[ARM Testing Update] 2022-12-24 - Breath Theme, Gstreamer, Meson and kernels
Hello ARM community.
Merry Christmas everyone, here is an update (mainly with point releases) to celebrate the holidays.
Breath has a new wallpaper
Some highlights:
  • Most of our kernels got updated
  • Breath theme has been updated to match Manjaro x64 for 22.0.0
  • SystemD updated to 252.4
  • Firefox updated to 108.0.1
  • Thunderbird updated to 102.6.1
  • Gstreamer updated to 1.20.5
  • Meson build tool updated to 1.0.0
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sat Dec 24 15:25:33 CET 2022)
  • arm-testing community aarch64: 384 new and 377 removed package(s)
  • arm-testing core aarch64: 42 new and 44 removed package(s)
  • arm-testing extra aarch64: 285 new and 286 removed package(s)
  • arm-testing kde-unstable aarch64: 209 new and 209 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2022-12-16         2022-12-24
                   breath-wallpapers             21.3.0-4             22.0.0-2
                                code             1.73.0-0             1.74.2-0
                               confy              0.6.3-1              0.6.4-1
                     element-desktop            1.11.16-1            1.11.17-1
                         element-web            1.11.16-1            1.11.17-1
                          gtk3-nocsd              3.0.1-1                    -
             mesa-apple-silicon-edge 23.0.0_pre20221214-1 23.0.0_pre20221219-1
                               phosh0.22.0+11+gb1fc33d9-10.22.0+36+ge5995917-1
               plasma5-themes-breath             21.3.0-4             22.0.0-2
         plasma5-themes-breath-extra             21.3.0-4             22.0.0-2
     plasma5-themes-breath-migration             21.3.0-4             22.0.0-2
                   sddm-breath-theme             21.3.0-4             22.0.0-2
                            topgrade             10.2.2-1             10.2.4-1
                              ventoy             1.0.79-4             1.0.85-1
    vulkan-swrast-apple-silicon-edge 23.0.0_pre20221214-1 23.0.0_pre20221219-1
                        wf-touch-git         34.b1075c5-1         36.8974eb0-1
                        wire-desktop          3.29.3004-1          3.30.3018-1
            gnome-shell-mobile-devel                    -43.1+r265+g9cf960534-1
                 mutter-mobile-devel                    -43.1+r139+g3be9031ee-1
:: Different sync package(s) in repository community aarch64
                          aliyun-cli            3.0.140-1            3.0.141-1
                             ansible              7.0.0-1              7.1.0-1
                          apache-orc              1.7.3-4              1.8.1-1
                           apptainer              1.1.4-1              1.1.4-2
                       arc-gtk-theme           20220405-2           20221218-1
                 arc-solid-gtk-theme           20220405-2           20221218-1
                              argocd              2.5.3-1              2.5.5-1
                            arp-scan              1.9.8-1             1.10.0-1
                          aws-c-auth             0.6.18-1             0.6.21-1
                   aws-c-compression             0.2.15-1             0.2.16-1
                  aws-c-event-stream             0.2.15-1             0.2.17-1
                          aws-c-http             0.6.24-1             0.6.28-1
                            aws-c-io             0.13.7-1            0.13.11-1
                          aws-c-mqtt             0.7.13-1              0.8.2-1
                            aws-c-s3             0.1.51-1              0.2.1-1
                      aws-c-sdkutils              0.1.6-1              0.1.7-1
                       aws-checksums             0.1.13-1             0.1.14-1
                          aws-cli-v2              2.9.6-1              2.9.8-1
                         aws-crt-cpp            0.18.11-1             0.19.1-1
                           aws-vault              6.6.0-2              6.6.1-1
                              awxkit            21.10.1-1            21.10.2-1
                                  b4             0.10.1-1             0.11.0-1
                               bacon              2.2.7-1              2.2.8-1
                bash-language-server              4.1.2-1              4.1.3-1
                                 bcc             0.25.0-2             0.26.0-1
                           bcc-tools             0.25.0-2             0.26.0-1
                               beets              1.6.0-3              1.6.0-4
                         bitcoin-cli               24.0-2             24.0.1-4
                      bitcoin-daemon               24.0-2             24.0.1-4
                          bitcoin-qt               24.0-2             24.0.1-4
                          bitcoin-tx               24.0-2             24.0.1-4
                               blosc             1.21.2-1             1.21.3-1
                               boinc             7.20.3-1             7.20.4-1
                           boinc-nox             7.20.3-1             7.20.4-1
                          bootconfig                6.0-2                6.1-1
                                 bpf                6.0-2                6.1-1
                               broot             1.17.1-1             1.18.0-1
                            calcurse              4.8.0-1              4.8.0-2
                             calibre              6.9.0-1             6.10.0-1
                             cargo-c             0.9.14-1             0.9.15-1
                          cargo-edit             0.11.6-1             0.11.7-1
                        cargo-expand             1.0.35-1             1.0.36-1
                               carla              2.5.2-1              2.5.2-2
               cgroup_event_listener                6.0-2                6.1-1
                             chezmoi             2.27.3-1             2.28.0-1
                            cinnamon              5.6.4-1              5.6.5-1
               cinnamon-translations              5.6.0-1              5.6.1-1
                               cli11              2.2.0-1              2.3.1-1
                                cloc               1.94-1               1.96-1
                             clojure        1.11.1.1200-1        1.11.1.1208-1
                         cloudflared          2022.11.1-1          2022.12.1-1
                             cockpit                281-1              282.1-1
                  cockpit-packagekit                281-1              282.1-1
                         cockpit-pcp                281-1              282.1-1
                      cockpit-podman                 58-1                 59-1
                    cockpit-storaged                281-1              282.1-1
                          containerd             1.6.12-1             1.6.14-1
                            cpupower                6.0-2                6.1-1
                           cxxbridge             1.0.83-1             1.0.85-1
                           darktable            2:4.0.1-3            2:4.2.0-1
                                dart             2.18.5-1             2.18.6-1
                           dart-sass             1.56.2-1             1.57.1-1
          deepin-qt5platform-plugins             5.0.70-1             5.0.71-1
                          difftastic             0.38.0-1             0.39.0-1
                          displaycal              3.9.6-2             3.9.10-1
                              docker         1:20.10.21-1         1:20.10.22-1
                      docker-compose             2.14.0-1             2.14.2-1
                               doctl             1.90.0-1             1.91.0-1
                               draco              1.5.5-1              1.5.5-2
                               drone             2.15.0-1             2.16.0-1
                           drone-oss             2.15.0-1             2.16.0-1
                         easyeffects              7.0.0-1              7.0.0-2
                                 efl             1.26.3-2             1.26.3-4
                            efl-docs             1.26.3-2             1.26.3-4
                              erlang             25.1.2-2               25.2-2
                          erlang-nox             25.1.2-1               25.2-1
                     erlang-unixodbc             25.1.2-2               25.2-2
                              fabric              2.7.1-1              2.7.1-2
                               faust             2.50.6-1             2.54.9-1
                            feeluown              3.8.8-2              3.8.9-1
               firefox-ublock-origin             1.45.2-1             1.46.0-1
                              fluidd             1.22.1-1             1.22.2-1
                               fplll              5.4.2-1              5.4.3-1
                                  fq              0.1.0-1              0.2.0-1
                             freeciv              3.0.4-1              3.0.5-1
                           freeimage            3.18.0-15            3.18.0-16
                                 gap             4.12.1-2             4.12.2-2
                        gap-packages             4.12.1-2             4.12.2-2
                                gdal              3.6.0-4              3.6.1-1
                              getdns              1.7.2-1              1.7.3-1
                               gfold              4.1.0-1              4.2.0-1
                                giac           1.9.0.29-1           1.9.0.33-1
                       git-warp-time              0.4.5-2              0.4.8-1
                               gitea             1.17.3-1             1.17.4-1
                       gitlab-runner             15.6.1-1             15.7.1-1
                               go-yq             4.30.5-1             4.30.6-1
                              gopass             1.15.0-1             1.15.2-1
                               gopls             0.10.1-1             0.11.0-1
                                gpac            1:2.0.0-2            1:2.2.0-1
                               gping              1.6.1-1              1.6.3-1
                          gpio-utils                6.0-2                6.1-1
                       grafana-agent             0.25.1-1             0.30.1-1
                  grafana-agent-crow             0.25.1-1             0.30.1-1
                    grafana-agentctl             0.25.1-1             0.30.1-1
                          grub-btrfs               4.11-2               4.12-2
