Hello ARM community.
Some small updates and QT!
Some highlights:
- Most of our kernels got updated
- KDE Frameworks 5.98.0
- LibreOffice updated to 7.4.1
- QT5 updated to 5.15.6
- QT6 updated to 6.3.2
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Fri Sep 16 19:53:17 CEST 2022)
- arm-testing community aarch64: 367 new and 356 removed package(s)
- arm-testing core aarch64: 29 new and 29 removed package(s)
- arm-testing extra aarch64: 432 new and 434 removed package(s)
- arm-testing kde-unstable aarch64: 372 new and 372 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-09-09 2022-09-16
eg25-manager 0.4.4-1 0.4.4-2
electron 20.1.2-1 20.1.4-1
electron18 18.3.12-1 18.3.13-1
electron19 19.0.16-1 19.0.17-1
element-desktop 1.11.4-1 1.11.5-1
element-web 1.11.4-1 1.11.5-1
gcr-4 3.90.0-1 3.92.0-1
glacier-settings 0.6.1-1 0.6.2-1
gnome-shell-mobile43beta+r279+g8dc3dc1f3-143beta+r282+gddef14879-1
phosh 0.21.0-10.21.0+27+g3c1b8dae-1
phosh-next 0.21.0-10.21.0+27+g3c1b8dae-1
plasma-mobile-settings 20220812-1 20220916-1
ppkb-tools 1.0+30+g9116325-1 1.2-1
qt5-quickcontrols-nemo 5.7.2-1 5.7.4-1
qt5-sensors-sensorfw 5.15.5-1 5.15.6-1
rpi-imager 1.7.2-2 1.7.3-1
squeekboard 1.19.0-1 1.20.0-1
waydroid 1.3.1-1 1.3.2-1
maliit-framework - 2.3.0-1.1
maliit-keyboard - 2.3.1-1.1
:: Different sync package(s) in repository community aarch64
abletonlink 3.0.3-1 3.0.5-1
aerc 0.11.0-1 0.12.0-1
ansible 6.3.0-1 6.4.0-1
ansible-core 2.13.3-1 2.13.4-1
atuin 0.10.0-1 11.0.0-1
aws-cli 1.25.58-1 1.25.71-1
bat 0.22.0-1 0.22.1-1
bespokesynth 1.1.0-41.1.0.r154.g0acb8ebf-1
bitwarden-cli 2022.8.0-1 2022.9.0-1
blender 17:3.3.0-1 17:3.3.0-2
boinctui 2.6.0-1 2.7.0-1
broot 1.14.2-2 1.14.3-1
budgie-desktop 10.6.4-1 10.6.4-3
budgie-desktop-view 1.2-1 1.2-2
buildah 1.27.0-1 1.27.1-1
bupstash 0.11.0-2 0.11.1-1
caja-extensions-common 1.26.0-2 1.26.1-1
caja-image-converter 1.26.0-2 1.26.1-1
caja-open-terminal 1.26.0-2 1.26.1-1
caja-sendto 1.26.0-2 1.26.1-1
caja-share 1.26.0-2 1.26.1-1
caja-wallpaper 1.26.0-2 1.26.1-1
caja-xattr-tags 1.26.0-2 1.26.1-1
cargo-edit 0.10.4-1 0.11.1-1
cargo-spellcheck 0.11.2-1 0.12.1-1
cargo-udeps 0.1.32-2 0.1.33-1
cargo-zigbuild 0.12.0-1 0.12.3-1
certbot 1.29.0-1 1.30.0-1
certbot-apache 1.29.0-1 1.30.0-1
certbot-dns-cloudflare 1.29.0-1 1.30.0-1
certbot-dns-cloudxns 1.29.0-1 -
certbot-dns-digitalocean 1.29.0-1 1.30.0-1
certbot-dns-dnsimple 1.29.0-1 1.30.0-1
certbot-dns-dnsmadeeasy 1.29.0-1 1.30.0-1
certbot-dns-gehirn 1.29.0-1 1.30.0-1
certbot-dns-google 1.29.0-1 1.30.0-1
certbot-dns-linode 1.29.0-1 1.30.0-1
certbot-dns-luadns 1.29.0-1 1.30.0-1
certbot-dns-nsone 1.29.0-1 1.30.0-1
certbot-dns-ovh 1.29.0-1 1.30.0-1
certbot-dns-rfc2136 1.29.0-1 1.30.0-1
certbot-dns-route53 1.29.0-1 1.30.0-1
certbot-dns-sakuracloud 1.29.0-1 1.30.0-1
certbot-nginx 1.29.0-1 1.30.0-1
cinnamon 5.4.9-1 5.4.12-1
cinnamon-control-center 5.4.6-1 5.4.7-1
cinnamon-screensaver 5.4.2-1 5.4.4-1
cinnamon-settings-daemon 5.4.4-1 5.4.5-1
clasp 3.3.8-1 3.3.9-1
cocogitto 5.1.0-2 5.2.0-1
copyq 6.2.0-2 6.2.0-3
cosign 1.10.1-2 1.11.1-1
cutefish-screenlocker 0.5-1 0.5-2
dagger 0.2.32-1 0.2.34-1
dart-sass 1.54.8-1 1.54.9-1
datree 1.6.6-1 1.6.19-1
deepin-qt5platform-plugins 5.0.65-1 5.0.65-2
dehydrated 0.7.0-2 0.7.0-3
docker 1:20.10.17-1 1:20.10.18-1
dsp 1.9-1 1.9-2
dua-cli 2.17.8-1 2.18.0-1
dummyhttp 0.6.0-1 1.0.2-1
eksctl 0.108.0-1 0.111.0-1
elixir 1.13.4-1 1.14.0-1
enlightenment 0.25.3-1 0.25.4-1
erlang 25.0.3-1 25.0.4-1
erlang-nox 25.0.3-1 25.0.4-1
erlang-unixodbc 25.0.3-1 25.0.4-1
etckeeper 1.18.17-1 1.18.18-1
fcitx-qt5 1.2.7-5 1.2.7-6
fcitx-qt6 1.2.7-5 1.2.7-6
fcitx5-pinyin-zhwiki 1:0.2.4.20220722-1 1:0.2.4.20220909-1
fd 8.4.0-1 8.4.0-1.1
filezilla 3.60.2-1 3.60.2-3
firefox-tree-style-tab 3.8.26-1 3.9.2-1
freecad 0.20.1-5 0.20.1-6
fulcio 0.5.2-1 0.5.3-1
gamescope 3.11.43-1 3.11.44-1
gammastep 2.0.8-1 2.0.9-1
gdu 5.16.0-1 5.17.1-1
genact 1.0.0-1 1.1.1-1
gitea 1.17.0-1 1.17.2-1
go 2:1.19-1 2:1.19.1-1
go-ethereum 1.10.23-1 1.10.25-1
go-yq 4.27.4-1 4.27.5-1
gopass 1.14.4-1 1.14.6-1
gopass-jsonapi 1.11.1-2 1.14.6-1
gopls 0.9.4-1 0.9.5-1
grails 5.1.2-1 5.2.3-1
grails-docs 5.1.2-1 5.2.3-1
gum 0.5.0-1 0.6.0-1
hashcat 1:6.2.5-1 1:6.2.6-1
helmfile 0.145.2-1 0.145.4-1
home-assistant 1:2022.8.7-1 1:2022.9.3-1
hound 0.5.1-1 0.6.0-1
ibus-m17n 1.4.11-1 1.4.13-1
ibus-table 1.16.11-1 1.16.12-1
ibus-table-chinese 1.8.6-1 1.8.7-1
ibus-unikey 0.6.1-6 0.6.1-7
iwd 1.29-1 1.30-1
jenkins 2.367-1 2.368-1
jruby 9.3.7.0-1 9.3.8.0-1
jupyter-nbclient 0.6.7-1 0.6.8-1
jupyter-nbformat 5.4.0-1 5.5.0-1
jupyterlab 3.4.6-1 3.4.7-1
just 1.4.0-1 1.5.0-1
kiwix-desktop 2.2.2-2 2.3.0-1
kmymoney 5.1.3-1 5.1.3-2
ko 0.11.2-2 0.12.0-3
kube-apiserver 1.25.0-1 1.25.1-1
kube-controller-manager 1.25.0-1 1.25.1-1
kube-proxy 1.25.0-1 1.25.1-1
kube-scheduler 1.25.0-1 1.25.1-1
kubeadm 1.25.0-1 1.25.1-1
kubectl 1.25.0-1 1.25.1-1
kubelet 1.25.0-1 1.25.1-1
kubernetes-control-plane-common 1.25.0-1 1.25.1-1
kubo 0.14.0-1 0.15.0-1
libayatana-indicator 0.9.1-2 0.9.2-1
libfilezilla 1:0.38.1-1 1:0.39.1-1
libfm-qt 1.1.0-3 1.1.0-4
libglacierapp 0.8.1-1 0.8.2-1
libharu 2.4.1-1 2.4.2-1
libluv 1.44.2_0-1 1.44.2_1-1
libqtxdg 3.9.1-3 3.9.1-4
libretro-beetle-pce-fast 1190-1 1191-1
libretro-beetle-psx 2623-1 2628-1
libretro-beetle-psx-hw 2623-1 2628-1
libretro-dolphin 33021-2 33024-1
libretro-gambatte 976-1 977-1
libretro-genesis-plus-gx 1928-1 1932-1
libretro-nestopia 1:89-1 1:91-1
libretro-play 7354-1 7389-1
libretro-shaders-slang 1003-1 1033-1
libsemigroups 2.2.1-1 2.2.2-1
libzim 8.0.0-1 8.0.1-1
lmms 1.2.2-10 1.2.2-11
lua-luv 1.44.2_0-1 1.44.2_1-1
lua51-luv 1.44.2_0-1 1.44.2_1-1
lua52-luv 1.44.2_0-1 1.44.2_1-1
lua53-luv 1.44.2_0-1 1.44.2_1-1
marked 4.0.10-1 4.0.12-1
matrix-appservice-irc 0.34.0-2 0.35.0-1
maturin 0.13.2-1 0.13.3-1
miniserve 0.20.0-1 0.21.0-1
muffin 5.4.5-1 5.4.7-1
mumble 1.4.274-1 1.4.287-1
murmur 1.4.274-1 1.4.287-1
neatvnc 0.5.3-1 0.5.4-1
nemo 5.4.2-1 5.4.3-1
nemo-qml-plugin-notifications 1.0.11-1 1.0.12-1
nemo-theme-glacier 0.2-1 0.2.1-1
nerdctl 0.22.2-1 0.23.0-1
nextcloud 24.0.4-1 24.0.5-1
nextcloud-client 2:3.5.4-1 2:3.6.0-2
nextcloud-client-cloudproviders 2:3.5.4-1 2:3.6.0-2
npm 8.19.1-1 8.19.2-1
npm-check-updates 16.0.1-1 16.1.1-1
nuitka 1.0.6-1 1.0.7-1
nushell 0.67.0-1 0.68.1-1
open-isns 0.101-1 0.102-1
otf-font-awesome 6.1.2-1 6.2.0-1
oxipng 5.0.1-1 6.0.1-1
papirus-icon-theme 20220808-1 20220910-1
patchage 1.0.8-1 1.0.10-1
pcsclite 1.9.8-1 1.9.9-1
pdfjs 2.15.349-1 2.16.105-1
perl-acme-alien-dontpanic 2.5300-1 2.5900-1
perl-alien-base-modulebuild 1.15-5 1.17-1
