Hello ARM community.
Sorry for the long wait.
Some highlights:
- Most of our kernels got updated
- KDE Frameworks updated to 5.94
- And KDE Gear got updated to point release 22.04.1
- QT5 updated to 5.15.4 branch, did we miss some rebuilds?
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Mon May 16 22:25:54 CEST 2022)
- arm-testing community aarch64: 187 new and 182 removed package(s)
- arm-testing core aarch64: 48 new and 47 removed package(s)
- arm-testing extra aarch64: 580 new and 580 removed package(s)
- arm-testing kde-unstable aarch64: 395 new and 395 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-05-11 2022-05-16
ap6256-firmware 2020.02-9 2020.02-10
gnome-control-center-mobile 42.1-5 42.1-6
gtk3-mobile 3.24.31-1 3.24.33-1
pika-backup 0.4.0.rc.1-1 1:0.4.0-1
postmarketos-tweaks-app 0.11.0-1 0.12.0-1
postmarketos-tweaks-app-phosh 0.11.0-1 0.12.0-1
snapd 2.55.4-1 2.55.5-1
timeshift 21.09.1-3 21.09.1-4
:: Different sync package(s) in repository community aarch64
aircrack-ng 1.6-6 1.7-1
aliyun-cli 3.0.117-1 3.0.119-1
ansible-lint 6.1.0-1 6.1.0-2
aws-cli 1.23.10-1 1.23.11-1
bash-bats 1.6.0-1 1.7.0-2
bash-language-server 2.1.0-1 3.0.2-1
bibletime 3.0.2-1 3.0.3-1
binaryen 1:107-1 1:108-1
blender 17:3.1.2-2 17:3.1.2-2.2
cargo-expand 1.0.19-1 1.0.21-1
cl-trivial-gray-streams r70.g2b3823e-1 2.0.0.r47.g2b3823e-1
cockpit 268.1-1 269-1
cockpit-machines 267-1 268-1
cockpit-pcp 268.1-1 269-1
dart 2.16.2-1 2.17.0-1
dcraw 9.28.0-2 9.28.0-3
deepin-qt5platform-plugins 5.0.59-1 5.0.59-2
devil 1.8.0-5 1.8.0-6
diffoscope 211-1 212-1
docker 1:20.10.15-1 1:20.10.16-1
element 0.46.4-1 0.46.5-1
fcitx-qt5 1.2.7-3 1.2.7-4
fcitx-qt6 1.2.7-3 1.2.7-4
fnlfmt 0.2.2-2 0.2.3-1
foot 1.12.1-1 1.12.1-2
foot-terminfo 1.12.1-1 1.12.1-2
frescobaldi 3.1.3-6 3.2-1
gimp-nufraw 0.43.3-3 0.43.3-4
gimp-plugin-gmic 3.1.1-1 3.1.2-1
git-delta 0.12.1-1 0.13.0-1
glances 3.2.4-2 3.2.5-1
glider 0.16.1-2 0.16.2-1
go 2:1.18.1-1 2:1.18.2-1
gsoap 2.8.121-1 2.8.122-1
haproxy 2.5.6-2 2.5.7-1
hck 0.7.1-2 0.7.2-1
hcloud 1.29.0-1 1.29.5-1
hcxtools 6.2.6-1 6.2.7-1
hedgedoc 1.9.3-1 1.9.3-2
helmfile 0.143.0-2 0.144.0-1
igsc 0.5.0-1 0.6.0-1
jami-daemon 20220407-1 20220511-2
jami-libclient 20220407-1 20220425-2
jenkins 2.346-1 2.347-1
jmol 14.32.54-1 14.32.55-1
jsmol 14.32.54-1 14.32.55-1
jupyter-nbconvert 6.4.5-5 6.5.0-3
jupyter-notebook 6.4.10-4 6.4.11-1
jupyter-retrolab 0.3.20-1 0.3.21-1
jupyter-server 1.16.0-2 1.17.0-1
jupyterlab 3.3.4-1 3.4.2-1
jupyterlab_pygments 0.1.2-4 0.2.2-1
kmymoney 5.1.2-6 5.1.2-7
knative-client 1.3.1-2 1.4.0-1
krita-plugin-gmic 3.0.2.2-3 3.1.2.1-1
kube-linter 0.2.6-2 0.3.0-2
kvantum 1.0.1-1 1.0.1-2
kvantum-theme-materia 20220207-1 20220510-1
libdwarf 1:0.3.3-1 1:0.4.0-1
libfm-qt 1.1.0-1 1.1.0-2
libicns 0.8.1-7 0.8.1-8
libperconaserverclient 8.0.27_18-3 8.0.28_19-1
libqtxdg 3.9.1-1 3.9.1-2
libzim 7.2.0-2 7.2.1-1
logwatch 7.5.6-2 7.6-1
lua-language-server 3.2.2-1 3.2.3-1
man-pages-cs 4.13-1 4.14.0-1
man-pages-da 4.13-1 4.14.0-1
man-pages-de 4.13-1 4.14.0-1
man-pages-es 4.13-1 4.14.0-1
man-pages-fi 4.13-1 4.14.0-1
man-pages-fr 4.13-1 4.14.0-1
man-pages-hu 4.13-1 4.14.0-1
man-pages-id 4.13-1 4.14.0-1
man-pages-it 4.13-1 4.14.0-1
man-pages-mk 4.13-1 4.14.0-1
man-pages-nb 4.13-1 4.14.0-1
man-pages-nl 4.13-1 4.14.0-1
man-pages-pl 4.13-1 4.14.0-1
man-pages-pt_br 4.13-1 4.14.0-1
man-pages-ro 4.13-1 4.14.0-1
man-pages-sr 4.13-1 4.14.0-1
man-pages-sv 4.13-1 4.14.0-1
man-pages-vi 4.13-1 4.14.0-1
marked 3.0.8-1 4.0.0-1
mat2 0.12.3-1 0.12.4-1
materia-kde 20220207-1 20220510-1
mediastreamer 5.1.29-1 5.1.30-1
mitmproxy 8.0.0-1 8.1.0-1
mkcert 1.4.3-2 1.4.4-1
mlite 0.3.8-1 0.4.0-1
mumble 1.4.230-5 1.4.230-6
murmur 1.4.230-5 1.4.230-6
mvt 1.5.4-1 1.5.4-2
networkmanager-strongswan 1.5.2-3 1.5.2-4
nikola 8.2.0-1 8.2.2-1
nodejs-yaml 2.0.0-1 2.0.1-1
nsd 4.4.0-1 4.5.0-1
opendht 1:2.4.0-1 1:2.4.4-1
openscenegraph 3.6.5-11 3.6.5-13
osbuild 55-2 56-1
pcsclite 1.9.5-1 1.9.7-1
percol 0.2.1-3 -
percona-server 8.0.27_18-3 8.0.28_19-1
percona-server-clients 8.0.27_18-3 8.0.28_19-1
php-snuffleupagus 0.7.1-2 0.8.0-1
phpmyadmin 5.1.3-1 5.2.0-1
pinentry-bemenu 0.10.0-1 0.11.0-1
poco 1.11.1-1 1.11.2-1
pulumi 3.28.0-2 3.32.0-1
pyright 1.1.245-1 1.1.247-1
python-anyio 3.5.0-1 3.6.1-1
python-apipkg 2.1.0-1 2.1.1-1
python-boto3 1.21.32-1 1.22.11-1
python-botocore 1.25.10-1 1.25.11-1
python-cryptography-vectors 36.0.2-1 37.0.1-1
python-flask-login 0.6.0-1 0.6.1-1
python-fs 2.4.15-1 2.4.16-1
python-httpx 0.22.0-1 0.22.0-2
python-jaraco.path 3.3.1-2 3.4.0-1
python-jupyter-sphinx 0.3.2-1 0.3.2-2
python-jupyterlab_server 2.12.0-1 2.13.0-1
python-jwcrypto 1.2.0-1 1.3.0-1
python-mt-940 4.23.0-3 4.26.0-1
python-osc-lib 2.4.2-3 2.5.0-1
python-oslo-concurrency 4.5.0-3 4.5.1-1
python-oslo-db 11.2.0-1 11.3.0-1
python-oslo-log 4.7.0-1 4.8.0-1
python-oslo-utils 4.10.1-1 4.10.2-1
python-osprofiler 3.4.2-3 3.4.3-1
python-pg8000 1.26.1-1 1.27.1-1
python-phonenumbers 8.12.47-1 8.12.48-1
python-pikepdf 5.1.2-1 5.1.3-1
python-pytest-asyncio 0.17.1-1 0.17.2-1
python-qiniu 7.7.0-1 7.7.1-1
python-scikit-learn 1.0.2-1 1.1.0-1
python-weasyprint 54.3-1 55.0-1
python-whitenoise 6.0.0-1 6.1.0-1
python-z3 4.8.16-1 4.8.17-1
python2-cairo 1.18.2-4 -
python2-gobject 3.36.1-5 -
python2-numpy 1.16.6-2 -
python2-wxpython3 3.0.2.0-3 -
qcad 3.27.4.0-1 3.27.5.0-2
qt5-ukui-platformtheme 1.0.7-2 1.0.7-3
ratpoints 2.2.1-1 -
readstat 1.1.7-1 1.1.8-1
rnote 0.5.1-1 0.5.3-1
ropgadget 6.6-3 6.7-1
runc 1.1.1-2 1.1.2-1
seatd 0.6.4-1 0.6.4-2
serverless 3.16.0-1 3.17.0-1
skrooge 2.27.0-2 2.27.0-3
srrdb-terminal-client 1.1.7-3 1.2.1-1
syft 0.43.0-1 0.46.0-1
tekton-cli 0.22.0-1 0.23.1-1
thebe git20160526-3 -
toml-bombadil 3.0.0-2 3.1.0-1
tor 0.4.6.10-1 0.4.7.7-1
typescript-language-server 0.9.7-2 0.10.0-1
uglify-js 3.15.4-1 3.15.5-1
ukui-window-switch 3.0.1-2 3.0.1-3
umockdev 0.17.9-1 0.17.10-1
v2ray-domain-list-community 20220509150921-1 20220512180118-1
v2ray-geoip 202205050051-1 202205120051-1
vals 0.14.0-1 0.16.2-1
vaultwarden-web 2.28.0-1 2.28.1-1
wasmer 2.2.0-1 2.2.1-1
xonsh 0.12.2-1 0.12.4-1
zerotier-one 1.8.9-1 1.8.10-1
zim-tools 3.1.0-1 3.1.1-1
ziproxy 3.3.2-2 3.3.2-3
adwaita-qt5 - 1.4.1-3
adwaita-qt6 - 1.4.1-3
eslint_d - 12.1.0-2
man-pages-el - 4.14.0-1
man-pages-uk - 4.14.0-1
prometheus-systemd-exporter - 0.4.0-1
python-autocommand - 2.2.1-1
python-ipycanvas - 0.12.0-1
python-pip-run - 8.8.0-1
python-qpageview - 0.6.2-1
qgnomeplatform-qt5 - 0.8.4-3
qgnomeplatform-qt6 - 0.8.4-3
