[ARM Testing Update] 2022-07-15 - KDE Gear, Plasma, Pipewire, Xorg and kernels
Hello ARM community.
New testing update with small updates.
Some highlights:
  • Most of our kernels got updated
  • KDE Gear updated to 22.04.3
  • KDE Plasma updated to 5.25.3
  • Pipewire updated to 0.3.55
  • Xorg updated to 21.1.4
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Fri Jul 15 20:33:19 CEST 2022)
  • arm-testing community aarch64: 329 new and 321 removed package(s)
  • arm-testing core aarch64: 41 new and 30 removed package(s)
  • arm-testing extra aarch64: 509 new and 517 removed package(s)
  • arm-testing kde-unstable aarch64: 388 new and 387 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2022-07-07         2022-07-15
                  alsa-ucm-pinephone              0.5.8-1              0.5.8-3
                                code             1.68.1-1             1.69.0-1
                        kodi-rpi-git20.x.60707.a05f4fc046-120.x.60733.a7ecb4ca50-1
                    kodi-rpi-git-dev20.x.60707.a05f4fc046-120.x.60733.a7ecb4ca50-1
           kodi-rpi-git-eventclients20.x.60707.a05f4fc046-120.x.60733.a7ecb4ca50-1
    kodi-rpi-git-tools-texturepacker20.x.60707.a05f4fc046-120.x.60733.a7ecb4ca50-1
                         kpeoplesink       r69.g889321f-2       r81.g4f129cb-2
                          libgbinder             1.1.23-1             1.1.24-1
                         libglibutil             1.0.65-1             1.0.66-1
                                phoc0.21.0beta1+8+gd24842d-10.21.0beta1+12+g56efa97-1
                               phosh0.20.0beta2+4+g5027b9c3-10.20.0beta2+16+g4f3074c8-2
                         pika-backup            1:0.4.1-1            1:0.4.2-1
            pinebookpro-post-install           20220607-1           20220713-1
                 rock64-post-install           20220603-1           20220713-1
              rockpro64-post-install           20220603-1           20220713-1
                      signal-desktop             5.48.0-1             5.49.0-1
                         squeekboard 1.18.0+34+gcc7657e-1             1.19.0-1
                         uboot-tools            2022.04-1                    -
                        wire-desktop          3.27.2944-1          3.28.2946-1
                              mimic3                    -              0.2.3-0
                          phosh-next                    -0.20.0beta2+8+g0e0efe59-1
:: Different sync package(s) in repository community aarch64
                                alot               0.10-3               0.10-4
                               amule            1:2.3.3-4            1:2.3.3-5
                             ansible              6.0.0-1              6.1.0-1
                              argocd              2.4.3-1              2.4.6-1
                            audacity            1:2.4.1-7            1:2.4.1-9
                             avrdude              1:7.0-1              1:7.0-2
                             aws-cli            1.25.17-1            1.25.17-2
                              awxkit             21.2.0-1             21.3.0-1
                bash-language-server              3.0.5-1              3.0.5-2
                                 bat             0.21.0-1             0.21.0-2
                       bitwarden-cli             1.22.1-2           2022.6.2-1
                               broot             1.14.0-1             1.14.2-1
                             buildah             1.26.1-1             1.26.2-1
                       cargo-nextest             0.9.24-1             0.9.26-1
                       cargo-release             0.21.0-1             0.21.1-1
                             certbot             1.28.0-1             1.29.0-1
                      certbot-apache             1.28.0-1             1.29.0-1
              certbot-dns-cloudflare             1.28.0-1             1.29.0-1
                certbot-dns-cloudxns             1.28.0-1             1.29.0-1
            certbot-dns-digitalocean             1.28.0-1             1.29.0-1
                certbot-dns-dnsimple             1.28.0-1             1.29.0-1
             certbot-dns-dnsmadeeasy             1.28.0-1             1.29.0-1
                  certbot-dns-gehirn             1.28.0-1             1.29.0-1
                  certbot-dns-google             1.28.0-1             1.29.0-1
                  certbot-dns-linode             1.28.0-1             1.29.0-1
                  certbot-dns-luadns             1.28.0-1             1.29.0-1
                   certbot-dns-nsone             1.28.0-1             1.29.0-1
                     certbot-dns-ovh             1.28.0-1             1.29.0-1
                 certbot-dns-rfc2136             1.28.0-1             1.29.0-1
                 certbot-dns-route53             1.28.0-1             1.29.0-1
             certbot-dns-sakuracloud             1.28.0-1             1.29.0-1
                       certbot-nginx             1.28.0-1             1.29.0-1
               cinnamon-translations              5.4.0-1              5.4.1-1
                          clonezilla             3.35.2-3             3.35.2-4
                          codeblocks              20.03-2              20.03-4
                              codec2            1:1.0.3-2            1:1.0.4-1
                             comtool              1.7.9-5              2.1.0-1
                      container-diff             0.17.0-1             0.17.0-2
                            cppcheck                2.8-1              2.8.2-1
                               cross              0.2.2-1              0.2.4-1
                             crystal              1.4.1-1              1.5.0-1
                              dagger             0.2.21-1             0.2.23-1
                                dart             2.17.5-1             2.17.6-1
                            dbus-c++              0.9.0-9             0.9.0-10
                          diffoscope                217-1                218-2
                          difftastic             0.30.0-1             0.31.0-1
                          displaycal              3.9.4-1              3.9.6-1
                                drbl             2.30.5-1             2.30.5-2
                            dscanner             0.12.1-1             0.12.2-1
                             duktape              2.7.0-2              2.7.0-4
                          duperemove             0.11.3-1             0.11.3-2
                                dust              0.8.0-1              0.8.1-1
                           dvdstyler              3.1.2-5              3.2.1-1
                              eid-mw              5.1.2-1              5.1.4-1
                            electrum              4.2.0-1              4.2.2-1
                              erlang             24.3.2-3             25.0.2-1
                     erlang-unixodbc             24.3.2-3             25.0.2-1
                    feeluown-netease              0.9.1-1              0.9.2-1
                           filezilla             3.60.1-1             3.60.1-2
              firefox-tree-style-tab             3.8.24-1             3.8.26-1
                             freecol             0.12.0-1             0.13.0-1
                               fwupd              1.8.1-1              1.8.2-2
                                geos             3.10.3-1             3.11.0-1
                                giac           1.9.0.13-1           1.9.0.19-1
                           git-cliff              0.7.0-1              0.8.1-1
                            git-grab              1.0.0-1              1.0.1-1
                                 gmm                5.4-1              5.4.2-1
                               gmrun               1.3w-1               1.4w-1
            gnome-appfolders-manager              0.4.5-1              0.4.5-2
                            gnuchess              6.2.9-1              6.2.9-2
                             go-ipfs             0.12.2-1             0.13.1-1
                               go-yq             4.25.3-1             4.26.1-1
                               grcov             0.8.10-2             0.8.11-1
                           gscan2pdf             2.12.6-1             2.12.6-2
                          gsimplecal                2.4-1                2.4-2
                          gwakeonlan              0.8.3-1              0.8.3-2
                              hcloud             1.30.0-1             1.30.1-1
                            hedgedoc              1.9.3-3              1.9.4-1
                        herbstluftwm              0.9.4-1              0.9.4-2
                               hugin           2021.0.0-3           2021.0.0-4
                  ibus-table-chinese              1.8.3-1              1.8.4-1
                                  jc             1.20.1-1             1.20.2-1
                             jenkins              2.358-1              2.359-1
                                jmol           14.32.62-1           14.32.63-1
                               jsmol           14.32.62-1           14.32.63-1
                                juce              7.0.0-1              7.0.1-1
                           juce-docs              7.0.0-1              7.0.1-1
                   jupyter-nbclassic              0.4.2-1              0.4.3-1
              jupyter-server-mathjax              0.2.5-1              0.2.6-1
                     jupyter_console              6.4.4-1              6.4.4-2
                                 jwm              2.4.2-1              2.4.2-2
                               kicad              6.0.6-1              6.0.6-2
                       knot-resolver              5.5.0-1              5.5.1-1
                   krita-plugin-gmic            3.1.4.2-1            3.1.4.3-1
                         kube-linter              0.3.0-2              0.4.0-1
                             kvantum              1.0.2-1              1.0.3-1
                           libad9361                0.2-5                0.2-7
                            libffado              2.4.5-1              2.4.6-1
                              libiio               0.23-4               0.24-1
                          librdkafka              1.8.2-1              1.9.1-1
                             libvirt            1:8.4.0-1            1:8.5.0-2
                        libvirt-glib              4.0.0-1              4.0.0-2
                      libvirt-python            1:8.4.0-1            1:8.5.0-1
             libvirt-storage-gluster            1:8.4.0-1            1:8.5.0-2
        libvirt-storage-iscsi-direct            1:8.4.0-1            1:8.5.0-2
                           limesuite            20.10.0-3            20.10.0-4
                              logcli              2.5.0-1              2.6.0-1
                                loki              2.5.0-1              2.6.0-1
                         loki-canary              2.5.0-1              2.6.0-1
                         lua-luaossl           20200709-2           20220711-1
                       lua51-luaossl           20200709-2           20220711-1
                       lua52-luaossl           20200709-2           20220711-1
                       lua53-luaossl           20200709-2           20220711-1
                                mako                1.7-2              1.7.1-1
                                mat2             0.12.4-1             0.13.0-1
                        mate-applets             1.26.0-1             1.26.1-1
                      matrix-synapse             1.61.1-1             1.62.0-1
                             maturin            0.12.20-1             0.13.0-1
                              mdbook             0.4.19-1             0.4.20-1
                           mediainfo              22.06-1              22.06-2
                       mediainfo-gui              22.06-1              22.06-2
                            mednafen             1.29.0-1             1.29.0-2
                         meilisearch             0.27.2-1             0.28.0-1
                              memray              1.1.0-2              1.2.0-1
                              miller              6.2.0-2              6.3.0-1
                            minikube             1.25.2-1             1.26.0-1
              nextcloud-app-calendar            1:3.4.1-1            1:3.4.2-1
                  nextcloud-app-mail             1.13.5-1             1.13.6-1
                             ngspice                 37-1                 37-2
                              nodejs             18.4.0-1             18.6.0-1
                  nodejs-lts-fermium            14.19.3-1            14.20.0-1
                  nodejs-lts-gallium            16.15.1-1            16.16.0-1
                                 npm             8.13.0-1             8.14.0-1
                                nrpe              4.0.3-2              4.0.3-3
                          open-iscsi              2.1.7-1              2.1.7-2
                      opensearch-cli              1.1.0-2              1.1.0-4
               opensearch-dashboards              2.0.1-1              2.1.0-1
opensearch-dashboards-alerting-plugin            2.0.1.0-1            2.1.0.0-1
opensearch-dashboards-anomaly-detection-plugin            2.0.1.0-1            2.1.0.0-1
opensearch-dashboards-gantt-chart-plugin            2.0.1.0-1            2.1.0.0-1
opensearch-dashboards-index-management-plugin            2.0.1.0-1            2.1.0.0-1
opensearch-dashboards-observability-plugin            2.0.1.0-1            2.1.0.0-1
