Hello ARM community.
Sorry for the long wait, but here’s the next update for you all to test.
Some highlights:
- Most of our kernels got updated
- Gnome updated to 42.0, some extensions might not work!
- And QT6 updated to 6.3.0
- KDE Frameworks updated to 5.93.0
- And Pamac got updated to 10.4.0
- Firefox updated to 99.0.1
- Added gnome-deskop-4 for gtk4 version
- Box64 updated to 0.1.8
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Tue Apr 19 18:41:37 CEST 2022)
- arm-testing community aarch64: 415 new and 375 removed package(s)
- arm-testing core aarch64: 48 new and 47 removed package(s)
- arm-testing extra aarch64: 423 new and 414 removed package(s)
- arm-testing kde-unstable aarch64: 365 new and 365 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-04-07 2022-04-19
box64 0.1.4-1 0.1.8-1
code 1.66.0-1 1.66.1-1
electron 18.0.0-1 18.0.4-1
electron15 15.5.0-1 15.5.2-1
electron16 16.2.0-1 16.2.2-1
element-desktop 1.10.8-2 1.10.10-1
element-web 1.10.8-2 1.10.10-1
hwinfo 21.80-1 21.81-1
ofono-hybris 9902.09074dc0-1 1.29-1
osmin 1.8.0-1 1.8.4-1
phoc 0.13.1+1+g8b17c27-1 0.13.1+9+g60a12f1-2
phosh0.17.0+88+gc55ae1cf-10.17.0+136+g67c1ba40-1
pika-backup 0.3.5-1 0.4.0.beta.3-1
postmarketos-tweaks-app 0.8.1-1 0.11.0-1
postmarketos-tweaks-app-phosh 0.8.1-1 0.11.0-1
python-gatt 0.2.7-1 0.2.7-2
signal-desktop 5.36.0-1 5.39.0-1
snapd 2.55.2-1 2.55.3-1
squeekboard 1.17.0+18+g5a21071-1 1.17.1-1
waydroid 1.2.0-2 1.2.1-1
waydroid-image 17.1_20211021-1 17.1_20220316-1
wayfire 0.7.2-1 0.7.3-1
wire-desktop 3.26.2941-1 3.27.2944-1
:: Different sync package(s) in repository community aarch64
adrdox 2.5.2-1 2.5.2-2
aerc 0.7.1-1 0.9.0-1
agordejo 0.3.1-1 0.4.0-1
aliyun-cli 3.0.113-1 3.0.117-1
ansible 5.5.0-1 5.6.0-1
appstream-generator 0.8.7-2 0.8.7-3
arch-release-promotion 0.2.1-2 0.2.2-1
asunder 2.9.7-2 2.9.7-3
atuin 0.8.0-3 0.8.1-1
babel-core 7.17.8-1 7.17.9-1
btop 1.2.5-1 1.2.6-1
budgie-desktop 10.6-1 10.6.1-1
bugzilla 5.0.6-3 5.0.6-5
buildkit 0.10.0-2 0.10.1-1
cargo-deny 0.11.3-2 0.11.4-1
cargo-generate 0.13.0-2 0.13.1-1
carla 2.4.2-2 2.4.3-1
chezmoi 2.15.0-1 2.15.1-1
clojure 1.11.0.1100-1 1.11.1.1105-1
cockpit 266-1 267-1
cockpit-machines 265-1 266-1
cockpit-pcp 266-1 267-1
cockpit-podman 45-1 46-1
cocogitto 5.0.1-1 5.1.0-1
croc 9.5.2-1 9.5.3-1
cryfs 0.11.2-1 0.11.2-2
crystal 1.3.2-1 1.4.0-1
curlie 1.6.7-2 1.6.9-1
d-containers 0.8.0-6 0.8.0-7
d-mir-core 1.1.14-8 1.1.14-9
d-stdx-allocator 3.0.2-18 3.0.2-19
dart-sass 1.49.11-1 1.50.0-1
diffoscope 209-1 210-1
difftastic 0.25.0-1 0.26.3-1
diffuse 0.7.3-1 0.7.4-1
dpkg 1.21.1-1 1.21.7-1
dqlite 1.9.1-1 1.10.0-1
dropbear 2020.81-3 2022.82-1
dropbear-scp 2020.81-3 2022.82-1
drumkv1 0.9.24-1 0.9.25-1
emacs-apel 10.8.20170122-2 10.8.20201107-1
esh 0.3.1-1 0.3.2-1
eva 0.2.7-2 0.3.0-1
fcitx5-pinyin-zhwiki 1:0.2.3.20220312-1 1:0.2.4.20220416-1
feeluown-netease 0.8-1 0.9.1-1
filebin 3.6.2-1 4.0.0-1
filezilla 3.58.0-1.1 3.59.0-1
findomain 7.2.0-1 8.1.0-1
flake8 1:4.0.1-4 1:4.0.1-5
flim 1.14.9-8 1.14.9-9
fluajho 1.7.1-1 1.7.2-1
fwupd-efi 1.2-1 1.3-1
fzf 0.29.0-1 0.30.0-1
gala 6.3.0-3 6.3.0-4
gcompris-qt 2.3-1 2.4-1
gerbera 1.10.0-1 1.10.0-2
gerbv 2.8.1-1 2.8.1-2
giac 1.7.0.53-1 1.7.0.57-1
gir-to-d 0.22.0-6 0.22.0-7
github-cli 2.7.0-1 2.8.0-1
glibd 2.3.0-5 2.3.0-6
gnome-appfolders-manager 0.4.3-1 0.4.4-1
gnome-firmware 42.0-1 42.1-1
gnome-shell-extension-appindicator 41-1 42-1
go 2:1.18-1 2:1.18.1-1
go-yq 4.24.2-1 4.24.5-1
gopls 0.8.2-1 0.8.3-1
gost 2.11.1-3 2.11.2-1
gpxsee 10.4-1 10.5-1
grpc 1.45.1-1 1.45.2-1
grpc-cli 1.45.1-1 1.45.2-1
gsoap 2.8.120-1 2.8.121-1
gtkd 3.10.0-2 3.10.0-3
gwakeonlan 0.8.1-1 0.8.2-2
hedgedoc 1.7.2-3 1.9.3-1
helm 3.8.1-1 3.8.2-1
htmlhint 1.1.3-1 1.1.4-1
httpbin 0.7.0-8 0.7.0-9
igraph 0.9.7-1 0.9.8-1
img2pdf 0.4.3-2 0.4.4-1
iperf 2.0.13-2 2.1.7-1
jami-daemon 20220317-1 20220407-1
jami-libclient 20220317-1 20220407-1
jami-qt 20220317-2 20220407-1
java-atk-wrapper-common 0.38.0-3 0.38.0-4
java-atk-wrapper-openjdk 0.38.0-3 0.38.0-4
java-atk-wrapper-openjdk11 0.38.0-3 0.38.0-4
java-atk-wrapper-openjdk8 0.38.0-3 0.38.0-4
jenkins 2.342-1 2.343-1
jmol 14.32.45-1 14.32.47-1
jsmol 14.32.45-1 14.32.47-1
jupyter-nbconvert 6.4.5-4 6.4.5-5
jupyter-server 1.16.0-1 1.16.0-2
jupyterlab 3.3.2-3 3.3.3-2
just 1.1.1-1 1.1.2-1
kak-lsp 12.0.1-1 12.1.0-1
keepassxc 2.7.0-2 2.7.1-1
kernelshark 2.1.0-1 2.1.0-2
kitty 0.24.4-1 0.25.0-1
kitty-shell-integration 0.24.4-1 0.25.0-1
kitty-terminfo 0.24.4-1 0.25.0-1
kotlin 1.6.10-1 1.6.20-1
labplot 2.8.2-4 2.8.2-5
ldc 3:1.28.1-2 3:1.29.0-1
libfabric 1.14.0-1 1.14.1-1
libfilezilla 1:0.36.0-1 1:0.37.1-1
liblphobos 3:1.28.1-2 3:1.29.0-1
libmupdf 1.19.0-2 1.19.1-1
libolm 3.2.10-1 3.2.11-1
libomemo 0.8.0-1 0.8.1-1
libtg_owt 0.git12.a264028-1 0.git12.a264028-2
libvirt 1:8.2.0-3 1:8.2.0-4
libvirt-storage-gluster 1:8.2.0-3 1:8.2.0-4
libvirt-storage-iscsi-direct 1:8.2.0-3 1:8.2.0-4
lightdm-pantheon-greeter 6.0.1-2 6.0.2-1
linuxdoc-tools 0.9.82-1 0.9.82-2
liquidctl 1.8.1-1 1.9.1-1
logcli 2.4.2-1 2.4.2-2
logwatch 7.5.6-1 7.5.6-2
loki 2.4.2-1 2.4.2-2
loki-canary 2.4.2-1 2.4.2-2
lsp-plugins 1.1.31-1 1.2.0-2
lsp-plugins-docs 1.1.31-1 1.2.0-2
lua-cliargs 3.0-7 3.0-8
lua-language-server 2.6.7-1 3.0.1-1
lua51-cliargs 3.0-7 3.0-8
lua52-cliargs 3.0-7 3.0-8
lua53-cliargs 3.0-7 3.0-8
luppp 1.2.1-2 1.2.1-3
lv2lint 0.14.0-1 0.16.2-1
lxd 5.0.0-1 5.0.0-2
lzip 1.22-1 1.23-1
mac 7.51-1 7.56-1
mailman 2.1.39-1 2.1.39-2
maliit-keyboard 2.2.1-1 2.2.1.1-1
matterbridge 1.25.0-1 1.25.0-2
maturin 0.12.11-1 0.12.12-1
mdbook 0.4.17-1 0.4.18-1
mediastreamer 5.1.10-1 5.1.20-1
mediawiki 1.37.1-2 1.37.2-1
mediawiki-math 1.37.1-2 1.37.2-1
mephisto.lv2 0.16.0-1 0.18.2-1
mimalloc 2.0.5-1 2.0.6-1
mmctl 6.5.0-1 6.6.0-1
mpv-mpris 0.7-2 0.7.1-1
mupdf-gl 1.19.0-2 1.19.1-1
mupdf-tools 1.19.0-2 1.19.1-1
musl 1.2.2-2 1.2.3-1
mustache-d 0.1.5-5 0.1.5-6
neomutt 20211029-2 20220415-1
new-session-manager 1.5.3-2 1.6.0-1
nextcloud-app-bookmarks 1:10.2.1-1 1:10.3.0-1
nextcloud-app-spreed 1:13.0.4-1 1:13.0.5-1
nginx-mod-njs 0.7.2-1 0.7.3-1
nlopt 2.7.1-1 2.7.1-2
nodejs 17.8.0-1 17.9.0-1
nodejs-lts-erbium 12.22.11-1 12.22.12-1
notion 1:4.0.2-3 1:4.0.2-4
npm-check-updates 12.5.7-1 12.5.9-1
nsjail 3.0-5 3.1-1
nushell 0.60.0-1 0.61.0-1
nvchecker 2.7-1 2.8-1
nvme-cli 1.16-2 2.0-2
octave 6.4.0-4.1 7.1.0-2
opendht 1:2.3.5-2 1:2.4.0-1
opendmarc 1.4.2-1 1.4.2-2
