Hello ARM community.
A smaller update this time around, getting ready for the next stable update.
Some highlights:
- Most of our kernels got updated
- Gnome 42.1 is here
- And Mesa got updated to 22.0.2
- Pipewire also got a small update to 0.3.51
- Our CPU Temp Speed script got a big update to now support multiple cores
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Sun May 1 18:03:35 CEST 2022)
- arm-testing community aarch64: 488 new and 477 removed package(s)
- arm-testing core aarch64: 54 new and 53 removed package(s)
- arm-testing extra aarch64: 159 new and 158 removed package(s)
- arm-testing kde-unstable aarch64: 171 new and 171 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-04-25 2022-05-01
chatty 0.6.2+9+ge2f4ed16-1 0.6.4-1
code 1.66.1-1 1.66.2-1
cpu-temp-speed 20200118-1 20220428-1
electron 18.1.0-1 18.2.0-1
electron15 15.5.2-1 15.5.3-1
electron16 16.2.3-1 16.2.4-1
electron17 17.4.1-1 17.4.2-1
element-desktop 1.10.10-1 1.10.11-1
element-web 1.10.10-1 1.10.11-1
evince-mobile 40.1-1 42.1-1
gnome-calendar-mobile 41.2-1 41.2-2
gnome-calls 42rc1-1 42.0-1
gnome-clocks-mobile 41.0-1 41.0-2
gnome-contacts-mobile 41.0-1 41.0-2
gnome-control-center-mobile 41.4-1 42.1-4
gnome-initial-setup-mobile 41.0-1 42.1.1-2
osmin 1.8.6-1 1.8.7-1
phoc 0.13.1+9+g60a12f1-2 0.13.1+22+g8d3f7a0-1
phosh0.17.0+136+g67c1ba40-10.17.0+138+gd900b66d-2
pika-backup 0.4.0.beta.4-10.4.0+beta.5+1+gcb65d8c-1
raspberrypi-userland-aarch64-git r827.14b90ff-1 r833.c4fd1b8-1
rpi-eeprom 20220310-1 20220428-1
snapd 2.55.3-1 2.55.4-1
:: Different sync package(s) in repository community aarch64
acorn 1:8.7.0-1 1:8.7.1-1
activity-log-manager 0.9.7-8 0.9.7-9
aerc 0.9.0-1 0.9.0-2
age 1.0.0-4 1.0.0-5
ali 0.7.5-1 0.7.5-2
alicloud-vault 1.3.4-1 1.3.4-2
almanah 0.12.3-3 0.12.3-4
amfora 1.9.2-1 1.9.2-2
ansible 5.6.0-1 5.7.0-1
ansible-core 2.12.4-1 2.12.5-1
ansible-lint 6.0.2-4 6.0.2-5
apache-orc 1.7.3-1 1.7.3-2
apptainer 1.0.1-1 1.0.1-2
arcus 4.13.1-1 4.13.1-2
arduino-builder 1.6.1-1 1.6.1-2
argocd 2.3.3-1 2.3.3-2
arrow 6.0.1-7 7.0.0-4
autorandr 1.12.1-1 1.12.1-2
aws-vault 6.6.0-1 6.6.0-2
awxkit 20.1.0-1 21.0.0-1
babeld 1.10-1 1.11-1
bat 0.20.0-1 0.20.0-2
bettercap 2.32.0-1 2.32.0-2
bitcoin-cli 22.0-2 23.0-1
bitcoin-daemon 22.0-2 23.0-1
bitcoin-qt 22.0-2 23.0-1
bitcoin-tx 22.0-2 23.0-1
bitwarden-cli 1.22.0-1 1.22.1-2
borgmatic 1.5.24-1 1.6.0-1
broot 1.11.1-1 1.11.1-2
browserpass 3.0.10-1 3.0.10-2
buildah 1.25.1-1 1.25.1-2
buildkit 0.10.1-1 0.10.2-1
buoh 0.8.2-14 0.8.2-15
byobu 5.133-2 5.133-3
capstone 4.0.2-5 4.0.2-6
cargo-c 0.9.8-1 0.9.9-1
cargo-edit 0.9.0-1 0.9.0-2
cfssl 1.6.1-2 1.6.1-3
chafa 1.8.0-1 1.10.1-1
charm 0.11.0-1 0.12.0-1
chezmoi 2.15.1-1 2.15.1-2
chuck 1.4.1.0-1 1.4.1.0-2
clementine1.4.0rc1+776+gcefe81d0c-11.4.0rc1+776+gcefe81d0c-2
cockatrice 2.8.0-7 2.8.0-8
cockpit 267-1 268.1-1
cockpit-machines 266-1 267-1
cockpit-pcp 267-1 268.1-1
cockpit-podman 46-1 47-1
codeblocks 17.12-10 20.03-2
coin 4.0.0.f4e446-2 4.0.0.f4e446-3
containerd 1.6.2-1 1.6.3-1
cri-o 1.23.2-1 1.23.2-2
croc 9.5.3-1 9.5.3-2
crun 1.4.4-1 1.4.5-1
cue 0.4.2-1 0.4.2-2
curaengine 4.13.1-1 4.13.1-2
curlie 1.6.9-1 1.6.9-2
dart-sass 1.50.1-1 1.51.0-1
dbmate 1.15.0-1 1.15.0-2
dht 0.26-3 0.27-1
diffoscope 210-1 211-1
difftastic 0.27.0-1 0.28.0-2
dillo 3.0.5-10 3.0.5-11
direnv 2.31.0-1 2.31.0-2
dnf 4.11.1-1 4.12.0-1
docker-compose 2.4.1-1 2.5.0-1
doctl 1.73.0-1 1.73.1-2
dog 0.1.0-2 0.1.0-3
dpdk 21.11-2 22.03-1
drone 2.11.1-1 2.11.1-2
drone-cli 1.5.0-1 1.5.0-2
drone-oss 2.11.1-1 2.11.1-2
drone-runner-docker 1.8.1-1 1.8.1-2
drone-runner-exec 1.0.0beta.9-3 1.0.0.beta.9-4
drone-runner-ssh 1.0.1-3 1.0.1-4
drumkv1 0.9.25-1 0.9.25-2
duf 0.8.1-1 0.8.1-2
dune 3.1.0-1 3.1.1-1
editorconfig-checker 2.4.0-2 2.4.0-3
elementary-icon-theme 6.1.0-2 7.0.0-1
elvish 0.18.0-1 0.18.0-2
emacs-nox 27.2-1 -
entityx 1.3.0-2 1.3.0-3
etherwall 3.0.3-2 3.0.3-3
featherpad 1.1.1-1 1.2.0-2
fetchmail 6.4.29-1 6.4.30-1
filemanager-actions 3.4-5 3.4-6
firewalld 1.0.3-3 1.1.1-1
