Hello ARM community.
Some cleanups and updates.
Some highlights:
- Most of our kernels got updated
- Firefox updated to 104.0
- Libva updated to 2.15.0
- Calamares updated to 3.2.61 with a new look
- Removed some old Electron packages no longer required
- Removed Bitwarden as it has not been building for
aarch64for a while. We recommended switching to the flatpak or appimage. - Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Mon Aug 29 00:03:36 CEST 2022)
- arm-testing community aarch64: 278 new and 262 removed package(s)
- arm-testing core aarch64: 21 new and 21 removed package(s)
- arm-testing extra aarch64: 193 new and 195 removed package(s)
- arm-testing kde-unstable aarch64: 369 new and 369 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-08-23 2022-08-29
bitwarden 1.28.3-1 -
electron 20.0.2-1 20.1.0-2
electron11 11.5.0-1 -
electron12 12.2.3-1 -
electron13 13.6.9-1 -
electron14 14.2.9-1 -
electron15 15.5.7-1 -
electron16 16.2.8-1 -
electron17 17.4.11-1 17.4.11-2
electron18 18.3.8-1 18.3.8-2
electron19 19.0.12-1 19.0.14-2
libglibutil 1.0.66-1 1.0.67-1
libva-utils 2.11.1-0.1 -
phoc 0.21.0+10+g7454ac0-1 0.21.0+12+g30d289d-1
phosh0.20.0+22+g1c471472-10.20.0+24+gab581c04-1
ventoy 1.0.79-2 1.0.79-3
vvmplayer 1.4-1 1.5-1
:: Different sync package(s) in repository community aarch64
aliyun-cli 3.0.124-1 3.0.125-1
ansible 6.2.0-1 6.3.0-1
ansible-lint 6.5.0-2 6.5.1-1
aspell-da 4.0-1 4.1-1
autopep8 1:1.6.0-2 1:1.7.0-1
awxkit 21.4.0-1 21.5.0-1
blueman 2.3.1-1 2.3.2-1
bolt 0.9.2-1 0.9.3-1
borgmatic 1.6.2-1 1.7.1-1
busted 2.0.0-11 2.1.1-2
cacti 1.2.21-1 1.2.22-1
cargo-pgx 0.4.3-1 0.4.5-1
chezmoi 2.20.0-1 2.21.0-1
clash 1.11.4-1 1.11.8-1
cockpit 274.1-1 275-1
cockpit-machines 272-1 273-1
cockpit-packagekit 274.1-1 275-1
cockpit-pcp 274.1-1 275-1
cockpit-podman 51.1-1 52-1
cockpit-storaged 274.1-1 275-1
copr-cli 1.101-2 1.103-1
cosign 1.10.1-1 1.10.1-2
crun 1.5-1 1.5-2
dagger 0.2.30-1 0.2.31-1
dante 1.4.3-2 1.4.3-3
dark-reader 4.9.56-1 4.9.57-1
dart 2.17.6-1 2.17.7-1
diffoscope 220-1 221-1
difftastic 0.32.0-1 0.33.0-1
dns-lexicon 3.11.3-2 3.11.4-1
docker-compose 2.10.0-1 2.10.2-1
docker-scan 0.17.0-2 0.19.0-1
dust 0.8.1-1 0.8.2-1
fetchmail 6.4.32-1 6.4.33-1
firefox-dark-reader 4.9.56-1 4.9.57-1
flatbuffers 2.0.6-2 2.0.7-1
fq 0.0.8-1 0.0.9-1
fst 0.120.0-1 0.122.0-1
gamescope 3.11.40-1 3.11.43-1
ganv 1.8.0-1 1.8.2-1
github-cli 2.14.4-1 2.14.7-1
glewlwyd 2.7.2-1 2.7.3-1
go-ethereum 1.10.22-1 1.10.23-1
gost 2.11.2-2 2.11.3-1
gpxsee 10.7-1 11.3-1
haxe 4.2.3-3 4.2.5-1
helm 3.9.3-2 3.9.4-1
home-assistant 1:2022.8.6-1 1:2022.8.7-1
iaito 5.7.0-1 5.7.0-2
ibus-libpinyin 1.12.1-2 1.13.0-1
ibus-table-chinese 1.8.4-1 1.8.5-1
iftop 1.0pre4-4 1.0pre4-5
influx-cli 2.3.0-1 2.4.0-1
influxdb 2.2.0-1 2.4.0-1
intel-oneapi-common 2022.1.0-2 2022.1.0-3
intel-oneapi-compiler-dpcpp-cpp-runtime 2022.1.0-1 2022.1.0-6
intel-oneapi-compiler-shared-runtime 2022.1.0-2 2022.1.0-6
intel-oneapi-openmp 2022.1.0-3 2022.1.0-7
intel-oneapi-tbb 2021.6.0-2 2021.6.0-4
ioping 1.2-1 1.3-1
jacktrip 1.6.2-1 1.6.3-1
jenkins 2.364-1 2.365-1
jmol 14.32.67-1 14.32.73-1
jrnl 3.0-1 3.1-1
jsmol 14.32.67-1 14.32.73-1
jupyter-nbclient 0.6.6-1 0.6.7-1
jupyter-widgetsnbextension 1:3.6.1-1 1:4.0.2-1
jupyterlab 3.4.4-1 3.4.5-1
jupyterlab-widgets 1.1.1-1 3.0.2-1
kanshi 1.2.0-4 1.3.0-1
kid3 3.9.1-2 3.9.2-1
kid3-common 3.9.1-2 3.9.2-1
kid3-qt 3.9.1-2 3.9.2-1
kube-apiserver 1.24.3-2 1.24.4-1
kube-controller-manager 1.24.3-2 1.24.4-1
kube-proxy 1.24.3-2 1.24.4-1
kube-scheduler 1.24.3-2 1.24.4-1
kubeadm 1.24.3-2 1.24.4-1
kubectl 1.24.3-2 1.24.4-1
kubelet 1.24.3-2 1.24.4-1
kubernetes-control-plane-common 1.24.3-2 1.24.4-1
libcss 0.9.1-4 0.9.1-6
libsemigroups 2.2.0-1 2.2.1-1
libspeechd 0.11.1-3 0.11.2-1
lollypop 1.4.35-1 1.4.35-2
lshw B.02.19.2-4 B.02.19.2-5
lua-busted 2.0.0-11 2.1.1-2
lua-luarepl 0.9-7 0.10-1
lua-luassert 1.8.0-7 1.9.0-1
lua-say 1.3-7 1.4.0-2
lua51-busted 2.0.0-11 2.1.1-2
lua51-luarepl 0.9-7 0.10-1
lua51-luassert 1.8.0-7 1.9.0-1
lua51-say 1.3-7 1.4.0-2
lua52-busted 2.0.0-11 2.1.1-2
lua52-luarepl 0.9-7 0.10-1
lua52-luassert 1.8.0-7 1.9.0-1
lua52-say 1.3-7 1.4.0-2
lua53-busted 2.0.0-11 2.1.1-2
lua53-luarepl 0.9-7 0.10-1
lua53-luassert 1.8.0-7 1.9.0-1
lua53-say 1.3-7 1.4.0-2
luacheck 0.26.1-1 1.0.0-1
lutris 0.5.10.1-2 0.5.11-1
marked 4.0.5-1 4.0.7-1
mellite 3.13.2-1 3.13.3-1
minio 2022.07.17-1 2022.08.25-1
minio-client 2022.07.15-1 2022.08.23-1
mongo-c-driver 1.22.0-1 1.22.1-1
mosquitto 2.0.14-3 2.0.15-1
neatvnc 0.5.1-1 0.5.3-1
netsurf 3.10-2 3.10-5
nextcloud-app-calendar 1:3.4.2-1 1:3.4.3-1
nginx-mod-njs 0.7.6-1 0.7.6-2
nicotine+ 3.2.3-1 3.2.4-1
nodejs 18.7.0-1 18.8.0-1
nomad 1.3.3-1 1.3.4-1
normaliz 3.9.3-2 3.9.4-1
notmuch 0.36-1 0.37-1
notmuch-mutt 0.36-1 0.37-1
notmuch-runtime 0.36-1 0.37-1
notmuch-vim 0.36-1 0.37-1
npm-check-updates 15.0.5-1 15.2.3-1
nuitka 0.8.4-1 1.0.5-2