openethereum 3.3.1-1 3.3.5-1
openimageio 2.3.13.0-1 2.3.14.0-1
openrct2 0.3.5.1-2 0.3.5.1-3
openttd 12.1-2 12.2-1
osbuild 53-1 54-1
padthv1 0.9.24-1 0.9.25-1
patroneo 2.3.0-1 2.3.1-1
pdfmod 0.9.1-11 0.9.1-12
pdfpc 4.5.0-1 4.5.0-2
perl-datetime-format-iso8601 0.16-1 0.16-2
php-grpc 1.45.1-1 1.45.2-1
php7-grpc 1.45.1-1 1.45.2-1
pitivi 2021.05-3 2021.05-4
plantuml 1.2021.16-1 1.2022.4-1
povray 2:3.7.0.9-8 2:3.7.0.10-1
powerdns 4.6.1-1 4.6.2-1
promtail 2.4.2-1 2.4.2-2
psi-plugins 1.5-1 1.5-2
puppet 7.14.0-1 7.15.0-1
pv 1.6.20-1 1.6.20-2
pyright 1.1.235-1 1.1.237-1
python-amqp 5.0.9-1 5.1.0-1
python-blosc 1.10.6-4 1.10.6-5
python-cerberus 1.3.4-3 1.3.4-4
python-cssbeautifier 1.14.2-1 1.14.3-1
python-dictpath 0.1.3-1 0.1.3-2
python-doit 0.34.2-1 0.35.0-1
python-dropbox 11.28.0-1 11.29.0-1
python-entrypoints 0.4-1 0.4-2
python-fasteners 0.16.3-3 0.17.3-1
python-fonttools 4.31.2-1 4.32.0-1
python-geoip2 4.2.0-3 4.3.0-1
python-gitdb 1:4.0.7-3 1:4.0.9-1
python-gitpython 3.1.24-3 3.1.27-1
python-google-api-core 2.7.1-1 2.7.2-1
python-google-api-python-client 2.42.0-1 2.44.0-1
python-google-auth-oauthlib 0.4.4-3 0.5.1-1
python-grpcio 1.45.1-1 1.45.2-1
python-hidapi 0.11.0.2-3 0.11.2-3
python-importlib_resources 5.6.0-1 5.7.0-1
python-inflect 5.4.0-1 5.5.2-1
python-jsbeautifier 1.14.2-1 1.14.3-1
python-jsondiff 1.3.1-1 2.0.0-1
python-jsonrpclib-pelix 0.4.3.1-4 0.4.3.2-1
python-jupyter_client 7.2.1-1 7.2.2-1
python-lsp-black 1.2.0-1 1.2.1-1
python-mdit_py_plugins 0.2.8-3 0.3.0-1
python-myst-parser 0.15.2-3 0.17.0-1
python-nbxmpp 2.0.4-3 2.0.6-1
python-olm 3.2.10-1 3.2.11-1
python-orjson 3.6.7-1 3.6.8-1
python-pg8000 1.24.1-1 1.24.2-1
python-pipenv 2022.3.28-1 2022.4.8-1
python-pkginfo 1.8.2-1 1.8.2-2
python-pudb 2022.1-1 2022.1.1-1
python-pylint 2.13.4-1 2.13.5-1
python-pytest-testinfra 6.6.0-1 6.7.0-1
python-pywinrm 0.4.2-4 0.4.3-1
python-pywlroots 0.15.11-1 0.15.12-1
python-rpy2 3.5.0-1 3.5.1-1
python-setproctitle 1.2.2-3 1.2.3-1
python-sphinx-click 3.1.0-1 4.0.2-1
python-sphinx-furo 2022.03.04-1 2022.04.07-1
python-sqlalchemy 1.4.34-1 1.4.35-1
python-tldextract 3.2.0-1 3.2.1-1
python-tqdm 4.63.2-1 4.64.0-1
python-zipp 3.7.0-1 3.8.0-1
python-zope-configuration 4.4.0-5 4.4.1-1
python2-gobject 3.36.1-4.1 3.36.1-5
qpwgraph 0.2.4-1 0.2.5-1
qtractor 0.9.25-1 0.9.26-1
raft 0.11.3-1 0.13.0-1
restic 0.13.0-1 0.13.1-1
rhvoice 1.6.0-1 1.8.0-1
rhvoice-language-albanian 1.6.0-1 1.8.0-1
rhvoice-language-brazilian-portuguese 1.6.0-1 1.8.0-1
rhvoice-language-english 1.6.0-1 1.8.0-1
rhvoice-language-esperanto 1.6.0-1 1.8.0-1
rhvoice-language-georgian 1.6.0-1 1.8.0-1
rhvoice-language-kyrgyz 1.6.0-1 1.8.0-1
rhvoice-language-macedonian 1.6.0-1 1.8.0-1
rhvoice-language-russian 1.6.0-1 1.8.0-1
rhvoice-language-tatar 1.6.0-1 1.8.0-1
rhvoice-language-ukrainian 1.6.0-1 1.8.0-1
rhvoice-voice-alan 1.6.0-1 1.8.0-1
rhvoice-voice-aleksandr 1.6.0-1 1.8.0-1
rhvoice-voice-aleksandr-hq 1.6.0-1 1.8.0-1
rhvoice-voice-anatol 1.6.0-1 1.8.0-1
rhvoice-voice-anna 1.6.0-1 1.8.0-1
rhvoice-voice-arina 1.6.0-1 1.8.0-1
rhvoice-voice-artemiy 1.6.0-1 1.8.0-1
rhvoice-voice-azamat 1.6.0-1 1.8.0-1
rhvoice-voice-bdl 1.6.0-1 1.8.0-1
rhvoice-voice-clb 1.6.0-1 1.8.0-1
rhvoice-voice-elena 1.6.0-1 1.8.0-1
rhvoice-voice-evgeniy-eng 1.6.0-1 1.8.0-1
rhvoice-voice-evgeniy-rus 1.6.0-1 1.8.0-1
rhvoice-voice-hana 1.6.0-1 1.8.0-1
rhvoice-voice-irina 1.6.0-1 1.8.0-1
rhvoice-voice-kiko 1.6.0-1 1.8.0-1
rhvoice-voice-leticia-f123 1.6.0-1 1.8.0-1
rhvoice-voice-lyubov 1.6.0-1 1.8.0-1
rhvoice-voice-marianna 1.6.0-1 1.8.0-1
rhvoice-voice-mikhail 1.6.0-1 1.8.0-1
rhvoice-voice-natalia 1.6.0-1 1.8.0-1
rhvoice-voice-natia 1.6.0-1 1.8.0-1
rhvoice-voice-nazgul 1.6.0-1 1.8.0-1
rhvoice-voice-pavel 1.6.0-1 1.8.0-1
rhvoice-voice-slt 1.6.0-1 1.8.0-1
rhvoice-voice-spomenka 1.6.0-1 1.8.0-1
rhvoice-voice-talgat 1.6.0-1 1.8.0-1
rhvoice-voice-tatiana 1.6.0-1 1.8.0-1
rhvoice-voice-victoria 1.6.0-1 1.8.0-1
rhvoice-voice-vitaliy 1.6.0-1 1.8.0-1
rhvoice-voice-volodymyr 1.6.0-1 1.8.0-1
rhvoice-voice-yuriy 1.6.0-1 1.8.0-1
rime-pinyin-zhwiki 1:0.2.3.20220312-1 1:0.2.4.20220416-1
roundcubemail 1.5.2-1 1.5.2-2
rspamd 3.1-4 3.2-2
rst2pdf 0.98-4 0.99-1
rstcheck 3.3.1-6 3.5.0-1
ruby-mini_portile2 2.7.1-1 2.8.0-1
ruby-nokogiri 1.13.1-2 1.13.3-1
ruby-public_suffix 4.0.6-2 4.0.7-1
ruby2.7 2.7.5-1 2.7.6-1
rust-analyzer 20220404-1 20220411-1
samplv1 0.9.24-1 0.9.25-1
selene-linter 0.16.0-2 0.17.0-1
semi 1.14.6-8 1.14.6-9
semver 7.3.5-2 7.3.7-1
serverless 3.11.0-1 3.14.0-1
shorewall 5.2.8-1 -
shorewall-core 5.2.8-1 -
shorewall6 5.2.8-1 -
shotwell 2:0.30.14-2 2:0.30.15-1
siege 4.1.1-1 4.1.2-1
sigal 2.2-2 2.3-1
skate 0.1.5-1 0.2.0-1
skopeo 1.6.1-1 1.7.0-1
soft-serve 0.2.3-1 0.3.0-1
spdlog 1.9.2-3 1.10.0-1
sqlfluff 0.11.2-1 0.12.0-1
squid 5.4.1-1 5.5-1
sshguard 2.4.2-1 2.4.2-2
starship 1.5.4-1 1.6.2-1
stylelint 14.6.1-1 14.7.0-1
stylua 0.13.0-1 0.13.1-1
syncthing 1.19.1-1 1.19.2-1
syncthing-relaysrv 1.19.1-1 1.19.2-1
synthv1 0.9.24-1 0.9.25-2
telegram-desktop 3.6.1-1 3.6.1-3
tepl 6.00.0-3 6.00.0-4
terraform 1.1.7-1 1.1.8-1
tilix 1.9.5-1 1.9.5-2
timescaledb 2.6.0-1 2.6.1-1
tor 0.4.6.9-1 0.4.6.10-1
trace-cmd 2.9.7-1 3.0.3-1
transmission-remote-gtk 1.4.2-1 1.5.1-1
trivy 0.25.1-1 0.25.4-1
tuna 1:0.14.1-3 1:0.17-1
uglify-js 3.15.3-1 3.15.4-1
unrealircd 6.0.2-1 6.0.3-1
uutils-coreutils 0.0.13-1 0.0.13-2
v2ray-domain-list-community 20220405035552-1 20220413144601-1
v2ray-geoip 202203310042-1 202204140052-1
vc-intrinsics 0.1.0-2 0.1.0.r5+g99ac111-1
vscode-css-languageserver 1.66.0-1 1.66.1-1
vscode-html-languageserver 1.66.0-1 1.66.1-1
vscode-json-languageserver 1.66.0-1 1.66.1-1
vultr-cli 2.12.2-1 2.13.0-1
wanderlust 20210407-2 20220103-1
wasmtime 0.35.2-1 0.35.3-1
watchexec 1.18.11-1 1.18.12-1
wezterm20220319.142410.0fcdea07-120220408.101518.b908e2dd-1
wingpanel 3.0.2-5 3.0.2-6
wordpress 5.9.2-1 5.9.3-1
wpscan 1:3.8.21-1 1:3.8.22-1
xfsdump 3.1.9-1 3.1.10-1
xonsh 0.11.0-3 0.12.0-1
xplr 0.17.3-1 0.17.4-1
yad 11.0-1 11.1-1
yadm 3.2.0-1 3.2.1-1
yt-dlp 2022.03.08.1-1 2022.04.08-1
zellij 0.27.0-1 0.28.1-1
zerotier-one 1.8.7-1 1.8.8-1
acme-user - 1.0.1-1
alpine-keyring - 2.4-1
angle-grinder - 0.18.0-2
apk-tools - 2.12.9-1
apko - 0.3.3-1
atool - 0.39.0-8
baresip - 2.0.2-1
choose - 1.3.3-2
gron - 0.7.1-1
hck - 0.7.1-2
htmlq - 0.4.0-1
hut - 0.1.0-2
java-atk-wrapper-openjdk17 - 0.38.0-4
jc - 1.18.6-2
