Hello ARM community.
Lots of stuff this time.
Some highlights:
- Most of our kernels got updated
- Plasma Mobile Gear updated to 22.06
- Firefox updated to 102.0
- And KDE Plasma updated to 5.25.2
- Vim updated to 9.0
- Added Mattermost Desktop to the repository
- QT5 updated to 5.15.5
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Thu Jun 30 21:01:14 CEST 2022)
- arm-testing community aarch64: 469 new and 450 removed package(s)
- arm-testing core aarch64: 50 new and 50 removed package(s)
- arm-testing extra aarch64: 317 new and 415 removed package(s)
- arm-testing kde-unstable aarch64: 341 new and 341 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-06-21 2022-06-30
alligator 22.04-1 22.06-1
angelfish 22.04-1 22.06-1
audiotube 22.04-1 22.06-1
calindori 22.04-1 22.06-1
chatty 0.6.6-1 0.6.7-1
clapper 0.5.1-1 0.5.2-2
gnome-settings-daemon-hybris 41.0-2 41.0-3
hwinfo 21.81-1 21.82-1
kalk 22.04-1 22.06-1
kasts 22.04-1 22.06-1
kclock 22.04-1 22.06-1
keysmith 22.04-1 22.06-1
kgx 0.4.0-2 -
khealthcertificate 22.04-1 -
kodi-rpi-git20.x.60586.2a7027f7ef-120.x.60615.6e005074e6-1
kodi-rpi-git-dev20.x.60586.2a7027f7ef-120.x.60615.6e005074e6-1
kodi-rpi-git-eventclients20.x.60586.2a7027f7ef-120.x.60615.6e005074e6-1
kodi-rpi-git-tools-texturepacker20.x.60586.2a7027f7ef-120.x.60615.6e005074e6-1
koko 22.04-1 22.06-1
kongress 22.04-1 22.06-1
krecorder 22.04-1 22.06-1
ktrip 22.04-1 22.06-2
kweather 22.04-1 22.06-1
libgbinder 1.1.21-1 1.1.23-1
libmm-pp-glib 1.18.6-1 1.18.10-1
linux-rpi4-udl 5.15.48-1 5.15.49-1
linux-rpi4-udl-headers 5.15.48-1 5.15.49-1
megapixels 1.4.3-2 1.5.1-1
mmsd-tng 1.9-1 1.10-1
modemmanager-pp 1.18.6-1 1.18.10-1
phoc 0.20.0+86+g70666f2-20.21.0beta1+1+g826ca55-1
phosh0.20.0beta1+40+g8cd2797a-10.20.0beta2+1+ga259011c-3
phosh-antispam 2.1-1 2.1.1-1
pika-backup 1:0.4.0-1 1:0.4.1-1
plasma-dialer 22.04-1 22.06-1
plasma-mobile-settings 20220530-1 20220628-1
plasma-phonebook 22.04-1 22.06-1
plasma-settings 22.04-1 22.06-1
qmlkonsole 22.04.1-1 22.06-1
qt5-virtualkeyboard-bigscreen 5.15.4+kde+r3-1 5.15.5+kde+r0-1
quartz64-post-install 20220607-1 20220624-1
siglo 0.9.6-5 0.9.8-1
spacebar 22.04-1 22.06-1
squeekboard 1.18.0-1 1.18.0+30+g50ef4ab-1
timeshift 22.06.1-1 22.06.3-1
tokodon 22.04-1 22.06-1
vakzination 22.04-1 22.06-1
mattermost-desktop - 5.1.0-1
opi4lts-post-install - 20220630-1
phosh-mobile-settings - 0.0.1+8+g85dcce4-1
python-es2-pyqt5 - 5.15.7-1
:: Different sync package(s) in repository community aarch64
aliyun-cli 3.0.121-1 3.0.123-1
ansible 5.9.0-1 6.0.0-1
ansible-core 2.13.0-1 2.13.1-1
antic 0.2.4-2 0.2.5-1
aqbanking 6.5.0-1 6.5.0-2
arb 2.22.1-1 2.23.0-1
argocd 2.4.0-1 2.4.3-1
argyllcms 2.3.0-1 2.3.1-1
aspell-da 1.6.36-2 4.0-1
aws-cli 1.24.7-1 1.25.17-1
awxkit 21.1.0-1 21.2.0-1
babel-core 7.18.2-1 7.18.5-1
bctoolbox 5.1.38-1 5.1.45-1
binaryen 1:108-1 1:109-1
borg 1.2.0-3 1.2.1-1
broot 1.13.2-1 1.13.3-1
btop 1.2.7-1 1.2.8-1
bzrtp 5.1.31-1 5.1.45-1
cadence 0.9.1-6 0.9.2-1
capnet-assist 2.4.1-2 2.4.2-2
cargo-depgraph 1.2.4-1 1.2.5-1
cargo-nextest 0.9.21-1 0.9.23-1
chezmoi 2.17.1-1 2.18.1-1
choqok 1.7.0-3 1.7.0-4
cinnamon 5.2.7-2 5.4.2-1
cinnamon-control-center 5.4.0-1 5.4.2-1
cinnamon-settings-daemon 5.4.0-1 5.4.1-1
clash 1.10.6-1 1.11.0-1
clojure 1.11.1.1105-2 1.11.1.1149-1
cockpit 271-1 272-1
cockpit-machines 270.2-1 271-1
cockpit-pcp 271-1 272-1
cockpit-podman 49.1-1 50-1
cozy-stack 1:1.5.5-1 1:1.5.6-1
criu 3.17-1 3.17.1-1
cross 0.2.1-2 0.2.2-1
dagger 0.2.19-1 0.2.21-1
dark-reader 4.9.51-1 4.9.52-1
dart 2.17.3-1 2.17.5-1
dart-sass 1.52.3-1 1.53.0-1
deepin-qt5platform-plugins 5.0.59-2 5.0.59-3
diffoscope 216-1 217-1
direnv 2.32.0-1 2.32.1-1
drone-runner-exec 1.0.0.beta.9-4 1.0.0.beta.10-1
dua-cli 2.17.1-1 2.17.7-1
dune 3.2.0-1 3.3.0-1
e-antic 1.2.1-1 1.2.1-2
eclib 20210625-4 20220621-2
emscripten 3.1.9-1 3.1.13-1
espeak-ng 1.51-1 1.51.1-1
esptool 3.3-1 4.1-1
exim 4.95-2 4.96-1
faust 2.40.0-1 2.41.1-1
fb-client 2.1.1-1 2.2.0-3
fcitx-qt5 1.2.7-4 1.2.7-5
fcitx-qt6 1.2.7-4 1.2.7-5
feeluown 3.8.5-1 3.8.6-1
feeluown-kuwo 0.1.5-2 0.1.6-1
fingerterm 1.4.5-1 1.4.6-1
firefox-dark-reader 4.9.51-1 4.9.52-1
firefox-extension-mailvelope 4.5.1-1 4.6.0-1
fisher 4.3.4-1 4.3.5-1
flint 2.8.5-1 2.9.0-1
focuswriter 1.7.6-3 1.8.0-1
foliate 2.6.4-1 2.6.4-2
gajim 1.4.4-1 1.4.5-2
gamescope 3.11.30-1 3.11.32-1
geos 3.9.1-1 3.10.3-1
ghostwriter 2.1.3-1 2.1.4-1
giac 1.9.0.7-1 1.9.0.11-1
gif2png 3.0.0-3 3.0.0-4
gimp-plugin-gmic 3.1.3-2 3.1.4-1
github-cli 2.12.1-1 2.13.0-1
gitlab-runner 15.0.0-2 15.1.0-1
go-yq 4.25.2-1 4.25.3-1
grpc 1.46.3-2 1.47.0-1
grpc-cli 1.46.3-2 1.47.0-1
gsimplecal 2.2-1 2.4-1
hcloud 1.29.5-1 1.30.0-1
home-assistant 2022.4.6-1 1:2022.6.7-1
hound 0.5.0-1 0.5.1-1
hugo 0.100.2-1 0.101.0-1
i3lock 2.14-1 2.14.1-1
i3status-rust 0.21.10-1 0.22.0-1
ibus-table 1.16.8-1 1.16.9-1
jacktrip 1.6.0-1 1.6.1-1
jedi-language-server 0.35.1-1 0.36.0-1
jenkins 2.355-1 2.357-1
jmol 14.32.60-1 14.32.62-1
jruby 9.3.4.0-1 9.3.6.0-1
jsmol 14.32.60-1 14.32.62-1
juce 6.1.6-1 7.0.0-1
juce-docs 6.1.6-1 7.0.0-1
jupyter-server 1.17.1-1 1.18.0-1
jupyter-widgetsnbextension 1:3.6.0-2 1:3.6.1-1
jupyterlab-widgets 1.0.2-2 1.1.1-1
kcptun 20210922-1 20220628-1
kea 2.0.2-1 2.0.2-2
kea-docs 2.0.2-1 2.0.2-2
kicad 6.0.5-1 6.0.6-1
kicad-library-3d 6.0.5-1 6.0.6-1
kicad-library 6.0.5-1 6.0.6-1
kiwix-desktop 2.2.1-3 2.2.2-1
kiwix-tools 3.2.0-4 3.3.0-1
kmymoney 5.1.2-7 5.1.2-9
krita-plugin-gmic 3.1.2.3-1 3.1.4.2-1
libfm-qt 1.1.0-2 1.1.0-3
libindi 1.9.6-1 1.9.6-2
libmediainfo 22.03-1 22.06-1
libmupdf 1.19.1-1 1.20.0-1
libmusicxml 3.21-1 3.22-1
libopenraw 0.3.1-1 0.3.2-1
libqtxdg 3.9.1-2 3.9.1-3
libretro-beetle-pce 1102-2 1143-1
libretro-beetle-pce-fast 1159-2 1186-1
libretro-beetle-psx 2612-1 2615-1
libretro-beetle-psx-hw 2612-1 2615-1
libretro-bsnes-hd 50-2 51-1
libretro-dolphin 33011-1 33015-1
libretro-genesis-plus-gx 1910-1 1918-1
libretro-overlays 210-2 219-1
libretro-shaders-slang 949-1 954-1
libretro-snes9x 2145-1 2152-1
librttopo 1.1.0-4 1.1.0-5
libsecp256k120220317+1581+ge0508ee-120220630+1625+g43756da-1
libtg_owt 0.git13.63a934d-1 0.git14.10d5f4b-1
lightdm-slick-greeter 1.5.7-1 1.5.9-1
linuxconsole 1.7.1-1 1.8.1-1
lmms 1.2.2-8 1.2.2-10
lollypop 1.4.33-1 1.4.34-1
lsp-plugins 1.2.1-1 1.2.2-1
lsp-plugins-docs 1.2.1-1 1.2.2-1
lttng-ust 2.13.2-1 2.13.3-1
lua-language-server 3.3.1-1 3.4.0-1
luajit2.1.0.beta3.r411.g68bb1140-12.1.0.beta3.r422.g4c2441c1-1
lxc 1:4.0.12-1 1:5.0.0-4
lxd 5.2-1 5.3-1
mame 0.244-1 0.245-1
mame-tools 0.244-1 0.245-1
matrix-synapse 1.60.0-1 1.61.1-1