                             haproxy              2.7.0-1              2.7.1-1
                      home-assistant        1:2022.12.3-1        1:2022.12.8-1
                              hyperv                6.0-2                6.1-1
                           ibus-m17n             1.4.17-1             1.4.18-1
                  ibus-table-chinese             1.8.11-1             1.8.12-1
                               icewm              3.2.3-1              3.3.0-1
                           iio-utils                6.0-2                6.1-1
                                 iwd                2.0-1                2.1-1
                                  jc             1.22.2-1             1.22.3-1
                             jenkins              2.382-1              2.383-1
                                jmol           14.32.81-1           14.32.82-1
                               jsmol           14.32.81-1           14.32.82-1
                   jupyter-nbconvert              7.2.6-1              7.2.7-1
                    jupyter-nbformat              5.7.0-1              5.7.1-1
                      jupyter-server              2.0.1-1              2.0.5-1
                          jupyterlab              3.5.1-1              3.5.2-1
                  jupyterlab-widgets              3.0.4-1              3.0.5-1
                              kanshi              1.3.0-1              1.3.1-1
                               kicad              6.0.9-3             6.0.10-1
                    kicad-library-3d              6.0.9-1             6.0.10-1
                       kicad-library              6.0.9-1             6.0.10-1
                             klayout            0.27.13-1               0.28-1
                                knot              3.2.3-1              3.2.4-1
                              kstars            1:3.6.2-1            1:3.6.2-2
                           libfabric             1.16.1-1             1.17.0-1
                        libmediainfo              22.09-1              22.12-1
                         libquotient             0.6.11-1              0.7.0-1
                            librecad              2.1.3-6              2.2.0-1
                             librepo             1.14.5-2             1.15.1-1
                 libretro-beetle-pce               1147-1               1157-1
            libretro-beetle-pce-fast               1193-1               1196-1
                 libretro-beetle-psx               2637-1               2642-1
              libretro-beetle-psx-hw               2637-1               2642-1
          libretro-beetle-supergrafx                959-1                963-1
                    libretro-dolphin              33038-1              33042-1
                    libretro-flycast               5247-1               5251-1
            libretro-genesis-plus-gx               1957-1               1962-1
                       libretro-mame              84800-1              85432-1
                    libretro-melonds               2010-1               2012-1
                   libretro-nestopia               1:93-1               1:95-1
                       libretro-play               7461-1               7473-1
              libretro-shaders-slang               1128-1               1137-1
                       libsemigroups              2.5.0-1              2.5.1-1
                             libsolv             0.7.22-2             0.7.23-1
                              libzen             0.4.39-1             0.4.40-1
                            lilypond             2.22.2-2             2.24.0-1
                    linux-tools-meta                6.0-2                6.1-1
                         lsp-plugins              1.2.3-1              1.2.4-1
                    lsp-plugins-docs              1.2.3-1              1.2.4-1
                            luacheck              1.0.0-1              1.1.0-1
                              luajit2.1.0.beta3.r457.g637721d0-12.1.0.beta3.r464.g8625eee7-1
                        luminancehdr             2.6.1-10             2.6.1-11
                     man-pages-zh_cn            1.6.3.6-1            1.6.3.7-1
                     man-pages-zh_tw            1.6.3.6-1            1.6.3.7-1
                      matrix-synapse             1.70.1-1             1.73.0-1
                             maturin             0.14.6-1             0.14.7-1
                               maude              3.2.1-1              3.2.2-1
                                  mc             4.8.28-1             4.8.28-2
                               mcfly              0.7.0-1              0.7.1-1
                              mdbook             0.4.24-1             0.4.25-1
                       mediainfo-gui              22.09-1              22.12-1
                           mediawiki             1.39.0-1             1.39.1-1
                        meson-python             0.11.0-1             0.12.0-1
                       mod_passenger             6.0.15-3             6.0.16-1
                     multipath-tools              0.9.3-1              0.9.4-1
                           musescore                4.0-1                4.0-2
                   nautilus-terminal              4.1.0-1                    -
                              nebula              1.6.0-1              1.6.1-1
                             neochat              22.11-1              22.11-3
                    neovim-lspconfig              0.1.3-3              0.1.4-1
                 nginx-mod-passenger             6.0.15-3             6.0.16-1
                            node-gyp              9.3.0-1              9.3.1-1
                              nodejs             19.2.0-1             19.3.0-1
                              nomacs        1:3.17.2206-8        1:3.17.2206-9
                   npm-check-updates             16.5.0-1             16.5.3-1
                              nsjail                3.2-1                3.3-1
                             nushell             0.72.1-2             0.73.0-1
                              octave              7.3.0-2              7.3.0-4
                                 oil             0.12.9-1             0.13.0-1
                                opam              2.1.3-1              2.1.4-1
                              opencc              1.1.5-1              1.1.6-1
                          opencc-doc              1.1.5-1              1.1.6-1
                         openimageio            2.4.6.1-1            2.4.6.1-2
                            openrct2              0.4.2-3              0.4.3-1
                         osv-scanner              1.0.0-1              1.0.2-1
          pantheon-applications-menu             2.11.0-1             2.11.1-1
                     pantheon-photos              2.8.0-1              2.8.0-2
                            parallel           20221122-1           20221222-1
                       parallel-docs           20221122-1           20221222-1
                            pcsclite              1.9.9-1              1.9.9-2
                                perf                6.0-2                6.1-1
                     perl-berkeleydb               0.65-1               0.65-4
             perl-cpan-perl-releases         5.20221120-1         5.20221220-1
              perl-datetime-timezone               2.56-1               2.57-1
                        perl-log-any              1.712-1              1.713-1
                    perl-ppix-regexp              0.085-2              0.086-1
                        phpldapadmin            1.2.6.4-1            1.2.6.4-4
                       phpvirtualbox              5.2_1-6              5.2_1-7
                               picom               10.1-1               10.2-1
                            polymake                4.7-2                4.8-1
                            prettier              2.7.1-1              2.8.1-1
                                proj              9.1.0-1              9.1.1-1
                               psalm              5.2.0-1              5.4.0-1
                            pybind11             2.10.1-1             2.10.2-1
                               pyenv              2.3.8-1              2.3.9-1
                             pyright            1.1.284-1            1.1.285-1
                 python-aioresponses              0.7.3-2              0.7.4-1
                         python-apsw           3.39.4.0-2           3.40.0.0-1
                     python-autobahn             22.7.1-1            22.12.1-1
                          python-bcc             0.25.0-2             0.26.0-1
                        python-blosc             1.11.0-1             1.11.1-1
                       python-btrees             4.11.0-1             4.11.2-1
                     python-cfn-lint             0.72.2-1             0.72.5-1
                    python-chameleon             3.10.1-1             3.10.2-1
                 python-cinderclient              9.1.0-1              9.2.0-1
                     python-ciso8601              2.2.0-3              2.3.0-1
           python-cmsis-pack-manager              0.4.0-3              0.5.0-1
                     python-colorcet              3.0.1-1              3.0.1-2
                   python-darkdetect              0.7.1-1              0.8.0-1
                         python-dask          2022.11.1-1          2022.12.1-1
                  python-distributed          2022.11.1-1          2022.12.1-1
                     python-django-q              1.3.9-5              1.3.9-6
                        python-faker             13.3.1-1             13.3.4-1
                    python-fakeredis              2.2.0-1              2.3.0-1
                   python-flask-cors             3.0.10-3             3.0.10-4
                       python-fpylll              0.5.7-1              0.5.8-1
                       python-fsspec           2022.5.0-1          2022.11.0-1
                         python-gdal              3.6.0-4              3.6.1-1
                        python-gdstk              0.9.7-1              0.9.8-1
                    python-geopandas             0.12.1-1             0.12.2-1
                        python-gmpy2              2.1.3-1              2.1.5-1
              python-google-api-core             2.10.2-1             2.11.0-1
     python-google-api-python-client             2.66.0-1             2.70.0-1
                  python-google-auth             2.14.1-1             2.15.0-1
     python-home-assistant-bluetooth              1.6.0-1              1.9.0-1
                     python-identify              2.5.9-1             2.5.11-1
