[ARM Testing Update] 2022-11-26 - LibreOffice, Mkinitcpio and kernels
Hello ARM community.
A small update this time.
Some highlights:
  • Most of our kernels got updated
  • LibreOffice updated to 7.4.3
  • Mkinitcpio updated to 33
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sat Nov 26 08:51:09 CET 2022)
  • arm-testing community aarch64: 364 new and 360 removed package(s)
  • arm-testing core aarch64: 41 new and 40 removed package(s)
  • arm-testing extra aarch64: 191 new and 191 removed package(s)
  • arm-testing kde-unstable aarch64: 353 new and 353 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2022-11-20         2022-11-26
                     asahi-fwextract            0.5pre1-2            0.5pre2-2
                       asahi-scripts         20220918.2-4         20221122-3.0
                          callaudiod   0.1.4+9+g7f2c637-1   0.1.4+9+g7f2c637-2
                            electron             21.3.0-1             21.3.1-1
                          electron19             19.1.6-1             19.1.7-1
                          electron20             20.3.5-1             20.3.7-1
                     element-desktop            1.11.14-1            1.11.15-1
                         element-web            1.11.14-1            1.11.15-1
                  gnome-shell-mobile43.0+r263+gfd58fd44e-143.1+r245+g4ef0db259-1
                           gradience              0.3.1-4              0.3.2-1
                          libgbinder             1.1.27-1             1.1.29-1
                       mutter-mobile43.0+r163+g9bd6ecb44-143.1+r124+g4e6674075-1
                          rpi-eeprom           20221104-1           20221125-1
                                vvmd               0.11-1               0.13-1
:: Different sync package(s) in repository community aarch64
                             acme.sh              3.0.4-1              3.0.5-1
                          aliyun-cli            3.0.131-1            3.0.136-1
                                amtk              5.6.0-1              5.6.1-1
                             ansible              6.6.0-1              7.0.0-1
                        ansible-lint              6.8.6-1              6.9.0-1
                               arrow              9.0.0-3             10.0.0-1
                              awxkit             21.8.0-1             21.9.0-1
                               b3sum              1.3.1-1              1.3.2-1
                bash-language-server              3.1.1-1              3.2.0-1
                             bchoppr             1.12.0-1             1.12.2-1
                            binaryen              1:110-1              1:111-1
                         bitcoin-cli               23.0-1               24.0-1
                      bitcoin-daemon               23.0-1               24.0-1
                          bitcoin-qt               23.0-1               24.0-1
                          bitcoin-tx               23.0-1               24.0-1
                             blueman              2.3.4-1              2.3.5-1
                             calibre              6.8.0-2              6.9.0-1
                        cargo-expand             1.0.32-1             1.0.35-1
                  cargo-supply-chain              0.3.1-1              0.3.2-1
                       cartridge-cli             2.12.2-1             2.12.3-1
                              ccache              4.7.3-1              4.7.4-2
                          cherrytree            0.99.51-1            0.99.52-1
                             chezmoi             2.27.1-1             2.27.2-1
                cinnamon-screensaver              5.6.0-1              5.6.1-1
                                 cjs              5.6.0-1              5.6.1-1
                         cloudflared          2022.10.3-1          2022.11.0-1
                             cockpit                279-1                280-1
                    cockpit-machines                277-1                278-1
                  cockpit-packagekit                279-1                280-1
                         cockpit-pcp                279-1                280-1
                      cockpit-podman                 56-1                 57-1
                    cockpit-storaged                279-1                280-1
                              coturn              4.6.0-2              4.6.0-3
                            cppcheck              2.9.2-1              2.9.3-1
                               crash              8.0.1-2              8.0.2-1
                                crun                1.7-1              1.7.1-1
                              direnv             2.32.1-1             2.32.2-1
                             dnsperf              2.9.0-3             2.10.0-1
                      docker-compose             2.12.2-1             2.13.0-1
                               doctl             1.87.0-1             1.88.0-1
                                dpdk              22.07-2              22.07-3
                           drone-cli              1.6.1-1              1.6.2-1
                                 dub             1.29.2-1             1.30.0-2
                                dune              3.4.1-2              3.6.1-1
                      emacs-php-mode             1.24.1-1             1.24.2-1
                             esptool                4.3-2                4.4-1
                                 etl              1.4.2-1              1.4.3-1
                           exploitdb           20221112-1           20221122-1
                              fcitx5             5.0.19-1             5.0.21-1
                        fcitx5-anthy             5.0.12-1             5.0.13-1
                      fcitx5-chewing             5.0.12-1             5.0.13-1
               fcitx5-chinese-addons             5.0.15-3             5.0.16-1
                   fcitx5-configtool             5.0.15-1             5.0.16-1
                          fcitx5-gtk             5.0.19-1             5.0.21-1
                          fcitx5-kkc             5.0.10-1             5.0.11-1
                         fcitx5-m17n             5.0.10-1             5.0.11-1
                           fcitx5-qt             5.0.15-1             5.0.16-1
                          fcitx5-skk             5.0.13-1             5.0.14-1
                  fcitx5-table-extra             5.0.11-1             5.0.12-1
                       fcitx5-unikey             5.0.11-1             5.0.12-1
                                ferm              2.5.1-2                2.7-1
                           filezilla             3.62.1-1             3.62.2-1
                         firecracker              1.1.2-1              1.1.3-1
                    firecracker-docs              1.1.2-1              1.1.3-1
                         flatbuffers           22.10.26-1           22.11.23-1
                          freeradius              3.2.1-3              3.2.1-4
                                gdal              3.5.3-3              3.6.0-2
                            gearmand           1.1.19.1-4             1.1.20-2
                               gedit               43.2-1               43.2-2
                               gerbv              2.9.3-1              2.9.4-1
                              getdns              1.7.0-2              1.7.2-1
                           git-cliff              0.9.2-1             0.10.0-1
                       gitlab-runner             15.5.1-1             15.6.1-1
                                 gmt              6.4.0-1              6.4.0-2
                             gmt-doc              6.4.0-1              6.4.0-2
                         gnome-latex             3.42.0-1             3.42.0-2
                               gnubg           1.06.002-7           1.07.001-1
                         goattracker               2.76-2               2.76-3
                              gpxsee               11.7-1               11.9-1
                                grpc             1.50.1-2             1.51.0-1
                            grpc-cli             1.50.1-2             1.51.0-1
                          hexer-hobu              1.4.0-8              1.4.0-9
                             hiredis              1.0.2-1              1.1.0-1
                                i2pd             2.43.0-3             2.44.0-1
                              icmake           10.03.01-2           10.03.02-1
                               isync              1.4.4-2              1.4.4-3
            java-xmlgraphics-commons                2.7-1                    -
                jedi-language-server             0.38.0-1             0.39.0-1
                             jenkins              2.378-1              2.379-1
                                jmol           14.32.80-1           14.32.81-1
                               jruby            9.3.9.0-1            9.4.0.0-1
                               jsmol           14.32.80-1           14.32.81-1
                      jupyter-server             1.23.2-1             1.23.3-1
                                knot              3.2.2-2              3.2.3-1
                            krusader              2.7.2-4              2.8.0-1
                                kubo             0.16.0-1             0.17.0-1
                              libime             1.0.14-2             1.0.15-1
                              liblas1.8.1.r128+gded46373-21.8.1.r128+gded46373-3
                             libnewt            0.52.21-8            0.52.22-1
              libperconaserverclient          8.0.29_21-5          8.0.30_22-1
                  libretro-core-info             1.12.0-1             1.13.0-1
                              luajit2.1.0.beta3.r449.gdad04f17-12.1.0.beta3.r455.g46aa45dc-1
                        man-pages-cs             4.15.0-1             4.16.0-1
                        man-pages-da             4.15.0-1             4.16.0-1
                        man-pages-de             4.15.0-1             4.16.0-1
                        man-pages-el             4.15.0-1             4.16.0-1