matterbridge 1.25.1-1 1.25.2-1
maven 3.8.4-1 3.8.6-1
mediainfo-gui 22.03-1 22.06-1
mediastreamer 5.1.43-1 5.1.45-1
minio 2022.05.26-1 2022.06.17-1
minio-client 2022.05.09-1 2022.06.17-1
miniserve 0.19.5-1 0.20.0-1
mitmproxy 8.1.0-1 8.1.0-2
mkosi 12-1 13-1
mmctl 7.0.0-2 7.0.1-1
mongo-c-driver 1.21.1-2 1.21.2-1
muffin 5.4.0-1 5.4.1-1
mupdf-gl 1.19.1-1 1.20.0-1
mupdf-tools 1.19.1-1 1.20.0-1
neochat 22.04-1 22.06-1
neovim 0.7.0-3 0.7.2-3
netcdf 4.8.1-3 4.9.0-3
netcdf-fortran-openmpi 4.5.3-3 4.5.4-1
netcdf-openmpi 4.8.1-3 4.9.0-3
newsboat 2.27-1 2.28-1
nextcloud 24.0.1-1 24.0.2-1
nextcloud-app-bookmarks 1:10.4.0-1 1:10.5.1-1
nextcloud-app-calendar 1:3.3.2-1 1:3.4.1-1
nextcloud-app-mail 1.13.4-1 1.13.5-1
nginx-mod-geoip2 3.3-6 3.4-1
nginx-mod-njs 0.7.4-2 0.7.5-1
nodejs 18.3.0-1 18.4.0-1
nomad-driver-nspawn 0.9.0-2 0.9.1-1
normaliz 3.9.3-1 3.9.3-2
npm 8.5.5-1 8.9.0-1
nvchecker 2.8-1 2.9-1
ocaml-sexplib0 0.15.0-1 0.15.1-1
oil 0.10.1-1 0.11.0-1
opendht 1:2.4.4-1 1:2.4.7.2-1
openfortivpn 1.17.2-1 1.17.3-1
opensearch-dashboards 2.0.0-1 2.0.1-1
opensearch-dashboards-alerting-plugin 2.0.0.0-1 2.0.1.0-1
opensearch-dashboards-anomaly-detection-plugin 2.0.0.0-1 2.0.1.0-1
opensearch-dashboards-gantt-chart-plugin 2.0.0.0-1 2.0.1.0-1
opensearch-dashboards-index-management-plugin 2.0.0.0-1 2.0.1.0-1
opensearch-dashboards-observability-plugin 2.0.0.0-1 2.0.1.0-1
opensearch-dashboards-query-workbench-plugin 2.0.0.0-1 2.0.1.0-1
opensearch-dashboards-reports-plugin 2.0.0.0-1 2.0.1.0-1
opensearch-dashboards-security-plugin 2.0.0.0-1 2.0.1.0-1
openxr 1.0.23-1 1.0.24-1
ortp 5.1.31-1 5.1.45-1
osbuild 58-1 59-1
owncloud-client 2.10.1.7187-1 2.10.1.7389-1
p2pool 2.0-2 2.1-1
pan 0.149-1 0.150-1
parallel 20220522-1 20220622-1
parallel-docs 20220522-1 20220622-1
pdal 2.4.2-1 2.4.2-2
perl-chart 2.402.1-1 2.402.3-1
perl-cpan-perl-releases 5.20220528-1 5.20220620-1
perl-throwable 0.200013-8 1.000-1
php-grpc 1.46.3-2 1.47.0-1
php7-grpc 1.46.3-2 1.47.0-1
piping-server 0.13.0-1 0.14.0-1
plantuml-server 1.2022.4-1 1.2022.6-1
pnetcdf-openmpi 1.12.3-2 1.12.3-3
poco 1.11.2-1 1.11.3-1
podman 4.1.1-1 4.1.1-2
podman-docker 4.1.1-1 4.1.1-2
polymake 4.6-4 4.6-6
pop-icon-theme2.1.0.r2434.28b598d347-12.1.0.r2446.baf29712c7-1
puppet 7.16.0-1 7.17.0-1
pyenv 2.3.1-1 2.3.2-1
pyright 1.1.254-1 1.1.256-1
python-aaf2 1.4.0-3 1.5.0-1
python-aiogram 2.20-1 2.21-1
python-apispec 5.2.0-1 5.2.1-1
python-argparse-manpage 1.5-3 3-1
python-atpublic 2.3-3 3.0.1-1
python-authlib 0.15.5-3 1.0.1-3
python-autopage 0.4.0-1 0.5.1-1
python-aws-sam-translator 1.45.0-1 1.46.0-1
python-bcrypt 3.2.1-1 3.2.2-1
python-black 22.3.0-1 22.6.0-1
python-bleach 4.1.0-3 5.0.0-1
python-boto3 1.23.7-1 1.24.17-1
python-botocore 1.26.7-1 1.27.17-1
python-breathe 4.33.1-1 4.34.0-1
python-cachetools 5.1.0-1 5.2.0-1
python-calver 2021.7.30-1 2022.06.26-1
python-canonicaljson 1.6.1-1 1.6.2-1
python-cattrs 1.10.0-3 22.1.0-1
python-certifi 2021.10.8-3 2022.06.15-1
python-cfn-lint 0.59.0-1 0.61.1-1
python-cftime 1.6.0-1 1.6.1-1
python-charset-normalizer 2.0.10-2 2.1.0-1
python-cloudflare 2.8.15-4 2.9.10-1
python-cppy 1.2.1-1 1.2.1-2
python-crate 0.26.0-3 0.27.0-1
python-cryptography-vectors 37.0.2-1 37.0.3-1
python-css-parser 1.0.6-5 1.0.7-1
python-cssbeautifier 1.14.3-1 1.14.4-1
python-dask 2022.03.0-2 2022.6.0-1
python-designateclient 4.5.0-1 4.5.1-1
python-diff-cover 6.5.0-1 6.5.1-1
python-discogs-client 2.3.14-1 2.3.15-1
python-distributed 2022.03.0-2 2022.6.0-1
python-django-debug-toolbar 3.2.4-1 3.5-1
python-django-modeltranslation 0.17.6-1 0.18.2-1
python-django-picklefield 3.0.1-5 3.1.0-1
python-docstring-to-markdown 0.9-4 0.10-1
python-dogpile.cache 1.1.5-1 1.1.6-1
python-elasticsearch 7.8.1-5 7.9.0-1
python-entrypoint2 1.0-1 1.1-1
python-fido2 0.9.3-3 1.0.0-1
python-fissix 21.6.6-3 21.11.13-1
python-flufl-lock 6.0-3 7.0-2
python-flufl.i18n 3.2-3 4.0-1
python-genshi 0.7.5-4 0.7.7-1
python-geopandas 0.10.2-2 0.11.0-1
python-graphene 3.0.0-3 3.1.0-1
python-grpcio 1.46.3-2 1.47.0-1
python-httpx 0.23.0-1 0.23.0-2
python-ini2toml 0.10-1 0.11-1
python-iosbackup 0.9.921-2 0.9.923-2
python-ipyparallel 8.4.0-1 8.4.1-1
python-ipywidgets 7.7.0-4 7.7.1-1
python-jsbeautifier 1.14.3-1 1.14.4-1
python-jupyter-sphinx 0.3.2-2 0.4.0-1
python-jupyter_packaging 0.12.1-1 0.12.2-1
python-kiwisolver 1.3.2-3 1.4.2-1
python-kubernetes 23.6.0-2 24.2.0-1
python-lttngust 2.13.2-1 2.13.3-1
python-lupa 1.10-3 1.13-1
python-netcdf4 1.5.8-1 1.6.0-1
python-netcdf4-openmpi 1.5.8-1 1.6.0-1
python-numexpr 2.8.1-1 2.8.3-1
python-orjson 3.7.2-1 3.7.5-1
python-outcome 1.1.0-3 1.2.0-1
python-pandas 1.4.2-1 1.4.3-1
python-param 1.12.1-1 1.12.2-1
python-pikepdf 5.1.5-1 5.1.5.post1-1
python-poppler-qt5 21.1.0-3 21.3.0-1
python-proxmoxer 1.2.0-2 1.3.1-1
python-psutil 5.9.0-2 5.9.1-1
python-pycares 4.1.2-3 4.2.1-1
python-pycryptodome 3.14.1-1 3.15.0-1
python-pygame-sdl21:2.1.0.r405.33f79ca-11:2.1.0.r411.7f814e9-1
python-pygit2 1.9.1-1 1.9.2-1
python-pylint 2.14.3-1 2.14.4-1
python-pymupdf 1.19.6-1 1.20.1-1
python-pynitrokey 0.4.24-1 0.4.25-1
python-pyroute2 0.6.12-1 0.6.13-1
python-pyscard 2.0.2-1 2.0.3-1
python-pytest-asyncio 0.18.1-1 0.18.2-1
python-pytest-console-scripts 1.2.1-4 1.3.1-1
python-pytest-testinfra 6.7.0-1 6.8.0-1
python-pytools 2022.1.4-1 2022.1.5-1
python-pywlroots 0.15.17-1 0.15.18-1
python-qdarkstyle 3.0.2-3 3.0.3-1
python-qtawesome 1.1.0-1 1.1.1-1
python-qtconsole 5.3.0-2 5.3.1-1
python-railroad-diagrams 1.1.1-1 2.0.4-1
python-rstr 3.0.0-3 3.2.0-1
python-s3transfer 0.5.2-1 0.6.0-1
python-scikit-build 0.13.1-2 0.15.0-1
python-setuptools-scm 6.4.2-1 7.0.3-1
python-setuptools-scm-git-archive 1.1-4 1.4-1
python-shapely 1.8.1-1 1.8.2-1
python-sphinx-basic-ng 0.0.1a11-1 0.0.1a12-1
python-sphinx-click 4.1.0-1 4.2.0-1
python-sphinx-furo 2022.06.04.1-1 2022.06.21-1
python-sphinx-reredirects 0.1.0-1 0.1.1-1
python-sphinxcontrib-spelling 7.5.1-1 7.6.0-1
python-sqlalchemy-utils 0.37.1-4 0.38.2-1
python-tabulate 0.8.9-4 0.8.10-1
python-trio 0.19.0-3 0.21.0-1
python-uncertainties 3.1.6-3 3.1.7-1
python-unidiff 0.7.3-1 0.7.4-1
python-websocket-client 1.3.2-1 1.3.3-1
python-zope-testrunner 5.4.0-3 5.5-1
python-zstandard 0.17.0-1 0.18.0-1
python2-pycryptodome 3.14.1-1 3.15.0-1
python2-pygame-sdl21:2.1.0.r405.33f79ca-11:2.1.0.r411.7f814e9-1
qcad 3.27.6.3-1 3.27.6.3-2
qgnomeplatform-qt5 0.8.4-3 0.8.4-4
qgnomeplatform-qt6 0.8.4-3 0.8.4-4
qt5-ukui-platformtheme 1.0.7-3 1.0.7-4
qutebrowser 2.5.1-1 2.5.2-1
r 4.2.0-4 4.2.1-1
range-v3 0.11.0-1 0.12.0-1