opensearch-dashboards-query-workbench-plugin            2.0.1.0-1            2.1.0.0-1
opensearch-dashboards-reports-plugin            2.0.1.0-1            2.1.0.0-1
opensearch-dashboards-security-plugin            2.0.1.0-1            2.1.0.0-1
                         openvswitch             2.16.1-2             2.16.1-3
                              p2pool                2.2-1              2.2.1-1
                            pageedit              1.7.0-1             1.9.10-1
                            pam-krb5               4.11-1               4.11-2
                  papirus-icon-theme           20220606-1           20220710-1
                           partclone             0.3.20-1             0.3.20-2
                     perl-goocanvas2               0.06-4               0.06-5
                   perl-json-maybexs           1.004003-3           1.004003-4
                    perl-test-simple           1.302190-2           1.302191-1
                      perl-test-utf8               1.01-6               1.02-1
                              picard              2.8.1-1              2.8.2-1
                                pigz                2.7-1                2.7-2
                         pipe-rename              1.4.2-1              1.5.0-1
                                pixz              1.0.7-2              1.0.7-3
                              poedit            1:3.0.1-3              1:3.1-1
                   powerdns-recursor              4.7.0-2              4.7.1-2
                            promtail              2.5.0-1              2.6.0-1
                              ps_mem               3.14-1               3.14-2
                             pyright            1.1.257-1            1.1.260-1
                         python-acme             1.28.0-1             1.29.0-1
          python-aiohttp-openmetrics              0.0.5-1              0.0.6-1
                      python-aiorpcx             0.22.0-1             0.22.1-1
                      python-astroid             2.11.6-1             2.12.2-1
                 python-atomicwrites              1.4.0-7              1.4.1-1
                        python-boto3            1.24.17-1            1.24.27-1
                     python-botocore            1.27.17-1            1.27.27-1
                     python-cfn-lint             0.61.1-1             0.61.2-1
         python-cryptography-vectors             37.0.3-1             37.0.4-1
                     python-curtsies             0.3.10-1             0.3.10-2
                     python-cwcwidth              0.1.6-1              0.1.6-2
                      python-cytoolz             0.11.2-3             0.12.0-1
                      python-debugpy              1.6.1-1              1.6.2-1
                       python-dotenv             0.20.0-1             0.20.0-2
                  python-elementpath              2.5.0-1              2.5.1-1
                      python-fastapi             0.68.1-2             0.78.0-1
                     python-filelock              3.5.1-1              3.6.0-1
                    python-fonttools             4.34.2-1             4.34.4-1
                       python-gitlab              3.5.0-1              3.6.0-1
                 python-glanceclient              4.0.0-1              4.0.1-1
                        python-hatch             0.23.1-1              1.3.1-1
                    python-hatchling             0.25.0-2              1.5.0-1
                    python-icalendar              4.0.9-3              4.1.0-1
                      python-inflect              5.6.0-1              5.6.1-1
                    python-ipykernel             6.15.0-1             6.15.1-1
                        python-jinja            1:3.1.2-1            1:3.1.2-2
                 python-jupyter_core             4.10.0-1             4.11.1-1
                     python-libevdev                0.9-4               0.10-1
                        python-magic               5.42-1           1:0.4.27-1
                python-matrix-common              1.1.0-1              1.2.1-1
                        python-minio              7.1.9-1             7.1.10-1
                      python-mistune              2.0.3-1              2.0.3-2
                       python-mocket             3.10.6-1             3.10.6-2
               python-more-itertools             8.13.0-1             8.13.0-2
                  python-mysqlclient              2.1.0-1              2.1.1-1
                     python-networkx              2.7.1-1              2.8.4-1
                       python-orjson              3.7.6-1              3.7.7-1
                      python-osc-lib              2.5.0-1              2.6.0-1
             python-ovirt-engine-sdk             4.4.15-1              4.5.1-1
                        python-paste              3.5.0-5              3.5.1-1
                      python-pip-run              8.8.0-1              8.8.1-1
                       python-pipenv           2022.6.7-1           2022.7.4-1
                       python-poetry             1.1.13-3             1.1.14-1
                   python-pre-commit             2.19.0-1             2.20.0-1
               python-prompt_toolkit             3.0.30-1             3.0.30-2
                     python-psycopg2              2.9.3-1              2.9.3-2
                        python-py7zr             0.18.5-1             0.19.0-1
                     python-pydantic              1.8.2-3              1.9.1-2
                       python-pyglet             1.5.26-1             1.5.26-2
                     python-pylibiio               0.23-4               0.24-1
                     python-pyspnego              0.5.2-1              0.5.3-1
              python-pytest-randomly             3.10.2-1             3.10.3-1
                        python-pyzmq             23.2.0-1             23.2.0-2
                    python-rapidjson                1.6-1                1.7-1
                 python-recommonmark              0.7.1-4              0.7.1-5
                         python-rich             12.4.4-1             12.5.1-1
                   python-s3transfer              0.6.0-1              0.6.0-2
                       python-shodan             1.27.0-2             1.28.0-1
                       python-sphinx              5.0.2-1              5.0.2-3
                 python-sphinx-jinja              1.4.0-1              2.0.2-1
                   python-sqlalchemy             1.4.37-1             1.4.39-1
                    python-starlette             0.14.2-4             0.20.4-1
                    python-stevedore              3.5.0-3              4.0.0-1
                       python-thrift             0.14.1-3             0.16.0-1
                   python-tldextract              3.3.0-1              3.3.1-1
                      python-tomlkit             0.11.0-1             0.11.1-1
                        python-toolz             0.11.2-3             0.12.0-1
                          python-tox             3.25.0-1             3.25.1-1
                        python-ujson              5.3.0-1              5.4.0-1
                   python-voluptuous             0.13.0-1             0.13.1-1
                   python-weasyprint               55.0-1               56.0-1
                     python-wxpython          1:4.0.7.2-3            1:4.1.1-3
                    python-xmltodict             0.13.0-1             0.13.0-2
                     python-zeroconf             0.38.5-1             0.38.7-1
                      python-ziamath                0.5-1                0.6-1
                         python-zipp              3.8.0-2              3.8.1-1
                                qcad           3.27.6.3-2           3.27.6.7-1
                           qcoro-qt5              0.5.1-1              0.6.0-1
                           qcoro-qt6              0.5.1-1              0.6.0-1
                            qpwgraph              0.3.3-1              0.3.4-1
              qt5-ukui-platformtheme              1.0.7-4              1.0.8-1
                            qtractor             0.9.26-2             0.9.27-2
                              rclone             1.58.1-1             1.59.0-1
                               redis              7.0.2-1              7.0.3-1
                               rekor              0.9.0-1              0.9.1-1
                              retext              7.2.3-1              7.2.3-2
                           rpm-tools             4.17.0-3             4.17.1-1
                       rust-analyzer           20220704-1           20220711-1
                              rustup             1.24.3-2             1.25.1-1
                       scummvm-tools              2.5.0-2              2.5.0-3
                           seamonkey            2.53.12-1            2.53.13-1
                          sequoia-sq             0.26.0-1             0.27.0-1
                          serverless             3.19.0-1             3.21.0-1
                             shutter             0.99.2-3             0.99.2-4
                              skopeo              1.8.0-1              1.9.0-1
                               smb4k              3.1.2-1              3.1.3-1
                            smplayer             22.2.0-2             22.7.0-1
                       soapyplutosdr              0.2.1-3              0.2.1-4
                              solaar              1.1.4-1              1.1.4-2
                               sonic              1.3.2-2              1.3.5-1
                           spice-gtk               0.40-1               0.41-1
                              stella                6.7-1                6.7-2
                            step-cli             0.20.0-1             0.21.0-1
                          streamlink              4.1.0-1              4.2.0-1
                            supermin              5.3.1-1              5.3.2-1
                                tepl              6.1.1-1              6.1.2-1
                           tesseract              5.1.0-2              5.2.0-1
                                 tig              2.5.5-1              2.5.6-1
                              tinygo             0.23.0-1             0.24.0-1
                        ttf-ibm-plex              6.0.0-1              6.0.2-1
                             ucblogo              6.2.2-2              6.2.2-3
                             unbound             1.16.0-1             1.16.1-1
                          uncrustify             0.74.0-1             0.75.1-1
                                 urh              2.9.3-1              2.9.3-2
                         urxvt-perls                2.3-1                2.3-2
                             usbview                3.0-1                3.0-2
         v2ray-domain-list-community     20220704031409-1     20220714074155-1
                         v2ray-geoip       202206300050-1       202207140057-1
                     vaultwarden-web           2022.5.2-1           2022.6.0-1
                            vbam-sdl2.1.4.r453.65b5affe-22.1.4.r453.65b5affe-3
                             vbam-wx2.1.4.r453.65b5affe-22.1.4.r453.65b5affe-3
                           virtualgl                3.0-2              3.0.1-1
                                 viu              1.4.0-1              1.4.0-2
           vscode-css-languageserver             1.68.0-1             1.69.0-1
          vscode-html-languageserver             1.68.0-1             1.69.0-1
          vscode-json-languageserver             1.68.0-1             1.69.0-1
                             web-ext              7.1.0-1              7.1.1-1
                             weechat                3.5-2                3.6-1
                           wordpress                6.0-1              6.0.1-1
                                  wt              4.7.1-2              4.8.0-1
                           wxsqlite3              4.7.8-1              4.7.8-2
                               wxsvg             1.5.23-3             1.5.23-4
                                xchm               1.32-2               1.33-1
                               xonsh             0.12.5-1             0.13.0-1
                yaml-language-server              1.8.0-1              1.9.0-1
                            yamllint             1.26.2-2             1.27.1-1
                           yggdrasil              0.4.3-2              0.4.4-1
                                  zk             0.10.1-1             0.11.0-1
                               lapce                    -              0.1.3-1
                            libsixel                    -             1.10.3-5
             perl-io-compress-brotli                    -           0.004001-1
                    python-inflate64                    -              0.1.3-1
                        python-pybcj                    -              0.6.1-1
                                ruby                    -              3.0.4-1
                           ruby-docs                    -              3.0.4-1
:: Different overlay package(s) in repository core aarch64
                               linux            5.18.11-1            5.18.12-1
               linux-clockworkpi-a06             5.18.9-1            5.18.12-1
       linux-clockworkpi-a06-headers             5.18.9-1            5.18.12-1
                       linux-headers            5.18.11-1            5.18.12-1
                           linux-lts            5.15.52-1            5.15.55-1
                   linux-lts-headers            5.15.52-1            5.15.55-1
