[ARM Testing Update] 2022-09-09 - KDE Gear, Plasma, Code and kernels
Hello ARM community.
Mainly plasma stuff this time!
Some highlights:
  • Most of our kernels got updated
  • KDE Gear applications updated to 22.08.1
  • Plasma updated to 5.25.5
  • Firefox updated to 104.0.2
  • Code updated to 1.71.0
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Fri Sep 9 16:48:42 CEST 2022)
  • arm-testing community aarch64: 321 new and 317 removed package(s)
  • arm-testing core aarch64: 18 new and 18 removed package(s)
  • arm-testing extra aarch64: 579 new and 579 removed package(s)
  • arm-testing kde-unstable aarch64: 342 new and 343 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2022-09-04         2022-09-09
                                code             1.69.2-1             1.71.0-1
                            electron             20.1.1-1             20.1.2-1
                          electron18            18.3.11-1            18.3.12-1
                          electron19            19.0.15-1            19.0.16-1
                  gnome-shell-mobile43beta+r271+g34333e93a-143beta+r279+g8dc3dc1f3-1
                       mutter-mobile43beta+r135+g1214d7e43-143beta+r214+g5a14d08dc-1
:: Different sync package(s) in repository community aarch64
                          abseil-cpp         20220623.0-1         20220623.1-1
                                afew              3.0.1-4              3.0.1-5
                            algol68g              3.0.6-1              3.0.7-1
                        algol68g-doc              3.0.6-1              3.0.7-1
                              antlr4             4.10.1-1             4.11.1-1
                      antlr4-runtime             4.10.1-2             4.11.1-1
                              argocd             2.4.10-1             2.4.11-1
                               atftp              0.7.5-1              0.8.0-3
                    autoconf-archive       1:2022.02.11-1       1:2022.09.03-1
                          babel-core            7.18.13-1             7.19.0-1
                                 bat             0.21.0-3             0.22.0-1
                           bctoolbox             5.1.55-1             5.1.58-1
                             blender           17:3.2.2-1           17:3.3.0-1
                  blueprint-compiler              0.2.0-1              0.4.0-1
                          bonzomatic       1.0.20210307-2       1.0.20220820-1
                           borgmatic              1.7.1-1              1.7.2-1
                               brook           20220404-1           20220406-1
                               bzrtp             5.1.55-1             5.1.58-1
                           capnproto             0.10.1-1             0.10.2-1
                        cargo-expand             1.0.30-1             1.0.31-1
                       cargo-nextest             0.9.35-1             0.9.36-1
                               chafa             1.12.1-1             1.12.3-1
                       checkbashisms             2.21.4-1             2.22.2-1
                             chezmoi             2.22.0-1             2.22.1-1
                               chuck            1.4.1.0-2            1.4.1.1-1
                                cimg              3.0.1-1              3.1.6-1
                              cl-clx 0.7.5.r67.g392421d-1 0.7.5.r71.gf5bc0ab-1
                   cloud-guest-utils               0.32-2               0.33-1
                   cloud-image-utils               0.32-2               0.33-1
                         cloud-utils               0.32-2               0.33-1
                           cmark-gfm       0.29.0.gfm.2-3       0.29.0.gfm.5-1
                             cockpit                275-1                276-1
                    cockpit-machines                273-1                274-1
                  cockpit-packagekit                275-1                276-1
                         cockpit-pcp                275-1                276-1
                      cockpit-podman                 52-1                 53-1
                    cockpit-storaged                275-1                276-1
                                coin       4.0.0.f4e446-3       4.0.0.04c190-4
                   containers-common           1:0.49.1-1           1:0.49.1-2
                                 coq             8.15.0-3             8.16.0-2
                             coq-doc             8.15.0-3             8.16.0-2
                              coqide             8.15.0-3             8.16.0-2
                               cri-o             1.24.2-1             1.25.0-1
                              crictl             1.24.2-1             1.25.0-1
                             critest             1.24.2-1             1.25.0-1
                                crun                1.5-2                1.6-1
                             crystal              1.5.0-2              1.5.1-1
                              danmaq              0.2.3-2            0.2.3.1-1
                           dd_rescue            1.99.11-1            1.99.12-1
                          disomaster              5.0.7-1              5.0.8-1
                            dokuwiki           20220731-1         20220731_a-1
                           drumgizmo             0.9.19-1             0.9.20-1
                           drumstick              2.7.1-1              2.7.1-2
                              drupal              9.4.4-1              9.4.5-1
                          emscripten             3.1.18-1             3.1.20-1
                                fcft              3.1.3-1              3.1.4-1
                    firefox-noscript             11.4.9-1            11.4.10-1
               firefox-ublock-origin             1.43.0-1             1.44.2-1
                                 gdu             5.15.0-1             5.16.0-1
                              genact             0.12.0-1              1.0.0-1
                              gensio              2.4.1-1              2.5.2-1
                                giac           1.9.0.19-1           1.9.0.21-1
                          github-cli             2.14.7-1             2.15.0-1
                               go-yq             4.27.3-1             4.27.4-1
                                gost             2.11.3-1             2.11.4-1
                              gpxsee               11.3-1               11.4-1
                             haproxy              2.6.4-1              2.6.5-2
                           hyperfine             1.14.0-1             1.15.0-1
                           ibus-m17n             1.4.10-1             1.4.11-1
                  ibus-table-chinese              1.8.5-1              1.8.6-1
                              igraph             0.9.10-1             0.10.1-1
                            ipmitool             1.8.18-7             1.8.19-1
                             ipython              8.4.0-1              8.5.0-1
                             jenkins              2.366-1              2.367-1
                                jenv  0.5.4.r12.7053916-2              0.5.5-1
                                jmol           14.32.73-1           14.32.74-1
                               jsmol           14.32.73-1           14.32.74-1
                          jupyterlab              3.4.5-1              3.4.6-1
                                 kea              2.0.3-2              2.2.0-1
                            kea-docs              2.0.3-2              2.2.0-1
                            kmymoney              5.1.2-9              5.1.3-1
                         kphotoalbum              5.8.1-2              5.9.1-1
                      kube-apiserver             1.24.4-1             1.25.0-1
             kube-controller-manager             1.24.4-1             1.25.0-1
                          kube-proxy             1.24.4-1             1.25.0-1
                      kube-scheduler             1.24.4-1             1.25.0-1
                             kubeadm             1.24.4-1             1.25.0-1
                             kubectl             1.24.4-1             1.25.0-1
                             kubelet             1.24.4-1             1.25.0-1
     kubernetes-control-plane-common             1.24.4-1             1.25.0-1
                               kubie             0.18.0-1             0.19.0-1
                              lhapdf              6.5.2-5              6.5.3-1
                           libgovirt              0.3.8-1            2:0.3.8-1
                             libharu              2.4.0-1              2.4.1-1
                              libltc              1.3.1-3              1.3.2-1
                      libmodsecurity            1:3.0.7-1            1:3.0.8-1
                            libmupdf             1.20.0-1             1.20.3-1
                             libvips             8.13.0-1             8.13.1-1
                                lnav             0.10.1-1             0.11.0-1
                              logcli              2.6.0-1              2.6.1-1
                                loki              2.6.0-1              2.6.1-1
                         loki-canary              2.6.0-1              2.6.1-1
                         lsp-plugins              1.2.2-1              1.2.3-1
                    lsp-plugins-docs              1.2.2-1              1.2.3-1
                 lua-language-server              3.5.3-1              3.5.5-1
                              marked              4.0.8-1             4.0.10-1
                       mediastreamer             5.1.55-1             5.1.58-1
                             mellite             3.13.3-1             3.13.4-1
                     multipath-tools              0.9.0-1              0.9.1-1
                              mumble           1.4.230-13            1.4.274-1
                            mupdf-gl             1.20.0-1             1.20.3-1
                         mupdf-tools             1.20.0-1             1.20.3-1
                              murmur           1.4.230-13            1.4.274-1
                     mysql-workbench             8.0.30-1             8.0.30-2
                             netdata             1.36.0-1             1.36.1-1
                 nextcloud-app-notes              4.5.0-1              4.5.1-1
                              nodejs             18.8.0-1             18.9.0-1
                   npm-check-updates             15.3.0-1             16.0.1-1
                              nuitka              1.0.5-2              1.0.6-1
                                 oil             0.12.4-1             0.12.5-1
                         openimageio           2.3.18.0-1           2.3.19.0-1
                             openui5            1.96.11-1            1.102.7-1
                              openxr             1.0.24-1             1.0.25-1
                                ortp             5.1.55-1             5.1.58-1
                             osbuild                 66-1                 66-2
                            pageedit             1.9.10-1             1.9.20-1
                          perl-chart            2.402.3-1            2.403.7-1
             perl-cpan-perl-releases         5.20220620-1         5.20220820-1
                perl-datetime-locale               1.35-1               1.36-1
                         perl-dbd-pg             3.15.1-1             3.16.0-1
         perl-email-mime-contenttype              1.026-1              1.027-1
                         perl-io-tee               0.65-5               0.66-1
                        perl-ipc-run         20200505.0-1         20220807.0-1
                   perl-locale-codes               3.71-1               3.72-1
                    perl-math-base85                0.4-5                0.5-1
                     perl-par-packer              1.055-1              1.056-1
                      perl-test-warn               0.36-2               0.37-1
                  perl-www-mechanize               2.13-1               2.15-1
                   perl-yaml-libyaml               0.83-3               0.84-1
                            perlbrew               0.95-1               0.96-1
                       piping-server             0.14.0-1             0.14.1-1
                           plan9port           20220720-1           20220818-1
                         pmbootstrap             1.45.0-1             1.46.0-1
                              podman              4.2.0-1              4.2.1-1
                       podman-docker              4.2.0-1              4.2.1-1
                 profile-sync-daemon             1:6.45-1             1:6.47-1
                            promtail              2.6.0-1              2.6.1-1
                             puzzles           20220128-1           20220802-1