                        man-pages-es             4.15.0-1             4.16.0-1
                        man-pages-fi             4.15.0-1             4.16.0-1
                        man-pages-fr             4.15.0-1             4.16.0-1
                        man-pages-hu             4.15.0-1             4.16.0-1
                        man-pages-id             4.15.0-1             4.16.0-1
                        man-pages-it             4.15.0-1             4.16.0-1
                        man-pages-mk             4.15.0-1             4.16.0-1
                        man-pages-nb             4.15.0-1             4.16.0-1
                        man-pages-nl             4.15.0-1             4.16.0-1
                        man-pages-pl             4.15.0-1             4.16.0-1
                     man-pages-pt_br             4.15.0-1             4.16.0-1
                        man-pages-ro             4.15.0-1             4.16.0-1
                        man-pages-sr             4.15.0-1             4.16.0-1
                        man-pages-sv             4.15.0-1             4.16.0-1
                        man-pages-uk             4.15.0-1             4.16.0-1
                        man-pages-vi             4.15.0-1             4.16.0-1
                              mapnik             3.1.0-14             3.1.0-15
                              marked              4.2.2-1              4.2.3-1
                          marked-man              1.2.1-1              1.2.3-1
                             maturin             0.13.7-1             0.14.2-1
                          merkaartor             0.19.0-3             0.19.0-4
                        meson-python             0.10.0-1             0.11.0-1
                            minetest              5.6.1-1              5.6.1-2
                     minetest-common              5.6.1-1              5.6.1-2
                     minetest-server              5.6.1-1              5.6.1-2
                   mitmproxy2swagger              0.7.0-2              0.7.1-1
                               mmctl              7.5.0-1              7.5.1-1
                         msgpack-cxx              4.1.2-1              4.1.3-1
                              mumble            1.4.287-4            1.4.287-5
                              murmur            1.4.287-4            1.4.287-5
                                 mvt                2.2-1              2.2.1-1
                               mympd             10.1.1-1             10.1.2-1
                                mypy              0.991-1              0.991-2
                     mysql-workbench             8.0.31-1             8.0.31-2
                   nautilus-terminal              3.5.0-2              4.1.0-1
                                nemo              5.4.3-1              5.6.0-1
                           newsflash              2.1.2-2              2.2.2-1
                                 nnn                4.6-1                4.7-1
                               nomad              1.4.2-1              1.4.3-1
                   npm-check-updates            16.3.20-1            16.3.23-1
                         ocaml-cairo              0.6.3-2              0.6.4-1
                      openscenegraph             3.6.5-14             3.6.5-15
                            opensips              3.3.0-2              3.3.2-1
           opensmtpd-filter-dkimsign                0.5-3                0.6-1
                              openxr             1.0.25-1             1.0.26-1
                     pacman-bintrans              0.3.0-2              0.4.0-1
               pacman-bintrans-tools              0.3.0-2              0.4.0-1
                            parallel           20221022-1           20221122-1
                       parallel-docs           20221022-1           20221122-1
                                pdal              2.4.3-2              2.4.3-3
                      percona-server          8.0.29_21-5          8.0.30_22-1
              percona-server-clients          8.0.29_21-5          8.0.30_22-1
                           perl-tidy           20220613-1           20221112-1
                            php-grpc             1.50.1-2             1.51.0-1
                         php-mongodb             1.14.2-2             1.15.0-1
                           php7-grpc             1.50.1-2             1.51.0-1
                        php7-mongodb             1.14.2-2             1.15.0-1
                              picard              2.8.3-1              2.8.4-1
                               picom                 10-1               10.1-1
                         pipe-rename              1.6.0-1              1.6.1-1
                     plantuml-server          1.2022.12-1          1.2022.13-1
                             plocate             1.1.16-1             1.1.17-1
                         pmbootstrap             1.49.0-1             1.50.0-1
                              podman              4.3.1-1              4.3.1-2
                       podman-docker              4.3.1-1              4.3.1-2
                             postgis              3.3.1-1              3.3.2-1
                   powerdns-recursor              4.7.3-2              4.7.4-1
       prometheus-wireguard-exporter              3.6.3-1              3.6.6-1
                             pyright            1.1.280-1            1.1.281-1
                      python-apispec              6.0.1-1              6.0.2-1
                  python-autocommand              2.2.1-1              2.2.2-1
           python-aws-sam-translator             1.53.0-1             1.54.0-1
                       python-awscrt             0.14.7-1             0.15.3-1
                        python-bleak             0.19.4-1             0.19.5-1
                python-canonicaljson              1.6.3-1              1.6.4-1
                     python-cfn-lint             0.68.1-1             0.72.0-1
                         python-cleo            1.0.0a5-2              2.0.1-3
                        python-cliff              4.0.0-2              4.1.0-1
                   python-cloudflare             2.10.4-1             2.10.5-1
                      python-cpplint              1.6.1-1              1.6.1-2
                        python-crate             0.27.1-1             0.27.2-1
                       python-debian             0.1.48-1             0.1.49-1
              python-designateclient              5.0.0-1              5.1.0-1
         python-django-debug-toolbar                3.5-1                3.7-1
                        python-faker             12.1.0-1             12.3.0-1
                        python-fiona             1.8.22-1             1.8.22-2
                 python-flake8-black              0.3.4-1              0.3.5-1
                  python-flask-dance              6.1.0-2              6.2.0-1
                  python-flatbuffers           22.10.26-1           22.11.23-1
                         python-gdal              3.5.3-3              3.6.0-2
                        python-gdstk              0.9.2-1              0.9.3-1
     python-googleapis-common-protos             1.56.4-1             1.57.0-1
                       python-grpcio             1.50.1-2             1.51.0-1
                 python-grpcio-tools             1.50.1-2             1.51.0-1
                     python-httpcore             0.16.0-1             0.16.1-1
                        python-httpx             0.23.0-2             0.23.1-1
                    python-icalendar              5.0.2-1              5.0.3-1
                     python-ini2toml             0.11.1-1             0.11.3-1
                    python-iosbackup            0.9.923-2            0.9.925-1
                    python-ipykernel             6.17.1-1             6.18.0-1
                        python-j2cli            0.3.12b-5            0.3.12b-6
               python-jaraco.context              4.1.2-1              4.2.0-1
                  python-jaraco.text             3.10.0-1             3.11.0-1
                  python-json-stream              1.4.0-1              2.1.0-1
                   python-jsonschema             4.17.0-1             4.17.1-1
                python-keystoneauth1              5.0.0-2              5.1.0-1
                 python-linux-procfs              0.7.0-1              0.7.1-1
                         python-lupa               1.13-1             1.14.1-1
              python-memory-profiler               0.60-1               0.61-1
          python-mitmproxy-wireguard             0.1.18-1             0.1.19-1
                         python-moto              4.0.9-1             4.0.10-1
                       python-mpi4py              3.1.3-2              3.1.4-1
                     python-nbsphinx              0.8.9-1             0.8.10-1
                python-neutronclient              8.1.0-1              8.2.0-1
                   python-novaclient             18.1.0-1             18.2.0-1
                 python-openapi-core             0.16.1-2             0.16.2-1
                       python-orjson              3.8.1-1              3.8.2-1
                     python-oslo-log              5.0.1-1              5.0.2-1
                   python-pdm-pep517            1:1.0.5-1            1:1.0.6-1
                         python-pdoc             12.2.1-1             12.3.0-1
                      python-pip-run              8.8.1-1              8.8.2-1
                       python-poetry              1.2.2-1              1.2.2-2
                  python-poetry-core              1.3.2-1              1.4.0-1
               python-prompt_toolkit             3.0.32-1             3.0.33-1
                 python-psycopg-pool              3.1.3-1              3.1.4-1
                      python-pyarrow              9.0.0-1             10.0.0-1
                  python-pycodestyle              2.9.1-2             2.10.0-1
                       python-pyface              7.4.2-1              7.4.3-1
                       python-pygit2             1.11.0-1             1.11.1-1
