[ARM Testing Update] 2022-03-28 - Certbot, Signal-Desktop and kernels
Hello ARM community.
Small batch this time, but we did get kernel 5.17 now.
Some highlights:
  • Most of our kernels got updated
  • Gnome updated to 41.5
  • And Firefox updated to 98.0.2
  • Mainline Linux updated to 5.17
  • And Certbot updated to 1.25
  • Amazfish updated to 2.0.5
  • Signal-Desktop updated to 5.36
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Mon Mar 28 20:51:22 CEST 2022)
  • arm-testing community aarch64: 384 new and 372 removed package(s)
  • arm-testing core aarch64: 39 new and 40 removed package(s)
  • arm-testing extra aarch64: 339 new and 323 removed package(s)
  • arm-testing kde-unstable aarch64: 272 new and 272 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2022-03-18         2022-03-28
                            amazfish              2.0.3-1              2.0.5-1
                          callaudiod  0.1.3+12+g4a92e48-4              0.1.4-1
                              chatty              0.6.2-1  0.6.2+9+ge2f4ed16-1
                            electron             17.1.2-1             17.2.0-1
                          electron14             14.2.7-1             14.2.8-1
                          electron15             15.4.1-1             15.4.2-1
                          electron16             16.1.0-1             16.1.1-1
                     element-desktop             1.10.7-1             1.10.8-1
                         element-web             1.10.7-1             1.10.8-1
                                phoc 0.12.0+65+g7f5d225-2  0.13.0+1+gb0ae098-1
                               phosh 0.16.0+12+g54b1045-2  0.17.0+1+g1c6d6cf-1
              portfolio-file-manager             0.9.13-1             0.9.14-1
                         powersupply              0.5.0-2              0.6.0-1
                   rpi4-post-install           20220221-1           20220326-1
                      signal-desktop             5.35.0-1             5.36.0-1
                               snapd             2.54.4-1             2.55.2-1
:: Different sync package(s) in repository community aarch64
                          aliyun-cli            3.0.111-1            3.0.113-1
                        ansible-lint              5.4.0-1              6.0.2-3
                 appstream-generator              0.8.7-1              0.8.7-2
                              argocd              2.3.1-1              2.3.2-1
                               arrow              6.0.1-6              6.0.1-7
                          authoscope              0.8.0-1              0.8.1-1
                        avisynthplus            3.7.1.a-1              3.7.2-1
                          babel-core             7.17.5-1             7.17.8-1
                               biber             1:2.16-1             1:2.17-1
                          bootconfig               5.16-1               5.17-1
                                 bpf               5.16-1               5.17-1
                            calcurse              4.7.1-1              4.7.1-2
                             calibre             5.38.0-1             5.39.1-1
                       cargo-nextest             0.9.11-1             0.9.12-1
                           cargo-pgx              0.4.0-1              0.4.1-1
                    cargo-spellcheck             0.10.1-1             0.11.0-1
                  cargo-supply-chain              0.2.0-2              0.3.1-1
                             certbot             1.23.0-1             1.25.0-1
                      certbot-apache             1.19.0-2             1.25.0-1
              certbot-dns-cloudflare             1.19.0-2             1.25.0-1
                certbot-dns-cloudxns             1.19.0-2             1.25.0-1
            certbot-dns-digitalocean             1.19.0-2             1.25.0-1
                certbot-dns-dnsimple             1.19.0-2             1.25.0-1
             certbot-dns-dnsmadeeasy             1.19.0-2             1.25.0-1
                  certbot-dns-gehirn             1.19.0-2             1.25.0-1
                  certbot-dns-google             1.19.0-2             1.25.0-1
                  certbot-dns-linode             1.19.0-2             1.25.0-1
                  certbot-dns-luadns             1.19.0-2             1.25.0-1
                   certbot-dns-nsone             1.19.0-2             1.25.0-1
                     certbot-dns-ovh             1.19.0-2             1.25.0-1
                 certbot-dns-rfc2136             1.18.0-2             1.25.0-1
                 certbot-dns-route53             1.19.0-2             1.25.0-1
             certbot-dns-sakuracloud             1.19.0-2             1.25.0-1
                       certbot-nginx             1.19.0-2             1.25.0-1
                                cgns              4.2.0-2              4.3.0-2
               cgroup_event_listener               5.16-1               5.17-1
                               clash              1.9.0-1             1.10.0-1
                             clojure        1.10.3.1087-1        1.10.3.1093-1
                          containerd              1.6.1-1              1.6.2-1
                            copr-cli               1.98-1               1.99-1
                            cppcheck                2.7-1              2.7.4-1
                            cpupower               5.16-1               5.17-1
                                crun              1.4.3-1              1.4.4-1
                                ctop              0.7.6-1              0.7.7-1
                           cuneiform             1.1.0-21             1.1.0-22
                              dbmate             1.14.0-1             1.15.0-1
                          diffoscope                207-1                208-1
                              direnv             2.30.3-1             2.31.0-1
                                 dnf             4.10.0-2             4.11.1-1
                         dns-lexicon              3.9.1-1              3.9.2-1
                              docker         1:20.10.13-1         1:20.10.14-1
                      docker-compose              2.3.3-1              2.3.4-1
                             doctest              2.4.6-1              2.4.7-1
                             dua-cli             2.16.0-1             2.17.1-1
                            electrum              4.1.5-2              4.2.0-1
                              elvish             0.17.0-1             0.18.0-1
                              erlang               24.3-1             24.3.2-1
                     erlang-unixodbc               24.3-1             24.3.2-1
                            feeluown              3.8.2-1              3.8.3-1
                    feeluown-qqmusic                0.4-1              0.4.1-1
                           fetchmail             6.4.28-1             6.4.29-1
                    firefox-noscript             11.3.2-1             11.4.1-1
                   firefox-tridactyl             1.22.0-1             1.22.1-1
                              flake8            1:4.0.1-3            1:4.0.1-4
                                giac           1.7.0.51-1           1.7.0.53-1
                              girara              0.3.6-1              0.3.7-1
                               gitea            1.15.11-1             1.16.5-1
                           glusterfs             1:10.0-3             1:10.1-1
                               go-yq             4.22.1-1             4.23.1-1
                              gopass             1.13.1-1             1.14.0-1
                               gping              1.3.0-1              1.3.1-1
                          gpio-utils               5.16-1               5.17-1
                                grpc             1.43.2-1             1.45.0-1
                            grpc-cli             1.43.2-1             1.45.0-1
                          gwakeonlan              0.7.0-3              0.8.0-1
                          gwenhywfar            5.8.2-1.1              5.9.0-1
                           highlight                4.1-1                4.2-1
                       highlight-gui                4.1-1                4.2-1
                            himalaya              0.5.9-1             0.5.10-1
                                hugo             0.94.2-1             0.95.0-1
                          hyperkitty              1.3.5-3              1.3.5-4
                              hyperv               5.16-1               5.17-1
                               iaito              5.3.1-35.5beta0.r16.g24a2eba2-1
                           iio-utils               5.16-1               5.17-1
                                 iwd               1.25-1               1.26-1
                                jake             10.8.2-1             10.8.3-1
                         jami-daemon           20220209-3           20220317-1
                      jami-libclient           20220207-1           20220317-1
                             jami-qt           20220211-1           20220317-2
                             jenkins              2.339-1              2.340-1
                       jitterentropy              3.3.1-2              3.4.0-1
                                jmol           14.32.38-1           14.32.42-1
                               jruby            9.3.3.0-1            9.3.4.0-1
                               jsmol           14.32.38-1           14.32.42-1
                                just              1.0.1-1              1.1.0-1
                            kalendar              1.0.0-1                    -
                           keepassxc              2.6.6-1              2.7.0-2
                               kicad              6.0.3-1              6.0.4-1
                    kicad-library-3d              6.0.3-1              6.0.4-1
                       kicad-library              6.0.3-1              6.0.4-1
                       kiwix-desktop              2.2.1-1              2.2.1-2
                         kiwix-tools              3.2.0-2              3.2.0-3
                       knot-resolver              5.4.4-1              5.5.0-1
                             libcgif              0.2.0-1              0.2.1-1
                              libdnf             0.65.0-1             0.66.0-1
                            libkiwix             10.0.1-1             10.1.0-1
                              liblas1.8.1.r120+ge12742f4-81.8.1.r127+ge6a1aaed-1
                        libmemcached             1.0.18-4                    -
                              libnfc              1.8.0-1              1.8.0-2
                        libsecp256k120211017+1410+g9526874-220220317+1581+ge0508ee-1
                    linux-tools-meta               5.16-1               5.17-1
                                lout               3.42-1             3.42.1-1
                          lua-socket           20200329-1            1:3.0.0-1
                        lua51-socket           20200329-1            1:3.0.0-1
                        lua52-socket           20200329-1            1:3.0.0-1
                        lua53-socket           20200329-1            1:3.0.0-1