                               pyenv              2.3.3-1              2.3.4-1
                             pyright            1.1.269-1            1.1.270-1
                       python-antlr4             4.10.1-1             4.11.1-1
                     python-apptools              5.1.0-3              5.2.0-1
                        python-arrow              1.2.2-1              1.2.3-1
                      python-astroid             2.12.5-1             2.12.9-1
                     python-atpublic                3.1-1              3.1.1-1
                      python-authres              1.2.0-7              1.2.0-8
                      python-awkward              1.8.0-2              1.9.0-1
                        python-build              0.8.0-1              0.8.0-2
                     python-cfn-lint             0.63.2-1             0.64.1-1
                    python-click-log              0.4.0-1              0.4.0-2
                   python-cloudflare             2.9.12-1             2.10.1-1
                     python-cmarkgfm              0.8.0-1              0.8.0-2
         python-cryptography-vectors             37.0.4-1             38.0.0-1
                python-cssbeautifier             1.14.6-1             1.14.6-2
                     python-daiquiri              3.2.0-1              3.2.1-1
                         python-dkim              1.0.5-6              1.0.5-7
                     python-docutils             1:0.19-1             1:0.19-2
                       python-dotenv             0.20.0-2             0.21.0-1
                      python-dulwich            0.20.45-1            0.20.46-1
                  python-elementpath              3.0.1-1              3.0.2-1
                      python-fastapi             0.81.0-1             0.82.0-1
                     python-filelock              3.7.1-1              3.8.0-1
            python-flake8-docstrings              1.6.0-2              1.6.0-3
                 python-flake8-isort              4.1.2-1              4.2.0-2
                   python-flufl-lock                7.1-1              7.1.1-1
                   python-flufl.i18n                4.1-1              4.1.1-1
                        python-gdstk              0.8.3-1              0.9.0-1
                   python-hypothesis             6.54.4-1             6.54.4-2
                    python-icalendar              4.1.0-1              4.1.0-2
                     python-identify              2.5.3-1              2.5.5-1
                       python-igraph             0.9.11-1             0.10.0-1
                    python-imagesize              1.4.1-1              1.4.1-2
                           python-jq              1.2.1-2              1.2.3-1
                 python-jsbeautifier             1.14.6-1             1.14.6-2
                 python-latex2mathml             3.63.0-1             3.63.1-1
                  python-levenshtein             0.20.1-2             0.20.2-1
                  python-littleutils              0.2.2-3              0.2.2-4
                     python-llvmlite             0.39.0-1             0.39.1-1
            python-matplotlib-inline              0.1.6-1              0.1.6-2
                       python-minidb              2.0.6-1              2.0.6-2
                       python-mocket             3.10.6-2             3.10.7-1
                   python-novaclient             18.0.0-1             18.1.0-1
                 python-openstacksdk             0.99.0-1            0.100.0-1
                   python-oslo-utils             4.12.1-1             4.12.3-1
                    python-pdftotext              2.2.2-2              2.2.2-3
                       python-pipenv          2022.8.24-1           2022.9.4-1
                       python-plette              0.2.3-7              0.3.0-1
                  python-prettytable              3.4.0-1              3.4.1-1
                      python-protego              0.2.0-1              0.2.1-1
                         python-pudb           2022.1.1-1           2022.1.2-1
                      python-pycapnp              1.1.1-1              1.2.0-1
                  python-pycodestyle              2.9.1-1              2.9.1-2
                     python-pydantic             1.10.1-1             1.10.2-1
                 python-pydispatcher              2.0.5-9              2.0.6-1
                         python-pyee              9.0.4-1              9.0.4-2
                     python-pyfiglet          0.8.post1-5          0.8.post1-6
                       python-pygit2             1.10.0-1             1.10.1-1
                       python-pyppmd             0.18.3-1              1.0.0-1
                      python-pyscard              2.0.3-1              2.0.4-1
                    python-pywlroots            0.15.20-1            0.15.21-1
                    python-rapidfuzz              2.4.3-1              2.6.1-1
                        python-regex           2022.6.2-1          2022.8.17-1
          python-scikit-hep-testdata             0.4.19-1             0.4.20-1
                 python-scikit-learn              1.1.1-1              1.1.2-1
                    python-softlayer              6.1.0-1              6.1.1-1
                  python-sounddevice              0.4.4-1              0.4.5-1
                       python-sphinx              5.1.1-1              5.1.1-2
               python-sphinx-autoapi              1.9.0-1              1.9.0-2
      python-sphinxcontrib-applehelp              1.0.2-8              1.0.2-9
        python-sphinxcontrib-devhelp              1.0.2-8              1.0.2-9
       python-sphinxcontrib-htmlhelp              2.0.0-3              2.0.0-5
         python-sphinxcontrib-jsmath             1.0.1-11             1.0.1-12
         python-sphinxcontrib-qthelp              1.0.3-8              1.0.3-9
python-sphinxcontrib-serializinghtml              1.1.5-3              1.1.5-4
                  python-tokenize-rt              4.2.1-3              4.2.1-4
                         python-toml             0.10.2-7             0.10.2-8
                      python-tzlocal              1:2.1-1              1:2.1-2
                      python-vobject            0.9.6.1-9           0.9.6.1-10
             python-websocket-client              1.4.0-1              1.4.1-1
                    python-xmlschema              2.0.0-1              2.0.1-1
              python-zope-annotation              4.7.0-5                4.8-1
              python-zope-testrunner                5.5-1              5.5.1-1
                           rankwidth                0.9-1                0.9-2
                       rapidfuzz-cpp              1.2.0-1              1.3.0-1
                              reaper               6.66-1               6.67-1
                              recoll             1.32.5-1             1.32.7-1
                                repo               2.29-1             2.29.1-1
                    robotfindskitten      2.7182818.701-6      2.8284271.702-1
                            rssguard              4.2.3-1              4.2.4-1
                rssguard-nowebengine              4.2.3-1              4.2.4-1
                            ruby-jwt              2.4.1-1              2.5.0-1
                ruby-puppet_metadata              1.7.0-1              1.8.0-1
                             ruby-rr              3.0.9-1              3.1.0-1
                        ruby-webmock             3.14.0-1             3.18.1-1
                       rust-analyzer           20220829-2           20220905-1
                       schemacrawler            16.17.3-1            16.18.1-1
                          sentry-cli              2.5.0-1              2.5.2-1
                             ser2net              4.3.7-1              4.3.8-1
                    sonic-visualiser                4.5-3                4.5-4
                               squid                5.6-1                5.7-1
                            sshuttle              1.1.0-1              1.1.1-1
                                sslh             1.22.c-1             1.22.c-2
                            starship             1.10.2-1             1.10.3-1
                           syncthing             1.20.3-1             1.21.0-1
                  syncthing-relaysrv             1.20.3-1             1.21.0-1
                               tdlib              0.5.0-4              0.9.2-2
                            termdown             1.18.0-2             1.18.0-3
                           terraform              1.2.8-1              1.2.9-1
                         ttc-iosevka             16.0.2-1             16.1.0-1
                    ttc-iosevka-aile             16.0.2-1             16.1.0-1
                   ttc-iosevka-curly             16.0.2-1             16.1.0-1
              ttc-iosevka-curly-slab             16.0.2-1             16.1.0-1
                  ttc-iosevka-etoile             16.0.2-1             16.1.0-1
                    ttc-iosevka-slab             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss01             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss02             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss03             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss04             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss05             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss06             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss07             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss08             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss09             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss10             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss11             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss12             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss13             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss14             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss15             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss16             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss17             16.0.2-1             16.1.0-1
                    ttc-iosevka-ss18             16.0.2-1             16.1.0-1
                    ttf-iosevka-nerd              2.1.0-2              2.2.1-1
      ttf-nerd-fonts-symbols-1000-em              2.2.1-5              2.2.2-1
 ttf-nerd-fonts-symbols-1000-em-mono              2.2.1-5              2.2.2-1
      ttf-nerd-fonts-symbols-2048-em              2.2.1-5              2.2.2-1
 ttf-nerd-fonts-symbols-2048-em-mono              2.2.1-5              2.2.2-1
                   ttf-sarasa-gothic             0.37.0-1             0.37.1-1
                              tuntox             0.0.10-1           0.0.10.1-1
                               udpxy             1.0.25-2           1.0.25.1-1
                            ueberzug             18.1.9-3             18.1.9-4
                            urlwatch               2.25-1               2.25-2
         v2ray-domain-list-community     20220902120816-1     20220907153354-1
                         v2ray-geoip       202209010055-1       202209080101-1
                     vaultwarden-web           2022.6.2-1           2022.8.1-1
                          vdirsyncer             0.18.0-3             0.18.0-4
                        vim-nerdtree            6.10.15-1            6.10.16-1
                                vint             0.3.20-4             0.3.20-5
                           virt-what               1.24-1               1.25-1
                                vmpk              0.8.7-2              0.8.8-1
                             vst3sdk     3.7.5_build_44-1     3.7.6_build_18-1
                           watchexec             1.20.5-1             1.20.6-1
                              weston             10.0.1-1             10.0.2-1
                             wezterm20220807.113146.c2fee766-220220905.102802.7d4b8249-1
                       wireshark-cli              3.6.7-1              3.6.8-1
                        wireshark-qt              3.6.7-1              3.6.8-1
                           wordpress              6.0.1-1              6.0.2-1
                            xandikos              0.2.8-1              0.2.8-2
                            yamllint             1.27.1-1             1.27.1-2
                       cartridge-cli                    -             2.12.2-1
                       docker-buildx                    -              0.9.1-1
                                mage                    -             1.13.0-2
                             monitor                    -           20220907-1
:: Different overlay package(s) in repository core aarch64