nvme-cli 2.0-3 2.1.2-1
octave 7.2.0-1 7.2.0-2
openrct2 0.4.1-3 0.4.1-4
openui5 1.89.1-1 1.96.11-1
operator-sdk 1.21.0-1 1.23.0-1
osbuild 63-2 64-1
owncloud-client 2.10.1.7389-1 2.11.0.8354-1
pan 0.150-1 0.151-1
patatt 0.5.0-1 0.6.2-1
patchage 1.0.6-2 1.0.8-1
php-snuffleupagus 0.8.2-1 0.8.3-1
picard 2.8.2-1 2.8.3-1
plantri 5.3-1 5.3-2
plantuml-server 1.2022.6-3 1.2022.7-1
plfit 0.9.3-1 0.9.4-1
pop-gtk-theme 5.4.5-3 5.5.1-1
pop-icon-theme2.1.0.r2490.c64e51453d-1 3.3.0-1
powerdns-recursor 4.7.1-2 4.7.2-1
pulumi 3.37.2-1 3.38.0-1
py3status 3.45-1 3.46-1
pyright 1.1.267-1 1.1.268-1
python-aiobotocore 2.3.4-1 2.4.0-1
python-aioconsole 0.4.0-1 0.5.0-1
python-astroid 2.12.2-1 2.12.4-1
python-awesomeversion 22.6.0-1 22.8.0-1
python-blinker 1.4-11 1.5-1
python-cfn-lint 0.62.0-1 0.63.0-1
python-copr 1.120-1 1.122-1
python-debugpy 1.6.2-2 1.6.3-1
python-deepdiff 5.8.0-1 5.8.1-1
python-django-compressor 4.0-1 4.1-1
python-fastapi 0.79.0-1 0.81.0-1
python-flatbuffers 2.0.6-2 2.0.7-1
python-fonttools 4.36.0-1 4.37.1-1
python-formencode 2.0.1-1 2.0.1-2
python-geoip2 4.5.0-1 4.6.0-1
python-gnupg 0.4.9-1 0.5.0-1
python-green 3.4.1-1 3.4.2-1
python-h11 0.12.0-3 0.13.0-1
python-importlib-metadata 4.8.1-3 4.8.2-1
python-ipycanvas 0.12.0-1 0.13.0-1
python-ipywidgets 7.7.1-2 8.0.1-1
python-jupyter_client 7.3.4-1 7.3.5-1
python-jupyter_packaging 0.12.2-1 0.12.3-1
python-jupyterlab_server 2.15.0-1 2.15.1-1
python-keystoneauth1 4.4.0-3 4.5.0-1
python-libtmux 0.14.0-1 0.14.2-1
python-mistune 2.0.3-2 2.0.4-1
python-mockito 1.3.0-1 1.3.1-1
python-moto 3.1.18-1 4.0.0-1
python-openapi-spec-validator 0.4.0-1 0.4.0-2
python-openstackclient 5.8.0-1 6.0.0-1
python-pdm 2.1.1-1 2.1.2-1
python-pdm-pep517 1:1.0.3-1 1:1.0.4-1
python-pikepdf 5.3.1-1 5.5.0-1
python-pip-api 0.0.18-2 0.0.21-1
python-pipenv 2022.7.24-1 2022.8.24-1
python-pivy 0.6.7-1 0.6.8-1
python-protego 0.1.16-5 0.2.0-1
python-pycodestyle 2.8.0-5 2.9.1-1
python-pynormaliz 2.16-1 2.17-1
python-pyocd 0.34.0-1 0.34.1-1
python-pythonfinder 1.2.10-1 1.3.1-1
python-pytools 2022.1.9-1 2022.1.10-1
python-pywlroots 0.15.19-1 0.15.20-1
python-requests-kerberos 0.14.0-1 0.14.0-2
python-rpy2 3.5.3-1 3.5.4-1
python-schemdraw 0.13-1 0.15-1
python-scipy 1.9.0-2 1.9.1-1
python-setuptools-rust 0.12.1-3 1.0.0-1
python-softlayer 5.9.9-1 6.1.0-1
python-sphinxcontrib-bibtex 2.4.2-1 2.5.0-1
python-sqlobject 3.9.1-2 3.9.1-3
python-sympy 1.10.1-1 1.11-1
python-tarantool 0.7.1-1 0.8.0-1
python-testfixtures 6.18.5-1 7.0.0-1
python-websocket-client 1.3.3-2 1.4.0-1
python-wilderness 0.1.7-1 0.1.7-2
python-wsproto 1.0.0-3 1.1.0-1
python-xapian 1:1.4.19-1 1:1.4.20-1
qbittorrent 4.4.3.1-3 4.4.4-1
qbittorrent-nox 4.4.3.1-3 4.4.4-1
raft 0.14.0-1 0.15.0-1
repod 0.2.0-1 0.2.1-1
restic 0.13.1-2 0.14.0-1
retroarch 1.10.3-1 1.10.3-2
ruby 3.0.4-7 3.0.4-9
ruby-addressable 2.8.0-1 2.8.1-1
ruby-bundledgems 3.0.4-7 3.0.4-9
ruby-cairo 1.17.5-7 1.17.6-1
ruby-csv 3.2.3-1 3.2.5-1
ruby-docs 3.0.4-7 3.0.4-9
ruby-puma 5.6.4-1 5.6.5-1
ruby-stdlib 3.0.4-7 3.0.4-9
runc 1.1.3-1 1.1.4-1
scaleway-cli 2.5.5-1 2.5.6-1
screenkey 1.5-1 1.5-2
singular 4.3.1.p1-2 4.3.1.p2-1
speech-dispatcher 0.11.1-3 0.11.2-1
step-cli 0.21.0-1 0.22.0-1
stylua 0.14.2-1 0.14.3-1
stylus 0.58.1-1 0.59.0-1
sundials 6.2.0-2 6.3.0-1
taskwarrior-tui 0.23.5-1 0.23.6-1
thunderbird-dark-reader 4.9.56-1 4.9.57-1
tig 2.5.6-1 2.5.7-1
tmuxp 1.13.0-1 1.13.1-1
typescript 4.7.4-1 4.8.2-1
typescript-language-server 1.1.1-1 1.1.2-1
unicode-cldr 38.0-2 39.0-1
unicode-cldr-annotations 38.0-2 39.0-1
unuran 1.8.1-6 1.9.0-1
uvicorn 0.18.2-1 0.18.3-1
v2ray-domain-list-community 20220821065410-1 20220826120058-1
v2ray-geoip 202208180100-1 202208250104-1
vbam-sdl2.1.4.r568.639003a8-12.1.4.r573.7f1d49d3-1
vbam-wx2.1.4.r568.639003a8-12.1.4.r573.7f1d49d3-1
wakatime 1:1.48.1-1 1:1.54.0-1
wpscan 1:3.8.22-1 1:3.8.22-2
xsimd 8.1.0-1 9.0.1-1
yt-dlp 2022.07.18-1 2022.08.19-1
dummyhttp - 0.5.0-1
haruna - 0.9.1-1
libva-utils - 2.15.0-1
python-mulpyplexer - 0.9-1
python-softlayer-zeep - 5.0.0-1
ruby-docile - 1.4.0-2
ruby-english - 0.7.1-1
ruby-erb - 2.2.3-2
ruby-etc - 1.3.0-2
ruby-fcntl - 1.0.1-1
ruby-fiddle - 1.1.0-1
ruby-fileutils - 1.6.0-1
ruby-find - 0.1.1-1
ruby-forwardable - 1.3.2-1
ruby-getoptlong - 0.1.1-1
ruby-io-console - 0.5.11-1
ruby-io-nonblock - 0.1.0-1
ruby-io-wait - 0.2.3-1
ruby-ipaddr - 1.2.4-1
ruby-logger - 1.5.1-1
ruby-mutex_m - 0.1.1-1
ruby-simplecov-html - 0.12.3-1
ruby-simplecov_json_formatter - 0.1.2-1
ruby-tmpdir - 0.1.2-1
:: Different overlay package(s) in repository core aarch64
linux 5.19.3-1 5.19.4-1
linux-clockworkpi-a06 5.19.3-1 5.19.4-1
linux-clockworkpi-a06-headers 5.19.3-1 5.19.4-1
linux-headers 5.19.3-1 5.19.4-1
linux-lts 5.15.62-1 5.15.63-1
linux-lts-headers 5.15.62-1 5.15.63-1
linux-opi 5.19.1-1 5.19.4-1
linux-opi-headers 5.19.1-1 5.19.4-1
linux-pinephone 5.19.3-1 5.19.4-1