flint 2.8.4-1 2.8.5-1
focuswriter 1.7.6-2 1.7.6-3
foot 1.11.0-2 1.12.1-1
foot-terminfo 1.11.0-2 1.12.1-1
fq 0.0.6-1 0.0.6-2
freerdp 2:2.6.1-3 2:2.7.0-1
fscrypt 0.3.3-1 0.3.3-2
fulcio 0.1.1-1 0.1.1-2
fx 21.0.0-3 22.0.10-2
gala 6.3.0-4 6.3.1-1
gamescope 3.11.22-2 3.11.30-1
gdu 5.13.2-1 5.13.2-2
gendesk 1.0.9-1 1.0.9-2
geoipupdate 4.9.0-1 4.9.0-2
gimp-plugin-gmic 3.0.2-1 3.1.0-1
git-sizer 1.5.0-1 1.5.0-2
github-cli 2.8.0-1 2.9.0-2
glab 1.22.0-1 1.22.0-2
glide 0.5.9-1 0.5.9-2
global 6.6.8-1 6.6.8-2
glow 1.4.1-2 1.4.1-3
gnome-games 40.0-2 40.0-3
gnome-recipes 2.0.4-2 2.0.4-3
go-bindata 4.0.0-1 4.0.0-2
go-bindata-assetfs 1.0.1-2 1.0.1-3
go-bindata-hashicorp 3.0.7+bf7910af-4 3.0.7+bf7910af-5
go-md2man 2.0.1-1 2.0.2-1
go-yq 4.24.5-1 4.25.1-1
goaccess 1.5.6-1 1.5.7-1
gocryptfs 2.2.1-2 2.2.1-3
goimapnotify 2.3.7-2 2.3.7-3
google-glog 0.5.0-2 0.6.0-1
gopass 1.14.0-1 1.14.0-2
gopass-jsonapi 1.11.1-1 1.11.1-2
gopass-summon-provider 1.12.0-1 1.12.0-2
goreleaser 1.7.0-1 1.7.0-2
gox 1.0.1-5 1.0.1-6
gpick 0.2.6-3 0.2.6-4
gpsd 3.23.1-4 3.24-1
gron 0.7.1-1 0.7.1-2
grpc 1.45.2-2 1.45.2-3
grpc-cli 1.45.2-2 1.45.2-3
grub-customizer 5.1.0-3 5.2.1-1
gtk-theme-elementary 6.1.1-2 7.0.0-1
guitarix 0.43.1-2 0.43.1-3
haproxy 2.5.5-1 2.5.6-2
helmfile 0.143.0-1 0.143.0-2
hey 0.1.4-4 0.1.4-5
home-assistant 2021.10.5-2 2022.4.6-1
hugo 0.96.0-1 0.97.3-2
hut 0.1.0-2 0.1.0-3
hyperion 1.03.2-27 1.03.2-28
iptux 0.8.3-2 0.8.3-3
ipython 8.2.0-1 8.3.0-1
java-rxtx 2.2pre2-7 2.2pre2-8
jc 1.18.6-2 1.18.8-1
jenkins 2.344-1 2.345-1
jmol 14.32.51-1 14.32.54-1
josm 18387-1 18427-1
jpegoptim 1.4.6-2 1.4.7-1
jsmol 14.32.51-1 14.32.54-1
jwt-cli 5.0.2-1 5.0.3-1
k9s 0.25.18-1 0.25.18-2
kbfs 5.9.1-1 5.9.3-2
kconfig-hardened-check 0.5.10-2 0.5.17-1
keepass 2.50-1 2.50-2
kernelshark 2.1.0-2 2.1.1-1
keybase 5.9.1-1 5.9.3-2
keybase-gui 5.9.1-1 5.9.3-2
klayout 0.27.8-1 0.27.9-1
knative-client 1.3.1-1 1.3.1-2
knot 3.1.6-1 3.1.8-1
ko 0.11.2-1 0.11.2-2
kodi-platform 20190726.809c5e9-35 20190726.809c5e9-37
kompose 1.26.0-1 1.26.0-2
kube-linter 0.2.6-1 0.2.6-2
kubeconform 0.4.13-1 0.4.13-2
kubectl-ingress-nginx 1.0.4-1 1.0.4-2
kustomize 4.5.4-1 4.5.4-2
lazygit 0.34-1 0.34-2
lego 4.6.0-1 4.6.0-2
leiningen 2.9.8-1 2.9.8-2
lesspipe 2.04-1 2.05-1
libcgif 0.2.1-1 0.3.0-1
libdbusmenu-glib 16.04.0-4 16.04.0-5
libdbusmenu-gtk2 16.04.0-4 16.04.0-5
libdbusmenu-gtk3 16.04.0-4 16.04.0-5
libfilezilla 1:0.37.1-1 1:0.37.2-1
libindicator-gtk2 12.10.1-9 12.10.1-10
libindicator-gtk3 12.10.1-9 12.10.1-10
libopenshot 0.2.7-9 0.2.7-10
libopusenc 0.2.1-2 0.2.1-3
libperconaserverclient 8.0.27_18-2 8.0.27_18-3
libpinyin 2.6.1-1 2.6.2-1
libressl 3.4.3-1 3.5.2-1
libretro-beetle-psx 2599-2 2612-1
libretro-beetle-psx-hw 2599-2 2612-1
libretro-core-info 1.10.0-2 1.10.3-1
libretro-dolphin 33006-2 33011-1
libretro-gambatte 958-2 965-1
libretro-genesis-plus-gx 1882-2 1910-1
libretro-nestopia 1:73-2 1:88-1
libretro-play 6906-2 7284-2
libretro-scummvm 93204-2 93205-2
libretro-shaders-slang 882-2 949-1
libretro-snes9x 2043-2 2145-1
librttopo 1.1.0-3 1.1.0-4
libslirp 4.6.1-1 4.7.0-1
libspatialite 5.0.1-1 5.0.1-2
libspeechd 0.11.1-2 0.11.1-3
libtpms 0.9.3-1 0.9.4-1
libvirt 1:8.2.0-4 1:8.2.0-7
libvirt-storage-gluster 1:8.2.0-4 1:8.2.0-7
libvirt-storage-iscsi-direct 1:8.2.0-4 1:8.2.0-7
libvolk 2:2.5.0-3 2:2.5.0-4
libxmlbird 1.2.12-1 1.2.12-2
lightdm-slick-greeter 1.5.6-1 1.5.7-1
linenoise-ng 1.0.1-1 1.0.1-2
lollypop 1.4.28-2 1.4.33-1
lua-language-server 3.0.1-1 3.2.2-1
lutris 0.5.9.1-5 0.5.10.1-2
lxmusic 0.4.7-5 0.4.7-6
lxtask 0.1.10-1 0.1.10-2
lxtask-gtk3 0.1.10-1 0.1.10-2
magnum 2020.06-1 2020.06-3
mame 0.242-1 0.243-1
mame-tools 0.242-1 0.243-1
mapnik 3.1.0-9 3.1.0-10
marker 2020.04.04.2-4 2020.04.04.2-5
matterbridge 1.25.0-2 1.25.0-3
maturin 0.12.12-1 0.12.14-1
menu-cache 1.1.0-2 1.1.0-3
miller 6.2.0-1 6.2.0-2
miniflux 2.0.36-1 2.0.36-2
mixxx 2.3.2-1 2.3.2-2
mmctl 6.6.0-1 6.6.1-1
modest 0.0.6.d021b90-2 0.0.6.d021b90-3
mopidy 3.2.0-2 3.3.0-1
mosh 1.3.2-16 1.3.2-17
mruby 3.0.0-1 3.0.0-2
