Hello ARM community.
Mostly point release updated this time, which is fine as we are preparing for our next stable update.
Arch Linux added earlyoom to their repositories, so we also get it
Some highlights:
- Most of our kernels got updated
- HWinfo updated to 22.1
- Firefox updated to 103.0.3
- Mesa updated to 22.1.6
- Gnome updated to 42.4
- EarlyOOM added to repositories
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Thu Aug 11 19:38:18 CEST 2022)
- arm-testing community aarch64: 245 new and 214 removed package(s)
- arm-testing core aarch64: 29 new and 28 removed package(s)
- arm-testing extra aarch64: 190 new and 190 removed package(s)
- arm-testing kde-unstable aarch64: 243 new and 243 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-08-06 2022-08-11
callaudiod 0.1.4+1+gd380d60-2 0.1.4+9+g7f2c637-1
electron 20.0.1-1 20.0.2-1
electron18 18.3.6-1 18.3.8-1
electron19 19.0.11-1 19.0.12-1
hwinfo 21.83-1 22.1-1
phoc 0.21.0-1 0.21.0+3+gcee43cf-1
phosh0.20.0beta3+15+gdf8eff99-1 0.20.0+2+g4a93126f-1
ventoy 1.0.79-1 1.0.79-2
glacier-contacts - 0.8.1-1
glacier-messages - 0.2.4-1
glacier-pinquery - 0.3.4-1
nemo-qml-plugin-statusnotifier - 1.0.1-1
voicecall - 0.7.14-1
watchmate - 0.1.0-1
:: Different sync package(s) in repository community aarch64
avr-binutils 2.38-2 2.39-1
aws-cli 1.25.44-1 1.25.48-1
bamf 0.5.5-2 0.5.6-1
batctl 2022.1-1 2022.2-1
bitwarden-cli 2022.6.2-2 2022.8.0-1
boinc 7.18.1-1 7.20.2-1
boinc-nox 7.18.1-1 7.20.2-1
bootconfig 5.18-1 5.19-1
bpf 5.18-1 5.19-1
buildah 1.26.4-1 1.27.0-1
camlp4 4.13+1-3 4.14+1-3
camlp5 8.0-3 8.0-4
cargo-zigbuild 0.11.3-1 0.12.0-1
cgroup_event_listener 5.18-1 5.19-1
charm 0.12.1-1 0.12.3-1
clojure 1.11.1.1149-1 1.11.1.1155-1
cockpit 273-1 274.1-1
cockpit-pcp 273-1 274.1-1
containerd 1.6.6-1 1.6.8-1
copr-cli 1.101-1 1.101-2
coq 8.15.0-1 8.15.0-3
coq-doc 8.15.0-1 8.15.0-3
coqide 8.15.0-1 8.15.0-3
corectrl 1.2.5-1 1.2.7-1
cosign 1.9.0-1 1.10.1-1
cpp-hocon 0.3.0-10 0.3.0-11
cpupower 5.18-1 5.19-1
cri-o 1.24.1-1 1.24.2-1
crypto++ 8.6.0-2 8.7.0-1
dark-reader 4.9.52-1 4.9.55-1
dart-sass 1.54.2-1 1.54.4-1
difftastic 0.31.0-1 0.32.0-1
dpkg 1.21.8-1 1.21.9-1
dune 3.4.1-1 3.4.1-2
esptool 4.1-1 4.2-2
facter 3.14.23-2 3.14.24-1
feeluown 3.8.6-1 3.8.7-1
ffnvcodec-headers8.1 8.1.24.11-2 8.1.24.13-1
fio 3.29-1 3.31-1
firefox-dark-reader 4.9.52-1 4.9.55-1
foot 1.12.1-2 1.13.0-1
foot-terminfo 1.12.1-2 1.13.0-1
fossil 2.18-1 2.19-1
freecad 0.20-1 0.20.1-1
fzf 0.32.0-1 0.32.1-1
gamemode 1.6.1-2 1.7-1
gcovr 5.1-1 5.2-1
github-cli 2.14.3-1 2.14.4-1
go-ethereum 1.10.20-1 1.10.21-1
gpio-utils 5.18-1 5.19-1
helm 3.9.0-1 3.9.3-2
helmfile 0.144.0-1 0.145.2-1
herbstluftwm 0.9.4-2 0.9.5-1
hivex 1.3.21-6 1.3.21-7
home-assistant 1:2022.7.4-2 1:2022.8.2-1
hugin 2021.0.0-4 2021.0.0-5
hyperv 5.18-1 5.19-1
ibus-m17n 1.4.9-1 1.4.10-1
ibus-table 1.16.10-1 1.16.11-1
iio-utils 5.18-1 5.19-1
interception-tools 0.6.8-4 0.6.8-5
iwd 1.27-1 1.29-1
jenkins 2.362-1 2.363-1
just 1.3.0-1 1.4.0-1
k9s 0.26.1-1 0.26.3-1
kea 2.0.2-2 2.0.3-2
kea-docs 2.0.2-2 2.0.3-2
kubectx 0.9.1-2 0.9.4-1
kustomize 4.5.4-2 4.5.6-1
lablgtk3 3.1.2-2 3.1.2-3
leatherman 1.12.7-2 1.12.8-2
libimagequant 4.0.0-1 4.0.1-1
libmemcached-awesome 1.1.1-1 1.1.2-1
libmgba 0.9.3-3 0.9.3-4
libnfs 5.0.1-2 5.0.2-1
libperconaserverclient 8.0.28_20-1 8.0.29_21-1
librdkafka 1.9.1-1 1.9.2-1
libvirt 1:8.6.0-1 1:8.6.0-2
libvirt-storage-gluster 1:8.6.0-1 1:8.6.0-2
libvirt-storage-iscsi-direct 1:8.6.0-1 1:8.6.0-2
libwhereami 0.5.0-12 0.5.0-13
linux-tools-meta 5.18-1 5.19-1
liteide 37.4-3 38.0-1
luajit2.1.0.beta3.r431.g5677985d-12.1.0.beta3.r439.g633f265f-1
meilisearch 0.28.0-1 0.28.1-1
mgba-qt 0.9.3-3 0.9.3-4
mgba-sdl 0.9.3-3 0.9.3-4
micro 2.0.11-3 2.0.11-4
