Hello ARM community.
Another small set up updates.
Some highlights:
- Most of our kernels got updated
- Firefox updated to 105.0.1
- Thunderbird updated to 102.3.0
- Glib2 updated to 2.74.0. Did we miss any rebuilds?
- Upstream has started to remove some Python2 based packages
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sun Sep 25 18:58:19 CEST 2022)
- arm-testing community aarch64: 190 new and 188 removed package(s)
- arm-testing core aarch64: 22 new and 22 removed package(s)
- arm-testing extra aarch64: 230 new and 227 removed package(s)
- arm-testing kde-unstable aarch64: 88 new and 88 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-09-22 2022-09-25
phosh0.21.0+32+g9afa49e6-10.21.0+40+g2c03f935-1
timeshift 22.06.5-1 22.06.5-2
:: Different sync package(s) in repository community aarch64
adobe-source-han-serif-cn-fonts 2.001-1 2.001-2
adobe-source-han-serif-hk-fonts 2.001-1 2.001-2
adobe-source-han-serif-jp-fonts 2.001-1 2.001-2
adobe-source-han-serif-kr-fonts 2.001-1 2.001-2
adobe-source-han-serif-otc-fonts 2.001-1 2.001-2
adobe-source-han-serif-tw-fonts 2.001-1 2.001-2
ansible-lint 6.6.1-1 6.7.0-1
atril 1.26.0-1 1.26.0-2
aws-cli 1.25.71-1 1.25.81-1
broot 1.14.3-1 1.15.0-1
buildah 1.27.1-1 1.27.2-1
cargo-edit 0.11.1-1 0.11.2-1
cherrytree 0.99.47-1 0.99.49-1
cockpit 276.1-1 277-1
cockpit-machines 274-1 275-1
cockpit-packagekit 276.1-1 277-1
cockpit-pcp 276.1-1 277-1
cockpit-podman 53-1 54-1
cockpit-storaged 276.1-1 277-1
ct 0.9.3-1 0.9.4-1
dark-reader 4.9.57-1 4.9.58-1
darktable 2:4.0.0-1 2:4.0.1-1
dart-sass 1.54.9-1 1.55.0-1
diffoscope 221-1 222-1
din 54-1 55-1
drone 2.12.1-1 2.13.0-1
drone-oss 2.12.1-1 2.13.0-1
firefox-dark-reader 4.9.57-1 4.9.58-1
fluidd 1.20.0-1 1.20.1-1
fwupd 1.8.4-1 1.8.5-1
git-cliff 0.9.1-1 0.9.2-1
github-cli 2.15.0-1 2.16.0-1
gitlab-runner 15.3.0-1 15.4.0-1
gloobus-preview 0.4.5.336-3 0.4.5.336-4
gopass 1.14.6-1 1.14.7-1
helm 3.9.4-1 3.10.0-1
highway 0.15.0-1 1.0.1-1
home-assistant 1:2022.9.3-1 1:2022.9.5-1
httpbin 0.7.0-9 0.7.0-10
i3-gaps 4.20.1-2 4.21-1
ibus-table-chinese 1.8.8-1 1.8.9-1
jenkins 2.369-1 2.370-1
k9s 0.26.3-1 0.26.5-1
kdiskmark 2.3.0-2 3.1.2-1
knative-client 1.4.0-1 1.7.0-1
kubeconform 0.4.13-2 0.4.14-2
kubeseal 0.18.1-1 0.18.5-1
libdeflate 1.11-1 1.14-1
libjxl 0.6.1-3 0.7.0-2
libjxl-doc 0.6.1-3 0.7.0-2
libsemigroups 2.2.2-1 2.2.3-1
libtg_owt 0.git15.621f3da-10.git16.442d5bb593c0ae314960308d78f2016ad1f80c3e-1
libtraceevent 1:1.6.2-1 1:1.6.3-1
libtraceevent-docs 1:1.6.2-1 1:1.6.3-1
libtracefs 1.4.2-1 1.5.0-1
libtracefs-docs 1.4.2-1 1.5.0-1
libvips 8.13.1-1 8.13.1-2
libxdp 1.2.6-1 1.2.8-1
lxd 5.5-2 5.6-1
marked 4.0.16-1 4.0.18-1
mimir 2.2.0-1 2.3.0-1