libabigail - 2.0-2
libcalfbox-lss - 1.0.0-2
libfixposix - 0.4.3-1
libmms - 0.6.4-3
libre - 2.2.2-1
librem - 2.0.1-1
libwnck - 2.31.0-3
nyxt - 2.2.4-3
pipe-rename - 1.4.2-1
python-darkdetect - 0.5.1-2
python-hachoir - 3.1.3-1
python-minio - 7.1.6-2
python-mistletoe - 0.8.2-2
python-pgpy - 0.5.4-2
python-pydyf - 0.1.2-3
python-pytest-param-files - 0.3.4-1
python-shodan - 1.27.0-2
python-weasyprint - 54.3-1
rhvoice-language-polish - 1.8.0-1
rhvoice-voice-magda - 1.8.0-1
rhvoice-voice-natan - 1.8.0-1
rhvoice-voice-suze - 1.8.0-1
scaleway-cli - 2.5.1-1
sparse - 0.6.4-2
syncplay - 1.6.9-5
ttf-dejavu - 2.37+18+g9b5d1b2f-3
up - 0.4-2
visidata - 2.8-2
xsv - 0.13.0-2
:: Different overlay package(s) in repository core aarch64
linux 5.17.1-4 5.17.3-1
linux-clockworkpi-a06 5.17.1-1 5.17.3-1
linux-clockworkpi-a06-headers 5.17.1-1 5.17.3-1
linux-headers 5.17.1-4 5.17.3-1
linux-lts 5.15.32-1 5.15.34-1
linux-lts-headers 5.15.32-1 5.15.34-1
linux-pinephone 5.17.1-2 5.17.3-2
linux-pinephone-headers 5.17.1-2 5.17.3-2
linux-pinephonepro 5.17.1-2 5.17.3-2
linux-pinephonepro-headers 5.17.1-2 5.17.3-2
linux-quartz64 5.17.0-0.5 5.17.0-2
linux-quartz64-headers 5.17.0-0.5 5.17.0-2
linux-rc 5.17.rc8-5 5.18.rc3-1
linux-rc-headers 5.17.rc8-5 5.18.rc3-1
linux-rpi4 5.15.32-2 5.15.33-1
linux-rpi4-headers 5.15.32-2 5.15.33-1
linux-rpi4-mainline 5.17.1-2 5.17.2-1
linux-rpi4-mainline-headers 5.17.1-2 5.17.2-1
linux-rpi4-rc 5.17.rc8-1 5.18.rc2-1
linux-rpi4-rc-headers 5.17.rc8-1 5.18.rc2-1
:: Different sync package(s) in repository core aarch64
amd-ucode 20220309.cd01f85-1 20220411.705f19a-1
gzip 1.11-1 1.12-1
hwdata 0.357-1 0.358-1
iana-etc 20220205-1 20220325-1
iproute2 5.17.0-1 5.17.0-2
krb5 1.19.2-2 1.19.3-1
libaio 0.3.112-2 0.3.112-3
libarchive 3.6.0-2 3.6.1-1
libffi 3.4.2-4 3.4.2-5
libgpg-error 1.44-1 1.45-1
libmnl 1.0.4-3 1.0.5-1
libnfnetlink 1.0.1-4 1.0.2-1
libusb 1.0.25-3 1.0.26-1
links 2.25-1 2.26-1
linux-firmware 20220309.cd01f85-1 20220411.705f19a-1
linux-firmware-bnx2x 20220309.cd01f85-1 20220411.705f19a-1
linux-firmware-liquidio 20220309.cd01f85-1 20220411.705f19a-1
linux-firmware-marvell 20220309.cd01f85-1 20220411.705f19a-1
linux-firmware-mellanox 20220309.cd01f85-1 20220411.705f19a-1
linux-firmware-nfp 20220309.cd01f85-1 20220411.705f19a-1
linux-firmware-qcom 20220309.cd01f85-1 20220411.705f19a-1
linux-firmware-qlogic 20220309.cd01f85-1 20220411.705f19a-1
linux-firmware-whence 20220309.cd01f85-1 20220411.705f19a-1
openssh 8.9p1-1 9.0p1-1
wpa_supplicant 2:2.10-3 2:2.10-4
xfsprogs 5.14.2-1 5.15.0-1
xz 5.2.5-2 5.2.5-3
libbpf - 0.7.0-1
:: Different overlay package(s) in repository extra aarch64
libpamac 11.2.0-13 11.3.0-1
libpamac-flatpak-plugin 11.2.0-13 11.3.0-1
libpamac-snap-plugin 11.2.0-13 11.3.0-1
mesa-git22.1.0_devel.151866.e1de9b0de5e-122.2.0_devel.152473.11c462534bd-1
pamac-cli 10.3.0-6 10.4.0-1
pamac-gnome-integration 10.3.0-6 10.4.0-1
pamac-gtk 10.3.0-6 10.4.0-1
qt5-es2-base 5.15.3+kde+r134-1 5.15.3+kde+r137-1
qt5-es2-wayland 5.15.3+kde+r40-1 5.15.3+kde+r41-1
qt5-es2-xcb-private-headers 5.15.3+kde+r134-1 5.15.3+kde+r137-1
:: Different sync package(s) in repository extra aarch64
adwaita-icon-theme 41.0-1 42.0-1
alsa-card-profiles 1:0.3.49-1 1:0.3.50-1
archboot-arm 2022.04-10 2022.04-24
attica 5.92.0-1 5.93.0-1
baloo 5.92.0-1 5.93.0-1
baobab 41.0-1 42.0-1
bluez-qt 5.92.0-1 5.93.0-1
breeze-icons 5.92.0-1 5.93.0-1
bullet 3.21-2 3.22-1
bullet-docs 3.21-2 3.22-1
chromium 100.0.4896.75-1 100.0.4896.127-1
cmake 3.23.0-1 3.23.1-1
composer 2.3.3-1 2.3.5-1
cups-filters 1.28.14-1 1.28.15-1
eog 41.2-1 42.0-1
eog-plugins 3.26.8-1 42.0-1
epiphany 41.3-2 42.1-1
ethtool 1:5.16-1 1:5.17-1
evince 41.4-1 42.1-1
evolution 3.42.4-1.1 3.44.0-1
evolution-bogofilter 3.42.4-1.1 3.44.0-1
evolution-data-server 3.42.4-2.1 3.44.0-1
evolution-ews 3.42.4-1.1 3.44.0-1
evolution-spamassassin 3.42.4-1.1 3.44.0-1
extra-cmake-modules 5.92.0-1 5.93.0-1
firefox 99.0-1 99.0.1-1
firefox-i18n-ach 99.0-1 99.0.1-1
firefox-i18n-af 99.0-1 99.0.1-1
firefox-i18n-an 99.0-1 99.0.1-1
firefox-i18n-ar 99.0-1 99.0.1-1
firefox-i18n-ast 99.0-1 99.0.1-1
firefox-i18n-az 99.0-1 99.0.1-1
firefox-i18n-be 99.0-1 99.0.1-1
firefox-i18n-bg 99.0-1 99.0.1-1
firefox-i18n-bn 99.0-1 99.0.1-1
firefox-i18n-br 99.0-1 99.0.1-1
firefox-i18n-bs 99.0-1 99.0.1-1
firefox-i18n-ca 99.0-1 99.0.1-1
firefox-i18n-ca-valencia 99.0-1 99.0.1-1
firefox-i18n-cak 99.0-1 99.0.1-1
firefox-i18n-cs 99.0-1 99.0.1-1
firefox-i18n-cy 99.0-1 99.0.1-1
firefox-i18n-da 99.0-1 99.0.1-1
firefox-i18n-de 99.0-1 99.0.1-1
firefox-i18n-dsb 99.0-1 99.0.1-1
firefox-i18n-el 99.0-1 99.0.1-1
firefox-i18n-en-ca 99.0-1 99.0.1-1
firefox-i18n-en-gb 99.0-1 99.0.1-1
firefox-i18n-en-us 99.0-1 99.0.1-1
firefox-i18n-eo 99.0-1 99.0.1-1
firefox-i18n-es-ar 99.0-1 99.0.1-1
firefox-i18n-es-cl 99.0-1 99.0.1-1
firefox-i18n-es-es 99.0-1 99.0.1-1
firefox-i18n-es-mx 99.0-1 99.0.1-1
firefox-i18n-et 99.0-1 99.0.1-1
firefox-i18n-eu 99.0-1 99.0.1-1
firefox-i18n-fa 99.0-1 99.0.1-1
firefox-i18n-ff 99.0-1 99.0.1-1
firefox-i18n-fi 99.0-1 99.0.1-1
firefox-i18n-fr 99.0-1 99.0.1-1
firefox-i18n-fy-nl 99.0-1 99.0.1-1
firefox-i18n-ga-ie 99.0-1 99.0.1-1
firefox-i18n-gd 99.0-1 99.0.1-1
firefox-i18n-gl 99.0-1 99.0.1-1
firefox-i18n-gn 99.0-1 99.0.1-1
firefox-i18n-gu-in 99.0-1 99.0.1-1
firefox-i18n-he 99.0-1 99.0.1-1
firefox-i18n-hi-in 99.0-1 99.0.1-1
firefox-i18n-hr 99.0-1 99.0.1-1
firefox-i18n-hsb 99.0-1 99.0.1-1
firefox-i18n-hu 99.0-1 99.0.1-1
firefox-i18n-hy-am 99.0-1 99.0.1-1
firefox-i18n-ia 99.0-1 99.0.1-1
firefox-i18n-id 99.0-1 99.0.1-1
firefox-i18n-is 99.0-1 99.0.1-1
firefox-i18n-it 99.0-1 99.0.1-1
firefox-i18n-ja 99.0-1 99.0.1-1
firefox-i18n-ka 99.0-1 99.0.1-1
firefox-i18n-kab 99.0-1 99.0.1-1
firefox-i18n-kk 99.0-1 99.0.1-1
firefox-i18n-km 99.0-1 99.0.1-1
firefox-i18n-kn 99.0-1 99.0.1-1
firefox-i18n-ko 99.0-1 99.0.1-1
firefox-i18n-lij 99.0-1 99.0.1-1
firefox-i18n-lt 99.0-1 99.0.1-1
firefox-i18n-lv 99.0-1 99.0.1-1
firefox-i18n-mk 99.0-1 99.0.1-1
firefox-i18n-mr 99.0-1 99.0.1-1
firefox-i18n-ms 99.0-1 99.0.1-1
firefox-i18n-my 99.0-1 99.0.1-1
firefox-i18n-nb-no 99.0-1 99.0.1-1
firefox-i18n-ne-np 99.0-1 99.0.1-1
firefox-i18n-nl 99.0-1 99.0.1-1
firefox-i18n-nn-no 99.0-1 99.0.1-1
firefox-i18n-oc 99.0-1 99.0.1-1
firefox-i18n-pa-in 99.0-1 99.0.1-1
firefox-i18n-pl 99.0-1 99.0.1-1
firefox-i18n-pt-br 99.0-1 99.0.1-1