mumble 1.4.230-4 1.4.230-5
murmur 1.4.230-4 1.4.230-5
mypy 0.942-2 0.950-1
mysql-workbench 8.0.28-2 8.0.29-1
mythes-hu 1:1.0-1 1:1.0-2
navit 0.5.6-3 0.5.6-4
nebula 1.5.2-1 1.5.2-2
neomutt 20220415-1 20220429-1
nerdctl 0.19.0-1 0.19.0-2
netdata 1.34.1-1 1.34.1-2
nextcloud-app-deck 1:1.6.1-1 1:1.6.2-1
nitroshare 0.3.4-3 0.3.4-4
nltk-data 3.6.4-1 3.6.4-2
nnn 4.4-1 4.5-1
nodejs-lts-gallium 16.14.2-2 16.15.0-1
nomad-driver-containerd 0.9.3-1 0.9.3-2
nomad-driver-lxc 0.3.0-2 0.3.0-3
nomad-driver-nspawn 0.9.0-1 0.9.0-2
nomad-driver-podman 0.3.0-1 0.3.0-2
notepadqq 1.4.8-5 1.4.8-6
nsjail 3.1-1 3.1-2
nut 2.7.4-3 2.8.0-1
ocrad 0.28-1 0.28-2
oniguruma 6.9.7.1-2 6.9.8-1
openfortivpn 1.17.1-2 1.17.2-1
openntpd 6.8p1-2 6.8p1-3
openrct2 0.3.5.1-4 0.4.0-1
opensmtpd 6.8.0p2-2 6.8.0p2-3
opensmtpd-filter-rspamd 0.1.7-2 0.1.7-3
operator-sdk 1.18.0-1 1.18.1-2
osbuild 54-1 55-1
packer 1.7.8-1 1.8.0-2
pacoloco 1.2-1 1.2-2
padthv1 0.9.25-1 0.9.25-2
pantheon-code 6.1.0-3 6.2.0-1
pantheon-notifications 6.0.0-2 6.0.1-1
peco 0.5.10-3 0.5.10-4
penguin-subtitle-player 1.5.0-1 1.5.0-2
percona-server 8.0.27_18-2 8.0.27_18-3
percona-server-clients 8.0.27_18-2 8.0.27_18-3
perlbrew 0.89-2 0.94-1
phodav 2.5-1 2.5-2
phototonic 2.1-2 2.1-3
php-grpc 1.45.2-2 1.45.2-3
php7-grpc 1.45.2-2 1.45.2-3
pianobar 2020.11.28-2 2022.04.01-1
picom 9.1-2 9.1-3
pidgin-libnotify 0.14-13 0.14-14
polkit-gnome 0.105-8 0.105-9
polyml 5.9-2 5.9-3
pop-icon-theme2.1.0.r2419.9998b20b78-22.1.0.r2434.28b598d347-1
popeye 0.9.8-1 0.9.8-2
pragha 1.3.4-3 1.3.4-4
promscale 0.10.0-1 0.10.0-2
promscale_extension 0.3.2-1 0.3.2-2
prosody 1:0.12.0-1 1:0.12.0-2
psensor 1.2.1-2 1.2.1-3
pulumi 3.28.0-1 3.28.0-2
purple-facebook 0.9.6-4 0.9.6-5
purple-skypeweb 1.7-2 1.7-3
pyright 1.1.239-1 1.1.242-1
python-awesomeversion 22.4.0-1 22.4.1-1
python-aws-sam-translator 1.42.0-3 1.45.0-1
python-capstone 4.0.2-5 4.0.2-6
python-cfn-lint 0.58.1-1 0.59.0-1
python-click 8.1.2-1 8.1.3-1
python-dnspython 1:2.2.0-1 1:2.2.1-1
python-eyed3 1:0.9.5-5 1:0.9.6-1
python-flake8-black 0.2.4-1 0.3.2-1
python-flask 2.1.1-1 2.1.2-1
python-fonttools 4.33.2-1 4.33.3-1
python-frozendict 1:2.3.1-1 1:2.3.2-1
python-gitlab 3.3.0-1 3.4.0-1
python-google-api-python-client 2.45.0-1 2.46.0-1
python-grpcio 1.45.2-2 1.45.2-3
python-identify 2.4.12-1 2.5.0-1
python-jinja 1:3.0.3-1 1:3.0.3-2
python-jupyter_client 7.2.2-1 7.3.0-1
python-jwcrypto 1.0-3 1.2.0-1
python-mocket 3.10.4-1 3.10.5-1
python-mysql-connector 8.0.28-1 8.0.29-1
python-phonenumbers 8.12.46-1 8.12.47-1
python-pipenv 2022.4.21-1 2022.4.21-2
python-py7zr 0.18.4-1 0.18.5-1
python-pyarrow 6.0.1-3 7.0.0-1
python-pyspnego 0.5.1-1 0.5.2-1
python-pytest-mpl 0.14.0-4 0.15.1-1
python-rapidyaml 0.3.0-3 0.4.1-1
python-readme-renderer 34.0-1 35.0-1
python-rich 12.2.0-1 12.3.0-1
python-shtab 1.5.3-1 1.5.4-1
python-tomlkit 0.10.1-1 0.10.2-1
python-werkzeug 2.1.1-1 2.1.2-1
python-z3 4.8.15-1 4.8.16-1
python2-numpy 1.16.6-1 1.16.6-2
qcad 3.27.1.8-1 3.27.3.0-1
qcoro-qt5 0.4.0-3 0.5.1-1
qcoro-qt6 0.4.0-3 0.5.1-1
qhttpengine 1.0.1-2 1.0.1-3
qjackctl 0.9.7-1 0.9.7-2
qjournalctl 0.6.3-2 0.6.3-3
qmc2 0.242-1 0.243-1
qmdnsengine 0.2.0-1 0.2.0-2
qmidictl 0.9.6-2 0.9.6-3
qmidinet 0.9.6-1 0.9.6-2
qmidiroute 0.4.0-7 0.4.0-8
qnapi 0.2.3-4 0.2.3-5
qsynth 0.9.7-1 0.9.7-2
qtractor 0.9.26-1 0.9.26-2
quiterss 0.19.4-1 0.19.4-2
qxgedit 0.9.6-1 0.9.6-2
qxmledit 0.9.16-1 0.9.16-2
r10k 3.14.2-1 3.15.0-1
rclone 1.58.0-1 1.58.1-1
reactphysics3d 0.8.0-1 0.8.0-2
reactphysics3d-docs 0.8.0-1 0.8.0-2
rekor 0.6.0-1 0.6.0-2
repo 2.23-1 2.24.1-1
restic 0.13.1-1 0.13.1-2
retroarch 1.10.0-4 1.10.3-1
retroarch-assets-glui 1:405-2 1:424-1
retroarch-assets-ozone 1:405-2 1:424-1
retroarch-assets-xmb 1:405-2 1:424-1
revive 1.1.4-1 1.1.4-2
rfdump 1.6-3 1.6-5
rootlesskit 1.0.0-1 1.0.0-2
rox 2.11-6 2.11-7
rst2pdf 0.99-1 0.99-2
rtl-sdr 1:0.8.0-3 1:0.8.0-4
ruby-nokogiri 1.13.3-1 1.13.3-2
rust-analyzer 20220418-1 20220425-1
rust-script 0.20.0-2 0.21.0-1
samplv1 0.9.25-1 0.9.25-2
sbctl 0.8-1 0.9-1