                              luajit2.1.0.beta3.r391.g8b8304f1-12.1.0.beta3.r395.ge2c312e0-1
                 lychee-link-checker              0.8.2-1              0.9.0-1
                                 mac               7.22-1               7.51-1
                        matterbridge             1.24.0-1             1.24.1-1
                                  mc             4.8.27-2             4.8.28-1
                               mcfly             0.5.13-1              0.6.0-1
                         meilisearch             0.26.0-1             0.26.1-1
                              miller              6.1.0-1              6.2.0-1
                           mitmproxy              7.0.4-2              8.0.0-1
                              mumble            1.4.230-3            1.4.230-4
                              murmur            1.4.230-3            1.4.230-4
                                mypy              0.931-2              0.942-1
                              ndisc6              1.0.4-2              1.0.5-1
                             nerdctl             0.17.1-2             0.18.0-1
                      netcdf-fortran              4.5.3-2              4.5.4-1
                      netcdf-openmpi              4.8.1-1              4.8.1-2
                            newsboat               2.26-1               2.27-1
                           nextcloud             23.0.2-1             23.0.3-1
              nextcloud-app-calendar            1:3.2.1-1            1:3.2.2-1
              nextcloud-app-contacts              4.0.8-1              4.1.0-1
                nextcloud-app-spreed           1:13.0.3-1           1:13.0.4-1
                 nextcloud-app-tasks             0.14.2-2             0.14.4-1
                    nextcloud-client            2:3.4.3-2            2:3.4.4-2
     nextcloud-client-cloudproviders            2:3.4.3-2            2:3.4.4-2
                           nicotine+              3.2.1-1              3.2.2-1
                              nodejs             17.7.1-1             17.8.0-1
                   nodejs-lts-erbium           12.22.10-1           12.22.11-1
                  nodejs-lts-fermium            14.19.0-1            14.19.1-1
                  nodejs-lts-gallium            16.14.1-1            16.14.2-1
                                 npm              8.5.4-1              8.5.5-1
                   npm-check-updates             12.5.3-1             12.5.4-1
                             nushell             0.44.0-1             0.60.0-1
                                 oil              0.9.8-1              0.9.9-1
                              opencc              1.1.2-3              1.1.3-1
                          opencc-doc              1.1.2-3              1.1.3-1
                             opendht            1:2.3.2-1            1:2.3.5-2
                             osbuild                 52-4                 53-1
                    otf-font-awesome              6.0.0-1              6.1.1-1
                       pantheon-code              6.1.0-2              6.1.0-3
                            parallel           20220222-1           20220322-1
                       parallel-docs           20220222-1           20220322-1
                                perf               5.16-1               5.17-1
                     perl-b-keywords               1.23-1               1.24-1
                 perl-ppix-quotelike              0.019-1              0.020-1
                    perl-ppix-regexp              0.082-1              0.083-1
                            php-grpc             1.43.2-1             1.45.0-1
                       php-memcached 3.1.5.r50.gd3b8ce1-1              3.2.0-1
                         php-mongodb             1.12.1-1             1.13.0-1
                           php7-grpc             1.43.2-1             1.45.0-1
                      php7-memcached 3.1.5.r50.gd3b8ce1-1              3.2.0-1
                        php7-mongodb             1.12.1-1             1.13.0-1
                     pnetcdf-openmpi             1.12.2-2             1.12.3-1
                           postorius              1.3.6-2              1.3.6-3
                            powerdns              4.6.0-1              4.6.1-1
                   powerdns-recursor              4.6.0-3              4.6.1-1
                            prettier              2.6.0-1              2.6.1-1
                             prosody          1:0.11.13-1           1:0.12.0-1
                             pyright            1.1.230-1            1.1.232-1
                         python-acme             1.23.0-1             1.25.0-2
                      python-aiorpcx             0.18.7-3             0.22.0-1
               python-ansible-compat              2.0.0-1              2.0.2-1
                  python-argcomplete             1.12.3-1              2.0.0-1
                      python-astroid             2.11.0-1             2.11.2-1
                     python-autobahn             22.2.2-1             22.3.1-1
                      python-awkward              1.7.0-1              1.8.0-2
                       python-behave         1.2.7.dev1-3         1.2.7.dev2-1
                        python-blosc             1.10.6-3             1.10.6-4
                   python-bottleneck              1.3.2-5              1.3.4-1
                    python-braintree             4.13.1-1             4.14.0-1
                       python-cftime              1.5.1-3              1.6.0-1
                 python-cloudscraper             1.2.58-4             1.2.60-1
                         python-copr              1.115-1              1.116-1
         python-cryptography-vectors             36.0.1-1             36.0.2-1
                         python-dask          2021.10.0-3          2022.03.0-1
                      python-debugpy              1.5.1-3              1.6.0-1
                  python-distributed          2021.10.0-3          2022.03.0-1
              python-django-haystack              3.1.1-3              3.1.1-4
              python-django-mailman3              1.3.7-3              1.3.7-4
                         python-docs             3.10.1-1             3.10.4-1
                       python-dotenv             0.19.2-3             0.20.0-1
                      python-dulwich            0.20.34-1            0.20.35-1
                  python-easyprocess                0.3-5                1.1-1
                  python-entrypoint2              0.2.4-3                1.0-1
                        python-fiona             1.8.20-6             1.8.21-1
           python-flask-security-too              4.0.1-4              4.1.3-1
                    python-fonttools             4.30.0-1             4.31.2-1
                       python-fsspec          2021.10.1-3          2022.02.0-1
              python-google-api-core              2.5.0-1              2.7.1-1
     python-google-api-python-client             2.37.0-1             2.42.0-1
                     python-graphviz               0.19-2             0.19.1-1
                       python-grpcio             1.43.2-1             1.45.0-1
                       python-hunter              3.4.1-1              3.4.2-1
                     python-identify             2.4.11-1             2.4.12-1
              python-internetarchive              2.3.0-1              3.0.0-1
                        python-jinja              3.0.3-3            1:3.0.3-1
                       python-josepy             1.12.0-1             1.13.0-2
            python-jupyter_packaging             0.11.1-3             0.12.0-2
                         python-krb5              0.1.2-3              0.3.0-1
                      python-libtmux             0.10.3-1             0.11.0-1
                         python-lmdb              1.2.1-3              1.3.0-1
                    python-lsp-black              1.0.1-1              1.1.0-1
                   python-lsp-server              1.3.2-2              1.4.0-1
                  python-mongoengine             0.23.1-4             0.24.0-1
                      python-netcdf4              1.5.7-4              1.5.8-1
              python-netcdf4-openmpi              1.5.7-4              1.5.8-1
                        python-odfpy              1.4.1-6              1.4.2-1
                     python-openmdao             3.14.0-1             3.15.0-1
                     python-oscrypto              1.2.1-5              1.3.0-2
                     python-oslo-log              4.6.1-3              4.7.0-1
                     python-pdfminer           20201018-5           20220319-1
                       python-peewee             3.14.8-4            3.14.10-1
                      python-pikepdf              5.0.1-1              5.1.0-1
                       python-pipenv           2022.1.8-2          2022.3.24-1
                      python-pkginfo              1.7.1-3              1.8.2-1
                       python-pluggy             0.13.1-8              1.0.0-1
                  python-prettytable              2.2.1-1              2.3.0-1
                    python-pycountry            22.1.10-2             22.3.5-1
                       python-pygit2              1.9.0-2              1.9.1-1
                     python-pyspnego              0.2.0-5              0.5.1-1
                     python-pytables              3.7.0-1              3.7.0-2
                   python-pytest-mpi                0.5-3                0.6-1
                 python-pytest-order              1.0.0-3              1.0.1-1
               python-pytest-timeout              2.0.2-1              2.1.0-1
                      python-pytools           2022.1.1-1           2022.1.2-1
                         python-pytz             2021.3-4             2022.1-1
             python-pyvirtualdisplay                2.2-2                3.0-1
                    python-pywlroots            0.15.10-1            0.15.11-1
                    python-qtawesome              1.0.3-3              1.1.0-1
                         python-qtpy             1.11.2-3              2.0.1-1
              python-readme-renderer               32.0-1               34.0-1
                        python-redis              4.0.0-1              4.0.1-1
                    python-reportlab              3.6.6-1              3.6.9-1
                    python-responses             0.19.0-1             0.20.0-1
                         python-rich             11.2.0-1             12.0.1-1
                 python-scikit-build             0.13.1-1             0.13.1-2
                  python-smbprotocol              1.7.0-3              1.9.0-1
                    python-sphobjinv              2.2.1-1              2.2.2-1
               python-spyder-kernels              2.2.0-2              2.2.1-2
                   python-sqlalchemy             1.4.30-1             1.4.32-1
                  python-statsmodels             0.13.2-1             0.13.2-2
                        python-sympy               1.10-1             1.10.1-1
                         python-tqdm             4.63.0-1             4.63.1-1
                       python-uproot              4.2.0-1              4.2.2-1
                  python-uproot-docs              4.2.0-1              4.2.2-1