:: Different overlay package(s) in repository core aarch64
boot-generic 20220205-1 20220512-1
linux 5.17.6-1 5.17.8-1
linux-clockworkpi-a06 5.17.6-1 5.17.8-1
linux-clockworkpi-a06-headers 5.17.6-1 5.17.8-1
linux-headers 5.17.6-1 5.17.8-1
linux-khadas 5.17.5-1 5.17.6-1
linux-khadas-headers 5.17.5-1 5.17.6-1
linux-lts 5.15.38-1 5.15.40-1
linux-lts-headers 5.15.38-1 5.15.40-1
linux-pinephone 5.17.6-2 5.17.8-1
linux-pinephone-headers 5.17.6-2 5.17.8-1
linux-pinephonepro 5.17.6-2 5.17.8-1
linux-pinephonepro-headers 5.17.6-2 5.17.8-1
linux-rc 5.18.rc6-1 5.18.rc7-1
linux-rc-headers 5.18.rc6-1 5.18.rc7-1
linux-rpi4 5.15.38-1 5.15.40-1
linux-rpi4-headers 5.15.38-1 5.15.40-1
linux-rpi4-mainline 5.17.6-1 5.17.8-1
linux-rpi4-mainline-headers 5.17.6-1 5.17.8-1
linux-rpi4-rc 5.18.rc6-1 5.18.rc7-1
linux-rpi4-rc-headers 5.18.rc6-1 5.18.rc7-1
manjaro-keyring 20220509-2 20220514-1
manjaro-system 20220404-1 20220515-1
raspberrypi-bootloader 20220509-1 20220510-1
raspberrypi-bootloader-x 20220509-1 20220510-1
boot-generic-efi - 20220512-1
:: Different sync package(s) in repository core aarch64
amd-ucode 20220411.705f19a-1 20220509.b19cbdc-1
curl 7.83.0-1 7.83.1-1
gnutls 3.7.4-2 3.7.5-1
lemon 3.38.4-1 3.38.5-1
libcurl-compat 7.83.0-1 7.83.1-1
libcurl-gnutls 7.83.0-1 7.83.1-1
libxml2 2.9.13-2 2.9.14-1
linux-firmware 20220411.705f19a-1 20220509.b19cbdc-1
linux-firmware-bnx2x 20220411.705f19a-1 20220509.b19cbdc-1
linux-firmware-liquidio 20220411.705f19a-1 20220509.b19cbdc-1
linux-firmware-marvell 20220411.705f19a-1 20220509.b19cbdc-1
linux-firmware-mellanox 20220411.705f19a-1 20220509.b19cbdc-1
linux-firmware-nfp 20220411.705f19a-1 20220509.b19cbdc-1
linux-firmware-qcom 20220411.705f19a-1 20220509.b19cbdc-1
linux-firmware-qlogic 20220411.705f19a-1 20220509.b19cbdc-1
linux-firmware-whence 20220411.705f19a-1 20220509.b19cbdc-1
psmisc 23.4-1 23.5-1
sqlite 3.38.4-1 3.38.5-1
sqlite-analyzer 3.38.4-1 3.38.5-1
sqlite-doc 3.38.4-1 3.38.5-1
sqlite-tcl 3.38.4-1 3.38.5-1
unixodbc 2.3.9-1 2.3.11-1
:: Different overlay package(s) in repository extra aarch64
elisa-qtmm 22.04.0-1 22.04.1-1
manjaro-chrootbuild r272.g9badf29-1 r276.g54a6175-1
mesa-git22.2.0_devel.153441.56070d33225-122.2.0_devel.153936.e9e8c649cd1-1
okular 22.04.0-1 22.04.1-1
pamac-cli 10.4.0-1 10.4.0-2
pamac-gnome-integration 10.4.0-1 10.4.0-2
pamac-gtk 10.4.0-1 10.4.0-2
:: Different sync package(s) in repository extra aarch64
akonadi 22.04.0-1 22.04.1-2
akonadi-calendar 22.04.0-1 22.04.1-1
akonadi-calendar-tools 22.04.0-1 22.04.1-1
akonadi-contacts 22.04.0-1 22.04.1-1
akonadi-import-wizard 22.04.0-1 22.04.1-1
akonadi-mime 22.04.0-1 22.04.1-1
akonadi-notes 22.04.0-1 22.04.1-1
akonadi-search 22.04.0-1 22.04.1-1
akonadiconsole 22.04.0-1 22.04.1-1
akregator 22.04.0-1 22.04.1-1
analitza 22.04.0-1 22.04.1-1
archboot-arm 2022.05-44 2022.05-64
archlinux-appstream-data 20220422-1 20220512-1
ark 22.04.0-1 22.04.1-1
artikulate 22.04.0-2 22.04.1-1
attica 5.93.0-1 5.94.0-1
audiocd-kio 22.04.0-1 22.04.1-1
baloo 5.93.0-1 5.94.0-1
baloo-widgets 22.04.0-1 22.04.1-1
blinken 22.04.0-1 22.04.1-1
bluez-qt 5.93.0-1 5.94.0-1
bomber 22.04.0-1 22.04.1-1
bovo 22.04.0-1 22.04.1-1
breeze-icons 5.93.0-1 5.94.0-1
bubblewrap 0.6.1-1 0.6.2-1
bubblewrap-suid 0.6.1-1 0.6.2-1
calendarsupport 22.04.0-1 22.04.1-1
cantor 22.04.0-1 22.04.1-1
cervisia 22.04.0-1 22.04.1-1
chromium 101.0.4951.54-1 101.0.4951.64-1
dbus-broker 29-2 30-2
digikam 7.6.0-2 7.6.0-3
dolphin 22.04.0-1 22.04.1-1
dolphin-plugins 22.04.0-1 22.04.1-1
dragon 22.04.0-1 22.04.1-1
eventviews 22.04.0-1 22.04.1-1
extra-cmake-modules 5.93.0-1 5.94.0-1
falkon 22.04.0-1 22.04.1-1
ffmpegthumbs 22.04.0-1 22.04.1-1
filelight 22.04.0-1 22.04.1-1
frameworkintegration 5.93.0-1 5.94.0-1
fuse-common 3.10.5-1 3.11.0-1
fuse3 3.10.5-1 3.11.0-1
gdb 11.2-1 12.1-1
gdb-common 11.2-1 12.1-1
gegl 0.4.36-2 0.4.36-3
gnome-todo 41.0+r69+ga9a5b7c-141.0+r106+gebc68374-1
granatier 22.04.0-1 22.04.1-1
grantlee-editor 22.04.0-1 22.04.1-1
grantleetheme 22.04.0-1 22.04.1-1
graphicsmagick 1.3.38-1 1.3.38-2
gtk-update-icon-cache 1:4.6.3-1 1:4.6.4-1
gtk3 1:3.24.33-31:3.24.33+r28+g01edbfb976-1
gtk3-demos 1:3.24.33-31:3.24.33+r28+g01edbfb976-1
gtk3-docs 1:3.24.33-31:3.24.33+r28+g01edbfb976-1
gtk4 1:4.6.3-1 1:4.6.4-1
gtk4-demos 1:4.6.3-1 1:4.6.4-1
gtk4-docs 1:4.6.3-1 1:4.6.4-1
gwenview 22.04.0-1 22.04.1-1
imagemagick 7.1.0.33-1 7.1.0.34-1
imagemagick-doc 7.1.0.33-1 7.1.0.34-1
incidenceeditor 22.04.0-1 22.04.1-1
itinerary 22.04.0-1 22.04.1-1
jasper 2.0.33-2 3.0.3-1
jasper-doc 2.0.33-2 3.0.3-1
juk 22.04.0-1 22.04.1-1
k3b 1:22.04.0-1 1:22.04.1-1
kaccounts-integration 22.04.0-1 22.04.1-1
kaccounts-providers 22.04.0-1 22.04.1-1
kactivities 5.93.0-1 5.94.0-1
kactivities-stats 5.93.0-1 5.94.0-1
kaddressbook 22.04.0-1 22.04.1-1
kajongg 22.04.0-2 22.04.1-1
kalarm 22.04.0-1 22.04.1-1
kalendar 22.04.0-1 22.04.1-1
kalgebra 22.04.0-1 22.04.1-1
kalzium 22.04.0-1 22.04.1-1
kamera 22.04.0-1 22.04.1-1
kamoso 22.04.0-1 22.04.1-1
kanagram 22.04.0-1 22.04.1-1
kapidox 5.93.0-1 5.94.0-1
kapman 22.04.0-1 22.04.1-1
kapptemplate 22.04.0-1 22.04.1-1
karchive 5.93.0-1 5.94.0-1
kate 22.04.0-1 22.04.1-1
katomic 22.04.0-1 22.04.1-1
kauth 5.93.0-1 5.94.0-1
kbackup 22.04.0-1 22.04.1-1
kblackbox 22.04.0-1 22.04.1-1
kblocks 22.04.0-1 22.04.1-1
kbookmarks 5.93.0-1 5.94.0-1
kbounce 22.04.0-1 22.04.1-1
kbreakout 22.04.0-1 22.04.1-1
kbruch 22.04.0-1 22.04.1-1
kcachegrind 22.04.0-1 22.04.1-1
kcachegrind-common 22.04.0-1 22.04.1-1
kcalc 22.04.0-1 22.04.1-1
kcalendarcore 5.93.0-1 5.94.0-1
kcalutils 22.04.0-2 22.04.1-1
kcharselect 22.04.0-1 22.04.1-1
kcmutils 5.93.0-1 5.94.0-1
kcodecs 5.93.0-1 5.94.0-1
kcolorchooser 22.04.0-1 22.04.1-1
kcompletion 5.93.0-1 5.94.0-1
kconfig 5.93.0-1 5.94.0-1
kconfigwidgets 5.93.0-1 5.94.0-1
kcontacts 1:5.93.0-1 1:5.94.0-1
kcoreaddons 5.93.0-1 5.94.0-1
kcrash 5.93.0-1 5.94.0-1
kcron 22.04.0-1 22.04.1-1
kdav 1:5.93.0-1 1:5.94.0-1
kdbusaddons 5.93.0-1 5.94.0-1
kde-dev-scripts 22.04.0-1 22.04.1-1
kde-dev-utils 22.04.0-1 22.04.1-1
kdebugsettings 22.04.0-1 22.04.1-1
kdeclarative 5.93.0-1 5.94.0-1
kdeconnect 22.04.0-2 22.04.1-1
kded 5.93.0-1 5.94.0-1
kdeedu-data 22.04.0-1 22.04.1-1
kdegraphics-mobipocket 22.04.0-1 22.04.1-1
kdegraphics-thumbnailers 22.04.0-1 22.04.1-1
kdelibs4support 5.93.0-1 5.94.0-1
kdenetwork-filesharing 22.04.0-1 22.04.1-1
kdenlive 22.04.0-1 22.04.1-1
kdepim-addons 22.04.0-1 22.04.1-1
kdepim-runtime 22.04.0-1 22.04.1-1