firefox-i18n-pt-pt 99.0-1 99.0.1-1
firefox-i18n-rm 99.0-1 99.0.1-1
firefox-i18n-ro 99.0-1 99.0.1-1
firefox-i18n-ru 99.0-1 99.0.1-1
firefox-i18n-si 99.0-1 99.0.1-1
firefox-i18n-sk 99.0-1 99.0.1-1
firefox-i18n-sl 99.0-1 99.0.1-1
firefox-i18n-son 99.0-1 99.0.1-1
firefox-i18n-sq 99.0-1 99.0.1-1
firefox-i18n-sr 99.0-1 99.0.1-1
firefox-i18n-sv-se 99.0-1 99.0.1-1
firefox-i18n-ta 99.0-1 99.0.1-1
firefox-i18n-te 99.0-1 99.0.1-1
firefox-i18n-th 99.0-1 99.0.1-1
firefox-i18n-tl 99.0-1 99.0.1-1
firefox-i18n-tr 99.0-1 99.0.1-1
firefox-i18n-trs 99.0-1 99.0.1-1
firefox-i18n-uk 99.0-1 99.0.1-1
firefox-i18n-ur 99.0-1 99.0.1-1
firefox-i18n-uz 99.0-1 99.0.1-1
firefox-i18n-vi 99.0-1 99.0.1-1
firefox-i18n-xh 99.0-1 99.0.1-1
firefox-i18n-zh-cn 99.0-1 99.0.1-1
firefox-i18n-zh-tw 99.0-1 99.0.1-1
frameworkintegration 5.92.0-1 5.93.0-1
gdm 41.3-2.1 42.0+r11+g4a52f026-1
gedit 41.0-1 42.0-1
gedit-plugins 41.0-1 42.0-1
geeqie 1.7.2-1 1.7.3-1
ghex 3.41.1-1 42.0-1
git 2.35.1-1 2.35.3-1
gjs 2:1.70.2-1 2:1.72.0-1
glibmm-2.68 2.70.0-1 2.72.0-1
glibmm-2.68-docs 2.70.0-1 2.72.0-1
gnome-backgrounds 41.0-1 42.0-1
gnome-bluetooth 3.34.5-2 3.34.5-3
gnome-builder 41.3-542.0+r12+gfd803f606-1
gnome-builder-libide-docs 41.3-542.0+r12+gfd803f606-1
gnome-calculator 41.1-1 42.0-1
gnome-calendar 41.2+r5+g2222a4ee-1 42.0-1
gnome-characters 41.0-1 42.0-1
gnome-clocks 41.0-1 42.0-1
gnome-contacts 41.0-2 42.0-1
gnome-control-center 41.4-1 42.0-1
gnome-desktop 1:41.5-1 1:42.0-1
gnome-disk-utility 41.0-1 42.0-1
gnome-font-viewer 41.0-1 42.0-1
gnome-logs 3.36.0-1 42.0-1
gnome-maps 41.4-1 42.0-2
gnome-music 1:41.0-2 1:42.0-1
gnome-nettool 3.8.1+205+g8550eef-3 42.0-1
gnome-photos1:40.0+r14+g884b1fd1-1 1:42.0-1
gnome-remote-desktop 41.2-1 42.0-1
gnome-screenshot 41.0-1 41.0+r25+g45f08f0-1
gnome-session 41.3-1 42.0-1
gnome-settings-daemon 41.0-2 42.1-1
gnome-shell 1:41.5-1 1:42.0-1
gnome-shell-extensions 41.2-1 42.0-1
gnome-software 41.5-1 42.0-1
gnome-software-packagekit-plugin 41.5-1 42.0-1
gnome-sound-recorder 40.0-1 42.0-1
gnome-system-monitor 41.0-1 42.0-1
gnome-terminal 3.42.2-2 3.44.0-1
gnome-tweaks 40.10-1 42beta+r9+gc66d8c3-1
gnome-user-docs 41.5-1 42.0-1
gnome-weather 41.0-1 42.0-1
gnote 41.1-1 42.0-1
gnu-efi 3.0.14-2 3.0.14-3
gnuplot 5.4.3-4 5.4.3-5
gnuplot-demos 5.4.3-4 5.4.3-5
gpaste 3.42.6-1 42.1-1
gptfdisk 1.0.8-1 1.0.9-1
gsettings-desktop-schemas 41.0-1 42.0-1
gst-plugin-pipewire 1:0.3.49-1 1:0.3.50-1
gtk-update-icon-cache 1:4.6.2-1 1:4.6.2-2
gtk4 1:4.6.2-1 1:4.6.2-2
gtk4-demos 1:4.6.2-1 1:4.6.2-2
gtk4-docs 1:4.6.2-1 1:4.6.2-2
gvfs 1.50.0-11.50.0+r5+g747c7f6e-1
gvfs-afc 1.50.0-11.50.0+r5+g747c7f6e-1
gvfs-goa 1.50.0-11.50.0+r5+g747c7f6e-1
gvfs-google 1.50.0-11.50.0+r5+g747c7f6e-1
gvfs-gphoto2 1.50.0-11.50.0+r5+g747c7f6e-1
gvfs-mtp 1.50.0-11.50.0+r5+g747c7f6e-1
gvfs-nfs 1.50.0-11.50.0+r5+g747c7f6e-1
gvfs-smb 1.50.0-11.50.0+r5+g747c7f6e-1
haveged 1.9.17-1 1.9.18-1
help2man 1.49.1-1 1.49.2-1
ibus 1.5.25-5 1.5.26-2
jack-example-tools 1-4 2-1
jack2 1.9.20-4 1.9.21-1
jack2-dbus 1.9.20-4 1.9.21-1
jack2-docs 1.9.20-4 1.9.21-1
jdk-openjdk 17.0.3.u3-1 18-2
jre-openjdk 17.0.3.u3-1 18-2
jre-openjdk-headless 17.0.3.u3-1 18-2
kactivities 5.92.0-1 5.93.0-1
kactivities-stats 5.92.0-1 5.93.0-1
kapidox 5.92.0-1 5.93.0-1
karchive 5.92.0-1 5.93.0-1
kauth 5.92.0-1 5.93.0-1
kbookmarks 5.92.0-1 5.93.0-1
kcalendarcore 5.92.0-1 5.93.0-1
kcmutils 5.92.0-1 5.93.0-1
kcodecs 5.92.0-1 5.93.0-1
kcompletion 5.92.0-1 5.93.0-1
kconfig 5.92.0-1 5.93.0-1
kconfigwidgets 5.92.0-1 5.93.0-1
kcontacts 1:5.92.0-1 1:5.93.0-1
kcoreaddons 5.92.0-1 5.93.0-1
kcrash 5.92.0-1 5.93.0-1
kdav 1:5.92.0-1 1:5.93.0-1
kdbusaddons 5.92.0-1 5.93.0-1
kdeclarative 5.92.0-1 5.93.0-1
kded 5.92.0-1 5.93.0-1
kdelibs4support 5.92.0-1 5.93.0-1
kdesignerplugin 5.92.0-1 5.93.0-1
kdesu 5.92.0-1 5.93.0-1
kdewebkit 5.92.0-1 5.93.0-1
kdnssd 5.92.0-1 5.93.0-1
kdoctools 5.92.0-1 5.93.0-1
kemoticons 5.92.0-1 5.93.0-1
kfilemetadata 5.92.0-2 5.93.0-1
kglobalaccel 5.92.0-1 5.93.0-1
kguiaddons 5.92.0-1 5.93.0-1
kholidays 1:5.92.0-1 1:5.93.0-1
khtml 5.92.0-1 5.93.0-1
ki18n 5.92.0-1 5.93.0-1
kiconthemes 5.92.0-1 5.93.0-1
kidletime 5.92.0-1 5.93.0-1
kimageformats 5.92.0-1 5.93.0-1
kinit 5.92.0-1 5.93.0-1
kio 5.92.0-1 5.93.0-1
kirigami2 5.92.0-1 5.93.0-1
kitemmodels 5.92.0-1 5.93.0-1
kitemviews 5.92.0-1 5.93.0-1
kjobwidgets 5.92.0-1 5.93.0-1
kjs 5.92.0-1 5.93.0-1
kjsembed 5.92.0-1 5.93.0-1
kmediaplayer 5.92.0-1 5.93.0-1
knewstuff 5.92.0-2 5.93.0-1
knotifications 5.92.0-1 5.93.0-1
knotifyconfig 5.92.0-1 5.93.0-1
kpackage 5.92.0-1 5.93.0-1
kparts 5.92.0-1 5.93.0-1
kpeople 5.92.0-1 5.93.0-1
kplotting 5.92.0-1 5.93.0-1
kproperty 3.2.0-2 3.2.0-3
kpty 5.92.0-1 5.93.0-1
kquickcharts 5.92.0-1 5.93.0-1
kreport 3.2.0-2 3.2.0-3
kross 5.92.0-1 5.93.0-1
krunner 5.92.0-1 5.93.0-1
kservice 5.92.0-1 5.93.0-1
ktexteditor 5.92.0-1 5.93.0-1
ktextwidgets 5.92.0-1 5.93.0-1
kunitconversion 5.92.0-1 5.93.0-1
kwallet 5.92.0-1 5.93.0-1
kwayland 5.92.0-1 5.93.0-2
kwidgetsaddons 5.92.0-1 5.93.0-1
kwindowsystem 5.92.0-1 5.93.0-1
kxmlgui 5.92.0-1 5.93.0-1
kxmlrpcclient 5.92.0-1 5.93.0-1
libbpf 0.7.0-1 -
libbsd 0.11.5-1 0.11.6-1
libcerf 1:1.17-1 1:2.1-1
libgdm 41.3-2.1 42.0+r11+g4a52f026-1
libgit2 1:1.4.2-1 1:1.4.3-1
libibus 1.5.25-5 1.5.26-2
libmms 0.6.4-3 -
libnautilus-extension 41.2-1 42.0+r7+gca3702e9b-1
libnma 1.8.36-3 1.8.38-1
libnma-common 1.8.36-3 1.8.38-1
libnma-gtk4 1.8.36-3 1.8.38-1
libphonenumber 1:8.12.39-1 1:8.12.46-1
liferea 1.13.7-1 1.13.8-1
mercurial 6.1-2 6.1.1-1
meson 0.62.0-1 0.62.0-2
modemmanager-qt 5.92.0-1 5.93.0-1
mtools 1:4.0.38-1 1:4.0.39-1
mutt 2.2.2-1 2.2.3-1
mutter 41.5-1 42.0-2
nautilus 41.2-1 42.0+r7+gca3702e9b-1
networkmanager-qt 5.92.0-1 5.93.0-1
openjdk-src 17.0.3.u3-1 18-2
orca 41.2-1 42.0-1
oxygen-icons 1:5.92.0-1 1:5.93.0-1
oxygen-icons-svg 1:5.92.0-1 1:5.93.0-1
pango 1:1.50.6-1 1:1.50.7-1
pango-docs 1:1.50.6-1 1:1.50.7-1
pavucontrol 1:5.0-1 1:5.0+r35+g964f298-1
php 8.1.4-1 8.1.5-1
php-apache 8.1.4-1 8.1.5-1
php-cgi 8.1.4-1 8.1.5-1
php-dblib 8.1.4-1 8.1.5-1
php-embed 8.1.4-1 8.1.5-1
php-enchant 8.1.4-1 8.1.5-1
php-fpm 8.1.4-1 8.1.5-1
php-gd 8.1.4-1 8.1.5-1
php-imap 8.1.4-1 8.1.5-1
php-intl 8.1.4-1 8.1.5-1
php-odbc 8.1.4-1 8.1.5-1
php-pgsql 8.1.4-1 8.1.5-1
php-phpdbg 8.1.4-1 8.1.5-1
php-pspell 8.1.4-1 8.1.5-1
php-snmp 8.1.4-1 8.1.5-1
php-sodium 8.1.4-1 8.1.5-1
php-sqlite 8.1.4-1 8.1.5-1
