Hello ARM community.
Sorry for the long wait, but here’s the next update for you all to test.
Some highlights:
- Most of our kernels got updated
- Plasma Mobile Gear updated to 22.04
- And regular KDE Gear updated to 22.04.0
- Manjaro Settings Manager updated to 0.5.7
- Some more Uboots updated to 22.04
- RPI Imager updated to 1.7.2
- And Osmin got updated to 1.8.6
- LXQT updated to 1.1.0
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Mon Apr 25 20:33:00 CEST 2022)
- arm-testing community aarch64: 592 new and 561 removed package(s)
- arm-testing core aarch64: 45 new and 45 removed package(s)
- arm-testing extra aarch64: 551 new and 556 removed package(s)
- arm-testing kde-unstable aarch64: 289 new and 289 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-04-19 2022-04-25
alligator 22.02-1 22.04-1
amazfish 2.0.5-2 2.0.8-1
angelfish 22.02-1 22.04-1
audiotube 22.02-1 22.04-1
calindori 22.02-1 22.04-1
electron 18.0.4-1 18.1.0-1
electron16 16.2.2-1 16.2.3-1
electron17 17.3.0-1 17.4.1-1
kalk 22.02-1 22.04-1
kasts 22.02-1 22.04-1
kclock 22.02-1 22.04-1
keysmith 22.02-1 22.04-1
khealthcertificate 22.02-1 22.04-1
koko 22.02-1 22.04-1
kongress 22.02-1 22.04-1
krecorder 22.02-1 22.04-1
ktrip 22.02-1 22.04-1
kweather 22.02-1 22.04-1
nemo-qml-plugin-dbus 2.1.25-1 2.1.28-1
osmin 1.8.4-1 1.8.6-1
pika-backup 0.4.0.beta.3-1 0.4.0.beta.4-1
plasma-dialer 22.02-2 22.04-1
plasma-phonebook 22.02-1 22.04-1
plasma-settings 22.02-1 22.04-1
qmlkonsole 22.02-1 22.04-1
rpi-imager 1.6.2-2 1.7.2-1
signal-desktop 5.39.0-1 5.40.1-1
spacebar 22.02.2-1 22.04-1
tokodon 22.02-1 22.04-1
vakzination 22.02-1 22.04-1
vvmd 0.7-1 0.8-1
:: Different sync package(s) in repository community aarch64
acme 2020.08.26-2 2020.08.26-3
allegro 5.2.7.0-2 5.2.7.0-3
amtk 5.3.1-1 5.3.2-1
antlr4 4.9.3-1 4.10.1-1
antlr4-runtime 4.9.3-4 4.10.1-2
appstream-generator 0.8.7-3 0.8.8-1
arduino-cli 0.19.3-1 0.19.3-2
arpack 3.8.0-1 3.8.0-2
arpwatch 3.1-2 3.3-1
aspell-nn 0.50.1-4 0.50.1-5
at51 1.0.0-1 1.0.0-3
atuin 0.8.1-1 0.9.1-1
avr-gcc 11.2.0-1 11.3.0-1
aws-c-auth 0.6.8-1 0.6.11-1
aws-c-cal 0.5.12-1 0.5.17-1
aws-c-common 0.6.19-1 0.6.20-1
aws-c-http 0.6.10-1 0.6.14-1
aws-c-io 0.10.16-1 0.10.22-1
aws-c-s3 0.1.30-1 0.1.38-1
aws-c-sdkutils 0.1.1-1 0.1.2-1
aws-crt-cpp 0.17.13-1 0.17.27-1
beebeep 5.8.4-4 5.8.4-5
blackmagic 1.7.1-1 1.7.1-2
bladerf 2021.03-1 2021.10-1
bonzomatic 1.0.20210307-1 1.0.20210307-2
browserpass 3.0.9-1 3.0.10-1
bsdiff 4.3-10 4.3-11
bspwm 0.9.10-1 0.9.10-2
btrfs-heatmap 9-1 9-2
bwm-ng 0.6.3-1 0.6.3-2
calc 2.14.0.8-1 2.14.0.8-2
calcurse 4.7.1-2 4.8.0-1
calibre 5.40.0-1 5.41.0-1
camlp4 4.13+1-2 4.13+1-3
cargo-depgraph 1.2.2-3 1.2.4-1
cargo-nextest 0.9.12-1 0.9.14-1
cargo-outdated 0.11.0-1 0.11.1-1
cargo-pgx 0.4.2-1 0.4.3-1
cargo-release 0.20.3-1 0.20.5-1
cataclysm-dda 0.F.3-1 0.F.3-2
cataclysm-dda-tiles 0.F.3-1 0.F.3-2
cbatticon 1.6.12-1 1.6.12-2
cgasm 1.0.0-2 1.0.0-3
cherrytree 0.99.46-1 0.99.47-1
chicken 5.3.0-2 5.3.0-3
choose 1.3.3-2 1.3.4-1
ciano 0.2.4-3 0.2.4-4
clasp 3.3.7-1 3.3.7-2
clojure 1.11.1.1105-1 1.11.1.1105-2
cm256cc 1.1.0-1 1.1.0-2
corrade 2020.06-1 2020.06-2
cppcheck 2.7.4-1 2.7.5-1
crystal 1.4.0-1 1.4.1-1
ctwm 4.0.3-1 4.0.3-2
cutefish-settings 0.8-1 0.8-2
cycfx2prog 0.47-2 0.47-3
dark-reader 4.9.47-1 4.9.48-1
dart-sass 1.50.0-1 1.50.1-1
difftastic 0.26.3-1 0.27.0-1
diffuse 0.7.4-1 0.7.4-2
din 53.1-1 54-1
dino 0.3.0-2 0.3.0-3
djview 4.12-2 4.12-3
docopt 0.6.3-1 0.6.3-2
dovecot 2.3.18-1 2.3.18-2
dovecot-fts-xapian 1.5.4.b-1 1.5.5-1
dpdk 21.11-1 21.11-2
dpkg 1.21.7-1 1.21.7-2
drone-runner-docker 1.8.0-1 1.8.1-1
dropbear 2022.82-1 2022.82-2
dropbear-scp 2022.82-1 2022.82-2
dsdp 5.8-5 5.8-6
duktape 2.7.0-1 2.7.0-2
dune 3.0.3-2 3.1.0-1
dunesh 0.1.7-1 0.1.7-2
dwdiff 2.1.4-3 2.1.4-4
e-antic 1.1.1-1 1.2.0-1
elfkickers 3.2-1 3.2-2
entr 5.0-1 5.0-2
erlang 24.3.2-2 24.3.2-3
erlang-cl 1.2.4-4 1.2.4-5
erlang-docs 24.0-1 24.0-2
erlang-nox 24.3.2-1 24.3.2-2
erlang-unixodbc 24.3.2-2 24.3.2-3
facter 3.14.22-2 3.14.23-1
fceux 2.6.4-1 2.6.4-2
fcitx-mozc2.26.4360.102.gca82d39-12.26.4360.102.gca82d39-2
fff 2.2-1 2.2-2
findomain 8.1.0-1 8.1.1-1
firefox-dark-reader 4.9.47-1 4.9.48-1
firefox-tree-style-tab 3.8.21-1 3.8.22-1
flameshot 11.0.0-4 11.0.0-5
flterm 2.4-1 2.4-2
fontobene-qt5 0.2.0-1 0.2.0-2
freeciv 3.0.0-1 3.0.1-1
freeradius 3.0.25-5 3.2.0-1
freerdp 2:2.6.1-1 2:2.6.1-3
fuse-zip 0.7.2-1 0.7.2-2
fvextra 1.4-1 1.4-2
fwbuilder 5.3.7-10 5.3.7-11
galculator 2.1.4-6 2.1.4-7
gauche 0.9.11-2 0.9.11-3
gavl 1.4.0-5 1.4.0-6
gcolor3 2.4.0-3 2.4.0-4
geany 1.38-1 1.38-2
geary 1:40.0-7 1:40.0-8
geda-gaf 1.10.2-1 1.10.2-2
geotag 0.103-3 0.103-4
gephi 0.9.2-3 0.9.4-1
gftp 2.9.1b-1 2.9.1b-2
gimagereader-common 3.4.0-2 3.4.0-3
gimagereader-gtk 3.4.0-2 3.4.0-3
gimagereader-qt 3.4.0-2 3.4.0-3
git-cliff 0.6.1-1 0.7.0-1
git-crypt 0.6.0-5 0.7.0-1
git-lfs 3.1.2-1 3.1.4-1
gitea 1.16.5-1 1.16.6-1
gitlab-runner 14.9.1-1 14.10.0-1
glider 0.15.3-2 0.16.1-1
glyr 1.0.10-3 1.0.10-4
gnac 0.2.4.1-10 0.2.4.1-11
gnubiff 2.2.17-9 2.2.17-10
gnustep-base 1.28.0-3 1.28.0-4
go-ipfs 0.11.0-1 0.12.2-1
gogglesmm 1.2.2-1 1.2.2-2
goocanvasmm 1.90.11-5 1.90.11-6
goxel 0.10.8-2 0.10.8-3
gpicview 0.2.5-6 0.2.5-7
gpscorrelate 2.0-2 2.0-3
grafx2 2.8-1 2.8-2
grails 5.1.1-1 5.1.1-2
grails-docs 5.1.1-1 5.1.1-2
grim 1.4.0-1 1.4.0-2
grpc 1.45.2-1 1.45.2-2
grpc-cli 1.45.2-1 1.45.2-2
gtk-sharp-3 2.99.3-3 2.99.3-4
gtk2-compat 1.0.0-2 1.0.0-3
gummi 2:0.8.2-1 2:0.8.2-2
gwget 1.0.4-17 1.0.4-18
hackrf 2021.03.1-1 2021.03.1-2
hexedit 1.5-1 1.6-1
hyphen-hu 20110815-1 20110815-2
i3status-rust 0.21.9-1 0.21.10-1
ibus-sunpinyin3.0.0rc1+32+gf39c195-13.0.0rc1+32+gf39c195-2
imv 4.3.1-3 4.3.1-5
inspectrum 0.2.3-1 0.2.3-2
intel-metee 3.1.2-2 3.1.3-1
intel-metee-doc 3.1.2-2 3.1.3-1
io 2017.09.06-5 2017.09.06-6
iwd 1.26-1 1.27-1
jad 1.5.8e-9 1.5.8e-10
jake 10.8.4-1 10.8.5-1
jenkins 2.343-1 2.344-1
jlatexmath 1.0.7-1 1.0.7-2
jmol 14.32.47-1 14.32.51-1
joyutils 1.7.1-2 1.7.1-3
jsmol 14.32.47-1 14.32.51-1
jupyter-nbclient 0.5.13-2 0.6.0-1
jupyterlab 3.3.3-2 3.3.4-1
jwm 2.4.0-1 2.4.1-1
kbibtex 1:0.9.2-6 1:0.9.2-7
kchmviewer 8.0-3 8.0-4
kde-development-environment-meta 20201210-1 20220422-2
kdiskmark 2.3.0-1 2.3.0-2
keynav 0.20180821.0-1 0.20180821.0-2
kiwix-desktop 2.2.1-2 2.2.1-3
kiwix-tools 3.2.0-3 3.2.0-4
kjots 5.1.0-2 5.1.0-3
kmymoney 5.1.2-5 5.1.2-6
kobodeluxe 0.5.1-10 0.5.1-11
kotlin 1.6.20-1 1.6.20-2
krita-plugin-gmic 3.0.2.1-1 3.0.2.2-2
l3afpad 0.8.18.1.11-5 0.8.18.1.11-6
libappindicator-gtk2 12.10.0.r296-1 12.10.0.r296-2
libappindicator-gtk3 12.10.0.r296-1 12.10.0.r296-2
libcss 0.9.1-3 0.9.1-4
libdatovka 0.2.1-1 0.2.1-2
libfm-qt 1.0.0-2 1.1.0-1
libgeotiff 1.6.0-3 1.6.0-4
libjcat 0.1.10-1 0.1.11-1
libkiwix 10.1.0-1 10.1.1-1
liblxqt 1.0.0-1 1.1.0-2
libmanette 0.2.6-2 0.2.6-3
libmodsecurity 1:3.0.6-3 1:3.0.6-4
libnsbmp 0.1.6-6 0.1.6-7
libnsgif 0.2.1-6 0.2.1-7
libopenraw 0.3.0-1 0.3.1-1