kdesdk-kioslaves 22.04.0-1 22.04.1-1
kdesdk-thumbnailers 22.04.0-1 22.04.1-1
kdesignerplugin 5.93.0-1 5.94.0-1
kdesu 5.93.0-1 5.94.0-1
kdevelop 22.04.0-1 22.04.1-1
kdevelop-php 22.04.0-1 22.04.1-1
kdewebkit 5.93.0-1 5.94.0-1
kdf 22.04.0-1 22.04.1-1
kdialog 22.04.0-1 22.04.1-1
kdiamond 22.04.0-1 22.04.1-1
kdnssd 5.93.0-1 5.94.0-1
kdoctools 5.93.0-1 5.94.0-1
keditbookmarks 22.04.0-1 22.04.1-1
kemoticons 5.93.0-1 5.94.0-1
kfilemetadata 5.93.0-1 5.94.0-1
kfind 22.04.0-1 22.04.1-1
kfloppy 22.04.0-1 22.04.1-1
kfourinline 22.04.0-1 22.04.1-1
kgeography 22.04.0-1 22.04.1-1
kget 22.04.0-1 22.04.1-1
kglobalaccel 5.93.0-1 5.94.0-1
kgoldrunner 22.04.0-1 22.04.1-1
kgpg 22.04.0-1 22.04.1-1
kguiaddons 5.93.0-1 5.94.0-1
khangman 22.04.0-2 22.04.1-1
khelpcenter 22.04.0-1 22.04.1-1
kholidays 1:5.93.0-1 1:5.94.0-1
khtml 5.93.0-1 5.94.0-1
ki18n 5.93.0-1 5.94.0-1
kiconthemes 5.93.0-1 5.94.0-1
kidentitymanagement 22.04.0-1 22.04.1-1
kidletime 5.93.0-1 5.94.0-1
kig 22.04.0-1 22.04.1-1
kigo 22.04.0-1 22.04.1-1
killbots 22.04.0-1 22.04.1-1
kimageformats 5.93.0-2 5.94.0-1
kimagemapeditor 22.04.0-2 22.04.1-1
kimap 22.04.0-1 22.04.1-1
kinit 5.93.0-1 5.94.0-1
kio 5.93.0-1 5.94.0-1
kio-extras 22.04.0-2 22.04.1-1
kio-gdrive 22.04.0-1 22.04.1-1
kirigami-gallery 22.04.0-1 22.04.1-1
kirigami2 5.93.0-1 5.94.0-1
kiriki 22.04.0-1 22.04.1-1
kitemmodels 5.93.0-1 5.94.0-1
kitemviews 5.93.0-1 5.94.0-1
kiten 22.04.0-1 22.04.1-1
kitinerary 22.04.0-2 22.04.1-1
kjobwidgets 5.93.0-1 5.94.0-1
kjs 5.93.0-1 5.94.0-1
kjsembed 5.93.0-1 5.94.0-1
kjumpingcube 22.04.0-1 22.04.1-1
kldap 22.04.0-1 22.04.1-1
kleopatra 22.04.0-1 22.04.1-1
klettres 22.04.0-1 22.04.1-1
klickety 22.04.0-1 22.04.1-1
klines 22.04.0-1 22.04.1-1
kmag 22.04.0-1 22.04.1-1
kmahjongg 22.04.0-1 22.04.1-1
kmail 22.04.0-1 22.04.1-1
kmail-account-wizard 22.04.0-1 22.04.1-1
kmailtransport 22.04.0-1 22.04.1-1
kmbox 22.04.0-1 22.04.1-1
kmediaplayer 5.93.0-1 5.94.0-1
kmime 22.04.0-1 22.04.1-1
kmines 22.04.0-1 22.04.1-1
kmix 22.04.0-1 22.04.1-1
kmousetool 22.04.0-1 22.04.1-1
kmouth 22.04.0-1 22.04.1-1
kmplot 22.04.0-1 22.04.1-1
knavalbattle 22.04.0-1 22.04.1-1
knetwalk 22.04.0-1 22.04.1-1
knewstuff 5.93.0-1 5.94.0-1
knights 22.04.0-2 22.04.1-1
knotes 22.04.0-1 22.04.1-1
knotifications 5.93.0-1 5.94.0-1
knotifyconfig 5.93.0-1 5.94.0-1
kolf 22.04.0-1 22.04.1-1
kollision 22.04.0-1 22.04.1-1
kolourpaint 22.04.0-1 22.04.1-1
kompare 22.04.0-1 22.04.1-1
konqueror 22.04.0-1 22.04.1-1
konquest 22.04.0-1 22.04.1-1
konsole 22.04.0-1 22.04.1-1
kontact 22.04.0-1 22.04.1-1
kontactinterface 22.04.0-1 22.04.1-1
kontrast 22.04.0-1 22.04.1-1
konversation 22.04.0-1 22.04.1-1
kopeninghours 22.04.0-1 22.04.1-1
kopete 22.04.0-1 22.04.1-1
korganizer 22.04.0-1 22.04.1-1
kosmindoormap 22.04.0-2 22.04.1-1
kpackage 5.93.0-1 5.94.0-1
kparts 5.93.0-1 5.94.0-1
kpat 22.04.0-1 22.04.1-1
kpeople 5.93.0-1 5.94.0-1
kpimtextedit 22.04.0-1 22.04.1-1
kpkpass 22.04.0-1 22.04.1-1
kplotting 5.93.0-1 5.94.0-1
kpmcore 22.04.0-1 22.04.1-1
kpty 5.93.0-1 5.94.0-1
kpublictransport 22.04.0-1 22.04.1-1
kqtquickcharts 22.04.0-1 22.04.1-1
kquickcharts 5.93.0-1 5.94.0-1
krdc 22.04.0-1 22.04.1-1
kreversi 22.04.0-1 22.04.1-1
krfb 22.04.0-2 22.04.1-1
kross 5.93.0-1 5.94.0-1
kruler 22.04.0-1 22.04.1-1
krunner 5.93.0-1 5.94.0-1
kservice 5.93.0-1 5.94.0-1
kshisen 22.04.0-1 22.04.1-1
ksirk 22.04.0-1 22.04.1-1
ksmtp 22.04.0-1 22.04.1-1
ksnakeduel 22.04.0-1 22.04.1-1
kspaceduel 22.04.0-1 22.04.1-1
ksquares 22.04.0-1 22.04.1-1
ksudoku 22.04.0-1 22.04.1-1
ksystemlog 22.04.0-1 22.04.1-1
kteatime 22.04.0-1 22.04.1-1
ktexteditor 5.93.0-1 5.94.0-1
ktextwidgets 5.93.0-1 5.94.0-1
ktimer 22.04.0-1 22.04.1-1
ktnef 22.04.0-1 22.04.1-1
ktorrent 22.04.0-1 22.04.1-1
ktouch 22.04.0-1 22.04.1-1
ktuberling 22.04.0-1 22.04.1-1
kturtle 22.04.0-1 22.04.1-1
kubrick 22.04.0-1 22.04.1-1
kunitconversion 5.93.0-1 5.94.0-1
kwallet 5.93.0-1 5.94.0-1
kwalletmanager 22.04.0-1 22.04.1-1
kwave 22.04.0-1 22.04.1-1
kwayland 5.93.0-2 5.94.0-2
kwidgetsaddons 5.93.0-1 5.94.0-1
kwin 5.24.5-1 5.24.5-2
kwindowsystem 5.93.0-1 5.94.0-1
kwordquiz 22.04.0-1 22.04.1-1
kwrite 22.04.0-1 22.04.1-1
kxmlgui 5.93.0-1 5.94.0-1
kxmlrpcclient 5.93.0-1 5.94.0-1
libakonadi 22.04.0-1 22.04.1-2
libappimage 1.0.4-2 1.0.4.5-1
libfido2 1.10.0-1 1.11.0-1
libgravatar 22.04.0-1 22.04.1-1
libkcddb 22.04.0-1 22.04.1-1
libkcompactdisc 22.04.0-1 22.04.1-1
libkdcraw 22.04.0-1 22.04.1-1
libkdegames 22.04.0-1 22.04.1-1
libkdepim 22.04.0-1 22.04.1-1
libkeduvocdocument 22.04.0-1 22.04.1-1
libkexiv2 22.04.0-1 22.04.1-1
libkgapi 22.04.0-1 22.04.1-1
libkleo 22.04.0-1 22.04.1-1
libkmahjongg 22.04.0-1 22.04.1-1
libkomparediff2 22.04.0-1 22.04.1-1
libksane 22.04.0-1 22.04.1-1
libksieve 22.04.0-1 22.04.1-1
libktorrent 22.04.0-1 22.04.1-1
libnotify 0.7.11-2 0.7.12-1
libraw 0.20.2-1 0.20.2-2
libreoffice-still 7.2.6-3 7.2.7-1
libreoffice-still-af 7.2.6-1 7.2.7-1
libreoffice-still-am 7.2.6-1 7.2.7-1
libreoffice-still-ar 7.2.6-1 7.2.7-1
libreoffice-still-as 7.2.6-1 7.2.7-1
libreoffice-still-ast 7.2.6-1 7.2.7-1
libreoffice-still-be 7.2.6-1 7.2.7-1
libreoffice-still-bg 7.2.6-1 7.2.7-1
libreoffice-still-bn 7.2.6-1 7.2.7-1
libreoffice-still-bn-in 7.2.6-1 7.2.7-1
libreoffice-still-bo 7.2.6-1 7.2.7-1
libreoffice-still-br 7.2.6-1 7.2.7-1
libreoffice-still-brx 7.2.6-1 7.2.7-1
libreoffice-still-bs 7.2.6-1 7.2.7-1
libreoffice-still-ca 7.2.6-1 7.2.7-1
libreoffice-still-ca-valencia 7.2.6-1 7.2.7-1
libreoffice-still-ckb 7.2.6-1 7.2.7-1
libreoffice-still-cs 7.2.6-1 7.2.7-1
libreoffice-still-cy 7.2.6-1 7.2.7-1
libreoffice-still-da 7.2.6-1 7.2.7-1
libreoffice-still-de 7.2.6-1 7.2.7-1
libreoffice-still-dgo 7.2.6-1 7.2.7-1
libreoffice-still-dsb 7.2.6-1 7.2.7-1
libreoffice-still-dz 7.2.6-1 7.2.7-1
libreoffice-still-el 7.2.6-1 7.2.7-1
libreoffice-still-en-gb 7.2.6-1 7.2.7-1
libreoffice-still-en-za 7.2.6-1 7.2.7-1
libreoffice-still-eo 7.2.6-1 7.2.7-1
libreoffice-still-es 7.2.6-1 7.2.7-1
libreoffice-still-et 7.2.6-1 7.2.7-1
libreoffice-still-eu 7.2.6-1 7.2.7-1
libreoffice-still-fa 7.2.6-1 7.2.7-1
libreoffice-still-fi 7.2.6-1 7.2.7-1
libreoffice-still-fr 7.2.6-1 7.2.7-1
libreoffice-still-fur 7.2.6-1 7.2.7-1
libreoffice-still-fy 7.2.6-1 7.2.7-1
libreoffice-still-ga 7.2.6-1 7.2.7-1
libreoffice-still-gd 7.2.6-1 7.2.7-1
libreoffice-still-gl 7.2.6-1 7.2.7-1
libreoffice-still-gu 7.2.6-1 7.2.7-1
libreoffice-still-gug 7.2.6-1 7.2.7-1
libreoffice-still-he 7.2.6-1 7.2.7-1
libreoffice-still-hi 7.2.6-1 7.2.7-1
libreoffice-still-hr 7.2.6-1 7.2.7-1
