[ARM Testing Update] 2022-04-04 - Electron, LibreOffice, Mesa and kernels
Hello ARM community.
Slowly getting ready for the next release.
Some highlights:
  • Most of our kernels got updated
  • Electron updated to 18.0
  • And LibreOffice updated to 7.3.2
  • Mesa updated to 22.0.1
  • And Plasma updated to 5.24.4
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Mon Apr 4 22:52:41 CEST 2022)
  • arm-testing community aarch64: 297 new and 330 removed package(s)
  • arm-testing core aarch64: 36 new and 37 removed package(s)
  • arm-testing extra aarch64: 334 new and 370 removed package(s)
  • arm-testing kde-unstable aarch64: 310 new and 310 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2022-03-28         2022-04-04
                                code             1.65.2-1             1.66.0-1
                            electron             17.2.0-1             18.0.0-1
                          electron15             15.4.2-1             15.5.0-1
                          electron16             16.1.1-1             16.2.0-1
                     element-desktop             1.10.8-1             1.10.8-2
                         element-web             1.10.8-1             1.10.8-2
                 gnome-authenticator             3.32.2-14.0.3.r105.g9351815-1
                          obs-studio             27.2.3-1             27.2.4-1
                                phoc  0.13.0+1+gb0ae098-1  0.13.1+1+g8b17c27-1
                               phosh  0.17.0+1+g1c6d6cf-10.17.0+58+gfdf28e4f-1
                          electron17                    -             17.3.0-1
:: Different sync package(s) in repository community aarch64
                               abcde              2.9.3-5                    -
                              acpica           20211217-1           20220331-1
                              adios2              2.7.1-4              2.8.0-1
                         advancecomp                2.1-3                    -
                              anjuta             3.34.0-8                    -
                       anjuta-extras 3.26.0+13+g8248f12-2                    -
                        ansible-core             2.12.3-1             2.12.4-1
                        ansible-lint              6.0.2-3              6.0.2-4
                          apache-orc              1.7.1-2              1.7.3-1
                                 apm              2.6.4-3              2.6.5-2
                              argocd              2.3.2-1              2.3.3-1
                          asoundconf              1:1.2-7                    -
                             aws-cli            1.22.74-1            1.22.87-1
                              awxkit             20.0.1-1             20.1.0-1
                              bcprov               1.70-1               1.71-1
                             blender           17:3.1.0-2           17:3.1.2-1
                               broot              1.9.4-1             1.10.0-1
                             buildah             1.24.2-1             1.25.1-1
                             calibre             5.39.1-1             5.40.0-1
                          cargo-edit              0.8.0-5              0.9.0-1
                           cargo-pgx              0.4.1-1              0.4.2-1
                    cargo-spellcheck             0.11.0-1             0.11.2-1
                           cd-discid                1.4-3                    -
                             certbot             1.25.0-1             1.25.0-2
                      certbot-apache             1.25.0-1             1.25.0-2
                       certbot-nginx             1.25.0-1             1.25.0-2
                               charm             0.10.3-1             0.11.0-1
                               cli11              2.1.2-1              2.2.0-1
                             clojure        1.10.3.1093-1        1.11.0.1100-1
                             cockpit                265-1                266-1
                    cockpit-machines                264-1                265-1
                         cockpit-pcp                265-1                266-1
                      cockpit-podman                 44-1                 45-1
                           cocogitto              5.0.0-1              5.0.1-1
                            conflict           20150705-5                    -
                                dart             2.16.1-1             2.16.2-1
                           dart-sass             1.49.9-1            1.49.11-1
          deepin-qt5platform-plugins             5.0.46-3             5.0.59-1
                          diffoscope                208-1                209-1
                      docker-compose              2.3.4-1              2.4.0-1
                               doctl             1.71.1-1             1.73.0-1
                               drone             2.11.0-1             2.11.1-1
                           drone-oss             2.11.0-1             2.11.1-1
                           dtkcommon             5.5.20-1             5.5.21-1
                      efm-langserver             0.0.40-1                    -
                              erlang             24.3.2-1             24.3.2-2
                          erlang-nox               24.3-1             24.3.2-1
                     erlang-unixodbc             24.3.2-1             24.3.2-2
                           espeak-ng               1.50-5               1.51-1
                    espeak-ng-espeak               1.50-5                    -
                     extremetuxracer              0.8.1-1                    -
                              fabric              2.6.0-3              2.7.0-1
                   faenza-icon-theme              1.3.1-6                    -
                          fanficfare             4.10.0-1                    -
                             fatsort          1.6.3.622-1          1.6.4.625-1
                              faudio              22.03-1              22.04-1
                               fceux              2.6.2-1              2.6.4-1
                            feeluown              3.8.3-1              3.8.4-1
                           findomain              7.0.1-1              7.2.0-1
                                 fio               3.28-2               3.29-1
                   firefox-clearurls             1.22.0-1                    -
  firefox-extension-https-everywhere          2021.7.13-1                    -
     firefox-extension-privacybadger          2021.8.17-1                    -
                      firefox-stylus             1.5.22-1                    -
        firefox-temporary-containers              1.9.2-3                    -
               firefox-ublock-origin             1.41.8-1             1.42.2-1
                                fish              3.3.1-1              3.4.1-1
                               gcovr                5.0-2                5.1-1
                                 ghi 1.2.0.r23.g0bf0e97-2                    -
                          github-cli              2.6.0-1              2.7.0-1
            gnome-appfolders-manager              0.4.2-2              0.4.3-1
                      gnome-firmware               41.0-1               42.0-1
                    gnome-icon-theme             3.12.0-6                    -
                   gnome-search-tool  3.6.0+82+g4a8f34e-2                    -
                         go-ethereum            1.10.16-2            1.10.17-1
                               go-yq             4.23.1-1             4.24.2-1
                            goaccess              1.5.5-1              1.5.6-1
                   golang-deepin-gir              2.0.2-5              2.1.0-1
                               gopls              0.8.1-1              0.8.2-1
                          goreleaser              1.4.1-1              1.7.0-1
        greenbone-security-assistant              9.0.1-1                    -
                              groovy              3.0.9-1              4.0.1-1
                            gvm-libs             10.0.2-2                    -
                          gwakeonlan              0.8.0-1              0.8.1-1
                        herbstluftwm              0.9.3-1              0.9.4-1
                      html-xml-utils                8.3-1                8.4-1
                            htmlhint              1.1.2-1              1.1.3-1
                                hugo             0.95.0-1             0.96.0-1
                               iaito5.5beta0.r16.g24a2eba2-15.5beta0.r16.g24a2eba2-2
                             innotop             1.13.0-1                    -
                             ipython              8.1.1-1              8.2.0-1
                                jake             10.8.3-1             10.8.4-1
                             jenkins              2.340-1              2.341-1
                                jmol           14.32.42-1           14.32.45-1
                               jsmol           14.32.42-1           14.32.45-1
                             jupyter              4.6.3-3                    -
                    jupyter-nbclient             0.5.13-1             0.5.13-2
                   jupyter-nbconvert              6.4.4-1              6.4.5-3
                    jupyter-notebook             6.4.10-2             6.4.10-3
                      jupyter-server             1.15.6-1             1.16.0-1
                                just              1.1.0-1              1.1.1-1
                                  ko             0.10.0-1             0.11.2-1
                           leptonica             1.82.0-1             1.82.0-2
                  level-zero-headers              1.7.9-1             1.7.15-1
                   level-zero-loader              1.7.9-1             1.7.15-1
                           libanjuta             3.34.0-8                    -
                        libfilezilla             0.36.0-1           1:0.36.0-1
                        libmediainfo              21.09-1              22.03-1
                             libsolv             0.7.20-1             0.7.22-1
                             libvirt            1:8.1.0-4            1:8.2.0-3
                      libvirt-python            1:8.1.0-1            1:8.2.0-1
             libvirt-storage-gluster            1:8.1.0-4            1:8.2.0-3
        libvirt-storage-iscsi-direct            1:8.1.0-4            1:8.2.0-3
                             libxmlb              0.3.7-1              0.3.8-1
                             lowdown             0.11.0-1             0.11.2-1
                                 lrs              071.b-1                072-1
                           lttng-ust             2.13.0-5             2.13.2-1
                           lua-expat              1.3.0-5              1.4.1-1
                         lua51-expat              1.3.0-5              1.4.1-1
                         lua52-expat              1.3.0-5              1.4.1-1
                         lua53-expat              1.3.0-5              1.4.1-1