                        python-pygls             0.12.1-1             0.13.0-1
                       python-pylint             2.15.5-1             2.15.6-1
                      python-pymongo              4.3.2-1              4.3.3-1
                     python-pynamodb              5.3.0-1              5.3.2-1
                      python-pyogrio              0.4.2-1              0.4.2-2
               python-pytest-enabler              1.3.0-2              1.3.1-1
         python-pytest-rerunfailures               10.2-5               10.3-1
                      python-pytools          2022.1.12-1          2022.1.13-1
                        python-redis              4.3.4-1              4.3.5-2
              python-requirementslib              2.1.0-1              2.2.0-1
          python-scikit-hep-testdata             0.4.21-1             0.4.23-2
                      python-sepaxml              2.5.0-1              2.6.0-1
                      python-shapely              1.8.2-1        1.8.5.post1-1
                        python-shtab              1.5.7-1              1.5.8-1
          python-sphinxext-opengraph              0.7.2-1              0.7.3-1
                    python-structlog             22.1.0-1             22.3.0-1
                    python-texttable              1.6.4-3              1.6.5-1
                    python-u-msgpack              2.7.1-5              2.7.2-1
                      python-unearth              0.6.1-1              0.6.2-1
                   python-weasyprint               57.0-2               57.1-1
                       python-xxhash              3.0.0-1              3.1.0-2
                         python-zeep              4.2.0-1              4.2.1-1
           python-zope-i18nmessageid              5.1.0-1              5.1.1-1
                python-zope-security                5.5-1                5.7-1
                                qgis             3.28.1-1             3.28.1-2
                                 qgo              2.1.0-7              2.1.1-1
                           qmapshack             1.16.1-3             1.16.1-4
                         qpid-proton             0.37.0-3             0.38.0-1
                            qrupdate              1.1.2-4              1.1.5-1
                            quiterss             0.19.4-2                    -
                               redis              7.0.5-2              7.0.5-3
                         rednotebook               2.26-1             2.27.1-1
                                repo             2.29.9-1               2.30-1
                           retroarch             1.12.0-2             1.13.0-2
                             rubocop             1.38.0-2             1.39.0-1
                          ruby-gpgme             2.0.21-1             2.0.22-1
                           ruby-haml              6.0.8-2             6.0.10-1
                        ruby-octokit              6.0.0-1              6.0.1-1
            ruby-rubocop-performance             1.15.0-2             1.15.1-1
                        ruby-sqlite3              1.5.2-2              1.5.4-1
                       rust-analyzer           20221114-3           20221121-1
                             s2n-tls             1.3.27-1             1.3.28-1
                       schemacrawler            16.18.1-1            16.19.1-1
                          sentry-cli              2.7.0-1              2.9.0-1
                          serverless             3.24.1-1             3.25.0-1
                            smplayer             22.7.0-1             22.7.0-2
                              smtube            21.10.0-3                    -
                                 snd               22.8-1               22.9-1
                   srs-state-threads              1.9.4-1              1.9.5-1
                          streamlink              5.1.0-1              5.1.1-1
                              stubby              0.4.0-2              0.4.2-1
                              swappy              1.5.0-1              1.5.1-1
                            swift-im             4.0.2-12                    -
                             swiften             4.0.2-12                    -
                           tailscale             1.32.2-2             1.32.3-1
                                tcsh            6.24.01-2            6.24.02-1
                    telegram-desktop              4.3.1-2              4.3.4-1
                             tellico              3.4.4-1              3.4.5-1
                                tepl            1:6.2.0-2            1:6.2.0-3
                           texstudio              4.3.1-1              4.4.0-1
                              tt-rss 2:r11390.602e86842-1 2:r11392.9a0dcdd6c-1
                         ttc-iosevka             16.3.6-1             16.4.0-1
                    ttc-iosevka-aile             16.3.6-1             16.4.0-1
                   ttc-iosevka-curly             16.3.6-1             16.4.0-1
              ttc-iosevka-curly-slab             16.3.6-1             16.4.0-1
                  ttc-iosevka-etoile             16.3.6-1             16.4.0-1
                    ttc-iosevka-slab             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss01             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss02             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss03             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss04             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss05             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss06             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss07             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss08             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss09             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss10             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss11             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss12             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss13             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss14             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss15             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss16             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss17             16.3.6-1             16.4.0-1
                    ttc-iosevka-ss18             16.3.6-1             16.4.0-1
                               typos            1.12.14-1             1.13.0-1
                             unbound             1.17.0-2             1.17.0-3
                                 upx              4.0.0-1              4.0.1-1
                             uvicorn             0.19.0-1             0.20.0-1
         v2ray-domain-list-community     20221117062320-1     20221124015645-1
                         v2ray-geoip       202211170054-1       202211240054-1
                         vapoursynth                R60-1                R61-1
                              viking                1.9-2               1.10-1
                                 vtk             9.1.0-22             9.1.0-23
                                wabt             1.0.30-1             1.0.31-1
                            wakatime           1:1.55.1-1           1:1.57.0-1
                          warpinator             1.2.14-1             1.2.15-1
                              wasmer              2.3.0-2              3.0.0-1
                            wasmtime              2.0.2-1              3.0.0-1
                              waybar             0.9.15-2             0.9.16-1
                             wezterm20220905.102802.7d4b8249-220221119.145034.49b9839f-1
                           wgetpaste               2.32-1               2.33-1
                           wordpress                6.1-1              6.1.1-1
                         x42-plugins           20221101-1           20221119-1
                          xcb-imdkit              1.0.3-1              1.0.4-1
                                 xed              3.2.7-1              3.2.8-1
                          xtrabackup          8.0.29_22-2          8.0.30_23-1
                              xxhash              0.8.1-2              0.8.1-3
                                 yad               12.0-1               12.1-1
                           yggdrasil              0.4.6-1              0.4.7-1
                                zmap              2.1.1-8              2.1.1-9
                        ceres-solver                    -              2.1.0-3
                       coin-or-lemon                    -              1.3.1-3
                               flann                    -              1.9.2-1
                             git-bug                    -              0.8.0-1
                              opengv                    -           1.0.git1-1
                         python-comm                    -              0.1.1-1
                       python-crc32c                    -                2.3-1
                                 vhs                    -              0.2.0-1
                       virt-firmware                    -                1.6-1
:: Different overlay package(s) in repository core aarch64
                 linux-apple-silicon             5.19.0-5           6.1rc6-5.1
         linux-apple-silicon-headers             5.19.0-5           6.1rc6-5.1
                            linux-rc            6.1.rc5-1            6.1.rc6-1
                    linux-rc-headers            6.1.rc5-1            6.1.rc6-1
                            linux515            5.15.79-2            5.15.79-3
                    linux515-headers            5.15.79-2            5.15.79-3
                             linux60              6.0.9-2              6.0.9-3
                     linux60-headers              6.0.9-2              6.0.9-3
                                m1n1              1.1.5-1              1.1.8-1