redmine 5.0.1-1 5.0.2-1
rekor 0.8.0-1 0.8.2-1
remmina 1:1.4.26-1 1:1.4.27-1
repo 2.26-1 2.27-1
retroarch-assets-glui 1:424-1 1:428-1
retroarch-assets-ozone 1:424-1 1:428-1
retroarch-assets-xmb 1:424-1 1:428-1
reuse 1.0.0-1 1.0.0-2
rev-plugins 0.7.1-6 0.8.1-1
rkcommon 1.9.0-1 1.10.0-1
ruby-gettext 3.4.2-1 3.4.3-1
ruby-jwt 2.3.0-1 2.4.1-1
ruby-metadata-json-lint 3.0.2-1 3.0.2-2
ruby-minitest-retry 0.2.1-2 0.2.2-1
ruby-mocha 1.13.0-1 1.14.0-1
ruby-pg 1.3.4-1 1.4.1-1
ruby-power_assert 2.0.0-1 2.0.1-1
ruby-puppet-resource_api 1.8.13-3 1.8.14-1
ruby-puppet_metadata 1.4.0-1 1.7.0-1
ruby-rr 1.2.1-7 3.0.9-1
ruby-sinatra 2.1.0-4 2.2.0-1
rust-analyzer 20220613-1 20220627-1
sccache 0.2.15-2 0.3.0-1
selene-linter 0.18.2-1 0.19.1-1
shotcut 22.04.25-1 22.06.23-1
sile 0.13.1-1 0.13.2-2
singular 4.3.0.p1-1 4.3.1-2
skrooge 2.27.0-3 2.27.0-4
spirv-headers 1:1.3.211.0-1 1:1.3.216.0-1
sqlcipher 4.5.1-1 4.5.1-2
sqlx-cli 0.5.10-1.1 0.6.0-1
sslscan 2.0.13-1 2.0.14-1
sssd 2.7.0-1 2.7.2-1
starship 1.8.0-1 1.9.1-1
stella 6.6-1 6.7-1
syft 0.46.0-1 0.49.0-1
symengine 0.9.0-1 0.9.0-2
tailscale 1.26.0-1 1.26.1-1
tanka 0.22.0-1 0.22.1-1
taplo-cli 0.6.8-1 0.6.9-1
telegram-desktop 3.7.3-1 4.0.2-2
terraform 1.2.2-1 1.2.3-1
terragrunt 0.37.1-1 0.38.1-1
thunderbird-dark-reader 4.9.51-1 4.9.52-1
tiled 1.8.5-1 1.9.0-1
topcom 0.17.8-1 0.17.10-1
trivy 0.29.0-1 0.29.2-1
ttf-nerd-fonts-symbols 2.1.0+36+gd0bf73a1-5 2.1.0+36+gd0bf73a1-6
ttf-nerd-fonts-symbols-mono 2.1.0+36+gd0bf73a1-5 2.1.0+36+gd0bf73a1-6
ttf-sarasa-gothic 0.36.4-1 0.36.5-1
typescript 4.7.3-1 4.7.4-1
typescript-language-server 0.11.1-1 0.11.2-1
ugrep 3.8.2-1 3.8.3-1
ukui-window-switch 3.0.1-4 3.0.1-5
unrealircd 6.0.3-1 6.0.4-1
uvicorn 0.17.6-1 0.18.2-1
v2ray-domain-list-community 20220617132201-1 20220629152223-1
v2ray-geoip 202206160052-1 202206300050-1
vapoursynth R58-1 R59-1
vaultwarden-web 2022.05.0-1 2022.5.2-1
verilator 4.222-1 4.224-1
virt-what 1.21-2 1.24-1
vkd3d 1.3-1 1.4-1
wabt 1.0.26-1 1.0.29-1
wasmer 2.2.1-1 2.3.0-1
watchexec 1.19.0-1 1.20.2-1
web-ext 7.0.0-1 7.1.0-1
weston 10.0.0-1 10.0.1-1
wezterm20220408.101518.b908e2dd-220220624.141144.bd1b7c5d-2
woob 3.0-5 3.0-6
xpra 4.2.3-4 4.3.3-1
xreader 3.3.0-1 3.4.0-1
yt-dlp 2022.05.18-1 2022.06.29-1
zoxide 0.8.1-2 0.8.2-1
darktable - 2:3.8.1-4
golang-github-linuxdeepin-go-gir - 2.1.0-1
grafana-agent - 0.25.1-1
grafana-agent-crow - 0.25.1-1
grafana-agentctl - 0.25.1-1
mimir - 2.1.0-4
pgformatter - 5.2-3
python-cachelib - 0.8.0-2
python-findpython - 0.1.6-1
python-pdm - 1.15.4-2
python-pdm-pep517 - 1:0.12.7-1
python-pygeos - 0.12.0-2
python-pyogrio - 0.4.0-1
qbe - 1.0-1
ruby-introspection - 0.0.4-2
ruby-metaclass - 0.0.4-1
xmrig - 6.18.0-1
:: Different overlay package(s) in repository core aarch64
linux 5.18.5-2 5.18.8-2
linux-clockworkpi-a06 5.18.5-1 5.18.8-1
linux-clockworkpi-a06-headers 5.18.5-1 5.18.8-1
linux-headers 5.18.5-2 5.18.8-2
linux-khadas 5.18.1-1 5.18.5-1
linux-khadas-headers 5.18.1-1 5.18.5-1
linux-lts 5.15.48-1 5.15.51-1
linux-lts-headers 5.15.48-1 5.15.51-1
linux-odroid 5.18.1-1 5.18.5-1
linux-odroid-headers 5.18.1-1 5.18.5-1
linux-pinephone 5.18.5-1 5.18.8-1
linux-pinephone-headers 5.18.5-1 5.18.8-1
linux-pinephonepro 5.18.5-1 5.18.8-1
linux-pinephonepro-headers 5.18.5-1 5.18.8-1
linux-rc 5.19.rc3-1 5.19.rc4-1
linux-rc-headers 5.19.rc3-1 5.19.rc4-1
linux-rpi4 5.15.48-1 5.15.50-1
linux-rpi4-headers 5.15.48-1 5.15.50-1
linux-rpi4-mainline 5.18.2-1 5.18.7-1
linux-rpi4-mainline-headers 5.18.2-1 5.18.7-1
linux-rpi4-rc 5.19.rc3-1 5.19.rc4-1
linux-rpi4-rc-headers 5.19.rc3-1 5.19.rc4-1
pacman 6.0.1-6 6.0.1-8.2
pacman-debug 6.0.1-6 -
uboot-orangepi4-lts - 2022.04-1
:: Different sync package(s) in repository core aarch64
amd-ucode 20220509.b19cbdc-1 20220610.7b71b75-1
ca-certificates-mozilla 3.79-1 3.80-1
curl 7.83.1-1 7.84.0-1
e2fsprogs 1.46.5-3 1.46.5-4
fuse2fs 1.46.5-3 1.46.5-4
kbd 2.5.0-2 2.5.1-1
lemon 3.38.5-1 3.39.0-2
libcurl-compat 7.83.1-1 7.84.0-1
libcurl-gnutls 7.83.1-1 7.84.0-1
libnghttp2 1.47.0-1 1.48.0-1
linux-firmware 20220509.b19cbdc-1 20220610.7b71b75-1
linux-firmware-bnx2x 20220509.b19cbdc-1 20220610.7b71b75-1
linux-firmware-liquidio 20220509.b19cbdc-1 20220610.7b71b75-1
linux-firmware-marvell 20220509.b19cbdc-1 20220610.7b71b75-1
linux-firmware-mellanox 20220509.b19cbdc-1 20220610.7b71b75-1
linux-firmware-nfp 20220509.b19cbdc-1 20220610.7b71b75-1
linux-firmware-qcom 20220509.b19cbdc-1 20220610.7b71b75-1
linux-firmware-qlogic 20220509.b19cbdc-1 20220610.7b71b75-1
linux-firmware-whence 20220509.b19cbdc-1 20220610.7b71b75-1
nss 3.79-1 3.80-1
openssl 1.1.1.o-1 1.1.1.p-1
sqlite 3.38.5-1 3.39.0-2
sqlite-analyzer 3.38.5-1 3.39.0-2
sqlite-doc 3.38.5-1 3.39.0-2
sqlite-tcl 3.38.5-1 3.39.0-2
sudo 1.9.11.p2-1 1.9.11.p3-1
:: Different overlay package(s) in repository extra aarch64
firefox-i18n-ach 101.0-1.1 -
firefox-i18n-af 101.0-1.1 -
firefox-i18n-an 101.0-1.1 -
firefox-i18n-ar 101.0-1.1 -
firefox-i18n-ast 101.0-1.1 -
firefox-i18n-az 101.0-1.1 -
firefox-i18n-be 101.0-1.1 -
firefox-i18n-bg 101.0-1.1 -
firefox-i18n-bn 101.0-1.1 -
firefox-i18n-br 101.0-1.1 -
firefox-i18n-bs 101.0-1.1 -
firefox-i18n-ca 101.0-1.1 -
firefox-i18n-ca-valencia 101.0-1.1 -
firefox-i18n-cak 101.0-1.1 -
firefox-i18n-cs 101.0-1.1 -
firefox-i18n-cy 101.0-1.1 -
firefox-i18n-da 101.0-1.1 -
firefox-i18n-de 101.0-1.1 -
firefox-i18n-dsb 101.0-1.1 -
firefox-i18n-el 101.0-1.1 -
firefox-i18n-en-ca 101.0-1.1 -
firefox-i18n-en-gb 101.0-1.1 -
firefox-i18n-en-us 101.0-1.1 -
firefox-i18n-eo 101.0-1.1 -
firefox-i18n-es-ar 101.0-1.1 -
firefox-i18n-es-cl 101.0-1.1 -
firefox-i18n-es-es 101.0-1.1 -
firefox-i18n-es-mx 101.0-1.1 -
firefox-i18n-et 101.0-1.1 -
firefox-i18n-eu 101.0-1.1 -
firefox-i18n-fa 101.0-1.1 -
firefox-i18n-ff 101.0-1.1 -
firefox-i18n-fi 101.0-1.1 -
firefox-i18n-fr 101.0-1.1 -
firefox-i18n-fy-nl 101.0-1.1 -
firefox-i18n-ga-ie 101.0-1.1 -
firefox-i18n-gd 101.0-1.1 -
firefox-i18n-gl 101.0-1.1 -
firefox-i18n-gn 101.0-1.1 -
firefox-i18n-gu-in 101.0-1.1 -
firefox-i18n-he 101.0-1.1 -
firefox-i18n-hi-in 101.0-1.1 -
firefox-i18n-hr 101.0-1.1 -
firefox-i18n-hsb 101.0-1.1 -
firefox-i18n-hu 101.0-1.1 -
firefox-i18n-hy-am 101.0-1.1 -
firefox-i18n-ia 101.0-1.1 -
firefox-i18n-id 101.0-1.1 -
firefox-i18n-is 101.0-1.1 -
firefox-i18n-it 101.0-1.1 -
firefox-i18n-ja 101.0-1.1 -
firefox-i18n-ka 101.0-1.1 -
firefox-i18n-kab 101.0-1.1 -
firefox-i18n-kk 101.0-1.1 -
firefox-i18n-km 101.0-1.1 -
firefox-i18n-kn 101.0-1.1 -
firefox-i18n-ko 101.0-1.1 -
firefox-i18n-lij 101.0-1.1 -
firefox-i18n-lt 101.0-1.1 -