                              luajit2.1.0.beta3.r395.ge2c312e0-12.1.0.beta3.r397.g20aea939-1
                                mame              0.241-1              0.242-1
                          mame-tools              0.241-1              0.242-1
                      matrix-synapse             1.54.0-1             1.55.2-1
                          maxima-ecl             5.44.0-3                    -
                              mcomix         1.3.0.dev0-6                    -
                              mdbook             0.4.15-1             0.4.17-1
                           mediaelch             2.8.14-1             2.8.16-1
                       mediainfo-gui              21.09-1              22.03-1
                               mgard              0.1.0-2              1.0.0-1
                           miniserve             0.19.3-1             0.19.4-1
                           miniupnpc              2.2.2-2              2.2.3-1
                               mmctl              6.4.2-1              6.5.0-1
                           mtd-utils              2.1.3-1              2.1.4-1
                               nedit              1:5.7-4                    -
                             nemiver              0.9.6-9                    -
             nextcloud-app-bookmarks           1:10.1.0-1           1:10.2.1-1
                   npm-check-updates             12.5.4-1             12.5.7-1
                              nuitka              0.7.5-1              0.7.6-1
                            onefetch             2.11.0-2             2.12.0-1
                          onionshare                2.5-1                2.5-2
                     openssh-askpass              2.1.0-3                    -
                     pantheon-camera              1.0.6-1              6.0.3-2
                           partclone             0.3.18-1             0.3.19-1
                             pcurses                  5-5                    -
                               pdftk              3.3.2-1              3.3.2-2
                      perl-alien-sdl             1.446-12                    -
            perl-file-find-rule-perl               1.15-4               1.16-1
                 perl-ppix-quotelike              0.020-1              0.021-1
                    perl-ppix-regexp              0.083-1              0.084-1
              perl-proc-processtable               0.62-1              0.634-1
                            perl-sdl              2.548-6                    -
                             pgpdump               0.34-1               0.35-1
                                poke                2.1-2                2.3-1
                            prettier              2.6.1-1              2.6.2-1
                 promscale_extension              0.3.1-1              0.3.2-1
                               pueue              2.0.1-1              2.0.2-1
                              pulumi             3.26.1-1             3.28.0-1
                           py3status               3.42-1               3.43-1
                            pybind11              2.9.1-1              2.9.2-1
                             pyright            1.1.232-1            1.1.234-1
                     python-autobahn             22.3.1-1             22.3.2-1
                     python-bcj-cffi              0.5.1-3                    -
                       python-bidict             0.21.4-1             0.22.0-1
                        python-black             22.1.0-2             22.3.0-1
                        python-boto3            1.21.19-1            1.21.32-1
                     python-botocore            1.24.19-1            1.24.32-1
                    python-braintree             4.14.0-1             4.15.2-1
                        python-click              8.0.4-1              8.1.2-1
                 python-cloudscraper             1.2.60-1                    -
                         python-cppy              1.2.0-1              1.2.1-1
                python-cssbeautifier             1.14.0-3             1.14.2-1
            python-database-knotinfo           2022.3.1-1           2022.4.1-1
                        python-faker              9.0.0-1              9.0.1-1
          python-flake8-blind-except              0.2.0-2                    -
              python-flake8-debugger              4.0.0-2                    -
                        python-flask              2.0.3-1              2.1.1-1
               python-flask-compress             1.10.1-1               1.11-1
                  python-flask-login              0.5.0-5              0.6.0-1
                     python-flatdict              4.0.1-3                    -
                python-funcparserlib              0.3.6-7            1.0.0a0-1
                       python-gitlab              3.2.0-1              3.3.0-1
                  python-hstspreload          2021.11.1-2                    -
                    python-ipykernel              6.9.2-2             6.11.0-2
                  python-ipyparallel              8.2.0-2              8.2.1-1
                 python-itsdangerous              2.1.0-1              2.1.2-2
                 python-jsbeautifier             1.14.0-3             1.14.2-1
               python-jupyter_client              7.1.2-1              7.2.1-1
            python-jupyter_packaging             0.12.0-2             0.12.0-3
            python-jupyterlab_server             2.11.2-1             2.12.0-1
                   python-kubernetes             22.6.0-1             23.3.0-1
                    python-lsp-black              1.1.0-1              1.2.0-1
                   python-lsp-server              1.4.0-1              1.4.1-1
                     python-lttngust             2.13.0-5             2.13.2-1
                         python-milc              1.6.5-3              1.6.6-1
                    python-miniupnpc              2.2.2-2              2.2.3-1
                 python-nest-asyncio              1.5.4-2              1.5.5-1
                     python-oscrypto              1.3.0-2              1.3.0-3
                       python-pandas              1.4.1-1              1.4.2-1
                        python-param             1.12.0-3             1.12.1-1
                        python-pcapy              1.0.4-2              1.0.5-1
                 python-phonenumbers            8.12.45-1            8.12.46-1
                      python-pikepdf              5.1.0-1              5.1.1-1
                       python-pillow              9.0.1-1              9.1.0-1
                    python-pip-shims              0.6.0-1              0.7.0-1
                       python-pipenv          2022.3.24-1          2022.3.28-1
                    python-ppmd-cffi              0.5.0-2                    -
                   python-pre-commit             2.17.0-1             2.18.1-1
                         python-pudb           2021.2.2-1             2022.1-1
                        python-py7zr             0.18.1-1             0.18.3-1
                    python-pykwalify              1.8.0-3                    -
                       python-pylint             2.12.2-2             2.13.4-1
                      python-pymongo             3.12.2-1             3.12.3-1
                       python-pyodbc             4.0.32-2                    -
                       python-pyppmd             0.18.0-1             0.18.2-1
                      python-pypugjs             5.9.10-1             5.9.11-1
                        python-qiniu              7.5.0-2              7.6.0-1
                    python-qtconsole              5.2.2-1              5.3.0-1
              python-requirementslib             1.5.16-4              1.6.0-1
                         python-rich             12.0.1-1             12.1.0-1
                         python-rpy2              3.4.5-3              3.5.0-1
                       python-rzpipe              0.1.0-1              0.1.0-2
                python-sourceinspect              0.0.3-2                    -
                       python-sphinx              4.4.0-1              4.5.0-1
          python-sphinxext-opengraph              0.6.2-1              0.6.3-1
                   python-sqlalchemy             1.4.32-1             1.4.34-1
                  python-statsmodels             0.13.2-2             0.13.2-3
                 python-telegram-bot             13.8.1-1                    -
                     python-testpath              0.5.0-3              0.6.0-1
                      python-tomlkit             0.10.0-1             0.10.1-1
                   python-tpm2-pytss              1.0.0-3              1.1.0-1
                         python-tqdm             4.63.1-1             4.63.2-1
                       python-tweepy              4.6.0-1              4.8.0-1
                        python-typer              0.4.0-2              0.4.1-1
             python-websocket-client              1.2.3-2              1.3.2-1
                     python-werkzeug              2.0.3-1              2.1.1-1
                                qmmp              2.0.3-4              2.0.4-1
                            qpdfview             0.4.18-2                    -
                           quodlibet              4.4.0-3              4.5.0-1
                         qutebrowser              2.4.0-2              2.5.0-1
                             rathole              0.4.0-2              0.4.1-1
                     raw-thumbnailer              0.2.1-7                    -
                               rizin              0.1.2-2              0.3.4-1
                        ruby-bundler             2.2.26-1             2.3.10-1
                             ruby-pg              1.3.3-1              1.3.4-1
                           ruby-puma              5.6.2-1              5.6.4-1
                           ruby-tins             1.26.0-2             1.31.0-1
                                runc              1.1.0-1              1.1.1-1
                       rust-analyzer           20220321-1           20220328-1
                      rustypaste-cli              0.1.5-1              0.1.6-1
                           rz-cutter              2.0.0-1              2.0.5-3
                           rz-ghidra              0.1.1-1              0.3.0-3
                              sakura              3.8.4-1                    -
                                salt               3004-4             3004.1-2
                           sdl_pango              0.1.2-8                    -
                          serverless              3.8.0-1             3.10.2-1
                              shards             0.16.0-1             0.17.0-1
                             shntool             3.0.10-7                    -
                             shotcut           22.01.30-2           22.03.30-1
                             signify                 30-1                 31-1
                              simavr                1.7-2                    -
                         simple-scan               40.7-1               42.0-1
                               skate              0.1.4-1              0.1.5-1