                       python-vector              0.8.4-1              0.8.5-2
                     python-waitress              2.1.0-1              2.1.1-1
                       python-xapian           1:1.4.18-3           1:1.4.19-1
                       python-xarray             0.20.1-3          2022.03.0-1
                         python-zict              2.0.0-5              2.1.0-1
                 python-zope-testing                4.9-4               4.10-1
                                pyzo             4.12.0-1             4.12.3-1
                         qbittorrent              4.4.1-1              4.4.2-1
                     qbittorrent-nox              4.4.1-1              4.4.2-1
                                qcad           3.27.1.6-3           3.27.1.8-1
                                qgis             3.24.0-1             3.24.1-1
                            qpwgraph              0.2.3-1              0.2.4-1
                               qtile             0.20.0-1             0.21.0-1
                            r2ghidra              5.4.1-2 5.6.2.r1.ga4ba1ddc-1
                             radare2              5.4.2-1              5.6.6-3
                             rathole              0.4.0-1              0.4.0-2
                              rclone             1.57.0-2             1.58.0-1
                              recoll             1.31.2-2             1.32.0-1
                              restic             0.12.1-2             0.13.0-1
                                rink              0.6.2-2              0.6.3-1
                               rnote              0.3.5-1              0.4.0-1
                          ruby-cairo             1.17.5-6             1.17.5-7
                     ruby-concurrent              1.1.9-1             1.1.10-1
                       ruby-zeitwerk              2.5.3-1              2.5.4-1
                       rust-analyzer           20220314-1           20220321-1
                          rustypaste              0.6.5-2              0.7.0-1
                           seamonkey            2.53.11-1          2.53.11.1-1
                          serverless              3.7.5-1              3.8.0-1
                             sha3sum              1.2.1-1              1.2.2-1
                              solaar              1.1.1-1              1.1.2-2
                        sound-gambit                0.6-1                0.7-1
               spirv-llvm-translator             13.0.0-113.0.0.r24+gf1372c87-1
                              spyder              5.2.0-2              5.2.2-1
                            sqlfluff             0.11.0-1             0.11.2-1
                            starship              1.4.2-1              1.5.4-1
                          strawberry              1.0.2-1              1.0.3-1
                           stylelint             14.6.0-1             14.6.1-1
                              stylus             0.56.0-1             0.57.0-1
                             tachyon             0.99.3-2             0.99.4-1
                           tailscale             1.22.1-1             1.22.2-1
                     taskwarrior-tui             0.20.1-1             0.22.0-1
                                tcsh            6.24.00-1            6.24.00-2
                   teensy-loader-cli                2.2-1                    -
                                tmon               5.16-1               5.17-1
                               tmuxp              1.9.4-1             1.10.0-1
                         tpm2-pkcs11              1.7.0-3              1.8.0-1
                         ttc-iosevka             15.0.2-1             15.0.3-1
                    ttc-iosevka-aile             15.0.2-1             15.0.3-1
                   ttc-iosevka-curly             15.0.2-1             15.0.3-1
              ttc-iosevka-curly-slab             15.0.2-1             15.0.3-1
                  ttc-iosevka-etoile             15.0.2-1             15.0.3-1
                    ttc-iosevka-slab             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss01             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss02             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss03             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss04             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss05             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss06             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss07             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss08             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss09             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss10             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss11             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss12             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss13             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss14             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss15             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss16             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss17             15.0.2-1             15.0.3-1
                    ttc-iosevka-ss18             15.0.2-1             15.0.3-1
                    ttf-font-awesome              6.0.0-1              6.1.1-1
                   ttf-sarasa-gothic             0.36.0-1             0.36.2-1
                          typescript              4.6.2-1              4.6.3-1
                            umockdev             0.17.7-1             0.17.8-1
                               usbip               5.16-1               5.17-1
         v2ray-domain-list-community     20220313173740-1     20220325131800-1
                         v2ray-geoip       202203100039-1       202203250919-1
                            valabind              1.8.0-2              1.8.0-3
                     vaultwarden-web             2.26.1-1             2.27.0-1
                               vigra1.11.1.r45+g8acd73a5-61.11.1.r67+g093d57d1-1
                        vim-himalaya              0.5.9-1             0.5.10-1
                                 vtk             9.1.0-10             9.1.0-12
                           watchexec             1.18.8-1            1.18.10-1
                              wcslib                7.7-1                7.9-1
                             web-ext              6.7.0-1              6.8.0-1
                             weechat              3.4.1-1                3.5-1
                             wezterm20220101.133340.7edc5b5a-120220319.142410.0fcdea07-1
                       wireshark-cli              3.6.2-1              3.6.3-1
                        wireshark-qt              3.6.2-1              3.6.3-1
                        wl-clipboard            1:2.0.0-3            1:2.1.0-1
                           wordpress              5.9.1-1              5.9.2-1
                           wxsqlite3              4.7.3-1              4.7.8-1
                yaml-language-server              1.5.1-1              1.6.0-1
                                 yaz             5.31.0-2             5.31.1-1
                             zathura              0.4.8-1              0.4.9-1
                   zathura-pdf-mupdf              0.3.7-1              0.3.8-1
                               bacon                    -              2.1.0-1
                             bibtool                    -               2.68-5
                            buildkit                    -             0.10.0-1
                               cli11                    -              2.1.2-1
                       gitlab-runner                    -             14.9.1-1
                libmemcached-awesome                    -              1.1.1-1
                            luacheck                    -             0.26.0-2
                        python-hatch                    -             0.23.1-1
                    python-hatchling                    -             0.21.1-2
                     python-pyqrcode                    -              1.2.1-5
                   python-tpm2-pytss                    -              1.0.0-3
                         rootlesskit                    -              1.0.0-1
                       schemacrawler                    -           16.16.12-1
                   teensy_loader_cli                    -                2.2-2
                              vkmark                    -           20220318-1
:: Different overlay package(s) in repository core aarch64
                               linux            5.16.15-2             5.17.1-2
               linux-clockworkpi-a06            5.16.15-1             5.17.1-1
       linux-clockworkpi-a06-headers            5.16.15-1             5.17.1-1
                       linux-headers            5.16.15-2             5.17.1-2
                        linux-khadas            5.16.11-1            5.16.17-1
                linux-khadas-headers            5.16.11-1            5.16.17-1
                           linux-lts            5.15.29-1            5.15.32-1
                   linux-lts-headers            5.15.29-1            5.15.32-1
                        linux-odroid             5.16.4-3            5.16.16-1
                linux-odroid-headers             5.16.4-3            5.16.16-1
                     linux-pinephone            5.16.16-1             5.17.1-1
             linux-pinephone-headers            5.16.16-1             5.17.1-1
                  linux-pinephonepro            5.16.16-1             5.17.1-1
          linux-pinephonepro-headers            5.16.16-1             5.17.1-1
                            linux-rc           5.17.rc8-3           5.17.rc8-4
                    linux-rc-headers           5.17.rc8-3           5.17.rc8-4
                          linux-rpi4            5.15.28-1            5.15.30-1
                  linux-rpi4-headers            5.15.28-1            5.15.30-1
                 linux-rpi4-mainline            5.16.14-1             5.17.0-1
         linux-rpi4-mainline-headers            5.16.14-1             5.17.0-1
                  uboot-pinephonepro       4:2022.04rc4-2       4:2022.04rc4-4
                       boot-gsking-x                    -            2022.03-1
:: Different sync package(s) in repository core aarch64
                              cronie              1.5.7-2              1.6.0-2
                                  gc              8.2.0-2              8.2.0-3
                               glib2             2.70.4-2             2.72.0-1
                          glib2-docs             2.70.4-2             2.72.0-1
                              gnutls              3.7.3-1              3.7.4-1
                            iproute2             5.16.0-1             5.17.0-1
              libnetfilter_conntrack              1.0.8-1              1.0.9-1
                  libsysprof-capture             3.42.1-3                    -
                              man-db             2.10.1-1             2.10.2-1
                              netctl               1.27-1               1.28-1
                   openssl-cryptodev            1.1.1.m-1            1.1.1.n-1