libperconaserverclient 8.0.27_18-1 8.0.27_18-2
libpgm 5.3.128-1.1 5.3.128-2
libqtxdg 3.8.0-2 3.9.0-1
libsemigroups 2.1.4-1 2.1.5-1
libtg_owt 0.git12.a264028-2 0.git13.63a934d-1
libuhd-firmware 4.1.0.1-1 4.1.0.1-2
libutf8proc 2.7.0-1 2.7.0-2
libwslay 1.1.1-3 1.1.1-4
libxmlrpc 1:1.51.08-1 1:1.51.08-2
libzim 7.2.0-1 7.2.0-2
lightdm-webkit2-greeter 2.2.5-4 2.2.5-6
liteide 37.4-1 37.4-2
lrzip 0.641-1 0.641-2
lua-bit32 5.3.5.1_0.10-3 5.3.5.1_0.10-5
lua-cassowary 2.3.1-3 2.3.2-1
lua-expat 1.4.1-1 1.4.1-2
lua-lanes 3.16.0-2 3.16.0-3
lua-linenoise 0.9-7 0.9-8
lua-luautf8 0.1.3-3 0.1.3-4
lua-sdl2 2.0.5.6.0-3 2.0.5.6.0-4
lua-system 0.2.1-8 0.2.1-9
lua-term 0.7-7 0.7-8
lua-yaml 1.1.2-5 1.1.2-7
lua51-bit32 5.3.5.1_0.10-3 5.3.5.1_0.10-5
lua51-cassowary 2.3.1-3 2.3.2-1
lua51-expat 1.4.1-1 1.4.1-2
lua51-lanes 3.16.0-2 3.16.0-3
lua51-linenoise 0.9-7 0.9-8
lua51-luautf8 0.1.3-3 0.1.3-4
lua51-system 0.2.1-8 0.2.1-9
lua51-term 0.7-7 0.7-8
lua51-yaml 1.1.2-5 1.1.2-7
lua52-bit32 5.3.5.1_0.10-3 5.3.5.1_0.10-5
lua52-cassowary 2.3.1-3 2.3.2-1
lua52-expat 1.4.1-1 1.4.1-2
lua52-lanes 3.16.0-2 3.16.0-3
lua52-linenoise 0.9-7 0.9-8
lua52-luautf8 0.1.3-3 0.1.3-4
lua52-system 0.2.1-8 0.2.1-9
lua52-term 0.7-7 0.7-8
lua52-yaml 1.1.2-5 1.1.2-7
lua53-bit32 5.3.5.1_0.10-3 5.3.5.1_0.10-5
lua53-cassowary 2.3.1-3 2.3.2-1
lua53-expat 1.4.1-1 1.4.1-2
lua53-lanes 3.16.0-2 3.16.0-3
lua53-linenoise 0.9-7 0.9-8
lua53-luautf8 0.1.3-3 0.1.3-4
lua53-system 0.2.1-8 0.2.1-9
lua53-term 0.7-7 0.7-8
lua53-yaml 1.1.2-5 1.1.2-7
luacheck 0.26.0-2 0.26.1-1
luarocks 3.8.0-1 3.9.0-1
lximage-qt 1.0.0-1 1.1.0-1
lxqt-about 1.0.0-1 1.1.0-1
lxqt-admin 1.0.0-1 1.1.0-1
lxqt-archiver 0.5.0-1 0.6.0-1
lxqt-build-tools 0.10.0-1 0.11.0-1
lxqt-config 1.0.0-1 1.1.0-1
lxqt-globalkeys 1.0.1-1 1.1.0-1
lxqt-notificationd 1.0.0-1 1.1.0-1
lxqt-openssh-askpass 1.0.0-1 1.1.0-1
lxqt-panel 1.0.0-1 1.1.0-1
lxqt-policykit 1.0.0-1 1.1.0-1
lxqt-powermanagement 1.0.0-1 1.1.0-1
lxqt-qtplugin 1.0.0-2 1.1.0-1
lxqt-runner 1.0.0-1 1.1.0-1
lxqt-session 1.0.1-1 1.1.0-1
lxqt-sudo 1.0.0-1 1.1.0-1
lxqt-themes 1.0.0-1 1.1.0-1
lzip 1.23-1 1.23-2
mailutils 3.14-2 3.15-1
maim 5.7.4-2 5.7.4-3
makedumpfile 1.7.0-4 1.7.1-1
mapnik 3.1.0-8 3.1.0-9
mathomatic 16.0.5-7 16.0.5-8
matrix-synapse 1.55.2-1 1.57.0-1
mediaelch 2.8.16-1 2.8.16-2
memconf 3.15-1 3.15-2
mg 20210314-1 20210314-2
micro 2.0.10-2 2.0.10-3
midori 9.0-3 9.0-4
minio 2022.04.01-1 2022.04.16-1
minio-client 2022.04.01-1 2022.04.16-1
minted 2.6-1 2.6-2
mongo-c-driver 1.21.1-1 1.21.1-2
moosefs 3.0.116-1 3.0.116-2
mtpaint 3.50.09-1 3.50.09-2
multimon-ng 1.1.9-1 1.1.9-2
multitail 6.5.0-1 6.5.1-1
muse 4.0.0-3 4.1.0-1
mypy 0.942-1 0.942-2
mysql-workbench 8.0.28-1 8.0.28-2
ncmpcpp 0.9.2-5 0.9.2-6
neochat 22.02-1 22.04-1
neovim 0.6.1-2 0.7.0-3
neovim-qt 0.2.16.1-1 0.2.16.1-2
nerdctl 0.18.0-1 0.19.0-1
netdata 1.33.1-1 1.34.1-1
netsurf-buildsystem 1.9-1 1.9-2
networkmanager-l2tp 1.20.0-2 1.20.0-3
nextcloud-app-bookmarks 1:10.3.0-1 1:10.3.1-1
nextcloud-app-news 18.0.0-1 18.0.1-1
ngircd 26.1-1 26.1-2
ngspice 36-1 36-2
nix 2.7.0-1 2.8.0-1
nix-docs 2.7.0-1 2.8.0-1
nodejs 17.9.0-1 17.9.0-2
nodejs-lts-erbium 12.22.12-1 12.22.12-2
nodejs-lts-fermium 14.19.1-1 14.19.1-2
nodejs-lts-gallium 16.14.2-1 16.14.2-2
nomacs 1:3.17.2206-6 1:3.17.2206-7
normaliz 3.9.2-1 3.9.3-1
nsgenbind 0.8-1 0.8-2
octave 7.1.0-2 7.1.0-3
openfpgaloader 0.5.0-1 0.5.0-2
openocd 1:0.11.0-1 1:0.11.0-2
openrct2 0.3.5.1-3 0.3.5.1-4
openttd 12.2-1 12.2-3
opus-tools 0.2-3 0.2-4
opusfile 0.12-1 0.12-2
parallel 20220322-1 20220422-1
parallel-docs 20220322-1 20220422-1
pasystray 0.8.0-1 0.8.0-2
patroneo 2.3.1-1 2.3.2-1
pavucontrol-qt 1.0.0-2 1.1.0-1
pcb 1:4.3.0-1 1:4.3.0-2
pcmanfm-qt 1.0.0-1 1.1.0-1
pekwm 0.2.1-1 0.2.1-2
percona-server 8.0.27_18-1 8.0.27_18-2
percona-server-clients 8.0.27_18-1 8.0.27_18-2
perl-goocanvas2 0.06-3 0.06-4
perl-ppi 1.272-1 1.273-1
perl-ppix-quotelike 0.021-1 0.022-1
perl-ppix-regexp 0.084-1 0.085-1
php-grpc 1.45.2-1 1.45.2-2
php-mongodb 1.13.0-1 1.13.0-2
php7-grpc 1.45.2-1 1.45.2-2
php7-mongodb 1.13.0-1 1.13.0-2
pinfo 0.6.13-1 0.6.13-2
plan9port 20211019-1 20211019-2
plantuml 1.2022.4-1 1.2022.4-2
plantuml-ascii-math 20171116-2 20171116-3
poedit 1:3.0.1-1 1:3.0.1-2
polyml 5.9-1 5.9-2
posterazor 1.9.7.pre-1 1.9.7.pre-2
postgis 3.2.0-1 3.2.1-1
povray 2:3.7.0.10-1 2:3.7.0.10-2
prjtrellis-db r262.f7f8375-1 r262.f7f8375-2
prjxray-db r225.1a4ee7c-1 r225.1a4ee7c-2
ps_mem 3.13-1 3.13-2
puppet 7.15.0-1 7.16.0-1
py3status 3.43-1 3.44-1
pyright 1.1.237-1 1.1.239-1
python-antlr4 4.9.3-2 4.10.1-1
python-argparse-addons 0.7.0-2 0.8.0-1
python-astroid 2.11.2-1 2.11.3-1
python-authheaders 0.14.1-3 0.15.1-1
python-babel 2.9.1-3 2.10.1-1
python-diff-cover 6.4.5-1 6.5.0-1
python-django-compressor 3.1-1 4.0-1
python-doit 0.35.0-1 0.36.0-1
python-fonttools 4.32.0-1 4.33.2-1
python-frozendict 1:2.3.0-1 1:2.3.1-1
python-geographiclib 1.52-3 2.0-1
python-google-api-python-client 2.44.0-1 2.45.0-1
python-grpcio 1.45.2-1 1.45.2-2
python-igraph 0.9.9-1 0.9.10-1
python-importlib_resources 5.7.0-1 5.7.1-1
python-ipykernel 6.12.1-1 6.13.0-1
python-jupyter_core 4.9.2-1 4.10.0-1
python-minio 7.1.6-2 7.1.7-1
python-pg8000 1.24.2-1 1.26.1-1
python-pikepdf 5.1.1-1 5.1.2-1
python-pipenv 2022.4.8-1 2022.4.21-1
python-pivy 0.6.6-4 0.6.6-5
python-pwntools 4.7.0-2 4.8.0-1
python-py7zr 0.18.3-1 0.18.4-1
python-pyglet 1.5.22-1 1.5.23-1
python-pygments 2.11.2-1 2.12.0-1
python-pyicu 2.8.1-1 2.9-1
python-pylint 2.13.5-1 2.13.7-1
python-pymongo 3.12.3-1 4.0-1
python-pynetbox 6.6.1-1 6.6.2-1
python-pytest 7.1.1-1 7.1.2-1
python-pywayland 0.4.11-1 0.4.12-1
python-pywlroots 0.15.12-1 0.15.13-1
python-signedjson 1.1.1-5 1.1.4-1
python-sphinx-click 4.0.2-1 4.0.3-1
python-sphinxcontrib-bibtex 2.4.1-2 2.4.2-1
python-sword 1.9.0-4 1.9.0-5
python-typed-ast 1.5.2-1 1.5.3-1
python-typing_extensions 4.1.0-1 4.2.0-1
python-ujson 5.1.0-2 5.2.0-1
python-unicorn 1.0.3-4 1.0.3-5
python-z3 4.8.14-1 4.8.15-1
python-zita-audiotools 1.0.0-10 1.3.0-1
python-zita-jacktools 1.5.3-2 1.6.0-1
qbittorrent 4.4.2-1 4.4.2-2
qbittorrent-nox 4.4.2-1 4.4.2-2
qmapshack 1.16.1-1 1.16.1-2
qmc2 0.195-3 0.242-1
qpwgraph 0.2.5-1 0.2.6-2
qterminal 1.0.0-1 1.1.0-1
qtermwidget 1.0.0-1 1.1.0-1
r10k 3.13.0-1 3.14.2-1
radicale 3.1.5-2 3.1.7-1
raylib 4.0.0-1 4.0.0-2
rekor 0.5.0-1 0.6.0-1
repo 2.22-1 2.23-1
retext 7.2.2-2 7.2.3-1
rkward 0.7.2-2 0.7.3-1
rspamd 3.2-2 3.2-3
rstcheck 3.5.0-1 5.0.0-1
rtorrent 0.9.8-2 0.9.8-3
ruby-fast_gettext 2.0.3-3 2.2.0-1
ruby-puppet_forge 3.1.0-1 3.2.0-1
ruby-rugged 1.4.2-1 1.4.3-1
ruby-unicorn-engine 1.0.3-4 1.0.3-5
rust-analyzer 20220411-1 20220418-1
s2n-tls 1.3.3-1 1.3.11-1
sasteroids 3.0.1-9 3.0.1-10
scrcpy 1.23-1 1.23-2
screengrab 2.3.0-1 2.4.0-1
scribus 1.5.8-3 1.5.8-4
sdcc 4.2.0-1 4.2.0-2
sdl_mixer 1.2.12-10 1.2.12-11
seamonkey 2.53.11.1-1 2.53.11.1-2
serialdv 1.1.4-1 1.1.4-2