                            smartdns                 35-1                 36-1
                               smb4k              3.1.1-1              3.1.2-1
                              sn0int             0.24.1-1             0.24.2-1
                                sqlc             1.12.0-1             1.13.0-1
                             sslscan             2.0.12-1             2.0.13-1
                         staticcheck           2021.1.2-1             2022.1-1
                              stylua             0.12.5-1             0.13.0-1
                                syft             0.38.0-1             0.43.0-1
                            sylpheed              3.7.0-6                    -
                              sympol             0.1.9-10             0.1.9-11
                           tcpreplay              4.3.4-1              4.4.1-1
                          terragrunt             0.36.2-1             0.36.6-1
                              thrift             0.15.0-1             0.16.0-1
                               tiled              1.8.2-1              1.8.4-1
                  treefrog-framework             1.23.0-1                    -
                         ttc-iosevka             15.0.3-1             15.1.0-1
                    ttc-iosevka-aile             15.0.3-1             15.1.0-1
                   ttc-iosevka-curly             15.0.3-1             15.1.0-1
              ttc-iosevka-curly-slab             15.0.3-1             15.1.0-1
                  ttc-iosevka-etoile             15.0.3-1             15.1.0-1
                    ttc-iosevka-slab             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss01             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss02             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss03             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss04             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss05             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss06             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss07             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss08             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss09             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss10             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss11             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss12             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss13             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss14             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss15             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss16             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss17             15.0.3-1             15.1.0-1
                    ttc-iosevka-ss18             15.0.3-1             15.1.0-1
                              udevil              0.4.4-4                    -
         v2ray-domain-list-community     20220325131800-1     20220403103254-1
                         v2ray-geoip       202203250919-1       202203310042-1
           vscode-css-languageserver             1.65.0-1             1.66.0-1
          vscode-html-languageserver             1.65.0-1             1.66.0-1
          vscode-json-languageserver             1.65.0-1             1.66.0-1
                           vultr-cli             2.12.1-1             2.12.2-1
                            wakatime           1:1.35.4-1           1:1.38.0-1
                            wasmtime             0.35.1-1             0.35.2-1
                           watchexec            1.18.10-1            1.18.11-1
                          winetricks           20191224-2           20220328-1
                                yaws              2.1.0-1                    -
                              zellij             0.26.1-1             0.27.0-1
                        zerotier-one              1.8.6-1              1.8.7-1
                      zram-generator              1.1.1-1              1.1.2-1
                                 dht                    -               0.26-3
                          difftastic                    -             0.25.0-1
                                 eva                    -              0.2.7-2
                           libdiscid                    -              0.6.2-3
                           libdvdcss                    -              1.4.3-1
                     libmusicbrainz5                    -              5.1.0-4
                           lua-lanes                    -             3.16.0-2
                         lua51-lanes                    -             3.16.0-2
                         lua52-lanes                    -             3.16.0-2
                         lua53-lanes                    -             3.16.0-2
                    mdbook-linkcheck                    -              0.7.6-2
                      pantheon-tasks                    -              6.2.0-2
                     python-dictpath                    -              0.1.3-1
       python-ephemeral-port-reserve                    -              1.1.4-1
               python-jupyter-sphinx                    -              0.3.2-1
                 python-openapi-core                    -             0.14.2-1
                              screen                    -              4.9.0-1
                             sheldon                    -              0.6.6-3
                      spice-protocol                    -             0.14.4-1
                               trivy                    -             0.25.0-2
:: Different overlay package(s) in repository core aarch64
                               linux             5.17.1-2             5.17.1-4
                       linux-headers             5.17.1-2             5.17.1-4
                        linux-khadas            5.16.17-1             5.17.1-1
                linux-khadas-headers            5.16.17-1             5.17.1-1
                            linux-rc           5.17.rc8-4           5.17.rc8-5
                    linux-rc-headers           5.17.rc8-4           5.17.rc8-5
                          linux-rpi4            5.15.30-1            5.15.32-2
                  linux-rpi4-headers            5.15.30-1            5.15.32-2
                 linux-rpi4-mainline             5.17.0-1             5.17.1-2
         linux-rpi4-mainline-headers             5.17.0-1             5.17.1-2
                      manjaro-system           20220215-2           20220404-1
              raspberrypi-bootloader           20220315-1           20220330-1
            raspberrypi-bootloader-x           20220315-1           20220330-1
:: Different sync package(s) in repository core aarch64
             ca-certificates-mozilla               3.76-1               3.77-1
                                crda               4.14-4                    -
                                curl             7.82.0-1             7.82.0-2
                               expat              2.4.7-1              2.4.8-1
                               groff             1.22.4-6             1.22.4-7
                                grub           2:2.06-4.1             2:2.06-5
                            jfsutils             1.1.15-7             1.1.15-8
                               lemon             3.38.1-1             3.38.2-1
                          libarchive              3.6.0-1              3.6.0-2
                      libcurl-compat             7.82.0-1             7.82.0-2
                      libcurl-gnutls             7.82.0-1             7.82.0-2
                           libgcrypt              1.9.4-1             1.10.1-1
                               mdadm                4.2-1                4.2-2
                             minizip           1:1.2.11-5           1:1.2.12-1
                                 nss               3.76-1               3.77-1
                                perl             5.34.0-3             5.34.1-1
                              sqlite             3.38.1-1             3.38.2-1
                     sqlite-analyzer             3.38.1-1             3.38.2-1
                          sqlite-doc             3.38.1-1             3.38.2-1
                          sqlite-tcl             3.38.1-1             3.38.2-1
                          util-linux             2.37.4-1               2.38-1
                     util-linux-libs             2.37.4-1               2.38-1
                      wireless-regdb         2022.02.18-1         2022.02.18-3
                                zlib           1:1.2.11-5           1:1.2.12-1
:: Different overlay package(s) in repository extra aarch64
                   libva-mesa-driver           21.3.7-2.1           22.0.1-0.1
                                mesa           21.3.7-2.1           22.0.1-0.1
                            mesa-git22.1.0_devel.151648.ae710f33296-122.1.0_devel.151866.e1de9b0de5e-1
                          mesa-vdpau           21.3.7-2.1           22.0.1-0.1
                         nm-tray-git       r202.cda09d7-1                    -
                         opencl-mesa           21.3.7-2.1           22.0.1-0.1
                       plasma-mobile             5.24.3-1             5.24.4-1
                    plasma-mobile-nm             5.24.3-1             5.24.4-1
                         plasma-nano             5.24.3-1             5.24.4-1
                   qqc2-breeze-style             5.24.3-1             5.24.4-1
                     vulkan-broadcom           21.3.7-2.1           22.0.1-0.1
                  vulkan-mesa-layers           21.3.7-2.1           22.0.1-0.1
                     vulkan-panfrost           21.3.7-2.1           22.0.1-0.1
                       vulkan-radeon           21.3.7-2.1           22.0.1-0.1
                       vulkan-swrast           21.3.7-2.1           22.0.1-0.1
:: Different sync package(s) in repository extra aarch64
                     accountsservice            22.08.8-1            22.08.8-2
                  alsa-card-profiles           1:0.3.48-1           1:0.3.49-1
                              antlr2             2.7.7-12                    -
                        archboot-arm           2022.03-48            2022.04-5
                 archboot-bootloader           20220307-3           20220329-1
                         archinstall              2.3.2-2              2.3.3-1
                     archlinux-menus                2.5-5                    -
                                babl             0.1.90-1             0.1.90-2
                              basket              2.49b-7                    -
                         bdf-unifont            14.0.02-1                    -
                   black-hole-solver             1.10.1-1             1.12.0-1
                           bluedevil           1:5.24.3-1           1:5.24.4-1
                              breeze             5.24.3-1             5.24.4-1
                         breeze-grub             5.24.3-1             5.24.4-1
                          breeze-gtk             5.24.3-1             5.24.4-1