minikube 1.26.1-1 1.27.0-1
msgpack-cxx 4.1.1-1 4.1.2-1
nextcloud-app-bookmarks 1:11.0.1-1 1:11.0.3-1
nextcloud-app-contacts 4.2.0-1 4.2.1-1
nodejs 18.9.0-1 18.9.1-1
npm-check-updates 16.2.1-1 16.3.1-1
nrpe 4.0.3-3 4.1.0-1
oil 0.12.5-1 0.12.6-1
openui5 1.102.7-1 1.106.0-1
parallel 20220822-1 20220922-1
parallel-docs 20220822-1 20220922-1
pdfarranger 1.9.0-2 1.9.1-1
pdftk 3.3.2-2 3.3.3-1
perl-path-tiny 0.122-2 0.124-1
perl-return-multilevel 0.08-2 0.08-3
perl-term-table 0.016-2 0.016-3
plantuml 1.2022.6-1 1.2022.7-1
powerline 2.8.2-4 2.8.3-1
powerline-common 2.8.2-4 2.8.3-1
powerline-fonts 2.8.2-4 2.8.3-1
powerline-vim 2.8.2-4 2.8.3-1
proxychains-ng 4.16-1 4.16-2
pulumi 3.39.3-1 3.40.1-1
python-aioresponses 0.7.3-1 0.7.3-2
python-ansible-compat 2.2.0-1 2.2.1-1
python-asteval 0.9.27-1 0.9.27-2
python-awkward 1.9.0-1 1.10.1-1
python-bincopy 17.10.3-1 17.14.0-1
python-boost-histogram 1.3.1-2 1.3.2-1
python-boto3 1.24.70-1 1.24.80-1
python-botocore 1.27.70-1 1.27.80-1
python-certifi 2022.09.14-1 2022.09.24-1
python-diff-cover 6.5.1-1 7.0.1-1
python-faker 9.3.0-1 9.3.1-1
python-fastjsonschema 2.16.1-1 2.16.2-1
python-graphql-core 3.2.1-1 3.2.2-1
python-libtmux 0.15.3-1 0.15.4-1
python-moto 4.0.0-1 4.0.5-1
python-paramiko 2.11.0-1 2.11.0-2
python-parse-type 0.6.0-1 0.6.0-2
python-peewee 3.15.2-1 3.15.3-1
python-plette 0.3.0-1 0.3.1-1
python-powerline 2.8.2-4 2.8.3-1
python-psutil 5.9.1-1 5.9.2-1
python-psycopg 3.1.1-1 3.1.2-1
python-pycryptodome 3.15.0-1 3.15.0-2
python-pyfakefs 4.6.3-1 4.7.0-1
python-pytest-django 4.5.2-1 4.5.2-2
python-pytest-forked 1.4.0-1 1.4.0-2
python-pytest-shell-utilities 1.6.0-1 1.7.0-1
python-pytest-xdist 2.5.0-1 2.5.0-2
python-redbaron 0.9.2-6 0.9.2-7
python-scikit-hep-testdata 0.4.20-1 0.4.21-1
python-setuptools-markdown 0.4.1-7 0.4.1-8
python-setuptools-rust 1.1.2-1 1.2.0-1
python-spsdk 1.7.0-1 1.7.1-1
python-stestr 4.0.0-1 4.0.1-1
python-svg.path 4.1-3 -
python-tenacity 8.0.1-3 8.1.0-1
python-trimesh 3.9.31-3 -
python-vector 0.8.5-2 0.10.0-1
python-xcffib 0.11.1-4 0.11.1-5
python-zeroconf 0.39.0-1 0.39.1-1
python2-docs 2.7.18-1 -
python2-pycryptodome 3.15.0-1 -
python2-typing 3.10.0.0-1 -
qtile 0.21.0-1 0.22.1-1
reaper 6.67-1 6.68-1
rekor 0.12.0-1 0.12.1-1
rpm-tools 4.17.1-1 4.18.0-1
rtirq 20210329-1 20220923-1
rubygems 3.3.19-1 3.3.21-1
salt 3004.2-1 3005-1
shotcut 22.06.23-1 22.09.23-1
singular 4.3.1.p2-2 4.3.1.p2-3
snapper 0.10.2-3 0.10.3-1
sopel 7.1.8-1 7.1.9-1
spire-agent 1.4.0-1 1.4.2-1
spire-server 1.4.0-1 1.4.2-1
streamlink 5.0.0-1 5.0.1-1
tcpreplay 4.4.1-1 4.4.2-1
telegram-desktop 4.1.1-1 4.2.0-1
terraform 1.2.9-1 1.3.0-1
terragrunt 0.38.9-1 0.38.12-1
■■■■■■■ 3.32-1 3.32-2