serverless 3.14.0-1 3.15.2-1
shellharden 4.2.0-1 4.2.0-2
shhmsg 1.4.2-4 1.4.2-5
shhopt 1.1.7-5 1.1.7-6
shotcut 22.03.30-1 22.04.22-1
sile 0.12.4-1 0.12.5-1
simple-scan 42.0-1 42.1-1
simplescreenrecorder 0.4.3-2 0.4.4-1
skk-jisyo 20210926-1 20210926-2
slib 3b6-1 3b6-2
slop 7.5-6 7.5-7
smem 1.5-2 1.5-3
snd 22.2-1 22.3-1
snorenotify 0.7.0-4 0.7.0-5
soapyuhd 0.4.1-4 0.4.1-5
songrec 0.3.0-2 0.3.1-1
soqt 1.6.0-2 1.6.0-3
spectrwm 3.4.1-1 3.4.1-2
spike 1.1.0-1 1.1.0-3
sqlfluff 0.12.0-1 0.13.0-1
staticcheck 2022.1-1 2022.1.1-1
step-ca 0.18.2-1 0.19.0-1
step-cli 0.18.2-1 0.19.0-1
sthttpd 2.27.1-3 2.27.1-4
strawberry 1.0.3-1 1.0.4-1
stylelint 14.7.0-1 14.7.1-1
sundials 6.1.1-1.1 6.2.0-1
suscan 0.1.0-5 0.1.0-6
swi-prolog 8.4.2-1 8.4.2-2
sxhkd 0.6.2-1 0.6.2-2
tachyon 0.99.4-1 0.99.5-1
tailscale 1.22.2-1 1.24.0-1
tamsyn-font 1.11-4 1.11-5
tectonic 0.8.2-1 0.8.2-2
telegram-desktop 3.6.1-3 3.7.1-2
tepl 6.00.0-4 6.00.0-5
tesseract 5.1.0-1 5.1.0-2
texstudio 4.2.2-1 4.2.3-1
thunderbird-dark-reader 4.9.47-1 4.9.48-1
tint2 17.0.2-1 17.0.2-2
tinyxml 2.6.2-8 2.6.2-9
tmuxp 1.10.0-1 1.10.1-1
toxic 0.11.3-1 0.11.3-2
trash-cli 0.21.10.24-3 0.22.4.16-1
trivy 0.25.4-1 0.26.0-2
ttc-iosevka 15.1.0-1 15.2.0-1
ttc-iosevka-aile 15.1.0-1 15.2.0-1
ttc-iosevka-curly 15.1.0-1 15.2.0-1
ttc-iosevka-curly-slab 15.1.0-1 15.2.0-1
ttc-iosevka-etoile 15.1.0-1 15.2.0-1
ttc-iosevka-slab 15.1.0-1 15.2.0-1
ttc-iosevka-ss01 15.1.0-1 15.2.0-1
ttc-iosevka-ss02 15.1.0-1 15.2.0-1
ttc-iosevka-ss03 15.1.0-1 15.2.0-1
ttc-iosevka-ss04 15.1.0-1 15.2.0-1
ttc-iosevka-ss05 15.1.0-1 15.2.0-1
ttc-iosevka-ss06 15.1.0-1 15.2.0-1
ttc-iosevka-ss07 15.1.0-1 15.2.0-1
ttc-iosevka-ss08 15.1.0-1 15.2.0-1
ttc-iosevka-ss09 15.1.0-1 15.2.0-1
ttc-iosevka-ss10 15.1.0-1 15.2.0-1
ttc-iosevka-ss11 15.1.0-1 15.2.0-1
ttc-iosevka-ss12 15.1.0-1 15.2.0-1
ttc-iosevka-ss13 15.1.0-1 15.2.0-1
ttc-iosevka-ss14 15.1.0-1 15.2.0-1
ttc-iosevka-ss15 15.1.0-1 15.2.0-1
ttc-iosevka-ss16 15.1.0-1 15.2.0-1
ttc-iosevka-ss17 15.1.0-1 15.2.0-1
ttc-iosevka-ss18 15.1.0-1 15.2.0-1
ttf-anonymous-pro 1.003-5 1.003-6
ttf-fira-code 6.2-1 6.2-2
ttf-jetbrains-mono 2.242-1 2.242-2
tupitube 0.2.18-2 0.2.18-3
twin 0.9.0-1 0.9.0-2
typespeed 0.6.5-8 0.6.5-9
ucblogo 6.2.2-1 6.2.2-2
ufw-extras 0.7.0-1 0.7.0-2
unarchiver 1.10.7-5 1.10.7-6
units 2.21-2 2.21-3
unittestpp 2.0.0-3 2.0.0-4
v2ray-domain-list-community 20220413144601-1 20220419022654-1
v2ray-geoip 202204140052-1 202204210050-1
vaultwarden-web 2.27.0-1 2.28.0-1
vc-intrinsics 0.1.0.r5+g99ac111-1 0.2.0-1
vtk 9.1.0-13 9.1.0-14
wasmtime 0.35.3-1 0.36.0-1
watchexec 1.18.12-1 1.19.0-1
wcslib 7.9-1 7.10-1
wgcf 2.2.12-1 2.2.13-1
winetricks 20220328-1 20220411-1
woff-fira-code 6.2-1 6.2-2
woff2-fira-code 6.2-1 6.2-2
wordpress 5.9.3-1 5.9.3-2
wtf 20200613-1 20200613-2
wvstreams 4.6.1-17 4.6.1-18
xalan-c 1:1.12-4 1:1.12-5
xaos 4.2.1-1 4.2.1-2
xcftools 1.0.7-7 1.0.7-8
xcircuit 3.10.30-1 3.10.30-2
xdelta3 3.1.0-2 3.1.0-3
xdiskusage 1.60-1 1.60-2
xfsdump 3.1.10-1 3.1.10-2
xh 0.15.0-1 0.16.0-1
xplc 0.3.13-9 0.3.13-10
yaz 5.31.1-1 5.31.1-2
zile 2.6.2-1 2.6.2-2
zint 2.10.0-1 2.10.0-2
zint-qt 2.10.0-1 2.10.0-2
zk 0.9.0-1 0.9.0-2
znc 1.8.2-7 1.8.2-8
zoxide 0.8.0-1 0.8.1-2
zutty 0.11-1 0.11-2
bore - 0.4.0-1
diskonaut - 0.11.0-2
fennel - 1.1.0-2
fnlfmt - 0.2.2-2
fx - 21.0.0-3
jwt-cli - 5.0.2-1
laborejo - 2.0.3-1
libvterm01 - 0.1.4-2
lua-cldr - 0.2.0-2
lua-fluent - 0.2.0-2
lua-loadkit - 1.1.0-1
lua51-cldr - 0.2.0-2
lua51-fluent - 0.2.0-2
lua51-loadkit - 1.1.0-1
lua52-cldr - 0.2.0-2
lua52-fluent - 0.2.0-2
lua52-loadkit - 1.1.0-1
lua53-cldr - 0.2.0-2
lua53-fluent - 0.2.0-2
lua53-loadkit - 1.1.0-1
memray - 1.0.3-4
pgcli - 3.4.1-2
plantuml-server - 1.2022.4-1
python-cli_helpers - 2.2.1-2
python-pgspecial - 1.13.1-2
r - 4.2.0-1
rust-script - 0.20.0-2
tembro - 0.5.0-1
typescript-language-server - 0.9.7-2
virt-what - 1.21-2
xdg-desktop-portal-lxqt - 0.2.0-1
:: Different overlay package(s) in repository core aarch64
linux 5.17.3-1 5.17.4-1
linux-clockworkpi-a06 5.17.3-1 5.17.4-1
linux-clockworkpi-a06-headers 5.17.3-1 5.17.4-1
linux-headers 5.17.3-1 5.17.4-1
linux-lts 5.15.34-1 5.15.35-1
linux-lts-headers 5.15.34-1 5.15.35-1
linux-odroid 5.16.16-1 5.17.3-1
linux-odroid-headers 5.16.16-1 5.17.3-1
linux-pinephone 5.17.3-2 5.17.4-1
linux-pinephone-headers 5.17.3-2 5.17.4-1
linux-pinephonepro 5.17.3-2 5.17.4-1
linux-pinephonepro-headers 5.17.3-2 5.17.4-1
linux-rc 5.18.rc3-1 5.18.rc4-1
linux-rc-headers 5.18.rc3-1 5.18.rc4-1
linux-rpi4 5.15.33-1 5.15.34-1
linux-rpi4-headers 5.15.33-1 5.15.34-1
linux-rpi4-mainline 5.17.2-1 5.17.3-1
linux-rpi4-mainline-headers 5.17.2-1 5.17.3-1
raspberrypi-bootloader 20220330-1 20220419-1
raspberrypi-bootloader-x 20220330-1 20220419-1
uboot-pine64 2021.10-2 2022.04-1
uboot-pine64-lts 2021.10-2 2022.04-1
uboot-pinebook 2021.10-2 2022.04-1
uboot-pinebookpro 2021.10-2 2022.04-1
uboot-rock64 2021.10-3 2022.04-1
uboot-rockpi4b 2022.01-2 2022.04-1
uboot-rockpi4c 2022.01-2 2022.04-1
uboot-rockpro64 2021.10-2 2022.04-1
:: Different sync package(s) in repository core aarch64
archlinux-keyring 20220224-1 20220424-1
coreutils 9.0-2 9.1-1
dialog 1:1.3_20220117-1 1:1.3_20220414-1
glib2 2.72.0-1 2.72.1-1
glib2-docs 2.72.0-1 2.72.1-1
icu 70.1-1 71.1-1
json-c 0.15-3 0.16-1
libaio 0.3.112-3 0.3.113-1
libcap 2.63-2 2.64-1
libcap-ng 0.8.2-7 0.8.3-1
libnl 3.5.0-3 3.6.0-1
libxml2 2.9.13-1 2.9.13-2
minizip 1:1.2.12-1 1:1.2.12-2
python-capng 0.8.2-7 0.8.3-1
wireless-regdb 2022.02.18-3 2022.04.08-1
xfsprogs 5.15.0-1 5.15.0-2
zlib 1:1.2.12-1 1:1.2.12-2
:: Different overlay package(s) in repository extra aarch64
boxit-arm 2.1.3-8 2.1.3-10
calamares 3.2.54-1 3.2.54-3
elisa-qtmm 21.12.3-1 22.04.0-1
manjaro-settings-manager 0.5.6-10 0.5.7-1
manjaro-settings-manager-kcm 0.5.6-10 0.5.7-1
mesa-git22.2.0_devel.152473.11c462534bd-122.2.0_devel.152789.6bef59f56b3-1
okular 21.12.3-1 22.04.0-1
qt5-es2-base 5.15.3+kde+r137-1 5.15.3+kde+r137-2
qt5-es2-xcb-private-headers 5.15.3+kde+r137-1 5.15.3+kde+r137-2
:: Different sync package(s) in repository extra aarch64
389-ds-base 2.1.0-1 2.1.0-2
adwaita-icon-theme 42.0-1 42.0+r1+gc144c3d75-1
akonadi 21.12.3-2 22.04.0-1
akonadi-calendar 21.12.3-1 22.04.0-1
akonadi-calendar-tools 21.12.3-1 22.04.0-1
akonadi-contacts 21.12.3-1 22.04.0-1
akonadi-import-wizard 21.12.3-1 22.04.0-1
akonadi-mime 21.12.3-1 22.04.0-1
akonadi-notes 21.12.3-1 22.04.0-1
akonadi-search 21.12.3-1 22.04.0-1
akonadiconsole 21.12.3-1 22.04.0-1
akregator 21.12.3-1 22.04.0-1
analitza 21.12.3-1 22.04.0-1
appstream 0.15.2-1 0.15.3-1
appstream-qt 0.15.2-1 0.15.3-1
archboot-arm 2022.04-24 2022.04-38
archlinux-appstream-data 20220327-1 20220422-1
ark 21.12.3-1 22.04.0-1
artikulate 21.12.3-1 22.04.0-1
assimp 5.2.2-1 5.2.3-1
at-spi2-core 2.44.0-2 2.44.1-1
audiocd-kio 21.12.3-1 22.04.0-1
baloo-widgets 21.12.3-1 22.04.0-1
bigloo 4.4c_2-1 4.4c_4-1
blas 3.10.0-1 3.10.1-1
