Hello ARM community.
Lots of point releases this time.
Some highlights:
- Most of our kernels got updated
- Firefox updated to 103.0.1
- Mesa updated to 22.1.4
- Cinnamon updated to 5.4.8
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
( Mon Aug 1 17:33:14 CEST 2022)
- arm-testing community aarch64: 451 new and 413 removed package(s)
- arm-testing core aarch64: 29 new and 29 removed package(s)
- arm-testing extra aarch64: 187 new and 187 removed package(s)
- arm-testing kde-unstable aarch64: 255 new and 254 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-07-22 2022-08-01
callaudiod 0.1.4+1+gd380d60-1 0.1.4+1+gd380d60-2
eg25-manager 0.4.3+1+g34472a5-1 0.4.4-1
electron 19.0.7-1 19.0.9-1
electron18 18.3.4-1 18.3.6-1
element-desktop 1.11.0-1 1.11.1-1
element-web 1.11.0-1 1.11.1-1
inxi 3.3.19.1-1 3.3.20.1-1
kodi-rpi-git20.x.60733.a7ecb4ca50-120.x.60769.6a5a129c30-1
kodi-rpi-git-dev20.x.60733.a7ecb4ca50-120.x.60769.6a5a129c30-1
kodi-rpi-git-eventclients20.x.60733.a7ecb4ca50-120.x.60769.6a5a129c30-1
kodi-rpi-git-tools-texturepacker20.x.60733.a7ecb4ca50-120.x.60769.6a5a129c30-1
nemo-qml-plugin-settings-git 0.1.1.r0.gec557c6-1 -
phoc0.21.0beta1+15+gbfa954a-10.21.0beta1+21+ge367874-2
phosh0.20.0beta2+18+g8bfc3fde-10.20.0beta3+4+gd4728aea-1
timeshift 22.06.3-1 22.06.5-1
waydroid-image 17.1_20220316-1 17.1_20220723-1
wayfire 0.7.3-1 0.7.4-1
wlrootsqt 1.0.0alpha1-1 1.0.0-1
bootsplash-theme-nemo - 0.1-4
buteo-mtp - 0.9.7-1
commhistory-daemon - 0.8.44-1
glacier-alarmclock - 0.1-1
glacier-calendar - 0.0.2-1
glacier-devicelock-plugin - 0.2.1-1
glacier-packagemanager - 0.4.1-1
glacier-settings - 0.6-1
glacier-testtool - 0.2.1-1
glacier-wayland-session - 0.8-3
glacier-weather - 0.1-1
lipstick-glacier-home - 0.37.6-1
nemo-qml-plugin-alarms - 0.3.11-2
nemo-qml-plugin-calendar - 0.6.47-1
nemo-qml-plugin-messages - 0.1.31-1
nemo-qml-plugin-notifications - 1.2.16-1
nemo-qml-plugin-settings - 0.1.1-1
nemo-theme-openmoko - 1.0-1
ngfd - 1.4.0-1
ngfd-plugin-native-vibrator - 1.3.1-1
ngfd-settings-nemo - 0.3.3-1
qt5-feedback-haptics-native-vibrator - 0.2.1-1
qt5-glacier-app - 0.8.2-1
qt5-lipstick - 0.45.3-1
qt5-quickcontrols-nemo-examples - 5.7.2-1
:: Different sync package(s) in repository community aarch64
aardvark-dns 1.0.3-1 1.1.0-1
adrdox 2.5.2-2 2.5.3-1
aerc 0.10.0-1 0.11.0-1
ansible-lint 6.3.0-1 6.4.0-1
apache-orc 1.7.3-2 1.7.3-4
appstream-generator 0.8.8-1 0.8.8-2
arrow 7.0.0-5 8.0.1-1
asciinema 2.2.0-1 2.2.0-2
audacity 1:2.4.1-9 1:3.1.3-1
babel-cli 7.17.10-1 7.18.9-1
babel-core 7.18.6-1 7.18.9-1
bat-extras2021.08.21.r1.g8ad00bd-32022.07.27.r7.gabda988-1
bctoolbox 5.1.45-1 5.1.51-1
blueberry 1.4.6-1 1.4.8-1
bmake 20220418-1 20220726-1
boinc 7.16.12-1 7.18.1-1
boinc-nox 7.16.12-1 7.18.1-1
brial 1.2.10-2 1.2.11-1
byacc 20210109-1 20220128-1
bzrtp 5.1.45-1 5.1.51-1
caddy 2.5.2-1 2.5.2-2
calibre 6.1.0-1 6.2.1-1
cargo-edit 0.10.2-1 0.10.4-1
cargo-expand 1.0.27-1 1.0.28-1
cargo-flamegraph 0.4.0-1 0.5.1-1
cargo-generate 0.15.2-1 0.16.0-1
cargo-nextest 0.9.26-1 0.9.33-1
cargo-tauri 1.0.4-1 1.0.5-1
cargo-zigbuild 0.11.1-1 0.11.3-1
cgal 5.4-1 5.5-1
chezmoi 2.19.0-1 2.20.0-1
cinnamon 5.4.4-1 5.4.8-1
cinnamon-settings-daemon 5.4.2-1 5.4.3-1
cinnamon-translations 5.4.1-1 5.4.2-1
clash 1.11.0-1 1.11.4-1
clasp 3.3.7-2 3.3.8-1
cockpit 272-1 273-1
cockpit-machines 271-1 272-1
cockpit-pcp 272-1 273-1
cockpit-podman 50-1 51.1-1
conmon 1:2.1.2-1 1:2.1.3-1
copr-cli 1.99-1 1.101-1
cython 0.29.30-1 0.29.32-1
cython2 0.29.30-1 0.29.32-1
d-containers 0.8.0-7 0.8.0-8
d-mir-core 1.1.14-9 1.1.14-10
d-stdx-allocator 3.0.2-19 3.0.2-20
dagger 0.2.25-1 0.2.27-1
dart-sass 1.53.0-1 1.54.0-1
datamash 1.7-1 1.8-1
debootstrap 1.0.126-1 1.0.127-2
deepin-qt5platform-plugins 5.0.59-3 5.0.59.1-1
diffoscope 219-1 220-1
diffstat 1.64-1 1.64-2
dns-lexicon 3.9.2-1 3.11.3-1
dscanner 0.12.2-1 0.12.2-2
dub 1.29.0-1 1.29.1-1
dune 3.3.0-1 3.3.1-1
editorconfig-checker 2.5.0-1 2.6.0-1
elinks 0.15.0-1 0.15.1-1
emscripten 3.1.13-1 3.1.17-1
erlang 25.0.2-1 25.0.3-1
erlang-nox 24.3.2-2 25.0.3-1
erlang-unixodbc 25.0.2-1 25.0.3-1
etherwall 3.0.3-4 3.0.4-1
fcitx 4.2.9.8-1 4.2.9.9-1
fetchmail 6.4.31-1 6.4.32-1
filezilla 3.60.1-3 3.60.2-1
firecracker 1.1.0-1 1.1.1-1
firecracker-docs 1.1.0-1 1.1.1-1
firewalld 1.1.1-1 1.2.0-1
fish 3.4.1-1 3.5.1-1
fq 0.0.7-1 0.0.8-1
freecad 0.19.4-5 0.20-1
freerdp 2:2.7.0-1 2:2.8.0-1
fwupd 1.8.2-2 1.8.3-1
fzf 0.30.0-3 0.31.0-1
gdal 3.4.3-3 3.5.1-1
geoipupdate 4.9.0-2 4.9.0-3
gir-to-d 0.22.0-7 0.22.0-8
gitlab-runner 15.1.0-1 15.2.1-1
glfw-doc 3.3.7-1 3.3.8-1
glfw-wayland 3.3.7-1 3.3.8-1
glfw-x11 3.3.7-1 3.3.8-1
glibd 2.3.0-6 2.3.0-7
gmt 6.3.0-2 6.4.0-1
gmt-doc 6.3.0-2 6.4.0-1
go-yq 4.26.1-1 4.27.1-1
grex 1.3.0-1 1.4.0-1