linux-pinephone-headers 5.19.3-1 5.19.4-1
linux-pinephonepro 5.19.3-1 5.19.4-1
linux-pinephonepro-headers 5.19.3-1 5.19.4-1
linux-rc 6.0.rc2-1 6.0.rc2-4
linux-rc-headers 6.0.rc2-1 6.0.rc2-4
linux-rpi4 5.15.56-1 5.15.61-1
linux-rpi4-headers 5.15.56-1 5.15.61-1
linux-rpi4-mainline 5.18.12-2 5.19.3-1
linux-rpi4-mainline-headers 5.18.12-2 5.19.3-1
:: Different sync package(s) in repository core aarch64
grub2:2.06.r297.g0c6c1aff2-1.12:2.06.r322.gd9b4638c5-1
iana-etc 20220603-1 20220715-1
libtasn1 4.18.0-1 4.19.0-1
:: Different overlay package(s) in repository extra aarch64
calamares 3.2.60-1 3.2.61-1
calamares-arm-oem 20220105-1 20220826-1
libva 2.12.0-0.1 -
mesa-git22.3.0_devel.158321.7b60414494bb-122.3.0_devel.158696.b915c45cb9b-1
snapd-glib 1.60-1 1.63-1
:: Different sync package(s) in repository extra aarch64
appstream 0.15.4-1 0.15.5-1
appstream-qt 0.15.4-1 0.15.5-1
chromaprint 1.5.1-3 1.5.1-4
composer 2.4.0-1 2.4.1-1
cups-filters 1.28.15-2 1.28.16-1
ethtool 1:5.18-1 1:5.19-1
firefox 103.0.2-1 104.0-1
firefox-i18n-ach 103.0.2-1 104.0-1
firefox-i18n-af 103.0.2-1 104.0-1
firefox-i18n-an 103.0.2-1 104.0-1
firefox-i18n-ar 103.0.2-1 104.0-1
firefox-i18n-ast 103.0.2-1 104.0-1
firefox-i18n-az 103.0.2-1 104.0-1
firefox-i18n-be 103.0.2-1 104.0-1
firefox-i18n-bg 103.0.2-1 104.0-1
firefox-i18n-bn 103.0.2-1 104.0-1
firefox-i18n-br 103.0.2-1 104.0-1
firefox-i18n-bs 103.0.2-1 104.0-1
firefox-i18n-ca 103.0.2-1 104.0-1
firefox-i18n-ca-valencia 103.0.2-1 104.0-1
firefox-i18n-cak 103.0.2-1 104.0-1
firefox-i18n-cs 103.0.2-1 104.0-1
firefox-i18n-cy 103.0.2-1 104.0-1
firefox-i18n-da 103.0.2-1 104.0-1
firefox-i18n-de 103.0.2-1 104.0-1
firefox-i18n-dsb 103.0.2-1 104.0-1
firefox-i18n-el 103.0.2-1 104.0-1
firefox-i18n-en-ca 103.0.2-1 104.0-1
firefox-i18n-en-gb 103.0.2-1 104.0-1
firefox-i18n-en-us 103.0.2-1 104.0-1
firefox-i18n-eo 103.0.2-1 104.0-1
firefox-i18n-es-ar 103.0.2-1 104.0-1
firefox-i18n-es-cl 103.0.2-1 104.0-1
firefox-i18n-es-es 103.0.2-1 104.0-1
firefox-i18n-es-mx 103.0.2-1 104.0-1
firefox-i18n-et 103.0.2-1 104.0-1
firefox-i18n-eu 103.0.2-1 104.0-1
firefox-i18n-fa 103.0.2-1 104.0-1
firefox-i18n-ff 103.0.2-1 104.0-1
firefox-i18n-fi 103.0.2-1 104.0-1
firefox-i18n-fr 103.0.2-1 104.0-1
firefox-i18n-fy-nl 103.0.2-1 104.0-1
firefox-i18n-ga-ie 103.0.2-1 104.0-1
firefox-i18n-gd 103.0.2-1 104.0-1
firefox-i18n-gl 103.0.2-1 104.0-1
firefox-i18n-gn 103.0.2-1 104.0-1
firefox-i18n-gu-in 103.0.2-1 104.0-1
firefox-i18n-he 103.0.2-1 104.0-1
firefox-i18n-hi-in 103.0.2-1 104.0-1
firefox-i18n-hr 103.0.2-1 104.0-1
firefox-i18n-hsb 103.0.2-1 104.0-1
firefox-i18n-hu 103.0.2-1 104.0-1
firefox-i18n-hy-am 103.0.2-1 104.0-1
firefox-i18n-ia 103.0.2-1 104.0-1
firefox-i18n-id 103.0.2-1 104.0-1
firefox-i18n-is 103.0.2-1 104.0-1
firefox-i18n-it 103.0.2-1 104.0-1
firefox-i18n-ja 103.0.2-1 104.0-1
firefox-i18n-ka 103.0.2-1 104.0-1
firefox-i18n-kab 103.0.2-1 104.0-1
firefox-i18n-kk 103.0.2-1 104.0-1
firefox-i18n-km 103.0.2-1 104.0-1
firefox-i18n-kn 103.0.2-1 104.0-1
firefox-i18n-ko 103.0.2-1 104.0-1
firefox-i18n-lij 103.0.2-1 104.0-1
firefox-i18n-lt 103.0.2-1 104.0-1
firefox-i18n-lv 103.0.2-1 104.0-1
firefox-i18n-mk 103.0.2-1 104.0-1
firefox-i18n-mr 103.0.2-1 104.0-1
firefox-i18n-ms 103.0.2-1 104.0-1
firefox-i18n-my 103.0.2-1 104.0-1
firefox-i18n-nb-no 103.0.2-1 104.0-1
firefox-i18n-ne-np 103.0.2-1 104.0-1
firefox-i18n-nl 103.0.2-1 104.0-1
firefox-i18n-nn-no 103.0.2-1 104.0-1
firefox-i18n-oc 103.0.2-1 104.0-1
firefox-i18n-pa-in 103.0.2-1 104.0-1
firefox-i18n-pl 103.0.2-1 104.0-1
firefox-i18n-pt-br 103.0.2-1 104.0-1
firefox-i18n-pt-pt 103.0.2-1 104.0-1
firefox-i18n-rm 103.0.2-1 104.0-1
firefox-i18n-ro 103.0.2-1 104.0-1
firefox-i18n-ru 103.0.2-1 104.0-1
firefox-i18n-sco 103.0.2-1 104.0-1
firefox-i18n-si 103.0.2-1 104.0-1
firefox-i18n-sk 103.0.2-1 104.0-1
firefox-i18n-sl 103.0.2-1 104.0-1
firefox-i18n-son 103.0.2-1 104.0-1
firefox-i18n-sq 103.0.2-1 104.0-1
firefox-i18n-sr 103.0.2-1 104.0-1
firefox-i18n-sv-se 103.0.2-1 104.0-1
firefox-i18n-szl 103.0.2-1 104.0-1
firefox-i18n-ta 103.0.2-1 104.0-1
firefox-i18n-te 103.0.2-1 104.0-1
firefox-i18n-th 103.0.2-1 104.0-1
firefox-i18n-tl 103.0.2-1 104.0-1
firefox-i18n-tr 103.0.2-1 104.0-1
firefox-i18n-trs 103.0.2-1 104.0-1
firefox-i18n-uk 103.0.2-1 104.0-1
firefox-i18n-ur 103.0.2-1 104.0-1
firefox-i18n-uz 103.0.2-1 104.0-1
firefox-i18n-vi 103.0.2-1 104.0-1
firefox-i18n-xh 103.0.2-1 104.0-1
firefox-i18n-zh-cn 103.0.2-1 104.0-1
firefox-i18n-zh-tw 103.0.2-1 104.0-1
flatpak 1:1.12.7-3 1:1.14.0-1
freetds 1.3.12-1 1.3.13-1
geoip-database 20220802-1 20220823-1
geoip-database-extra 20220802-1 20220823-1
gnome-bluetooth-3.0 42.2-1 42.3-1
gvim 9.0.0236-1 9.0.0246-1
imagemagick 7.1.0.45-1 7.1.0.46-1
imagemagick-doc 7.1.0.45-1 7.1.0.46-1
js91 91.12.0-1 91.13.0-1
kaccounts-integration 22.08.0-1 22.08.0-2
kaccounts-providers 22.08.0-1 22.08.0-2