libreoffice-still-hsb 7.2.6-1 7.2.7-1
libreoffice-still-hu 7.2.6-1 7.2.7-1
libreoffice-still-id 7.2.6-1 7.2.7-1
libreoffice-still-is 7.2.6-1 7.2.7-1
libreoffice-still-it 7.2.6-1 7.2.7-1
libreoffice-still-ja 7.2.6-1 7.2.7-1
libreoffice-still-ka 7.2.6-1 7.2.7-1
libreoffice-still-kab 7.2.6-1 7.2.7-1
libreoffice-still-kk 7.2.6-1 7.2.7-1
libreoffice-still-km 7.2.6-1 7.2.7-1
libreoffice-still-kmr-latn 7.2.6-1 7.2.7-1
libreoffice-still-kn 7.2.6-1 7.2.7-1
libreoffice-still-ko 7.2.6-1 7.2.7-1
libreoffice-still-kok 7.2.6-1 7.2.7-1
libreoffice-still-ks 7.2.6-1 7.2.7-1
libreoffice-still-lb 7.2.6-1 7.2.7-1
libreoffice-still-lo 7.2.6-1 7.2.7-1
libreoffice-still-lt 7.2.6-1 7.2.7-1
libreoffice-still-lv 7.2.6-1 7.2.7-1
libreoffice-still-mai 7.2.6-1 7.2.7-1
libreoffice-still-mk 7.2.6-1 7.2.7-1
libreoffice-still-ml 7.2.6-1 7.2.7-1
libreoffice-still-mn 7.2.6-1 7.2.7-1
libreoffice-still-mni 7.2.6-1 7.2.7-1
libreoffice-still-mr 7.2.6-1 7.2.7-1
libreoffice-still-my 7.2.6-1 7.2.7-1
libreoffice-still-nb 7.2.6-1 7.2.7-1
libreoffice-still-ne 7.2.6-1 7.2.7-1
libreoffice-still-nl 7.2.6-1 7.2.7-1
libreoffice-still-nn 7.2.6-1 7.2.7-1
libreoffice-still-nr 7.2.6-1 7.2.7-1
libreoffice-still-nso 7.2.6-1 7.2.7-1
libreoffice-still-oc 7.2.6-1 7.2.7-1
libreoffice-still-om 7.2.6-1 7.2.7-1
libreoffice-still-or 7.2.6-1 7.2.7-1
libreoffice-still-pa-in 7.2.6-1 7.2.7-1
libreoffice-still-pl 7.2.6-1 7.2.7-1
libreoffice-still-pt 7.2.6-1 7.2.7-1
libreoffice-still-pt-br 7.2.6-1 7.2.7-1
libreoffice-still-ro 7.2.6-1 7.2.7-1
libreoffice-still-ru 7.2.6-1 7.2.7-1
libreoffice-still-rw 7.2.6-1 7.2.7-1
libreoffice-still-sa-in 7.2.6-1 7.2.7-1
libreoffice-still-sat 7.2.6-1 7.2.7-1
libreoffice-still-sd 7.2.6-1 7.2.7-1
libreoffice-still-sdk 7.2.6-3 7.2.7-1
libreoffice-still-si 7.2.6-1 7.2.7-1
libreoffice-still-sid 7.2.6-1 7.2.7-1
libreoffice-still-sk 7.2.6-1 7.2.7-1
libreoffice-still-sl 7.2.6-1 7.2.7-1
libreoffice-still-sq 7.2.6-1 7.2.7-1
libreoffice-still-sr 7.2.6-1 7.2.7-1
libreoffice-still-sr-latn 7.2.6-1 7.2.7-1
libreoffice-still-ss 7.2.6-1 7.2.7-1
libreoffice-still-st 7.2.6-1 7.2.7-1
libreoffice-still-sv 7.2.6-1 7.2.7-1
libreoffice-still-sw-tz 7.2.6-1 7.2.7-1
libreoffice-still-szl 7.2.6-1 7.2.7-1
libreoffice-still-ta 7.2.6-1 7.2.7-1
libreoffice-still-te 7.2.6-1 7.2.7-1
libreoffice-still-tg 7.2.6-1 7.2.7-1
libreoffice-still-th 7.2.6-1 7.2.7-1
libreoffice-still-tn 7.2.6-1 7.2.7-1
libreoffice-still-tr 7.2.6-1 7.2.7-1
libreoffice-still-ts 7.2.6-1 7.2.7-1
libreoffice-still-tt 7.2.6-1 7.2.7-1
libreoffice-still-ug 7.2.6-1 7.2.7-1
libreoffice-still-uk 7.2.6-1 7.2.7-1
libreoffice-still-uz 7.2.6-1 7.2.7-1
libreoffice-still-ve 7.2.6-1 7.2.7-1
libreoffice-still-vec 7.2.6-1 7.2.7-1
libreoffice-still-vi 7.2.6-1 7.2.7-1
libreoffice-still-xh 7.2.6-1 7.2.7-1
libreoffice-still-zh-cn 7.2.6-1 7.2.7-1
libreoffice-still-zh-tw 7.2.6-1 7.2.7-1
libreoffice-still-zu 7.2.6-1 7.2.7-1
librsvg 2:2.54.1-1 2:2.54.3-1
librsvg-docs 2:2.54.1-1 2:2.54.3-1
llvm 13.0.1-2 13.0.1-3
llvm-libs 13.0.1-2 13.0.1-3
llvm-ocaml 13.0.1-2 13.0.1-3
lokalize 22.04.0-1 22.04.1-1
lskat 22.04.0-1 22.04.1-1
mailcommon 22.04.0-1 22.04.1-1
mailimporter 22.04.0-1 22.04.1-1
marble 22.04.0-2 22.04.1-1
marble-common 22.04.0-2 22.04.1-1
marble-maps 22.04.0-2 22.04.1-1
marble-qt 22.04.0-2 22.04.1-1
markdownpart 22.04.0-1 22.04.1-1
mbox-importer 22.04.0-1 22.04.1-1
mdds 2.0.2-1 2.0.3-1
messagelib 22.04.0-1 22.04.1-1
minuet 22.04.0-1 22.04.1-1
mobile-broadband-provider-info 20220315-1 20220511-1
moc 1:2.5.2-5 1:2.5.2-6
modemmanager-qt 5.93.0-1 5.94.0-1
mokutil 0.5.0-1 0.6.0-1
networkmanager-qt 5.93.0-1 5.94.0-1
noto-fonts 20220502-1 20220502-2
noto-fonts-extra 20220502-1 20220502-2
openjpeg2 2.4.0-1 2.5.0-1
oxygen-icons 1:5.93.0-1 1:5.94.0-1
oxygen-icons-svg 1:5.93.0-1 1:5.94.0-1
palapeli 22.04.0-1 22.04.1-1
pappl 1.1.0-1 1.2.0-1
parley 22.04.0-1 22.04.1-1
partitionmanager 22.04.0-1 22.04.1-1
php 8.1.5-2 8.1.6-1
php-apache 8.1.5-2 8.1.6-1
php-cgi 8.1.5-2 8.1.6-1
php-dblib 8.1.5-2 8.1.6-1
php-embed 8.1.5-2 8.1.6-1
php-enchant 8.1.5-2 8.1.6-1
php-fpm 8.1.5-2 8.1.6-1
php-gd 8.1.5-2 8.1.6-1
php-imap 8.1.5-2 8.1.6-1
php-intl 8.1.5-2 8.1.6-1
php-odbc 8.1.5-2 8.1.6-1
php-pgsql 8.1.5-2 8.1.6-1
php-phpdbg 8.1.5-2 8.1.6-1
php-pspell 8.1.5-2 8.1.6-1
php-snmp 8.1.5-2 8.1.6-1
php-sodium 8.1.5-2 8.1.6-1
php-sqlite 8.1.5-2 8.1.6-1
php-tidy 8.1.5-2 8.1.6-1
php-xsl 8.1.5-2 8.1.6-1
picmi 22.04.0-1 22.04.1-1
pim-data-exporter 22.04.0-1 22.04.1-1
pim-sieve-editor 22.04.0-1 22.04.1-1
pimcommon 22.04.0-1 22.04.1-1
pipewire-media-session 1:0.4.1-1 1:0.4.1-2
pipewire-media-session-docs 1:0.4.1-1 1:0.4.1-2
plasma-framework 5.93.0-4 5.94.0-1
plasma-wayland-session 5.24.5-1 5.24.5-2
plasma-workspace 5.24.5-1 5.24.5-2
poppler 22.05.0-1 22.05.0-2
poppler-glib 22.05.0-1 22.05.0-2
poppler-qt5 22.05.0-1 22.05.0-2
poppler-qt6 22.05.0-1 22.05.0-2
postgresql 14.2-1 14.3-1
postgresql-docs 14.2-1 14.3-1
postgresql-libs 14.2-1 14.3-1
postgresql-old-upgrade 13.6-1 13.7-1
poxml 22.04.0-1 22.04.1-1
print-manager 22.04.0-1 22.04.1-1
prison 5.93.0-1 5.94.0-1
purpose 5.93.0-1 5.94.0-1
pyside2 5.15.3-3 5.15.4-1
pyside2-tools 5.15.3-3 5.15.4-1
python-cryptography 36.0.2-1 37.0.0-1
python-qscintilla-qt5 2.13.2-1 2.13.3-1
python-qscintilla-qt6 2.13.2-1 2.13.3-1
python-setuptools 1:59.8.0-1 1:60.5.0-1
python-shiboken2 5.15.3-3 5.15.4-1
qcachegrind 22.04.0-1 22.04.1-1
qqc2-desktop-style 5.93.0-1 5.94.0-1
qt5-3d 5.15.3+kde+r18-1 5.15.4+kde+r17-1
qt5-base 5.15.3+kde+r145-1 5.15.4+kde+r135-1
qt5-charts 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-connectivity 5.15.3+kde+r6-1 5.15.4+kde+r4-1
qt5-datavis3d 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-declarative 5.15.3+kde+r20-1 5.15.4+kde+r17-1
qt5-doc 5.15.3-1 5.15.4-1
qt5-examples 5.15.3-1 5.15.4-1
qt5-gamepad 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-graphicaleffects 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-imageformats 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-location 5.15.3+kde+r2-1 5.15.4+kde+r2-1
qt5-lottie 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-mqtt 5.15.2-3 5.15.2-4
qt5-multimedia 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-networkauth 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-purchasing 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-quick3d 5.15.3+kde+r2-1 5.15.4+kde+r2-1
qt5-quickcontrols 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-quickcontrols2 5.15.3+kde+r4-1 5.15.4+kde+r4-1