minetest 5.5.1-1 5.6.0-1
minetest-common 5.5.1-1 5.6.0-1
minetest-server 5.5.1-1 5.6.0-1
mongo-c-driver 1.21.2-1 1.22.0-1
musescore 3.6.2-5 3.6.2-7
netdata 1.35.1-1 1.36.0-1
nextcloud-app-mail 1.13.6-1 1.13.7-1
nomad 1.3.2-1 1.3.3-1
npm 8.16.0-1 8.17.0-1
npm-check-updates 15.0.0-1 15.0.2-1
ocaml-base 0.15.0-1 0.15.0-2
ocaml-cairo 0.6.3-1 0.6.3-2
ocaml-compiler-libs-repackaged 0.12.4-3 -
ocaml-csexp 1.5.1-4 1.5.1-5
ocaml-findlib 1.9.5-1 1.9.5-2
ocaml-hashcons 1.3-4 1.3-5
ocaml-lablgl 1.06-11 1.06-12
ocaml-num 1.4-5 1.4-6
ocaml-pp 1.1.2-2 1.1.2-3
ocaml-ppx_derivers 1.2.1-8 1.2.1-9
ocaml-sexplib0 0.15.1-1 0.15.1-2
ocaml-stdio 0.15.0-1 0.15.0-2
ocaml-stdlib-shims 0.3.0-4 0.3.0-5
ocaml-zarith 1.12-4 1.12-5
ocamlbuild 0.14.1-1 0.14.1-2
openblas 0.3.20-1 0.3.21-1
osbuild 60-1 63-2
papirus-icon-theme 20220710-1 20220808-1
pdal 2.4.2-3 2.4.3-1
percona-server 8.0.28_20-1 8.0.29_21-1
percona-server-clients 8.0.28_20-1 8.0.29_21-1
perf 5.18-1 5.19-1
perl-file-sharedir-install 0.13-6 0.14-1
perl-json 4.08-1 4.09-1
perl-test-trap 0.3.4-5 0.3.5-1
pgformatter 5.2-3 5.3-1
phpldapadmin 1.2.6.3-1 1.2.6.4-1
plantuml-server 1.2022.6-1 1.2022.6-2
puppet 7.17.0-1 7.18.0-1
pyright 1.1.265-1 1.1.266-1
python-aws-sam-translator 1.48.0-1 1.49.0-1
python-boto3 1.24.44-1 1.24.48-1
python-botocore 1.27.44-1 1.27.48-1
python-bottle 0.12.21-1 0.12.22-1
python-braintree 4.15.2-1 4.16.0-1
python-crashtest 0.3.1-6 0.4.0-1
python-cssbeautifier 1.14.4-1 1.14.5-1
python-dominate 2.6.0-5 2.7.0-1
python-dotty-dict 1.3.0-5 1.3.1-1
python-email-validator 1.2.0-1 1.2.1-1
python-findpython 0.2.0-1 0.2.1-1
python-gitlab 3.7.0-1 3.8.1-1
python-google-api-python-client 2.55.0-1 2.56.0-1
python-jsbeautifier 1.14.4-1 1.14.5-1
python-networkx 2.8.4-1 2.8.5-1
python-oslo-config 8.8.0-1 9.0.0-1
python-oslo-utils 4.11.0-1 4.12.0-1
python-phonenumbers 8.12.52-1 8.12.53-1
python-pycares 4.2.1-1 4.2.2-1
python-pygame-sdl21:2.1.0.r411.7f814e9-11:2.1.0.r411.7f814e9-2
python-rapidjson 1.7-1 1.8-1
python-shellingham 1.4.0-4 1.5.0-1
python-simplejson 3.17.6-3 3.17.6-4
python-testflo 1.4.8-1 1.4.9-1
python-tomlkit 0.11.1-1 0.11.3-1
python2-future 0.18.2-2 -
python2-pygame-sdl21:2.1.0.r411.7f814e9-1 -
rclone 1.59.0-1 1.59.1-1
reactphysics3d 0.8.0-2 0.9.0-1
reactphysics3d-docs 0.8.0-2 0.9.0-1
reaper 6.64-1 6.64-2
recoll 1.32.1-1 1.32.5-1
revive 1.2.1-1 1.2.3-1
rizin 0.3.4-1 0.4.0-1
ruby 3.0.4-2 3.0.4-5
ruby-bundledgems 3.0.4-2 3.0.4-5
ruby-bundler 2.3.18-1 2.3.19-1
ruby-docs 3.0.4-2 3.0.4-5
ruby-erubi 1.10.0-2 1.11.0-1
ruby-minitest 5.15.0-1 5.16.2-1
ruby-msgpack 1.5.3-1 1.5.4-1
ruby-nats-pure 2.1.0-1 2.1.2-1
ruby-nokogiri 1.13.6-1 1.13.8-2
ruby-pcaprub 0.12.4-8 0.13.1-1
ruby-pg 1.4.2-1 1.4.3-1
ruby-sqlite3 1.4.2-5 1.4.4-1
ruby-stdlib 3.0.4-2 3.0.4-5
rust-analyzer 20220801-1 20220808-1
rz-cutter 2.0.5-3 2.1.0-2
rz-ghidra 0.3.0-3 0.4.0-2
siege 4.1.2-1 4.1.5-1
sile 0.14.0-1 0.14.1-1
skate 0.2.0-2 0.2.1-3
smartdns 36.1-1 37-2
snd 22.5-1 22.6-1
soft-serve 0.3.3-1 0.4.0-2
sqlc 1.14.0-1 1.15.0-1
taplo-cli 0.6.9-1 0.6.10-1
terragrunt 0.38.1-1 0.38.7-1
texstudio 4.2.3-1 4.3.0-1
thunderbird-dark-reader 4.9.52-1 4.9.55-1
tllist 1.0.5-3 1.1.0-1
tmon 5.18-1 5.19-1
tor 0.4.7.8-1 0.4.7.8-2
typescript-language-server 0.11.2-1 1.0.0-1
ufw-extras 0.7.0-2 0.7.0-3
usbip 5.18-1 5.19-1
usbredir 0.12.0-1 0.13.0-1
v2ray-domain-list-community 20220803154734-1 20220809072217-1
v2ray-geoip 202207280056-1 202208040058-1
vscode-css-languageserver 1.69.0-1 1.70.0-1
vscode-html-languageserver 1.69.0-1 1.70.0-1
vscode-json-languageserver 1.69.0-1 1.70.0-1
xonsh 0.13.0-1 0.13.1-1
yaegi 0.12.0-1 0.14.1-1
yosys 0.12-6 0.12-7
zeroc-ice 3.7.7-1 3.7.8-1
zsh-completions 0.34.0-1 0.34.0-2
camlp-streams - 5.0.1-1