                     linux-pinephone             5.18.9-1            5.18.10-1
             linux-pinephone-headers             5.18.9-1            5.18.10-1
                  linux-pinephonepro             5.18.9-1            5.18.10-1
          linux-pinephonepro-headers             5.18.9-1            5.18.10-1
                            linux-rc           5.19.rc5-1           5.19.rc6-2
                    linux-rc-headers           5.19.rc5-1           5.19.rc6-2
                 linux-rpi4-mainline             5.18.9-1             5.18.9-2
         linux-rpi4-mainline-headers             5.18.9-1             5.18.9-2
                       linux-rpi4-rc           5.19.rc5-1           5.19.rc6-1
               linux-rpi4-rc-headers           5.19.rc5-1           5.19.rc6-1
                     uboot-pinephone            2022.04-1            2022.07-1
                  uboot-pinephonepro          4:2022.04-1          4:2022.07-1
                           amd-ucode                    - 20220708.be7798e-0.1
                      linux-firmware                    - 20220708.be7798e-0.1
                linux-firmware-bnx2x                    - 20220708.be7798e-0.1
             linux-firmware-liquidio                    - 20220708.be7798e-0.1
              linux-firmware-marvell                    - 20220708.be7798e-0.1
             linux-firmware-mellanox                    - 20220708.be7798e-0.1
                  linux-firmware-nfp                    - 20220708.be7798e-0.1
                 linux-firmware-qcom                    - 20220708.be7798e-0.1
               linux-firmware-qlogic                    - 20220708.be7798e-0.1
               linux-firmware-whence                    - 20220708.be7798e-0.1
                         uboot-tools                    -            2022.07-1
:: Different sync package(s) in repository core aarch64
                   archlinux-keyring           20220424-1           20220713-1
                                curl             7.84.0-1             7.84.0-2
                          efibootmgr                 17-2                 18-1
                               gnupg             2.2.35-2             2.2.36-1
                      libcurl-compat             7.84.0-1             7.84.0-2
                      libcurl-gnutls             7.84.0-1             7.84.0-2
                               libnl              3.6.0-3              3.7.0-1
                   openssl-cryptodev            1.1.1.n-1            1.1.1.q-1
                             systemd              251.2-1              251.3-1
                        systemd-libs              251.2-1              251.3-1
                  systemd-resolvconf              251.2-1              251.3-1
                  systemd-sysvcompat              251.2-1              251.3-1
:: Different overlay package(s) in repository extra aarch64
                          elisa-qtmm            22.04.2-1            22.04.3-1
                       gnome-console42.beta+66+g8991a6c-2               42.2-1
                                kwin           5.25.2-1.0           5.25.3-1.1
                            mesa-git22.2.0_devel.156171.7bb62d9dd859-122.2.0_devel.156464.b8397991c888-1
                              okular            22.04.2-1            22.04.3-1
                       plasma-mobile             5.25.2-1             5.25.3-1
                    plasma-mobile-nm             5.25.2-1             5.25.3-1
                         plasma-nano             5.25.2-1             5.25.3-1
                   qqc2-breeze-style             5.25.2-1             5.25.3-1
                               snapd             2.56.2-1             2.56.3-1
:: Different sync package(s) in repository extra aarch64
                             akonadi            22.04.2-3            22.04.3-1
                    akonadi-calendar            22.04.2-1            22.04.3-1
              akonadi-calendar-tools            22.04.2-1            22.04.3-1
                    akonadi-contacts            22.04.2-1            22.04.3-1
               akonadi-import-wizard            22.04.2-1            22.04.3-1
                        akonadi-mime            22.04.2-1            22.04.3-1
                       akonadi-notes            22.04.2-1            22.04.3-1
                      akonadi-search            22.04.2-1            22.04.3-1
                      akonadiconsole            22.04.2-1            22.04.3-1
                           akregator            22.04.2-1            22.04.3-1
                  alsa-card-profiles           1:0.3.53-3           1:0.3.55-2
                            alsa-lib            1.2.7.1-1            1.2.7.2-1
                       alsa-ucm-conf            1.2.7.1-1            1.2.7.2-1
                            analitza            22.04.2-1            22.04.3-1
                                 ark            22.04.2-1            22.04.3-1
                          artikulate            22.04.2-1            22.04.3-1
                              assimp              5.2.4-1              5.2.4-2
                              attica             5.95.0-1             5.96.0-1
                         audiocd-kio            22.04.2-1            22.04.3-1
                               baloo             5.95.0-1             5.96.0-1
                       baloo-widgets            22.04.2-1            22.04.3-1
                             blinken            22.04.2-1            22.04.3-1
                           bluedevil           1:5.25.2-1           1:5.25.3-1
                            bluez-qt             5.95.0-1             5.96.0-1
                              bomber            22.04.2-1            22.04.3-1
                                bovo            22.04.2-1            22.04.3-1
                              breeze             5.25.2-1             5.25.3-1
                         breeze-grub             5.25.2-1             5.25.3-1
                          breeze-gtk             5.25.2-1             5.25.3-1
                        breeze-icons             5.95.0-1             5.96.0-1
                     calendarsupport            22.04.2-1            22.04.3-1
                              cantor            22.04.2-1            22.04.3-1
                            cervisia            22.04.2-1            22.04.3-1
                               cmake             3.23.2-1             3.23.2-2
                            composer              2.3.8-1              2.3.9-1
                              deluge            1:2.1.0-1            1:2.1.1-1
                          deluge-gtk            1:2.1.0-1            1:2.1.1-1
                            devtools           20220207-2           20220621-1
                            discover             5.25.2-2             5.25.3-1
                                dkms              3.0.5-1              3.0.5-2
                             dolphin            22.04.2-1            22.04.3-1
                     dolphin-plugins            22.04.2-1            22.04.3-1
                              dragon            22.04.2-1            22.04.3-1
                             drkonqi             5.25.2-1             5.25.3-1
                               elisa            22.04.2-1            22.04.3-1
                            epiphany               42.2-1               42.3-1
                          eventviews            22.04.2-1            22.04.3-1
                 extra-cmake-modules             5.95.0-1             5.96.0-1
                              falkon            22.04.2-1            22.04.3-1
                        ffmpegthumbs            22.04.2-1            22.04.3-1
                           filelight            22.04.2-1            22.04.3-1
                                flac              1.3.4-2              1.3.4-3
                            flac-doc              1.3.4-2              1.3.4-3
                          fluidsynth              2.2.7-1              2.2.8-1
                frameworkintegration             5.95.0-1             5.96.0-1
                                 git             2.37.0-1             2.37.1-1
                                  gn    0.2042.2ecd43a1-2    0.2050.9ef32177-1
                 gnome-bluetooth-3.0               42.1-1               42.2-1
                       gnome-desktop             1:42.2-1             1:42.3-1
                     gnome-desktop-4             1:42.2-1             1:42.3-1
                gnome-desktop-common             1:42.2-1             1:42.3-1
                        gnome-tweaks 42beta+r9+gc66d8c3-142beta+r14+g2d9d76c-1
                             gnuplot              5.4.3-5              5.4.3-6
                       gnuplot-demos              5.4.3-5              5.4.3-6
                           granatier            22.04.2-1            22.04.3-1
                     grantlee-editor            22.04.2-1            22.04.3-1
                       grantleetheme            22.04.2-1            22.04.3-1
                 gst-plugin-pipewire           1:0.3.53-3           1:0.3.55-2
                             gtk-vnc              1.3.0-1              1.3.1-1
                            gwenview            22.04.2-1            22.04.3-1
                         imagemagick           7.1.0.40-1           7.1.0.43-1
                     imagemagick-doc           7.1.0.40-1           7.1.0.43-1
                              imlib2              1.9.0-3              1.9.1-1
                     incidenceeditor            22.04.2-1            22.04.3-1
                           itinerary            22.04.2-1            22.04.3-1
                                 juk            22.04.2-1            22.04.3-1
                                 k3b          1:22.04.2-1          1:22.04.3-1
               kaccounts-integration            22.04.2-1            22.04.3-1
                 kaccounts-providers            22.04.2-1            22.04.3-1
                         kactivities             5.95.0-1             5.96.0-1
                   kactivities-stats             5.95.0-1             5.96.0-1
                   kactivitymanagerd             5.25.2-1             5.25.3-1
                        kaddressbook            22.04.2-1            22.04.3-1
                             kajongg            22.04.2-1            22.04.3-1
                              kalarm            22.04.2-1            22.04.3-1
                            kalendar            22.04.2-1            22.04.3-1
                            kalgebra            22.04.2-1            22.04.3-1
                             kalzium            22.04.2-1            22.04.3-1
                              kamera            22.04.2-1            22.04.3-1
                              kamoso            22.04.2-1            22.04.3-1
                            kanagram            22.04.2-1            22.04.3-1
                             kapidox             5.95.0-1             5.96.0-1
                              kapman            22.04.2-1            22.04.3-1
                        kapptemplate            22.04.2-1            22.04.3-1
                            karchive             5.95.0-1             5.96.0-1
                                kate            22.04.2-1            22.04.3-1
                             katomic            22.04.2-1            22.04.3-1
                               kauth             5.95.0-1             5.96.0-1
                             kbackup            22.04.2-1            22.04.3-1
                           kblackbox            22.04.2-1            22.04.3-1
                             kblocks            22.04.2-1            22.04.3-1
                          kbookmarks             5.95.0-1             5.96.0-1
                             kbounce            22.04.2-1            22.04.3-1
                           kbreakout            22.04.2-1            22.04.3-1
                              kbruch            22.04.2-1            22.04.3-1
                         kcachegrind            22.04.2-1            22.04.3-1
                  kcachegrind-common            22.04.2-1            22.04.3-1
                               kcalc            22.04.2-1            22.04.3-1
                       kcalendarcore             5.95.0-1             5.96.0-1
                           kcalutils            22.04.2-1            22.04.3-1
                         kcharselect            22.04.2-1            22.04.3-1
                            kcmutils             5.95.0-1             5.96.0-1
                             kcodecs             5.95.0-1             5.96.0-1
                       kcolorchooser            22.04.2-1            22.04.3-1
                         kcompletion             5.95.0-1             5.96.0-1
                             kconfig             5.95.0-1             5.96.0-1
                      kconfigwidgets             5.95.0-1             5.96.0-1
                           kcontacts           1:5.95.0-1           1:5.96.0-1
                         kcoreaddons             5.95.0-1             5.96.0-1
                              kcrash             5.95.0-1             5.96.0-1
                               kcron            22.04.2-1            22.04.3-1
                                kdav           1:5.95.0-1           1:5.96.0-1
                         kdbusaddons             5.95.0-1             5.96.0-1
                       kde-cli-tools             5.25.2-1             5.25.3-1
                     kde-dev-scripts            22.04.2-1            22.04.3-1
                       kde-dev-utils            22.04.2-1            22.04.3-1