qt5-quicktimeline 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-remoteobjects 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-script 5.15.9-1 5.15.9-2
qt5-scxml 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-sensors 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-serialbus 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-serialport 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-speech 5.15.3+kde+r1-1 5.15.4+kde+r1-1
qt5-svg 5.15.3+kde+r12-1 5.15.4+kde+r10-1
qt5-tools 5.15.3+kde+r1-1 5.15.4+kde+r0-1
qt5-translations 5.15.3+kde+r2-1 5.15.4+kde+r2-1
qt5-virtualkeyboard 5.15.3+kde+r3-1 5.15.4+kde+r3-1
qt5-wayland 5.15.3+kde+r44-1 5.15.4+kde+r38-1
qt5-webchannel 5.15.3+kde+r3-1 5.15.4+kde+r3-1
qt5-webengine 5.15.9-2 5.15.9-3
qt5-webglplugin 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-webkit 5.212.0alpha4-13 5.212.0alpha4-14
qt5-websockets 5.15.3+kde+r3-1 5.15.4+kde+r3-1
qt5-webview 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-x11extras 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt5-xcb-private-headers 5.15.3+kde+r145-1 5.15.4+kde+r135-1
qt5-xmlpatterns 5.15.3+kde+r0-1 5.15.4+kde+r0-1
qt6-imageformats 6.3.0-1 6.3.0-2
rocs 22.04.0-1 22.04.1-1
signon-kwallet-extension 22.04.0-1 22.04.1-1
skanlite 22.04.0-1 22.04.1-1
skanpage 22.04.0-1 22.04.1-1
solid 5.93.0-1 5.94.0-1
sonnet 5.93.0-1 5.94.0-1
spectacle 22.04.0-1 22.04.1-1
step 22.04.0-1 22.04.1-1
svgpart 22.04.0-1 22.04.1-1
sweeper 22.04.0-1 22.04.1-1
syndication 5.93.0-1 5.94.0-1
syntax-highlighting 5.93.0-1 5.94.0-1
telepathy-kde-accounts-kcm 22.04.0-1 22.04.1-1
telepathy-kde-approver 22.04.0-1 22.04.1-1
telepathy-kde-auth-handler 22.04.0-1 22.04.1-1
telepathy-kde-call-ui 22.04.0-1 22.04.1-1
telepathy-kde-common-internals 22.04.0-1 22.04.1-1
telepathy-kde-contact-list 22.04.0-1 22.04.1-1
telepathy-kde-contact-runner 22.04.0-1 22.04.1-1
telepathy-kde-desktop-applets 22.04.0-1 22.04.1-1
telepathy-kde-filetransfer-handler 22.04.0-1 22.04.1-1
telepathy-kde-integration-module 22.04.0-1 22.04.1-1
telepathy-kde-send-file 22.04.0-1 22.04.1-1
telepathy-kde-text-ui 22.04.0-1 22.04.1-1
threadweaver 5.93.0-1 5.94.0-1
ttf-croscore 20220502-1 20220502-2
umbrello 22.04.0-1 22.04.1-1
vulkan-headers 1:1.3.212-1 1:1.3.213-1
vulkan-icd-loader 1.3.209-1 1.3.213-1
vulkan-tools 1.3.207-1 1.3.213-1
vulkan-validation-layers 1.3.204.1-1 1.3.211.0-1
wireplumber 0.4.10-2 0.4.10-3
wireplumber-docs 0.4.10-2 0.4.10-3
xdg-dbus-proxy 0.1.3-1 0.1.4-1
xfce4-terminal 1.0.2-1 1.0.3-1
yakuake 22.04.0-1 22.04.1-1
zanshin 22.04.0-1 22.04.1-1
zeroconf-ioslave 22.04.0-1 22.04.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.04.0.r12724.ged9c5c991-122.04.1.r12734.g29e357458-1
akonadi-calendar22.04.0.r2080.g95150f5-122.04.1.r2083.ge46a70e-1
akonadi-calendar-tools22.04.0.r950.g766c0da-122.04.1.r951.gd34a9a9-1
akonadi-contacts22.04.0.r3170.gc3797ba5-122.04.1.r3171.g4a0e5e5e-1
akonadi-import-wizard22.04.0.r1811.g30d4ff9-122.04.1.r1812.g74b83c6-1
akonadi-mime22.04.0.r1719.gab395a5-122.04.1.r1719.gab395a5-1
akonadi-notes22.04.0.r1073.g6dd0081-122.04.1.r1073.g6dd0081-1
akonadi-search22.04.0.r1221.g3914962-122.04.1.r1222.gd123945-1
akonadiconsole22.04.0.r1586.gceaf3e7-122.04.1.r1588.gae7536c-1
akregator22.04.0.r6399.g59d1b74b-122.04.1.r6408.ga4f84fa6-1
alligator 22.04.r6.gf8bfeef-1 22.04.r9.g67ebf21-1
analitza22.04.0.r2339.g3c8c5a57-122.04.1.r2339.g3c8c5a57-1
angelfish 22.04.r13.g02918e3-1 22.04.r19.gf52caba-1
ark22.04.0.r4734.g3981425a-122.04.1.r4736.g15bccd6a-1
artikulate22.04.0.r1417.gd6f8df1-122.04.1.r1418.ge6d9441-1
attica5.93.0.r864.g3fe5414-15.94.0.r865.g735bad1-1
audiocd-kio22.04.0.r1061.gbbfe873-122.04.1.r1064.g96e5180-1
audiotube 22.04.r5.g613dd1e-1 22.04.r9.gc83d7f5-1
aura-browser r45.c96ff07-3 r47.c924414-1
baloo5.93.0.r3047.gd699c1ac-15.94.0.r3049.geaa4dbdb-1
baloo-widgets22.04.0.r742.g864bb7c-122.04.1.r744.g754c6d9-1
blinken22.04.0.r665.g8366737-122.04.1.r666.g80351c1-1
bluedevil1:5.24.5.r2391.g349f45c5-11:5.24.5.r2393.gdedbba3f-1
bluez-qt5.93.0.r709.gd393ffc-15.94.0.r710.g5a4f5ef-1
bomber22.04.0.r561.gec27fa9-122.04.1.r562.g6920357-1
bovo22.04.0.r774.gf9bb910-122.04.1.r776.g6b3cebb-1
breeze5.24.5.r2392.ga907a4aa-15.24.5.r2394.ga6188267-1
breeze-gtk5.24.5.r460.g69ddaab-15.24.5.r463.gf83845b-1
breeze-icons5.93.0.r1895.g154aabe5-15.94.0.r1896.gcaf9b8e0-1
buho 2.1.1.r5.g9f1cee6-1 2.1.1.r9.g8cdcee3-1
calamares-git3.2.57.r10688.d5a79180e-1 .r10688.d5a79180e-1
calendarsupport22.04.0.r687.gcabd1e0-122.04.1.r702.gf7b182e-1
calindori 22.04.r2.g8ad0ee8-1 22.04.r8.gf9e4438-1
cervisia22.04.0.r1661.g119ad33-122.04.1.r1664.g12571f5-1
discover5.24.5.r8647.g9e4495c9-15.24.5.r8671.ge8e13de4-1
dolphin22.04.0.r6953.g47014b26b-122.04.1.r6958.g0b27270be-1
dolphin-plugins22.04.0.r652.g2e58a9e-122.04.1.r654.gb8b6632-1
dragon22.04.0.r1031.gfc7f036-122.04.1.r1036.g3428276-1
drkonqi5.24.5.r778.gaf218d23-15.24.5.r779.g48f2e760-1
elisa22.04.0.r2952.g0242be13-122.04.1.r2964.g6463cde6-1
elisa-qtmm22.04.0.r2952.g0242be13-122.04.1.r2965.gf80d24b9-1
eventviews22.04.0.r818.g4aedf65-122.04.1.r838.g7f0fa86-1
extra-cmake-modules5.93.0.r3478.g0a624648-15.94.0.r3481.g92cac962-1
ffmpegthumbs22.04.0.r212.gfc78559-122.04.1.r215.g188a562-1
filelight22.04.0.r1104.g232c919-122.04.1.r1110.g603a966-1
frameworkintegration5.93.0.r631.g450ca3e-15.94.0.r633.ga37dcd9-1
granatier22.04.0.r974.g905ad3a-122.04.1.r975.g4b14157-1
grantlee-editor22.04.0.r820.gd7f9ba4-122.04.1.r821.gebeaf31-1
grantleetheme22.04.0.r393.gb8a3619-122.04.1.r394.g9fbdd58-1
gwenview22.04.0.r6840.g6c7ce0a5-122.04.1.r6849.g8cc4c78c-1
incidenceeditor22.04.0.r891.g9db2ace-122.04.1.r891.g9db2ace-1
index-fm 2.1.1.r14.g0f3da0b-1 2.1.1.r17.g410a56b-1
itinerary22.04.0.r1816.gaa0b455-122.04.1.r1822.gdf0f16d-1
juk22.04.0.r3141.g1a808445-122.04.1.r3142.gdbae0029-1
k3b1:22.04.0.r6772.g5c6d98c2b-11:22.04.1.r6777.gdbc9964c9-1
kaccounts-integration22.04.0.r1253.gc0d08d3-122.04.1.r1254.g6b916de-1
kaccounts-providers22.04.0.r395.gae51a37-122.04.1.r395.gae51a37-1
kactivities5.93.0.r1393.gf9f494d0-15.94.0.r1394.gd965ec3f-1
kactivities-stats5.93.0.r402.gecc54e7-15.94.0.r405.g5418265-1
kactivitymanagerd5.24.5.r1394.g9b2a05a-15.24.5.r1396.g7eec88a-1
kaddressbook22.04.0.r6162.g555540fa-122.04.1.r6168.gab0ce544-1
kajongg22.04.0.r4338.gca8b9e97-122.04.1.r4340.g031ec8c5-1
kalarm22.04.0.r7904.gd6a957ed-122.04.1.r7911.g35c49688-1
kalgebra22.04.0.r2060.g6acdb42-122.04.1.r2061.ge6aa7a2-1