                              python             3.10.2-1             3.10.4-1
                        python-tests             3.10.2-1             3.10.4-1
                             sysprof             3.42.1-3                    -
                             systemd              250.4-1              250.4-2
                        systemd-libs              250.4-1              250.4-2
                  systemd-resolvconf              250.4-1              250.4-2
                  systemd-sysvcompat              250.4-1              250.4-2
                              tzdata              2021e-1              2022a-1
:: Different overlay package(s) in repository extra aarch64
                           calamares             3.2.53-1             3.2.54-1
                          elisa-qtmm            21.12.2-1            21.12.3-1
                 manjaro-chrootbuild      r265.gd6558f7-1      r272.g9badf29-1
                            mesa-git22.1.0_devel.151051.177805cc03e-122.1.0_devel.151648.ae710f33296-1
              network-manager-applet             1.24.0-1                    -
                nm-connection-editor             1.24.0-1                    -
                   libva-mesa-driver                    -           21.3.7-2.1
                                mesa                    -           21.3.7-2.1
                          mesa-vdpau                    -           21.3.7-2.1
                         opencl-mesa                    -           21.3.7-2.1
                     vulkan-broadcom                    -           21.3.7-2.1
                  vulkan-mesa-layers                    -           21.3.7-2.1
                     vulkan-panfrost                    -           21.3.7-2.1
                       vulkan-radeon                    -           21.3.7-2.1
                       vulkan-swrast                    -           21.3.7-2.1
:: Different sync package(s) in repository extra aarch64
                            alacarte           1:3.42.0-2           1:3.44.1-1
                        alertmanager             0.23.0-3             0.24.0-1
                              apache             2.4.52-1             2.4.53-1
                        archboot-arm           2022.03-20           2022.03-48
            archlinux-appstream-data         20220211-1.1           20220327-1
                        at-spi2-core             2.42.0-1             2.44.0-2
                                 atk             2.36.0-1             2.38.0-1
                                bird              2.0.8-3              2.0.9-2
                               bluez               5.64-1               5.64-2
                          bluez-cups               5.64-1               5.64-2
                       bluez-hid2hci               5.64-1               5.64-2
                          bluez-libs               5.64-1               5.64-2
                       bluez-plugins               5.64-1               5.64-2
                         bluez-utils               5.64-1               5.64-2
                               cairo             1.17.4-5             1.17.6-1
                            cbindgen             0.20.0-1             0.21.0-1
                         chromaprint              1.5.1-2              1.5.1-3
                            chromium       99.0.4844.74-1       99.0.4844.84-1
                        cups-filters            1.28.12-1            1.28.13-1
                         dbus-broker                 29-1                 29-2
                                 eog               41.1-2               41.2-1
                         file-roller             3.40.0-1             3.42.0-1
                             firefox           98.0.1-1.1             98.0.2-1
                    firefox-i18n-ach             98.0.1-1             98.0.2-1
                     firefox-i18n-af             98.0.1-1             98.0.2-1
                     firefox-i18n-an             98.0.1-1             98.0.2-1
                     firefox-i18n-ar             98.0.1-1             98.0.2-1
                    firefox-i18n-ast             98.0.1-1             98.0.2-1
                     firefox-i18n-az             98.0.1-1             98.0.2-1
                     firefox-i18n-be             98.0.1-1             98.0.2-1
                     firefox-i18n-bg             98.0.1-1             98.0.2-1
                     firefox-i18n-bn             98.0.1-1             98.0.2-1
                     firefox-i18n-br             98.0.1-1             98.0.2-1
                     firefox-i18n-bs             98.0.1-1             98.0.2-1
                     firefox-i18n-ca             98.0.1-1             98.0.2-1
            firefox-i18n-ca-valencia             98.0.1-1             98.0.2-1
                    firefox-i18n-cak             98.0.1-1             98.0.2-1
                     firefox-i18n-cs             98.0.1-1             98.0.2-1
                     firefox-i18n-cy             98.0.1-1             98.0.2-1
                     firefox-i18n-da             98.0.1-1             98.0.2-1
                     firefox-i18n-de             98.0.1-1             98.0.2-1
                    firefox-i18n-dsb             98.0.1-1             98.0.2-1
                     firefox-i18n-el             98.0.1-1             98.0.2-1
                  firefox-i18n-en-ca             98.0.1-1             98.0.2-1
                  firefox-i18n-en-gb             98.0.1-1             98.0.2-1
                  firefox-i18n-en-us             98.0.1-1             98.0.2-1
                     firefox-i18n-eo             98.0.1-1             98.0.2-1
                  firefox-i18n-es-ar             98.0.1-1             98.0.2-1
                  firefox-i18n-es-cl             98.0.1-1             98.0.2-1
                  firefox-i18n-es-es             98.0.1-1             98.0.2-1
                  firefox-i18n-es-mx             98.0.1-1             98.0.2-1
                     firefox-i18n-et             98.0.1-1             98.0.2-1
                     firefox-i18n-eu             98.0.1-1             98.0.2-1
                     firefox-i18n-fa             98.0.1-1             98.0.2-1
                     firefox-i18n-ff             98.0.1-1             98.0.2-1
                     firefox-i18n-fi             98.0.1-1             98.0.2-1
                     firefox-i18n-fr             98.0.1-1             98.0.2-1
                  firefox-i18n-fy-nl             98.0.1-1             98.0.2-1
                  firefox-i18n-ga-ie             98.0.1-1             98.0.2-1
                     firefox-i18n-gd             98.0.1-1             98.0.2-1
                     firefox-i18n-gl             98.0.1-1             98.0.2-1
                     firefox-i18n-gn             98.0.1-1             98.0.2-1
                  firefox-i18n-gu-in             98.0.1-1             98.0.2-1
                     firefox-i18n-he             98.0.1-1             98.0.2-1
                  firefox-i18n-hi-in             98.0.1-1             98.0.2-1
                     firefox-i18n-hr             98.0.1-1             98.0.2-1
                    firefox-i18n-hsb             98.0.1-1             98.0.2-1
                     firefox-i18n-hu             98.0.1-1             98.0.2-1
                  firefox-i18n-hy-am             98.0.1-1             98.0.2-1
                     firefox-i18n-ia             98.0.1-1             98.0.2-1
                     firefox-i18n-id             98.0.1-1             98.0.2-1
                     firefox-i18n-is             98.0.1-1             98.0.2-1
                     firefox-i18n-it             98.0.1-1             98.0.2-1
                     firefox-i18n-ja             98.0.1-1             98.0.2-1
                     firefox-i18n-ka             98.0.1-1             98.0.2-1
                    firefox-i18n-kab             98.0.1-1             98.0.2-1
                     firefox-i18n-kk             98.0.1-1             98.0.2-1
                     firefox-i18n-km             98.0.1-1             98.0.2-1
                     firefox-i18n-kn             98.0.1-1             98.0.2-1
                     firefox-i18n-ko             98.0.1-1             98.0.2-1
                    firefox-i18n-lij             98.0.1-1             98.0.2-1
                     firefox-i18n-lt             98.0.1-1             98.0.2-1
                     firefox-i18n-lv             98.0.1-1             98.0.2-1
                     firefox-i18n-mk             98.0.1-1             98.0.2-1
                     firefox-i18n-mr             98.0.1-1             98.0.2-1
                     firefox-i18n-ms             98.0.1-1             98.0.2-1
                     firefox-i18n-my             98.0.1-1             98.0.2-1
                  firefox-i18n-nb-no             98.0.1-1             98.0.2-1
                  firefox-i18n-ne-np             98.0.1-1             98.0.2-1
                     firefox-i18n-nl             98.0.1-1             98.0.2-1
                  firefox-i18n-nn-no             98.0.1-1             98.0.2-1
                     firefox-i18n-oc             98.0.1-1             98.0.2-1
                  firefox-i18n-pa-in             98.0.1-1             98.0.2-1
                     firefox-i18n-pl             98.0.1-1             98.0.2-1
                  firefox-i18n-pt-br             98.0.1-1             98.0.2-1
                  firefox-i18n-pt-pt             98.0.1-1             98.0.2-1
                     firefox-i18n-rm             98.0.1-1             98.0.2-1
                     firefox-i18n-ro             98.0.1-1             98.0.2-1
                     firefox-i18n-ru             98.0.1-1             98.0.2-1
                     firefox-i18n-si             98.0.1-1             98.0.2-1
                     firefox-i18n-sk             98.0.1-1             98.0.2-1
                     firefox-i18n-sl             98.0.1-1             98.0.2-1
                    firefox-i18n-son             98.0.1-1             98.0.2-1
                     firefox-i18n-sq             98.0.1-1             98.0.2-1
                     firefox-i18n-sr             98.0.1-1             98.0.2-1
                  firefox-i18n-sv-se             98.0.1-1             98.0.2-1
                     firefox-i18n-ta             98.0.1-1             98.0.2-1
                     firefox-i18n-te             98.0.1-1             98.0.2-1
                     firefox-i18n-th             98.0.1-1             98.0.2-1
                     firefox-i18n-tl             98.0.1-1             98.0.2-1
                     firefox-i18n-tr             98.0.1-1             98.0.2-1
                    firefox-i18n-trs             98.0.1-1             98.0.2-1
                     firefox-i18n-uk             98.0.1-1             98.0.2-1
                     firefox-i18n-ur             98.0.1-1             98.0.2-1
                     firefox-i18n-uz             98.0.1-1             98.0.2-1
                     firefox-i18n-vi             98.0.1-1             98.0.2-1
                     firefox-i18n-xh             98.0.1-1             98.0.2-1
                  firefox-i18n-zh-cn             98.0.1-1             98.0.2-1
                  firefox-i18n-zh-tw             98.0.1-1             98.0.2-1
