Hello ARM community.
New point release of Thunderbird, while we wait for the new big one.
LLVM/Clang updated to 14.0
Some highlights:
- Most of our kernels got updated
- Thunderbird updated to 91.11.0
- And Firefox had a point update with 102.0.1
- LLVM and Clang updated to 14.0
- Element Desktop updated to 1.11.0
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Thu Jul 7 12:57:49 CEST 2022)
- arm-testing community aarch64: 260 new and 257 removed package(s)
- arm-testing core aarch64: 27 new and 27 removed package(s)
- arm-testing extra aarch64: 300 new and 298 removed package(s)
- arm-testing kde-unstable aarch64: 348 new and 348 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-06-30 2022-07-07
code 1.68.0-1 1.68.1-1
eg25-manager 0.4.3-1 0.4.3+1+g34472a5-1
electron 19.0.5-1 19.0.7-1
electron17 17.4.8-1 17.4.9-1
element-desktop 1.10.15-1 1.11.0-1
element-web 1.10.15-1 1.11.0-1
gnome-contacts-mobile 41.0-2 42.0-1
gnome-control-center-mobile 42.2-1.7 42.3-1
gnome-initial-setup-mobile 42.1.1-2 42.2-1
gnome-todo-mobile 3.28.1+33+gc03a4c1-3 41.0-1
kodi-rpi-git20.x.60615.6e005074e6-120.x.60707.a05f4fc046-1
kodi-rpi-git-dev20.x.60615.6e005074e6-120.x.60707.a05f4fc046-1
kodi-rpi-git-eventclients20.x.60615.6e005074e6-120.x.60707.a05f4fc046-1
kodi-rpi-git-tools-texturepacker20.x.60615.6e005074e6-120.x.60707.a05f4fc046-1
libmm-pp-glib 1.18.10-1 1.18.10-2
linux-rpi4-udl 5.15.49-1 5.15.52-1
linux-rpi4-udl-headers 5.15.49-1 5.15.52-1
megapixels 1.5.1-1 1.5.2-1
modemmanager-pp 1.18.10-1 1.18.10-2
phoc0.21.0beta1+1+g826ca55-10.21.0beta1+8+gd24842d-1
phosh0.20.0beta2+1+ga259011c-3.00.20.0beta2+4+g5027b9c3-1
phosh-mobile-settings 0.0.1+8+g85dcce4-1 0.20.0_beta1-1
python-gbinder 1.0.0-2 1.1.0-1
siglo 0.9.8-1 0.9.9-2
signal-desktop 5.43.0-1 5.48.0-1
squeekboard 1.18.0+30+g50ef4ab-1 1.18.0+34+gcc7657e-1
:: Different sync package(s) in repository community aarch64
afl 2.57b-9 2.57b-11
apk-tools 2.12.9-1 2.12.10-1
babel-core 7.18.5-1 7.18.6-1
bandit 1.7.2-1 1.7.4-1
baresip 2.4.0-1 2.5.0-1
bash-language-server 3.0.3-1 3.0.5-1
bcc 0.24.0-1 0.24.0-2
bcc-tools 0.24.0-1 0.24.0-2
bemenu 0.6.7-1 0.6.10-1
bemenu-ncurses 0.6.7-1 0.6.10-1
bemenu-wayland 0.6.7-1 0.6.10-1
bemenu-x11 0.6.7-1 0.6.10-1
blender 17:3.2.0-3 17:3.2.1-1
bpftrace 0.15.0-1 0.15.0-2
broot 1.13.3-1 1.14.0-1
caja 1.26.0-1 1.26.1-1
cargo-c 0.9.10-1 0.9.11-1
cargo-edit 0.9.0-2 0.9.1-1
cargo-nextest 0.9.23-1 0.9.24-1
cargo-udeps 0.1.29-1 0.1.30-1
ccls 0.20210330-5 0.20210330-7
cinnamon-control-center 5.4.2-1 5.4.3-1
cloc 1.92-1 1.94-1
converseen 0.9.9.5-1 0.9.9.6-1
copyq 6.1.0-1 6.2.0-1
couchdb 3.2.2-2 3.2.2-3
cozy-stack 1:1.5.6-1 1:1.5.7-1
darktable 2:3.8.1-4 2:4.0.0-1
deja-dup 43.3-1 43.4-1
difftastic 0.29.1-1 0.30.0-1
docker-compose 2.6.0-1 2.6.1-1
doctl 1.77.0-1 1.78.0-1
dokuwiki 20200729-3 20220626rc-1
dsp 1.8-3 1.9-1
dunst 1.8.1-1 1.9.0-1
duplicity 0.8.22-1 0.8.23-1
faudio 22.06-1 22.07-1
faust 2.41.1-1 2.41.1-2
fb-client 2.2.0-3 2.3.0-1
fcitx5 5.0.17-2 5.0.18-2
fcitx5-anthy 5.0.11-1 5.0.12-1
fcitx5-chewing 5.0.11-1 5.0.12-1
fcitx5-chinese-addons 5.0.13-2 5.0.14-1
fcitx5-configtool 5.0.13-1 5.0.14-1
fcitx5-gtk 5.0.15-1 5.0.16-1
fcitx5-hangul 5.0.9-1 5.0.10-1
fcitx5-kkc 5.0.9-1 5.0.10-1
fcitx5-libthai 5.0.8-1 5.0.9-1
fcitx5-lua 5.0.8-1 5.0.9-1
fcitx5-m17n 5.0.9-1 5.0.10-1
fcitx5-qt 5.0.13-1 5.0.14-1
fcitx5-sayura 5.0.7-1 5.0.8-1
fcitx5-skk 5.0.12-1 5.0.13-1
fcitx5-table-extra 5.0.10-1 5.0.11-1
fcitx5-table-other 5.0.9-1 5.0.10-1
fcitx5-unikey 5.0.10-1 5.0.11-1
fisher 4.3.5-1 4.4.2-1
flameshot 11.0.0-5 12.1.0-1
gfold 4.0.0-1 4.0.1-1
giac 1.9.0.11-1 1.9.0.13-1
gimp-plugin-gmic 3.1.4-1 3.1.5-1
glulxe-term 1:0.5.4-1 1:0.6.0-1
gnome-passwordsafe 6.5-1 6.5-2
go-ethereum 1.10.19-1 1.10.20-1
goaccess 1.6-1 1.6.1-1
gopls 0.8.4-1 0.9.0-1
gtest 1.11.0-4 1.12.0-2
hedgedoc 1.9.3-2 1.9.3-3
homebank 5.5.5-1 5.5.6-1
in-toto 1.1.1-3 1.2.0-1
interception-dual-function-keys 1.4.0-2 1.5.0-1
jami-daemon 20220511-2 20220629-2
jami-libclient 20220425-2 -
jami-qt 20220407-1 20220627-1
jenkins 2.357-1 2.358-1
jupyter-nbclassic 0.3.7-2 0.4.2-1
jupyter-nbclient 0.6.4-1 0.6.6-1
jupyter-server 1.18.0-1 1.18.1-1
jupyter_console 6.4.3-1 6.4.4-1
ldc 3:1.29.0-1 3:1.29.0-4
lego 4.7.0-1 4.8.0-1
libc++ 13.0.1-1 14.0.6-1
libc++abi 13.0.1-1 14.0.6-1
libc++experimental 13.0.1-1 14.0.6-1
libime 1.0.12-2 1.0.13-2
liblphobos 3:1.29.0-1 3:1.29.0-4
libre 2.4.0-1 2.5.0-1
librem 2.4.0-1 2.5.0-1
libsemigroups 2.1.5-1 2.2.0-1
libtpms 0.9.4-1 0.9.5-1
libxdp 1.2.3-8 1.2.5-1
liquidctl 1.9.1-1 1.10.0-1
ltris 1.2.4-1 1.2.5-1
lua-language-server 3.4.0-1 3.4.2-1
mako 1.6-3 1.7-2
maliit-framework 2.2.1-1 2.3.0-1
maliit-keyboard 2.2.1.1-1 2.3.0-1
mdbook 0.4.18-1 0.4.19-1
mediawiki 1.38.1-1 1.38.2-1
minio 2022.06.17-1 2022.06.30-1
minio-client 2022.06.17-1 2022.06.26-1
mitmproxy 8.1.0-2 8.1.1-1
mvt 1.5.4-2 1.5.5-1
nauty 27r3-1 27r4-1
nextcloud-client 2:3.5.1-2 2:3.5.2-1
nextcloud-client-cloudproviders 2:3.5.1-2 2:3.5.2-1
npm 8.9.0-1 8.13.0-1
npm-check-updates 13.1.4-1 14.0.0-1
nsd 4.5.0-1 4.6.0-1
nushell 0.64.0-1 0.65.0-1
nvme-cli 2.0-2 2.0-3
