0.2-1 5.0.2-2
nextcloud-app-mail 2.2.1-1 2.2.2-1
nextcloud-app-news 20.0.0-1 20.0.0-2
nextcloud-app-notes 4.6.0-1 4.6.0-2
nushell 0.73.0-1 0.74.0-1
osv-scanner 1.0.2-1 1.1.0-1
patchelf 0.17.0-1 0.17.2-1
pd-lua 0.10.2-1 0.11.2-1
perl-email-address 1.912-2 1.913-1
perl-email-mime 1.952-1 1.953-1
perl-email-mime-contenttype 1.027-1 1.028-1
perl-email-simple 2.216-2 2.218-1
perl-finance-quote 1.54-1 1.5400-1
perl-params-validationcompiler 0.30-5 0.31-1
perl-test-deep 1.202-1 1.204-1
pgformatter 5.3-1 5.4-1
php-geoip 1.1.1-8 1.1.1-9
php-grpc 1.51.1-2 1.51.1-3
php-igbinary 3.2.12-1 3.2.12-2
php-imagick 3.7.0-2 3.7.0-3
php-memcache 8.0-3 8.0-4
php-memcached 3.2.0-1 3.2.0-2
php-mongodb 1.15.0-1 1.15.0-2
php-redis 5.3.7-1 5.3.7-2
php-snuffleupagus 0.9.0-1 0.9.0-2
php7-geoip 1.1.1-8 -
php7-grpc 1.51.1-2 -
php7-igbinary 3.2.12-1 -
php7-imagick 3.7.0-2 -
php7-memcache 8.0-3 -
php7-memcached 3.2.0-1 -
php7-mongodb 1.15.0-1 -
php7-redis 5.3.7-1 -
plantuml-server 1.2022.14-1 1.2023.0-1
prettier 2.8.2-1 2.8.3-1
puzzles 20230101-1 20230110-1
pyenv 2.3.9-1 2.3.10-1
pyright 1.1.287-1 1.1.289-1
python-acme 2.1.0-1 2.2.0-1
python-build 0.9.0-1 0.10.0-1
python-contourpy 1.0.6-1 1.0.7-1
python-esbonio 0.15.0-3 0.15.0-4
python-faker 13.13.1-1 13.14.0-1
python-fastapi 0.89.0-1 0.89.1-1
python-fpylll 0.5.8-2 0.5.9-1
python-gdstk 0.9.14-1 0.9.15-1
python-googleapis-common-protos 1.57.0-1 1.58.0-1
python-grpcio 1.51.1-2 1.51.1-3
python-grpcio-tools 1.51.1-2 1.51.1-3
python-hypothesis-auto 1.1.4-6 1.1.4-7
python-identify 2.5.12-1 2.5.13-1
python-importlib-metadata 5.0.0-1 5.0.0-2
python-jupyter-events 0.6.0-1 0.6.3-1
python-jupyter_client 7.4.8-1 7.4.9-1
python-lsprotocol 2022.0.0a9-1 2022.0.0a10-1
python-manuel 1.12.4-1 1.12.4-2
python-memory-profiler 0.61-1 0.61-2
python-mitmproxy-wireguard 0.1.19-1 0.1.20-1
python-nbval 0.9.6-4 0.10.0-1
python-nbxmpp 4.0.0-1 4.0.1-1
python-openapi-schema-validator 0.3.4-2 0.4.0-1
python-orjson 3.8.4-1 3.8.5-1
python-pbr 5.11.0-2 5.11.1-1
python-poetry 1.3.1-3 1.3.2-1
python-pook 1.0.2-3 1.1.1-1
python-pyproject2setuppy 22-1 -
python-pysol_cards 0.14.2-3 0.14.3-1
python-pytest 7.2.0-4 7.2.1-1
python-pytest-lsp 0.1.3-1 0.2.1-1
python-pytest-pylint 0.19.0-1 0.19.0-2
python-pytest-rerunfailures 10.3-1 11.0-1
python-pytest-socket 0.5.1-1 0.5.1-2
python-pytz 2022.6-1 2022.7-1
python-rich 13.0.1-1 13.1.0-1
python-sphinx-alabaster-theme 0.7.12-9 0.7.13-1
python-sqlalchemy-migrate 0.13.0-9 0.13.0-10
python-toposort 1.7-3 1.9-1
python-xcffib 1.0.0-1 1.1.0-1
python-xkbcommon 0.4-3 0.8-1
restic 0.14.0-1 0.15.0-1
rng-tools 6.15-2 6.16-1
ruff 0.0.217-1 0.0.221-1
s2n-tls 1.3.31-1 1.3.32-1
step-cli 0.23.0-1 0.23.1-1
strawberry 1.0.13-1 1.0.14-1
toml-bombadil 3.1.0-1 3.1.0-2
tor 0.4.7.12-1 0.4.7.13-1
ttf-jetbrains-mono 2.242-2 2.304-1
typescript-language-server 3.0.1-1 3.0.2-1
typos 1.13.6-1 1.13.7-1
unbound 1.17.0-3 1.17.1-1
uwsgi 2.0.21-2 2.0.21-3
uwsgi-plugin-cgi 2.0.21-2 2.0.21-3
uwsgi-plugin-lua51 2.0.21-2 2.0.21-3
uwsgi-plugin-notfound 2.0.21-2 2.0.21-3
uwsgi-plugin-php 2.0.21-2 2.0.21-3
uwsgi-plugin-php7 2.0.21-2 -
uwsgi-plugin-psgi 2.0.21-2 2.0.21-3
uwsgi-plugin-python 2.0.21-2 2.0.21-3
uwsgi-plugin-rack 2.0.21-2 2.0.21-3
uwsgi-plugin-webdav 2.0.21-2 2.0.21-3
uwsgi-plugin-zabbix 2.0.21-2 2.0.21-3
v2ray-domain-list-community 20230109145423-1 20230112070720-1
v2ray-geoip 202301050046-1 202301120046-1
vaultwarden-web 2022.12.0-1 2023.1.0-1
viking 1.10-1 1.10-2
warpinator 1.4.2-2 1.4.3-1
waybar 0.9.16-2 0.9.17-1
xdebug 3.1.5-1 3.2.0-1
xine-ui 0.99.13-2 0.99.14-1
xplr 0.20.1-1 0.20.2-1
xreader 3.6.2-2 3.6.3-1
yamllint 1.28.0-1 1.29.0-1
php-legacy-geoip - 1.1.1-9
php-legacy-grpc - 1.51.1-3
php-legacy-igbinary - 3.2.12-2
php-legacy-imagick - 3.7.0-3
php-legacy-memcache - 8.0-4
php-legacy-memcached - 3.2.0-2
php-legacy-mongodb - 1.15.0-2
php-legacy-redis - 5.3.7-2
python-flit-core - 3.8.0-3
python-pep517 - 0.13.0-1
uwsgi-plugin-php-legacy - 2.0.21-3
:: Different overlay package(s) in repository core aarch64