kdesdk-kioslaves 22.04.3-1 -
krita 5.0.8-1 5.1.0-1
kwallet 5.97.0-2 5.97.0-3
libqalculate 4.2.0-1 4.3.0-1
librsvg 2:2.54.4-1 2:2.54.5-1
librsvg-docs 2:2.54.4-1 2:2.54.5-1
libssh 0.9.6-1 0.10.0-1
libssh-docs 0.9.6-1 0.10.0-1
libtiff 4.4.0-3 4.4.0-4
libva-mesa-driver 22.1.6-1 22.1.7-1
libwpe 1.12.2-1 1.12.3-1
mariadb 10.8.4-1 10.9.2-1
mariadb-clients 10.8.4-1 10.9.2-1
mariadb-libs 10.8.4-1 10.9.2-1
mesa 22.1.6-1 22.1.7-1
mesa-vdpau 22.1.6-1 22.1.7-1
mlt 7.8.0-1 7.8.0-2
mytop 10.8.4-1 10.9.2-1
ndctl 73-1 74-1
netpbm 10.73.37-1 10.73.37-2
opencl-mesa 22.1.6-1 22.1.7-1
openpmix 4.1.2-1 4.2.0-1
pahole 1.23-1 1:1.23-1
python-rdflib 6.1.1-1 6.2.0-1
python-setuptools 1:62.1.0-1 1:62.3.0-1
python-urllib3 1.26.11-1 1.26.12-1
python-urllib3-doc 1.26.11-1 1.26.12-1
python-virtualenv 20.11.0-1 20.11.1-1
qalculate-gtk 4.2.0-1 4.3.0-1
qalculate-qt 4.2.0-1 4.3.0-1
qbs 1.23.0-1 1.23.1-1
qt5-base 5.15.5+kde+r174-1 5.15.5+kde+r178-1
qt5-quickcontrols2 5.15.5+kde+r5-1 5.15.5+kde+r6-1
qt5-xcb-private-headers 5.15.5+kde+r174-1 5.15.5+kde+r178-1
qtcreator 8.0.0-1 8.0.1-1
qtcreator-devel 8.0.0-1 8.0.1-1
sdl2 2.0.22-2 2.24.0-1
sdl2_image 2.6.1-1 2.6.2-1
sdl2_mixer 2.6.1-1 2.6.2-1
sdl2_net 1:2.0.1-3 1:2.2.0-1
sdl2_ttf 2.20.0-1 2.20.1-1
slang 2.3.2-2 2.3.3-1
sof-firmware 2.2-1 2.2.1-1
sof-tools 2.2-1 2.2.1-1
spglib 1.16.5-1 2.0.0-1
system-config-printer 1.5.16-1 1.5.17-1
taglib 1.12-1 1.12-2
telepathy-kde-auth-handler 22.04.2-1 22.08.0-1
telepathy-kde-call-ui 22.04.2-1 22.08.0-1
telepathy-kde-common-internals 22.04.2-2 22.08.0-1
telepathy-kde-contact-list 22.04.2-1 22.08.0-1
telepathy-kde-contact-runner 22.04.2-1 22.08.0-1
telepathy-kde-desktop-applets 22.04.2-1 22.08.0-1
telepathy-kde-filetransfer-handler 22.04.2-1 22.08.0-1
telepathy-kde-integration-module 22.04.2-1 22.08.0-1
telepathy-kde-send-file 22.04.2-1 22.08.0-1
telepathy-kde-text-ui 22.04.2-1 22.08.0-1
vim-runtime 9.0.0236-1 9.0.0246-1
vulkan-broadcom 22.1.6-1 22.1.7-1
vulkan-mesa-layers 22.1.6-1 22.1.7-1
vulkan-panfrost 22.1.6-1 22.1.7-1
vulkan-radeon 22.1.6-1 22.1.7-1
vulkan-swrast 22.1.6-1 22.1.7-1
webkit2gtk 2.36.6-1 2.36.7-1
webkit2gtk-4.1 2.36.6-1 2.36.7-1
webkit2gtk-5.0 2.36.6-1 2.36.7-1
wpewebkit 2.36.6-1 2.36.7-1
wxwidgets-common 3.2.0-4 3.2.0-5
wxwidgets-gtk3 3.2.0-4 3.2.0-5
wxwidgets-qt5 3.2.0-4 3.2.0-5
x2643:0.164.r3095.baee400-23:0.164.r3095.baee400-4
xapian-core 1:1.4.19-2 1:1.4.20-1
zeroconf-ioslave 22.04.3-1 -
libva - 2.15.0-2
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.04.3.r12802.gcb0d18b9c-122.08.0.r12802.gcb0d18b9c-1
akonadi-calendar22.04.3.r2154.g598b22f-122.08.0.r2154.g598b22f-1
akonadi-calendar-tools22.04.3.r963.gce7b2e7-122.08.0.r963.gce7b2e7-1
akonadi-contacts22.04.3.r3237.g662cca11-122.08.0.r3237.g662cca11-1
akonadi-import-wizard22.04.3.r1846.gf1b7b43-122.08.0.r1846.gf1b7b43-1
akonadi-mime22.04.3.r1752.g646aea7-122.08.0.r1752.g646aea7-1
akonadi-notes22.04.3.r1086.g26b3b67-122.08.0.r1086.g26b3b67-1
akonadi-search22.04.3.r1259.gb491a83-122.08.0.r1259.gb491a83-1
akonadiconsole22.04.3.r1614.g8f85775-122.08.0.r1614.g8f85775-1
akregator22.04.3.r6463.g52a0f30b-122.08.0.r6463.g52a0f30b-1
alligator 22.06.r37.g6fe4859-1 22.06.r43.g99520ae-1
analitza22.04.3.r2356.gc2e4500d-122.08.0.r2356.gc2e4500d-1
angelfish 22.06.r44.g298c0b4-1 22.06.r48.g7c7d922-1
ark22.04.3.r4834.gdcffa72f-122.08.0.r4837.gcb74426e-1
artikulate22.04.3.r1428.g898a7e8-122.08.0.r1429.gf9d76b2-1
attica5.97.0.r880.gd0556f3-15.97.0.r881.ga657a93-1
audiocd-kio22.04.3.r1106.g7a176f7-122.08.0.r1107.g7911e32-1
audiotube 22.06.r25.g6fdb032-1 22.06.r29.gdc3b35b-1
aura-browser r55.80b7f15-1 r58.bde47ff-1
baloo5.97.0.r3061.g179156c3-15.97.0.r3063.ge562610c-1
baloo-widgets22.04.3.r769.g56dade9-122.08.0.r771.g7e9603a-1
blinken22.04.3.r680.g1d3fae9-122.08.0.r683.g58ecf86-1
bluedevil1:5.25.4.r2429.g77fc223b-11:5.25.4.r2433.gfa5f301a-1
bomber22.04.3.r572.g2a54bd9-122.08.0.r574.g65e9dbd-1
bovo22.04.3.r783.gf19bf48-122.08.0.r784.gc111bc4-1
breeze5.25.4.r2439.g45745976-15.25.4.r2442.g8d88a824-1
breeze-gtk5.25.4.r485.gf5c1363-15.25.4.r486.g0abbbbd-1
breeze-icons5.97.0.r1912.gdef613b8-15.97.0.r1916.g1efbc677-1
calendarsupport22.04.3.r726.g8949f0c-122.08.0.r726.g8949f0c-1
calindori 22.06.r18.g6d044e2-1 22.06.r19.gac70dc6-1
cervisia22.04.3.r1690.g3a429e2-122.08.0.r1690.g3a429e2-1
discover5.25.4.r8785.g0f45fa26-15.25.4.r8805.g162fedf9-1
dolphin22.04.3.r7075.g53be1a4cc-122.08.0.r7080.g4ddc4159e-1
dolphin-plugins22.04.3.r676.gbb59561-122.08.0.r676.gbb59561-1
dragon22.04.3.r1059.gccf75f6-122.08.0.r1059.gccf75f6-1
drkonqi5.25.4.r814.gdf9c831a-15.25.4.r818.g5f677d8a-1
elisa22.04.3.r3018.g7c6a1977-122.08.0.r3020.g220c110b-1
elisa-qtmm22.04.3.r3018.g7c6a1977-122.08.0.r3020.g220c110b-1
eventviews22.04.3.r876.g8dededf-122.08.0.r876.g8dededf-1
extra-cmake-modules5.97.0.r3512.gcfe46733-15.97.0.r3515.g479fe1a4-1