                 uboot-apple-silicon            2022.07-1            2022.10-1
            linux-apple-silicon-edge                    -           6.1rc6-5.1
:: Different sync package(s) in repository core aarch64
                           amd-ucode   20221109.60310c2-1   20221109.60310c2-2
                   archlinux-keyring           20221110-1           20221123-1
                              brotli              1.0.9-8              1.0.9-9
                     brotli-testdata              1.0.9-8              1.0.9-9
                               bzip2              1.0.8-4              1.0.8-5
                                gawk              5.2.0-3              5.2.1-1
                                 icu               72.1-1               72.1-2
                             libedit       20210910_3.1-1       20210910_3.1-2
                           libxcrypt             4.4.31-1             4.4.33-1
                    libxcrypt-compat             4.4.31-1             4.4.33-1
                      linux-firmware   20221109.60310c2-1   20221109.60310c2-2
                linux-firmware-bnx2x   20221109.60310c2-1   20221109.60310c2-2
             linux-firmware-liquidio   20221109.60310c2-1   20221109.60310c2-2
              linux-firmware-marvell   20221109.60310c2-1   20221109.60310c2-2
             linux-firmware-mellanox   20221109.60310c2-1   20221109.60310c2-2
                  linux-firmware-nfp   20221109.60310c2-1   20221109.60310c2-2
                 linux-firmware-qcom   20221109.60310c2-1   20221109.60310c2-2
               linux-firmware-qlogic   20221109.60310c2-1   20221109.60310c2-2
               linux-firmware-whence   20221109.60310c2-1   20221109.60310c2-2
                                 lzo               2.10-3               2.10-4
                             minizip           1:1.2.13-1           1:1.2.13-2
                          mkinitcpio                 32-2                 33-1
                                mpfr          4.1.0.p13-3              4.1.1-1
                            pciutils              3.8.0-2              3.9.0-1
                       python-brotli              1.0.9-8              1.0.9-9
                             systemd              252.1-1              252.2-1
                        systemd-libs              252.1-1              252.2-1
                  systemd-resolvconf              252.1-1              252.2-1
                  systemd-sysvcompat              252.1-1              252.2-1
                                zlib           1:1.2.13-1           1:1.2.13-2
:: Different overlay package(s) in repository extra aarch64
              plasma-wayland-session           5.26.3-0.1           5.26.3-0.2
                    plasma-workspace           5.26.3-0.1           5.26.3-0.2
                        qt5-es2-base    5.15.7+kde+r174-1    5.15.7+kde+r175-1
                     qt5-es2-wayland     5.15.7+kde+r52-1     5.15.7+kde+r55-1
:: Different sync package(s) in repository extra aarch64
                                 ant            1.10.12-1            1.10.12-2
                             ant-doc            1.10.12-1            1.10.12-2
                arch-install-scripts                 27-1                 28-1
                              breezy              3.3.0-1              3.3.1-1
                            chromium     107.0.5304.110-1     107.0.5304.121-1
                               cmake             3.24.3-1             3.25.0-1
                            devtools           20221012-1           20221012-2
                           dump_syms              2.0.0-1              2.1.0-1
                             freetds             1.3.14-1             1.3.15-1
                     grml-zsh-config             0.19.4-1             0.19.5-1
                                gtk31:3.24.34+r156+g812b3930d0-1          1:3.24.35-2
                          gtk3-demos1:3.24.34+r156+g812b3930d0-1          1:3.24.35-2
                           gtk3-docs1:3.24.34+r156+g812b3930d0-1          1:3.24.35-2
                 java-commons-daemon              1.3.1-1              1.3.2-1
                           java-jsvc              1.3.1-1              1.3.2-1
                              libpng             1.6.38-2             1.6.39-1
                   libreoffice-fresh              7.4.2-2              7.4.3-1
                libreoffice-fresh-af              7.4.2-1              7.4.3-1
                libreoffice-fresh-am              7.4.2-1              7.4.3-1
                libreoffice-fresh-ar              7.4.2-1              7.4.3-1
                libreoffice-fresh-as              7.4.2-1              7.4.3-1
               libreoffice-fresh-ast              7.4.2-1              7.4.3-1
                libreoffice-fresh-be              7.4.2-1              7.4.3-1
                libreoffice-fresh-bg              7.4.2-1              7.4.3-1
                libreoffice-fresh-bn              7.4.2-1              7.4.3-1
             libreoffice-fresh-bn-in              7.4.2-1              7.4.3-1
                libreoffice-fresh-bo              7.4.2-1              7.4.3-1
                libreoffice-fresh-br              7.4.2-1              7.4.3-1
               libreoffice-fresh-brx              7.4.2-1              7.4.3-1
                libreoffice-fresh-bs              7.4.2-1              7.4.3-1
                libreoffice-fresh-ca              7.4.2-1              7.4.3-1
       libreoffice-fresh-ca-valencia              7.4.2-1              7.4.3-1
               libreoffice-fresh-ckb              7.4.2-1              7.4.3-1
                libreoffice-fresh-cs              7.4.2-1              7.4.3-1
                libreoffice-fresh-cy              7.4.2-1              7.4.3-1
                libreoffice-fresh-da              7.4.2-1              7.4.3-1
                libreoffice-fresh-de              7.4.2-1              7.4.3-1
               libreoffice-fresh-dgo              7.4.2-1              7.4.3-1
               libreoffice-fresh-dsb              7.4.2-1              7.4.3-1
                libreoffice-fresh-dz              7.4.2-1              7.4.3-1
                libreoffice-fresh-el              7.4.2-1              7.4.3-1
             libreoffice-fresh-en-gb              7.4.2-1              7.4.3-1
             libreoffice-fresh-en-za              7.4.2-1              7.4.3-1
                libreoffice-fresh-eo              7.4.2-1              7.4.3-1
                libreoffice-fresh-es              7.4.2-1              7.4.3-1
                libreoffice-fresh-et              7.4.2-1              7.4.3-1
                libreoffice-fresh-eu              7.4.2-1              7.4.3-1
                libreoffice-fresh-fa              7.4.2-1              7.4.3-1
                libreoffice-fresh-fi              7.4.2-1              7.4.3-1
                libreoffice-fresh-fr              7.4.2-1              7.4.3-1
               libreoffice-fresh-fur              7.4.2-1              7.4.3-1
                libreoffice-fresh-fy              7.4.2-1              7.4.3-1
                libreoffice-fresh-ga              7.4.2-1              7.4.3-1
                libreoffice-fresh-gd              7.4.2-1              7.4.3-1
                libreoffice-fresh-gl              7.4.2-1              7.4.3-1
                libreoffice-fresh-gu              7.4.2-1              7.4.3-1
               libreoffice-fresh-gug              7.4.2-1              7.4.3-1
                libreoffice-fresh-he              7.4.2-1              7.4.3-1
                libreoffice-fresh-hi              7.4.2-1              7.4.3-1
                libreoffice-fresh-hr              7.4.2-1              7.4.3-1
               libreoffice-fresh-hsb              7.4.2-1              7.4.3-1
                libreoffice-fresh-hu              7.4.2-1              7.4.3-1
                libreoffice-fresh-id              7.4.2-1              7.4.3-1
                libreoffice-fresh-is              7.4.2-1              7.4.3-1
                libreoffice-fresh-it              7.4.2-1              7.4.3-1
                libreoffice-fresh-ja              7.4.2-1              7.4.3-1
                libreoffice-fresh-ka              7.4.2-1              7.4.3-1
               libreoffice-fresh-kab              7.4.2-1              7.4.3-1
                libreoffice-fresh-kk              7.4.2-1              7.4.3-1
                libreoffice-fresh-km              7.4.2-1              7.4.3-1
          libreoffice-fresh-kmr-latn              7.4.2-1              7.4.3-1
                libreoffice-fresh-kn              7.4.2-1              7.4.3-1
                libreoffice-fresh-ko              7.4.2-1              7.4.3-1
               libreoffice-fresh-kok              7.4.2-1              7.4.3-1
                libreoffice-fresh-ks              7.4.2-1              7.4.3-1
                libreoffice-fresh-lb              7.4.2-1              7.4.3-1
                libreoffice-fresh-lo              7.4.2-1              7.4.3-1
                libreoffice-fresh-lt              7.4.2-1              7.4.3-1
                libreoffice-fresh-lv              7.4.2-1              7.4.3-1
               libreoffice-fresh-mai              7.4.2-1              7.4.3-1
                libreoffice-fresh-mk              7.4.2-1              7.4.3-1
                libreoffice-fresh-ml              7.4.2-1              7.4.3-1
                libreoffice-fresh-mn              7.4.2-1              7.4.3-1
               libreoffice-fresh-mni              7.4.2-1              7.4.3-1
                libreoffice-fresh-mr              7.4.2-1              7.4.3-1
                libreoffice-fresh-my              7.4.2-1              7.4.3-1
                libreoffice-fresh-nb              7.4.2-1              7.4.3-1
                libreoffice-fresh-ne              7.4.2-1              7.4.3-1
                libreoffice-fresh-nl              7.4.2-1              7.4.3-1
                libreoffice-fresh-nn              7.4.2-1              7.4.3-1
                libreoffice-fresh-nr              7.4.2-1              7.4.3-1