sensors-applet 3.0.0+13+g0728426-4 3.0.0+13+g0728426-5
serverless 3.15.2-1 3.16.0-1
shotcut 22.04.22-1 22.04.25-1
skate 0.2.0-1 0.2.0-2
snapper 0.10.0-1 0.10.1-1
snappy-player 1.0-7 1.0-8
soft-serve 0.3.0-1 0.3.0-2
solaar 1.1.2-2 1.1.3-1
speech-dispatcher 0.11.1-2 0.11.1-3
spice-up 1.8.2-3 1.8.2-4
sqlc 1.13.0-1 1.13.0-2
sqlcipher 4.5.0-1 4.5.1-1
srrdb-terminal-client 1.1.7-2 1.1.7-3
ssh-key-confirmer 0.1-1 0.1-2
sssd 2.6.3-1 2.7.0-1
starship 1.6.2-1 1.6.3-1
steadyflow 0.2.0-9 0.2.0-10
step-cli 0.19.0-1 0.19.0-2
stern 1.21.0-2 1.21.0-3
strawberry 1.0.4-1 1.0.4-2
stylelint 14.7.1-1 14.8.1-1
sugar-activity-browse 207-1 207-2
sugar-activity-calculate 47-1 47-2
sugar-activity-chat 86-1 86-2
sugar-activity-imageviewer 1:65-1 1:65-2
sugar-activity-jukebox 36-1 36-2
sugar-activity-log 42-1 42-2
sugar-activity-paint 70-1 70-2
sugar-activity-pippy 75-1 75-2
sugar-activity-read 123-1 123-2
sugar-activity-terminal 47-1 47-2
sugar-activity-turtleart 220-1 220-2
sugar-activity-write 101-1 101-2
sugar-runner 0.110.0-4 0.110.0-5
switchboard-plug-about 6.0.1-2 6.1.0-2
switchboard-plug-keyboard 2.6.0-2 2.7.0-1
switchboard-plug-locale 2.5.6-2 2.5.7-1
switchboard-plug-online-accounts 6.3.0-2 6.4.0-1
switchboard-plug-sound 2.3.0-2 2.3.1-1
swtpm 0.7.2-1 0.7.3-1
symphytum 2.6-2 2.6-3
syncthing 1.19.2-1 1.19.2-2
syncthing-relaysrv 1.19.2-1 1.19.2-2
synergy 1.10.3-2 1.10.3-3
synthv1 0.9.25-2 0.9.25-3
tailscale 1.24.0-1 1.24.2-1
taskwarrior-tui 0.22.0-1 0.23.3-1
tea 0.8.0-1 0.8.0-2
tectonic 0.8.2-2 0.9.0-1
telegram-desktop 3.7.1-2 3.7.3-1
texmaker 5.1.2-1 5.1.3-1
timescaledb 2.6.1-1 2.6.1-2
timescaledb-tune 0.12.0-1 0.12.0-2
tmuxp 1.10.1-1 1.11.0-1
tomlplusplus 3.0.1-1 3.1.0-1
trivy 0.26.0-2 0.27.1-1
ttf-sarasa-gothic 0.36.2-1 0.36.3-1
typescript 4.6.3-1 4.6.4-1
uget 2.2.3-4 2.2.3-5
umockdev 0.17.8-1 0.17.9-1
unpaper 6.1-9 7.0.0-1
up 0.4-2 0.4-3
upterm 0.7.5-2 0.7.5-3
upx 3.96-2 3.96-3
uvicorn 0.17.0.post1-2 0.17.6-1
v2ray-domain-list-community 20220419022654-1 20220429034939-1
v2ray-geoip 202204210050-1 202204280105-1
variety 0.8.5-3 0.8.6-1
vc-intrinsics 0.2.0-1 0.3.0-1
vegeta 12.8.4-2 12.8.4-3
vice 3.6.1-1 3.6.1-2
vocal 2.4.2-4 2.4.2-5
wakatime 1:1.38.0-1 1:1.42.2-1
wallutils 5.10.0-1 5.10.0-2
waylandpp 0.2.9-2 1.0.0-1
wcslib 7.10-1 7.11-1
wezterm20220408.101518.b908e2dd-120220408.101518.b908e2dd-2
wt 4.6.1-1 4.7.1-1
xa 2.3.12-1 2.3.13-1
xchm 1.32-1 1.32-2
xonsh 0.12.0-1 0.12.2-1
xtrabackup 8.0.27_19-2 8.0.27_19-3
yaml-language-server 1.6.0-1 1.7.0-1
yggdrasil 0.4.3-1 0.4.3-2
yosys 0.12-3 0.12-4
yubikey-touch-detector 1.9.3-1 1.9.3-2
zerotier-one 1.8.8-1 1.8.9-1
zk 0.9.0-2 0.10.0-1
dagger - 0.2.8-2
lei - 1.8.0-1
libxdp - 1.2.3-6
minizip-ng - 3.0.6-3
nextcloud-app-notify_push - 0.4.0-2
patatt - 0.4.9-1
perl-publicinbox - 1.8.0-1
perl-search-xapian - 1.2.25.5-1
python-aiodiscover - 1.4.11-1
python-lru-dict - 1.1.7-2
ugrep - 3.7.9-2
xdp-tools - 1.2.3-6
:: Different overlay package(s) in repository core aarch64
linux 5.17.4-1 5.17.5-3
linux-clockworkpi-a06 5.17.4-1 5.17.5-1
linux-clockworkpi-a06-headers 5.17.4-1 5.17.5-1
linux-headers 5.17.4-1 5.17.5-3
linux-lts 5.15.35-1 5.15.36-1
linux-lts-headers 5.15.35-1 5.15.36-1
linux-pinephone 5.17.4-1 5.17.5-1
linux-pinephone-headers 5.17.4-1 5.17.5-1
linux-pinephonepro 5.17.4-1 5.17.5-1
linux-pinephonepro-headers 5.17.4-1 5.17.5-1
linux-rc 5.18.rc4-1 5.18.rc4-2
linux-rc-headers 5.18.rc4-1 5.18.rc4-2
linux-rpi4 5.15.34-1 5.15.36-1
linux-rpi4-headers 5.15.34-1 5.15.36-1
linux-rpi4-mainline 5.17.3-1 5.17.4-2
linux-rpi4-mainline-headers 5.17.3-1 5.17.4-2
linux-rpi4-rc 5.18.rc2-1 5.18.rc4-2
linux-rpi4-rc-headers 5.18.rc2-1 5.18.rc4-2
uboot-pinebookpro-bsp 1.5-10 1.24.126-1
uboot-opi3-lts - 2022.04-1
:: Different sync package(s) in repository core aarch64
audit 3.0.7-1 3.0.8-1
bison 3.8.2-3 3.8.2-4
brotli 1.0.9-7 1.0.9-8
brotli-testdata 1.0.9-7 1.0.9-8
btrfs-progs 5.16.2-1 5.17-1
cronie 1.6.0-2 1.6.1-1
curl 7.82.0-2 7.83.0-1
debuginfod 0.186-5 0.187-1
elfutils 0.186-5 0.187-1