ffmpegthumbs22.04.3.r234.g517d88d-122.08.0.r234.g517d88d-1
filelight22.04.3.r1167.g49495ed-122.08.0.r1172.g25330a9-1
frameworkintegration5.97.0.r651.g024845b-15.97.0.r652.g03a2072-1
granatier22.04.3.r987.g5f0c5c2-122.08.0.r988.g2c72822-1
grantlee-editor22.04.3.r836.gfb003ca-122.08.0.r836.gfb003ca-1
grantleetheme22.04.3.r410.gcb5fba1-122.08.0.r416.g89d4179-1
gwenview22.04.3.r6889.ge9655a87-122.08.0.r6889.ge9655a87-1
incidenceeditor22.04.3.r927.g25536cb-122.08.0.r927.g25536cb-1
itinerary22.04.3.r1991.gff73f02-122.08.0.r1994.gcd83347-1
juk22.04.3.r3176.g1da7d2f4-122.08.0.r3179.gc2494c96-1
k3b1:22.04.3.r6813.g9852763a3-11:22.08.0.r6815.g52eb2b3e1-1
kaccounts-integration22.04.3.r1270.g39ac07f-122.08.0.r1272.gf22cdfc-1
kaccounts-providers22.04.3.r402.gba64646-122.08.0.r402.gba64646-1
kactivities5.97.0.r1406.g5b0488df-15.97.0.r1407.gb0525939-1
kactivities-stats5.97.0.r415.g36ae17b-15.97.0.r416.gb6dde55-1
kactivitymanagerd5.25.4.r1418.g242af20-15.25.4.r1421.g703ebd6-1
kaddressbook22.04.3.r6235.gdc20289d-122.08.0.r6236.g225256de-1
kajongg22.04.3.r4348.g1c5a3ffa-122.08.0.r4349.g51f03457-1
kalarm22.04.3.r7995.g32b96e48-122.08.0.r7997.g5f39acc8-1
kalgebra22.04.3.r2073.g91da468-122.08.0.r2075.g6d6d5d3-1
kalk 22.06.r19.g8b2bbf8-1 22.06.r21.g3fea480-1
kalzium22.04.3.r4375.g69c3bd06-122.08.0.r4377.ge08b6835-1
kamera22.04.3.r732.g1c3d3d4-122.08.0.r733.geaffffa-1
kamoso22.04.3.r1473.g7b64a63-122.08.0.r1474.gb16b282-1
kanagram22.04.3.r1324.gfadf8af-122.08.0.r1324.gfadf8af-1
kapman22.04.3.r666.g0ccc626-122.08.0.r667.g61b78cf-1
kapptemplate22.04.3.r998.gba7fdc9-122.08.0.r998.gba7fdc9-1
karchive5.97.0.r552.g2ed029e-15.97.0.r553.gea0136c-1
kate22.04.3.r19420.ga1a08e1c1-122.08.0.r19459.ge1b4bc5ca-1
katomic22.04.3.r970.g23ac27b-122.08.0.r974.g1d7f4b2-1
kauth5.97.0.r505.gbd6ac34-15.97.0.r507.gdc84f0b-1
kbackup22.04.3.r454.gf8c63e9-122.08.0.r455.g5d4a2ed-1
kblackbox22.04.3.r776.g59e7617-122.08.0.r778.ga885c5f-1
kblocks22.04.3.r752.g4c1ebb6-122.08.0.r753.g6bcb670-1
kbookmarks5.97.0.r467.g87e310e-15.97.0.r468.g24e6405-1
kbounce22.04.3.r857.g203340f-122.08.0.r858.g885818f-1
kbreakout22.04.3.r933.gc80f6a9-122.08.0.r934.g37d59b6-1
kbruch22.04.3.r874.g159d907-122.08.0.r876.gbd022d1-1
kcachegrind22.04.3.r1192.gfab7e8d-122.08.0.r1193.gbfc3bfa-1
kcachegrind-common22.04.3.r1192.gfab7e8d-122.08.0.r1193.gbfc3bfa-1
kcalc22.04.3.r1629.g015112d-122.08.0.r1629.g015112d-1
kcalendarcore5.97.0.r1338.ge850e7431-15.97.0.r1339.g039c13246-1
kcalutils22.04.3.r983.g63a4e0073-122.08.0.r983.g63a4e0073-1
kcharselect22.04.3.r541.gb2b3294-122.08.0.r541.gb2b3294-1
kclock 22.06.r28.g4ec9c30-1 22.06.r31.g6d9194a-1
kcmutils5.97.0.r657.g7d89daa-15.97.0.r660.g19aa3af-1
kcodecs5.97.0.r428.gf80165c-15.97.0.r429.g321caa3-1
kcolorchooser22.04.3.r279.g8672f3b-122.08.0.r280.gf9a8480-1
kcompletion5.97.0.r508.ga0543fc-15.97.0.r510.gff0558b-1
kconfigwidgets5.97.0.r756.ge7bbd2b-15.97.0.r768.ge910e11-1
kcontacts1:5.97.0.r3344.gdbce3458-11:5.97.0.r3345.g4a4269e0-1
kcoreaddons5.97.0.r1545.g6f3722ef-15.97.0.r1548.g0fdf125b-1
kcrash5.97.0.r453.g48aac26-15.97.0.r454.g612d2cf-1
kcron22.04.3.r848.g44fb6fe-122.08.0.r849.g5708bdd-1
kdav1:5.97.0.r1352.g860e88b-11:5.97.0.r1353.gcdc0aa0-1
kdbusaddons5.97.0.r424.g2a3fbf2-15.97.0.r425.g8b7f0c2-1
kde-cli-tools5.25.4.r1952.gda029c6-15.25.4.r1954.gee512e1-1
kde-dev-scripts22.04.3.r4152.gea6d462-122.08.0.r4152.gea6d462-1
kde-dev-utils22.04.3.r596.g4a84ce3-122.08.0.r596.g4a84ce3-1
kde-gtk-config5.25.4.r942.gfdbf3f8-15.25.4.r943.g3d768af-1
kdebugsettings22.04.3.r964.gaa08e5d-122.08.0.r965.g302b9fe-1
kdeclarative5.97.0.r1024.g11d1633-15.97.0.r1028.g6d5ac25-1
kdeconnect22.04.3.r3517.gde5b15c2-122.08.0.r3526.gb25f7e07-1
kdecoration5.25.4.r295.g5df2f5b-15.25.4.r296.g90c18c9-1
kded5.97.0.r471.g36e129e-15.97.0.r472.gd197029-1
kdeedu-data22.04.3.r17.g1b749b8-122.08.0.r17.g1b749b8-1
kdegraphics-mobipocket22.04.3.r274.gc9f5c9f-122.08.0.r274.gc9f5c9f-1
kdegraphics-thumbnailers22.04.3.r280.g205a26f-122.08.0.r280.g205a26f-1
kdenetwork-filesharing22.04.3.r978.g02e97fb-122.08.0.r981.gaca8cd9-1
kdenlive22.04.3.r16570.g3d7c851e3-122.08.0.r16615.gf39db62b9-1
kdepim-addons22.04.3.r4763.gfe8f11e0e-122.08.0.r4790.g01c767039-1
kdepim-runtime22.04.3.r15565.gdac8964cd-122.08.0.r15576.gcc66c549a-1
kdeplasma-addons5.25.4.r9006.ga55956832-15.25.4.r9009.g3bb3fc690-1
kdesdk-kioslaves22.04.3.r505.g1f7909e-122.08.0.r505.g1f7909e-1
kdesdk-thumbnailers22.04.3.r93.g7ff219f-122.08.0.r93.g7ff219f-1
kdesu5.97.0.r514.g9933872-15.97.0.r516.g7188b15-1
kdf22.04.3.r869.g63a7a59-122.08.0.r872.g5aa27fa-1
kdialog22.04.3.r1236.g9ca9c31f3-122.08.0.r1238.g001e3f53a-1
kdiamond22.04.3.r733.gda2c490-122.08.0.r735.gaadedc8-1
kdnssd5.97.0.r357.g644bfab-15.97.0.r358.gf470de8-1
kdoctools5.97.0.r674.g16768d9-15.97.0.r675.g121fe81-1
keditbookmarks22.04.3.r2769.g4cb790286-122.08.0.r2771.gba417d5a9-1