                               linux             5.19.6-2             5.19.8-1
               linux-clockworkpi-a06             5.19.6-1             5.19.8-1
       linux-clockworkpi-a06-headers             5.19.6-1             5.19.8-1
                       linux-headers             5.19.6-2             5.19.8-1
                           linux-lts            5.15.64-1            5.15.67-1
                   linux-lts-headers            5.15.64-1            5.15.67-1
                     linux-pinephone             5.19.6-1             5.19.7-1
             linux-pinephone-headers             5.19.6-1             5.19.7-1
                  linux-pinephonepro             5.19.6-1             5.19.7-1
          linux-pinephonepro-headers             5.19.6-1             5.19.7-1
                            linux-rc            6.0.rc3-3            6.0.rc4-2
                    linux-rc-headers            6.0.rc3-3            6.0.rc4-2
:: Different sync package(s) in repository core aarch64
                               lemon             3.39.2-2             3.39.3-1
                                less              1:590-1              1:608-1
                              sqlite             3.39.2-2             3.39.3-1
                     sqlite-analyzer             3.39.2-2             3.39.3-1
                          sqlite-doc             3.39.2-2             3.39.3-1
                          sqlite-tcl             3.39.2-2             3.39.3-1
:: Different overlay package(s) in repository extra aarch64
                          elisa-qtmm            22.08.0-1            22.08.1-1
                                kwin           5.25.4-1.1           5.25.5-1.1
                              okular            22.08.0-1            22.08.1-1
                       plasma-mobile             5.25.4-1             5.25.5-1
                    plasma-mobile-nm             5.25.4-1             5.25.5-1
                         plasma-nano             5.25.4-1             5.25.5-1
                   qqc2-breeze-style             5.25.4-1             5.25.5-1
                        qt5-es2-base    5.15.5+kde+r174-1    5.15.5+kde+r184-1
                     qt5-es2-wayland     5.15.5+kde+r38-3     5.15.5+kde+r38-4
         qt5-es2-xcb-private-headers    5.15.5+kde+r174-1    5.15.5+kde+r184-1
:: Different sync package(s) in repository extra aarch64
                         389-ds-base              2.2.2-1              2.3.0-1
                           aisleriot            3.22.23-2            3.22.25-1
                             akonadi            22.08.0-1            22.08.1-1
                    akonadi-calendar            22.08.0-1            22.08.1-1
              akonadi-calendar-tools            22.08.0-1            22.08.1-1
                    akonadi-contacts            22.08.0-1            22.08.1-1
               akonadi-import-wizard            22.08.0-1            22.08.1-1
                        akonadi-mime            22.08.0-1            22.08.1-1
                       akonadi-notes            22.08.0-1            22.08.1-1
                      akonadi-search            22.08.0-1            22.08.1-1
                      akonadiconsole            22.08.0-1            22.08.1-1
                           akregator            22.08.0-1            22.08.1-1
                            analitza            22.08.0-1            22.08.1-1
                                 ark            22.08.0-1            22.08.1-1
                          artikulate            22.08.0-1            22.08.1-1
                         audiocd-kio            22.08.0-1            22.08.1-1
                       baloo-widgets            22.08.0-2            22.08.1-1
                             blinken            22.08.0-1            22.08.1-1
                           bluedevil           1:5.25.4-1           1:5.25.5-1
                              bomber            22.08.0-1            22.08.1-1
                                bovo            22.08.0-1            22.08.1-1
                              breeze             5.25.4-1             5.25.5-1
                         breeze-grub             5.25.4-1             5.25.5-1
                          breeze-gtk             5.25.4-1             5.25.5-1
                     calendarsupport            22.08.0-1            22.08.1-1
                              cantor            22.08.0-1            22.08.1-1
                            cervisia            22.08.0-1            22.08.1-1
                            chromium     105.0.5195.102-1     105.0.5195.102-2
                            coordgen              3.0.0-1              3.0.1-1
                             digikam              7.8.0-1              7.8.0-2
                     directx-headers            1.606.3-1            1.606.4-1
                            discover             5.25.4-1             5.25.5-1
                             dolphin            22.08.0-1            22.08.1-1
                     dolphin-plugins            22.08.0-1            22.08.1-1
                              dragon            22.08.0-1            22.08.1-1
                             drkonqi             5.25.4-1             5.25.5-1
                         egl-wayland           2:1.1.10-1           2:1.1.11-2
                               elisa            22.08.0-1            22.08.1-1
                          eventviews            22.08.0-1            22.08.1-1
                              falkon            22.08.0-1            22.08.1-1
                              ffmpeg            2:5.1.1-1            2:5.1.1-3
                        ffmpegthumbs            22.08.0-1            22.08.1-1
                           filelight            22.08.0-1            22.08.1-1
                             firefox            104.0.1-1            104.0.2-1
                    firefox-i18n-ach            104.0.1-1            104.0.2-1
                     firefox-i18n-af            104.0.1-1            104.0.2-1
                     firefox-i18n-an            104.0.1-1            104.0.2-1
                     firefox-i18n-ar            104.0.1-1            104.0.2-1
                    firefox-i18n-ast            104.0.1-1            104.0.2-1
                     firefox-i18n-az            104.0.1-1            104.0.2-1
                     firefox-i18n-be            104.0.1-1            104.0.2-1
                     firefox-i18n-bg            104.0.1-1            104.0.2-1
                     firefox-i18n-bn            104.0.1-1            104.0.2-1
                     firefox-i18n-br            104.0.1-1            104.0.2-1
                     firefox-i18n-bs            104.0.1-1            104.0.2-1
                     firefox-i18n-ca            104.0.1-1            104.0.2-1
            firefox-i18n-ca-valencia            104.0.1-1            104.0.2-1
                    firefox-i18n-cak            104.0.1-1            104.0.2-1
                     firefox-i18n-cs            104.0.1-1            104.0.2-1
                     firefox-i18n-cy            104.0.1-1            104.0.2-1
                     firefox-i18n-da            104.0.1-1            104.0.2-1
                     firefox-i18n-de            104.0.1-1            104.0.2-1
                    firefox-i18n-dsb            104.0.1-1            104.0.2-1
                     firefox-i18n-el            104.0.1-1            104.0.2-1
                  firefox-i18n-en-ca            104.0.1-1            104.0.2-1
                  firefox-i18n-en-gb            104.0.1-1            104.0.2-1
                  firefox-i18n-en-us            104.0.1-1            104.0.2-1
                     firefox-i18n-eo            104.0.1-1            104.0.2-1
                  firefox-i18n-es-ar            104.0.1-1            104.0.2-1
                  firefox-i18n-es-cl            104.0.1-1            104.0.2-1
                  firefox-i18n-es-es            104.0.1-1            104.0.2-1
                  firefox-i18n-es-mx            104.0.1-1            104.0.2-1
                     firefox-i18n-et            104.0.1-1            104.0.2-1
                     firefox-i18n-eu            104.0.1-1            104.0.2-1
                     firefox-i18n-fa            104.0.1-1            104.0.2-1
                     firefox-i18n-ff            104.0.1-1            104.0.2-1
                     firefox-i18n-fi            104.0.1-1            104.0.2-1
                     firefox-i18n-fr            104.0.1-1            104.0.2-1
                  firefox-i18n-fy-nl            104.0.1-1            104.0.2-1
                  firefox-i18n-ga-ie            104.0.1-1            104.0.2-1
                     firefox-i18n-gd            104.0.1-1            104.0.2-1
                     firefox-i18n-gl            104.0.1-1            104.0.2-1
                     firefox-i18n-gn            104.0.1-1            104.0.2-1
                  firefox-i18n-gu-in            104.0.1-1            104.0.2-1
                     firefox-i18n-he            104.0.1-1            104.0.2-1
                  firefox-i18n-hi-in            104.0.1-1            104.0.2-1
                     firefox-i18n-hr            104.0.1-1            104.0.2-1
                    firefox-i18n-hsb            104.0.1-1            104.0.2-1
                     firefox-i18n-hu            104.0.1-1            104.0.2-1
                  firefox-i18n-hy-am            104.0.1-1            104.0.2-1
                     firefox-i18n-ia            104.0.1-1            104.0.2-1
                     firefox-i18n-id            104.0.1-1            104.0.2-1
                     firefox-i18n-is            104.0.1-1            104.0.2-1
                     firefox-i18n-it            104.0.1-1            104.0.2-1
                     firefox-i18n-ja            104.0.1-1            104.0.2-1
                     firefox-i18n-ka            104.0.1-1            104.0.2-1
                    firefox-i18n-kab            104.0.1-1            104.0.2-1
                     firefox-i18n-kk            104.0.1-1            104.0.2-1
                     firefox-i18n-km            104.0.1-1            104.0.2-1
                     firefox-i18n-kn            104.0.1-1            104.0.2-1
                     firefox-i18n-ko            104.0.1-1            104.0.2-1
                    firefox-i18n-lij            104.0.1-1            104.0.2-1
                     firefox-i18n-lt            104.0.1-1            104.0.2-1
                     firefox-i18n-lv            104.0.1-1            104.0.2-1
                     firefox-i18n-mk            104.0.1-1            104.0.2-1
                     firefox-i18n-mr            104.0.1-1            104.0.2-1
                     firefox-i18n-ms            104.0.1-1            104.0.2-1
                     firefox-i18n-my            104.0.1-1            104.0.2-1
                  firefox-i18n-nb-no            104.0.1-1            104.0.2-1
                  firefox-i18n-ne-np            104.0.1-1            104.0.2-1
                     firefox-i18n-nl            104.0.1-1            104.0.2-1
                  firefox-i18n-nn-no            104.0.1-1            104.0.2-1
                     firefox-i18n-oc            104.0.1-1            104.0.2-1
                  firefox-i18n-pa-in            104.0.1-1            104.0.2-1
                     firefox-i18n-pl            104.0.1-1            104.0.2-1
                  firefox-i18n-pt-br            104.0.1-1            104.0.2-1
                  firefox-i18n-pt-pt            104.0.1-1            104.0.2-1
                     firefox-i18n-rm            104.0.1-1            104.0.2-1
                     firefox-i18n-ro            104.0.1-1            104.0.2-1
                     firefox-i18n-ru            104.0.1-1            104.0.2-1
                    firefox-i18n-sco            104.0.1-1            104.0.2-1
                     firefox-i18n-si            104.0.1-1            104.0.2-1
                     firefox-i18n-sk            104.0.1-1            104.0.2-1
                     firefox-i18n-sl            104.0.1-1            104.0.2-1
                    firefox-i18n-son            104.0.1-1            104.0.2-1
                     firefox-i18n-sq            104.0.1-1            104.0.2-1
                     firefox-i18n-sr            104.0.1-1            104.0.2-1
                  firefox-i18n-sv-se            104.0.1-1            104.0.2-1
                    firefox-i18n-szl            104.0.1-1            104.0.2-1
                     firefox-i18n-ta            104.0.1-1            104.0.2-1
                     firefox-i18n-te            104.0.1-1            104.0.2-1
                     firefox-i18n-th            104.0.1-1            104.0.2-1
                     firefox-i18n-tl            104.0.1-1            104.0.2-1
                     firefox-i18n-tr            104.0.1-1            104.0.2-1