firefox-i18n-lv 101.0-1.1 -
firefox-i18n-mk 101.0-1.1 -
firefox-i18n-mr 101.0-1.1 -
firefox-i18n-ms 101.0-1.1 -
firefox-i18n-my 101.0-1.1 -
firefox-i18n-nb-no 101.0-1.1 -
firefox-i18n-ne-np 101.0-1.1 -
firefox-i18n-nl 101.0-1.1 -
firefox-i18n-nn-no 101.0-1.1 -
firefox-i18n-oc 101.0-1.1 -
firefox-i18n-pa-in 101.0-1.1 -
firefox-i18n-pl 101.0-1.1 -
firefox-i18n-pt-br 101.0-1.1 -
firefox-i18n-pt-pt 101.0-1.1 -
firefox-i18n-rm 101.0-1.1 -
firefox-i18n-ro 101.0-1.1 -
firefox-i18n-ru 101.0-1.1 -
firefox-i18n-sco 101.0-1.1 -
firefox-i18n-si 101.0-1.1 -
firefox-i18n-sk 101.0-1.1 -
firefox-i18n-sl 101.0-1.1 -
firefox-i18n-son 101.0-1.1 -
firefox-i18n-sq 101.0-1.1 -
firefox-i18n-sr 101.0-1.1 -
firefox-i18n-sv-se 101.0-1.1 -
firefox-i18n-szl 101.0-1.1 -
firefox-i18n-ta 101.0-1.1 -
firefox-i18n-te 101.0-1.1 -
firefox-i18n-th 101.0-1.1 -
firefox-i18n-tl 101.0-1.1 -
firefox-i18n-tr 101.0-1.1 -
firefox-i18n-trs 101.0-1.1 -
firefox-i18n-uk 101.0-1.1 -
firefox-i18n-ur 101.0-1.1 -
firefox-i18n-uz 101.0-1.1 -
firefox-i18n-vi 101.0-1.1 -
firefox-i18n-xh 101.0-1.1 -
firefox-i18n-zh-cn 101.0-1.1 -
firefox-i18n-zh-tw 101.0-1.1 -
kirigami-addons 1:0.2-1 1:0.3-1
libnm 1.34.0-1 1.38.2-1
mesa-git22.2.0_devel.155653.9ca0c0b4b408-122.2.0_devel.155889.b28efd80ebb4-1
networkmanager 1.34.0-1 1.38.2-1
nm-cloud-setup 1.34.0-1 1.38.2-1
oxygen-sounds 5.23.3-1 -
plasma-mobile 5.25.0-1 5.25.2-1
plasma-mobile-nm 5.25.0-1 5.25.2-1
plasma-nano 5.25.0-1 5.25.2-1
python-es2-pyqt5 5.15.6-7.1 -
python-pyqt5-sip4-compat 5.15.6-1 -
qqc2-breeze-style 5.25.0-1 5.25.2-1
qt5-es2-base 5.15.4+kde+r168-1 5.15.5+kde+r163-1
qt5-es2-declarative 5.15.4+kde+r19-1 5.15.5+kde+r19-1
qt5-es2-multimedia 5.15.4+kde+r1-1 5.15.5+kde+r1-1
qt5-es2-wayland 5.15.4+kde+r38-1 5.15.5+kde+r38-1
qt5-es2-xcb-private-headers 5.15.4+kde+r168-1 5.15.5+kde+r163-1
gnome-console -42.beta+66+g8991a6c-2
js91 - 91.10.0-1
:: Different sync package(s) in repository extra aarch64
akonadi 22.04.2-2 22.04.2-3
bluedevil 1:5.25.0-1 1:5.25.2-1
breeze 5.25.0-1 5.25.2-1
breeze-grub 5.25.0-1 5.25.2-1
breeze-gtk 5.25.0-1 5.25.2-1
bullet 3.24-1 3.24-2
bullet-docs 3.24-1 3.24-2
chromium 102.0.5005.115-1 103.0.5060.53-1
digikam 7.6.0-5 7.7.0-1
discover 5.25.0-1 5.25.2-1
drkonqi 5.25.0-1 5.25.2-1
firefox 101.0-1 102.0-1
firefox-i18n-ach 101.0.1-1 102.0-1
firefox-i18n-af 101.0.1-1 102.0-1
firefox-i18n-an 101.0.1-1 102.0-1
firefox-i18n-ar 101.0.1-1 102.0-1
firefox-i18n-ast 101.0.1-1 102.0-1
firefox-i18n-az 101.0.1-1 102.0-1
firefox-i18n-be 101.0.1-1 102.0-1
firefox-i18n-bg 101.0.1-1 102.0-1
firefox-i18n-bn 101.0.1-1 102.0-1
firefox-i18n-br 101.0.1-1 102.0-1
firefox-i18n-bs 101.0.1-1 102.0-1
firefox-i18n-ca 101.0.1-1 102.0-1
firefox-i18n-ca-valencia 101.0.1-1 102.0-1
firefox-i18n-cak 101.0.1-1 102.0-1
firefox-i18n-cs 101.0.1-1 102.0-1
firefox-i18n-cy 101.0.1-1 102.0-1
firefox-i18n-da 101.0.1-1 102.0-1
firefox-i18n-de 101.0.1-1 102.0-1
firefox-i18n-dsb 101.0.1-1 102.0-1
firefox-i18n-el 101.0.1-1 102.0-1
firefox-i18n-en-ca 101.0.1-1 102.0-1
firefox-i18n-en-gb 101.0.1-1 102.0-1
firefox-i18n-en-us 101.0.1-1 102.0-1
firefox-i18n-eo 101.0.1-1 102.0-1
firefox-i18n-es-ar 101.0.1-1 102.0-1
firefox-i18n-es-cl 101.0.1-1 102.0-1
firefox-i18n-es-es 101.0.1-1 102.0-1
firefox-i18n-es-mx 101.0.1-1 102.0-1
firefox-i18n-et 101.0.1-1 102.0-1
firefox-i18n-eu 101.0.1-1 102.0-1
firefox-i18n-fa 101.0.1-1 102.0-1
firefox-i18n-ff 101.0.1-1 102.0-1
firefox-i18n-fi 101.0.1-1 102.0-1
firefox-i18n-fr 101.0.1-1 102.0-1
firefox-i18n-fy-nl 101.0.1-1 102.0-1
firefox-i18n-ga-ie 101.0.1-1 102.0-1
firefox-i18n-gd 101.0.1-1 102.0-1
firefox-i18n-gl 101.0.1-1 102.0-1
firefox-i18n-gn 101.0.1-1 102.0-1
firefox-i18n-gu-in 101.0.1-1 102.0-1
firefox-i18n-he 101.0.1-1 102.0-1
firefox-i18n-hi-in 101.0.1-1 102.0-1
firefox-i18n-hr 101.0.1-1 102.0-1
firefox-i18n-hsb 101.0.1-1 102.0-1
firefox-i18n-hu 101.0.1-1 102.0-1
firefox-i18n-hy-am 101.0.1-1 102.0-1
firefox-i18n-ia 101.0.1-1 102.0-1
firefox-i18n-id 101.0.1-1 102.0-1
firefox-i18n-is 101.0.1-1 102.0-1
firefox-i18n-it 101.0.1-1 102.0-1
firefox-i18n-ja 101.0.1-1 102.0-1
firefox-i18n-ka 101.0.1-1 102.0-1
firefox-i18n-kab 101.0.1-1 102.0-1
firefox-i18n-kk 101.0.1-1 102.0-1
firefox-i18n-km 101.0.1-1 102.0-1
firefox-i18n-kn 101.0.1-1 102.0-1
firefox-i18n-ko 101.0.1-1 102.0-1
firefox-i18n-lij 101.0.1-1 102.0-1
firefox-i18n-lt 101.0.1-1 102.0-1
firefox-i18n-lv 101.0.1-1 102.0-1
firefox-i18n-mk 101.0.1-1 102.0-1
firefox-i18n-mr 101.0.1-1 102.0-1
firefox-i18n-ms 101.0.1-1 102.0-1
firefox-i18n-my 101.0.1-1 102.0-1
firefox-i18n-nb-no 101.0.1-1 102.0-1
firefox-i18n-ne-np 101.0.1-1 102.0-1
firefox-i18n-nl 101.0.1-1 102.0-1
firefox-i18n-nn-no 101.0.1-1 102.0-1
firefox-i18n-oc 101.0.1-1 102.0-1
firefox-i18n-pa-in 101.0.1-1 102.0-1
firefox-i18n-pl 101.0.1-1 102.0-1
firefox-i18n-pt-br 101.0.1-1 102.0-1
firefox-i18n-pt-pt 101.0.1-1 102.0-1
firefox-i18n-rm 101.0.1-1 102.0-1
firefox-i18n-ro 101.0.1-1 102.0-1
firefox-i18n-ru 101.0.1-1 102.0-1
firefox-i18n-sco 101.0.1-1 102.0-1
firefox-i18n-si 101.0.1-1 102.0-1
firefox-i18n-sk 101.0.1-1 102.0-1
firefox-i18n-sl 101.0.1-1 102.0-1
firefox-i18n-son 101.0.1-1 102.0-1
firefox-i18n-sq 101.0.1-1 102.0-1
firefox-i18n-sr 101.0.1-1 102.0-1
firefox-i18n-sv-se 101.0.1-1 102.0-1
firefox-i18n-szl 101.0.1-1 102.0-1
firefox-i18n-ta 101.0.1-1 102.0-1
firefox-i18n-te 101.0.1-1 102.0-1
firefox-i18n-th 101.0.1-1 102.0-1
firefox-i18n-tl 101.0.1-1 102.0-1
firefox-i18n-tr 101.0.1-1 102.0-1
firefox-i18n-trs 101.0.1-1 102.0-1
firefox-i18n-uk 101.0.1-1 102.0-1
firefox-i18n-ur 101.0.1-1 102.0-1
firefox-i18n-uz 101.0.1-1 102.0-1
firefox-i18n-vi 101.0.1-1 102.0-1
firefox-i18n-xh 101.0.1-1 102.0-1
firefox-i18n-zh-cn 101.0.1-1 102.0-1
firefox-i18n-zh-tw 101.0.1-1 102.0-1
geoip-database 20220524-1 20220621-1
geoip-database-extra 20220524-1 20220621-1
git 2.36.1-1 2.37.0-1
glib-networking 1:2.72.0-1 1:2.72.1-1
gst-editing-services 1.20.2-2 1.20.3-1
gst-libav 1.20.2-2 1.20.3-1
gst-plugin-gtk 1.20.2-2 1.20.3-1
gst-plugin-opencv 1.20.2-2 1.20.3-1
gst-plugin-qmlgl 1.20.2-2 1.20.3-1
gst-plugin-va 1.20.2-2 1.20.3-1
gst-plugin-wpe 1.20.2-2 1.20.3-1
gst-plugins-bad 1.20.2-2 1.20.3-1
gst-plugins-bad-libs 1.20.2-2 1.20.3-1
gst-plugins-base 1.20.2-2 1.20.3-1
gst-plugins-base-libs 1.20.2-2 1.20.3-1
gst-plugins-good 1.20.2-2 1.20.3-1
gst-plugins-ugly 1.20.2-2 1.20.3-1
gst-python 1.20.2-2 1.20.3-1
gst-rtsp-server 1.20.2-2 1.20.3-1
gstreamer 1.20.2-2 1.20.3-1
gstreamer-docs 1.20.2-2 1.20.3-1
gstreamer-vaapi 1.20.2-2 1.20.3-1
gvim 8.2.5046-2 9.0.0000-1