grub-customizer 5.2.1-1 5.2.2-1
gtkd 3.10.0-3 3.10.0-4
haproxy 2.6.0-1 2.6.2-1
hexer-hobu 1.4.0-7 1.4.0-8
hut 0.1.0-3 0.2.0-1
iaito5.5beta0.r16.g24a2eba2-2 5.7.0-1
iwd 1.28-1 1.27-1
jami-daemon 20220629-2 20220722-1
jami-qt 20220627-1 20220726-1
jc 1.20.2-1 1.20.4-1
jenkins 2.360-1 2.361-1
jmol 14.32.63-1 14.32.66-1
joyutils 1.7.1-3 1.8.1-1
jsmol 14.32.63-1 14.32.66-1
just 1.2.0-1 1.3.0-1
k9s 0.25.18-2 0.26.0-2
kicad 6.0.6-2 6.0.7-1
kicad-library-3d 6.0.6-1 6.0.7-1
kicad-library 6.0.6-1 6.0.7-1
kotlin 1.6.20-2 1.7.0-1
kstars 1:3.5.9-1 1:3.6.0-1
kubeseal 0.17.5-1 0.18.1-1
kubie 0.17.0-1 0.17.2-1
kustomize 4.5.5-1 4.5.4-2
kvantum 1.0.3-1 1.0.4-1
ldc 3:1.29.0-4 3:1.30.0-1
libgeotiff 1.6.0-4 1.7.1-1
libhx 4.5-1 4.6-1
libindi 1.9.6-2 1.9.7-1
liblas1.8.1.r127+ge6a1aaed-21.8.1.r128+gded46373-1
liblphobos 3:1.29.0-4 3:1.30.0-1
libspatialite 5.0.1-2 5.0.1-3
libstrophe 1:0.12.0-1 1:0.12.1-1
libstrophe-doc 1:0.12.0-1 1:0.12.1-1
libvips 8.12.2-1 8.13.0-1
liquidshell 1.8-1 1.8.1-1
lua-language-server 3.5.0-1 3.5.1-1
lua-penlight 1.12.0-2 1.13.1-1
lua-socket 1:3.0.0-1 1:3.1.0-1
lua51-penlight 1.12.0-2 1.13.1-1
lua51-socket 1:3.0.0-1 1:3.1.0-1
lua52-penlight 1.12.0-2 1.13.1-1
lua52-socket 1:3.0.0-1 1:3.1.0-1
lua53-penlight 1.12.0-2 1.13.1-1
lua53-socket 1:3.0.0-1 1:3.1.0-1
lxd 5.3-1 5.4-1
lychee-link-checker 0.10.0-1 0.10.1-1
m2r 0.2.1-10 0.2.1-11
maliit-keyboard 2.3.0-1 2.3.1-1
mame 0.245-1 0.246-1
mame-tools 0.245-1 0.246-1
mapnik 3.1.0-11 3.1.0-12
marked 4.0.4-1 4.0.5-1
matrix-synapse 1.63.0-1 1.63.1-1
maturin 0.13.0-1 0.13.1-1
mdbook 0.4.20-1 0.4.21-1
mediastreamer 5.1.45-1 5.1.51-1
merkaartor 0.19.0-2 0.19.0-3
minio 2022.06.30-1 2022.07.17-1
minio-client 2022.06.26-1 2022.07.15-1
molecule 3.6.1-1 4.0.1-1
mpv 1:0.34.1-4 1:0.34.1-5
muffin 5.4.3-1 5.4.4-1
mumble 1.4.230-6 1.4.230-13
murmur 1.4.230-6 1.4.230-13
mustache-d 0.1.5-6 0.1.5-7
mxml 3.3-1 3.3.1-1
mysql-workbench 8.0.29-1 8.0.30-1
n2n 3.0-1 3.1.0-1
ncnn 20220721-1 20220729-1
nemo 5.4.1-1 5.4.2-1
neovim-qt 0.2.16.1-2 0.2.17-1
netavark 1.0.3-2 1.1.0-1
networkmanager-l2tp 1.20.0-3 1.20.4-1
nextcloud-app-bookmarks 1:10.5.1-1 1:11.0.1-1
nextcloud-client 2:3.5.2-1 2:3.5.3-1
nextcloud-client-cloudproviders 2:3.5.2-1 2:3.5.3-1
nlopt 2.7.1-2 2.7.1-3
nnn 4.5-1 4.6-1
nodejs 18.6.0-1 18.7.0-1
noise-suppression-for-voice 0.91-2 1.03-1
npm 8.14.0-1 8.15.1-1
npm-check-updates 14.0.2-1 15.0.0-1
nushell 0.65.0-1 0.66.2-1
ocaml-findlib 1.9.1-4 1.9.5-1
octave 7.1.0-4 7.2.0-1
oha 0.4.7-1 0.5.3-1
oil 0.11.0-1 0.12.0-1
opendht 1:2.4.7.2-1 1:2.4.9-1
openrct2 0.4.1-1 0.4.1-2
openscenegraph 3.6.5-13 3.6.5-14
openvswitch 2.16.1-3 2.16.4-1
ortp 5.1.45-1 5.1.51-1
osdlyrics 0.5.10-2 0.5.11-1
osinfo-db 20220516-1 20220727-1
pacman-bintrans 0.2.0-1 0.3.0-1
pacman-bintrans-tools 0.2.0-1 0.3.0-1
pam_mount 2.18-1 2.19-1
parallel 20220622-1 20220722-1
parallel-docs 20220622-1 20220722-1
pass 1.7.4-2 1.7.4-3
patchelf 0.14.5-1 0.15.0-1
pdal 2.4.2-2 2.4.2-3
perl-ppi 1.275-1 1.276-1
perl-sys-virt 7.9.0-2 8.5.0-1
perl-www-mechanize 2.10-1 2.12-1
pigar 0.10.0-4 1.0.0-1
plan9port 20211019-2 20220720-1
poco 1.11.3-1 1.12.1-1
postgis 3.2.1-1 3.2.1-2
powerdns 4.6.2-2 4.6.3-1
procs 0.12.3-1 0.13.0-1
proj 8.2.0-1 9.0.1-1
prometheus-systemd-exporter 0.4.0-1 0.5.0-1
pulumi 3.34.1-1 3.37.1-1
pyright 1.1.262-1 1.1.264-1
python-adblock 0.5.2-1 0.6.0-1
python-aiosqlite 0.17.0-3 0.17.0-4
python-apscheduler 3.8.1-1 3.9.1-1
python-arpeggio 1.10.2-3 2.0.0-1
python-astunparse 1.6.3-5 1.6.3-6
python-aws-sam-translator 1.47.0-1 1.48.0-1
python-beautifulsoup4 4.10.0-1 4.11.1-1
python-bleach 5.0.1-1 5.0.1-2
python-cfn-lint 0.61.3-1 0.61.4-1
python-cherrypy 18.6.1-4 18.8.0-1
python-click-didyoumean 0.2.0-1 0.3.0-1
python-configupdater 3.1-1 3.1.1-1
python-copr 1.116-1 1.120-1
python-cssselect2 0.5.0-1 0.6.0-1
python-deepdiff 5.7.0-1 5.8.0-1
python-dephell 0.8.3-7 -
python-dephell-archive 0.1.7-2 -
python-dephell-argparse 0.1.3-5 -
python-dephell-changelogs 0.0.1-6 -
python-dephell-discover 0.2.10-6 -
python-dephell-licenses 0.1.7-6 -
python-dephell-links 0.1.5-2 -
python-dephell-markers 1.0.3-2 -
python-dephell-pythons 0.1.15-4 -
python-dephell-setuptools 0.2.4-4 -
python-dephell-shells 0.1.5-3 -
python-dephell-specifier 0.2.2-5 -
python-dephell-venvs 0.1.18-2 -
python-dephell-versioning 0.1.2-5 -
python-django-sekizai 3.0.1-1 4.0.0-1
python-executing 0.8.3-1 0.9.1-1
python-fiona 1.8.21-1 1.8.21-2
python-flake8-isort 4.1.1-2 4.1.2-1
python-flask 2.1.2-1 2.1.3-1
python-flask-caching 1.10.1-3 2.0.1-1
python-flask-dance 5.1.0-1 6.0.0-1
python-freezegun 1.1.0-1 1.2.1-1
python-fuse 1.0.4-3 1.0.5-1
python-gdal 3.4.3-3 3.5.1-1
python-geopandas 0.11.0-1 0.11.1-1
python-gitlab 3.6.0-1 3.7.0-1