linux 6.1.4-3 6.1.6-2
linux-aml 6.0.17-1 6.1.5-1
linux-aml-headers 6.0.17-1 6.1.5-1
linux-clockworkpi-a06 6.1.4-1 6.1.6-1
linux-clockworkpi-a06-headers 6.1.4-1 6.1.6-1
linux-headers 6.1.4-3 6.1.6-2
linux-odroid 6.0.16-1 6.1.4-1
linux-odroid-headers 6.0.16-1 6.1.4-1
linux-rc 6.2.rc3-3 6.2.rc4-1
linux-rc-headers 6.2.rc3-3 6.2.rc4-1
linux-rpi4-mainline 6.1.4-1 6.1.5-1
linux-rpi4-mainline-headers 6.1.4-1 6.1.5-1
linux60 6.0.18-1 6.0.19-1
linux60-headers 6.0.18-1 6.0.19-1
linux61 6.1.4-1 6.1.6-2
linux61-headers 6.1.4-1 6.1.6-2
raspberrypi-bootloader 20230105-1 20230113-1
raspberrypi-bootloader-x 20230105-1 20230113-1
:: Different sync package(s) in repository core aarch64
audit 3.0.8-1 3.0.9-1
nilfs-utils 2.2.9-1 2.2.9-2
python-audit 3.0.8-1 3.0.9-1
traceroute 2.1.0-5 2.1.1-1
xz 5.4.0-1 5.4.1-1
:: Different overlay package(s) in repository extra aarch64
calamares-arm-oem 20221003-1 20230112-1
libva-mesa-driver 22.3.2-0.4 22.3.3-0.1
mesa 22.3.2-0.4 22.3.3-0.1
mesa-vdpau 22.3.2-0.4 22.3.3-0.1
opencl-mesa 22.3.2-0.4 22.3.3-0.1
vulkan-broadcom 22.3.2-0.4 22.3.3-0.1
vulkan-mesa-layers 22.3.2-0.4 22.3.3-0.1
vulkan-panfrost 22.3.2-0.4 22.3.3-0.1
vulkan-radeon 22.3.2-0.4 22.3.3-0.1
vulkan-swrast 22.3.2-0.4 22.3.3-0.1
vulkan-virtio 22.3.2-0.4 22.3.3-0.1
:: Different sync package(s) in repository extra aarch64
alsa-card-profiles 1:0.3.63-5 1:0.3.64-1
chromium 108.0.5359.124-1 109.0.5414.74-1
conky 1.15.0-1 1.17.0-1
deluge 1:2.1.1-1 1:2.1.1-2
deluge-gtk 1:2.1.1-1 1:2.1.1-2
devtools 20221012-2 20230105-1
ethtool 1:6.0-2 1:6.1-1
fmt 9.1.0-3 9.1.0-4
gnome-nibbles 3.38.2-13.38.2+r53+g8de2599-1
gnome-taquin 3.38.1-13.38.1+r35+g35edb95-1
gnome-text-editor 43.1-1 43.2-1
gst-plugin-pipewire 1:0.3.63-5 1:0.3.64-1
gtksourceview5 5.6.1-1 5.6.2-1
gtksourceview5-docs 5.6.1-1 5.6.2-1
gvim 9.0.1046-1 9.0.1182-1
hwdetect 2022.11-1 2023.01-1
iagno 3.38.1-13.38.1+r57+gd147e1a-1
kdenlive 22.12.1-1 22.12.1-2
kdevelop-pg-qt 2.2.1-1 2.2.2-1
kdiff3 1.10.0-1 1.10.0-2
libpst 0.6.76-8 0.6.76-9
libpst-docs 0.6.76-8 0.6.76-9
libraqm 0.9.0-1 0.10.0-1
libreoffice-fresh 7.4.3-4 7.4.4-1
libreoffice-fresh-af 7.4.3-1 7.4.4-1
libreoffice-fresh-am 7.4.3-1 7.4.4-1
libreoffice-fresh-ar 7.4.3-1 7.4.4-1
libreoffice-fresh-as 7.4.3-1 7.4.4-1
libreoffice-fresh-ast 7.4.3-1 7.4.4-1
libreoffice-fresh-be 7.4.3-1 7.4.4-1
libreoffice-fresh-bg 7.4.3-1 7.4.4-1
libreoffice-fresh-bn 7.4.3-1 7.4.4-1
libreoffice-fresh-bn-in 7.4.3-1 7.4.4-1
libreoffice-fresh-bo 7.4.3-1 7.4.4-1
libreoffice-fresh-br 7.4.3-1 7.4.4-1
libreoffice-fresh-brx 7.4.3-1 7.4.4-1
libreoffice-fresh-bs 7.4.3-1 7.4.4-1
libreoffice-fresh-ca 7.4.3-1 7.4.4-1
libreoffice-fresh-ca-valencia 7.4.3-1 7.4.4-1
libreoffice-fresh-ckb 7.4.3-1 7.4.4-1
libreoffice-fresh-cs 7.4.3-1 7.4.4-1
libreoffice-fresh-cy 7.4.3-1 7.4.4-1
libreoffice-fresh-da 7.4.3-1 7.4.4-1
libreoffice-fresh-de 7.4.3-1 7.4.4-1
libreoffice-fresh-dgo 7.4.3-1 7.4.4-1
libreoffice-fresh-dsb 7.4.3-1 7.4.4-1
libreoffice-fresh-dz 7.4.3-1 7.4.4-1
libreoffice-fresh-el 7.4.3-1 7.4.4-1
libreoffice-fresh-en-gb 7.4.3-1 7.4.4-1
libreoffice-fresh-en-za 7.4.3-1 7.4.4-1
libreoffice-fresh-eo 7.4.3-1 7.4.4-1
libreoffice-fresh-es 7.4.3-1 7.4.4-1
libreoffice-fresh-et 7.4.3-1 7.4.4-1
libreoffice-fresh-eu 7.4.3-1 7.4.4-1
libreoffice-fresh-fa 7.4.3-1 7.4.4-1
libreoffice-fresh-fi 7.4.3-1 7.4.4-1
libreoffice-fresh-fr 7.4.3-1 7.4.4-1
libreoffice-fresh-fur 7.4.3-1 7.4.4-1
libreoffice-fresh-fy 7.4.3-1 7.4.4-1
libreoffice-fresh-ga 7.4.3-1 7.4.4-1
libreoffice-fresh-gd 7.4.3-1 7.4.4-1
libreoffice-fresh-gl 7.4.3-1 7.4.4-1
libreoffice-fresh-gu 7.4.3-1 7.4.4-1
libreoffice-fresh-gug 7.4.3-1 7.4.4-1
libreoffice-fresh-he 7.4.3-1 7.4.4-1
libreoffice-fresh-hi 7.4.3-1 7.4.4-1
libreoffice-fresh-hr 7.4.3-1 7.4.4-1
libreoffice-fresh-hsb 7.4.3-1 7.4.4-1
libreoffice-fresh-hu 7.4.3-1 7.4.4-1
libreoffice-fresh-id 7.4.3-1 7.4.4-1
libreoffice-fresh-is 7.4.3-1 7.4.4-1
libreoffice-fresh-it 7.4.3-1 7.4.4-1
libreoffice-fresh-ja 7.4.3-1 7.4.4-1