                         python-ipdb             0.13.9-3            0.13.10-1
                    python-ipykernel             6.19.2-1             6.19.4-1
                   python-ipywidgets              8.0.3-2              8.0.4-1
                   python-jsonpickle              2.2.0-1              3.0.0-1
                     python-jupymake               0.9-14               0.9-15
                 python-jupyter_core              5.1.0-1              5.1.1-1
            python-jupyterlab_server             2.16.5-1             2.16.6-1
                     python-keycloak              1.8.0-1              2.6.1-1
                 python-latex2mathml             3.74.1-1             3.75.0-1
                    python-mediafile             0.10.1-1             0.11.0-1
                    python-milksnake  0.1.5.r3.gef0723e-1                    -
                         python-moto             4.0.10-1             4.0.12-1
              python-netcdf4-openmpi              1.6.0-1              1.6.2-1
                 python-openapi-core             0.16.2-1             0.16.3-1
                    python-patchwork              1.0.1-5              1.0.1-6
                          python-pdm              2.3.2-1              2.3.3-1
                       python-pg8000             1.29.3-1             1.29.4-1
                 python-phonenumbers             8.13.2-1             8.13.3-1
                      python-pip-run              8.8.2-1              9.1.0-1
                       python-pipenv         2022.11.30-2         2022.12.19-1
                       python-plette              0.4.2-1              0.4.4-1
                      python-psycopg              3.1.4-1              3.1.6-1
                  python-pygame-sdl21:2.1.0.r412.bed8099-11:2.1.0.r414.a3c9121-1
                        python-pygls             0.13.0-1             0.13.1-1
                       python-pylint             2.15.8-1             2.15.9-1
                        python-pyocd             0.34.3-1             0.34.3-2
                       python-pyproj              3.4.0-1              3.4.1-1
                     python-pyspnego              0.6.3-1              0.7.0-1
               python-pytest-asyncio             0.20.2-1             0.20.3-1
                  python-pytest-mypy             0.10.2-1             0.10.3-1
          python-pytest-skip-markers              1.3.0-1              1.4.0-1
                    python-pywayland             0.4.14-1             0.4.15-1
                         python-rope              1.5.1-1              1.6.0-1
                 python-setproctitle              1.3.1-1              1.3.2-1
               python-setuptools-scm              7.0.5-1              7.1.0-1
          python-sphinxext-opengraph              0.7.3-1              0.7.4-1
               python-subprocess-tee              0.4.0-1              0.4.1-1
                    python-traitlets              5.7.1-1              5.8.0-1
                      python-unearth              0.6.3-1              0.7.0-1
                   python-weasyprint               57.1-1               57.2-1
                    python-wurlitzer              3.0.2-4              3.0.3-1
                      python-zconfig              3.6.0-3              3.6.1-1
                                qcad           3.27.8.4-1           3.27.8.6-1
                                qgis             3.28.1-2             3.28.2-1
                       rapidfuzz-cpp             1.10.1-1             1.10.4-1
                              rclone             1.60.1-2             1.61.0-1
                              reaper               6.71-2               6.72-1
                               redis              7.0.6-1              7.0.7-1
                         release-cli             0.14.0-1             0.15.0-1
                             remmina           1:1.4.28-1           1:1.4.29-1
                               rnote              0.5.9-1             0.5.10-1
                          rosegarden              22.06-1              22.12-1
                            rssguard              4.2.5-1              4.2.7-2
                rssguard-nowebengine              4.2.5-1              4.2.7-2
               ruby-cucumber-gherkin             25.0.2-1             26.0.1-1
              ruby-cucumber-messages             20.0.0-1             21.0.1-1
                           ruby-http              5.1.0-1              5.1.1-1
                                ruff            0.0.182-1            0.0.192-1
                       rust-analyzer           20221212-1           20221219-1
                               s-tui              1.1.3-2              1.1.4-1
                             s2n-tls             1.3.28-1             1.3.31-1
                             schroot             1.6.13-1             1.6.13-2
                          sentry-cli              2.9.0-1             2.11.0-1
                          serverless             3.25.1-1             3.26.0-1
                               shfmt              3.5.1-1              3.6.0-1
                            shotwell          2:0.30.17-2          2:0.30.17-3
                             snapper             0.10.3-1             0.10.4-1
                              solaar              1.1.7-2              1.1.8-1
                    spotify-launcher              0.3.0-2              0.4.0-1
                              spyder              5.4.0-2              5.4.0-3
                            sqlfluff              1.4.4-1              1.4.5-1
                               squid                5.7-2                5.7-4
                              stubby              0.4.2-1              0.4.3-1
                            sundials              6.4.1-2              6.5.0-1
                                tcsh            6.24.06-1            6.24.07-1
                           tesseract              5.2.0-2              5.3.0-1
                         timescaledb              2.8.1-3              2.9.0-1
                                tmon                6.0-2                6.1-1
                             tokodon              22.11-1            22.11.2-1
                           towncrier             22.8.0-1            22.12.0-1
                              tt-rss 2:r11408.fa9c614ff-1 2:r11420.fb4bc2615-1
                         ttc-iosevka             16.7.0-1             16.8.0-1
                    ttc-iosevka-aile             16.7.0-1             16.8.0-1
                   ttc-iosevka-curly             16.7.0-1             16.8.0-1
              ttc-iosevka-curly-slab             16.7.0-1             16.8.0-1
                  ttc-iosevka-etoile             16.7.0-1             16.8.0-1
                    ttc-iosevka-slab             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss01             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss02             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss03             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss04             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss05             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss06             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss07             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss08             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss09             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss10             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss11             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss12             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss13             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss14             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss15             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss16             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss17             16.7.0-1             16.8.0-1
                    ttc-iosevka-ss18             16.7.0-1             16.8.0-1
                               typos             1.13.4-1             1.13.6-1
                               usbip                6.0-2                6.1-1
         v2ray-domain-list-community     20221212022004-1     20221222065944-1
                         v2ray-geoip       202212080044-1       202212220043-1
                     vaultwarden-web          2022.11.2-1          2022.12.0-1
                           verilator              5.002-1              5.004-1
                            wasmtime              3.0.1-1              4.0.0-1
                             xreader              3.6.0-1              3.6.2-1
                                 yad               12.2-1               12.3-1
                               yosys               0.23-1               0.24-1
                             you-get           0.4.1620-1           0.4.1650-1
                                clap                    -              1.1.3-2
                            guile2.2                    -              2.2.7-3
                  openpgp-card-tools                    -              0.9.0-3
                      python-esbonio                    -             0.15.0-2
               python-pyspellchecker                    -              0.7.1-1
               python-pytest-jupyter                    -              0.6.2-1
                   python-pytest-lsp                    -              0.1.3-1
             sequoia-chameleon-gnupg                    -              0.1.0-1
:: Different overlay package(s) in repository core aarch64
                               linux              6.1.0-1              6.1.1-1
                           linux-aml             6.0.12-1             6.0.13-1
                   linux-aml-headers             6.0.12-1             6.0.13-1
                       linux-headers              6.1.0-1              6.1.1-1
                           linux-lts            5.15.83-1            5.15.85-1
                   linux-lts-headers            5.15.83-1            5.15.85-1
                      linux-quartz64           5.19.0-0.6                    -
              linux-quartz64-headers           5.19.0-0.6                    -
                          linux-rpi4            5.15.83-1            5.15.84-1
                  linux-rpi4-headers            5.15.83-1            5.15.84-1
                 linux-rpi4-mainline             6.0.13-1              6.1.1-1
         linux-rpi4-mainline-headers             6.0.13-1              6.1.1-1
                            linux515            5.15.83-1            5.15.85-1