thunderbird-dark-reader 4.9.57-1 4.9.58-1
tmuxp 1.14.0-1 1.15.2-1
topcom 0.17.10-1 1.1.1-1
traefik 2.8.4-1 2.8.7-1
ttc-iosevka 16.1.0-1 16.2.0-1
ttc-iosevka-aile 16.1.0-1 16.2.0-1
ttc-iosevka-curly 16.1.0-1 16.2.0-1
ttc-iosevka-curly-slab 16.1.0-1 16.2.0-1
ttc-iosevka-etoile 16.1.0-1 16.2.0-1
ttc-iosevka-slab 16.1.0-1 16.2.0-1
ttc-iosevka-ss01 16.1.0-1 16.2.0-1
ttc-iosevka-ss02 16.1.0-1 16.2.0-1
ttc-iosevka-ss03 16.1.0-1 16.2.0-1
ttc-iosevka-ss04 16.1.0-1 16.2.0-1
ttc-iosevka-ss05 16.1.0-1 16.2.0-1
ttc-iosevka-ss06 16.1.0-1 16.2.0-1
ttc-iosevka-ss07 16.1.0-1 16.2.0-1
ttc-iosevka-ss08 16.1.0-1 16.2.0-1
ttc-iosevka-ss09 16.1.0-1 16.2.0-1
ttc-iosevka-ss10 16.1.0-1 16.2.0-1
ttc-iosevka-ss11 16.1.0-1 16.2.0-1
ttc-iosevka-ss12 16.1.0-1 16.2.0-1
ttc-iosevka-ss13 16.1.0-1 16.2.0-1
ttc-iosevka-ss14 16.1.0-1 16.2.0-1
ttc-iosevka-ss15 16.1.0-1 16.2.0-1
ttc-iosevka-ss16 16.1.0-1 16.2.0-1
ttc-iosevka-ss17 16.1.0-1 16.2.0-1
ttc-iosevka-ss18 16.1.0-1 16.2.0-1
unbound 1.16.2-1 1.16.3-1
v2ray-domain-list-community 20220921050909-1 20220924145006-1
v2ray-geoip 202209170841-1 202209220104-1
vapoursynth R59-1 R60-1
vulture 2.5-1 2.6-1
wails 1.16.9-2 2.0.0-2
wakatime 1:1.54.0-1 1:1.55.1-1
x42-plugins 20220914-1 20220923-1
xdp-tools 1.2.6-1 1.2.8-1
xfsdump 3.1.10-2 3.1.11-1
xreader 3.4.5-1 3.4.5-2
xsecurelock 1.7.0-2 1.8.0-1
cloudflared - 2022.9.1-1
lf - 27-2
python-babelfish - 0.6.0-2
python-guessit - 3.4.3-2
python-puremagic - 1.14-2
python-rebulk - 3.1.0-2
uasm - 2.55-2
:: Different overlay package(s) in repository core aarch64
linux 5.19.10-4 5.19.11-3
linux-clockworkpi-a06 5.19.10-1 5.19.11-1
linux-clockworkpi-a06-headers 5.19.10-1 5.19.11-1
linux-headers 5.19.10-4 5.19.11-3
linux-lts 5.15.69-1 5.15.70-1
linux-lts-headers 5.15.69-1 5.15.70-1
linux-pinephone 5.19.10-1 5.19.11-1
linux-pinephone-headers 5.19.10-1 5.19.11-1
linux-pinephonepro 5.19.10-1 5.19.11-1
linux-pinephonepro-headers 5.19.10-1 5.19.11-1
linux-rc 6.0.rc6-5 6.0.rc6-7
linux-rc-headers 6.0.rc6-5 6.0.rc6-7
linux515 5.15.69-1 5.15.70-1
linux515-headers 5.15.69-1 5.15.70-1
linux519 5.19.10-1 5.19.11-2
linux519-headers 5.19.10-1 5.19.11-2
pacman 6.0.1-8.2 6.0.1-9.1
:: Different sync package(s) in repository core aarch64
glib2 2.72.3-3 2.74.0-1
glib2-docs 2.72.3-3 2.74.0-1
iana-etc 20220715-1 20220915-1
libnghttp2 1.49.0-1 1.50.0-1
tzdata 2022c-1 2022d-1
:: Different overlay package(s) in repository extra aarch64
mesa-git22.3.0_devel.159906.9d3a5c916c5-122.3.0_devel.160395.26d1b0ca022-1
qt5-es2-wayland 5.15.6+kde+r47-1 5.15.6+kde+r49-1
:: Different sync package(s) in repository extra aarch64
aom 3.4.0-1 3.5.0-1
aom-docs 3.4.0-1 3.5.0-1
archinstall 2.5.0-1 2.5.1-1