kalzium22.04.0.r4321.g318a6b0c-122.04.1.r4336.ga3a03dee-1
kamera22.04.0.r712.ged6c71f-122.04.1.r713.gef84f7a-1
kamoso22.04.0.r1456.g4c6f238-122.04.1.r1459.g2bac85a-1
kanagram22.04.0.r1308.gad84640-122.04.1.r1309.gca259de-1
kapidox5.93.0.r569.gdd1470c-15.94.0.r571.g9d0fffa-1
kapman22.04.0.r648.gf4852a9-122.04.1.r649.g6d297f7-1
kapptemplate22.04.0.r988.g9337cd3-122.04.1.r990.g95e97f3-1
karchive5.93.0.r538.gf63a2ba-15.94.0.r539.g606d862-1
kasts 22.04.r3.gcb9000f-1 22.04.r10.gf0bab73-1
kate22.04.0.r19009.ga9674c261-122.04.1.r19023.g6db5a71ac-1
katomic22.04.0.r956.ga57f1de-122.04.1.r957.gf023528-1
kauth5.93.0.r497.g7881fd7-15.94.0.r498.g4e32555-1
kbackup22.04.0.r431.g1698d87-122.04.1.r432.gc7f65c1-1
kblackbox22.04.0.r763.gd93f264-122.04.1.r764.g76662e9-1
kblocks22.04.0.r710.gebe3797-122.04.1.r711.g7228f93-1
kbookmarks5.93.0.r458.g144d69f-15.94.0.r459.g749d823-1
kbounce22.04.0.r845.g9d83f73-122.04.1.r846.g9457f55-1
kbreakout22.04.0.r911.gd6c874b-122.04.1.r913.g15d19ab-1
kbruch22.04.0.r860.g536b1a8-122.04.1.r862.ga350245-1
kcachegrind22.04.0.r1177.g8269eb6-122.04.1.r1178.g26c0cec-1
kcachegrind-common22.04.0.r1177.g8269eb6-122.04.1.r1178.g26c0cec-1
kcalc22.04.0.r1608.ge88662c-122.04.1.r1610.g3f94af6-1
kcalendarcore5.93.0.r1314.g770ece2db-15.94.0.r1315.g71ecc4421-1
kcalutils22.04.0.r957.g56f47990d-122.04.1.r963.g0f2359231-1
kcharselect22.04.0.r521.gfd7f2ca-122.04.1.r523.g41f2f44-1
kclock 22.04.r2.gab6b2a0-1 22.04.r11.gd5cd85a-1
kcmutils5.93.0.r625.gbc3c3bc-15.94.0.r633.gaf57bca-1
kcodecs5.93.0.r418.gdd64b09-15.94.0.r419.gaa3d702-1
kcolorchooser22.04.0.r264.gdac265d-122.04.1.r266.gb9094eb-1
kcompletion5.93.0.r492.g3f68837-15.94.0.r493.g3fbc676-1
kconfig5.93.0.r950.g893376f6-15.94.0.r954.ge4d19066-1
kconfigwidgets5.93.0.r729.g906190b-15.94.0.r734.g0deb1de-1
kcontacts1:5.93.0.r3330.g656afdbc-11:5.94.0.r3333.gb2946319-1
kcoreaddons5.93.0.r1467.g8347d2f5-15.94.0.r1478.g9e26ee97-1
kcrash5.93.0.r443.ge0e1410-15.94.0.r445.gee91713-1
kcron22.04.0.r841.g0e3d815-122.04.1.r841.g0e3d815-1
kdav1:5.93.0.r1340.ge7c525e-11:5.94.0.r1341.g98c1a18-1
kdbusaddons5.93.0.r411.g37a701f-15.94.0.r413.g3e3dbcb-1
kde-cli-tools5.24.5.r1932.g78789e3-15.24.5.r1933.ge3fdf1e-1
kde-dev-scripts22.04.0.r4145.g06765a6-122.04.1.r4145.g06765a6-1
kde-dev-utils22.04.0.r581.g750ebd1-122.04.1.r583.g03c5b1a-1
kde-gtk-config5.24.5.r926.g9929926-15.24.5.r930.g687ee79-1
kdebugsettings22.04.0.r918.g55546ea-122.04.1.r920.gb063fbc-1
kdeclarative5.93.0.r990.g23209c6-15.94.0.r994.g07b1e86-1
kdeconnect22.04.0.r3437.g77047268-122.04.1.r3442.gbee030fc-1
kded5.93.0.r458.gf66f2c3-15.94.0.r460.gbf1c2be-1
kdeedu-data22.04.0.r16.g8312b2d-122.04.1.r17.g1b749b8-1
kdegraphics-mobipocket22.04.0.r269.gf32ff03-122.04.1.r270.g8a94719-1
kdegraphics-thumbnailers22.04.0.r262.g501484e-122.04.1.r264.g757fb9c-1
kdelibs4support5.93.0.r1080.gfd7ccadb-15.94.0.r1085.gd992e20b-1
kdenetwork-filesharing22.04.0.r928.ga286e81-122.04.1.r929.gdc85116-1
kdenlive22.04.0.r16042.g98052eb4d-122.04.1.r16060.gd84fa82f7-1
kdepim-addons22.04.0.r4628.geac1649d9-122.04.1.r4638.gd54d5510e-1
kdepim-runtime22.04.0.r15507.g38018e4c1-122.04.1.r15516.ge3a69e539-1
kdeplasma-addons5.24.5.r8784.g41c8267ad-15.24.5.r8793.gc1f182862-1
kdesdk-kioslaves22.04.0.r502.g633726e-122.04.1.r502.g633726e-1
kdesdk-thumbnailers22.04.0.r88.g1092504-122.04.1.r89.g068d9d1-1
kdesignerplugin5.93.0.r352.gfe65895-15.94.0.r353.g8d42012-1
kdesu5.93.0.r505.g6c69c07-15.94.0.r506.g5a84e16-1
kdewebkit5.93.0.r299.g1beed50-15.94.0.r300.gc530140-1
kdf22.04.0.r851.g36787de-122.04.1.r852.gf5c7650-1
kdialog22.04.0.r1212.g146f1cf1c-122.04.1.r1214.g84db6eb7d-1
kdiamond22.04.0.r721.ga057509-122.04.1.r723.g8c95cba-1
kdnssd5.93.0.r348.g9a734c5-15.94.0.r349.g10b41e7-1
kdoctools5.93.0.r657.g50d53ec-15.94.0.r658.g64b5339-1
keditbookmarks22.04.0.r2762.gc70a7d063-122.04.1.r2763.g84e6abb45-1
kemoticons5.93.0.r410.g974fe55-15.94.0.r412.g54baefa-1
keysmith 22.04.r1.g0b5fdbe-1 22.04.r5.gbacea75-1
kfilemetadata5.93.0.r860.g8d4d411-15.94.0.r861.g1ca01a7-1
kfind22.04.0.r2679.g426228e1d-122.04.1.r2682.gcc6601cb4-1
kfloppy22.04.0.r792.gc7c198f-122.04.1.r793.gbdac023-1
kfourinline22.04.0.r1020.g5f89df0-122.04.1.r1024.g9bbc3f0-1
kgamma55.24.5.r472.g9025840-15.24.5.r473.ge593e27-1
kgeography22.04.0.r1155.g87eaa17-122.04.1.r1156.ga2c1e95-1
kget22.04.0.r3188.gf98b8248-122.04.1.r3191.g1f1876c7-1
kglobalaccel5.93.0.r512.g2eff290-15.94.0.r514.g633fe86-1
kgoldrunner22.04.0.r1277.g9c9c765-122.04.1.r1278.g34a975a-1
kgpg22.04.0.r3184.g5f9fe70e-122.04.1.r3186.g574f1c4d-1
kguiaddons5.93.0.r460.g4392268-15.94.0.r464.gd7402db-1
khangman22.04.0.r1600.g2080240-122.04.1.r1601.g0a9af72-1
khealthcertificate 22.04.r2.ga1608c1-1 22.04.r5.g004d4d4-1
khelpcenter22.04.0.r2736.ge189841a-122.04.1.r2738.gb7276f90-1
kholidays1:5.93.0.r1032.ge59e1fb-11:5.94.0.r1033.g37e6565-1
khotkeys5.24.5.r2126.g0a74984-15.24.5.r2129.g58171c2-1
khtml5.93.0.r581.gfbc98d0-15.94.0.r582.g3468d5f-1
ki18n5.93.0.r552.gbabae50-15.94.0.r553.g62121fc-1
kiconthemes5.93.0.r597.gb600890-15.94.0.r599.g389af6a-1
kidentitymanagement22.04.0.r3885.g295094e7-122.04.1.r3887.g1c7d1b8b-1
kidletime5.93.0.r354.gbdd25b5-15.94.0.r355.g4fd7c98-1
kig22.04.0.r3182.g0d804a75-122.04.1.r3185.g3d2e2e8c-1
kigo22.04.0.r561.g9b57f65-122.04.1.r563.gb663e27-1
killbots22.04.0.r782.gb229ce4-122.04.1.r784.g04236a4-1
kimageformats5.93.0.r399.g52134fc-15.94.0.r402.gebcc345-1
kimagemapeditor22.04.0.r486.g3006809-122.04.1.r488.ga654793-1
kimap22.04.0.r1188.ga6a5fb4-122.04.1.r1189.g21ff886-1
kinfocenter5.24.5.r2077.ge32ff979-15.24.5.r2079.g2c7a3694-1
kinit5.93.0.r434.g2735784-15.94.0.r435.g3101b1d-1
kio5.93.0.r5427.g4d820eebb-15.94.0.r5459.gc11e99a49-1
kio-extras22.04.0.r7235.g35c8637f-122.04.1.r7239.g3638f589-1
kio-gdrive22.04.0.r596.gc51f5d9-122.04.1.r598.gf970418-1
kirigami-gallery22.04.0.r238.g8b2a1ca-122.04.1.r239.ga0c5568-1
kirigami25.93.0.r3116.g607f02b8-15.94.0.r3133.g88c572b4-1
kiriki22.04.0.r450.ga635e3d-122.04.1.r450.ga635e3d-1
kitemmodels5.93.0.r605.ge915650-15.94.0.r606.g8457927-1
kitemviews5.93.0.r369.gdfbf6f8-15.94.0.r370.g8cd9580-1
kiten22.04.0.r1183.ga08ea23-122.04.1.r1184.g2c622ae-1
kitinerary22.04.0.r2175.gea213ec-122.04.1.r2184.gc9cecdc-1
kjobwidgets5.93.0.r413.g764bb7f-15.94.0.r414.g307dbce-1
kjs5.93.0.r360.g4243416-15.94.0.r361.gcbe7055-1
kjsembed5.93.0.r324.g78971b8-15.94.0.r325.ga813cb8-1
kjumpingcube22.04.0.r823.g17122ff-122.04.1.r823.g17122ff-1
kldap22.04.0.r947.gb74c9fd-122.04.1.r947.gb74c9fd-1