                    firefox-i18n-trs            104.0.1-1            104.0.2-1
                     firefox-i18n-uk            104.0.1-1            104.0.2-1
                     firefox-i18n-ur            104.0.1-1            104.0.2-1
                     firefox-i18n-uz            104.0.1-1            104.0.2-1
                     firefox-i18n-vi            104.0.1-1            104.0.2-1
                     firefox-i18n-xh            104.0.1-1            104.0.2-1
                  firefox-i18n-zh-cn            104.0.1-1            104.0.2-1
                  firefox-i18n-zh-tw            104.0.1-1            104.0.2-1
                          fluidsynth              2.2.8-1              2.2.9-2
                 gnome-bluetooth-3.0               42.3-1               42.4-1
                           granatier            22.08.0-1            22.08.1-1
                     grantlee-editor            22.08.0-1            22.08.1-1
                       grantleetheme            22.08.0-1            22.08.1-1
                      graphicsmagick             1.3.38-3             1.3.38-4
                     grml-zsh-config             0.19.3-1             0.19.3-2
               gtk-update-icon-cache            1:4.6.7-1            1:4.8.0-1
                                gtk4            1:4.6.7-1            1:4.8.0-1
                          gtk4-demos            1:4.6.7-1            1:4.8.0-1
                           gtk4-docs            1:4.6.7-1            1:4.8.0-1
                            gwenview            22.08.0-1            22.08.1-1
                 ibus-typing-booster             2.18.9-1            2.18.10-1
                         imagemagick           7.1.0.47-1           7.1.0.47-2
                     imagemagick-doc           7.1.0.47-1           7.1.0.47-2
                     incidenceeditor            22.08.0-1            22.08.1-1
                            inkscape              1.2.1-4              1.2.1-5
                           itinerary            22.08.0-1            22.08.1-1
                                 juk            22.08.0-1            22.08.1-1
                                 k3b          1:22.08.0-1          1:22.08.1-1
               kaccounts-integration            22.08.0-2            22.08.1-1
                 kaccounts-providers            22.08.0-2            22.08.1-1
                   kactivitymanagerd             5.25.4-1             5.25.5-1
                        kaddressbook            22.08.0-1            22.08.1-1
                             kajongg            22.08.0-1            22.08.1-1
                              kalarm            22.08.0-1            22.08.1-1
                            kalendar            22.08.0-1            22.08.1-1
                            kalgebra            22.08.0-1            22.08.1-1
                             kalzium            22.08.0-1            22.08.1-1
                              kamera            22.08.0-1            22.08.1-1
                              kamoso            22.08.0-1            22.08.1-1
                            kanagram            22.08.0-1            22.08.1-1
                              kapman            22.08.0-1            22.08.1-1
                        kapptemplate            22.08.0-1            22.08.1-1
                                kate            22.08.0-1            22.08.1-1
                             katomic            22.08.0-1            22.08.1-1
                             kbackup            22.08.0-1            22.08.1-1
                           kblackbox            22.08.0-1            22.08.1-1
                             kblocks            22.08.0-1            22.08.1-1
                             kbounce            22.08.0-1            22.08.1-1
                           kbreakout            22.08.0-1            22.08.1-1
                              kbruch            22.08.0-1            22.08.1-1
                         kcachegrind            22.08.0-1            22.08.1-1
                  kcachegrind-common            22.08.0-1            22.08.1-1
                               kcalc            22.08.0-1            22.08.1-1
                           kcalutils            22.08.0-1            22.08.1-1
                         kcharselect            22.08.0-1            22.08.1-1
                       kcolorchooser            22.08.0-1            22.08.1-1
                               kcron            22.08.0-1            22.08.1-1
                       kde-cli-tools             5.25.4-1             5.25.5-1
                     kde-dev-scripts            22.08.0-1            22.08.1-1
                       kde-dev-utils            22.08.0-1            22.08.1-1
                      kde-gtk-config             5.25.4-1             5.25.5-1
                      kdebugsettings            22.08.0-1            22.08.1-1
                          kdeconnect            22.08.0-1            22.08.1-1
                         kdecoration             5.25.4-1             5.25.5-1
                         kdeedu-data            22.08.0-1            22.08.1-1
              kdegraphics-mobipocket            22.08.0-1            22.08.1-1
            kdegraphics-thumbnailers            22.08.0-1            22.08.1-1
              kdenetwork-filesharing            22.08.0-1            22.08.1-1
                            kdenlive            22.08.0-1            22.08.1-1
                       kdepim-addons            22.08.0-1            22.08.1-1
                      kdepim-runtime            22.08.0-1            22.08.1-1
                    kdeplasma-addons             5.25.4-1             5.25.5-1
                          kdesdk-kio            22.08.0-1            22.08.1-1
                 kdesdk-thumbnailers            22.08.0-1            22.08.1-1
                            kdevelop            22.08.0-1            22.08.1-1
                        kdevelop-php            22.08.0-1            22.08.1-1
                                 kdf            22.08.0-1            22.08.1-1
                             kdialog            22.08.0-1            22.08.1-1
                            kdiamond            22.08.0-1            22.08.1-1
                      keditbookmarks            22.08.0-1            22.08.1-1
                               kfind            22.08.0-1            22.08.1-1
                             kfloppy            22.08.0-1            22.08.1-1
                         kfourinline            22.08.0-1            22.08.1-1
                             kgamma5             5.25.4-1             5.25.5-1
                          kgeography            22.08.0-1            22.08.1-1
                                kget            22.08.0-1            22.08.1-1
                         kgoldrunner            22.08.0-1            22.08.1-1
                                kgpg            22.08.0-1            22.08.1-1
                            khangman            22.08.0-1            22.08.1-1
                         khelpcenter            22.08.0-1            22.08.1-1
                            khotkeys             5.25.4-1             5.25.5-1
                 kidentitymanagement            22.08.0-1            22.08.1-1
                                 kig            22.08.0-1            22.08.1-1
                                kigo            22.08.0-1            22.08.1-1
                            killbots            22.08.0-1            22.08.1-1
                     kimagemapeditor            22.08.0-1            22.08.1-1
                               kimap            22.08.0-1            22.08.1-1
                         kinfocenter             5.25.4-1             5.25.5-1
                          kio-extras            22.08.0-1            22.08.1-1
                          kio-gdrive            22.08.0-1            22.08.1-1
                        kio-zeroconf            22.08.0-1            22.08.1-1
                    kirigami-gallery            22.08.0-1            22.08.1-1
                              kiriki            22.08.0-1            22.08.1-1
                               kiten            22.08.0-1            22.08.1-1
                          kitinerary            22.08.0-2            22.08.1-1
                        kjumpingcube            22.08.0-1            22.08.1-1
                               kldap            22.08.0-1            22.08.1-1
                           kleopatra            22.08.0-1            22.08.1-1
                            klettres            22.08.0-1            22.08.1-1
                            klickety            22.08.0-1            22.08.1-1
                              klines            22.08.0-1            22.08.1-1
                                kmag            22.08.0-1            22.08.1-1
                           kmahjongg            22.08.0-1            22.08.1-1
                               kmail            22.08.0-1            22.08.1-1
                kmail-account-wizard            22.08.0-1            22.08.1-1
                      kmailtransport            22.08.0-1            22.08.1-1
                               kmbox            22.08.0-1            22.08.1-1
                           kmenuedit             5.25.4-1             5.25.5-1
                               kmime            22.08.0-1            22.08.1-1
                              kmines            22.08.0-1            22.08.1-1
                                kmix            22.08.0-1            22.08.1-1
                          kmousetool            22.08.0-1            22.08.1-1
                              kmouth            22.08.0-1            22.08.1-1
                              kmplot            22.08.0-1            22.08.1-1
                        knavalbattle            22.08.0-1            22.08.1-1
                            knetwalk            22.08.0-1            22.08.1-1
                             knights            22.08.0-1            22.08.1-1
                              knotes            22.08.0-1            22.08.1-1
                                kolf            22.08.0-1            22.08.1-1
                           kollision            22.08.0-1            22.08.1-1
                         kolourpaint            22.08.0-1            22.08.1-1
                             kompare            22.08.0-1            22.08.1-1
                           konqueror            22.08.0-1            22.08.1-1
                            konquest            22.08.0-1            22.08.1-1
                             konsole            22.08.0-1            22.08.1-1
                             kontact            22.08.0-1            22.08.1-1
                    kontactinterface            22.08.0-1            22.08.1-1
                            kontrast            22.08.0-1            22.08.1-1
                        konversation            22.08.0-1            22.08.1-1
                       kopeninghours            22.08.0-1            22.08.1-1
                              kopete            22.08.0-1            22.08.1-1
                          korganizer            22.08.0-1            22.08.1-1
                       kosmindoormap            22.08.0-1            22.08.1-1
                                kpat            22.08.0-1            22.08.1-1
                        kpimtextedit            22.08.0-1            22.08.1-1
                             kpkpass            22.08.0-1            22.08.1-1
                             kpmcore            22.08.0-1            22.08.1-1
                    kpublictransport            22.08.0-1            22.08.1-1
                      kqtquickcharts            22.08.0-1            22.08.1-1
                                krdc            22.08.0-1            22.08.1-1
                            kreversi            22.08.0-1            22.08.1-1
                                krfb            22.08.0-1            22.08.1-1
                              kruler            22.08.0-1            22.08.1-1
                           ksanecore            22.08.0-1            22.08.1-1
                             kscreen             5.25.4-1             5.25.5-1
                       kscreenlocker             5.25.4-1             5.25.5-1
                             kshisen            22.08.0-1            22.08.1-1
                               ksirk            22.08.0-1            22.08.1-1
                               ksmtp            22.08.0-1            22.08.1-1
                          ksnakeduel            22.08.0-1            22.08.1-1
                          kspaceduel            22.08.0-1            22.08.1-1
                            ksquares            22.08.0-1            22.08.1-1
                         ksshaskpass             5.25.4-1             5.25.5-1
                             ksudoku            22.08.0-1            22.08.1-1