python-glfw 2.5.3-1 2.5.4-1
python-httplib2 0.20.3-1 0.20.4-1
python-hypothesmith 0.1.9-3 0.2.0-1
python-inflect 5.6.2-1 6.0.0-1
python-jaraco.test 5.0.0-4 5.1.0-1
python-jeepney 0.7.1-3 0.8.0-1
python-jmespath 1.0.0-1 1.0.1-1
python-jsonpointer 2.1-3 2.3-1
python-jsonschema-objects 0.3.15-2 0.4.1-1
python-kivy 2.0.0-4 2.1.0-1
python-lexicon 2.0.0-3 2.0.1-1
python-logilab-common 1.9.1-1 1.9.6-1
python-lsp-server 1.4.1-1 1.5.0-1
python-magnumclient 3.5.0-2 3.7.0-1
python-manuel 1.10.1-7 1.12.4-1
python-memory-profiler 0.58.0-3 0.60-1
python-minio 7.1.10-1 7.1.11-1
python-mysql-connector 8.0.29-1 8.0.30-1
python-openapi-spec-validator 0.3.1-4 0.4.0-1
python-orjson 3.7.8-1 3.7.11-1
python-osc-lib 2.6.0-1 2.6.1-1
python-pdm 1.15.4-2 2.1.0-1
python-pdm-pep517 1:0.12.7-1 1:1.0.3-1
python-pdoc 7.4.0-2 12.0.2-1
python-peewee 3.14.10-1 3.15.1-1
python-pendulum 2.1.2-5 2.1.2-6
python-phonenumbers 8.12.51-1 8.12.52-1
python-pivy 0.6.6-5 0.6.7-1
python-plyvel 1.3.0-2 1.4.0-1
python-poetry 1.1.14-1 1.1.14-2
python-precis_i18n 1.0.3-4 1.0.4-1
python-prettytable 2.3.0-1 3.3.0-1
python-psycopg 3.0.15-1 3.0.16-1
python-pyarrow 7.0.0-1 8.0.0-1
python-pycapnp 1.1.0-5 1.1.1-1
python-pydrive2 1.13.0-1 1.14.0-1
python-pykerberos 1.2.1-9 1.2.4-1
python-pylink-square 0.14.0-1 0.14.1-1
python-pylint 2.14.4-1 2.14.5-1
python-pymongo 4.0-1 4.2.0-1
python-pyogrio 0.4.0-1 0.4.0-2
python-pyproj 3.0.1-3 3.3.1-1
python-pypugjs 5.9.11-1 5.9.12-1
python-pyro 4.80-5 4.82-1
python-pytest-celery 0.0.0-3 0.0.0-4
python-pytest-enabler 1.2.1-2 1.3.0-1
python-pytest-flake8 1.0.7-3 1.1.1-1
python-pytest-mock 3.7.0-1 3.8.2-1
python-pytest-socket 0.5.0-1 0.5.1-1
python-pytzdata 2020.1-5 2020.1-6
python-pywayland 0.4.13-1 0.4.14-1
python-pywlroots 0.15.18-1 0.15.19-1
python-qiniu 7.8.0-1 7.9.0-1
python-r2pipe 5.4.0-2 5.7.0-1
python-redis 4.0.2-1 4.3.4-1
python-requirementslib 1.6.0-1 1.6.9-1
python-rjsmin 1.2.0-3 1.2.1-1
python-rpy2 3.5.2-1 3.5.3-1
python-rsa 4.8-3 4.9-1
python-rtree 0.9.7-4 1.0.0-1
python-rzpipe 0.1.0-2 0.4.0-1
python-scipy 1.8.1-1 1.9.0-1
python-secretstorage 3.3.1-3 3.3.2-1
python-semantic-version 2.9.0-1 2.10.0-1
python-solidpython 1.1.1-3 1.1.3-1
python-soupsieve 2.3.1-1 2.3.2.post1-1
python-sphinx 5.0.2-3 5.1.1-1
python-sphinx-autoapi 1.8.4-3 1.9.0-1
python-sphinx-autobuild 2020.09.01-2 2021.03.14-1
python-sphinx-inline-tabs 2020.10.19.beta4-5 2022.01.02.beta11-1
python-sphinx-theme-builder 0.2.0a12-2 0.2.0b1-1
python-sphinxcontrib-seqdiag 2.0.0-5 3.0.0-1
python-spyder-kernels 2.3.1-1 2.3.2-1
python-structlog 21.5.0-1 22.1.0-1
python-tftpy 0.8.0-4 0.8.2-1
python-typer 0.4.1-1 0.6.1-1
python-wand 0.6.7-3 0.6.8-1
python-weasyprint 56.0-1 56.1-1
python-xarray 2022.03.0-1 2022.06.0-1
python-xmlschema 1.9.2-1 1.11.3-1
python-z3 4.8.17-1 4.9.0-1
qcad 3.27.6.7-1 3.27.6.7-3
qgis 3.26.0-1 3.26.1-1
qmapshack 1.16.1-2 1.16.1-3
rekor 0.9.1-1 0.10.0-1
restinio 0.6.15-1 0.6.16-1
rnote 0.5.3-1 0.5.4-1
roundcubemail 1.5.3-1 1.6.0-1
ruby-diff-lcs 1.4.4-2 1.5.0-1
ruby-ed25519 1.2.4-4 1.3.0-1
ruby-multipart-post 2.1.1-3 2.2.3-1
ruby-pg 1.4.1-1 1.4.2-1
ruby-rake-compiler 1.1.1-2 1.2.0-1
ruby-rspec 3.10.0-1 3.11.0-1
ruby-rspec-core 3.10.1-1 3.11.0-1
ruby-rspec-expectations 3.10.1-1 3.11.0-1
ruby-rspec-mocks 3.10.2-1 3.11.1-1
ruby-rspec-support 3.10.2-1 3.11.0-1
ruby-rugged 1.4.3-1 1.4.3-2
rust-analyzer 20220718-1 20220725-1
scrapy 2.5.1-1 2.6.2-1
sd 0.7.6-1 0.7.6-2
selene-linter 0.19.1-1 0.20.0-1
serd 0.30.12-2 0.30.14-1
shellharden 4.2.0-2 4.3.0-1
shotgun 2.2.1-1 2.3.0-1
skopeo 1.9.0-1 1.9.1-1
skrooge 2.27.0-4 2.28.0-1
sndio 1.8.1-2 1.9.0-1
sord 0.16.10-2 0.16.12-3
spyder 5.3.1-1 5.3.2-2
stellarsolver 2.3-1 2.4-1
strawberry 1.0.6-1 1.0.7-1
stylua 0.14.1-1 0.14.2-1
supertux 0.6.3-3 0.6.3-4
sweethome3d 6.6-4 7.0.2-1
taskwarrior-tui 0.23.4-1 0.23.5-1
tekton-cli 0.23.1-1 0.25.0-2
terraform 1.2.3-1 1.2.6-1
tilix 1.9.5-2 1.9.5-3
timescaledb 2.7.0-1 2.7.2-1
timescaledb-old-upgrade 2.7.0-1 2.7.2-1
translate-toolkit 3.7.1-1 3.7.2-1
trivy 0.30.2-1 0.30.4-1
ttf-joypixels 6.6.0-2 7.0.0-1
ttf-sarasa-gothic 0.36.7-1 0.36.8-1
uglify-js 3.16.2-1 3.16.3-1
v2ray-domain-list-community 20220721123730-1 20220730021420-1
v2ray-geoip 202207210057-1 202207280056-1
vaultwarden 1.25.0-1 1.25.2-1
vaultwarden-web 2022.6.0-1 2022.6.2-1
visidata 2.9-1 2.9.1-1
vtk 9.1.0-18 9.1.0-19
waifu2x-ncnn-vulkan 20220419-2 20220728-1
wallutils 5.10.0-3 5.11.1-1
warpinator 1.2.12-1 1.2.13-1
wasmer 2.3.0-1 2.3.0-2
wireshark-cli 3.6.6-1 3.6.7-1
wireshark-qt 3.6.6-1 3.6.7-1
xapp 2.2.13-1 2.2.14-1
xed 3.2.5-1 3.2.7-1
xine-lib 1.2.12-1 1.2.12-2
xreader 3.4.1-1 3.4.2-1
yq 3.0.2-1 3.1.0-1
z3 4.8.17-1 4.9.0-1
zellij 0.30.0-1 0.31.0-1
zint 2.10.0-2 2.11.0-1