                      kde-gtk-config             5.25.2-1             5.25.3-1
                      kdebugsettings            22.04.2-1            22.04.3-1
                        kdeclarative             5.95.0-1             5.96.0-1
                          kdeconnect            22.04.2-1            22.04.3-1
                         kdecoration             5.25.2-1             5.25.3-1
                                kded             5.95.0-1             5.96.0-1
                         kdeedu-data            22.04.2-1            22.04.3-1
              kdegraphics-mobipocket            22.04.2-1            22.04.3-1
            kdegraphics-thumbnailers            22.04.2-1            22.04.3-1
                     kdelibs4support             5.95.0-1             5.96.0-1
              kdenetwork-filesharing            22.04.2-1            22.04.3-1
                            kdenlive            22.04.2-2            22.04.3-1
                       kdepim-addons            22.04.2-1            22.04.3-1
                      kdepim-runtime            22.04.2-1            22.04.3-1
                    kdeplasma-addons             5.25.2-1             5.25.3-1
                    kdesdk-kioslaves            22.04.2-1            22.04.3-1
                 kdesdk-thumbnailers            22.04.2-1            22.04.3-1
                     kdesignerplugin             5.95.0-1             5.96.0-1
                               kdesu             5.95.0-1             5.96.0-1
                            kdevelop            22.04.2-3            22.04.3-1
                        kdevelop-php            22.04.2-1            22.04.3-1
                           kdewebkit             5.95.0-1             5.96.0-1
                                 kdf            22.04.2-1            22.04.3-1
                             kdialog            22.04.2-1            22.04.3-1
                            kdiamond            22.04.2-1            22.04.3-1
                              kdnssd             5.95.0-1             5.96.0-1
                           kdoctools             5.95.0-1             5.96.0-1
                      keditbookmarks            22.04.2-1            22.04.3-1
                          kemoticons             5.95.0-1             5.96.0-1
                       kfilemetadata             5.95.0-1             5.96.0-1
                               kfind            22.04.2-1            22.04.3-1
                             kfloppy            22.04.2-1            22.04.3-1
                         kfourinline            22.04.2-1            22.04.3-1
                             kgamma5             5.25.2-1             5.25.3-1
                          kgeography            22.04.2-1            22.04.3-1
                                kget            22.04.2-1            22.04.3-1
                        kglobalaccel             5.95.0-1             5.96.0-1
                         kgoldrunner            22.04.2-1            22.04.3-1
                                kgpg            22.04.2-1            22.04.3-1
                          kguiaddons             5.95.0-1             5.96.0-1
                            khangman            22.04.2-1            22.04.3-1
                         khelpcenter            22.04.2-1            22.04.3-1
                           kholidays           1:5.95.0-1           1:5.96.0-1
                            khotkeys             5.25.2-1             5.25.3-1
                               khtml             5.95.0-1             5.96.0-1
                               ki18n             5.95.0-1             5.96.0-1
                         kiconthemes             5.95.0-1             5.96.0-1
                 kidentitymanagement            22.04.2-1            22.04.3-1
                           kidletime             5.95.0-1             5.96.0-1
                                 kig            22.04.2-2            22.04.3-1
                                kigo            22.04.2-1            22.04.3-1
                            killbots            22.04.2-1            22.04.3-1
                       kimageformats             5.95.0-1             5.96.0-1
                     kimagemapeditor            22.04.2-1            22.04.3-1
                               kimap            22.04.2-1            22.04.3-1
                         kinfocenter             5.25.2-1             5.25.3-1
                               kinit             5.95.0-1             5.96.0-1
                                 kio             5.95.0-1             5.96.0-1
                          kio-extras            22.04.2-1            22.04.3-1
                          kio-gdrive            22.04.2-1            22.04.3-1
                    kirigami-gallery            22.04.2-1            22.04.3-1
                           kirigami2             5.95.0-1             5.96.0-1
                              kiriki            22.04.2-1            22.04.3-1
                         kitemmodels             5.95.0-1             5.96.0-1
                          kitemviews             5.95.0-1             5.96.0-1
                               kiten            22.04.2-1            22.04.3-1
                          kitinerary            22.04.2-1            22.04.3-1
                         kjobwidgets             5.95.0-1             5.96.0-1
                                 kjs             5.95.0-1             5.96.0-1
                            kjsembed             5.95.0-1             5.96.0-1
                        kjumpingcube            22.04.2-1            22.04.3-1
                               kldap            22.04.2-1            22.04.3-1
                           kleopatra            22.04.2-1            22.04.3-1
                            klettres            22.04.2-1            22.04.3-1
                            klickety            22.04.2-1            22.04.3-1
                              klines            22.04.2-1            22.04.3-1
                                kmag            22.04.2-1            22.04.3-1
                           kmahjongg            22.04.2-1            22.04.3-1
                               kmail            22.04.2-1            22.04.3-1
                kmail-account-wizard            22.04.2-1            22.04.3-1
                      kmailtransport            22.04.2-1            22.04.3-1
                               kmbox            22.04.2-1            22.04.3-1
                        kmediaplayer             5.95.0-1             5.96.0-1
                           kmenuedit             5.25.2-1             5.25.3-1
                               kmime            22.04.2-1            22.04.3-1
                              kmines            22.04.2-1            22.04.3-1
                                kmix            22.04.2-1            22.04.3-1
                          kmousetool            22.04.2-1            22.04.3-1
                              kmouth            22.04.2-1            22.04.3-1
                              kmplot            22.04.2-1            22.04.3-1
                        knavalbattle            22.04.2-1            22.04.3-1
                            knetwalk            22.04.2-1            22.04.3-1
                           knewstuff             5.95.0-1             5.96.0-1
                             knights            22.04.2-1            22.04.3-1
                              knotes            22.04.2-1            22.04.3-1
                      knotifications             5.95.0-1             5.96.0-1
                       knotifyconfig             5.95.0-1             5.96.0-1
                                kolf            22.04.2-1            22.04.3-1
                           kollision            22.04.2-1            22.04.3-1
                         kolourpaint            22.04.2-1            22.04.3-1
                             kompare            22.04.2-1            22.04.3-1
                           konqueror            22.04.2-1            22.04.3-1
                            konquest            22.04.2-1            22.04.3-1
                             konsole            22.04.2-1            22.04.3-1
                             kontact            22.04.2-1            22.04.3-1
                    kontactinterface            22.04.2-1            22.04.3-1
                            kontrast            22.04.2-1            22.04.3-1
                        konversation            22.04.2-1            22.04.3-1
                       kopeninghours            22.04.2-2            22.04.3-1
                              kopete            22.04.2-1            22.04.3-1
                          korganizer            22.04.2-1            22.04.3-1
                       kosmindoormap            22.04.2-2            22.04.3-1
                            kpackage             5.95.0-1             5.96.0-1
                              kparts             5.95.0-1             5.96.0-1
                                kpat            22.04.2-1            22.04.3-1
                             kpeople             5.95.0-1             5.96.0-1
                        kpimtextedit            22.04.2-1            22.04.3-1
                             kpkpass            22.04.2-1            22.04.3-1
                           kplotting             5.95.0-1             5.96.0-1
                             kpmcore            22.04.2-1            22.04.3-1
                                kpty             5.95.0-1             5.96.0-1
                    kpublictransport            22.04.2-1            22.04.3-1
                      kqtquickcharts            22.04.2-1            22.04.3-1
                        kquickcharts             5.95.0-1             5.96.0-1
                                krdc            22.04.2-1            22.04.3-1
                            kreversi            22.04.2-1            22.04.3-1
                                krfb            22.04.2-1            22.04.3-1
                               kross             5.95.0-1             5.96.0-1
                              kruler            22.04.2-1            22.04.3-1
                             krunner             5.95.0-1             5.96.0-1
                             kscreen             5.25.2-1             5.25.3-1
                       kscreenlocker             5.25.2-1             5.25.3-1
                            kservice             5.95.0-1             5.96.0-1
                             kshisen            22.04.2-1            22.04.3-1
                               ksirk            22.04.2-1            22.04.3-1
                               ksmtp            22.04.2-1            22.04.3-1
                          ksnakeduel            22.04.2-1            22.04.3-1
                          kspaceduel            22.04.2-1            22.04.3-1
                            ksquares            22.04.2-1            22.04.3-1
                         ksshaskpass             5.25.2-1             5.25.3-1
                             ksudoku            22.04.2-1            22.04.3-1
                          ksystemlog            22.04.2-1            22.04.3-1
                        ksystemstats             5.25.2-1             5.25.3-1
                            kteatime            22.04.2-1            22.04.3-1
                         ktexteditor             5.95.0-1             5.96.0-1
                        ktextwidgets             5.95.0-1             5.96.0-1
                              ktimer            22.04.2-1            22.04.3-1
                               ktnef            22.04.2-1            22.04.3-1
                            ktorrent            22.04.2-1            22.04.3-1
                              ktouch            22.04.2-1            22.04.3-1
                          ktuberling            22.04.2-1            22.04.3-1
                             kturtle            22.04.2-1            22.04.3-1
                             kubrick            22.04.2-1            22.04.3-1
                     kunitconversion             5.95.0-1             5.96.0-1
                             kwallet             5.95.0-1             5.96.0-1
                         kwallet-pam             5.25.2-1             5.25.3-1
                      kwalletmanager            22.04.2-1            22.04.3-1
                               kwave            22.04.2-1            22.04.3-1
                            kwayland             5.95.0-1             5.96.0-1
                kwayland-integration             5.25.2-1             5.25.3-1
                      kwidgetsaddons             5.95.0-1             5.96.0-1
                                kwin             5.25.2-1             5.25.3-1
                       kwindowsystem             5.95.0-1             5.96.0-1
                           kwordquiz            22.04.2-1            22.04.3-1
                              kwrite            22.04.2-1            22.04.3-1
                             kwrited             5.25.2-1             5.25.3-1
                             kxmlgui             5.95.0-1             5.96.0-1
                       kxmlrpcclient             5.95.0-1             5.96.0-1
                          latex2html             2020.2-1             2022.2-1
                      layer-shell-qt             5.25.2-1             5.25.3-1
                          libadwaita            1:1.1.2-1            1:1.1.3-1
                    libadwaita-demos            1:1.1.2-1            1:1.1.3-1
                     libadwaita-docs            1:1.1.2-1            1:1.1.3-1
                          libakonadi            22.04.2-3            22.04.3-1
