Hello ARM community.
Mostly point releases of stuff this time.
Attending Fosdem 2022 online conference this next weekend?
Some highlights:
- Most of our kernels got updated
- Firefox updated to 96.0.3
- And Thunderbird is now at version 91.5.1
- Pipewire updated to 0.3.44
- Mesa updated to 21.3.5
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Sun Jan 30 20:34:10 CET 2022)
- arm-testing community aarch64: 500 new and 479 removed package(s)
- arm-testing core aarch64: 43 new and 42 removed package(s)
- arm-testing extra aarch64: 327 new and 315 removed package(s)
- arm-testing kde-unstable aarch64: 274 new and 274 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-01-22 2022-01-30
chatty 0.6.0-0 0.6.0-2
electron 16.0.7-1 16.0.8-1
electron13 13.6.7-1 13.6.8-1
electron14 14.2.4-1 14.2.5-1
electron15 15.3.5-1 15.3.6-1
gnome-calls42beta1+10+g12ac809-042beta1+10+g12ac809-1
gtking-pro-post-install 20220121-1 20220125-1
phoc 0.12.0-0 0.12.0-2
phosh 0.15.0-0 0.15.0+19+g5f81a92-1
pinephone-manjaro-tweaks 20220114-1 20220126-1
pinephonepro-manjaro-tweaks 20220114-1 20220126-1
pinetab-post-install 20210610-1 20220128-1
rpi-eeprom 20211213-1 20220124-1
squeekboard 1.16.0-0 1.16.0+3+gdfe2c60-1
maliit-framework - 2.1.1-1.0
:: Different sync package(s) in repository community aarch64
adobe-source-han-serif-cn-fonts 2.000-1 2.001-1
adobe-source-han-serif-hk-fonts 2.000-1 2.001-1
adobe-source-han-serif-jp-fonts 2.000-1 2.001-1
adobe-source-han-serif-kr-fonts 2.000-1 2.001-1
adobe-source-han-serif-otc-fonts 2.000-1 2.001-1
adobe-source-han-serif-tw-fonts 2.000-1 2.001-1
adrdox 2.5.0-3 2.5.2-1
alacritty 0.9.0-3 0.10.0-2
appstream-generator 0.8.5-4 0.8.6-2
arb 2.22.0-1 2.22.1-1
argyllcms 2.2.1-1 2.3.0-1
atop 2.6.0-3 2.7.1-1
avisynthplus 3.7.1-1 3.7.1.a-1
avr-libc 2.0.0-4 2.1.0-1
awxkit 19.5.0-2 19.5.1-1
baidupcs-go 3.8.4-1 3.8.5-1
bandit 1.7.1-1 1.7.2-1
bat 0.18.3-1 0.19.0-1
bcc 0.22.0-5 0.23.0-1
bcc-tools 0.22.0-5 0.23.0-1
bemenu 0.6.4-1 0.6.4-2
bemenu-ncurses 0.6.4-1 0.6.4-2
bemenu-wayland 0.6.4-1 0.6.4-2
bemenu-x11 0.6.4-1 0.6.4-2
binocle 0.2.0-1 0.3.0-1
blender 17:3.0.0-4 17:3.0.1-1
bolt 0.9.1-1 0.9.2-1
bpftrace 0.14.0-2 0.14.1-1
broot 1.9.1-1 1.9.2-1
buildah 1.23.1-1 1.24.0-1
cadence 0.9.1-4 0.9.1-5
cage 0.1.4-3 0.1.4-4
cargo-c 0.9.7-1 0.9.7-2
cargo-crev 0.22.2-1 0.23.0-1
cargo-release 0.19.3-1 0.19.4-1
certbot 1.21.0-3 1.22.0-1
cherrytree 0.99.44-1 0.99.45-1
chezmoi 2.10.0-1 2.10.1-1
clojure 1.10.3.1058-1 1.10.3.1069-1
cockpit 260-1 261-1
cockpit-machines 259-1 260-1
cockpit-pcp 260-1 261-1
cockpit-podman 39-1 40-1
coin-or-cbc 2.10.6-1 2.10.7-1
conmon 1:2.0.32-2 1:2.1.0-1
containers-common 0.47.0-1 0.47.1-1
converseen 0.9.9.3-1 0.9.9.4-1
crun 1.4.1-1 1.4.2-1
crystal 1.3.0-1 1.3.2-1
cython 0.29.26-2 0.29.27-1
cython2 0.29.26-2 0.29.27-1
d-containers 0.8.0-5 0.8.0-6
d-mir-core 1.1.14-7 1.1.14-8
d-stdx-allocator 3.0.2-17 3.0.2-18
darkstat 3.0.721-1 3.0.721-2
dcd 1:0.13.6-1 1:0.13.6-2
diffoscope 200-1 202-1
doctl 1.69.0-1 1.70.0-1
drone 2.8.0-1 2.9.1-1
drone-oss 2.8.0-1 2.9.1-1
dscanner 0.11.1-1 0.11.1-2
dub 1.27.0-1 1.27.0-2
dune 2.9.1-2 2.9.2-1
erlang 24.2-1 24.2-3
erlang-nox 24.2-1 24.2-3
erlang-unixodbc 24.2-1 24.2-3
faudio 21.12-1 22.01-1
fcitx5-pinyin-zhwiki 1:0.2.3.20220101-1 1:0.2.3.20220127-1
fd 8.3.1-1 8.3.2-1
fetchmail 6.4.26-1 6.4.27-1
firetools 0.9.64-1 0.9.64-2
fpc 3.2.2-2 3.2.2-3
fs-uae 3.1.66-1 3.1.66-2
fs-uae-launcher 3.1.66-1 3.1.68-1
fwupd-efi 1.1-1 1.2-1
gambit-c 4.9.4-1 4.9.4-2
gauche 0.9.10-3 0.9.11-1
gdu 5.12.1-1 5.13.0-1
giac 1.7.0.45-1 1.7.0.47-1
giada 0.19.2-1 -
gifsicle 1.93-1 1.93-2
gimagereader-common 3.3.1-4 3.4.0-1
gimagereader-gtk 3.3.1-4 3.4.0-1
gimagereader-qt 3.3.1-4 3.4.0-1
gir-to-d 0.22.0-5 0.22.0-6
gitea 1.15.8-1 1.15.10-1
gitui 0.19.0-1 0.20.1-1
glibd 2.3.0-4 2.3.0-5
gnome-break-timer 2.0.3-2 2.1.0-1
go-tools 4:0.1.8-1 4:0.1.9-1
go-yq 4.17.2-1 4.18.1-1
gopls 0.7.4-1 0.7.5-1
goreleaser 1.3.0-1 1.4.1-1
gqrx 2.15.1-1 2.15.8-1
grpc 1.43.0-3 1.43.2-1
grpc-cli 1.43.0-3 1.43.2-1
gtk-layer-shell 0.6.0-2 0.7.0-1
gtkd 3.10.0-1 3.10.0-2
helm 3.7.2-1 3.8.0-1
helmfile 0.142.0-1 0.143.0-1