                          fluidsynth              2.2.5-1              2.2.6-1
                               folks             0.15.4-1             0.15.5-1
                               fping                5.0-1                5.1-2
                         gdk-pixbuf2             2.42.6-2             2.42.8-1
                    gdk-pixbuf2-docs             2.42.6-2             2.42.8-1
                      geoip-database           20220222-1           20220315-1
                geoip-database-extra           20220222-1           20220315-1
                                 gjs         2:1.70.1-2.1           2:1.70.2-1
                     glib-networking           1:2.70.1-1           1:2.72.0-1
                       gnome-desktop             1:41.3-1             1:41.5-1
                         gnome-shell             1:41.4-1             1:41.5-1
                      gnome-software             41.4-1.1               41.5-1
    gnome-software-packagekit-plugin             41.4-1.1               41.5-1
                     gnome-user-docs               41.2-1               41.5-1
               gobject-introspection             1.70.0-5             1.72.0-1
       gobject-introspection-runtime             1.70.0-5             1.72.0-1
                            graphene             1.10.6-1             1.10.8-1
                              gthumb3.12.0+r23+g810e7dfe-1             3.12.1-1
               gtk-update-icon-cache            1:4.6.1-3            1:4.6.2-1
                                gtk3          1:3.24.33-1          1:3.24.33-2
                          gtk3-demos          1:3.24.33-1          1:3.24.33-2
                           gtk3-docs          1:3.24.33-1          1:3.24.33-2
                                gtk4            1:4.6.1-3            1:4.6.2-1
                          gtk4-demos            1:4.6.1-3            1:4.6.2-1
                           gtk4-docs            1:4.6.1-3            1:4.6.2-1
                           gtkmm-4.0              4.6.0-1              4.6.1-1
                      gtkmm-4.0-docs              4.6.0-1              4.6.1-1
                      gtksourceview4              4.8.2-1              4.8.3-1
                                gvfs             1.48.1-3             1.50.0-1
                            gvfs-afc             1.48.1-3             1.50.0-1
                            gvfs-goa             1.48.1-3             1.50.0-1
                         gvfs-google             1.48.1-3             1.50.0-1
                        gvfs-gphoto2             1.48.1-3             1.50.0-1
                            gvfs-mtp             1.48.1-3             1.50.0-1
                            gvfs-nfs             1.48.1-3             1.50.0-1
                            gvfs-smb             1.48.1-3             1.50.0-1
                            harfbuzz              4.0.1-1              4.1.0-1
                        harfbuzz-icu              4.0.1-1              4.1.0-1
                 ibus-typing-booster            2.15.15-1            2.15.25-1
                         imagemagick           7.1.0.27-1           7.1.0.29-1
                     imagemagick-doc           7.1.0.27-1           7.1.0.29-1
                             ipp-usb             0.9.19-1             0.9.20-1
                                js78            78.15.0-3            78.15.0-4
                                js91             91.7.0-1             91.7.1-1
                        jsonrpc-glib             3.40.0-1             3.42.0-1
                       kfilemetadata             5.92.0-1             5.92.0-2
                                 kig            21.12.3-1            21.12.3-2
                           knewstuff             5.92.0-1             5.92.0-2
                            lablgtk2            2.18.11-9           2.18.11-10
                                 ldb            2:2.4.2-1            2:2.5.0-1
                          libadwaita          1:1.0.2-1.1            1:1.1.0-1
                    libadwaita-demos          1:1.0.2-1.1            1:1.1.0-1
                     libadwaita-docs          1:1.0.2-1.1            1:1.1.0-1
                           libdazzle           3.42.0.1-1             3.44.0-1
                            libepoxy              1.5.9-1             1.5.10-1
                          libetebase              0.5.1-2              0.5.2-1
                            libevdev             1.12.0-1             1.12.1-1
                     libglib-testing              0.1.0-1              0.1.1-1
                              libgsf            1.14.48-1            1.14.49-1
                            libhandy              1.4.0-1              1.6.1-1
                              libnma             1.8.34-1             1.8.36-1
                             libpeas             1.30.0-3             1.32.0-1
                      libphonenumber            8.12.41-1          1:8.12.39-1
                           libportal                0.5-1                0.6-1
                      libportal-docs                0.5-1                0.6-1
                      libportal-gtk3                0.5-1                0.6-1
                      libportal-gtk4                0.5-1                0.6-1
                       libportal-qt5                0.5-1                0.6-1
                            libsoup3              3.0.4-2              3.0.5-1
                          libsynctex         2021.59745-1         2021.59745-2
                            libwacom              2.1.0-1              2.2.0-1
                               meson             0.61.3-1             0.62.0-1
                  mkinitcpio-archiso                 61-1                 62-1
                               msmtp             1.8.19-1             1.8.20-1
                           msmtp-mta             1.8.19-1             1.8.20-1
                                mutt              2.2.1-1              2.2.2-1
                              mutter               41.4-1               41.5-1
                            nftables            1:1.0.1-3            1:1.0.2-1
           nginx-prometheus-exporter              0.9.0-2             0.10.0-1
                         openconnect             1:8.20-1             1:8.20-2
                               pango           1:1.50.5-1           1:1.50.6-1
                          pango-docs           1:1.50.5-1           1:1.50.6-1
                    perl-alien-build               2.47-1               2.48-1
                  perl-file-mimeinfo               0.31-1               0.32-1
                    perl-html-parser               3.76-2               3.77-1
                 perl-image-exiftool              12.30-1              12.40-1
                         perl-libwww               6.58-1               6.59-1
                            pkgstats              3.2.0-1              3.2.1-1
                         plasma-meta               5.23-2               5.24-1
                             pyside2             5.15.3-1             5.15.3-3
                       pyside2-tools             5.15.2-1             5.15.3-3
                             pyside6              6.2.3-3              6.2.4-1
                   python-asn1crypto              1.5.0-1              1.5.1-1
                 python-cryptography             36.0.1-1             36.0.2-1
                       python-django             3.2.10-1              4.0.3-1
                 python-editdistance              0.5.3-6              0.6.0-1
                   python-feedparser              6.0.2-1              6.0.3-1
                         python-lxml              4.7.1-1              4.8.0-1
                    python-lxml-docs              4.7.1-1              4.8.0-1
                   python-markupsafe              2.0.1-3              2.1.1-1
                       python-pycurl             7.45.0-1             7.45.1-1
                    python-pyopenssl             21.0.0-5             22.0.0-1
                    python-pyparsing              3.0.2-1              3.0.7-1
               python-qscintilla-qt5             2.13.1-3             2.13.2-1
               python-qscintilla-qt6             2.13.1-3             2.13.2-1
                   python-setuptools           1:59.3.0-1           1:59.4.0-1
                    python-shiboken2             5.15.3-1             5.15.3-3
                        python-tomli              2.0.0-1              2.0.1-1
                      python-urllib3             1.26.8-1             1.26.9-1
                  python-urllib3-doc             1.26.8-1             1.26.9-1
                        python-wrapt             1.13.3-1             1.14.0-1
                            qt5-base    5.15.3+kde+r136-1    5.15.3+kde+r137-1
                        qt5-location      5.15.3+kde+r1-1      5.15.3+kde+r2-1
             qt5-xcb-private-headers    5.15.3+kde+r136-1    5.15.3+kde+r137-1
                              qt6-3d              6.2.3-3              6.2.4-1
                         qt6-5compat              6.2.3-2              6.2.4-1
                            qt6-base            6.2.3-5.1              6.2.4-1
                          qt6-charts              6.2.3-2              6.2.4-1
                    qt6-connectivity              6.2.3-2              6.2.4-1
                       qt6-datavis3d              6.2.3-2              6.2.4-1
                     qt6-declarative              6.2.3-2              6.2.4-1
                             qt6-doc              6.2.3-1              6.2.4-1
                        qt6-examples              6.2.3-1              6.2.4-1
                    qt6-imageformats              6.2.3-2              6.2.4-1
                          qt6-lottie              6.2.3-2              6.2.4-1
                      qt6-multimedia              6.2.3-2              6.2.4-1
                     qt6-networkauth              6.2.3-2              6.2.4-1
                     qt6-positioning              6.2.3-2              6.2.4-1
                         qt6-quick3d              6.2.3-3              6.2.4-1
                   qt6-quicktimeline              6.2.3-2              6.2.4-1
                   qt6-remoteobjects              6.2.3-2              6.2.4-1
                           qt6-scxml              6.2.3-2              6.2.4-1
                         qt6-sensors              6.2.3-2              6.2.4-1
                       qt6-serialbus              6.2.3-2              6.2.4-1
                      qt6-serialport              6.2.3-2              6.2.4-1
                     qt6-shadertools              6.2.3-2              6.2.4-1
                             qt6-svg              6.2.3-2              6.2.4-1
                           qt6-tools              6.2.3-4              6.2.4-1
                    qt6-translations              6.2.3-1              6.2.4-1
                 qt6-virtualkeyboard              6.2.3-2              6.2.4-1
                         qt6-wayland              6.2.3-2              6.2.4-1
                      qt6-webchannel              6.2.3-2              6.2.4-1
                       qt6-webengine              6.2.3-8              6.2.4-1
                      qt6-websockets              6.2.3-2              6.2.4-1