bind 9.18.6-1 9.18.7-1
evince 42.3-1 42.3-2
evince-lib-docs 42.3-1 42.3-2
firefox 105.0-2 105.0.1-1
firefox-i18n-ach 105.0-1 105.0.1-1
firefox-i18n-af 105.0-1 105.0.1-1
firefox-i18n-an 105.0-1 105.0.1-1
firefox-i18n-ar 105.0-1 105.0.1-1
firefox-i18n-ast 105.0-1 105.0.1-1
firefox-i18n-az 105.0-1 105.0.1-1
firefox-i18n-be 105.0-1 105.0.1-1
firefox-i18n-bg 105.0-1 105.0.1-1
firefox-i18n-bn 105.0-1 105.0.1-1
firefox-i18n-br 105.0-1 105.0.1-1
firefox-i18n-bs 105.0-1 105.0.1-1
firefox-i18n-ca 105.0-1 105.0.1-1
firefox-i18n-ca-valencia 105.0-1 105.0.1-1
firefox-i18n-cak 105.0-1 105.0.1-1
firefox-i18n-cs 105.0-1 105.0.1-1
firefox-i18n-cy 105.0-1 105.0.1-1
firefox-i18n-da 105.0-1 105.0.1-1
firefox-i18n-de 105.0-1 105.0.1-1
firefox-i18n-dsb 105.0-1 105.0.1-1
firefox-i18n-el 105.0-1 105.0.1-1
firefox-i18n-en-ca 105.0-1 105.0.1-1
firefox-i18n-en-gb 105.0-1 105.0.1-1
firefox-i18n-en-us 105.0-1 105.0.1-1
firefox-i18n-eo 105.0-1 105.0.1-1
firefox-i18n-es-ar 105.0-1 105.0.1-1
firefox-i18n-es-cl 105.0-1 105.0.1-1
firefox-i18n-es-es 105.0-1 105.0.1-1
firefox-i18n-es-mx 105.0-1 105.0.1-1
firefox-i18n-et 105.0-1 105.0.1-1
firefox-i18n-eu 105.0-1 105.0.1-1
firefox-i18n-fa 105.0-1 105.0.1-1
firefox-i18n-ff 105.0-1 105.0.1-1
firefox-i18n-fi 105.0-1 105.0.1-1
firefox-i18n-fr 105.0-1 105.0.1-1
firefox-i18n-fy-nl 105.0-1 105.0.1-1
firefox-i18n-ga-ie 105.0-1 105.0.1-1
firefox-i18n-gd 105.0-1 105.0.1-1
firefox-i18n-gl 105.0-1 105.0.1-1
firefox-i18n-gn 105.0-1 105.0.1-1
firefox-i18n-gu-in 105.0-1 105.0.1-1
firefox-i18n-he 105.0-1 105.0.1-1
firefox-i18n-hi-in 105.0-1 105.0.1-1
firefox-i18n-hr 105.0-1 105.0.1-1
firefox-i18n-hsb 105.0-1 105.0.1-1
firefox-i18n-hu 105.0-1 105.0.1-1
firefox-i18n-hy-am 105.0-1 105.0.1-1
firefox-i18n-ia 105.0-1 105.0.1-1
firefox-i18n-id 105.0-1 105.0.1-1
firefox-i18n-is 105.0-1 105.0.1-1
firefox-i18n-it 105.0-1 105.0.1-1
firefox-i18n-ja 105.0-1 105.0.1-1
firefox-i18n-ka 105.0-1 105.0.1-1
firefox-i18n-kab 105.0-1 105.0.1-1
firefox-i18n-kk 105.0-1 105.0.1-1
firefox-i18n-km 105.0-1 105.0.1-1
firefox-i18n-kn 105.0-1 105.0.1-1
firefox-i18n-ko 105.0-1 105.0.1-1
firefox-i18n-lij 105.0-1 105.0.1-1
firefox-i18n-lt 105.0-1 105.0.1-1
firefox-i18n-lv 105.0-1 105.0.1-1
firefox-i18n-mk 105.0-1 105.0.1-1
firefox-i18n-mr 105.0-1 105.0.1-1
firefox-i18n-ms 105.0-1 105.0.1-1
firefox-i18n-my 105.0-1 105.0.1-1
firefox-i18n-nb-no 105.0-1 105.0.1-1
firefox-i18n-ne-np 105.0-1 105.0.1-1
firefox-i18n-nl 105.0-1 105.0.1-1
firefox-i18n-nn-no 105.0-1 105.0.1-1
firefox-i18n-oc 105.0-1 105.0.1-1
firefox-i18n-pa-in 105.0-1 105.0.1-1
firefox-i18n-pl 105.0-1 105.0.1-1
firefox-i18n-pt-br 105.0-1 105.0.1-1
firefox-i18n-pt-pt 105.0-1 105.0.1-1