                    linux515-headers            5.15.83-1            5.15.85-1
                             linux60             6.0.13-1             6.0.15-1
                     linux60-headers             6.0.13-1             6.0.15-1
                      pacman-mirrors             4.23.2-2  4.23.2+2+g2f58b3c-3
:: Different sync package(s) in repository core aarch64
                           amd-ucode   20221109.60310c2-2   20221214.f3c283e-1
                   archlinux-keyring           20221213-1           20221220-1
                                curl             7.86.0-4             7.87.0-1
                               glib2             2.74.3-1             2.74.4-1
                          glib2-docs             2.74.3-1             2.74.4-1
                            iana-etc           20221107-1           20221215-1
                      libcurl-compat             7.86.0-4             7.87.0-1
                      libcurl-gnutls             7.86.0-4             7.87.0-1
                              libmpc              1.3.0-2              1.3.1-1
                      linux-firmware   20221109.60310c2-2   20221214.f3c283e-1
                linux-firmware-bnx2x   20221109.60310c2-2   20221214.f3c283e-1
             linux-firmware-liquidio   20221109.60310c2-2   20221214.f3c283e-1
              linux-firmware-marvell   20221109.60310c2-2   20221214.f3c283e-1
             linux-firmware-mellanox   20221109.60310c2-2   20221214.f3c283e-1
                  linux-firmware-nfp   20221109.60310c2-2   20221214.f3c283e-1
                 linux-firmware-qcom   20221109.60310c2-2   20221214.f3c283e-1
               linux-firmware-qlogic   20221109.60310c2-2   20221214.f3c283e-1
               linux-firmware-whence   20221109.60310c2-2   20221214.f3c283e-1
                         openssl-1.1            1.1.1.s-2            1.1.1.s-4
                             openssl              3.0.7-2              3.0.7-4
                            pciutils              3.9.0-1              3.9.0-2
                                perl             5.36.0-1             5.36.0-3
                             systemd              252.3-1              252.4-2
                        systemd-libs              252.3-1              252.4-2
                  systemd-resolvconf              252.3-1              252.4-2
                  systemd-sysvcompat              252.3-1              252.4-2
                            xfsprogs              6.0.0-1              6.0.0-2
:: Different overlay package(s) in repository extra aarch64
                    libxfce4ui-nocsd             4.16.0-1                    -
                   manjaro-arm-tools             2.11.0-1             2.11.1-1
:: Different sync package(s) in repository extra aarch64
                           appstream             0.15.5-1             0.15.6-1
                        appstream-qt             0.15.5-1             0.15.6-1
                           aspell-de           20161207-3       20161207.7.0-1
                                bind             9.18.9-1            9.18.10-1
                          bogofilter              1.2.5-5              1.2.5-7
                         chromaprint              1.5.1-5              1.5.1-6
                          cifs-utils                7.0-1                7.0-2
                            composer              2.4.4-3              2.5.1-1
                     default-cursors                  1-1                  2-1
                     directx-headers            1.606.4-1            1.608.0-1
                             dolphin            22.12.0-1            22.12.0-3
                                 ell               0.54-1               0.55-1
                           evolution             3.46.2-1             3.46.2-2
                evolution-bogofilter             3.46.2-1             3.46.2-2
                       evolution-ews             3.46.2-1             3.46.2-2
              evolution-spamassassin             3.46.2-1             3.46.2-2
                           filelight            22.12.0-1            22.12.0-2
                             firefox              108.0-1            108.0.1-1
                    firefox-i18n-ach              108.0-1            108.0.1-1
                     firefox-i18n-af              108.0-1            108.0.1-1
                     firefox-i18n-an              108.0-1            108.0.1-1
                     firefox-i18n-ar              108.0-1            108.0.1-1
                    firefox-i18n-ast              108.0-1            108.0.1-1
                     firefox-i18n-az              108.0-1            108.0.1-1
                     firefox-i18n-be              108.0-1            108.0.1-1
                     firefox-i18n-bg              108.0-1            108.0.1-1
                     firefox-i18n-bn              108.0-1            108.0.1-1
                     firefox-i18n-br              108.0-1            108.0.1-1
                     firefox-i18n-bs              108.0-1            108.0.1-1
                     firefox-i18n-ca              108.0-1            108.0.1-1
            firefox-i18n-ca-valencia              108.0-1            108.0.1-1
                    firefox-i18n-cak              108.0-1            108.0.1-1
                     firefox-i18n-cs              108.0-1            108.0.1-1
                     firefox-i18n-cy              108.0-1            108.0.1-1
                     firefox-i18n-da              108.0-1            108.0.1-1
                     firefox-i18n-de              108.0-1            108.0.1-1
                    firefox-i18n-dsb              108.0-1            108.0.1-1
                     firefox-i18n-el              108.0-1            108.0.1-1
                  firefox-i18n-en-ca              108.0-1            108.0.1-1
                  firefox-i18n-en-gb              108.0-1            108.0.1-1
                  firefox-i18n-en-us              108.0-1            108.0.1-1
                     firefox-i18n-eo              108.0-1            108.0.1-1
                  firefox-i18n-es-ar              108.0-1            108.0.1-1
                  firefox-i18n-es-cl              108.0-1            108.0.1-1
                  firefox-i18n-es-es              108.0-1            108.0.1-1
                  firefox-i18n-es-mx              108.0-1            108.0.1-1
                     firefox-i18n-et              108.0-1            108.0.1-1
                     firefox-i18n-eu              108.0-1            108.0.1-1
                     firefox-i18n-fa              108.0-1            108.0.1-1
                     firefox-i18n-ff              108.0-1            108.0.1-1
                     firefox-i18n-fi              108.0-1            108.0.1-1
                     firefox-i18n-fr              108.0-1            108.0.1-1
                  firefox-i18n-fy-nl              108.0-1            108.0.1-1
                  firefox-i18n-ga-ie              108.0-1            108.0.1-1
                     firefox-i18n-gd              108.0-1            108.0.1-1
                     firefox-i18n-gl              108.0-1            108.0.1-1
                     firefox-i18n-gn              108.0-1            108.0.1-1
                  firefox-i18n-gu-in              108.0-1            108.0.1-1
                     firefox-i18n-he              108.0-1            108.0.1-1
                  firefox-i18n-hi-in              108.0-1            108.0.1-1
                     firefox-i18n-hr              108.0-1            108.0.1-1
                    firefox-i18n-hsb              108.0-1            108.0.1-1
                     firefox-i18n-hu              108.0-1            108.0.1-1
                  firefox-i18n-hy-am              108.0-1            108.0.1-1
                     firefox-i18n-ia              108.0-1            108.0.1-1
                     firefox-i18n-id              108.0-1            108.0.1-1
                     firefox-i18n-is              108.0-1            108.0.1-1
                     firefox-i18n-it              108.0-1            108.0.1-1
                     firefox-i18n-ja              108.0-1            108.0.1-1
                     firefox-i18n-ka              108.0-1            108.0.1-1
                    firefox-i18n-kab              108.0-1            108.0.1-1
                     firefox-i18n-kk              108.0-1            108.0.1-1
                     firefox-i18n-km              108.0-1            108.0.1-1
                     firefox-i18n-kn              108.0-1            108.0.1-1
                     firefox-i18n-ko              108.0-1            108.0.1-1
                    firefox-i18n-lij              108.0-1            108.0.1-1
                     firefox-i18n-lt              108.0-1            108.0.1-1
                     firefox-i18n-lv              108.0-1            108.0.1-1
                     firefox-i18n-mk              108.0-1            108.0.1-1
                     firefox-i18n-mr              108.0-1            108.0.1-1
                     firefox-i18n-ms              108.0-1            108.0.1-1
                     firefox-i18n-my              108.0-1            108.0.1-1
                  firefox-i18n-nb-no              108.0-1            108.0.1-1
                  firefox-i18n-ne-np              108.0-1            108.0.1-1
                     firefox-i18n-nl              108.0-1            108.0.1-1
                  firefox-i18n-nn-no              108.0-1            108.0.1-1
                     firefox-i18n-oc              108.0-1            108.0.1-1
                  firefox-i18n-pa-in              108.0-1            108.0.1-1
                     firefox-i18n-pl              108.0-1            108.0.1-1
                  firefox-i18n-pt-br              108.0-1            108.0.1-1
                  firefox-i18n-pt-pt              108.0-1            108.0.1-1
                     firefox-i18n-rm              108.0-1            108.0.1-1
                     firefox-i18n-ro              108.0-1            108.0.1-1
                     firefox-i18n-ru              108.0-1            108.0.1-1
                    firefox-i18n-sco              108.0-1            108.0.1-1
                     firefox-i18n-si              108.0-1            108.0.1-1
                     firefox-i18n-sk              108.0-1            108.0.1-1
                     firefox-i18n-sl              108.0-1            108.0.1-1
                    firefox-i18n-son              108.0-1            108.0.1-1
                     firefox-i18n-sq              108.0-1            108.0.1-1
                     firefox-i18n-sr              108.0-1            108.0.1-1