helvum 0.3.2-1 0.3.3-1
hiera 3.7.0-2 3.8.0-1
highway 0.14.2-2 0.15.0-1
hivex 1.3.21-3 1.3.21-4
htmldoc 1.9.14-1 1.9.14-2
htmlhint 1.1.0-1 1.1.2-1
i3-wm 4.20.1-1 4.20.1-2
irker 2.20-1 2.21-1
iverilog 11.0-1 11.0-2
iwd 1.21-1 1.23-1
jenkins 2.331-1 2.332-1
jmol 14.32.14-1 14.32.15-1
jsmol 14.32.14-1 14.32.15-1
juce 6.1.4-1 6.1.5-1
juce-docs 6.1.4-1 6.1.5-1
jupyter-nbclient 0.5.4-4 0.5.10-1
jupyter-nbconvert 6.1.0-5 6.4.1-1
jupyter-notebook 6.4.4-4 6.4.7-1
jupyter-widgetsnbextension 1:3.5.1-5 1:3.5.2-1
kak-lsp 11.1.0-1 12.0.1-1
kiwix-desktop 2.0.5-1 2.1.0-1
kiwix-tools 3.1.2-6 3.2.0-1
kubeone 1.3.0-1 1.3.3-1
kubeseal 0.17.2-1 0.17.3-1
latte-dock 0.10.7-1 0.10.8-1
ldc 3:1.28.0-3 3:1.28.1-1
libaxc 0.3.6-1 0.3.7-1
libemf 1.0.13-1 1.0.13-2
libilbc 3.0.4-1 3.0.4-2
libjxl 0.6.1-2 0.6.1-3
libjxl-doc 0.6.1-2 0.6.1-3
libliftoff 0.1.0-2 0.1.0.r31.2e1dd93-1
liblphobos 3:1.28.0-3 3:1.28.1-1
libmysofa 1.2.1-1 1.2.1-2
libpano13 2.9.20-1 2.9.21-1
libperconaserverclient 8.0.26_16-5 8.0.26_17-1
libsvm 3.25-3 3.25-4
libvirt-python 1:7.8.0-3 1:8.0.0-1
libzim 7.1.0-1 7.2.0-1
log4cxx 0.12.0-1 0.12.1-1
lrzsz 0.12.20-7 0.12.20-8
lua-language-server 2.6.0-1 2.6.3-1
lv2file 0.91-1 0.93-1
lzlib 1.12-2 1.13-1
matrix-synapse 1.50.1-1 1.50.2-1
mcfly 0.5.12-1 0.5.13-1
mcomix 1.3.0.dev0-5 1.3.0.dev0-6
miniflux 2.0.34-2 2.0.35-1
minikube 1.24.0-1 1.25.1-1
minted 2.5-3 2.6-1
mpv 1:0.34.1-1 1:0.34.1-2
mujs 1.2.0-1 1.2.0-2
mumble 1.3.4-12 1.4.230-2
murmur 1.3.4-12 1.4.230-2
mustache-d 0.1.5-4 0.1.5-5
nawk 20180827-2 20220122-1
nebula 1.5.0-1 1.5.2-1
netdata 1.32.1-2 1.33.0-1
nextcloud 23.0.0-2 23.0.0-4
nextcloud-app-spreed 1:13.0.1-1 1:13.0.2-1
nextcloud-client 2:3.4.1-1 2:3.4.2-1
nextcloud-client-cloudproviders 2:3.4.1-1 2:3.4.2-1
nginx-mod-njs 0.7.1-1 0.7.2-1
nix 2.5.1-2 2.6.0-1
nix-docs 2.5.1-2 2.6.0-1
nodejs-lts-erbium 12.22.8-1 12.22.9-1
nodejs-lts-fermium 14.18.2-1 14.18.3-1
nodejs-lts-gallium 16.13.1-1 16.13.2-1
notmuch 0.34.2-1 0.34.3-1
notmuch-mutt 0.34.2-1 0.34.3-1
notmuch-runtime 0.34.2-1 0.34.3-1
notmuch-vim 0.34.2-1 0.34.3-1
npm 8.3.2-1 8.4.0-1
nsd 4.3.8-1 4.3.9-1
nvme-cli 1.16-1 1.16-2
ocrad 0.27-2 0.28-1
oil 0.9.6-1 0.9.7-1
opendoas 6.8.1-3 6.8.2-1
pantheon-calendar 6.0.3-2 6.1.0-1
pantheon-files 6.1.1-1 6.1.2-1
pantheon-mail 6.3.1-2 6.4.0-1
parallel 20211222-1 20220122-1
parallel-docs 20211222-1 20220122-1
pax 20201030-1 20201030-2
pd-gem 0.94-7 0.94-8
percona-server 8.0.26_16-5 8.0.26_17-1
percona-server-clients 8.0.26_16-5 8.0.26_17-1
perl-par-packer 1.052-4 1.054-1
perl-path-tiny 0.120-1 0.122-1
php-grpc 1.43.0-3 1.43.2-1
php-memcached 3.1.5.r16.gbfb0a66-2 3.1.5.r50.gd3b8ce1-1
php7-grpc 1.43.0-3 1.43.2-1
php7-memcached 3.1.5.r16.gbfb0a66-2 3.1.5.r50.gd3b8ce1-1
phpmyadmin 5.1.1-1 5.1.2-1
piping-server 0.10.2-1 0.12.0-1
poke 1.4-1 2.0-1
powerdns 4.5.3-1 4.6.0-1
primesieve 7.7-1 7.8-1
procs 0.12.0-1 0.12.1-1
prosody 1:0.11.12-1 1:0.11.13-1
proxychains-ng 4.15-1 4.16-1
pulumi 3.22.1-1 3.23.2-1
pyenv 2.2.3-1 2.2.4-1
pyright 1.1.212-1 1.1.216-1
python-acme 1.21.0-3 1.22.0-3
python-bcc 0.22.0-5 0.23.0-1
python-black 21.12b0-3 22.1.0-1
python-cheroot 8.5.2-6 8.6.0-1
python-decorator 5.1.0-3 5.1.1-1
python-dephell 0.8.3-6 0.8.3-7
python-dephell-setuptools 0.2.4-3 0.2.4-4
python-django-classy-tags 2.0.0-6 3.0.0-1
python-django-crispy-forms 1.13.0-3 1.14.0-1
python-django-sekizai 2.0.0-7 3.0.0-1
python-dnspython 1:2.1.0-3 1:2.2.0-1
python-dropbox 11.25.0-2 11.26.0-1
python-dulwich 0.20.30-1 0.20.32-1
python-emoji 1.6.1-1 1.6.3-1
python-fonttools 4.28.5-1 4.29.0-1
python-gast 0.5.2-3 0.5.3-1
python-gitlab 3.1.0-1 3.1.1-1
python-google-api-python-client 2.35.0-1 2.36.0-1
python-graphql-relay 3.1.0-3 3.1.4-1
python-grpcio 1.43.0-3 1.43.2-1
python-heatclient 2.4.0-2 2.5.0-1
python-httpcore 0.14.3-3 0.14.5-1
python-httpx 0.21.3-1 0.22.0-1
python-identify 2.4.4-1 2.4.5-1
python-internetarchive 2.2.0-1 2.3.0-1
python-jaraco 2021.12.20-1 2022.1.24-1
python-jsondiff 1.3.0-3 1.3.1-1
python-matplotlib 3.5.1-1 3.5.1-2
python-mistune 2.0.0-2 2.0.2-1
python-nose-progressive 1.5.2-8 -
python-noseofyeti 2.2.0-1 2.3.0-1
python-orjson 3.6.5-2 3.6.6-1