kleopatra22.04.0.r6402.ge94a4f7e-122.04.1.r6432.g3e64320a-1
klettres22.04.0.r958.g58ed1a5-122.04.1.r959.g96e9f69-1
klickety22.04.0.r670.gfb08802-122.04.1.r671.gb3fef15-1
klines22.04.0.r810.gfcd3c88-122.04.1.r811.g64d9b4a-1
kmag22.04.0.r733.g8bf8b40-122.04.1.r734.g744b1d5-1
kmahjongg22.04.0.r1525.gb1597dd-122.04.1.r1527.gaa2ab6f-1
kmail22.04.0.r26354.g4f956ced5-122.04.1.r26366.ga398a78c1-1
kmail-account-wizard22.04.0.r881.g1cb9994-122.04.1.r882.g5b6714c-1
kmailtransport22.04.0.r1739.gf2caaf5-122.04.1.r1740.g8aad2c6-1
kmbox22.04.0.r594.gcb3a986-122.04.1.r595.g18c65a3-1
kmediaplayer5.93.0.r315.gb48fbd0-15.94.0.r316.g7df07d1-1
kmime22.04.0.r1512.gb2fc3cb-122.04.1.r1512.gb2fc3cb-1
kmines22.04.0.r1763.g293326e-122.04.1.r1764.g423ef92-1
kmix22.04.0.r2445.g1edbea3e-122.04.1.r2449.g969b5f23-1
kmousetool22.04.0.r432.g1b9c2c9-122.04.1.r435.gb82ac74-1
kmouth22.04.0.r721.g65c4778-122.04.1.r722.g8709521-1
kmplot22.04.0.r1487.g0b5922a-122.04.1.r1488.g828fdc5-1
knavalbattle22.04.0.r1425.g30177a5-122.04.1.r1427.gf01b240-1
knetwalk22.04.0.r694.gbd4bca8-122.04.1.r695.ge900c4a-1
knewstuff5.93.0.r1329.g836a7b80-15.94.0.r1333.g667327a6-1
knights22.04.0.r1125.gfaa996a-122.04.1.r1130.g2f0f72a-1
knotes22.04.0.r3644.g48b40e65-122.04.1.r3653.g39257fed-1
knotifications5.93.0.r734.g36910d5-15.94.0.r736.g7b9aea6-1
knotifyconfig5.93.0.r380.g474a45f-15.94.0.r381.g151f62c-1
koko 22.04.r3.gaca9166-1 22.04.r12.gab1e5bc-1
kolf22.04.0.r1493.g30e6741-122.04.1.r1495.g2d75b5d-1
kollision22.04.0.r531.g9448d47-122.04.1.r532.g1cab48e-1
kolourpaint22.04.0.r2400.g82149b32-122.04.1.r2403.gb2416163-1
kompare22.04.0.r1134.gdca5563-122.04.1.r1135.gb8f9e36-1
kongress 22.04.r2.ga3fed48-1 22.04.r6.ga14c118-1
konqueror22.04.0.r15100.ge2b8e2d46-122.04.1.r15106.g7efa0d97a-1
konquest22.04.0.r925.gee6f566-122.04.1.r928.g38b8460-1
konsole22.04.0.r8352.gc2c2f8a0-122.04.1.r8358.gc88c123f-1
kontact22.04.0.r5511.g41806d4f-122.04.1.r5514.g8a14fae1-1
kontactinterface22.04.0.r680.g138b847-122.04.1.r684.g1683244-1
kontrast22.04.0.r200.gc2bef9b-122.04.1.r201.gc4ca5e4-1
konversation22.04.0.r9106.g9a4d6e6a-122.04.1.r9107.gbbdeca71-1
kopeninghours22.04.0.r330.gdb6b104-122.04.1.r330.gdb6b104-1
kopete22.04.0.r16422.g39d0e2d82-122.04.1.r16425.g6eddda540-1
korganizer22.04.0.r11688.g9fc825f31-122.04.1.r11696.g19cfd18ee-1
kosmindoormap22.04.0.r729.g8f0d3eb-122.04.1.r730.gb18a5ca-1
kpackage5.93.0.r746.g791d8d3-15.94.0.r749.g18a78cf-1
kparts5.93.0.r581.gd515a3c-15.94.0.r583.gca07315-1
kpat22.04.0.r2609.g5872b857-122.04.1.r2612.g6588eaa0-1
kpeople5.93.0.r1373.g192254e-15.94.0.r1374.g2ebb48c-1
kpimtextedit22.04.0.r1590.g8a1b22b-122.04.1.r1591.g9fc3ac6-1
kpkpass22.04.0.r295.gb50573a-122.04.1.r296.ge1e2625-1
kplotting5.93.0.r321.gad0c611-15.94.0.r322.g4bfe58d-1
kpmcore22.04.0.r1280.gd247e02-122.04.1.r1283.gfd4a330-1
kpty5.93.0.r371.gc1fcde6-15.94.0.r372.g8488c2f-1
kpublictransport22.04.0.r2008.g6de7af9a-122.04.1.r2009.g2b831f73-1
kqtquickcharts22.04.0.r75.g188b79d-122.04.1.r75.g188b79d-1
kquickcharts5.93.0.r516.gecd6deb-15.94.0.r517.g3c721a6-1
krdc22.04.0.r1588.g71c0581-122.04.1.r1590.g8c38078-1
krecorder 22.04.r4.g9c6ef50-1 22.04.r12.g16bfbe3-1
kreversi22.04.0.r1262.gfe10b13-122.04.1.r1265.g3352f57-1
krfb22.04.0.r1487.gf1da762-122.04.1.r1489.g6f1d60b-1
kross5.93.0.r356.gf26bbc1-15.94.0.r357.ge05a14d-1
kross-interpreters22.04.0.r724.g2a6213a-122.04.1.r724.g2a6213a-1
kruler22.04.0.r732.g1bdf0a4-122.04.1.r733.g15e0b0e-1
krunner5.93.0.r746.g1f1d5c0-15.94.0.r753.g137c9d0-1
kscreen5.24.5.r1447.g15056b9-15.24.5.r1450.g09908d8-1
kscreenlocker5.24.5.r933.gbdf08b1-15.24.5.r939.g4485c8c-1
kservice5.93.0.r1006.g3ee50d4-15.94.0.r1007.g77e24c0-1
kshisen22.04.0.r1236.g9ac4258-122.04.1.r1238.g3c95ec1-1
ksirk22.04.0.r1015.gd5a6ecc-122.04.1.r1021.ge38aebe-1
ksmtp22.04.0.r446.g56c9d3a-122.04.1.r446.g56c9d3a-1
ksnakeduel22.04.0.r842.gdba5cb4-122.04.1.r843.g484b81f-1
kspaceduel22.04.0.r668.g5803b53-122.04.1.r669.g68bfd25-1
ksquares22.04.0.r555.ga77eec8-122.04.1.r556.gecb4a1b-1
ksudoku22.04.0.r1104.g9eef6a0-122.04.1.r1107.gd4ee434-1
ksysguard5.24.5.r3527.g201f9174-15.24.5.r3529.g7b55ce26-1
ksystemlog22.04.0.r721.ge731263-122.04.1.r723.g7012513-1
ksystemstats5.24.5.r223.g43dc782-15.24.5.r224.g679c508-1
kteatime22.04.0.r752.gfea14d1-122.04.1.r753.gf947215-1
ktexteditor5.93.0.r3353.gb06e6b0f-15.94.0.r3403.gdf44da08-1
ktextwidgets5.93.0.r445.ga7e170e-15.94.0.r446.g806cb54-1
ktimer22.04.0.r510.g75822fc-122.04.1.r511.g57b450a-1
ktnef22.04.0.r716.g4bb7ebb-122.04.1.r716.g4bb7ebb-1
ktorrent22.04.0.r2841.gbe32bddf-122.04.1.r2844.g2e0aa9e3-1
ktouch22.04.0.r2176.g8cbf36e-122.04.1.r2177.g52883f6-1
ktrip 22.04.r2.g0ef33c8-1 22.04.r5.g395c735-1
ktuberling22.04.0.r1038.g2702133-122.04.1.r1039.g39154ce-1
kturtle22.04.0.r1160.g8159849-122.04.1.r1163.ga445e43-1
kubrick22.04.0.r400.g650ce3f-122.04.1.r404.g318140e-1
kunitconversion5.93.0.r413.g947a8eb-15.94.0.r414.g9c78b76-1
kwallet5.93.0.r1143.g6cc6174-15.94.0.r1145.gc6275eb-1
kwallet-pam5.24.5.r264.g2da1635-15.24.5.r266.gbc69453-1
kwalletmanager22.04.0.r1269.g93197cb-122.04.1.r1269.g93197cb-1
kwave22.04.0.r3776.g4492edfb-122.04.1.r3785.gdf5832a0-1
kwayland5.93.0.r1155.g95536cc-15.94.0.r1159.g70eb1df-1
kweather 22.04.r3.gb6b6b5f-1 22.04.r12.gafc5508-1
kweathercore 0.5.r12.gf738a7b-1 0.5.r22.g807fda7-1
kwidgetsaddons5.93.0.r932.g5534343e-15.94.0.r939.gaf36ab53-1
kwin5.24.5.r22374.gfa36628a8-15.24.5.r22463.g2178f26e7-1
kwindowsystem5.93.0.r677.gd861023-15.94.0.r678.g0b71d76-1
kwinft5.24.5.r20594.gf9b2f9b3f-15.24.5.r20608.gc6af0068f-1
kwordquiz22.04.0.r1177.g2290976-122.04.1.r1179.g6d0e584-1
kwrite22.04.0.r19009.ga9674c261-122.04.1.r19023.g6db5a71ac-1
kwrited5.24.5.r503.g4bba2da-15.24.5.r504.g4050519-1
kxmlgui5.93.0.r871.ge556c39d-15.94.0.r874.g9dd91dca-1
kxmlrpcclient5.93.0.r478.ga00e63b16-15.94.0.r479.g1cd5f0394-1
layer-shell-qt5.24.4.r55.gae883df-15.24.5.r56.g345676a-1
libakonadi22.04.0.r12724.ged9c5c991-122.04.1.r12734.g29e357458-1
libgravatar22.04.0.r422.g5713bc5-122.04.1.r422.g5713bc5-1
libkcddb22.04.0.r759.g117d30f-122.04.1.r760.gb00105a-1
libkcompactdisc22.04.0.r394.g45a78f3-122.04.1.r395.g88be8fe-1
libkdcraw22.04.0.r1153.ga4a99cf-122.04.1.r1153.ga4a99cf-1
libkdegames22.04.0.r2231.g7ff26535-122.04.1.r2232.g63969b23-1
libkdepim22.04.0.r905.gf1e0ff4-122.04.1.r906.g538cba3-1
libkeduvocdocument22.04.0.r1810.g5b20cc7-122.04.1.r1810.g5b20cc7-1
libkexiv222.04.0.r820.g601c27d-122.04.1.r821.gcee9d6e-1
libkgapi22.04.0.r1357.g71ab68a-122.04.1.r1359.g4c38fd1-1