perl-type-tiny 1.016006-1 1.016010-1
pgcli 3.4.1-2 3.5.0-1
php-mongodb 1.14.0-1 1.14.1-1
php7-mongodb 1.14.0-1 1.14.1-1
pifpaf 3.1.5-3 3.1.5-4
profanity 1:0.12.1-2 1:0.13.0-1
profanity-gtk 1:0.12.1-2 1:0.13.0-1
profile-sync-daemon 1:6.47-1 1:6.48-1
pulumi 3.38.0-1 3.39.3-1
pyright 1.1.270-1 1.1.271-1
python-acme 1.29.0-1 1.30.0-1
python-aioconsole 0.5.0-1 0.5.1-1
python-aiodiscover 1.4.11-1 1.4.13-1
python-aws-sam-translator 1.50.0-1 1.51.0-1
python-billiard 4.0.1-1 4.0.2-1
python-bleak 0.16.0-1 0.17.0-1
python-boto3 1.24.57-1 1.24.70-1
python-botocore 1.27.57-1 1.27.70-1
python-certifi 2022.06.15-1 2022.09.14-1
python-cfn-lint 0.64.1-1 0.65.0-1
python-chameleon 3.10.0-1 3.10.1-1
python-cryptography-vectors 38.0.0-1 38.0.1-1
python-discogs-client 2.3.15-1 2.4-1
python-django-extensions 3.2.0-1 3.2.1-1
python-docker 5.0.3-3 6.0.0-1
python-doublex 1.9.3-2 1.9.4-1
python-faker 9.0.1-1 9.1.0-1
python-fastapi 0.82.0-1 0.85.0-1
python-fonttools 4.37.1-1 4.37.2-1
python-glanceclient 4.0.1-1 4.1.0-1
python-glfw 2.5.4-1 2.5.5-1
python-google-api-core 2.8.2-1 2.10.0-1
python-google-api-python-client 2.57.0-1 2.60.0-1
python-google-auth 1.35.0-1 2.0.2-1
python-graphene 3.1.0-1 3.1.1-1
python-igraph 0.10.0-1 0.10.1-1
python-ipykernel 6.15.2-1 6.15.3-1
python-itemadapter 0.6.0-1 0.7.0-1
python-json-logger 2.0.3-1 2.0.4-1
python-jsonpickle 2.1.0-1 2.2.0-1
python-jsonschema 4.15.0-1 4.16.0-1
python-jwcrypto 1.3.1-1 1.4.2-1
python-keystoneauth1 4.6.0-1 5.0.0-1
python-latex2mathml 3.63.1-1 3.64.0-1
python-libtmux 0.14.2-1 0.15.1-1
python-litedram 2020.12-3 2021.04-1
python-liteeth 2020.12-3 2021.04-1
python-liteiclink 2020.12-3 2021.04-1
python-litejesd204b 2020.12-3 2021.04-1
python-litepcie 2020.12-3 2021.04-1
python-litesata 2020.12-3 2021.04-1
python-litescope 2020.12-3 2021.04-1
python-litesdcard 2020.12-3 2021.04-1
python-litevideo 2020.12-3 2021.04-1
python-litex 2020.12-3 2021.04-1
python-litex-boards 2020.12-3 2021.04-1
python-mamba 0.11.2-3 0.11.2-4
python-mocket 3.10.7-1 3.10.8-1
python-mockito 1.3.2-1 1.3.4-1
python-nbxmpp 3.1.1-1 3.2.1-1
python-ntlm-auth 1.5.0-5 1.5.0-6
python-openapi-core 0.14.5-1 0.15.0-1
python-openapi-schema-validator 0.3.2-1 0.3.4-1
python-openapi-spec-validator 0.5.0-1 0.5.1-1
python-openstacksdk 0.100.0-1 0.101.0-1
python-oslo-utils 4.12.3-1 6.0.1-1
python-pandas 1.4.3-1 1.4.4-1
python-pgspecial 1.13.1-2 2.0.1-1
python-phonenumbers 8.12.54-1 8.12.55-1
python-pipenv 2022.9.4-1 2022.9.8-1
python-prompt_toolkit 3.0.30-2 3.0.31-1
python-psycopg 3.1-1 3.1.1-1
python-psycopg-pool 3.1.1-2 3.1.2-1
python-pycapnp 1.2.0-1 1.2.1-1
python-pyhamcrest 2.0.0-1 2.0.1-1
python-pyrsistent 0.18.1-1 0.19.0-1
python-pysrt 1.1.2-3 1.1.2-4
python-pytest-httpserver 1.0.5-1 1.0.6-1
python-qiniu 7.9.0-1 7.9.0-2
python-readme-renderer 37.0-1 37.1-1
python-requirementslib 2.0.0-1 2.0.2-1
python-rope 0.23.0-1 1.3.0-1
python-sphinx-furo 2022.06.21-1 2022.09.15-1
python-sphinxcontrib-towncrier 0.2.1a0-1 0.3.0a0-1
python-termcolor 1.1.0-12 2.0.0-1
python-traitlets 5.3.0-1 5.4.0-1
python-warlock 1.3.3-7 2.0.1-1
python-watchdog 1.0.1-1 1.0.2-1
python-xmlschema 2.0.1-1 2.0.3-1
python-z3-solver 4.11.0-1 4.11.2-1
python-zope-hookable 5.1.0-3 5.2-1
python-zope-schema 6.2.0-3 6.2.1-1
python-zope-security 5.3-1 5.4-1
pyzy 1.0-6 1.1-1
qcad 3.27.6.7-3 3.27.6.7-4
qgnomeplatform-qt5 0.8.4-4 0.8.4-5
qgnomeplatform-qt6 0.8.4-4 0.8.4-5
qt5-quickcontrols-nemo 5.6.6-1 5.7-1
qt5-ukui-platformtheme 1.0.8-1 1.0.8-2
rclone 1.59.1-1 1.59.2-1
rekor 0.11.0-1 0.12.0-1
repo 2.29.1-1 2.29.2-1
rime-pinyin-zhwiki 1:0.2.4.20220722-1 1:0.2.4.20220909-1
ruby-atk 3.5.1-1 4.0.3-1
ruby-bundler 2.3.19-1 2.3.22-1
ruby-cairo-gobject 3.5.1-1 4.0.3-1
ruby-gdk3 3.5.1-1 4.0.3-1
ruby-gdk_pixbuf2 3.5.1-1 4.0.3-1
ruby-gio2 3.5.1-1 4.0.3-1
ruby-glib2 3.5.1-1 4.0.3-1
ruby-gobject-introspection 3.5.1-1 4.0.3-1
ruby-gtk3 3.5.1-1 4.0.3-1
ruby-pango 3.5.1-1 4.0.3-1
rust-analyzer 20220905-1 20220912-1
rust-bindgen 0.60.0-1 0.60.1-1
serd 0.30.14-1 0.30.16-1
serd-docs 0.30.14-1 0.30.16-1
singular 4.3.1.p2-1 4.3.1.p2-2
skrooge 2.28.0-1 2.28.0-2
snd 22.6-1 22.7-1
solaar 1.1.4-2 1.1.5-1
sopel 7.1.4-1 7.1.7-1
sord 0.16.12-3 0.16.14-1
sord-docs 0.16.12-3 0.16.14-1
sqlfluff 1.3.0-1 1.3.1-1
sratom 0.6.12-1 0.6.14-1
sratom-docs 0.6.12-1 0.6.14-1
srs-state-threads 1.9.3-2 1.9.4-1
stb r2126.af1a5bc-1 r2129.8b5f1f3-1
step-ca 0.21.0-1 0.22.1-1
stunnel 5.65-1 5.66-1
sunpinyin 3.0.0rc1-4 3.0.0rc2-1
syft 0.53.4-1 0.55.0-1
tailscale 1.30.0-1 1.30.1-1
tea 0.8.0-2 0.9.0-1
tmuxp 1.13.1-1 1.14.0-1
traefik 2.8.3-1 2.8.4-1
tt-rss 2:r11325.8f19423c2-1 2:r11370.d47b8c849-1
ttf-font-awesome 6.1.2-1 6.2.0-1
ttf-iosevka-nerd 2.2.1-1 2.2.2-1
typescript 4.8.2-1 4.8.3-1
typescript-language-server 1.1.2-1 1.2.0-1
ukui-panel 3.0.5-1 3.0.6.4-1
ukui-settings-daemon 3.0.3-1 3.1.1.1-1
ukui-themes 1.4.1-1 3.0.1-1
ukui-window-switch 3.0.1-5 3.0.1-6
unicode-cldr 39.0-1 40.0-1
unicode-cldr-annotations 39.0-1 40.0-1
v2ray 4.45.2-1 5.1.0-2
v2ray-domain-list-community 20220907153354-1 20220915110629-1
v2ray-geoip 202209080101-1 202209150105-1
vaultwarden-web 2022.8.1-1 2022.9.0-1
visidata 2.10-1 2.10.1-1
wallutils 5.11.1-1 5.12.2-1
wcslib 7.11-1 7.12-1
wimlib 1.13.5-1 1.13.6-1
woodpecker-agent 0.15.3-1 0.15.4-1
woodpecker-cli 0.15.3-1 0.15.4-1
woodpecker-server 0.15.3-1 0.15.4-1
xapp 2.2.14-1 2.2.15-1
xplr 0.19.0-1 0.19.3-1
xreader 3.4.2-1 3.4.5-1
yaegi 0.14.1-1 0.14.2-1
yamllint 1.27.1-2 1.28.0-1
z3 4.11.0-1 4.11.2-1
zellij 0.31.3-1 0.31.4-1
zigbee2mqtt 1.27.2-1 1.27.2-2
zim-tools 3.1.1-2 3.1.2-1
zutty 0.12-1 0.13-1
budgie-control-center - 1.1.1-2
ladybird - 20220912-2
libxml++2.6 - 2.42.1-1
libxml++2.6-docs - 2.42.1-1
munge - 0.5.15-2
pdfjs-legacy - 2.16.105-1
python-pep440 - 0.1.2-1
ruby-gdk4 - 4.0.3-1
ruby-gtk4 - 4.0.3-1
ruby-vte3 - 4.0.3-1
:: Different overlay package(s) in repository core aarch64
linux 5.19.8-1 5.19.9-1
linux-clockworkpi-a06 5.19.8-1 5.19.9-1
linux-clockworkpi-a06-headers 5.19.8-1 5.19.9-1
linux-headers 5.19.8-1 5.19.9-1
linux-lts 5.15.67-1 5.15.68-1
linux-lts-headers 5.15.67-1 5.15.68-1
linux-pinephone 5.19.8-1 5.19.9-1
linux-pinephone-headers 5.19.8-1 5.19.9-1
linux-pinephonepro 5.19.8-1 5.19.9-1
linux-pinephonepro-headers 5.19.8-1 5.19.9-1
linux-rc 6.0.rc4-2 6.0.rc5-1
linux-rc-headers 6.0.rc4-2 6.0.rc5-1
linux-rpi4 5.15.61-1 5.15.67-1
linux-rpi4-headers 5.15.61-1 5.15.67-1
linux-rpi4-mainline 5.19.3-1 5.19.8-1
linux-rpi4-mainline-headers 5.19.3-1 5.19.8-1
linux-rpi4-rc 6.0.rc3-1 6.0.rc5-1
linux-rpi4-rc-headers 6.0.rc3-1 6.0.rc5-1