cmctl - 1.8.2-1
cockpit-packagekit - 274.1-1
cockpit-storaged - 274.1-1
ct - 0.9.3-1
datree - 1.6.0-1
earlyoom - 1.7-1
eksctl - 0.106.0-1
kube-apiserver - 1.24.3-2
kube-controller-manager - 1.24.3-2
kube-proxy - 1.24.3-2
kube-scheduler - 1.24.3-2
kubeadm - 1.24.3-2
kubectl - 1.24.3-2
kubectl-cert-manager - 1.9.0-1
kubelet - 1.24.3-2
kubernetes-control-plane-common - 1.24.3-2
med-openmpi - 4.1.1-2
prometheus-wireguard-exporter - 3.6.3-1
python-bleak - 0.15.1-1
python-fnvhash - 0.1.0-3
python-home-assistant-bluetooth - 1.4.0-1
ruby-date - 3.2.2-1
ruby-net-http - 0.2.2-1
ruby-open-uri - 0.2.0-2
ruby-time - 0.2.0-2
ruby-uri - 0.11.0-2
wldash - 0.3.0-2
:: Different overlay package(s) in repository core aarch64
linux 5.19.0-1 5.19.1-1
linux-clockworkpi-a06 5.19.0-1 5.19.1-1
linux-clockworkpi-a06-headers 5.19.0-1 5.19.1-1
linux-headers 5.19.0-1 5.19.1-1
linux-lts 5.15.59-1 5.15.60-1
linux-lts-headers 5.15.59-1 5.15.60-1
linux-odroid 5.18.12-2 5.19.0-1
linux-odroid-headers 5.18.12-2 5.19.0-1
linux-pinephone 5.19.0-1 5.19.1-1
linux-pinephone-headers 5.19.0-1 5.19.1-1
linux-pinephonepro 5.19.0-1 5.19.1-1
linux-pinephonepro-headers 5.19.0-1 5.19.1-1
:: Different sync package(s) in repository core aarch64
gnutls 3.7.6-1 3.7.7-1
lemon 3.39.1-1 3.39.2-1
libevent 2.1.12-1 2.1.12-2
nano 6.3-1 6.4-1
nettle 3.8-1 3.8.1-1
nspr 4.34-1 4.34.1-1
sqlite 3.39.1-1 3.39.2-1
sqlite-analyzer 3.39.1-1 3.39.2-1
sqlite-doc 3.39.1-1 3.39.2-1
sqlite-tcl 3.39.1-1 3.39.2-1
systemd 251.3-1 251.4-1
systemd-libs 251.3-1 251.4-1
systemd-resolvconf 251.3-1 251.4-1
systemd-sysvcompat 251.3-1 251.4-1
util-linux 2.38-1 2.38.1-1
util-linux-libs 2.38-1 2.38.1-1
libevent-docs - 2.1.12-2
:: Different overlay package(s) in repository extra aarch64
manjaro-settings-manager 0.5.7-1 0.5.7-2
manjaro-settings-manager-kcm 0.5.7-1 0.5.7-2
snapd 2.57-2 2.57.1-1
:: Different sync package(s) in repository extra aarch64
apparmor 3.0.6-1 3.0.7-1
appstream-glib 0.8.0-1 0.8.1-1
bluez 5.64-2 5.65-1
bluez-cups 5.64-2 5.65-1
bluez-hid2hci 5.64-2 5.65-1
bluez-libs 5.64-2 5.65-1
bluez-plugins 5.64-2 5.65-1
bluez-utils 5.64-2 5.65-1
brltty 6.5-1 6.5-2
brltty-udev-generic 6.5-1 6.5-2
cups-filters 1.28.15-1 1.28.15-2
dbus-broker 31-1 32-1
dconf-editor 3.38.3-1 3.38.3-2
directx-headers 1.602.0-1 1.606.3-1
dkms 3.0.5-2 3.0.6-1
ell 0.51-1 0.52-1
eog 42.2-1 42.3-1
eog-docs 42.2-1 42.3-1
facile 1.1.4-1 1.1.4-2
firefox 103.0.1-1 103.0.2-1
firefox-i18n-ach 103.0.1-1 103.0.2-1
firefox-i18n-af 103.0.1-1 103.0.2-1
firefox-i18n-an 103.0.1-1 103.0.2-1
firefox-i18n-ar 103.0.1-1 103.0.2-1
firefox-i18n-ast 103.0.1-1 103.0.2-1
firefox-i18n-az 103.0.1-1 103.0.2-1
firefox-i18n-be 103.0.1-1 103.0.2-1
firefox-i18n-bg 103.0.1-1 103.0.2-1
firefox-i18n-bn 103.0.1-1 103.0.2-1
firefox-i18n-br 103.0.1-1 103.0.2-1
firefox-i18n-bs 103.0.1-1 103.0.2-1
firefox-i18n-ca 103.0.1-1 103.0.2-1
firefox-i18n-ca-valencia 103.0.1-1 103.0.2-1
firefox-i18n-cak 103.0.1-1 103.0.2-1
firefox-i18n-cs 103.0.1-1 103.0.2-1
firefox-i18n-cy 103.0.1-1 103.0.2-1
firefox-i18n-da 103.0.1-1 103.0.2-1
firefox-i18n-de 103.0.1-1 103.0.2-1
firefox-i18n-dsb 103.0.1-1 103.0.2-1
firefox-i18n-el 103.0.1-1 103.0.2-1
firefox-i18n-en-ca 103.0.1-1 103.0.2-1
firefox-i18n-en-gb 103.0.1-1 103.0.2-1
firefox-i18n-en-us 103.0.1-1 103.0.2-1
firefox-i18n-eo 103.0.1-1 103.0.2-1
firefox-i18n-es-ar 103.0.1-1 103.0.2-1
firefox-i18n-es-cl 103.0.1-1 103.0.2-1
firefox-i18n-es-es 103.0.1-1 103.0.2-1
firefox-i18n-es-mx 103.0.1-1 103.0.2-1
firefox-i18n-et 103.0.1-1 103.0.2-1
firefox-i18n-eu 103.0.1-1 103.0.2-1
firefox-i18n-fa 103.0.1-1 103.0.2-1
firefox-i18n-ff 103.0.1-1 103.0.2-1
firefox-i18n-fi 103.0.1-1 103.0.2-1
firefox-i18n-fr 103.0.1-1 103.0.2-1