gyp 20190716.fcd686f1-7 20220404.9ecf45e3-1
harfbuzz 4.3.0-1 4.4.1-1
harfbuzz-icu 4.3.0-1 4.4.1-1
hplip 1:3.22.4-2 1:3.22.6-1
imagemagick 7.1.0.38-1 7.1.0.39-1
imagemagick-doc 7.1.0.38-1 7.1.0.39-1
java-commons-daemon 1.2.4-2 1.3.1-1
java-jsvc 1.2.4-2 1.3.1-1
js91 91.10.0-1 91.11.0-1
kactivitymanagerd 5.25.0-1 5.25.2-1
kde-cli-tools 5.25.0-1 5.25.2-1
kde-gtk-config 5.25.0-1 5.25.2-1
kdecoration 5.25.0-1 5.25.2-1
kdeplasma-addons 5.25.0-1 5.25.2-1
kdiff3 1.9.5-1 1.9.6-1
kgamma5 5.25.0-1 5.25.2-1
khealthcertificate 22.04-1 22.06-1
khotkeys 5.25.0-1 5.25.2-1
kinfocenter 5.25.0-1 5.25.2-1
kmenuedit 5.25.0-1 5.25.2-1
kscreen 5.25.0-1 5.25.2-1
kscreenlocker 5.25.0-1 5.25.2-1
ksshaskpass 5.25.0-1 5.25.2-1
ksystemstats 5.25.0-1 5.25.2-1
kwallet-pam 5.25.0-1 5.25.2-1
kwayland-integration 5.25.0-1 5.25.2-1
kwin 5.25.0-1 5.25.2-1
kwrited 5.25.0-1 5.25.2-1
layer-shell-qt 5.25.0-1 5.25.2-1
libakonadi 22.04.2-2 22.04.2-3
libblockdev 2.26-3 2.27-1
libidn 1.38-1 1.41-1
libkscreen 5.25.0-1 5.25.2-1
libksysguard 5.25.0-1 5.25.2-1
libmm-glib 1.18.8-1 1.18.10-1
libmp4v2 5.0.1-1 1:2.1.1-1
libmtp 1.1.19-1 1.1.19-2
libproxy 0.4.17-7 0.4.18-1
libproxy-webkit 0.4.17-7 0.4.18-1
libpulse 16.0-1 16.1-1
libqmi 1.30.6-1 1.30.8-1
liburing 2.1-1 2.2-1
libva-mesa-driver 22.1.1-2 22.1.2-1
libvpx 1.11.0-2 1.12.0-1
libwacom 2.2.0-1 2.3.0-1
mesa 22.1.1-2 22.1.2-1
mesa-vdpau 22.1.1-2 22.1.2-1
milou 5.25.0-1 5.25.2-1
mkvtoolnix-cli 67.0.0-2 68.0.0-1
mkvtoolnix-gui 67.0.0-2 68.0.0-1
mlt 7.6.0-2 7.8.0-1
modemmanager 1.18.8-1 1.18.10-1
noto-fonts 20220502-3 20220607-1
noto-fonts-extra 20220502-3 20220607-1
openal 1.22.0-1 1.22.2-1
openal-examples 1.22.0-1 1.22.2-1
opencl-mesa 22.1.1-2 22.1.2-1
openconnect 1:9.01-1 1:9.01-2
oxygen 5.25.0-1 5.25.2-1
oxygen-sounds 5.25.0-1 5.25.2-1
perl-lwp-protocol-https 6.10-3 6.10-4
perl-mozilla-ca 20200520-5 20211001-1
plasma-browser-integration 5.25.0-1 5.25.2-1
plasma-desktop 5.25.0-1 5.25.2-1
plasma-disks 5.25.0-1 5.25.2-1
plasma-firewall 5.25.0-1 5.25.2-1
plasma-integration 5.25.0-1 5.25.2-1
plasma-nm 5.25.0-1 5.25.2-1
plasma-pa 5.25.0-1 5.25.2-1
plasma-sdk 5.25.0-1 5.25.2-1
plasma-systemmonitor 5.25.0-1 5.25.2-1
plasma-thunderbolt 5.25.0-1 5.25.2-1
plasma-vault 5.25.0-1 5.25.2-1
plasma-wayland-session 5.25.0-1 5.25.2-1
plasma-workspace 5.25.0-1 5.25.2-1
plasma-workspace-wallpapers 5.25.0-1 5.25.2-1
polkit-kde-agent 5.25.0-1 5.25.2-1
power-profiles-daemon 0.11.1-1 0.12-1
powerdevil 5.25.0-2 5.25.2-1
prometheus 2.36.1-1 2.36.2-1
prometheus-blackbox-exporter 0.21.0-1 0.21.1-1
pulseaudio 16.0-1 16.1-1
pulseaudio-bluetooth 16.0-1 16.1-1
pulseaudio-equalizer 16.0-1 16.1-1
pulseaudio-jack 16.0-1 16.1-1
pulseaudio-lirc 16.0-1 16.1-1
pulseaudio-rtp 16.0-1 16.1-1
pulseaudio-zeroconf 16.0-1 16.1-1
pyside2 5.15.4-1 5.15.5-1
pyside2-tools 5.15.4-1 5.15.5-1
python-asgiref 3.5.1-1 3.5.2-1
python-csv23 0.3.3-1 0.3.4-1
python-lxml 4.8.0-1 4.9.0-1
python-lxml-docs 4.8.0-1 4.9.0-1
python-pip 21.0-1 22.1.2-1
python-pybullet 3.24-1 3.24-2
python-resolvelib 0.5.5-4 0.8.1-1
python-shiboken2 5.15.4-1 5.15.5-1
python-trove-classifiers 2022.5.19-1 2022.6.26-1
qt5-3d 5.15.4+kde+r17-1 5.15.5+kde+r15-1
qt5-base 5.15.4+kde+r168-1 5.15.5+kde+r166-1
qt5-charts 5.15.4+kde+r0-1 5.15.5+kde+r1-1
qt5-connectivity 5.15.4+kde+r5-1 5.15.5+kde+r5-1
qt5-datavis3d 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-declarative 5.15.4+kde+r19-1 5.15.5+kde+r19-1
qt5-doc 5.15.4-1 5.15.5-1
qt5-examples 5.15.4-1 5.15.5-1
qt5-gamepad 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-graphicaleffects 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-imageformats 5.15.4+kde+r2-1 5.15.5+kde+r3-1
qt5-location 5.15.4+kde+r2-1 5.15.5+kde+r3-1
qt5-lottie 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-mqtt 5.15.2-4 5.15.2-5
qt5-multimedia 5.15.4+kde+r1-1 5.15.5+kde+r1-1
qt5-networkauth 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-purchasing 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-quick3d 5.15.4+kde+r2-1 5.15.5+kde+r1-1
qt5-quickcontrols 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-quickcontrols2 5.15.4+kde+r4-1 5.15.5+kde+r5-1
qt5-quicktimeline 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-remoteobjects 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-script 5.15.10-1 5.15.10-2
qt5-scxml 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-sensors 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-serialbus 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-serialport 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-speech 5.15.4+kde+r1-1 5.15.5+kde+r1-1
qt5-svg 5.15.4+kde+r10-1 5.15.5+kde+r10-1
qt5-tools 5.15.4+kde+r1-1 5.15.5+kde+r1-1
qt5-translations 5.15.4+kde+r2-1 5.15.5+kde+r2-1
qt5-virtualkeyboard 5.15.4+kde+r3-1 5.15.5+kde+r3-1
qt5-wayland 5.15.4+kde+r38-1 5.15.5+kde+r38-1
qt5-webchannel 5.15.4+kde+r3-1 5.15.5+kde+r3-1
qt5-webengine 5.15.10-1 5.15.10-2
qt5-webglplugin 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-webkit 5.212.0alpha4-14 5.212.0alpha4-15
qt5-websockets 5.15.4+kde+r3-1 5.15.5+kde+r3-1
qt5-webview 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-x11extras 5.15.4+kde+r0-1 5.15.5+kde+r0-1
qt5-xcb-private-headers 5.15.4+kde+r168-1 5.15.5+kde+r166-1
qt5-xmlpatterns 5.15.4+kde+r0-1 5.15.5+kde+r0-1
sbcl 2.2.4-1 2.2.5-1
sddm-kcm 5.25.0-1 5.25.2-1
sof-firmware 2.1.1-1 2.1.1.a-1
sof-tools 2.1.1-1 2.1.1.a-1
speex 1.2.0-3 1.2.1-1
speexdsp 1.2.0-2.1 1.2.1-1
squashfuse 0.1.104-2 0.1.105-1
strace 5.17-1 5.18-1
syslog-ng 3.36.1-1 3.37.1-1
systemsettings 5.25.0-1 5.25.2-1
telepathy-kde-common-internals 22.04.2-1 22.04.2-2
tomcat-native 1.2.32-1 1.2.34-1
tomcat10 10.0.20-2 10.0.22-1
tomcat8 8.5.78-2 8.5.81-1
tomcat9 9.0.62-2 9.0.64-1
ttf-croscore 20220502-3 20220607-1
vim-runtime 8.2.5046-2 9.0.0000-1
vlc 3.0.17.4-5 3.0.17.4-6
vulkan-broadcom 22.1.1-2 22.1.2-1
vulkan-mesa-layers 22.1.1-2 22.1.2-1
vulkan-panfrost 22.1.1-2 22.1.2-1
vulkan-radeon 22.1.1-2 22.1.2-1
vulkan-swrast 22.1.1-2 22.1.2-1
xdg-desktop-portal-kde 5.25.0-1 5.25.2-1
xf86-video-vesa 2.5.0-2 2.5.0-3
bullet-dp - 3.24-2
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.04.2.r12775.g23b4f0f3a-122.04.2.r12781.gcfc1a5a24-1
akonadi-calendar22.04.2.r2128.g13425fd-122.04.2.r2130.g24f3853-1
akonadi-calendar-tools22.04.2.r953.g7b2d882-122.04.2.r954.ge03fb1e-1
akonadi-contacts22.04.2.r3192.g0c241dd0-122.04.2.r3218.g2b8bb1a6-1
akonadi-import-wizard22.04.2.r1833.g9a6d052-122.04.2.r1834.g6f3672c-1
akonadi-mime22.04.2.r1737.gda65f9f-122.04.2.r1739.g68cf99f-1