                              libdrm            2.4.111-1            2.4.112-1
                             libgit2            1:1.4.3-1            1:1.4.4-1
                         libgravatar            22.04.2-1            22.04.3-1
                              libgsf            1.14.49-1            1.14.50-1
                            libhandy              1.6.2-1              1.6.3-1
                       libhandy-docs              1.6.2-1              1.6.3-1
                            libkcddb            22.04.2-1            22.04.3-1
                     libkcompactdisc            22.04.2-1            22.04.3-1
                           libkdcraw            22.04.2-1            22.04.3-1
                         libkdegames            22.04.2-1            22.04.3-1
                           libkdepim            22.04.2-1            22.04.3-1
                  libkeduvocdocument            22.04.2-1            22.04.3-1
                           libkexiv2            22.04.2-1            22.04.3-1
                            libkgapi            22.04.2-1            22.04.3-1
                             libkleo            22.04.2-1            22.04.3-1
                        libkmahjongg            22.04.2-1            22.04.3-1
                     libkomparediff2            22.04.2-1            22.04.3-1
                            libksane            22.04.2-1            22.04.3-1
                          libkscreen             5.25.2-1             5.25.3-1
                           libksieve            22.04.2-1            22.04.3-1
                        libksysguard             5.25.2-1             5.25.3-1
                         libktorrent            22.04.2-1            22.04.3-1
                           libnotify             0.7.12-1              0.8.0-1
                              libx11              1.8.1-2              1.8.1-3
                            lokalize            22.04.2-1            22.04.3-1
                               lskat            22.04.2-1            22.04.3-1
                          mailcommon            22.04.2-1            22.04.3-1
                        mailimporter            22.04.2-1            22.04.3-1
                              marble            22.04.2-2            22.04.3-1
                       marble-common            22.04.2-2            22.04.3-1
                         marble-maps            22.04.2-2            22.04.3-1
                           marble-qt            22.04.2-2            22.04.3-1
                        markdownpart            22.04.2-1            22.04.3-1
                       mbox-importer            22.04.2-1            22.04.3-1
                           mercurial              6.1.4-1                6.2-1
                          messagelib            22.04.2-1            22.04.3-1
                               milou             5.25.2-1             5.25.3-1
                              minuet            22.04.2-1            22.04.3-1
                     modemmanager-qt             5.95.0-1             5.96.0-1
                            mousepad              0.5.9-1             0.5.10-1
                                 mpd             0.23.7-1             0.23.8-1
                              namcap             3.2.10-5              3.3.1-1
                   networkmanager-qt             5.95.0-1             5.96.0-1
                           openbabel              3.1.1-3              3.1.1-4
                         opencolorio              2.1.1-2              2.1.2-1
                                orca               42.2-1               42.3-1
                              oxygen             5.25.2-1             5.25.3-1
                        oxygen-icons           1:5.95.0-1           1:5.96.0-1
                    oxygen-icons-svg           1:5.95.0-1           1:5.96.0-1
                       oxygen-sounds             5.25.2-1             5.25.3-1
                            palapeli            22.04.2-1            22.04.3-1
                              parley            22.04.2-1            22.04.3-1
                    partitionmanager            22.04.2-1            22.04.3-1
                    perl-alien-build               2.49-1               2.50-1
                perl-crypt-passwdmd5               1.41-3               1.42-1
                     perl-date-manip               6.86-2               6.87-1
                  perl-file-mimeinfo               0.32-2               0.33-1
                   perl-http-message               6.36-2               6.37-1
                   perl-log-log4perl               1.54-3               1.55-1
                            perl-uri               5.10-2               5.12-1
                                 php              8.1.7-2              8.1.8-1
                          php-apache              8.1.7-2              8.1.8-1
                             php-cgi              8.1.7-2              8.1.8-1
                           php-dblib              8.1.7-2              8.1.8-1
                           php-embed              8.1.7-2              8.1.8-1
                         php-enchant              8.1.7-2              8.1.8-1
                             php-fpm              8.1.7-2              8.1.8-1
                              php-gd              8.1.7-2              8.1.8-1
                            php-imap              8.1.7-2              8.1.8-1
                            php-intl              8.1.7-2              8.1.8-1
                            php-odbc              8.1.7-2              8.1.8-1
                           php-pgsql              8.1.7-2              8.1.8-1
                          php-phpdbg              8.1.7-2              8.1.8-1
                          php-pspell              8.1.7-2              8.1.8-1
                            php-snmp              8.1.7-2              8.1.8-1
                          php-sodium              8.1.7-2              8.1.8-1
                          php-sqlite              8.1.7-2              8.1.8-1
                            php-tidy              8.1.7-2              8.1.8-1
                             php-xsl              8.1.7-2              8.1.8-1
                                php7             7.4.29-4             7.4.30-1
                         php7-apache             7.4.29-4             7.4.30-1
                            php7-cgi             7.4.29-4             7.4.30-1
                          php7-dblib             7.4.29-4             7.4.30-1
                          php7-embed             7.4.29-4             7.4.30-1
                        php7-enchant             7.4.29-4             7.4.30-1
                            php7-fpm             7.4.29-4             7.4.30-1
                             php7-gd             7.4.29-4             7.4.30-1
                           php7-imap             7.4.29-4             7.4.30-1
                           php7-intl             7.4.29-4             7.4.30-1
                           php7-odbc             7.4.29-4             7.4.30-1
                          php7-pgsql             7.4.29-4             7.4.30-1
                         php7-phpdbg             7.4.29-4             7.4.30-1
                         php7-pspell             7.4.29-4             7.4.30-1
                           php7-snmp             7.4.29-4             7.4.30-1
                         php7-sodium             7.4.29-4             7.4.30-1
                         php7-sqlite             7.4.29-4             7.4.30-1
                           php7-tidy             7.4.29-4             7.4.30-1
                            php7-xsl             7.4.29-4             7.4.30-1
                               picmi            22.04.2-1            22.04.3-1
                   pim-data-exporter            22.04.2-1            22.04.3-1
                    pim-sieve-editor            22.04.2-1            22.04.3-1
                           pimcommon            22.04.2-1            22.04.3-1
                       pipewire-alsa           1:0.3.53-3           1:0.3.55-2
                       pipewire-docs           1:0.3.53-3           1:0.3.55-2
                       pipewire-jack           1:0.3.53-3           1:0.3.55-2
                      pipewire-pulse           1:0.3.53-3           1:0.3.55-2
                       pipewire-v4l2           1:0.3.53-3           1:0.3.55-2
                   pipewire-x11-bell           1:0.3.53-3           1:0.3.55-2
                   pipewire-zeroconf           1:0.3.53-3           1:0.3.55-2
          plasma-browser-integration             5.25.2-1             5.25.3-1
                      plasma-desktop             5.25.2-1             5.25.3-1
                        plasma-disks             5.25.2-1             5.25.3-1
                     plasma-firewall             5.25.2-1             5.25.3-1
                    plasma-framework             5.95.0-2             5.96.0-1
                  plasma-integration             5.25.2-1             5.25.3-1
                           plasma-nm             5.25.2-1             5.25.3-1
                           plasma-pa             5.25.2-1             5.25.3-1
                          plasma-sdk             5.25.2-1             5.25.3-1
                plasma-systemmonitor             5.25.2-1             5.25.3-1
                  plasma-thunderbolt             5.25.2-1             5.25.3-1
                        plasma-vault             5.25.2-1             5.25.3-1
              plasma-wayland-session             5.25.2-1           5.25.3.1-1
                    plasma-workspace             5.25.2-1           5.25.3.1-1
         plasma-workspace-wallpapers             5.25.2-1             5.25.3-1
                              polkit              0.120-5                121-1
                    polkit-kde-agent             5.25.2-1             5.25.3-1
                             poppler            22.06.0-1            22.07.0-1
                        poppler-glib            22.06.0-1            22.07.0-1
                         poppler-qt5            22.06.0-1            22.07.0-1
                         poppler-qt6            22.06.0-1            22.07.0-1
                          powerdevil             5.25.2-1             5.25.3-1
                               poxml            22.04.2-1            22.04.3-1
                       print-manager            22.04.2-1            22.04.3-1
                              prison             5.95.0-1             5.96.0-1
                             purpose             5.95.0-1             5.96.0-1
                 python-cryptography             37.0.2-1             37.0.4-1
                    python-openbabel              3.1.1-3              3.1.1-4
                       python-pyqt3d             5.15.2-3                    -
              python-pyqt5-webengine             5.15.6-1           5.15.6-1.1
                    python-pyqtchart             5.15.2-3                    -
        python-pyqtdatavisualization             5.15.2-2                    -
               python-pyqtpurchasing             5.15.2-2                    -
                python-pyqtwebengine             5.15.2-2                    -
                         qcachegrind            22.04.2-1            22.04.3-1
                  qqc2-desktop-style             5.95.0-1             5.96.0-1
                           ristretto             0.12.2-1             0.12.3-1
                                rocs            22.04.2-1            22.04.3-1
                                ruby              3.0.4-1                    -
                           ruby-docs              3.0.4-1                    -
                            sddm-kcm             5.25.2-1             5.25.3-1
                          sdl2_image              2.0.5-2              2.6.0-2
                          sdl2_mixer              2.0.4-7              2.6.1-1
                            sdl2_ttf             2.0.18-1             2.20.0-1
            signon-kwallet-extension            22.04.2-1            22.04.3-1
                            skanlite            22.04.2-1            22.04.3-1
                            skanpage            22.04.2-1            22.04.3-1
                               solid             5.95.0-1             5.96.0-1
                              sonnet             5.95.0-1             5.96.0-1
                           spectacle            22.04.2-1            22.04.3-1
                                step            22.04.2-1            22.04.3-1
                             svgpart            22.04.2-1            22.04.3-1
                             sweeper            22.04.2-1            22.04.3-1
                         syndication             5.95.0-1             5.96.0-1
                 syntax-highlighting             5.95.0-1             5.96.0-1
                      systemsettings             5.25.2-1             5.25.3-1
          telepathy-kde-accounts-kcm            22.04.2-1            22.04.3-1
              telepathy-kde-approver            22.04.2-1            22.04.3-1
                        threadweaver             5.95.0-1             5.96.0-1
                           truecrypt             1:7.1a-9                    -
                            umbrello            22.04.2-1            22.04.3-1
                              upower            0.99.19-1            0.99.20-1
                                vala             0.56.1-1             0.56.2-1
                         wireplumber             0.4.11-1             0.4.11-2
                    wireplumber-docs             0.4.11-1             0.4.11-2