blinken 21.12.3-1 22.04.0-1
bomber 21.12.3-1 22.04.0-1
boost 1.78.0-1 1.78.0-2
boost-libs 1.78.0-1 1.78.0-2
bovo 21.12.3-1 22.04.0-1
brltty 6.4-9 6.4-10
calendarsupport 21.12.3-1 22.04.0-1
calligra 3.2.1-31 3.2.1-32
cantor 21.12.3-1 22.04.0-1
cbindgen 0.21.0-1 0.23.0-1
cblas 3.10.0-1 3.10.1-1
cervisia 21.12.3-1 22.04.0-1
chromium 100.0.4896.127-1 100.0.4896.127-2
clisp 2.49.93-5 2.49.93-6
conky 1.12.2-1 1.12.2-2
digikam 7.6.0-1 7.6.0-2
dolphin 21.12.3-1 22.04.0-1
dolphin-plugins 21.12.3-1 22.04.0-1
dragon 21.12.3-1 22.04.0-1
ecl 21.2.1-2.1 21.2.1-3
elisa 21.12.3-1 22.04.0-1
ell 0.49-1 0.50-1
enchant 2.3.2-1 2.3.2-2
eog 42.0-1 42.1-1
eog-docs 42.0-1 42.1-1
eog-plugins 42.0-1 42.1-1
epiphany 42.1-1 42.2-1
eventviews 21.12.3-1 22.04.0-1
evince 42.1-1 42.2-1
evince-lib-docs 42.1-1 42.2-1
evolution 3.44.0-1 3.44.1-1
evolution-bogofilter 3.44.0-1 3.44.1-1
evolution-data-server 3.44.0-1 3.44.1-1
evolution-ews 3.44.0-1 3.44.1-1
evolution-spamassassin 3.44.0-1 3.44.1-1
exiv2 0.27.5-1 0.27.5-3
falkon 3.2.0-2 22.04.0-1
ffcall 2.4-1 2.4-2
ffmpegthumbs 21.12.3-1 22.04.0-1
filelight 21.12.3-1 22.04.0-1
freetds 1.3.9-1.1 1.3.10-1
freetype2 2.12.0-1 2.12.0-2
freetype2-demos 2.12.0-1 2.12.0-2
freetype2-docs 2.12.0-1 2.12.0-2
fribidi 1.0.11-1 1.0.12-1
ghex 42.0-1 42.1-1
ghex-docs 42.0-1 42.1-1
git 2.35.3-1 2.36.0-1
glslang 11.8.0-2 11.9.0-1
gnome-builder42.0+r12+gfd803f606-1 42.1-1
gnome-builder-libide-docs42.0+r12+gfd803f606-1 42.1-1
gnome-maps 42.0-2 42.1-1
gnome-remote-desktop 42.0-1 42.1-1
granatier 21.12.3-1 22.04.0-1
grantlee-editor 21.12.3-1 22.04.0-1
grantleetheme 21.12.3-1 22.04.0-1
gspell 1.8.4-1 1.10.0-1
gtk-update-icon-cache 1:4.6.2-2 1:4.6.3-1
gtk4 1:4.6.2-2 1:4.6.3-1
gtk4-demos 1:4.6.2-2 1:4.6.3-1
gtk4-docs 1:4.6.2-2 1:4.6.3-1
gtksourceview5 5.4.0-1 5.4.1-1
gtksourceview5-docs 5.4.0-1 5.4.1-1
gvfs1.50.0+r5+g747c7f6e-1 1.50.1-1
gvfs-afc1.50.0+r5+g747c7f6e-1 1.50.1-1
gvfs-goa1.50.0+r5+g747c7f6e-1 1.50.1-1
gvfs-google1.50.0+r5+g747c7f6e-1 1.50.1-1
gvfs-gphoto21.50.0+r5+g747c7f6e-1 1.50.1-1
gvfs-mtp1.50.0+r5+g747c7f6e-1 1.50.1-1
gvfs-nfs1.50.0+r5+g747c7f6e-1 1.50.1-1
gvfs-smb1.50.0+r5+g747c7f6e-1 1.50.1-1
gwenview 21.12.3-1 22.04.0-1
harfbuzz 4.2.0-1 4.2.1-1
harfbuzz-icu 4.2.0-1 4.2.1-1
imagemagick 7.1.0.29-1 7.1.0.31-1
imagemagick-doc 7.1.0.29-1 7.1.0.31-1
incidenceeditor 21.12.3-1 22.04.0-1
itinerary 21.12.3-1 22.04.0-1
jasper 2.0.33-1 2.0.33-2
jasper-doc 2.0.33-1 2.0.33-2
jdk-openjdk 18-2 18.0.1.u10-1
jdk11-openjdk 11.0.15.u3-1 11.0.15.u10-1
jdk17-openjdk 17.0.3.u5-1 17.0.3.u7-2
jre-openjdk 18-2 18.0.1.u10-1
jre-openjdk-headless 18-2 18.0.1.u10-1
jre11-openjdk 11.0.15.u3-1 11.0.15.u10-1
jre11-openjdk-headless 11.0.15.u3-1 11.0.15.u10-1
jre17-openjdk 17.0.3.u5-1 17.0.3.u7-2
jre17-openjdk-headless 17.0.3.u5-1 17.0.3.u7-2
jsoncpp 1.9.5-1 1.9.5-2
jsoncpp-doc 1.9.5-1 1.9.5-2
juk 21.12.3-1 22.04.0-1
k3b 1:21.12.3-2 1:22.04.0-1
kaccounts-integration 21.12.3-1 22.04.0-1
kaccounts-providers 21.12.3-1 22.04.0-1
kaddressbook 21.12.3-1 22.04.0-1
kajongg 21.12.3-1 22.04.0-2
kalarm 21.12.3-1 22.04.0-1
kalarmcal 21.12.3-1 -
kalendar 1.0.0-1 22.04.0-1
kalgebra 21.12.3-1 22.04.0-1
kalzium 21.12.3-1 22.04.0-1
kamera 21.12.3-1 22.04.0-1
kamoso 21.12.3-1 22.04.0-1
kanagram 21.12.3-1 22.04.0-1
kapman 21.12.3-1 22.04.0-1
kapptemplate 21.12.3-1 22.04.0-1
kate 21.12.3-1 22.04.0-1
katomic 21.12.3-1 22.04.0-1
kbackup 21.12.3-1 22.04.0-1
kblackbox 21.12.3-1 22.04.0-1
kblocks 21.12.3-1 22.04.0-1
kbounce 21.12.3-1 22.04.0-1
kbreakout 21.12.3-1 22.04.0-1
kbruch 21.12.3-1 22.04.0-1
kcachegrind 21.12.3-1 22.04.0-1
kcachegrind-common 21.12.3-1 22.04.0-1
kcalc 21.12.3-1 22.04.0-1
kcalutils 21.12.3-1 22.04.0-1
kcharselect 21.12.3-1 22.04.0-1
kcolorchooser 21.12.3-1 22.04.0-1
kcron 21.12.3-1 22.04.0-1
kdb 3.2.0-8 3.2.0-9
kde-accessibility-meta 21.12-2 22.04-1
kde-applications-meta 21.12-2 22.04-1
kde-dev-scripts 21.12.3-1 22.04.0-1
kde-dev-utils 21.12.3-1 22.04.0-1
kde-education-meta 21.12-2 22.04-1
kde-games-meta 21.12-2 22.04-1
kde-graphics-meta 21.12-2 22.04-1
kde-multimedia-meta 21.12-2 22.04-1
kde-network-meta 21.12-2 22.04-1
kde-pim-meta 21.12-2 22.04-1
kde-sdk-meta 21.12-2 22.04-1
kde-system-meta 21.12-2 22.04-1
kde-utilities-meta 21.12-2 22.04-1
kdebugsettings 21.12.3-1 22.04.0-1
kdeconnect 21.12.3-1 22.04.0-2
kdeedu-data 21.12.3-1 22.04.0-1
kdegraphics-mobipocket 21.12.3-1 22.04.0-1
kdegraphics-thumbnailers 21.12.3-1 22.04.0-1
kdenetwork-filesharing 21.12.3-1 22.04.0-1
kdenlive 21.12.3-1 22.04.0-1
kdepim-addons 21.12.3-2 22.04.0-1
kdepim-runtime 21.12.3-1 22.04.0-1
kdesdk-kioslaves 21.12.3-1 22.04.0-1
kdesdk-thumbnailers 21.12.3-1 22.04.0-1
kdevelop 21.12.3-1 22.04.0-1
kdevelop-meta 21.12-2 22.04-1
kdevelop-php 21.12.3-1 22.04.0-1
kdf 21.12.3-1 22.04.0-1
kdialog 21.12.3-1 22.04.0-1
kdiamond 21.12.3-1 22.04.0-1
keditbookmarks 21.12.3-1 22.04.0-1
kfind 21.12.3-1 22.04.0-1
kfloppy 21.12.3-1 22.04.0-1
kfourinline 21.12.3-1 22.04.0-1
kgeography 21.12.3-1 22.04.0-1
kget 21.12.3-2 22.04.0-1
kgoldrunner 21.12.3-1 22.04.0-1
kgpg 21.12.3-1 22.04.0-1
khangman 21.12.3-1 22.04.0-1
khelpcenter 21.12.3-1 22.04.0-1
kidentitymanagement 21.12.3-1 22.04.0-1
kig 21.12.3-2 22.04.0-1
kigo 21.12.3-1 22.04.0-1
killbots 21.12.3-1 22.04.0-1
kimagemapeditor 21.12.3-1 22.04.0-1
kimap 21.12.3-1 22.04.0-1
kio-extras 21.12.3-1 22.04.0-1
kio-gdrive 21.12.3-1 22.04.0-1
kipi-plugins 21.12.3-1 -
kirigami-gallery 21.12.3-1 22.04.0-1
kiriki 21.12.3-1 22.04.0-1
kiten 21.12.3-1 22.04.0-1
kitinerary 21.12.3-1 22.04.0-1
kjumpingcube 21.12.3-1 22.04.0-1
kldap 21.12.3-1 22.04.0-1
kleopatra 21.12.3-2 22.04.0-1
klettres 21.12.3-1 22.04.0-1
klickety 21.12.3-1 22.04.0-1
klines 21.12.3-1 22.04.0-1
kmag 21.12.3-1 22.04.0-1
kmahjongg 21.12.3-1 22.04.0-1
kmail 21.12.3-2 22.04.0-1
kmail-account-wizard 21.12.3-2 22.04.0-1
kmailtransport 21.12.3-1 22.04.0-1
kmbox 21.12.3-1 22.04.0-1
kmime 21.12.3-1 22.04.0-1
kmines 21.12.3-1 22.04.0-1
kmix 21.12.3-1 22.04.0-1
kmousetool 21.12.3-1 22.04.0-1
kmouth 21.12.3-1 22.04.0-1
kmplot 21.12.3-1 22.04.0-1
knavalbattle 21.12.3-1 22.04.0-1
knetwalk 21.12.3-1 22.04.0-1
knights 21.12.3-1 22.04.0-1
knotes 21.12.3-1 22.04.0-1
kolf 21.12.3-1 22.04.0-1
kollision 21.12.3-1 22.04.0-1
kolourpaint 21.12.3-1 22.04.0-1
kompare 21.12.3-1 22.04.0-1
konqueror 21.12.3-1 22.04.0-1
konquest 21.12.3-1 22.04.0-1
konsole 21.12.3-1 22.04.0-1
kontact 21.12.3-1 22.04.0-1
kontactinterface 21.12.3-1 22.04.0-1
kontrast 21.12.3-1 22.04.0-1
konversation 21.12.3-1 22.04.0-1
kopeninghours 21.12.3-1 22.04.0-1
kopete 21.12.3-1 22.04.0-1
korganizer 21.12.3-1 22.04.0-1
kosmindoormap 21.12.3-1 22.04.0-1
kpat 21.12.3-1 22.04.0-1
kpimtextedit 21.12.3-1 22.04.0-1
kpkpass 21.12.3-1 22.04.0-1
kpmcore 21.12.3-1 22.04.0-1
kpublictransport 21.12.3-1 22.04.0-1
kqtquickcharts 21.12.3-1 22.04.0-1
krdc 21.12.3-1 22.04.0-1
kreversi 21.12.3-1 22.04.0-1