openshadinglanguage 1.11.17.0-3 1.11.17.0-4
p2pool 2.1-1 2.2-1
perl-convert-uulib 1.5-10 1.8-1
perl-devel-checklib 1.15-2 1.16-1
perl-par-packer 1.054-3 1.055-1
perl-xml-libxslt 2.001000-1 2.002000-1
phpldapadmin 1.2.6.2-2 1.2.6.3-1
pitivi 2021.05-4 2022.06-1
pmbootstrap 1.43.1-1 1.45.0-1
primecount 7.3-1 7.4-1
primesieve 7.9-1 8.0-1
pyright 1.1.256-1 1.1.257-1
python-aiounittest 1.4.1-3 1.4.2-1
python-apispec 5.2.1-1 5.2.2-1
python-apsw 3.38.1-1 3.38.5-1
python-aresponses 2.1.5-1 2.1.6-1
python-atom 0.6.0-5 -
python-autobahn 22.5.1-1 22.6.1-1
python-awesomeversion 22.5.2-1 22.6.0-1
python-aws-xray-sdk 2.9.0-1 2.10.0-1
python-bcc 0.24.0-1 0.24.0-2
python-bottleneck 1.3.4-1 1.3.5-1
python-colorama 0.4.4-6 0.4.5-1
python-curtsies 0.3.5-3 0.3.10-1
python-cwcwidth 0.1.4-3 0.1.6-1
python-dask 2022.6.0-1 2022.6.1-1
python-database-knotinfo 2022.6.1-1 2022.7.1-1
python-debugpy 1.6.0-1 1.6.1-1
python-distributed 2022.6.0-1 2022.6.1-1
python-docutils 1:0.18.1-1 1:0.19-1
python-dukpy 0.3-7 -
python-dulwich 0.20.43-1 0.20.44-1
python-findpython 0.1.6-1 0.2.0-1
python-flask-httpauth 4.4.0-3 4.7.0-1
python-fonttools 4.33.3-1 4.34.2-1
python-google-auth-oauthlib 0.5.1-1 0.5.2-1
python-gphoto2 2.3.2-1 2.3.3-1
python-ifaddr 0.1.7-5 0.2.0-1
python-imagesize 1.3.0-3 1.4.1-1
python-jupyterlab_server 2.14.0-1 2.15.0-1
python-keycloak 0.26.1-2 1.8.0-1
python-kiwisolver 1.4.2-1 1.4.3-1
python-magic 5.40-3 5.42-1
python-marshmallow 3.15.0-1 3.16.0-1
python-mechanize 1:0.4.6-3 1:0.4.8-1
python-meilisearch 0.16.2-2 0.18.3-1
python-mistune 2.0.2-1 2.0.3-1
python-numpydoc 1.1.0-5 1.4.0-1
python-orjson 3.7.5-1 3.7.6-1
python-pam 1.8.4-7 2.0.2-1
python-pecan 1.4.1-1 1.4.2-1
python-phonenumbers 8.12.50-1 8.12.51-1
python-pikepdf 5.1.5.post1-1 5.3.1-1
python-pillow 9.1.1-1 9.2.0-1
python-prompt_toolkit 3.0.29-1 3.0.30-1
python-pygls 0.11.2-3 0.11.3-1
python-pykeepass 4.0.2-1 4.0.3-1
python-pylibacl 0.5.4-7 0.6.0-1
python-pyocr 0.8-3 0.8.3-1
python-pytest-tap 3.2-2 3.3-1
python-pywayland 0.4.12-1 0.4.13-1
python-pyzmq 23.1.0-1 23.2.0-1
python-qiniu 7.7.1-1 7.8.0-1
python-securesystemslib 0.21.0-3 0.23.0-1
python-sepaxml 2.4.1-3 2.5.0-1
python-setuptools-scm 7.0.3-1 7.0.4-1
python-sphinx-click 4.2.0-1 4.3.0-1
python-sqlalchemy 1.4.36-1 1.4.37-1
python-tappy 3.0-3 3.1-1
python-vcrpy 4.1.1-5 4.2.0-1
python-xmltodict 0.12.0-8 0.13.0-1
python-zeroconf 0.38.4-1 0.38.5-1
python-ziafont 0.3.1-1 0.4-1
qpwgraph 0.3.2-1 0.3.3-1
r 4.2.1-1 4.2.1-2
reaper 6.61-1 6.63-1
rekor 0.8.2-1 0.9.0-1
reprotest 0.7.19-2 0.7.20-1
rhit 1.7.0-1 1.7.1-1
ruby-hpricot 0.8.6-12 -
ruby-msgpack 1.5.2-1 1.5.3-1
ruby-ronn-ng 0.9.1-4 0.9.1-5
rust-analyzer 20220627-1 20220704-1
salt 3004.1-3 3004.2-1
scaleway-cli 2.5.3-1 2.5.4-1
sdcv 0.5.3-1 0.5.4-1
singular 4.3.1-2 4.3.1.p1-2
snd 22.4-1 22.5-1
solaar 1.1.3-1 1.1.4-1
sparse 0.6.4-2 0.6.4-3
spirv-llvm-translator13.0.0.r27+gd7a03044-114.0.0.r57+g33898cef-1
sqlfluff 1.0.0-1 1.1.0-1
sslscan 2.0.14-1 2.0.15-1
sssd 2.7.2-1 2.7.3-1
stylua 0.13.1-1 0.14.0-1
syncthing 1.20.2-1 1.20.3-1
syncthing-relaysrv 1.20.2-1 1.20.3-1
timescaledb-tune 0.12.0-2 0.13.0-1
translate-toolkit 3.6.2-1 3.7.1-1
ts-node 10.8.1-1 10.8.2-1
ttf-sarasa-gothic 0.36.5-1 0.36.6-1
uglify-js 3.16.1-1 3.16.2-1
v2ray-domain-list-community 20220629152223-1 20220704031409-1
variety 0.8.7-1 0.8.9-1
vc-intrinsics 0.4.2-1 0.5.0-1
vokoscreen 3.2.0-1 3.3.0-1
vulture 2.4-1 2.5-1
warpinator 1.2.10-1 1.2.12-1
watchexec 1.20.2-1 1.20.4-1
workrave 1.10.49-1 1.10.50-1
xapp 2.2.11-1 2.2.12-1
xdp-tools 1.2.3-8 1.2.5-1
xed 3.2.3-1 3.2.4-1
xreader 3.4.0-1 3.4.1-1
xwallpaper 0.7.3-2 0.7.4-1
you-get 0.4.1612-1 0.4.1620-1
yq 2.14.0-1 3.0.2-1
zerotier-one 1.10.0-1 1.10.1-1
zig 0.7.1-1 0.9.1-2
bupstash - 0.11.0-2
cargo-zigbuild - 0.11.1-1
git-grab - 1.0.0-1
melange - 0.1.0-1
python-pydrive2 - 1.10.1-1
repod - 0.1.0-1
rubygems - 3.3.15-1
:: Different overlay package(s) in repository core aarch64
linux 5.18.8-2 5.18.9-1
linux-clockworkpi-a06 5.18.8-1 5.18.9-1
linux-clockworkpi-a06-headers 5.18.8-1 5.18.9-1
linux-headers 5.18.8-2 5.18.9-1
linux-lts 5.15.51-1 5.15.52-1
linux-lts-headers 5.15.51-1 5.15.52-1
linux-pinephone 5.18.8-1 5.18.9-1
linux-pinephone-headers 5.18.8-1 5.18.9-1
linux-pinephonepro 5.18.8-1 5.18.9-1
linux-pinephonepro-headers 5.18.8-1 5.18.9-1
linux-rc 5.19.rc4-1 5.19.rc5-1
linux-rc-headers 5.19.rc4-1 5.19.rc5-1
linux-rpi4 5.15.50-1 5.15.52-1
linux-rpi4-headers 5.15.50-1 5.15.52-1
linux-rpi4-mainline 5.18.7-1 5.18.9-1
linux-rpi4-mainline-headers 5.18.7-1 5.18.9-1
linux-rpi4-rc 5.19.rc4-1 5.19.rc5-1
linux-rpi4-rc-headers 5.19.rc4-1 5.19.rc5-1
raspberrypi-bootloader 20220527-1 20220704-1
raspberrypi-bootloader-x 20220527-1 20220704-1
:: Different sync package(s) in repository core aarch64
glib2 2.72.2-1 2.72.3-1
glib2-docs 2.72.2-1 2.72.3-1
hwdata 0.360-1 0.361-1
kmod 29-3 30-1
libisl 0.24-4 0.25-1
mkinitcpio 31-2.1 31-3
openssl 1.1.1.p-1 1.1.1.q-1
:: Different overlay package(s) in repository extra aarch64
js91 91.10.0-1 -
mesa-git22.2.0_devel.155889.b28efd80ebb4-122.2.0_devel.156171.7bb62d9dd859-1
qt5-es2-base 5.15.5+kde+r163-1 5.15.5+kde+r170-1