                        wxgtk-common            3.0.5.1-3                    -
                              wxgtk2            3.0.5.1-3                    -
                              wxgtk3            3.0.5.1-3                    -
              xdg-desktop-portal-kde             5.25.2-1             5.25.3-1
                xf86-input-synaptics              1.9.1-3              1.9.2-1
                    xf86-input-wacom              1.0.0-1              1.1.0-1
                    xfce4-xkb-plugin              0.8.2-1              0.8.3-1
                      xorg-font-util              1.3.2-3              1.3.3-1
                xorg-fonts-encodings              1.0.5-2              1.0.6-1
                         xorg-server             21.1.3-7             21.1.4-1
                  xorg-server-common             21.1.3-7             21.1.4-1
                   xorg-server-devel             21.1.3-7             21.1.4-1
                  xorg-server-xephyr             21.1.3-7             21.1.4-1
                   xorg-server-xnest             21.1.3-7             21.1.4-1
                    xorg-server-xvfb             21.1.3-7             21.1.4-1
                     xorg-xclipboard              1.1.3-4              1.1.4-1
                         xorg-xcmsdb              1.0.5-4              1.0.6-1
                       xorg-xconsole              1.0.7-4              1.0.8-1
                            xorg-xev              1.2.4-1              1.2.5-1
                       xorg-xfontsel              1.0.6-3              1.1.0-1
                       xorg-xkbutils              1.0.4-5              1.0.5-1
                           xorg-xmag              1.0.6-4              1.0.7-1
                       xorg-xmessage              1.0.5-3              1.0.6-1
                        xorg-xmodmap             1.0.10-3             1.0.11-1
                            xorg-xpr              1.0.5-3              1.1.0-1
                       xorg-xrefresh              1.0.6-3              1.0.7-1
                       xorg-xwayland             22.1.2-1             22.1.3-1
                           xorg-xwud              1.0.5-3              1.0.6-1
                             yakuake            22.04.2-1            22.04.3-1
                             zanshin            22.04.2-1            22.04.3-1
                    zeroconf-ioslave            22.04.2-1            22.04.3-1
                           zxing-cpp              1.3.0-1              1.4.0-1
                    wxwidgets-common                    -              3.2.0-2
                      wxwidgets-gtk3                    -              3.2.0-2
                       wxwidgets-qt5                    -              3.2.0-2
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi22.04.2.r12790.ga8f072835-122.04.3.r12795.g425666ba7-1
                    akonadi-calendar22.04.2.r2134.g5008298-122.04.3.r2140.ge74a923-1
              akonadi-calendar-tools22.04.2.r955.g78bc490-122.04.3.r957.g97ab528-1
                    akonadi-contacts22.04.2.r3222.g91382c72-122.04.3.r3227.g41e4ae03-1
                        akonadi-mime22.04.2.r1743.g6e384f4-122.04.3.r1746.g8e3618b-1
                       akonadi-notes22.04.2.r1079.gdcf26c6-122.04.3.r1081.ge598e6a-1
                      akonadi-search22.04.2.r1244.g217440c-122.04.3.r1249.ga07a980-1
                           alligator  22.06.r4.g8d0eb37-1 22.06.r19.g4677847-1
                            analitza22.04.2.r2352.gb312e7db-122.04.3.r2352.gb312e7db-1
                           angelfish  22.06.r5.gf1131ad-1  22.06.r9.g486ec6d-1
                                 ark22.04.2.r4790.g8ffef346-122.04.3.r4817.g3861d22e-1
                          artikulate22.04.2.r1420.g603ba8c-122.04.3.r1424.g5696807-1
                              attica5.95.0.r875.gc0cabad-15.96.0.r876.g694daa4-1
                         audiocd-kio22.04.2.r1075.g5fcf99f-122.04.3.r1088.g89d626d-1
                           audiotube  22.06.r4.g05be539-1 22.06.r12.g1aabf2e-1
                               baloo5.95.0.r3058.g66444ad9-15.96.0.r3059.gea7d6992-1
                       baloo-widgets22.04.2.r761.g1390bc7-122.04.3.r762.g66425c4-1
                             blinken22.04.2.r672.g8c5c962-122.04.3.r674.gd2f67e7-1
                           bluedevil1:5.25.2.r2415.g84feb9ae-11:5.25.3.r2416.g65656cba-1
                            bluez-qt5.95.0.r714.g036c18e-15.96.0.r715.gc4f457a-1
                              bomber22.04.2.r568.g34e6fee-122.04.3.r569.g56cdf3c-1
                                bovo22.04.2.r781.g9974daa-122.04.3.r782.ga336e2a-1
                              breeze5.25.2.r2427.g664ad9b2-15.25.3.r2430.g224f6c37-1
                         breeze-grub5.25.2.r11.g63136a9-15.25.3.r11.g63136a9-1
                          breeze-gtk5.25.2.r485.gf5c1363-15.25.3.r485.gf5c1363-1
                        breeze-icons5.95.0.r1907.g2efe5026-15.96.0.r1908.ge6ae2ea7-1
                                buho  2.1.2.r5.g7c140d0-1  2.1.2.r6.g3fe40dc-1
                     calendarsupport22.04.2.r713.geed496f-122.04.2.r715.g08e6017-1
                           calindori  22.06.r4.g61ab916-1  22.06.r7.g53c09da-1
                            cervisia22.04.2.r1671.g44d23b1-122.04.3.r1688.gbf242b9-1
                            discover5.25.2.r8727.g24d3c665-15.25.3.r8730.g45170af1-1
                             dolphin22.04.2.r7030.gf3a0986b8-122.04.3.r7045.g513fe3bb4-1
                     dolphin-plugins22.04.2.r666.g11c7e24-122.04.3.r668.g0db9289-1
                              dragon22.04.2.r1047.gc4ec64b-122.04.3.r1048.ge20da44-1
                             drkonqi5.25.2.r800.g7a514e37-15.25.3.r801.g00b3f48e-1
                               elisa22.04.2.r2993.gddb53c4a-122.04.3.r3000.g137dc97f-1
                          elisa-qtmm22.04.2.r2993.gddb53c4a-122.04.3.r3000.g137dc97f-1
                          eventviews22.04.2.r852.g41703f4-122.04.2.r857.gb612b23-1
                 extra-cmake-modules5.95.0.r3504.g0064cf77-15.96.0.r3505.g7d9d14e7-1
                        ffmpegthumbs22.04.2.r223.g15e8b7e-122.04.3.r224.gd56f12a-1
                           filelight22.04.2.r1146.g696d25c-122.04.3.r1154.g97fbbd4-1
                frameworkintegration5.95.0.r645.g0ea3706-15.96.0.r646.g8d61097-1
                           granatier22.04.2.r981.gd4587f5-122.04.3.r986.gb00b485-1
                       grantleetheme22.04.2.r404.g1cc8b0b-122.04.3.r406.g6816d83-1
                            gwenview22.04.2.r6874.gfaa1f11f-122.04.2.r6875.g6f2203fb-1
                           itinerary22.04.2.r1935.geb45637-122.04.3.r1948.g2b8f969-1
                                 juk22.04.2.r3160.gb81df2ac-122.04.3.r3163.g9de34979-1
                                 k3b1:22.04.2.r6798.gf4d447a24-11:22.04.3.r6805.g37c595478-1
               kaccounts-integration22.04.2.r1261.gf26f043-122.04.3.r1266.g6e872ab-1
                 kaccounts-providers22.04.2.r399.g2025b96-122.04.3.r400.gdeeece1-1
                         kactivities5.95.0.r1399.g336982ef-15.96.0.r1404.gfeda83d6-1
                   kactivities-stats5.95.0.r411.g90f9427-15.96.0.r412.gd64e767-1
                   kactivitymanagerd5.25.2.r1412.g6b9a376-15.25.3.r1412.g6b9a376-1
                        kaddressbook22.04.2.r6212.gf733cbb5-122.04.2.r6213.g8588e4eb-1
                              kalarm22.04.2.r7952.g75b03dbd-122.04.3.r7956.gef920816-1
                            kalgebra22.04.2.r2068.g8f4b41d-122.04.3.r2069.g71f9bdf-1
                                kalk  22.06.r7.g3aeecc7-1  22.06.r8.g7626461-1
                             kalzium22.04.2.r4365.gaeeeb32a-122.04.3.r4370.g254ff1d8-1
                              kamera22.04.2.r726.g8d8dd08-122.04.3.r728.gf685528-1
                              kamoso22.04.2.r1469.g0553dd7-122.04.3.r1470.gc7d4dd4-1
                            kanagram22.04.2.r1315.ge0de2d1-122.04.3.r1318.g8437164-1
                             kapidox5.95.0.r572.g9baade5-15.96.0.r573.gabf4756-1
                              kapman22.04.2.r661.g38630ec-122.04.3.r665.g6e39899-1
                        kapptemplate22.04.2.r996.g16a48d2-122.04.3.r997.g20b2c62-1
                            karchive5.95.0.r548.gd81a8ee-15.96.0.r549.g20b8e69-1
                               kasts 22.06.r18.gfa2d552-1 22.06.r27.gce45074-1
                                kate22.04.2.r19213.g356278ab2-122.04.3.r19238.g2403075c3-1
                             katomic22.04.2.r966.gb49eb3c-122.04.3.r967.gf5c1e78-1
                               kauth5.95.0.r502.g6af7041-15.96.0.r503.g4545a5a-1
                             kbackup22.04.2.r446.ge10a50f-122.04.3.r447.gc03a8d9-1
                           kblackbox22.04.2.r770.g05f5509-122.04.3.r774.g8428377-1
                             kblocks22.04.2.r732.gb71d839-122.04.3.r749.g7250568-1
                          kbookmarks5.95.0.r464.g9ba8ede-15.96.0.r465.gdfcd9a6-1
                             kbounce22.04.2.r853.ge9aa7f5-122.04.3.r856.gaec2598-1
                           kbreakout22.04.2.r927.gf6d7870-122.04.3.r930.gb90aab3-1
                              kbruch22.04.2.r871.g1a2963b-122.04.3.r872.gbe4aa00-1
                         kcachegrind22.04.2.r1188.g2a19a76-122.04.3.r1189.gbdeab59-1
                  kcachegrind-common22.04.2.r1188.g2a19a76-122.04.3.r1189.gbdeab59-1
                               kcalc22.04.2.r1621.gbd8a0dd-122.04.3.r1622.ga2ad8a3-1
                       kcalendarcore5.95.0.r1333.g62b78a12f-15.96.0.r1335.g0fbb0c73f-1
                           kcalutils22.04.2.r971.g47c43cb1c-122.04.3.r973.ga853bbb6d-1
                         kcharselect22.04.2.r535.g5fb4eca-122.04.3.r538.g9c2bd2e-1
                              kclock 22.06.r10.gedc9add-1 22.06.r13.g882a72a-1
                            kcmutils5.95.0.r646.g682cae8-15.96.0.r648.g58af203-1
                             kcodecs5.95.0.r425.g023a5cc-15.96.0.r426.ge62c81c-1
                       kcolorchooser22.04.2.r276.ga066dc4-122.04.3.r277.gdb41f6d-1
                         kcompletion5.95.0.r497.g4fa1fe3-15.96.0.r506.gb10de8d-1
                             kconfig5.95.0.r963.gee0e9486-15.96.0.r964.gd96f19bc-1
                      kconfigwidgets5.95.0.r748.g12080c8-15.96.0.r750.geb393b1-1
                           kcontacts1:5.95.0.r3339.ga8e2cf32-11:5.96.0.r3341.gcabbaf31-1
                         kcoreaddons5.95.0.r1522.gd88079c9-15.96.0.r1530.g8e0f756e-1
                              kcrash5.95.0.r450.g2308abd-15.96.0.r451.g0dcdf97-1
                               kcron22.04.2.r848.g44fb6fe-122.04.3.r848.g44fb6fe-1
                                kdav1:5.95.0.r1348.g9821d72-11:5.96.0.r1350.g20ecfa7-1
                         kdbusaddons5.95.0.r420.g9184af3-15.96.0.r421.gfe3cbed-1
                       kde-cli-tools5.25.2.r1945.g5d1ed28-15.25.3.r1945.g5d1ed28-1
                     kde-dev-scripts22.04.2.r4147.g60726b0-122.04.3.r4152.gea6d462-1
                       kde-dev-utils22.04.2.r593.g7d26ddb-122.04.3.r594.gb8df7e2-1
                      kde-gtk-config5.25.2.r938.gda46494-15.25.3.r938.gda46494-1
                      kdebugsettings22.04.2.r933.ge346d14-122.04.3.r942.gfc9b1f2-1
                        kdeclarative5.95.0.r1015.g375647c-15.96.0.r1016.g8666822-1
                          kdeconnect22.04.2.r3481.g2da891b3-122.04.3.r3490.g280c0fb2-1
                         kdecoration5.25.2.r295.g5df2f5b-15.25.3.r295.g5df2f5b-1
                                kded5.95.0.r466.gc9e9441-15.96.0.r467.gc7a921a-1
                         kdeedu-data22.04.2.r17.g1b749b8-122.04.3.r17.g1b749b8-1
              kdegraphics-mobipocket22.04.2.r274.gc9f5c9f-122.04.3.r274.gc9f5c9f-1
            kdegraphics-thumbnailers22.04.2.r274.g1359130-122.04.3.r274.g1359130-1
                     kdelibs4support5.95.0.r1096.g6701e008-15.96.0.r1098.g72f301e4-1
              kdenetwork-filesharing22.04.2.r961.gbc35019-122.04.3.r961.gbc35019-1
                            kdenlive22.04.2.r16341.gc67783c3d-122.04.3.r16365.g9c3e77ecd-1
                       kdepim-addons22.04.2.r4692.g213bcfc37-122.04.2.r4698.g4281d604b-1
                      kdepim-runtime22.04.2.r15554.g740ab1bad-122.04.3.r15559.g04a8d8375-1
                    kdeplasma-addons5.25.2.r8917.g122ee9e5d-15.25.3.r8926.gb7c0de671-1
                    kdesdk-kioslaves22.04.2.r503.g5a8c59f-122.04.3.r505.g1f7909e-1
                 kdesdk-thumbnailers22.04.2.r92.g5da979d-122.04.3.r93.g7ff219f-1
                     kdesignerplugin5.95.0.r357.gd05ed69-15.96.0.r358.g1603103-1
                               kdesu5.95.0.r511.g4ca945d-15.96.0.r512.gb1963b7-1
                           kdewebkit5.95.0.r304.ga756ad0-15.96.0.r305.g6be60b7-1
                                 kdf22.04.2.r865.gd4118a0-122.04.3.r866.g2d1bcf1-1
                             kdialog22.04.2.r1231.g85b41be88-122.04.3.r1232.g1f8285e07-1
                            kdiamond22.04.2.r730.g8f8734b-122.04.3.r731.gd2acca8-1
                              kdnssd5.95.0.r354.gdd8b264-15.96.0.r355.g60f918e-1
                           kdoctools5.95.0.r671.g6d957f1-15.96.0.r672.gd1a4ebe-1
                      keditbookmarks22.04.2.r2767.g800862758-122.04.3.r2768.ga1096196d-1
                          kemoticons5.95.0.r421.gf585f9c-15.96.0.r422.ge293d50-1
                            keysmith  22.06.r4.gddbaea9-1  22.06.r7.gdc845ae-1
                       kfilemetadata5.95.0.r865.gcdb65cc-15.96.0.r866.gcb95bf6-1
                               kfind22.04.2.r2704.g672e6ca9d-122.04.3.r2707.gce0bdd888-1
                             kfloppy22.04.2.r795.g1075e90-122.04.3.r798.ged6a909-1
                         kfourinline22.04.2.r1030.g789e233-122.04.3.r1031.ga76109c-1
                             kgamma55.25.2.r481.g5d1c771-15.25.3.r481.g5d1c771-1