akonadi-notes22.04.2.r1076.gf431a80-122.04.2.r1077.g4554f42-1
akonadi-search22.04.2.r1238.g2ce4fa0-122.04.2.r1240.g0235a27-1
akonadiconsole22.04.2.r1593.g5c3c2c6-122.04.2.r1594.g80dd1f5-1
akregator22.04.2.r6435.g9c5aca0f-122.04.2.r6437.g04ada5e5-1
alligator 22.04.r26.gda4cced-1 22.06.r3.gb505ed1-1
analitza22.04.2.r2340.ge77e2099-122.04.2.r2341.gd22ca62d-1
angelfish 22.04.r35.g05f548c-1 22.06.r2.gf31c383-1
ark22.04.2.r4781.g0eea2195-122.04.2.r4784.gdc5d8501-1
attica5.95.0.r873.g3e2a430-15.95.0.r874.g197c295-1
audiocd-kio22.04.2.r1067.g27e5dab-122.04.2.r1068.gff54fa8-1
audiotube 22.04.r54.g923ae5f-1 22.06.r3.gf12c4e3-1
baloo5.95.0.r3056.g77640514-15.95.0.r3057.g1803a661-1
bluedevil1:5.25.0.r2409.g1cd23983-11:5.25.2.r2412.gc2908658-1
bluez-qt5.95.0.r712.g8a55d40-15.95.0.r713.g0bd628e-1
bomber22.04.2.r566.gb3e8fa1-122.04.2.r567.g5e9d06e-1
breeze5.25.0.r2415.g54ffea94-15.25.2.r2425.ge85efaab-1
breeze-grub5.25.0.r11.g63136a9-15.25.2.r11.g63136a9-1
breeze-gtk5.25.0.r485.gf5c1363-15.25.2.r485.gf5c1363-1
buho 2.1.2.r3.g68a7a0a-1 2.1.2.r5.g7c140d0-1
calendarsupport22.04.2.r710.gc00699c-122.04.2.r712.g05c0720-1
calindori 22.04.r30.g4ec2be8-1 22.06.r3.gc7efaa2-1
discover5.25.0.r8704.g17580b1d-15.25.2.r8721.g4daabe64-1
disman5.24.5.r1841.g11bd631-15.25.0.r1844.g9f33299-1
dolphin22.04.2.r7017.g5ebf2065d-122.04.2.r7024.gdc3d153bb-1
dolphin-plugins22.04.2.r663.g1b416e7-122.04.2.r664.g01536e1-1
dragon22.04.2.r1044.gd3d59ff-122.04.2.r1045.g32d9cd4-1
drkonqi5.25.0.r794.gb83a59ef-15.25.2.r796.g7f32dac3-1
elisa22.04.2.r2981.g1c55dcef-122.04.2.r2988.gaf7dc83e-1
elisa-qtmm22.04.2.r2981.g1c55dcef-122.04.2.r2988.gaf7dc83e-1
eventviews22.04.2.r850.g561d2c5-122.04.2.r851.g5db0c7b-1
extra-cmake-modules5.95.0.r3503.g8687d6cb-15.95.0.r3504.g0064cf77-1
filelight22.04.2.r1138.g861afa5-122.04.2.r1140.g8083f26-1
frameworkintegration5.95.0.r640.g02f7b32-15.95.0.r642.gc27427f-1
granatier22.04.2.r979.gd9376be-122.04.2.r980.gca7fa04-1
grantlee-editor22.04.2.r824.g468ddaa-122.04.2.r825.g59b3f70-1
grantleetheme22.04.2.r402.gcc63045-122.04.2.r403.gceb2c55-1
gwenview22.04.2.r6862.g3e9e5275-122.04.2.r6863.gde2e003d-1
incidenceeditor22.04.2.r903.g4b971fd-122.04.2.r906.g81cd689-1
index-fm 2.1.2.r31.gc247492-1 2.1.2.r34.ga0e0b5d-1
itinerary22.04.2.r1914.g111454b-122.04.2.r1920.ge27ef28-1
juk22.04.2.r3156.g60597b74-122.04.2.r3158.g43272041-1
k3b1:22.04.2.r6794.g155f4173c-11:22.04.2.r6796.ga446d1ae5-1
kaccounts-integration22.04.2.r1260.g722c934-122.04.2.r1261.gf26f043-1
kactivitymanagerd5.25.0.r1404.g4800f70-15.25.2.r1408.g1297cd1-1
kaddressbook22.04.2.r6206.gc15b1318-122.04.2.r6210.g173cf909-1
kalarm22.04.2.r7931.g2c303202-122.04.2.r7933.g30b536b7-1
kalk 22.04.r17.gfc0dd78-1 22.06.r4.g6c08c76-1
kalzium22.04.2.r4362.g57bfa9b3-122.04.2.r4364.g96cd1d22-1
kamera22.04.2.r722.g0fc71b5-122.04.2.r724.gf7b79dd-1
kapman22.04.2.r659.ga953ecc-122.04.2.r660.gdda3bea-1
kasts 22.04.r59.g5d8c81c-1 22.06.r4.gac58ad0-1
kate22.04.2.r19129.ge34792b1b-122.04.2.r19179.ga69004b4b-1
katomic22.04.2.r964.gce5209d-122.04.2.r965.g84570d0-1
kauth5.95.0.r500.g45e4859-15.95.0.r501.g8c7194a-1
kbackup22.04.2.r444.gd21d341-122.04.2.r445.gbb05f7e-1
kblackbox22.04.2.r767.gaf07c9e-122.04.2.r768.g62af1c7-1
kblocks22.04.2.r730.g6684de9-122.04.2.r731.gc8cd0a0-1
kbounce22.04.2.r851.g1455a9e-122.04.2.r852.gcd19c1e-1
kbreakout22.04.2.r925.gd560231-122.04.2.r926.gadc9efb-1
kcalc22.04.2.r1615.g029c5b8-122.04.2.r1616.g51c3e94-1
kcalendarcore5.95.0.r1327.ge511aa0e8-15.95.0.r1330.g5b03ae2bd-1
kcalutils22.04.2.r967.g2f2f818f0-122.04.2.r969.g0aca3fd6d-1
kcharselect22.04.2.r532.g7788372-122.04.2.r533.g1c65036-1
kclock 22.04.r30.ge70bbca-1 22.06.r3.g52ebe91-1
kcmutils5.95.0.r643.g1a295da-15.95.0.r644.ga5e6f13-1
kcodecs5.95.0.r423.g9c370d3-15.95.0.r424.g6292a25-1
kcompletion5.95.0.r495.geac2729-15.95.0.r496.gc856ff1-1
kconfig5.95.0.r960.ga83e1f50-15.95.0.r961.g5ce3f9eb-1
kconfigwidgets5.95.0.r745.g16b8a55-15.95.0.r746.g95d9d09-1
kcontacts1:5.95.0.r3336.g9abe56ee-11:5.95.0.r3337.g4bb5e72d-1
kcoreaddons5.95.0.r1508.g35fb5966-15.95.0.r1510.g4e944878-1
kcron22.04.2.r845.g73f6e5b-122.04.2.r846.g3b76467-1
kdav1:5.95.0.r1344.g007a2b6-11:5.95.0.r1345.gb7c68d4-1
kdbusaddons5.95.0.r417.g991b736-15.95.0.r418.g048fcbe-1
kde-cli-tools5.25.0.r1941.g81bc9a7-15.25.2.r1944.g1993048-1
kde-dev-scripts22.04.2.r4146.g04f44a1-122.04.2.r4147.g60726b0-1
kde-dev-utils22.04.2.r590.ge8897f8-122.04.2.r591.gab48b72-1
kde-gtk-config5.25.0.r935.g1c13481-15.25.2.r937.gfdf1446-1
kdebugsettings22.04.2.r926.ga6d383b-122.04.2.r928.gbae60ee-1
kdeclarative5.95.0.r1009.g79ca235-15.95.0.r1014.g4455212-1
kdeconnect22.04.2.r3466.gfc1efc3e-122.04.2.r3474.g19d0b8f4-1
kdecoration5.25.0.r290.gde4e9d4-15.25.2.r295.g5df2f5b-1
kded5.95.0.r463.gbfa7d31-15.95.0.r465.g393b75f-1
kdegraphics-mobipocket22.04.2.r273.g416f47e-122.04.2.r274.gc9f5c9f-1
kdegraphics-thumbnailers22.04.2.r272.g3f44b67-122.04.2.r273.ga5019a6-1
kdelibs4support5.95.0.r1092.g56ac36d6-15.95.0.r1094.gbb588fe9-1
kdenetwork-filesharing22.04.2.r956.g70826c9-122.04.2.r958.g0a99319-1
kdenlive22.04.2.r16280.g352f532d2-122.04.2.r16314.gb89e89ceb-1
kdepim-addons22.04.2.r4678.g6bb95fb05-122.04.2.r4681.g3b7013202-1
kdepim-runtime22.04.2.r15550.g49bac12ea-122.04.2.r15552.g6409422a4-1
kdeplasma-addons5.25.0.r8897.gcae7962a1-15.25.2.r8911.gc92c8deee-1
kdesignerplugin5.95.0.r355.gd7683e7-15.95.0.r356.g3302d04-1
kdesu5.95.0.r508.ge288ba9-15.95.0.r510.g7a00d15-1
kdf22.04.2.r858.g8b9c16c-122.04.2.r860.g7b05477-1
kdialog22.04.2.r1228.g1032b256c-122.04.2.r1229.g96dc0ae5b-1
kdiamond22.04.2.r728.g75b350a-122.04.2.r729.g9b166eb-1
kdisplay5.24.5.r1513.g21100f4-15.25.0.r1516.g4617e62-1
kdnssd5.95.0.r351.g10435ce-15.95.0.r353.g1d281be-1
kdoctools5.95.0.r662.gc73e13e-15.95.0.r669.g5bdc9f9-1
kemoticons5.95.0.r418.g6a34588-15.95.0.r419.g177ec00-1
keysmith 22.04.r17.ge65e075-1 22.06.r2.g7333384-1
kfilemetadata5.95.0.r863.g62b72c7-15.95.0.r864.g46d9a1f-1
kfind22.04.2.r2698.g3aec9b6e5-122.04.2.r2700.g4861044f7-1
kgamma55.25.0.r479.g2e745b2-15.25.2.r481.g5d1c771-1
kgeography22.04.2.r1158.g2855b54-122.04.2.r1159.g134210d-1
kglobalaccel5.95.0.r526.gcc8d1be-15.95.0.r527.g00c90e1-1
kgoldrunner22.04.2.r1286.g90b56da-122.04.2.r1288.g9483df7-1
kgpg22.04.2.r3191.g5d3c044b-122.04.2.r3194.g7b9f0a58-1
kguiaddons5.95.0.r473.g37bab8b-15.95.0.r478.g38b5679-1
khealthcertificate 22.04.r7.gd34cbfe-1 22.06.r0.gd34cbfe-1
kholidays1:5.95.0.r1039.g16ae9fe-11:5.95.0.r1041.g1ccd78b-1
khotkeys5.25.0.r2142.ga4c9785-15.25.2.r2146.gbee2224-1