libreoffice-fresh-ka 7.4.3-1 7.4.4-1
libreoffice-fresh-kab 7.4.3-1 7.4.4-1
libreoffice-fresh-kk 7.4.3-1 7.4.4-1
libreoffice-fresh-km 7.4.3-1 7.4.4-1
libreoffice-fresh-kmr-latn 7.4.3-1 7.4.4-1
libreoffice-fresh-kn 7.4.3-1 7.4.4-1
libreoffice-fresh-ko 7.4.3-1 7.4.4-1
libreoffice-fresh-kok 7.4.3-1 7.4.4-1
libreoffice-fresh-ks 7.4.3-1 7.4.4-1
libreoffice-fresh-lb 7.4.3-1 7.4.4-1
libreoffice-fresh-lo 7.4.3-1 7.4.4-1
libreoffice-fresh-lt 7.4.3-1 7.4.4-1
libreoffice-fresh-lv 7.4.3-1 7.4.4-1
libreoffice-fresh-mai 7.4.3-1 7.4.4-1
libreoffice-fresh-mk 7.4.3-1 7.4.4-1
libreoffice-fresh-ml 7.4.3-1 7.4.4-1
libreoffice-fresh-mn 7.4.3-1 7.4.4-1
libreoffice-fresh-mni 7.4.3-1 7.4.4-1
libreoffice-fresh-mr 7.4.3-1 7.4.4-1
libreoffice-fresh-my 7.4.3-1 7.4.4-1
libreoffice-fresh-nb 7.4.3-1 7.4.4-1
libreoffice-fresh-ne 7.4.3-1 7.4.4-1
libreoffice-fresh-nl 7.4.3-1 7.4.4-1
libreoffice-fresh-nn 7.4.3-1 7.4.4-1
libreoffice-fresh-nr 7.4.3-1 7.4.4-1
libreoffice-fresh-nso 7.4.3-1 7.4.4-1
libreoffice-fresh-oc 7.4.3-1 7.4.4-1
libreoffice-fresh-om 7.4.3-1 7.4.4-1
libreoffice-fresh-or 7.4.3-1 7.4.4-1
libreoffice-fresh-pa-in 7.4.3-1 7.4.4-1
libreoffice-fresh-pl 7.4.3-1 7.4.4-1
libreoffice-fresh-pt 7.4.3-1 7.4.4-1
libreoffice-fresh-pt-br 7.4.3-1 7.4.4-1
libreoffice-fresh-ro 7.4.3-1 7.4.4-1
libreoffice-fresh-ru 7.4.3-1 7.4.4-1
libreoffice-fresh-rw 7.4.3-1 7.4.4-1
libreoffice-fresh-sa-in 7.4.3-1 7.4.4-1
libreoffice-fresh-sat 7.4.3-1 7.4.4-1
libreoffice-fresh-sd 7.4.3-1 7.4.4-1
libreoffice-fresh-sdk 7.4.3-4 7.4.4-1
libreoffice-fresh-si 7.4.3-1 7.4.4-1
libreoffice-fresh-sid 7.4.3-1 7.4.4-1
libreoffice-fresh-sk 7.4.3-1 7.4.4-1
libreoffice-fresh-sl 7.4.3-1 7.4.4-1
libreoffice-fresh-sq 7.4.3-1 7.4.4-1
libreoffice-fresh-sr 7.4.3-1 7.4.4-1
libreoffice-fresh-sr-latn 7.4.3-1 7.4.4-1
libreoffice-fresh-ss 7.4.3-1 7.4.4-1
libreoffice-fresh-st 7.4.3-1 7.4.4-1
libreoffice-fresh-sv 7.4.3-1 7.4.4-1
libreoffice-fresh-sw-tz 7.4.3-1 7.4.4-1
libreoffice-fresh-szl 7.4.3-1 7.4.4-1
libreoffice-fresh-ta 7.4.3-1 7.4.4-1
libreoffice-fresh-te 7.4.3-1 7.4.4-1
libreoffice-fresh-tg 7.4.3-1 7.4.4-1
libreoffice-fresh-th 7.4.3-1 7.4.4-1
libreoffice-fresh-tn 7.4.3-1 7.4.4-1
libreoffice-fresh-tr 7.4.3-1 7.4.4-1
libreoffice-fresh-ts 7.4.3-1 7.4.4-1
libreoffice-fresh-tt 7.4.3-1 7.4.4-1
libreoffice-fresh-ug 7.4.3-1 7.4.4-1
libreoffice-fresh-uk 7.4.3-1 7.4.4-1
libreoffice-fresh-uz 7.4.3-1 7.4.4-1
libreoffice-fresh-ve 7.4.3-1 7.4.4-1
libreoffice-fresh-vec 7.4.3-1 7.4.4-1
libreoffice-fresh-vi 7.4.3-1 7.4.4-1
libreoffice-fresh-xh 7.4.3-1 7.4.4-1
libreoffice-fresh-zh-cn 7.4.3-1 7.4.4-1
libreoffice-fresh-zh-tw 7.4.3-1 7.4.4-1
libreoffice-fresh-zu 7.4.3-1 7.4.4-1
libwebp 1.2.4-2 1.3.0-2
libxfce4util 4.18.0-1 4.18.1-1
marble 22.12.1-1 22.12.1-2
marble-common 22.12.1-1 22.12.1-2
marble-maps 22.12.1-1 22.12.1-2
marble-qt 22.12.1-1 22.12.1-2
php 8.1.13-4 8.2.1-1
php-apache 8.1.13-4 8.2.1-1
php-apcu 5.1.22-2 5.1.22-3
php-cgi 8.1.13-4 8.2.1-1
php-dblib 8.1.13-4 8.2.1-1
php-embed 8.1.13-4 8.2.1-1
php-enchant 8.1.13-4 8.2.1-1
php-fpm 8.1.13-4 8.2.1-1
php-gd 8.1.13-4 8.2.1-1
php-imap 8.1.13-4 -
php-intl 8.1.13-4 -
php-odbc 8.1.13-4 8.2.1-1
php-pgsql 8.1.13-4 8.2.1-1
php-phpdbg 8.1.13-4 8.2.1-1
php-pspell 8.1.13-4 8.2.1-1
php-snmp 8.1.13-4 8.2.1-1
php-sodium 8.1.13-4 8.2.1-1
php-sqlite 8.1.13-4 8.2.1-1
php-tidy 8.1.13-4 8.2.1-1
php-xsl 8.1.13-4 8.2.1-1
php7 7.4.33-4 -
php7-apache 7.4.33-4 -
php7-apcu 5.1.22-2 -
php7-cgi 7.4.33-4 -
php7-dblib 7.4.33-4 -
php7-embed 7.4.33-4 -
php7-enchant 7.4.33-4 -
php7-fpm 7.4.33-4 -
php7-gd 7.4.33-4 -
php7-imap 7.4.33-4 -
php7-intl 7.4.33-4 -
php7-odbc 7.4.33-4 -
php7-pgsql 7.4.33-4 -
php7-phpdbg 7.4.33-4 -
php7-pspell 7.4.33-4 -
php7-snmp 7.4.33-4 -
php7-sodium 7.4.33-4 -
php7-sqlite 7.4.33-4 -
php7-tidy 7.4.33-4 -
php7-xsl 7.4.33-4 -
pipewire-alsa 1:0.3.63-5 1:0.3.64-1
pipewire-audio 1:0.3.63-5 1:0.3.64-1
pipewire-docs 1:0.3.63-5 1:0.3.64-1
pipewire-jack 1:0.3.63-5 1:0.3.64-1
pipewire-pulse 1:0.3.63-5 1:0.3.64-1
pipewire-v4l2 1:0.3.63-5 1:0.3.64-1