                          kgeography22.04.2.r1160.geb6d9dd-122.04.3.r1161.g65d2576-1
                                kget22.04.2.r3213.g260b7650-122.04.3.r3215.g827824c6-1
                        kglobalaccel5.95.0.r533.g84bdb69-15.96.0.r536.gca47aad-1
                         kgoldrunner22.04.2.r1289.g70f24e5-122.04.3.r1290.g9270c9b-1
                                kgpg22.04.2.r3196.g07882605-122.04.3.r3197.gc45271cd-1
                          kguiaddons5.95.0.r479.g5f6be73-15.96.0.r480.gbabf1aa-1
                            khangman22.04.2.r1617.gbb373d1-122.04.3.r1618.gb49b93f-1
                         khelpcenter22.04.2.r2750.g279b7dde-122.04.3.r2757.g460a5dff-1
                           kholidays1:5.95.0.r1044.gc89aabb-11:5.96.0.r1045.g8cc6ac7-1
                            khotkeys5.25.2.r2148.g9893b39-15.25.3.r2149.g831ed9e-1
                               khtml5.95.0.r589.g26ca9ab-15.96.0.r590.g559f347-1
                               ki18n5.95.0.r563.g8b142fe-15.96.0.r564.g0926f2b-1
                         kiconthemes5.95.0.r611.gc9d2f6c-15.96.0.r614.g524cc07-1
                 kidentitymanagement22.04.2.r3892.gb54c71bc-122.04.3.r3894.g490e2cd4-1
                           kidletime5.95.0.r361.g077d659-15.96.0.r362.g07f0ef5-1
                                 kig22.04.2.r3199.g31faa538-122.04.3.r3201.g9783d25e-1
                                kigo22.04.2.r575.gf780c4c-122.04.3.r576.g0bcdcce-1
                            killbots22.04.2.r799.gedca99c-122.04.3.r800.g5357bac-1
                       kimageformats5.95.0.r418.g9b3133a-15.96.0.r419.gd030c75-1
                     kimagemapeditor22.04.2.r498.gc25b7ab-122.04.3.r500.g98044a1-1
                               kimap22.04.2.r1198.gdb6c159-122.04.3.r1200.gc0d4834-1
                         kinfocenter5.25.2.r2113.g53ee4e7c-15.25.3.r2116.gcc19207f-1
                               kinit5.95.0.r442.g577fe9c-15.96.0.r443.g208c119-1
                                 kio5.95.0.r5559.g9da77659d-15.96.0.r5582.g90afd1559-1
                          kio-extras22.04.2.r7293.g22b9d3bd-122.04.3.r7298.g52a56adc-1
                          kio-gdrive22.04.2.r617.g5433bd6-122.04.3.r620.g8a6015c-1
                     kirigami-addons  1:0.3.r0.g917a0fa-1  1:0.3.r4.g4054d97-1
                    kirigami-gallery22.04.2.r248.ge234799-122.04.3.r254.g82bfb6a-1
                           kirigami25.95.0.r3172.gf6390be4-15.96.0.r3181.gc28dff79-1
                              kiriki22.04.2.r456.ge4464f0-122.04.3.r457.gf91e1d2-1
                         kitemmodels5.95.0.r612.gb10d523-15.96.0.r613.g8f6edf9-1
                          kitemviews5.95.0.r378.gddbebf8-15.96.0.r379.g77f35ee-1
                               kiten22.04.2.r1187.g47e651e-122.04.3.r1204.g30d55af-1
                          kitinerary22.04.2.r2288.g1826a60-122.04.3.r2298.g46ce330-1
                         kjobwidgets5.95.0.r419.g534d4ef-15.96.0.r422.g437782c-1
                                 kjs5.95.0.r364.g9ecac5b-15.96.0.r365.g782fef5-1
                            kjsembed5.95.0.r330.g739a999-15.96.0.r332.gc786956-1
                        kjumpingcube22.04.2.r828.g4359e77-122.04.3.r829.gec18caf-1
                               kldap22.04.2.r956.gc8c4d6a-122.04.3.r958.g09889e4-1
                           kleopatra22.04.2.r6634.gdbc0e886-122.04.3.r6674.g3e82c3fd-1
                            klettres22.04.2.r967.gf09902c-122.04.3.r970.g2f8b05f-1
                            klickety22.04.2.r679.g671bd53-122.04.3.r701.geb808ff-1
                              klines22.04.2.r823.g24962cf-122.04.3.r824.g7911d74-1
                                kmag22.04.2.r740.g8d360f5-122.04.3.r742.gb02aa68-1
                           kmahjongg22.04.2.r1557.gaaca0da-122.04.3.r1559.g96f1bbf-1
                               kmail22.04.2.r26439.gde3d97145-122.04.2.r26440.ge666c1ea4-1
                      kmailtransport22.04.2.r1749.ge3d7fbf-122.04.3.r1751.gd05322e-1
                               kmbox22.04.2.r601.g07a272c-122.04.3.r603.g29bb1b6-1
                        kmediaplayer5.95.0.r320.gd8713aa-15.96.0.r321.gf68bf85-1
                           kmenuedit5.25.2.r1052.gce1f6cb-15.25.3.r1054.ge07192d-1
                               kmime22.04.2.r1520.gbe8aa96-122.04.3.r1522.g16fb26b-1
                              kmines22.04.2.r1770.g859e949-122.04.3.r1771.gd14a074-1
                                kmix22.04.2.r2454.g0abe8a6b-122.04.3.r2455.g77494fc6-1
                          kmousetool22.04.2.r448.gd1fc84e-122.04.3.r449.gf5bc443-1
                              kmouth22.04.2.r734.g7d73167-122.04.3.r734.g7d73167-1
                              kmplot22.04.2.r1497.g7674529-122.04.3.r1501.gd71227e-1
                        knavalbattle22.04.2.r1436.gc8ecc65-122.04.3.r1440.g442257c-1
                            knetwalk22.04.2.r705.g3cf77a1-122.04.3.r706.g4c5c5f5-1
                           knewstuff5.95.0.r1361.g7402b2b1-15.96.0.r1366.g39c74671-1
                             knights22.04.2.r1150.g90391df-122.04.3.r1151.g5a6ba8b-1
                      knotifications5.95.0.r748.ga9d11ee-15.96.0.r751.gc66aea1-1
                       knotifyconfig5.95.0.r388.g4f30169-15.96.0.r389.gc0aad14-1
                                koko  22.06.r5.g5c5daae-1  22.06.r6.gdd9222a-1
                                kolf22.04.2.r1513.g500da49-122.04.3.r1514.ge9edb64-1
                           kollision22.04.2.r540.g2f219f1-122.04.3.r541.g9e8398b-1
                         kolourpaint22.04.2.r2417.g922d4c75-122.04.3.r2425.g8b6d4d1b-1
                             kompare22.04.2.r1144.g344ec8d-122.04.3.r1145.gf7b472b-1
                            kongress  22.06.r3.g9d310c9-1  22.06.r5.gbaa77e7-1
                           konqueror22.04.2.r15126.g048083993-122.04.3.r15130.g90807e9fa-1
                            konquest22.04.2.r936.g5115000-122.04.3.r937.g82baf47-1
                             konsole22.04.2.r8533.gf4b83696-122.04.3.r8550.ga49dfc0f-1
                             kontact22.04.2.r5545.g4b1c5c83-122.04.2.r5546.g3f092aac-1
                    kontactinterface22.04.2.r698.g7969038-122.04.3.r701.g8dc1cca-1
                            kontrast22.04.2.r210.gf0e87e4-122.04.3.r211.gde0b942-1
                        konversation22.04.2.r9128.ge7bbd6c1-122.04.3.r9130.g08bfe884-1
                       kopeninghours22.04.2.r332.g37dacc1-122.04.3.r333.g79db379-1
                              kopete22.04.2.r16444.gae623c90d-122.04.3.r16444.gae623c90d-1
                       kosmindoormap22.04.2.r744.gd3d9d0f-122.04.3.r745.gd64ad4d-1
                            kpackage5.95.0.r757.gee20342-15.96.0.r758.g2cc209e-1
                              kparts5.95.0.r591.g8a14644-15.96.0.r592.g58357be-1
                                kpat22.04.2.r2625.g5e59e5b2-122.04.3.r2626.g6d53abc5-1
                             kpeople5.95.0.r1379.g230c82a-15.96.0.r1380.gea10047-1
                         kpeoplesink       r80.g8f64248-1       r81.g4f129cb-3
                        kpimtextedit22.04.2.r1602.ge2c7bf1-122.04.3.r1604.g1bf4ec6-1
                           kpipewire5.25.2.r134.gca8fbdb-15.25.3.r134.gca8fbdb-1
                             kpkpass22.04.2.r300.gefa8479-122.04.3.r302.g19d9f17-1
                           kplotting5.95.0.r327.gc121d42-15.96.0.r328.g61fd8b9-1
                             kpmcore22.04.2.r1292.g3dc4b78-122.04.3.r1293.g1ec8b8b-1
                                kpty5.95.0.r379.gbc039ac-15.96.0.r380.gfba4b75-1
                    kpublictransport22.04.2.r2031.g6b2a87e6-122.04.3.r2033.g58994c55-1
                      kqtquickcharts22.04.2.r77.g9b882ce-122.04.3.r77.g9b882ce-1
                        kquickcharts5.95.0.r520.gb7697fe-15.96.0.r525.g0b6c9e5-1
                   kquickimageeditor       r70.gbe39cdb-1       r72.gb19c42e-1
                                krdc22.04.2.r1607.g4a1a276-122.04.3.r1609.g194d0c5-1
                           krecorder  22.06.r7.g5cbc570-1  22.06.r8.gb303c3b-1
                            kreversi22.04.2.r1275.gcffcd49-122.04.3.r1276.gd267028-1
                                krfb22.04.2.r1506.gd1d0850-122.04.3.r1507.g2cd15b6-1
                               kross5.95.0.r361.gc64793a-15.96.0.r362.g06fc4ec-1
                  kross-interpreters22.04.2.r724.g2a6213a-122.04.3.r724.g2a6213a-1
                              kruler22.04.2.r738.g96cf3a0-122.04.3.r739.g56ea9fe-1
                             krunner5.95.0.r774.g6e1ef5f-15.96.0.r776.gef20c81-1
                             kscreen5.25.2.r1479.gdd4ce63-15.25.3.r1484.gbcc0353-1
                       kscreenlocker5.25.2.r968.gcc7a05c-15.25.3.r969.g51ae818-1
                            kservice5.95.0.r1020.g58b061f-15.96.0.r1023.g5b12b2d-1
                             kshisen22.04.2.r1250.g250c4f1-122.04.3.r1251.gc911899-1
                               ksirk22.04.2.r1036.g294de44-122.04.3.r1037.gaefec34-1
                               ksmtp22.04.2.r451.g266ed11-122.04.3.r453.g09909c6-1
                          ksnakeduel22.04.2.r859.g558b861-122.04.3.r860.gd452466-1
                          kspaceduel22.04.2.r678.g21c85b3-122.04.3.r679.g9766b8b-1
                            ksquares22.04.2.r565.gda9f023-122.04.3.r566.g608dcbf-1
                         ksshaskpass5.25.2.r212.gd1bef1b-15.25.3.r212.gd1bef1b-1
                             ksudoku22.04.2.r1121.g0c28bd9-122.04.3.r1122.g5057715-1
                           ksysguard5.25.2.r3536.g163b3822-15.25.3.r3537.g47f5443b-1
                          ksystemlog22.04.2.r737.gdc39a2c-122.04.3.r738.g75a35bc-1
                        ksystemstats5.25.2.r231.g442ec4f-15.25.3.r232.g5ae8db9-1
                            kteatime22.04.2.r761.g6cd7ba4-122.04.3.r763.g24b20aa-1
                         ktexteditor5.95.0.r3430.g509ca8a4-15.96.0.r3439.gfb610965-1
                        ktextwidgets5.95.0.r452.g138967f-15.96.0.r453.g7f5c312-1
                              ktimer22.04.2.r521.g6c8a10b-122.04.3.r524.gafb0cec-1
                               ktnef22.04.2.r721.g855853f-122.04.3.r723.gd2cd453-1
                            ktorrent22.04.2.r2866.ge7a394ae-122.04.3.r2867.gcb0986aa-1
                              ktouch22.04.2.r2186.g55c07f6-122.04.3.r2191.gdfd4dfa-1
                               ktrip  22.06.r6.gba29a14-1  22.06.r7.g6c20cf6-1
                          ktuberling22.04.2.r1064.g06d2867-122.04.3.r1065.g75e542e-1
                             kturtle22.04.2.r1177.g1c2f5d1-122.04.3.r1178.gbe120d4-1
                             kubrick22.04.2.r412.ge19d338-122.04.3.r413.gb7f7406-1
                     kunitconversion5.95.0.r422.ga205fcb-15.96.0.r423.ge54e91e-1
                             kwallet5.95.0.r1158.g36d83d1-15.96.0.r1162.g6239a80-1
                         kwallet-pam5.25.2.r271.g40ad5fe-15.25.3.r271.g40ad5fe-1
                      kwalletmanager22.04.2.r1276.gaab5f6e-122.04.3.r1280.gb6c61f2-1
                               kwave22.04.2.r3799.g56b8c294-122.04.3.r3800.gb5ccf044-1
                            kwayland5.95.0.r1169.g2cbfb45-15.96.0.r1170.ge5fda97-1
                kwayland-integration5.25.2.r210.g232f727-15.25.3.r212.gef63862-1
                     kwayland-server5.25.2.r1480.g7f15f36-15.25.3.r1480.g7f15f36-1
                            kweather 22.06.r11.gc30638f-1 22.06.r14.g4e09fef-1
                        kweathercore    0.6.r3.g405594f-1    0.6.r5.g51000a1-1
                      kwidgetsaddons5.95.0.r950.g65f2136a-15.96.0.r951.g4407542b-1
                                kwin5.25.2.r22703.g40fb202ae-15.25.3.r22762.ge801819a2-1
                       kwindowsystem5.95.0.r687.ga79f887-15.96.0.r688.gcf30501-1
                           kwordquiz22.04.2.r1186.g46a62fd-122.04.3.r1189.g589682f-1
                              kwrite22.04.2.r19213.g356278ab2-122.04.3.r19238.g2403075c3-1
                             kwrited5.25.2.r513.g1fd988d-15.25.3.r513.g1fd988d-1
                             kxmlgui5.95.0.r891.g265eac17-15.96.0.r893.gde0790fe-1
                       kxmlrpcclient5.95.0.r484.g53289676b-15.96.0.r485.g39b1f081d-1
                      layer-shell-qt5.25.2.r62.g7bd6366-15.25.3.r62.g7bd6366-1
                          libakonadi22.04.2.r12790.ga8f072835-122.04.3.r12795.g425666ba7-1
                            libkcddb22.04.2.r764.ga779c9f-122.04.3.r764.ga779c9f-1
                     libkcompactdisc22.04.2.r396.g25896b1-122.04.3.r396.g25896b1-1
                           libkdcraw22.04.2.r1153.ga4a99cf-122.04.3.r1153.ga4a99cf-1
                         libkdegames22.04.2.r2251.gc5848c0d-122.04.3.r2251.gc5848c0d-1
                           libkdepim22.04.2.r911.g4cae214-122.04.3.r913.g5e2ee45-1
                  libkeduvocdocument22.04.2.r1810.g5b20cc7-122.04.3.r1810.g5b20cc7-1
                           libkexiv222.04.2.r827.g40cd78b-122.04.3.r827.g40cd78b-1
                            libkgapi22.04.2.r1367.g7833cb8-122.04.3.r1370.g3246ebd-1
                             libkipi22.04.2.r1280.g5b6d13f-122.04.3.r1280.g5b6d13f-1
                             libkleo22.04.2.r1192.g7201c46-122.04.3.r1206.g121ed86-1
                        libkmahjongg22.04.2.r485.g63e3d24-122.04.3.r485.g63e3d24-1
                     libkomparediff222.04.2.r346.g5e898ac-122.04.3.r346.g5e898ac-1
                            libksane22.04.2.r596.gccb6b71-122.04.3.r604.g779611e-1
                          libkscreen5.25.2.r1632.g6c3140b-15.25.3.r1632.g6c3140b-1
                        libksysguard5.25.2.r2417.gccb0a41-15.25.3.r2419.gabe0012-1
                         libktorrent22.04.2.r551.g66cdae3-122.04.3.r552.g4f6c01c-1
                            lokalize22.04.2.r1837.g0134f3c6-122.04.3.r1839.g33f0eb22-1
                               lskat22.04.2.r859.g956bab5-122.04.3.r860.gbf65356-1