               libreoffice-fresh-nso              7.4.2-1              7.4.3-1
                libreoffice-fresh-oc              7.4.2-1              7.4.3-1
                libreoffice-fresh-om              7.4.2-1              7.4.3-1
                libreoffice-fresh-or              7.4.2-1              7.4.3-1
             libreoffice-fresh-pa-in              7.4.2-1              7.4.3-1
                libreoffice-fresh-pl              7.4.2-1              7.4.3-1
                libreoffice-fresh-pt              7.4.2-1              7.4.3-1
             libreoffice-fresh-pt-br              7.4.2-1              7.4.3-1
                libreoffice-fresh-ro              7.4.2-1              7.4.3-1
                libreoffice-fresh-ru              7.4.2-1              7.4.3-1
                libreoffice-fresh-rw              7.4.2-1              7.4.3-1
             libreoffice-fresh-sa-in              7.4.2-1              7.4.3-1
               libreoffice-fresh-sat              7.4.2-1              7.4.3-1
                libreoffice-fresh-sd              7.4.2-1              7.4.3-1
               libreoffice-fresh-sdk              7.4.2-2              7.4.3-1
                libreoffice-fresh-si              7.4.2-1              7.4.3-1
               libreoffice-fresh-sid              7.4.2-1              7.4.3-1
                libreoffice-fresh-sk              7.4.2-1              7.4.3-1
                libreoffice-fresh-sl              7.4.2-1              7.4.3-1
                libreoffice-fresh-sq              7.4.2-1              7.4.3-1
                libreoffice-fresh-sr              7.4.2-1              7.4.3-1
           libreoffice-fresh-sr-latn              7.4.2-1              7.4.3-1
                libreoffice-fresh-ss              7.4.2-1              7.4.3-1
                libreoffice-fresh-st              7.4.2-1              7.4.3-1
                libreoffice-fresh-sv              7.4.2-1              7.4.3-1
             libreoffice-fresh-sw-tz              7.4.2-1              7.4.3-1
               libreoffice-fresh-szl              7.4.2-1              7.4.3-1
                libreoffice-fresh-ta              7.4.2-1              7.4.3-1
                libreoffice-fresh-te              7.4.2-1              7.4.3-1
                libreoffice-fresh-tg              7.4.2-1              7.4.3-1
                libreoffice-fresh-th              7.4.2-1              7.4.3-1
                libreoffice-fresh-tn              7.4.2-1              7.4.3-1
                libreoffice-fresh-tr              7.4.2-1              7.4.3-1
                libreoffice-fresh-ts              7.4.2-1              7.4.3-1
                libreoffice-fresh-tt              7.4.2-1              7.4.3-1
                libreoffice-fresh-ug              7.4.2-1              7.4.3-1
                libreoffice-fresh-uk              7.4.2-1              7.4.3-1
                libreoffice-fresh-uz              7.4.2-1              7.4.3-1
                libreoffice-fresh-ve              7.4.2-1              7.4.3-1
               libreoffice-fresh-vec              7.4.2-1              7.4.3-1
                libreoffice-fresh-vi              7.4.2-1              7.4.3-1
                libreoffice-fresh-xh              7.4.2-1              7.4.3-1
             libreoffice-fresh-zh-cn              7.4.2-1              7.4.3-1
             libreoffice-fresh-zh-tw              7.4.2-1              7.4.3-1
                libreoffice-fresh-zu              7.4.2-1              7.4.3-1
                        libsidplayfp              2.4.0-1              2.4.1-1
                             libupnp            1.14.14-1            1.14.15-1
                              libwps             0.4.12-2             0.4.13-1
                           libxrandr              1.5.2-5              1.5.3-1
                           mercurial              6.3.0-1              6.3.1-1
                               meson             0.64.0-1             0.64.1-1
                               metis          5.1.0.p10-2                    -
                           mythes-en           20221102-1           20221102-2
                  perl-io-socket-ssl              2.076-1              2.077-1
                                 php             8.1.12-2             8.1.13-1
                          php-apache             8.1.12-2             8.1.13-1
                             php-cgi             8.1.12-2             8.1.13-1
                           php-dblib             8.1.12-2             8.1.13-1
                           php-embed             8.1.12-2             8.1.13-1
                         php-enchant             8.1.12-2             8.1.13-1
                             php-fpm             8.1.12-2             8.1.13-1
                              php-gd             8.1.12-2             8.1.13-1
                            php-imap             8.1.12-2             8.1.13-1
                            php-intl             8.1.12-2             8.1.13-1
                            php-odbc             8.1.12-2             8.1.13-1
                           php-pgsql             8.1.12-2             8.1.13-1
                          php-phpdbg             8.1.12-2             8.1.13-1
                          php-pspell             8.1.12-2             8.1.13-1
                            php-snmp             8.1.12-2             8.1.13-1
                          php-sodium             8.1.12-2             8.1.13-1
                          php-sqlite             8.1.12-2             8.1.13-1
                            php-tidy             8.1.12-2             8.1.13-1
                             php-xsl             8.1.12-2             8.1.13-1
                          postgresql               14.5-4               14.6-1
                     postgresql-docs               14.5-4               14.6-1
                     postgresql-libs               14.5-4               14.6-1
              postgresql-old-upgrade               13.8-3               13.9-1
                          prometheus             2.40.2-1             2.40.3-1
                             pyside6            6.4.0.1-1              6.4.1-2
                        python-cairo             1.21.0-1             1.22.0-1
                       python-merge3             0.0.10-1             0.0.12-1
                        python-numpy             1.23.4-1             1.23.5-1
                 python-patiencediff              0.2.6-1              0.2.8-1
                   python-setuptools           1:65.5.0-1           1:65.6.1-1
                                 qbs             1.23.2-1             1.24.0-1
                            qt5-base    5.15.7+kde+r174-1    5.15.7+kde+r176-1
                         qt5-wayland     5.15.7+kde+r53-1     5.15.7+kde+r55-1
                          qt5-webkit     5.212.0alpha4-18                    -
             qt5-xcb-private-headers    5.15.7+kde+r174-1    5.15.7+kde+r176-1
                           qtcreator              8.0.2-1              9.0.0-1
                     qtcreator-devel              8.0.2-1              9.0.0-1
                                sdl2             2.24.2-1             2.26.0-1
                           shiboken6            6.4.0.1-1              6.4.1-2
                           syslog-ng             3.38.1-2             3.38.1-3
                                 tcl             8.6.12-3             8.6.13-1
                                  tk             8.6.12-1             8.6.13-1
            java-xmlgraphics-commons                    -                2.8-1
           python-setuptools-gettext                    -              0.1.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi22.08.3.r12855.gd1dfa3fbd-122.08.3.r12856.g9c5056e2b-1
                    akonadi-calendar22.08.3.r2209.g0a66fdb-122.08.3.r2213.g01df474-1
              akonadi-calendar-tools22.08.3.r982.g8f0dd10-122.08.3.r983.g2c9acbd-1
                    akonadi-contacts22.08.3.r3296.g525552dd-122.08.3.r3298.g5807e4de-1
               akonadi-import-wizard22.08.3.r1867.gc3dd79b-122.08.3.r1869.g3f698b5-1
                        akonadi-mime22.08.3.r1786.g37437ac-122.08.3.r1787.gbaf7d71-1
                       akonadi-notes22.08.3.r1107.g7d445c9-122.08.3.r1108.ga0522fa-1
                      akonadi-search22.08.3.r1298.g0738c98-122.08.3.r1300.g09a2696-1
                           akregator22.08.3.r6511.g517d05e4-122.08.3.r6513.g355e117d-1
                           alligator 22.09.r19.gb332065-1 22.09.r20.g308421b-1
                            analitza22.08.3.r2367.g820dcdfb-122.08.3.r2368.ge431a229-1
                           angelfish 22.09.r24.g414e000-1 22.09.r26.g5f8bb2e-1
                                 ark22.08.3.r4945.g70b4ac1d-122.08.3.r4947.gac8a66d6-1
                          artikulate22.08.3.r1463.gb1b44a4-122.08.3.r1464.g0c79f10-1
                         audiocd-kio22.08.3.r1128.g42e8243-122.08.3.r1129.g30b3d27-1
                           audiotube 22.09.r43.g54d7c27-1 22.09.r55.gc56bbb6-1
                        aura-browser5.26.0.r136.g5a8f224-15.26.0.r139.g00a7283-1
                               baloo5.100.0.r3097.gf059955c-15.100.0.r3098.g78b7a39e-1
                       baloo-widgets22.08.3.r784.g66f8ae5-122.08.3.r785.g4e76c0a-1
                             blinken22.08.3.r699.g4228813-122.08.3.r700.g96b4d97-1
                           bluedevil1:5.26.3.r2494.gfa20d7ba-11:5.26.3.r2496.g25a9ddd0-1
                              bomber22.08.3.r592.g5da9b7e-122.08.3.r593.ga14a222-1
                                bovo22.08.3.r806.g8cffdbb-122.08.3.r807.g33e1d0e-1
                              breeze5.26.3.r2508.gfbe608b1-15.26.3.r2510.geb97f1de-1
                                buho 2.2.0.r19.g4e00c31-1 2.2.0.r20.g803f159-1
                     calendarsupport22.08.3.r754.gfdd43c0-122.08.3.r755.g47269a5-1
                           calindori 22.09.r14.gc2eb266-1 22.09.r15.gdfca85f-1
                            cervisia22.08.3.r1721.g5f5959e-122.08.3.r1722.g26ac466-1
                            discover5.26.3.r9026.gaa0879b7b-15.26.3.r9031.g814e3abc6-1