pipewire-x11-bell 1:0.3.63-5 1:0.3.64-1
pipewire-zeroconf 1:0.3.63-5 1:0.3.64-1
plasma-wayland-session 5.26.5-1 5.26.5-2
plasma-workspace 5.26.5-1 5.26.5-2
python-pep517 0.13.0-1 -
python-trove-classifiers 2022.12.22-1 2023.1.12-1
qt5-declarative 5.15.8+kde+r24-1 5.15.8+kde+r24-2
rav1e 0.6.2-1 0.6.3-1
rust 1:1.66.0-1.1 1:1.66.1-1
rust-src 1:1.66.0-1.1 1:1.66.1-1
tomcat8 8.5.84-1 8.5.85-1
tracker3-miners 3.4.2-2 3.4.3-1
vim-runtime 9.0.1046-1 9.0.1182-1
xfce4-panel 4.18.0-1 4.18.1-1
xfce4-screenshooter 1.10.2-1 1.10.3-1
xsd 4.0.0-4 4.0.0-5
xterm 377-1 378-1
php-legacy - 8.1.14-1.1
php-legacy-apache - 8.1.14-1.1
php-legacy-apcu - 5.1.22-3
php-legacy-cgi - 8.1.14-1.1
php-legacy-dblib - 8.1.14-1.1
php-legacy-embed - 8.1.14-1.1
php-legacy-enchant - 8.1.14-1.1
php-legacy-fpm - 8.1.14-1.1
php-legacy-gd - 8.1.14-1.1
php-legacy-odbc - 8.1.14-1.1
php-legacy-pgsql - 8.1.14-1.1
php-legacy-phpdbg - 8.1.14-1.1
php-legacy-pspell - 8.1.14-1.1
php-legacy-snmp - 8.1.14-1.1
php-legacy-sodium - 8.1.14-1.1
php-legacy-sqlite - 8.1.14-1.1
php-legacy-tidy - 8.1.14-1.1
php-legacy-xsl - 8.1.14-1.1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.12.1.r12877.g97a1d73da-122.12.1.r12884.g90e6b42a2-1
akonadi-calendar22.12.1.r2251.g435dd6e-122.12.1.r2255.gf80d25b-1
akonadi-calendar-tools22.12.1.r997.g53df992-122.12.1.r998.gd59d9fa-1
akonadi-contacts22.12.1.r3322.g10ba0be6-122.12.1.r3323.g02c344d1-1
akonadi-import-wizard22.12.1.r1885.gd3c497c-122.12.1.r1888.g40c3511-1
akonadi-mime22.12.1.r1802.gd8bd2f4-122.12.1.r1803.g8940226-1
akonadi-notes22.12.1.r1118.g39f885a-122.12.1.r1119.g62b2ba6-1
akonadi-search22.12.1.r1320.gd358bf5-122.12.1.r1321.g79f4f74-1
akregator22.12.1.r6549.g13fa485c-122.12.1.r6556.g03459401-1
alligator 22.11.r25.g7dc61dc-1 22.11.r26.g67af0dd-1
analitza22.12.1.r2376.g104d166a-122.12.1.r2377.g72d81727-1
angelfish 22.11.r31.gd63d706-1 22.11.r32.g1eeddb8-1
ark22.12.1.r4984.g315e98a1-122.12.1.r4985.g14665aeb-1
artikulate22.12.1.r1487.gae361c5-122.12.1.r1488.gc8d3c6c-1
audiocd-kio22.12.1.r1148.ge5b2bdb-122.12.1.r1150.g46beaa3-1
audiotube 22.11.r49.g4d4dc7e-1 22.11.r55.g4237746-1
aura-browser5.26.0.r164.g483720b-15.26.0.r167.g3e42f95-1
baloo-widgets22.12.1.r804.gdb1f2cc-122.12.1.r806.g344e399-1
blinken22.12.1.r712.gec31d53-122.12.1.r713.g3092e90-1
bluedevil1:5.26.5.r2557.g9ff7d40d-11:5.26.5.r2559.gb9740b56-1
bomber22.12.1.r609.gbb4b60f-122.12.1.r611.g2d9eba3-1
bovo22.12.1.r822.gf34a565-122.12.1.r823.g08ff085-1
breeze5.26.5.r2546.gd233a468-15.26.5.r2548.gf4fc55d6-1
buho 2.2.1.r12.g49ffec9-1 2.2.1.r13.gddab823-1
calendarsupport22.08.3.r775.g173b277-122.08.3.r777.ga86b4eb-1
calindori 22.11.r13.g7f5b487-1 22.11.r15.gbc5c657-1
cervisia22.12.1.r1737.g5a7ea0d-122.12.1.r1739.gbfb5e20-1
discover5.26.5.r9139.g51432481b-15.26.5.r9152.g76cec88bc-1
dolphin22.12.1.r7226.geab9205c3-122.12.1.r7233.g135174d6b-1
dolphin-plugins22.12.1.r716.ge619b86-122.12.1.r720.g107a339-1
dragon22.12.1.r1129.gcb45215-122.12.1.r1130.g22f5ec2-1
drkonqi5.26.5.r872.g5a63338f-15.26.5.r873.gd923e6d0-1
elisa22.12.1.r3113.g427a6f17-122.12.1.r3120.gf8478b91-1
elisa-qtmm22.12.1.r3113.g427a6f17-122.12.1.r3120.gf8478b91-1
eventviews22.08.3.r923.gb9b57e4-122.08.3.r927.gd1be10f-1
extra-cmake-modules5.101.0.r3544.gbc3a8b86-15.101.0.r3545.g34fd474a-1
ffmpegthumbs22.12.1.r243.g3035976-122.12.1.r244.g76f786b-1
filelight22.12.1.r1314.g902a954-122.12.1.r1317.g3f6bc9a-1
granatier22.12.1.r1022.gd0ba57d-122.12.1.r1023.gb4c7564-1
grantlee-editor22.12.1.r890.g207da5f-122.12.1.r892.g7bc9b6a-1
grantleetheme22.12.1.r454.ga1b4c1a-122.12.1.r455.gc71d785-1
gwenview22.12.1.r7010.g057114e6-122.12.1.r7015.gbb3388b1-1
incidenceeditor22.12.1.r977.g1cf27a8-122.12.1.r979.g8306dc7-1
index-fm 2.2.1.r11.gbd54399-1 2.2.1.r12.g94f843a-1
itinerary22.12.1.r2228.g412d8d9-122.12.1.r2243.g81e57a3-1
juk22.12.1.r3220.g25a71982-122.12.1.r3221.g05fdc509-1
k3b1:22.12.1.r6900.g2625bc960-11:22.12.1.r6902.gef88bd479-1
kaccounts-integration22.12.1.r1325.gffb333c-122.12.1.r1326.g54d5f0c-1
