[ARM Testing Update] 2022-04-07 - Firefox, Thunderbird, Osmin and kernels
Hello ARM community.
Slowly getting ready for the next release.
Some highlights:
  • Most of our kernels got updated
  • Firefox updated to 99.0
  • And Thunderbird updated to 91.8
  • Osmin updated to 1.8.0
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Thu Apr 7 08:20:48 CEST 2022)
  • arm-testing community aarch64: 145 new and 145 removed package(s)
  • arm-testing core aarch64: 13 new and 12 removed package(s)
  • arm-testing extra aarch64: 199 new and 208 removed package(s)
  • arm-testing kde-unstable aarch64: 185 new and 185 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2022-04-04         2022-04-07
                               osmin              1.7.2-1              1.8.0-1
                               phosh0.17.0+58+gfdf28e4f-10.17.0+88+gc55ae1cf-1
                         squeekboard  1.17.0+2+g59c3da0-1 1.17.0+18+g5a21071-1
:: Different sync package(s) in repository community aarch64
                        aardvark-dns              1.0.1-1              1.0.2-1
                anything-sync-daemon               5.86-1              6.0.0-1
                       arc-gtk-theme           20220223-1           20220405-1
                 arc-solid-gtk-theme           20220223-1           20220405-1
                               broot             1.10.0-1             1.11.1-1
                            buildkit             0.10.0-1             0.10.0-2
                               cacti             1.2.19-1             1.2.20-1
                             certbot             1.25.0-2             1.26.0-1
                      certbot-apache             1.25.0-2             1.26.0-1
              certbot-dns-cloudflare             1.25.0-1             1.26.0-1
                certbot-dns-cloudxns             1.25.0-1             1.26.0-1
            certbot-dns-digitalocean             1.25.0-1             1.26.0-1
                certbot-dns-dnsimple             1.25.0-1             1.26.0-1
             certbot-dns-dnsmadeeasy             1.25.0-1             1.26.0-1
                  certbot-dns-gehirn             1.25.0-1             1.26.0-1
                  certbot-dns-google             1.25.0-1             1.26.0-1
                  certbot-dns-linode             1.25.0-1             1.26.0-1
                  certbot-dns-luadns             1.25.0-1             1.26.0-1
                   certbot-dns-nsone             1.25.0-1             1.26.0-1
                     certbot-dns-ovh             1.25.0-1             1.26.0-1
                 certbot-dns-rfc2136             1.25.0-1             1.26.0-1
                 certbot-dns-route53             1.25.0-1             1.26.0-1
             certbot-dns-sakuracloud             1.25.0-1             1.26.0-1
                       certbot-nginx             1.25.0-2             1.26.0-1
                             chezmoi             2.14.0-1             2.15.0-1
                   containers-common           1:0.47.4-3           1:0.47.4-4
                                 cue              0.4.1-1              0.4.2-1
                      docker-compose              2.4.0-1              2.4.1-1
                           drumstick              2.5.1-1              2.6.0-1
                             e-antic              1.1.0-1              1.1.1-1
                               faust             2.37.3-2             2.40.0-1
                             freecad             0.19.4-1             0.19.4-2
                               fwupd              1.7.6-1              1.7.7-1
                              gaupol             1.10.1-2               1.11-1
                            glfw-doc              3.3.6-1              3.3.7-1
                        glfw-wayland              3.3.6-1              3.3.7-1
                            glfw-x11              3.3.6-1              3.3.7-1
                              gource               0.51-7               0.52-1
                                grpc             1.45.0-1             1.45.1-1
                            grpc-cli             1.45.0-1             1.45.1-1
                              harvid              0.8.3-3              0.9.0-1
                               helix              0.6.0-1              22.03-1
                       i3status-rust             0.21.8-1             0.21.9-1
                            jacktrip              1.5.2-1              1.5.3-1
                             jenkins              2.341-1              2.342-1
                   jupyter-nbclassic              0.3.7-1              0.3.7-2
                   jupyter-nbconvert              6.4.5-3              6.4.5-4
                    jupyter-nbformat              5.2.0-1              5.3.0-2
                    jupyter-notebook             6.4.10-3             6.4.10-4
          jupyter-widgetsnbextension            1:3.6.0-1            1:3.6.0-2
                          jupyterlab              3.3.2-2              3.3.2-3
                      knative-client              1.0.0-1              1.3.1-1
                         kube-linter              0.2.5-1              0.2.6-1
                           kustomize              4.4.1-1              4.5.4-1
                             liblscp              0.9.5-1              0.9.6-1
                       libtraceevent            1:1.5.2-1            1:1.5.3-1
                  libtraceevent-docs            1:1.5.2-1            1:1.5.3-1
                                 lxd               4.24-1              5.0.0-1
                    maliit-framework              2.2.0-1              2.2.1-1
                     maliit-keyboard              2.2.0-1              2.2.1-1
               matrix-appservice-irc             0.33.0-1             0.33.1-1
                        matterbridge             1.24.1-1             1.25.0-1
                               minio         2022.03.14-1         2022.04.01-1
                        minio-client         2022.03.13-1         2022.04.01-1
                       mod_passenger             6.0.12-4             6.0.13-1