keysmith 22.06.r20.ge01962c-1 22.06.r21.gb3287c4-1
kfilemetadata5.97.0.r871.g36a3f75-15.97.0.r872.g4960249-1
kfind22.04.3.r2719.g94b734cf5-122.08.0.r2724.g6df53c4ed-1
kfloppy22.04.3.r801.g2a5038a-122.08.0.r802.gcf9dbeb-1
kfourinline22.04.3.r1032.gf12a7f5-122.08.0.r1033.gaa4650f-1
kgamma55.25.4.r481.g5d1c771-15.25.4.r483.g7f02758-1
kgeography22.04.3.r1162.g153531f-122.08.0.r1165.g4752d09-1
kget22.04.3.r3219.gf2af4abf-122.08.0.r3221.g402fbff7-1
kglobalaccel5.97.0.r558.g79e7cd4-15.97.0.r572.g4440581-1
kgoldrunner22.04.3.r1294.ge3cb3b6-122.08.0.r1296.g18d0a86-1
kgpg22.04.3.r3204.gd4ee0694-122.08.0.r3204.gd4ee0694-1
kguiaddons5.97.0.r484.g2af2d76-15.97.0.r488.g1f15bbe-1
khangman22.04.3.r1623.g30d2e54-122.08.0.r1626.g3b72f18-1
khelpcenter22.04.3.r2772.gb9dfda05-122.08.0.r2775.g4ce7a63d-1
kholidays1:5.97.0.r1053.g4cd06ff-11:5.97.0.r1054.g4496f7e-1
khotkeys5.25.4.r2155.g3a2895b-15.25.4.r2156.gf2c00e7-1
ki18n5.97.0.r566.g9298068-15.97.0.r568.g08b148f-1
kiconthemes5.97.0.r621.gef3e9ad-15.97.0.r629.g2776c53-1
kidentitymanagement22.04.3.r3901.g5901ed15-122.08.0.r3901.g5901ed15-1
kidletime5.97.0.r364.g6f20ac9-15.97.0.r365.gc3dc01a-1
kig22.04.3.r3201.g9783d25e-122.08.0.r3230.g5cb99d5a-1
kigo22.04.3.r585.gead0e58-122.08.0.r587.g9834b4b-1
killbots22.04.3.r802.gd0e6de7-122.08.0.r805.gbc28d3f-1
kimageformats5.97.0.r423.g62e477a-15.97.0.r424.g43543f9-1
kimagemapeditor22.04.3.r503.gd60bf67-122.08.0.r503.gd60bf67-1
kimap22.04.3.r1206.g9f395a8-122.08.0.r1207.g0441373-1
kinfocenter5.25.4.r2135.g6b17c658-15.25.4.r2137.g0db5a518-1
kio5.97.0.r5669.g4b46733b9-15.97.0.r5675.g35caca8a3-1
kio-extras22.04.3.r7332.g9c4f7cd1-122.08.0.r7336.gc773f481-1
kio-gdrive22.04.3.r629.gfb7c7e9-122.08.0.r629.gfb7c7e9-1
kirigami-gallery22.04.3.r264.gcb4ae79-122.08.0.r264.gcb4ae79-1
kirigami25.97.0.r3302.g423537b0-15.97.0.r3304.g27b2a4fb-1
kiriki22.04.3.r461.g8f83065-122.08.0.r462.g15b63db-1
kitemmodels5.97.0.r616.g315f278-15.97.0.r617.gadb9fe0-1
kitemviews5.97.0.r381.g987b910-15.97.0.r382.g0fee09c-1
kiten22.04.3.r1207.g99d1609-122.08.0.r1208.g0a91880-1
kitinerary22.04.3.r2372.g2e1c362-122.08.0.r2372.g2e1c362-1
kjobwidgets5.97.0.r426.g811f3c2-15.97.0.r427.g41aa14f-1
kjumpingcube22.04.3.r831.g0f447de-122.08.0.r833.ga00c16a-1
kldap22.04.3.r963.g7311ef7-122.08.0.r963.g7311ef7-1
kleopatra22.04.3.r6799.gdbdb8950-122.08.0.r6810.g7c8fd291-1
klettres22.04.3.r972.gebc55cc-122.08.0.r976.g2a045ff-1
klickety22.04.3.r706.ga9f487a-122.08.0.r707.g9c57ed8-1
klines22.04.3.r830.gf8e4590-122.08.0.r832.gbda1644-1
kmag22.04.3.r744.g24a22bd-122.08.0.r746.gafa5b8d-1
kmahjongg22.04.3.r1569.gdd62313-122.08.0.r1570.g393130a-1
kmail22.04.3.r26506.g07124a2e8-122.08.0.r26507.g2287f9f8d-1
kmail-account-wizard22.04.3.r896.gb83a0e4-122.08.0.r897.g29efe6a-1
kmailtransport22.04.3.r1757.g9cb2e22-122.08.0.r1757.g9cb2e22-1
kmbox22.04.3.r608.g7401f4b-122.08.0.r609.g88bc917-1
kmenuedit5.25.4.r1062.g6e7cd3f-15.25.4.r1064.geec37fb-1
kmime22.04.3.r1526.g4429c30-122.08.0.r1527.g91e0ee1-1
kmines22.04.3.r1774.gb5699a9-122.08.0.r1775.g087951a-1
kmix22.04.3.r2459.g07dd1b95-122.08.0.r2461.gee82e9ee-1
kmousetool22.04.3.r453.g0078db7-122.08.0.r456.gd4387f8-1
kmouth22.04.3.r741.g4384969-122.08.0.r742.g205c4c0-1
kmplot22.04.3.r1505.gedccb7d-122.08.0.r1506.gefced9f-1
knavalbattle22.04.3.r1442.g317f0da-122.08.0.r1443.g52b030e-1
knetwalk22.04.3.r708.g6f5d2c7-122.08.0.r712.g3e3cc02-1
knewstuff5.97.0.r1374.gadb6c0e3-15.97.0.r1376.gc81158ab-1
knights22.04.3.r1153.gc3d77b4-122.08.0.r1154.ga283020-1
knotes22.04.3.r3691.gf4501d55-122.08.0.r3693.gb12c1f9a-1
knotifications5.97.0.r754.gc40af19-15.97.0.r755.g55799c6-1
knotifyconfig5.97.0.r391.geeedb37-15.97.0.r392.g8adea7a-1
kolf22.04.3.r1518.g6297a22-122.08.0.r1519.gaf9eb01-1
kollision22.04.3.r543.g0b77fd6-122.08.0.r545.ga7fea4b-1
kolourpaint22.04.3.r2433.g7c96c656-122.08.0.r2434.g33f87381-1
kompare22.04.3.r1153.gab4a440-122.08.0.r1153.gab4a440-1
konqueror22.04.3.r15153.gc13bd7db1-122.08.0.r15168.ga8c8fd72f-1
konquest22.04.3.r939.g078d7c7-122.08.0.r941.g25d422e-1
konsole22.04.3.r8583.gfc45802b-122.08.0.r8593.g3961d02a-1
kontact22.04.3.r5565.g669d3562-122.08.0.r5565.g669d3562-1
kontactinterface22.04.3.r705.gdae2936-122.08.0.r705.gdae2936-1
kontrast22.04.3.r212.g216d41e-122.08.0.r213.g8111ef1-1
konversation22.04.3.r9140.gae0790dd-122.08.0.r9148.gd462dee6-1
kopeninghours22.04.3.r334.g8a274d0-122.08.0.r334.g8a274d0-1
kopete22.04.3.r16449.ga8bef4117-122.08.0.r16449.ga8bef4117-1
korganizer22.04.3.r11793.gd02a7117d-122.08.0.r11793.gd02a7117d-1
kosmindoormap22.04.3.r751.g3200795-122.08.0.r751.g3200795-1
kpackage5.97.0.r762.gbc74dd2-15.97.0.r763.g633615e-1
kparts5.97.0.r596.g00157d6-15.97.0.r597.g9759b90-1
kpat22.04.3.r2629.g468e80d3-122.08.0.r2629.g468e80d3-1
kpeople5.97.0.r1383.g749dbf8-15.97.0.r1384.g629279d-1
kpimtextedit22.04.3.r1613.g1a5d3c7-122.08.0.r1613.g1a5d3c7-1