krfb 21.12.3-1 22.04.0-1
krita 5.0.2-3 5.0.5-2
kruler 21.12.3-1 22.04.0-1
kshisen 21.12.3-1 22.04.0-1
ksirk 21.12.3-1 22.04.0-1
ksmtp 21.12.3-1 22.04.0-1
ksnakeduel 21.12.3-1 22.04.0-1
kspaceduel 21.12.3-1 22.04.0-1
ksquares 21.12.3-1 22.04.0-1
ksudoku 21.12.3-1 22.04.0-1
ksystemlog 21.12.3-1 22.04.0-1
kteatime 21.12.3-1 22.04.0-1
ktimer 21.12.3-1 22.04.0-1
ktnef 21.12.3-1 22.04.0-1
ktorrent 21.12.3-1 22.04.0-1
ktouch 21.12.3-1 22.04.0-1
ktuberling 21.12.3-1 22.04.0-1
kturtle 21.12.3-1 22.04.0-1
kubrick 21.12.3-1 22.04.0-1
kwalletmanager 21.12.3-1 22.04.0-1
kwave 21.12.3-1 22.04.0-1
kwordquiz 21.12.3-1 22.04.0-1
kwrite 21.12.3-1 22.04.0-1
lapack 3.10.0-1 3.10.1-1
lapack-doc 3.10.0-1 3.10.1-1
lapacke 3.10.0-1 3.10.1-1
libadwaita 1:1.1.0-1 1:1.1.1-1
libadwaita-demos 1:1.1.0-1 1:1.1.1-1
libadwaita-docs 1:1.1.0-1 1:1.1.1-1
libakonadi 21.12.3-2 22.04.0-1
libbsd 0.11.6-1 0.11.6-2
libcdr 0.1.7-3 0.1.7-4
libe-book 0.1.3-10 0.1.3-11
libgravatar 21.12.3-1 22.04.0-1
libhandy 1.6.1-1 1.6.2-1
libhandy-docs 1.6.1-1 1.6.2-1
libical 3.0.14-2 3.0.14-3
libinput 1.20.0-2 1.20.1-1
libkcddb 21.12.3-1 22.04.0-1
libkcompactdisc 21.12.3-1 22.04.0-1
libkdcraw 21.12.3-1 22.04.0-1
libkdegames 21.12.3-1 22.04.0-1
libkdepim 21.12.3-1 22.04.0-1
libkeduvocdocument 21.12.3-1 22.04.0-1
libkexiv2 21.12.3-1 22.04.0-1
libkgapi 21.12.3-1 22.04.0-1
libkipi 21.12.3-1 -
libkleo 21.12.3-2 22.04.0-1
libkmahjongg 21.12.3-1 22.04.0-1
libkomparediff2 21.12.3-1 22.04.0-1
libksane 21.12.3-1 22.04.0-1
libksieve 21.12.3-1 22.04.0-1
libktorrent 21.12.3-1 22.04.0-1
libkvkontakte 5.0.0-3 -
libmediawiki 5.37.0-3 -
libmspub 0.1.4-11 0.1.4-12
libnautilus-extension 42.0+r7+gca3702e9b-1 42.1.1-1
libphonenumber 1:8.12.46-1 1:8.12.46-2
libqalculate 4.1.1-1 4.1.1-2
libqxp 0.0.2-7 0.0.2-8
libreoffice-fresh 7.3.2-1 7.3.2-2
libreoffice-fresh-sdk 7.3.2-1 7.3.2-2
libreoffice-still 7.2.6-1 7.2.6-2
libreoffice-still-sdk 7.2.6-1 7.2.6-2
librsvg 2:2.54.0-2 2:2.54.1-1
librsvg-docs 2:2.54.0-2 2:2.54.1-1
libsynctex 2021.59745-2 2021.59745-3
libvisio 0.1.7-6 0.1.7-7
libzmf 0.0.2-11 0.0.2-12
lokalize 21.12.3-1 22.04.0-1
lskat 21.12.3-1 22.04.0-1
m17n-lib 1.8.0-11 1.8.0-12
mailcommon 21.12.3-2 22.04.0-1
mailimporter 21.12.3-1 22.04.0-1
marble 21.12.3-1 22.04.0-1
marble-common 21.12.3-1 22.04.0-1
marble-maps 21.12.3-1 22.04.0-1
marble-qt 21.12.3-1 22.04.0-1
markdownpart 21.12.3-1 22.04.0-1
mbox-importer 21.12.3-1 22.04.0-1
meson 0.62.0-2 0.62.1-1
messagelib 21.12.3-2 22.04.0-1
minuet 21.12.3-1 22.04.0-1
mpd 0.23.6-1 0.23.6-2
nautilus 42.0+r7+gca3702e9b-1 42.1.1-1
nuspell 5.1.0-1 5.1.0-2
openal 1.21.1-3 1.22.0-1
openal-examples 1.21.1-3 1.22.0-1
openexr 3.1.4-1 3.1.5-1
openjdk-src 18-2 18.0.1.u10-1
openjdk11-src 11.0.15.u3-1 11.0.15.u10-1
openjdk17-src 17.0.3.u5-1 17.0.3.u7-2
palapeli 21.12.3-1 22.04.0-1
parley 21.12.3-1 22.04.0-1
parted 3.4-2 3.5-1
partitionmanager 21.12.3-1 22.04.0-1
perl-file-listing 6.14-2 6.15-1
php 8.1.5-1 8.1.5-2
php-apache 8.1.5-1 8.1.5-2
php-cgi 8.1.5-1 8.1.5-2
php-dblib 8.1.5-1 8.1.5-2
php-embed 8.1.5-1 8.1.5-2
php-enchant 8.1.5-1 8.1.5-2
php-fpm 8.1.5-1 8.1.5-2
php-gd 8.1.5-1 8.1.5-2
php-imap 8.1.5-1 8.1.5-2
php-intl 8.1.5-1 8.1.5-2
php-odbc 8.1.5-1 8.1.5-2
php-pgsql 8.1.5-1 8.1.5-2
php-phpdbg 8.1.5-1 8.1.5-2
php-pspell 8.1.5-1 8.1.5-2
php-snmp 8.1.5-1 8.1.5-2
php-sodium 8.1.5-1 8.1.5-2
php-sqlite 8.1.5-1 8.1.5-2
php-tidy 8.1.5-1 8.1.5-2
php-xsl 8.1.5-1 8.1.5-2
php7 7.4.29-1 7.4.29-2
php7-apache 7.4.29-1 7.4.29-2
php7-cgi 7.4.29-1 7.4.29-2
php7-dblib 7.4.29-1 7.4.29-2
php7-embed 7.4.29-1 7.4.29-2
php7-enchant 7.4.29-1 7.4.29-2
php7-fpm 7.4.29-1 7.4.29-2
php7-gd 7.4.29-1 7.4.29-2
php7-imap 7.4.29-1 7.4.29-2
php7-intl 7.4.29-1 7.4.29-2
php7-odbc 7.4.29-1 7.4.29-2
php7-pgsql 7.4.29-1 7.4.29-2
php7-phpdbg 7.4.29-1 7.4.29-2
php7-pspell 7.4.29-1 7.4.29-2
php7-snmp 7.4.29-1 7.4.29-2
php7-sodium 7.4.29-1 7.4.29-2
php7-sqlite 7.4.29-1 7.4.29-2
php7-tidy 7.4.29-1 7.4.29-2
php7-xsl 7.4.29-1 7.4.29-2
picmi 21.12.3-1 22.04.0-1
pim-data-exporter 21.12.3-1 22.04.0-1
pim-sieve-editor 21.12.3-1 22.04.0-1
pimcommon 21.12.3-1 22.04.0-1
pkcs11-helper 1.28.0-1 1.29.0-1
plasma-framework 5.93.0-2 5.93.0-4
postfix 3.7.0-2 3.7.1-1
postfix-cdb 3.7.0-2 3.7.1-1
postfix-ldap 3.7.0-2 3.7.1-1
postfix-lmdb 3.7.0-2 3.7.1-1
postfix-mysql 3.7.0-2 3.7.1-1
postfix-pcre 3.7.0-2 3.7.1-1
postfix-pgsql 3.7.0-2 3.7.1-1
postfix-sqlite 3.7.0-2 3.7.1-1
postgresql 13.6-1 14.2-1
postgresql-docs 13.6-1 14.2-1
postgresql-libs 13.6-1 14.2-1
postgresql-old-upgrade 12.9-1.1 13.6-1
poxml 21.12.3-1 22.04.0-1
print-manager 21.12.3-1 22.04.0-1
pyside6 6.2.4-1 6.3.0-1
python-gobject 3.42.0-3 3.42.1-1
python-opengl 3.1.5-6 3.1.6-1
python-pyqt5-sip 12.9.1-1 12.10.1-1
python-pyqt6-3d 6.2.0-3 6.3.0-1
python-pyqt6 6.2.3-1 6.3.0-1
python-pyqt6-charts 6.2.0-3 6.3.0-1
python-pyqt6-datavisualization 6.2.0-3 6.3.0-1
python-pyqt6-networkauth 6.2.0-3 6.3.0-1
python-pyqt6-sip 13.2.1-1 13.3.1-1
qcachegrind 21.12.3-1 22.04.0-1
qt5-base 5.15.3+kde+r137-1 5.15.3+kde+r145-1
qt5-webengine 5.15.9-1 5.15.9-2
qt5-webkit 5.212.0alpha4-12 5.212.0alpha4-13
qt5-xcb-private-headers 5.15.3+kde+r137-1 5.15.3+kde+r145-1
qt6-5compat 6.3.0-1 6.3.0-2
qt6-base 6.3.0-1 6.3.0-3
qt6-webengine 6.3.0-1 6.3.0-2
quazip-qt5 1.2-2 1.3-1
quazip-qt6 1.2-2 1.3-1
r 4.1.3-1 -
raptor 2.0.15-18 2.0.15-19
rocs 21.12.3-1 22.04.0-1
rsync 3.2.3-4 3.2.4-1
ruby 3.0.3-1 3.0.4-1
ruby-docs 3.0.3-1 3.0.4-1
samba 4.16.0-4 4.16.0-5
shaderc 2022.1-2 2022.1-3
shiboken6 6.2.4-1 6.3.0-1
signon-kwallet-extension 21.12.3-1 22.04.0-1
sip 6.5.1-1 6.6.1-2
skanlite 21.12.3-1 22.04.0-1
smbclient 4.16.0-4 4.16.0-5
spectacle 21.12.3-1 22.04.0-1
step 21.12.3-1 22.04.0-1
suitesparse 5.11.0-1 5.12.0-1
svgpart 21.12.3-1 22.04.0-1
sweeper 21.12.3-1 22.04.0-1
tali 40.6-1 40.7-1
telepathy-kde-accounts-kcm 21.12.3-1 22.04.0-1
telepathy-kde-approver 21.12.3-1 22.04.0-1
telepathy-kde-auth-handler 21.12.3-1 22.04.0-1
telepathy-kde-call-ui 21.12.3-1 22.04.0-1
telepathy-kde-common-internals 21.12.3-1 22.04.0-1
telepathy-kde-contact-list 21.12.3-1 22.04.0-1
telepathy-kde-contact-runner 21.12.3-1 22.04.0-1
telepathy-kde-desktop-applets 21.12.3-1 22.04.0-1
telepathy-kde-filetransfer-handler 21.12.3-1 22.04.0-1
telepathy-kde-integration-module 21.12.3-1 22.04.0-1
telepathy-kde-meta 21.12-2 22.04-1
telepathy-kde-send-file 21.12.3-1 22.04.0-1
telepathy-kde-text-ui 21.12.3-1 22.04.0-1
texlive-bin 2021.59745-2 2021.59745-3
thunderbird 91.8.0-1 91.8.1-1
thunderbird-i18n-af 91.8.0-1 91.8.1-1
thunderbird-i18n-ar 91.8.0-1 91.8.1-1
thunderbird-i18n-ast 91.8.0-1 91.8.1-1
thunderbird-i18n-be 91.8.0-1 91.8.1-1
thunderbird-i18n-bg 91.8.0-1 91.8.1-1
thunderbird-i18n-br 91.8.0-1 91.8.1-1
thunderbird-i18n-ca 91.8.0-1 91.8.1-1
thunderbird-i18n-cak 91.8.0-1 91.8.1-1
thunderbird-i18n-cs 91.8.0-1 91.8.1-1
thunderbird-i18n-cy 91.8.0-1 91.8.1-1
thunderbird-i18n-da 91.8.0-1 91.8.1-1