                          ksystemlog            22.08.0-1            22.08.1-1
                        ksystemstats             5.25.4-1             5.25.5-1
                            kteatime            22.08.0-1            22.08.1-1
                              ktimer            22.08.0-1            22.08.1-1
                               ktnef            22.08.0-1            22.08.1-1
                            ktorrent            22.08.0-1            22.08.1-1
                              ktouch            22.08.0-1            22.08.1-1
                          ktuberling            22.08.0-1            22.08.1-1
                             kturtle            22.08.0-1            22.08.1-1
                             kubrick            22.08.0-1            22.08.1-1
                         kwallet-pam             5.25.4-1             5.25.5-1
                      kwalletmanager            22.08.0-1            22.08.1-1
                               kwave            22.08.0-1            22.08.1-1
                kwayland-integration             5.25.4-1             5.25.5-1
                                kwin             5.25.4-1             5.25.5-1
                           kwordquiz            22.08.0-1            22.08.1-1
                             kwrited             5.25.4-1             5.25.5-1
                      layer-shell-qt             5.25.4-1             5.25.5-1
                          libakonadi            22.08.0-1            22.08.1-1
                      libdmapsharing             2.9.41-1             2.9.41-2
                         libgnomekbd           1:3.28.0-1           1:3.28.1-1
                         libgravatar            22.08.0-1            22.08.1-1
                             libheif             1.13.0-1             1.13.0-2
                            libkcddb            22.08.0-1            22.08.1-1
                     libkcompactdisc            22.08.0-1            22.08.1-1
                           libkdcraw            22.08.0-1            22.08.1-1
                         libkdegames            22.08.0-1            22.08.1-1
                           libkdepim            22.08.0-1            22.08.1-1
                  libkeduvocdocument            22.08.0-1            22.08.1-1
                           libkexiv2            22.08.0-1            22.08.1-1
                            libkgapi            22.08.0-1            22.08.1-1
                             libkleo            22.08.0-1            22.08.1-1
                        libkmahjongg            22.08.0-1            22.08.1-1
                     libkomparediff2            22.08.0-1            22.08.1-1
                            libksane            22.08.0-1            22.08.1-1
                          libkscreen             5.25.4-1             5.25.5-1
                           libksieve            22.08.0-1            22.08.1-1
                        libksysguard             5.25.4-1             5.25.5-1
                         libktorrent            22.08.0-1            22.08.1-1
                      liblightdm-qt5           1:1.32.0-1           1:1.32.0-4
                            liblouis             3.22.0-1             3.23.0-1
                              libnma             1.8.40-1             1.10.0-1
                       libnma-common             1.8.40-1             1.10.0-1
                         libnma-gtk4             1.8.40-1             1.10.0-1
                   libreoffice-fresh              7.4.0-3              7.4.0-4
               libreoffice-fresh-sdk              7.4.0-3              7.4.0-4
                   libreoffice-still              7.3.5-3              7.3.6-1
                libreoffice-still-af              7.3.5-1              7.3.6-1
                libreoffice-still-am              7.3.5-1              7.3.6-1
                libreoffice-still-ar              7.3.5-1              7.3.6-1
                libreoffice-still-as              7.3.5-1              7.3.6-1
               libreoffice-still-ast              7.3.5-1              7.3.6-1
                libreoffice-still-be              7.3.5-1              7.3.6-1
                libreoffice-still-bg              7.3.5-1              7.3.6-1
                libreoffice-still-bn              7.3.5-1              7.3.6-1
             libreoffice-still-bn-in              7.3.5-1              7.3.6-1
                libreoffice-still-bo              7.3.5-1              7.3.6-1
                libreoffice-still-br              7.3.5-1              7.3.6-1
               libreoffice-still-brx              7.3.5-1              7.3.6-1
                libreoffice-still-bs              7.3.5-1              7.3.6-1
                libreoffice-still-ca              7.3.5-1              7.3.6-1
       libreoffice-still-ca-valencia              7.3.5-1              7.3.6-1
               libreoffice-still-ckb              7.3.5-1              7.3.6-1
                libreoffice-still-cs              7.3.5-1              7.3.6-1
                libreoffice-still-cy              7.3.5-1              7.3.6-1
                libreoffice-still-da              7.3.5-1              7.3.6-1
                libreoffice-still-de              7.3.5-1              7.3.6-1
               libreoffice-still-dgo              7.3.5-1              7.3.6-1
               libreoffice-still-dsb              7.3.5-1              7.3.6-1
                libreoffice-still-dz              7.3.5-1              7.3.6-1
                libreoffice-still-el              7.3.5-1              7.3.6-1
             libreoffice-still-en-gb              7.3.5-1              7.3.6-1
             libreoffice-still-en-za              7.3.5-1              7.3.6-1
                libreoffice-still-eo              7.3.5-1              7.3.6-1
                libreoffice-still-es              7.3.5-1              7.3.6-1
                libreoffice-still-et              7.3.5-1              7.3.6-1
                libreoffice-still-eu              7.3.5-1              7.3.6-1
                libreoffice-still-fa              7.3.5-1              7.3.6-1
                libreoffice-still-fi              7.3.5-1              7.3.6-1
                libreoffice-still-fr              7.3.5-1              7.3.6-1
               libreoffice-still-fur              7.3.5-1              7.3.6-1
                libreoffice-still-fy              7.3.5-1              7.3.6-1
                libreoffice-still-ga              7.3.5-1              7.3.6-1
                libreoffice-still-gd              7.3.5-1              7.3.6-1
                libreoffice-still-gl              7.3.5-1              7.3.6-1
                libreoffice-still-gu              7.3.5-1              7.3.6-1
               libreoffice-still-gug              7.3.5-1              7.3.6-1
                libreoffice-still-he              7.3.5-1              7.3.6-1
                libreoffice-still-hi              7.3.5-1              7.3.6-1
                libreoffice-still-hr              7.3.5-1              7.3.6-1
               libreoffice-still-hsb              7.3.5-1              7.3.6-1
                libreoffice-still-hu              7.3.5-1              7.3.6-1
                libreoffice-still-id              7.3.5-1              7.3.6-1
                libreoffice-still-is              7.3.5-1              7.3.6-1
                libreoffice-still-it              7.3.5-1              7.3.6-1
                libreoffice-still-ja              7.3.5-1              7.3.6-1
                libreoffice-still-ka              7.3.5-1              7.3.6-1
               libreoffice-still-kab              7.3.5-1              7.3.6-1
                libreoffice-still-kk              7.3.5-1              7.3.6-1
                libreoffice-still-km              7.3.5-1              7.3.6-1
          libreoffice-still-kmr-latn              7.3.5-1              7.3.6-1
                libreoffice-still-kn              7.3.5-1              7.3.6-1
                libreoffice-still-ko              7.3.5-1              7.3.6-1
               libreoffice-still-kok              7.3.5-1              7.3.6-1
                libreoffice-still-ks              7.3.5-1              7.3.6-1
                libreoffice-still-lb              7.3.5-1              7.3.6-1
                libreoffice-still-lo              7.3.5-1              7.3.6-1
                libreoffice-still-lt              7.3.5-1              7.3.6-1
                libreoffice-still-lv              7.3.5-1              7.3.6-1
               libreoffice-still-mai              7.3.5-1              7.3.6-1
                libreoffice-still-mk              7.3.5-1              7.3.6-1
                libreoffice-still-ml              7.3.5-1              7.3.6-1
                libreoffice-still-mn              7.3.5-1              7.3.6-1
               libreoffice-still-mni              7.3.5-1              7.3.6-1
                libreoffice-still-mr              7.3.5-1              7.3.6-1
                libreoffice-still-my              7.3.5-1              7.3.6-1
                libreoffice-still-nb              7.3.5-1              7.3.6-1
                libreoffice-still-ne              7.3.5-1              7.3.6-1
                libreoffice-still-nl              7.3.5-1              7.3.6-1
                libreoffice-still-nn              7.3.5-1              7.3.6-1
                libreoffice-still-nr              7.3.5-1              7.3.6-1
               libreoffice-still-nso              7.3.5-1              7.3.6-1
                libreoffice-still-oc              7.3.5-1              7.3.6-1
                libreoffice-still-om              7.3.5-1              7.3.6-1
                libreoffice-still-or              7.3.5-1              7.3.6-1
             libreoffice-still-pa-in              7.3.5-1              7.3.6-1
                libreoffice-still-pl              7.3.5-1              7.3.6-1
                libreoffice-still-pt              7.3.5-1              7.3.6-1
             libreoffice-still-pt-br              7.3.5-1              7.3.6-1
                libreoffice-still-ro              7.3.5-1              7.3.6-1
                libreoffice-still-ru              7.3.5-1              7.3.6-1
                libreoffice-still-rw              7.3.5-1              7.3.6-1
             libreoffice-still-sa-in              7.3.5-1              7.3.6-1
               libreoffice-still-sat              7.3.5-1              7.3.6-1
                libreoffice-still-sd              7.3.5-1              7.3.6-1
               libreoffice-still-sdk              7.3.5-3              7.3.6-1
                libreoffice-still-si              7.3.5-1              7.3.6-1
               libreoffice-still-sid              7.3.5-1              7.3.6-1
                libreoffice-still-sk              7.3.5-1              7.3.6-1
                libreoffice-still-sl              7.3.5-1              7.3.6-1
                libreoffice-still-sq              7.3.5-1              7.3.6-1
                libreoffice-still-sr              7.3.5-1              7.3.6-1
           libreoffice-still-sr-latn              7.3.5-1              7.3.6-1
                libreoffice-still-ss              7.3.5-1              7.3.6-1
                libreoffice-still-st              7.3.5-1              7.3.6-1
                libreoffice-still-sv              7.3.5-1              7.3.6-1
             libreoffice-still-sw-tz              7.3.5-1              7.3.6-1
               libreoffice-still-szl              7.3.5-1              7.3.6-1
                libreoffice-still-ta              7.3.5-1              7.3.6-1
                libreoffice-still-te              7.3.5-1              7.3.6-1
                libreoffice-still-tg              7.3.5-1              7.3.6-1
                libreoffice-still-th              7.3.5-1              7.3.6-1
                libreoffice-still-tn              7.3.5-1              7.3.6-1
                libreoffice-still-tr              7.3.5-1              7.3.6-1
                libreoffice-still-ts              7.3.5-1              7.3.6-1
                libreoffice-still-tt              7.3.5-1              7.3.6-1
                libreoffice-still-ug              7.3.5-1              7.3.6-1
                libreoffice-still-uk              7.3.5-1              7.3.6-1
                libreoffice-still-uz              7.3.5-1              7.3.6-1
                libreoffice-still-ve              7.3.5-1              7.3.6-1
               libreoffice-still-vec              7.3.5-1              7.3.6-1
                libreoffice-still-vi              7.3.5-1              7.3.6-1
                libreoffice-still-xh              7.3.5-1              7.3.6-1
             libreoffice-still-zh-cn              7.3.5-1              7.3.6-1