kpipewire5.25.4.r135.g3bc932e-15.25.4.r136.gcd022a2-1
kpkpass22.04.3.r305.g5803cb5-122.08.0.r306.gd4b7a98-1
kplotting5.97.0.r330.ge73705d-15.97.0.r331.gbd63ff8-1
kpmcore22.04.3.r1296.gf19fd90-122.08.0.r1297.g6d2fa58-1
kpty5.97.0.r382.g56c7dae-15.97.0.r383.g84658d5-1
kpublictransport22.04.3.r2041.g983c40cd-122.08.0.r2041.g983c40cd-1
kqtquickcharts22.04.3.r77.g9b882ce-122.08.0.r77.g9b882ce-1
krdc22.04.3.r1619.gb3c173e-122.08.0.r1621.gd3e2bbf-1
krecorder 22.06.r15.gd749fdf-1 22.06.r19.g8304326-1
kreversi22.04.3.r1279.g480fd85-122.08.0.r1281.gc7dec7a-1
krfb22.04.3.r1515.g4606fca-122.08.0.r1515.g4606fca-1
kross-interpreters22.04.3.r724.g2a6213a-122.08.0.r724.g2a6213a-1
kruler22.04.3.r743.gb06fab2-122.08.0.r748.g7f3366b-1
krunner5.97.0.r781.g7ac2e31-15.97.0.r782.g43a8518-1
kscreen5.25.4.r1526.g6a21e3a-15.25.4.r1528.g2c437f1-1
kservice5.97.0.r1028.gfc737c7-15.97.0.r1029.gf392335-1
kshisen22.04.3.r1252.gaa75b67-122.08.0.r1253.g7649fdd-1
ksirk22.04.3.r1045.g95939bf-122.08.0.r1046.g8119616-1
ksmtp22.04.3.r457.g4cf3897-122.08.0.r457.g4cf3897-1
ksnakeduel22.04.3.r861.gf46b2f8-122.08.0.r863.g5193af2-1
kspaceduel22.04.3.r681.gc8228fe-122.08.0.r683.g623323c-1
ksquares22.04.3.r567.g7142f12-122.08.0.r569.gfbc2399-1
ksshaskpass5.25.4.r212.gd1bef1b-15.25.4.r213.g725a602-1
ksudoku22.04.3.r1133.g4401239-122.08.0.r1134.g59cf95a-1
ksysguard5.25.4.r3540.geea1d41b-15.25.4.r3544.ga33b3673-1
ksystemlog22.04.3.r748.g9d559bf-122.08.0.r750.gbd082be-1
kteatime22.04.3.r767.gf414707-122.08.0.r767.gf414707-1
ktexteditor5.97.0.r3508.g7f5c2834-15.97.0.r3515.g93e19185-1
ktextwidgets5.97.0.r456.g58008d0-15.97.0.r457.gbde86b3-1
ktimer22.04.3.r533.g1aa7faf-122.08.0.r534.g8d5bf37-1
ktnef22.04.3.r728.g1c91e0a-122.08.0.r728.g1c91e0a-1
ktorrent22.04.3.r2879.g40177951-122.08.0.r2881.gdf49a0fa-1
ktouch22.04.3.r2198.g21fa0f7-122.08.0.r2199.g343d452-1
ktuberling22.04.3.r1073.g87ff652-122.08.0.r1074.g0ab170d-1
kturtle22.04.3.r1181.g1755a0b-122.08.0.r1183.ge072ed9-1
kubrick22.04.3.r417.g3eae0c0-122.08.0.r417.g3eae0c0-1
kunitconversion5.97.0.r425.ga95506a-15.97.0.r426.g39cbac1-1
kwallet5.97.0.r1170.g6f419a9-15.97.0.r1173.g2e7e501-1
kwallet-pam5.25.4.r271.g40ad5fe-15.25.4.r273.g2961c86-1
kwalletmanager22.04.3.r1285.gb41444f-122.08.0.r1286.g9b8de9d-1
kwave22.04.3.r3803.gc09e9745-122.08.0.r3804.g4d19132c-1
kwayland5.97.0.r1176.g3ad0772-15.97.0.r1177.g6c88c7d-1
kwayland-integration5.25.4.r212.gef63862-15.25.4.r213.ge312a38-1
kweather 22.06.r50.gce81b22-1 22.06.r53.g817ec72-1
kweathercore 0.6.r15.g4b36a26-1 0.6.r20.ga91bb3c-1
kwidgetsaddons5.97.0.r972.ga75ebe8b-15.97.0.r979.g128495be-1
kwin5.25.4.r23025.gb0423c32a-15.25.4.r23048.g070f63c45-1
kwindowsystem5.97.0.r691.g5d66351-15.97.0.r692.g8f3de55-1
kwordquiz22.04.3.r1198.gb92c023-122.08.0.r1199.g4914691-1
kwrite22.04.3.r19420.ga1a08e1c1-122.08.0.r19459.ge1b4bc5ca-1
kwrited5.25.4.r514.g2a65ab9-15.25.4.r516.g4fb19a5-1
kxmlgui5.97.0.r901.gf4038b6b-15.97.0.r903.g014733d9-1
layer-shell-qt5.25.4.r62.g7bd6366-15.25.4.r64.g5af50ac-1
libakonadi22.04.3.r12802.gcb0d18b9c-122.08.0.r12802.gcb0d18b9c-1
libgravatar22.04.3.r435.g94114a9-122.08.0.r435.g94114a9-1
libkcddb22.04.3.r767.g8898b31-122.08.0.r768.g7a30ef8-1
libkcompactdisc22.04.3.r398.ga55bed8-122.08.0.r399.g61b5f60-1
libkdcraw22.04.3.r1153.ga4a99cf-122.08.0.r1153.ga4a99cf-1
libkdegames22.04.3.r2255.g839ccd0e-122.08.0.r2256.g2529b8c6-1
libkdepim22.04.3.r923.gb276e74-122.08.0.r923.gb276e74-1
libkeduvocdocument22.04.3.r1811.gd4b7962-122.08.0.r1812.g8a1b9c7-1
libkexiv222.04.3.r830.ge8e6b67-122.08.0.r830.ge8e6b67-1
libkgapi22.04.3.r1374.g029ff4f-122.08.0.r1374.g029ff4f-1
libkipi22.04.3.r1280.g5b6d13f-122.08.0.r1280.g5b6d13f-1
libkleo22.04.3.r1254.gb5c7bfe-122.08.0.r1268.g5688e83-1
libkmahjongg22.04.3.r488.gf8dd902-122.08.0.r489.g38ac255-1
libkomparediff222.04.3.r346.g5e898ac-122.08.0.r346.g5e898ac-1
libksane22.04.3.r604.g779611e-122.08.0.r604.g779611e-1
libkscreen5.25.4.r1634.g4004b09-15.25.4.r1635.g4f441a4-1
libksieve22.04.3.r1739.g549bd98b-122.08.0.r1739.g549bd98b-1
libksysguard5.25.4.r2427.gfac897d-15.25.4.r2429.g052249c-1
libktorrent22.04.3.r562.g92ec083-122.08.0.r563.g85add79-1
lokalize22.04.3.r1847.ga03f7375-122.08.0.r1847.ga03f7375-1
lskat22.04.3.r863.g367290c-122.08.0.r865.g103d3ea-1
mailcommon22.04.3.r1290.gdeba643-122.08.0.r1290.gdeba643-1
mailimporter22.04.3.r531.g788fbb7-122.08.0.r531.g788fbb7-1
marble22.04.3.r13464.g246e38fae-122.08.0.r13465.gb59e3597c-1
marble-common22.04.3.r13464.g246e38fae-122.08.0.r13465.gb59e3597c-1
marble-qt22.04.3.r13464.g246e38fae-122.08.0.r13465.gb59e3597c-1
markdownpart22.04.3.r132.g8d3f6f5-122.08.0.r133.g43d8d6b-1
mauikit 2.2.0.r0.g2e5ada2f-1 2.2.0.r1.g84eefaef-1
mauiman r30.3f79747-1 r31.3101050-1
mbox-importer22.04.3.r577.g5312c7a-122.08.0.r577.g5312c7a-1
messagelib22.04.3.r6661.g645518ef6-122.08.0.r6661.g645518ef6-1
milou5.25.4.r781.gf71a8fd-15.25.4.r782.gdbcd209-1