                  firefox-i18n-sv-se              108.0-1            108.0.1-1
                    firefox-i18n-szl              108.0-1            108.0.1-1
                     firefox-i18n-ta              108.0-1            108.0.1-1
                     firefox-i18n-te              108.0-1            108.0.1-1
                     firefox-i18n-th              108.0-1            108.0.1-1
                     firefox-i18n-tl              108.0-1            108.0.1-1
                     firefox-i18n-tr              108.0-1            108.0.1-1
                    firefox-i18n-trs              108.0-1            108.0.1-1
                     firefox-i18n-uk              108.0-1            108.0.1-1
                     firefox-i18n-ur              108.0-1            108.0.1-1
                     firefox-i18n-uz              108.0-1            108.0.1-1
                     firefox-i18n-vi              108.0-1            108.0.1-1
                     firefox-i18n-xh              108.0-1            108.0.1-1
                  firefox-i18n-zh-cn              108.0-1            108.0.1-1
                  firefox-i18n-zh-tw              108.0-1            108.0.1-1
                                gegl             0.4.40-2             0.4.40-3
                gnome-control-center               43.1-2               43.2-1
                gst-editing-services             1.20.4-3             1.20.5-1
                           gst-libav             1.20.4-3             1.20.5-1
                      gst-plugin-gtk             1.20.4-3             1.20.5-1
                   gst-plugin-opencv             1.20.4-3             1.20.5-1
                    gst-plugin-qmlgl             1.20.4-3             1.20.5-1
                       gst-plugin-va             1.20.4-3             1.20.5-1
                      gst-plugin-wpe             1.20.4-3             1.20.5-1
                     gst-plugins-bad             1.20.4-3             1.20.5-1
                gst-plugins-bad-libs             1.20.4-3             1.20.5-1
                    gst-plugins-base             1.20.4-3             1.20.5-1
               gst-plugins-base-libs             1.20.4-3             1.20.5-1
                    gst-plugins-good             1.20.4-3             1.20.5-1
                    gst-plugins-ugly             1.20.4-3             1.20.5-1
                          gst-python             1.20.4-3             1.20.5-1
                     gst-rtsp-server             1.20.4-3             1.20.5-1
                           gstreamer             1.20.4-3             1.20.5-1
                      gstreamer-docs             1.20.4-3             1.20.5-1
                     gstreamer-vaapi             1.20.4-3             1.20.5-1
                              gthumb             3.12.2-1             3.12.2-2
               gtk-update-icon-cache            1:4.8.2-1            1:4.8.3-1
                                gtk3          1:3.24.35-2          1:3.24.36-1
                          gtk3-demos          1:3.24.35-2          1:3.24.36-1
                           gtk3-docs          1:3.24.35-2          1:3.24.36-1
                                gtk4            1:4.8.2-1            1:4.8.3-1
                          gtk4-demos            1:4.8.2-1            1:4.8.3-1
                           gtk4-docs            1:4.8.2-1            1:4.8.3-1
                            guile1.8             1.8.8-10                    -
                               gupnp            1:1.6.2-1            1:1.6.3-1
                          gupnp-docs            1:1.6.2-1            1:1.6.3-1
                            harfbuzz              5.3.1-3              6.0.0-1
                        harfbuzz-icu              5.3.1-3              6.0.0-1
                            help2man             1.49.2-1             1.49.3-1
                         imagemagick           7.1.0.54-1           7.1.0.55-2
                     imagemagick-doc           7.1.0.54-1           7.1.0.55-2
                              imlib2              1.9.1-2             1.10.0-1
                            kalendar            22.12.0-1            22.12.0-2
                            kdenlive            22.12.0-1            22.12.0-2
                       kimageformats            5.101.0-1            5.101.0-2
                               krita              5.1.4-1              5.1.4-3
                             libgusb              0.4.2-1              0.4.3-1
                         libiec61883              1.2.0-6              1.2.0-7
                           libkdcraw            22.12.0-1            22.12.0-2
                        libqalculate              4.4.0-2              4.5.0-1
                              libraw             0.20.2-3             0.21.0-2
                           libsigc++             2.10.8-1             2.12.0-1
                       libsigc++-3.0              3.2.0-1              3.4.0-1
                  libsigc++-3.0-docs              3.2.0-1              3.4.0-1
                      libsigc++-docs             2.10.8-1             2.12.0-1
                               libsm              1.2.3-3              1.2.4-1
                             libsoxr              0.1.3-2              0.1.3-3
                            libunrar            1:6.2.2-1            1:6.2.3-1
                              libx11              1.8.2-2              1.8.3-3
                          mesa-amber             21.3.9-2             21.3.9-3
                               meson             0.64.1-1              1.0.0-2
                            nftables            1:1.0.5-1            1:1.0.6-1
                     perl-date-manip               6.89-1               6.90-1
                  perl-io-socket-ssl              2.077-1              2.078-1
                   perl-module-build             0.4231-7             0.4232-1
                phonon-qt5-gstreamer             4.10.0-3             4.10.0-4
                          prometheus             2.40.5-1             2.40.7-1
        prometheus-blackbox-exporter             0.22.0-1             0.23.0-1
                       python-beaker             1.11.0-8             1.12.0-1
                 python-editdistance              0.6.1-1              0.6.2-1
                 python-patiencediff             0.2.11-1             0.2.12-1
                       python-pycurl             7.45.1-2             7.45.2-1
            python-trove-classifiers          2022.12.1-1         2022.12.22-1
                       qalculate-gtk              4.4.0-1              4.5.0-1
                        qalculate-qt              4.4.0-1              4.5.0-1
                         qt5-wayland     5.15.7+kde+r56-1     5.15.7+kde+r58-1
                           qtcreator              9.0.0-2              9.0.1-1
                     qtcreator-devel              9.0.0-2              9.0.1-1
                           ristretto             0.12.3-1             0.12.4-1
                               rsync              3.2.7-2              3.2.7-3
                                rust         1:1.65.0-1.1         1:1.66.0-1.1
                            rust-src         1:1.65.0-1.1         1:1.66.0-1.1
                               samba             4.17.3-1             4.17.4-2
                           smbclient             4.17.3-1             4.17.4-2
                              strace                6.0-1                6.1-1
                          subversion             1.14.2-3             1.14.2-5
                              thunar             4.18.0-1             4.18.1-1
                         thunderbird            102.6.0-1            102.6.1-1
                 thunderbird-i18n-af            102.6.0-1            102.6.1-1
                 thunderbird-i18n-ar            102.6.0-1            102.6.1-1
                thunderbird-i18n-ast            102.6.0-1            102.6.1-1
                 thunderbird-i18n-be            102.6.0-1            102.6.1-1
                 thunderbird-i18n-bg            102.6.0-1            102.6.1-1
                 thunderbird-i18n-br            102.6.0-1            102.6.1-1
                 thunderbird-i18n-ca            102.6.0-1            102.6.1-1
                thunderbird-i18n-cak            102.6.0-1            102.6.1-1
                 thunderbird-i18n-cs            102.6.0-1            102.6.1-1
                 thunderbird-i18n-cy            102.6.0-1            102.6.1-1
                 thunderbird-i18n-da            102.6.0-1            102.6.1-1
                 thunderbird-i18n-de            102.6.0-1            102.6.1-1
                thunderbird-i18n-dsb            102.6.0-1            102.6.1-1
                 thunderbird-i18n-el            102.6.0-1            102.6.1-1
              thunderbird-i18n-en-gb            102.6.0-1            102.6.1-1
              thunderbird-i18n-en-us            102.6.0-1            102.6.1-1
              thunderbird-i18n-es-ar            102.6.0-1            102.6.1-1
              thunderbird-i18n-es-es            102.6.0-1            102.6.1-1
                 thunderbird-i18n-et            102.6.0-1            102.6.1-1
                 thunderbird-i18n-eu            102.6.0-1            102.6.1-1
                 thunderbird-i18n-fi            102.6.0-1            102.6.1-1
                 thunderbird-i18n-fr            102.6.0-1            102.6.1-1
              thunderbird-i18n-fy-nl            102.6.0-1            102.6.1-1
              thunderbird-i18n-ga-ie            102.6.0-1            102.6.1-1
                 thunderbird-i18n-gd            102.6.0-1            102.6.1-1
                 thunderbird-i18n-gl            102.6.0-1            102.6.1-1
                 thunderbird-i18n-he            102.6.0-1            102.6.1-1
                 thunderbird-i18n-hr            102.6.0-1            102.6.1-1
                thunderbird-i18n-hsb            102.6.0-1            102.6.1-1
                 thunderbird-i18n-hu            102.6.0-1            102.6.1-1
              thunderbird-i18n-hy-am            102.6.0-1            102.6.1-1
                 thunderbird-i18n-id            102.6.0-1            102.6.1-1
                 thunderbird-i18n-is            102.6.0-1            102.6.1-1
                 thunderbird-i18n-it            102.6.0-1            102.6.1-1
                 thunderbird-i18n-ja            102.6.0-1            102.6.1-1
                 thunderbird-i18n-ka            102.6.0-1            102.6.1-1
                thunderbird-i18n-kab            102.6.0-1            102.6.1-1
                 thunderbird-i18n-kk            102.6.0-1            102.6.1-1