                             dolphin22.08.3.r7168.g0888e1611-122.08.3.r7170.g9811eb803-1
                     dolphin-plugins22.08.3.r704.g6a2a0a5-122.08.3.r705.g9ff6dd5-1
                              dragon22.08.3.r1088.gd63540c-122.08.3.r1093.g922b52b-1
                             drkonqi5.26.3.r859.g18850345-15.26.3.r860.g8e6e4ed7-1
                               elisa22.08.3.r3075.gbbf2b4cd-122.08.3.r3078.g62c8ad3b-1
                          elisa-qtmm22.08.3.r3075.gbbf2b4cd-122.08.3.r3078.g62c8ad3b-1
                          eventviews22.08.3.r907.g044451c-122.08.3.r909.g6731395-1
                           filelight22.08.3.r1242.g6d1282b-122.08.3.r1243.gd8a5a22-1
                           granatier22.08.3.r1006.g2c2c28b-122.08.3.r1007.g5350363-1
                     grantlee-editor22.08.3.r869.ga3e331f-122.08.3.r870.g46a3d18-1
                       grantleetheme22.08.3.r441.ge9dcb79-122.08.3.r442.g8f13c34-1
                            gwenview22.08.3.r6970.gde7ca748-122.08.3.r6973.gfde46325-1
                     incidenceeditor22.08.3.r964.g3ad92e8-122.08.3.r965.gaf7e564-1
                            index-fm 2.2.0.r29.gb8e9d79-1 2.2.0.r30.g4cefa20-1
                                 juk22.08.3.r3207.gd7ed61cb-122.08.3.r3209.g05d6c79b-1
                                 k3b1:22.08.3.r6862.g3d8eb0bf9-11:22.08.3.r6863.gdd77a2cac-1
               kaccounts-integration22.08.3.r1304.g6ab8c4a-122.08.3.r1305.gb7bfd85-1
                 kaccounts-providers22.08.3.r410.g44feb58-122.08.3.r411.ga25a055-1
                   kactivitymanagerd5.26.3.r1430.g90be558-15.26.3.r1431.g399a77b-1
                        kaddressbook22.08.3.r6273.gb6be1038-122.08.3.r6275.g1663db7a-1
                             kajongg22.08.3.r4370.ge2f85efa-122.08.3.r4372.g8f471606-1
                              kalarm22.08.3.r8103.g1c3c787c-122.08.3.r8108.gc04a22bb-1
                            kalgebra22.08.3.r2099.g8324e2f-122.08.3.r2101.g94448d8-1
                                kalk 22.09.r25.g75908de-1 22.09.r26.gea6ac17-1
                             kalzium22.08.3.r4436.g15079112-122.08.3.r4437.g9945ed98-1
                              kamera22.08.3.r749.g14315fd-122.08.3.r750.g667c9cc-1
                              kamoso22.08.3.r1498.g179cb3f-122.08.3.r1499.g5e4b68b-1
                            kanagram22.08.3.r1349.g8562c5a-122.08.3.r1351.g65ae9b8-1
                             kapidox5.100.0.r579.g93bb975-15.100.0.r580.ga9f5efc-1
                              kapman22.08.3.r685.g7588930-122.08.3.r688.g7ec6435-1
                        kapptemplate22.08.3.r1022.g1da6a34-122.08.3.r1023.g287a776-1
                            karchive5.100.0.r579.g9a91d7d-15.100.0.r582.g2f8c47b-1
                               kasts22.09.2.r35.g534a019-122.09.2.r36.g7adaa85-1
                                kate22.08.3.r19899.g091212e8a-122.08.3.r19909.ge7c159a52-1
                             katomic22.08.3.r989.g1490a09-122.08.3.r991.g20eb7bc-1
                               kauth5.100.0.r524.gc1c15d7-15.100.0.r525.gb868566-1
                             kbackup22.08.3.r475.g10188dd-122.08.3.r476.g81cd131-1
                           kblackbox22.08.3.r800.gdefed27-122.08.3.r801.g6cd4985-1
                             kblocks22.08.3.r772.ge472363-122.08.3.r773.g11f59ce-1
                          kbookmarks5.100.0.r489.g6fbe38c-15.100.0.r490.g2ea6806-1
                             kbounce22.08.3.r877.g9a27a49-122.08.3.r878.g9862230-1
                           kbreakout22.08.3.r956.g415bc60-122.08.3.r957.g181e435-1
                              kbruch22.08.3.r911.gd049c3b-122.08.3.r912.g9d5adfb-1
                         kcachegrind22.08.3.r1213.g1be4022-122.08.3.r1214.ge4f32fc-1
                  kcachegrind-common22.08.3.r1213.g1be4022-122.08.3.r1214.ge4f32fc-1
                               kcalc22.08.3.r1657.gcf34c14-122.08.3.r1658.g466384f-1
                           kcalutils22.08.3.r1013.gcb73f6b11-122.08.3.r1014.gbad778153-1
                         kcharselect22.08.3.r571.g995d40c-122.08.3.r572.gceecc87-1
                              kclock 22.09.r35.g31d334a-1 22.09.r36.g2559c97-1
                            kcmutils5.100.0.r684.g1e30aa7-15.100.0.r685.gdcb2ef5-1
                             kcodecs5.100.0.r450.gd08fb14-15.100.0.r451.g541163c-1
                       kcolorchooser22.08.3.r293.g26a7df7-122.08.3.r294.g29628cd-1
                         kcompletion5.100.0.r527.gab9654c-15.100.0.r528.g2350986-1
                             kconfig5.100.0.r1009.ga66d57f5-15.100.0.r1010.g62cb8e29-1
                      kconfigwidgets5.100.0.r811.gc1534bc7-15.100.0.r813.g28d355e3-1
                           kcontacts1:5.100.0.r3365.gd0c5e9bb-11:5.100.0.r3366.ga7e50968-1
                         kcoreaddons5.100.0.r1611.gbd44446a-15.100.0.r1614.g0d7a10a1-1
                               kcron22.08.3.r862.g99289a0-122.08.3.r863.gf73596a-1
                                kdav1:5.100.0.r1372.gb76c96e-11:5.100.0.r1373.gd8929ad-1
                         kdbusaddons5.100.0.r445.gc07960c-15.100.0.r446.g634ef1f-1
                       kde-cli-tools5.26.3.r2002.g2132f1b-15.26.3.r2005.g2a9fc27-1
                       kde-dev-utils22.08.3.r615.g366fafe-122.08.3.r616.gd9ede57-1
                      kdebugsettings22.08.3.r1037.g6a0fc08-122.08.3.r1038.gec5400c-1
                        kdeclarative5.100.0.r1069.gd0bd6f8-15.100.0.r1072.gf5d8e30-1
                          kdeconnect22.08.3.r3597.g59bd294c-122.08.3.r3600.g960530f6-1
                         kdecoration5.26.3.r311.g92ce620-15.26.3.r312.g0a2a546-1
                                kded5.100.0.r482.g7cd34a5-15.100.0.r483.g2663ef4-1
                     kdelibs4support5.100.0.r1126.g56e8f057-15.100.0.r1127.g8eb8f8f0-1
              kdenetwork-filesharing22.08.3.r1004.g9db822f-122.08.3.r1005.gc2542d6-1
                            kdenlive22.08.3.r17031.gfadb0f853-122.08.3.r17066.g8dec8d652-1
                       kdepim-addons22.08.3.r4935.g33badfaa6-122.08.3.r4936.gd108409ef-1
                      kdepim-runtime22.08.3.r15658.g741c6d25c-122.08.3.r15659.gcc11186ba-1
                    kdeplasma-addons5.26.3.r9155.gb356752e3-15.26.3.r9165.g8522fd7e6-1
                 kdesdk-thumbnailers22.08.3.r108.g2bcbc12-122.08.3.r109.g61ea611-1
                     kdesignerplugin5.100.0.r375.ge330447-15.100.0.r377.ge6cbe8c-1
                               kdesu5.100.0.r532.g397af19-15.100.0.r533.g4d338be-1
                                 kdf22.08.3.r899.g55a829b-122.08.3.r901.g73e054b-1
                             kdialog22.08.3.r1262.gcd0a98750-122.08.3.r1264.g8a5789210-1
                            kdiamond22.08.3.r753.g9053c3f-122.08.3.r754.ge8ac5b1-1
                              kdnssd5.100.0.r375.g7346d4b-15.100.0.r376.g103a6da-1
                           kdoctools5.100.0.r695.gc132d11-15.100.0.r696.g6027da4-1
                      keditbookmarks22.08.3.r2787.g54ef1daeb-122.08.3.r2788.geeeadcddf-1
                            keysmith 22.09.r18.gb7af99e-1 22.09.r19.ga5ff479-1
                       kfilemetadata5.100.0.r898.g2e63271-15.100.0.r900.g59be59b-1
                               kfind22.08.3.r2751.g80b1627cb-122.08.3.r2752.g5a5c884b3-1
                             kfloppy22.08.3.r820.g7b49b96-122.08.3.r821.g58b0671-1
                         kfourinline22.08.3.r1057.g10624c5-122.08.3.r1059.g9afdd55-1
                             kgamma55.26.3.r496.gb9a93c7-15.26.3.r497.gfc2d4c8-1
                          kgeography22.08.3.r1202.gd91724b-122.08.3.r1203.gad059d7-1
                                kget22.08.3.r3258.g632afe3e-122.08.3.r3259.g23261221-1
                        kglobalaccel5.100.0.r591.gc11d949-15.100.0.r596.g091ac4e-1
                         kgoldrunner22.08.3.r1324.g4355eee-122.08.3.r1326.g092bb5a-1
                          kguiaddons5.100.0.r514.g31454f7-15.100.0.r515.g15f0a0b-1
                            khangman22.08.3.r1642.gd323bb4-122.08.3.r1643.g593464a-1
                         khelpcenter22.08.3.r2806.gcead834a-122.08.3.r2822.gaa82b2f3-1
                           kholidays1:5.100.0.r1081.g89f0cea-11:5.100.0.r1082.gcb69faf-1
                            khotkeys5.26.3.r2178.gcc7dc02-15.26.3.r2180.g5ef685d-1
                               khtml5.100.0.r618.g5e9b0cf-15.100.0.r620.gf07c71a-1
                               ki18n5.100.0.r598.g6ea5e1a-15.100.0.r599.gd74fd22-1
                         kiconthemes5.100.0.r651.g7364c8e-15.100.0.r652.g2626f88-1
                 kidentitymanagement22.08.3.r3928.ga40c0b57-122.08.3.r3929.ga641faf0-1
                                 kig22.08.3.r3255.g01cdd395-122.08.3.r3257.ga10805d7-1
                                kigo22.08.3.r606.g9db67da-122.08.3.r608.g079c8c8-1
                            killbots22.08.3.r828.gb6346ca-122.08.3.r829.gafc571f-1
                     kimagemapeditor22.08.3.r539.ge1ad890-122.08.3.r541.g3d21036-1
                               kimap22.08.3.r1226.gd7266ca-122.08.3.r1227.g94edb2b-1
                         kinfocenter5.26.3.r2225.g7b97d4a0-15.26.3.r2229.g11ed1778-1
                               kinit5.100.0.r462.gd342489-15.100.0.r463.g7da05e3-1
                                 kio5.100.0.r5877.g5f1f34383-15.100.0.r5884.g7555aa8ef-1
                          kio-extras22.08.3.r7393.gad2a8fe42-122.08.3.r7400.g91b1dff25-1
                          kio-gdrive22.08.3.r671.gcb5a59d-122.08.3.r672.g3302166-1
                     kirigami-addons 1:0.5.r50.gdf45e10-1 1:0.5.r68.g8280a8b-1
                    kirigami-gallery22.08.3.r296.g711aed6-122.08.3.r297.g313cef1-1
                           kirigami25.100.0.r3463.g0a1f2b00-15.100.0.r3472.ga8cc3f8e-1
                              kiriki22.08.3.r481.ga2964af-122.08.3.r482.g1675a7e-1
                         kitemmodels5.100.0.r629.g7de5725-15.100.0.r631.g3b318e2-1
                          kitemviews5.100.0.r400.gd2aa5e5-15.100.0.r401.gadef181-1
                               kiten22.08.3.r1228.g8eebbd6-122.08.3.r1229.gf88b2ae-1
                          kitinerary22.08.3.r2526.gda662dae-122.08.3.r2527.g5daf4a39-1
                         kjobwidgets5.100.0.r447.g7a35ea0-15.100.0.r448.g76d8ce0-1