qt5-es2-datavis3d 5.15.4+kde+r0-1 5.15.5-1
qt5-es2-xcb-private-headers 5.15.5+kde+r163-1 5.15.5+kde+r170-1
:: Different sync package(s) in repository extra aarch64
389-ds-base 2.1.1-1 2.2.1-1
alsa-card-profiles 1:0.3.52-2 1:0.3.53-3
arch-install-scripts 24-2 25-2
bird 2.0.9-2 2.0.10-1
brltty 6.4-10 6.5-1
chromium 103.0.5060.53-1 103.0.5060.114-1
clang 13.0.1-2 14.0.6-1
clazy 1.11-1 1.11-2
compiler-rt 13.0.1-1 14.0.6-1
composer 2.3.7-1 2.3.8-1
deluge 1:2.0.5-1 1:2.1.0-1
deluge-gtk 1:2.0.5-1 1:2.1.0-1
discover 5.25.2-1 5.25.2-2
dkms 3.0.3-1 3.0.5-1
dmidecode 3.3-1 3.4-1
evolution 3.44.2-1 3.44.3-1
evolution-bogofilter 3.44.2-1 3.44.3-1
evolution-data-server 3.44.2-1 3.44.3-1
evolution-ews 3.44.2-1 3.44.3-1
evolution-spamassassin 3.44.2-1 3.44.3-1
exempi 2.6.1-1 2.6.2-1
firefox 102.0-1 102.0.1-1
firefox-i18n-ach 102.0-1 102.0.1-1
firefox-i18n-af 102.0-1 102.0.1-1
firefox-i18n-an 102.0-1 102.0.1-1
firefox-i18n-ar 102.0-1 102.0.1-1
firefox-i18n-ast 102.0-1 102.0.1-1
firefox-i18n-az 102.0-1 102.0.1-1
firefox-i18n-be 102.0-1 102.0.1-1
firefox-i18n-bg 102.0-1 102.0.1-1
firefox-i18n-bn 102.0-1 102.0.1-1
firefox-i18n-br 102.0-1 102.0.1-1
firefox-i18n-bs 102.0-1 102.0.1-1
firefox-i18n-ca 102.0-1 102.0.1-1
firefox-i18n-ca-valencia 102.0-1 102.0.1-1
firefox-i18n-cak 102.0-1 102.0.1-1
firefox-i18n-cs 102.0-1 102.0.1-1
firefox-i18n-cy 102.0-1 102.0.1-1
firefox-i18n-da 102.0-1 102.0.1-1
firefox-i18n-de 102.0-1 102.0.1-1
firefox-i18n-dsb 102.0-1 102.0.1-1
firefox-i18n-el 102.0-1 102.0.1-1
firefox-i18n-en-ca 102.0-1 102.0.1-1
firefox-i18n-en-gb 102.0-1 102.0.1-1
firefox-i18n-en-us 102.0-1 102.0.1-1
firefox-i18n-eo 102.0-1 102.0.1-1
firefox-i18n-es-ar 102.0-1 102.0.1-1
firefox-i18n-es-cl 102.0-1 102.0.1-1
firefox-i18n-es-es 102.0-1 102.0.1-1
firefox-i18n-es-mx 102.0-1 102.0.1-1
firefox-i18n-et 102.0-1 102.0.1-1
firefox-i18n-eu 102.0-1 102.0.1-1
firefox-i18n-fa 102.0-1 102.0.1-1
firefox-i18n-ff 102.0-1 102.0.1-1
firefox-i18n-fi 102.0-1 102.0.1-1
firefox-i18n-fr 102.0-1 102.0.1-1
firefox-i18n-fy-nl 102.0-1 102.0.1-1
firefox-i18n-ga-ie 102.0-1 102.0.1-1
firefox-i18n-gd 102.0-1 102.0.1-1
firefox-i18n-gl 102.0-1 102.0.1-1
firefox-i18n-gn 102.0-1 102.0.1-1
firefox-i18n-gu-in 102.0-1 102.0.1-1
firefox-i18n-he 102.0-1 102.0.1-1
firefox-i18n-hi-in 102.0-1 102.0.1-1
firefox-i18n-hr 102.0-1 102.0.1-1
firefox-i18n-hsb 102.0-1 102.0.1-1
firefox-i18n-hu 102.0-1 102.0.1-1
firefox-i18n-hy-am 102.0-1 102.0.1-1
firefox-i18n-ia 102.0-1 102.0.1-1
firefox-i18n-id 102.0-1 102.0.1-1
firefox-i18n-is 102.0-1 102.0.1-1
firefox-i18n-it 102.0-1 102.0.1-1
firefox-i18n-ja 102.0-1 102.0.1-1
firefox-i18n-ka 102.0-1 102.0.1-1
firefox-i18n-kab 102.0-1 102.0.1-1
firefox-i18n-kk 102.0-1 102.0.1-1
firefox-i18n-km 102.0-1 102.0.1-1
firefox-i18n-kn 102.0-1 102.0.1-1
firefox-i18n-ko 102.0-1 102.0.1-1
firefox-i18n-lij 102.0-1 102.0.1-1
firefox-i18n-lt 102.0-1 102.0.1-1
firefox-i18n-lv 102.0-1 102.0.1-1
firefox-i18n-mk 102.0-1 102.0.1-1
firefox-i18n-mr 102.0-1 102.0.1-1
firefox-i18n-ms 102.0-1 102.0.1-1
firefox-i18n-my 102.0-1 102.0.1-1
firefox-i18n-nb-no 102.0-1 102.0.1-1
firefox-i18n-ne-np 102.0-1 102.0.1-1
firefox-i18n-nl 102.0-1 102.0.1-1
firefox-i18n-nn-no 102.0-1 102.0.1-1
firefox-i18n-oc 102.0-1 102.0.1-1
firefox-i18n-pa-in 102.0-1 102.0.1-1
firefox-i18n-pl 102.0-1 102.0.1-1
firefox-i18n-pt-br 102.0-1 102.0.1-1
firefox-i18n-pt-pt 102.0-1 102.0.1-1
firefox-i18n-rm 102.0-1 102.0.1-1
firefox-i18n-ro 102.0-1 102.0.1-1
firefox-i18n-ru 102.0-1 102.0.1-1
firefox-i18n-sco 102.0-1 102.0.1-1
firefox-i18n-si 102.0-1 102.0.1-1
firefox-i18n-sk 102.0-1 102.0.1-1
firefox-i18n-sl 102.0-1 102.0.1-1
firefox-i18n-son 102.0-1 102.0.1-1
firefox-i18n-sq 102.0-1 102.0.1-1
firefox-i18n-sr 102.0-1 102.0.1-1
firefox-i18n-sv-se 102.0-1 102.0.1-1
firefox-i18n-szl 102.0-1 102.0.1-1
firefox-i18n-ta 102.0-1 102.0.1-1
firefox-i18n-te 102.0-1 102.0.1-1
firefox-i18n-th 102.0-1 102.0.1-1
firefox-i18n-tl 102.0-1 102.0.1-1
firefox-i18n-tr 102.0-1 102.0.1-1
firefox-i18n-trs 102.0-1 102.0.1-1
firefox-i18n-uk 102.0-1 102.0.1-1
firefox-i18n-ur 102.0-1 102.0.1-1
firefox-i18n-uz 102.0-1 102.0.1-1
firefox-i18n-vi 102.0-1 102.0.1-1
firefox-i18n-xh 102.0-1 102.0.1-1
firefox-i18n-zh-cn 102.0-1 102.0.1-1
firefox-i18n-zh-tw 102.0-1 102.0.1-1
geocode-glib 3.26.2+r9+g6047da3-2 3.26.3-1
gjs 2:1.72.0-1 2:1.72.1-1
gn 0.2042.2ecd43a1-1 0.2042.2ecd43a1-2
gnome-builder 42.1-1 42.1-2
gnome-builder-libide-docs 42.1-1 42.1-2
gnome-calculator 42.1-1 42.2-1
gnome-control-center 42.2-1 42.3-1
gnome-maps 42.2-1 42.3-1
gnome-remote-desktop 42.2-1 42.3-1
gnome-shell 1:42.2-1 1:42.3.1-1
gnome-shell-extensions 42.2-1 42.3-1
gnome-software 42.2-1 42.3-1
gnome-software-packagekit-plugin 42.2-1 42.3-1
gst-plugin-pipewire 1:0.3.52-2 1:0.3.53-3
gtk-update-icon-cache 1:4.6.5-1 1:4.6.6-1
gtk4 1:4.6.5-1 1:4.6.6-1
gtk4-demos 1:4.6.5-1 1:4.6.6-1
gtk4-docs 1:4.6.5-1 1:4.6.6-1
imagemagick 7.1.0.39-1 7.1.0.40-1
imagemagick-doc 7.1.0.39-1 7.1.0.40-1
inkscape 1.2-4 1.2-5
kdevelop 22.04.2-1 22.04.2-3
libclc 13.0.1-1 14.0.6-1
libcuckoo 0.3-1 0.3.1-1