                            chemtool             1.6.14-4                    -
                            chromium       99.0.4844.84-1      100.0.4896.60-2
                   claws-mail-themes           20140629-3                    -
                            clawsker              1.3.5-1                    -
                             clutter             1.26.4-1             1.26.4-2
                         clutter-gtk              1.8.4-2              1.8.4-3
                               cmake             3.22.3-1             3.23.0-1
                                cogl             1.22.8-1             1.22.8-2
                          colord-gtk              0.3.0-1              0.3.0-2
                   colord-gtk-common              0.3.0-1              0.3.0-2
                         colord-gtk4              0.3.0-1              0.3.0-2
                            composer              2.2.9-1              2.3.3-1
                              davfs2              1.6.1-1                    -
                             devhelp               41.2-3 41.2+r48+g14272cae-1
                        devhelp-docs               41.2-3 41.2+r48+g14272cae-1
                                 dht               0.26-3                    -
                            discover             5.24.3-1             5.24.4-1
                             drkonqi             5.24.3-1             5.24.4-1
                        five-or-more             3.32.2-1             3.32.3-1
                          fontconfig          2:2.13.96-1           2:2.14.0-1
                         foomatic-db         3:20211116-1         3:20220328-1
                 foomatic-db-nonfree         3:20211116-1         3:20220328-1
            foomatic-db-nonfree-ppds         3:20211116-1         3:20220328-1
                    foomatic-db-ppds         3:20211116-1         3:20220328-1
                           freetype2             2.11.1-1             2.12.0-1
                     freetype2-demos             2.11.1-1             2.12.0-1
                      freetype2-docs             2.11.1-1             2.12.0-1
                                 gcr             3.41.0-1             3.41.0-2
                                gegl             0.4.36-1             0.4.36-2
                              genius             1.0.27-2                    -
                        geocode-glib 3.26.2+r9+g6047da3-1 3.26.2+r9+g6047da3-2
                            ghostpcl             9.55.0-4             9.56.0-1
                         ghostscript             9.55.0-4             9.56.0-1
                            ghostxps             9.55.0-4             9.56.0-1
                              giblib              1.2.4-8                    -
                                gimp            2.10.30-1            2.10.30-2
                          git-review             1.28.0-5                    -
                        gnome-autoar              0.4.3-1              0.4.3-2
                       gnome-builder               41.3-4               41.3-5
           gnome-builder-libide-docs               41.3-4               41.3-5
                         gnome-chess               41.1-1               42.0-1
                 gnome-color-manager3.36.0+r24+ge7eb7b53-13.36.0+r25+g4aab8b59-1
           gnome-icon-theme-symbolic             3.12.0-6                    -
               gnome-online-accounts             3.40.1-1             3.44.0-1
                        gnome-sudoku               40.2-1               42.0-1
                             gparted              1.3.1-1              1.4.0-1
                      graphicsmagick             1.3.37-1             1.3.38-1
                     grml-zsh-config             0.19.1-1             0.19.2-1
                              gsound              1.0.3-1              1.0.3-2
                 gst-plugin-pipewire           1:0.3.48-1           1:0.3.49-1
                              gthumb             3.12.1-1             3.12.2-1
                                gvim           8.2.4464-1           8.2.4651-1
                               habak              0.2.5-7                    -
                            harfbuzz              4.1.0-1              4.2.0-1
                        harfbuzz-icu              4.1.0-1              4.2.0-1
                               hwloc              2.7.0-1              2.7.1-1
                             hylafax              6.0.7-4                    -
                               imath              3.1.4-1              3.1.5-1
                           json-glib              1.6.6-1              1.6.6-2
                      json-glib-docs              1.6.6-1              1.6.6-2
                   kactivitymanagerd             5.24.3-1             5.24.4-1
                       kde-cli-tools             5.24.3-1             5.24.4-1
                      kde-gtk-config             5.24.3-1             5.24.4-1
                         kdecoration             5.24.3-1             5.24.4-1
                    kdeplasma-addons             5.24.3-1             5.24.4-1
                             kgamma5             5.24.3-1             5.24.4-1
                            khotkeys             5.24.3-1             5.24.4-1
                         kinfocenter             5.24.3-1             5.24.4-1
                           kmenuedit             5.24.3-1             5.24.4-1
                             kscreen             5.24.3-1             5.24.4-1
                       kscreenlocker             5.24.3-1             5.24.4-1
                         ksshaskpass             5.24.3-1             5.24.4-1
                        ksystemstats             5.24.3-1             5.24.4-1
                         kwallet-pam             5.24.3-1             5.24.4-1
                kwayland-integration             5.24.3-1             5.24.4-1
                     kwayland-server             5.24.3-1             5.24.4-1
                                kwin             5.24.3-1             5.24.4-1
                             kwrited             5.24.3-1             5.24.4-1
                      layer-shell-qt             5.24.3-1             5.24.4-1
                         libcanberra    0.30+2+gc0620e4-5 1:0.30+r2+gc0620e4-1
                        libchamplain            0.12.20-2            0.12.20-3
                           libdiscid              0.6.2-3                    -
                           libdvdcss              1.4.3-1                    -
                          libetebase              0.5.2-1              0.5.3-1
                            libgdata             0.18.1-1             0.18.1-2
              libgnome-games-support              1.8.2-1              1.8.2-2
                         libgnomekbd  3.26.1+2+g8d02ebd-21:3.26.1+r5+g54da436-1
                         libgweather 40.0+r87+g80e5a652-1 40.0+r87+g80e5a652-2
                             libical             3.0.14-1             3.0.14-2
                            libinput             1.20.0-1             1.20.0-2
                          libkscreen             5.24.3-1             5.24.4-1
                        libksysguard             5.24.3-1             5.24.4-1
                     libmusicbrainz5              5.1.0-4                    -
                              libnma             1.8.36-1             1.8.36-3
                       libnumbertext              1.0.8-1              1.0.9-1
                              libpgf             7.21.7-1                    -
                              libpst             0.6.76-5             0.6.76-6
                         libpst-docs             0.6.76-5             0.6.76-6
                   libreoffice-fresh              7.3.1-1              7.3.2-1
                libreoffice-fresh-af              7.3.1-1              7.3.2-1
                libreoffice-fresh-am              7.3.1-1              7.3.2-1
                libreoffice-fresh-ar              7.3.1-1              7.3.2-1
                libreoffice-fresh-as              7.3.1-1              7.3.2-1
               libreoffice-fresh-ast              7.3.1-1              7.3.2-1
                libreoffice-fresh-be              7.3.1-1              7.3.2-1
                libreoffice-fresh-bg              7.3.1-1              7.3.2-1
                libreoffice-fresh-bn              7.3.1-1              7.3.2-1
             libreoffice-fresh-bn-in              7.3.1-1              7.3.2-1
                libreoffice-fresh-bo              7.3.1-1              7.3.2-1
                libreoffice-fresh-br              7.3.1-1              7.3.2-1
               libreoffice-fresh-brx              7.3.1-1              7.3.2-1
                libreoffice-fresh-bs              7.3.1-1              7.3.2-1
                libreoffice-fresh-ca              7.3.1-1              7.3.2-1
       libreoffice-fresh-ca-valencia              7.3.1-1              7.3.2-1
               libreoffice-fresh-ckb              7.3.1-1              7.3.2-1
                libreoffice-fresh-cs              7.3.1-1              7.3.2-1
                libreoffice-fresh-cy              7.3.1-1              7.3.2-1
                libreoffice-fresh-da              7.3.1-1              7.3.2-1
                libreoffice-fresh-de              7.3.1-1              7.3.2-1
               libreoffice-fresh-dgo              7.3.1-1              7.3.2-1
               libreoffice-fresh-dsb              7.3.1-1              7.3.2-1
                libreoffice-fresh-dz              7.3.1-1              7.3.2-1
                libreoffice-fresh-el              7.3.1-1              7.3.2-1
             libreoffice-fresh-en-gb              7.3.1-1              7.3.2-1
             libreoffice-fresh-en-za              7.3.1-1              7.3.2-1
                libreoffice-fresh-eo              7.3.1-1              7.3.2-1
                libreoffice-fresh-es              7.3.1-1              7.3.2-1
                libreoffice-fresh-et              7.3.1-1              7.3.2-1
                libreoffice-fresh-eu              7.3.1-1              7.3.2-1
                libreoffice-fresh-fa              7.3.1-1              7.3.2-1
                libreoffice-fresh-fi              7.3.1-1              7.3.2-1
                libreoffice-fresh-fr              7.3.1-1              7.3.2-1
               libreoffice-fresh-fur              7.3.1-1              7.3.2-1
                libreoffice-fresh-fy              7.3.1-1              7.3.2-1
                libreoffice-fresh-ga              7.3.1-1              7.3.2-1
                libreoffice-fresh-gd              7.3.1-1              7.3.2-1
                libreoffice-fresh-gl              7.3.1-1              7.3.2-1
                libreoffice-fresh-gu              7.3.1-1              7.3.2-1
               libreoffice-fresh-gug              7.3.1-1              7.3.2-1
                libreoffice-fresh-he              7.3.1-1              7.3.2-1
                libreoffice-fresh-hi              7.3.1-1              7.3.2-1
                libreoffice-fresh-hr              7.3.1-1              7.3.2-1