                         qt6-webview              6.2.3-2              6.2.4-1
                           qtcreator              6.0.2-4              7.0.0-1
                               samba             4.15.6-1             4.16.0-1
                           shiboken6              6.2.3-3              6.2.4-1
                           smbclient             4.15.6-1             4.16.0-1
                                tali               40.5-1               40.6-1
                       template-glib  3.34.0+4+g5196521-1             3.34.1-1
                 texlive-bibtexextra         2021.61406-1         2021.62705-1
                         texlive-bin         2021.59745-1         2021.59745-2
                        texlive-core         2021.61403-1         2021.62793-1
                  texlive-fontsextra         2021.61408-1         2021.62623-1
                texlive-formatsextra         2021.57972-1         2021.62145-1
                       texlive-games         2021.60973-1         2021.62102-1
                  texlive-humanities         2021.60935-1         2021.61878-1
                 texlive-langchinese         2021.61285-1         2021.62313-1
                texlive-langcyrillic         2021.60630-1         2021.62110-1
                   texlive-langextra         2021.60975-1         2021.62109-1
                   texlive-langgreek         2021.57684-1         2021.61820-1
                texlive-langjapanese         2021.61273-1         2021.62737-1
                  texlive-langkorean         2021.61183-1         2021.62398-1
                  texlive-latexextra         2021.61405-1         2021.62806-1
                       texlive-music         2021.60382-1         2021.62509-1
                    texlive-pictures         2021.61392-1         2021.62760-1
                    texlive-pstricks         2021.61407-1         2021.61917-1
                  texlive-publishers         2021.61397-1         2021.62814-1
                     texlive-science         2021.61383-1         2021.62659-1
                            tracker3              3.2.1-2              3.3.0-1
                       tracker3-docs              3.2.1-2              3.3.0-1
                     tracker3-miners              3.2.2-1              3.3.0-1
                              unison             2.51.5-1             2.52.0-1
                            usbguard              1.1.0-1              1.1.1-1
                                vala             0.54.7-1             0.56.0-2
                   vulkan-icd-loader            1.3.207-1            1.3.208-1
                          webkit2gtk             2.34.6-1             2.36.0-1
                      webkit2gtk-4.1             2.34.6-1             2.36.0-1
                      webkit2gtk-5.0             2.34.6-1             2.36.0-1
                                wget             1.21.2-1             1.21.3-1
                         wireplumber              0.4.8-2              0.4.9-1
                    wireplumber-docs              0.4.8-2              0.4.9-1
                         xapian-core           1:1.4.18-1           1:1.4.19-1
                  xdg-desktop-portal             1.14.0-1             1.14.1-1
              xdg-desktop-portal-gtk             1.12.0-1             1.14.0-1
             xfce4-pulseaudio-plugin              0.4.3-1              0.4.3-2
                          yelp-tools               41.0-1               42.0-1
                            yelp-xsl               41.1-1               42.0-1
                        zabbix-agent              6.0.1-1              6.0.2-1
                       zabbix-agent2              6.0.1-1              6.0.2-1
                 zabbix-frontend-php              6.0.1-1              6.0.2-1
                        zabbix-proxy              6.0.1-1              6.0.2-1
                       zabbix-server              6.0.1-1              6.0.2-1
                                 zip                3.0-9               3.0-10
                   jsonrpc-glib-docs                    -             3.42.0-1
                            kalendar                    -              1.0.0-1
                       libepoxy-docs                    -             1.5.10-1
                       libhandy-docs                    -              1.6.1-1
                        libpeas-docs                    -             1.32.0-1
                  libsysprof-capture                    -             3.44.0-1
              network-manager-applet                    -             1.26.0-1
                nm-connection-editor                    -             1.26.0-1
                             sysprof                    -             3.44.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.12.2.r12711.g4d8fdf914-121.12.2.r12712.g054e7b167-1
                    akonadi-calendar21.12.2.1.r2049.gd987efe-121.12.2.1.r2056.g328b964-1
              akonadi-calendar-tools21.12.2.1.r939.g6b5ba40-121.12.2.1.r942.gdd8d6c5-1
                    akonadi-contacts21.12.2.r3156.ge41554f9-121.12.2.r3160.geff3b1fc-1
               akonadi-import-wizard21.12.2.1.r1797.g64b72aa-121.12.2.1.r1802.gb92e8f1-1
                        akonadi-mime21.12.2.1.r1706.g34d9bea-121.12.2.1.r1709.gdc26109-1
                       akonadi-notes21.12.2.1.r1063.g2b3eef1-121.12.2.1.r1065.g472c8c2-1
                      akonadi-search21.12.2.1.r1210.gb2d9c7e-121.12.2.1.r1214.g5ed2d63-1
                      akonadiconsole21.12.2.1.r1577.g91aa1e3-121.12.2.1.r1579.ge3ecdd8-1
                           akregator21.12.2.r6350.g8b386cc3-121.12.2.r6355.gd4a9825c-1
                            amazfish  2.0.3.r5.gdef0ed4-1  2.0.5.r0.g822c988-1
                           angelfish 22.02.r11.g88d7427-1 22.02.r12.g62e1de3-1
                                 ark21.12.2.1.r4715.g389511b1-121.12.2.1.r4718.g5c95ab20-1
                          artikulate21.12.2.1.r1406.g6421d7a-121.12.2.1.r1408.gb90e82c-1
                         audiocd-kio21.12.2.1.r1051.ge392f00-121.12.2.1.r1053.ge6db30d-1
                           audiotube 22.02.r14.g1a93e0d-1 22.02.r15.g0249604-1
                               baloo5.92.0.r3042.g41ea9394-15.92.0.r3043.g1eed0fcb-1
                             blinken21.12.2.1.r656.g3396042-121.12.2.1.r658.g3dbe8a8-1
                           bluedevil1:5.24.3.r2381.g608de9bd-11:5.24.3.r2384.g504d44ad-1
                              bomber21.12.2.1.r552.g07efc86-121.12.2.1.r556.gc6409ef-1
                                bovo21.12.2.1.r767.gc8336f5-121.12.2.1.r770.gb804b26-1
                              breeze5.24.3.r2366.gaf1ddf45-15.24.3.r2371.g3ce6b178-1
                          breeze-gtk5.24.3.r451.g1c4d3d1-15.24.3.r459.g64e5e24-1
                        breeze-icons5.92.0.r1887.g77af4671-15.92.0.r1890.gff66b122-1
                                buho  2.1.1.r1.g02d432d-1  2.1.1.r3.g278078b-1
                     calendarsupport21.12.2.r671.g3287867-121.12.2.r678.gd815b45-1
                            discover5.24.3.r8596.gd3fa32a3-15.24.3.r8604.g1dfd0d7d-1
                     dolphin-plugins21.12.2.r645.g58ff080-121.12.2.r648.gbb1de5a-1
                             drkonqi5.24.3.r741.gdc8579af-15.24.3.r751.ge540b701-1
                               elisa21.12.2.1.r2908.g74c04d51-121.12.2.1.r2910.gf6255822-1
                          elisa-qtmm21.12.2.1.r2908.g74c04d51-121.12.2.1.r2910.gf6255822-1
                          eventviews21.12.2.r796.g90d9ff3-121.12.2.r799.ga53feee-1
                 extra-cmake-modules5.91.0.r3455.g7cb3191-15.91.0.r3467.g19311d2-1
                        ffmpegthumbs21.12.2.1.r209.gd27049f-121.12.2.1.r210.g255affd-1
                           filelight21.12.2.r1059.g01acfad-121.12.2.r1064.g7f605ad-1
                frameworkintegration5.92.0.r624.g6117719-15.92.0.r627.g1dc39dd-1
                           granatier21.12.2.1.r963.g4eb9587-121.12.2.1.r965.ge9ff3bc-1
                     grantlee-editor21.12.2.1.r810.g78d8afc-121.12.2.1.r813.g87be3d0-1
                       grantleetheme21.12.2.r385.g2eed32d-121.12.2.r386.g1792967-1
                            gwenview21.12.2.1.r6816.g38f1da76-121.12.2.1.r6819.g312c6059-1
                     incidenceeditor21.12.2.1.r851.g3e127a9-121.12.2.1.r854.g653a917-1
                           itinerary21.12.2.1.r1747.g31543e9-121.12.2.1.r1754.ge7924e1-1
                                 juk21.12.2.1.r3135.gda0d8d71-121.12.2.1.r3136.g40997ef4-1
                                 k3b1:21.12.2.1.r6716.gfcb2336b4-11:21.12.2.1.r6720.gf616e9c27-1
               kaccounts-integration21.12.2.r1244.g5012daa-121.12.2.r1246.g247ae41-1
                 kaccounts-providers21.12.2.1.r392.g9370311-121.12.2.1.r394.g59df5c8-1
                   kactivitymanagerd5.24.3.r1385.gb5c80ae-15.24.3.r1388.gdb88936-1
                        kaddressbook21.12.2.1.r6123.g0b5823a7-121.12.2.1.r6131.ge99e5b50-1
                             kajongg21.12.2.1.r4331.g29d00a4f-121.12.2.1.r4332.g0c60e939-1
                              kalarm21.12.2.1.r7829.g306878b7-121.12.2.1.r7840.g72b42497-1
                                kalk 22.02.r12.g89afe56-1 22.02.r14.g4a08991-1
                             kalzium21.12.2.1.r4307.ged1603d8-121.12.2.1.r4309.g6965a7cf-1
                              kamera21.12.1.r705.gdd5795b-121.12.1.r706.g96388b0-1
                            kanagram21.12.2.r1302.gb277148-121.12.2.r1303.g2e0dba9-1
                              kapman21.12.2.1.r638.g716d254-121.12.2.1.r641.gde89758-1
                        kapptemplate21.12.2.1.r980.g1b19092-121.12.2.1.r982.gbd47199-1
                            karchive5.92.0.r534.g17647fa-15.92.0.r535.g9e0700c-1
                               kasts  22.02.r5.gbbded05-1  22.02.r9.g09395b5-1
                                kate21.12.2.1.r18794.g916c617e4-121.12.2.1.r18841.g130c10192-1
                             katomic21.12.2.1.r948.gdfb9ace-121.12.2.1.r950.g720fbbd-1
                               kauth5.92.0.r492.g863d87c-15.92.0.r493.gcdb973a-1
                             kbackup21.12.2.1.r423.g8cf381e-121.12.2.1.r426.g5981c22-1
                           kblackbox21.12.2.1.r756.ga3cb067-121.12.2.1.r759.g7c4b793-1
                             kblocks21.12.2.1.r698.g06637b4-121.12.2.1.r706.gd8eb0ff-1
                          kbookmarks5.92.0.r453.g81bf8e2-15.92.0.r455.gf3bbcc3-1
                           kbreakout21.12.2.1.r899.ge97c83d-121.12.2.1.r903.g6258122-1
                              kbruch21.12.2.1.r853.gee0afff-121.12.2.1.r855.g1da42e0-1
                               kcalc21.12.2.1.r1599.g456ab08-121.12.2.1.r1600.g0bccd5c-1
                       kcalendarcore5.92.0.r1306.gdbd6a1d40-15.92.0.r1309.g1526e87af-1
                           kcalutils21.12.2.1.r941.g89d2174cf-121.12.2.1.r943.g703a509e0-1
                         kcharselect21.12.2.r506.gbf7e16d-121.12.2.r509.ga597ed8-1
                              kclock 22.02.r23.g94ddac8-1 22.02.r31.g6f0eb4c-1
                            kcmutils5.92.0.r607.gc9c58de-15.92.0.r609.g4b12a96-1
                       kcolorchooser21.12.2.1.r253.gc922e9b-121.12.2.1.r255.gacd6f3d-1
                             kconfig5.92.0.r943.g7206ba3f-15.92.0.r944.g3c861a6c-1
                      kconfigwidgets5.92.0.r696.g00804e2-15.92.0.r703.g9199569-1