kaccounts-providers22.12.1.r423.gc7f7051-122.12.1.r424.gefcee30-1
kactivities-stats5.101.0.r427.g789d193-15.101.0.r428.gc7ab8bd-1
kactivitymanagerd5.26.5.r1443.ge041829-15.26.5.r1444.g741248e-1
kaddressbook22.12.1.r6295.g32e6a223-122.12.1.r6299.g4d0ef0a6-1
kajongg22.12.1.r4385.gcbb7a6b9-122.12.1.r4386.gb948aa76-1
kalarm22.12.1.r8222.g8c3856e4-122.12.1.r8228.gd9440418-1
kalgebra22.12.1.r2117.gc374d3f-122.12.1.r2121.g1cf6cda-1
kalk 22.11.r26.gf827060-1 22.11.r27.g1832e6c-1
kalzium22.12.1.r4455.g0229d66b-122.12.1.r4456.gcdd7f968-1
kamera22.12.1.r776.g06148ba-122.12.1.r782.gc4209e2-1
kamoso22.12.1.r1522.g9e92e44-122.12.1.r1523.g61a8082-1
kanagram22.12.1.r1367.gc6d39a9-122.12.1.r1368.g67a8c97-1
kapman22.12.1.r703.gb1c1b54-122.12.1.r704.g1875a26-1
kapptemplate22.12.1.r1034.g6c749df-122.12.1.r1035.g135de62-1
kasts 22.11.r60.ga306d14-1 22.11.r61.g420a053-1
kate22.12.1.r20112.g7f6658a99-122.12.1.r20185.gf6e2e422c-1
katomic22.12.1.r1005.g181a7ae-122.12.1.r1006.g747eb0b-1
kbackup22.12.1.r496.gf60d119-122.12.1.r497.gd8aeeb5-1
kblackbox22.12.1.r812.ge72ae17-122.12.1.r813.g5de4e8e-1
kblocks22.12.1.r787.g455104a-122.12.1.r788.g14cac55-1
kbounce22.12.1.r897.g2293f4d-122.12.1.r898.ge3dc5de-1
kbreakout22.12.1.r971.g5ca7f0b-122.12.1.r972.gb2f3fda-1
kbruch22.12.1.r923.gb260011-122.12.1.r924.gbaea8a7-1
kcachegrind22.12.1.r1229.g2bcea93-122.12.1.r1230.g98d5e96-1
kcachegrind-common22.12.1.r1229.g2bcea93-122.12.1.r1230.g98d5e96-1
kcalc22.12.1.r1673.g8d62cfc-122.12.1.r1674.g0020b82-1
kcalendarcore5.101.0.r1356.gd48789027-15.101.0.r1358.g6585c73a9-1
kcalutils22.12.1.r1025.g91dac684d-122.12.1.r1026.gcb8e8df88-1
kcharselect22.12.1.r584.g960ccb1-122.12.1.r585.gc7301e1-1
kclock 22.11.r32.g4e55eb0-1 22.11.r37.g571858a-1
kcmutils5.101.0.r702.ga7b2861-15.101.0.r703.ged76bce-1
kcolorchooser22.12.1.r306.g60706c0-122.12.1.r307.g96dc32b-1
kconfig5.101.0.r1021.gada48267-15.101.0.r1022.g40ff273f-1
kconfigwidgets5.101.0.r844.g270b4872-15.101.0.r846.g2f5d6a41-1
kcron22.12.1.r877.gcd59138-122.12.1.r879.ge5fbb95-1
kde-cli-tools5.26.5.r2039.ge9c56c1-15.26.5.r2041.gbaab41e-1
kde-dev-utils22.12.1.r627.g48150f6-122.12.1.r628.gaaf30b7-1
kdebugsettings22.12.1.r1058.gd5a41c4-122.12.1.r1061.gb73f4f9-1
kdeconnect22.12.1.r3656.ged92c412-122.12.1.r3661.g5db7d31e-1
kdecoration5.26.5.r318.g8172c90-15.26.5.r319.gb32fb3f-1
kdenetwork-filesharing22.12.1.r1027.gb15eba9-122.12.1.r1031.g88e61d1-1
kdenlive22.12.1.r17284.ga7ebb90f2-122.12.1.r17309.g33cf53602-1
kdepim-addons22.12.1.r5013.gcd515446e-122.12.1.r5022.g7be26c88b-1
kdepim-runtime22.12.1.r15679.g920ffd0c1-122.12.1.r15684.g7221cf565-1
kdeplasma-addons5.26.5.r9253.g730c75cf6-15.26.5.r9268.gd41e79124-1
kdesdk-thumbnailers22.12.1.r114.ga06c4b3-122.12.1.r115.g2c4538f-1
kdf22.12.1.r915.g7f66ecd-122.12.1.r916.g217f8c4-1
kdialog22.12.1.r1284.gdb42c8e11-122.12.1.r1286.gaac92e91c-1
kdiamond22.12.1.r766.g58a819d-122.12.1.r767.g7a9729f-1
keditbookmarks22.12.1.r2797.gc0be691f1-122.12.1.r2798.g582cbc1cd-1
keysmith 22.11.r8.gda81850-1 22.11.r10.g16cfcd2-1
kfilemetadata5.101.0.r911.ge24799d-15.101.0.r912.g5bd67e9-1
kfind22.12.1.r2770.g42b43a966-122.12.1.r2771.gce8db2e32-1
kfloppy22.12.1.r835.ge8407aa-122.12.1.r836.g6617053-1
kfourinline22.12.1.r1070.g7b4553f-122.12.1.r1074.g400840f-1
kgamma55.26.5.r504.g4af53cd-15.26.5.r505.g1ff44c3-1
kgeography22.12.1.r1220.g0b1eecc-122.12.1.r1222.g41a1abf-1
kget22.12.1.r3297.g2264cf5b-122.12.1.r3303.g00986787-1
kgoldrunner22.12.1.r1338.g13e4928-122.12.1.r1339.g0ee52bc-1
kguiaddons5.101.0.r526.g92e12f1-15.101.0.r527.gc28c8b7-1
khangman22.12.1.r1661.g82e6f79-122.12.1.r1662.g56cbdb1-1
khelpcenter22.12.1.r2848.g4703d7bf-122.12.1.r2850.g7f8f183a-1
khotkeys5.26.5.r2200.g3f8bae6-15.26.5.r2203.g8e4255b-1
kidentitymanagement22.12.1.r3942.g4c8848ff-122.12.1.r3944.g9e53f6d3-1
kig22.12.1.r3275.gba664a1b-122.12.1.r3276.gf397b806-1
kigo22.12.1.r620.g43ac508-122.12.1.r621.g3245d5f-1
killbots22.12.1.r843.g4bfb760-122.12.1.r844.g1065fca-1