               libreoffice-fresh-hsb              7.3.1-1              7.3.2-1
                libreoffice-fresh-hu              7.3.1-1              7.3.2-1
                libreoffice-fresh-id              7.3.1-1              7.3.2-1
                libreoffice-fresh-is              7.3.1-1              7.3.2-1
                libreoffice-fresh-it              7.3.1-1              7.3.2-1
                libreoffice-fresh-ja              7.3.1-1              7.3.2-1
                libreoffice-fresh-ka              7.3.1-1              7.3.2-1
               libreoffice-fresh-kab              7.3.1-1              7.3.2-1
                libreoffice-fresh-kk              7.3.1-1              7.3.2-1
                libreoffice-fresh-km              7.3.1-1              7.3.2-1
          libreoffice-fresh-kmr-latn              7.3.1-1              7.3.2-1
                libreoffice-fresh-kn              7.3.1-1              7.3.2-1
                libreoffice-fresh-ko              7.3.1-1              7.3.2-1
               libreoffice-fresh-kok              7.3.1-1              7.3.2-1
                libreoffice-fresh-ks              7.3.1-1              7.3.2-1
                libreoffice-fresh-lb              7.3.1-1              7.3.2-1
                libreoffice-fresh-lo              7.3.1-1              7.3.2-1
                libreoffice-fresh-lt              7.3.1-1              7.3.2-1
                libreoffice-fresh-lv              7.3.1-1              7.3.2-1
               libreoffice-fresh-mai              7.3.1-1              7.3.2-1
                libreoffice-fresh-mk              7.3.1-1              7.3.2-1
                libreoffice-fresh-ml              7.3.1-1              7.3.2-1
                libreoffice-fresh-mn              7.3.1-1              7.3.2-1
               libreoffice-fresh-mni              7.3.1-1              7.3.2-1
                libreoffice-fresh-mr              7.3.1-1              7.3.2-1
                libreoffice-fresh-my              7.3.1-1              7.3.2-1
                libreoffice-fresh-nb              7.3.1-1              7.3.2-1
                libreoffice-fresh-ne              7.3.1-1              7.3.2-1
                libreoffice-fresh-nl              7.3.1-1              7.3.2-1
                libreoffice-fresh-nn              7.3.1-1              7.3.2-1
                libreoffice-fresh-nr              7.3.1-1              7.3.2-1
               libreoffice-fresh-nso              7.3.1-1              7.3.2-1
                libreoffice-fresh-oc              7.3.1-1              7.3.2-1
                libreoffice-fresh-om              7.3.1-1              7.3.2-1
                libreoffice-fresh-or              7.3.1-1              7.3.2-1
             libreoffice-fresh-pa-in              7.3.1-1              7.3.2-1
                libreoffice-fresh-pl              7.3.1-1              7.3.2-1
                libreoffice-fresh-pt              7.3.1-1              7.3.2-1
             libreoffice-fresh-pt-br              7.3.1-1              7.3.2-1
                libreoffice-fresh-ro              7.3.1-1              7.3.2-1
                libreoffice-fresh-ru              7.3.1-1              7.3.2-1
                libreoffice-fresh-rw              7.3.1-1              7.3.2-1
             libreoffice-fresh-sa-in              7.3.1-1              7.3.2-1
               libreoffice-fresh-sat              7.3.1-1              7.3.2-1
                libreoffice-fresh-sd              7.3.1-1              7.3.2-1
               libreoffice-fresh-sdk              7.3.1-1              7.3.2-1
                libreoffice-fresh-si              7.3.1-1              7.3.2-1
               libreoffice-fresh-sid              7.3.1-1              7.3.2-1
                libreoffice-fresh-sk              7.3.1-1              7.3.2-1
                libreoffice-fresh-sl              7.3.1-1              7.3.2-1
                libreoffice-fresh-sq              7.3.1-1              7.3.2-1
                libreoffice-fresh-sr              7.3.1-1              7.3.2-1
           libreoffice-fresh-sr-latn              7.3.1-1              7.3.2-1
                libreoffice-fresh-ss              7.3.1-1              7.3.2-1
                libreoffice-fresh-st              7.3.1-1              7.3.2-1
                libreoffice-fresh-sv              7.3.1-1              7.3.2-1
             libreoffice-fresh-sw-tz              7.3.1-1              7.3.2-1
               libreoffice-fresh-szl              7.3.1-1              7.3.2-1
                libreoffice-fresh-ta              7.3.1-1              7.3.2-1
                libreoffice-fresh-te              7.3.1-1              7.3.2-1
                libreoffice-fresh-tg              7.3.1-1              7.3.2-1
                libreoffice-fresh-th              7.3.1-1              7.3.2-1
                libreoffice-fresh-tn              7.3.1-1              7.3.2-1
                libreoffice-fresh-tr              7.3.1-1              7.3.2-1
                libreoffice-fresh-ts              7.3.1-1              7.3.2-1
                libreoffice-fresh-tt              7.3.1-1              7.3.2-1
                libreoffice-fresh-ug              7.3.1-1              7.3.2-1
                libreoffice-fresh-uk              7.3.1-1              7.3.2-1
                libreoffice-fresh-uz              7.3.1-1              7.3.2-1
                libreoffice-fresh-ve              7.3.1-1              7.3.2-1
               libreoffice-fresh-vec              7.3.1-1              7.3.2-1
                libreoffice-fresh-vi              7.3.1-1              7.3.2-1
                libreoffice-fresh-xh              7.3.1-1              7.3.2-1
             libreoffice-fresh-zh-cn              7.3.1-1              7.3.2-1
             libreoffice-fresh-zh-tw              7.3.1-1              7.3.2-1
                libreoffice-fresh-zu              7.3.1-1              7.3.2-1
                             librsvg           2:2.54.0-1           2:2.54.0-2
                        librsvg-docs           2:2.54.0-1           2:2.54.0-2
                            libsoup3              3.0.5-1              3.0.6-1
                            libspnav                0.3-1                1.0-1
                          libstemmer              2.2.0-1              2.2.0-2
                             libtiff              4.3.0-1              4.3.0-2
                   libva-mesa-driver             21.3.7-2           22.0.0-1.1
                   libvisual-plugins             0.4.0-11                    -
                              libwpe             1.12.0-1             1.12.0-2
                              libx11            1.7.3.1-1              1.7.5-1
                            libxcomp          3.5.99.26-1                    -
                          libxcursor              1.2.0-2              1.2.1-1
                              libxmi                1.2-9                    -
                             libxvmc             1.0.12-3             1.0.13-1
                         lockdown-ms           20130326-4                    -
                                 lyx            2.3.6.1-3                    -
                                mesa             21.3.7-2           22.0.0-1.1
                          mesa-vdpau             21.3.7-2           22.0.0-1.1
                               milou             5.24.3-1             5.24.4-1
                                 mlt              7.4.0-3              7.6.0-1
      mobile-broadband-provider-info           20210805-1           20220315-1
                           mod_fcgid              2.3.9-5                    -
                            mousepad              0.5.8-1              0.5.9-1
                             nghttp2             1.47.0-1                    -
                            nss_ldap                265-9                    -
                          nx-headers          3.5.99.26-1                    -
                              nx-x11          3.5.99.26-1                    -
                             nxagent          3.5.99.26-1                    -
                             nxproxy          3.5.99.26-1                    -
                         opencl-mesa             21.3.7-2           22.0.0-1.1
                              opencv              4.5.5-3              4.5.5-4
                      opencv-samples              4.5.5-3              4.5.5-4
                              oxygen             5.24.3-1             5.24.4-1
                            pam_ldap                186-9                    -
                    perl-html-parser               3.77-1               3.78-1
                       pipewire-alsa           1:0.3.48-1           1:0.3.49-1
                       pipewire-docs           1:0.3.48-1           1:0.3.49-1
                       pipewire-jack           1:0.3.48-1           1:0.3.49-1
                      pipewire-pulse           1:0.3.48-1           1:0.3.49-1
                       pipewire-v4l2           1:0.3.48-1           1:0.3.49-1
                   pipewire-x11-bell           1:0.3.48-1           1:0.3.49-1
                   pipewire-zeroconf           1:0.3.48-1           1:0.3.49-1
          plasma-browser-integration             5.24.3-1             5.24.4-1
                      plasma-desktop             5.24.3-1             5.24.4-1
                        plasma-disks             5.24.3-1             5.24.4-1
                     plasma-firewall             5.24.3-1             5.24.4-1
                    plasma-framework             5.92.0-1             5.92.0-2
                  plasma-integration             5.24.3-1             5.24.4-1
                           plasma-nm             5.24.3-1             5.24.4-1
                           plasma-pa             5.24.3-1             5.24.4-1
                          plasma-sdk             5.24.3-1             5.24.4-1
                plasma-systemmonitor             5.24.3-1             5.24.4-1
                  plasma-thunderbolt             5.24.3-1             5.24.4-1
                        plasma-vault             5.24.3-1             5.24.4-1
              plasma-wayland-session             5.24.3-1             5.24.4-2
                    plasma-workspace             5.24.3-1             5.24.4-2
         plasma-workspace-wallpapers             5.24.3-1             5.24.4-1
                    polkit-kde-agent             5.24.3-1             5.24.4-1
                          powerdevil             5.24.3-1             5.24.4-1
                            procmail              3.22-10                    -
                       progsreiserfs           0.3.0.5-10                    -
                          prometheus             2.33.4-1             2.34.0-1
        prometheus-blackbox-exporter             0.20.0-1             0.20.0-2
                     python-dbusmock             0.25.0-1             0.27.3-1
                        python-evdev              1.4.0-3              1.5.0-1
                       python-opencv              4.5.5-3              4.5.5-4
                                 qbs             1.21.0-1             1.22.0-1