libdmtx 0.7.5-2 0.7.7-1
libgphoto2 2.5.29-1 2.5.30-1
liblangtag 0.6.3-3 0.6.4-1
libmtp 1.1.19-2 1.1.20-1
libsoup3 3.0.6-1 3.0.7-1
libva-mesa-driver 22.1.2-1 22.1.3-1
lld 13.0.1-1 14.0.6-1
lldb 13.0.1-1 14.0.6-1
llvm 13.0.1-6 14.0.6-1
llvm-libs 13.0.1-6 14.0.6-1
llvm-ocaml 13.0.1-6 -
mesa 22.1.2-1 22.1.3-1
mesa-amber 21.3.9-1 21.3.9-2
mesa-vdpau 22.1.2-1 22.1.3-1
meson 0.62.2-1 0.63.0-1
mutter 42.2-1 42.3-1
mutter-docs 42.2-1 42.3-1
ncmpc 0.46-2 0.47-1
opencl-mesa 22.1.2-1 22.1.3-1
openmp 13.0.1-1 14.0.6-1
orca 42.1-1 42.2-1
pango 1:1.50.7-1 1:1.50.8-1
pango-docs 1:1.50.7-1 1:1.50.8-1
perl-alien-build 2.48-3 2.49-1
pipewire-alsa 1:0.3.52-2 1:0.3.53-3
pipewire-docs 1:0.3.52-2 1:0.3.53-3
pipewire-jack 1:0.3.52-2 1:0.3.53-3
pipewire-pulse 1:0.3.52-2 1:0.3.53-3
pipewire-v4l2 1:0.3.52-2 1:0.3.53-3
pipewire-x11-bell 1:0.3.52-2 1:0.3.53-3
pipewire-zeroconf 1:0.3.52-2 1:0.3.53-3
polari 42.0-1 42.1-1
polly 13.0.1-1 14.0.6-1
postgresql 14.3-2 14.3-3
postgresql-docs 14.3-2 14.3-3
postgresql-libs 14.3-2 14.3-3
postgresql-old-upgrade 13.7-2 13.7-3
prometheus-memcached-exporter 0.9.0-2 0.10.0-1
protobuf 21.1-1 21.2-1
pyside2 5.15.5-1 5.15.5-3
pyside2-tools 5.15.5-1 5.15.5-3
pyside6 6.3.1-1 6.3.1-3
python-cffi 1.15.0-3 1.15.1-1
python-dbusmock 0.27.5-1 0.28.1-1
python-django 4.0.5-1 4.0.6-1
python-fastbencode 0.0.7-1 0.0.9-1
python-numpy 1.22.4-1 1.23.0-1
python-protobuf 21.1-1 21.2-1
python-pytest-qt 4.0.2-3 4.1.0-1
python-shiboken2 5.15.5-1 5.15.5-3
qt5-base 5.15.5+kde+r166-1 5.15.5+kde+r170-1
qt5-imageformats 5.15.5+kde+r3-1 5.15.5+kde+r4-1
qt5-tools 5.15.5+kde+r1-1 5.15.5+kde+r1-3
qt5-xcb-private-headers 5.15.5+kde+r166-1 5.15.5+kde+r170-1
qt6-tools 6.3.1-1 6.3.1-3
qtcreator 7.0.2-2 7.0.2-4
qtcreator-devel 7.0.2-2 7.0.2-4
rubygems 3.3.15-1 -
rust 1:1.61.0-1 1:1.62.0-1
rust-src 1:1.61.0-1 1:1.62.0-1
shiboken6 6.3.1-1 6.3.1-3
sip 6.6.2-1 6.6.2-2
sof-firmware 2.1.1.a-1 2.2-1
sof-tools 2.1.1.a-1 2.2-1
sushi 41.2-1 42.0-1
thunderbird 91.10.0-1 91.11.0-1
thunderbird-i18n-af 91.10.0-1 91.11.0-1
thunderbird-i18n-ar 91.10.0-1 91.11.0-1
thunderbird-i18n-ast 91.10.0-1 91.11.0-1
thunderbird-i18n-be 91.10.0-1 91.11.0-1
thunderbird-i18n-bg 91.10.0-1 91.11.0-1
thunderbird-i18n-br 91.10.0-1 91.11.0-1
thunderbird-i18n-ca 91.10.0-1 91.11.0-1
thunderbird-i18n-cak 91.10.0-1 91.11.0-1
thunderbird-i18n-cs 91.10.0-1 91.11.0-1
thunderbird-i18n-cy 91.10.0-1 91.11.0-1
thunderbird-i18n-da 91.10.0-1 91.11.0-1
thunderbird-i18n-de 91.10.0-1 91.11.0-1
thunderbird-i18n-dsb 91.10.0-1 91.11.0-1
thunderbird-i18n-el 91.10.0-1 91.11.0-1
thunderbird-i18n-en-gb 91.10.0-1 91.11.0-1
thunderbird-i18n-en-us 91.10.0-1 91.11.0-1
thunderbird-i18n-es-ar 91.10.0-1 91.11.0-1
thunderbird-i18n-es-es 91.10.0-1 91.11.0-1
thunderbird-i18n-et 91.10.0-1 91.11.0-1
thunderbird-i18n-eu 91.10.0-1 91.11.0-1
thunderbird-i18n-fi 91.10.0-1 91.11.0-1
thunderbird-i18n-fr 91.10.0-1 91.11.0-1
thunderbird-i18n-fy-nl 91.10.0-1 91.11.0-1
thunderbird-i18n-ga-ie 91.10.0-1 91.11.0-1
thunderbird-i18n-gd 91.10.0-1 91.11.0-1
thunderbird-i18n-gl 91.10.0-1 91.11.0-1
thunderbird-i18n-he 91.10.0-1 91.11.0-1
thunderbird-i18n-hr 91.10.0-1 91.11.0-1
thunderbird-i18n-hsb 91.10.0-1 91.11.0-1
thunderbird-i18n-hu 91.10.0-1 91.11.0-1
thunderbird-i18n-hy-am 91.10.0-1 91.11.0-1
thunderbird-i18n-id 91.10.0-1 91.11.0-1
thunderbird-i18n-is 91.10.0-1 91.11.0-1
thunderbird-i18n-it 91.10.0-1 91.11.0-1
thunderbird-i18n-ja 91.10.0-1 91.11.0-1
thunderbird-i18n-ka 91.10.0-1 91.11.0-1
thunderbird-i18n-kab 91.10.0-1 91.11.0-1
thunderbird-i18n-kk 91.10.0-1 91.11.0-1
thunderbird-i18n-ko 91.10.0-1 91.11.0-1
thunderbird-i18n-lt 91.10.0-1 91.11.0-1
thunderbird-i18n-ms 91.10.0-1 91.11.0-1
thunderbird-i18n-nb-no 91.10.0-1 91.11.0-1
thunderbird-i18n-nl 91.10.0-1 91.11.0-1
thunderbird-i18n-nn-no 91.10.0-1 91.11.0-1
thunderbird-i18n-pa-in 91.10.0-1 91.11.0-1
thunderbird-i18n-pl 91.10.0-1 91.11.0-1
thunderbird-i18n-pt-br 91.10.0-1 91.11.0-1
thunderbird-i18n-pt-pt 91.10.0-1 91.11.0-1
thunderbird-i18n-rm 91.10.0-1 91.11.0-1
thunderbird-i18n-ro 91.10.0-1 91.11.0-1
thunderbird-i18n-ru 91.10.0-1 91.11.0-1
thunderbird-i18n-sk 91.10.0-1 91.11.0-1
thunderbird-i18n-sl 91.10.0-1 91.11.0-1
thunderbird-i18n-sq 91.10.0-1 91.11.0-1
thunderbird-i18n-sr 91.10.0-1 91.11.0-1
thunderbird-i18n-sv-se 91.10.0-1 91.11.0-1
thunderbird-i18n-th 91.10.0-1 91.11.0-1
thunderbird-i18n-tr 91.10.0-1 91.11.0-1
thunderbird-i18n-uk 91.10.0-1 91.11.0-1
thunderbird-i18n-uz 91.10.0-1 91.11.0-1
thunderbird-i18n-vi 91.10.0-1 91.11.0-1
thunderbird-i18n-zh-cn 91.10.0-1 91.11.0-1
thunderbird-i18n-zh-tw 91.10.0-1 91.11.0-1
tracker3 3.3.1-1 3.3.2-1
tracker3-docs 3.3.1-1 3.3.2-1
vulkan-broadcom 22.1.2-1 22.1.3-1
vulkan-mesa-layers 22.1.2-1 22.1.3-1
vulkan-panfrost 22.1.2-1 22.1.3-1
vulkan-radeon 22.1.2-1 22.1.3-1
vulkan-swrast 22.1.2-1 22.1.3-1
wayland 1.20.0-2 1.21.0-1
wayland-docs 1.20.0-2 1.21.0-1
webkit2gtk 2.36.3-1 2.36.4-2
webkit2gtk-4.1 2.36.3-1 2.36.4-2
webkit2gtk-5.0 2.36.3-1 2.36.4-2
wireplumber 0.4.10-3 0.4.11-1
wireplumber-docs 0.4.10-3 0.4.11-1
wpewebkit 2.36.3-1 2.36.4-2
xdg-desktop-portal-gnome 42.1-1 42.3-1