kimageformats5.101.0.r474.g4c6d2b9-15.101.0.r475.g14742cb-1
kimagemapeditor22.12.1.r555.gc02e5d6-122.12.1.r558.g47c99d9-1
kimap22.12.1.r1239.ge62cd61-122.12.1.r1240.g374e487-1
kinfocenter5.26.5.r2276.g5820506d-15.26.5.r2284.gd2f462b0-1
kio5.101.0.r6003.g78b153dfa-15.101.0.r6013.ga831d650e-1
kio-extras22.12.1.r7469.gfeb173610-122.12.1.r7474.ga176945a7-1
kio-gdrive22.12.1.r690.gbb58b34-122.12.1.r691.ge1ad779-1
kirigami-addons1:0.6.1.r18.g007acd9-11:0.6.1.r24.gff9598e-1
kirigami-gallery22.12.1.r309.g780e0c8-122.12.1.r314.g838e042-1
kirigami25.101.0.r3566.gf52d372a-15.101.0.r3569.ge9f19ecd-1
kiriki22.12.1.r507.gdd4d3d1-122.12.1.r508.ge23b9d4-1
kiten22.12.1.r1246.g56b2f3a-122.12.1.r1252.g1aa1e45-1
kitinerary22.12.1.r2617.g30940b97-122.12.1.r2630.g6e30e92a-1
kjumpingcube22.12.1.r884.gedff2cf-122.12.1.r888.g8dcc023-1
kldap22.12.1.r1008.g318613b-122.12.1.r1009.gfaeea56-1
kleopatra22.12.1.r7058.ge94e93b5-122.12.1.r7070.g9c441441-1
klettres22.12.1.r1012.g4206a66-122.12.1.r1013.geba013c-1
klickety22.12.1.r743.g6d2b109-122.12.1.r748.gaf1b176-1
klines22.12.1.r861.g198f3f2-122.12.1.r862.gc88fb2f-1
kmag22.12.1.r778.g7bcb7a3-122.12.1.r779.gea64760-1
kmahjongg22.12.1.r1606.g05d4949-122.12.1.r1608.g3382562-1
kmail22.12.1.r26746.g273cb534f-122.12.1.r26755.g8d4d897c1-1
kmail-account-wizard22.12.1.r934.g3d72d5a-122.12.1.r936.g655d447-1
kmailtransport22.12.1.r1843.g9ce63eb-122.12.1.r1844.gc197378-1
kmenuedit5.26.5.r1138.ge4c683e-15.26.5.r1139.g11060fe-1
kmime22.12.1.r1570.g3f3a244-122.12.1.r1571.gcb18c70-1
kmines22.12.1.r1812.g1b7bc50-122.12.1.r1813.g4ecf55b-1
kmix22.12.1.r2495.gf84e1122-122.12.1.r2497.gb3011429-1
kmousetool22.12.1.r484.g00eba6c-122.12.1.r485.g9017d64-1
kmouth22.12.1.r791.g17a8494-122.12.1.r792.ge649fdd-1
kmplot22.12.1.r1558.g327e9d5-122.12.1.r1559.g1e5a01d-1
knavalbattle22.12.1.r1483.gf30c00c-122.12.1.r1484.gc2fba5e-1
knetwalk22.12.1.r758.gd718d6a-122.12.1.r759.g25fd263-1
knights22.12.1.r1203.gd6cafbd-122.12.1.r1204.g7bed0ae-1
knotes22.12.1.r3771.gc631d038-122.12.1.r3776.gc4779449-1
knotifications5.101.0.r795.gb396a59-15.101.0.r796.g95557fc-1
koko 22.11.r7.ge171a83-1 22.11.r8.g01d0953-1
kolf22.12.1.r1571.gbe434f0-122.12.1.r1573.gbe56894-1
kollision22.12.1.r578.gd05ef91-122.12.1.r579.ge8f1618-1
kolourpaint22.12.1.r2479.ga3800624-122.12.1.r2481.g1be76a8b-1
kompare22.12.1.r1227.g826075f-122.12.1.r1230.g041e440-1
kongress 22.11.r8.g293452a-1 22.11.r9.g9398368-1
konqueror22.12.1.r15283.g47e8212a6-122.12.1.r15288.g2bfd4c7cb-1
konquest22.12.1.r992.g971d978-122.12.1.r994.gee1d0e1-1
konsole22.12.1.r8829.ga991d8d9-122.12.1.r8831.gb783fdcb4-1
kontact22.12.1.r5637.g34eb5c48-122.12.1.r5641.g66bf88e4-1
kontactinterface22.12.1.r738.g25204d8-122.12.1.r739.g0b5a9d8-1
kontrast22.12.1.r277.g45a114a-122.12.1.r278.ga1e7a64-1
konversation22.12.1.r9235.g67c7eb1c-122.12.1.r9237.gaf5eee7e-1
kopeninghours22.12.1.r360.g520996c-122.12.1.r361.g2d25401-1
kopete22.12.1.r16515.g46255da4e-122.12.1.r16518.g98437e708-1
korganizer22.12.1.r11913.g3d798597b-122.12.1.r11917.g55faf0010-1
kosmindoormap22.12.1.r898.gf64aff8-122.12.1.r900.g0a940b2-1
kpat22.12.1.r2680.g7eba4e17-122.12.1.r2689.g763df906-1
kpeoplevcard 0.1.r62.g46245c2-1 0.1.r64.g11d8e74-1
kpimtextedit22.12.1.r1745.g5ad6172-122.12.1.r1756.gbd2eef9-1
kpipewire5.26.5.r187.gf490a41-15.26.5.r195.g41d8692-1
kpmcore22.12.1.r1339.ge1839b3-122.12.1.r1342.g6582336-1
kpublictransport22.12.1.r2091.g85ac4f00-122.12.1.r2093.gb38885f2-1
krdc22.12.1.r1670.gb09a414-122.12.1.r1673.g2437822-1
krecorder 22.11.r30.gdb08838-1 22.11.r31.g807b968-1
kreversi22.12.1.r1321.g2356234-122.12.1.r1322.g3f0b79e-1
krfb22.12.1.r1538.gd7cafa3-122.12.1.r1543.ge0ec84e-1
kruler22.12.1.r790.gecfaa2a-122.12.1.r801.gd4b472d-1
ksanecore r665.gd603483-1 r668.g5e3d71f-1
kscreen5.26.5.r1649.gb60f129-15.26.5.r1653.g78e508c-1
kscreenlocker5.26.5.r1050.ga588f26-15.26.5.r1053.gec651b2-1
kshisen22.12.1.r1288.gb58575b-122.12.1.r1289.g3c3eaf5-1
ksirk22.12.1.r1098.gb3f0db7-122.12.1.r1100.gdedf84c-1
ksmtp22.12.1.r486.g9800e89-122.12.1.r487.g4e1250c-1