             libreoffice-still-zh-tw              7.3.5-1              7.3.6-1
                libreoffice-still-zu              7.3.5-1              7.3.6-1
                              libssh             0.10.2-1             0.10.4-1
                         libssh-docs             0.10.2-1             0.10.4-1
                               libva             2.15.0-2             2.15.0-6
                              libxft              2.3.4-1              2.3.5-1
                             lightdm           1:1.32.0-1           1:1.32.0-4
                 lightdm-gtk-greeter            1:2.0.8-2            1:2.0.8-3
                        link-grammar             5.10.2-4             5.10.5-1
                            lokalize            22.08.0-1            22.08.1-1
                               lskat            22.08.0-1            22.08.1-1
                           maeparser              1.2.4-6              1.3.0-1
                          mailcommon            22.08.0-1            22.08.1-1
                        mailimporter            22.08.0-1            22.08.1-1
                              marble            22.08.0-1            22.08.1-1
                       marble-common            22.08.0-1            22.08.1-1
                         marble-maps            22.08.0-1            22.08.1-1
                           marble-qt            22.08.0-1            22.08.1-1
                        markdownpart            22.08.0-1            22.08.1-1
                       mbox-importer            22.08.0-1            22.08.1-1
                                meld             3.21.3-2             3.22.0-1
                          messagelib            22.08.0-1            22.08.1-1
                               milou             5.25.4-1             5.25.5-1
                              minuet            22.08.0-1            22.08.1-1
                                neon             0.32.2-1             0.32.3-1
                             numactl             2.0.14-3             2.0.15-1
                              oxygen             5.25.4-1             5.25.5-1
                       oxygen-sounds             5.25.4-1             5.25.5-1
                            palapeli            22.08.0-1            22.08.1-1
                              parley            22.08.0-1            22.08.1-1
                    partitionmanager            22.08.0-1            22.08.1-1
                         pavucontrol 1:5.0+r35+g964f298-1 1:5.0+r61+gee77d86-2
                    perl-alien-build               2.53-1               2.56-1
                     perl-date-manip               6.88-1               6.89-1
                  perl-io-socket-ssl              2.074-3              2.075-1
                   perl-log-log4perl               1.55-1               1.56-1
                       perl-text-csv               2.01-1               2.02-1
                               picmi            22.08.0-1            22.08.1-1
                   pim-data-exporter            22.08.0-1            22.08.1-1
                    pim-sieve-editor            22.08.0-1            22.08.1-1
                           pimcommon            22.08.0-1            22.08.1-1
          plasma-browser-integration             5.25.4-1             5.25.5-1
                      plasma-desktop             5.25.4-1             5.25.5-1
                        plasma-disks             5.25.4-1             5.25.5-1
                     plasma-firewall             5.25.4-1             5.25.5-1
                  plasma-integration             5.25.4-1             5.25.5-1
                           plasma-nm             5.25.4-1             5.25.5-1
                           plasma-pa             5.25.4-1             5.25.5-1
                          plasma-sdk             5.25.4-1             5.25.5-1
                plasma-systemmonitor             5.25.4-1             5.25.5-1
                  plasma-thunderbolt             5.25.4-1             5.25.5-1
                        plasma-vault             5.25.4-1             5.25.5-1
            plasma-wayland-protocols              1.7.0-1              1.8.0-1
              plasma-wayland-session             5.25.4-1             5.25.5-2
                    plasma-workspace             5.25.4-1             5.25.5-2
         plasma-workspace-wallpapers             5.25.4-1             5.25.5-1
                    polkit-kde-agent             5.25.4-1             5.25.5-1
                          powerdevil             5.25.4-1             5.25.5-1
                               poxml            22.08.0-1            22.08.1-1
                       print-manager            22.08.0-1            22.08.1-1
                 python-cryptography             37.0.4-1             38.0.0-1
                      python-systemd               234-11                235-1
                      python-twisted             22.1.0-1             22.2.0-1
                   python-virtualenv            20.13.0-1            20.13.1-1
                         qcachegrind            22.08.0-1            22.08.1-1
                            qt5-base    5.15.5+kde+r180-1    5.15.5+kde+r184-1
                         qt5-wayland     5.15.5+kde+r38-3     5.15.5+kde+r38-4
             qt5-xcb-private-headers    5.15.5+kde+r180-1    5.15.5+kde+r184-1
                                rocs            22.08.0-1            22.08.1-1
                               samba             4.16.4-3             4.16.5-1
                                sbcl              2.2.5-1              2.2.8-1
                            sddm-kcm             5.25.4-1             5.25.5-1
                    shared-mime-info   2.0+144+g13695c7-1   2.0+155+gf4e7cbc-1
            signon-kwallet-extension            22.08.0-1            22.08.1-1
                            skanlite            22.08.0-1            22.08.1-1
                            skanpage            22.08.0-1            22.08.1-1
                           smbclient             4.16.4-3             4.16.5-1
                           spectacle            22.08.0-1            22.08.1-1
                                step            22.08.0-1            22.08.1-1
                             svgpart            22.08.0-1            22.08.1-1
                             sweeper            22.08.0-1            22.08.1-1
                      systemsettings             5.25.4-1             5.25.5-1
          telepathy-kde-accounts-kcm            22.08.0-1            22.08.1-1
              telepathy-kde-approver            22.08.0-1            22.08.1-1
          telepathy-kde-auth-handler            22.08.0-1            22.08.1-1
               telepathy-kde-call-ui            22.08.0-1            22.08.1-1
      telepathy-kde-common-internals            22.08.0-1            22.08.1-1
          telepathy-kde-contact-list            22.08.0-1            22.08.1-1
        telepathy-kde-contact-runner            22.08.0-1            22.08.1-1
       telepathy-kde-desktop-applets            22.08.0-1            22.08.1-1
  telepathy-kde-filetransfer-handler            22.08.0-1            22.08.1-1
    telepathy-kde-integration-module            22.08.0-1            22.08.1-1
             telepathy-kde-send-file            22.08.0-1            22.08.1-1
               telepathy-kde-text-ui            22.08.0-1            22.08.1-1
                            umbrello            22.08.0-1            22.08.1-1
                                vde2              2.3.3-1              2.3.3-2
                 vulkan-extra-layers          1.2.189.0-1          1.3.224.1-1
                  vulkan-extra-tools          1.2.189.0-1          1.3.224.1-1
                      vulkan-headers          1:1.3.221-1          1:1.3.227-1
                    vulkan-html-docs          1:1.3.221-1          1:1.3.227-1
                   vulkan-icd-loader            1.3.221-1            1.3.226-1
                        vulkan-tools            1.3.217-1            1.3.226-1
                             wolfssl              5.3.0-1              5.4.0-1
              xdg-desktop-portal-kde             5.25.4-1             5.25.5-1
                    xkeyboard-config               2.36-3  2.36+89+g382c5feb-1
                             yakuake            22.08.0-1            22.08.1-1
                             zanshin            22.08.0-1            22.08.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi22.08.0.r12812.g2914fca2b-122.08.0.r12815.g47b324a6b-1
                    akonadi-contacts22.08.0.r3238.g75a9892f-122.08.0.r3239.g85448842-1
               akonadi-import-wizard22.08.0.r1847.gddd3a51-122.08.0.r1848.g15dfec5-1
                       akonadi-notes22.08.0.r1087.g4870b81-122.08.0.r1088.ga124163-1
                      akonadi-search22.08.0.r1276.gdbf4b7e-122.08.0.r1277.gdd09f68-1
                      akonadiconsole22.08.0.r1616.gc2f0e46-122.08.0.r1620.gc595fed-1
                           akregator22.08.0.r6464.ge8ebb005-122.08.0.r6466.g9de19dc8-1
                           alligator 22.06.r44.g89817c2-1 22.06.r48.g9e992a6-1
                            amazfish  2.0.8.r5.gd083090-1 2.0.8.r10.g4a9d5a2-1
                           angelfish 22.06.r48.g7c7d922-1 22.06.r52.ge0e4dbe-1
                                 ark22.08.0.r4837.gcb74426e-122.08.0.r4841.ge6efb7d0-1
                          artikulate22.08.0.r1429.gf9d76b2-122.08.0.r1432.gc819306-1
                              attica5.97.0.r882.g3e75343-15.97.0.r884.ga909265-1
                         audiocd-kio22.08.0.r1107.g7911e32-122.08.0.r1108.gde52745-1
                           audiotube 22.06.r34.g76763b9-1 22.06.r35.gb6cd3c4-1
                        aura-browser        r61.337e1fb-1        r68.821531a-1
                               baloo5.97.0.r3064.ge1d30520-15.97.0.r3065.gdff7e8f4-1
                             blinken22.08.0.r683.g58ecf86-122.08.0.r684.g7ce780d-1
                           bluedevil1:5.25.4.r2434.g18f444a6-11:5.25.5.r2434.g18f444a6-1
                            bluez-qt5.97.0.r718.g2ad9f59-15.97.0.r719.g932455b-1
                              bomber22.08.0.r574.g65e9dbd-122.08.0.r575.g68168a2-1
                                bovo22.08.0.r784.gc111bc4-122.08.0.r786.gcd9e2ac-1
                              breeze5.25.4.r2444.g49390f6f-15.25.5.r2445.g022df2ba-1
                         breeze-grub5.25.4.r11.g63136a9-15.25.5.r11.g63136a9-1
                          breeze-gtk5.25.4.r487.g783eafd-15.25.5.r488.gcc0f107-1
                        breeze-icons5.97.0.r1916.g1efbc677-15.97.0.r1918.g0e430302-1
                     calendarsupport22.08.0.r727.gfb7421b-122.08.0.r728.g503675b-1
                            cervisia22.08.0.r1690.g3a429e2-122.08.0.r1699.ge2d0b64-1
                            discover5.25.4.r8820.g60f9e919-15.25.5.r8826.g593ce4ec-2
                              disman5.25.4.r1844.g9f33299-15.25.5.r1844.g9f33299-1
                             dolphin22.08.0.r7081.gaa7481583-122.08.0.r7084.gf49cba188-1
                     dolphin-plugins22.08.0.r676.gbb59561-122.08.0.r677.gc67bc7d-1
                              dragon22.08.0.r1061.ge401f05-122.08.0.r1062.g4f2df9d-1
                             drkonqi5.25.4.r820.g1fada030-15.25.5.r822.g68ef6f0d-1
                               elisa22.08.0.r3022.gf92232dd-122.08.0.r3025.g833791ad-1
                          elisa-qtmm22.08.0.r3022.gf92232dd-122.08.0.r3025.g833791ad-1
                 extra-cmake-modules5.97.0.r3515.g479fe1a4-15.97.0.r3517.g7bb60fd0-1
                        ffmpegthumbs22.08.0.r235.g81b2463-122.08.0.r236.g6efa4c1-1
                           filelight22.08.0.r1175.g2e060bb-122.08.0.r1176.gb4fc99b-1
                frameworkintegration5.97.0.r652.g03a2072-15.97.0.r653.g0bc14a7-1
                           granatier22.08.0.r988.g2c72822-122.08.0.r989.g0066152-1
                     grantlee-editor22.08.0.r837.g6fcc5bc-122.08.0.r838.g2a44f07-1
                            gwenview22.08.0.r6892.g94a08d2c-122.08.0.r6898.gaeb3f4fc-1
                           itinerary22.08.0.r1994.gcd83347-122.08.0.r2005.g554eefd-1
                                 juk22.08.0.r3180.g9583c576-122.08.0.r3181.ga16fd747-1
                                 k3b1:22.08.0.r6815.g52eb2b3e1-11:22.08.0.r6816.ga94f8d7ef-1
               kaccounts-integration22.08.0.r1273.g3763868-122.08.0.r1274.gb317f0f-1
                         kactivities5.97.0.r1408.g84944dfa-15.97.0.r1409.g3ba53fcd-1
                   kactivities-stats5.97.0.r416.gb6dde55-15.97.0.r417.gc9ad8e7-1
                   kactivitymanagerd5.25.4.r1421.g703ebd6-15.25.5.r1421.g703ebd6-1
                        kaddressbook22.08.0.r6237.g367eef6e-122.08.0.r6241.g90f770e9-1
                             kajongg22.08.0.r4349.g51f03457-122.08.0.r4350.g4110278b-1
                              kalarm22.08.0.r7998.g865d8401-122.08.0.r8001.g5573357b-1
                            kalgebra22.08.0.r2079.gf0b9169-122.08.0.r2080.g4b39929-1