                    maliit-framework2.2.1.r26.g4604743f-1 2.3.0.r0.gcb623a42-1
                     maliit-keyboard2.2.1.1.r59.gfa554a68-1 2.3.0.r0.gdcde37d3-1
                              marble22.04.2.r13455.g14f090099-122.04.3.r13457.g9549f409a-1
                       marble-common22.04.2.r13455.g14f090099-122.04.3.r13457.g9549f409a-1
                           marble-qt22.04.2.r13455.g14f090099-122.04.3.r13457.g9549f409a-1
                        markdownpart22.04.2.r129.g21207fc-122.04.3.r130.gaabaf84-1
                           maui-clip  2.1.2.r6.g1480a86-1  2.1.2.r8.gccab67d-1
                        maui-manager        r25.563c3a9-1        r27.e52c416-1
                          maui-shell 0.5.0.r43.g4feaa5c-1 0.5.0.r52.gb0ccd14-1
                             mauiman        r15.b5c87ae-1        r22.f42eb96-1
                               milou5.25.2.r779.g0363d7a-15.25.3.r780.ga50415d-1
                              minuet22.04.2.r615.g5b74c41-122.04.3.r618.gd5a8e59-1
                     modemmanager-qt5.95.0.r557.g936dfff-15.96.0.r558.gbc128da-1
             mycroft-skill-installer        r95.a6e7d81-1        r96.eb1016d-1
                             neochat22.06.r12.g1dff2b82-122.06.r40.ga37fd071-1
                   networkmanager-qt5.95.0.r1157.g7a1de86-15.96.0.r1158.gea3156d-1
                              okular22.04.2.r9784.g64086998c-122.04.3.r9792.g37dd66593-1
                              oxygen5.25.2.r4494.g9a0bebcb-15.25.3.r4497.g489752e0-1
                        oxygen-icons1:5.95.0.r5.gbff159d-11:5.96.0.r5.gbff159d-1
                    oxygen-icons-svg1:5.95.0.r5.gbff159d-11:5.96.0.r5.gbff159d-1
                            palapeli22.04.2.r1290.g11fbde7-122.04.3.r1293.gb8840f4-1
                              parley22.04.2.r4530.g31e5011a-122.04.3.r4531.g5d76d7d5-1
                    partitionmanager22.04.2.r1634.gfda3b25-122.04.3.r1637.g799603c-1
                               picmi22.04.2.r565.g2457d21-122.04.3.r565.g2457d21-1
                        plank-player        r28.916d4c1-1        r29.f536191-1
                    plasma-bigscreen      r475.gd536355-1      r485.g6520768-1
          plasma-browser-integration5.25.2.r1336.g19f9c47b-15.25.3.r1338.g5b57c8be-1
                       plasma-camera  1.0.r127.g85ec608-1  1.0.r129.gd7cd0e4-1
                      plasma-desktop5.25.2.r9398.gb45d0cd6d-15.25.3.r9421.g890b3862b-1
                       plasma-dialer 22.06.r11.g479885a-1 22.06.r15.g5714110-1
                        plasma-disks5.25.2.r284.g7d97510-15.25.3.r285.gd2e6d02-1
                     plasma-firewall5.25.2.r640.ga715576-15.25.3.r642.gbbdfe7b-1
                    plasma-framework5.95.0.r16356.gebe2341f0-15.96.0.r16364.gbea3b07c3-1
                  plasma-integration5.25.2.r570.g62d32e8-15.25.3.r571.gb0cd3e1-1
                       plasma-mobile5.25.2.r1882.gc632dab1c-15.25.3.r1910.gd2824deed-1
                    plasma-mobile-nm5.25.2.r3283.gd9ae2eb6-15.25.3.r3294.g141ce673-1
                         plasma-nano5.25.2.r190.g8dc8976-15.25.3.r191.g5deb2a5-1
                           plasma-nm5.25.2.r3283.gd9ae2eb6-15.25.3.r3294.g141ce673-1
                           plasma-pa5.25.2.r1057.gf5bcbb8-15.25.3.r1058.g751b314-1
                    plasma-phonebook  22.06.r3.g746e900-1  22.06.r4.gd3c3687-1
            plasma-remotecontrollers       r92.gf9d7b6f-1       r93.g0ab8e75-1
                          plasma-sdk5.25.2.r2372.g9220179e-15.25.3.r2377.g29f3ee38-1
                     plasma-settings 22.06.r11.g3ccfa49-1 22.06.r27.g587b098-1
                plasma-systemmonitor5.25.2.r588.g696db20-15.25.3.r591.g1ea5812-1
                  plasma-thunderbolt5.25.2.r193.g8369978-15.25.3.r193.g8369978-1
                        plasma-vault5.25.2.r388.gf2f7183-15.25.3.r388.gf2f7183-1
              plasma-wayland-session5.25.2.r12039.gf24b7554b-15.25.3.r12076.g4989651e0-1
                    plasma-workspace5.25.2.r12039.gf24b7554b-15.25.3.r12076.g4989651e0-1
         plasma-workspace-wallpapers5.25.2.r357.gf1d882b-15.25.3.r360.g7705661-1
                          plasmatube  22.06.r5.g5e4a4fb-1  22.06.r6.g858abe4-1
                    polkit-kde-agent5.25.2.r531.ge482883-15.25.3.r531.ge482883-1
                          powerdevil5.25.2.r2558.g7614cac2-15.25.3.r2559.gbfb57f41-1
                               poxml22.04.2.r282.g2615361-122.04.3.r282.g2615361-1
                       print-manager22.04.2.r1142.g236fafa-122.04.3.r1145.g5d29881-1
                              prison5.95.0.r391.ge853937-15.96.0.r393.g74e34fa-1
                             purpose5.95.0.r981.gc1e757a-15.96.0.r983.ge4ae404-1
                         qcachegrind22.04.2.r1188.g2a19a76-122.04.3.r1189.gbdeab59-1
                          qmlkonsole  22.06.r5.g3478624-1  22.06.r8.ge54d9b8-1
                   qqc2-breeze-style5.25.2.r248.g2514ff8-15.25.3.r249.g36ec4ea-1
                  qqc2-desktop-style5.95.0.r628.g6279e3f-15.96.0.r639.gf804b45-1
                                rocs22.04.2.r3090.ge301b547-122.04.3.r3091.ged76779c-1
                            sddm-kcm5.25.2.r668.g7f477a3-15.25.3.r670.g08ecf2b-1
            signon-kwallet-extension22.04.2.r81.gd26709f-122.04.3.r82.g67533cf-1
                               solid5.95.0.r778.g82da602-15.96.0.r782.g806fb38-1
                              sonnet5.95.0.r700.g4c0d97f-15.96.0.r707.g091b91f-1
                            spacebar 22.06.r10.g9164ea3-1 22.06.r15.g9274506-1
                           spectacle22.04.2.r1368.g5ab3344-122.04.3.r1373.gba86116-1
                                step22.04.2.r1199.g733e773-122.04.3.r1200.g64a0495-1
                             svgpart22.04.2.r231.g0eaa001-122.04.3.r232.g9279041-1
                             sweeper22.04.2.r577.g00d5ee3-122.04.3.r578.g89755e6-1
                         syndication5.95.0.r877.gd7c4419-15.96.0.r878.g90db4b7-1
                 syntax-highlighting5.95.0.r1845.g2d8cdb5b-15.96.0.r1854.g778fa485-1
                      systemsettings5.25.2.r2689.gb788b584-15.25.3.r2693.g682b604c-1
          telepathy-kde-accounts-kcm22.04.2.r1219.g9ec4fad-122.04.3.r1220.g5d7feff-1
              telepathy-kde-approver22.04.2.r305.gcc15f81-122.04.3.r306.g53cec00-1
          telepathy-kde-auth-handler22.04.2.r283.gece2e65-122.04.3.r284.gc59f7d0-1
               telepathy-kde-call-ui22.04.2.r449.g4c30cd2-122.04.3.r450.ga1ee093-1
      telepathy-kde-common-internals22.04.2.r2021.g0f4205e-122.04.3.r2022.g09a775a-1
          telepathy-kde-contact-list22.04.2.r1092.gfa49eb5-122.04.3.r1093.g9c27117-1
        telepathy-kde-contact-runner22.04.2.r262.g1dd12e4-122.04.3.r263.gac42a1d-1
       telepathy-kde-desktop-applets22.04.2.r1005.g18d27bc-122.04.3.r1006.gb0a027c-1
  telepathy-kde-filetransfer-handler22.04.2.r226.g89862cf-122.04.3.r227.ga6083c9-1
    telepathy-kde-integration-module22.04.2.r401.ge4be972-122.04.3.r402.ga5572ce-1
             telepathy-kde-send-file22.04.2.r235.ga2969bb-122.04.3.r236.gcac0c0c-1
               telepathy-kde-text-ui22.04.2.r2047.g8999016-122.04.3.r2048.g596eeaf-1
                        threadweaver5.95.0.r545.gf106607-15.96.0.r546.g167d409-1
                             tokodon  22.06.r7.g00dcbf3-1 22.06.r13.g21aae2b-1
                            umbrello22.04.2.r8485.ge4d79cfe8-122.04.3.r8486.g4f81aaa82-1
                         vakzination  22.06.r6.g58eb8c5-1  22.06.r9.g872245a-1
              xdg-desktop-portal-kde5.25.2.r507.g5bc09db-15.25.3.r509.g3b31623-1
                             yakuake22.04.2.r801.gf79c14a-122.04.3.r802.g10be48c-1
                    zeroconf-ioslave22.04.2.r392.g30a1c9b-122.04.3.r394.gd86416e-1
                           ksanecore                    -      r622.g181a0bb-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Old Issues
Plasma Dialer cannot answer calls
Sadly Plasma Dialer 22.02 has a serious regression with no known workaround. It’s not possible to accept incoming calls. Very sorry about this. Follow the upstream bug report. We will patch the package as soon as a solution is found.
Plasma Mobile - Black screen after update
We are seeing some reports about Plasma Mobile on the PinePhone only showing a black screen after entering the PIN after this update.
Workaround: Downgrade qt5-es2-wayland to 5.15.2+kde+r41 which is now back in Stable and Testing branch repositories.
New Breath theme not applying correctly
With the update to the new Breath theme, a migration package tries to apply the new theme correctly.
However this is not getting done for Plasma’s Lockscreen and the SDDM theme.
So please go through your settings after updating to make sure the themes are correctly applied.
Fix: manjaro-system should take care of this for you.
Plasma Mobile switch to ModemManager
With the PlaMo Gear 21.12 release, Plasma Mobile is now using ModemManager as the telephony stack. So in order to use SIM capabilities, you need to switch from using oFono to ModemManager.
Fix: Run sudo systemctl disable --now ofono ofonoctl && sudo systemctl enable --now ModemManager. You might have to reboot your phone for Plasma Mobile to pick up this change.
Plasma Mobile has does not launch after update
This was caused by an error in kwin 5.23.2 which only affects installs based on openGLES (qt5-es2).
Fix: Update to kwin 5.23.2-1.2 or above.
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Hi,
@Strit and ARM dev, how to solve this issue ?
ok, it’s solved, I uninstalled wxgtk2 first and then proceed with the upgrade.
https://archlinux.org/news/wxwidgets-32-update-may-need-manual-intervention/
Something go wrong during the up date with an Odroid c4 kde
:: Replace wxgtk-common with extra/wxwidgets-common? [Y/n] y
:: Replace wxgtk3 with extra/wxwidgets-gtk3? [Y/n] y
resolving dependencies...
:: removing wxgtk-common breaks dependency 'wxgtk-common' required by wxgtk2
[nlc4@c4 ~]$
I’ll try to refuse
:: Replace wxgtk-common with extra/wxwidgets-common? [Y/n] n
:: Replace wxgtk3 with extra/wxwidgets-gtk3? [Y/n] n
:: wxwidgets-gtk3 and wxgtk3 are in conflict. Remove wxgtk3? [y/N] y
:: wxwidgets-common and wxgtk-common are in conflict. Remove wxgtk-common? [y/N] y
[nlc4@c4 ~]$
no up date issue with the Odroid m1 LXQt
wxgtk2 has been removed from the repository, so you should remove it from your installs.
Thanks for your reply, I found the same answer on the forum :-)
It is necessary for the odroid C4 kde (remove wxgtk2 first and then proceed with the upgrade) and not for the odroid m1 LXQt
Odroid m1 up to date
Summary
[m1@nls-m1 ~]$ date -u
mar. 19 juil. 2022 17:31:10 UTC
[m1@nls-m1 ~]$ screenfetch
                             m1@nls-m1
                             OS: Manjaro-ARM 22.07
                             Kernel: aarch64 Linux 5.19.0-rc6-2-MANJARO-ARM-RC
         #####               Uptime: 3d 5h 31m
        #######              Packages: Unknown
        ##O#O##              Shell: bash 5.1.16
        #######              Resolution: 1920x1080
      ###########            DE: LXQt 1.1.0
     #############           WM: OpenBox
    ###############          WM Theme: Mikachu
    ################         GTK Theme: Matcha-light-azul [GTK2/3]
   #################         Icon Theme: Papirus-Light
 #####################       Font: Noto Sans 11
 #####################       Disk:
   #################         CPU: Unknown @ 4x 1.992GHz
                             GPU: Mali-G52 r1 (Panfrost)
                             RAM: 1203MiB / 7450MiB
[m1@nls-m1 ~]$ uname -a
Linux nls-m1 5.19.0-rc6-2-MANJARO-ARM-RC #1 SMP PREEMPT Wed Jul 13 11:33:41 UTC 2022 aarch64 GNU/Linux
[m1@nls-m1 ~]$ sudo pacman -Syyuu
[sudo] password for m1:
:: Synchronising package databases...
 core                                      268,4 KiB   298 KiB/s 00:01 [########################################] 100%
 extra                                       2,5 MiB   747 KiB/s 00:03 [########################################] 100%
 community                                   6,6 MiB  1090 KiB/s 00:06 [########################################] 100%
Packages (2) linux-firmware-20220708.be7798e-0.2  linux-firmware-whence-20220708.be7798e-0.2
Total Download Size:   129,56 MiB
Total Installed Size:  474,46 MiB
Net Upgrade Size:        0,00 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 linux-firmware-whence-20220708.be779...    33,7 KiB   129 KiB/s 00:00 [########################################] 100%
 linux-firmware-20220708.be7798e-0.2-any   129,5 MiB  2047 KiB/s 01:05 [########################################] 100%
 Total (2/2)                               129,6 MiB  2044 KiB/s 01:05 [########################################] 100%
(2/2) checking keys in keyring                                         [########################################] 100%
(2/2) checking package integrity                                       [########################################] 100%
(2/2) loading package files                                            [########################################] 100%
(2/2) checking for file conflicts                                      [########################################] 100%
(2/2) checking available disk space                                    [########################################] 100%
(1/2) upgrading linux-firmware-whence                                  [########################################] 100%
(2/2) upgrading linux-firmware                                         [########################################] 100%
(1/2) Creating temporary files...
(2/2) Arming ConditionNeedsUpdate...
[m1@nls-m1 ~]$ reboot
My native keyboard is now working well :-)
@Strit
I know of this. But it’s only in Helsingør Kommune. Although the others are recommended to get a similar check done.
12 posts were split to a new topic: WiFi no longer works