zint-qt 2.10.0-2 2.11.0-1
zutty 0.11-2 0.12-1
audacity-docs - 1:3.1.3-1
debian-ports-archive-keyring - 2022.02.15-1
gitsign - 0.2.0-2
gum - 0.2.0-4
intel-oneapi-common - 2022.1.0-2
intel-oneapi-compiler-dpcpp-cpp-runtime - 2022.1.0-1
intel-oneapi-compiler-shared-runtime - 2022.1.0-2
intel-oneapi-mkl - 2022.1.0_223-3
intel-oneapi-openmp - 2022.1.0-3
intel-oneapi-tbb - 2021.6.0-2
libretro-mame2016 - 44430-1
libsbsms - 2.3.0-3
mxml-docs - 3.3.1-1
openslide - 3.4.1-3
pc-ble-driver - 4.1.4-3
python-click-command-tree - 1.1.0-1
python-hatch-vcs - 0.2.0-1
python-pc-ble-driver-py - 0.17.0-1
python-piccata - 2.0.1-1
python-pyproject-metadata - 0.6.1-1
python-pyspinel - 1.0.3-1
python-pytest-httpserver - 1.0.5-1
python-requests-gssapi - 1.2.3-2
python-unearth - 0.6.1-1
python-whatthepatch - 1.0.2-1
serd-docs - 0.30.14-1
sord-docs - 0.16.12-3
umoci - 0.4.7-2
:: Different overlay package(s) in repository core aarch64
linux 5.18.13-1 5.18.14-1
linux-clockworkpi-a06 5.18.13-1 5.18.15-1
linux-clockworkpi-a06-headers 5.18.13-1 5.18.15-1
linux-headers 5.18.13-1 5.18.14-1
linux-khadas 5.18.12-1 5.18.14-1
linux-khadas-headers 5.18.12-1 5.18.14-1
linux-lts 5.15.56-1 5.15.58-1
linux-lts-headers 5.15.56-1 5.15.58-1
linux-odroid 5.18.12-1 5.18.12-2
linux-odroid-headers 5.18.12-1 5.18.12-2
linux-pinephone 5.18.12-1 5.18.15-1
linux-pinephone-headers 5.18.12-1 5.18.15-1
linux-pinephonepro 5.18.12-1 5.18.15-1
linux-pinephonepro-headers 5.18.12-1 5.18.15-1
linux-quartz64 5.19.0-0.4 5.19.0-0.5
linux-quartz64-headers 5.19.0-0.4 5.19.0-0.5
linux-rc 5.19.rc7-1 5.19.rc8-1
linux-rc-headers 5.19.rc7-1 5.19.rc8-1
manjaro-keyring 20220514-1 20220514-2
:: Different sync package(s) in repository core aarch64
archlinux-keyring 20220713-1 20220727-1
archlinuxarm-keyring 20140119-1 20140119-2
base 2-2 3-1
ca-certificates-mozilla 3.80-1 3.81-1
cryptsetup 2.4.3-2 2.5.0-1
iptables 1:1.8.8-1 1:1.8.8-2
iptables-nft 1:1.8.8-1 1:1.8.8-2
libcap 2.64-1 2.65-1
logrotate 3.19.0-1 3.20.1-1
nss 3.80-1 3.81-1
:: Different overlay package(s) in repository extra aarch64
appstream-glib 0.7.18-3 -
bootsplash-viewer 1.1-1 1.1-2
mesa-git22.2.0_devel.156755.81d85be9a5cf-122.2.0_devel.157428.5780ea90c4d9-1
qt5-es2-base 5.15.5+kde+r170-1 5.15.5+kde+r174-1
qt5-es2-wayland 5.15.5+kde+r38-1 5.15.5+kde+r38-2
qt5-es2-xcb-private-headers 5.15.5+kde+r170-1 5.15.5+kde+r174-1
:: Different sync package(s) in repository extra aarch64
389-ds-base 2.2.1-1 2.2.2-1
accerciser 3.38.0-3 3.40.0-1
aiksaurus 1.2.1-7 1.2.1-9
arch-install-scripts 25-2 26-1
archlinux-appstream-data 20220618-1 20220727-1
avogadrolibs 1.96.0-2 1.97.0-1
avogadrolibs-qt5 1.96.0-2 1.97.0-1
babl 0.1.90-2 0.1.92-1
bind 9.18.4-1 9.18.5-1
cmake 3.23.2-2 3.23.3-1
ddcutil 1.2.2-2 1.3.0-1
expect 5.45.4-2 5.45.4-3
firefox 102.0.1-1 103.0.1-1
firefox-i18n-ach 102.0.1-1 103.0.1-1
firefox-i18n-af 102.0.1-1 103.0.1-1
firefox-i18n-an 102.0.1-1 103.0.1-1
firefox-i18n-ar 102.0.1-1 103.0.1-1
firefox-i18n-ast 102.0.1-1 103.0.1-1
firefox-i18n-az 102.0.1-1 103.0.1-1
firefox-i18n-be 102.0.1-1 103.0.1-1
firefox-i18n-bg 102.0.1-1 103.0.1-1
firefox-i18n-bn 102.0.1-1 103.0.1-1
firefox-i18n-br 102.0.1-1 103.0.1-1
firefox-i18n-bs 102.0.1-1 103.0.1-1
firefox-i18n-ca 102.0.1-1 103.0.1-1
firefox-i18n-ca-valencia 102.0.1-1 103.0.1-1
firefox-i18n-cak 102.0.1-1 103.0.1-1
firefox-i18n-cs 102.0.1-1 103.0.1-1
firefox-i18n-cy 102.0.1-1 103.0.1-1
firefox-i18n-da 102.0.1-1 103.0.1-1
firefox-i18n-de 102.0.1-1 103.0.1-1
firefox-i18n-dsb 102.0.1-1 103.0.1-1
firefox-i18n-el 102.0.1-1 103.0.1-1
firefox-i18n-en-ca 102.0.1-1 103.0.1-1
firefox-i18n-en-gb 102.0.1-1 103.0.1-1
firefox-i18n-en-us 102.0.1-1 103.0.1-1
firefox-i18n-eo 102.0.1-1 103.0.1-1
firefox-i18n-es-ar 102.0.1-1 103.0.1-1
firefox-i18n-es-cl 102.0.1-1 103.0.1-1
firefox-i18n-es-es 102.0.1-1 103.0.1-1
firefox-i18n-es-mx 102.0.1-1 103.0.1-1
firefox-i18n-et 102.0.1-1 103.0.1-1
firefox-i18n-eu 102.0.1-1 103.0.1-1
firefox-i18n-fa 102.0.1-1 103.0.1-1
firefox-i18n-ff 102.0.1-1 103.0.1-1
firefox-i18n-fi 102.0.1-1 103.0.1-1
firefox-i18n-fr 102.0.1-1 103.0.1-1
firefox-i18n-fy-nl 102.0.1-1 103.0.1-1
firefox-i18n-ga-ie 102.0.1-1 103.0.1-1
firefox-i18n-gd 102.0.1-1 103.0.1-1
firefox-i18n-gl 102.0.1-1 103.0.1-1
firefox-i18n-gn 102.0.1-1 103.0.1-1
firefox-i18n-gu-in 102.0.1-1 103.0.1-1
firefox-i18n-he 102.0.1-1 103.0.1-1
firefox-i18n-hi-in 102.0.1-1 103.0.1-1
firefox-i18n-hr 102.0.1-1 103.0.1-1
firefox-i18n-hsb 102.0.1-1 103.0.1-1
firefox-i18n-hu 102.0.1-1 103.0.1-1
firefox-i18n-hy-am 102.0.1-1 103.0.1-1
firefox-i18n-ia 102.0.1-1 103.0.1-1
firefox-i18n-id 102.0.1-1 103.0.1-1
firefox-i18n-is 102.0.1-1 103.0.1-1
firefox-i18n-it 102.0.1-1 103.0.1-1
firefox-i18n-ja 102.0.1-1 103.0.1-1