                                kalk 22.06.r22.gfc531ca-1 22.06.r23.g5900cca-1
                             kalzium22.08.0.r4380.gc5adadec-122.08.0.r4381.g2ab2567f-1
                              kamera22.08.0.r733.geaffffa-122.08.0.r735.g3bff072-1
                              kamoso22.08.0.r1474.gb16b282-122.08.0.r1475.ge7516d9-1
                            kanagram22.08.0.r1325.g51c94dc-122.08.0.r1327.g09d3b7f-1
                              kapman22.08.0.r667.g61b78cf-122.08.0.r668.g9f495fa-1
                        kapptemplate22.08.0.r998.gba7fdc9-122.08.0.r999.g92b96bf-1
                            karchive5.97.0.r553.gea0136c-15.97.0.r554.g0a17848-1
                               kasts 22.06.r43.g46e7a71-1 22.06.r49.g3a6446d-1
                                kate22.08.0.r19467.g951663dcf-122.08.0.r19510.ga4ddde63f-1
                             katomic22.08.0.r974.g1d7f4b2-122.08.0.r975.gd2f9b5b-1
                               kauth5.97.0.r507.gdc84f0b-15.97.0.r508.g29871cb-1
                             kbackup22.08.0.r456.g7adb111-122.08.0.r458.g62b16d5-1
                           kblackbox22.08.0.r778.ga885c5f-122.08.0.r779.gd725db4-1
                             kblocks22.08.0.r753.g6bcb670-122.08.0.r755.gde3f9bd-1
                          kbookmarks5.97.0.r468.g24e6405-15.97.0.r469.g04303ac-1
                             kbounce22.08.0.r858.g885818f-122.08.0.r860.gab57d45-1
                           kbreakout22.08.0.r934.g37d59b6-122.08.0.r936.gb91a653-1
                              kbruch22.08.0.r876.gbd022d1-122.08.0.r877.g6fefc4a-1
                         kcachegrind22.08.0.r1193.gbfc3bfa-122.08.0.r1194.g95e6bf4-1
                  kcachegrind-common22.08.0.r1193.gbfc3bfa-122.08.0.r1194.g95e6bf4-1
                               kcalc22.08.0.r1630.g09d9224-122.08.0.r1631.gade2032-1
                       kcalendarcore5.97.0.r1341.g5a274162b-15.97.0.r1342.gd47f9dfb6-1
                         kcharselect22.08.0.r541.gb2b3294-122.08.0.r542.gef794bb-1
                            kcmutils5.97.0.r661.g1e29d46-15.97.0.r662.gd50d235-1
                             kcodecs5.97.0.r429.g321caa3-15.97.0.r430.g233229e-1
                       kcolorchooser22.08.0.r281.gcc3a46b-122.08.0.r282.g146cff8-1
                         kcompletion5.97.0.r510.gff0558b-15.97.0.r511.g4418032-1
                             kconfig5.96.0.r965.g491f5464-15.97.0.r974.gee7321d9-1
                      kconfigwidgets5.97.0.r770.g808115d-15.97.0.r774.g929969a-1
                           kcontacts1:5.97.0.r3345.g4a4269e0-11:5.97.0.r3346.g41ed7faf-1
                         kcoreaddons5.97.0.r1549.gd172653a-15.97.0.r1553.g9d3bd721-1
                              kcrash5.97.0.r454.g612d2cf-15.97.0.r455.g863ce2b-1
                                kdav1:5.97.0.r1353.gcdc0aa0-11:5.97.0.r1354.g738ee0e-1
                         kdbusaddons5.97.0.r425.g8b7f0c2-15.97.0.r426.g6863eb9-1
                       kde-cli-tools5.25.4.r1954.gee512e1-15.25.5.r1954.gee512e1-1
                       kde-dev-utils22.08.0.r596.g4a84ce3-122.08.0.r597.gc99a709-1
                      kde-gtk-config5.25.4.r944.g9dd7296-15.25.5.r944.g9dd7296-1
                      kdebugsettings22.08.0.r965.g302b9fe-122.08.0.r966.g261bb78-1
                        kdeclarative5.97.0.r1031.g2324be6-15.97.0.r1032.g728e928-1
                          kdeconnect22.08.0.r3528.g5639905b-122.08.0.r3533.gf53dadaf-1
                         kdecoration5.25.4.r297.g8e8c753-15.25.5.r297.g8e8c753-1
                                kded5.97.0.r473.g3fc0cb5-15.97.0.r474.gd7afee7-1
                     kdelibs4support5.97.0.r1107.gf710ee39-15.97.0.r1108.g848ff7a6-1
              kdenetwork-filesharing22.08.0.r983.g701600b-122.08.0.r984.g4b523fb-1
                            kdenlive22.08.0.r16625.g3239b0bfc-122.08.0.r16630.ga6cf70275-1
                       kdepim-addons22.08.0.r4792.g8711ba0cf-122.08.0.r4814.g6fc9b0bae-1
                      kdepim-runtime22.08.0.r15580.g9cc715771-122.08.0.r15581.g9c1f024fd-1
                    kdeplasma-addons5.25.4.r9018.g165c320e3-15.25.5.r9024.gd43dbeda5-1
                     kdesignerplugin5.97.0.r360.g4e339e1-15.97.0.r361.g87a3cdd-1
                               kdesu5.97.0.r516.g7188b15-15.97.0.r517.g6c84dc0-1
                           kdewebkit5.97.0.r307.g6910e1c-15.97.0.r308.gd200b32-1
                                 kdf22.08.0.r872.g5aa27fa-122.08.0.r874.gaaf2494-1
                             kdialog22.08.0.r1238.g001e3f53a-122.08.0.r1239.ge1e295bba-1
                            kdiamond22.08.0.r735.gaadedc8-122.08.0.r737.g34a28f2-1
                            kdisplay5.25.4.r1516.g4617e62-15.25.5.r1516.g4617e62-1
                              kdnssd5.97.0.r358.gf470de8-15.97.0.r359.gd95a3bc-1
                           kdoctools5.97.0.r676.g724b8b1-15.97.0.r677.g0cf8914-1
                      keditbookmarks22.08.0.r2771.gba417d5a9-122.08.0.r2772.g06b8c499f-1
                          kemoticons5.97.0.r424.g634c7fc-15.97.0.r425.g460be3d-1
                       kfilemetadata5.97.0.r873.g36abc6b-15.97.0.r874.g44ad4ae-1
                               kfind22.08.0.r2725.g2b32d3377-122.08.0.r2727.g028a3296a-1
                             kfloppy22.08.0.r803.g5852314-122.08.0.r804.g7094a06-1
                         kfourinline22.08.0.r1033.gaa4650f-122.08.0.r1035.gf6fbb1b-1
                             kgamma55.25.4.r483.g7f02758-15.25.5.r483.g7f02758-1
                          kgeography22.08.0.r1166.g5fb452a-122.08.0.r1167.g1068881-1
                                kget22.08.0.r3222.g314137d7-122.08.0.r3223.ge0e262f4-1
                        kglobalaccel5.97.0.r572.g4440581-15.97.0.r573.g5b5714d-1
                         kgoldrunner22.08.0.r1296.g18d0a86-122.08.0.r1298.g8011965-1
                                kgpg22.08.0.r3204.gd4ee0694-122.08.0.r3205.g43647cce-1
                          kguiaddons5.97.0.r488.g1f15bbe-15.97.0.r489.gb044646-1
                            khangman22.08.0.r1627.gfbc6002-122.08.0.r1628.g3983a91-1
                         khelpcenter22.08.0.r2775.g4ce7a63d-122.08.0.r2776.gca7b392a-1
                           kholidays1:5.97.0.r1055.g6ef2166-11:5.97.0.r1056.ge295e2e-1
                            khotkeys5.25.4.r2157.ga5fb7bb-15.25.5.r2157.ga5fb7bb-1
                               khtml5.97.0.r596.gdd31205-15.97.0.r597.g738a2f5-1
                               ki18n5.97.0.r568.g08b148f-15.97.0.r571.g241e0cf-1
                         kiconthemes5.97.0.r629.g2776c53-15.97.0.r631.gec3faeb-1
                           kidletime5.97.0.r366.gcce9af4-15.97.0.r367.g2186217-1
                                 kig22.08.0.r3230.g5cb99d5a-122.08.0.r3231.gd903d20d-1
                                kigo22.08.0.r587.g9834b4b-122.08.0.r589.g1a9aafc-1
                            killbots22.08.0.r805.gbc28d3f-122.08.0.r806.g03e1708-1
                       kimageformats5.97.0.r424.g43543f9-15.97.0.r426.gfeb6d9b-1
                     kimagemapeditor22.08.0.r503.gd60bf67-122.08.0.r504.g7b5955a-1
                         kinfocenter5.25.4.r2139.gaf64a096-15.25.5.r2143.ga2d44215-1
                               kinit5.97.0.r446.gff55ecc-15.97.0.r447.gabd053b-1
                                 kio5.97.0.r5684.g42b92c40b-15.97.0.r5689.gfd71bbe22-1
                          kio-extras22.08.0.r7336.gc773f481-122.08.0.r7337.geea1ecae-1
                          kio-gdrive22.08.0.r629.gfb7c7e9-122.08.0.r630.gc0a0861-1
                    kirigami-gallery22.08.0.r264.gcb4ae79-122.08.0.r267.gd97fd10-1
                           kirigami25.97.0.r3308.g5c6a91b0-15.97.0.r3311.g787efe84-1
                              kiriki22.08.0.r462.g15b63db-122.08.0.r463.gfc8b595-1
                         kitemmodels5.97.0.r617.gadb9fe0-15.97.0.r618.gdc308cd-1
                          kitemviews5.97.0.r382.g0fee09c-15.97.0.r383.gf9ff0f1-1
                               kiten22.08.0.r1211.ge810f07-122.08.0.r1212.gf92c420-1
                          kitinerary22.08.0.r2373.gafa0176-122.08.0.r2378.g8aab5bc-1
                         kjobwidgets5.97.0.r427.g41aa14f-15.97.0.r428.g1de71b2-1
                                 kjs5.97.0.r369.gf9d42de-15.97.0.r370.gd8755f9-1
                            kjsembed5.97.0.r334.g7b2368e-15.97.0.r335.g92e03cc-1
                        kjumpingcube22.08.0.r833.ga00c16a-122.08.0.r835.gadc4c50-1
                           kleopatra22.08.0.r6815.g43f95b16-122.08.0.r6820.g7c2e3741-1
                            klettres22.08.0.r977.g9965d4c-122.08.0.r979.g967fb2d-1
                            klickety22.08.0.r707.g9c57ed8-122.08.0.r708.gdb9481b-1
                              klines22.08.0.r832.gbda1644-122.08.0.r835.g1cf8674-1
                                kmag22.08.0.r746.gafa5b8d-122.08.0.r747.g749515f-1
                           kmahjongg22.08.0.r1571.g02417cf-122.08.0.r1572.g923c705-1
                               kmail22.08.0.r26512.ge40410dee-122.08.0.r26532.gdce18d54f-1
                      kmailtransport22.08.0.r1758.g15ae764-122.08.0.r1759.gee11252-1
                        kmediaplayer5.97.0.r323.g7fb8753-15.97.0.r324.g77060a5-1
                           kmenuedit5.25.4.r1064.geec37fb-15.25.5.r1066.g002751a-1
                              kmines22.08.0.r1775.g087951a-122.08.0.r1777.gf346b6d-1
                                kmix22.08.0.r2461.gee82e9ee-122.08.0.r2462.g7f39c685-1
                          kmousetool22.08.0.r456.gd4387f8-122.08.0.r458.g7c339f7-1
                              kmouth22.08.0.r742.g205c4c0-122.08.0.r744.gf469bfd-1
                              kmplot22.08.0.r1506.gefced9f-122.08.0.r1507.gbf031fa-1
                        knavalbattle22.08.0.r1444.g0750f0f-122.08.0.r1446.g8c77ca2-1
                            knetwalk22.08.0.r712.g3e3cc02-122.08.0.r714.gc3077a0-1
                           knewstuff5.97.0.r1376.gc81158ab-15.97.0.r1380.g9a2f2e9a-1
                             knights22.08.0.r1154.ga283020-122.08.0.r1155.g5d8fcd1-1
                              knotes22.08.0.r3694.g165627b5-122.08.0.r3695.g03d70da2-1
                      knotifications5.97.0.r756.g443153b-15.97.0.r757.g190c316-1
                       knotifyconfig5.97.0.r392.g8adea7a-15.97.0.r393.g71dd801-1
                                kolf22.08.0.r1519.gaf9eb01-122.08.0.r1520.g6e60a80-1
                           kollision22.08.0.r545.ga7fea4b-122.08.0.r546.g966b81b-1
                         kolourpaint22.08.0.r2435.g2273ee76-122.08.0.r2436.ga0ba712c-1
                             kompare22.08.0.r1153.gab4a440-122.08.0.r1154.gb510628-1
                           konqueror22.08.0.r15168.ga8c8fd72f-122.08.0.r15169.g3bd23d983-1
                            konquest22.08.0.r948.gdc6d45e-122.08.0.r950.g43ef992-1
                             konsole22.08.0.r8597.g03d89137-122.08.0.r8606.g6adbc553-1
                             kontact22.08.0.r5567.gc9bd926e-122.08.0.r5569.ga2c4bc05-1
                            kontrast22.08.0.r213.g8111ef1-122.08.0.r214.g8f23b21-1
                        konversation22.08.0.r9159.ge3e683c6-122.08.0.r9160.g265bb5be-1
                       kopeninghours22.08.0.r335.gb198c63-122.08.0.r336.g6dd734d-1
                          korganizer22.08.0.r11794.ga3de772c9-122.08.0.r11795.g3a25863b3-1
                       kosmindoormap22.08.0.r753.g272d45c-122.08.0.r754.g8e12202-1
                            kpackage5.97.0.r764.g03ba625-15.97.0.r765.gf0bd447-1
                              kparts5.97.0.r598.g6514243-15.97.0.r599.g5ea9476-1
                                kpat22.08.0.r2629.g468e80d3-122.08.0.r2631.ge867674a-1
                             kpeople5.97.0.r1384.g629279d-15.97.0.r1385.g7ef76d6-1
                           kpipewire5.25.4.r137.g217f015-15.25.5.r138.gcef4bfc-1
                           kplotting5.97.0.r331.gbd63ff8-15.97.0.r332.g6becc5c-1
                                kpty5.97.0.r384.gd346d5c-15.97.0.r385.g6d29a4f-1
                    kpublictransport22.08.0.r2042.gf4849d63-122.08.0.r2044.g80e0e620-1
                        kquickcharts5.97.0.r529.g3837586-15.97.0.r531.ge9ad31e-1
                                krdc22.08.0.r1621.gd3e2bbf-122.08.0.r1624.g0760c95-1
                            kreversi22.08.0.r1281.gc7dec7a-122.08.0.r1282.ge56b129-1
                                krfb22.08.0.r1515.g4606fca-122.08.0.r1516.gc59abf0-1
                               kross5.97.0.r365.g58a8fcb-15.97.0.r366.g0e1db3e-1
                  kross-interpreters22.08.0.r724.g2a6213a-122.08.0.r725.gdef2cfe-1
                              kruler22.08.0.r749.g7d02cfb-122.08.0.r750.g927e58c-1
                             krunner5.97.0.r782.g43a8518-15.97.0.r783.ga4f1df1-1
                           ksanecore      r623.g0c094db-1      r624.gc8717a5-1
                             kscreen5.25.4.r1529.g2c6ef85-15.25.5.r1529.g2c6ef85-1
                       kscreenlocker5.25.4.r979.ga973ebc-15.25.5.r981.gc5d4169-1
                            kservice5.97.0.r1030.g7aaa422-15.97.0.r1031.gcca46c7-1