gnupg 2.2.32-2 2.2.35-1
gnutls 3.7.4-1 3.7.4-2
iana-etc 20220325-1 20220427-1
iproute2 5.17.0-2 5.17.0-3
lemon 3.38.2-1 3.38.3-1
libcurl-compat 7.82.0-2 7.83.0-1
libcurl-gnutls 7.82.0-2 7.83.0-1
libelf 0.186-5 0.187-1
libinih 53-2 55-2
libnl 3.6.0-1 3.6.0-3
libpipeline 1.5.5-1 1.5.6-1
libseccomp 2.5.3-3 2.5.4-1
nano 6.2-1 6.3-1
ncurses 6.3-2 6.3-3
pciutils 3.7.0-2 3.8.0-1
python-audit 3.0.7-1 3.0.8-1
python-brotli 1.0.9-7 1.0.9-8
sqlite 3.38.2-1 3.38.3-1
sqlite-analyzer 3.38.2-1 3.38.3-1
sqlite-doc 3.38.2-1 3.38.3-1
sqlite-tcl 3.38.2-1 3.38.3-1
systemd 250.4-2 250.5-1
systemd-libs 250.4-2 250.5-1
systemd-resolvconf 250.4-2 250.5-1
systemd-sysvcompat 250.4-2 250.5-1
:: Different overlay package(s) in repository extra aarch64
mesa-git22.2.0_devel.152789.6bef59f56b3-122.2.0_devel.153080.53fe6f10846-1
:: Different sync package(s) in repository extra aarch64
alertmanager 0.24.0-1 0.24.0-2
alsa-card-profiles 1:0.3.50-1 1:0.3.51-1
amf-headers 1.4.23-2 1.4.24-2
archboot-arm 2022.04-38 2022.04-64
archinstall 2.3.3-1 2.4.2-1
bind 9.18.1-1 9.18.2-1
booster 0.7-2 0.7-3
bullet 3.22-1 3.23-1
bullet-docs 3.22-1 3.23-1
chromium 100.0.4896.127-2 101.0.4951.41-1
cifs-utils 6.14-1 6.15-1
clutter-gst 3.0.27-3 3.0.27-4
finch 2.14.8-1 2.14.9-1
fluidsynth 2.2.6-1 2.2.7-1
geoip-database 20220315-1 20220419-1
geoip-database-extra 20220315-1 20220419-1
ghex 42.1-1 42.2-1
ghex-docs 42.1-1 42.2-1
gnome-calendar 42.0-1 42.1-1
gnome-control-center 42.0-1 42.1-1
gnome-desktop 1:42.0-1 1:42.1-1
gnome-desktop-4 1:42.0-1 1:42.1-1
gnome-desktop-common 1:42.0-1 1:42.1-1
gnome-music 1:42.0-1 1:42.1-1
gnome-notes 40.1-1 40.1-2
gnome-remote-desktop 42.1-1 42.1.1-1
gnome-software 42.0-1 42.1-1
gnome-software-packagekit-plugin 42.0-1 42.1-1
gnumeric 1.12.51-1 1.12.52-1
goffice 0.10.51-1 0.10.52-1
gperftools 2.9.1-1 2.9.1-2
gst-plugin-pipewire 1:0.3.50-1 1:0.3.51-1
gtk3 1:3.24.33-2 1:3.24.33-3
gtk3-demos 1:3.24.33-2 1:3.24.33-3
gtk3-docs 1:3.24.33-2 1:3.24.33-3
gvim 8.2.4651-1 8.2.4827-1
hefur 1.0-5 1.0-6
hplip 1:3.22.2-2 1:3.22.4-1
hwdetect 2022.01-5 2022.04-2
imlib2 1.8.1-1 1.9.0-3
ipp-usb 0.9.20-1 0.9.20-2
irqbalance 1.8.0-1 1.8.0-2
java-rhino 1.7.13-1 1.7.14-1
kcalutils 22.04.0-1 22.04.0-2
khealthcertificate 21.12-1 22.04-1
kio-extras 22.04.0-1 22.04.0-2
kismet 2022_02_R1-1 2022_02_R1-2
kosmindoormap 22.04.0-1 22.04.0-2
krita 5.0.5-2 5.0.6-1
libgudev 237-1 237-2
libmbim 1.26.2-1 1.26.4-1
libmm-glib 1.18.6-1.1 1.18.8-1
libnitrokey 3.6-1 3.7-1
libnotify 0.7.9-2 0.7.11-1
libopenmpt 0.6.2-1 0.6.3-1
libphonenumber 1:8.12.46-2 1:8.12.47-1
libpurple 2.14.8-1 2.14.9-1
libqmi 1.30.4-1.1 1.30.6-1
libqrtr-glib 1.2.2-1 1.2.2-2
libsynctex 2021.59745-3 2022.62885-1
libtransmission 3.00-3 3.00-4
libva-mesa-driver 22.0.1-3 22.0.2-1
luit 20210218-1 20220111-1
marble 22.04.0-1 22.04.0-2
marble-common 22.04.0-1 22.04.0-2
marble-maps 22.04.0-1 22.04.0-2
marble-qt 22.04.0-1 22.04.0-2
mesa 22.0.1-3 22.0.2-1
mesa-vdpau 22.0.1-3 22.0.2-1
mkinitcpio-archiso 62-1 63-1
mkvtoolnix-cli 64.0.0-2 67.0.0-2
mkvtoolnix-gui 64.0.0-2 67.0.0-2
modemmanager 1.18.6-1.1 1.18.8-1
mono 6.12.0.122-1 6.12.0.177-1
mtr 0.95-1 0.95-3
mtr-gtk 0.95-1 0.95-3
mutt 2.2.3-1 2.2.4-1
nginx-prometheus-exporter 0.10.0-1 0.10.0-2
opencl-mesa 22.0.1-3 22.0.2-1
opencv 4.5.5-4 4.5.5-5
opencv-samples 4.5.5-4 4.5.5-5
pidgin 2.14.8-1 2.14.9-1
pipewire-alsa 1:0.3.50-1 1:0.3.51-1
pipewire-docs 1:0.3.50-1 1:0.3.51-1
pipewire-jack 1:0.3.50-1 1:0.3.51-1
pipewire-pulse 1:0.3.50-1 1:0.3.51-1
pipewire-v4l2 1:0.3.50-1 1:0.3.51-1
pipewire-x11-bell 1:0.3.50-1 1:0.3.51-1
pipewire-zeroconf 1:0.3.50-1 1:0.3.51-1
pkgstats 3.2.1-1 3.2.2-1
postfix 3.7.1-1 3.7.2-1
postfix-cdb 3.7.1-1 3.7.2-1
postfix-ldap 3.7.1-1 3.7.2-1
postfix-lmdb 3.7.1-1 3.7.2-1
postfix-mysql 3.7.1-1 3.7.2-1
postfix-pcre 3.7.1-1 3.7.2-1
postfix-pgsql 3.7.1-1 3.7.2-1
postfix-sqlite 3.7.1-1 3.7.2-1
prometheus 2.34.0-1 2.35.0-2
prometheus-blackbox-exporter 0.20.0-2 0.20.0-3
prometheus-memcached-exporter 0.9.0-1 0.9.0-2