thunderbird-i18n-de 91.8.0-1 91.8.1-1
thunderbird-i18n-dsb 91.8.0-1 91.8.1-1
thunderbird-i18n-el 91.8.0-1 91.8.1-1
thunderbird-i18n-en-gb 91.8.0-1 91.8.1-1
thunderbird-i18n-en-us 91.8.0-1 91.8.1-1
thunderbird-i18n-es-ar 91.8.0-1 91.8.1-1
thunderbird-i18n-es-es 91.8.0-1 91.8.1-1
thunderbird-i18n-et 91.8.0-1 91.8.1-1
thunderbird-i18n-eu 91.8.0-1 91.8.1-1
thunderbird-i18n-fi 91.8.0-1 91.8.1-1
thunderbird-i18n-fr 91.8.0-1 91.8.1-1
thunderbird-i18n-fy-nl 91.8.0-1 91.8.1-1
thunderbird-i18n-ga-ie 91.8.0-1 91.8.1-1
thunderbird-i18n-gd 91.8.0-1 91.8.1-1
thunderbird-i18n-gl 91.8.0-1 91.8.1-1
thunderbird-i18n-he 91.8.0-1 91.8.1-1
thunderbird-i18n-hr 91.8.0-1 91.8.1-1
thunderbird-i18n-hsb 91.8.0-1 91.8.1-1
thunderbird-i18n-hu 91.8.0-1 91.8.1-1
thunderbird-i18n-hy-am 91.8.0-1 91.8.1-1
thunderbird-i18n-id 91.8.0-1 91.8.1-1
thunderbird-i18n-is 91.8.0-1 91.8.1-1
thunderbird-i18n-it 91.8.0-1 91.8.1-1
thunderbird-i18n-ja 91.8.0-1 91.8.1-1
thunderbird-i18n-ka 91.8.0-1 91.8.1-1
thunderbird-i18n-kab 91.8.0-1 91.8.1-1
thunderbird-i18n-kk 91.8.0-1 91.8.1-1
thunderbird-i18n-ko 91.8.0-1 91.8.1-1
thunderbird-i18n-lt 91.8.0-1 91.8.1-1
thunderbird-i18n-ms 91.8.0-1 91.8.1-1
thunderbird-i18n-nb-no 91.8.0-1 91.8.1-1
thunderbird-i18n-nl 91.8.0-1 91.8.1-1
thunderbird-i18n-nn-no 91.8.0-1 91.8.1-1
thunderbird-i18n-pa-in 91.8.0-1 91.8.1-1
thunderbird-i18n-pl 91.8.0-1 91.8.1-1
thunderbird-i18n-pt-br 91.8.0-1 91.8.1-1
thunderbird-i18n-pt-pt 91.8.0-1 91.8.1-1
thunderbird-i18n-rm 91.8.0-1 91.8.1-1
thunderbird-i18n-ro 91.8.0-1 91.8.1-1
thunderbird-i18n-ru 91.8.0-1 91.8.1-1
thunderbird-i18n-sk 91.8.0-1 91.8.1-1
thunderbird-i18n-sl 91.8.0-1 91.8.1-1
thunderbird-i18n-sq 91.8.0-1 91.8.1-1
thunderbird-i18n-sr 91.8.0-1 91.8.1-1
thunderbird-i18n-sv-se 91.8.0-1 91.8.1-1
thunderbird-i18n-th 91.8.0-1 91.8.1-1
thunderbird-i18n-tr 91.8.0-1 91.8.1-1
thunderbird-i18n-uk 91.8.0-1 91.8.1-1
thunderbird-i18n-uz 91.8.0-1 91.8.1-1
thunderbird-i18n-vi 91.8.0-1 91.8.1-1
thunderbird-i18n-zh-cn 91.8.0-1 91.8.1-1
thunderbird-i18n-zh-tw 91.8.0-1 91.8.1-1
tracker 2.3.6+7+gb27396252-3 2.3.6+7+gb27396252-4
tracker-miners 2.3.5+2+gec09554af-4 2.3.5+2+gec09554af-5
tracker3 3.3.0-1 3.3.0-2
tracker3-docs 3.3.0-1 3.3.0-2
tracker3-miners 3.3.0-1 3.3.0-2
umbrello 21.12.3-1 22.04.0-1
vala 0.56.0-2 0.56.1-1
vlc 3.0.17.3-1 3.0.17.4-1
vte-common 0.68.0-1 0.68.0-2
vte3 0.68.0-1 0.68.0-2
webkit2gtk 2.36.0-2 2.36.1-1
webkit2gtk-4.1 2.36.0-2 2.36.1-1
webkit2gtk-5.0 2.36.0-2 2.36.1-1
wpewebkit 2.36.0-2 2.36.1-1
xerces-c 3.2.3-5 3.2.3-6
xfce4-terminal 1.0.1-1 1.0.2-1
xorg-xauth 1.1.1-1 1.1.2-1
xorgproto 2021.5-1 2022.1-1
yakuake 21.12.3-1 22.04.0-1
yasm 1.3.0-4 1.3.0-5
zabbix-agent 6.0.2-1 6.0.3-1
zabbix-agent2 6.0.2-1 6.0.3-1
zabbix-frontend-php 6.0.2-1 6.0.3-1
zabbix-proxy 6.0.2-1 6.0.3-1
zabbix-server 6.0.2-1 6.0.3-1
zanshin 21.12.3-1 22.04.0-1
zeroconf-ioslave 21.12.3-1 22.04.0-1
zsh 5.8.1-1 5.8.1-2
zsh-doc 5.8.1-1 5.8.1-2
skanpage - 22.04.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.12.2.1.r12724.ged9c5c991-122.04.0.r12724.ged9c5c991-1
akonadi-calendar21.12.2.1.r2072.gf891436-122.04.0.r2074.g8e23c89-1
akonadi-calendar-tools21.12.2.1.r947.g70a8b4e-122.04.0.r948.g419c74f-1
akonadi-contacts21.12.2.1.r3168.gcabd8e6a-122.04.0.r3168.gcabd8e6a-1
akonadi-import-wizard21.12.2.1.r1809.ge5b1a60-122.04.0.r1809.ge5b1a60-1
akonadi-mime21.12.2.1.r1717.gfdc1ad9-122.04.0.r1717.gfdc1ad9-1
akonadi-notes21.12.2.1.r1071.ga09eff6-122.04.0.r1071.ga09eff6-1
akonadi-search21.12.2.1.r1218.gd750214-122.04.0.r1218.gd750214-1
akonadiconsole21.12.2.1.r1584.gbf9abdc-122.04.0.r1584.gbf9abdc-1
akregator21.12.2.1.r6388.g3136292e-122.04.0.r6389.g002a66dd-1
alligator 22.02.r10.g9e6e28d-1 22.04.r0.geb9dd9c-1
analitza21.12.2.1.r2336.g4344e637-122.04.0.r2336.g4344e637-1
angelfish 22.02.r19.gadf0bc3-1 22.04.r0.g9a49fcb-1
ark21.12.2.1.r4733.g3b2a6e23-122.04.0.r4734.g3981425a-1
artikulate21.12.2.1.r1413.g881d378-122.04.0.r1414.g1946979-1
audiocd-kio21.12.2.1.r1056.g79b09d7-122.04.0.r1056.g79b09d7-1
aura-browser r45.c96ff07-1 r45.c96ff07-3
baloo-widgets21.12.2.1.r736.g20b8adc-122.04.0.r740.gde5476a-1
blinken21.12.2.1.r663.gc80904d-122.04.0.r663.gc80904d-1
bomber21.12.2.1.r560.g665f5e1-122.04.0.r560.g665f5e1-1
bovo21.12.2.1.r773.gb32fdb4-122.04.0.r773.gb32fdb4-1
breeze5.24.4.r2382.g37e44cf3-15.24.4.r2384.g1319a747-1
cervisia21.12.2.1.r1660.g755eb43-122.04.0.r1660.g755eb43-1
discover5.24.4.r8629.g57a7901a-15.24.4.r8631.g032d71c8-1
dolphin21.12.2.1.r6917.gfb0a3c03a-122.04.0.r6920.g6c91dfa47-1
dolphin-plugins21.12.2.1.r651.g6a71839-122.04.0.r651.g6a71839-1
dragon21.12.2.1.r1030.ga47eb40-122.04.0.r1030.ga47eb40-1
drkonqi5.24.4.r762.g3a071bf8-15.24.4.r763.gb58dc557-1
elisa21.12.2.1.r2941.g3a8a861d-122.04.0.r2947.g1364827b-1
elisa-qtmm21.12.2.1.r2941.g3a8a861d-122.04.0.r2947.g1364827b-1
ffmpegthumbs21.12.2.1.r212.gfc78559-122.04.0.r212.gfc78559-1
filelight21.12.2.1.r1081.g58e47b1-122.04.0.r1082.g38a71d1-1
granatier21.12.2.1.r973.gd3ccebd-122.04.0.r973.gd3ccebd-1
grantlee-editor21.12.2.1.r817.g1a281e5-122.04.0.r818.g3beff87-1
grantleetheme21.12.2.1.r390.g1ede968-122.04.0.r390.g1ede968-1
gwenview21.12.2.1.r6838.g72601b2a-122.04.0.r6838.g72601b2a-1
incidenceeditor21.12.2.1.r875.g9ddeeda-122.04.0.r881.g18c6631-1
index-fm 2.1.1.r9.g5573935-1 2.1.1.r11.gc7df1be-1
itinerary21.12.2.1.r1796.g046fab9-122.04.0.r1806.g9782997-1
juk21.12.2.1.r3140.g2bf57f4a-122.04.0.r3141.g1a808445-1
k3b1:21.12.2.1.r6748.g1582bc13e-11:22.04.0.r6749.g009d2db08-1
kaccounts-integration21.12.2.1.r1252.g7ac2983-122.04.0.r1252.g7ac2983-1
kaccounts-providers21.12.2.1.r395.gae51a37-122.04.0.r395.gae51a37-1
kaddressbook21.12.2.1.r6158.gc3811762-122.04.0.r6158.gc3811762-1
kajongg21.12.2.1.r4336.geb6aea02-122.04.0.r4337.g75cf1656-1
kalarm21.12.2.1.r7867.g24c4e2a2-122.04.0.r7883.g24db39c6-1
kalarmcal21.12.2.1.r1186.gd40d710-1 -
kalgebra21.12.2.1.r2060.g6acdb42-122.04.0.r2060.g6acdb42-1
kalk 22.02.r22.gb39a23e-1 22.04.r0.gb82c8ee-1
kalzium21.12.2.1.r4314.g76ca8ec2-122.04.0.r4321.g318a6b0c-1
kamera21.12.2.1.r711.g35e9c54-122.04.0.r712.ged6c71f-1
kamoso21.12.2.1.r1456.g4c6f238-122.04.0.r1456.g4c6f238-1
kanagram21.12.2.1.r1306.g26a586f-122.04.0.r1307.g5d826cc-1
kapidox5.93.0.r568.g7809855-15.93.0.r569.gdd1470c-1
kapman21.12.2.1.r647.gfad3e39-122.04.0.r647.gfad3e39-1
kapptemplate21.12.2.1.r987.g2250ba7-122.04.0.r988.g9337cd3-1
kasts 22.02.r20.gc249c09-1 22.04.r0.gfe213df-1
kate21.12.2.1.r18937.g3edeb6a00-122.04.0.r18945.gdadf8130e-1
katomic21.12.2.1.r955.ged0bf40-122.04.0.r955.ged0bf40-1
kbackup21.12.2.1.r430.ga1769ab-122.04.0.r430.ga1769ab-1
kblackbox21.12.2.1.r762.g2cc1b10-122.04.0.r762.g2cc1b10-1
kblocks21.12.2.1.r709.g4baa939-122.04.0.r709.g4baa939-1
kbounce21.12.2.1.r844.gf5a1bfc-122.04.0.r844.gf5a1bfc-1
kbreakout21.12.2.1.r909.g5dd9090-122.04.0.r910.ga1314f4-1
kbruch21.12.2.1.r860.g536b1a8-122.04.0.r860.g536b1a8-1