xfce4-settings 4.16.2-2 4.16.3-1
zenity 3.42.1-1 3.43.0-1
brltty-udev-generic - 6.5-1
clang13 - 13.0.1-3
lld13 - 13.0.1-1
llvm13 - 13.0.1-3
llvm13-libs - 13.0.1-3
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.04.2.r12781.gcfc1a5a24-122.04.2.r12790.ga8f072835-1
akonadi-calendar22.04.2.r2130.g24f3853-122.04.2.r2134.g5008298-1
akonadi-calendar-tools22.04.2.r954.ge03fb1e-122.04.2.r955.g78bc490-1
akonadi-contacts22.04.2.r3218.g2b8bb1a6-122.04.2.r3222.g91382c72-1
akonadi-import-wizard22.04.2.r1834.g6f3672c-122.04.2.r1836.gcaddfee-1
akonadi-mime22.04.2.r1739.g68cf99f-122.04.2.r1743.g6e384f4-1
akonadi-notes22.04.2.r1077.g4554f42-122.04.2.r1079.gdcf26c6-1
akonadi-search22.04.2.r1240.g0235a27-122.04.2.r1244.g217440c-1
akonadiconsole22.04.2.r1594.g80dd1f5-122.04.2.r1598.g71db2cb-1
akregator22.04.2.r6437.g04ada5e5-122.04.2.r6444.g56c9f484-1
alligator 22.06.r3.gb505ed1-1 22.06.r4.g8d0eb37-1
analitza22.04.2.r2341.gd22ca62d-122.04.2.r2352.gb312e7db-1
angelfish 22.06.r2.gf31c383-1 22.06.r5.gf1131ad-1
ark22.04.2.r4784.gdc5d8501-122.04.2.r4790.g8ffef346-1
artikulate22.04.2.r1419.g1761afe-122.04.2.r1420.g603ba8c-1
attica5.95.0.r874.g197c295-15.95.0.r875.gc0cabad-1
audiocd-kio22.04.2.r1068.gff54fa8-122.04.2.r1075.g5fcf99f-1
audiotube 22.06.r3.gf12c4e3-1 22.06.r4.g05be539-1
aura-browser r53.a41bce9-1 r54.ff5a74a-1
baloo5.95.0.r3057.g1803a661-15.95.0.r3058.g66444ad9-1
baloo-widgets22.04.2.r759.g3479921-122.04.2.r761.g1390bc7-1
blinken22.04.2.r671.g5a81524-122.04.2.r672.g8c5c962-1
bluedevil1:5.25.2.r2412.gc2908658-11:5.25.2.r2415.g84feb9ae-1
bluez-qt5.95.0.r713.g0bd628e-15.95.0.r714.g036c18e-1
bomber22.04.2.r567.g5e9d06e-122.04.2.r568.g34e6fee-1
bovo22.04.2.r779.gae412fe-122.04.2.r781.g9974daa-1
breeze5.25.2.r2425.ge85efaab-15.25.2.r2427.g664ad9b2-1
breeze-icons5.95.0.r1904.g57ae311b-15.95.0.r1907.g2efe5026-1
calendarsupport22.04.2.r712.g05c0720-122.04.2.r713.geed496f-1
calindori 22.06.r3.gc7efaa2-1 22.06.r4.g61ab916-1
cervisia22.04.2.r1670.gcfffa58-122.04.2.r1671.g44d23b1-1
discover5.25.2.r8721.g4daabe64-15.25.2.r8727.g24d3c665-1
dolphin22.04.2.r7024.gdc3d153bb-122.04.2.r7030.gf3a0986b8-1
dolphin-plugins22.04.2.r664.g01536e1-122.04.2.r666.g11c7e24-1
dragon22.04.2.r1045.g32d9cd4-122.04.2.r1047.gc4ec64b-1
drkonqi5.25.2.r796.g7f32dac3-15.25.2.r800.g7a514e37-1
elisa22.04.2.r2988.gaf7dc83e-122.04.2.r2993.gddb53c4a-1
elisa-qtmm22.04.2.r2988.gaf7dc83e-122.04.2.r2993.gddb53c4a-1
eventviews22.04.2.r851.g5db0c7b-122.04.2.r852.g41703f4-1
ffmpegthumbs22.04.2.r222.g3410855-122.04.2.r223.g15e8b7e-1
filelight22.04.2.r1140.g8083f26-122.04.2.r1146.g696d25c-1
frameworkintegration5.95.0.r642.gc27427f-15.95.0.r645.g0ea3706-1
granatier22.04.2.r980.gca7fa04-122.04.2.r981.gd4587f5-1
grantlee-editor22.04.2.r825.g59b3f70-122.04.2.r826.gebb27ca-1
grantleetheme22.04.2.r403.gceb2c55-122.04.2.r404.g1cc8b0b-1
gwenview22.04.2.r6863.gde2e003d-122.04.2.r6874.gfaa1f11f-1
incidenceeditor22.04.2.r906.g81cd689-122.04.2.r908.gd73a8db-1
index-fm 2.1.2.r34.ga0e0b5d-1 2.1.2.r36.g5132862-1
itinerary22.04.2.r1920.ge27ef28-122.04.2.r1935.geb45637-1
juk22.04.2.r3158.g43272041-122.04.2.r3160.gb81df2ac-1
k3b1:22.04.2.r6796.ga446d1ae5-11:22.04.2.r6798.gf4d447a24-1
kactivities5.95.0.r1398.ge4f58553-15.95.0.r1399.g336982ef-1
kactivities-stats5.95.0.r410.g366c579-15.95.0.r411.g90f9427-1
kactivitymanagerd5.25.2.r1408.g1297cd1-15.25.2.r1412.g6b9a376-1
kaddressbook22.04.2.r6210.g173cf909-122.04.2.r6212.gf733cbb5-1
kalarm22.04.2.r7933.g30b536b7-122.04.2.r7952.g75b03dbd-1
kalgebra22.04.2.r2064.g7cb92dc-122.04.2.r2068.g8f4b41d-1
kalk 22.06.r4.g6c08c76-1 22.06.r7.g3aeecc7-1
kalzium22.04.2.r4364.g96cd1d22-122.04.2.r4365.gaeeeb32a-1
kamera22.04.2.r724.gf7b79dd-122.04.2.r726.g8d8dd08-1
kamoso22.04.2.r1467.g8d426f2-122.04.2.r1469.g0553dd7-1
kanagram22.04.2.r1314.gf126bc4-122.04.2.r1315.ge0de2d1-1
kapman22.04.2.r660.gdda3bea-122.04.2.r661.g38630ec-1
kapptemplate22.04.2.r995.g5544793-122.04.2.r996.g16a48d2-1
karchive5.95.0.r546.g02873f6-15.95.0.r548.gd81a8ee-1
kasts 22.06.r4.gac58ad0-1 22.06.r18.gfa2d552-1
kate22.04.2.r19179.ga69004b4b-122.04.2.r19213.g356278ab2-1
katomic22.04.2.r965.g84570d0-122.04.2.r966.gb49eb3c-1
kauth5.95.0.r501.g8c7194a-15.95.0.r502.g6af7041-1
kbackup22.04.2.r445.gbb05f7e-122.04.2.r446.ge10a50f-1
kblackbox22.04.2.r768.g62af1c7-122.04.2.r770.g05f5509-1
kblocks22.04.2.r731.gc8cd0a0-122.04.2.r732.gb71d839-1
kbookmarks5.95.0.r463.g4ea91aa-15.95.0.r464.g9ba8ede-1
kbounce22.04.2.r852.gcd19c1e-122.04.2.r853.ge9aa7f5-1
kbreakout22.04.2.r926.gadc9efb-122.04.2.r927.gf6d7870-1
kbruch22.04.2.r870.g1cae120-122.04.2.r871.g1a2963b-1
kcachegrind22.04.2.r1187.gfff2c26-122.04.2.r1188.g2a19a76-1
kcachegrind-common22.04.2.r1187.gfff2c26-122.04.2.r1188.g2a19a76-1
kcalc22.04.2.r1616.g51c3e94-122.04.2.r1621.gbd8a0dd-1
kcalendarcore5.95.0.r1330.g5b03ae2bd-15.95.0.r1333.g62b78a12f-1
kcalutils22.04.2.r969.g0aca3fd6d-122.04.2.r971.g47c43cb1c-1
kcharselect22.04.2.r533.g1c65036-122.04.2.r535.g5fb4eca-1
kclock 22.06.r3.g52ebe91-1 22.06.r10.gedc9add-1
kcmutils5.95.0.r644.ga5e6f13-15.95.0.r646.g682cae8-1