                            netavark              1.0.1-1              1.0.2-1
          networkmanager-fortisslvpn              1.4.0-1              1.4.0-2
                 nginx-mod-passenger             6.0.12-4             6.0.13-1
                              nuitka              0.7.6-1              0.7.7-1
                      openbsd-netcat            1.218_2-1            1.218_5-1
                         opencascade            1:7.5.3-2            1:7.5.3-3
                     owncloud-client        2.10.0.6519-1        2.10.1.7187-1
                            pacredir              0.4.4-1              0.4.5-1
                                pari             2.13.3-1             2.13.4-1
                                 pcp              5.3.6-1              5.3.7-1
                             pcp-gui              5.3.6-1              5.3.7-1
                   pcp-pmda-activemq              5.3.6-1              5.3.7-1
                        pcp-pmda-bcc              5.3.6-1              5.3.7-1
                      pcp-pmda-bind2              5.3.6-1              5.3.7-1
                   pcp-pmda-bpftrace              5.3.6-1              5.3.7-1
                    pcp-pmda-libvirt              5.3.6-1              5.3.7-1
                      pcp-pmda-mysql              5.3.6-1              5.3.7-1
                      pcp-pmda-nginx              5.3.6-1              5.3.7-1
                 pcp-pmda-nutcracker              5.3.6-1              5.3.7-1
                pcp-pmda-openmetrics              5.3.6-1              5.3.7-1
                     pcp-pmda-podman              5.3.6-1              5.3.7-1
                 pcp-pmda-postgresql              5.3.6-1              5.3.7-1
                       pcp-pmda-snmp              5.3.6-1              5.3.7-1
                                  pd             0.52.1-1             0.52.2-1
                                pdal              2.3.0-5              2.4.0-1
                     perl-par-packer              1.054-1              1.054-2
                            php-grpc             1.45.0-1             1.45.1-1
                           php7-grpc             1.45.0-1             1.45.1-1
                              podman              4.0.1-2              4.0.3-1
                       podman-docker              4.0.1-2              4.0.3-1
                            polymake                4.6-1                4.6-2
                   powerdns-recursor              4.6.1-1              4.6.2-1
                           profanity           1:0.11.1-4           1:0.12.1-2
                       profanity-gtk           1:0.11.1-4           1:0.12.1-2
                             pyright            1.1.234-1            1.1.235-1
                         python-acme             1.25.0-2             1.26.0-1
                python-aiohttp-socks              0.7.1-3              0.7.1-4
               python-awesomeversion             22.2.0-1             22.4.0-1
                   python-diff-cover              6.4.4-2              6.4.5-1
               python-django-allauth             0.49.0-1             0.50.0-1
                       python-falcon              3.0.1-3              3.1.0-1
                       python-grpcio             1.45.0-1             1.45.1-1
          python-importlib_resources              5.4.0-3              5.6.0-1
                    python-ipykernel             6.11.0-2             6.12.1-1
                   python-ipywidgets              7.7.0-2              7.7.0-3
                   python-matrix-nio             0.19.0-2             0.19.0-4
                python-pylink-square             0.11.1-2             0.12.0-1
                      python-pymupdf             1.19.5-1             1.19.6-1
                   python-pynitrokey             0.4.20-1             0.4.21-1
              python-pytest-metadata             1.11.0-3              2.0.1-1
                 python-python-socks              2.0.3-1              2.0.3-2
                         python-rich             12.1.0-1             12.2.0-1
                        python-spsdk              1.6.2-1              1.6.3-2
               python-spyder-kernels              2.2.1-2              2.3.0-2
                                qgis             3.24.1-1             3.24.1-2
                            qjackctl              0.9.6-1              0.9.7-1
                            qmidictl              0.9.5-1              0.9.6-2
                            qmidinet              0.9.5-1              0.9.6-1
                              qsynth            0.9.6-1.1              0.9.7-1
                             qxgedit              0.9.5-1              0.9.6-1
                             rocksdb             6.29.3-1              7.0.4-1
                          ruby-nio4r              2.5.7-2              2.5.8-1
                       rust-analyzer           20220328-1           20220404-1
                          serverless             3.10.2-1             3.11.0-1
                            smartdns                 36-1               36.1-1
                             snapper              0.9.1-2             0.10.0-1
                    sonic-visualiser                4.4-2                4.5-1
                              spyder              5.2.2-1              5.3.0-2
                               trivy             0.25.0-2             0.25.1-1
                    uutils-coreutils             0.0.12-1             0.0.13-1
         v2ray-domain-list-community     20220403103254-1     20220405035552-1
                                vmpk              0.8.6-1              0.8.7-2
                                 vtk             9.1.0-12             9.1.0-13
                      weechat-matrix              0.3.0-6              0.3.0-8
                         x42-plugins           20220107-1           20220327-1
                              xjadeo             0.8.10-4             0.8.11-1
:: Different overlay package(s) in repository core aarch64