                                 kjs5.100.0.r380.g6972508-15.100.0.r381.gc4157f8-1
                            kjsembed5.100.0.r347.gb0e7370-15.100.0.r348.gae5d788-1
                        kjumpingcube22.08.3.r873.g984fbd4-122.08.3.r874.ge785f62-1
                               kldap22.08.3.r991.gc409ecb-122.08.3.r993.g7d7cb02-1
                           kleopatra22.08.3.r6937.gd5449938-122.08.3.r6938.g90f3a220-1
                            klettres22.08.3.r993.g732b7b0-122.08.3.r995.g2291e9d-1
                            klickety22.08.3.r726.g498db20-122.08.3.r727.gbf48aa9-1
                              klines22.08.3.r850.gc970dfb-122.08.3.r852.g5e73614-1
                                kmag22.08.3.r764.g7e6733b-122.08.3.r766.gb0280d2-1
                           kmahjongg22.08.3.r1593.gb692927-122.08.3.r1594.gfea0b37-1
                               kmail22.08.3.r26629.gf34415639-122.08.3.r26631.gf8ee27240-1
                kmail-account-wizard22.08.3.r917.g2526f51-122.08.3.r918.g8683978-1
                      kmailtransport22.08.3.r1809.gf063af4-122.08.3.r1813.g4141653-1
                           kmenuedit5.26.3.r1106.g712b67f-15.26.3.r1108.g7ef8b33-1
                               kmime22.08.3.r1561.gfdfc106-122.08.3.r1562.ge4466dd-1
                              kmines22.08.3.r1797.g0e8106e-122.08.3.r1798.g4834c81-1
                                kmix22.08.3.r2479.g020b987e-122.08.3.r2480.g941c459c-1
                          kmousetool22.08.3.r471.g649eb80-122.08.3.r472.g4c1d738-1
                              kmouth22.08.3.r772.gc24cdb2-122.08.3.r774.ga18dfb0-1
                              kmplot22.08.3.r1543.g60b4245-122.08.3.r1545.gf4cba73-1
                        knavalbattle22.08.3.r1464.g06f66cd-122.08.3.r1465.g9c5c759-1
                            knetwalk22.08.3.r744.g6dfc849-122.08.3.r745.g34fbc65-1
                           knewstuff5.100.0.r1428.gfa4db400-15.100.0.r1429.g9c0a2f8b-1
                             knights22.08.3.r1185.ge109ec9-122.08.3.r1186.gf024c7c-1
                              knotes22.08.3.r3742.g7bc3f935-122.08.3.r3743.gccbd2311-1
                      knotifications5.100.0.r779.g0ce4c25-15.100.0.r780.g1c9ca10-1
                       knotifyconfig5.100.0.r408.gd349fba-15.100.0.r409.geb06760-1
                                koko 22.09.r18.g2981e0f-1 22.09.r19.gbeec0df-1
                                kolf22.08.3.r1558.g7c5d58f-122.08.3.r1560.g72b7fce-1
                           kollision22.08.3.r560.g5f4a1de-122.08.3.r561.g0b61940-1
                         kolourpaint22.08.3.r2462.ga98c809a-122.08.3.r2464.gbad4d9f5-1
                             kompare22.08.3.r1201.g0dcf15c-122.08.3.r1202.g098f37a-1
                            kongress 22.09.r17.g7f25a56-1 22.09.r18.g7621e60-1
                           konqueror22.08.3.r15230.gb5733f065-122.08.3.r15234.g45f44aeb2-1
                            konquest22.08.3.r977.ga2c8b42-122.08.3.r978.g9edf326-1
                             konsole22.08.3.r8749.gd2ea8291-122.08.3.r8750.gb534bcc6-1
                             kontact22.08.3.r5602.gb645dd63-122.08.3.r5603.g47908bc8-1
                    kontactinterface22.08.3.r722.g6e78de6-122.08.3.r723.g547d217-1
                            kontrast22.08.3.r261.gf15edd4-122.08.3.r262.gd06135f-1
                        konversation22.08.3.r9199.gad1d4a02-122.08.3.r9201.gfc592914-1
                       kopeninghours22.08.3.r348.gb490cd2-122.08.3.r349.gdfa928f-1
                          korganizer22.08.3.r11885.g2c078fab4-122.08.3.r11886.ge128226de-1
                       kosmindoormap22.08.3.r788.g1c90b38-122.08.3.r801.gb44bfe2-1
                            kpackage5.100.0.r790.g631116d-15.100.0.r791.g242f4aa-1
                              kparts5.100.0.r635.g654b283-15.100.0.r636.g962c908-1
                                kpat22.08.3.r2652.g42b3d470-122.08.3.r2653.gb685978a-1
                             kpeople5.100.0.r1401.gc60ffb9-15.100.0.r1402.gfc02e54-1
                        kpeoplevcard   0.1.r46.g9a7c632-1   0.1.r49.ga62ff5a-1
                        kpimtextedit22.08.3.r1664.geff8c85-122.08.3.r1680.gc8d3504-1
                           kpipewire5.26.3.r169.ge5a0546-15.26.3.r172.g3d7758f-1
                             kpmcore22.08.3.r1327.g680fed4-122.08.3.r1328.g5324e85-1
                                kpty5.100.0.r398.gc16e2cb-15.100.0.r399.g48ca9d5-1
                    kpublictransport22.08.3.r2055.g0afa825d-122.08.3.r2058.gf6ad9e36-1
                        kquickcharts5.100.0.r542.g0319a6f-15.100.0.r547.gf2d2a05-1
                                krdc22.08.3.r1643.ga900e8f-122.08.3.r1644.gc09dffd-1
                           krecorder 22.09.r52.gc68a4ba-1 22.09.r55.gf8fea3d-1
                            kreversi22.08.3.r1308.gb8cb721-122.08.3.r1310.g9fc6d29-1
                                krfb22.08.3.r1528.g9699e7a-122.08.3.r1529.g21763fe-1
                               kross5.100.0.r378.g318569a-15.100.0.r379.gede70e0-1
                              kruler22.08.3.r766.g2f495fc-122.08.3.r767.g2b93a4e-1
                             krunner5.100.0.r796.g491d699-15.100.0.r799.gc196cb3-1
                           ksanecore      r649.ge056d0b-1      r652.g5a57acf-1
                             kscreen5.26.3.r1593.g746ccf7-15.26.3.r1602.g4719e4a-1
                       kscreenlocker5.26.3.r1010.g08ff2f1-15.26.3.r1015.g2d9d548-1
                            kservice5.100.0.r1051.ga8c723d-15.100.0.r1052.ge4c06fd-1
                             kshisen22.08.3.r1271.g2e18bbc-122.08.3.r1272.g1088461-1
                               ksirk22.08.3.r1079.gd2ef4ce-122.08.3.r1081.gb665e4a-1
                               ksmtp22.08.3.r476.g5bb7b67-122.08.3.r477.g0928530-1
                          ksnakeduel22.08.3.r882.ga01d613-122.08.3.r883.g320a8a0-1
                          kspaceduel22.08.3.r700.gc9cd722-122.08.3.r701.g9ab2c91-1
                            ksquares22.08.3.r603.g5b19cbf-122.08.3.r604.gc86a666-1
                         ksshaskpass5.26.3.r225.g8102825-15.26.3.r226.g7423b6e-1
                             ksudoku22.08.3.r1151.g3b0c7d2-122.08.3.r1152.g84fd086-1
                           ksysguard5.26.3.r3560.gdb80938c-15.26.3.r3562.gaa6517ce-1
                          ksystemlog22.08.3.r778.gf61e1b9-122.08.3.r779.g1c3993e-1
                        ksystemstats5.26.3.r254.g2384253-15.26.3.r256.g6ab8074-1
                            kteatime22.08.3.r781.ge14befd-122.08.3.r783.g6a2d5bb-1
                         ktexteditor5.100.0.r3638.g3b0992c8-15.100.0.r3641.gcceb37eb-1
                        ktextwidgets5.100.0.r477.ge5686fd-15.100.0.r478.g8065f83-1
                              ktimer22.08.3.r551.g5976adc-122.08.3.r552.g99df5a1-1
                               ktnef22.08.3.r752.gd2f9abb-122.08.3.r753.gf5efb32-1
                            ktorrent22.08.3.r2918.ge3a5edaf-122.08.3.r2919.g3cc687c7-1
                              ktouch22.08.3.r2220.g7efd691-122.08.3.r2221.gbe05bf1-1
                               ktrip 22.09.r12.ga4495cf-1 22.09.r13.g9cb0b48-1
                          ktuberling22.08.3.r1109.ga1ea1df-122.08.3.r1111.g559351b-1
                             kturtle22.08.3.r1204.g9aaf9cb-122.08.3.r1206.gb906fd1-1
                             kubrick22.08.3.r451.ga23f256-122.08.3.r452.g526f1ce-1
                     kunitconversion5.100.0.r455.g13e5b79-15.100.0.r456.ge670ee3-1
                             kwallet5.100.0.r1202.gb684f32-15.100.0.r1203.g74bcf00-1
                      kwalletmanager22.08.3.r1341.g56e56c4-122.08.3.r1342.gd397952-1
                               kwave22.08.3.r3829.g5a46cb7e-122.08.3.r3830.g482f3d0c-1
                kwayland-integration5.26.3.r220.g36eeaac-15.26.3.r221.g8eb1f9b-1
                            kweather 22.09.r38.ge3d3450-1 22.09.r39.g0ffdf7a-1
                        kweathercore   0.7.r14.g207eff9-1   0.7.r15.ga7ae7c2-1
                      kwidgetsaddons5.100.0.r1020.g6ef9b222-15.100.0.r1022.geea17ba8-1
                                kwin5.26.3.r23605.gcf3b167d5-15.26.3.r23619.gf70caec4b-1
                       kwindowsystem5.100.0.r718.g4728ac6-15.100.0.r719.gcf5da72-1
                           kwordquiz22.08.3.r1242.g995bcfe-122.08.3.r1243.g272e526-1
                              kwrite22.08.3.r19899.g091212e8a-122.08.3.r19909.ge7c159a52-1
                             kxmlgui5.100.0.r931.gb5edb51c-15.100.0.r933.g9feac22e-1
                       kxmlrpcclient5.100.0.r499.gbb30748f0-15.100.0.r500.g763c12314-1
                          libakonadi22.08.3.r12855.gd1dfa3fbd-122.08.3.r12856.g9c5056e2b-1
                         libgravatar22.08.3.r452.g861489b-122.08.3.r453.gfb7dd43-1
                            libkcddb22.08.3.r778.g13e281f-122.08.3.r779.g7fd5971-1
                     libkcompactdisc22.08.3.r405.g75484ae-122.08.3.r406.g8aa81d2-1
                         libkdegames22.08.3.r2276.g97cb1474-122.08.3.r2277.g14784879-1
                           libkdepim22.08.3.r940.g4f0b095-122.08.3.r941.g770c32b-1
                  libkeduvocdocument22.08.3.r1823.g22fb0ef-122.08.3.r1824.g427b94b-1
                            libkgapi22.08.3.r1393.g034dd46-122.08.3.r1394.gd154844-1
                             libkleo22.08.3.r1310.gfc3de03-122.08.3.r1313.gc79ef23-1
                        libkmahjongg22.08.3.r504.gf55e9b0-122.08.3.r505.g4b36950-1
                     libkomparediff222.08.3.r369.gdc05104-122.08.3.r370.gf9766b1-1
                            libksane22.08.3.r618.g58ec1de-122.08.3.r619.gb9e5583-1
                          libkscreen5.26.3.r1680.gedd290e-15.26.3.r1686.gbdc44a8-1
                           libksieve22.08.3.r1776.ga55ee749-122.08.3.r1778.g427dc520-1
                        libksysguard5.26.3.r2481.gbea1591-15.26.3.r2484.gfef9dbd-1
                         libktorrent22.08.3.r575.g0a7cf1d-122.08.3.r576.g8e2753a-1
                            lokalize22.08.3.r1875.gd473f58c-122.08.3.r1876.g9bcd9b6b-1
                               lskat22.08.3.r884.g847f80e-122.08.3.r886.ged80748-1
                          mailcommon22.08.3.r1337.gaa1c839-122.08.3.r1338.g4e2aa9c-1
                        mailimporter22.08.3.r561.ga9c5d88-122.08.3.r562.g8bb4d6c-1