ki18n5.95.0.r558.gd8314ee-15.95.0.r560.gccf7752-1
kiconthemes5.95.0.r603.g7b3288f-15.95.0.r604.g5450fef-1
kidentitymanagement22.04.2.r3890.gbccaf0ed-122.04.2.r3891.gbbc310f5-1
kidletime5.95.0.r357.g092bc38-15.95.0.r359.g603752c-1
kigo22.04.2.r572.g4d98c05-122.04.2.r574.g7157b7b-1
killbots22.04.2.r794.geb181b1-122.04.2.r795.g4a2ceae-1
kimageformats5.95.0.r404.g2aec1d3-15.95.0.r409.g6cd0056-1
kimap22.04.2.r1195.g80ae9b4-122.04.2.r1197.g58f55fc-1
kinfocenter5.25.0.r2099.g65f3051c-15.25.2.r2104.gb723659d-1
kinit5.95.0.r438.g3531c4b-15.95.0.r441.g043b301-1
kio5.95.0.r5509.g6aa4db75d-15.95.0.r5519.gda65b36c7-1
kio-extras22.04.2.r7265.g3f861f63-122.04.2.r7271.gbfb13d4b-1
kio-gdrive22.04.2.r613.ga698d46-122.04.2.r615.gdf30b05-1
kirigami-addons 1:0.2.r32.g917a0fa-1 1:0.3.r0.g917a0fa-1
kirigami-gallery22.04.2.r242.g389a897-122.04.2.r246.g8b2015b-1
kirigami25.95.0.r3156.g73d4c0c3-15.95.0.r3165.gdd0bdd78-1
kiriki22.04.2.r453.gb3e0308-122.04.2.r454.gd5a2372-1
kitemmodels5.95.0.r608.g00f2db8-15.95.0.r611.ga5a4a50-1
kitemviews5.95.0.r373.g8213c87-15.95.0.r375.g85ad995-1
kitinerary22.04.2.r2254.g1ae9d49-122.04.2.r2278.ga296a2f-1
kjobwidgets5.95.0.r416.gb636904-15.95.0.r418.g0e2a51a-1
kjsembed5.95.0.r327.g5c51bcf-15.95.0.r329.g1f95849-1
kjumpingcube22.04.2.r826.gec3cd36-122.04.2.r827.gc7c5691-1
kldap22.04.2.r952.ge0d6f23-122.04.2.r953.g65608b9-1
kleopatra22.04.2.r6576.ga0459257-122.04.2.r6603.g75fdc663-1
klettres22.04.2.r965.g1c2e818-122.04.2.r966.g01c6515-1
klickety22.04.2.r676.g3e4a46c-122.04.2.r677.g7b5c9f2-1
klines22.04.2.r819.gdfa6689-122.04.2.r821.gb160952-1
kmahjongg22.04.2.r1551.gf6c525e-122.04.2.r1554.ga90f494-1
kmail22.04.2.r26416.g1d3fb518a-122.04.2.r26432.gedfa4fa9f-1
kmail-account-wizard22.04.2.r887.g826f9dd-122.04.2.r888.gf9a0363-1
kmailtransport22.04.2.r1745.g6e08863-122.04.2.r1746.gd0cdf03-1
kmbox22.04.2.r599.g62b4fa7-122.04.2.r600.g9b19f74-1
kmediaplayer5.95.0.r318.g560b0af-15.95.0.r319.g9b02622-1
kmenuedit5.25.0.r1042.g3d3785e-15.25.2.r1047.g18535fc-1
kmime22.04.2.r1518.ga183dcc-122.04.2.r1519.gbff6f93-1
kmines22.04.2.r1766.g794f6e4-122.04.2.r1768.g6810451-1
knavalbattle22.04.2.r1433.g11fcde0-122.04.2.r1435.gac7a67a-1
knetwalk22.04.2.r701.g73f7fd6-122.04.2.r704.g71ebbff-1
knewstuff5.95.0.r1355.g70ef3713-15.95.0.r1358.g5278e9be-1
knights22.04.2.r1144.ge36f2e2-122.04.2.r1149.gd639e69-1
knotes22.04.2.r3670.g9e3b836c-122.04.2.r3673.g05ba2ef7-1
knotifications5.95.0.r744.gfe5476c-15.95.0.r746.gd908a73-1
knotifyconfig5.95.0.r384.gb1ad8bb-15.95.0.r386.g2ca383e-1
koko 22.04.r29.g3b0e186-1 22.06.r2.g0c434e9-1
kolf22.04.2.r1506.g4122e82-122.04.2.r1510.gb1d3bfc-1
kollision22.04.2.r537.g882ff91-122.04.2.r538.g223fc54-1
kolourpaint22.04.2.r2413.ge0c9f0c4-122.04.2.r2414.g511c737b-1
kompare22.04.2.r1142.gc31d802-122.04.2.r1143.g00cb002-1
kongress 22.04.r19.gf965e46-1 22.06.r2.g75d32b1-1
konqueror22.04.2.r15121.g111ebc5a1-122.04.2.r15123.gc1559a3da-1
konquest22.04.2.r934.g8d790dc-122.04.2.r935.g6f619b8-1
konsole22.04.2.r8477.g4276bd33-122.04.2.r8491.ga24ab084-1
kontact22.04.2.r5538.g35dfc0d4-122.04.2.r5543.g6d0fa206-1
kontactinterface22.04.2.r695.g55c27c1-122.04.2.r697.ge3e11cd-1
konversation22.04.2.r9120.ge7d3b8f8-122.04.2.r9126.g20426948-1
kopeninghours22.04.2.r331.g9676833-122.04.2.r332.g37dacc1-1
kopete22.04.2.r16441.g73ae620b4-122.04.2.r16444.gae623c90d-1
korganizer22.04.2.r11723.g092799b0e-122.04.2.r11751.g7ef0598d6-1
kosmindoormap22.04.2.r736.g3e20e18-122.04.2.r739.gcb63fd2-1
kpackage5.95.0.r752.g3fa2476-15.95.0.r753.g8ada44b-1
kparts5.95.0.r587.ga563fe5-15.95.0.r589.g86b6137-1
kpat22.04.2.r2619.g22b77e05-122.04.2.r2622.g1ca733ee-1
kpeople5.95.0.r1376.g07e1a84-15.95.0.r1378.g10a44f2-1
kpimtextedit22.04.2.r1597.g08daf8b-122.04.2.r1598.gf030726-1
kpipewire5.25.0.r110.gf5dd13a-15.25.2.r132.ga5079d8-1
kpkpass22.04.2.r298.g76e2810-122.04.2.r299.g95a9ecf-1
kplotting5.95.0.r324.g0fa36e5-15.95.0.r326.g38e8631-1
kpmcore22.04.2.r1287.g83a8654-122.04.2.r1290.g0ad245f-1
kpty5.95.0.r375.g5d745ae-15.95.0.r377.g38f9344-1
kpublictransport22.04.2.r2022.g61f73bd9-122.04.2.r2023.gd4b7fdfb-1
kqtquickcharts22.04.2.r75.g188b79d-122.04.2.r76.gf1d32c3-1
krdc22.04.2.r1599.g322ed80-122.04.2.r1601.gc5e182f-1
krecorder 22.04.r25.gbb8eaa3-1 22.06.r2.gf06447d-1
kreversi22.04.2.r1272.gb7ccf09-122.04.2.r1273.g3eff2f6-1
krfb22.04.2.r1497.g4433609-122.04.2.r1501.g720478a-1
kross5.95.0.r359.gd3baa4f-15.95.0.r360.g00e924b-1
kruler22.04.2.r735.g9fc56a2-122.04.2.r737.ga482c4b-1
krunner5.95.0.r768.gb27fa82-15.95.0.r771.g487dd0c-1
kscreen5.25.0.r1475.g3387ca5-15.25.2.r1478.gf730b96-1
kscreenlocker5.25.0.r955.g71c1cde-15.25.2.r964.gc313db7-1
kservice5.95.0.r1017.g5db9c1d-15.95.0.r1019.gefa53cf-1
kshisen22.04.2.r1246.g51c42a2-122.04.2.r1248.g94615c4-1
ksirk22.04.2.r1030.gc2fff2b-122.04.2.r1034.ga599a82-1
ksmtp22.04.2.r449.gf6086e4-122.04.2.r450.g7264754-1
ksnakeduel22.04.2.r854.ge10193f-122.04.2.r857.g8bc8c68-1
kspaceduel22.04.2.r674.g262e5a0-122.04.2.r677.g92431af-1
ksquares22.04.2.r560.g78306b6-122.04.2.r563.gd531158-1
ksshaskpass5.25.0.r210.gcd5e9f9-15.25.2.r212.gd1bef1b-1
ksudoku22.04.2.r1117.g324aa5e-122.04.2.r1120.gd56c605-1
ksysguard5.25.0.r3533.gcb52be2f-15.25.2.r3534.gd30385c7-1
ksystemlog22.04.2.r734.gfe661b5-122.04.2.r735.g2bb9981-1
ksystemstats5.25.0.r229.g2b5c815-15.25.2.r231.g442ec4f-1
ktexteditor5.95.0.r3421.g83e90c5e-15.95.0.r3426.gade54508-1
ktextwidgets5.95.0.r448.g5cab5e6-15.95.0.r449.g7ce6a33-1
ktimer22.04.2.r518.gedc32ed-122.04.2.r520.g419ed68-1
ktnef22.04.2.r719.g4832e5d-122.04.2.r720.gca64fcd-1
ktorrent22.04.2.r2863.g6149f01c-122.04.2.r2865.g2f4923d7-1
ktrip 22.04.r14.g77205a6-1 22.06.r4.g81cacb3-1
ktuberling22.04.2.r1043.g2499bca-122.04.2.r1046.g1f31242-1
kturtle22.04.2.r1173.g7fd5c38-122.04.2.r1176.g379b8db-1
kunitconversion5.95.0.r419.g8192623-15.95.0.r420.g724aa0d-1
kwallet5.95.0.r1152.g1f9ddb3-15.95.0.r1155.g9c4e2a5-1
kwallet-pam5.25.0.r269.g4112e1f-15.25.2.r270.g40e31dd-1
kwave22.04.2.r3797.gca0072aa-122.04.2.r3798.g0061bf34-1
kwayland5.95.0.r1164.ga6d238b-15.95.0.r1168.g8679ea3-1
kwayland-integration5.25.0.r208.g3d9bd69-15.25.2.r210.g232f727-1
kwayland-server5.25.0.r1480.g7f15f36-15.25.2.r1480.g7f15f36-1
kweather 22.04.r34.g29f47a4-1 22.06.r4.g0bb7bc5-1
kweathercore 0.5.r29.g48e07b1-1 0.6.r3.g405594f-1
kwidgetsaddons5.95.0.r947.g02f2c2e2-15.95.0.r948.g422ab481-1
kwin5.25.0.r22627.g4082fdf96-15.25.2.r22677.gda7dad158-1
kwindowsystem5.95.0.r684.ge66fb67-15.95.0.r685.g866a4c6-1
kwinft5.24.5.r20822.g972bc0a4c-15.25.0.r20860.g5bda3d48c-1