                 thunderbird-i18n-ko            102.6.0-1            102.6.1-1
                 thunderbird-i18n-lt            102.6.0-1            102.6.1-1
                 thunderbird-i18n-ms            102.6.0-1            102.6.1-1
              thunderbird-i18n-nb-no            102.6.0-1            102.6.1-1
                 thunderbird-i18n-nl            102.6.0-1            102.6.1-1
              thunderbird-i18n-nn-no            102.6.0-1            102.6.1-1
              thunderbird-i18n-pa-in            102.6.0-1            102.6.1-1
                 thunderbird-i18n-pl            102.6.0-1            102.6.1-1
              thunderbird-i18n-pt-br            102.6.0-1            102.6.1-1
              thunderbird-i18n-pt-pt            102.6.0-1            102.6.1-1
                 thunderbird-i18n-rm            102.6.0-1            102.6.1-1
                 thunderbird-i18n-ro            102.6.0-1            102.6.1-1
                 thunderbird-i18n-ru            102.6.0-1            102.6.1-1
                 thunderbird-i18n-sk            102.6.0-1            102.6.1-1
                 thunderbird-i18n-sl            102.6.0-1            102.6.1-1
                 thunderbird-i18n-sq            102.6.0-1            102.6.1-1
                 thunderbird-i18n-sr            102.6.0-1            102.6.1-1
              thunderbird-i18n-sv-se            102.6.0-1            102.6.1-1
                 thunderbird-i18n-th            102.6.0-1            102.6.1-1
                 thunderbird-i18n-tr            102.6.0-1            102.6.1-1
                 thunderbird-i18n-uk            102.6.0-1            102.6.1-1
                 thunderbird-i18n-uz            102.6.0-1            102.6.1-1
                 thunderbird-i18n-vi            102.6.0-1            102.6.1-1
              thunderbird-i18n-zh-cn            102.6.0-1            102.6.1-1
              thunderbird-i18n-zh-tw            102.6.0-1            102.6.1-1
                       virglrenderer             0.10.3-1             0.10.3-2
            vulkan-validation-layers          1.3.224.1-1          1.3.231.1-1
                          webkit2gtk             2.38.2-2             2.38.3-1
                      webkit2gtk-4.1             2.38.2-2             2.38.3-1
                 webkit2gtk-4.1-docs             2.38.2-2             2.38.3-1
                      webkit2gtk-5.0             2.38.2-2             2.38.3-1
                 webkit2gtk-5.0-docs             2.38.2-2             2.38.3-1
                     webkit2gtk-docs             2.38.2-2             2.38.3-1
                            xcb-util              0.4.0-4              0.4.1-1
                       xfce4-notifyd              0.6.4-2              0.6.5-1
                 xfce4-screenshooter             1.10.0-1             1.10.1-2
                      xfce4-settings             4.18.0-1             4.18.1-1
                   xfce4-taskmanager              1.5.4-1              1.5.5-1
                         xorg-server             21.1.5-1             21.1.6-1
                  xorg-server-common             21.1.5-1             21.1.6-1
                   xorg-server-devel             21.1.5-1             21.1.6-1
                  xorg-server-xephyr             21.1.5-1             21.1.6-1
                   xorg-server-xnest             21.1.5-1             21.1.6-1
                    xorg-server-xvfb             21.1.5-1             21.1.6-1
                       xorg-xdriinfo              1.0.6-3              1.0.7-1
                       xorg-xwayland             22.1.6-1             22.1.7-1
                         libwbclient                    -             4.17.4-2
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi22.12.0.r12865.g2b8e57846-122.12.0.r12866.g3c9d75b18-1
                    akonadi-calendar22.12.0.r2229.g23f871f-122.12.0.r2238.g9fa16a3-1
              akonadi-calendar-tools22.12.0.r988.gdfbf920-122.12.0.r989.g38ec37f-1
                        akonadi-mime22.12.0.r1793.g273a99c-122.12.0.r1794.gfe85873-1
                      akonadi-search22.12.0.r1307.g2825827-122.12.0.r1310.g8f5fdd4-1
                      akonadiconsole22.12.0.r1638.g623908e-122.12.0.r1639.g1402f67-1
                           akregator22.12.0.r6529.g3c222264-122.12.0.r6531.g64fdf372-1
                           alligator 22.11.r14.g5e0aac9-1 22.11.r15.gcde14df-1
                           angelfish 22.11.r17.g059495c-1 22.11.r18.g5841cdc-1
                                 ark22.12.0.r4968.ga660fb58-122.12.0.r4969.g1165b92b-1
                          artikulate22.12.0.r1475.gf29766f-122.12.0.r1477.gd5ff3d7-1
                           audiotube 22.11.r13.g3963eb4-1 22.11.r16.gd14e118-1
                        aura-browser5.26.0.r150.g865f072-15.26.0.r153.gb17567e-1
                       baloo-widgets22.12.0.r787.g792ca65-122.12.0.r799.g8e59e92-1
                           bluedevil1:5.26.4.r2525.g76888dd1-11:5.26.4.r2534.gd989999c-1
                              breeze5.26.4.r2533.gd50d9468-15.26.4.r2534.g417e68bf-1
                        breeze-icons5.101.0.r1940.gfc73eba3-15.101.0.r1941.g6cc0aad2-1
                            discover5.26.4.r9083.gb5248576c-15.26.4.r9097.gab37017a9-1
                             dolphin22.12.0.r7195.g0e22101ac-122.12.0.r7200.gb508215d3-1
                              dragon22.12.0.r1118.g4af295c-122.12.0.r1120.g217276b-1
                               elisa22.12.0.r3089.gc15fc54d-122.12.0.r3093.g0325f35c-1
                          elisa-qtmm22.12.0.r3089.gc15fc54d-122.12.0.r3093.g0325f35c-1
                 extra-cmake-modules5.101.0.r3539.gf4e1590d-15.101.0.r3544.gbc3a8b86-1
                           filelight22.12.0.r1280.g4b51723-122.12.0.r1293.gf053bd5-1
                       grantleetheme22.12.0.r447.g278809e-122.12.0.r449.gef5406c-1
                            gwenview22.12.0.r6988.gb4578f37-122.12.0.r6989.g017195b2-1
                           itinerary22.12.0.r2184.g524574e-122.12.0.r2186.ge5b5e11-1
               kaccounts-integration22.12.0.r1309.g2df9387-122.12.0.r1311.g58341ac-1
                        kaddressbook22.12.0.r6281.gbd791c40-122.12.0.r6282.g4ce9bf3c-1
                              kalarm22.12.0.r8158.g12aea306-122.12.0.r8175.g4235c257-1
                                kalk 22.11.r11.g0ebd46a-1 22.11.r15.gb55f58f-1
                             kalzium22.12.0.r4445.g73a2500b-122.12.0.r4446.g5c1ab74b-1
                              kamoso22.12.0.r1506.g54d0170-122.12.0.r1512.g5d60346-1
                            kanagram22.12.0.r1356.g8a7166c-122.12.0.r1357.ga9676e8-1
                             kapidox5.101.0.r581.g6e89a92-15.101.0.r584.gce3a81e-1
                            karchive5.101.0.r592.gdc629e2-15.101.0.r594.g75b7d07-1
                               kasts 22.11.r37.g3caadc0-1 22.11.r48.g2633a4c-1
                                kate22.12.0.r20007.g086d608f1-122.12.0.r20047.gf486848c7-1
                             kbackup22.12.0.r488.gdf665c1-122.12.0.r489.g35e6e55-1
                         kcachegrind22.12.0.r1221.g53f3c79-122.12.0.r1222.g7fd89e1-1
                  kcachegrind-common22.12.0.r1221.g53f3c79-122.12.0.r1222.g7fd89e1-1
                              kclock 22.11.r10.g2a42cec-1 22.11.r16.g5283d2f-1
                      kconfigwidgets5.101.0.r830.gebf18ede-15.101.0.r832.g5f7788dc-1
                           kcontacts1:5.101.0.r3377.g29756ed5-11:5.101.0.r3378.gc0f92be2-1
                         kcoreaddons5.101.0.r1623.g4f35c8d7-15.101.0.r1631.g8ad66b2f-1
                       kde-cli-tools5.26.4.r2017.g25f1936-15.26.4.r2028.g05bc19b-1
                     kde-dev-scripts22.12.0.r4169.g3eb5104-122.12.0.r4170.gf586109-1
                      kdebugsettings22.12.0.r1045.g3a1525c-122.12.0.r1047.g433dc5d-1
                        kdeclarative5.101.0.r1081.gf1571c3-15.101.0.r1084.g9b5d427-1
                          kdeconnect22.12.0.r3625.gf3f580ac-122.12.0.r3632.g29f56dcc-1
                         kdecoration5.26.4.r315.gb9ca603-15.26.4.r316.gdfa74e6-1
                     kdelibs4support5.101.0.r1135.g08168fb3-15.101.0.r1136.g80175c78-1
                            kdenlive22.12.0.r17178.gb09b23b68-122.12.0.r17255.g02cea77f4-1
                       kdepim-addons22.12.0.r4955.gf9f78882b-122.12.0.r4963.gd2fa125dc-1
                    kdeplasma-addons5.26.4.r9206.gc317c7518-15.26.4.r9222.g4d96e53bd-1
                             kdialog22.12.0.r1276.gc490a83e1-122.12.0.r1278.g7d76838d3-1
                           kdoctools5.101.0.r701.g5b420d0-15.101.0.r702.g6ea04e8-1
                          kgeography22.12.0.r1211.gd06380e-122.12.0.r1212.g6473f18-1
                                kget22.12.0.r3269.gb57a4f2d-122.12.0.r3274.g88500f1d-1
                        kglobalaccel5.101.0.r615.ge94d543-15.101.0.r616.gcaea207-1
                         kgoldrunner22.12.0.r1331.g1bb948a-122.12.0.r1332.gf2adf8b-1
                            khangman22.12.0.r1654.gb637036-122.12.0.r1655.g72689de-1
                  khealthcertificate  22.11.r2.gaff4c6f-1  22.11.r3.g206bc08-1
                         khelpcenter22.12.0.r2836.g1d62f530-122.12.0.r2838.g291d35b3-1
                           kholidays1:5.101.0.r1090.gc1654e3-11:5.101.0.r1092.g8ceca1b-1
                            khotkeys5.26.4.r2184.g741bac3-15.26.4.r2187.g998c0a5-1
                               khtml5.101.0.r631.g13141d0-15.101.0.r634.g50a89a2-1
                 kidentitymanagement22.12.0.r3933.g36630862-122.12.0.r3934.gb85a62a9-1
                                 kig22.12.0.r3264.gbbc879f1-122.12.0.r3265.g8e5d726f-1
                         kinfocenter5.26.4.r2241.g3c095b45-15.26.4.r2250.gf066b1a6-1
                                 kio5.101.0.r5961.g1d033c04c-15.101.0.r5970.g36b9540dc-1
                          kio-extras22.12.0.r7438.gd34985da4-122.12.0.r7444.g964714b97-1
                     kirigami-addons1:0.6.1.r5.g0e3fc8b-11:0.6.1.r9.g339fd5b-1
                    kirigami-gallery22.12.0.r303.g407031e-122.12.0.r304.gef7ade2-1
                           kirigami25.101.0.r3531.g0fbebc95-15.101.0.r3540.g14724a13-1
                              kiriki22.12.0.r501.g3b8869d-122.12.0.r502.g6cb570b-1
                         kitemmodels5.101.0.r635.g8344793-15.101.0.r636.gee96d30-1
                               kiten22.12.0.r1236.gd080868-122.12.0.r1237.g930dcf8-1
                          kitinerary22.12.0.r2579.gd6f305d3-122.12.0.r2585.g6c2b3ae9-1
                           kleopatra22.12.0.r7011.gf50e1900-122.12.0.r7032.g9f839740-1
                            klettres22.12.0.r1005.g8d9bc03-122.12.0.r1006.g1b4e268-1
                            klickety22.12.0.r736.gd2236e8-122.12.0.r737.g24f94cf-1
                                kmag22.12.0.r772.gc46593e-122.12.0.r773.gd8e6757-1