libkipi22.04.0.r1276.gf61a329-122.04.1.r1278.g4ec0a9a-1
libkleo22.04.0.r1147.g343b5bb-122.04.1.r1148.ga7653ca-1
libkmahjongg22.04.0.r479.g398fb7f-122.04.1.r480.g3e0bb8d-1
libkomparediff222.04.0.r342.gf465f1a-122.04.1.r342.gf465f1a-1
libksane22.04.0.r595.gd3e7150-122.04.1.r595.gd3e7150-1
libkscreen5.24.5.r1622.g85780ca-15.24.5.r1623.g167b699-1
libksieve22.04.0.r1696.gf4402fb3-122.04.1.r1696.gf4402fb3-1
libksysguard5.24.5.r2390.g587fff4-15.24.5.r2395.g3456133-1
libktorrent22.04.0.r547.gcc058bb-122.04.1.r547.gcc058bb-1
lokalize22.04.0.r1817.g5a6e40f9-122.04.1.r1818.ge534a6f0-1
lskat22.04.0.r846.g577986e-122.04.1.r847.g22bcb47-1
mailcommon22.04.0.r1233.g16fc04a-122.04.1.r1235.g93ee65d-1
mailimporter22.04.0.r517.g86da4a4-122.04.1.r518.g8e469d3-1
maliit-framework2.2.1.r18.g779a9471-12.2.1.r20.gfe0a5d7f-1
maliit-keyboard2.2.1.1.r0.gae81a17b-12.2.1.1.r13.g4c07f7a2-1
marble22.04.0.r13429.gff2ded2d8-122.04.1.r13432.g2361f898f-1
marble-common22.04.0.r13429.gff2ded2d8-122.04.1.r13432.g2361f898f-1
marble-qt22.04.0.r13429.gff2ded2d8-122.04.1.r13432.g2361f898f-1
markdownpart22.04.0.r112.ga2459a6-122.04.1.r115.g56a0932-1
maui-clip 2.1.1.r3.gd083bfa-1 2.1.1.r9.g22418d5-1
maui-nota 2.1.1.r19.gd99c39d-1 2.1.1.r23.gc51d7c9-1
maui-pix 2.1.0.r23.g9a7ce1c-1 2.1.0.r32.g357b7ba-1
maui-shell 0.5.0.r17.gdf25c04-1 0.5.0.r24.g160acae-1
mauikit2.1.1.r19.g702845e6-12.1.1.r32.g535bd57e-1
mbox-importer22.04.0.r565.g37c3735-122.04.1.r566.gf165139-1
messagelib22.04.0.r6481.g15e6585b3-122.04.1.r6535.gf29c5b553-1
milou5.24.5.r769.gbc9b438-15.24.5.r770.g0dbf227-1
minuet22.04.0.r604.g7352285-122.04.1.r608.g8c15a22-1
modemmanager-qt5.93.0.r552.g31cec82-15.94.0.r553.g1dba164-1
mycroft-skill-installer r89.118828a-3 r90.18c228b-1
neochat 22.04.r4.gb64cd3c1-122.04.r30.gb994907b-1
networkmanager-qt5.93.0.r1151.g74b8f39-15.94.0.r1152.g99619ac-1
okular22.04.0.r9718.g7c596be34-122.04.1.r9725.ge8d5f24ad-1
oxygen5.24.5.r4465.gdfc60756-15.24.5.r4466.ge1babdde-1
oxygen-icons1:5.93.0.r5.gbff159d-11:5.94.0.r5.gbff159d-1
oxygen-icons-svg1:5.93.0.r5.gbff159d-11:5.94.0.r5.gbff159d-1
palapeli22.04.0.r1273.gd3ff3ac-122.04.1.r1277.g59d3cc6-1
parley22.04.0.r4512.g970c9a6c-122.04.1.r4516.g0df1d7dc-1
partitionmanager22.04.0.r1613.gcdc7ffc-122.04.1.r1615.gc5609fe-1
picmi22.04.0.r561.g09b785d-122.04.1.r561.g09b785d-1
pim-data-exporter22.04.0.r2659.g59505fd5-122.04.1.r2664.g6a6ec3d4-1
pim-sieve-editor22.04.0.r1620.geb530c9-122.04.1.r1624.geaba7a3-1
pimcommon22.04.0.r1218.gd6f0a7b-122.04.1.r1221.g0ff8128-1
plank-player r25.0b1acfb-1 r26.fb747e3-1
plasma-bigscreen r466.gb9b302e-3 r467.g7e79edc-1
plasma-desktop5.24.5.r9236.g549ec82fd-15.24.5.r9259.gdad8082ee-1
plasma-dialer 22.04.r6.gbef9fb6-1 22.04.r15.g280861e-1
plasma-disks5.24.5.r267.gc431831-15.24.5.r269.g70787f1-1
plasma-firewall5.24.5.r618.ge4b0126-15.24.5.r620.g3515962-1
plasma-framework5.93.0.r16277.ga05965f06-15.94.0.r16300.g12d5943b0-1
plasma-mobile5.24.5.r1753.gfc300d1a2-15.24.5.r1765.g4c83a3e42-1
plasma-mobile-nm5.24.5.r3238.ga129817a-15.24.5.r3239.gba895483-1
plasma-nano5.24.5.r181.gce97791-15.24.5.r182.g12a8821-1
plasma-nm5.24.5.r3238.ga129817a-15.24.5.r3239.gba895483-1
plasma-pa5.24.5.r1048.gabf787c-15.24.5.r1050.g47f8338-1
plasma-phonebook 22.04.r2.g17b3e1b-1 22.04.r8.gc5c190b-1
plasma-sdk5.24.5.r2341.g5bcff9c1-15.24.5.r2346.ga421f566-1
plasma-settings 22.04.r6.g58dd132-1 22.04.r18.ga21db05-1
plasma-systemmonitor5.24.5.r562.g5f0ee57-15.24.5.r567.g0ca0b4f-1
plasma-vault5.24.5.r378.g38603f5-15.24.5.r379.g94d2ab3-1
plasma-wayland-protocols1.4.0.r1048.g129263b-11.4.0.r1053.g26fb07b-1
plasma-wayland-session5.24.5.r11706.g13e1ddcf9-15.24.5.r11764.gad1a51c83-1
plasma-workspace5.24.5.r11706.g13e1ddcf9-15.24.5.r11764.gad1a51c83-1
plasmatube 22.04.r3.g5503113-1 22.04.r6.gbbc43e8-1
powerdevil5.24.5.r2537.gce15edd2-15.24.5.r2538.ga3225694-1
poxml22.04.0.r281.g183b2c7-122.04.1.r281.g183b2c7-1
print-manager22.04.0.r1124.g5966b21-122.04.1.r1125.g631b086-1
prison5.93.0.r371.gc5a70fc-15.94.0.r375.g71384bf-1
pulseaudio-qt 1.3.0.r19.g38a3558-1 1.3.0.r21.gade2151-1
purpose5.93.0.r966.g41bd964-15.94.0.r968.g20591ed-1
qcachegrind22.04.0.r1177.g8269eb6-122.04.1.r1178.g26c0cec-1
qmlkonsole 22.04.r11.g6199fee-1 22.04.r19.g355754d-1
qqc2-desktop-style5.93.0.r597.g19e30c1-15.94.0.r598.gb5c335d-1
rocs22.04.0.r3072.g913fe2d7-122.04.1.r3075.g22396c4b-1
sddm-kcm5.24.5.r646.g0ed6926-15.24.5.r647.g2ea254d-1
signon-kwallet-extension22.04.0.r79.g87b0c1e-122.04.1.r79.g87b0c1e-1
solid5.93.0.r766.g1f0c29b-15.94.0.r768.g626fa4a-1
sonnet5.93.0.r687.ga5ce28a-15.94.0.r693.g7d98576-1
spacebar 22.04.r2.gf117f55-1 22.04.r6.g0fcbe67-1
spectacle22.04.0.r1342.gb332b57-122.04.1.r1345.gedbe920-1
step22.04.0.r1182.g6a6edd3-122.04.1.r1185.gebaf6cb-1
svgpart22.04.0.r214.g53cd08d-122.04.1.r215.gf36061c-1
sweeper22.04.0.r563.g8f9ea8e-122.04.1.r567.gc6b8472-1
syndication5.93.0.r870.gdbeaf26-15.94.0.r871.g01aacf0-1
syntax-highlighting5.93.0.r1829.g42a061b0-15.94.0.r1830.g12e610d0-1
systemsettings5.24.5.r2650.g2b5f723c-15.24.5.r2656.ge373a9a9-1
telepathy-kde-accounts-kcm22.04.0.r1211.ga82a68a-122.04.1.r1211.ga82a68a-1
telepathy-kde-approver22.04.0.r301.g420e8ac-122.04.1.r302.gf9aae9d-1
telepathy-kde-auth-handler22.04.0.r282.ga240a20-122.04.1.r282.ga240a20-1
telepathy-kde-call-ui22.04.0.r448.gf01f09a-122.04.1.r448.gf01f09a-1
telepathy-kde-common-internals22.04.0.r2010.g48a8c04-122.04.1.r2010.g48a8c04-1
telepathy-kde-contact-list22.04.0.r1090.g58353ef-122.04.1.r1090.g58353ef-1
telepathy-kde-contact-runner22.04.0.r258.gd1d25e2-122.04.1.r258.gd1d25e2-1
telepathy-kde-desktop-applets22.04.0.r1000.g135606f-122.04.1.r1000.g135606f-1
telepathy-kde-filetransfer-handler22.04.0.r225.g3958b9e-122.04.1.r225.g3958b9e-1
telepathy-kde-integration-module22.04.0.r399.gfed9154-122.04.1.r399.gfed9154-1
telepathy-kde-send-file22.04.0.r234.gae2a4de-122.04.1.r234.gae2a4de-1
telepathy-kde-text-ui22.04.0.r2037.g6695846-122.04.1.r2037.g6695846-1
threadweaver5.93.0.r538.g1c94a42-15.94.0.r539.g557d9bd-1
tokodon 22.04.r3.g37e95c6-1 22.04.r26.gce37bc5-1
umbrello22.04.0.r8455.g9c517800e-122.04.1.r8461.g253f318d7-1
vakzination 22.04.r6.g74a99e5-1 22.04.r13.g7b4f3db-1
vvave 2.1.1.r13.g1407d5f-1 2.1.1.r22.geb01109-1
xdg-desktop-portal-kde5.24.4.r469.gf781751-15.24.5.r477.gf15399f-1
yakuake22.04.0.r788.gc9bf101-122.04.1.r790.g554ca4b-1
zeroconf-ioslave22.04.0.r377.g70ae6cc-122.04.1.r378.gd6a38e6-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