python-ovirt-engine-sdk 4.4.14-2 4.4.15-1
python-pandas 1.3.5-1 1.4.0-1
python-pandocfilters 1.4.3-5 1.5.0-1
python-pikepdf 4.3.1-1 4.4.1-1
python-pilkit 2.0-9 2.0-10
python-pivy 0.6.6-3 0.6.6-4
python-prompt_toolkit 3.0.24-1 3.0.26-1
python-pure-eval 0.2.1-2 0.2.2-1
python-pynitrokey 0.4.10-1 0.4.13-1
python-pytesseract 0.3.8-3 0.3.9-1
python-pytest-django 4.5.1-1 4.5.2-1
python-pytest-forked 1.3.0-6 1.4.0-1
python-pytest-xdist 2.4.0-3 2.5.0-1
python-python-socks 2.0.2-1 2.0.3-1
python-pywayland 0.4.7-3 0.4.9-1
python-pywlroots 0.14.12-1 0.15.3-1
python-pyzmq 22.2.1-3 22.3.0-1
python-reportlab 3.6.5-1 3.6.6-1
python-rich 10.16.2-1 11.1.0-1
python-selenium 3.141.0-4 -
python-sphinx-click 3.0.2-3 3.0.3-1
python-stone 3.2.1-3 3.3.1-1
python-svglib 1.2.0-1 1.2.1-1
python-tempora 4.1.2-3 5.0.0-1
python-terminado 0.11.1-3 0.13.1-1
python-traitlets 5.1.0-3 5.1.1-1
python-tweepy 4.4.0-1 4.5.0-1
python-typed-ast 1.5.1-1 1.5.2-1
python-unidiff 0.7.0-3 0.7.2-1
python-zipp 3.6.0-3 3.7.0-1
qtile 0.19.0-1 0.20.0-1
radicale 3.1.1-1 3.1.3-1
realtime-privileges 3-1 4-1
release-cli 0.10.0-1 0.11.0-1
remake 4.3+dbg1.5-1 4.3+dbg1.6-1
remind 3.3.10-1 3.3.11-1
rime-pinyin-zhwiki 1:0.2.3.20220101-1 1:0.2.3.20220127-1
rofi 1.7.2-1 1.7.3-1
rtosc 0.2.0-3 0.3.1-1
rubberband 2.0.1-1 2.0.2-1
ruby-i18n 1.8.11-1 1.9.1-1
ruby-irb 1.3.6-1 1.4.1-1
ruby-msgpack 1.4.2-3 1.4.4-1
ruby-nokogiri 1.12.5-2 1.13.1-1
ruby-rails-html-sanitizer 1.4.2-1 1.4.2-2
ruby-reline 0.2.5-1 0.3.1-1
rust-analyzer 20220117-1 20220124-1
schroot 1.6.10-29 1.6.10-30
scribus 1.5.7-12 1.5.8-1
sentry-cli 1.71.0-1 1.72.1-1
sequoia-sop 0.24.0-1 0.25.0-1
serverless 2.72.1-1 3.0.1-1
sile 0.12.1-1 0.12.2-1
simutrans 122.0-1 123.0-1
skrooge 2.26.1-2 2.27.0-1
squid 5.2-3 5.3-1
sssd 2.6.1-3 2.6.3-1
stellarsolver 1.8-2 1.9-2
stunnel 5.61-1 5.62-1
stylelint 14.2.0-1 14.3.0-1
sundials 6.1.0-1 6.1.0-2
supermin 5.2.1-2 5.3.1-1
sway 1:1.6.1-3 1:1.7-1
tailscale 1.20.1-1 1.20.2-1
taskwarrior-tui 0.18.2-1 0.18.5-1
tcsh 6.23.00-1 6.23.02-1
terraform 1.1.3-1 1.1.4-1
terragrunt 0.35.20-1 0.36.0-1
tesseract 4.1.1-8 5.0.1-2
tesseract-data-afr 2:4.1.0-1 2:4.1.0-2
tesseract-data-amh 2:4.1.0-1 2:4.1.0-2
tesseract-data-ara 2:4.1.0-1 2:4.1.0-2
tesseract-data-asm 2:4.1.0-1 2:4.1.0-2
tesseract-data-aze 2:4.1.0-1 2:4.1.0-2
tesseract-data-aze_cyrl 2:4.1.0-1 2:4.1.0-2
tesseract-data-bel 2:4.1.0-1 2:4.1.0-2
tesseract-data-ben 2:4.1.0-1 2:4.1.0-2
tesseract-data-bod 2:4.1.0-1 2:4.1.0-2
tesseract-data-bos 2:4.1.0-1 2:4.1.0-2
tesseract-data-bre 2:4.1.0-1 2:4.1.0-2
tesseract-data-bul 2:4.1.0-1 2:4.1.0-2
tesseract-data-cat 2:4.1.0-1 2:4.1.0-2
tesseract-data-ceb 2:4.1.0-1 2:4.1.0-2
tesseract-data-ces 2:4.1.0-1 2:4.1.0-2
tesseract-data-chi_sim 2:4.1.0-1 2:4.1.0-2
tesseract-data-chi_tra 2:4.1.0-1 2:4.1.0-2
tesseract-data-chr 2:4.1.0-1 2:4.1.0-2
tesseract-data-cos 2:4.1.0-1 2:4.1.0-2
tesseract-data-cym 2:4.1.0-1 2:4.1.0-2
tesseract-data-dan 2:4.1.0-1 2:4.1.0-2
tesseract-data-dan_frak 2:4.1.0-1 2:4.1.0-2
tesseract-data-deu 2:4.1.0-1 2:4.1.0-2
tesseract-data-deu_frak 2:4.1.0-1 2:4.1.0-2
tesseract-data-div 2:4.1.0-1 2:4.1.0-2
tesseract-data-dzo 2:4.1.0-1 2:4.1.0-2
tesseract-data-ell 2:4.1.0-1 2:4.1.0-2
tesseract-data-eng 2:4.1.0-1 2:4.1.0-2
tesseract-data-enm 2:4.1.0-1 2:4.1.0-2
tesseract-data-epo 2:4.1.0-1 2:4.1.0-2
tesseract-data-equ 2:4.1.0-1 2:4.1.0-2
tesseract-data-est 2:4.1.0-1 2:4.1.0-2
tesseract-data-eus 2:4.1.0-1 2:4.1.0-2
tesseract-data-fao 2:4.1.0-1 2:4.1.0-2
tesseract-data-fas 2:4.1.0-1 2:4.1.0-2
tesseract-data-fil 2:4.1.0-1 2:4.1.0-2
tesseract-data-fin 2:4.1.0-1 2:4.1.0-2
tesseract-data-fra 2:4.1.0-1 2:4.1.0-2
tesseract-data-frk 2:4.1.0-1 2:4.1.0-2
tesseract-data-frm 2:4.1.0-1 2:4.1.0-2
tesseract-data-fry 2:4.1.0-1 2:4.1.0-2
tesseract-data-gla 2:4.1.0-1 2:4.1.0-2
tesseract-data-gle 2:4.1.0-1 2:4.1.0-2
tesseract-data-glg 2:4.1.0-1 2:4.1.0-2
tesseract-data-grc 2:4.1.0-1 2:4.1.0-2
tesseract-data-guj 2:4.1.0-1 2:4.1.0-2
tesseract-data-hat 2:4.1.0-1 2:4.1.0-2
tesseract-data-heb 2:4.1.0-1 2:4.1.0-2
tesseract-data-hin 2:4.1.0-1 2:4.1.0-2
tesseract-data-hrv 2:4.1.0-1 2:4.1.0-2
tesseract-data-hun 2:4.1.0-1 2:4.1.0-2