kcachegrind21.12.2.1.r1177.g8269eb6-122.04.0.r1177.g8269eb6-1
kcachegrind-common21.12.2.1.r1177.g8269eb6-122.04.0.r1177.g8269eb6-1
kcalc21.12.2.1.r1606.gfcbe1d3-122.04.0.r1606.gfcbe1d3-1
kcalutils21.12.2.1.r947.gfb1f70086-122.04.0.r954.g7cb0cde8e-1
kcharselect21.12.2.1.r521.gfd7f2ca-122.04.0.r521.gfd7f2ca-1
kclock 22.02.r37.g643252c-1 22.02.r38.ga5d03f3-1
kcmutils5.93.0.r613.gfb88727-15.93.0.r624.g36966b1-1
kcolorchooser21.12.2.1.r264.gdac265d-122.04.0.r264.gdac265d-1
kconfigwidgets5.93.0.r725.g0da09a5-15.93.0.r726.g0cf8a52-1
kcron21.12.2.1.r840.g3ecc959-122.04.0.r840.g3ecc959-1
kde-dev-scripts21.12.2.1.r4145.g06765a6-122.04.0.r4145.g06765a6-1
kde-dev-utils21.12.2.1.r579.ged8499b-122.04.0.r581.g750ebd1-1
kdebugsettings21.12.2.1.r917.g9a6e8af-122.04.0.r918.g55546ea-1
kdeconnect21.12.2.1.r3427.ge48a0b5f-122.04.0.r3430.gda84914b-1
kdeedu-data21.12.2.1.r16.g8312b2d-122.04.0.r16.g8312b2d-1
kdegraphics-mobipocket21.12.2.1.r266.g6606ec7-122.04.0.r269.gf32ff03-1
kdegraphics-thumbnailers21.12.2.1.r262.g501484e-122.04.0.r262.g501484e-1
kdenetwork-filesharing21.12.2.1.r926.gf57d414-122.04.0.r927.gacd90a8-1
kdenlive21.12.2.1.r15986.g7b7c568ba-122.04.0.r16002.g370bb750e-1
kdepim-addons21.12.2.1.r4622.gecd7b660c-122.04.0.r4623.g9bc03daf1-1
kdepim-runtime21.12.2.1.r15501.gd40c00a1f-122.04.0.r15503.g747556638-1
kdesdk-kioslaves21.12.2.1.r502.g633726e-122.04.0.r502.g633726e-1
kdesdk-thumbnailers21.12.2.1.r88.g1092504-122.04.0.r88.g1092504-1
kdf21.12.2.1.r847.g354ec2b-122.04.0.r847.g354ec2b-1
kdialog21.12.2.1.r1212.g146f1cf1c-122.04.0.r1212.g146f1cf1c-1
kdiamond21.12.2.1.r720.g50868d6-122.04.0.r720.g50868d6-1
keditbookmarks21.12.2.1.r2762.gc70a7d063-122.04.0.r2762.gc70a7d063-1
keysmith 22.02.r8.g226e070-1 22.02.r9.ga8197c3-1
kfind21.12.2.1.r2679.g426228e1d-122.04.0.r2679.g426228e1d-1
kfloppy21.12.2.1.r791.g0f13873-122.04.0.r791.g0f13873-1
kfourinline21.12.2.1.r1019.g94390ac-122.04.0.r1019.g94390ac-1
kgeography21.12.2.1.r1144.ga518151-122.04.0.r1144.ga518151-1
kget21.12.2.1.r3184.gc43ec4ac-122.04.0.r3184.gc43ec4ac-1
kgoldrunner21.12.2.1.r1276.g188bb68-122.04.0.r1276.g188bb68-1
kgpg21.12.2.1.r3183.gc10637d0-122.04.0.r3183.gc10637d0-1
kguiaddons5.93.0.r458.g5f6fd28-15.93.0.r460.g4392268-1
khangman21.12.2.1.r1596.g0be2d48-122.04.0.r1597.g076c946-1
khelpcenter21.12.2.1.r2734.g0ad337d9-122.04.0.r2734.g0ad337d9-1
kidentitymanagement21.12.2.1.r3883.gd95d451e-122.04.0.r3883.gd95d451e-1
kig21.12.2.1.r3182.g0d804a75-122.04.0.r3182.g0d804a75-1
kigo21.12.2.1.r560.g1ac92cb-122.04.0.r560.g1ac92cb-1
killbots21.12.2.1.r780.g830641f-122.04.0.r780.g830641f-1
kimagemapeditor21.12.2.1.r486.g3006809-122.04.0.r486.g3006809-1
kimap21.12.2.1.r1186.g181f0d3-122.04.0.r1186.g181f0d3-1
kinfocenter5.24.4.r2069.geefed473-15.24.4.r2070.g0ce08e24-1
kio5.93.0.r5404.gb21b81f19-15.93.0.r5422.ge4970b195-1
kio-extras21.12.2.1.r7228.ga71b56c0-122.04.0.r7230.g2b5d8bb3-1
kio-gdrive21.12.2.1.r595.g1ab2849-122.04.0.r596.gc51f5d9-1
kipi-plugins21.12.2.1.r12087.g604ce6cc3-122.04.0.r12087.g604ce6cc3-1
kirigami-addons 1:0.2.r27.g9422f0f-1 1:0.2.r28.g67f7e4e-1
kirigami-gallery21.12.2.1.r238.g8b2a1ca-122.04.0.r238.g8b2a1ca-1
kiriki21.12.2.1.r448.g22ec3ba-122.04.0.r448.g22ec3ba-1
kitemmodels5.93.0.r604.gd469614-15.93.0.r605.ge915650-1
kiten21.12.2.1.r1183.ga08ea23-122.04.0.r1183.ga08ea23-1
kitinerary21.12.2.1.r2152.g017ef2f-122.04.0.r2165.gf4c27d7-1
kjumpingcube21.12.2.1.r821.g9c0676c-122.04.0.r821.g9c0676c-1
kldap21.12.2.1.r945.g0713bcc-122.04.0.r945.g0713bcc-1
kleopatra21.12.2.1.r6368.g5b467723-122.04.0.r6382.g670728a2-1
klettres21.12.2.1.r957.gf6fec52-122.04.0.r957.gf6fec52-1
klickety21.12.2.1.r670.gfb08802-122.04.0.r670.gfb08802-1
klines21.12.2.1.r808.ga194437-122.04.0.r808.ga194437-1
kmag21.12.2.1.r733.g8bf8b40-122.04.0.r733.g8bf8b40-1
kmahjongg21.12.2.1.r1522.g47e13ac-122.04.0.r1523.g2841f09-1
kmail21.12.2.1.r26336.g4be40793c-122.04.0.r26336.g4be40793c-1
kmail-account-wizard21.12.2.1.r878.g349bb22-122.04.0.r878.g349bb22-1
kmailtransport21.12.2.1.r1725.g12ea2f6-122.04.0.r1725.g12ea2f6-1
kmbox21.12.2.1.r592.g82271c2-122.04.0.r592.g82271c2-1
kmenuedit5.24.4.r1033.g5881fcd-15.24.4.r1034.g6157644-1
kmime21.12.2.1.r1504.g68700df-122.04.0.r1504.g68700df-1
kmines21.12.2.1.r1762.gce1fc8f-122.04.0.r1762.gce1fc8f-1
kmix21.12.2.1.r2437.g2da8a3f7-122.04.0.r2442.g4a078384-1
kmousetool21.12.2.1.r431.g8f55646-122.04.0.r431.g8f55646-1
kmouth21.12.2.1.r720.g5bf6440-122.04.0.r721.g65c4778-1
kmplot21.12.2.1.r1483.g16bdae3-122.04.0.r1483.g16bdae3-1
knavalbattle21.12.2.1.r1424.g18b027f-122.04.0.r1424.g18b027f-1
knetwalk21.12.2.1.r693.gc833d2c-122.04.0.r693.gc833d2c-1
knewstuff5.93.0.r1323.gef3a137d-15.93.0.r1325.g5859827f-1
knights21.12.2.1.r1122.gce7a9b4-122.04.0.r1122.gce7a9b4-1
knotes21.12.2.1.r3640.g8973ee1f-122.04.0.r3641.g4ac9c749-1
koko 22.02.r4.gbd32df4-1 22.04.r0.gef28e0f-1
kolf21.12.2.1.r1487.gee13864-122.04.0.r1489.gb62dc89-1
kollision21.12.2.1.r529.g5223b0e-122.04.0.r529.g5223b0e-1
kolourpaint21.12.2.1.r2388.gf59b261e-122.04.0.r2390.g838158e4-1
kompare21.12.2.1.r1133.g2da8145-122.04.0.r1134.gdca5563-1
kongress 22.02.r5.ga07f09c-1 22.04.r0.g70ad19b-1
konqueror21.12.2.1.r15096.g00314e597-122.04.0.r15099.ga5b00c961-1
konquest21.12.2.1.r924.gfb830d8-122.04.0.r924.gfb830d8-1
konsole21.12.2.1.r8332.g029ee4e2-122.04.0.r8333.gad1421f8-1
kontact21.12.2.1.r5507.g2801e4d8-122.04.0.r5507.g2801e4d8-1
kontactinterface21.12.2.1.r678.gdb3964e-122.04.0.r678.gdb3964e-1
kontrast21.12.2.1.r200.gc2bef9b-122.04.0.r200.gc2bef9b-1
konversation21.12.2.1.r9106.g9a4d6e6a-122.04.0.r9106.g9a4d6e6a-1
kopeninghours21.12.2.1.r326.g44c5494-122.04.0.r329.g1761ac6-1
kopete21.12.2.1.r16413.g914f0965e-122.04.0.r16413.g914f0965e-1
korganizer21.12.2.1.r11679.g6e052c947-122.04.0.r11681.ge8898f47e-1
kosmindoormap21.12.2.1.r719.g9530056-122.04.0.r724.gb3f9d6e-1
kpat21.12.2.1.r2606.g33556cba-122.04.0.r2608.g9167d8c8-1
kpeoplesink r78.g9a75f7b-1 r79.g9d18ae6-1
kpimtextedit21.12.2.1.r1587.g030e913-122.04.0.r1587.g030e913-1
kpkpass21.12.2.1.r287.gfbb7d68-122.04.0.r287.gfbb7d68-1
kpmcore21.12.2.1.r1280.gd247e02-122.04.0.r1280.gd247e02-1
kpublictransport21.12.2.1.r2001.ga1f81652-122.04.0.r2005.g1718e551-1
kqtquickcharts21.12.2.1.r75.g188b79d-122.04.0.r75.g188b79d-1
krdc21.12.2.1.r1574.g1f42ee8-122.04.0.r1580.g17bb70e-1
krecorder 22.02.r13.g55ca4b7-1 22.04.r0.gc749dab-1
kreversi21.12.2.1.r1262.gfe10b13-122.04.0.r1262.gfe10b13-1
krfb21.12.2.1.r1477.ga58c787-122.04.0.r1479.gfcebbfb-1
kross-interpreters21.12.2.1.r724.g2a6213a-122.04.0.r724.g2a6213a-1
kruler21.12.2.1.r732.g1bdf0a4-122.04.0.r732.g1bdf0a4-1
kshisen21.12.2.1.r1235.g1957eed-122.04.0.r1235.g1957eed-1
ksirk21.12.2.1.r1015.gd5a6ecc-122.04.0.r1015.gd5a6ecc-1
ksmtp21.12.2.1.r443.gecd8493-122.04.0.r443.gecd8493-1
ksnakeduel21.12.2.1.r841.g24c0748-122.04.0.r841.g24c0748-1
kspaceduel21.12.2.1.r667.g18dd978-122.04.0.r667.g18dd978-1