minuet22.04.3.r619.g95e0c81-122.08.0.r620.g7b17819-1
neochat22.06.r68.g63af4cae-122.06.r93.g6cca3dbe-1
okular22.04.3.r9816.g5eed8258e-122.08.0.r9817.g986c2e6db-1
oxygen5.25.4.r4502.g1feb2847-15.25.4.r4503.g4368c0c8-1
palapeli22.04.3.r1306.gb051333-122.08.0.r1309.g1c4d3ad-1
parley22.04.3.r4540.g21073171-122.08.0.r4541.gcc3bf06d-1
partitionmanager22.04.3.r1641.ge1336b1-122.08.0.r1642.gb47f7b1-1
picmi22.04.3.r566.g1720e96-122.08.0.r567.g0daadd8-1
pim-data-exporter22.04.3.r2783.gcdef1f0c-122.08.0.r2783.gcdef1f0c-1
pim-sieve-editor22.04.3.r1650.g9d583ee-122.08.0.r1650.g9d583ee-1
pimcommon22.04.3.r1284.gd48d4a0-122.08.0.r1312.g8eab52e-1
plank-player r31.35ad97b-1 r32.025b29b-1
plasma-bigscreen r498.gfba59fd-1 r501.g0970c95-1
plasma-browser-integration5.25.4.r1347.g8757b4df-15.25.4.r1350.g290ee44b-1
plasma-camera 1.0.r129.gd7cd0e4-1 1.0.r132.g239459e-1
plasma-desktop5.25.4.r9557.g52a200d39-15.25.4.r9568.g1f1e4606f-1
plasma-dialer 22.06.r48.gbf0a9d4-1 22.06.r65.g3858af6-1
plasma-disks5.25.4.r287.g38d3106-15.25.4.r289.gde3c1bc-1
plasma-framework5.97.0.r16393.gc6853261e-15.97.0.r16402.g7a48005d9-1
plasma-integration5.25.4.r574.g31277ed-15.25.4.r575.g7b1ece8-1
plasma-mobile5.25.4.r1937.g7a4a0dddc-15.25.4.r1938.g66e7b8cbf-1
plasma-mobile-nm5.25.4.r3321.g7e9a57d1-15.25.4.r3324.g9682a9b4-1
plasma-nano5.25.4.r192.gbd29071-15.25.4.r193.g0987bae-1
plasma-nm5.25.4.r3321.g7e9a57d1-15.25.4.r3324.g9682a9b4-1
plasma-pa5.25.4.r1069.gcbcda4a-15.25.4.r1071.g415069d-1
plasma-phonebook 22.06.r13.g96e92f2-1 22.06.r18.g77821b7-1
plasma-remotecontrollers r95.g34feeed-1 r118.g5e0f22a-1
plasma-sdk5.25.4.r2386.g282db459-15.25.4.r2388.gcba48c02-1
plasma-settings 22.06.r74.g757c41c-1 22.06.r80.gd838502-1
plasma-systemmonitor5.25.4.r611.g2a8e964-15.25.4.r612.g19d1630-1
plasma-thunderbolt5.25.4.r194.gfa11777-15.25.4.r197.gd5272df-1
plasma-vault5.25.4.r388.gf2f7183-15.25.4.r389.gd114f8b-1
plasma-wayland-protocols1.4.0.r1056.gf882bd9-11.4.0.r1057.gee026f0-1
plasma-wayland-session5.25.4.r12229.g57d55e386-15.25.4.r12246.gacea9036c-1
plasma-workspace5.25.4.r12229.g57d55e386-15.25.4.r12246.gacea9036c-1
plasmatube 22.06.r18.ge43bd18-1 22.06.r22.gaa0107c-1
powerdevil5.25.4.r2587.gdbb3e021-15.25.4.r2589.g622d95b9-1
poxml22.04.3.r282.g2615361-122.08.0.r282.g2615361-1
print-manager22.04.3.r1156.g9582e7a-122.08.0.r1156.g9582e7a-1
prison5.97.0.r398.g49f9970-15.97.0.r399.g3ce44be-1
purpose5.97.0.r990.g68cea83-15.97.0.r991.gca13427-1
qcachegrind22.04.3.r1192.gfab7e8d-122.08.0.r1193.gbfc3bfa-1
qmlkonsole 22.06.r31.g6acf47f-1 22.06.r35.g78dedce-1
qqc2-breeze-style5.25.4.r249.g36ec4ea-15.25.4.r251.g7f67497-1
qqc2-desktop-style5.97.0.r648.ge0ac4c6-15.97.0.r652.gd671cf6-1
rocs22.04.3.r3110.g8f75ac0d-122.08.0.r3113.g4cde3b32-1
sddm-kcm5.25.4.r683.gd3ba802-15.25.4.r684.gef78919-1
signon-kwallet-extension22.04.3.r82.g67533cf-122.08.0.r82.g67533cf-1
solid5.97.0.r786.g79bdd41-15.97.0.r790.g6549bda-1
sonnet5.97.0.r709.g5ab17c1-15.97.0.r710.g17b99c8-1
spacebar 22.06.r58.g52bcf4d-1 22.06.r60.g270ee9e-1
spectacle22.04.3.r1384.gfd85cc1-122.08.0.r1384.gfd85cc1-1
step22.04.3.r1206.g78637a2-122.08.0.r1207.g0783602-1
svgpart22.04.3.r235.g939b16d-122.08.0.r236.g173ad86-1
sweeper22.04.3.r584.g116bcd0-122.08.0.r584.g116bcd0-1
syndication5.97.0.r880.g638e4b5-15.97.0.r881.g7ed59d9-1
syntax-highlighting5.97.0.r1909.ga7cfa1d4-15.97.0.r1911.g656fbbcf-1
systemsettings5.25.4.r2701.gea3f2d06-15.25.4.r2706.g7e3cec9d-1
telepathy-kde-accounts-kcm22.04.3.r1220.g5d7feff-122.08.0.r1220.g5d7feff-1
telepathy-kde-approver22.04.3.r306.g53cec00-122.08.0.r306.g53cec00-1
telepathy-kde-auth-handler22.04.3.r284.gc59f7d0-122.08.0.r284.gc59f7d0-1
telepathy-kde-call-ui22.04.3.r450.ga1ee093-122.08.0.r450.ga1ee093-1
telepathy-kde-common-internals22.04.3.r2022.g09a775a-122.08.0.r2022.g09a775a-1
telepathy-kde-contact-list22.04.3.r1093.g9c27117-122.08.0.r1093.g9c27117-1
telepathy-kde-contact-runner22.04.3.r263.gac42a1d-122.08.0.r263.gac42a1d-1
telepathy-kde-desktop-applets22.04.3.r1007.g06cd5ac-122.08.0.r1007.g06cd5ac-1
telepathy-kde-filetransfer-handler22.04.3.r227.ga6083c9-122.08.0.r227.ga6083c9-1
telepathy-kde-integration-module22.04.3.r402.ga5572ce-122.08.0.r402.ga5572ce-1
telepathy-kde-send-file22.04.3.r236.gcac0c0c-122.08.0.r236.gcac0c0c-1
telepathy-kde-text-ui22.04.3.r2048.g596eeaf-122.08.0.r2048.g596eeaf-1
threadweaver5.97.0.r549.gca3006f-15.97.0.r550.g05004a0-1
tokodon 22.06.r31.g6095386-1 22.06.r32.g245aade-1
umbrello22.04.3.r8502.ge52640032-122.08.0.r8502.ge52640032-1
vakzination 22.06.r37.g116876d-1 22.06.r40.g8e36b60-1
vvave 2.2.0.r0.g6a94b8a-1 2.2.0.r1.g4980751-1
xdg-desktop-portal-kde5.25.4.r514.gb8ead2d-15.25.4.r518.gf117959-1
yakuake22.04.3.r823.g2551725-122.08.0.r825.gbb3bb90-1
zeroconf-ioslave22.04.3.r394.gd86416e-122.08.0.r394.gd86416e-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