firefox-i18n-rm 105.0-1 105.0.1-1
firefox-i18n-ro 105.0-1 105.0.1-1
firefox-i18n-ru 105.0-1 105.0.1-1
firefox-i18n-sco 105.0-1 105.0.1-1
firefox-i18n-si 105.0-1 105.0.1-1
firefox-i18n-sk 105.0-1 105.0.1-1
firefox-i18n-sl 105.0-1 105.0.1-1
firefox-i18n-son 105.0-1 105.0.1-1
firefox-i18n-sq 105.0-1 105.0.1-1
firefox-i18n-sr 105.0-1 105.0.1-1
firefox-i18n-sv-se 105.0-1 105.0.1-1
firefox-i18n-szl 105.0-1 105.0.1-1
firefox-i18n-ta 105.0-1 105.0.1-1
firefox-i18n-te 105.0-1 105.0.1-1
firefox-i18n-th 105.0-1 105.0.1-1
firefox-i18n-tl 105.0-1 105.0.1-1
firefox-i18n-tr 105.0-1 105.0.1-1
firefox-i18n-trs 105.0-1 105.0.1-1
firefox-i18n-uk 105.0-1 105.0.1-1
firefox-i18n-ur 105.0-1 105.0.1-1
firefox-i18n-uz 105.0-1 105.0.1-1
firefox-i18n-vi 105.0-1 105.0.1-1
firefox-i18n-xh 105.0-1 105.0.1-1
firefox-i18n-zh-cn 105.0-1 105.0.1-1
firefox-i18n-zh-tw 105.0-1 105.0.1-1
flac 1.4.0-1 1.4.1-1
flac-doc 1.4.0-1 1.4.1-1
ghostpcl 9.56.1-1 10.0.0-1
ghostscript 9.56.1-1 10.0.0-1
ghostxps 9.56.1-1 10.0.0-1
gimp 2.10.32-1 2.10.32-2
glib-networking 1:2.72.2-1 1:2.74.0-1
glibmm 2.66.4-1 2.66.5-1
glibmm-2.68 2.72.1-1 2.74.0-1
glibmm-2.68-docs 2.72.1-1 2.74.0-1
glibmm-docs 2.66.4-1 2.66.5-1
gobject-introspection 1.72.0-1 1.74.0-1
gobject-introspection-runtime 1.72.0-1 1.74.0-1
graphviz 5.0.1-1 5.0.1-2
hwdetect 2022.09-3 2022.09-4
imagemagick 7.1.0.48-1 7.1.0.49-1
imagemagick-doc 7.1.0.48-1 7.1.0.49-1
imlib2 1.9.1-1 1.9.1-2
kdesu 5.98.0-1 5.98.0-3
kimageformats 5.98.0-1 5.98.0-2
krita 5.1.1-1 5.1.1-2
kwayland 5.98.0-2 5.98.0-3
libbluray 1.3.2-1 1.3.3-1
libgxps 0.3.2-1 0.3.2-2
libreoffice-fresh 7.4.1-2 7.4.1-3
libreoffice-fresh-sdk 7.4.1-2 7.4.1-3
libspectre 0.2.10-1 0.2.10-2
libva 2.15.0-6 2.15.0-7
libwnck3 40.1-1 43.0-1
libwpe 1.12.3-1 1.14.0-1
lsof 4.95.0-1 4.96.3-1
mkinitcpio-archiso 63-1 64-1
pappl 1.2.1-1 1.2.2-1
perl-ffi-checklib 0.29-1 0.30-1
perl-net-dns-resolver-mock 1.20200215-5 1.20220817-1
python-mako 1.2.2-1 1.2.3-1
python-virtualenv 20.14.0-1 20.14.1-1
python2-setuptools 2:44.1.1-2 -
qt5-wayland 5.15.6+kde+r48-1 5.15.6+kde+r49-1
rust 1:1.63.0-1 1:1.64.0-1
rust-src 1:1.63.0-1 1:1.64.0-1
sdl2_image 2.6.2-1 2.6.2-2
sof-firmware 2.2.1-1 2.2.2-1
sof-tools 2.2.1-1 2.2.2-1
thunderbird 102.2.2-1 102.3.0-1
thunderbird-i18n-af 102.2.2-1 102.3.0-1
thunderbird-i18n-ar 102.2.2-1 102.3.0-1
thunderbird-i18n-ast 102.2.2-1 102.3.0-1
thunderbird-i18n-be 102.2.2-1 102.3.0-1
thunderbird-i18n-bg 102.2.2-1 102.3.0-1
thunderbird-i18n-br 102.2.2-1 102.3.0-1
thunderbird-i18n-ca 102.2.2-1 102.3.0-1
thunderbird-i18n-cak 102.2.2-1 102.3.0-1
thunderbird-i18n-cs 102.2.2-1 102.3.0-1
thunderbird-i18n-cy 102.2.2-1 102.3.0-1