php-tidy 8.1.4-1 8.1.5-1
php-xsl 8.1.4-1 8.1.5-1
php7 7.4.28-1 7.4.29-1
php7-apache 7.4.28-1 7.4.29-1
php7-cgi 7.4.28-1 7.4.29-1
php7-dblib 7.4.28-1 7.4.29-1
php7-embed 7.4.28-1 7.4.29-1
php7-enchant 7.4.28-1 7.4.29-1
php7-fpm 7.4.28-1 7.4.29-1
php7-gd 7.4.28-1 7.4.29-1
php7-imap 7.4.28-1 7.4.29-1
php7-intl 7.4.28-1 7.4.29-1
php7-odbc 7.4.28-1 7.4.29-1
php7-pgsql 7.4.28-1 7.4.29-1
php7-phpdbg 7.4.28-1 7.4.29-1
php7-pspell 7.4.28-1 7.4.29-1
php7-snmp 7.4.28-1 7.4.29-1
php7-sodium 7.4.28-1 7.4.29-1
php7-sqlite 7.4.28-1 7.4.29-1
php7-tidy 7.4.28-1 7.4.29-1
php7-xsl 7.4.28-1 7.4.29-1
pipewire-alsa 1:0.3.49-1 1:0.3.50-1
pipewire-docs 1:0.3.49-1 1:0.3.50-1
pipewire-jack 1:0.3.49-1 1:0.3.50-1
pipewire-pulse 1:0.3.49-1 1:0.3.50-1
pipewire-v4l2 1:0.3.49-1 1:0.3.50-1
pipewire-x11-bell 1:0.3.49-1 1:0.3.50-1
pipewire-zeroconf 1:0.3.49-1 1:0.3.50-1
plasma-framework 5.92.0-2 5.93.0-2
polari41.0+r11+g0f0a4b54-1.1 42.0-1
prison 5.92.0-1 5.93.0-1
purpose 5.92.0-1 5.93.0-1
python-automat 20.2.0-8 20.2.0-9
python-django 4.0.3-1 4.0.4-1
python-prometheus_client 0.13.1-1 0.14.1-1
python-pybullet 3.21-2 3.22-1
python-pyparsing 3.0.7-1 3.0.8-1
python-setuptools 1:59.4.0-1 1:59.5.0-1
qqc2-desktop-style 5.92.0-1 5.93.0-1
qt5-script 5.15.8-4 5.15.9-1
qt5-wayland 5.15.3+kde+r40-1 5.15.3+kde+r44-1
qt5-webengine 5.15.8-11 5.15.9-1
qt6-3d 6.2.4-1 6.3.0-1
qt6-5compat 6.2.4-1 6.3.0-1
qt6-base 6.2.4-1 6.3.0-1
qt6-charts 6.2.4-1 6.3.0-1
qt6-connectivity 6.2.4-1 6.3.0-1
qt6-datavis3d 6.2.4-1 6.3.0-1
qt6-declarative 6.2.4-1 6.3.0-1
qt6-doc 6.2.4-1 6.3.0-1
qt6-examples 6.2.4-1 6.3.0-1
qt6-imageformats 6.2.4-1 6.3.0-1
qt6-lottie 6.2.4-1 6.3.0-1
qt6-multimedia 6.2.4-1 6.3.0-1
qt6-networkauth 6.2.4-1 6.3.0-1
qt6-positioning 6.2.4-1 6.3.0-1
qt6-quick3d 6.2.4-1 6.3.0-1
qt6-quicktimeline 6.2.4-1 6.3.0-1
qt6-remoteobjects 6.2.4-1 6.3.0-1
qt6-scxml 6.2.4-1 6.3.0-1
qt6-sensors 6.2.4-1 6.3.0-1
qt6-serialbus 6.2.4-1 6.3.0-1
qt6-serialport 6.2.4-1 6.3.0-1
qt6-shadertools 6.2.4-1 6.3.0-1
qt6-svg 6.2.4-1 6.3.0-1
qt6-tools 6.2.4-1 6.3.0-1
qt6-translations 6.2.4-1 6.3.0-1
qt6-virtualkeyboard 6.2.4-1 6.3.0-1
qt6-wayland 6.2.4-1 6.3.0-1
qt6-webchannel 6.2.4-1 6.3.0-1
qt6-webengine 6.2.4-2 6.3.0-1
qt6-websockets 6.2.4-1 6.3.0-1
qt6-webview 6.2.4-1 6.3.0-1
rust 1:1.59.0-1 1:1.60.0-1
rust-src 1:1.59.0-1 1:1.60.0-1
sof-firmware 2.0-1 2.1.1-1
sof-tools 2.0-1 2.1.1-1
solid 5.92.0-1 5.93.0-1
sonnet 5.92.0-1 5.93.0-1
sushi 41.1-1 41.2-1
swell-foop 41.0.1-1 41.1-1
syndication 5.92.0-1 5.93.0-1
syntax-highlighting 5.92.0-1 5.93.0-1
threadweaver 5.92.0-1 5.93.0-1
totem 3.38.2-1 42.0-1
ttf-dejavu 2.37+18+g9b5d1b2f-3 -
vde2 2.3.2-20 2.3.2-21
whois 5.5.12-1 5.5.13-1
xapian-core 1:1.4.19-1 1:1.4.19-2
xdg-desktop-portal 1.14.2-1 1.14.3-1
xdg-desktop-portal-gnome 41.1-2 42.0.1-1
xfce4-panel 4.16.3-3 4.16.4-1
xfce4-taskmanager 1.4.2-1 1.5.2.201.g58cf9b2-1
xfce4-terminal 1.0.0-1 1.0.1-1
xorg-xclock 1.1.0-1 1.1.1-1
xorg-xdpyinfo 1.3.2-4 1.3.3-4
yelp 41.2-1 42.1-2
eog-docs - 42.0-1
evince-lib-docs - 42.1-1
ghex-docs - 42.0-1
gnome-bluetooth-3.0 - 42.0-1
gnome-desktop-4 - 1:42.0-1
gnome-desktop-common - 1:42.0-1
jdk17-openjdk - 17.0.3.u5-1
jre17-openjdk - 17.0.3.u5-1
jre17-openjdk-headless - 17.0.3.u5-1
mutter-docs - 42.0-2
openjdk17-src - 17.0.3.u5-1
qt6-languageserver - 6.3.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.12.2.r12716.gd6c994fb1-121.12.2.1.r12724.ged9c5c991-1
akonadi-calendar21.12.2.1.r2063.gfb7c24d-121.12.2.1.r2072.gf891436-1
akonadi-calendar-tools21.12.2.1.r943.g61e3635-121.12.2.1.r947.g70a8b4e-1
akonadi-contacts21.12.2.r3164.g9f54148d-121.12.2.1.r3168.gcabd8e6a-1
akonadi-import-wizard21.12.2.1.r1804.g0b9b769-121.12.2.1.r1809.ge5b1a60-1
akonadi-mime21.12.2.1.r1711.g6e45f7a-121.12.2.1.r1717.gfdc1ad9-1
akonadi-notes21.12.2.1.r1066.geb8a226-121.12.2.1.r1071.ga09eff6-1
akonadi-search21.12.2.1.r1216.g2417b02-121.12.2.1.r1218.gd750214-1
akonadiconsole21.12.2.1.r1581.g6c8d51f-121.12.2.1.r1584.gbf9abdc-1
akregator21.12.2.r6363.g8f4d201f-121.12.2.1.r6388.g3136292e-1
alligator 22.02.r6.gb278e86-1 22.02.r10.g9e6e28d-1
amazfish 2.0.5.r0.g822c988-1 2.0.5.r14.gcc91cbe-1
analitza21.12.2.1.r2335.g7c51885a-121.12.2.1.r2336.g4344e637-1
angelfish 22.02.r16.g0546104-1 22.02.r19.gadf0bc3-1
ark21.12.2.1.r4721.gfb424025-121.12.2.1.r4733.g3b2a6e23-1
artikulate21.12.2.1.r1410.g67aea66-121.12.2.1.r1413.g881d378-1
attica5.92.0.r862.gc6b7f2b-15.93.0.r864.g3fe5414-1
audiocd-kio21.12.2.1.r1055.g2fac6d9-121.12.2.1.r1056.g79b09d7-1
audiotube 22.02.r15.g0249604-1 22.02.r19.g32f98a7-1
aura-browser r44.3d28e35-1 r45.c96ff07-1
baloo5.92.0.r3044.g7a2ac836-15.93.0.r3046.g97fc3f6c-1
baloo-widgets21.12.2.r735.ga1ef854-121.12.2.1.r736.g20b8adc-1
blinken21.12.2.1.r660.ga3fe3c1-121.12.2.1.r663.gc80904d-1
bluedevil1:5.24.4.r2387.g96cffffc-11:5.24.4.r2388.g84731dd4-1
bluez-qt5.92.0.r708.g0ab9192-15.93.0.r709.gd393ffc-1
bomber21.12.2.1.r557.g613f51a-121.12.2.1.r560.g665f5e1-1
bovo21.12.2.1.r771.gd5fcf44-121.12.2.1.r773.gb32fdb4-1
breeze5.24.4.r2379.g94d75fa1-15.24.4.r2382.g37e44cf3-1
breeze-gtk5.24.4.r459.g64e5e24-15.24.4.r460.g69ddaab-1
breeze-icons5.92.0.r1893.g327feb5a-15.93.0.r1895.g154aabe5-1
calendarsupport21.12.2.r680.gf83af73-121.12.2.r686.gd83d160-1
calindori 22.02.r10.g2935faa-1 22.02.r12.ge765bec-1
cervisia21.12.2.1.r1656.g56bc817-121.12.2.1.r1660.g755eb43-1
discover5.24.4.r8620.g3901c96d-15.24.4.r8629.g57a7901a-1
dolphin21.12.2.1.r6905.g989d19c12-121.12.2.1.r6917.gfb0a3c03a-1
dolphin-plugins21.12.2.r649.g277f988-121.12.2.1.r651.g6a71839-1
dragon21.12.2.1.r1029.gb98922a-121.12.2.1.r1030.ga47eb40-1
drkonqi5.24.4.r754.gf8cf3b1e-15.24.4.r762.g3a071bf8-1
elisa21.12.2.1.r2935.gd6b1e2e1-121.12.2.1.r2941.g3a8a861d-1
elisa-qtmm21.12.2.1.r2935.gd6b1e2e1-121.12.2.1.r2941.g3a8a861d-1
eventviews21.12.2.r801.gd8dc8eb-121.12.2.r813.g8acbce2-1
extra-cmake-modules5.92.0.r3469.geccf695-15.93.0.r3474.g01f41fe3-1
ffmpegthumbs21.12.2.1.r210.g255affd-121.12.2.1.r212.gfc78559-1
filelight21.12.2.r1079.g8d7aee6-121.12.2.1.r1081.g58e47b1-1
frameworkintegration5.92.0.r630.ge6f07e0-15.93.0.r631.g450ca3e-1
granatier21.12.2.1.r971.gaff58a3-121.12.2.1.r973.gd3ccebd-1
grantlee-editor21.12.2.1.r814.g0c0574a-121.12.2.1.r817.g1a281e5-1
grantleetheme21.12.2.r387.g625a374-121.12.2.1.r390.g1ede968-1
gwenview21.12.2.1.r6833.ga79ee0e8-121.12.2.1.r6838.g72601b2a-1