ksquares21.12.2.1.r554.g276bded-122.04.0.r554.g276bded-1
ksudoku21.12.2.1.r1100.g62cdaa2-122.04.0.r1100.g62cdaa2-1
ksystemlog21.12.2.1.r719.gd9d9244-122.04.0.r719.gd9d9244-1
kteatime21.12.2.1.r750.g23998f6-122.04.0.r750.g23998f6-1
ktexteditor5.93.0.r3345.gd3f3188c-15.93.0.r3350.gf3cd48fc-1
ktimer21.12.2.1.r508.g9d461ac-122.04.0.r509.g3d1f120-1
ktnef21.12.2.1.r714.g3d3d558-122.04.0.r714.g3d3d558-1
ktorrent21.12.2.1.r2838.g86932d7a-122.04.0.r2838.g86932d7a-1
ktouch21.12.2.1.r2173.g1b67484-122.04.0.r2175.gc5b9c00-1
ktuberling21.12.2.1.r1036.g824e2ff-122.04.0.r1038.g2702133-1
kturtle21.12.2.1.r1160.g8159849-122.04.0.r1160.g8159849-1
kubrick21.12.2.1.r399.g81a247c-122.04.0.r399.g81a247c-1
kwalletmanager21.12.2.1.r1264.g7c3af2b-122.04.0.r1264.g7c3af2b-1
kwave21.12.2.1.r3776.g4492edfb-122.04.0.r3776.g4492edfb-1
kwayland5.93.0.r1154.g9e70125-15.93.0.r1155.g95536cc-1
kwayland-integration5.24.4.r200.g2ac5b52-15.24.4.r202.g402d7ba-1
kwayland-server5.24.4.r1474.gcdc9dcf-15.24.4.r1478.g6c8002b-1
kweather 22.02.r21.ge3e11ec-1 22.04.r0.gd4b2720-1
kwin5.24.4.r21123.g3d038b715-15.24.4.r21127.gcc6b54911-1
kwordquiz21.12.2.1.r1176.g7e07353-122.04.0.r1176.g7e07353-1
kwrite21.12.2.1.r18937.g3edeb6a00-122.04.0.r18945.gdadf8130e-1
libakonadi21.12.2.1.r12724.ged9c5c991-122.04.0.r12724.ged9c5c991-1
libgravatar21.12.2.1.r420.gda9de61-122.04.0.r420.gda9de61-1
libkcddb21.12.2.1.r752.gee0f14e-122.04.0.r752.gee0f14e-1
libkcompactdisc21.12.2.1.r392.g056d3bf-122.04.0.r392.g056d3bf-1
libkdcraw21.12.2.1.r1152.g52c0298-122.04.0.r1153.ga4a99cf-1
libkdegames21.12.2.1.r2231.g7ff26535-122.04.0.r2231.g7ff26535-1
libkdepim21.12.2.1.r903.g2989cae-122.04.0.r903.g2989cae-1
libkeduvocdocument21.12.2.1.r1809.g3a34565-122.04.0.r1809.g3a34565-1
libkexiv221.12.2.1.r819.g65ad062-122.04.0.r820.g601c27d-1
libkgapi21.12.2.1.r1355.gbc59849-122.04.0.r1355.gbc59849-1
libkipi21.12.2.1.r1276.gf61a329-122.04.0.r1276.gf61a329-1
libkleo21.12.2.1.r1107.g75e8501-122.04.0.r1136.g2da96d2-1
libkmahjongg21.12.2.1.r478.g99719ee-122.04.0.r478.g99719ee-1
libkomparediff221.12.2.1.r342.gf465f1a-122.04.0.r342.gf465f1a-1
libksane21.12.2.1.r594.g38fbdb9-122.04.0.r595.gd3e7150-1
libkscreen5.24.4.r1620.g33b8ed6-15.24.4.r1621.gcb34c9a-1
libksieve21.12.2.1.r1693.g1598612c-122.04.0.r1693.g1598612c-1
libktorrent21.12.2.1.r547.gcc058bb-122.04.0.r547.gcc058bb-1
lokalize21.12.2.1.r1816.gd4b2db75-122.04.0.r1816.gd4b2db75-1
lottie-qml r24.0db824c-1 r24.0db824c-3
lskat21.12.2.1.r845.gb6ccfbc-122.04.0.r845.gb6ccfbc-1
mailcommon21.12.2.1.r1229.gaa7cb35-122.04.0.r1229.gaa7cb35-1
mailimporter21.12.2.1.r515.gdbe0124-122.04.0.r515.gdbe0124-1
marble21.12.2.1.r13420.g17bafd867-122.04.0.r13424.gf6c340322-1
marble-common21.12.2.1.r13420.g17bafd867-122.04.0.r13424.gf6c340322-1
marble-qt21.12.2.1.r13420.g17bafd867-122.04.0.r13424.gf6c340322-1
markdownpart21.12.2.1.r109.g7c87778-122.04.0.r110.g15fb104-1
maui-nota 2.1.1.r18.g907c41f-1 2.1.1.r19.gd99c39d-1
maui-shellv0.5.0.r11.g60472af-1 0.5.0.r15.g8b9a927-1
mauikit2.1.1.r17.g1d90da03-12.1.1.r18.g39fabe30-1
mbox-importer21.12.2.1.r562.gd5c39d7-122.04.0.r562.gd5c39d7-1
messagelib21.12.2.1.r6478.gcb2f997c3-122.04.0.r6478.gcb2f997c3-1
minuet21.12.2.1.r603.g28ac43e-122.04.0.r603.g28ac43e-1
mycroft-bigscreen21.2.2.r4908.g3d64aa5940-121.2.2.r4910.gf030b7e165-2
mycroft-gui r719.22652c3-1 r719.22652c3-3
mycroft-skill-installer r89.118828a-1 r89.118828a-3
neochat22.02.r57.g81ba5f6e-122.02.r58.g180a754e-1
okular21.12.2.1.r9702.gfb3baa087-122.04.0.r9703.g8f54710b5-1
oxygen5.24.4.r4458.g0143247a-15.24.4.r4462.g4709cec4-1
palapeli21.12.2.1.r1270.g3e6aa2c-122.04.0.r1270.g3e6aa2c-1
parley21.12.2.1.r4511.g277a18cc-122.04.0.r4511.g277a18cc-1
partitionmanager21.12.2.1.r1610.g3b6093f-122.04.0.r1610.g3b6093f-1
picmi21.12.2.1.r559.gdbb68b9-122.04.0.r559.gdbb68b9-1
pico-wizard-bigscreen-configs r7.a3393d7-1 r7.a3393d7-2
pim-data-exporter21.12.2.1.r2590.g6bc8daca-122.04.0.r2590.g6bc8daca-1
pim-sieve-editor21.12.2.1.r1617.gd95bbb8-122.04.0.r1617.gd95bbb8-1
plank-player r21.cee6654-1 r25.0b1acfb-1
plasma-bigscreen r465.g96442b3-1 r466.gb9b302e-3
plasma-browser-integration5.24.4.r1313.g0383bff0-15.24.4.r1315.gb8f751fd-1
plasma-desktop5.24.4.r9206.gc2eba6f67-15.24.4.r9207.gb7f0d8ad4-1
plasma-firewall5.24.4.r608.gcb5f0e0-15.24.4.r609.g88a01b2-1
plasma-framework5.93.0.r16262.g8e8f6676c-15.93.0.r16264.g1db3a46aa-1
plasma-nano5.24.4.r180.gd36c0bc-15.24.4.r181.gce97791-1
plasma-nm5.24.4.r3234.g04bbbbf1-15.24.4.r3235.g4651adc7-1
plasma-pa5.24.4.r1040.g82cfbb5-15.24.4.r1044.g9ecc5a5-1
plasma-phonebook 22.02.r5.g5ad5a2f-1 22.04.r0.g43cd575-1
plasma-settings 22.02.r27.gb6bd7fd-1 22.04.r1.g031bdd8-1
plasma-wayland-session5.24.4.r11654.gf994e1301-15.24.4.r11686.g5292eb426-1
plasma-workspace5.24.4.r11654.gf994e1301-15.24.4.r11686.g5292eb426-1
poxml21.12.2.1.r281.g183b2c7-122.04.0.r281.g183b2c7-1
print-manager21.12.2.1.r1121.g89b0d71-122.04.0.r1121.g89b0d71-1
python-cec 0.2.8.r3.g227c69b-1 0.2.8.r3.g227c69b-3
python-uinput 0.11.2.r0.gbefe94a-4 0.11.2.r0.gbefe94a-6
qcachegrind21.12.2.1.r1177.g8269eb6-122.04.0.r1177.g8269eb6-1
qmlkonsole 22.02.r2.gadaf67f-1 22.04.r0.g8d3b279-1
raspberrypi-bigscreen-resolution-fix r2.ede1763-1 r2.ede1763-3
rocs21.12.2.1.r3072.g913fe2d7-122.04.0.r3072.g913fe2d7-1
signon-kwallet-extension21.12.2.1.r79.g87b0c1e-122.04.0.r79.g87b0c1e-1
spacebar22.02.2.r22.g723528f-1 22.04.r1.gb5b1446-1
spectacle21.12.2.1.r1336.g807dc60-122.04.0.r1339.g8e00fd6-1
step21.12.2.1.r1178.gbfcca27-122.04.0.r1181.g96612a7-1
svgpart21.12.2.1.r214.g53cd08d-122.04.0.r214.g53cd08d-1
sweeper21.12.2.1.r562.g533a234-122.04.0.r562.g533a234-1
telepathy-kde-accounts-kcm21.12.2.1.r1211.ga82a68a-122.04.0.r1211.ga82a68a-1
telepathy-kde-approver21.12.2.1.r300.gbcee3ed-122.04.0.r300.gbcee3ed-1
telepathy-kde-auth-handler21.12.2.1.r282.ga240a20-122.04.0.r282.ga240a20-1
telepathy-kde-call-ui21.12.2.1.r448.gf01f09a-122.04.0.r448.gf01f09a-1
telepathy-kde-common-internals21.12.2.1.r2009.gf67843e-122.04.0.r2009.gf67843e-1
telepathy-kde-contact-list21.12.2.1.r1090.g58353ef-122.04.0.r1090.g58353ef-1
telepathy-kde-contact-runner21.12.2.1.r258.gd1d25e2-122.04.0.r258.gd1d25e2-1
telepathy-kde-desktop-applets21.12.2.1.r1000.g135606f-122.04.0.r1000.g135606f-1
telepathy-kde-filetransfer-handler21.12.2.1.r225.g3958b9e-122.04.0.r225.g3958b9e-1
telepathy-kde-integration-module21.12.2.1.r399.gfed9154-122.04.0.r399.gfed9154-1
telepathy-kde-send-file21.12.2.1.r234.gae2a4de-122.04.0.r234.gae2a4de-1
telepathy-kde-text-ui21.12.2.1.r2036.ge226558-122.04.0.r2037.g6695846-1
umbrello21.12.2.1.r8447.g129462a49-122.04.0.r8448.ga42f0cbe6-1
xdg-desktop-portal-kde5.24.4.r449.g5fd51ef-15.24.4.r455.gee713b2-1
yakuake21.12.2.1.r784.g871e27f-122.04.0.r784.g871e27f-1
zeroconf-ioslave21.12.2.1.r376.ge2fb8a8-122.04.0.r376.ge2fb8a8-1
plasma-mobile-settings - 20220421-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