thunderbird-i18n-da 102.2.2-1 102.3.0-1
thunderbird-i18n-de 102.2.2-1 102.3.0-1
thunderbird-i18n-dsb 102.2.2-1 102.3.0-1
thunderbird-i18n-el 102.2.2-1 102.3.0-1
thunderbird-i18n-en-gb 102.2.2-1 102.3.0-1
thunderbird-i18n-en-us 102.2.2-1 102.3.0-1
thunderbird-i18n-es-ar 102.2.2-1 102.3.0-1
thunderbird-i18n-es-es 102.2.2-1 102.3.0-1
thunderbird-i18n-et 102.2.2-1 102.3.0-1
thunderbird-i18n-eu 102.2.2-1 102.3.0-1
thunderbird-i18n-fi 102.2.2-1 102.3.0-1
thunderbird-i18n-fr 102.2.2-1 102.3.0-1
thunderbird-i18n-fy-nl 102.2.2-1 102.3.0-1
thunderbird-i18n-ga-ie 102.2.2-1 102.3.0-1
thunderbird-i18n-gd 102.2.2-1 102.3.0-1
thunderbird-i18n-gl 102.2.2-1 102.3.0-1
thunderbird-i18n-he 102.2.2-1 102.3.0-1
thunderbird-i18n-hr 102.2.2-1 102.3.0-1
thunderbird-i18n-hsb 102.2.2-1 102.3.0-1
thunderbird-i18n-hu 102.2.2-1 102.3.0-1
thunderbird-i18n-hy-am 102.2.2-1 102.3.0-1
thunderbird-i18n-id 102.2.2-1 102.3.0-1
thunderbird-i18n-is 102.2.2-1 102.3.0-1
thunderbird-i18n-it 102.2.2-1 102.3.0-1
thunderbird-i18n-ja 102.2.2-1 102.3.0-1
thunderbird-i18n-ka 102.2.2-1 102.3.0-1
thunderbird-i18n-kab 102.2.2-1 102.3.0-1
thunderbird-i18n-kk 102.2.2-1 102.3.0-1
thunderbird-i18n-ko 102.2.2-1 102.3.0-1
thunderbird-i18n-lt 102.2.2-1 102.3.0-1
thunderbird-i18n-ms 102.2.2-1 102.3.0-1
thunderbird-i18n-nb-no 102.2.2-1 102.3.0-1
thunderbird-i18n-nl 102.2.2-1 102.3.0-1
thunderbird-i18n-nn-no 102.2.2-1 102.3.0-1
thunderbird-i18n-pa-in 102.2.2-1 102.3.0-1
thunderbird-i18n-pl 102.2.2-1 102.3.0-1
thunderbird-i18n-pt-br 102.2.2-1 102.3.0-1
thunderbird-i18n-pt-pt 102.2.2-1 102.3.0-1
thunderbird-i18n-rm 102.2.2-1 102.3.0-1
thunderbird-i18n-ro 102.2.2-1 102.3.0-1
thunderbird-i18n-ru 102.2.2-1 102.3.0-1
thunderbird-i18n-sk 102.2.2-1 102.3.0-1
thunderbird-i18n-sl 102.2.2-1 102.3.0-1
thunderbird-i18n-sq 102.2.2-1 102.3.0-1
thunderbird-i18n-sr 102.2.2-1 102.3.0-1
thunderbird-i18n-sv-se 102.2.2-1 102.3.0-1
thunderbird-i18n-th 102.2.2-1 102.3.0-1
thunderbird-i18n-tr 102.2.2-1 102.3.0-1
thunderbird-i18n-uk 102.2.2-1 102.3.0-1
thunderbird-i18n-uz 102.2.2-1 102.3.0-1
thunderbird-i18n-vi 102.2.2-1 102.3.0-1
thunderbird-i18n-zh-cn 102.2.2-1 102.3.0-1
thunderbird-i18n-zh-tw 102.2.2-1 102.3.0-1
tomcat10 10.0.23-1 10.0.25-1
tomcat9 9.0.65-1 9.0.66-1
tracker-miners1:2.3.5+r3+gd9d61d87f-21:2.3.5+r3+gd9d61d87f-3
tracker3 3.3.3-1 3.4.0-1
tracker3-docs 3.3.3-1 3.4.0-1
tracker3-miners 3.3.1-2 3.4.0-2
webkit2gtk 2.36.7-1 2.38.0-2
webkit2gtk-4.1 2.36.7-1 2.38.0-2
webkit2gtk-5.0 2.36.7-1 2.38.0-2
wpebackend-fdo 1.12.1-1 1.14.0-1
wpewebkit 2.36.7-1 2.38.0-2
xorg-xkbprint 1.0.5-1 1.0.5-2
webkit2gtk-4.1-docs - 2.38.0-2
webkit2gtk-5.0-docs - 2.38.0-2
webkit2gtk-docs - 2.38.0-2
wpewebkit-docs - 2.38.0-2