tesseract-data-hye 2:4.1.0-1 2:4.1.0-2
tesseract-data-iku 2:4.1.0-1 2:4.1.0-2
tesseract-data-ind 2:4.1.0-1 2:4.1.0-2
tesseract-data-isl 2:4.1.0-1 2:4.1.0-2
tesseract-data-ita 2:4.1.0-1 2:4.1.0-2
tesseract-data-ita_old 2:4.1.0-1 2:4.1.0-2
tesseract-data-jav 2:4.1.0-1 2:4.1.0-2
tesseract-data-jpn 2:4.1.0-1 2:4.1.0-2
tesseract-data-kan 2:4.1.0-1 2:4.1.0-2
tesseract-data-kat 2:4.1.0-1 2:4.1.0-2
tesseract-data-kat_old 2:4.1.0-1 2:4.1.0-2
tesseract-data-kaz 2:4.1.0-1 2:4.1.0-2
tesseract-data-khm 2:4.1.0-1 2:4.1.0-2
tesseract-data-kir 2:4.1.0-1 2:4.1.0-2
tesseract-data-kmr 2:4.1.0-1 2:4.1.0-2
tesseract-data-kor 2:4.1.0-1 2:4.1.0-2
tesseract-data-kor_vert 2:4.1.0-1 2:4.1.0-2
tesseract-data-lao 2:4.1.0-1 2:4.1.0-2
tesseract-data-lat 2:4.1.0-1 2:4.1.0-2
tesseract-data-lav 2:4.1.0-1 2:4.1.0-2
tesseract-data-lit 2:4.1.0-1 2:4.1.0-2
tesseract-data-ltz 2:4.1.0-1 2:4.1.0-2
tesseract-data-mal 2:4.1.0-1 2:4.1.0-2
tesseract-data-mar 2:4.1.0-1 2:4.1.0-2
tesseract-data-mkd 2:4.1.0-1 2:4.1.0-2
tesseract-data-mlt 2:4.1.0-1 2:4.1.0-2
tesseract-data-mon 2:4.1.0-1 2:4.1.0-2
tesseract-data-mri 2:4.1.0-1 2:4.1.0-2
tesseract-data-msa 2:4.1.0-1 2:4.1.0-2
tesseract-data-mya 2:4.1.0-1 2:4.1.0-2
tesseract-data-nep 2:4.1.0-1 2:4.1.0-2
tesseract-data-nld 2:4.1.0-1 2:4.1.0-2
tesseract-data-nor 2:4.1.0-1 2:4.1.0-2
tesseract-data-oci 2:4.1.0-1 2:4.1.0-2
tesseract-data-ori 2:4.1.0-1 2:4.1.0-2
tesseract-data-osd 2:4.1.0-1 2:4.1.0-2
tesseract-data-pan 2:4.1.0-1 2:4.1.0-2
tesseract-data-pol 2:4.1.0-1 2:4.1.0-2
tesseract-data-por 2:4.1.0-1 2:4.1.0-2
tesseract-data-pus 2:4.1.0-1 2:4.1.0-2
tesseract-data-que 2:4.1.0-1 2:4.1.0-2
tesseract-data-ron 2:4.1.0-1 2:4.1.0-2
tesseract-data-rus 2:4.1.0-1 2:4.1.0-2
tesseract-data-san 2:4.1.0-1 2:4.1.0-2
tesseract-data-sin 2:4.1.0-1 2:4.1.0-2
tesseract-data-slk 2:4.1.0-1 2:4.1.0-2
tesseract-data-slk_frak 2:4.1.0-1 2:4.1.0-2
tesseract-data-slv 2:4.1.0-1 2:4.1.0-2
tesseract-data-snd 2:4.1.0-1 2:4.1.0-2
tesseract-data-spa 2:4.1.0-1 2:4.1.0-2
tesseract-data-spa_old 2:4.1.0-1 2:4.1.0-2
tesseract-data-sqi 2:4.1.0-1 2:4.1.0-2
tesseract-data-srp 2:4.1.0-1 2:4.1.0-2
tesseract-data-srp_latn 2:4.1.0-1 2:4.1.0-2
tesseract-data-sun 2:4.1.0-1 2:4.1.0-2
tesseract-data-swa 2:4.1.0-1 2:4.1.0-2
tesseract-data-swe 2:4.1.0-1 2:4.1.0-2
tesseract-data-syr 2:4.1.0-1 2:4.1.0-2
tesseract-data-tam 2:4.1.0-1 2:4.1.0-2
tesseract-data-tat 2:4.1.0-1 2:4.1.0-2
tesseract-data-tel 2:4.1.0-1 2:4.1.0-2
tesseract-data-tgk 2:4.1.0-1 2:4.1.0-2
tesseract-data-tgl 2:4.1.0-1 2:4.1.0-2
tesseract-data-tha 2:4.1.0-1 2:4.1.0-2
tesseract-data-tir 2:4.1.0-1 2:4.1.0-2
tesseract-data-ton 2:4.1.0-1 2:4.1.0-2
tesseract-data-tur 2:4.1.0-1 2:4.1.0-2
tesseract-data-uig 2:4.1.0-1 2:4.1.0-2
tesseract-data-ukr 2:4.1.0-1 2:4.1.0-2
tesseract-data-urd 2:4.1.0-1 2:4.1.0-2
tesseract-data-uzb 2:4.1.0-1 2:4.1.0-2
tesseract-data-uzb_cyrl 2:4.1.0-1 2:4.1.0-2
tesseract-data-vie 2:4.1.0-1 2:4.1.0-2
tesseract-data-yid 2:4.1.0-1 2:4.1.0-2
tesseract-data-yor 2:4.1.0-1 2:4.1.0-2
texstudio 4.2.0-1 4.2.1-1
traefik 2.5.6-1 2.6.0-1
transcode 1.1.7-38 1.1.7-39
tree-sitter 0.20.3-1 0.20.4-1
tt-rss 2:r11198.7aeaa1b03-1 2:r11216.56fd06d61-2
ufw-extras 0.6.0-1 0.7.0-1
uglify-js 3.14.5-1 3.15.0-1
umockdev 0.17.5-1 0.17.6-1
urlscan 0.9.8-1 0.9.9-1
uvicorn 0.17.0-1 0.17.0.post1-1
v2ray-domain-list-community 20220121101834-1 20220124140856-1
v2ray-geoip 202201200035-1 202201270031-1
vaultwarden 1.23.1-1 1.23.1-2
vaultwarden-web 2.25.0-1 2.25.1-1
vice 3.6.0-1 3.6.1-1
vivid 0.7.0-1 0.8.0-1
vnstat 2.8-1 2.9-1
watchexec 1.18.0-1 1.18.4-1
waylock 0.3.3-2 0.3.4-1
wf-recorder 0.2.1-2 0.2.1-3
wlroots 0.14.1-3 0.15.0-4
woob 3.0-4 3.0-5
wordpress 5.8.3-1 5.9-1
wt 4.5.0-5 4.6.1-1
wtype 0.3-2 0.4-1
x11vnc 1:0.9.16-4 1:0.9.16-5
xh 0.14.1-1 0.15.0-1
xl2tpd 1.3.16-1 1.3.17-1
xsel 1.2.0.20190821-1 1.2.0.20200527-1
xwallpaper 0.7.3-1 0.7.3-2
zeroc-ice 3.7.6-1 3.7.7-1
zim-tools 3.0.0-1 3.1.0-1
zola 0.15.2-1 0.15.3-1
zynaddsubfx 3.0.5-2 3.0.6-2
charm - 0.9.2-2
fcft - 2.5.1-2
gamescope - 3.11.0beta4-1
glow - 1.4.1-2
i3-wm-debug - 4.20.1-2
libkiwix - 10.0.0-1
lua53-lgi - 0.9.2-4.1
nvme-cli-debug - 1.16-2
python-pythonfinder - 1.2.9-3