firefox-i18n-fy-nl 103.0.1-1 103.0.2-1
firefox-i18n-ga-ie 103.0.1-1 103.0.2-1
firefox-i18n-gd 103.0.1-1 103.0.2-1
firefox-i18n-gl 103.0.1-1 103.0.2-1
firefox-i18n-gn 103.0.1-1 103.0.2-1
firefox-i18n-gu-in 103.0.1-1 103.0.2-1
firefox-i18n-he 103.0.1-1 103.0.2-1
firefox-i18n-hi-in 103.0.1-1 103.0.2-1
firefox-i18n-hr 103.0.1-1 103.0.2-1
firefox-i18n-hsb 103.0.1-1 103.0.2-1
firefox-i18n-hu 103.0.1-1 103.0.2-1
firefox-i18n-hy-am 103.0.1-1 103.0.2-1
firefox-i18n-ia 103.0.1-1 103.0.2-1
firefox-i18n-id 103.0.1-1 103.0.2-1
firefox-i18n-is 103.0.1-1 103.0.2-1
firefox-i18n-it 103.0.1-1 103.0.2-1
firefox-i18n-ja 103.0.1-1 103.0.2-1
firefox-i18n-ka 103.0.1-1 103.0.2-1
firefox-i18n-kab 103.0.1-1 103.0.2-1
firefox-i18n-kk 103.0.1-1 103.0.2-1
firefox-i18n-km 103.0.1-1 103.0.2-1
firefox-i18n-kn 103.0.1-1 103.0.2-1
firefox-i18n-ko 103.0.1-1 103.0.2-1
firefox-i18n-lij 103.0.1-1 103.0.2-1
firefox-i18n-lt 103.0.1-1 103.0.2-1
firefox-i18n-lv 103.0.1-1 103.0.2-1
firefox-i18n-mk 103.0.1-1 103.0.2-1
firefox-i18n-mr 103.0.1-1 103.0.2-1
firefox-i18n-ms 103.0.1-1 103.0.2-1
firefox-i18n-my 103.0.1-1 103.0.2-1
firefox-i18n-nb-no 103.0.1-1 103.0.2-1
firefox-i18n-ne-np 103.0.1-1 103.0.2-1
firefox-i18n-nl 103.0.1-1 103.0.2-1
firefox-i18n-nn-no 103.0.1-1 103.0.2-1
firefox-i18n-oc 103.0.1-1 103.0.2-1
firefox-i18n-pa-in 103.0.1-1 103.0.2-1
firefox-i18n-pl 103.0.1-1 103.0.2-1
firefox-i18n-pt-br 103.0.1-1 103.0.2-1
firefox-i18n-pt-pt 103.0.1-1 103.0.2-1
firefox-i18n-rm 103.0.1-1 103.0.2-1
firefox-i18n-ro 103.0.1-1 103.0.2-1
firefox-i18n-ru 103.0.1-1 103.0.2-1
firefox-i18n-sco 103.0.1-1 103.0.2-1
firefox-i18n-si 103.0.1-1 103.0.2-1
firefox-i18n-sk 103.0.1-1 103.0.2-1
firefox-i18n-sl 103.0.1-1 103.0.2-1
firefox-i18n-son 103.0.1-1 103.0.2-1
firefox-i18n-sq 103.0.1-1 103.0.2-1
firefox-i18n-sr 103.0.1-1 103.0.2-1
firefox-i18n-sv-se 103.0.1-1 103.0.2-1
firefox-i18n-szl 103.0.1-1 103.0.2-1
firefox-i18n-ta 103.0.1-1 103.0.2-1
firefox-i18n-te 103.0.1-1 103.0.2-1
firefox-i18n-th 103.0.1-1 103.0.2-1
firefox-i18n-tl 103.0.1-1 103.0.2-1
firefox-i18n-tr 103.0.1-1 103.0.2-1
firefox-i18n-trs 103.0.1-1 103.0.2-1
firefox-i18n-uk 103.0.1-1 103.0.2-1
firefox-i18n-ur 103.0.1-1 103.0.2-1
firefox-i18n-uz 103.0.1-1 103.0.2-1
firefox-i18n-vi 103.0.1-1 103.0.2-1
firefox-i18n-xh 103.0.1-1 103.0.2-1
firefox-i18n-zh-cn 103.0.1-1 103.0.2-1
firefox-i18n-zh-tw 103.0.1-1 103.0.2-1
gdk-pixbuf2 2.42.8-1 2.42.9-1
gdk-pixbuf2-docs 2.42.8-1 2.42.9-1
geocode-glib 3.26.3-1 3.26.4-1
gjs 2:1.72.1-1 2:1.72.2-1
glade 3.38.2-3 3.40.0-1
gnome-chess 42.0-1 42.1-1
gnome-desktop 1:42.3-1 1:42.4-1
gnome-desktop-4 1:42.3-1 1:42.4-1
gnome-desktop-common 1:42.3-1 1:42.4-1
gnome-remote-desktop 42.3-1 42.4-1
gnu-efi 3.0.14-4 3.0.15-1
graphviz 5.0.0-1 5.0.0-2
gsm 1.0.21-1 1.0.22-1
lablgtk2 2.18.12-1 2.18.12-2
lib2geom 1.2-1 1.2-2
libbluray 1.3.1-1 1.3.2-1
libdmapsharing 2.9.39-3 2.9.41-1
libevdev 1.12.1-1 1.13.0-1
libglvnd 1.4.0-2 1.4.0-3
libva-mesa-driver 22.1.4-1 22.1.6-1
libwacom 2.3.0-1 2.4.0-1
libwebp 1.2.3-1 1.2.4-1
libxcvt 0.1.1-1 0.1.2-1
liferea 1.13.8-1 1.13.9-1
lighttpd 1.4.65-1 1.4.66-1
lprint 1.1.0-1 1.1.0-2
lua 5.4.4-1 5.4.4-2
mesa 22.1.4-1 22.1.6-1
mesa-vdpau 22.1.4-1 22.1.6-1
msmtp 1.8.20-1 1.8.22-1
msmtp-mta 1.8.20-1 1.8.22-1
mutt 2.2.6-1 2.2.7-1
ocaml 4.13.1-3 4.14.0-1
ocaml-bigarray-compat 1.0.0-2 1.0.0-3
ocaml-compiler-libs 4.13.1-3 4.14.0-1
ocaml-ctypes 0.20.0-2 0.20.1-1
ocaml-integers 0.5.1-2 0.7.0-1
ocaml-result 1.5-6 1.5-7
ocaml-topkg 1.0.4-2 1.0.5-1
opencl-mesa 22.1.4-1 22.1.6-1
pkgstats 3.2.3-1 3.2.4-1
prometheus-blackbox-exporter 0.21.1-1 0.22.0-1
python-trove-classifiers 2022.7.22-1 2022.8.7-1
rsync 3.2.4-1 3.2.5pre2-1
rust 1:1.62.1-1 1:1.62.1-1.1
rust-src 1:1.62.1-1 1:1.62.1-1.1