:: Different overlay package(s) in repository kde-unstable aarch64
akregator22.08.1.r6467.g269a82b3-122.08.1.r6468.g9502d30f-1
alligator 22.06.r53.g3533c4b-1 22.06.r54.gea7e820-1
angelfish 22.06.r60.g516a931-1 22.06.r61.g903a6a6-1
ark22.08.1.r4843.g3e2f5298-122.08.1.r4844.g68e3d95b-1
audiocd-kio22.08.1.r1108.gde52745-122.08.1.r1110.g6f34356-1
audiotube 22.06.r38.g4c7db5d-1 22.06.r39.g14116b9-1
aura-browser r85.ad7280d-1 r87.cf2d8da-1
blinken22.08.1.r684.g7ce780d-122.08.1.r685.gf7cdbef-1
bluez-qt5.98.0.r722.g0aa271c-15.98.0.r723.g93739fb-1
breeze5.25.5.r2459.g1548737f-15.25.5.r2463.g3edee6f6-1
calindori 22.06.r20.gcc4435e-1 22.06.r21.g5d901d9-1
discover5.25.5.r8842.gecb14532-15.25.5.r8843.g84b316a5-1
dolphin22.08.1.r7090.g6c65d06bc-122.08.1.r7092.gc9271bf5b-1
elisa22.08.1.r3036.g01f63956-122.08.1.r3037.g32f5640b-1
elisa-qtmm22.08.1.r3036.g01f63956-122.08.1.r3037.g32f5640b-1
eventviews22.08.1.r878.g3175478-122.08.1.r879.g1d17fab-1
incidenceeditor22.08.1.r929.g5936c21-122.08.1.r930.g73b7387-1
k3b1:22.08.1.r6820.g06791702e-11:22.08.1.r6821.gea8593d12-1
kactivities-stats5.98.0.r419.g6d112a4-15.98.0.r420.g4694833-1
kaddressbook22.08.1.r6242.g27b84992-122.08.1.r6243.g50ef406e-1
kalgebra22.08.1.r2080.g4b39929-122.08.1.r2081.ga37dc18-1
kate22.08.1.r19581.gd650cd552-122.08.1.r19589.gc277ed7d9-1
kcalc22.08.1.r1632.gf5f967a-122.08.1.r1634.g599466d-1
kcharselect22.08.1.r542.gef794bb-122.08.1.r544.g28c1abb-1
kcolorchooser22.08.1.r282.g146cff8-122.08.1.r283.gb247fe8-1
kcontacts1:5.98.0.r3349.ga80a7142-11:5.98.0.r3350.g1d757eba-1
kdav1:5.98.0.r1356.gc8fb1d7-11:5.98.0.r1357.g79ca85d-1
kde-dev-scripts22.08.1.r4153.gebd2fd2-122.08.1.r4160.g17634bd-1
kdebugsettings22.08.1.r967.ge3488f0-122.08.1.r968.ged282d1-1
kdeconnect22.08.1.r3541.g6e679320-122.08.1.r3543.gae0815ea-1
kdegraphics-thumbnailers22.08.1.r281.gb5b329a-122.08.1.r282.g60bc567-1
kdenetwork-filesharing22.08.1.r985.g34f8836-122.08.1.r986.gd919ec9-1
kdeplasma-addons5.25.5.r9039.g4353fcb11-15.25.5.r9043.g91c86c213-1
kdesu5.98.0.r519.g3e2efce-15.98.0.r521.gbda57d5-1
kdialog22.08.1.r1240.g076549769-122.08.1.r1241.gba56917ee-1
kfilemetadata5.98.0.r876.gca96468-15.98.0.r877.gb25af77-1
kholidays1:5.98.0.r1060.g6f1fe68-11:5.98.0.r1061.g2ddf774-1
kiconthemes5.98.0.r634.gd8ca344-15.98.0.r636.g1f48af6-1
kidentitymanagement22.08.1.r3903.ga0406ad1-122.08.1.r3904.g6e156eb1-1
kimageformats5.98.0.r433.g6f3a326-15.98.0.r435.g2f27dff-1
kinfocenter5.25.5.r2158.gb05c2fd6-15.25.5.r2159.gd6bee8dc-1
kio5.98.0.r5706.g0b5eb5566-15.98.0.r5707.g1087dbcaa-1
kio-gdrive22.08.1.r641.g7278f5f-122.08.1.r644.g6c8de22-1
kirigami-addons 1:0.3.r16.gbd37cc5-1 1:0.3.r17.gd28810b-1