:: Different sync package(s) in repository core aarch64
ca-certificates 20210603-1 20220905-1
ca-certificates-utils 20210603-1 20220905-1
curl 7.85.0-1 7.85.0-2
gawk 5.1.1-1 5.2.0-3
gc 8.2.0-3 8.2.2-1
grep 3.7-1 3.8-2
hwdata 0.361-1 0.362-1
libcurl-compat 7.85.0-1 7.85.0-2
libcurl-gnutls 7.85.0-1 7.85.0-2
python 3.10.6-1 3.10.7-1
python-tests 3.10.6-1 3.10.7-1
:: Different overlay package(s) in repository extra aarch64
kwin 5.25.5-1.1 5.25.5-2.1
libnm 1.38.2-1 1.40.0-1
manjaro-settings-manager 0.5.7-2 0.5.7-3
manjaro-settings-manager-kcm 0.5.7-2 0.5.7-3
mesa-git22.3.0_devel.159254.a03ce740bbb-122.3.0_devel.159481.dcc52618952-1
networkmanager 1.38.2-1 1.40.0-1
nm-cloud-setup 1.38.2-1 1.40.0-1
qt5-es2-base 5.15.5+kde+r184-1 5.15.6+kde+r165-1
qt5-es2-datavis3d 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-es2-declarative 5.15.5+kde+r19-1 5.15.6+kde+r20-1
qt5-es2-multimedia 5.15.5+kde+r1-1 5.15.6+kde+r1-1
qt5-es2-wayland 5.15.5+kde+r38-4 5.15.6+kde+r43-1
qt5-es2-xcb-private-headers 5.15.5+kde+r184-1 5.15.6+kde+r165-1
snapd 2.57.1-2 2.57.2-1
thunderbird 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-af 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-ar 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-ast 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-be 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-bg 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-br 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-ca 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-cak 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-cs 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-cy 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-da 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-de 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-dsb 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-el 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-en-gb 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-en-us 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-es-ar 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-es-es 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-et 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-eu 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-fi 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-fr 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-fy-nl 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-ga-ie 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-gd 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-gl 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-he 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-hr 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-hsb 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-hu 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-hy-am 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-id 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-is 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-it 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-ja 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-ka 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-kab 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-kk 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-ko 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-lt 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-ms 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-nb-no 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-nl 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-nn-no 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-pa-in 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-pl 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-pt-br 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-pt-pt 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-rm 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-ro 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-ru 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-sk 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-sl 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-sq 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-sr 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-sv-se 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-th 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-tr 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-uk 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-uz 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-vi 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-zh-cn 102.2.2-0.1 102.2.2-0.2
thunderbird-i18n-zh-tw 102.2.2-0.1 102.2.2-0.2
:: Different sync package(s) in repository extra aarch64
akonadi 22.08.1-1 22.08.1-2
assimp 5.2.4-2 5.2.5-1
asymptote 2.79-1 2.82-1
attica 5.97.0-1 5.98.0-1
audacious 4.1-3 4.2-3
audacious-plugins 4.1-6 4.2-1
baloo 5.97.0-1 5.98.0-1
bluez-qt 5.97.0-1 5.98.0-1
breeze-icons 5.97.0-1 5.98.0-1
chromium 105.0.5195.102-2 105.0.5195.125-1
cmake 3.24.1-1 3.24.2-1
ell 0.52-1 0.53-1
emacs 28.1-7 28.2-1
emacs-nativecomp 28.1-7 28.2-1
emacs-nox 28.1-7 28.2-1
expect 5.45.4-3 5.45.4-4
extra-cmake-modules 5.97.0-1 5.98.0-1
frameworkintegration 5.97.0-1 5.98.0-1
grantlee 5.2.0-3 5.3.0-1
gsasl 2.0.1-1 2.2.0-1
gtkmm-4.0 4.6.1-1 4.8.0-1
gtkmm-4.0-docs 4.6.1-1 4.8.0-1
gtkmm3 3.24.6-1 3.24.7-1
gtkmm3-docs 3.24.6-1 3.24.7-1
hwdetect 2022.04-2 2022.09-1
imagemagick 7.1.0.47-2 7.1.0.48-1
imagemagick-doc 7.1.0.47-2 7.1.0.48-1
iso-codes 4.11.0-1 4.11.0-2
kactivities 5.97.0-1 5.98.0-1
kactivities-stats 5.97.0-1 5.98.0-1
kapidox 5.97.0-1 5.98.0-1
karchive 5.97.0-1 5.98.0-1
kauth 5.97.0-1 5.98.0-1
kbookmarks 5.97.0-1 5.98.0-1
kcalendarcore 5.97.0-1 5.98.0-1
kcmutils 5.97.0-1 5.98.0-1
kcodecs 5.97.0-1 5.98.0-1
kcompletion 5.97.0-1 5.98.0-1
kconfig 5.97.0-1 5.98.0-1
kconfigwidgets 5.97.0-1 5.98.0-1
kcontacts 1:5.97.0-1 1:5.98.0-1
kcoreaddons 5.97.0-1 5.98.0-1
kcrash 5.97.0-1 5.98.0-1
kdav 1:5.97.0-1 1:5.98.0-1
kdbusaddons 5.97.0-1 5.98.0-1
kdeclarative 5.97.0-1 5.98.0-1
kded 5.97.0-1 5.98.0-1
kdelibs4support 5.97.0-1 5.98.0-1
kdesignerplugin 5.97.0-1 5.98.0-1
kdesu 5.97.0-1 5.98.0-1
kdewebkit 5.97.0-1 5.98.0-1
kdnssd 5.97.0-1 5.98.0-1
kdoctools 5.97.0-1 5.98.0-1
kdsoap 2.0.0-1 2.1.1-1
kemoticons 5.97.0-1 5.98.0-1
kfilemetadata 5.97.0-1 5.98.0-1
kglobalaccel 5.97.0-1 5.98.0-1
kguiaddons 5.97.0-1 5.98.0-1
kholidays 1:5.97.0-1 1:5.98.0-1