kcodecs5.95.0.r424.g6292a25-15.95.0.r425.g023a5cc-1
kcolorchooser22.04.2.r273.gdb56e9b-122.04.2.r276.ga066dc4-1
kcompletion5.95.0.r496.gc856ff1-15.95.0.r497.g4fa1fe3-1
kconfig5.95.0.r961.g5ce3f9eb-15.95.0.r963.gee0e9486-1
kconfigwidgets5.95.0.r746.g95d9d09-15.95.0.r748.g12080c8-1
kcontacts1:5.95.0.r3337.g4bb5e72d-11:5.95.0.r3339.ga8e2cf32-1
kcoreaddons5.95.0.r1510.g4e944878-15.95.0.r1522.gd88079c9-1
kcrash5.95.0.r449.g8e84cea-15.95.0.r450.g2308abd-1
kcron22.04.2.r846.g3b76467-122.04.2.r848.g44fb6fe-1
kdav1:5.95.0.r1345.gb7c68d4-11:5.95.0.r1348.g9821d72-1
kdbusaddons5.95.0.r418.g048fcbe-15.95.0.r420.g9184af3-1
kde-cli-tools5.25.2.r1944.g1993048-15.25.2.r1945.g5d1ed28-1
kde-dev-utils22.04.2.r591.gab48b72-122.04.2.r593.g7d26ddb-1
kde-gtk-config5.25.2.r937.gfdf1446-15.25.2.r938.gda46494-1
kdebugsettings22.04.2.r928.gbae60ee-122.04.2.r933.ge346d14-1
kdeclarative5.95.0.r1014.g4455212-15.95.0.r1015.g375647c-1
kdeconnect22.04.2.r3474.g19d0b8f4-122.04.2.r3481.g2da891b3-1
kded5.95.0.r465.g393b75f-15.95.0.r466.gc9e9441-1
kdegraphics-thumbnailers22.04.2.r273.ga5019a6-122.04.2.r274.g1359130-1
kdelibs4support5.95.0.r1094.gbb588fe9-15.95.0.r1096.g6701e008-1
kdenetwork-filesharing22.04.2.r958.g0a99319-122.04.2.r961.gbc35019-1
kdenlive22.04.2.r16314.gb89e89ceb-122.04.2.r16341.gc67783c3d-1
kdepim-addons22.04.2.r4681.g3b7013202-122.04.2.r4692.g213bcfc37-1
kdepim-runtime22.04.2.r15552.g6409422a4-122.04.2.r15554.g740ab1bad-1
kdeplasma-addons5.25.2.r8911.gc92c8deee-15.25.2.r8917.g122ee9e5d-1
kdesdk-thumbnailers22.04.2.r91.g97befb5-122.04.2.r92.g5da979d-1
kdesignerplugin5.95.0.r356.g3302d04-15.95.0.r357.gd05ed69-1
kdesu5.95.0.r510.g7a00d15-15.95.0.r511.g4ca945d-1
kdewebkit5.95.0.r303.g966b456-15.95.0.r304.ga756ad0-1
kdf22.04.2.r860.g7b05477-122.04.2.r865.gd4118a0-1
kdialog22.04.2.r1229.g96dc0ae5b-122.04.2.r1231.g85b41be88-1
kdiamond22.04.2.r729.g9b166eb-122.04.2.r730.g8f8734b-1
kdnssd5.95.0.r353.g1d281be-15.95.0.r354.gdd8b264-1
kdoctools5.95.0.r669.g5bdc9f9-15.95.0.r671.g6d957f1-1
keditbookmarks22.04.2.r2766.gf43976f3a-122.04.2.r2767.g800862758-1
kemoticons5.95.0.r419.g177ec00-15.95.0.r421.gf585f9c-1
keysmith 22.06.r2.g7333384-1 22.06.r4.gddbaea9-1
kfilemetadata5.95.0.r864.g46d9a1f-15.95.0.r865.gcdb65cc-1
kfind22.04.2.r2700.g4861044f7-122.04.2.r2704.g672e6ca9d-1
kfloppy22.04.2.r794.gd3a1176-122.04.2.r795.g1075e90-1
kfourinline22.04.2.r1029.gbf8d78f-122.04.2.r1030.g789e233-1
kgeography22.04.2.r1159.g134210d-122.04.2.r1160.geb6d9dd-1
kget22.04.2.r3203.g7ceb76b4-122.04.2.r3213.g260b7650-1
kglobalaccel5.95.0.r527.g00c90e1-15.95.0.r533.g84bdb69-1
kgoldrunner22.04.2.r1288.g9483df7-122.04.2.r1289.g70f24e5-1
kgpg22.04.2.r3194.g7b9f0a58-122.04.2.r3196.g07882605-1
kguiaddons5.95.0.r478.g38b5679-15.95.0.r479.g5f6be73-1
khangman22.04.2.r1615.g026608f-122.04.2.r1617.gbb373d1-1
khelpcenter22.04.2.r2746.g2a98c394-122.04.2.r2750.g279b7dde-1
kholidays1:5.95.0.r1041.g1ccd78b-11:5.95.0.r1044.gc89aabb-1
khotkeys5.25.2.r2146.gbee2224-15.25.2.r2148.g9893b39-1
khtml5.95.0.r588.gf78ee37-15.95.0.r589.g26ca9ab-1
ki18n5.95.0.r560.gccf7752-15.95.0.r563.g8b142fe-1
kiconthemes5.95.0.r604.g5450fef-15.95.0.r611.gc9d2f6c-1
kidentitymanagement22.04.2.r3891.gbbc310f5-122.04.2.r3892.gb54c71bc-1
kidletime5.95.0.r359.g603752c-15.95.0.r361.g077d659-1
kig22.04.2.r3190.g3a3aedbc-122.04.2.r3199.g31faa538-1
kigo22.04.2.r574.g7157b7b-122.04.2.r575.gf780c4c-1
killbots22.04.2.r795.g4a2ceae-122.04.2.r799.gedca99c-1
kimageformats5.95.0.r409.g6cd0056-15.95.0.r418.g9b3133a-1
kimagemapeditor22.04.2.r495.g4254485-122.04.2.r498.gc25b7ab-1
kimap22.04.2.r1197.g58f55fc-122.04.2.r1198.gdb6c159-1
kinfocenter5.25.2.r2104.gb723659d-15.25.2.r2113.g53ee4e7c-1
kinit5.95.0.r441.g043b301-15.95.0.r442.g577fe9c-1
kio5.95.0.r5519.gda65b36c7-15.95.0.r5559.g9da77659d-1
kio-extras22.04.2.r7271.gbfb13d4b-122.04.2.r7293.g22b9d3bd-1
kio-gdrive22.04.2.r615.gdf30b05-122.04.2.r617.g5433bd6-1
kirigami-gallery22.04.2.r246.g8b2015b-122.04.2.r248.ge234799-1
kirigami25.95.0.r3165.gdd0bdd78-15.95.0.r3172.gf6390be4-1
kiriki22.04.2.r454.gd5a2372-122.04.2.r456.ge4464f0-1
kitemmodels5.95.0.r611.ga5a4a50-15.95.0.r612.gb10d523-1
kitemviews5.95.0.r375.g85ad995-15.95.0.r378.gddbebf8-1
kiten22.04.2.r1186.gd129628-122.04.2.r1187.g47e651e-1
kitinerary22.04.2.r2278.ga296a2f-122.04.2.r2288.g1826a60-1
kjobwidgets5.95.0.r418.g0e2a51a-15.95.0.r419.g534d4ef-1
kjs5.95.0.r363.gfe9b0f5-15.95.0.r364.g9ecac5b-1
kjsembed5.95.0.r329.g1f95849-15.95.0.r330.g739a999-1
kjumpingcube22.04.2.r827.gc7c5691-122.04.2.r828.g4359e77-1
kldap22.04.2.r953.g65608b9-122.04.2.r956.gc8c4d6a-1
kleopatra22.04.2.r6603.g75fdc663-122.04.2.r6634.gdbc0e886-1
klettres22.04.2.r966.g01c6515-122.04.2.r967.gf09902c-1
klickety22.04.2.r677.g7b5c9f2-122.04.2.r679.g671bd53-1
klines22.04.2.r821.gb160952-122.04.2.r823.g24962cf-1
kmag22.04.2.r737.g2ea44ab-122.04.2.r740.g8d360f5-1
kmahjongg22.04.2.r1554.ga90f494-122.04.2.r1557.gaaca0da-1
kmail22.04.2.r26432.gedfa4fa9f-122.04.2.r26439.gde3d97145-1
kmail-account-wizard22.04.2.r888.gf9a0363-122.04.2.r890.g5b15131-1
kmailtransport22.04.2.r1746.gd0cdf03-122.04.2.r1749.ge3d7fbf-1