                              marble22.08.3.r13504.g3dcee485f-122.08.3.r13510.ga4244d046-1
                       marble-common22.08.3.r13504.g3dcee485f-122.08.3.r13510.ga4244d046-1
                           marble-qt22.08.3.r13504.g3dcee485f-122.08.3.r13510.ga4244d046-1
                        markdownpart22.08.3.r149.gd2dc365-122.08.3.r150.g26bb968-1
                           maui-clip 2.2.0.r32.g190b4ae-1 2.2.0.r33.g5c8fa48-1
                           maui-nota 2.2.0.r23.g66d3a44-1 2.2.0.r24.g5335440-1
                            maui-pix 2.2.0.r36.g5f6df97-1 2.2.0.r37.gfe08be8-1
                             mauikit2.2.0.r74.g2c774bf9-12.2.0.r77.gdc4c5c42-1
                    mauikit-accounts 2.2.0.r12.g8481ef6-1 2.2.0.r15.g2d1fe90-1
                mauikit-filebrowsing 2.2.0.r19.g918c709-1 2.2.0.r22.gdd88716-1
                  mauikit-imagetools 2.2.0.r12.gdf7d78f-1 2.2.0.r15.gf120fa6-1
                  mauikit-texteditor 2.2.0.r14.gad474c5-1 2.2.0.r17.g23948dd-1
                       mbox-importer22.08.3.r596.gd76f150-122.08.3.r597.g33f7050-1
                          messagelib22.08.3.r6760.gd6c865a15-122.08.3.r6779.gac2dd59f9-1
                               milou5.26.3.r795.g1800942-15.26.3.r797.g5e267c0-1
                              minuet22.08.3.r643.gffb7eac-122.08.3.r644.gc6647da-1
                             neochat22.09.r196.g8af40613-122.09.r222.gd647bae1-1
                              okular22.08.3.r9885.gfc8059575-122.08.3.r9891.ge3920241f-1
                              oxygen5.26.3.r4524.gc7824301-15.26.3.r4525.g628cd2d9-1
                            palapeli22.08.3.r1342.g273912a-122.08.3.r1343.gab77616-1
                              parley22.08.3.r4564.g185de1c4-122.08.3.r4565.g63279288-1
                    partitionmanager22.08.3.r1681.g4e17f68-122.08.3.r1682.g3ba8726-1
                               picmi22.08.3.r603.g4489fc2-122.08.3.r604.ge413c75-1
                   pim-data-exporter22.08.3.r2824.g21664b3c-122.08.3.r2825.gca882357-1
                    pim-sieve-editor22.08.3.r1691.g291353c-122.08.3.r1692.gb8a6152-1
                           pimcommon22.08.3.r1680.gf031266c-122.08.3.r1690.gab3d518c-1
                        plank-player5.26.0.r96.gb71cabc-15.26.0.r99.g72d5644-1
                    plasma-bigscreen5.26.0.r565.ge9713cd-15.26.0.r570.g0212ca7-1
          plasma-browser-integration5.26.3.r1384.ge4a38777-15.26.3.r1385.g393ad005-1
                       plasma-camera  1.0.r140.g881fdf4-1  1.0.r141.gaec6806-1
                      plasma-desktop5.26.3.r9823.g6c0cf7ec3-15.26.3.r9832.gc910673c0-1
                       plasma-dialer 22.09.r57.g4cd945e-1 22.09.r61.gdff085f-1
                        plasma-disks5.26.3.r311.g00948d1-15.26.3.r312.g19bfd1d-1
                     plasma-firewall5.26.3.r681.ge08a2cf-15.26.3.r682.g92fa5e9-1
                    plasma-framework5.100.0.r16525.g1e5bbcf45-15.100.0.r16528.g60294f9fa-1
                  plasma-integration5.26.3.r602.ge357d8e-15.26.3.r603.g8e42038-1
                       plasma-mobile5.26.3.r2063.gaf535bac3-15.26.3.r2067.g56342d15b-1
                    plasma-mobile-nm5.26.3.r3428.g0faa0817-15.26.3.r3429.g0cc6d1af-1
                         plasma-nano5.26.3.r207.g617ae31-15.26.3.r208.gbf64b9c-1
                           plasma-nm5.26.3.r3428.g0faa0817-15.26.3.r3429.g0cc6d1af-1
                           plasma-pa5.26.3.r1141.gaa143c4-15.26.3.r1142.ga1113ce-1
                    plasma-phonebook  22.09.r7.g9c3ead9-1 22.09.r10.ge3b2f94-1
            plasma-remotecontrollers5.26.0.r188.g9818a50-15.26.0.r191.g630d542-1
                          plasma-sdk5.26.3.r2432.g55cff702-15.26.3.r2433.gedb7739b-1
                     plasma-settings 22.09.r39.g541a791-1 22.09.r43.ge1911ba-1
                plasma-systemmonitor5.26.3.r655.g9443277-15.26.3.r657.g74878d3-1
                  plasma-thunderbolt5.26.3.r209.g9d48e97-15.26.3.r210.g1202636-1
                        plasma-vault5.26.3.r405.g0032707-15.26.3.r406.g6fac1d8-1
              plasma-wayland-session5.26.3.r12696.gcfce721d3-15.26.3.r12708.g3004a2aa0-1
                    plasma-workspace5.26.3.r12696.gcfce721d3-15.26.3.r12708.g3004a2aa0-1
                          plasmatube 22.09.r13.g77916c1-1 22.09.r14.gaf49c26-1
                    polkit-kde-agent5.26.3.r547.gada8d4d-15.26.3.r548.gdfec6d5-1
                          powerdevil5.26.3.r2625.g3692b18f-15.26.3.r2626.g7b926707-1
                       print-manager22.08.3.r1199.g9f991aa-122.08.3.r1200.g92282ea-1
                             purpose5.100.0.r1032.g07d6b88-15.100.0.r1035.g865d5b7-1
                         qcachegrind22.08.3.r1213.g1be4022-122.08.3.r1214.ge4f32fc-1
                          qmlkonsole 22.09.r28.g179d16f-1 22.09.r29.gb9cdc9f-1
                  qqc2-desktop-style5.100.0.r687.gefa03a3-15.100.0.r688.ge4df7e7-1
                                rocs22.08.3.r3151.gb9703b63-122.08.3.r3152.g95ce6ef5-1
                            sddm-kcm5.26.3.r704.gbafc5e3-15.26.3.r705.g7a8e25b-1
                               solid5.100.0.r821.g347df8b-15.100.0.r823.g596d188-1
                              sonnet5.100.0.r731.gee64932-15.100.0.r732.gfe576a4-1
                            spacebar 22.09.r10.gdbae334-1 22.09.r11.g8cb2c8a-1
                           spectacle22.08.3.r1424.g7989699-122.08.3.r1425.g908a305-1
                                step22.08.3.r1276.g3f52ca6-122.08.3.r1277.gd6890c3-1
                             svgpart22.08.3.r250.gcbfdda4-122.08.3.r251.g0621cf7-1
                             sweeper22.08.3.r603.g139c318-122.08.3.r605.g51118f2-1
                      systemsettings5.26.3.r2773.g3216fa69-15.26.3.r2774.g0f01b7e6-1
          telepathy-kde-accounts-kcm22.08.3.r1230.gfbe8754-122.08.3.r1231.g9093a80-1
              telepathy-kde-approver22.08.3.r315.gdaa310d-122.08.3.r316.gf8ede79-1
          telepathy-kde-auth-handler22.08.3.r294.gc3821f0-122.08.3.r295.g8b2828f-1
               telepathy-kde-call-ui22.08.3.r460.gdaa21b3-122.08.3.r461.gfd46554-1
      telepathy-kde-common-internals22.08.3.r2036.g944c514-122.08.3.r2037.g988694a-1
          telepathy-kde-contact-list22.08.3.r1105.g49527aa-122.08.3.r1106.gc7ed4ce-1
        telepathy-kde-contact-runner22.08.3.r275.g4f1324e-122.08.3.r276.g3090aa6-1
       telepathy-kde-desktop-applets22.08.3.r1017.g05dcedb-122.08.3.r1018.gb7c017b-1
  telepathy-kde-filetransfer-handler22.08.3.r237.gd6e9f4b-122.08.3.r238.gd8d3894-1
    telepathy-kde-integration-module22.08.3.r413.ga363fe6-122.08.3.r414.g1f6eba6-1
             telepathy-kde-send-file22.08.3.r247.g348388e-122.08.3.r248.gcfe98b2-1
                             tokodon 22.09.r59.g737b6c1-1 22.09.r65.gac30161-1
                               vvave 2.2.0.r24.g22daef2-1 2.2.0.r27.ge1dc21b-1
              xdg-desktop-portal-kde5.26.3.r561.ge2f6d40-15.26.3.r563.gce90e78-1
                             yakuake22.08.3.r848.gbba7198-122.08.3.r850.g4bdc1c1-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
2022-11-20
OpenSSL 1.1 library not found
Some applications might still be looking for openssl 1.1.
Solution: Install openssl-1.1 package with sudo pacman -S openssl-1.1.
2022-10-31
Firefox shows wrong colors when playing video on Raspberry Pi 4
Since Mesa 22.2, Firefox has been showing weird colors when playing video on the Raspberry Pi 4. This is caused by an issue in upstream mesa, which was recently fixed.
Fix: Update to mesa 22.2.3-0.1 in the repository, which includes this fix.
Chromium in Wayland crashes with --in-process-gpu
Since Mesa 22.2.0, Chromium running in wayland sessions seems to crash when running with the --in-process-gpu option. Running in X11 seems fine, although it’s slow.
Workaround: Downgrade to mesa 22.1.7 from cache with sudo pacman -U /var/cache/pacman/pkg/mesa-22.1.7-*, until the issue is fixed upstream.
2022-10-21
Plasma Mobile Dialer seems to be unreliable
Plasma Dialer 22.09 seems to have issues switching audio profiles and as such might require manual switching. Sometimes audio is completely missing.
Reduced video performance on youtube
Some may encounter reduced video playback performance on YouTube in Firefox with the new Mesa 22.2 drivers.
No workaround at this time.
Old Issues
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
[Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Glib error means many apps won’t launch
eg chromium
… Glib: g_log_set_writer_func() call multiple times
Trace/breakpoint trap (core dumped)
eg firefox
[1203, main thread] ###!!! ASSERTION: g_log_set_writer_func() call multiple times: ā€˜glib assertion’, file /build/firefox/src/firefox-107.0/toolkit/xre/nsSigHandlers.cpp:164
eg pcmanfm
This began with the update ~10 days ago, gnome was updated, don’t know if that’s related.
Unfortunately I tried to fix by switching to the stable branch, so deleted old versions of glib etc and so can’t try reverting packages - same problem with stable branch.
Can’t reproduce here.
Are you sure your system is completely up-to-date?
Check with:
sudo pacman-mirrors -f5
sudo pacman -Syyuu
Yes it is up to date, I ran those commands and got the ā€œthere is nothing to doā€ message.
Hi,
Odroid C4 KDE up to date.
Odroid C4 LXQt up to date, no issue from LXQt 1.1 to LXQt 1.2 :partying_face:
Issue now with vnc and LXQt… I keep the 1.1 build image.
Hello, waydroid is finally working on my ugoos box (am6b+), as mentioned in this ticket (Waydroid display corrupted Ā· Issue #356 Ā· waydroid/waydroid Ā· GitHub), it is necessary to have the latest image for waydroid. I found the latest images here: WayDroid download | SourceForge.net .
If it can help :slight_smile:
Same problem here
@Strit @spikerguy and others dev I don’t mention
Question to the Manjaro arm dev :
Is the Odroid N2L a future sbc available with Manjaro ?
what a powerfull device
I believe that @spikerguy got a Dev unit, so we will see what the near future brings!
WIP already :smiley:
I have received one already and tried booting but need some work on bootloader.
SOLVED
After much wailing and gnashing of teeth (a.k.a. gnome sux) I narrowed it down to gtk3-classic being installed. Run
pacman -S gtk2 gtk3
to solve this problem.
Or, developers stop using #%$&# gnome challenge…