                     linux-pinephone             5.17.1-1             5.17.1-2
             linux-pinephone-headers             5.17.1-1             5.17.1-2
                  linux-pinephonepro             5.17.1-1             5.17.1-2
          linux-pinephonepro-headers             5.17.1-1             5.17.1-2
                      linux-quartz64           5.17.0-0.4           5.17.0-0.5
              linux-quartz64-headers           5.17.0-0.4           5.17.0-0.5
                     uboot-pinephone         2022.04rc4-1            2022.04-1
                  uboot-pinephonepro       4:2022.04rc4-4          4:2022.04-1
                  uboot-soquartz-cm4                    -        2022.01.rc4-1
:: Different sync package(s) in repository core aarch64
                                kmod                 29-2                 29-3
                           libsecret             0.20.5-1             0.20.5-2
                      libsecret-docs             0.20.5-1             0.20.5-2
                                nspr               4.33-1               4.33-2
:: Different overlay package(s) in repository extra aarch64
                   libva-mesa-driver           22.0.1-0.1                    -
                                mesa           22.0.1-0.1                    -
                          mesa-vdpau           22.0.1-0.1                    -
                         opencl-mesa           22.0.1-0.1                    -
                     vulkan-broadcom           22.0.1-0.1                    -
                  vulkan-mesa-layers           22.0.1-0.1                    -
                     vulkan-panfrost           22.0.1-0.1                    -
                       vulkan-radeon           22.0.1-0.1                    -
                       vulkan-swrast           22.0.1-0.1                    -
:: Different sync package(s) in repository extra aarch64
                        archboot-arm            2022.04-5           2022.04-10
                               cairo             1.17.6-1             1.17.6-2
                            chromium      100.0.4896.60-2      100.0.4896.75-1
                          claws-mail              4.0.0-3              4.1.0-1
                        cups-filters            1.28.13-1            1.28.14-1
                               emacs               27.2-2               28.1-1
                              ffmpeg              2:5.0-5              2:5.0-6
                             firefox             98.0.2-1               99.0-1
                    firefox-i18n-ach             98.0.2-1               99.0-1
                     firefox-i18n-af             98.0.2-1               99.0-1
                     firefox-i18n-an             98.0.2-1               99.0-1
                     firefox-i18n-ar             98.0.2-1               99.0-1
                    firefox-i18n-ast             98.0.2-1               99.0-1
                     firefox-i18n-az             98.0.2-1               99.0-1
                     firefox-i18n-be             98.0.2-1               99.0-1
                     firefox-i18n-bg             98.0.2-1               99.0-1
                     firefox-i18n-bn             98.0.2-1               99.0-1
                     firefox-i18n-br             98.0.2-1               99.0-1
                     firefox-i18n-bs             98.0.2-1               99.0-1
                     firefox-i18n-ca             98.0.2-1               99.0-1
            firefox-i18n-ca-valencia             98.0.2-1               99.0-1
                    firefox-i18n-cak             98.0.2-1               99.0-1
                     firefox-i18n-cs             98.0.2-1               99.0-1
                     firefox-i18n-cy             98.0.2-1               99.0-1
                     firefox-i18n-da             98.0.2-1               99.0-1
                     firefox-i18n-de             98.0.2-1               99.0-1
                    firefox-i18n-dsb             98.0.2-1               99.0-1
                     firefox-i18n-el             98.0.2-1               99.0-1
                  firefox-i18n-en-ca             98.0.2-1               99.0-1
                  firefox-i18n-en-gb             98.0.2-1               99.0-1
                  firefox-i18n-en-us             98.0.2-1               99.0-1
                     firefox-i18n-eo             98.0.2-1               99.0-1
                  firefox-i18n-es-ar             98.0.2-1               99.0-1
                  firefox-i18n-es-cl             98.0.2-1               99.0-1
                  firefox-i18n-es-es             98.0.2-1               99.0-1
                  firefox-i18n-es-mx             98.0.2-1               99.0-1
                     firefox-i18n-et             98.0.2-1               99.0-1
                     firefox-i18n-eu             98.0.2-1               99.0-1
                     firefox-i18n-fa             98.0.2-1               99.0-1
                     firefox-i18n-ff             98.0.2-1               99.0-1
                     firefox-i18n-fi             98.0.2-1               99.0-1
                     firefox-i18n-fr             98.0.2-1               99.0-1
                  firefox-i18n-fy-nl             98.0.2-1               99.0-1
                  firefox-i18n-ga-ie             98.0.2-1               99.0-1
                     firefox-i18n-gd             98.0.2-1               99.0-1
                     firefox-i18n-gl             98.0.2-1               99.0-1
                     firefox-i18n-gn             98.0.2-1               99.0-1
                  firefox-i18n-gu-in             98.0.2-1               99.0-1
                     firefox-i18n-he             98.0.2-1               99.0-1
                  firefox-i18n-hi-in             98.0.2-1               99.0-1
                     firefox-i18n-hr             98.0.2-1               99.0-1
                    firefox-i18n-hsb             98.0.2-1               99.0-1
                     firefox-i18n-hu             98.0.2-1               99.0-1