                             kshisen22.08.0.r1253.g7649fdd-122.08.0.r1254.g6889e36-1
                               ksirk22.08.0.r1046.g8119616-122.08.0.r1048.gd16cf92-1
                          ksnakeduel22.08.0.r863.g5193af2-122.08.0.r865.g4b67e36-1
                          kspaceduel22.08.0.r683.g623323c-122.08.0.r684.gf712f53-1
                            ksquares22.08.0.r569.gfbc2399-122.08.0.r570.g7bce2d7-1
                         ksshaskpass5.25.4.r214.gf64c107-15.25.5.r214.gf64c107-1
                             ksudoku22.08.0.r1134.g59cf95a-122.08.0.r1135.gcbc8725-1
                           ksysguard5.25.4.r3544.ga33b3673-15.25.5.r3544.ga33b3673-1
                          ksystemlog22.08.0.r750.gbd082be-122.08.0.r752.g521756f-1
                        ksystemstats5.25.4.r233.gc7f3377-15.25.5.r234.g8175033-1
                            kteatime22.08.0.r767.gf414707-122.08.0.r768.g4b94625-1
                         ktexteditor5.97.0.r3521.g417a4243-15.97.0.r3528.gab304129-1
                        ktextwidgets5.97.0.r457.gbde86b3-15.97.0.r458.gb929a68-1
                              ktimer22.08.0.r535.g075e247-122.08.0.r536.gc59aeb9-1
                               ktnef22.08.0.r729.g65c3625-122.08.0.r730.gcded6ea-1
                            ktorrent22.08.0.r2881.gdf49a0fa-122.08.0.r2882.gb58972a1-1
                              ktouch22.08.0.r2199.g343d452-122.08.0.r2200.ga56eaaf-1
                               ktrip 22.06.r13.gde581c1-1 22.06.r14.g3130146-1
                          ktuberling22.08.0.r1074.g0ab170d-122.08.0.r1075.ge0ebc3a-1
                             kturtle22.08.0.r1185.g9069431-122.08.0.r1186.gca7d0ef-1
                             kubrick22.08.0.r417.g3eae0c0-122.08.0.r418.g2003b83-1
                     kunitconversion5.97.0.r427.g040e530-15.97.0.r428.g598f3a2-1
                             kwallet5.97.0.r1174.gdb1d2ec-15.97.0.r1177.g6522935-1
                         kwallet-pam5.25.4.r274.ga7b1f15-15.25.5.r274.ga7b1f15-1
                      kwalletmanager22.08.0.r1288.gea0b220-122.08.0.r1296.geb0ffa8-1
                               kwave22.08.0.r3805.g2fa1edb5-122.08.0.r3806.gec348d90-1
                            kwayland5.97.0.r1177.g6c88c7d-15.97.0.r1179.gcb13afd-1
                kwayland-integration5.25.4.r214.gbc75096-15.25.5.r214.gbc75096-1
                     kwayland-server5.25.4.r1481.gdec04c4-1                    -
                            kweather 22.06.r60.gc394400-1 22.06.r63.g898ec43-1
                        kweathercore   0.6.r21.gc0ec5c1-1   0.6.r22.ge27d7c8-1
                      kwidgetsaddons5.97.0.r980.gf3947ecf-15.97.0.r981.gce728c52-1
                                kwin5.25.4.r23082.g3cf773704-15.25.5.r23114.g1598cecc8-1
                       kwindowsystem5.97.0.r692.g8f3de55-15.97.0.r694.gb61821e-1
                              kwinft5.25.4.r21056.g483de1b14-15.25.5.r21388.g4b98d3887-1
                           kwordquiz22.08.0.r1202.g48cd051-122.08.0.r1203.g69bf4ad-1
                              kwrite22.08.0.r19467.g951663dcf-122.08.0.r19510.ga4ddde63f-1
                             kwrited5.25.4.r516.g4fb19a5-15.25.5.r516.g4fb19a5-1
                             kxmlgui5.97.0.r903.g014733d9-15.97.0.r904.gb3740169-1
                       kxmlrpcclient5.97.0.r487.g0a2e87399-15.97.0.r488.ga317aa5fc-1
                      layer-shell-qt5.25.4.r64.g5af50ac-15.25.5.r64.g5af50ac-1
                          libakonadi22.08.0.r12812.g2914fca2b-122.08.0.r12815.g47b324a6b-1
                           libkexiv222.08.0.r831.g9e1bfc0-122.08.0.r832.ga131658-1
                          libkscreen5.25.4.r1636.g0f6bed2-15.25.5.r1636.g0f6bed2-1
                        libksysguard5.25.4.r2429.g052249c-15.25.5.r2430.g8e1f0fc-1
                         libktorrent22.08.0.r563.g85add79-122.08.0.r564.gc5f7928-1
                            lokalize22.08.0.r1847.ga03f7375-122.08.0.r1848.ga01091f4-1
                               lskat22.08.0.r865.g103d3ea-122.08.0.r866.g3211e3f-1
                        mailimporter22.08.0.r533.ge9a31d2-122.08.0.r534.g6f82744-1
                              marble22.08.0.r13468.gaaf624f17-122.08.0.r13469.g78d4ab70f-1
                       marble-common22.08.0.r13468.gaaf624f17-122.08.0.r13469.g78d4ab70f-1
                           marble-qt22.08.0.r13468.gaaf624f17-122.08.0.r13469.g78d4ab70f-1
                        markdownpart22.08.0.r133.g43d8d6b-122.08.0.r134.g1fcb493-1
                           maui-nota  2.2.0.r1.gcdf606a-1  2.2.0.r2.g1719b5d-1
                            maui-pix  2.2.0.r2.g6781170-1  2.2.0.r4.g7a80376-1
                          maui-shell  0.5.5.r6.g6a67519-1 0.5.5.r12.g70f78d4-1
                             mauikit 2.2.0.r3.gb81ef3cb-1 2.2.0.r8.gc9a3d2a8-1
                  mauikit-texteditor  2.2.0.r0.g60b5ab0-1  2.2.0.r1.g3dad8cc-1
                       mbox-importer22.08.0.r578.g1ee8719-122.08.0.r579.g3b76015-1
                               milou5.25.4.r783.g951b63d-15.25.5.r783.g951b63d-1
                              minuet22.08.0.r624.gc646cdc-122.08.0.r625.gf969168-1
                     modemmanager-qt5.97.0.r560.g6852adb-15.97.0.r561.g07130ae-1
             mycroft-skill-installer        r97.0d50d79-1        r98.fc1ada8-1
                             neochat22.06.r95.gefd3f2e8-122.06.r108.g5d4efad2-1
                   networkmanager-qt5.97.0.r1160.g6faa206-15.97.0.r1161.g51d2bb1-1
                              okular22.08.0.r9822.gb2c56a0a7-122.08.0.r9827.gd0359e634-1
                              oxygen5.25.4.r4504.g190c81d3-15.25.5.r4505.gc39dab71-1
                            palapeli22.08.0.r1309.g1c4d3ad-122.08.0.r1310.g755e23d-1
                              parley22.08.0.r4543.g54c4fdfa-122.08.0.r4544.gcfb8d323-1
                    partitionmanager22.08.0.r1642.gb47f7b1-122.08.0.r1643.g4f8c6b6-1
                   pim-data-exporter22.08.0.r2784.gcca582f8-122.08.0.r2785.ga6bd2c8c-1
                    pim-sieve-editor22.08.0.r1651.ga214dbc-122.08.0.r1652.g58efae1-1
                           pimcommon22.08.0.r1335.g6069b7c-122.08.0.r1353.gd42b95d-1
                        plank-player        r32.025b29b-1        r33.192d96d-1
                    plasma-bigscreen      r502.g61a99f7-1      r503.g2dfeb0e-1
          plasma-browser-integration5.25.4.r1351.ga585099a-15.25.5.r1352.g43589ce7-1
                      plasma-desktop5.25.4.r9577.g05c315406-15.25.5.r9593.g7f1c5184d-1
                       plasma-dialer 22.06.r71.g6ffc2ee-1 22.06.r73.g5e5cc81-1
                        plasma-disks5.25.4.r290.g5f16c9c-15.25.5.r291.g97e0a00-1
                     plasma-firewall5.25.4.r647.g73a5e1f-15.25.5.r648.g914424c-1
                    plasma-framework5.97.0.r16404.g9cc3f9ee5-15.97.0.r16408.g025cdf39e-1
                  plasma-integration5.25.4.r575.g7b1ece8-15.25.5.r575.g7b1ece8-1
                       plasma-mobile5.25.4.r1945.g048acddf1-15.25.5.r1953.gcbd1acc11-1
                    plasma-mobile-nm5.25.4.r3326.g96fd39ad-15.25.5.r3327.g5b6a91bb-1
                         plasma-nano5.25.4.r194.gf48262e-15.25.5.r195.g66fe6fd-1
                           plasma-nm5.25.4.r3326.g96fd39ad-15.25.5.r3327.g5b6a91bb-1
                           plasma-pa5.25.4.r1081.ge06ad53-15.25.5.r1084.g8810ebe-1
            plasma-remotecontrollers      r126.g3842595-1      r129.g1df612a-1
                          plasma-sdk5.25.4.r2389.g5f5316aa-15.25.5.r2391.g5cf7d599-1
                     plasma-settings 22.06.r84.g79664fd-1 22.06.r86.g152d96d-1
                plasma-systemmonitor5.25.4.r613.g577842a-15.25.5.r616.g8b36bdd-1
                  plasma-thunderbolt5.25.4.r197.gd5272df-15.25.5.r197.gd5272df-1
                        plasma-vault5.25.4.r390.gacc70f5-15.25.5.r390.gacc70f5-1
            plasma-wayland-protocols1.4.0.r1057.gee026f0-11.4.0.r1060.gc958440-1
              plasma-wayland-session5.25.4.r12268.g9938babf6-15.25.5.r12291.g6ce2204b7-1
                    plasma-workspace5.25.4.r12268.g9938babf6-15.25.5.r12291.g6ce2204b7-1
         plasma-workspace-wallpapers5.25.4.r376.g3e0ccff-15.25.5.r376.g3e0ccff-1
                          plasmatube 22.06.r22.gaa0107c-1 22.06.r27.g0d897c1-1
                    polkit-kde-agent5.25.4.r532.ga21bd57-15.25.5.r532.ga21bd57-1
                          powerdevil5.25.4.r2590.g6220db1b-15.25.5.r2592.gf1bd0749-1
                               poxml22.08.0.r282.g2615361-122.08.0.r283.g1b8e394-1
                       print-manager22.08.0.r1156.g9582e7a-122.08.0.r1162.gfcd9cd1-1
                              prison5.97.0.r399.g3ce44be-15.97.0.r400.g83f1b09-1
                             purpose5.97.0.r993.g8a7157b-15.97.0.r994.g2cc7697-1
                         qcachegrind22.08.0.r1193.gbfc3bfa-122.08.0.r1194.g95e6bf4-1
                          qmlkonsole 22.06.r38.g5c0145b-1 22.06.r39.g4ceaf7b-1
                   qqc2-breeze-style5.25.4.r252.g717d6cb-15.25.5.r252.g717d6cb-1
                  qqc2-desktop-style5.97.0.r656.g4645d80-15.97.0.r657.g4623715-1
                                rocs22.08.0.r3115.gf222c927-122.08.0.r3116.gb8a43350-1
                            sddm-kcm5.25.4.r684.gef78919-15.25.5.r688.ga2f59af-1
                               solid5.97.0.r790.g6549bda-15.97.0.r792.gd36bec2-1
                              sonnet5.97.0.r710.g17b99c8-15.97.0.r711.ge10fd9b-1
                            spacebar 22.06.r60.g270ee9e-1 22.06.r66.g647f068-1
                           spectacle22.08.0.r1386.gb9ae842-122.08.0.r1387.g90a36db-1
                                step22.08.0.r1211.g17e70bd-122.08.0.r1212.g6bf7e59-1
                             svgpart22.08.0.r236.g173ad86-122.08.0.r237.ge782b84-1
                             sweeper22.08.0.r586.gfd050d1-122.08.0.r587.geb9487e-1
                         syndication5.97.0.r882.g89f1c36-15.97.0.r883.g427c476-1
                 syntax-highlighting5.97.0.r1915.g5f8019b5-15.97.0.r1920.g0dd050e7-1
                      systemsettings5.25.4.r2709.g1d271095-15.25.5.r2711.gb842bcad-1
          telepathy-kde-auth-handler22.08.0.r284.gc59f7d0-122.08.0.r285.gcb15eb7-1
      telepathy-kde-common-internals22.08.0.r2023.gb2e9fec-122.08.0.r2024.g02d14eb-1
          telepathy-kde-contact-list22.08.0.r1093.g9c27117-122.08.0.r1094.g3721af4-1
       telepathy-kde-desktop-applets22.08.0.r1007.g06cd5ac-122.08.0.r1008.gaa3cc9d-1
  telepathy-kde-filetransfer-handler22.08.0.r227.ga6083c9-122.08.0.r228.g9e012f5-1
    telepathy-kde-integration-module22.08.0.r402.ga5572ce-122.08.0.r403.ga4e79eb-1
             telepathy-kde-send-file22.08.0.r236.gcac0c0c-122.08.0.r237.g7c8384d-1
               telepathy-kde-text-ui22.08.0.r2048.g596eeaf-122.08.0.r2049.ge638741-1
                        threadweaver5.97.0.r550.g05004a0-15.97.0.r551.ga95dbf6-1
                         vakzination 22.06.r44.g5e2f858-1 22.06.r46.g2f1320d-1
                               vvave  2.2.0.r1.g4980751-1  2.2.0.r2.ga07311d-1
                            wrapland5.25.4.r1761.gc522abc3-15.25.5.r1784.g34e4fa71-1
              xdg-desktop-portal-kde5.25.4.r519.g6976bbc-15.25.5.r519.g6976bbc-1
                             yakuake22.08.0.r825.gbb3bb90-122.08.0.r826.g50a8719-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Before 2022-08-23
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Before 2022-07-22
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Old Issues
Plasma Dialer cannot answer calls
Sadly Plasma Dialer 22.02 has a serious regression with no known workaround. It’s not possible to accept incoming calls. Very sorry about this. Follow the upstream bug report. We will patch the package as soon as a solution is found.
Plasma Mobile - Black screen after update
We are seeing some reports about Plasma Mobile on the PinePhone only showing a black screen after entering the PIN after this update.
Workaround: Downgrade qt5-es2-wayland to 5.15.2+kde+r41 which is now back in Stable and Testing branch repositories.
New Breath theme not applying correctly
With the update to the new Breath theme, a migration package tries to apply the new theme correctly.
However this is not getting done for Plasma’s Lockscreen and the SDDM theme.
So please go through your settings after updating to make sure the themes are correctly applied.
Fix: manjaro-system should take care of this for you.
Plasma Mobile switch to ModemManager
With the PlaMo Gear 21.12 release, Plasma Mobile is now using ModemManager as the telephony stack. So in order to use SIM capabilities, you need to switch from using oFono to ModemManager.
Fix: Run sudo systemctl disable --now ofono ofonoctl && sudo systemctl enable --now ModemManager. You might have to reboot your phone for Plasma Mobile to pick up this change.
Plasma Mobile has does not launch after update
This was caused by an error in kwin 5.23.2 which only affects installs based on openGLES (qt5-es2).
Fix: Update to kwin 5.23.2-1.2 or above.
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