firefox-i18n-ka 102.0.1-1 103.0.1-1
firefox-i18n-kab 102.0.1-1 103.0.1-1
firefox-i18n-kk 102.0.1-1 103.0.1-1
firefox-i18n-km 102.0.1-1 103.0.1-1
firefox-i18n-kn 102.0.1-1 103.0.1-1
firefox-i18n-ko 102.0.1-1 103.0.1-1
firefox-i18n-lij 102.0.1-1 103.0.1-1
firefox-i18n-lt 102.0.1-1 103.0.1-1
firefox-i18n-lv 102.0.1-1 103.0.1-1
firefox-i18n-mk 102.0.1-1 103.0.1-1
firefox-i18n-mr 102.0.1-1 103.0.1-1
firefox-i18n-ms 102.0.1-1 103.0.1-1
firefox-i18n-my 102.0.1-1 103.0.1-1
firefox-i18n-nb-no 102.0.1-1 103.0.1-1
firefox-i18n-ne-np 102.0.1-1 103.0.1-1
firefox-i18n-nl 102.0.1-1 103.0.1-1
firefox-i18n-nn-no 102.0.1-1 103.0.1-1
firefox-i18n-oc 102.0.1-1 103.0.1-1
firefox-i18n-pa-in 102.0.1-1 103.0.1-1
firefox-i18n-pl 102.0.1-1 103.0.1-1
firefox-i18n-pt-br 102.0.1-1 103.0.1-1
firefox-i18n-pt-pt 102.0.1-1 103.0.1-1
firefox-i18n-rm 102.0.1-1 103.0.1-1
firefox-i18n-ro 102.0.1-1 103.0.1-1
firefox-i18n-ru 102.0.1-1 103.0.1-1
firefox-i18n-sco 102.0.1-1 103.0.1-1
firefox-i18n-si 102.0.1-1 103.0.1-1
firefox-i18n-sk 102.0.1-1 103.0.1-1
firefox-i18n-sl 102.0.1-1 103.0.1-1
firefox-i18n-son 102.0.1-1 103.0.1-1
firefox-i18n-sq 102.0.1-1 103.0.1-1
firefox-i18n-sr 102.0.1-1 103.0.1-1
firefox-i18n-sv-se 102.0.1-1 103.0.1-1
firefox-i18n-szl 102.0.1-1 103.0.1-1
firefox-i18n-ta 102.0.1-1 103.0.1-1
firefox-i18n-te 102.0.1-1 103.0.1-1
firefox-i18n-th 102.0.1-1 103.0.1-1
firefox-i18n-tl 102.0.1-1 103.0.1-1
firefox-i18n-tr 102.0.1-1 103.0.1-1
firefox-i18n-trs 102.0.1-1 103.0.1-1
firefox-i18n-uk 102.0.1-1 103.0.1-1
firefox-i18n-ur 102.0.1-1 103.0.1-1
firefox-i18n-uz 102.0.1-1 103.0.1-1
firefox-i18n-vi 102.0.1-1 103.0.1-1
firefox-i18n-xh 102.0.1-1 103.0.1-1
firefox-i18n-zh-cn 102.0.1-1 103.0.1-1
firefox-i18n-zh-tw 102.0.1-1 103.0.1-1
gedit 42.1-1 42.2-1
gegl 0.4.36-3 0.4.38-1
gsm 1.0.19-1 1.0.20-1
harfbuzz 4.4.1-1 5.0.1-1
harfbuzz-icu 4.4.1-1 5.0.1-1
hwloc 2.7.1-1 2.8.0-1
imagemagick 7.1.0.43-1 7.1.0.45-1
imagemagick-doc 7.1.0.43-1 7.1.0.45-1
iso-codes 4.10.0-1 4.11.0-1
ispell 3.4.04-1 3.4.05-1
jdk8-openjdk 8.u312-2 8.u322-1
jre8-openjdk 8.u312-2 8.u322-1
jre8-openjdk-headless 8.u312-2 8.u322-1
js91 91.11.0-1 91.12.0-1
lame 3.100-3 3.100-4
ldb 2:2.5.1-1 2:2.5.2-1
lib2geom 1.1-2 1.2-1
libmm-glib 1.18.10-1 1.18.10-2
libphonenumber 1:8.12.52-1 1:8.12.52-3
libplacebo 4.192.1-3 4.208.0-1
libspiro 1:20200505-2 1:20220722-1
libtiff 4.4.0-1 4.4.0-3
libtorrent-rasterbar 1:2.0.6-2 1:2.0.7-1
libuv 1.43.0-1 1.44.2-1
libva-mesa-driver 22.1.3-1 22.1.4-1
llvm 14.0.6-1 14.0.6-2
llvm-libs 14.0.6-1 14.0.6-2
mercurial 6.2-1 6.2.1-1
mesa 22.1.3-1 22.1.4-1
mesa-vdpau 22.1.3-1 22.1.4-1
mobile-broadband-provider-info 20220511-1 20220725-1
modemmanager 1.18.10-1 1.18.10-2
opencl-mesa 22.1.3-1 22.1.4-1
openjdk8-src 8.u312-2 8.u322-1
ostree 2022.4-1 2022.5-1
perl-libwww 6.60-2 6.67-1
plasma-wayland-session 5.25.3.1-1 5.25.3.1-2
plasma-workspace 5.25.3.1-1 5.25.3.1-2
protobuf 21.2-1 21.4-1
psutils 2.05-1 2.09-1
python-feedparser 6.0.3-1 6.0.10-1
python-numpy 1.23.0-1 1.23.1-1
python-pip 22.1.2-1 22.2.1-1
python-platformdirs 2.5.1-1 2.5.2-1
python-protobuf 21.2-1 21.4-1
python-trove-classifiers 2022.6.26-1 2022.7.22-1
qt5-base 5.15.5+kde+r172-1 5.15.5+kde+r174-1
qt5-wayland 5.15.5+kde+r38-1 5.15.5+kde+r38-3
qt5-xcb-private-headers 5.15.5+kde+r172-1 5.15.5+kde+r174-1
rrdtool 1.7.2-11 1.8.0-1
samba 4.16.3-1 4.16.4-1
smbclient 4.16.3-1 4.16.4-1
tbb 2021.5.0-1 2021.5.0-2
uhttpmock 0.5.3-1 0.5.5-1
vlc 3.0.17.4-6 3.0.17.4-7
vulkan-broadcom 22.1.3-1 22.1.4-1
vulkan-mesa-layers 22.1.3-1 22.1.4-1
vulkan-panfrost 22.1.3-1 22.1.4-1
vulkan-radeon 22.1.3-1 22.1.4-1
vulkan-swrast 22.1.3-1 22.1.4-1
wavpack 5.4.0-1 5.5.0-1
webkit2gtk 2.36.4-2 2.36.5-1
webkit2gtk-4.1 2.36.4-2 2.36.5-1
webkit2gtk-5.0 2.36.4-2 2.36.5-1
wpewebkit 2.36.4-2 2.36.5-1
zabbix-agent 6.2.0-1 6.2.1-2
zabbix-agent2 6.2.0-1 6.2.1-2
zabbix-frontend-php 6.2.0-1 6.2.1-2
zabbix-proxy 6.2.0-1 6.2.1-2
zabbix-server 6.2.0-1 6.2.1-2
appstream-glib - 0.8.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.04.3.r12795.g425666ba7-122.04.3.r12797.g5e6620486-1
akonadi-calendar22.04.3.r2142.gd82e700-122.04.3.r2148.g6f8be46-1
akonadi-calendar-tools22.04.3.r957.g97ab528-122.04.3.r959.g9e027c8-1
akonadi-contacts22.04.3.r3229.ge11e12c3-122.04.3.r3233.gaa2fe31b-1
akonadi-import-wizard22.04.2.r1836.gcaddfee-122.04.3.r1841.g7bc967b-1
akonadi-mime22.04.3.r1746.g8e3618b-122.04.3.r1749.g53c13b4-1
akonadi-notes22.04.3.r1081.ge598e6a-122.04.3.r1083.g6a1a413-1
akonadi-search22.04.3.r1250.g996f4a5-122.04.3.r1253.gbf732e7-1
akonadiconsole22.04.2.r1598.g71db2cb-122.04.3.r1602.gee6df9c-1
akregator22.04.2.r6444.g56c9f484-122.04.3.r6456.ge98d960c-1
alligator 22.06.r22.ge37b88b-1 22.06.r26.g1dcaced-1