                  firefox-i18n-hy-am             98.0.2-1               99.0-1
                     firefox-i18n-ia             98.0.2-1               99.0-1
                     firefox-i18n-id             98.0.2-1               99.0-1
                     firefox-i18n-is             98.0.2-1               99.0-1
                     firefox-i18n-it             98.0.2-1               99.0-1
                     firefox-i18n-ja             98.0.2-1               99.0-1
                     firefox-i18n-ka             98.0.2-1               99.0-1
                    firefox-i18n-kab             98.0.2-1               99.0-1
                     firefox-i18n-kk             98.0.2-1               99.0-1
                     firefox-i18n-km             98.0.2-1               99.0-1
                     firefox-i18n-kn             98.0.2-1               99.0-1
                     firefox-i18n-ko             98.0.2-1               99.0-1
                    firefox-i18n-lij             98.0.2-1               99.0-1
                     firefox-i18n-lt             98.0.2-1               99.0-1
                     firefox-i18n-lv             98.0.2-1               99.0-1
                     firefox-i18n-mk             98.0.2-1               99.0-1
                     firefox-i18n-mr             98.0.2-1               99.0-1
                     firefox-i18n-ms             98.0.2-1               99.0-1
                     firefox-i18n-my             98.0.2-1               99.0-1
                  firefox-i18n-nb-no             98.0.2-1               99.0-1
                  firefox-i18n-ne-np             98.0.2-1               99.0-1
                     firefox-i18n-nl             98.0.2-1               99.0-1
                  firefox-i18n-nn-no             98.0.2-1               99.0-1
                     firefox-i18n-oc             98.0.2-1               99.0-1
                  firefox-i18n-pa-in             98.0.2-1               99.0-1
                     firefox-i18n-pl             98.0.2-1               99.0-1
                  firefox-i18n-pt-br             98.0.2-1               99.0-1
                  firefox-i18n-pt-pt             98.0.2-1               99.0-1
                     firefox-i18n-rm             98.0.2-1               99.0-1
                     firefox-i18n-ro             98.0.2-1               99.0-1
                     firefox-i18n-ru             98.0.2-1               99.0-1
                     firefox-i18n-si             98.0.2-1               99.0-1
                     firefox-i18n-sk             98.0.2-1               99.0-1
                     firefox-i18n-sl             98.0.2-1               99.0-1
                    firefox-i18n-son             98.0.2-1               99.0-1
                     firefox-i18n-sq             98.0.2-1               99.0-1
                     firefox-i18n-sr             98.0.2-1               99.0-1
                  firefox-i18n-sv-se             98.0.2-1               99.0-1
                     firefox-i18n-ta             98.0.2-1               99.0-1
                     firefox-i18n-te             98.0.2-1               99.0-1
                     firefox-i18n-th             98.0.2-1               99.0-1
                     firefox-i18n-tl             98.0.2-1               99.0-1
                     firefox-i18n-tr             98.0.2-1               99.0-1
                    firefox-i18n-trs             98.0.2-1               99.0-1
                     firefox-i18n-uk             98.0.2-1               99.0-1
                     firefox-i18n-ur             98.0.2-1               99.0-1
                     firefox-i18n-uz             98.0.2-1               99.0-1
                     firefox-i18n-vi             98.0.2-1               99.0-1
                     firefox-i18n-xh             98.0.2-1               99.0-1
                  firefox-i18n-zh-cn             98.0.2-1               99.0-1
                  firefox-i18n-zh-tw             98.0.2-1               99.0-1
                            ghostpcl             9.56.0-1             9.56.1-1
                         ghostscript             9.56.0-1             9.56.1-1
                            ghostxps             9.56.0-1             9.56.1-1
                           gucharmap             14.0.1-1             14.0.3-1
                              hitori             3.38.3-1             3.38.4-1
                                js91             91.7.1-1             91.8.0-1
                              libgee             0.20.5-1             0.20.5-2
                       libnumbertext              1.0.9-1             1.0.10-1
                        libqalculate              4.1.0-1              4.1.1-1
                          libsndfile             1.0.31-1              1.1.0-2
                   libva-mesa-driver           22.0.0-1.1             22.0.1-3
                                mesa           22.0.0-1.1             22.0.1-3
                          mesa-vdpau           22.0.0-1.1             22.0.1-3
          networkmanager-openconnect              1.2.8-1              1.2.8-2
              networkmanager-openvpn             1.8.18-1             1.8.18-2
                 networkmanager-pptp             1.2.10-1             1.2.10-2
                 networkmanager-vpnc              1.2.8-1              1.2.8-2
                         opencl-mesa           22.0.0-1.1             22.0.1-3
                       qalculate-gtk              4.1.0-1              4.1.1-1
                        qalculate-qt              4.1.0-1              4.1.1-1
                       qt5-webengine            5.15.8-10            5.15.8-11
                       qt6-webengine              6.2.4-1              6.2.4-2
                         thunderbird             91.7.0-1             91.8.0-1
                 thunderbird-i18n-af             91.7.0-1             91.8.0-1
                 thunderbird-i18n-ar             91.7.0-1             91.8.0-1
                thunderbird-i18n-ast             91.7.0-1             91.8.0-1