kwrite22.04.2.r19129.ge34792b1b-122.04.2.r19179.ga69004b4b-1
kwrited5.25.0.r509.g9cfbcd4-15.25.2.r513.g1fd988d-1
kxmlgui5.95.0.r886.gf9772b11-15.95.0.r887.g8b7ef573-1
kxmlrpcclient5.95.0.r482.g9d96a79eb-15.95.0.r483.gebbf23743-1
layer-shell-qt5.25.0.r59.g34e7c90-15.25.2.r61.g13961ef-1
libakonadi22.04.2.r12775.g23b4f0f3a-122.04.2.r12781.gcfc1a5a24-1
libgravatar22.04.2.r425.gf25146c-122.04.2.r426.g32d910f-1
libkdegames22.04.2.r2247.g550fa13d-122.04.2.r2250.g79e50359-1
libkdepim22.04.2.r909.g0d7d0ac-122.04.2.r910.g946e944-1
libkexiv222.04.2.r823.g6dce742-122.04.2.r825.g3ccebcb-1
libkgapi22.04.2.r1365.g0e4f739-122.04.2.r1366.g6dd4cc3-1
libkleo22.04.2.r1182.gf641eca-122.04.2.r1187.g46f12d7-1
libkscreen5.25.0.r1630.g28b1f89-15.25.2.r1632.g6c3140b-1
libksieve22.04.2.r1718.g990608f2-122.04.2.r1720.g50241b44-1
libksysguard5.25.0.r2412.g2437fd7-15.25.2.r2416.g70c4f70-1
lokalize22.04.2.r1832.gbef89622-122.04.2.r1834.g91fee00b-1
lskat22.04.2.r855.gb8bed10-122.04.2.r856.g62e927a-1
mailcommon22.04.2.r1246.g15d8479-122.04.2.r1249.ga3960a7-1
mailimporter22.04.2.r521.g5e0c82c-122.04.2.r522.gc623df1-1
maliit-framework2.2.1.r22.g29429b24-12.2.1.r26.g4604743f-1
maliit-keyboard2.2.1.1.r13.g4c07f7a2-12.2.1.1.r17.g4daaa6db-1
marble22.04.2.r13449.gcb32bb359-122.04.2.r13451.gf643c9733-1
marble-common22.04.2.r13449.gcb32bb359-122.04.2.r13451.gf643c9733-1
marble-qt22.04.2.r13449.gcb32bb359-122.04.2.r13451.gf643c9733-1
maui-clip 2.1.2.r5.g585c401-1 2.1.2.r6.g1480a86-1
maui-manager r17.1ab55a3-1 r19.ec6ded8-1
maui-nota 2.1.2.r7.g7c553df-1 2.1.2.r10.g8451565-1
maui-pix 2.1.2.r13.gea17b4b-1 2.1.2.r17.g68f91a1-1
maui-shell 0.5.0.r33.gbaab5e1-1 0.5.0.r36.g1301d84-1
mauikit2.1.2.r38.g92231be2-12.1.2.r47.g4619afa1-1
mauikit-filebrowsing 2.1.2.r7.g74c5e2a-1 2.1.2.r9.g2ae2187-1
mauiman r10.5e57b3a-1 r14.3594fc0-1
mbox-importer22.04.2.r569.g3301724-122.04.2.r570.g1891796-1
messagelib22.04.2.r6582.ge8989952d-122.04.2.r6608.g605be84d8-1
milou5.25.0.r776.g7cb6340-15.25.2.r778.ge90fc8b-1
modemmanager-qt5.95.0.r555.ge6dbd16-15.95.0.r556.g1aa1b1e-1
mycroft-bigscreen 1:0.0.4a25-1 1:0.0.4a25-2
mycroft-skill-installer r94.3f124f8-2 r95.a6e7d81-1
neochat22.04.r87.g06b4c40b-1 22.06.r6.gaf198292-1
networkmanager-qt5.95.0.r1154.ga9a9bb1-15.95.0.r1156.g6c9d9ae-1
okular22.04.2.r9758.g8870f6074-122.04.2.r9760.g41e59e4f5-1
oxygen5.25.0.r4485.g49e860d3-15.25.2.r4490.g33ebd8ab-1
palapeli22.04.2.r1286.g4aa0212-122.04.2.r1289.g0414160-1
parley22.04.2.r4526.g3ec94a32-122.04.2.r4527.ga9c8182d-1
partitionmanager22.04.2.r1630.g1b55a1f-122.04.2.r1631.g47861ed-1
picmi22.04.2.r564.g4c78eed-122.04.2.r565.g2457d21-1
pim-data-exporter22.04.2.r2761.g931b33b5-122.04.2.r2762.g2b3faf8f-1
pim-sieve-editor22.04.2.r1629.gd8fac69-122.04.2.r1631.g95e82b6-1
pimcommon22.04.2.r1244.g440bbb9-122.04.2.r1245.g897cb82-1
plank-player r27.21e231b-1 r28.916d4c1-1
plasma-bigscreen r471.g7e52bf0-1 r473.gfb4606d-1
plasma-browser-integration5.25.0.r1331.g1ee520f9-15.25.2.r1333.g909552b1-1
plasma-desktop5.25.0.r9347.g4f4faffe7-15.25.2.r9375.g1a0150d72-1
plasma-dialer 22.04.r39.g8ea86f3-1 22.06.r6.g89c0b37-1
plasma-disks5.25.0.r277.g544e1c7-15.25.2.r282.g0532fc1-1
plasma-firewall5.25.0.r628.ga79630a-15.25.2.r636.gb980d67-1
plasma-framework5.95.0.r16345.gd9bc10339-15.95.0.r16353.gad77dc0a3-1
plasma-integration5.25.0.r568.gbc6f94f-15.25.2.r570.g62d32e8-1
plasma-mobile5.25.0.r1828.g6ed9a7d65-15.25.2.r1876.gb7f1a5b37-1
plasma-mobile-nm5.25.0.r3259.gfbc36095-15.25.2.r3273.g0d9cd3c9-1
plasma-nano5.25.0.r187.ga823e03-15.25.2.r189.g34b95f3-1
plasma-nm5.25.0.r3259.gfbc36095-15.25.2.r3273.g0d9cd3c9-1
plasma-pa5.25.0.r1052.g14a5ceb-15.25.2.r1055.g76b86df-1
plasma-phonebook 22.04.r25.gf52e121-1 22.06.r2.g16ef452-1
plasma-sdk5.25.0.r2365.g93e6b093-15.25.2.r2370.g652a96df-1
plasma-settings 22.04.r48.g2d9f832-1 22.06.r5.g763f96a-1
plasma-systemmonitor5.25.0.r577.g7471d88-15.25.2.r586.gcc52c33-1
plasma-thunderbolt5.25.0.r188.gef12dd5-15.25.2.r192.g5c15dd8-1
plasma-vault5.25.0.r383.g6ce0f40-15.25.2.r387.gd03bc02-1
plasma-wayland-session5.25.0.r11987.g24b22270d-15.25.2.r12014.g923ce7e58-1
plasma-workspace5.25.0.r11987.g24b22270d-15.25.2.r12014.g923ce7e58-1
plasma-workspace-wallpapers5.25.0.r353.g169c4b3-15.25.2.r357.gf1d882b-1
plasmatube 22.04.r19.gcafd472-1 22.06.r4.g9108a3a-1
polkit-kde-agent5.25.0.r528.gdc2264d-15.25.2.r530.gbb0d0c1-1
powerdevil5.25.0.r2552.g2ebe655d-15.25.2.r2557.g33b17fcd-1
print-manager22.04.2.r1137.g0e2d46d-122.04.2.r1139.g68244a1-1
prison5.95.0.r387.g541e19c-15.95.0.r390.g25e4b63-1
pulseaudio-qt 1.3.0.r21.gade2151-1 1.3.0.r22.gf35baaf-1
purpose5.95.0.r976.gf4f4ef4-15.95.0.r978.g49f2b20-1
qmlkonsole 22.04.r41.g71465ab-1 22.06.r3.g2cb6c9c-1
qqc2-breeze-style5.25.0.r248.g2514ff8-15.25.2.r248.g2514ff8-1
qqc2-desktop-style5.95.0.r624.g17715aa-15.95.0.r626.g4b403c9-1
rocs22.04.2.r3085.g3261b2e9-122.04.2.r3087.g77821b37-1
sddm-kcm5.25.0.r664.g34909d7-15.25.2.r666.g26f35f1-1
solid5.95.0.r772.g5c4585e-15.95.0.r777.gf5d1af7-1
sonnet5.95.0.r697.g263f3dd-15.95.0.r699.g1d0257b-1
spacebar 22.04.r30.g45b64b3-1 22.06.r3.gd82353e-1
spectacle22.04.2.r1357.gb02454b-122.04.2.r1362.ge117fdf-1
step22.04.2.r1192.g9297122-122.04.2.r1195.g85b505c-1
svgpart22.04.2.r226.g05ee109-122.04.2.r228.g8a55a98-1
syndication5.95.0.r874.g1ce6816-15.95.0.r876.gb330731-1
syntax-highlighting5.95.0.r1843.g6ff1f09d-15.95.0.r1844.gf9961452-1
systemsettings5.25.0.r2671.gcb5acd47-15.25.2.r2683.g4b691491-1
telepathy-kde-accounts-kcm22.04.2.r1217.gf18fe77-122.04.2.r1219.g9ec4fad-1
telepathy-kde-approver22.04.2.r304.geea421c-122.04.2.r305.gcc15f81-1
telepathy-kde-common-internals22.04.2.r2018.g46dc56c-122.04.2.r2021.g0f4205e-1
telepathy-kde-contact-list22.04.2.r1091.gbad1b7a-122.04.2.r1092.gfa49eb5-1
telepathy-kde-contact-runner22.04.2.r260.g5ccf4e3-122.04.2.r262.g1dd12e4-1
telepathy-kde-desktop-applets22.04.2.r1003.g1b9eb63-122.04.2.r1005.g18d27bc-1
telepathy-kde-integration-module22.04.2.r400.gd2643d8-122.04.2.r401.ge4be972-1
telepathy-kde-text-ui22.04.2.r2045.gf5f9baf-122.04.2.r2047.g8999016-1
threadweaver5.95.0.r541.g0ec4b7f-15.95.0.r544.g3228e68-1
tokodon 22.04.r52.geb4ee87-1 22.06.r4.g5703501-1
vakzination 22.04.r31.gc420822-1 22.06.r4.gbb47d4d-1
vvave 2.1.2.r21.g8741399-1 2.1.2.r25.g6d836d1-1
wrapland5.24.5.r1755.g1c509e2b-15.25.0.r1761.gc522abc3-1
xdg-desktop-portal-kde5.25.0.r498.g826878e-15.25.2.r505.g6377ed4-1
yakuake22.04.2.r797.gc92c662-122.04.2.r799.ged1c78c-1
zeroconf-ioslave22.04.2.r388.g6e1c9fe-122.04.2.r390.g9c1a418-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