analitza22.04.3.r2355.g4637e049-122.04.3.r2356.gc2e4500d-1
angelfish 22.06.r21.g4ab1280-1 22.06.r24.g48cd9a7-1
ark22.04.3.r4820.g239f99d3-122.04.3.r4823.g55f774bd-1
artikulate22.04.3.r1424.g5696807-122.04.3.r1425.g1066b70-1
attica5.96.0.r876.g694daa4-15.96.0.r878.g9e2a404-1
audiocd-kio22.04.3.r1094.g8f766a9-122.04.3.r1101.g059a3f8-1
audiotube 22.06.r17.g56ffb52-1 22.06.r19.gef59e9d-1
aura-browser r54.ff5a74a-1 r55.80b7f15-1
baloo-widgets22.04.3.r763.gf93b9a3-122.04.3.r764.ge7669e5-1
blinken22.04.3.r674.gd2f67e7-122.04.3.r676.gc226950-1
bluedevil1:5.25.3.r2416.g65656cba-11:5.25.3.r2425.g69532493-1
bomber22.04.3.r570.gbe88435-122.04.3.r571.gb7c2acf-1
breeze5.25.3.r2432.gc0f7505c-15.25.3.r2434.g737ef761-1
calendarsupport22.04.2.r716.g955489f-122.04.3.r719.g0d93a55-1
calindori 22.06.r8.g8553328-1 22.06.r9.g1b8b909-1
cervisia22.04.3.r1688.gbf242b9-122.04.3.r1689.ge08a02a-1
discover5.25.3.r8742.gcd2b9b05-15.25.3.r8769.g268f98e5-1
dolphin22.04.3.r7050.gd0c3e373a-122.04.3.r7054.gd7ca76799-1
drkonqi5.25.3.r809.g80efd753-15.25.3.r811.gf58645f1-1
elisa22.04.3.r3000.g137dc97f-122.04.3.r3002.gdd57c124-1
elisa-qtmm22.04.3.r3000.g137dc97f-122.04.3.r3002.gdd57c124-1
eventviews22.04.2.r857.gb612b23-122.04.3.r862.g17c0b0e-1
ffmpegthumbs22.04.3.r224.gd56f12a-122.04.3.r227.g8f27039-1
filelight22.04.3.r1155.g7d2f734-122.04.3.r1157.gdc184ef-1
frameworkintegration5.96.0.r646.g8d61097-15.96.0.r647.g817408a-1
grantlee-editor22.04.2.r826.gebb27ca-122.04.3.r831.g1a1dd3a-1
grantleetheme22.04.3.r406.g6816d83-122.04.3.r407.g2bc2e26-1
gwenview22.04.2.r6875.g6f2203fb-122.04.3.r6887.gb948a072-1
incidenceeditor22.04.2.r908.gd73a8db-122.04.3.r912.gd7141d5-1
itinerary22.04.3.r1961.gd2cf370-122.04.3.r1970.g6f1f8b2-1
juk22.04.3.r3167.g03eb4fc3-122.04.3.r3168.gb8f64903-1
k3b1:22.04.3.r6807.ga8f810d6a-11:22.04.3.r6808.g27ac23378-1
kaccounts-integration22.04.3.r1266.g6e872ab-122.04.3.r1268.gfd1d35c-1
kaccounts-providers22.04.3.r400.gdeeece1-122.04.3.r401.g897a4ed-1
kactivitymanagerd5.25.3.r1412.g6b9a376-15.25.3.r1413.gc562bf6-1
kaddressbook22.04.2.r6213.g8588e4eb-122.04.3.r6225.g7f5e4c61-1
kajongg22.04.2.r4345.g075109cd-122.04.3.r4347.g86f0115c-1
kalarm22.04.3.r7966.g387f37e3-122.04.3.r7972.g5ac7ad15-1
kalk 22.06.r9.g52b84ad-1 22.06.r13.ga060835-1
kanagram22.04.3.r1318.g8437164-122.04.3.r1319.g9180818-1
kapidox5.96.0.r573.gabf4756-15.96.0.r574.g13f1157-1
kasts 22.06.r29.g91de33f-1 22.06.r32.g8844d94-1
kate22.04.3.r19251.g2a72944b0-122.04.3.r19266.ga8b4c0f44-1
kbackup22.04.3.r447.gc03a8d9-122.04.3.r449.g7d24781-1
kblackbox22.04.3.r774.g8428377-122.04.3.r775.g8a71905-1
kblocks22.04.3.r749.g7250568-122.04.3.r751.g599c64d-1
kbruch22.04.3.r872.gbe4aa00-122.04.3.r873.gab39884-1
kcalc22.04.3.r1622.ga2ad8a3-122.04.3.r1626.g0157bea-1
kcalutils22.04.3.r978.g9a68537fa-122.04.3.r980.ge39d4f073-1
kclock 22.06.r14.g16989c8-1 22.06.r22.gf23328a-1
kcolorchooser22.04.3.r277.gdb41f6d-122.04.3.r278.ge237116-1
kcontacts1:5.96.0.r3341.gcabbaf31-11:5.96.0.r3342.gdff759f2-1
kcoreaddons5.96.0.r1532.gdf8a2f6b-15.96.0.r1540.gfadef3bb-1
kde-cli-tools5.25.3.r1945.g5d1ed28-15.25.3.r1947.ge85be44-1
kde-gtk-config5.25.3.r938.gda46494-15.25.3.r939.g3c56cb7-1
kdebugsettings22.04.3.r949.g5890609-122.04.3.r955.g6967cdc-1
kdeclarative5.96.0.r1016.g8666822-15.96.0.r1018.g92b6cf0-1
kdeconnect22.04.3.r3494.geefdf0c5-122.04.3.r3505.g1c65ede5-1
kdegraphics-thumbnailers22.04.3.r274.g1359130-122.04.3.r275.g90f30e3-1
kdelibs4support5.96.0.r1098.g72f301e4-15.96.0.r1100.g7cf36906-1
kdenetwork-filesharing22.04.3.r961.gbc35019-122.04.3.r964.gc177fc3-1
kdenlive22.04.3.r16404.gfab80c851-122.04.3.r16463.g382ec1a0c-1
kdepim-addons22.04.2.r4698.g4281d604b-122.04.3.r4733.gc10a61798-1
kdepim-runtime22.04.3.r15560.ga9f36a1b6-122.04.3.r15565.gdac8964cd-1
kdeplasma-addons5.25.3.r8938.g4f6891294-15.25.3.r8967.g8b918d58b-1
kdf22.04.3.r866.g2d1bcf1-122.04.3.r867.g822be92-1
kdiamond22.04.3.r731.gd2acca8-122.04.3.r732.g6207f90-1
keysmith 22.06.r9.gab97a00-1 22.06.r17.g9d403f6-1
kfind22.04.3.r2707.gce0bdd888-122.04.3.r2708.gf40bc0d4b-1
kfloppy22.04.3.r798.ged6a909-122.04.3.r799.gf7ef5df-1
kget22.04.3.r3216.g3682529a-122.04.3.r3217.gbd08a346-1
kgoldrunner22.04.3.r1290.g9270c9b-122.04.3.r1293.gab710ef-1
kgpg22.04.3.r3197.gc45271cd-122.04.3.r3199.g22092caf-1
kguiaddons5.96.0.r480.gbabf1aa-15.96.0.r481.ga3b46ae-1
khangman22.04.3.r1619.gca39294-122.04.3.r1621.gfd91cfe-1
khealthcertificate 22.06.r0.gd34cbfe-1 22.06.r12.gd20ebea-1
khelpcenter22.04.3.r2759.g1bfabb70-122.04.3.r2767.g2b26e275-1
khotkeys5.25.3.r2151.g292cd1d-15.25.3.r2154.gf725bc7-1
kiconthemes5.96.0.r614.g524cc07-15.96.0.r615.g9095ef7-1
kidentitymanagement22.04.3.r3894.g490e2cd4-122.04.3.r3896.g95be9356-1
kigo22.04.3.r576.g0bcdcce-122.04.3.r577.g0aa6d0a-1