                 thunderbird-i18n-be             91.7.0-1             91.8.0-1
                 thunderbird-i18n-bg             91.7.0-1             91.8.0-1
                 thunderbird-i18n-br             91.7.0-1             91.8.0-1
                 thunderbird-i18n-ca             91.7.0-1             91.8.0-1
                thunderbird-i18n-cak             91.7.0-1             91.8.0-1
                 thunderbird-i18n-cs             91.7.0-1             91.8.0-1
                 thunderbird-i18n-cy             91.7.0-1             91.8.0-1
                 thunderbird-i18n-da             91.7.0-1             91.8.0-1
                 thunderbird-i18n-de             91.7.0-1             91.8.0-1
                thunderbird-i18n-dsb             91.7.0-1             91.8.0-1
                 thunderbird-i18n-el             91.7.0-1             91.8.0-1
              thunderbird-i18n-en-gb             91.7.0-1             91.8.0-1
              thunderbird-i18n-en-us             91.7.0-1             91.8.0-1
              thunderbird-i18n-es-ar             91.7.0-1             91.8.0-1
              thunderbird-i18n-es-es             91.7.0-1             91.8.0-1
                 thunderbird-i18n-et             91.7.0-1             91.8.0-1
                 thunderbird-i18n-eu             91.7.0-1             91.8.0-1
                 thunderbird-i18n-fi             91.7.0-1             91.8.0-1
                 thunderbird-i18n-fr             91.7.0-1             91.8.0-1
              thunderbird-i18n-fy-nl             91.7.0-1             91.8.0-1
              thunderbird-i18n-ga-ie             91.7.0-1             91.8.0-1
                 thunderbird-i18n-gd             91.7.0-1             91.8.0-1
                 thunderbird-i18n-gl             91.7.0-1             91.8.0-1
                 thunderbird-i18n-he             91.7.0-1             91.8.0-1
                 thunderbird-i18n-hr             91.7.0-1             91.8.0-1
                thunderbird-i18n-hsb             91.7.0-1             91.8.0-1
                 thunderbird-i18n-hu             91.7.0-1             91.8.0-1
              thunderbird-i18n-hy-am             91.7.0-1             91.8.0-1
                 thunderbird-i18n-id             91.7.0-1             91.8.0-1
                 thunderbird-i18n-is             91.7.0-1             91.8.0-1
                 thunderbird-i18n-it             91.7.0-1             91.8.0-1
                 thunderbird-i18n-ja             91.7.0-1             91.8.0-1
                 thunderbird-i18n-ka             91.7.0-1             91.8.0-1
                thunderbird-i18n-kab             91.7.0-1             91.8.0-1
                 thunderbird-i18n-kk             91.7.0-1             91.8.0-1
                 thunderbird-i18n-ko             91.7.0-1             91.8.0-1
                 thunderbird-i18n-lt             91.7.0-1             91.8.0-1
                 thunderbird-i18n-ms             91.7.0-1             91.8.0-1
              thunderbird-i18n-nb-no             91.7.0-1             91.8.0-1
                 thunderbird-i18n-nl             91.7.0-1             91.8.0-1
              thunderbird-i18n-nn-no             91.7.0-1             91.8.0-1
              thunderbird-i18n-pa-in             91.7.0-1             91.8.0-1
                 thunderbird-i18n-pl             91.7.0-1             91.8.0-1
              thunderbird-i18n-pt-br             91.7.0-1             91.8.0-1
              thunderbird-i18n-pt-pt             91.7.0-1             91.8.0-1
                 thunderbird-i18n-rm             91.7.0-1             91.8.0-1
                 thunderbird-i18n-ro             91.7.0-1             91.8.0-1
                 thunderbird-i18n-ru             91.7.0-1             91.8.0-1
                 thunderbird-i18n-sk             91.7.0-1             91.8.0-1
                 thunderbird-i18n-sl             91.7.0-1             91.8.0-1
                 thunderbird-i18n-sq             91.7.0-1             91.8.0-1
                 thunderbird-i18n-sr             91.7.0-1             91.8.0-1
              thunderbird-i18n-sv-se             91.7.0-1             91.8.0-1
                 thunderbird-i18n-th             91.7.0-1             91.8.0-1
                 thunderbird-i18n-tr             91.7.0-1             91.8.0-1
                 thunderbird-i18n-uk             91.7.0-1             91.8.0-1
                 thunderbird-i18n-uz             91.7.0-1             91.8.0-1
                 thunderbird-i18n-vi             91.7.0-1             91.8.0-1
              thunderbird-i18n-zh-cn             91.7.0-1             91.8.0-1
              thunderbird-i18n-zh-tw             91.7.0-1             91.8.0-1
                     vulkan-broadcom           22.0.0-1.1             22.0.1-3
                      vulkan-headers          1:1.3.208-1          1:1.3.211-1
                    vulkan-html-docs          1:1.3.208-1          1:1.3.211-1
                  vulkan-mesa-layers           22.0.0-1.1             22.0.1-3
                     vulkan-panfrost           22.0.0-1.1             22.0.1-3
                       vulkan-radeon           22.0.0-1.1             22.0.1-3
                       vulkan-swrast           22.0.0-1.1             22.0.1-3
                    xf86-video-dummy              0.3.8-5              0.4.0-1
                   xfce4-eyes-plugin              4.5.1-1              4.6.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.12.2.r12715.gb764a86d5-121.12.2.r12716.gd6c994fb1-1
                    akonadi-calendar21.12.2.1.r2058.g2173f6a-121.12.2.1.r2063.gfb7c24d-1
                    akonadi-contacts21.12.2.r3163.g04799464-121.12.2.r3164.g9f54148d-1
                           akregator21.12.2.r6360.g4993640d-121.12.2.r6363.g8f4d201f-1
                           angelfish 22.02.r14.ga13407b-1 22.02.r16.g0546104-1
                              attica5.92.0.r860.gdde032d-15.92.0.r862.gc6b7f2b-1
                         audiocd-kio21.12.2.1.r1054.g4a451af-121.12.2.1.r1055.g2fac6d9-1
                               baloo5.92.0.r3043.g1eed0fcb-15.92.0.r3044.g7a2ac836-1