prometheus-mysqld-exporter 0.13.0-1 0.13.0-2
prometheus-node-exporter 1.3.1-1 1.3.1-2
protobuf 3.19.4-1 3.20.1-1
protobuf-c 1.4.0-2 1.4.0-3
python-opencv 4.5.5-4 4.5.5-5
python-protobuf 3.19.4-1 3.20.1-1
python-pybullet 3.22-1 3.23-1
qbs 1.22.0-1 1.22.1-1
qtcreator 7.0.0-1 7.0.1-1
rhino-javadoc 1.7.13-1 1.7.14-1
samba 4.16.0-5 4.16.0-6
sdl2 2.0.20-2 2.0.22-1
sip 6.6.1-2 6.6.1-3
smbclient 4.16.0-5 4.16.0-6
texlive-bibtexextra 2021.62705-1 2022.63023-1
texlive-bin 2021.59745-3 2022.62885-1
texlive-core 2021.62793-1 2022.63035-1
texlive-fontsextra 2021.62623-1 2022.62977-1
texlive-formatsextra 2021.62145-1 2022.62529-1
texlive-games 2021.62102-1 2022.62102-1
texlive-humanities 2021.61878-1 2022.62929-1
texlive-langchinese 2021.62313-1 2022.62922-1
texlive-langcyrillic 2021.62110-1 2022.62517-1
texlive-langextra 2021.62109-1 2022.62837-1
texlive-langgreek 2021.61820-1 2022.61820-1
texlive-langjapanese 2021.62737-1 2022.63011-1
texlive-langkorean 2021.62398-1 2022.63005-1
texlive-latexextra 2021.62806-1 2022.63034-1
texlive-music 2021.62509-1 2022.62533-1
texlive-pictures 2021.62760-1 2022.62992-1
texlive-pstricks 2021.61917-1 2022.62977-1
texlive-publishers 2021.62814-1 2022.63013-1
texlive-science 2021.62659-1 2022.62977-1
thunar 4.16.11-1 4.16.11-2
thunar-archive-plugin 0.4.0-3 0.5.0-1
tomcat-native 1.2.31-2 1.2.32-1
tomcat10 10.0.16-2 10.0.20-2
tomcat8 8.5.75-2 8.5.78-2
tomcat9 9.0.58-2 9.0.62-2
transmission-cli 3.00-3 3.00-4
transmission-gtk 3.00-3 3.00-4
transmission-qt 3.00-3 3.00-4
usbguard 1.1.1-1 1.1.1-2
vim-runtime 8.2.4651-1 8.2.4827-1
vlc 3.0.17.4-1 3.0.17.4-2
vulkan-broadcom 22.0.1-3 22.0.2-1
vulkan-mesa-layers 22.0.1-3 22.0.2-1
vulkan-panfrost 22.0.1-3 22.0.2-1
vulkan-radeon 22.0.1-3 22.0.2-1
vulkan-swrast 22.0.1-3 22.0.2-1
xdg-desktop-portal-gnome 42.0.1-1 42.1-1
xfce4-settings 4.16.2-1 4.16.2-2
zenity 3.42.0-1 3.42.1-1
gnome-info-collect - 1.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi-calendar22.04.0.r2074.g8e23c89-122.04.0.r2077.g292fc1b-1
akregator22.04.0.r6389.g002a66dd-122.04.0.r6393.gca64b2ca-1
alligator 22.04.r0.geb9dd9c-1 22.04.r3.ge10c6ec-1
amazfish 2.0.5.r14.gcc91cbe-1 2.0.8.r0.g3ffc996-1
analitza22.04.0.r2336.g4344e637-122.04.0.r2339.g3c8c5a57-1
angelfish 22.04.r0.g9a49fcb-1 22.04.r6.g52e0b2a-1
audiocd-kio22.04.0.r1056.g79b09d7-122.04.0.r1061.gbbfe873-1
audiotube 22.02.r19.g32f98a7-1 22.04.r5.g613dd1e-1
baloo5.93.0.r3046.g97fc3f6c-15.93.0.r3047.gd699c1ac-1
blinken22.04.0.r663.gc80904d-122.04.0.r665.g8366737-1
bluedevil1:5.24.4.r2388.g84731dd4-11:5.24.4.r2390.g0d56d545-1
breeze5.24.4.r2384.g1319a747-15.24.4.r2388.g8b13e977-1
calendarsupport21.12.2.r686.gd83d160-122.04.0.r687.gcabd1e0-1
calindori 22.02.r12.ge765bec-1 22.04.r2.g8ad0ee8-1
discover5.24.4.r8631.g032d71c8-15.24.4.r8646.g49bfacd7-1
dolphin22.04.0.r6920.g6c91dfa47-122.04.0.r6936.g1a8be1544-1
dolphin-plugins22.04.0.r651.g6a71839-122.04.0.r652.g2e58a9e-1
dragon22.04.0.r1030.ga47eb40-122.04.0.r1031.gfc7f036-1
drkonqi5.24.4.r763.gb58dc557-15.24.4.r775.g93cc744d-1
elisa22.04.0.r2947.g1364827b-122.04.0.r2950.g69edc479-1
elisa-qtmm22.04.0.r2947.g1364827b-122.04.0.r2950.g69edc479-1
eventviews21.12.2.r813.g8acbce2-122.04.0.r818.g4aedf65-1
extra-cmake-modules5.93.0.r3474.g01f41fe3-15.93.0.r3478.g0a624648-1
filelight22.04.0.r1082.g38a71d1-122.04.0.r1103.gb3c3919-1
incidenceeditor22.04.0.r881.g18c6631-122.04.0.r889.g6f428a7-1
index-fm 2.1.1.r11.gc7df1be-1 2.1.1.r14.g0f3da0b-1
itinerary22.04.0.r1806.g9782997-122.04.0.r1814.g879e5fb-1
k3b1:22.04.0.r6749.g009d2db08-11:22.04.0.r6756.g977a38dd6-1
kaccounts-integration22.04.0.r1252.g7ac2983-122.04.0.r1253.gc0d08d3-1
kactivitymanagerd5.24.4.r1389.g4dc228a-15.24.4.r1394.g9b2a05a-1
kaddressbook22.04.0.r6158.gc3811762-122.04.0.r6159.g40664f66-1
kalarm22.04.0.r7883.g24db39c6-122.04.0.r7894.gadd97de6-1
kanagram22.04.0.r1307.g5d826cc-122.04.0.r1308.gad84640-1
kasts 22.04.r0.gfe213df-1 22.04.r3.gcb9000f-1
kate22.04.0.r18945.gdadf8130e-122.04.0.r18984.g7753a3c03-1