kmbox22.04.2.r600.g9b19f74-122.04.2.r601.g07a272c-1
kmediaplayer5.95.0.r319.g9b02622-15.95.0.r320.gd8713aa-1
kmenuedit5.25.2.r1047.g18535fc-15.25.2.r1052.gce1f6cb-1
kmime22.04.2.r1519.gbff6f93-122.04.2.r1520.gbe8aa96-1
kmines22.04.2.r1768.g6810451-122.04.2.r1770.g859e949-1
kmix22.04.2.r2451.g9bb7ee36-122.04.2.r2454.g0abe8a6b-1
kmousetool22.04.2.r445.g9ef888a-122.04.2.r448.gd1fc84e-1
kmouth22.04.2.r731.gb6eb782-122.04.2.r734.g7d73167-1
kmplot22.04.2.r1496.ge9322f1-122.04.2.r1497.g7674529-1
knavalbattle22.04.2.r1435.gac7a67a-122.04.2.r1436.gc8ecc65-1
knetwalk22.04.2.r704.g71ebbff-122.04.2.r705.g3cf77a1-1
knewstuff5.95.0.r1358.g5278e9be-15.95.0.r1361.g7402b2b1-1
knights22.04.2.r1149.gd639e69-122.04.2.r1150.g90391df-1
knotes22.04.2.r3673.g05ba2ef7-122.04.2.r3676.g75d403e5-1
knotifications5.95.0.r746.gd908a73-15.95.0.r748.ga9d11ee-1
knotifyconfig5.95.0.r386.g2ca383e-15.95.0.r388.g4f30169-1
koko 22.06.r2.g0c434e9-1 22.06.r5.g5c5daae-1
kolf22.04.2.r1510.gb1d3bfc-122.04.2.r1513.g500da49-1
kollision22.04.2.r538.g223fc54-122.04.2.r540.g2f219f1-1
kolourpaint22.04.2.r2414.g511c737b-122.04.2.r2417.g922d4c75-1
kompare22.04.2.r1143.g00cb002-122.04.2.r1144.g344ec8d-1
kongress 22.06.r2.g75d32b1-1 22.06.r3.g9d310c9-1
konqueror22.04.2.r15123.gc1559a3da-122.04.2.r15126.g048083993-1
konquest22.04.2.r935.g6f619b8-122.04.2.r936.g5115000-1
konsole22.04.2.r8491.ga24ab084-122.04.2.r8533.gf4b83696-1
kontact22.04.2.r5543.g6d0fa206-122.04.2.r5545.g4b1c5c83-1
kontactinterface22.04.2.r697.ge3e11cd-122.04.2.r698.g7969038-1
kontrast22.04.2.r208.gdde15c4-122.04.2.r210.gf0e87e4-1
konversation22.04.2.r9126.g20426948-122.04.2.r9128.ge7bbd6c1-1
korganizer22.04.2.r11751.g7ef0598d6-122.04.2.r11762.g3a95821a7-1
kosmindoormap22.04.2.r739.gcb63fd2-122.04.2.r744.gd3d9d0f-1
kpackage5.95.0.r753.g8ada44b-15.95.0.r757.gee20342-1
kparts5.95.0.r589.g86b6137-15.95.0.r591.g8a14644-1
kpat22.04.2.r2622.g1ca733ee-122.04.2.r2625.g5e59e5b2-1
kpeople5.95.0.r1378.g10a44f2-15.95.0.r1379.g230c82a-1
kpimtextedit22.04.2.r1598.gf030726-122.04.2.r1602.ge2c7bf1-1
kpipewire5.25.2.r132.ga5079d8-15.25.2.r134.gca8fbdb-1
kpkpass22.04.2.r299.g95a9ecf-122.04.2.r300.gefa8479-1
kplotting5.95.0.r326.g38e8631-15.95.0.r327.gc121d42-1
kpmcore22.04.2.r1290.g0ad245f-122.04.2.r1292.g3dc4b78-1
kpty5.95.0.r377.g38f9344-15.95.0.r379.gbc039ac-1
kpublictransport22.04.2.r2023.gd4b7fdfb-122.04.2.r2031.g6b2a87e6-1
kqtquickcharts22.04.2.r76.gf1d32c3-122.04.2.r77.g9b882ce-1
kquickcharts5.95.0.r519.gc9638ad-15.95.0.r520.gb7697fe-1
krdc22.04.2.r1601.gc5e182f-122.04.2.r1607.g4a1a276-1
krecorder 22.06.r2.gf06447d-1 22.06.r7.g5cbc570-1
kreversi22.04.2.r1273.g3eff2f6-122.04.2.r1275.gcffcd49-1
krfb22.04.2.r1501.g720478a-122.04.2.r1506.gd1d0850-1
kross5.95.0.r360.g00e924b-15.95.0.r361.gc64793a-1
kruler22.04.2.r737.ga482c4b-122.04.2.r738.g96cf3a0-1
krunner5.95.0.r771.g487dd0c-15.95.0.r774.g6e1ef5f-1
kscreen5.25.2.r1478.gf730b96-15.25.2.r1479.gdd4ce63-1
kscreenlocker5.25.2.r964.gc313db7-15.25.2.r968.gcc7a05c-1
kservice5.95.0.r1019.gefa53cf-15.95.0.r1020.g58b061f-1
kshisen22.04.2.r1248.g94615c4-122.04.2.r1250.g250c4f1-1
ksirk22.04.2.r1034.ga599a82-122.04.2.r1036.g294de44-1
ksmtp22.04.2.r450.g7264754-122.04.2.r451.g266ed11-1
ksnakeduel22.04.2.r857.g8bc8c68-122.04.2.r859.g558b861-1
kspaceduel22.04.2.r677.g92431af-122.04.2.r678.g21c85b3-1
ksquares22.04.2.r563.gd531158-122.04.2.r565.gda9f023-1
ksudoku22.04.2.r1120.gd56c605-122.04.2.r1121.g0c28bd9-1
ksysguard5.25.2.r3534.gd30385c7-15.25.2.r3536.g163b3822-1
ksystemlog22.04.2.r735.g2bb9981-122.04.2.r737.gdc39a2c-1
kteatime22.04.2.r759.g8ee5306-122.04.2.r761.g6cd7ba4-1
ktexteditor5.95.0.r3426.gade54508-15.95.0.r3430.g509ca8a4-1
ktextwidgets5.95.0.r449.g7ce6a33-15.95.0.r452.g138967f-1
ktimer22.04.2.r520.g419ed68-122.04.2.r521.g6c8a10b-1
ktnef22.04.2.r720.gca64fcd-122.04.2.r721.g855853f-1
ktorrent22.04.2.r2865.g2f4923d7-122.04.2.r2866.ge7a394ae-1
ktouch22.04.2.r2184.gbaa288f-122.04.2.r2186.g55c07f6-1
ktrip 22.06.r4.g81cacb3-1 22.06.r6.gba29a14-1
ktuberling22.04.2.r1046.g1f31242-122.04.2.r1064.g06d2867-1
kturtle22.04.2.r1176.g379b8db-122.04.2.r1177.g1c2f5d1-1
kubrick22.04.2.r410.g72d5fd9-122.04.2.r412.ge19d338-1
kunitconversion5.95.0.r420.g724aa0d-15.95.0.r422.ga205fcb-1
kwallet5.95.0.r1155.g9c4e2a5-15.95.0.r1158.g36d83d1-1
kwallet-pam5.25.2.r270.g40e31dd-15.25.2.r271.g40ad5fe-1
kwalletmanager22.04.2.r1271.g20e42b5-122.04.2.r1276.gaab5f6e-1
kwave22.04.2.r3798.g0061bf34-122.04.2.r3799.g56b8c294-1
kwayland5.95.0.r1168.g8679ea3-15.95.0.r1169.g2cbfb45-1
kweather 22.06.r4.g0bb7bc5-1 22.06.r11.gc30638f-1
kwidgetsaddons5.95.0.r948.g422ab481-15.95.0.r950.g65f2136a-1
kwin5.25.2.r22677.gda7dad158-15.25.2.r22703.g40fb202ae-1
kwindowsystem5.95.0.r685.g866a4c6-15.95.0.r687.ga79f887-1
kwordquiz22.04.2.r1185.g5483ce2-122.04.2.r1186.g46a62fd-1
kwrite22.04.2.r19179.ga69004b4b-122.04.2.r19213.g356278ab2-1
kxmlgui5.95.0.r887.g8b7ef573-15.95.0.r891.g265eac17-1
kxmlrpcclient5.95.0.r483.gebbf23743-15.95.0.r484.g53289676b-1
layer-shell-qt5.25.2.r61.g13961ef-15.25.2.r62.g7bd6366-1
libakonadi22.04.2.r12781.gcfc1a5a24-122.04.2.r12790.ga8f072835-1