                            bluez-qt5.92.0.r707.g7fa6265-15.92.0.r708.g0ab9192-1
                              breeze5.24.4.r2377.g0f97c23b-15.24.4.r2379.g94d75fa1-1
                        breeze-icons5.92.0.r1890.gff66b122-15.92.0.r1893.g327feb5a-1
                            discover5.24.4.r8613.g4907ad07-15.24.4.r8620.g3901c96d-1
                             dolphin21.12.2.1.r6898.g0c38a27cc-121.12.2.1.r6905.g989d19c12-1
                             drkonqi5.24.4.r753.gfcca1043-15.24.4.r754.gf8cf3b1e-1
                               elisa21.12.2.1.r2911.g01177f52-121.12.2.1.r2935.gd6b1e2e1-1
                          elisa-qtmm21.12.2.1.r2911.g01177f52-121.12.2.1.r2935.gd6b1e2e1-1
                           filelight21.12.2.r1075.g182c6df-121.12.2.r1079.g8d7aee6-1
                frameworkintegration5.92.0.r629.g7e3cf1b-15.92.0.r630.ge6f07e0-1
                           granatier21.12.2.1.r967.g4356e9e-121.12.2.1.r971.gaff58a3-1
                            gwenview21.12.2.1.r6824.g888dcb7e-121.12.2.1.r6833.ga79ee0e8-1
                     incidenceeditor21.12.2.1.r856.g2a424be-121.12.2.1.r869.g5407359-1
                           itinerary21.12.2.1.r1762.g3c2c64b-121.12.2.1.r1763.gbaca503-1
                                 juk21.12.2.1.r3138.g8086d808-121.12.2.1.r3139.gc36f4420-1
                                 k3b1:21.12.2.1.r6722.gd42ac36f1-11:21.12.2.1.r6725.gdb3d8d408-1
               kaccounts-integration21.12.2.r1251.gd38b71b-121.12.2.r1252.g7ac2983-1
                         kactivities5.92.0.r1390.geec00c0-15.92.0.r1391.g8ec7442-1
                   kactivities-stats5.92.0.r399.gd4ab11f-15.92.0.r400.g61c0328-1
                        kaddressbook21.12.2.1.r6134.g091e3e2e-121.12.2.1.r6136.gf4f0986d-1
                              kalarm21.12.2.1.r7847.gb6494e89-121.12.2.1.r7848.gcaf73623-1
                              kamoso21.12.2.1.r1453.gd16108f-121.12.2.1.r1455.gd39a7ec-1
                            karchive5.92.0.r535.g9e0700c-15.92.0.r537.g0eb4584-1
                               kasts 22.02.r13.g893c647-1 22.02.r15.ge5a3408-1
                                kate21.12.2.1.r18894.g9f8dcc2b7-121.12.2.1.r18915.g9036a5d86-1
                               kauth5.92.0.r494.g68562de-15.92.0.r496.g6169cf0-1
                          kbookmarks5.92.0.r455.gf3bbcc3-15.92.0.r457.g47b7927-1
                       kcalendarcore5.92.0.r1310.g384d2a14c-15.92.0.r1312.g88650d497-1
                         kcharselect21.12.2.r510.gaa55ede-121.12.2.r517.gedea8a6-1
                            kcmutils5.92.0.r610.g8c61a2e-15.92.0.r611.g71b389d-1
                             kcodecs5.92.0.r415.g60bc042-15.92.0.r416.g190d755-1
                       kcolorchooser21.12.2.1.r257.gd5bcd55-121.12.2.1.r262.g0282cd0-1
                         kcompletion5.92.0.r489.g6668477-15.92.0.r490.g5cb3b5a-1
                             kconfig5.92.0.r946.g66c8a3b8-15.92.0.r948.g288cbe4a-1
                      kconfigwidgets5.92.0.r710.geb8dabb-15.92.0.r718.g8060bdb-1
                           kcontacts1:5.92.0.r3318.g5eebf0d8-11:5.92.0.r3322.g3627d11b-1
                         kcoreaddons5.92.0.r1450.g55053dec-15.92.0.r1460.g45a2e5cf-1
                              kcrash5.92.0.r439.ga89f0b5-15.92.0.r440.ge705853-1
                                kdav1:5.92.0.r1337.g26321bf-11:5.92.0.r1338.ge45bcdb-1
                         kdbusaddons5.92.0.r409.g201c1fc-15.92.0.r410.g8ce9670-1
                       kde-cli-tools5.24.4.r1920.g63df213-15.24.4.r1922.gfe0367b-1
                       kde-dev-utils21.12.2.1.r575.g1bb3f9b-121.12.2.1.r577.g31d8362-1
                        kdeclarative5.92.0.r986.gc3b8430-15.92.0.r987.gfb55876-1
                          kdeconnect21.12.2.1.r3420.g872e2130-121.12.2.1.r3422.g43960f3e-1
                                kded5.92.0.r455.g530695b-15.92.0.r456.g70ad9d2-1
                     kdelibs4support5.92.0.r1078.g29af2d66-15.92.0.r1079.g24ea8da1-1
              kdenetwork-filesharing21.12.2.1.r920.g0a3f474-121.12.2.1.r922.gb43d4ae-1
                            kdenlive21.12.1.r15925.gf9da836d1-121.12.1.r15945.g3594e8a2a-1
                       kdepim-addons21.12.2.r4604.gbddd0a37-121.12.2.r4612.gc2ee10fe-1
                      kdepim-runtime21.12.2.r15477.g6682edb52-121.12.2.r15485.g766486a64-1
                    kdeplasma-addons5.24.4.r8707.g697943a00-15.24.4.r8710.g5f02e49f0-1
                     kdesignerplugin5.92.0.r350.g4e32de7-15.92.0.r351.g0344e85-1
                               kdesu5.92.0.r503.g82d1460-15.92.0.r504.g8e8af0c-1
                           kdewebkit5.92.0.r297.gb19e3d7-15.92.0.r298.g11363e5-1
                              kdnssd5.92.0.r345.g0325d14-15.92.0.r346.g1072cb0-1
                           kdoctools5.92.0.r654.gf81bb14-15.92.0.r656.gb992dc9-1
                          kemoticons5.92.0.r407.g3bc35df-15.92.0.r408.g874bb3d-1
                            keysmith  22.02.r5.g20314d3-1  22.02.r7.g506234c-1
                       kfilemetadata5.92.0.r853.g02a23ab-15.92.0.r857.g562eaa4-1
                               kfind21.12.2.1.r2676.g53eb27138-121.12.2.1.r2677.g818f75714-1
                         kfourinline21.12.2.1.r1016.gf82e16c-121.12.2.1.r1017.gda3fc3d-1
                          kgeography21.12.2.1.r1141.g3192844-121.12.2.1.r1142.g7a07b72-1
                                kget21.12.2.1.r3167.gd817abb3-121.12.2.1.r3174.g8a33ddb3-1
                        kglobalaccel5.92.0.r507.g69e337c-15.92.0.r508.ge4a33e5-1
                          kguiaddons5.92.0.r452.g7f8dcbb-15.92.0.r455.g136a7a3-1
                           kholidays1:5.92.0.r1000.g6d895d7-11:5.92.0.r1001.g911c6b0-1
                               khtml5.92.0.r577.ga58f402-15.92.0.r578.gec65222-1
                               ki18n5.92.0.r547.g525826a-15.92.0.r551.g2787adc-1
                         kiconthemes5.92.0.r593.g74a6d4c-15.92.0.r594.g5c0053a-1
                           kidletime5.92.0.r351.gcd50406-15.92.0.r352.gc030e0f-1
                                kigo21.12.2.r554.g58de38c-121.12.2.r558.gd3d6e41-1