incidenceeditor21.12.2.1.r869.g5407359-121.12.2.1.r875.g9ddeeda-1
index-fm 2.1.1.r6.g4540e26-1 2.1.1.r9.g5573935-1
itinerary21.12.2.1.r1763.gbaca503-121.12.2.1.r1796.g046fab9-1
juk21.12.2.1.r3139.gc36f4420-121.12.2.1.r3140.g2bf57f4a-1
k3b1:21.12.2.1.r6725.gdb3d8d408-11:21.12.2.1.r6748.g1582bc13e-1
kaccounts-integration21.12.2.r1252.g7ac2983-121.12.2.1.r1252.g7ac2983-1
kaccounts-providers21.12.2.1.r394.g59df5c8-121.12.2.1.r395.gae51a37-1
kactivities5.92.0.r1391.g8ec7442-15.93.0.r1393.gf9f494d0-1
kactivities-stats5.92.0.r400.g61c0328-15.93.0.r402.gecc54e7-1
kaddressbook21.12.2.1.r6136.gf4f0986d-121.12.2.1.r6158.gc3811762-1
kajongg21.12.2.1.r4334.g081a6040-121.12.2.1.r4336.geb6aea02-1
kalarm21.12.2.1.r7848.gcaf73623-121.12.2.1.r7867.g24c4e2a2-1
kalgebra21.12.2.1.r2059.gbc6d395-121.12.2.1.r2060.g6acdb42-1
kalk 22.02.r19.gab8e8a9-1 22.02.r22.gb39a23e-1
kalzium21.12.2.1.r4310.g678d26db-121.12.2.1.r4314.g76ca8ec2-1
kamera21.12.1.r709.gb0d8443-121.12.2.1.r711.g35e9c54-1
kamoso21.12.2.1.r1455.gd39a7ec-121.12.2.1.r1456.g4c6f238-1
kanagram21.12.2.r1304.gc6f9ed4-121.12.2.1.r1306.g26a586f-1
kapidox5.92.0.r566.gd385445-15.93.0.r568.g7809855-1
kapman21.12.2.1.r643.g3d5f40f-121.12.2.1.r647.gfad3e39-1
kapptemplate21.12.2.1.r984.ga7c3df8-121.12.2.1.r987.g2250ba7-1
karchive5.92.0.r537.g0eb4584-15.93.0.r538.gf63a2ba-1
kasts 22.02.r15.ge5a3408-1 22.02.r20.gc249c09-1
kate21.12.2.1.r18915.g9036a5d86-121.12.2.1.r18937.g3edeb6a00-1
katomic21.12.2.1.r953.g45e059e-121.12.2.1.r955.ged0bf40-1
kauth5.92.0.r496.g6169cf0-15.93.0.r497.g7881fd7-1
kbackup21.12.2.1.r427.g1d6d230-121.12.2.1.r430.ga1769ab-1
kblackbox21.12.2.1.r760.gd534b61-121.12.2.1.r762.g2cc1b10-1
kblocks21.12.2.1.r707.gb9f9940-121.12.2.1.r709.g4baa939-1
kbookmarks5.92.0.r457.g47b7927-15.93.0.r458.g144d69f-1
kbounce21.12.2.1.r842.g22d86c9-121.12.2.1.r844.gf5a1bfc-1
kbreakout21.12.2.1.r907.g39ab63d-121.12.2.1.r909.g5dd9090-1
kbruch21.12.2.1.r857.g99d9277-121.12.2.1.r860.g536b1a8-1
kcachegrind21.12.2.1.r1174.g535da9f-121.12.2.1.r1177.g8269eb6-1
kcachegrind-common21.12.2.1.r1174.g535da9f-121.12.2.1.r1177.g8269eb6-1
kcalc21.12.2.1.r1603.g3ad4e0a-121.12.2.1.r1606.gfcbe1d3-1
kcalendarcore5.92.0.r1312.g88650d497-15.93.0.r1314.g770ece2db-1
kcalutils21.12.2.1.r944.g9c8fb9066-121.12.2.1.r947.gfb1f70086-1
kcharselect21.12.2.r517.gedea8a6-121.12.2.1.r521.gfd7f2ca-1
kclock 22.02.r35.g6c2f1cc-1 22.02.r37.g643252c-1
kcmutils5.92.0.r611.g71b389d-15.93.0.r613.gfb88727-1
kcodecs5.92.0.r416.g190d755-15.93.0.r418.gdd64b09-1
kcolorchooser21.12.2.1.r262.g0282cd0-121.12.2.1.r264.gdac265d-1
kcompletion5.92.0.r490.g5cb3b5a-15.93.0.r492.g3f68837-1
kconfig5.92.0.r948.g288cbe4a-15.93.0.r950.g893376f6-1
kconfigwidgets5.92.0.r718.g8060bdb-15.93.0.r725.g0da09a5-1
kcontacts1:5.92.0.r3322.g3627d11b-11:5.93.0.r3329.gbc176765-1
kcoreaddons5.92.0.r1460.g45a2e5cf-15.93.0.r1463.ge2cf4c9c-1
kcrash5.92.0.r440.ge705853-15.93.0.r443.ge0e1410-1
kcron21.12.2.1.r839.ga2fead8-121.12.2.1.r840.g3ecc959-1
kdav1:5.92.0.r1338.ge45bcdb-11:5.93.0.r1340.ge7c525e-1
kdbusaddons5.92.0.r410.g8ce9670-15.93.0.r411.g37a701f-1
kde-cli-tools5.24.4.r1922.gfe0367b-15.24.4.r1924.gd350e17-1
kde-dev-utils21.12.2.1.r577.g31d8362-121.12.2.1.r579.ged8499b-1
kdebugsettings21.12.2.1.r901.g3026229-121.12.2.1.r917.g9a6e8af-1
kdeclarative5.92.0.r987.gfb55876-15.93.0.r990.g23209c6-1
kdeconnect21.12.2.1.r3422.g43960f3e-121.12.2.1.r3427.ge48a0b5f-1
kded5.92.0.r456.g70ad9d2-15.93.0.r457.gec36fda-1
kdegraphics-mobipocket21.12.2.1.r265.g8e1b8b9-121.12.2.1.r266.g6606ec7-1
kdegraphics-thumbnailers21.12.2.1.r261.gfccb596-121.12.2.1.r262.g501484e-1
kdelibs4support5.92.0.r1079.g24ea8da1-15.93.0.r1080.gfd7ccadb-1
kdenetwork-filesharing21.12.2.1.r922.gb43d4ae-121.12.2.1.r926.gf57d414-1
kdenlive21.12.1.r15945.g3594e8a2a-121.12.2.1.r15986.g7b7c568ba-1
kdepim-addons21.12.2.r4612.gc2ee10fe-121.12.2.1.r4622.gecd7b660c-1
kdepim-runtime21.12.2.r15485.g766486a64-121.12.2.1.r15501.gd40c00a1f-1
kdeplasma-addons5.24.4.r8710.g5f02e49f0-15.24.4.r8744.g0a6c7ff7a-1
kdesignerplugin5.92.0.r351.g0344e85-15.93.0.r352.gfe65895-1
kdesu5.92.0.r504.g8e8af0c-15.93.0.r505.g6c69c07-1
kdewebkit5.92.0.r298.g11363e5-15.93.0.r299.g1beed50-1
kdf21.12.2.1.r846.g7c94c2b-121.12.2.1.r847.g354ec2b-1
kdialog21.12.2.1.r1210.gf711b0807-121.12.2.1.r1212.g146f1cf1c-1
kdiamond21.12.2.1.r718.ge41138a-121.12.2.1.r720.g50868d6-1
kdnssd5.92.0.r346.g1072cb0-15.93.0.r348.g9a734c5-1
kdoctools5.92.0.r656.gb992dc9-15.93.0.r657.g50d53ec-1
keditbookmarks21.12.2.1.r2761.g1fd08561c-121.12.2.1.r2762.gc70a7d063-1
kemoticons5.92.0.r408.g874bb3d-15.93.0.r410.g974fe55-1
keysmith 22.02.r7.g506234c-1 22.02.r8.g226e070-1
kfilemetadata5.92.0.r857.g562eaa4-15.93.0.r860.g8d4d411-1
kfind21.12.2.1.r2677.g818f75714-121.12.2.1.r2679.g426228e1d-1
kfloppy21.12.2.r790.ge3dfd23-121.12.2.1.r791.g0f13873-1
kfourinline21.12.2.1.r1017.gda3fc3d-121.12.2.1.r1019.g94390ac-1
kgeography21.12.2.1.r1142.g7a07b72-121.12.2.1.r1144.ga518151-1
kget21.12.2.1.r3174.g8a33ddb3-121.12.2.1.r3184.gc43ec4ac-1
kglobalaccel5.92.0.r508.ge4a33e5-15.93.0.r509.ga75819f-1
kgoldrunner21.12.2.1.r1272.g854fa14-121.12.2.1.r1276.g188bb68-1
kgpg21.12.2.1.r3181.gf8aae35d-121.12.2.1.r3183.gc10637d0-1
kguiaddons5.92.0.r455.g136a7a3-15.93.0.r458.g5f6fd28-1
khangman21.12.2.1.r1593.g8e6e1bd-121.12.2.1.r1596.g0be2d48-1
khelpcenter21.12.2.r2730.gbbe43d95-121.12.2.1.r2734.g0ad337d9-1
kholidays1:5.92.0.r1001.g911c6b0-11:5.93.0.r1006.g15aefbd-1
khotkeys5.24.4.r2118.g5735c4a-15.24.4.r2122.g44ba571-1
khtml5.92.0.r578.gec65222-15.93.0.r581.gfbc98d0-1
ki18n5.92.0.r551.g2787adc-15.93.0.r552.gbabae50-1
kiconthemes5.92.0.r594.g5c0053a-15.93.0.r597.gb600890-1
kidentitymanagement21.12.2.1.r3879.g37726c07-121.12.2.1.r3883.gd95d451e-1
kidletime5.92.0.r352.gc030e0f-15.93.0.r354.gbdd25b5-1
kig21.12.2.1.r3179.g7bd68390-121.12.2.1.r3182.g0d804a75-1
kigo21.12.2.r558.gd3d6e41-121.12.2.1.r560.g1ac92cb-1
killbots21.12.2.1.r776.ga88a61c-121.12.2.1.r780.g830641f-1
kimageformats5.92.0.r389.g98f19c6-15.93.0.r399.g52134fc-1
kimagemapeditor21.12.2.1.r482.g8c5307d-121.12.2.1.r486.g3006809-1
kimap21.12.2.1.r1182.gd0525ee-121.12.2.1.r1186.g181f0d3-1
kinfocenter5.24.4.r2058.g3f626c1-15.24.4.r2069.geefed473-1
kinit5.92.0.r433.g83f67a1-15.93.0.r434.g2735784-1
kio5.92.0.r5395.g3841e741b-15.93.0.r5404.gb21b81f19-1
kio-extras21.12.2.1.r7216.g877da1c8-121.12.2.1.r7228.ga71b56c0-1