python-socksio - 1.0.0-1
rnote - 0.3.0-1
rtosc-docs - 0.3.1-1
ruby-globalid - 1.0.0-1
ruby-marcel - 1.0.2-1
ruby-method_source - 1.0.0-2
ruby-permessage_deflate - 0.1.4-1
ruby-websocket-driver - 0.7.5-2
ruby-websocket-extensions - 0.1.5-2
skate - 0.1.3-2
soft-serve - 0.1.3-2
tllist - 1.0.5-3
xwallpaper-debug - 0.7.3-2
youtube-dl - 2021.12.17-1
:: Different overlay package(s) in repository core aarch64
linux 5.16.2-4 5.16.4-1
linux-clockworkpi-a06 5.16.2-2 5.16.4-1
linux-clockworkpi-a06-headers 5.16.2-2 5.16.4-1
linux-headers 5.16.2-4 5.16.4-1
linux-khadas 5.16.2-1 5.16.2-2
linux-khadas-headers 5.16.2-1 5.16.2-2
linux-lts 5.15.16-2 5.15.18-1
linux-lts-headers 5.15.16-2 5.15.18-1
linux-pinephone 5.16.2-1 5.16.4-1
linux-pinephone-headers 5.16.2-1 5.16.4-1
linux-pinephonepro 5.16.2-2 5.16.4-1
linux-pinephonepro-headers 5.16.2-2 5.16.4-1
linux-quartz64 5.16.0-0.9 5.16.0-0.10
linux-quartz64-headers 5.16.0-0.9 5.16.0-0.10
linux-rc 5.16.rc8-2 5.17.rc2-1
linux-rc-headers 5.16.rc8-2 5.17.rc2-1
linux-rpi4 5.10.92-1 5.10.94-1
linux-rpi4-headers 5.10.92-1 5.10.94-1
linux-rpi4-mainline 5.16.1-1 5.16.3-1
linux-rpi4-mainline-headers 5.16.1-1 5.16.3-1
linux-rpi4-rc 5.16.rc8-1 5.17.rc1-1
linux-rpi4-rc-headers 5.16.rc8-1 5.17.rc1-1
raspberrypi-bootloader 20220117-1 20220124-1
raspberrypi-bootloader-x 20220117-1 20220124-1
uboot-pinephonepro 3:2021.01rc3-2 4:2021.01-1
:: Different sync package(s) in repository core aarch64
archlinux-keyring 20220118-1 20220125-1
dialog 1:1.3_20211214-1 1:1.3_20220117-1
glib2 2.70.2-2 2.70.3-1
glib2-docs 2.70.2-2 2.70.3-1
libcap 2.62-1 2.63-1
libgpg-error 1.43-1 1.44-1
libldap 2.6.0-2 2.6.1-1
licenses 20200427-1 20220125-1
nfs-utils 2.5.4-2 2.6.1-1
nfsidmap 2.5.4-2 2.6.1-1
openldap 2.6.0-2 2.6.1-1
python 3.10.1-2 3.10.2-1
python-tests 3.10.1-2 3.10.2-1
util-linux 2.37.2-5 2.37.3-1
util-linux-libs 2.37.2-5 2.37.3-1
wpa_supplicant 2:2.9-8 2:2.10-1
zstd 1.5.1-2.1 1.5.2-2
zstd-debug - 1.5.2-2
:: Different overlay package(s) in repository extra aarch64
alsa-card-profiles 1:0.3.43-1.1 -
gst-plugin-pipewire 1:0.3.43-1.1 -
libnma 1.8.32-1 -
libpamac 11.2.0-1 11.2.0-6
libpamac-flatpak-plugin 11.2.0-1 11.2.0-6
libpamac-snap-plugin 11.2.0-1 11.2.0-6
mesa-git22.0.0_devel.149220.4198ca4b3f6-122.0.0_devel.149534.708a33d1328-1
pamac-cli 10.3.0-1 10.3.0-4
pamac-gnome-integration 10.3.0-1 10.3.0-4
pamac-gtk 10.3.0-1 10.3.0-4
pipewire-alsa 1:0.3.43-1.1 -
pipewire-docs 1:0.3.43-1.1 -
pipewire-jack 1:0.3.43-1.1 -
pipewire-pulse 1:0.3.43-1.1 -
pipewire-v4l2 1:0.3.43-1.1 -
pipewire-zeroconf 1:0.3.43-1.1 -
polkit 0.120-3.0 -
qt5-es2-base 5.15.2+kde+r294-1 5.15.2+kde+r295-1
qt5-es2-wayland 5.15.2+kde+r41-1.1 5.15.2+kde+r46-1
qt5-es2-xcb-private-headers 5.15.2+kde+r294-1 5.15.2+kde+r295-1
kactivitymanagerd - 5.23.5-1.0
plasma-framework - 5.90.0-1.0
:: Different sync package(s) in repository extra aarch64
accountsservice 0.6.55-3 22.04.62-2
alsa-card-profiles 1:0.3.43-5 1:0.3.44-1
arch-rebuild-order 0.3-1 0.3-2
archboot-arm 2022.01-60 2022.01-89
booster 0.7-1 0.7-2
chromium 97.0.4692.99-1 97.0.4692.99-2
clawsker 1.3.4-1 1.3.5-1
cmake 3.22.1-5 3.22.2-1
cups 1:2.4.0-4 1:2.4.1-1
ddcutil 1.2.1-1 1.2.2-1
devtools 20211129-1 20220126-1
eclipse-ecj 4.6.3-2 4.22-1
ell 0.47-1 0.48-1
ethtool 1:5.15-1 1:5.16-1
faac 1.30-2 1.30-3
firefox 96.0.2-1 96.0.3-1
firefox-i18n-ach 96.0.2-1 96.0.3-1
firefox-i18n-af 96.0.2-1 96.0.3-1
firefox-i18n-an 96.0.2-1 96.0.3-1
firefox-i18n-ar 96.0.2-1 96.0.3-1
firefox-i18n-ast 96.0.2-1 96.0.3-1
firefox-i18n-az 96.0.2-1 96.0.3-1
firefox-i18n-be 96.0.2-1 96.0.3-1
firefox-i18n-bg 96.0.2-1 96.0.3-1
firefox-i18n-bn 96.0.2-1 96.0.3-1
firefox-i18n-br 96.0.2-1 96.0.3-1
firefox-i18n-bs 96.0.2-1 96.0.3-1
firefox-i18n-ca 96.0.2-1 96.0.3-1
firefox-i18n-ca-valencia 96.0.2-1 96.0.3-1
firefox-i18n-cak 96.0.2-1 96.0.3-1
firefox-i18n-cs 96.0.2-1 96.0.3-1
firefox-i18n-cy 96.0.2-1 96.0.3-1
firefox-i18n-da 96.0.2-1 96.0.3-1
firefox-i18n-de 96.0.2-1 96.0.3-1
firefox-i18n-dsb 96.0.2-1 96.0.3-1
firefox-i18n-el 96.0.2-1 96.0.3-1
firefox-i18n-en-ca 96.0.2-1 96.0.3-1
firefox-i18n-en-gb 96.0.2-1 96.0.3-1
firefox-i18n-en-us 96.0.2-1 96.0.3-1