samba 4.16.4-2 4.16.4-3
scons 4.3.0-3 4.4.0-1
smbclient 4.16.4-2 4.16.4-3
tomcat8 8.5.81-1 8.5.82-1
tracker3 3.3.2-1 3.3.3-1
tracker3-docs 3.3.2-1 3.3.3-1
unzip 6.0-18 6.0-19
varnish 7.1.0-1 7.1.1-1
vulkan-broadcom 22.1.4-1 22.1.6-1
vulkan-mesa-layers 22.1.4-1 22.1.6-1
vulkan-panfrost 22.1.4-1 22.1.6-1
vulkan-radeon 22.1.4-1 22.1.6-1
vulkan-swrast 22.1.4-1 22.1.6-1
webkit2gtk 2.36.5-2 2.36.6-1
webkit2gtk-4.1 2.36.5-2 2.36.6-1
webkit2gtk-5.0 2.36.5-2 2.36.6-1
wireplumber 0.4.11-2 0.4.11-3
wireplumber-docs 0.4.11-2 0.4.11-3
wpebackend-fdo 1.12.0-2 1.12.1-1
wpewebkit 2.36.5-2 2.36.6-1
xdg-user-dirs 0.17-3 0.18-1
xfce4-screenshooter 1.9.10-2 1.9.11-1
xkeyboard-config 2.36-2 2.36-3
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.04.3.r12798.g5576b4a9b-122.04.3.r12799.g00999d2ce-1
akonadi-import-wizard22.04.3.r1842.g7922089-122.04.3.r1843.gceab58e-1
akonadi-search22.04.3.r1253.gbf732e7-122.04.3.r1254.g5ace2e2-1
alligator 22.06.r26.g1dcaced-1 22.06.r28.g6453795-1
angelfish 22.06.r26.gc82bc51-1 22.06.r30.gc1f7265-1
ark22.04.3.r4824.g96601a5e-122.04.3.r4826.g26b3cc3b-1
artikulate22.04.3.r1425.g1066b70-122.04.3.r1427.g726f90a-1
attica5.96.0.r878.g9e2a404-15.96.0.r879.g1544fae-1
audiocd-kio22.04.3.r1103.g2cd9d9f-122.04.3.r1105.g9e2b9d1-1
audiotube 22.06.r19.gef59e9d-1 22.06.r23.gb4c6749-1
baloo5.96.0.r3059.gea7d6992-15.96.0.r3060.gfaed70bc-1
baloo-widgets22.04.3.r764.ge7669e5-122.04.3.r765.gd34e9d9-1
blinken22.04.3.r676.gc226950-122.04.3.r677.gef45841-1
bluedevil1:5.25.4.r2425.g69532493-11:5.25.4.r2427.g83047c80-1
bluez-qt5.96.0.r715.gc4f457a-15.96.0.r716.g3848dd2-1
breeze5.25.4.r2435.geef93418-15.25.4.r2439.g45745976-1
breeze-icons5.96.0.r1909.gacc75ff7-15.96.0.r1911.g788ff4e0-1
buho 2.1.2.r6.g3fe40dc-1 2.1.2.r7.gd31b470-1
calendarsupport22.04.3.r720.g0d96f02-122.04.3.r722.g780a4e3-1
calindori 22.06.r9.g1b8b909-1 22.06.r16.ge791c0c-1
discover5.25.4.r8770.g0ee32898-15.25.4.r8775.gd3def74e-1
dolphin22.04.3.r7057.g86c103e76-122.04.3.r7058.g19cd2364a-1
dolphin-plugins22.04.3.r668.g0db9289-122.04.3.r674.ga4b3242-1
dragon22.04.3.r1054.g92c0656-122.04.3.r1056.g8ddd812-1
drkonqi5.25.4.r811.gf58645f1-15.25.4.r813.g489dac6b-1
eventviews22.04.3.r862.g17c0b0e-122.04.3.r863.g340af1a-1
extra-cmake-modules5.96.0.r3506.gce726d38-15.96.0.r3510.ga7e2d05a-1
ffmpegthumbs22.04.3.r227.g8f27039-122.04.3.r231.gd69b6e7-1
filelight22.04.3.r1157.gdc184ef-122.04.3.r1164.g1aee822-1
frameworkintegration5.96.0.r647.g817408a-15.96.0.r649.gc8faffa-1
gwenview22.04.3.r6887.gb948a072-122.04.3.r6888.g5a5d4822-1
index-fm 2.1.2.r37.g83c1c65-1 2.1.2.r38.ga9a62ae-1
itinerary22.04.3.r1970.g6f1f8b2-122.04.3.r1971.ga4f7ae9-1
juk22.04.3.r3173.g3639f717-122.04.3.r3174.g17d1c06f-1
k3b1:22.04.3.r6808.g27ac23378-11:22.04.3.r6810.gf0dd4b990-1
kactivities5.96.0.r1404.gfeda83d6-15.96.0.r1405.g7de15f9d-1
kactivities-stats5.96.0.r412.gd64e767-15.96.0.r413.g76ef2ca-1
kactivitymanagerd5.25.4.r1413.gc562bf6-15.25.4.r1416.gc7aa02b-1
kaddressbook22.04.3.r6225.g7f5e4c61-122.04.3.r6227.g2b10e627-1
kalgebra22.04.3.r2070.g0c74265-122.04.3.r2072.g1b91491-1
kalk 22.06.r13.ga060835-1 22.06.r14.g88ed070-1
kamera22.04.3.r729.g4cd82d0-122.04.3.r731.g2536689-1
kamoso22.04.3.r1470.gc7d4dd4-122.04.3.r1471.g7e56d6f-1
kanagram22.04.3.r1319.g9180818-122.04.3.r1323.g4065c72-1
karchive5.96.0.r549.g20b8e69-15.96.0.r550.g1fd9dc6-1
kasts 22.06.r32.g8844d94-1 22.06.r37.g9b97613-1
kate22.04.3.r19267.g672c193c9-122.04.3.r19280.gbdff4fcc4-1
kauth5.96.0.r503.g4545a5a-15.96.0.r504.g463ce9b-1
kbookmarks5.96.0.r465.gdfcd9a6-15.96.0.r466.gb7c7b99-1
kbreakout22.04.3.r930.gb90aab3-122.04.3.r932.g27b90b7-1
kcachegrind22.04.3.r1189.gbdeab59-122.04.3.r1191.g0d0fefd-1
kcachegrind-common22.04.3.r1189.gbdeab59-122.04.3.r1191.g0d0fefd-1