kio-gdrive21.12.2.1.r592.g6b068bb-121.12.2.1.r595.g1ab2849-1
kipi-plugins21.12.2.1.r12085.gaed78cb02-121.12.2.1.r12087.g604ce6cc3-1
kirigami-addons 1:0.2.r26.g03cbae6-1 1:0.2.r27.g9422f0f-1
kirigami-gallery21.12.2.1.r235.g5bb850c-121.12.2.1.r238.g8b2a1ca-1
kirigami25.92.0.r3105.g260f3343-15.93.0.r3111.g6c741e52-1
kiriki21.12.2.1.r446.g03b4088-121.12.2.1.r448.g22ec3ba-1
kitemmodels5.92.0.r600.g2c1d8fd-15.93.0.r604.gd469614-1
kitemviews5.92.0.r367.g216967b-15.93.0.r369.gdfbf6f8-1
kiten21.12.2.1.r1180.g59319a1-121.12.2.1.r1183.ga08ea23-1
kitinerary21.12.2.1.r2135.g6093673-121.12.2.1.r2152.g017ef2f-1
kjobwidgets5.92.0.r411.gaa97b08-15.93.0.r413.g764bb7f-1
kjs5.92.0.r358.gf6a0701-15.93.0.r360.g4243416-1
kjsembed5.92.0.r322.gf0b7a01-15.93.0.r324.g78971b8-1
kjumpingcube21.12.2.1.r818.g96aa656-121.12.2.1.r821.g9c0676c-1
kldap21.12.2.1.r941.gfdd3743-121.12.2.1.r945.g0713bcc-1
kleopatra21.12.2.1.r6324.g7aae07cb-121.12.2.1.r6368.g5b467723-1
klettres21.12.2.1.r953.g2a36e8f-121.12.2.1.r957.gf6fec52-1
klickety21.12.2.1.r666.g2f3840b-121.12.2.1.r670.gfb08802-1
klines21.12.2.1.r802.geef7e01-121.12.2.1.r808.ga194437-1
kmag21.12.2.1.r726.gce7ddf0-121.12.2.1.r733.g8bf8b40-1
kmahjongg21.12.2.r1519.g6172833-121.12.2.1.r1522.g47e13ac-1
kmail21.12.2.r26320.g5ee59d106-121.12.2.1.r26336.g4be40793c-1
kmail-account-wizard21.12.2.1.r873.g2edc296-121.12.2.1.r878.g349bb22-1
kmailtransport21.12.2.1.r1721.ga805cc4-121.12.2.1.r1725.g12ea2f6-1
kmbox21.12.2.1.r588.g364b8d0-121.12.2.1.r592.g82271c2-1
kmediaplayer5.92.0.r314.gce7adac-15.93.0.r315.gb48fbd0-1
kmenuedit5.24.4.r1029.gaffeb14-15.24.4.r1033.g5881fcd-1
kmime21.12.2.1.r1501.gabf00b2-121.12.2.1.r1504.g68700df-1
kmines21.12.2.r1759.g9eadbaa-121.12.2.1.r1762.gce1fc8f-1
kmix21.12.2.1.r2433.g67acca5d-121.12.2.1.r2437.g2da8a3f7-1
kmousetool21.12.2.1.r427.g7f6dfb2-121.12.2.1.r431.g8f55646-1
kmouth21.12.2.1.r711.g4b51919-121.12.2.1.r720.g5bf6440-1
kmplot21.12.2.1.r1479.g41ac6b0-121.12.2.1.r1483.g16bdae3-1
knavalbattle21.12.2.1.r1422.g977213f-121.12.2.1.r1424.g18b027f-1
knetwalk21.12.2.1.r690.g0970c49-121.12.2.1.r693.gc833d2c-1
knewstuff5.92.0.r1319.g0a523693-15.93.0.r1323.gef3a137d-1
knights21.12.2.1.r1116.gfc6d1a5-121.12.2.1.r1122.gce7a9b4-1
knotes21.12.2.r3625.g16adaf15-121.12.2.1.r3640.g8973ee1f-1
knotifications5.92.0.r726.gf58cab5-15.93.0.r731.gbb26a1a-1
knotifyconfig5.92.0.r378.g5d38bda-15.93.0.r380.g474a45f-1
koko 22.02.r0.g0df92e5-1 22.02.r4.gbd32df4-1
kolf21.12.2.1.r1483.g6c8ac13-121.12.2.1.r1487.gee13864-1
kollision21.12.2.1.r527.g086b93f-121.12.2.1.r529.g5223b0e-1
kolourpaint21.12.2.1.r2384.gb1e116da-121.12.2.1.r2388.gf59b261e-1
kompare21.12.2.1.r1131.g50a8d3d-121.12.2.1.r1133.g2da8145-1
kongress 22.02.r3.g97ad69d-1 22.02.r5.ga07f09c-1
konqueror21.12.2.r15091.g6d55c26d3-121.12.2.1.r15096.g00314e597-1
konquest21.12.2.1.r922.g70d6dac-121.12.2.1.r924.gfb830d8-1
konsole21.12.2.r8326.g0653603b-121.12.2.1.r8332.g029ee4e2-1
kontact21.12.2.1.r5498.gaec105c4-121.12.2.1.r5507.g2801e4d8-1
kontactinterface21.12.2.1.r672.g4f7f47e-121.12.2.1.r678.gdb3964e-1
kontrast21.12.2.1.r195.gfba2aa3-121.12.2.1.r200.gc2bef9b-1
konversation21.12.2.1.r9097.g235ef003-121.12.2.1.r9106.g9a4d6e6a-1
kopeninghours21.12.2.1.r323.gb266e34-121.12.2.1.r326.g44c5494-1
korganizer21.12.2.r11666.g23116fa65-121.12.2.1.r11679.g6e052c947-1
kosmindoormap21.12.2.1.r708.g2ddcd90-121.12.2.1.r719.g9530056-1
kpackage5.92.0.r743.gddddb8b-15.93.0.r745.gbf2011b-1
kparts5.92.0.r579.gcbc2f5b-15.93.0.r581.gd515a3c-1
kpat21.12.2.r2605.gb1afb1f-121.12.2.1.r2606.g33556cba-1
kpeople5.92.0.r1370.g1379d3a-15.93.0.r1373.g192254e-1
kpimtextedit21.12.2.1.r1572.g6b828a0-121.12.2.1.r1587.g030e913-1
kpkpass21.12.2.1.r280.gc70b770-121.12.2.1.r287.gfbb7d68-1
kplotting5.92.0.r318.g5cf7e5d-15.93.0.r321.gad0c611-1
kpmcore21.12.2.r1280.gd247e02-121.12.2.1.r1280.gd247e02-1
kpty5.92.0.r369.gc8945f1-15.93.0.r370.gd911181-1
kpublictransport21.12.1.r1987.gf7f93ea3-121.12.2.1.r2001.ga1f81652-1
kquickcharts5.92.0.r512.gb4b8f8b-15.93.0.r516.gecd6deb-1
krdc21.12.2.1.r1568.g694e95f-121.12.2.1.r1574.g1f42ee8-1
krecorder 22.02.r10.gd1d9fab-1 22.02.r13.g55ca4b7-1
kreversi21.12.2.1.r1260.g202d63b-121.12.2.1.r1262.gfe10b13-1
krfb21.12.2.1.r1475.g9b634ae-121.12.2.1.r1477.ga58c787-1
kross5.92.0.r354.g4150d02-15.93.0.r356.gf26bbc1-1
kruler21.12.2.1.r730.g1929aeb-121.12.2.1.r732.g1bdf0a4-1
krunner5.92.0.r742.gef1e99d-15.93.0.r746.g1f1d5c0-1
kscreen5.24.4.r1444.g275cdc0-15.24.4.r1447.g15056b9-1
kscreenlocker5.24.4.r921.g59052e7-15.24.4.r926.g6bfb981-1
kservice5.92.0.r1003.gd55a8c2-15.93.0.r1005.g8d038e2-1
kshisen21.12.2.1.r1233.g12d6444-121.12.2.1.r1235.g1957eed-1
ksirk21.12.2.1.r1014.g824b0aa-121.12.2.1.r1015.gd5a6ecc-1
ksmtp21.12.2.1.r428.g834cdb9-121.12.2.1.r443.gecd8493-1
ksnakeduel21.12.2.1.r839.g7264cd7-121.12.2.1.r841.g24c0748-1
kspaceduel21.12.2.1.r665.gfb1045f-121.12.2.1.r667.g18dd978-1
ksquares21.12.2.1.r552.g2ea3532-121.12.2.1.r554.g276bded-1
ksudoku21.12.2.1.r1099.g33e7235-121.12.2.1.r1100.g62cdaa2-1
ksystemlog21.12.2.1.r714.gf468d79-121.12.2.1.r719.gd9d9244-1
kteatime21.12.2.1.r747.gf4d9f73-121.12.2.1.r750.g23998f6-1
ktexteditor5.92.0.r3315.g66d92ec7-15.93.0.r3345.gd3f3188c-1
ktextwidgets5.92.0.r442.gf01ea31-15.93.0.r445.ga7e170e-1
ktimer21.12.2.1.r506.g18fb181-121.12.2.1.r508.g9d461ac-1
ktnef21.12.2.1.r711.g81ba74b-121.12.2.1.r714.g3d3d558-1
ktorrent21.12.2.r2833.ge6a6d63d-121.12.2.1.r2838.g86932d7a-1
ktouch21.12.2.1.r2172.g05b2fca-121.12.2.1.r2173.g1b67484-1
ktrip 22.02.r7.g0ca5308-1 22.02.r9.g93c79a0-1
ktuberling21.12.2.1.r1034.gac99858-121.12.2.1.r1036.g824e2ff-1
kturtle21.12.2.1.r1157.gf039ae6-121.12.2.1.r1160.g8159849-1
kubrick21.12.2.1.r397.gb0c7b8a-121.12.2.1.r399.g81a247c-1
kunitconversion5.92.0.r409.gd10e313-15.93.0.r413.g947a8eb-1
kwallet5.92.0.r1138.gd396695-15.93.0.r1141.g5e2ae66-1
kwalletmanager21.12.2.1.r1263.g8ae2d3f-121.12.2.1.r1264.g7c3af2b-1
kwave21.12.2.1.r3775.g6f27a0d0-121.12.2.1.r3776.g4492edfb-1
kwayland5.92.0.r1151.g15af039-15.93.0.r1154.g9e70125-1
kwayland-server5.24.4.r1466.gb1e8ac2-15.24.4.r1474.gcdc9dcf-1
kweather 22.02.r14.gc3ab3c5-1 22.02.r21.ge3e11ec-1
kweathercore 0.5.r7.g49175a5-1 0.5.r12.gf738a7b-1
kwidgetsaddons5.92.0.r922.gbc47af59-15.93.0.r932.g5534343e-1
kwin5.24.4.r21020.g9de79c62c-15.24.4.r21123.g3d038b715-1
kwindowsystem5.92.0.r671.gcb7f9b1-15.93.0.r677.gd861023-1