khtml 5.97.0-1 5.98.0-1
ki18n 5.97.0-1 5.98.0-1
kiconthemes 5.97.0-1 5.98.0-1
kidletime 5.97.0-1 5.98.0-1
kimageformats 5.97.0-1 5.98.0-1
kinit 5.97.0-1 5.98.0-1
kio 5.97.0-1 5.98.0-1
kirigami2 5.97.0-1 5.98.0-1
kitemmodels 5.97.0-1 5.98.0-1
kitemviews 5.97.0-1 5.98.0-1
kjobwidgets 5.97.0-1 5.98.0-1
kjs 5.97.0-1 5.98.0-1
kjsembed 5.97.0-1 5.98.0-1
kmediaplayer 5.97.0-1 5.98.0-1
knewstuff 5.97.0-1 5.98.0-1
knotifications 5.97.0-1 5.98.0-1
knotifyconfig 5.97.0-1 5.98.0-1
kpackage 5.97.0-1 5.98.0-1
kparts 5.97.0-1 5.98.0-1
kpeople 5.97.0-1 5.98.0-1
kplotting 5.97.0-1 5.98.0-1
kpty 5.97.0-1 5.98.0-1
kquickcharts 5.97.0-1 5.98.0-1
krita 5.1.0-1 5.1.1-1
kross 5.97.0-1 5.98.0-1
krunner 5.97.0-1 5.98.0-1
kservice 5.97.0-1 5.98.0-1
ktexteditor 5.97.0-1 5.98.0-1
ktextwidgets 5.97.0-1 5.98.0-1
kunitconversion 5.97.0-1 5.98.0-1
kwallet 5.97.0-4 5.98.0-1
kwayland 5.97.0-1 5.98.0-1
kwidgetsaddons 5.97.0-1 5.98.0-1
kwin 5.25.5-1 5.25.5-2
kwindowsystem 5.97.0-1 5.98.0-1
kxmlgui 5.97.0-1 5.98.0-1
kxmlrpcclient 5.97.0-1 5.98.0-1
libadwaita 1:1.1.5-1 1:1.2.0-1
libadwaita-demos 1:1.1.5-1 1:1.2.0-1
libadwaita-docs 1:1.1.5-1 1:1.2.0-1
libakonadi 22.08.1-1 22.08.1-2
libglvnd 1.4.0-3 1.5.0-1
libguess 1.2-4 -
libgusb 0.3.10-2 0.4.0-1
libhandy 1.6.3-1 1.8.0-1
libhandy-docs 1.6.3-1 1.8.0-1
libmm-glib 1.18.10-2 1.18.12-1
libnma 1.10.0-1 1.10.2-1
libnma-common 1.10.0-1 1.10.2-1
libnma-gtk4 1.10.0-1 1.10.2-1
libreoffice-fresh 7.4.0-4 7.4.1-1
libreoffice-fresh-af 7.4.0-1 7.4.1-1
libreoffice-fresh-am 7.4.0-1 7.4.1-1
libreoffice-fresh-ar 7.4.0-1 7.4.1-1
libreoffice-fresh-as 7.4.0-1 7.4.1-1
libreoffice-fresh-ast 7.4.0-1 7.4.1-1
libreoffice-fresh-be 7.4.0-1 7.4.1-1
libreoffice-fresh-bg 7.4.0-1 7.4.1-1
libreoffice-fresh-bn 7.4.0-1 7.4.1-1
libreoffice-fresh-bn-in 7.4.0-1 7.4.1-1
libreoffice-fresh-bo 7.4.0-1 7.4.1-1
libreoffice-fresh-br 7.4.0-1 7.4.1-1
libreoffice-fresh-brx 7.4.0-1 7.4.1-1
libreoffice-fresh-bs 7.4.0-1 7.4.1-1
libreoffice-fresh-ca 7.4.0-1 7.4.1-1
libreoffice-fresh-ca-valencia 7.4.0-1 7.4.1-1
libreoffice-fresh-ckb 7.4.0-1 7.4.1-1
libreoffice-fresh-cs 7.4.0-1 7.4.1-1
libreoffice-fresh-cy 7.4.0-1 7.4.1-1
libreoffice-fresh-da 7.4.0-1 7.4.1-1
libreoffice-fresh-de 7.4.0-1 7.4.1-1
libreoffice-fresh-dgo 7.4.0-1 7.4.1-1
libreoffice-fresh-dsb 7.4.0-1 7.4.1-1
libreoffice-fresh-dz 7.4.0-1 7.4.1-1
libreoffice-fresh-el 7.4.0-1 7.4.1-1
libreoffice-fresh-en-gb 7.4.0-1 7.4.1-1
libreoffice-fresh-en-za 7.4.0-1 7.4.1-1
libreoffice-fresh-eo 7.4.0-1 7.4.1-1
libreoffice-fresh-es 7.4.0-1 7.4.1-1
libreoffice-fresh-et 7.4.0-1 7.4.1-1
libreoffice-fresh-eu 7.4.0-1 7.4.1-1
libreoffice-fresh-fa 7.4.0-1 7.4.1-1
libreoffice-fresh-fi 7.4.0-1 7.4.1-1
libreoffice-fresh-fr 7.4.0-1 7.4.1-1
libreoffice-fresh-fur 7.4.0-1 7.4.1-1
libreoffice-fresh-fy 7.4.0-1 7.4.1-1
libreoffice-fresh-ga 7.4.0-1 7.4.1-1
libreoffice-fresh-gd 7.4.0-1 7.4.1-1
libreoffice-fresh-gl 7.4.0-1 7.4.1-1
libreoffice-fresh-gu 7.4.0-1 7.4.1-1
libreoffice-fresh-gug 7.4.0-1 7.4.1-1
libreoffice-fresh-he 7.4.0-1 7.4.1-1
libreoffice-fresh-hi 7.4.0-1 7.4.1-1
libreoffice-fresh-hr 7.4.0-1 7.4.1-1
libreoffice-fresh-hsb 7.4.0-1 7.4.1-1
libreoffice-fresh-hu 7.4.0-1 7.4.1-1
libreoffice-fresh-id 7.4.0-1 7.4.1-1
libreoffice-fresh-is 7.4.0-1 7.4.1-1
libreoffice-fresh-it 7.4.0-1 7.4.1-1
libreoffice-fresh-ja 7.4.0-1 7.4.1-1
libreoffice-fresh-ka 7.4.0-1 7.4.1-1
libreoffice-fresh-kab 7.4.0-1 7.4.1-1
libreoffice-fresh-kk 7.4.0-1 7.4.1-1
libreoffice-fresh-km 7.4.0-1 7.4.1-1
libreoffice-fresh-kmr-latn 7.4.0-1 7.4.1-1
libreoffice-fresh-kn 7.4.0-1 7.4.1-1
libreoffice-fresh-ko 7.4.0-1 7.4.1-1
libreoffice-fresh-kok 7.4.0-1 7.4.1-1
libreoffice-fresh-ks 7.4.0-1 7.4.1-1
libreoffice-fresh-lb 7.4.0-1 7.4.1-1
libreoffice-fresh-lo 7.4.0-1 7.4.1-1
libreoffice-fresh-lt 7.4.0-1 7.4.1-1
libreoffice-fresh-lv 7.4.0-1 7.4.1-1
libreoffice-fresh-mai 7.4.0-1 7.4.1-1
libreoffice-fresh-mk 7.4.0-1 7.4.1-1
libreoffice-fresh-ml 7.4.0-1 7.4.1-1
libreoffice-fresh-mn 7.4.0-1 7.4.1-1
libreoffice-fresh-mni 7.4.0-1 7.4.1-1
libreoffice-fresh-mr 7.4.0-1 7.4.1-1
libreoffice-fresh-my 7.4.0-1 7.4.1-1
libreoffice-fresh-nb 7.4.0-1 7.4.1-1
libreoffice-fresh-ne 7.4.0-1 7.4.1-1
libreoffice-fresh-nl 7.4.0-1 7.4.1-1
libreoffice-fresh-nn 7.4.0-1 7.4.1-1
libreoffice-fresh-nr 7.4.0-1 7.4.1-1
libreoffice-fresh-nso 7.4.0-1 7.4.1-1
libreoffice-fresh-oc 7.4.0-1 7.4.1-1
libreoffice-fresh-om 7.4.0-1 7.4.1-1
libreoffice-fresh-or 7.4.0-1 7.4.1-1
libreoffice-fresh-pa-in 7.4.0-1 7.4.1-1
libreoffice-fresh-pl 7.4.0-1 7.4.1-1
libreoffice-fresh-pt 7.4.0-1 7.4.1-1
libreoffice-fresh-pt-br 7.4.0-1 7.4.1-1
libreoffice-fresh-ro 7.4.0-1 7.4.1-1
libreoffice-fresh-ru 7.4.0-1 7.4.1-1
libreoffice-fresh-rw 7.4.0-1 7.4.1-1
libreoffice-fresh-sa-in 7.4.0-1 7.4.1-1
libreoffice-fresh-sat 7.4.0-1 7.4.1-1
libreoffice-fresh-sd 7.4.0-1 7.4.1-1
libreoffice-fresh-sdk 7.4.0-4 7.4.1-1
libreoffice-fresh-si 7.4.0-1 7.4.1-1
libreoffice-fresh-sid 7.4.0-1 7.4.1-1
libreoffice-fresh-sk 7.4.0-1 7.4.1-1
libreoffice-fresh-sl 7.4.0-1 7.4.1-1
libreoffice-fresh-sq 7.4.0-1 7.4.1-1
libreoffice-fresh-sr 7.4.0-1 7.4.1-1
libreoffice-fresh-sr-latn 7.4.0-1 7.4.1-1
libreoffice-fresh-ss 7.4.0-1 7.4.1-1
libreoffice-fresh-st 7.4.0-1 7.4.1-1
libreoffice-fresh-sv 7.4.0-1 7.4.1-1
libreoffice-fresh-sw-tz 7.4.0-1 7.4.1-1
libreoffice-fresh-szl 7.4.0-1 7.4.1-1
libreoffice-fresh-ta 7.4.0-1 7.4.1-1
libreoffice-fresh-te 7.4.0-1 7.4.1-1
libreoffice-fresh-tg 7.4.0-1 7.4.1-1
libreoffice-fresh-th 7.4.0-1 7.4.1-1
libreoffice-fresh-tn 7.4.0-1 7.4.1-1
libreoffice-fresh-tr 7.4.0-1 7.4.1-1
libreoffice-fresh-ts 7.4.0-1 7.4.1-1
libreoffice-fresh-tt 7.4.0-1 7.4.1-1
libreoffice-fresh-ug 7.4.0-1 7.4.1-1
libreoffice-fresh-uk 7.4.0-1 7.4.1-1
libreoffice-fresh-uz 7.4.0-1 7.4.1-1
libreoffice-fresh-ve 7.4.0-1 7.4.1-1
libreoffice-fresh-vec 7.4.0-1 7.4.1-1
libreoffice-fresh-vi 7.4.0-1 7.4.1-1
libreoffice-fresh-xh 7.4.0-1 7.4.1-1
libreoffice-fresh-zh-cn 7.4.0-1 7.4.1-1
libreoffice-fresh-zh-tw 7.4.0-1 7.4.1-1
libreoffice-fresh-zu 7.4.0-1 7.4.1-1
libsoup3 3.0.8-1 3.2.0-1
libxft 2.3.5-1 2.3.6-1
libxml++ 3.2.3-1 3.2.4-1
libxml++-5.0 5.0.1-1 5.0.2-1
libxml++-5.0-docs 5.0.1-1 5.0.2-1
libxml++-docs 3.2.3-1 3.2.4-1
libxml++2.6 2.42.1-1 -
libxml++2.6-docs 2.42.1-1 -
libxp 1.0.3-5 1.0.4-1
modemmanager 1.18.10-2 1.18.12-1
modemmanager-qt 5.97.0-1 5.98.0-1
networkmanager-qt 5.97.0-1 5.98.0-1
nuspell 5.1.0-2 5.1.1-1
oxygen-icons 1:5.97.0-1 1:5.98.0-1
oxygen-icons-svg 1:5.97.0-1 1:5.98.0-1
perl-alien-build 2.56-1 2.65-1
perl-exporter-tiny 1.004000-1 1.004001-1
perl-ffi-checklib 0.28-3 0.29-1