                         kcoreaddons5.92.0.r1443.gec41ef16-15.92.0.r1446.gbc2440ca-1
                              kcrash5.92.0.r437.g9d13d87-15.92.0.r438.ga9fb4b5-1
                               kcron21.12.2.1.r836.g86f659d-121.12.2.1.r838.gec9a749-1
                                kdav1:5.92.0.r1336.gbd981a7-11:5.92.0.r1337.g26321bf-1
                       kde-cli-tools5.24.3.r1915.g8d6ef8c-15.24.3.r1917.g8415c2b-1
                       kde-dev-utils21.12.2.1.r573.g2aa9a74-121.12.2.1.r575.g1bb3f9b-1
                      kdebugsettings21.12.2.1.r896.g53aae06-121.12.2.1.r898.g96a4511-1
                        kdeclarative5.92.0.r985.g8570dfb-15.92.0.r986.gc3b8430-1
                          kdeconnect21.12.2.1.r3412.g5a9361c2-121.12.2.1.r3417.gf5037a42-1
                                kded5.92.0.r451.gf02a9af-15.92.0.r453.g0e83af7-1
            kdegraphics-thumbnailers21.12.2.1.r255.gd9f0c38-121.12.2.1.r258.g201fb2c-1
                     kdelibs4support5.92.0.r1075.gab1bca20-15.92.0.r1077.g68885aa3-1
              kdenetwork-filesharing21.12.2.1.r903.g81f68e1-121.12.2.1.r915.g670272d-1
                            kdenlive21.12.1.r15819.g7dee407ab-121.12.1.r15911.ge7271d918-1
                       kdepim-addons21.12.2.r4584.ga6f6f335-121.12.2.r4598.g04b663c5-1
                      kdepim-runtime21.12.2.r15469.g611bec397-121.12.2.r15475.g3d50a241b-1
                    kdeplasma-addons5.24.3.r8670.gd264fff12-15.24.3.r8685.g4fa0636da-1
                                 kdf21.12.2.1.r838.geb47fa2-121.12.2.1.r841.gbb0abea-1
                            kdiamond21.12.2.1.r710.g61a0a34-121.12.2.1.r715.g18e05a9-1
                          kemoticons5.92.0.r406.ge74dcd6-15.92.0.r407.g3bc35df-1
                               kfind21.12.2.1.r2670.g8c512173c-121.12.2.1.r2672.g9b40ba6fc-1
                         kfourinline21.12.2.1.r1012.g58a0e9b-121.12.2.1.r1015.gf8e0146-1
                          kgeography21.12.2.1.r1139.g7f415a4-121.12.2.1.r1140.g0133d70-1
                                kget21.12.2.1.r3163.g7b4ca8fa-121.12.2.1.r3165.g0a1eb6bc-1
                         kgoldrunner21.12.2.1.r1267.gbe9d052-121.12.2.1.r1270.g32e4017-1
                                kgpg21.12.2.1.r3174.ge55cce4e-121.12.2.1.r3178.gd0d187be-1
                          kguiaddons5.92.0.r448.ga02c852-15.92.0.r452.g7f8dcbb-1
                            khangman21.12.2.1.r1590.gd685107-121.12.2.1.r1592.gb625feb-1
                  khealthcertificate  22.02.r0.g32e9e01-1  22.02.r2.g52fb7cf-1
                         khelpcenter21.12.2.r2725.g627564c5-121.12.2.r2728.g488b5643-1
                            khotkeys5.24.3.r2113.ged47291-15.24.3.r2115.g3b3ebbf-1
                 kidentitymanagement21.12.2.1.r3875.gdf829e46-121.12.2.1.r3878.g18ebd91c-1
                                kigo21.12.2.r552.g899098f-121.12.2.r554.g58de38c-1
                            killbots21.12.2.1.r767.gab1d772-121.12.2.1.r775.gc7689e9-1
                       kimageformats5.92.0.r386.ge69dff7-15.92.0.r387.g3e751dd-1
                               kimap21.12.2.1.r1178.gacb00db-121.12.2.1.r1180.gb89caab-1
                         kinfocenter5.24.3.r2046.g1fb7a9e-15.24.3.r2050.gf36eb08-1
                                 kio5.92.0.r5358.g1f12ece78-15.92.0.r5370.g9b1a4f4df-1
                          kio-extras21.12.2.1.r7207.g22fafece-121.12.2.1.r7209.g23baa544-1
                          kio-gdrive21.12.2.1.r585.g466cdbc-121.12.2.1.r588.g88e9e0f-1
                        kipi-plugins21.12.2.1.r12080.gc9526b8ac-121.12.2.1.r12081.g2be2c15b5-1
                     kirigami-addons 1:0.2.r20.gfda83e6-1 1:0.2.r23.gb0960c3-1
                    kirigami-gallery21.12.2.1.r232.g70d039a-121.12.2.1.r233.g25d23b6-1
                              kiriki21.12.2.1.r442.gb07b187-121.12.2.1.r445.g4fea4b8-1
                          kitemviews5.92.0.r365.gfc6dbc7-15.92.0.r366.g1c15548-1
                               kiten21.12.2.1.r1177.g264d272-121.12.2.1.r1179.g1b6dbb6-1
                          kitinerary21.12.2.1.r2117.gd6ad887-121.12.2.1.r2121.gc83a6dc-1
                        kjumpingcube21.12.2.1.r815.g2aeb8f8-121.12.2.1.r816.g2b61370-1
                               kldap21.12.2.1.r938.g23abaa6-121.12.2.1.r940.g380159d-1
                           kleopatra21.12.2.1.r6314.gb6f570f5-121.12.2.1.r6316.g4a3594fa-1
                            klettres21.12.2.1.r951.g3166350-121.12.2.1.r952.ge165957-1
                              klines21.12.2.1.r797.g1ff0561-121.12.2.1.r800.g77d56ff-1
                           kmahjongg21.12.2.r1516.g52e1e39-121.12.2.r1518.g3902c41-1
                               kmail21.12.2.r26289.g07345bf14-121.12.2.r26302.ge0595a63c-1
                kmail-account-wizard21.12.2.1.r868.geba0d08-121.12.2.1.r872.gf70ffd0-1
                      kmailtransport21.12.2.1.r1716.g979c6cd-121.12.2.1.r1719.g0381b22-1
                               kmbox21.12.2.1.r584.g2e5d5ba-121.12.2.1.r586.g0d15501-1
                           kmenuedit5.24.3.r1014.g4a3c599-15.24.3.r1022.gece35be-1
                               kmime21.12.2.1.r1499.gbc05378-121.12.2.1.r1500.g8e5ce74-1
                              kmouth21.12.2.1.r706.g66b2b33-121.12.2.1.r709.g73997a0-1
                              kmplot21.12.2.1.r1477.gc1bc857-121.12.2.1.r1478.g3f9f8ba-1
                        knavalbattle21.12.2.1.r1417.g48f55ff-121.12.2.1.r1420.g7f9b2c5-1
                            knetwalk21.12.2.1.r683.gab4c2f8-121.12.2.1.r688.gabadca9-1
                           knewstuff5.92.0.r1300.gce1cf018-15.92.0.r1311.gd235c280-1
                             knights21.12.2.1.r1112.g4b1f0ea-121.12.2.1.r1114.g91a8ed5-1
                              knotes21.12.2.r3608.g07de53cd-121.12.2.r3612.gc2f19f7e-1
                                kolf21.12.2.1.r1476.g355cf4e-121.12.2.1.r1480.gdfe6002-1
                           kollision21.12.2.1.r521.g120f0e1-121.12.2.1.r525.g7b19e18-1
                             kompare21.12.2.1.r1125.g45d5334-121.12.2.1.r1126.g7538eb8-1
                            kongress  22.02.r1.g07cddec-1  22.02.r2.g16a3e3a-1
                           konqueror21.12.2.r15050.g2020b6d48-121.12.2.r15059.g72983faf0-1
                             konsole21.12.2.r8312.g5039938a-121.12.2.r8322.g440d9d5c-1
                             kontact21.12.2.1.r5486.g6d513671-121.12.2.1.r5493.gd1e694f2-1
                    kontactinterface21.12.2.1.r668.g123bab4-121.12.2.1.r670.g9e05aec-1
                        konversation21.12.2.1.r9086.gc5b06610-121.12.2.1.r9094.g0768a83f-1
                       kopeninghours21.12.2.1.r321.g01bf1eb-121.12.2.1.r322.gd3439b6-1
                              kopete21.12.2.1.r16407.g31e606591-121.12.2.1.r16410.ga31b1b21f-1
                          korganizer21.12.2.r11643.g6d285af8b-121.12.2.r11647.g0fad3b3b9-1
                       kosmindoormap21.12.2.1.r706.g0f55048-121.12.2.1.r708.g2ddcd90-1
                            kpackage5.92.0.r738.g62d41e0-15.92.0.r741.g57ba435-1
                              kparts5.92.0.r574.gd1745fa-15.92.0.r575.g6df8f08-1
                                kpat21.12.2.r2602.g6bb3925-121.12.2.r2604.g8f7deaa-1
                        kpimtextedit21.12.2.1.r1567.gcb86598-121.12.2.1.r1569.g91ea87a-1
                             kpkpass21.12.2.1.r275.g0105471-121.12.2.1.r277.g7433acd-1
                             kpmcore21.12.2.r1272.g76ede03-121.12.2.r1279.g5afe143-1
                    kpublictransport21.12.1.r1984.g0fc8912e-121.12.1.r1985.g9ee1a6f8-1
                                krdc21.12.2.1.r1565.g761502a-121.12.2.1.r1566.gf163967-1
                           krecorder  22.02.r8.gb61cea1-1 22.02.r10.gd1d9fab-1
                            kreversi21.12.2.1.r1256.ge7f911e-121.12.2.1.r1257.g5b84251-1
                                krfb21.12.2.1.r1472.ge2f3910-121.12.2.1.r1473.g4a6970d-1
                              kruler21.12.2.1.r725.g3436835-121.12.2.1.r726.g8e2757e-1
                             kscreen5.24.3.r1434.g7ea4408-15.24.3.r1439.g769116f-1
                       kscreenlocker5.24.3.r910.g9d3a95f-15.24.3.r912.g5516314-1
                            kservice5.92.0.r996.g79b66d0-15.92.0.r997.g111ca51-1
                             kshisen21.12.2.1.r1227.g275b8c9-121.12.2.1.r1232.g12d541a-1
                               ksmtp21.12.2.1.r425.g9b389ac-121.12.2.1.r427.ga93700b-1
                          kspaceduel21.12.2.1.r661.g9884782-121.12.2.1.r664.g592dac2-1
                             ksudoku21.12.2.1.r1094.g5d35f1f-121.12.2.1.r1096.g31990dd-1
                           ksysguard5.24.3.r3524.g1367cb0d-15.24.3.r3525.g02dc1395-1
                          ksystemlog21.12.2.1.r708.gc5c7a9d-121.12.2.1.r710.g500b12b-1
                         ktexteditor5.92.0.r3273.gdd1edbd6-15.92.0.r3306.g5a7a895f-1
                              ktimer21.12.2.1.r499.g3ed4118-121.12.2.1.r503.g44ffa16-1
                               ktnef21.12.2.1.r707.g50eac67-121.12.2.1.r710.g647dea9-1
                            ktorrent21.12.2.r2826.g50a06198-121.12.2.r2829.g56656946-1
                              ktouch21.12.2.1.r2168.gf37391d-121.12.2.1.r2171.gc37d57d-1
                             kturtle21.12.2.1.r1155.g375405a-121.12.2.1.r1156.g9b37d6e-1
                             kwallet5.92.0.r1134.g016552b-15.92.0.r1136.ge07c810-1
                      kwalletmanager21.12.2.1.r1255.gcf1dd80-121.12.2.1.r1262.g4eb6b7e-1
                               kwave21.12.2.1.r3766.g870e8fd3-121.12.2.1.r3772.ga2066c56-1
                            kwayland5.92.0.r1148.ge2ce367-15.92.0.r1150.g0181767-1
                     kwayland-server5.24.3.r1458.g0a98dd7-15.24.3.r1465.ge2f9315-1
                            kweather  22.02.r8.gf320de6-1 22.02.r12.g52c140d-1
                                kwin5.24.3.r20937.g140c2fb20-15.24.3.r20992.g0aab6e3ee-1
                           kwordquiz21.12.2.r1172.g1c3a502-121.12.2.r1174.g0a54f3e-1
                              kwrite21.12.2.1.r18794.g916c617e4-121.12.2.1.r18841.g130c10192-1
                             kwrited5.24.3.r501.g2de2d30-15.24.3.r502.g7f4c59c-1
                             kxmlgui5.92.0.r857.gb3610c5a-15.92.0.r860.ga82076a6-1
                          libakonadi21.12.2.r12711.g4d8fdf914-121.12.2.r12712.g054e7b167-1
                         libgravatar21.12.2.1.r410.g8aeb731-121.12.2.1.r413.ga97ac57-1
                         libkdegames21.12.2.1.r2218.g7c637920-121.12.2.1.r2228.g651962ca-1
                           libkdepim21.12.2.1.r895.geb4089c-121.12.2.1.r897.gab3c82a-1
                  libkeduvocdocument21.12.2.1.r1808.g7bebaf5-121.12.2.1.r1809.g3a34565-1
                            libkgapi21.12.2.1.r1349.g796c430-121.12.2.1.r1350.g8125534-1
                             libkleo21.12.2.1.r1098.gc4b2a06-121.12.2.1.r1101.gf290218-1
                        libkmahjongg21.12.2.1.r475.g2259e1e-121.12.2.1.r476.g8e13a4a-1
                            libksane21.12.2.1.r592.g323cf80-121.12.2.1.r593.gc955840-1
                           libksieve21.12.2.1.r1677.g5e894204-121.12.2.1.r1680.g76cafbac-1
                        libksysguard5.24.3.r2382.g2ce71ca-15.24.3.r2383.g29af1b1-1
                            lokalize21.12.2.1.r1812.gb0544763-121.12.2.1.r1813.g5ec185be-1
                               lskat21.12.2.1.r838.gef0d9be-121.12.2.1.r841.g01237db-1
                          mailcommon21.12.2.1.r1208.gfed0e1f-121.12.2.1.r1211.g1313d37-1