firefox-i18n-eo 96.0.2-1 96.0.3-1
firefox-i18n-es-ar 96.0.2-1 96.0.3-1
firefox-i18n-es-cl 96.0.2-1 96.0.3-1
firefox-i18n-es-es 96.0.2-1 96.0.3-1
firefox-i18n-es-mx 96.0.2-1 96.0.3-1
firefox-i18n-et 96.0.2-1 96.0.3-1
firefox-i18n-eu 96.0.2-1 96.0.3-1
firefox-i18n-fa 96.0.2-1 96.0.3-1
firefox-i18n-ff 96.0.2-1 96.0.3-1
firefox-i18n-fi 96.0.2-1 96.0.3-1
firefox-i18n-fr 96.0.2-1 96.0.3-1
firefox-i18n-fy-nl 96.0.2-1 96.0.3-1
firefox-i18n-ga-ie 96.0.2-1 96.0.3-1
firefox-i18n-gd 96.0.2-1 96.0.3-1
firefox-i18n-gl 96.0.2-1 96.0.3-1
firefox-i18n-gn 96.0.2-1 96.0.3-1
firefox-i18n-gu-in 96.0.2-1 96.0.3-1
firefox-i18n-he 96.0.2-1 96.0.3-1
firefox-i18n-hi-in 96.0.2-1 96.0.3-1
firefox-i18n-hr 96.0.2-1 96.0.3-1
firefox-i18n-hsb 96.0.2-1 96.0.3-1
firefox-i18n-hu 96.0.2-1 96.0.3-1
firefox-i18n-hy-am 96.0.2-1 96.0.3-1
firefox-i18n-ia 96.0.2-1 96.0.3-1
firefox-i18n-id 96.0.2-1 96.0.3-1
firefox-i18n-is 96.0.2-1 96.0.3-1
firefox-i18n-it 96.0.2-1 96.0.3-1
firefox-i18n-ja 96.0.2-1 96.0.3-1
firefox-i18n-ka 96.0.2-1 96.0.3-1
firefox-i18n-kab 96.0.2-1 96.0.3-1
firefox-i18n-kk 96.0.2-1 96.0.3-1
firefox-i18n-km 96.0.2-1 96.0.3-1
firefox-i18n-kn 96.0.2-1 96.0.3-1
firefox-i18n-ko 96.0.2-1 96.0.3-1
firefox-i18n-lij 96.0.2-1 96.0.3-1
firefox-i18n-lt 96.0.2-1 96.0.3-1
firefox-i18n-lv 96.0.2-1 96.0.3-1
firefox-i18n-mk 96.0.2-1 96.0.3-1
firefox-i18n-mr 96.0.2-1 96.0.3-1
firefox-i18n-ms 96.0.2-1 96.0.3-1
firefox-i18n-my 96.0.2-1 96.0.3-1
firefox-i18n-nb-no 96.0.2-1 96.0.3-1
firefox-i18n-ne-np 96.0.2-1 96.0.3-1
firefox-i18n-nl 96.0.2-1 96.0.3-1
firefox-i18n-nn-no 96.0.2-1 96.0.3-1
firefox-i18n-oc 96.0.2-1 96.0.3-1
firefox-i18n-pa-in 96.0.2-1 96.0.3-1
firefox-i18n-pl 96.0.2-1 96.0.3-1
firefox-i18n-pt-br 96.0.2-1 96.0.3-1
firefox-i18n-pt-pt 96.0.2-1 96.0.3-1
firefox-i18n-rm 96.0.2-1 96.0.3-1
firefox-i18n-ro 96.0.2-1 96.0.3-1
firefox-i18n-ru 96.0.2-1 96.0.3-1
firefox-i18n-si 96.0.2-1 96.0.3-1
firefox-i18n-sk 96.0.2-1 96.0.3-1
firefox-i18n-sl 96.0.2-1 96.0.3-1
firefox-i18n-son 96.0.2-1 96.0.3-1
firefox-i18n-sq 96.0.2-1 96.0.3-1
firefox-i18n-sr 96.0.2-1 96.0.3-1
firefox-i18n-sv-se 96.0.2-1 96.0.3-1
firefox-i18n-ta 96.0.2-1 96.0.3-1
firefox-i18n-te 96.0.2-1 96.0.3-1
firefox-i18n-th 96.0.2-1 96.0.3-1
firefox-i18n-tl 96.0.2-1 96.0.3-1
firefox-i18n-tr 96.0.2-1 96.0.3-1
firefox-i18n-trs 96.0.2-1 96.0.3-1
firefox-i18n-uk 96.0.2-1 96.0.3-1
firefox-i18n-ur 96.0.2-1 96.0.3-1
firefox-i18n-uz 96.0.2-1 96.0.3-1
firefox-i18n-vi 96.0.2-1 96.0.3-1
firefox-i18n-xh 96.0.2-1 96.0.3-1
firefox-i18n-zh-cn 96.0.2-1 96.0.3-1
firefox-i18n-zh-tw 96.0.2-1 96.0.3-1
fluidsynth 2.2.4-1 2.2.5-1
gdb 11.1-4 11.2-1
gdb-common 11.1-4 11.2-1
geeqie 1.7.1-1 1.7.2-1
geoip-database 20211221-1 20220125-1
geoip-database-extra 20211221-1 20220125-1
git 2.34.1-1 2.35.1-1
gn 0.1938.0153d369-1 0.1956.fc295f3a-1
grml-zsh-config 0.19.0-2 0.19.1-1
gst-plugin-pipewire 1:0.3.43-5 1:0.3.44-1
hwdetect 2021.10-1 2022.01-5
imagemagick 7.1.0.19-1 7.1.0.21-1
imagemagick-doc 7.1.0.19-1 7.1.0.21-1
jack-example-tools 1-2 1-3
js78 78.15.0-2 78.15.0-3
kismet 2021_08_R1-4 2022_01_R1-1
libbsd 0.11.3-1 0.11.5-1
libcups 1:2.4.0-4 1:2.4.1-1
libplacebo 4.157.0-1 4.192.0-1
libunrar 1:6.1.3-1 1:6.1.4-1
libva-mesa-driver 21.3.4-1 21.3.5-1.1
lua 5.4.3-1 5.4.4-1
lua53-lgi 0.9.2-4.1 -
mesa 21.3.4-1 21.3.5-1.1
mesa-vdpau 21.3.4-1 21.3.5-1.1
muparser 2.3.2-1 2.3.3-1
noto-fonts-cjk 20211026-1 20220126-1
opencl-mesa 21.3.4-1 21.3.5-1.1
openexr 3.1.3-1 3.1.4-1
perl-io-socket-ssl 2.073-1 2.074-1
pipewire-alsa 1:0.3.43-5 1:0.3.44-1
pipewire-docs 1:0.3.43-5 1:0.3.44-1
pipewire-jack 1:0.3.43-5 1:0.3.44-1
pipewire-pulse 1:0.3.43-5 1:0.3.44-1
pipewire-v4l2 1:0.3.43-5 1:0.3.44-1
pipewire-zeroconf 1:0.3.43-5 1:0.3.44-1
polkit 0.120-3 0.120-4
protobuf 3.19.2-1 3.19.4-1
python-asgiref 3.4.1-3 3.5.0-1
python-lxml 4.6.5-1 4.7.1-1
python-lxml-docs 4.6.5-1 4.7.1-1
python-nose 1.3.7-13 1.3.7-14
python-prometheus_client 0.11.0-3 0.12.0-1
python-protobuf 3.19.2-1 3.19.4-1
python-tomli 1.2.3-1 2.0.0-1
python-urllib3 1.26.7-5 1.26.8-1
python-urllib3-doc 1.26.7-5 1.26.8-1
qt5-3d 5.15.2+kde+r39-1 5.15.2+kde+r39-2
qt5-base 5.15.2+kde+r294-1 5.15.2+kde+r295-2