kcalc22.04.0.r1606.gfcbe1d3-122.04.0.r1608.ge88662c-1
kcalutils22.04.0.r954.g7cb0cde8e-122.04.0.r955.g663ea1216-1
kclock 22.02.r38.ga5d03f3-1 22.04.r2.gab6b2a0-1
kcmutils5.93.0.r624.g36966b1-15.93.0.r625.gbc3c3bc-1
kconfigwidgets5.93.0.r726.g0cf8a52-15.93.0.r729.g906190b-1
kcontacts1:5.93.0.r3329.gbc176765-11:5.93.0.r3330.g656afdbc-1
kcoreaddons5.93.0.r1463.ge2cf4c9c-15.93.0.r1467.g8347d2f5-1
kde-cli-tools5.24.4.r1924.gd350e17-15.24.4.r1931.g7259c78-1
kdeconnect22.04.0.r3430.gda84914b-122.04.0.r3434.g117ac915-1
kded5.93.0.r457.gec36fda-15.93.0.r458.gf66f2c3-1
kdenlive22.04.0.r16002.g370bb750e-122.04.0.r16028.g285e1086b-1
kdepim-addons22.04.0.r4623.g9bc03daf1-122.04.0.r4626.gd0dbd0113-1
kdepim-runtime22.04.0.r15503.g747556638-122.04.0.r15505.ga6aa9a697-1
kdeplasma-addons5.24.4.r8744.g0a6c7ff7a-15.24.4.r8746.g4ca3314f5-1
kdf22.04.0.r847.g354ec2b-122.04.0.r849.g5b24988-1
keysmith 22.02.r9.ga8197c3-1 22.04.r1.g0b5fdbe-1
kgeography22.04.0.r1144.ga518151-122.04.0.r1155.g87eaa17-1
kglobalaccel5.93.0.r509.ga75819f-15.93.0.r512.g2eff290-1
kgpg22.04.0.r3183.gc10637d0-122.04.0.r3184.g5f9fe70e-1
khangman22.04.0.r1597.g076c946-122.04.0.r1598.g29774e6-1
khealthcertificate 22.02.r2.g52fb7cf-1 22.04.r2.ga1608c1-1
khelpcenter22.04.0.r2734.g0ad337d9-122.04.0.r2735.gffb20e35-1
kholidays1:5.93.0.r1006.g15aefbd-11:5.93.0.r1032.ge59e1fb-1
khotkeys5.24.4.r2122.g44ba571-15.24.4.r2124.g5cc2e62-1
kinfocenter5.24.4.r2070.g0ce08e24-15.24.4.r2075.g5e6b8426-1
kio5.93.0.r5422.ge4970b195-15.93.0.r5427.g4d820eebb-1
kio-extras22.04.0.r7230.g2b5d8bb3-122.04.0.r7234.ga58c6891-1
kirigami25.93.0.r3111.g6c741e52-15.93.0.r3116.g607f02b8-1
kitinerary22.04.0.r2165.gf4c27d7-122.04.0.r2172.g732fc54-1
kleopatra22.04.0.r6382.g670728a2-122.04.0.r6397.gff3c40d5-1
klettres22.04.0.r957.gf6fec52-122.04.0.r958.g58ed1a5-1
klines22.04.0.r808.ga194437-122.04.0.r809.ga7b19ea-1
kmahjongg22.04.0.r1523.g2841f09-122.04.0.r1524.ge7f9743-1
kmail22.04.0.r26336.g4be40793c-122.04.0.r26346.g79af00221-1
kmime22.04.0.r1504.g68700df-122.04.0.r1510.g03adaa1-1
kmix22.04.0.r2442.g4a078384-122.04.0.r2445.g1edbea3e-1
kmousetool22.04.0.r431.g8f55646-122.04.0.r432.g1b9c2c9-1
knewstuff5.93.0.r1325.g5859827f-15.93.0.r1329.g836a7b80-1
knotes22.04.0.r3641.g4ac9c749-122.04.0.r3642.gd985e12a-1
knotifications5.93.0.r731.gbb26a1a-15.93.0.r732.g5f3a711-1
koko 22.04.r0.gef28e0f-1 22.04.r3.gaca9166-1
kolf22.04.0.r1489.gb62dc89-122.04.0.r1490.g3da197d-1
kongress 22.04.r0.g70ad19b-1 22.04.r2.ga3fed48-1
konsole22.04.0.r8333.gad1421f8-122.04.0.r8349.g3955ca70-1
kontact22.04.0.r5507.g2801e4d8-122.04.0.r5508.gbf11b33a-1
korganizer22.04.0.r11681.ge8898f47e-122.04.0.r11685.gae94e32b9-1
kosmindoormap22.04.0.r724.gb3f9d6e-122.04.0.r728.g0f3f58c-1
kpackage5.93.0.r745.gbf2011b-15.93.0.r746.g791d8d3-1
kpeoplevcard 0.1.r17.gebf9df1-1 0.1.r19.g5ba8518-1
kpkpass22.04.0.r287.gfbb7d68-122.04.0.r293.gebad279-1
kpty5.93.0.r370.gd911181-15.93.0.r371.gc1fcde6-1
kpublictransport22.04.0.r2005.g1718e551-122.04.0.r2006.g5a9ce860-1
kquickimageeditor r68.g61f48f8-1 r69.g43b8194-1
krdc22.04.0.r1580.g17bb70e-122.04.0.r1581.g03f9a66-1
krecorder 22.04.r0.gc749dab-1 22.04.r4.g9c6ef50-1
krfb22.04.0.r1479.gfcebbfb-122.04.0.r1485.g17d3f53-1
kscreenlocker5.24.4.r926.g6bfb981-15.24.4.r933.gbdf08b1-1
kservice5.93.0.r1005.g8d038e2-15.93.0.r1006.g3ee50d4-1
ksshaskpass5.24.4.r206.g1412c4a-15.24.4.r207.g5110d15-1
ksudoku22.04.0.r1100.g62cdaa2-122.04.0.r1103.gdf7f631-1
ksysguard5.24.4.r3525.g02dc1395-15.24.4.r3527.g201f9174-1
ksystemlog22.04.0.r719.gd9d9244-122.04.0.r721.ge731263-1
ksystemstats5.24.4.r219.g6fd7f37-15.24.4.r220.ga54cd46-1
kteatime22.04.0.r750.g23998f6-122.04.0.r752.gfea14d1-1
ktexteditor5.93.0.r3350.gf3cd48fc-15.93.0.r3353.gb06e6b0f-1
ktorrent22.04.0.r2838.g86932d7a-122.04.0.r2840.gbeba8171-1
ktouch22.04.0.r2175.gc5b9c00-122.04.0.r2176.g8cbf36e-1
ktrip 22.02.r9.g93c79a0-1 22.04.r2.g0ef33c8-1
kubrick22.04.0.r399.g81a247c-122.04.0.r400.g650ce3f-1
kwallet5.93.0.r1141.g5e2ae66-15.93.0.r1143.g6cc6174-1