kirigami25.98.0.r3347.gb88f096b-15.98.0.r3350.g80e885e7-1
kitinerary22.08.1.r2394.g903ea18-122.08.1.r2396.g3410116-1
kleopatra22.08.1.r6850.g8e527a1d-122.08.1.r6852.g1dac90d9-1
knewstuff5.98.0.r1388.g35320e38-15.98.0.r1389.gceba876e-1
knotes22.08.1.r3696.g84b67a8b-122.08.1.r3697.g75f66b45-1
knotifications5.98.0.r759.g6281974-15.98.0.r760.g0450e43-1
koko 22.06.r24.g6719be6-1 22.06.r26.g4ce78c2-1
kopete22.08.1.r16451.gf605ed945-122.08.1.r16452.gac28f78d7-1
korganizer22.08.1.r11797.g4f7fab3f2-122.08.1.r11798.gd92b0c583-1
kpimtextedit22.08.1.r1624.gf3cdc48-122.08.1.r1626.g4078c88-1
kpublictransport22.08.1.r2046.g1bc888f3-122.08.1.r2047.gc7b54d48-1
kquickcharts5.98.0.r535.g907e6f7-15.98.0.r536.gfec03c3-1
kscreen5.25.5.r1537.g58b71b4-15.25.5.r1538.g07f2f68-1
ksystemlog22.08.1.r754.gcf2dfea-122.08.1.r755.gabb98ec-1
ktexteditor5.98.0.r3545.gfa13320b-15.98.0.r3546.gd1744032-1
kwayland5.98.0.r1185.g315270d-15.98.0.r1188.ga59a303-1
kweathercore 0.6.r24.gbed7445-1 0.6.r25.g5f915f8-1
kwin5.25.5.r23215.gf2defd1df-15.25.5.r23220.g1c6a95bce-1
kwrite22.08.1.r19581.gd650cd552-122.08.1.r19589.gc277ed7d9-1
libksieve22.08.1.r1741.g02a50cf6-122.08.1.r1743.ge82dad2e-1
libksysguard5.25.5.r2434.gc3655d6-15.25.5.r2435.gab3ed19-1
maliit-framework 2.3.0.r4.g19a763cb-1 2.3.0.r6.g5b0d1a0c-1
neochat22.06.r135.gd2ed1cfb-122.06.r142.g917f7715-1
networkmanager-qt5.98.0.r1165.gbdae716-15.98.0.r1166.g7e4ada1-1
pim-data-exporter22.08.1.r2786.g5709df23-122.08.1.r2787.gb07a4adc-1
pim-sieve-editor22.08.1.r1653.gaf93fbd-122.08.1.r1654.g826da88-1
pimcommon22.08.1.r1363.g1f85cbf-122.08.1.r1365.gf4bf3c9-1
plank-player r55.9aa61fa-1 r57.030d3c0-1
plasma-bigscreen r513.g885deff-1 r514.g6ea47b8-1
plasma-desktop5.25.5.r9653.g7204c2c95-15.25.5.r9662.g2664a3a94-1
plasma-dialer22.06.r118.gfaa6e37-122.06.r120.gf84bbf5-1
plasma-framework5.98.0.r16427.g3ec8b097c-15.98.0.r16429.gd674a99d1-1
plasma-mobile5.25.5.r1980.ge11f31f48-15.25.5.r1982.g9d7881f3c-1
plasma-mobile-nm5.25.5.r3336.ge914305c-15.25.5.r3337.ga0eedd40-1
plasma-nm5.25.5.r3336.ge914305c-15.25.5.r3337.ga0eedd40-1
plasma-pa5.25.5.r1090.g0fee41e-15.25.5.r1091.gdd339b2-1
plasma-systemmonitor5.25.5.r627.gbfe2062-15.25.5.r628.g352ae33-1
plasma-wayland-session5.25.5.r12379.gda38d4b03-15.25.5.r12393.g2bf362985-1
plasma-workspace5.25.5.r12379.gda38d4b03-15.25.5.r12393.g2bf362985-1
qmlkonsole 22.06.r43.g6f19359-1 22.06.r44.gd87bedb-1
qqc2-desktop-style5.98.0.r671.ga6612fb-15.98.0.r675.ga03c9b4-1
rocs22.08.1.r3123.gb07c1833-122.08.1.r3128.g7f23a916-1
systemsettings5.25.5.r2718.gb3ce91ba-15.25.5.r2719.g68c53794-1
tokodon 22.06.r37.g9f22197-1 22.06.r39.gfb56fe5-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