qt5-charts 5.15.2-1 5.15.2-2
qt5-connectivity 5.15.2+kde+r5-1 5.15.2+kde+r5-2
qt5-datavis3d 5.15.2-1 5.15.2-2
qt5-declarative 5.15.2+kde+r43-1 5.15.2+kde+r43-2
qt5-gamepad 5.15.2-1 5.15.2-2
qt5-graphicaleffects 5.15.2-1 5.15.2-2
qt5-imageformats 5.15.2-1 5.15.2-2
qt5-location 5.15.2-4 5.15.2-5
qt5-lottie 5.15.2-1 5.15.2-2
qt5-sensors 5.15.2-1 5.15.2-2
qt5-serialport 5.15.2-1 5.15.2-2
qt5-tools 5.15.2+kde+r17-4 5.15.2+kde+r17-5
qt5-wayland 5.15.2+kde+r44-1 5.15.2+kde+r46-1
qt5-webchannel 5.15.2+kde+r5-1 5.15.2+kde+r5-2
qt5-webengine 5.15.8-1 5.15.8-3
qt5-websockets 5.15.2+kde+r7-1 5.15.2+kde+r7-2
qt5-xcb-private-headers 5.15.2+kde+r294-1 5.15.2+kde+r295-2
qt6-3d 6.2.2-1 6.2.3-1
qt6-5compat 6.2.2-1 6.2.3-1
qt6-base 6.2.2-5 6.2.3-1
qt6-charts 6.2.2-1 6.2.3-1
qt6-connectivity 6.2.2-1 6.2.3-1
qt6-datavis3d 6.2.2-1 6.2.3-1
qt6-declarative 6.2.2-1 6.2.3-1
qt6-doc 6.2.2-1 6.2.3-1
qt6-examples 6.2.2-1 6.2.3-1
qt6-imageformats 6.2.2-1 6.2.3-1
qt6-lottie 6.2.2-1 6.2.3-1
qt6-multimedia 6.2.2-1 6.2.3-1
qt6-networkauth 6.2.2-1 6.2.3-1
qt6-positioning 6.2.2-1 6.2.3-1
qt6-quick3d 6.2.2-1 6.2.3-1
qt6-quicktimeline 6.2.2-1 6.2.3-1
qt6-remoteobjects 6.2.2-1 6.2.3-1
qt6-scxml 6.2.2-1 6.2.3-1
qt6-sensors 6.2.2-1 6.2.3-1
qt6-serialbus 6.2.2-1 6.2.3-1
qt6-serialport 6.2.2-1 6.2.3-1
qt6-shadertools 6.2.2-1 6.2.3-1
qt6-svg 6.2.2-1 6.2.3-1
qt6-tools 6.2.2-1 6.2.3-1
qt6-translations 6.2.2-2 6.2.3-1
qt6-virtualkeyboard 6.2.2-2 6.2.3-1
qt6-wayland 6.2.2-1 6.2.3-1
qt6-webchannel 6.2.2-1 6.2.3-1
qt6-webengine 6.2.2-2 6.2.3-1
qt6-websockets 6.2.2-1 6.2.3-1
qt6-webview 6.2.2-1 6.2.3-1
quazip 1.2-1 -
rebuilderd-website 0.5.4-1 0.5.5-1
recode 3.7.9-1 3.7.11-1
rubygems 3.2.29-1 3.3.5-1
sane 1.0.32-3 1.1.1-1
syslog-ng 3.35.1-3 3.35.1-4
thunderbird 91.5.0-2 91.5.1-1
thunderbird-i18n-af 91.5.0-2 91.5.1-1
thunderbird-i18n-ar 91.5.0-2 91.5.1-1
thunderbird-i18n-ast 91.5.0-2 91.5.1-1
thunderbird-i18n-be 91.5.0-2 91.5.1-1
thunderbird-i18n-bg 91.5.0-2 91.5.1-1
thunderbird-i18n-br 91.5.0-2 91.5.1-1
thunderbird-i18n-ca 91.5.0-2 91.5.1-1
thunderbird-i18n-cak 91.5.0-2 91.5.1-1
thunderbird-i18n-cs 91.5.0-2 91.5.1-1
thunderbird-i18n-cy 91.5.0-2 91.5.1-1
thunderbird-i18n-da 91.5.0-2 91.5.1-1
thunderbird-i18n-de 91.5.0-2 91.5.1-1
thunderbird-i18n-dsb 91.5.0-2 91.5.1-1
thunderbird-i18n-el 91.5.0-2 91.5.1-1
thunderbird-i18n-en-gb 91.5.0-2 91.5.1-1
thunderbird-i18n-en-us 91.5.0-2 91.5.1-1
thunderbird-i18n-es-ar 91.5.0-2 91.5.1-1
thunderbird-i18n-es-es 91.5.0-2 91.5.1-1
thunderbird-i18n-et 91.5.0-2 91.5.1-1
thunderbird-i18n-eu 91.5.0-2 91.5.1-1
thunderbird-i18n-fi 91.5.0-2 91.5.1-1
thunderbird-i18n-fr 91.5.0-2 91.5.1-1
thunderbird-i18n-fy-nl 91.5.0-2 91.5.1-1
thunderbird-i18n-ga-ie 91.5.0-2 91.5.1-1
thunderbird-i18n-gd 91.5.0-2 91.5.1-1
thunderbird-i18n-gl 91.5.0-2 91.5.1-1
thunderbird-i18n-he 91.5.0-2 91.5.1-1
thunderbird-i18n-hr 91.5.0-2 91.5.1-1
thunderbird-i18n-hsb 91.5.0-2 91.5.1-1
thunderbird-i18n-hu 91.5.0-2 91.5.1-1
thunderbird-i18n-hy-am 91.5.0-2 91.5.1-1
thunderbird-i18n-id 91.5.0-2 91.5.1-1
thunderbird-i18n-is 91.5.0-2 91.5.1-1
thunderbird-i18n-it 91.5.0-2 91.5.1-1
thunderbird-i18n-ja 91.5.0-2 91.5.1-1
thunderbird-i18n-ka 91.5.0-2 91.5.1-1
thunderbird-i18n-kab 91.5.0-2 91.5.1-1
thunderbird-i18n-kk 91.5.0-2 91.5.1-1
thunderbird-i18n-ko 91.5.0-2 91.5.1-1
thunderbird-i18n-lt 91.5.0-2 91.5.1-1
thunderbird-i18n-ms 91.5.0-2 91.5.1-1
thunderbird-i18n-nb-no 91.5.0-2 91.5.1-1
thunderbird-i18n-nl 91.5.0-2 91.5.1-1
thunderbird-i18n-nn-no 91.5.0-2 91.5.1-1
thunderbird-i18n-pa-in 91.5.0-2 91.5.1-1
thunderbird-i18n-pl 91.5.0-2 91.5.1-1
thunderbird-i18n-pt-br 91.5.0-2 91.5.1-1
thunderbird-i18n-pt-pt 91.5.0-2 91.5.1-1
thunderbird-i18n-rm 91.5.0-2 91.5.1-1
thunderbird-i18n-ro 91.5.0-2 91.5.1-1
thunderbird-i18n-ru 91.5.0-2 91.5.1-1
thunderbird-i18n-sk 91.5.0-2 91.5.1-1
thunderbird-i18n-sl 91.5.0-2 91.5.1-1
thunderbird-i18n-sq 91.5.0-2 91.5.1-1
thunderbird-i18n-sr 91.5.0-2 91.5.1-1
thunderbird-i18n-sv-se 91.5.0-2 91.5.1-1
thunderbird-i18n-th 91.5.0-2 91.5.1-1
thunderbird-i18n-tr 91.5.0-2 91.5.1-1
thunderbird-i18n-uk 91.5.0-2 91.5.1-1
thunderbird-i18n-uz 91.5.0-2 91.5.1-1