ksnakeduel22.12.1.r898.g1da2848-122.12.1.r899.g7b25dc3-1
kspaceduel22.12.1.r716.g88194a0-122.12.1.r717.ge72b844-1
ksquares22.12.1.r627.gc9b6155-122.12.1.r628.gb0739bf-1
ksshaskpass5.26.5.r244.g04ec6e2-15.26.5.r245.ge96b12b-1
ksudoku22.12.1.r1165.gdfb72a1-122.12.1.r1166.g23dd547-1
ksysguard5.26.5.r3575.ga203916c-15.26.5.r3578.g05bad52b-1
ksystemlog22.12.1.r800.gd8290bd-122.12.1.r802.g7180d1f-1
ksystemstats5.26.5.r267.g60353c6-15.26.5.r270.g46441ad-1
kteatime22.12.1.r795.gc2fc1c9-122.12.1.r796.g4e7a3b8-1
ktexteditor5.101.0.r3718.g9d0b873a-15.101.0.r3723.g800af913-1
ktimer22.12.1.r563.gcd395a2-122.12.1.r564.g6cfd638-1
ktnef22.12.1.r768.g4f2833b-122.12.1.r769.g35ff43c-1
ktorrent22.12.1.r2939.ga99dbd4f-122.12.1.r2940.g5aae5aa1-1
ktouch22.12.1.r2237.gf0d1974-122.12.1.r2238.gefbfd72-1
ktrip 22.11.r7.g5e48739-1 22.11.r8.g7d39985-1
ktuberling22.12.1.r1124.g56415d1-122.12.1.r1125.g57a9636-1
kturtle22.12.1.r1224.gaea7cd4-122.12.1.r1225.g4acbba0-1
kubrick22.12.1.r462.g6191e34-122.12.1.r463.g260ba83-1
kunitconversion5.101.0.r469.gd4ba2d5-15.101.0.r470.g75d06ab-1
kwalletmanager22.12.1.r1370.geed7c8a-122.12.1.r1376.gbda0283-1
kwave22.12.1.r3845.gd811896a-122.12.1.r3846.g46a07707-1
kweather 22.11.r24.gcfb1c8a-1 22.11.r25.gaa48b47-1
kweathercore 0.7.r23.g4efa958-1 0.7.r24.g048a045-1
kwidgetsaddons5.101.0.r1042.g2263cd1c-15.101.0.r1043.g3d9d07dc-1
kwin5.26.5.r23881.g612099a31-15.26.5.r23917.g9cd52b406-1
kwordquiz22.12.1.r1267.g57db74e-122.12.1.r1269.g62b1533-1
kwrite22.12.1.r20112.g7f6658a99-122.12.1.r20185.gf6e2e422c-1
kxmlgui5.101.0.r949.g753cdbf6-15.101.0.r987.g770bca68-1
libakonadi22.12.1.r12877.g97a1d73da-122.12.1.r12884.g90e6b42a2-1
libgravatar22.12.1.r462.g2740bae-122.12.1.r463.g3730e17-1
libkcddb22.12.1.r787.gf59b27d-122.12.1.r789.gcb914dd-1
libkcompactdisc22.12.1.r412.g336370d-122.12.1.r414.ge659ce9-1
libkdegames22.12.1.r2287.g64d112e1-122.12.1.r2288.g2e1e574c-1
libkdepim22.12.1.r951.g23267f8-122.12.1.r952.g29596ea-1
libkeduvocdocument22.12.1.r1832.g81d4f8a-122.12.1.r1833.g9363af7-1
libkgapi22.12.1.r1411.g7a04384-122.12.1.r1412.gc9c39a2-1
libkleo22.12.1.r1363.gfe6577a-122.12.1.r1368.g5f90a60-1
libkmahjongg22.12.1.r512.g0a3537b-122.12.1.r513.g2fe3cc3-1
libkomparediff222.12.1.r375.g5aa0680-122.12.1.r376.g30f1234-1
libksane22.12.1.r629.g7b67c3e-122.12.1.r630.g0160b4c-1
libkscreen5.26.5.r1720.g23a05bd-15.26.5.r1722.g5c160c4-1
libksieve22.12.1.r1800.g293bafc0-122.12.1.r1802.gbbf9030f-1
libksysguard5.26.5.r2510.gc470b8d-15.26.5.r2517.g2802a0e-1
libktorrent22.12.1.r584.g3383d01-122.12.1.r585.g2efbc08-1
lokalize22.12.1.r1895.g52f85256-122.12.1.r1898.gad5c260d-1
lskat22.12.1.r898.ga0d4f43-122.12.1.r899.gd6035ba-1
mailcommon22.12.1.r1362.gbe5cd0c-122.12.1.r1364.gadfaf6f-1
mailimporter22.12.1.r573.g3a4a447-122.12.1.r575.g715710e-1
marble22.12.1.r13549.gd9c9c210f-122.12.1.r13550.g36b24781d-1
marble-common22.12.1.r13549.gd9c9c210f-122.12.1.r13550.g36b24781d-1
marble-qt22.12.1.r13549.gd9c9c210f-122.12.1.r13550.g36b24781d-1
markdownpart22.12.1.r161.g12ffa7c-122.12.1.r162.g762b55e-1
maui-clip 2.2.1.r10.g4176a86-1 2.2.1.r11.g9179a9a-1
maui-nota 2.2.1.r7.g3397e27-1 2.2.1.r8.g281d097-1
mauikit2.2.1.r32.ge6be0921-12.2.1.r35.gdab2af73-1
mauikit-accounts 2.2.1.r17.ge00f525-1 2.2.1.r21.ga36fe1b-1
mauikit-filebrowsing 2.2.0.r44.gd2694ec-1 2.2.0.r50.g6abf6c8-1
mauikit-texteditor 2.2.1.r16.ge535fa8-1 2.2.1.r19.g97b3429-1
mbox-importer22.12.1.r609.g2d5a434-122.12.1.r610.ge4a5e18-1
messagelib22.12.1.r6838.gdd86de960-122.12.1.r6852.g21fe13adc-1
milou5.26.5.r801.g5a5f9fd-15.26.5.r802.g53aef7f-1
minuet22.12.1.r658.gcfb7ccd-122.12.1.r659.gff10cf6-1
neochat22.11.r103.g982d21dd-122.11.r119.g7818747e-1
okular22.12.1.r9939.g32da63605-122.12.1.r9940.g0b705a4b7-1
oxygen5.26.5.r4542.g53012441-15.26.5.r4543.g079b51bf-1
palapeli22.12.1.r1357.gf55c5e2-122.12.1.r1358.gda5aafd-1
parley22.12.1.r4578.ge3ace90b-122.12.1.r4580.g3eb71d55-1
partitionmanager22.12.1.r1723.g74dc517-122.12.1.r1724.g84e0ed6-1