killbots22.04.3.r800.g5357bac-122.04.3.r801.ge083b35-1
kimageformats5.96.0.r419.gd030c75-15.96.0.r421.g6074c4d-1
kimap22.04.3.r1200.gc0d4834-122.04.3.r1203.g85c570f-1
kinfocenter5.25.3.r2124.ge928b457-15.25.3.r2129.g59184a24-1
kio5.96.0.r5595.gc6207ee11-15.96.0.r5617.gbef623c10-1
kio-extras22.04.3.r7302.g2b4ec3a8-122.04.3.r7314.g2430179b-1
kio-gdrive22.04.3.r620.g8a6015c-122.04.3.r622.g85bd479-1
kirigami-gallery22.04.3.r256.g09384d4-122.04.3.r259.gf983f28-1
kirigami25.96.0.r3184.g1b19825b-15.96.0.r3187.g07959ea6-1
kiriki22.04.3.r457.gf91e1d2-122.04.3.r458.g9484807-1
kitemmodels5.96.0.r613.g8f6edf9-15.96.0.r614.g8d0117c-1
kiten22.04.3.r1204.g30d55af-122.04.3.r1206.g07564c4-1
kitinerary22.04.3.r2328.gf19e8f4-122.04.3.r2340.g9c83d2e-1
kjs5.96.0.r365.g782fef5-15.96.0.r367.gd1b8856-1
kjumpingcube22.04.3.r829.gec18caf-122.04.3.r830.g1dfa2f1-1
kldap22.04.3.r958.g09889e4-122.04.3.r960.gf0ea918-1
kleopatra22.04.3.r6697.ga71ac7b3-122.04.3.r6723.gaf5904e2-1
klettres22.04.3.r970.g2f8b05f-122.04.3.r971.g76432f8-1
klickety22.04.3.r701.geb808ff-122.04.3.r703.gbc1c850-1
klines22.04.3.r824.g7911d74-122.04.3.r829.g1a1611f-1
kmag22.04.3.r742.gb02aa68-122.04.3.r743.g99e4aaf-1
kmahjongg22.04.3.r1565.g6d8fc1b-122.04.3.r1567.g6df1f7f-1
kmail22.04.2.r26440.ge666c1ea4-122.04.3.r26463.ge277afc67-1
kmail-account-wizard22.04.2.r890.g5b15131-122.04.3.r894.gf27b1fb-1
kmailtransport22.04.3.r1751.gd05322e-122.04.3.r1753.g15578ec-1
kmbox22.04.3.r603.g29bb1b6-122.04.3.r605.g818a148-1
kmenuedit5.25.3.r1054.ge07192d-15.25.3.r1058.g372bd9e-1
kmime22.04.3.r1522.g16fb26b-122.04.3.r1523.ge9ebffa-1
kmines22.04.3.r1772.ga4000b6-122.04.3.r1773.g9b0543f-1
kmix22.04.3.r2455.g77494fc6-122.04.3.r2456.gae08af55-1
kmousetool22.04.3.r449.gf5bc443-122.04.3.r451.gec55edf-1
kmouth22.04.3.r734.g7d73167-122.04.3.r735.gea167b1-1
kmplot22.04.3.r1501.gd71227e-122.04.3.r1502.g5cd3999-1
knetwalk22.04.3.r706.g4c5c5f5-122.04.3.r707.g800f644-1
knewstuff5.96.0.r1367.g6b941efe-15.96.0.r1368.g3bf2a1f2-1
knotes22.04.2.r3676.g75d403e5-122.04.3.r3685.g85f97513-1
knotifications5.96.0.r751.gc66aea1-15.96.0.r752.gb83d890-1
koko 22.06.r9.gc8e4141-1 22.06.r12.g8a3a8bc-1
kolf22.04.3.r1514.ge9edb64-122.04.3.r1515.gcd146ae-1
kollision22.04.3.r541.g9e8398b-122.04.3.r542.g4223584-1
kolourpaint22.04.3.r2425.g8b6d4d1b-122.04.3.r2429.gb5116cfc-1
kongress 22.06.r10.ge9b588f-1 22.06.r12.g4126d2f-1
konqueror22.04.3.r15131.g1d7ed315e-122.04.3.r15134.g12e4f8431-1
konquest22.04.3.r937.g82baf47-122.04.3.r938.gf977f64-1
konsole22.04.3.r8554.g05a4d489-122.04.3.r8562.g036be9ee-1
kontact22.04.2.r5546.g3f092aac-122.04.3.r5556.gd7c715b9-1
kontactinterface22.04.3.r701.g8dc1cca-122.04.3.r703.gf628539-1
konversation22.04.3.r9131.g4d441ef8-122.04.3.r9132.gd0ca8bf5-1
kopete22.04.3.r16444.gae623c90d-122.04.3.r16446.gd5d42981c-1
korganizer22.04.2.r11762.g3a95821a7-122.04.3.r11780.gf25a8724e-1
kosmindoormap22.04.3.r745.gd64ad4d-122.04.3.r746.gafe12ac-1
kpackage5.96.0.r759.ge8b40d7-15.96.0.r760.g74bf92c-1
kparts5.96.0.r592.g58357be-15.96.0.r594.g4743e72-1
kpat22.04.3.r2626.g6d53abc5-122.04.3.r2627.gdd62a1ab-1
kpeople5.96.0.r1380.gea10047-15.96.0.r1381.ge9b7118-1
kpeoplevcard 0.1.r22.g041b88b-1 0.1.r23.ga63a61d-1
kpimtextedit22.04.3.r1609.g9095e0b-122.04.3.r1610.gcd1a992-1
kpkpass22.04.3.r302.g19d9f17-122.04.3.r303.gb52e9dd-1
kpmcore22.04.3.r1293.g1ec8b8b-122.04.3.r1294.gf01581f-1
kpublictransport22.04.3.r2033.g58994c55-122.04.3.r2038.g704136b5-1
krdc22.04.3.r1610.g6b9f4c1-122.04.3.r1617.g6953f60-1
krecorder 22.06.r9.g182d96f-1 22.06.r10.g7551196-1
kreversi22.04.3.r1276.gd267028-122.04.3.r1277.ge439d6c-1
kruler22.04.3.r739.g56ea9fe-122.04.3.r742.g7a29873-1
krunner5.96.0.r776.gef20c81-15.96.0.r778.g1fcb430-1
kscreen5.25.3.r1491.g387fda6-15.25.3.r1505.ge15d173-1
kscreenlocker5.25.3.r969.g51ae818-15.25.3.r972.g87f3043-1
ksirk22.04.3.r1037.gaefec34-122.04.3.r1040.g0f6e3dc-1
ksmtp22.04.3.r453.g09909c6-122.04.3.r454.g7efcbbb-1
kspaceduel22.04.3.r679.g9766b8b-122.04.3.r680.g87cab42-1
ksudoku22.04.3.r1123.g61a004a-122.04.3.r1125.g56f3503-1
ksysguard5.25.3.r3537.g47f5443b-15.25.3.r3538.g13734f4d-1
ksystemlog22.04.3.r738.g75a35bc-122.04.3.r743.g59d0474-1
kteatime22.04.3.r763.g24b20aa-122.04.3.r764.g8bcc6b3-1
ktexteditor5.96.0.r3440.g623703c7-15.96.0.r3442.g9dd9142e-1
ktimer22.04.3.r524.gafb0cec-122.04.3.r527.g11ffead-1
ktnef22.04.3.r723.gd2cd453-122.04.3.r725.gcde8001-1
ktorrent22.04.3.r2868.gce4aef3c-122.04.3.r2871.gefcfdaa3-1
ktouch22.04.3.r2191.gdfd4dfa-122.04.3.r2195.gd290b2a-1
ktrip 22.06.r8.g162e6ef-1 22.06.r9.g649ae9b-1
ktuberling22.04.3.r1065.g75e542e-122.04.3.r1072.gcd78e2a-1
kubrick22.04.3.r413.gb7f7406-122.04.3.r416.gc7023a4-1
kwallet5.96.0.r1163.g47ed32b-15.96.0.r1165.gcc873f6-1