perl-mime-charset 1.012.2-9 1.013.1-1
plasma-framework 5.97.0-1 5.98.0-1
plasma-integration 5.25.5-1 5.25.5-2
plasma-wayland-session 5.25.5-2 5.25.5-3
plasma-workspace 5.25.5-2 5.25.5-3
prison 5.97.0-1 5.98.0-1
purpose 5.97.0-1 5.98.0-1
pyside2 5.15.5-3 5.15.6-1
pyside2-tools 5.15.5-3 5.15.6-1
pyside6 6.3.1-3 6.3.2-1
python-cryptography 38.0.0-1 38.0.1-1
python-idna 3.3-4 3.4-1
python-numpy 1.23.2-1 1.23.3-1
python-patiencediff 0.2.2-3 0.2.3-1
python-shiboken2 5.15.5-3 5.15.6-1
python-twisted 22.2.0-1 22.8.0-1
python-virtualenv 20.13.1-1 20.13.3-1
qqc2-desktop-style 5.97.0-1 5.98.0-1
qt5-3d 5.15.5+kde+r15-1 5.15.6+kde+r6-1
qt5-base 5.15.5+kde+r184-1 5.15.6+kde+r167-1
qt5-charts 5.15.5+kde+r1-1 5.15.6+kde+r0-1
qt5-connectivity 5.15.5+kde+r5-1 5.15.6+kde+r5-1
qt5-datavis3d 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-declarative 5.15.5+kde+r19-1 5.15.6+kde+r20-1
qt5-gamepad 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-graphicaleffects 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-imageformats 5.15.5+kde+r4-1 5.15.6+kde+r4-1
qt5-location 5.15.5+kde+r3-1 5.15.6+kde+r3-1
qt5-lottie 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-mqtt 5.15.2-5 5.15.2-6
qt5-multimedia 5.15.5+kde+r1-1 5.15.6+kde+r1-1
qt5-networkauth 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-purchasing 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-quick3d 5.15.5+kde+r1-1 5.15.6+kde+r1-1
qt5-quickcontrols 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-quickcontrols2 5.15.5+kde+r6-1 5.15.6+kde+r5-1
qt5-quicktimeline 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-remoteobjects 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-script 5.15.10-2 5.15.10-3
qt5-scxml 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-sensors 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-serialbus 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-serialport 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-speech 5.15.5+kde+r1-1 5.15.6+kde+r1-1
qt5-svg 5.15.5+kde+r11-1 5.15.6+kde+r9-1
qt5-tools 5.15.5+kde+r1-3 5.15.6+kde+r1-1
qt5-translations 5.15.5+kde+r2-1 5.15.6+kde+r2-1
qt5-virtualkeyboard 5.15.5+kde+r3-1 5.15.6+kde+r1-1
qt5-wayland 5.15.5+kde+r38-4 5.15.6+kde+r43-2
qt5-webchannel 5.15.5+kde+r3-1 5.15.6+kde+r3-1
qt5-webengine 5.15.10-2.1 5.15.10-3
qt5-webglplugin 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-webkit 5.212.0alpha4-15 5.212.0alpha4-16
qt5-websockets 5.15.5+kde+r3-1 5.15.6+kde+r2-1
qt5-webview 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-x11extras 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt5-xcb-private-headers 5.15.5+kde+r184-1 5.15.6+kde+r167-1
qt5-xmlpatterns 5.15.5+kde+r0-1 5.15.6+kde+r0-1
qt6-3d 6.3.1-1 6.3.2-1
qt6-5compat 6.3.1-1 6.3.2-1
qt6-base 6.3.1-1 6.3.2-1
qt6-charts 6.3.1-1 6.3.2-1
qt6-connectivity 6.3.1-1 6.3.2-1
qt6-datavis3d 6.3.1-1 6.3.2-1
qt6-declarative 6.3.1-1 6.3.2-1
qt6-doc 6.3.1-1 6.3.2-1
qt6-examples 6.3.1-1 6.3.2-1
qt6-imageformats 6.3.1-1 6.3.2-1
qt6-languageserver 6.3.1-1 6.3.2-1
qt6-lottie 6.3.1-1 6.3.2-1
qt6-multimedia 6.3.1-1 6.3.2-1
qt6-networkauth 6.3.1-1 6.3.2-1
qt6-positioning 6.3.1-1 6.3.2-1
qt6-quick3d 6.3.1-1 6.3.2-1
qt6-quicktimeline 6.3.1-1 6.3.2-1
qt6-remoteobjects 6.3.1-1 6.3.2-1
qt6-scxml 6.3.1-1 6.3.2-1
qt6-sensors 6.3.1-1 6.3.2-1
qt6-serialbus 6.3.1-1 6.3.2-1
qt6-serialport 6.3.1-1 6.3.2-1
qt6-shadertools 6.3.1-1 6.3.2-1
qt6-svg 6.3.1-1 6.3.2-1
qt6-tools 6.3.1-3 6.3.2-1
qt6-translations 6.3.1-1 6.3.2-1
qt6-virtualkeyboard 6.3.1-1 6.3.2-1
qt6-wayland 6.3.1-1 6.3.2-1
qt6-webchannel 6.3.1-1 6.3.2-1
qt6-webengine 6.3.1-1.1 6.3.2-1
qt6-websockets 6.3.1-1 6.3.2-1
qt6-webview 6.3.1-1 6.3.2-1
rsync 3.2.5-2 3.2.6-1
sdl2 2.24.0-1 2.24.0-2
shiboken6 6.3.1-3 6.3.2-1
solid 5.97.0-1 5.98.0-1
sonnet 5.97.0-1 5.98.0-1
syndication 5.97.0-1 5.98.0-1
syntax-highlighting 5.97.0-1 5.98.0-1
threadweaver 5.97.0-1 5.98.0-1
tree 2.0.2-2 2.0.4-1
vde2 2.3.3-2 2.3.3-3
wayland-utils 1.0.0-2 1.1.0-1
whois 5.5.13-1 5.5.13-2
wolfssl 5.4.0-1 5.5.0-1
wxwidgets-common 3.2.0-6 3.2.1-1
wxwidgets-gtk3 3.2.0-6 3.2.1-1
wxwidgets-qt5 3.2.0-6 3.2.1-1
xdg-utils 1.1.3+21+g1a58bc2-1 1.1.3+21+g1a58bc2-2
xfce4-pulseaudio-plugin 0.4.4-1 0.4.5-1
libsoup3-docs - 3.2.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.08.0.r12815.g47b324a6b-122.08.1.r12817.ga15d646d5-1
akonadi-calendar22.08.0.r2155.ga631bc7-122.08.1.r2156.g5c7fdcd-1
akonadi-calendar-tools22.08.0.r964.g2e9fe93-122.08.1.r965.g09c1a55-1
akonadi-contacts22.08.0.r3239.g85448842-122.08.1.r3241.g2167502f-1
akonadi-import-wizard22.08.0.r1848.g15dfec5-122.08.1.r1850.gb605756-1
akonadi-mime22.08.0.r1753.g5d9a102-122.08.1.r1755.g9a4e8bf-1
akonadi-notes22.08.0.r1088.ga124163-122.08.1.r1089.g63c6808-1
akonadi-search22.08.0.r1277.gdd09f68-122.08.1.r1278.gc4e6f04-1
akonadiconsole22.08.0.r1620.gc595fed-122.08.1.r1621.g627ef5b-1
akregator22.08.0.r6466.g9de19dc8-122.08.1.r6467.g269a82b3-1
alligator 22.06.r48.g9e992a6-1 22.06.r51.g0da5e73-1
amazfish 2.0.8.r10.g4a9d5a2-1 2.0.8.r12.gb7023fd-1
analitza22.08.0.r2358.g04dd73a5-122.08.1.r2358.g04dd73a5-1
angelfish 22.06.r52.ge0e4dbe-1 22.06.r56.gb000b84-1
ark22.08.0.r4841.ge6efb7d0-122.08.1.r4843.g3e2f5298-1
artikulate22.08.0.r1432.gc819306-122.08.1.r1432.gc819306-1
attica5.97.0.r884.ga909265-15.98.0.r884.ga909265-1
audiocd-kio22.08.0.r1108.gde52745-122.08.1.r1108.gde52745-1
audiotube 22.06.r35.gb6cd3c4-1 22.06.r37.gf26bc80-1
aura-browser r68.821531a-1 r81.aa492e5-1
baloo5.97.0.r3065.gdff7e8f4-15.98.0.r3065.gdff7e8f4-1
baloo-widgets22.08.0.r771.g7e9603a-122.08.1.r771.g7e9603a-1
blinken22.08.0.r684.g7ce780d-122.08.1.r684.g7ce780d-1
bluez-qt5.97.0.r719.g932455b-15.98.0.r719.g932455b-1
bomber22.08.0.r575.g68168a2-122.08.1.r575.g68168a2-1
bovo22.08.0.r786.gcd9e2ac-122.08.1.r786.gcd9e2ac-1
breeze5.25.5.r2445.g022df2ba-15.25.5.r2452.g6e278306-1
breeze-icons5.97.0.r1918.g0e430302-15.98.0.r1918.g0e430302-1
calendarsupport22.08.0.r728.g503675b-122.08.1.r729.g3cdcfff-1
cask-server r4.gc9912e8-1 r7.ga16cff8-1
cervisia22.08.0.r1699.ge2d0b64-122.08.1.r1701.g3c23021-1
discover5.25.5.r8826.g593ce4ec-25.25.5.r8831.g071f300f-1
dolphin22.08.0.r7084.gf49cba188-122.08.1.r7085.g8ff021ca6-1
dolphin-plugins22.08.0.r677.gc67bc7d-122.08.1.r678.g678ff40-1
dragon22.08.0.r1062.g4f2df9d-122.08.1.r1062.g4f2df9d-1
drkonqi5.25.5.r822.g68ef6f0d-15.25.5.r824.gb1e5bb03-1
elisa22.08.0.r3025.g833791ad-122.08.1.r3032.g921aff71-1
elisa-qtmm22.08.0.r3025.g833791ad-122.08.1.r3032.g921aff71-1
eventviews22.08.0.r877.g9030a9f-122.08.1.r878.g3175478-1