kcalendarcore5.96.0.r1335.g0fbb0c73f-15.96.0.r1336.g5c2c1ff23-1
kcharselect22.04.3.r538.g9c2bd2e-122.04.3.r539.g222c074-1
kclock 22.06.r22.gf23328a-1 22.06.r24.ga963493-1
kcmutils5.96.0.r651.g85097f0-15.96.0.r655.g746cd5e-1
kcodecs5.96.0.r426.ge62c81c-15.96.0.r427.geab5287-1
kcompletion5.96.0.r506.gb10de8d-15.96.0.r507.g1196686-1
kconfigwidgets5.96.0.r752.g89d04a1-15.96.0.r754.ge4b6cb0-1
kcontacts1:5.96.0.r3342.gdff759f2-11:5.96.0.r3343.ga7f93d4c-1
kcoreaddons5.96.0.r1540.gfadef3bb-15.96.0.r1543.g231c98e2-1
kcrash5.96.0.r451.g0dcdf97-15.96.0.r452.g72cd5b4-1
kdav1:5.96.0.r1350.g20ecfa7-11:5.96.0.r1351.gea558bc-1
kdbusaddons5.96.0.r421.gfe3cbed-15.96.0.r422.g5e8a7bd-1
kde-cli-tools5.25.4.r1948.g819457a-15.25.4.r1949.g2986931-1
kde-dev-utils22.04.3.r594.gb8df7e2-122.04.3.r595.gb9fc576-1
kdebugsettings22.04.3.r955.g6967cdc-122.04.3.r957.g72be805-1
kdeclarative5.96.0.r1018.g92b6cf0-15.96.0.r1020.g0a1f77c-1
kdeconnect22.04.3.r3506.g65d83a62-122.04.3.r3511.g4918be1e-1
kded5.96.0.r468.gec9f232-15.96.0.r470.g143cbf3-1
kdelibs4support5.96.0.r1100.g7cf36906-15.96.0.r1102.g8b2dc42a-1
kdenetwork-filesharing22.04.3.r970.gc6ddc1d-122.04.3.r971.g8a37b42-1
kdenlive22.04.3.r16501.g89b9d2e31-122.04.3.r16541.gaaa8c7737-1
kdepim-addons22.04.3.r4734.gbe6746a69-122.04.3.r4741.g14ad5a25b-1
kdeplasma-addons5.25.4.r8976.g6aef3e90b-15.25.4.r8990.g756312c36-1
kdesignerplugin5.96.0.r358.g1603103-15.96.0.r359.g65341e2-1
kdesu5.96.0.r512.gb1963b7-15.96.0.r513.g8bf4ac2-1
kdewebkit5.96.0.r305.g6be60b7-15.96.0.r306.g3ca78da-1
kdnssd5.96.0.r355.g60f918e-15.96.0.r356.gfb07d29-1
kdoctools5.96.0.r672.gd1a4ebe-15.96.0.r673.g602065c-1
kemoticons5.96.0.r422.ge293d50-15.96.0.r423.g9ca93ce-1
keysmith 22.06.r17.g9d403f6-1 22.06.r18.g8ed0399-1
kfilemetadata5.96.0.r868.g138880a-15.96.0.r870.ge85d971-1
kfind22.04.3.r2708.gf40bc0d4b-122.04.3.r2709.g020051c70-1
kget22.04.3.r3217.gbd08a346-122.04.3.r3218.gba6038e8-1
kglobalaccel5.96.0.r537.g5683e03-15.96.0.r538.g27624db-1
kgpg22.04.3.r3199.g22092caf-122.04.3.r3201.gda83984d-1
kguiaddons5.96.0.r481.ga3b46ae-15.96.0.r483.g6493b29-1
khangman22.04.3.r1621.gfd91cfe-122.04.3.r1622.g520cbd6-1
khealthcertificate 22.06.r15.g71707d1-1 22.06.r16.ga58e3ba-1
khelpcenter22.04.3.r2767.g2b26e275-122.04.3.r2769.g1bbd6650-1
kholidays1:5.96.0.r1045.g8cc6ac7-11:5.96.0.r1052.gb883a37-1
khtml5.96.0.r590.g559f347-15.96.0.r593.g9712a64-1
ki18n5.96.0.r564.g0926f2b-15.96.0.r565.g7c12a65-1
kiconthemes5.96.0.r615.g9095ef7-15.96.0.r617.gda34334-1
kidletime5.96.0.r362.g07f0ef5-15.96.0.r363.g11d238e-1
kimageformats5.96.0.r421.g6074c4d-15.96.0.r422.ge6955e1-1
kinfocenter5.25.4.r2130.g5364405c-15.25.4.r2132.gb8b2386d-1
kinit5.96.0.r443.g208c119-15.96.0.r445.g85ca4b6-1
kio5.96.0.r5621.g03e4f020e-15.96.0.r5637.ge26e09610-1
kio-extras22.04.3.r7315.g4320d77a-122.04.3.r7329.g9f7a0a17-1
kio-gdrive22.04.3.r624.g0cdfd52-122.04.3.r628.g720962f-1
kirigami-addons 1:0.3.r6.gbd7741e-1 1:0.3.r7.g3830da0-1
kirigami-gallery22.04.3.r259.gf983f28-122.04.3.r263.g297783e-1
kirigami25.96.0.r3187.g07959ea6-15.96.0.r3222.gb5126b2b-1
kiriki22.04.3.r458.g9484807-122.04.3.r460.gfbf4770-1
kitemmodels5.96.0.r614.g8d0117c-15.96.0.r615.g78cde10-1
kitemviews5.96.0.r379.g77f35ee-15.96.0.r380.ge4d9fcd-1
kitinerary22.04.3.r2343.g3ab40c7-122.04.3.r2352.g5c6ae46-1
kjobwidgets5.96.0.r422.g437782c-15.96.0.r423.g6cfd3fc-1
kjs5.96.0.r367.gd1b8856-15.96.0.r368.gfd9252e-1
kjsembed5.96.0.r332.gc786956-15.96.0.r333.gef9ea48-1
kleopatra22.04.3.r6752.g45d1f6b3-122.04.3.r6771.gda3aef1b-1
klickety22.04.3.r703.gbc1c850-122.04.3.r705.g4b86a96-1
kmahjongg22.04.3.r1567.g6df1f7f-122.04.3.r1568.g6a75094-1
kmail22.04.3.r26474.g385b4157e-122.04.3.r26498.g643b5855c-1