kwalletmanager22.04.0.r1264.g7c3af2b-122.04.0.r1267.g8eeefb6-1
kwayland-server5.24.4.r1478.g6c8002b-15.24.4.r1479.g1b6b6e9-1
kweather 22.04.r0.gd4b2720-1 22.04.r3.gb6b6b5f-1
kwin5.24.4.r21127.gcc6b54911-15.24.4.r22351.g87e72506b-1
kwrite22.04.0.r18945.gdadf8130e-122.04.0.r18984.g7753a3c03-1
layer-shell-qt5.24.2.r55.gae883df-15.24.4.r55.gae883df-1
libkcddb22.04.0.r752.gee0f14e-122.04.0.r759.g117d30f-1
libkcompactdisc22.04.0.r392.g056d3bf-122.04.0.r394.g45a78f3-1
libkeduvocdocument22.04.0.r1809.g3a34565-122.04.0.r1810.g5b20cc7-1
libkleo22.04.0.r1136.g2da96d2-122.04.0.r1142.gcf01300-1
libkmahjongg22.04.0.r478.g99719ee-122.04.0.r479.g398fb7f-1
libkscreen5.24.4.r1621.gcb34c9a-15.24.4.r1622.g85780ca-1
libksieve22.04.0.r1693.g1598612c-122.04.0.r1694.gc147f140-1
mailcommon22.04.0.r1229.gaa7cb35-122.04.0.r1230.gec36803-1
maliit-framework 2.2.1.r8.gc220a8c8-12.2.1.r18.g779a9471-1
marble22.04.0.r13424.gf6c340322-122.04.0.r13425.g90f92105e-1
marble-common22.04.0.r13424.gf6c340322-122.04.0.r13425.g90f92105e-1
marble-qt22.04.0.r13424.gf6c340322-122.04.0.r13425.g90f92105e-1
markdownpart22.04.0.r110.g15fb104-122.04.0.r111.gfd655bd-1
maui-pix 2.1.0.r20.gaffcf43-1 2.1.0.r23.g9a7ce1c-1
maui-shell 0.5.0.r15.g8b9a927-1 0.5.0.r17.gdf25c04-1
mauikit2.1.1.r18.g39fabe30-12.1.1.r19.g702845e6-1
mauikit-filebrowsing 2.1.1.r1.gf63bf6e-1 2.1.1.r2.g9fe9bff-1
milou5.24.4.r764.g8118e8d-15.24.4.r768.g642d370-1
mycroft-bigscreen21.2.2.r4910.gf030b7e165-221.2.2.r4911.ga909fc8f19-1
neochat22.02.r58.g180a754e-1 22.04.r4.gb64cd3c1-1
networkmanager-qt5.93.0.r1150.ga7b1849-15.93.0.r1151.g74b8f39-1
okular22.04.0.r9703.g8f54710b5-122.04.0.r9718.g7c596be34-1
oxygen5.24.4.r4462.g4709cec4-15.24.4.r4464.gf898b70d-1
partitionmanager22.04.0.r1610.g3b6093f-122.04.0.r1612.g6930d47-1
picmi22.04.0.r559.gdbb68b9-122.04.0.r560.g9cc0df5-1
pim-data-exporter22.04.0.r2590.g6bc8daca-122.04.0.r2625.g48fd3bb1-1
pim-sieve-editor22.04.0.r1617.gd95bbb8-122.04.0.r1618.g2fab796-1
pimcommon21.12.2.r1215.g65fbabb-122.04.0.r1218.gd6f0a7b-1
plasma-browser-integration5.24.4.r1315.gb8f751fd-15.24.4.r1316.gf2086f25-1
plasma-desktop5.24.4.r9207.gb7f0d8ad4-15.24.4.r9222.gd21f5cfbb-1
plasma-dialer 22.02.r22.gdb9dad0-1 22.04.r6.gbef9fb6-1
plasma-firewall5.24.4.r609.g88a01b2-15.24.4.r616.gea46f45-1
plasma-framework5.93.0.r16264.g1db3a46aa-15.93.0.r16277.ga05965f06-1
plasma-mobile5.24.4.r1732.gf0e1d4e46-15.24.4.r1747.ga18313b44-1
plasma-mobile-nm5.24.4.r3235.g4651adc7-15.24.4.r3237.g721e6a22-1
plasma-nm5.24.4.r3235.g4651adc7-15.24.4.r3237.g721e6a22-1
plasma-pa5.24.4.r1044.g9ecc5a5-15.24.4.r1046.g0608769-1
plasma-phonebook 22.04.r0.g43cd575-1 22.04.r2.g17b3e1b-1
plasma-settings 22.04.r1.g031bdd8-1 22.04.r6.g58dd132-1
plasma-wayland-session5.24.4.r11686.g5292eb426-15.24.4.r11706.g13e1ddcf9-1
plasma-workspace5.24.4.r11686.g5292eb426-15.24.4.r11706.g13e1ddcf9-1
plasma-workspace-wallpapers5.24.4.r334.g709fbae-15.24.4.r336.g685fa57-1
plasmatube 22.02.r15.g7e97658-1 22.04.r3.g5503113-1
powerdevil5.24.4.r2529.g94f81868-15.24.4.r2537.gce15edd2-1
prison5.93.0.r370.gb74a73b-15.93.0.r371.gc5a70fc-1
pulseaudio-qt 1.3.0.r18.g126aa3e-1 1.3.0.r19.g38a3558-1
qmlkonsole 22.04.r0.g8d3b279-1 22.04.r11.g6199fee-1
sddm-kcm5.24.4.r645.g9b7062d-15.24.4.r646.g0ed6926-1
spacebar 22.04.r1.gb5b1446-1 22.04.r2.gf117f55-1
spectacle22.04.0.r1339.g8e00fd6-122.04.0.r1341.g1c174d0-1
step22.04.0.r1181.g96612a7-122.04.0.r1182.g6a6edd3-1
systemsettings5.24.4.r2642.gae29f170-15.24.4.r2648.g4f5dbf01-1
telepathy-kde-approver22.04.0.r300.gbcee3ed-122.04.0.r301.g420e8ac-1
telepathy-kde-common-internals22.04.0.r2009.gf67843e-122.04.0.r2010.g48a8c04-1
tokodon 22.02.r25.g0394cd7-1 22.04.r3.g37e95c6-1
umbrello22.04.0.r8448.ga42f0cbe6-122.04.0.r8453.g7ff869767-1
vakzination 22.02.r5.g3c8be02-1 22.04.r6.g74a99e5-1
vvave 2.1.1.r10.gea81747-1 2.1.1.r13.g1407d5f-1
xdg-desktop-portal-kde5.24.4.r455.gee713b2-15.24.4.r469.gf781751-1
yakuake22.04.0.r784.g871e27f-122.04.0.r788.gc9bf101-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