extra-cmake-modules5.97.0.r3517.g7bb60fd0-15.98.0.r3519.gf51c901e-1
ffmpegthumbs22.08.0.r236.g6efa4c1-122.08.1.r236.g6efa4c1-1
filelight22.08.0.r1176.gb4fc99b-122.08.1.r1177.g9828bce-1
frameworkintegration5.97.0.r653.g0bc14a7-15.98.0.r653.g0bc14a7-1
granatier22.08.0.r989.g0066152-122.08.1.r989.g0066152-1
grantlee-editor22.08.0.r838.g2a44f07-122.08.1.r839.g39e5a8c-1
grantleetheme22.08.0.r417.g9d4df4a-122.08.1.r418.gf8ee1d0-1
gwenview22.08.0.r6898.gaeb3f4fc-122.08.1.r6900.gc0d45c85-1
incidenceeditor22.08.0.r928.g87c066f-122.08.1.r929.g5936c21-1
index-fm 2.2.0.r0.gd92e665-1 2.2.0.r1.g9619c9b-1
itinerary22.08.0.r2005.g554eefd-122.08.1.r2005.g554eefd-1
juk22.08.0.r3181.ga16fd747-122.08.1.r3181.ga16fd747-1
k3b1:22.08.0.r6816.ga94f8d7ef-11:22.08.1.r6816.ga94f8d7ef-1
kaccounts-integration22.08.0.r1274.gb317f0f-122.08.1.r1274.gb317f0f-1
kaccounts-providers22.08.0.r402.gba64646-122.08.1.r402.gba64646-1
kactivities5.97.0.r1409.g3ba53fcd-15.98.0.r1409.g3ba53fcd-1
kactivities-stats5.97.0.r417.gc9ad8e7-15.98.0.r417.gc9ad8e7-1
kaddressbook22.08.0.r6241.g90f770e9-122.08.1.r6242.g27b84992-1
kajongg22.08.0.r4350.g4110278b-122.08.1.r4350.g4110278b-1
kalarm22.08.0.r8001.g5573357b-122.08.1.r8003.g113a8345-1
kalgebra22.08.0.r2080.g4b39929-122.08.1.r2080.g4b39929-1
kalk 22.06.r23.g5900cca-1 22.06.r26.g149d00c-1
kalzium22.08.0.r4381.g2ab2567f-122.08.1.r4381.g2ab2567f-1
kamera22.08.0.r735.g3bff072-122.08.1.r736.g4a702e8-1
kamoso22.08.0.r1475.ge7516d9-122.08.1.r1477.g4744064-1
kanagram22.08.0.r1327.g09d3b7f-122.08.1.r1327.g09d3b7f-1
kapidox5.97.0.r575.g6ed0a41-15.98.0.r575.g6ed0a41-1
kapman22.08.0.r668.g9f495fa-122.08.1.r668.g9f495fa-1
kapptemplate22.08.0.r999.g92b96bf-122.08.1.r1006.g23bf10f-1
karchive5.97.0.r554.g0a17848-15.98.0.r554.g0a17848-1
kasts 22.06.r49.g3a6446d-1 22.06.r56.g7a052bf-1
kate22.08.0.r19510.ga4ddde63f-122.08.1.r19533.gaba9082fd-1
katomic22.08.0.r975.gd2f9b5b-122.08.1.r975.gd2f9b5b-1
kauth5.97.0.r508.g29871cb-15.98.0.r508.g29871cb-1
kbackup22.08.0.r458.g62b16d5-122.08.1.r458.g62b16d5-1
kblackbox22.08.0.r779.gd725db4-122.08.1.r779.gd725db4-1
kblocks22.08.0.r755.gde3f9bd-122.08.1.r755.gde3f9bd-1
kbookmarks5.97.0.r469.g04303ac-15.98.0.r469.g04303ac-1
kbounce22.08.0.r860.gab57d45-122.08.1.r860.gab57d45-1
kbreakout22.08.0.r936.gb91a653-122.08.1.r936.gb91a653-1
kbruch22.08.0.r877.g6fefc4a-122.08.1.r877.g6fefc4a-1
kcachegrind22.08.0.r1194.g95e6bf4-122.08.1.r1194.g95e6bf4-1
kcachegrind-common22.08.0.r1194.g95e6bf4-122.08.1.r1194.g95e6bf4-1
kcalc22.08.0.r1631.gade2032-122.08.1.r1631.gade2032-1
kcalendarcore5.97.0.r1342.gd47f9dfb6-15.98.0.r1343.gf62b4e6b3-1
kcalutils22.08.0.r984.ga17af78e8-122.08.1.r985.g73a2337f5-1
kcharselect22.08.0.r542.gef794bb-122.08.1.r542.gef794bb-1
kclock 22.06.r31.g6d9194a-1 22.06.r36.gfb1572f-1
kcmutils5.97.0.r662.gd50d235-15.98.0.r663.g9258334-1
kcodecs5.97.0.r430.g233229e-15.98.0.r430.g233229e-1
kcolorchooser22.08.0.r282.g146cff8-122.08.1.r282.g146cff8-1
kcompletion5.97.0.r511.g4418032-15.98.0.r511.g4418032-1
kconfig5.97.0.r974.gee7321d9-15.98.0.r976.ge7183b90-1
kconfigwidgets5.97.0.r774.g929969a-15.98.0.r775.g0f0cf30-1
kcontacts1:5.97.0.r3346.g41ed7faf-11:5.98.0.r3346.g41ed7faf-1
kcoreaddons5.97.0.r1553.g9d3bd721-15.98.0.r1555.g48525592-1
kcrash5.97.0.r455.g863ce2b-15.98.0.r455.g863ce2b-1
kcron22.08.0.r849.g5708bdd-122.08.1.r849.g5708bdd-1
kdav1:5.97.0.r1354.g738ee0e-11:5.98.0.r1354.g738ee0e-1
kdbusaddons5.97.0.r426.g6863eb9-15.98.0.r427.gcf1194c-1
kde-dev-scripts22.08.0.r4152.gea6d462-122.08.1.r4153.gebd2fd2-1
kde-dev-utils22.08.0.r597.gc99a709-122.08.1.r599.gc48d323-1
kde-gtk-config5.25.5.r944.g9dd7296-15.25.5.r945.g30898d4-1
kdebugsettings22.08.0.r966.g261bb78-122.08.1.r967.ge3488f0-1
kdeclarative5.97.0.r1032.g728e928-15.98.0.r1041.g0fd84c6-1
kdeconnect22.08.0.r3533.gf53dadaf-122.08.1.r3537.gdcf41545-1
kded5.97.0.r474.gd7afee7-15.98.0.r475.ge98fa6e-1
kdeedu-data22.08.0.r19.g5209dd7-122.08.1.r19.g5209dd7-1
kdegraphics-mobipocket22.08.0.r275.g6cdb65d-122.08.1.r275.g6cdb65d-1
kdegraphics-thumbnailers22.08.0.r281.gb5b329a-122.08.1.r281.gb5b329a-1
kdelibs4support5.97.0.r1108.g848ff7a6-15.98.0.r1108.g848ff7a6-1
kdenetwork-filesharing22.08.0.r984.g4b523fb-122.08.1.r984.g4b523fb-1
kdenlive22.08.0.r16630.ga6cf70275-122.08.1.r16641.g81e4196b2-1
kdepim-addons22.08.0.r4814.g6fc9b0bae-122.08.1.r4837.gce705c16e-1
kdepim-runtime22.08.0.r15581.g9c1f024fd-122.08.1.r15599.gb7a26f3be-1
kdeplasma-addons5.25.5.r9024.gd43dbeda5-15.25.5.r9034.gec364f86f-1
kdesdk-kioslaves22.08.0.r505.g1f7909e-122.08.1.r505.g1f7909e-1
kdesdk-thumbnailers22.08.0.r93.g7ff219f-122.08.1.r93.g7ff219f-1
kdesignerplugin5.97.0.r361.g87a3cdd-15.98.0.r361.g87a3cdd-1
kdesu5.97.0.r517.g6c84dc0-15.98.0.r517.g6c84dc0-1
kdewebkit5.97.0.r308.gd200b32-15.98.0.r308.gd200b32-1
kdf22.08.0.r874.gaaf2494-122.08.1.r874.gaaf2494-1
kdialog22.08.0.r1239.ge1e295bba-122.08.1.r1239.ge1e295bba-1
kdiamond22.08.0.r737.g34a28f2-122.08.1.r737.g34a28f2-1
kdnssd5.97.0.r359.gd95a3bc-15.98.0.r359.gd95a3bc-1
kdoctools5.97.0.r677.g0cf8914-15.98.0.r679.gf8bb0e5-1
keditbookmarks22.08.0.r2772.g06b8c499f-122.08.1.r2772.g06b8c499f-1
kemoticons5.97.0.r425.g460be3d-15.98.0.r425.g460be3d-1
kfilemetadata5.97.0.r874.g44ad4ae-15.98.0.r874.g44ad4ae-1
kfind22.08.0.r2727.g028a3296a-122.08.1.r2728.g6bb945983-1
kfloppy22.08.0.r804.g7094a06-122.08.1.r804.g7094a06-1
kfourinline22.08.0.r1035.gf6fbb1b-122.08.1.r1042.g292eea5-1
kgeography22.08.0.r1167.g1068881-122.08.1.r1168.gbe6af72-1
kget22.08.0.r3223.ge0e262f4-122.08.1.r3223.ge0e262f4-1
kglobalaccel5.97.0.r573.g5b5714d-15.98.0.r574.g93b431e-1
kgoldrunner22.08.0.r1298.g8011965-122.08.1.r1298.g8011965-1
kgpg22.08.0.r3205.g43647cce-122.08.1.r3207.g8a45bc3c-1
kguiaddons5.97.0.r489.gb044646-15.98.0.r493.g58e08d5-1
khangman22.08.0.r1628.g3983a91-122.08.1.r1628.g3983a91-1
khelpcenter22.08.0.r2776.gca7b392a-122.08.1.r2778.gbaba4175-1
kholidays1:5.97.0.r1056.ge295e2e-11:5.98.0.r1056.ge295e2e-1
khotkeys5.25.5.r2157.ga5fb7bb-15.25.5.r2158.g3582ef1-1
khtml5.97.0.r597.g738a2f5-15.98.0.r598.g40dedf5-1
ki18n5.97.0.r571.g241e0cf-15.98.0.r571.g241e0cf-1
kiconthemes5.97.0.r631.gec3faeb-15.98.0.r632.gc5b74ac-1
kidentitymanagement22.08.0.r3902.g21ad53b4-122.08.1.r3903.ga0406ad1-1
kidletime5.97.0.r367.g2186217-15.98.0.r368.g5ceaf67-1
kig22.08.0.r3231.gd903d20d-122.08.1.r3231.gd903d20d-1
kigo22.08.0.r589.g1a9aafc-122.08.1.r589.g1a9aafc-1
killbots22.08.0.r806.g03e1708-122.08.1.r807.gc917a99-1
kimageformats5.97.0.r426.gfeb6d9b-15.98.0.r429.g2192830-1
kimagemapeditor22.08.0.r504.g7b5955a-122.08.1.r507.gbaf537e-1