picmi22.12.1.r615.g19dcd41-122.12.1.r616.gc3eb48d-1
pim-data-exporter22.12.1.r2852.ge07f3b81-122.12.1.r2855.g23dfdf15-1
pim-sieve-editor22.12.1.r1718.g3897354-122.12.1.r1719.g44a1a91-1
pimcommon22.08.3.r1906.g7b131703-122.08.3.r1909.g9c17b8b1-1
plank-player5.26.0.r123.gca031f4-15.26.0.r126.g15fa7d8-1
plasma-bigscreen5.26.0.r609.g784adb2-15.26.0.r614.g0690960-1
plasma-browser-integration5.26.5.r1411.g4df1e0d4-15.26.5.r1413.gf8da3d31-1
plasma-camera 1.0.r148.gf10c6b6-1 1.0.r150.g6799ff1-1
plasma-desktop5.26.5.r10000.g8c2357859-15.26.5.r10018.gd450e5605-1
plasma-dialer 22.11.r36.g574f8c9-1 22.11.r44.g7c10c02-1
plasma-disks5.26.5.r322.g93bb3d5-15.26.5.r323.gd82488f-1
plasma-firewall5.26.5.r703.g1f90af0-15.26.5.r704.g8edb5f3-1
plasma-framework5.101.0.r16581.gb0a263507-15.101.0.r16582.gdedbfb905-1
plasma-integration5.26.5.r620.g8a4772f-15.26.5.r621.g19f9874-1
plasma-mobile5.26.5.r2124.ge2ace4e65-15.26.5.r2128.gfa9b25077-1
plasma-mobile-nm5.26.5.r3501.g685c86e4-15.26.5.r3504.gda02162b-1
plasma-nano5.26.5.r216.g32c3cad-15.26.5.r217.g2637714-1
plasma-nm5.26.5.r3501.g685c86e4-15.26.5.r3504.gda02162b-1
plasma-pa5.26.5.r1167.g3c21c5c-15.26.5.r1169.g574bf11-1
plasma-phonebook 22.11.r19.g8dd370d-1 22.11.r26.ge3cb60c-1
plasma-remotecontrollers5.26.0.r218.geb2afac-15.26.0.r221.g72a0956-1
plasma-sdk5.26.5.r2464.gab95e954-15.26.5.r2465.gfe980a93-1
plasma-settings 22.11.r20.g42b17ee-1 22.11.r24.gf85d63c-1
plasma-systemmonitor5.26.5.r677.gf439d74-15.26.5.r683.g096af7f-1
plasma-thunderbolt5.26.5.r218.g6003bfb-15.26.5.r219.g682ba05-1
plasma-vault5.26.5.r418.g9f5a51e-15.26.5.r419.gf6f004d-1
plasma-wayland-session5.26.5.r13084.g515f48790-15.26.5.r13103.ge365c363a-1
plasma-workspace5.26.5.r13084.g515f48790-15.26.5.r13103.ge365c363a-1
plasma-workspace-wallpapers5.26.5.r404.gf26824a-15.26.5.r405.gd0295f2-1
plasmatube 22.11.r37.gb5eb42d-1 22.11.r38.g00d6439-1
polkit-kde-agent5.26.5.r557.g7861228-15.26.5.r558.g5d96246-1
powerdevil5.26.5.r2664.g8b8656cd-15.26.5.r2666.g14f963a8-1
print-manager22.12.1.r1225.ga76d90c-122.12.1.r1228.g86bdf2e-1
qcachegrind22.12.1.r1229.g2bcea93-122.12.1.r1230.g98d5e96-1
qmlkonsole 22.11.r34.g37f6554-1 22.11.r35.g489fa89-1
qqc2-desktop-style5.101.0.r701.gf375f4d-15.101.0.r711.g122cd90-1
rocs22.12.1.r3163.g85e5889a-122.12.1.r3164.gbb031f77-1
sddm-kcm5.26.5.r713.gc92292d-15.26.5.r719.ga157ffc-1
spacebar 22.11.r35.g71c6706-1 22.11.r47.gadb6ada-1
spectacle22.12.1.r1470.g712cb8f-122.12.1.r1476.gfb31896-1
step22.12.1.r1291.g6eed4ff-122.12.1.r1292.g3b6e3e9-1
svgpart22.12.1.r263.g0480411-122.12.1.r264.g4e9ae1d-1
sweeper22.12.1.r616.g03dc59f-122.12.1.r617.g60766b9-1
syntax-highlighting5.101.0.r2072.gf08c1d99-15.101.0.r2073.ga7b12583-1
systemsettings5.26.5.r2812.g11660547-15.26.5.r2818.gb14ae84a-1
telepathy-kde-accounts-kcm22.12.1.r1242.gdf61ded-122.12.1.r1243.gd92306d-1
telepathy-kde-approver22.12.1.r320.g4703377-122.12.1.r321.g7bc59df-1
telepathy-kde-auth-handler22.12.1.r301.gfa68fb6-122.12.1.r302.g44a646f-1
telepathy-kde-call-ui22.12.1.r468.gf5e0c61-122.12.1.r469.g100c6aa-1
telepathy-kde-common-internals22.12.1.r2049.g097d31d-122.12.1.r2050.geea02f1-1
telepathy-kde-contact-list22.12.1.r1116.g7a3afe3-122.12.1.r1117.gb607187-1
telepathy-kde-contact-runner22.12.1.r281.g505a51e-122.12.1.r282.g4a34a54-1
telepathy-kde-desktop-applets22.12.1.r1022.g0e0ef63-122.12.1.r1023.g44c0fcf-1
telepathy-kde-filetransfer-handler22.12.1.r243.g9c6e07e-122.12.1.r244.gfdd1772-1
telepathy-kde-integration-module22.12.1.r422.g6a27ba0-122.12.1.r423.gbde993d-1
telepathy-kde-send-file22.12.1.r252.g9592045-122.12.1.r253.g3d8896b-1
telepathy-kde-text-ui22.12.1.r2079.g050325d0-122.12.1.r2080.gc8a203a5-1
tokodon23.01.0.r46.g2f7bcda-123.01.0.r62.gd5aad00-1
vakzination 22.11.r12.g8ffe12c-1 22.11.r14.g408bb9b-1
vvave 2.2.1.r58.gd6830ad-1 2.2.1.r66.g9554287-1
xdg-desktop-portal-kde5.26.5.r597.g16b0ddd-15.26.5.r607.g828b53d-1
yakuake22.12.1.r900.gb67a2a9-122.12.1.r902.g7c1935c-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