kmediaplayer5.96.0.r321.gf68bf85-15.96.0.r322.g014a259-1
kmenuedit5.25.4.r1059.g4ace756-15.25.4.r1062.g6e7cd3f-1
kmix22.04.3.r2457.g7d0e816d-122.04.3.r2458.g3e373718-1
kmousetool22.04.3.r451.gec55edf-122.04.3.r452.g6c9b62d-1
kmouth22.04.3.r735.gea167b1-122.04.3.r740.geeb10c5-1
kmplot22.04.3.r1502.g5cd3999-122.04.3.r1504.gb8fc5ca-1
knewstuff5.96.0.r1368.g3bf2a1f2-15.96.0.r1369.ga97b882d-1
knights22.04.3.r1151.g5a6ba8b-122.04.3.r1152.g982c276-1
knotes22.04.3.r3686.g5fe123ee-122.04.3.r3687.gf1bb3407-1
knotifications5.96.0.r752.gb83d890-15.96.0.r753.g04dbd95-1
knotifyconfig5.96.0.r389.gc0aad14-15.96.0.r390.gbd78f1a-1
koko 22.06.r12.g8a3a8bc-1 22.06.r13.g906a5fe-1
kolourpaint22.04.3.r2429.gb5116cfc-122.04.3.r2431.gb7708ae4-1
kompare22.04.3.r1146.g3d27211-122.04.3.r1151.gaa70fa4-1
kongress 22.06.r12.g4126d2f-1 22.06.r26.g6ceb7ca-1
konqueror22.04.3.r15134.g12e4f8431-122.04.3.r15137.g216e1227c-1
konsole22.04.3.r8563.gbcedf80b-122.04.3.r8568.g0cf95671-1
kontact22.04.3.r5556.gd7c715b9-122.04.3.r5557.g79b09230-1
konversation22.04.3.r9132.gd0ca8bf5-122.04.3.r9133.g77b9f876-1
kopete22.04.3.r16446.gd5d42981c-122.04.3.r16447.gf95cf63c8-1
korganizer22.04.3.r11782.gb7797cdb2-122.04.3.r11786.gf621be218-1
kpackage5.96.0.r760.g74bf92c-15.96.0.r761.g5f69b4a-1
kparts5.96.0.r594.g4743e72-15.96.0.r595.g8f564bc-1
kpeople5.96.0.r1381.ge9b7118-15.96.0.r1382.g22c5339-1
kplotting5.96.0.r328.g61fd8b9-15.96.0.r329.gc67bc59-1
kpmcore22.04.3.r1294.gf01581f-122.04.3.r1295.g8381994-1
kpty5.96.0.r380.gfba4b75-15.96.0.r381.g99d043f-1
kquickcharts5.96.0.r525.g0b6c9e5-15.96.0.r527.g1a8baa3-1
krecorder 22.06.r10.g7551196-1 22.06.r11.g2e30772-1
krfb22.04.3.r1511.g5173e7f-122.04.3.r1514.ga8ccd7c-1
kross5.96.0.r362.g06fc4ec-15.96.0.r364.gcca187e-1
krunner5.96.0.r778.g1fcb430-15.96.0.r779.gbe6e416-1
kscreen5.25.4.r1511.gff4cd54-15.25.4.r1519.ge5fd138-1
kscreenlocker5.25.4.r973.g799cd6a-15.25.4.r974.g5af2dbd-1
kservice5.96.0.r1026.ge6e67ba-15.96.0.r1027.g19eb760-1
ksirk22.04.3.r1041.g667c2e4-122.04.3.r1042.g70493a9-1
ksudoku22.04.3.r1125.g56f3503-122.04.3.r1126.g83bf947-1
ksysguard5.25.4.r3539.g3c8b00a1-15.25.4.r3540.geea1d41b-1
ktexteditor5.96.0.r3443.g985ea47e-15.96.0.r3457.gc871d8a5-1
ktextwidgets5.96.0.r453.g7f5c312-15.96.0.r454.g608c190-1
ktimer22.04.3.r527.g11ffead-122.04.3.r528.g708661f-1
ktorrent22.04.3.r2871.gefcfdaa3-122.04.3.r2872.gd5b96763-1
ktrip 22.06.r10.g7e18d4c-1 22.06.r11.gcc2e33e-1
kturtle22.04.3.r1179.g78a90cb-122.04.3.r1180.gd962bae-1
kunitconversion5.96.0.r423.ge54e91e-15.96.0.r424.g7456dc5-1
kwallet5.96.0.r1165.gcc873f6-15.96.0.r1166.g8c458cc-1
kwayland5.96.0.r1172.g5227e3f-15.96.0.r1175.g57cf099-1
kwayland-server5.25.4.r1480.g7f15f36-15.25.4.r1481.gdec04c4-1
kweather 22.06.r26.gc4609bc-1 22.06.r37.g720614f-1
kweathercore 0.6.r8.ge6b2118-1 0.6.r11.g869226a-1
kwidgetsaddons5.96.0.r962.ge4ad049e-15.96.0.r965.gecc211bc-1
kwin5.25.4.r22931.gb6f6e7f15-15.25.4.r22965.g3197c7892-1
kwindowsystem5.96.0.r689.gaf80173-15.96.0.r690.gf543b42-1
kwordquiz22.04.3.r1193.g8ec09c7-122.04.3.r1197.gc04c65a-1
kwrite22.04.3.r19267.g672c193c9-122.04.3.r19280.gbdff4fcc4-1
kxmlgui5.96.0.r898.g072c1e8e-15.96.0.r899.gebf356da-1
kxmlrpcclient5.96.0.r485.g39b1f081d-15.96.0.r486.g4f9239727-1
libakonadi22.04.3.r12798.g5576b4a9b-122.04.3.r12799.g00999d2ce-1
libkeduvocdocument22.04.3.r1810.g5b20cc7-122.04.3.r1811.gd4b7962-1
libkgapi22.04.3.r1371.gd1e1cbf-122.04.3.r1372.g87bdfc1-1
libkleo22.04.3.r1243.g576de59-122.04.3.r1245.g2fa5e70-1
libkmahjongg22.04.3.r486.ga227949-122.04.3.r487.g8694c45-1
libksieve22.04.3.r1733.g087d103a-122.04.3.r1735.g3682ce96-1
libksysguard5.25.4.r2425.g9a01468-15.25.4.r2426.gbd1dc2a-1
libktorrent22.04.3.r552.g4f6c01c-122.04.3.r561.g4a88224-1