kimap22.08.0.r1208.g5734404-122.08.1.r1209.ga44064d-1
kinfocenter5.25.5.r2143.ga2d44215-15.25.5.r2152.g434eb250-1
kinit5.97.0.r447.gabd053b-15.98.0.r447.gabd053b-1
kio5.97.0.r5689.gfd71bbe22-15.98.0.r5698.ged1a8a529-1
kio-extras22.08.0.r7337.geea1ecae-122.08.1.r7339.g9596b7c3-1
kio-gdrive22.08.0.r630.gc0a0861-122.08.1.r634.g39f110c-1
kirigami-addons 1:0.3.r12.geef408e-1 1:0.3.r13.gf1ed873-1
kirigami-gallery22.08.0.r267.gd97fd10-122.08.1.r270.g5800f94-1
kirigami25.97.0.r3311.g787efe84-15.98.0.r3331.gc9339665-1
kiriki22.08.0.r463.gfc8b595-122.08.1.r466.g3f55813-1
kitemmodels5.97.0.r618.gdc308cd-15.98.0.r618.gdc308cd-1
kitemviews5.97.0.r383.gf9ff0f1-15.98.0.r383.gf9ff0f1-1
kiten22.08.0.r1212.gf92c420-122.08.1.r1212.gf92c420-1
kitinerary22.08.0.r2378.g8aab5bc-122.08.1.r2386.g7fb9196-1
kjobwidgets5.97.0.r428.g1de71b2-15.98.0.r428.g1de71b2-1
kjs5.97.0.r370.gd8755f9-15.98.0.r370.gd8755f9-1
kjsembed5.97.0.r335.g92e03cc-15.98.0.r335.g92e03cc-1
kjumpingcube22.08.0.r835.gadc4c50-122.08.1.r835.gadc4c50-1
kldap22.08.0.r965.g8bef887-122.08.1.r966.ga143fca-1
kleopatra22.08.0.r6820.g7c2e3741-122.08.1.r6849.g0f4b3205-1
klettres22.08.0.r979.g967fb2d-122.08.1.r979.g967fb2d-1
klickety22.08.0.r708.gdb9481b-122.08.1.r708.gdb9481b-1
klines22.08.0.r835.g1cf8674-122.08.1.r835.g1cf8674-1
kmag22.08.0.r747.g749515f-122.08.1.r747.g749515f-1
kmahjongg22.08.0.r1572.g923c705-122.08.1.r1572.g923c705-1
kmail22.08.0.r26532.gdce18d54f-122.08.1.r26534.g8582350b7-1
kmail-account-wizard22.08.0.r898.gd1e398b-122.08.1.r900.g00d6fe0-1
kmailtransport22.08.0.r1759.gee11252-122.08.1.r1762.g9eeaf6a-1
kmbox22.08.0.r610.gece7530-122.08.1.r611.g787ff12-1
kmediaplayer5.97.0.r324.g77060a5-15.98.0.r324.g77060a5-1
kmenuedit5.25.5.r1066.g002751a-15.25.5.r1067.g87c38a3-1
kmime22.08.0.r1528.gf2395b0-122.08.1.r1529.g8f3846d-1
kmines22.08.0.r1777.gf346b6d-122.08.1.r1779.g6da5312-1
kmix22.08.0.r2462.g7f39c685-122.08.1.r2462.g7f39c685-1
kmousetool22.08.0.r458.g7c339f7-122.08.1.r459.gfc04da4-1
kmouth22.08.0.r744.gf469bfd-122.08.1.r744.gf469bfd-1
kmplot22.08.0.r1507.gbf031fa-122.08.1.r1508.gfb4c443-1
knavalbattle22.08.0.r1446.g8c77ca2-122.08.1.r1446.g8c77ca2-1
knetwalk22.08.0.r714.gc3077a0-122.08.1.r714.gc3077a0-1
knewstuff5.97.0.r1380.g9a2f2e9a-15.98.0.r1385.g3538e95a-1
knights22.08.0.r1155.g5d8fcd1-122.08.1.r1155.g5d8fcd1-1
knotes22.08.0.r3695.g03d70da2-122.08.1.r3696.g84b67a8b-1
knotifications5.97.0.r757.g190c316-15.98.0.r757.g190c316-1
knotifyconfig5.97.0.r393.g71dd801-15.98.0.r393.g71dd801-1
koko 22.06.r16.g4907b89-1 22.06.r17.g2b6fdde-1
kolf22.08.0.r1520.g6e60a80-122.08.1.r1520.g6e60a80-1
kollision22.08.0.r546.g966b81b-122.08.1.r546.g966b81b-1
kolourpaint22.08.0.r2436.ga0ba712c-122.08.1.r2436.ga0ba712c-1
kompare22.08.0.r1154.gb510628-122.08.1.r1154.gb510628-1
konqueror22.08.0.r15169.g3bd23d983-122.08.1.r15171.g093e76722-1
konquest22.08.0.r950.g43ef992-122.08.1.r950.g43ef992-1
konsole22.08.0.r8606.g6adbc553-122.08.1.r8614.g26c678e2-1
kontact22.08.0.r5569.ga2c4bc05-122.08.1.r5570.g59802d96-1
kontactinterface22.08.0.r707.gb780650-122.08.1.r708.g18d6cdb-1
kontrast22.08.0.r214.g8f23b21-122.08.1.r235.g9667712-1
konversation22.08.0.r9160.g265bb5be-122.08.1.r9161.gb3d4b0e5-1
kopeninghours22.08.0.r336.g6dd734d-122.08.1.r336.g6dd734d-1
kopete22.08.0.r16450.gffed03395-122.08.1.r16451.gf605ed945-1
korganizer22.08.0.r11795.g3a25863b3-122.08.1.r11796.g4c0125d79-1
kosmindoormap22.08.0.r754.g8e12202-122.08.1.r754.g8e12202-1
kpackage5.97.0.r765.gf0bd447-15.98.0.r768.gc9d1f3d-1
kparts5.97.0.r599.g5ea9476-15.98.0.r599.g5ea9476-1
kpat22.08.0.r2631.ge867674a-122.08.1.r2631.ge867674a-1
kpeople5.97.0.r1385.g7ef76d6-15.98.0.r1385.g7ef76d6-1
kpimtextedit22.08.0.r1616.g0501391-122.08.1.r1623.gb9c0e14-1
kpkpass22.08.0.r307.g4523c15-122.08.1.r308.gc8f690d-1
kplotting5.97.0.r332.g6becc5c-15.98.0.r332.g6becc5c-1
kpmcore22.08.0.r1297.g6d2fa58-122.08.1.r1297.g6d2fa58-1
kpty5.97.0.r385.g6d29a4f-15.98.0.r385.g6d29a4f-1
kpublictransport22.08.0.r2044.g80e0e620-122.08.1.r2044.g80e0e620-1
kqtquickcharts22.08.0.r77.g9b882ce-122.08.1.r77.g9b882ce-1
kquickcharts5.97.0.r531.ge9ad31e-15.98.0.r534.g0c70041-1
krdc22.08.0.r1624.g0760c95-122.08.1.r1624.g0760c95-1
krecorder 22.06.r21.g9a7d56f-1 22.06.r23.g8a71b35-1
kreversi22.08.0.r1282.ge56b129-122.08.1.r1282.ge56b129-1
krfb22.08.0.r1516.gc59abf0-122.08.1.r1516.gc59abf0-1
kross5.97.0.r366.g0e1db3e-15.98.0.r366.g0e1db3e-1
kross-interpreters22.08.0.r725.gdef2cfe-122.08.1.r725.gdef2cfe-1
kruler22.08.0.r750.g927e58c-122.08.1.r750.g927e58c-1
krunner5.97.0.r783.ga4f1df1-15.98.0.r786.g0f73c7a-1
kscreen5.25.5.r1529.g2c6ef85-15.25.5.r1532.g072f7d2-1
kservice5.97.0.r1031.gcca46c7-15.98.0.r1031.gcca46c7-1
kshisen22.08.0.r1254.g6889e36-122.08.1.r1254.g6889e36-1
ksirk22.08.0.r1048.gd16cf92-122.08.1.r1048.gd16cf92-1
ksmtp22.08.0.r459.ge72dfca-122.08.1.r460.gf14c06f-1
ksnakeduel22.08.0.r865.g4b67e36-122.08.1.r866.g0bc5994-1
kspaceduel22.08.0.r684.gf712f53-122.08.1.r684.gf712f53-1
ksquares22.08.0.r570.g7bce2d7-122.08.1.r571.g3ce16cd-1
ksudoku22.08.0.r1135.gcbc8725-122.08.1.r1135.gcbc8725-1
ksystemlog22.08.0.r752.g521756f-122.08.1.r754.gcf2dfea-1
kteatime22.08.0.r768.g4b94625-122.08.1.r768.g4b94625-1
ktexteditor5.97.0.r3528.gab304129-15.98.0.r3530.g17415653-1
ktextwidgets5.97.0.r458.gb929a68-15.98.0.r458.gb929a68-1
ktimer22.08.0.r536.gc59aeb9-122.08.1.r536.gc59aeb9-1
ktnef22.08.0.r730.gcded6ea-122.08.1.r731.ge241cb1-1
ktorrent22.08.0.r2882.gb58972a1-122.08.1.r2883.gc8d8071e-1
ktouch22.08.0.r2200.ga56eaaf-122.08.1.r2200.ga56eaaf-1
ktuberling22.08.0.r1075.ge0ebc3a-122.08.1.r1075.ge0ebc3a-1
kturtle22.08.0.r1186.gca7d0ef-122.08.1.r1186.gca7d0ef-1
kubrick22.08.0.r418.g2003b83-122.08.1.r419.gf5fd79b-1
kunitconversion5.97.0.r428.g598f3a2-15.98.0.r428.g598f3a2-1
kwallet5.97.0.r1177.g6522935-15.98.0.r1177.g6522935-1
kwalletmanager22.08.0.r1296.geb0ffa8-122.08.1.r1298.g4f8bd7b-1
kwave22.08.0.r3806.gec348d90-122.08.1.r3806.gec348d90-1
kwayland5.97.0.r1179.gcb13afd-15.98.0.r1182.gcb6e4e3-1
kweather 22.06.r63.g898ec43-1 22.06.r73.gc3f313d-1
kwidgetsaddons5.97.0.r981.gce728c52-15.98.0.r981.gce728c52-1
kwin5.25.5.r23114.g1598cecc8-15.25.5.r23172.g106d06125-1
kwindowsystem5.97.0.r694.gb61821e-15.98.0.r695.gacf85e4-1
kwordquiz22.08.0.r1203.g69bf4ad-122.08.1.r1203.g69bf4ad-1
kwrite22.08.0.r19510.ga4ddde63f-122.08.1.r19533.gaba9082fd-1
kwrited5.25.5.r516.g4fb19a5-15.25.5.r517.g3ef9176-1
kxmlgui5.97.0.r904.gb3740169-15.98.0.r905.g72919b5e-1
kxmlrpcclient5.97.0.r488.ga317aa5fc-15.98.0.r488.ga317aa5fc-1