                                 re2         1:20220201-1         1:20220401-1
                               samba             4.16.0-1             4.16.0-4
                      sane-frontends             1.0.14-9                    -
                              screen              4.9.0-1                    -
                            sddm-kcm             5.24.3-1             5.24.4-1
                    shared-mime-info   2.0+115+gd74a913-1   2.0+144+g13695c7-1
                           smbclient             4.16.0-1             4.16.0-4
                            snowball              2.2.0-1              2.2.0-2
                      spice-protocol             0.14.4-1                    -
                          stellarium             0.21.3-1                    -
                              strace               5.16-1               5.17-1
                               sushi               41.0-1               41.1-1
                      systemsettings             5.24.3-1             5.24.4-1
                          tamu-anova              0.2.1-7                    -
                            testdisk                7.1-3                7.1-4
                             texmacs              2.1.1-1                    -
                              thunar            4.16.10-1            4.16.11-1
                         vim-runtime           8.2.4464-1           8.2.4651-1
                          vte-common             0.66.2-1             0.68.0-1
                                vte3             0.66.2-1             0.68.0-1
                     vulkan-broadcom             21.3.7-2           22.0.0-1.1
                  vulkan-mesa-layers             21.3.7-2           22.0.0-1.1
                     vulkan-panfrost             21.3.7-2           22.0.0-1.1
                       vulkan-radeon             21.3.7-2           22.0.0-1.1
                       vulkan-swrast             21.3.7-2           22.0.0-1.1
                             wayland             1.20.0-1             1.20.0-2
                        wayland-docs             1.20.0-1             1.20.0-2
                          webkit2gtk             2.36.0-1             2.36.0-2
                      webkit2gtk-4.1             2.36.0-1             2.36.0-2
                      webkit2gtk-5.0             2.36.0-1             2.36.0-2
                      wpebackend-fdo             1.12.0-1             1.12.0-2
                           wpewebkit             2.34.6-1             2.36.0-2
                          x2goclient            4.1.2.2-3                    -
                          x2goserver           4.1.0.3-10                    -
                               xawtv              3.107-1                    -
                  xdg-desktop-portal             1.14.1-1             1.14.2-1
              xdg-desktop-portal-kde             5.24.3-1             5.24.4-1
                 xfce4-screenshooter             1.9.10-1             1.9.10-2
                      xfce4-terminal             0.8.10-2              1.0.0-1
                         xorg-appres              1.0.5-2              1.0.6-1
                           xorg-docs              1.7.1-3              1.7.2-1
                        xorg-iceauth              1.0.8-2              1.0.9-1
                    xorg-mkfontscale              1.2.1-2              1.2.2-1
                      xorg-setxkbmap              1.3.2-2              1.3.3-1
                            xorg-twm             1.0.11-1             1.0.12-1
                          xorg-xcalc              1.1.0-2              1.1.1-1
                         xorg-xclock              1.0.9-2              1.1.0-1
                            xorg-xdm             1.1.12-3             1.1.13-1
                          xorg-xedit              1.2.2-3              1.2.3-1
                          xorg-xload              1.1.3-2              1.1.4-1
                       xorg-xlsfonts              1.0.6-3              1.0.7-1
                       xorg-xwayland             22.1.0-1             22.1.1-1
                              zenity             3.41.0-1             3.42.0-1
                      gtksourceview5                    -              5.4.0-1
                 gtksourceview5-docs                    -              5.4.0-1
            libgnome-games-support-2                    -              2.0.0-1
                       libgweather-4                    -              4.0.0-1
                  libgweather-4-docs                    -              4.0.0-1
                       libnma-common                    -             1.8.36-3
                         libnma-gtk4                    -             1.8.36-3
                          mesa-amber                    -             21.3.8-4
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.12.2.r12712.g054e7b167-121.12.2.r12715.gb764a86d5-1
                    akonadi-calendar21.12.2.1.r2056.g328b964-121.12.2.1.r2058.g2173f6a-1
              akonadi-calendar-tools21.12.2.1.r942.gdd8d6c5-121.12.2.1.r943.g61e3635-1
                    akonadi-contacts21.12.2.r3160.geff3b1fc-121.12.2.r3163.g04799464-1
               akonadi-import-wizard21.12.2.1.r1802.gb92e8f1-121.12.2.1.r1804.g0b9b769-1
                        akonadi-mime21.12.2.1.r1709.gdc26109-121.12.2.1.r1711.g6e45f7a-1
                       akonadi-notes21.12.2.1.r1065.g472c8c2-121.12.2.1.r1066.geb8a226-1
                      akonadi-search21.12.2.1.r1214.g5ed2d63-121.12.2.1.r1216.g2417b02-1
                      akonadiconsole21.12.2.1.r1579.ge3ecdd8-121.12.2.1.r1581.g6c8d51f-1
                           akregator21.12.2.r6355.gd4a9825c-121.12.2.r6360.g4993640d-1
                           alligator  22.02.r4.g62f6c6f-1  22.02.r6.gb278e86-1
                           angelfish 22.02.r12.g62e1de3-1 22.02.r14.ga13407b-1
                                 ark21.12.2.1.r4718.g5c95ab20-121.12.2.1.r4721.gfb424025-1
                          artikulate21.12.2.1.r1408.gb90e82c-121.12.2.1.r1410.g67aea66-1
                         audiocd-kio21.12.2.1.r1053.ge6db30d-121.12.2.1.r1054.g4a451af-1
                             blinken21.12.2.1.r658.g3dbe8a8-121.12.2.1.r660.ga3fe3c1-1
                           bluedevil1:5.24.3.r2384.g504d44ad-11:5.24.4.r2387.g96cffffc-1
                            bluez-qt5.92.0.r706.g97a0033-15.92.0.r707.g7fa6265-1
                              bomber21.12.2.1.r556.gc6409ef-121.12.2.1.r557.g613f51a-1
                                bovo21.12.2.1.r770.gb804b26-121.12.2.1.r771.gd5fcf44-1
                              breeze5.24.3.r2371.g3ce6b178-15.24.4.r2377.g0f97c23b-1
                         breeze-grub5.24.3.r11.g63136a9-15.24.4.r11.g63136a9-1
                          breeze-gtk5.24.3.r459.g64e5e24-15.24.4.r459.g64e5e24-1
                                buho  2.1.1.r3.g278078b-1  2.1.1.r5.g9f1cee6-1
                     calendarsupport21.12.2.r678.gd815b45-121.12.2.r680.gf83af73-1
                           calindori  22.02.r8.g554be1d-1 22.02.r10.g2935faa-1
                            cervisia21.12.2.1.r1654.gf931187-121.12.2.1.r1656.g56bc817-1
                            discover5.24.3.r8604.g1dfd0d7d-15.24.4.r8613.g4907ad07-1
                             dolphin21.12.2.1.r6832.gd68bb06e8-121.12.2.1.r6898.g0c38a27cc-1
                     dolphin-plugins21.12.2.r648.gbb1de5a-121.12.2.r649.g277f988-1
                              dragon21.12.2.1.r1027.g0d71796-121.12.2.1.r1029.gb98922a-1
                             drkonqi5.24.3.r751.ge540b701-15.24.4.r753.gfcca1043-1
                               elisa21.12.2.1.r2910.gf6255822-121.12.2.1.r2911.g01177f52-1
                          elisa-qtmm21.12.2.1.r2910.gf6255822-121.12.2.1.r2911.g01177f52-1
                          eventviews21.12.2.r799.ga53feee-121.12.2.r801.gd8dc8eb-1
                 extra-cmake-modules5.91.0.r3467.g19311d2-15.92.0.r3469.geccf695-1
                           filelight21.12.2.r1064.g7f605ad-121.12.2.r1075.g182c6df-1
                frameworkintegration5.92.0.r627.g1dc39dd-15.92.0.r629.g7e3cf1b-1
                           granatier21.12.2.1.r965.ge9ff3bc-121.12.2.1.r967.g4356e9e-1
                     grantlee-editor21.12.2.1.r813.g87be3d0-121.12.2.1.r814.g0c0574a-1
                       grantleetheme21.12.2.r386.g1792967-121.12.2.r387.g625a374-1
                            gwenview21.12.2.1.r6819.g312c6059-121.12.2.1.r6824.g888dcb7e-1
                     incidenceeditor21.12.2.1.r854.g653a917-121.12.2.1.r856.g2a424be-1
                           itinerary21.12.2.1.r1754.ge7924e1-121.12.2.1.r1762.g3c2c64b-1
                                 juk21.12.2.1.r3136.g40997ef4-121.12.2.1.r3138.g8086d808-1
                                 k3b1:21.12.2.1.r6720.gf616e9c27-11:21.12.2.1.r6722.gd42ac36f1-1
               kaccounts-integration21.12.2.r1246.g247ae41-121.12.2.r1251.gd38b71b-1
                   kactivitymanagerd5.24.3.r1388.gdb88936-15.24.4.r1389.g4dc228a-1
                        kaddressbook21.12.2.1.r6131.ge99e5b50-121.12.2.1.r6134.g091e3e2e-1
                             kajongg21.12.2.1.r4332.g0c60e939-121.12.2.1.r4334.g081a6040-1
                              kalarm21.12.2.1.r7840.g72b42497-121.12.2.1.r7847.gb6494e89-1
                            kalgebra21.12.2.1.r2058.g656a53f-121.12.2.1.r2059.gbc6d395-1
                                kalk 22.02.r14.g4a08991-1 22.02.r19.gab8e8a9-1
                             kalzium21.12.2.1.r4309.g6965a7cf-121.12.2.1.r4310.g678d26db-1
                              kamera21.12.1.r706.g96388b0-121.12.1.r709.gb0d8443-1
                              kamoso21.12.2.1.r1451.gbf55b3f-121.12.2.1.r1453.gd16108f-1
                            kanagram21.12.2.r1303.g2e0dba9-121.12.2.r1304.gc6f9ed4-1
                              kapman21.12.2.1.r641.gde89758-121.12.2.1.r643.g3d5f40f-1
                        kapptemplate21.12.2.1.r982.gbd47199-121.12.2.1.r984.ga7c3df8-1
                               kasts  22.02.r9.g09395b5-1 22.02.r13.g893c647-1
                                kate21.12.2.1.r18841.g130c10192-121.12.2.1.r18894.g9f8dcc2b7-1
                             katomic21.12.2.1.r950.g720fbbd-121.12.2.1.r953.g45e059e-1
                               kauth5.92.0.r493.gcdb973a-15.92.0.r494.g68562de-1
                             kbackup21.12.2.1.r426.g5981c22-121.12.2.1.r427.g1d6d230-1
                           kblackbox21.12.2.1.r759.g7c4b793-121.12.2.1.r760.gd534b61-1
                             kblocks21.12.2.1.r706.gd8eb0ff-121.12.2.1.r707.gb9f9940-1
                             kbounce21.12.2.1.r838.ga102c9f-121.12.2.1.r842.g22d86c9-1
                           kbreakout21.12.2.1.r903.g6258122-121.12.2.1.r907.g39ab63d-1
                              kbruch21.12.2.1.r855.g1da42e0-121.12.2.1.r857.g99d9277-1
                         kcachegrind21.12.2.1.r1172.gb144e21-121.12.2.1.r1174.g535da9f-1
                  kcachegrind-common21.12.2.1.r1172.gb144e21-121.12.2.1.r1174.g535da9f-1
                               kcalc21.12.2.1.r1600.g0bccd5c-121.12.2.1.r1603.g3ad4e0a-1
                       kcalendarcore5.92.0.r1309.g1526e87af-15.92.0.r1310.g384d2a14c-1
                           kcalutils21.12.2.1.r943.g703a509e0-121.12.2.1.r944.g9c8fb9066-1