kwordquiz21.12.2.r1175.ga103cbf-121.12.2.1.r1176.g7e07353-1
kwrite21.12.2.1.r18915.g9036a5d86-121.12.2.1.r18937.g3edeb6a00-1
kwrited5.24.4.r502.g7f4c59c-15.24.4.r503.g4bba2da-1
kxmlgui5.92.0.r867.g5f989947-15.93.0.r871.ge556c39d-1
kxmlrpcclient5.92.0.r477.gbbdab17df-15.93.0.r478.ga00e63b16-1
libakonadi21.12.2.r12716.gd6c994fb1-121.12.2.1.r12724.ged9c5c991-1
libgravatar21.12.2.1.r414.g4e87355-121.12.2.1.r420.gda9de61-1
libkcddb21.12.2.r752.gee0f14e-121.12.2.1.r752.gee0f14e-1
libkdcraw21.12.2.1.r1151.g0368098-121.12.2.1.r1152.g52c0298-1
libkdegames21.12.2.1.r2230.gd036c9c3-121.12.2.1.r2231.g7ff26535-1
libkdepim21.12.2.1.r898.g5efb1d7-121.12.2.1.r903.g2989cae-1
libkexiv221.12.2.1.r818.gd8dbd19-121.12.2.1.r819.g65ad062-1
libkgapi21.12.2.1.r1352.ge1296a1-121.12.2.1.r1355.gbc59849-1
libkleo21.12.2.1.r1102.g98af5bd-121.12.2.1.r1107.g75e8501-1
libkmahjongg21.12.2.1.r477.g7ac6fdb-121.12.2.1.r478.g99719ee-1
libksieve21.12.2.1.r1690.g9ab37cf7-121.12.2.1.r1693.g1598612c-1
lokalize21.12.2.1.r1814.gd7d43f36-121.12.2.1.r1816.gd4b2db75-1
lskat21.12.2.1.r841.g01237db-121.12.2.1.r845.gb6ccfbc-1
mailcommon21.12.2.1.r1221.g1e0ac5a-121.12.2.1.r1229.gaa7cb35-1
mailimporter21.12.2.1.r511.g730ca87-121.12.2.1.r515.gdbe0124-1
maliit-framework 2.2.1.r0.gad906cad-1 2.2.1.r8.gc220a8c8-1
maliit-keyboard2.2.0.r25.g06517b03-12.2.1.1.r0.gae81a17b-1
marble21.12.2.1.r13410.gdabb47d5d-121.12.2.1.r13420.g17bafd867-1
marble-common21.12.2.1.r13410.gdabb47d5d-121.12.2.1.r13420.g17bafd867-1
marble-qt21.12.2.1.r13410.gdabb47d5d-121.12.2.1.r13420.g17bafd867-1
markdownpart21.12.2.1.r106.g0480ace-121.12.2.1.r109.g7c87778-1
maui-clip 2.1.1.r1.g900dd3d-1 2.1.1.r3.gd083bfa-1
maui-nota 2.1.1.r15.g545749a-1 2.1.1.r18.g907c41f-1
maui-pix 2.1.0.r15.g83cefe5-1 2.1.0.r20.gaffcf43-1
maui-shell v0.5.0.r0.g61ae7f2-1v0.5.0.r11.g60472af-1
mauikit2.1.1.r14.g795f1150-12.1.1.r17.g1d90da03-1
mauikit-imagetools 2.1.1.r1.g184168a-1 2.1.1.r2.gf5e0766-1
mbox-importer21.12.2.1.r559.ged55947-121.12.2.1.r562.gd5c39d7-1
messagelib21.12.1.r6472.gfd22bc629-121.12.2.1.r6478.gcb2f997c3-1
minuet21.12.2.1.r601.gf211186-121.12.2.1.r603.g28ac43e-1
modemmanager-qt5.92.0.r551.g0222a64-15.93.0.r552.g31cec82-1
mycroft-bigscreen21.2.2.r4904.gccd577bbf4-121.2.2.r4908.g3d64aa5940-1
mycroft-skill-installer r88.72bb7ab-1 r89.118828a-1
neochat22.02.r40.g024fb1a9-122.02.r57.g81ba5f6e-1
networkmanager-qt5.92.0.r1149.g9ab40c0-15.93.0.r1150.ga7b1849-1
okular21.12.2.1.r9690.g8aa96484d-121.12.2.1.r9702.gfb3baa087-1
oxygen5.24.4.r4454.g8db0682e-15.24.4.r4458.g0143247a-1
oxygen-icons1:5.92.0.r5.gbff159d-11:5.93.0.r5.gbff159d-1
oxygen-icons-svg1:5.92.0.r5.gbff159d-11:5.93.0.r5.gbff159d-1
palapeli21.12.2.1.r1268.g8139e79-121.12.2.1.r1270.g3e6aa2c-1
parley21.12.2.r4510.gc4fa03ea-121.12.2.1.r4511.g277a18cc-1
partitionmanager21.12.2.r1608.gd493384-121.12.2.1.r1610.g3b6093f-1
picmi21.12.2.1.r558.gf379367-121.12.2.1.r559.gdbb68b9-1
pim-data-exporter21.12.2.r2585.gbdf0218b-121.12.2.1.r2590.g6bc8daca-1
pim-sieve-editor21.12.2.r1611.gae3f691-121.12.2.1.r1617.gd95bbb8-1
pimcommon21.12.2.r1210.gb107f8d-121.12.2.r1215.g65fbabb-1
plasma-bigscreen r459.g811b78b-1 r465.g96442b3-1
plasma-browser-integration5.24.4.r1308.gdb24643d-15.24.4.r1313.g0383bff0-1
plasma-camera 1.0.r116.g4f4d9b2-1 1.0.r120.ged8d9b2-1
plasma-desktop5.24.4.r9185.g9b0d1e442-15.24.4.r9206.gc2eba6f67-1
plasma-dialer 22.02.r20.g7b7062a-1 22.02.r22.gdb9dad0-1
plasma-framework5.92.0.r16240.gfe079da99-15.93.0.r16262.g8e8f6676c-1
plasma-integration5.24.4.r558.g8a36a5b-15.24.4.r562.g43922b5-1
plasma-mobile5.24.4.r1691.g03f3411c9-15.24.4.r1732.gf0e1d4e46-1
plasma-mobile-nm5.24.4.r3231.g54bd6d62-15.24.4.r3235.g4651adc7-1
plasma-nano5.24.4.r177.g8992514-15.24.4.r180.gd36c0bc-1
plasma-nm5.24.4.r3231.g54bd6d62-15.24.4.r3234.g04bbbbf1-1
plasma-pa5.24.4.r1039.gb7bd02b-15.24.4.r1040.g82cfbb5-1
plasma-phonebook 22.02.r3.g36bfe25-1 22.02.r5.g5ad5a2f-1
plasma-sdk5.24.4.r2338.g1187d73e-15.24.4.r2340.g9f04ccd4-1
plasma-settings 22.02.r23.g34aaaa3-1 22.02.r27.gb6bd7fd-1
plasma-systemmonitor5.24.4.r558.g96976cf-15.24.4.r559.g704cc5c-1
plasma-thunderbolt5.24.4.r183.g022c70c-15.24.4.r184.g7463c2b-1
plasma-wayland-protocols1.4.0.r1047.gb49a289-11.4.0.r1048.g129263b-1
plasma-wayland-session5.24.4.r11623.g16ae8b9e6-15.24.4.r11654.gf994e1301-1
plasma-workspace5.24.4.r11623.g16ae8b9e6-15.24.4.r11654.gf994e1301-1
plasmatube 22.02.r11.ga2aa32b-1 22.02.r15.g7e97658-1
polkit-kde-agent5.24.4.r518.gff0264d-15.24.4.r519.g33ad741-1
powerdevil5.24.4.r2527.g4c031ac8-15.24.4.r2529.g94f81868-1
print-manager21.12.2.r1117.g3cebb72-121.12.2.1.r1121.g89b0d71-1
prison5.92.0.r366.g0d48f0b-15.93.0.r370.gb74a73b-1
purpose5.92.0.r959.g51725bef-15.93.0.r966.g41bd964-1
qcachegrind21.12.2.1.r1174.g535da9f-121.12.2.1.r1177.g8269eb6-1
qmlkonsole 22.02.r0.gaf58029-1 22.02.r2.gadaf67f-1
qqc2-desktop-style5.92.0.r595.g210a614-15.93.0.r597.g19e30c1-1
rocs21.12.2.1.r3070.gc0785a1f-121.12.2.1.r3072.g913fe2d7-1
solid5.92.0.r763.g3628f56-15.93.0.r766.g1f0c29b-1
sonnet5.92.0.r685.g9f7baaf-15.93.0.r687.ga5ce28a-1
spacebar22.02.2.r18.gbfa09f1-122.02.2.r22.g723528f-1
spectacle21.12.2.1.r1318.g1f864a1-121.12.2.1.r1336.g807dc60-1
step21.12.2.1.r1176.g392ec82-121.12.2.1.r1178.gbfcca27-1
svgpart21.12.2.1.r211.ga933290-121.12.2.1.r214.g53cd08d-1
sweeper21.12.2.1.r561.gcda16ca-121.12.2.1.r562.g533a234-1
syndication5.92.0.r868.g1520abd-15.93.0.r870.gdbeaf26-1
syntax-highlighting5.92.0.r1823.g9e4bda8f-15.93.0.r1829.g42a061b0-1
systemsettings5.24.4.r2640.ge2b85abe-15.24.4.r2642.gae29f170-1
telepathy-kde-accounts-kcm21.12.2.1.r1210.g052843e-121.12.2.1.r1211.ga82a68a-1
telepathy-kde-common-internals21.12.2.1.r2007.g5e1b8b1-121.12.2.1.r2009.gf67843e-1
telepathy-kde-integration-module21.12.2.1.r397.g797a0ab-121.12.2.1.r399.gfed9154-1
telepathy-kde-text-ui21.12.2.1.r2035.g60f7371-121.12.2.1.r2036.ge226558-1
threadweaver5.92.0.r536.g6b31874-15.93.0.r538.g1c94a42-1
tokodon 22.02.r13.g0932587-1 22.02.r25.g0394cd7-1
umbrello21.12.2.r8437.g55a1e56fd-121.12.2.1.r8447.g129462a49-1
vakzination 22.02.r3.g43cd761-1 22.02.r5.g3c8be02-1
vvave 2.1.1.r7.geaa3902-1 2.1.1.r10.gea81747-1
xdg-desktop-portal-kde5.24.4.r448.g9d217b4-15.24.4.r449.g5fd51ef-1
yakuake21.12.2.1.r779.g89fcbe7-121.12.2.1.r784.g871e27f-1
zeroconf-ioslave21.12.2.1.r373.g63ff6d3-121.12.2.1.r376.ge2fb8a8-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