libgravatar22.04.2.r426.g32d910f-122.04.2.r427.gd78f119-1
libkdegames22.04.2.r2250.g79e50359-122.04.2.r2251.gc5848c0d-1
libkdepim22.04.2.r910.g946e944-122.04.2.r911.g4cae214-1
libkexiv222.04.2.r825.g3ccebcb-122.04.2.r827.g40cd78b-1
libkgapi22.04.2.r1366.g6dd4cc3-122.04.2.r1367.g7833cb8-1
libkleo22.04.2.r1187.g46f12d7-122.04.2.r1192.g7201c46-1
libkmahjongg22.04.2.r484.g1aef9b5-122.04.2.r485.g63e3d24-1
libksieve22.04.2.r1720.g50241b44-122.04.2.r1723.g911ef126-1
libksysguard5.25.2.r2416.g70c4f70-15.25.2.r2417.gccb0a41-1
lokalize22.04.2.r1834.g91fee00b-122.04.2.r1837.g0134f3c6-1
lskat22.04.2.r856.g62e927a-122.04.2.r859.g956bab5-1
mailcommon22.04.2.r1249.ga3960a7-122.04.2.r1255.g4d4ebcf-1
mailimporter22.04.2.r522.gc623df1-122.04.2.r524.g20a7033-1
maliit-keyboard2.2.1.1.r17.g4daaa6db-12.2.1.1.r59.gfa554a68-1
marble22.04.2.r13451.gf643c9733-122.04.2.r13455.g14f090099-1
marble-common22.04.2.r13451.gf643c9733-122.04.2.r13455.g14f090099-1
marble-qt22.04.2.r13451.gf643c9733-122.04.2.r13455.g14f090099-1
markdownpart22.04.2.r127.g9cd5d34-122.04.2.r129.g21207fc-1
maui-manager r19.ec6ded8-1 r25.563c3a9-1
maui-nota 2.1.2.r10.g8451565-1 2.1.2.r11.g1064432-1
maui-shell 0.5.0.r36.g1301d84-1 0.5.0.r43.g4feaa5c-1
mauikit2.1.2.r47.g4619afa1-12.1.2.r49.g82274116-1
mauiman r14.3594fc0-1 r15.b5c87ae-1
mbox-importer22.04.2.r570.g1891796-122.04.2.r572.g286306b-1
messagelib22.04.2.r6608.g605be84d8-122.04.2.r6619.gfcde856ee-1
milou5.25.2.r778.ge90fc8b-15.25.2.r779.g0363d7a-1
minuet22.04.2.r614.g3e56823-122.04.2.r615.g5b74c41-1
modemmanager-qt5.95.0.r556.g1aa1b1e-15.95.0.r557.g936dfff-1
neochat 22.06.r6.gaf198292-122.06.r12.g1dff2b82-1
networkmanager-qt5.95.0.r1156.g6c9d9ae-15.95.0.r1157.g7a1de86-1
okular22.04.2.r9760.g41e59e4f5-122.04.2.r9784.g64086998c-1
oxygen5.25.2.r4490.g33ebd8ab-15.25.2.r4494.g9a0bebcb-1
palapeli22.04.2.r1289.g0414160-122.04.2.r1290.g11fbde7-1
parley22.04.2.r4527.ga9c8182d-122.04.2.r4530.g31e5011a-1
partitionmanager22.04.2.r1631.g47861ed-122.04.2.r1634.gfda3b25-1
pim-data-exporter22.04.2.r2762.g2b3faf8f-122.04.2.r2766.gd3faa685-1
pim-sieve-editor22.04.2.r1631.g95e82b6-122.04.2.r1635.gaf6aa2b-1
pimcommon22.04.2.r1245.g897cb82-122.04.2.r1246.g945b8c4-1
plasma-bigscreen r473.gfb4606d-1 r475.gd536355-1
plasma-browser-integration5.25.2.r1333.g909552b1-15.25.2.r1336.g19f9c47b-1
plasma-desktop5.25.2.r9375.g1a0150d72-15.25.2.r9398.gb45d0cd6d-1
plasma-dialer 22.06.r6.g89c0b37-1 22.06.r11.g479885a-1
plasma-disks5.25.2.r282.g0532fc1-15.25.2.r284.g7d97510-1
plasma-firewall5.25.2.r636.gb980d67-15.25.2.r640.ga715576-1
plasma-framework5.95.0.r16353.gad77dc0a3-15.95.0.r16356.gebe2341f0-1
plasma-mobile5.25.2.r1876.gb7f1a5b37-15.25.2.r1882.gc632dab1c-1
plasma-mobile-nm5.25.2.r3273.g0d9cd3c9-15.25.2.r3283.gd9ae2eb6-1
plasma-nano5.25.2.r189.g34b95f3-15.25.2.r190.g8dc8976-1
plasma-nm5.25.2.r3273.g0d9cd3c9-15.25.2.r3283.gd9ae2eb6-1
plasma-pa5.25.2.r1055.g76b86df-15.25.2.r1057.gf5bcbb8-1
plasma-phonebook 22.06.r2.g16ef452-1 22.06.r3.g746e900-1
plasma-sdk5.25.2.r2370.g652a96df-15.25.2.r2372.g9220179e-1
plasma-settings 22.06.r5.g763f96a-1 22.06.r11.g3ccfa49-1
plasma-systemmonitor5.25.2.r586.gcc52c33-15.25.2.r588.g696db20-1
plasma-thunderbolt5.25.2.r192.g5c15dd8-15.25.2.r193.g8369978-1
plasma-vault5.25.2.r387.gd03bc02-15.25.2.r388.gf2f7183-1
plasma-wayland-session5.25.2.r12014.g923ce7e58-15.25.2.r12039.gf24b7554b-1
plasma-workspace5.25.2.r12014.g923ce7e58-15.25.2.r12039.gf24b7554b-1
plasmatube 22.06.r4.g9108a3a-1 22.06.r5.g5e4a4fb-1
polkit-kde-agent5.25.2.r530.gbb0d0c1-15.25.2.r531.ge482883-1
powerdevil5.25.2.r2557.g33b17fcd-15.25.2.r2558.g7614cac2-1
print-manager22.04.2.r1139.g68244a1-122.04.2.r1142.g236fafa-1
prison5.95.0.r390.g25e4b63-15.95.0.r391.ge853937-1
purpose5.95.0.r978.g49f2b20-15.95.0.r981.gc1e757a-1
qcachegrind22.04.2.r1187.gfff2c26-122.04.2.r1188.g2a19a76-1
qmlkonsole 22.06.r3.g2cb6c9c-1 22.06.r5.g3478624-1
qqc2-desktop-style5.95.0.r626.g4b403c9-15.95.0.r628.g6279e3f-1
rocs22.04.2.r3087.g77821b37-122.04.2.r3090.ge301b547-1
sddm-kcm5.25.2.r666.g26f35f1-15.25.2.r668.g7f477a3-1
solid5.95.0.r777.gf5d1af7-15.95.0.r778.g82da602-1
sonnet5.95.0.r699.g1d0257b-15.95.0.r700.g4c0d97f-1
spacebar 22.06.r3.gd82353e-1 22.06.r10.g9164ea3-1
spectacle22.04.2.r1362.ge117fdf-122.04.2.r1368.g5ab3344-1
step22.04.2.r1195.g85b505c-122.04.2.r1199.g733e773-1
svgpart22.04.2.r228.g8a55a98-122.04.2.r231.g0eaa001-1
sweeper22.04.2.r573.g02092f6-122.04.2.r577.g00d5ee3-1
syndication5.95.0.r876.gb330731-15.95.0.r877.gd7c4419-1
syntax-highlighting5.95.0.r1844.gf9961452-15.95.0.r1845.g2d8cdb5b-1
systemsettings5.25.2.r2683.g4b691491-15.25.2.r2689.gb788b584-1
threadweaver5.95.0.r544.g3228e68-15.95.0.r545.gf106607-1
tokodon 22.06.r4.g5703501-1 22.06.r7.g00dcbf3-1
vakzination 22.06.r4.gbb47d4d-1 22.06.r6.g58eb8c5-1
vvave 2.1.2.r25.g6d836d1-1 2.1.2.r26.ge0417a4-1
xdg-desktop-portal-kde5.25.2.r505.g6377ed4-15.25.2.r507.g5bc09db-1
yakuake22.04.2.r799.ged1c78c-122.04.2.r801.gf79c14a-1
zeroconf-ioslave22.04.2.r390.g9c1a418-122.04.2.r392.g30a1c9b-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