                       kimageformats5.92.0.r387.g3e751dd-15.92.0.r389.g98f19c6-1
                         kinfocenter5.24.4.r2053.gfde4c18-15.24.4.r2058.g3f626c1-1
                               kinit5.92.0.r432.ga3aa283-15.92.0.r433.g83f67a1-1
                                 kio5.92.0.r5382.g872f8ea2f-15.92.0.r5395.g3841e741b-1
                     kirigami-addons 1:0.2.r25.g126a186-1 1:0.2.r26.g03cbae6-1
                           kirigami25.92.0.r3102.g83a27204-15.92.0.r3105.g260f3343-1
                         kitemmodels5.92.0.r598.g6395874-15.92.0.r600.g2c1d8fd-1
                          kitemviews5.92.0.r366.g1c15548-15.92.0.r367.g216967b-1
                          kitinerary21.12.2.1.r2133.g1a0b660-121.12.2.1.r2135.g6093673-1
                         kjobwidgets5.92.0.r408.g706f536-15.92.0.r411.gaa97b08-1
                                 kjs5.92.0.r357.gf7885ff-15.92.0.r358.gf6a0701-1
                            kjsembed5.92.0.r321.gc43332b-15.92.0.r322.gf0b7a01-1
                           kleopatra21.12.2.1.r6320.g285677f0-121.12.2.1.r6324.g7aae07cb-1
                               kmail21.12.2.r26316.g4232d588a-121.12.2.r26320.g5ee59d106-1
                        kmediaplayer5.92.0.r313.g79c1c65-15.92.0.r314.gce7adac-1
                           kmenuedit5.24.4.r1027.gf5d2457-15.24.4.r1029.gaffeb14-1
                                kmix21.12.2.1.r2427.g582f076e-121.12.2.1.r2433.g67acca5d-1
                           knewstuff5.92.0.r1312.g4afdaac2-15.92.0.r1319.g0a523693-1
                              knotes21.12.2.r3616.g991a5dfd-121.12.2.r3625.g16adaf15-1
                      knotifications5.92.0.r725.g403b5d7-15.92.0.r726.gf58cab5-1
                       knotifyconfig5.92.0.r377.g2379d3a-15.92.0.r378.g5d38bda-1
                             kompare21.12.2.1.r1127.gbdfed31-121.12.2.1.r1131.g50a8d3d-1
                           konqueror21.12.2.r15063.gc4238fd7b-121.12.2.r15091.g6d55c26d3-1
                             konsole21.12.2.r8324.g100199e3-121.12.2.r8326.g0653603b-1
                             kontact21.12.2.1.r5497.g78da9f4a-121.12.2.1.r5498.gaec105c4-1
                       kopeninghours21.12.2.1.r322.gd3439b6-121.12.2.1.r323.gb266e34-1
                          korganizer21.12.2.r11662.gbbf857f49-121.12.2.r11666.g23116fa65-1
                            kpackage5.92.0.r742.g0c3503c-15.92.0.r743.gddddb8b-1
                              kparts5.92.0.r578.g5792035-15.92.0.r579.gcbc2f5b-1
                             kpeople5.92.0.r1368.g63c76ec-15.92.0.r1370.g1379d3a-1
                           kplotting5.92.0.r317.g2cfe75b-15.92.0.r318.g5cf7e5d-1
                                kpty5.92.0.r368.g71d8e44-15.92.0.r369.gc8945f1-1
                    kpublictransport21.12.1.r1986.gca05823d-121.12.1.r1987.gf7f93ea3-1
                        kquickcharts5.92.0.r511.g6214f29-15.92.0.r512.gb4b8f8b-1
                   kquickimageeditor       r67.g14c01c4-1       r68.g61f48f8-1
                               kross5.92.0.r353.gae6b3f3-15.92.0.r354.g4150d02-1
                             krunner5.92.0.r741.g2fb490f-15.92.0.r742.gef1e99d-1
                             kscreen5.24.4.r1443.g476e44e-15.24.4.r1444.g275cdc0-1
                       kscreenlocker5.24.4.r917.ga90a9a9-15.24.4.r921.g59052e7-1
                            kservice5.92.0.r997.g111ca51-15.92.0.r1003.gd55a8c2-1
                            kteatime21.12.2.1.r743.gfacb915-121.12.2.1.r747.gf4d9f73-1
                         ktexteditor5.92.0.r3308.g7bd83826-15.92.0.r3315.g66d92ec7-1
                        ktextwidgets5.92.0.r441.g9386521-15.92.0.r442.gf01ea31-1
                              ktimer21.12.2.1.r505.ge57b6a0-121.12.2.1.r506.g18fb181-1
                            ktorrent21.12.2.r2832.gde64efd7-121.12.2.r2833.ge6a6d63d-1
                               ktrip  22.02.r4.g652977e-1  22.02.r7.g0ca5308-1
                             kubrick21.12.2.1.r395.gcd3a40c-121.12.2.1.r397.gb0c7b8a-1
                     kunitconversion5.92.0.r408.gcb09b05-15.92.0.r409.gd10e313-1
                             kwallet5.92.0.r1137.gf192163-15.92.0.r1138.gd396695-1
                            kwayland5.92.0.r1150.g0181767-15.92.0.r1151.g15af039-1
                kwayland-integration5.24.4.r199.gb05afab-15.24.4.r200.g2ac5b52-1
                            kweather 22.02.r13.gac5a112-1 22.02.r14.gc3ab3c5-1
                        kweathercore    0.5.r5.g4305095-1    0.5.r7.g49175a5-1
                      kwidgetsaddons5.92.0.r920.ga7853cf2-15.92.0.r922.gbc47af59-1
                                kwin5.24.4.r21014.gcba443dbe-15.24.4.r21020.g9de79c62c-1
                       kwindowsystem5.92.0.r670.gc8b03a4-15.92.0.r671.gcb7f9b1-1
                              kwrite21.12.2.1.r18894.g9f8dcc2b7-121.12.2.1.r18915.g9036a5d86-1
                             kxmlgui5.92.0.r861.g24450bb5-15.92.0.r867.g5f989947-1
                       kxmlrpcclient5.92.0.r476.gc2ca2c045-15.92.0.r477.gbbdab17df-1
                          libakonadi21.12.2.r12715.gb764a86d5-121.12.2.r12716.gd6c994fb1-1
                         libkdegames21.12.2.1.r2229.gafd6857e-121.12.2.1.r2230.gd036c9c3-1
                           libksieve21.12.2.1.r1685.g94b52a9c-121.12.2.1.r1690.g9ab37cf7-1
                          mailcommon21.12.2.1.r1213.g05b9671-121.12.2.1.r1221.g1e0ac5a-1
                    maliit-framework 2.2.0.r2.gc9ea3457-1 2.2.1.r0.gad906cad-1
                              marble21.12.2.1.r13408.gb5075f323-121.12.2.1.r13410.gdabb47d5d-1
                       marble-common21.12.2.1.r13408.gb5075f323-121.12.2.1.r13410.gdabb47d5d-1
                           marble-qt21.12.2.1.r13408.gb5075f323-121.12.2.1.r13410.gdabb47d5d-1
                           maui-nota 2.1.1.r14.g752ebb0-1 2.1.1.r15.g545749a-1
                            maui-pix 2.1.0.r14.g5c5fc16-1 2.1.0.r15.g83cefe5-1
                             mauikit2.1.1.r13.g44cabb15-12.1.1.r14.g795f1150-1
                          messagelib21.12.1.r6463.g12b2699e1-121.12.1.r6472.gfd22bc629-1
                              minuet21.12.2.1.r599.g3b07c01-121.12.2.1.r601.gf211186-1