lokalize22.04.3.r1842.gebce661b-122.04.3.r1844.g4948d782-1
mailcommon22.04.3.r1278.gb37062e-122.04.3.r1286.g719097c-1
maui-nota 2.1.2.r11.g1064432-1 2.1.2.r12.g5beaff7-1
maui-pix 2.1.2.r18.g1ea25f0-1 2.1.2.r19.g476ee36-1
maui-shell 0.5.0.r64.g9259c71-1 0.5.0.r72.ge969251-1
mauikit2.1.2.r52.g71e20e86-12.1.2.r54.g64a66e51-1
mauikit-imagetools 2.1.2.r4.gf2b432e-1 2.1.2.r5.gad0d210-1
mauikit-texteditor 2.1.2.r4.g2270a27-1 2.1.2.r5.g60b5ab0-1
mauiman r26.0eff78b-1 r28.101f05f-1
messagelib22.04.3.r6639.g71170855e-122.04.3.r6645.geed933cda-1
milou5.25.4.r780.ga50415d-15.25.4.r781.gf71a8fd-1
modemmanager-qt5.96.0.r558.gbc128da-15.96.0.r559.gd870646-1
neochat22.06.r56.g84a265b7-122.06.r62.gef1ff04e-1
networkmanager-qt5.96.0.r1158.gea3156d-15.96.0.r1159.g5f9316a-1
okular22.04.3.r9796.g63d783912-122.04.3.r9811.g46f803433-1
oxygen5.25.4.r4500.ga50719e0-15.25.4.r4501.gdf744478-1
palapeli22.04.3.r1295.ga1284bd-122.04.3.r1296.g21365b1-1
parley22.04.3.r4538.g5c4efe10-122.04.3.r4539.gc94e64dd-1
partitionmanager22.04.3.r1637.g799603c-122.04.3.r1638.g203d965-1
pimcommon22.04.3.r1258.g6000a95-122.04.3.r1261.g7306c658-1
plasma-bigscreen r494.gcff5977-1 r497.gb8eedee-1
plasma-browser-integration5.25.4.r1340.gc81db22f-15.25.4.r1342.g9ba3362d-1
plasma-desktop5.25.4.r9504.gcd6d7e4b1-15.25.4.r9523.g0868a5ae8-1
plasma-dialer 22.06.r22.gd032a2d-1 22.06.r24.ge16d3a1-1
plasma-firewall5.25.4.r645.g66cb96f-15.25.4.r646.gf7df8cb-1
plasma-framework5.96.0.r16375.g2b187cbcb-15.96.0.r16380.gf8f57a695-1
plasma-mobile5.25.4.r1926.gaeddd5ab7-15.25.4.r1928.g74b61890f-1
plasma-mobile-nm5.25.4.r3309.g2be2dd88-15.25.4.r3312.g748832ff-1
plasma-nano5.25.4.r191.g5deb2a5-15.25.4.r192.gbd29071-1
plasma-nm5.25.4.r3309.g2be2dd88-15.25.4.r3312.g748832ff-1
plasma-phonebook 22.06.r10.g91aad88-1 22.06.r11.g689a118-1
plasma-sdk5.25.4.r2383.g92be00a4-15.25.4.r2385.g53055b35-1
plasma-settings 22.06.r51.gf80c55a-2 22.06.r58.gcad2124-1
plasma-systemmonitor5.25.4.r604.g22c9b55-15.25.4.r608.g42fde83-1
plasma-wayland-session5.25.4.r12161.gb7e4da6b1-15.25.4.r12183.ge0a515655-1
plasma-workspace5.25.4.r12161.gb7e4da6b1-15.25.4.r12183.ge0a515655-1
plasma-workspace-wallpapers5.25.4.r369.gd788478-15.25.4.r373.gdc15ca9-1
plasmatube 22.06.r8.g939828c-1 22.06.r11.gdb1c664-1
powerdevil5.25.4.r2575.g53ff4a3b-15.25.4.r2579.gd7391ea2-1
print-manager22.04.3.r1151.g6d417bb-122.04.3.r1154.g21bcb24-1
prison5.96.0.r394.gd7671ab-15.96.0.r396.g7f359b9-1
purpose5.96.0.r985.g64ed389-15.96.0.r989.g0acb6e7-1
qcachegrind22.04.3.r1189.gbdeab59-122.04.3.r1191.g0d0fefd-1
qmlkonsole 22.06.r12.g9fe7f12-1 22.06.r14.g812010d-1
qqc2-desktop-style5.96.0.r646.g1bcaf0b-15.96.0.r647.g138b675-1
rocs22.04.3.r3095.g4c9d2cfa-122.04.3.r3109.g0829d4f2-1
sddm-kcm5.25.4.r673.g70e0760-15.25.4.r680.gd5dcd87-1
solid5.96.0.r784.g8c9ad6a-15.96.0.r785.gf7391d6-1
sonnet5.96.0.r707.g091b91f-15.96.0.r708.g0b11814-1
spacebar 22.06.r45.g6ae2512-1 22.06.r52.gb4c58dc-1
spectacle22.04.3.r1377.gde864e6-122.04.3.r1380.g0eca369-1
syndication5.96.0.r878.g90db4b7-15.96.0.r879.g6a9c9de-1
syntax-highlighting5.96.0.r1883.g25639c63-15.96.0.r1889.g2b322ad9-1
systemsettings5.25.4.r2699.g46fb188f-15.25.4.r2700.gd1c2c73e-1
telepathy-kde-desktop-applets22.04.3.r1006.gb0a027c-122.04.3.r1007.g06cd5ac-1
threadweaver5.96.0.r547.g8187da6-15.96.0.r548.gec07224-1
tokodon 22.06.r25.gaf55861-1 22.06.r26.g5b4fa72-1
umbrello22.04.3.r8487.g908b3425f-122.04.3.r8492.g9c85b9404-1
vakzination 22.06.r24.g950f134-1 22.06.r29.g83474f4-1
vvave 2.1.2.r26.ge0417a4-1 2.1.2.r27.g9ec0341-1
xdg-desktop-portal-kde5.25.4.r512.g57f17b2-15.25.4.r513.g7b0219e-1
yakuake22.04.3.r807.g1213c6d-122.04.3.r812.g81292d7-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