libakonadi22.08.0.r12815.g47b324a6b-122.08.1.r12817.ga15d646d5-1
libgravatar22.08.0.r436.g34eb1f4-122.08.1.r437.g0b40917-1
libkcddb22.08.0.r768.g7a30ef8-122.08.1.r768.g7a30ef8-1
libkcompactdisc22.08.0.r399.g61b5f60-122.08.1.r399.g61b5f60-1
libkdcraw22.08.0.r1154.gbbcf3da-122.08.1.r1154.gbbcf3da-1
libkdegames22.08.0.r2256.g2529b8c6-122.08.1.r2256.g2529b8c6-1
libkdepim22.08.0.r925.gcd31f0b-122.08.1.r926.g614cf13-1
libkeduvocdocument22.08.0.r1812.g8a1b9c7-122.08.1.r1812.g8a1b9c7-1
libkexiv222.08.0.r832.ga131658-122.08.1.r832.ga131658-1
libkgapi22.08.0.r1376.g113ad68-122.08.1.r1377.g7ea83ff-1
libkipi22.08.0.r1280.g5b6d13f-122.08.1.r1280.g5b6d13f-1
libkleo22.08.0.r1270.g8e3344a-122.08.1.r1277.gae317a5-1
libkmahjongg22.08.0.r489.g38ac255-122.08.1.r489.g38ac255-1
libkomparediff222.08.0.r346.g5e898ac-122.08.1.r346.g5e898ac-1
libksane22.08.0.r605.g800eed2-122.08.1.r605.g800eed2-1
libkscreen5.25.5.r1636.g0f6bed2-15.25.5.r1637.gc6265f2-1
libksieve22.08.0.r1740.g28ccab1f-122.08.1.r1741.g02a50cf6-1
libktorrent22.08.0.r564.gc5f7928-122.08.1.r564.gc5f7928-1
lokalize22.08.0.r1848.ga01091f4-122.08.1.r1848.ga01091f4-1
lskat22.08.0.r866.g3211e3f-122.08.1.r866.g3211e3f-1
mailcommon22.08.0.r1291.g993a59b-122.08.1.r1292.gfbf2167-1
mailimporter22.08.0.r534.g6f82744-122.08.1.r535.g0483511-1
maliit-framework 2.3.0.r2.g7a929ce8-1 2.3.0.r2.g7a929ce8-2
marble22.08.0.r13469.g78d4ab70f-122.08.1.r13469.g78d4ab70f-1
marble-common22.08.0.r13469.g78d4ab70f-122.08.1.r13469.g78d4ab70f-1
marble-qt22.08.0.r13469.g78d4ab70f-122.08.1.r13469.g78d4ab70f-1
markdownpart22.08.0.r134.g1fcb493-122.08.1.r135.g218c38e-1
maui-pix 2.2.0.r4.g7a80376-1 2.2.0.r5.g2d0e7bb-1
maui-shell 0.5.5.r12.g70f78d4-1 0.5.5.r16.g9fea97c-1
mauikit 2.2.0.r8.gc9a3d2a8-12.2.0.r11.g533a7027-1
mauiman r31.3101050-1 r33.6ef5b9c-1
mbox-importer22.08.0.r579.g3b76015-122.08.1.r580.g71aaaf8-1
messagelib22.08.0.r6670.g795740ba6-122.08.1.r6672.ge88ab7359-1
minuet22.08.0.r625.gf969168-122.08.1.r625.gf969168-1
modemmanager-qt5.97.0.r561.g07130ae-15.98.0.r561.g07130ae-1
neochat22.06.r108.g5d4efad2-122.06.r127.g3797b012-1
networkmanager-qt5.97.0.r1161.g51d2bb1-15.98.0.r1162.g4ec5aab-1
okular22.08.0.r9827.gd0359e634-122.08.1.r9832.g2911f7a88-1
oxygen-icons1:5.97.0.r5.gbff159d-11:5.98.0.r5.gbff159d-1
oxygen-icons-svg1:5.97.0.r5.gbff159d-11:5.98.0.r5.gbff159d-1
palapeli22.08.0.r1310.g755e23d-122.08.1.r1311.g1feacd5-1
parley22.08.0.r4544.gcfb8d323-122.08.1.r4544.gcfb8d323-1
partitionmanager22.08.0.r1643.g4f8c6b6-122.08.1.r1644.g00a0f40-1
picmi22.08.0.r567.g0daadd8-122.08.1.r567.g0daadd8-1
pim-data-exporter22.08.0.r2785.ga6bd2c8c-122.08.1.r2786.g5709df23-1
pim-sieve-editor22.08.0.r1652.g58efae1-122.08.1.r1653.gaf93fbd-1
pimcommon22.08.0.r1353.gd42b95d-122.08.1.r1363.g1f85cbf-1
plank-player r33.192d96d-1 r49.bb1c245-1
plasma-bigscreen r503.g2dfeb0e-1 r505.g15257d7-1
plasma-desktop5.25.5.r9593.g7f1c5184d-15.25.5.r9628.gfb77be09d-1
plasma-dialer 22.06.r73.g5e5cc81-1 22.06.r97.ge775b13-1
plasma-framework5.97.0.r16408.g025cdf39e-15.98.0.r16415.g7cbafee75-1
plasma-integration5.25.5.r575.g7b1ece8-15.25.5.r576.g52bd3c9-1
plasma-mobile5.25.5.r1953.gcbd1acc11-15.25.5.r1973.ga15475b8f-1
plasma-mobile-nm5.25.5.r3327.g5b6a91bb-15.25.5.r3330.gf33cfdd8-1
plasma-nm5.25.5.r3327.g5b6a91bb-15.25.5.r3330.gf33cfdd8-1
plasma-pa5.25.5.r1084.g8810ebe-15.25.5.r1086.gc022e8a-1
plasma-phonebook 22.06.r18.g77821b7-1 22.06.r19.g7e61336-1
plasma-remotecontrollers r129.g1df612a-1 r130.gb11be55-1
plasma-sdk5.25.5.r2391.g5cf7d599-15.25.5.r2399.g57df86fc-1
plasma-settings 22.06.r86.g152d96d-1 22.06.r94.gc756da8-1
plasma-systemmonitor5.25.5.r616.g8b36bdd-15.25.5.r621.g9ca406b-1
plasma-thunderbolt5.25.5.r197.gd5272df-15.25.5.r198.ge761487-1
plasma-wayland-session5.25.5.r12291.g6ce2204b7-15.25.5.r12334.g48ffa11cd-1
plasma-workspace5.25.5.r12291.g6ce2204b7-15.25.5.r12334.g48ffa11cd-1
plasma-workspace-wallpapers5.25.5.r376.g3e0ccff-15.25.5.r377.g59418f2-1
plasmatube 22.06.r27.g0d897c1-1 22.06.r30.gcd9313c-1
powerdevil5.25.5.r2592.gf1bd0749-15.25.5.r2593.gcabacd5a-1
poxml22.08.0.r283.g1b8e394-122.08.1.r283.g1b8e394-1
print-manager22.08.0.r1162.gfcd9cd1-122.08.1.r1162.gfcd9cd1-1
prison5.97.0.r400.g83f1b09-15.98.0.r400.g83f1b09-1
purpose5.97.0.r994.g2cc7697-15.98.0.r996.g7605fe1-1
qcachegrind22.08.0.r1194.g95e6bf4-122.08.1.r1194.g95e6bf4-1
qmlkonsole 22.06.r39.g4ceaf7b-1 22.06.r41.g7602599-1
qqc2-desktop-style5.97.0.r657.g4623715-15.98.0.r667.g50bec91-1
rocs22.08.0.r3116.gb8a43350-122.08.1.r3123.gb07c1833-1
sddm0.19.0.r141.ge67307e-10.19.0.r148.g0280166-1
signon-kwallet-extension22.08.0.r82.g67533cf-122.08.1.r82.g67533cf-1
solid5.97.0.r792.gd36bec2-15.98.0.r793.gb9ef941-1
sonnet5.97.0.r711.ge10fd9b-15.98.0.r711.ge10fd9b-1
spacebar 22.06.r66.g647f068-1 22.06.r70.gea1300b-1
spectacle22.08.0.r1387.g90a36db-122.08.1.r1388.ge431fdd-1
step22.08.0.r1212.g6bf7e59-122.08.1.r1212.g6bf7e59-1
svgpart22.08.0.r237.ge782b84-122.08.1.r238.g8771db3-1
sweeper22.08.0.r587.geb9487e-122.08.1.r587.geb9487e-1
syndication5.97.0.r883.g427c476-15.98.0.r883.g427c476-1
syntax-highlighting5.97.0.r1920.g0dd050e7-15.98.0.r1922.g52b6928f-1
systemsettings5.25.5.r2711.gb842bcad-15.25.5.r2712.gc9ce49e4-1
telepathy-kde-accounts-kcm22.08.0.r1220.g5d7feff-122.08.1.r1220.g5d7feff-1
telepathy-kde-approver22.08.0.r306.g53cec00-122.08.1.r306.g53cec00-1
telepathy-kde-auth-handler22.08.0.r285.gcb15eb7-122.08.1.r285.gcb15eb7-1
telepathy-kde-call-ui22.08.0.r450.ga1ee093-122.08.1.r450.ga1ee093-1
telepathy-kde-common-internals22.08.0.r2024.g02d14eb-122.08.1.r2024.g02d14eb-1
telepathy-kde-contact-list22.08.0.r1094.g3721af4-122.08.1.r1094.g3721af4-1
telepathy-kde-contact-runner22.08.0.r263.gac42a1d-122.08.1.r263.gac42a1d-1
telepathy-kde-desktop-applets22.08.0.r1008.gaa3cc9d-122.08.1.r1008.gaa3cc9d-1
telepathy-kde-filetransfer-handler22.08.0.r228.g9e012f5-122.08.1.r228.g9e012f5-1
telepathy-kde-integration-module22.08.0.r403.ga4e79eb-122.08.1.r403.ga4e79eb-1
telepathy-kde-send-file22.08.0.r237.g7c8384d-122.08.1.r237.g7c8384d-1
telepathy-kde-text-ui22.08.0.r2049.ge638741-122.08.1.r2050.g168fa8b-1
threadweaver5.97.0.r551.ga95dbf6-15.98.0.r551.ga95dbf6-1
tokodon 22.06.r32.g245aade-1 22.06.r36.g58852da-1
umbrello22.08.0.r8502.ge52640032-122.08.1.r8502.ge52640032-1
vakzination 22.06.r46.g2f1320d-1 22.06.r48.g88ccd4a-1
xdg-desktop-portal-kde5.25.5.r519.g6976bbc-15.25.5.r520.g62dd495-1
yakuake22.08.0.r826.g50a8719-122.08.1.r826.g50a8719-1
zeroconf-ioslave22.08.0.r394.gd86416e-122.08.1.r394.gd86416e-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