                     modemmanager-qt5.92.0.r550.g2110a7b-15.92.0.r551.g0222a64-1
                             neochat22.02.r36.g1cc8d915-122.02.r40.g024fb1a9-1
                   networkmanager-qt5.92.0.r1148.gf3abb2e-15.92.0.r1149.g9ab40c0-1
                              okular21.12.2.1.r9687.g8c31962e8-121.12.2.1.r9690.g8aa96484d-1
                            palapeli21.12.2.1.r1266.g3509076-121.12.2.1.r1268.g8139e79-1
                              parley21.12.2.r4509.g18d28283-121.12.2.r4510.gc4fa03ea-1
                    pim-sieve-editor21.12.2.r1606.g42195a9-121.12.2.r1611.gae3f691-1
                    plasma-bigscreen      r457.g6503645-1      r459.g811b78b-1
                      plasma-desktop5.24.4.r9166.g7a94a8239-15.24.4.r9185.g9b0d1e442-1
                    plasma-framework5.92.0.r16226.gd74a8286e-15.92.0.r16240.gfe079da99-1
                  plasma-integration5.24.4.r557.g2b406a9-15.24.4.r558.g8a36a5b-1
                       plasma-mobile5.24.4.r1689.g7e53aab27-15.24.4.r1691.g03f3411c9-1
                    plasma-mobile-nm5.24.4.r3228.gaee1498f-15.24.4.r3231.g54bd6d62-1
                           plasma-nm5.24.4.r3228.gaee1498f-15.24.4.r3231.g54bd6d62-1
                           plasma-pa5.24.4.r1037.g5c8f126-15.24.4.r1039.gb7bd02b-1
              plasma-wayland-session5.24.4.r11612.g4eb900ae6-15.24.4.r11623.g16ae8b9e6-1
                    plasma-workspace5.24.4.r11612.g4eb900ae6-15.24.4.r11623.g16ae8b9e6-1
                          plasmatube  22.02.r9.gaafb938-1 22.02.r11.ga2aa32b-1
                              prison5.92.0.r364.g2279598-15.92.0.r366.g0d48f0b-1
                             purpose5.92.0.r957.gc4beb3d8-15.92.0.r959.g51725bef-1
                  qqc2-desktop-style5.92.0.r590.g60d5852-15.92.0.r595.g210a614-1
                                rocs21.12.2.1.r3068.g727c9976-121.12.2.1.r3070.gc0785a1f-1
            signon-kwallet-extension21.12.2.1.r75.g46af618-121.12.2.1.r79.g87b0c1e-1
                               solid5.92.0.r762.g6b0ae19-15.92.0.r763.g3628f56-1
                              sonnet5.92.0.r684.g32a6f74-15.92.0.r685.g9f7baaf-1
                         syndication5.92.0.r867.g0baa14c-15.92.0.r868.g1520abd-1
                 syntax-highlighting5.92.0.r1820.gb5075e6c-15.92.0.r1823.g9e4bda8f-1
                      systemsettings5.24.4.r2639.geaa5505f-15.24.4.r2640.ge2b85abe-1
                        threadweaver5.92.0.r535.g46253ab-15.92.0.r536.g6b31874-1
                             tokodon  22.02.r5.g12bfe2e-1 22.02.r13.g0932587-1
                            umbrello21.12.2.r8433.g41a11789e-121.12.2.r8437.g55a1e56fd-1
                               vvave  2.1.1.r6.g10507dc-1  2.1.1.r7.geaa3902-1
              xdg-desktop-portal-kde5.24.4.r446.g9cad776-15.24.4.r448.g9d217b4-1
                             yakuake21.12.2.1.r778.g9fe5ff2-121.12.2.1.r779.g89fcbe7-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Old Issues
Plasma Dialer cannot answer calls
Sadly Plasma Dialer 22.02 has a serious regression with no known workaround. It’s not possible to accept incoming calls. Very sorry about this. Follow the upstream bug report. We will patch the package as soon as a solution is found.
Plasma Mobile - Black screen after update
We are seeing some reports about Plasma Mobile on the PinePhone only showing a black screen after entering the PIN after this update.
Workaround: Downgrade qt5-es2-wayland to 5.15.2+kde+r41 which is now back in Stable and Testing branch repositories.
New Breath theme not applying correctly
With the update to the new Breath theme, a migration package tries to apply the new theme correctly.
However this is not getting done for Plasma’s Lockscreen and the SDDM theme.
So please go through your settings after updating to make sure the themes are correctly applied.
Fix: manjaro-system should take care of this for you.
Plasma Mobile switch to ModemManager
With the PlaMo Gear 21.12 release, Plasma Mobile is now using ModemManager as the telephony stack. So in order to use SIM capabilities, you need to switch from using oFono to ModemManager.
Fix: Run sudo systemctl disable --now ofono ofonoctl && sudo systemctl enable --now ModemManager. You might have to reboot your phone for Plasma Mobile to pick up this change.
Plasma Mobile has does not launch after update
This was caused by an error in kwin 5.23.2 which only affects installs based on openGLES (qt5-es2).
Fix: Update to kwin 5.23.2-1.2 or above.
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Fixed. Thanks.
Is The Odroid M1 a future Manjaro arm device ?
An arm device with a native sata slot, m2 ssd slot, emmc slot, micro sd slot…
Odroid M1 Hands-On First Look! An All-New ARM Based Single Board Computer - YouTube
We hope so. :wink:
Hello, wayland seems to work better and better with Kde. The display of waydroid is always buggy, the installation of chromium-docker never ends in pacman manager. tested on ugoos am6b+
You do know that the installation is downloading the entire Chrome-OS to extract Widevine, right? So depending on your internet speed, that can take a long time.
even while waiting half an hour I never managed to go further than that:
Hello,
finally i managed to install it via sudo pacman -S chromium-docker but when I want to start it I get this error message :
Set host IP for Pulseaudio /usr/local/bin/chromium-armhf: ligne 4: hostname : commande introuvable Enabling XHost Forwarding non-network local connections being added to access control list Searching for Docker image ... Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/images/json?filters=%7B%22reference%22%3A%7B%22hthiemann%2Fchromium-armhf%3Alatest%22%3Atrue%7D%7D": dial unix /var/run/docker.sock: connect: permission denied Found and using /usr/local/bin/chromium-armhf: ligne 13: pax11publish : commande introuvable "docker run" requires at least 1 argument. See docker run --help. Usage: docker run [OPTIONS] IMAGE [COMMAND] [ARG...] Run a command in a new container
do you have an idea to solve
this problem ?
permission denied error means the user was not added to the group correctly.
run
sudo chromium-armhf and it should work.