                           kmahjongg22.12.0.r1597.g48a36ba-122.12.0.r1598.gb3225d7-1
                               kmail22.12.0.r26680.g550bea1d2-122.12.0.r26700.gb35b1d520-1
                kmail-account-wizard22.12.0.r925.g6710367-122.12.0.r927.g7713319-1
                      kmailtransport22.12.0.r1833.g5b6c62a-122.12.0.r1835.g024d640-1
                           kmenuedit5.26.4.r1119.g2a46d38-15.26.4.r1123.ge8c6290-1
                                kmix22.12.0.r2487.gfafd175e-122.12.0.r2488.gc52a2142-1
                              kmouth22.12.0.r781.g021fce1-122.12.0.r782.gf43bc73-1
                           knewstuff5.101.0.r1439.g5fbeb50c-15.101.0.r1446.g8f2b7dc3-1
                             knights22.12.0.r1193.g78fadcd-122.12.0.r1194.g0f3db93-1
                              knotes22.12.0.r3753.g5f80c0a3-122.12.0.r3757.g9f4bc8bc-1
                             kompare22.12.0.r1208.g58b9290-122.12.0.r1210.gbcb18d5-1
                            kongress  22.11.r2.gcde56a9-1  22.11.r3.gc7b321e-1
                           konqueror22.12.0.r15253.g4df51e7cd-122.12.0.r15256.ga07fc894f-1
                             konsole22.12.0.r8788.g2b4b2e39-122.12.0.r8802.g031ca6f7-1
                             kontact22.12.0.r5619.gaf2b5a3b-122.12.0.r5624.g482d1417-1
                    kontactinterface22.12.0.r728.gfa98307-122.12.0.r733.g3624848-1
                        konversation22.12.0.r9216.gfe3330b8-122.12.0.r9218.g47a339f9-1
                          korganizer22.12.0.r11900.gf391f4440-122.12.0.r11901.g1303454a3-1
                            kpackage5.101.0.r798.ge41e01b-15.101.0.r799.g685f236-1
                              kparts5.101.0.r641.g5df4f7d-15.101.0.r642.g475401e-1
                             kpeople5.101.0.r1407.g01aa953-15.101.0.r1408.ga1c11f0-1
                        kpeoplevcard   0.1.r55.ga17d6a8-1   0.1.r57.g847df8a-1
                        kpimtextedit22.12.0.r1734.g4d57648-122.12.0.r1736.g10e0f90-1
                           kpipewire5.26.4.r178.g60a4f96-15.26.4.r181.g3f09496-1
                    kpublictransport22.12.0.r2062.gdec79db8-122.12.0.r2070.g1ef36fdc-1
                                krdc22.12.0.r1652.gbc58d52-122.12.0.r1657.g879a73f-1
                           krecorder 22.11.r21.ga17b5c1-1 22.11.r23.g78a332a-1
                            kreversi22.12.0.r1314.gb02f695-122.12.0.r1315.gc5dd5a2-1
                              kruler22.12.0.r774.g56fe588-122.12.0.r776.g2ab4d97-1
                           ksanecore      r658.g58093c5-1      r660.g1b80e58-1
                             kscreen5.26.4.r1625.g2ced020-15.26.4.r1636.gdbb98be-1
                       kscreenlocker5.26.4.r1038.gf116f85-15.26.4.r1043.g4b19732-1
                            kservice5.101.0.r1057.gdcd94bf-15.101.0.r1063.g3c2ce08-1
                             kshisen22.12.0.r1278.gf3869f3-122.12.0.r1280.g2895137-1
                               ksirk22.12.0.r1089.g2be48fc-122.12.0.r1091.g8f83d99-1
                         ksshaskpass5.26.4.r234.gc2b51bf-15.26.4.r235.gab04982-1
                             ksudoku22.12.0.r1156.gb5b62ed-122.12.0.r1158.gc288555-1
                           ksysguard5.26.4.r3568.g049afcad-15.26.4.r3569.ge44ce920-1
                          ksystemlog22.12.0.r787.g5890ba3-122.12.0.r789.ga9d0a80-1
                         ktexteditor5.101.0.r3680.g03080ea2-15.101.0.r3686.gfa426486-1
                        ktextwidgets5.101.0.r483.g4b4de3f-15.101.0.r485.g694595f-1
                               ktnef22.12.0.r759.ga6a2b4f-122.12.0.r762.gccba639-1
                            ktorrent22.12.0.r2928.gd6ebfb7e-122.12.0.r2930.g8994ce70-1
                              ktouch22.12.0.r2225.gadc1a00-122.12.0.r2227.gc7065f4-1
                     kunitconversion5.101.0.r461.gdbb9515-15.101.0.r463.g80f0d48-1
                             kwallet5.101.0.r1213.g4ecc347-15.101.0.r1214.g85ee8a9-1
                      kwalletmanager22.12.0.r1353.g688d924-122.12.0.r1357.gbfc0d8c-1
                               kwave22.12.0.r3836.g608c1016-122.12.0.r3837.gf1aaf8f5-1
                            kwayland5.101.0.r1200.ga566356-15.101.0.r1201.gf2e9002-1
                            kweather 22.11.r13.g01c7627-1 22.11.r14.g31b5819-1
                                kwin5.26.4.r23744.gbf48c3b80-15.26.4.r23812.g8c5f8e2fa-1
                       kwindowsystem5.101.0.r729.g65d27e2-15.101.0.r730.gc01039b-1
                           kwordquiz22.12.0.r1254.g90b4082-122.12.0.r1257.gfa2ea69-1
                              kwrite22.12.0.r20007.g086d608f1-122.12.0.r20047.gf486848c7-1
                             kwrited5.26.4.r520.g5ddc413-15.26.4.r521.g21190ee-1
                             kxmlgui5.101.0.r940.gca26767d-15.101.0.r941.g4f3cdf47-1
                          libakonadi22.12.0.r12865.g2b8e57846-122.12.0.r12866.g3c9d75b18-1
                           libkdcraw22.12.0.r1155.g26e8429-122.12.0.r1156.g0843c60-1
                             libkipi22.12.0.r1282.gabe801d-122.12.0.r1287.gd143c44-1
                             libkleo22.12.0.r1352.g884d8b4-122.12.0.r1353.gd866af3-1
                        libkmahjongg22.12.0.r509.g9d53e9d-122.12.0.r510.g7edd616-1
                            libksane22.12.0.r625.g99e05d6-122.12.0.r626.ge287409-1
                          libkscreen5.26.4.r1706.g68a389c-15.26.4.r1709.ge84d610-1
                           libksieve22.12.0.r1789.g6228d0d5-122.12.0.r1791.g44d761d6-1
                        libksysguard5.26.4.r2496.gf935b77-15.26.4.r2498.gf9579bd-1
                          mailcommon22.12.0.r1351.g21a88f8-122.12.0.r1352.g62683ab-1
                        mailimporter22.12.0.r568.gfb93eb2-122.12.0.r569.g1cf5013-1
                              marble22.12.0.r13530.g373ef623f-122.12.0.r13533.g0f289d578-1
                       marble-common22.12.0.r13530.g373ef623f-122.12.0.r13533.g0f289d578-1
                           marble-qt22.12.0.r13530.g373ef623f-122.12.0.r13533.g0f289d578-1
                             mauikit2.2.1.r20.g5e525e1a-12.2.1.r23.g67aadca4-1
                    mauikit-accounts  2.2.1.r7.gcf46949-1  2.2.1.r9.g60d88a6-1
                mauikit-filebrowsing 2.2.0.r31.g5a3b152-1 2.2.0.r35.geb16ddf-1
                  mauikit-texteditor  2.2.1.r7.gd42b585-1  2.2.1.r9.g86889d0-1
                          messagelib22.12.0.r6808.gbb53e0954-122.12.0.r6826.ga030bcf6e-1
                              minuet22.12.0.r648.g49a9fcb-122.12.0.r652.gb2ee1fb-1
                     modemmanager-qt5.101.0.r570.g43cf85b-15.101.0.r572.g10ea45a-1
                             neochat22.11.r42.g907d52d6-122.11.r52.gcdbf5ea8-1
                              okular22.12.0.r9913.g048349d33-122.12.0.r9917.g38438b00b-1
                              oxygen5.26.4.r4534.ge04d43dc-15.26.4.r4535.g1d2d1d5e-1
                              parley22.12.0.r4571.gc20d236c-122.12.0.r4572.g690cda7b-1
                    partitionmanager22.12.0.r1700.gc615bd3-122.12.0.r1705.g76bf9e0-1
                   pim-data-exporter22.12.0.r2836.g0fab0aa5-122.12.0.r2840.g0f155ccc-1
                           pimcommon22.08.3.r1830.g8fcadf93-122.08.3.r1841.geb2c2f10-1
                        plank-player5.26.0.r105.g3ad5676-15.26.0.r107.g28f0581-1
                    plasma-bigscreen5.26.0.r585.g62d870a-15.26.0.r590.g63c6f89-1
          plasma-browser-integration5.26.4.r1401.g82816df9-15.26.4.r1402.g7d6e0d80-1
                      plasma-desktop5.26.4.r9918.gd89d6f48f-15.26.4.r9936.g97b0957c0-1
                       plasma-dialer 22.11.r14.g7627469-1 22.11.r18.gc7b9512-1
                     plasma-firewall5.26.4.r693.g3067cb2-15.26.4.r697.gffac520-1
                    plasma-framework5.101.0.r16568.g6b3ec4b0c-15.101.0.r16569.gdd61557a2-1
                  plasma-integration5.26.4.r613.gcb3231e-15.26.4.r614.g62e323b-1
                       plasma-mobile5.26.4.r2092.g395f5ccdc-15.26.4.r2100.ge38df038c-1
                    plasma-mobile-nm5.26.4.r3462.g4e1d7d81-15.26.4.r3479.g4654501e-1
                         plasma-nano5.26.4.r212.g557ecdf-15.26.4.r213.g184864d-1
                           plasma-nm5.26.4.r3462.g4e1d7d81-15.26.4.r3479.g4654501e-1
                           plasma-pa5.26.4.r1155.ga01dee6-15.26.4.r1156.gd02243f-1
                    plasma-phonebook  22.11.r7.g04b3c6c-1 22.11.r11.g374ba0e-1
            plasma-remotecontrollers5.26.0.r203.ge53fcd5-15.26.0.r206.g2faf02f-1
                          plasma-sdk5.26.4.r2452.g865bdeb8-15.26.4.r2454.g482ff1fe-1
                     plasma-settings  22.11.r9.g67a8602-1 22.11.r11.gd81b4f2-1
                plasma-systemmonitor5.26.4.r664.g349dc01-15.26.4.r665.ga2bebfa-1
              plasma-wayland-session5.26.4.r12992.ga0e9d9e31-15.26.4.r13028.geb2428ffc-1
                    plasma-workspace5.26.4.r12992.ga0e9d9e31-15.26.4.r13028.geb2428ffc-1
                          plasmatube  22.11.r4.g9c9da20-1 22.11.r24.g37dd9f3-1
                          powerdevil5.26.4.r2649.g82c1045e-15.26.4.r2653.g7128c087-1
                       print-manager22.12.0.r1214.g5e8c656-122.12.0.r1215.gc5a4ddf-1
                             purpose5.101.0.r1043.gaf00a2c-15.101.0.r1045.g1ce2b97-1
                         qcachegrind22.12.0.r1221.g53f3c79-122.12.0.r1222.g7fd89e1-1
                                rocs22.12.0.r3155.g1dcae0ea-122.12.0.r3156.g0ed95000-1
                               solid5.101.0.r831.g4b07132-15.101.0.r836.g37f697f-1
                              sonnet5.101.0.r741.g53ab432-15.101.0.r743.g04b5ff7-1
                            spacebar  22.11.r8.g2169eeb-1 22.11.r13.ge80a227-1
                           spectacle22.12.0.r1448.g9b51a50-122.12.0.r1458.ge576fd8-1
                                step22.12.0.r1282.gebc4e93-122.12.0.r1283.gda14d24-1
                             svgpart22.12.0.r257.g7c845bc-122.12.0.r260.gc11d2f6-1
                 syntax-highlighting5.101.0.r2045.g6b969864-15.101.0.r2052.g10fe5c3b-1
                      systemsettings5.26.4.r2785.g74727e7a-15.26.4.r2788.gcddeecd9-1
          telepathy-kde-accounts-kcm22.12.0.r1235.ga0ea27d-122.12.0.r1237.g2d15da5-1
          telepathy-kde-contact-list22.12.0.r1111.gd96a8a8-122.12.0.r1112.gd99e30d-1
               telepathy-kde-text-ui22.12.0.r2072.g5d630da9-122.12.0.r2076.g34addf43-1
                             tokodon22.11.1.r19.g8532b9c-122.11.2.r26.gad34600-1
                         vakzination  22.11.r5.g5c0738e-1  22.11.r7.ga1c54f4-1
                               vvave 2.2.1.r13.g8c9f1ae-1 2.2.1.r16.g360ca19-1
              xdg-desktop-portal-kde5.26.4.r582.gc53684f-15.26.4.r589.g8f2ab1d-1
                             yakuake22.12.0.r861.g63cc5a2-122.12.0.r894.g24dc69a-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
2022-11-20
OpenSSL 1.1 library not found
Some applications might still be looking for openssl 1.1.