                        mailimporter21.12.2.1.r508.gf005dbe-121.12.2.1.r510.g97367a7-1
                    maliit-framework 2.2.0.r0.g1f2443db-1 2.2.0.r2.gc9ea3457-1
                     maliit-keyboard2.2.0.r15.gf1d4312a-12.2.0.r17.gd8028731-1
                              marble21.12.2.1.r13402.gbf3a3ff11-121.12.2.1.r13406.g396e4725d-1
                       marble-common21.12.2.1.r13402.gbf3a3ff11-121.12.2.1.r13406.g396e4725d-1
                           marble-qt21.12.2.1.r13402.gbf3a3ff11-121.12.2.1.r13406.g396e4725d-1
                           maui-nota 2.1.1.r10.gcc1c0a0-1 2.1.1.r12.g9b66b49-1
                            maui-pix 2.1.0.r12.gbffcd1b-1 2.1.0.r13.gaa91a6e-1
                          maui-shell       r166.167c285-1       r169.e370183-1
                             mauikit2.1.1.r10.g4d820a1a-12.1.1.r12.g58004ea5-1
                       mbox-importer21.12.2.1.r556.g5b2d424-121.12.2.1.r558.g549e240-1
                          messagelib21.12.1.r6436.g9cb5b9d36-121.12.1.r6447.g5969e2c80-1
                               milou5.24.3.r763.g6a2fd07-15.24.3.r764.g8118e8d-1
                              minuet21.12.2.1.r598.g41ae771-121.12.2.1.r599.g3b07c01-1
                   mycroft-bigscreen21.2.2.r4902.g5f4c68e583-121.2.2.r4904.gccd577bbf4-1
                              okular21.12.2.1.r9652.gad6426be5-121.12.2.1.r9669.g64676e6ff-1
                            palapeli21.12.2.1.r1265.g71d9f71-121.12.2.1.r1266.g3509076-1
                              parley21.12.2.r4507.g5a9bb35d-121.12.2.r4509.g18d28283-1
                    partitionmanager21.12.2.r1602.g4ce27ce-121.12.2.r1608.gd493384-1
                   pim-data-exporter21.12.2.r2582.g0623382f-121.12.2.r2584.g3df2c281-1
                    pim-sieve-editor21.12.2.r1595.g902ff51-121.12.2.r1599.g750117c-1
                           pimcommon21.12.2.r1203.g9fd75aa-121.12.2.r1207.g7d2abd9-1
                    plasma-bigscreen      r452.g14769c6-1      r454.gbb5b1f2-1
                       plasma-camera  1.0.r114.g1c638ba-1  1.0.r115.g563b83d-1
                      plasma-desktop5.24.3.r9126.g69f4af186-15.24.3.r9145.g42480e30a-1
                       plasma-dialer 22.02.r16.gbc3453b-1 22.02.r18.g28d4489-1
                        plasma-disks5.24.3.r259.g74a8f69-15.24.3.r263.gbb53c25-1
                     plasma-firewall5.24.3.r599.gf5fb94a-15.24.3.r606.g8b971ef-1
                    plasma-framework5.92.0.r16211.ge53cee90d-15.92.0.r16220.g47ad0a574-1
                  plasma-integration5.24.3.r552.g65cbbba-15.24.3.r553.gaeb3dfb-1
                       plasma-mobile5.24.3.r1674.ga86c06cfd-15.24.3.r1686.g5f20862a3-1
                    plasma-mobile-nm5.24.3.r3216.g57abb2f6-15.24.3.r3220.gc6ab31b8-1
                           plasma-nm5.24.3.r3216.g57abb2f6-15.24.3.r3220.gc6ab31b8-1
                           plasma-pa5.24.3.r1033.g8d79911-15.24.3.r1035.g57b0485-1
                          plasma-sdk5.24.3.r2331.g3ef06c64-15.24.3.r2335.g12d81677-1
                     plasma-settings 22.02.r19.g86f6d4e-1 22.02.r22.gec38ae4-1
                plasma-systemmonitor5.24.3.r553.g76a3d6f-15.24.3.r556.g920acfb-1
                        plasma-vault5.24.3.r375.gdbe85a8-15.24.3.r377.g8cf0264-1
              plasma-wayland-session5.24.3.r11556.g39b429f13-15.24.3.r11591.g460a6485b-1
                    plasma-workspace5.24.3.r11556.g39b429f13-15.24.3.r11591.g460a6485b-1
         plasma-workspace-wallpapers5.24.3.r333.g896dd9c-15.24.3.r334.g709fbae-1
                          powerdevil5.24.3.r2524.g7586da3a-15.24.3.r2527.g4c031ac8-1
                       print-manager21.12.2.r1104.gdb216c0-121.12.2.r1113.g12ba07c-1
                             purpose5.91.0.r953.g6773fa71-15.91.0.r955.g9cbacaf7-1
                  qqc2-desktop-style5.92.0.r588.ga42ef45-15.92.0.r590.g60d5852-1
                                rocs21.12.2.1.r3059.ge428ad5f-121.12.2.1.r3061.g74b5c362-1
                                sddm0.19.0.r138.gd19813c-10.19.0.r141.ge67307e-1
                            sddm-kcm5.24.3.r644.g11d2ff1-15.24.3.r645.g9b7062d-1
                               solid5.92.0.r760.gd5335ad-15.92.0.r761.gd95067c-1
                              sonnet5.92.0.r683.g70874c9-15.92.0.r684.g32a6f74-1
                            spacebar22.02.2.r10.g6b18cae-122.02.2.r14.g1d90ebe-1
                           spectacle21.12.2.1.r1309.g2dbb2bd-121.12.2.1.r1316.g6b0733a-1
                                step21.12.2.1.r1174.g78c2423-121.12.2.1.r1175.g801f4db-1
                             sweeper21.12.2.1.r558.g528006f-121.12.2.1.r561.gcda16ca-1
                 syntax-highlighting5.92.0.r1816.g1a0c480f-15.92.0.r1820.gb5075e6c-1
                      systemsettings5.24.3.r2631.ga93554d4-15.24.3.r2635.g46b54f32-1
              telepathy-kde-approver21.12.2.1.r299.g58b535d-121.12.2.1.r300.gbcee3ed-1
      telepathy-kde-common-internals21.12.2.1.r2002.g3b11e85-121.12.2.1.r2005.g14c7889-1
               telepathy-kde-text-ui21.12.2.1.r2031.gc381360-121.12.2.1.r2034.gfc0acdc-1
                             tokodon  22.02.r3.g198139f-1  22.02.r5.g12bfe2e-1
                            umbrello21.12.2.r8412.g81f6992f5-121.12.2.r8428.ga1cb29f22-1
                               vvave  2.1.1.r4.ge805b43-1  2.1.1.r6.g10507dc-1
              xdg-desktop-portal-kde5.24.3.r443.g79f3b13-15.24.3.r444.g1011a69-1
                             yakuake21.12.2.1.r773.g56c0b6f-121.12.2.1.r776.g5b8b334-1
                    zeroconf-ioslave21.12.2.1.r371.gae2fa67-121.12.2.1.r372.g187b338-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Old Issues
Plasma Dialer cannot answer calls
Sadly Plasma Dialer 22.02 has a serious regression with no known workaround. It’s not possible to accept incoming calls. Very sorry about this. Follow the upstream bug report. We will patch the package as soon as a solution is found.
Plasma Mobile - Black screen after update
We are seeing some reports about Plasma Mobile on the PinePhone only showing a black screen after entering the PIN after this update.
Workaround: Downgrade qt5-es2-wayland to 5.15.2+kde+r41 which is now back in Stable and Testing branch repositories.
New Breath theme not applying correctly
With the update to the new Breath theme, a migration package tries to apply the new theme correctly.
However this is not getting done for Plasma’s Lockscreen and the SDDM theme.
So please go through your settings after updating to make sure the themes are correctly applied.
Fix: manjaro-system should take care of this for you.
Plasma Mobile switch to ModemManager
With the PlaMo Gear 21.12 release, Plasma Mobile is now using ModemManager as the telephony stack. So in order to use SIM capabilities, you need to switch from using oFono to ModemManager.
Fix: Run sudo systemctl disable --now ofono ofonoctl && sudo systemctl enable --now ModemManager. You might have to reboot your phone for Plasma Mobile to pick up this change.
Plasma Mobile has does not launch after update
This was caused by an error in kwin 5.23.2 which only affects installs based on openGLES (qt5-es2).
Fix: Update to kwin 5.23.2-1.2 or above.
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Poor souls
catdoc: Extract text from Office 98 files
:laughing:
ETA:
Everything is fine after a reboot, thanks very much!
I tried installing Amazfish on my plasma mobile pinephone and got this error. There appears to be a conflict between mpris-qt5 and qtmpris? It would seem amazfish needs mpris-qt5 and dialer needs qtmpris but these packages contain overlapping files.
$ sudo pacman -S amazfish
resolving dependencies...
Packages (6) kdb-3.2.0-8  mlite-0.3.8-1  mpris-qt5-1.0.4-2  nemo-qml-plugin-dbus-2.1.25-1
             qt5-connectivity-5.15.3+kde+r6-1  amazfish-2.0.5-1
Total Download Size:   10.57 MiB
Total Installed Size:  20.25 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 mpris-qt5-1.0.4-2-aarch64                   131.9 KiB   115 KiB/s 00:01 [########################################] 100% mlite-0.3.8-1-aarch64                        99.8 KiB  86.9 KiB/s 00:01 [########################################] 100% nemo-qml-plugin-dbus-2.1.25-1-aarch64        95.9 KiB   799 KiB/s 00:00 [########################################] 100% qt5-connectivity-5.15.3+kde+r6-1-aarch64    487.2 KiB   353 KiB/s 00:01 [########################################] 100% kdb-3.2.0-8-aarch64                           2.3 MiB   877 KiB/s 00:03 [########################################] 100% amazfish-2.0.5-1-aarch64                      7.5 MiB  2.45 MiB/s 00:03 [########################################] 100% Total (6/6)                                  10.6 MiB  3.39 MiB/s 00:03 [########################################] 100%
(6/6) checking keys in keyring                                           [########################################] 100%
(6/6) checking package integrity                                         [########################################] 100%
(6/6) loading package files                                              [########################################] 100%
(6/6) checking for file conflicts                                        [########################################] 100%
error: failed to commit transaction (conflicting files)
mpris-qt5: /usr/include/qt/MprisQt/Mpris exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/include/qt/MprisQt/MprisController exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/include/qt/MprisQt/MprisManager exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/include/qt/MprisQt/MprisPlayer exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/include/qt/MprisQt/mpris.h exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/include/qt/MprisQt/mpriscontroller.h exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/include/qt/MprisQt/mprismanager.h exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/include/qt/MprisQt/mprisplayer.h exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/include/qt/MprisQt/mprisqt.h exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/lib/libmpris-qt5.so exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/lib/libmpris-qt5.so.1 exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/lib/libmpris-qt5.so.1.0 exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/lib/libmpris-qt5.so.1.0.0 exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/lib/pkgconfig/mpris-qt5.pc exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/lib/qt/mkspecs/features/mpris-qt5.prf exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/lib/qt/qml/org/nemomobile/mpris/libmpris-qt5-qml-plugin.so exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/lib/qt/qml/org/nemomobile/mpris/plugins.qmltypes exists in filesystem (owned by qtmpris)
mpris-qt5: /usr/lib/qt/qml/org/nemomobile/mpris/qmldir exists in filesystem (owned by qtmpris)
When I try to uninstall qtmpris I get the following dependency error:
[eric@manjaro-arm ~]$ sudo pacman -R qtmpris
[sudo] password for eric:
checking dependencies...
:: removing qtmpris breaks dependency 'qtmpris' required by plasma-dialer
Thanks for reporting. Trying to see if Amazfish can be built with the qtmpris as a dependency instead.
EDIT:
Just uploaded version 2.0.5-2 to Unstable and Testing, which uses qtmpris instead of mpris-qt5. Hopefully that works.
Thanks @Strit! I cannot test it out at this time but it does install now.