kwalletmanager22.04.3.r1280.gb6c61f2-122.04.3.r1282.gc6579ba-1
kwave22.04.3.r3800.gb5ccf044-122.04.3.r3801.gac141b3f-1
kweather 22.06.r16.gc572d1b-1 22.06.r25.gb729666-1
kwidgetsaddons5.96.0.r952.g8bce29ac-15.96.0.r959.ge3465ead-1
kwin5.25.3.r22827.gb6cf576ef-15.25.3.r22868.gbd8d65a86-1
kwindowsystem5.96.0.r688.gcf30501-15.96.0.r689.gaf80173-1
kwrite22.04.3.r19251.g2a72944b0-122.04.3.r19266.ga8b4c0f44-1
kwrited5.25.3.r513.g1fd988d-15.25.3.r514.g2a65ab9-1
kxmlgui5.96.0.r894.g59affd7d-15.96.0.r898.g072c1e8e-1
libakonadi22.04.3.r12795.g425666ba7-122.04.3.r12797.g5e6620486-1
libgravatar22.04.2.r427.gd78f119-122.04.3.r431.gddf44e2-1
libkcddb22.04.3.r764.ga779c9f-122.04.3.r765.g5088301-1
libkdepim22.04.3.r918.g9472b5b-122.04.3.r920.g4a76d55-1
libkgapi22.04.3.r1370.g3246ebd-122.04.3.r1371.gd1e1cbf-1
libkleo22.04.3.r1221.g1be06ea-122.04.3.r1240.g07e762c-1
libkmahjongg22.04.3.r485.g63e3d24-122.04.3.r486.ga227949-1
libkscreen5.25.3.r1633.gf6c8db3-15.25.3.r1634.g4004b09-1
libksieve22.04.2.r1723.g911ef126-122.04.3.r1733.g087d103a-1
libksysguard5.25.3.r2420.g481a0eb-15.25.3.r2425.g9a01468-1
lskat22.04.3.r860.gbf65356-122.04.3.r862.g1426b3a-1
mailcommon22.04.2.r1255.g4d4ebcf-122.04.3.r1269.g5f8ee03-1
mailimporter22.04.2.r524.g20a7033-122.04.3.r528.g077ecad-1
marble22.04.3.r13457.g9549f409a-122.04.3.r13459.g4aac89480-1
marble-common22.04.3.r13457.g9549f409a-122.04.3.r13459.g4aac89480-1
marble-qt22.04.3.r13457.g9549f409a-122.04.3.r13459.g4aac89480-1
markdownpart22.04.3.r130.gaabaf84-122.04.3.r131.g8f0d5b2-1
maui-clip 2.1.2.r8.gccab67d-1 2.1.2.r11.gb56ee85-1
maui-shell 0.5.0.r52.gb0ccd14-1 0.5.0.r57.g1182b2e-1
mauikit2.1.2.r50.g8ad10f4d-12.1.2.r51.gdaf7fab6-1
mauiman r23.6ccbef3-1 r26.0eff78b-1
mbox-importer22.04.2.r572.g286306b-122.04.3.r576.gd246cc1-1
messagelib22.04.2.r6619.gfcde856ee-122.04.3.r6636.g9b961d803-1
neochat22.06.r51.g94f32560-122.06.r56.g84a265b7-1
okular22.04.3.r9792.g37dd66593-122.04.3.r9793.gb96902b40-1
oxygen5.25.3.r4499.g84305086-15.25.3.r4500.ga50719e0-1
palapeli22.04.3.r1293.gb8840f4-122.04.3.r1294.gf2d5df8-1
parley22.04.3.r4533.g767fa241-122.04.3.r4535.gf3a4ad33-1
picmi22.04.3.r565.g2457d21-122.04.3.r566.g1720e96-1
pim-data-exporter22.04.2.r2766.gd3faa685-122.04.3.r2770.g975f545c-1
pim-sieve-editor22.04.2.r1635.gaf6aa2b-122.04.3.r1645.g766e5fe-1
pimcommon22.04.2.r1246.g945b8c4-122.04.3.r1258.g6000a95-1
plank-player r30.7520b22-1 r31.35ad97b-1
plasma-bigscreen r489.gee83ea0-1 r494.gcff5977-1
plasma-desktop5.25.3.r9454.g0fc8d0316-15.25.3.r9497.g0dbd7da03-1
plasma-dialer 22.06.r16.gf6cf597-1 22.06.r22.gd032a2d-1
plasma-firewall5.25.3.r643.g0c9bbb3-15.25.3.r644.g2dfb7dd-1
plasma-framework5.96.0.r16366.g50eaece7a-15.96.0.r16374.g5ddb367d0-1
plasma-integration5.25.3.r571.gb0cd3e1-15.25.3.r572.g6ed27d1-1
plasma-mobile5.25.3.r1918.ga0ea1f743-15.25.3.r1926.gaeddd5ab7-1
plasma-mobile-nm5.25.3.r3294.g141ce673-15.25.3.r3307.g117e0add-1
plasma-nm5.25.3.r3294.g141ce673-15.25.3.r3307.g117e0add-1
plasma-pa5.25.3.r1058.g751b314-15.25.3.r1064.g99fd1b1-1
plasma-phonebook 22.06.r5.g62a98d0-1 22.06.r8.g6a98656-1
plasma-remotecontrollers r93.g0ab8e75-1 r95.g34feeed-1
plasma-sdk5.25.3.r2378.g811d92d1-15.25.3.r2382.g720c0865-1
plasma-settings 22.06.r32.g0a02044-1 22.06.r48.ga3af120-1
plasma-systemmonitor5.25.3.r597.g43f1a12-15.25.3.r603.g5ce820d-1
plasma-wayland-session5.25.3.r12094.g502430d76-15.25.3.r12151.g8df9bef6f-1
plasma-workspace5.25.3.r12094.g502430d76-15.25.3.r12151.g8df9bef6f-1
plasma-workspace-wallpapers5.25.3.r361.g2c96c7a-15.25.3.r368.g30a6341-1
plasmatube 22.06.r7.g07b6f24-1 22.06.r8.g939828c-1
powerdevil5.25.3.r2559.gbfb57f41-15.25.3.r2574.ga4e1252c-1
print-manager22.04.3.r1147.g66eda1f-122.04.3.r1149.g9e58537-1
prison5.96.0.r393.g74e34fa-15.96.0.r394.gd7671ab-1
purpose5.96.0.r984.g51e3a30-15.96.0.r985.g64ed389-1
qmlkonsole 22.06.r10.ga75f5ab-1 22.06.r12.g9fe7f12-1
qqc2-desktop-style5.96.0.r643.g299748e-15.96.0.r646.g1bcaf0b-1
rocs22.04.3.r3091.ged76779c-122.04.3.r3095.g4c9d2cfa-1
sddm-kcm5.25.3.r671.gea131ce-15.25.3.r673.g70e0760-1
spacebar 22.06.r18.g075044d-1 22.06.r45.g6ae2512-1
spectacle22.04.3.r1374.gf32cc2f-122.04.3.r1377.gde864e6-1
step22.04.3.r1200.g64a0495-122.04.3.r1205.gbf9c057-1
svgpart22.04.3.r232.g9279041-122.04.3.r234.gb4c5361-1
sweeper22.04.3.r578.g89755e6-122.04.3.r579.g28430e5-1
syntax-highlighting5.96.0.r1854.g778fa485-15.96.0.r1869.g4568c392-1
systemsettings5.25.3.r2694.gd2a36f1d-15.25.3.r2696.gec27bae1-1
tokodon 22.06.r17.gb30ed83-1 22.06.r22.gb0cb919-1
vakzination 22.06.r10.gdaac6be-1 22.06.r19.g50d4ab9-1
yakuake22.04.3.r803.g7bd2d68-122.04.3.r807.g1213c6d-1
cask-server - r2.ge1c218e-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