                         kcharselect21.12.2.r509.ga597ed8-121.12.2.r510.gaa55ede-1
                              kclock 22.02.r31.g6f0eb4c-1 22.02.r35.g6c2f1cc-1
                            kcmutils5.92.0.r609.g4b12a96-15.92.0.r610.g8c61a2e-1
                             kcodecs5.92.0.r414.gc003a22-15.92.0.r415.g60bc042-1
                       kcolorchooser21.12.2.1.r255.gacd6f3d-121.12.2.1.r257.gd5bcd55-1
                         kcompletion5.92.0.r488.gffa9c89-15.92.0.r489.g6668477-1
                             kconfig5.92.0.r944.g3c861a6c-15.92.0.r946.g66c8a3b8-1
                      kconfigwidgets5.92.0.r703.g9199569-15.92.0.r710.geb8dabb-1
                           kcontacts1:5.92.0.r3314.g41114f48-11:5.92.0.r3318.g5eebf0d8-1
                         kcoreaddons5.92.0.r1446.gbc2440ca-15.92.0.r1450.g55053dec-1
                              kcrash5.92.0.r438.ga9fb4b5-15.92.0.r439.ga89f0b5-1
                               kcron21.12.2.1.r838.gec9a749-121.12.2.1.r839.ga2fead8-1
                       kde-cli-tools5.24.3.r1917.g8415c2b-15.24.4.r1920.g63df213-1
                      kde-gtk-config5.24.3.r924.g4ee021a-15.24.4.r926.g9929926-1
                      kdebugsettings21.12.2.1.r898.g96a4511-121.12.2.1.r901.g3026229-1
                          kdeconnect21.12.2.1.r3417.gf5037a42-121.12.2.1.r3420.g872e2130-1
                         kdecoration5.24.3.r288.g4123ec8-15.24.4.r288.g4123ec8-1
                                kded5.92.0.r453.g0e83af7-15.92.0.r455.g530695b-1
            kdegraphics-thumbnailers21.12.2.1.r258.g201fb2c-121.12.2.1.r261.gfccb596-1
                     kdelibs4support5.92.0.r1077.g68885aa3-15.92.0.r1078.g29af2d66-1
              kdenetwork-filesharing21.12.2.1.r915.g670272d-121.12.2.1.r920.g0a3f474-1
                            kdenlive21.12.1.r15911.ge7271d918-121.12.1.r15925.gf9da836d1-1
                       kdepim-addons21.12.2.r4598.g04b663c5-121.12.2.r4604.gbddd0a37-1
                      kdepim-runtime21.12.2.r15475.g3d50a241b-121.12.2.r15477.g6682edb52-1
                    kdeplasma-addons5.24.3.r8685.g4fa0636da-15.24.4.r8707.g697943a00-1
                               kdesu5.92.0.r502.gf543caa-15.92.0.r503.g82d1460-1
                                 kdf21.12.2.1.r841.gbb0abea-121.12.2.1.r846.g7c94c2b-1
                             kdialog21.12.2.1.r1206.g5e331761c-121.12.2.1.r1210.gf711b0807-1
                            kdiamond21.12.2.1.r715.g18e05a9-121.12.2.1.r718.ge41138a-1
                              kdnssd5.92.0.r344.g93a5892-15.92.0.r345.g0325d14-1
                           kdoctools5.92.0.r653.ga00d2d9-15.92.0.r654.gf81bb14-1
                            keysmith  22.02.r3.g93b3fbc-1  22.02.r5.g20314d3-1
                       kfilemetadata5.92.0.r851.g4c1839f-15.92.0.r853.g02a23ab-1
                               kfind21.12.2.1.r2672.g9b40ba6fc-121.12.2.1.r2676.g53eb27138-1
                             kfloppy21.12.2.r789.g9795729-121.12.2.r790.ge3dfd23-1
                         kfourinline21.12.2.1.r1015.gf8e0146-121.12.2.1.r1016.gf82e16c-1
                             kgamma55.24.3.r471.gfa4f2b8-15.24.4.r472.g9025840-1
                          kgeography21.12.2.1.r1140.g0133d70-121.12.2.1.r1141.g3192844-1
                                kget21.12.2.1.r3165.g0a1eb6bc-121.12.2.1.r3167.gd817abb3-1
                        kglobalaccel5.92.0.r505.gc4fff79-15.92.0.r507.g69e337c-1
                         kgoldrunner21.12.2.1.r1270.g32e4017-121.12.2.1.r1272.g854fa14-1
                                kgpg21.12.2.1.r3178.gd0d187be-121.12.2.1.r3181.gf8aae35d-1
                            khangman21.12.2.1.r1592.gb625feb-121.12.2.1.r1593.g8e6e1bd-1
                         khelpcenter21.12.2.r2728.g488b5643-121.12.2.r2730.gbbe43d95-1
                           kholidays1:5.92.0.r999.g29fdd3e-11:5.92.0.r1000.g6d895d7-1
                            khotkeys5.24.3.r2115.g3b3ebbf-15.24.4.r2118.g5735c4a-1
                               ki18n5.92.0.r546.ga234e7c-15.92.0.r547.g525826a-1
                 kidentitymanagement21.12.2.1.r3878.g18ebd91c-121.12.2.1.r3879.g37726c07-1
                           kidletime5.92.0.r350.ge160ff5-15.92.0.r351.gcd50406-1
                                 kig21.12.2.1.r3178.g05a44120-121.12.2.1.r3179.g7bd68390-1
                            killbots21.12.2.1.r775.gc7689e9-121.12.2.1.r776.ga88a61c-1
                     kimagemapeditor21.12.2.1.r481.g0958da4-121.12.2.1.r482.g8c5307d-1
                               kimap21.12.2.1.r1180.gb89caab-121.12.2.1.r1182.gd0525ee-1
                         kinfocenter5.24.3.r2050.gf36eb08-15.24.4.r2053.gfde4c18-1
                                 kio5.92.0.r5370.g9b1a4f4df-15.92.0.r5382.g872f8ea2f-1
                          kio-extras21.12.2.1.r7209.g23baa544-121.12.2.1.r7216.g877da1c8-1
                          kio-gdrive21.12.2.1.r588.g88e9e0f-121.12.2.1.r592.g6b068bb-1
                        kipi-plugins21.12.2.1.r12081.g2be2c15b5-121.12.2.1.r12085.gaed78cb02-1
                     kirigami-addons 1:0.2.r23.gb0960c3-1 1:0.2.r25.g126a186-1
                    kirigami-gallery21.12.2.1.r233.g25d23b6-121.12.2.1.r235.g5bb850c-1
                           kirigami25.91.0.r3097.g3ccfae68-15.92.0.r3102.g83a27204-1
                              kiriki21.12.2.1.r445.g4fea4b8-121.12.2.1.r446.g03b4088-1
                               kiten21.12.2.1.r1179.g1b6dbb6-121.12.2.1.r1180.g59319a1-1
                          kitinerary21.12.2.1.r2121.gc83a6dc-121.12.2.1.r2133.g1a0b660-1
                         kjobwidgets5.92.0.r407.g97d433d-15.92.0.r408.g706f536-1
                        kjumpingcube21.12.2.1.r816.g2b61370-121.12.2.1.r818.g96aa656-1
                               kldap21.12.2.1.r940.g380159d-121.12.2.1.r941.gfdd3743-1
                           kleopatra21.12.2.1.r6316.g4a3594fa-121.12.2.1.r6320.g285677f0-1
                            klettres21.12.2.1.r952.ge165957-121.12.2.1.r953.g2a36e8f-1
                            klickety21.12.2.1.r664.g637824d-121.12.2.1.r666.g2f3840b-1
                              klines21.12.2.1.r800.g77d56ff-121.12.2.1.r802.geef7e01-1
                                kmag21.12.2.1.r724.gc1b1a98-121.12.2.1.r726.gce7ddf0-1
                           kmahjongg21.12.2.r1518.g3902c41-121.12.2.r1519.g6172833-1
                               kmail21.12.2.r26302.ge0595a63c-121.12.2.r26316.g4232d588a-1
                kmail-account-wizard21.12.2.1.r872.gf70ffd0-121.12.2.1.r873.g2edc296-1
                      kmailtransport21.12.2.1.r1719.g0381b22-121.12.2.1.r1721.ga805cc4-1
                               kmbox21.12.2.1.r586.g0d15501-121.12.2.1.r588.g364b8d0-1
                           kmenuedit5.24.3.r1022.gece35be-15.24.4.r1027.gf5d2457-1
                               kmime21.12.2.1.r1500.g8e5ce74-121.12.2.1.r1501.gabf00b2-1
                              kmines21.12.2.r1757.g3238863-121.12.2.r1759.g9eadbaa-1
                                kmix21.12.2.1.r2425.g4cc50d16-121.12.2.1.r2427.g582f076e-1
                          kmousetool21.12.2.1.r425.ga475e60-121.12.2.1.r427.g7f6dfb2-1
                              kmouth21.12.2.1.r709.g73997a0-121.12.2.1.r711.g4b51919-1
                              kmplot21.12.2.1.r1478.g3f9f8ba-121.12.2.1.r1479.g41ac6b0-1
                        knavalbattle21.12.2.1.r1420.g7f9b2c5-121.12.2.1.r1422.g977213f-1
                            knetwalk21.12.2.1.r688.gabadca9-121.12.2.1.r690.g0970c49-1
                           knewstuff5.92.0.r1311.gd235c280-15.92.0.r1312.g4afdaac2-1
                             knights21.12.2.1.r1114.g91a8ed5-121.12.2.1.r1116.gfc6d1a5-1
                              knotes21.12.2.r3612.gc2f19f7e-121.12.2.r3616.g991a5dfd-1
                                kolf21.12.2.1.r1480.gdfe6002-121.12.2.1.r1483.g6c8ac13-1
                           kollision21.12.2.1.r525.g7b19e18-121.12.2.1.r527.g086b93f-1
                         kolourpaint21.12.2.1.r2383.g95aec03e-121.12.2.1.r2384.gb1e116da-1
                             kompare21.12.2.1.r1126.g7538eb8-121.12.2.1.r1127.gbdfed31-1
                            kongress  22.02.r2.g16a3e3a-1  22.02.r3.g97ad69d-1
                           konqueror21.12.2.r15059.g72983faf0-121.12.2.r15063.gc4238fd7b-1
                            konquest21.12.2.1.r920.g8bdcd97-121.12.2.1.r922.g70d6dac-1
                             konsole21.12.2.r8322.g440d9d5c-121.12.2.r8324.g100199e3-1
                             kontact21.12.2.1.r5493.gd1e694f2-121.12.2.1.r5497.g78da9f4a-1
                    kontactinterface21.12.2.1.r670.g9e05aec-121.12.2.1.r672.g4f7f47e-1
                            kontrast21.12.2.1.r194.gb7b8fb0-121.12.2.1.r195.gfba2aa3-1
                        konversation21.12.2.1.r9094.g0768a83f-121.12.2.1.r9097.g235ef003-1
                              kopete21.12.2.1.r16410.ga31b1b21f-121.12.2.1.r16413.g914f0965e-1
                          korganizer21.12.2.r11647.g0fad3b3b9-121.12.2.r11662.gbbf857f49-1
                            kpackage5.92.0.r741.g57ba435-15.92.0.r742.g0c3503c-1
                              kparts5.92.0.r575.g6df8f08-15.92.0.r578.g5792035-1
                                kpat21.12.2.r2604.g8f7deaa-121.12.2.r2605.gb1afb1f-1
                         kpeoplesink       r77.g5d5e1b9-1       r78.g9a75f7b-1
                        kpimtextedit21.12.2.1.r1569.g91ea87a-121.12.2.1.r1572.g6b828a0-1
                             kpkpass21.12.2.1.r277.g7433acd-121.12.2.1.r280.gc70b770-1
                             kpmcore21.12.2.r1279.g5afe143-121.12.2.r1280.gd247e02-1
                                kpty5.92.0.r366.g96d7c84-15.92.0.r368.g71d8e44-1
                    kpublictransport21.12.1.r1985.g9ee1a6f8-121.12.1.r1986.gca05823d-1
                                krdc21.12.2.1.r1566.gf163967-121.12.2.1.r1568.g694e95f-1
                            kreversi21.12.2.1.r1257.g5b84251-121.12.2.1.r1260.g202d63b-1
                                krfb21.12.2.1.r1473.g4a6970d-121.12.2.1.r1475.g9b634ae-1
                              kruler21.12.2.1.r726.g8e2757e-121.12.2.1.r730.g1929aeb-1
                             krunner5.92.0.r739.g1ef7a4a-15.92.0.r741.g2fb490f-1
                             kscreen5.24.3.r1439.g769116f-15.24.4.r1443.g476e44e-1
                       kscreenlocker5.24.3.r912.g5516314-15.24.4.r917.ga90a9a9-1
                             kshisen21.12.2.1.r1232.g12d541a-121.12.2.1.r1233.g12d6444-1
                               ksirk21.12.2.1.r1013.ge8328b3-121.12.2.1.r1014.g824b0aa-1
                               ksmtp21.12.2.1.r427.ga93700b-121.12.2.1.r428.g834cdb9-1
                          ksnakeduel21.12.2.1.r838.gb96d956-121.12.2.1.r839.g7264cd7-1
                          kspaceduel21.12.2.1.r664.g592dac2-121.12.2.1.r665.gfb1045f-1
                            ksquares21.12.2.1.r551.g5dadded-121.12.2.1.r552.g2ea3532-1
                         ksshaskpass5.24.3.r206.g1412c4a-15.24.4.r206.g1412c4a-1
                             ksudoku21.12.2.1.r1096.g31990dd-121.12.2.1.r1099.g33e7235-1
                           ksysguard5.24.3.r3525.g02dc1395-15.24.4.r3525.g02dc1395-1
                          ksystemlog21.12.2.1.r710.g500b12b-121.12.2.1.r714.gf468d79-1
                        ksystemstats5.24.3.r219.g6fd7f37-15.24.4.r219.g6fd7f37-1