Solution: Install openssl-1.1 package with sudo pacman -S openssl-1.1.
2022-10-31
Firefox shows wrong colors when playing video on Raspberry Pi 4
Since Mesa 22.2, Firefox has been showing weird colors when playing video on the Raspberry Pi 4. This is caused by an issue in upstream mesa, which was recently fixed.
Fix: Update to mesa 22.2.3-0.1 in the repository, which includes this fix.
Chromium in Wayland crashes with --in-process-gpu
Since Mesa 22.2.0, Chromium running in wayland sessions seems to crash when running with the --in-process-gpu option. Running in X11 seems fine, although it’s slow.
Workaround: Downgrade to mesa 22.1.7 from cache with sudo pacman -U /var/cache/pacman/pkg/mesa-22.1.7-*, until the issue is fixed upstream.
2022-10-21
Plasma Mobile Dialer seems to be unreliable
Plasma Dialer 22.09 seems to have issues switching audio profiles and as such might require manual switching. Sometimes audio is completely missing.
Reduced video performance on youtube
Some may encounter reduced video playback performance on YouTube in Firefox with the new Mesa 22.2 drivers.
No workaround at this time.
Old Issues
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
[Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Webpages in Firefox still don’t accept touch input of any kind, at least not on Pinephone (Phosh). Firefox 107.1 works.
Maybe the mobile config needs to be updated to 108. It appears that Firefox changed a lot of stuff under the hood in 108.
Hi @Strit & @spikerguy,
With the latest Unstable Branch (updated today) with mesa-22.3.2-1 Chromium Wayland includding with “–in-process-gpu” now works with GPU Acceleration.
Thank you.
Wishing All A Happy Prosperous New Year!
[ARM Testing Update] 2023-02-11 - LibreOffice, KDE Gear, Mesa , Waydroid and kernels
[ARM Testing Update] 2023-02-02 - Kernels, Phosh, Thunderbird, Firefox, Pipewire
[ARM Testing Update] 2023-10-21 - Kernels, PipeWire, KDE Gear & Frameworks, Thunderbird
[ARM Testing Update] 2023-03-30 - Phosh, Blender, Kernels, Thunderbird, Xorg-Server, KDE-git
[ARM Stable Update] 2023-06-21 - Kernels, Apple Silicon, Wireplumber, KDE-git
[ARM Testing Update] 2023-05-04 - Kernels, Firmware, Firefox, Thunderbird, KDE Gear, Phosh, Pipewire
[ARM Testing Update] 2023-04-06 - Phosh, Systemd, LibreOffice 7.5.2, Qemu, KDE-git
[ARM Testing Update] 2023-04-14 - Kernels, Plasma, Frameworks, Thunderbird, Firefox
[ARM Stable Update] 2023-06-12 - Kernels, Apple Silicon, Calls 44.2, LibPamac
[ARM Testing Update] 2023-05-16 - Kernels, Pamac 11, CallaudioD, Chatty, KDE-git
[ARM Stable Update] 2023-05-27 - Kernels, Firmware, Pipewire, Phosh, KDE Gear, Qemu
[ARM Testing Update] 2023-05-31 - Kernels, Gnome 44, Plasma 5.27.5, Firefox, LibreOffice, Python 3.11
[ARM Testing Update] 2023-06-26 - Kernels, KDE, Systemd, Pamac, LibreOffice, Qemu
[ARM Testing Update] 2023-06-30 - Kernel, Linux-Firmware, Plymouth, Blender 3.6, KDE-git
[ARM Stable Update] 2023-07-08 - Kernels, KDE Frameworks, systemd, LibreOffice, Pipewire, (Community to Extra Migration)
[ARM Testing Update] 2023-08-19 - Kernel, ICU, Systemd, KDE, Phosh, LibreOffice, Firefox
[ARM Stable Update] 2023-09-28 - Kernels, LibPamac, KDE, Gnome, Firefox, Pipewire, Thunderbird
[ARM Testing Update] 2023-09-28 - Kernels, Firefox, Thunderbird, Plasma, KDE Gear, LibreOffice, Systemd
[ARM Stable Update] 2023-10-01 - Kernels, Systemd, KDE, Firefox, Thunderbird, LibreOffice
[ARM Testing Update] 2023-10-13 - KDE Frameworks, Gnome 45, Firefox, Thunderbird, PipeWire, Qt5
[ARM Stable Update] 2023-12-05 - Kernels, Firefox, Thunderbird, LibreOffice, KDE
[ARM Stable Update] 2023-11-15 - Kernels, OPI5-Plus, KODI, Plasma, Pipewire, Plasma, Gnome 45
[ARM Stable Update] 2023-09-10 - Kernel, Phosh, LibreOffice, Firefox, Systemd
[ARM Stable Update] 2024-01-04 - Kernels, Bluez, KODI, Firefox, Thunderbird, Pamac, Plasma, KDE Gear, Pipewire
[ARM Testing Update] 2023-04-20 - Kenrels, LxQt 1.3.0, Firefox, Pipewire
[ARM Stable Update] 2023-06-06 - Kernels, Plasma, KDE Gear, KDE Frameworks, Python 3.11, Gnome 44.1
[ARM Stable Update] 2024-03-14 - Kernels, KDE, Firefox, Thunderbird, Systemd, Mesa, Pipewire
[ARM Testing Update] 2023-06-09 - Kernels, Apple Silicon, Mobile, KDE-git
[ARM Stable Update] 2023-04-27 - Plasma 5.27.4, Phosh 0.26, Apple Silicon Support, Pamac, LibreOffice
[ARM Stable Update] 2023-01-24 - QT, PHP 8.2, LLVM/Clang 15, Firefox 109, Sway 1.8 and Kernels
[ARM Testing Update] 2023-01-15 - LibreOffice, PHP, Pipewire and kernels
[ARM Testing Update] 2023-03-25 - Apple Silicon, Pamac 11.0-rc1, Firefox
[ARM Testing Update] 2023-03-20 - Kernels, Plasma 5.27.3, Pamac, Firefox, LibreOffice, Thunderbird
[ARM Stable Update] 2023-01-03 - Handbrake 1.6, Breath 22.0, XFCE 4.18, Mesa 22.3 and Kernels
[ARM Stable Update] 2023-02-16 - Firefox 110, PlaMo Gear 23.01, Mesa, LibreOffice 7.5 and Kernels
GT King Pro Manjaro-Arm-Gnome-linux-aml-6.0.13-1 up to date on Testing Branch.
Also upgraded to mesa-22.3.2-1 from Unstable Branch. With the latest stable mesa-22.3.2-1 now Chromium Wayland works with GPU Acceleration. As pointed out on the earlier post.
Very good to hear.