                            kteatime21.12.2.1.r742.gab083a6-121.12.2.1.r743.gfacb915-1
                         ktexteditor5.92.0.r3306.g5a7a895f-15.92.0.r3308.g7bd83826-1
                        ktextwidgets5.92.0.r440.g8805f06-15.92.0.r441.g9386521-1
                              ktimer21.12.2.1.r503.g44ffa16-121.12.2.1.r505.ge57b6a0-1
                               ktnef21.12.2.1.r710.g647dea9-121.12.2.1.r711.g81ba74b-1
                            ktorrent21.12.2.r2829.g56656946-121.12.2.r2832.gde64efd7-1
                              ktouch21.12.2.1.r2171.gc37d57d-121.12.2.1.r2172.g05b2fca-1
                               ktrip  22.02.r1.g3459a37-1  22.02.r4.g652977e-1
                          ktuberling21.12.2.1.r1033.g336409f-121.12.2.1.r1034.gac99858-1
                             kturtle21.12.2.1.r1156.g9b37d6e-121.12.2.1.r1157.gf039ae6-1
                             kwallet5.92.0.r1136.ge07c810-15.92.0.r1137.gf192163-1
                         kwallet-pam5.24.3.r264.g2da1635-15.24.4.r264.g2da1635-1
                      kwalletmanager21.12.2.1.r1262.g4eb6b7e-121.12.2.1.r1263.g8ae2d3f-1
                               kwave21.12.2.1.r3772.ga2066c56-121.12.2.1.r3775.g6f27a0d0-1
                kwayland-integration5.24.3.r199.gb05afab-15.24.4.r199.gb05afab-1
                     kwayland-server5.24.3.r1465.ge2f9315-15.24.4.r1466.gb1e8ac2-1
                            kweather 22.02.r12.g52c140d-1 22.02.r13.gac5a112-1
                      kwidgetsaddons5.92.0.r919.ga2a02ec2-15.92.0.r920.ga7853cf2-1
                                kwin5.24.3.r20992.g0aab6e3ee-15.24.4.r21014.gcba443dbe-1
                           kwordquiz21.12.2.r1174.g0a54f3e-121.12.2.r1175.ga103cbf-1
                              kwrite21.12.2.1.r18841.g130c10192-121.12.2.1.r18894.g9f8dcc2b7-1
                             kwrited5.24.3.r502.g7f4c59c-15.24.4.r502.g7f4c59c-1
                             kxmlgui5.92.0.r860.ga82076a6-15.92.0.r861.g24450bb5-1
                          libakonadi21.12.2.r12712.g054e7b167-121.12.2.r12715.gb764a86d5-1
                         libgravatar21.12.2.1.r413.ga97ac57-121.12.2.1.r414.g4e87355-1
                         libkdegames21.12.2.1.r2228.g651962ca-121.12.2.1.r2229.gafd6857e-1
                           libkdepim21.12.2.1.r897.gab3c82a-121.12.2.1.r898.g5efb1d7-1
                            libkgapi21.12.2.1.r1350.g8125534-121.12.2.1.r1352.ge1296a1-1
                             libkleo21.12.2.1.r1101.gf290218-121.12.2.1.r1102.g98af5bd-1
                        libkmahjongg21.12.2.1.r476.g8e13a4a-121.12.2.1.r477.g7ac6fdb-1
                            libksane21.12.2.1.r593.gc955840-121.12.2.1.r594.g38fbdb9-1
                          libkscreen5.24.3.r1620.g33b8ed6-15.24.4.r1620.g33b8ed6-1
                           libksieve21.12.2.1.r1680.g76cafbac-121.12.2.1.r1685.g94b52a9c-1
                        libksysguard5.24.3.r2383.g29af1b1-15.24.4.r2383.g29af1b1-1
                            lokalize21.12.2.1.r1813.g5ec185be-121.12.2.1.r1814.gd7d43f36-1
                          mailcommon21.12.2.1.r1211.g1313d37-121.12.2.1.r1213.g05b9671-1
                        mailimporter21.12.2.1.r510.g97367a7-121.12.2.1.r511.g730ca87-1
                     maliit-keyboard2.2.0.r17.gd8028731-12.2.0.r25.g06517b03-1
                              marble21.12.2.1.r13406.g396e4725d-121.12.2.1.r13408.gb5075f323-1
                       marble-common21.12.2.1.r13406.g396e4725d-121.12.2.1.r13408.gb5075f323-1
                           marble-qt21.12.2.1.r13406.g396e4725d-121.12.2.1.r13408.gb5075f323-1
                        markdownpart21.12.2.1.r104.g2e9782a-121.12.2.1.r106.g0480ace-1
                           maui-nota 2.1.1.r12.g9b66b49-1 2.1.1.r14.g752ebb0-1
                            maui-pix 2.1.0.r13.gaa91a6e-1 2.1.0.r14.g5c5fc16-1
                          maui-shell       r169.e370183-1 v0.5.0.r0.g61ae7f2-1
                             mauikit2.1.1.r12.g58004ea5-12.1.1.r13.g44cabb15-1
                    mauikit-accounts  2.1.1.r0.g30326de-1  2.1.1.r1.g0efebb4-1
                mauikit-filebrowsing  2.1.1.r0.gaca5421-1  2.1.1.r1.gf63bf6e-1
                  mauikit-imagetools  2.1.1.r0.g6da2624-1  2.1.1.r1.g184168a-1
                  mauikit-texteditor  2.1.1.r1.ga6eec0f-1  2.1.1.r2.gc77ec41-1
                       mbox-importer21.12.2.1.r558.g549e240-121.12.2.1.r559.ged55947-1
                          messagelib21.12.1.r6447.g5969e2c80-121.12.1.r6463.g12b2699e1-1
                               milou5.24.3.r764.g8118e8d-15.24.4.r764.g8118e8d-1
                     modemmanager-qt5.92.0.r549.g2be3452-15.92.0.r550.g2110a7b-1
             mycroft-skill-installer        r87.d2f2a47-1        r88.72bb7ab-1
                             neochat22.02.r34.ga747d44c-122.02.r36.g1cc8d915-1
                   networkmanager-qt5.92.0.r1144.g4f667f3-15.92.0.r1148.gf3abb2e-1
                              okular21.12.2.1.r9669.g64676e6ff-121.12.2.1.r9687.g8c31962e8-1
                              oxygen5.24.3.r4451.gbf4888d5-15.24.4.r4454.g8db0682e-1
                   pim-data-exporter21.12.2.r2584.g3df2c281-121.12.2.r2585.gbdf0218b-1
                    pim-sieve-editor21.12.2.r1599.g750117c-121.12.2.r1606.g42195a9-1
                           pimcommon21.12.2.r1207.g7d2abd9-121.12.2.r1210.gb107f8d-1
                    plasma-bigscreen      r454.gbb5b1f2-1      r457.g6503645-1
          plasma-browser-integration5.24.3.r1306.ga3e8e7a6-15.24.4.r1308.gdb24643d-1
                       plasma-camera  1.0.r115.g563b83d-1  1.0.r116.g4f4d9b2-1
                      plasma-desktop5.24.3.r9145.g42480e30a-15.24.4.r9166.g7a94a8239-1
                       plasma-dialer 22.02.r18.g28d4489-1 22.02.r20.g7b7062a-1
                        plasma-disks5.24.3.r263.gbb53c25-15.24.4.r266.gede83b6-1
                     plasma-firewall5.24.3.r606.g8b971ef-15.24.4.r608.gcb5f0e0-1
                    plasma-framework5.92.0.r16220.g47ad0a574-15.92.0.r16226.gd74a8286e-1
                  plasma-integration5.24.3.r553.gaeb3dfb-15.24.4.r557.g2b406a9-1
                       plasma-mobile5.24.3.r1686.g5f20862a3-15.24.4.r1689.g7e53aab27-1
                    plasma-mobile-nm5.24.3.r3220.gc6ab31b8-15.24.4.r3228.gaee1498f-1
                         plasma-nano5.24.3.r176.gf4a6251-15.24.4.r177.g8992514-1
                           plasma-nm5.24.3.r3220.gc6ab31b8-15.24.4.r3228.gaee1498f-1
                           plasma-pa5.24.3.r1035.g57b0485-15.24.4.r1037.g5c8f126-1
                          plasma-sdk5.24.3.r2335.g12d81677-15.24.4.r2338.g1187d73e-1
                     plasma-settings 22.02.r22.gec38ae4-1 22.02.r23.g34aaaa3-1
                plasma-systemmonitor5.24.3.r556.g920acfb-15.24.4.r558.g96976cf-1
                  plasma-thunderbolt5.24.3.r182.ga89df5b-15.24.4.r183.g022c70c-1
                        plasma-vault5.24.3.r377.g8cf0264-15.24.4.r378.g38603f5-1
              plasma-wayland-session5.24.3.r11591.g460a6485b-15.24.4.r11612.g4eb900ae6-1
                    plasma-workspace5.24.3.r11591.g460a6485b-15.24.4.r11612.g4eb900ae6-1
         plasma-workspace-wallpapers5.24.3.r334.g709fbae-15.24.4.r334.g709fbae-1
                          plasmatube  22.02.r8.gea4bed0-1  22.02.r9.gaafb938-1
                    polkit-kde-agent5.24.3.r518.gff0264d-15.24.4.r518.gff0264d-1
                          powerdevil5.24.3.r2527.g4c031ac8-15.24.4.r2527.g4c031ac8-1
                       print-manager21.12.2.r1113.g12ba07c-121.12.2.r1117.g3cebb72-1
                             purpose5.91.0.r955.g9cbacaf7-15.92.0.r957.gc4beb3d8-1
                         qcachegrind21.12.2.1.r1172.gb144e21-121.12.2.1.r1174.g535da9f-1
                   qqc2-breeze-style5.24.3.r242.g5a20abd-15.24.4.r242.g5a20abd-1
                                rocs21.12.2.1.r3061.g74b5c362-121.12.2.1.r3068.g727c9976-1
                            sddm-kcm5.24.3.r645.g9b7062d-15.24.4.r645.g9b7062d-1
                               solid5.92.0.r761.gd95067c-15.92.0.r762.g6b0ae19-1
                            spacebar22.02.2.r14.g1d90ebe-122.02.2.r18.gbfa09f1-1
                           spectacle21.12.2.1.r1316.g6b0733a-121.12.2.1.r1318.g1f864a1-1
                                step21.12.2.1.r1175.g801f4db-121.12.2.1.r1176.g392ec82-1
                             svgpart21.12.2.1.r210.g5612f01-121.12.2.1.r211.ga933290-1
                      systemsettings5.24.3.r2635.g46b54f32-15.24.4.r2639.geaa5505f-1
      telepathy-kde-common-internals21.12.2.1.r2005.g14c7889-121.12.2.1.r2007.g5e1b8b1-1
    telepathy-kde-integration-module21.12.2.1.r396.g5b8dc56-121.12.2.1.r397.g797a0ab-1
               telepathy-kde-text-ui21.12.2.1.r2034.gfc0acdc-121.12.2.1.r2035.g60f7371-1
                            umbrello21.12.2.r8428.ga1cb29f22-121.12.2.r8433.g41a11789e-1
              xdg-desktop-portal-kde5.24.3.r444.g1011a69-15.24.4.r446.g9cad776-1
                             yakuake21.12.2.1.r776.g5b8b334-121.12.2.1.r778.g9fe5ff2-1
                    zeroconf-ioslave21.12.2.1.r372.g187b338-121.12.2.1.r373.g63ff6d3-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Old Issues
Plasma Dialer cannot answer calls
Sadly Plasma Dialer 22.02 has a serious regression with no known workaround. It’s not possible to accept incoming calls. Very sorry about this. Follow the upstream bug report. We will patch the package as soon as a solution is found.
Plasma Mobile - Black screen after update
We are seeing some reports about Plasma Mobile on the PinePhone only showing a black screen after entering the PIN after this update.
Workaround: Downgrade qt5-es2-wayland to 5.15.2+kde+r41 which is now back in Stable and Testing branch repositories.
New Breath theme not applying correctly
With the update to the new Breath theme, a migration package tries to apply the new theme correctly.
However this is not getting done for Plasma’s Lockscreen and the SDDM theme.
So please go through your settings after updating to make sure the themes are correctly applied.
Fix: manjaro-system should take care of this for you.
Plasma Mobile switch to ModemManager
With the PlaMo Gear 21.12 release, Plasma Mobile is now using ModemManager as the telephony stack. So in order to use SIM capabilities, you need to switch from using oFono to ModemManager.
Fix: Run sudo systemctl disable --now ofono ofonoctl && sudo systemctl enable --now ModemManager. You might have to reboot your phone for Plasma Mobile to pick up this change.
Plasma Mobile has does not launch after update
This was caused by an error in kwin 5.23.2 which only affects installs based on openGLES (qt5-es2).
Fix: Update to kwin 5.23.2-1.2 or above.
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Hi,
I tried to build an LXQt image for the Odroid N2, something go wrong, a package is missing from the repo
[nls@lap ~]$ sudo buildarmimg -d on2 -e lxqt -v 2022.04.06 -b testing -n
error: target not found: qpdfview
[nls@lap ~]$
The solution ? My LXQt build conf file is now looking so,
qterminal
#qpdfview
openbox
Hm. Seems qpdfview was part of the spring cleaning in Arch and it has been moved to the AUR. Will adjust the profile.
Thanks for your reply.
To the AUR it’s a regression.
Is it temporally or definitive ?
Likely definitive. I don’t see any indication as to why it was moved, so I guess it’s part of the spring cleaning they do.