thunderbird-i18n-vi 91.5.0-2 91.5.1-1
thunderbird-i18n-zh-cn 91.5.0-2 91.5.1-1
thunderbird-i18n-zh-tw 91.5.0-2 91.5.1-1
tomcat10 10.0.15-1 10.0.16-1
varnish 7.0.1-1 7.0.2-1
vlc 3.0.16-6 3.0.16-7
vulkan-broadcom 21.3.4-1 21.3.5-1.1
vulkan-headers 1:1.2.203-1 1:1.3.204-1
vulkan-html-docs 1:1.2.203-1 1:1.3.204-1
vulkan-mesa-layers 21.3.4-1 21.3.5-1.1
vulkan-panfrost 21.3.4-1 21.3.5-1.1
vulkan-radeon 21.3.4-1 21.3.5-1.1
vulkan-swrast 21.3.4-1 21.3.5-1.1
wayland-protocols 1.24-1 1.25-1
xf86-input-libinput 1.2.0-2 1.2.1-1
xfce4-cpufreq-plugin 1.2.5-1 1.2.6-1
arch-rebuild-order-debug - 0.3-2
js91 - 91.5.1-1
libnma - 1.8.34-1
pipewire-x11-bell - 1:0.3.44-1
qt5-3d-debug - 5.15.2+kde+r39-2
qt5-base-debug - 5.15.2+kde+r295-2
qt5-charts-debug - 5.15.2-2
qt5-connectivity-debug - 5.15.2+kde+r5-2
qt5-datavis3d-debug - 5.15.2-2
qt5-declarative-debug - 5.15.2+kde+r43-2
qt5-gamepad-debug - 5.15.2-2
qt5-graphicaleffects-debug - 5.15.2-2
qt5-imageformats-debug - 5.15.2-2
qt5-location-debug - 5.15.2-5
qt5-lottie-debug - 5.15.2-2
qt5-sensors-debug - 5.15.2-2
qt5-serialport-debug - 5.15.2-2
qt5-tools-debug - 5.15.2+kde+r17-5
qt5-webchannel-debug - 5.15.2+kde+r5-2
qt5-webengine-debug - 5.15.8-3
qt5-websockets-debug - 5.15.2+kde+r7-2
quazip-qt5 - 1.2-2
quazip-qt6 - 1.2-2
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.12.1.r12681.g9f131336c-121.12.1.r12688.ga84cbd6c2-1
akonadi-calendar21.12.1.r2024.g557c407-121.12.1.r2027.gef50a4b-1
akonadi-calendar-tools21.12.1.r929.g0756f97-121.12.1.r931.g2423b8e-1
akonadi-contacts21.12.1.r3109.g5c37312c-121.12.1.r3113.ga5414370-1
akonadi-import-wizard21.12.1.r1785.g8205e6d-121.12.1.r1788.g69cf414-1
akonadi-mime21.12.1.r1691.g31ce516-121.12.1.r1692.g87bdbc2-1
akonadi-notes21.12.1.r1054.gcc50e4c-121.12.1.r1055.g00ce3a7-1
akonadi-search21.12.1.r1170.gb7cd0b6-121.12.1.r1172.gd3d532b-1
akonadiconsole21.12.1.r1565.ga2e1dd9-121.12.1.r1567.gc9b8650-1
akregator21.12.1.r6295.g0aca1119-121.12.1.r6323.g5aaffb19-1
ark21.12.1.r4682.g519d8587-121.12.1.r4686.g26e97d73-1
artikulate21.12.1.r1400.g1a40d7c-121.12.1.r1403.gab06b82-1
audiocd-kio21.12.1.r1046.g9fab120-121.12.1.r1047.gfd9512f-1
baloo5.90.0.r3029.g5ec9408c-15.90.0.r3031.g42130460-1
baloo-widgets21.12.1.r725.g8bea1e0-121.12.1.r726.g9c35b9e-1
blinken21.12.1.r651.g0c3452b-121.12.1.r652.gbf33cfc-1
bluedevil1:5.23.5.r2358.g45ade9f1-11:5.23.5.r2366.gcc56a287-1
bomber21.12.1.r548.g051157c-121.12.1.r549.g2967434-1
bovo21.12.1.r764.g1c1cb31-121.12.1.r765.g603fd27-1
breeze5.23.5.r2331.g2f926402-15.23.5.r2337.g278008a5-1
breeze-icons5.90.0.r1876.g9b4abf62-15.90.0.r1878.g331b1e4d-1
calendarsupport21.12.1.r654.gd2a7362-121.12.1.r656.gbec30d7-1
calindori 21.12.r12.g61c16b6-1 21.12.r18.g383d047-1
cervisia21.12.1.r1648.g88e45d6-121.12.1.r1651.g61ced0d-1
discover5.23.5.r8498.g8b45c204-15.23.5.r8511.g04fbe47f-1
dolphin21.12.1.r6814.gb81d3fbbb-121.12.1.r6823.g26ac2f6e0-1
dolphin-plugins21.12.1.r634.g3f28929-121.12.1.r637.g1f6fc2b-1
dragon21.12.1.r1022.gaf16f17-121.12.1.r1023.g75f8df3-1
elisa21.12.1.r2848.g17ed3ad6-121.12.1.r2856.g4d19a79b-1
eventviews21.12.1.r783.g85700d9-121.12.1.r784.g5994ad6-1
extra-cmake-modules5.90.0.r3425.g13d2e4a-15.90.0.r3434.gfffae63-1
ffmpegthumbs21.12.1.r203.g460a8ae-121.12.1.r204.gd52f1f9-1
filelight21.12.1.r1023.g1b923ad-121.12.1.r1029.g9da46b6-1
frameworkintegration5.90.0.r619.g7c22639-15.90.0.r620.g294b746-1
granatier21.12.1.r956.g910bc47-121.12.1.r957.g29af30f-1
grantlee-editor21.12.1.r801.g0b1df37-121.12.1.r802.g8be77aa-1
grantleetheme21.12.1.r373.g9286145-121.12.1.r375.g11b8caf-1
gwenview21.12.1.r6748.g84c6c47f-121.12.1.r6750.g9dab8057-1
incidenceeditor21.12.1.r831.g48e9b7f-121.12.1.r833.g02f6010-1
itinerary21.12.1.r1707.g16d6981-121.12.1.r1709.g99268b7-1
juk21.12.1.r3127.gcbfe6541-121.12.1.r3128.ge4bb58f6-1
k3b1:21.12.1.r6708.g8febdb005-11:21.12.1.r6709.gb608f9df7-1
kactivities5.90.0.r1382.g48de926-15.90.0.r1384.gce73fdc-1
kactivitymanagerd5.23.5.r1380.gd52963c-15.23.5.r1381.g66ea663-1
kaddressbook21.12.1.r6097.gaed71b23-121.12.1.r6100.g35b9e166-1
kajongg21.12.1.r4212.gb30bf619-121.12.1.r4213.g4c788d86-1
kalarm21.12.1.r6579.g20409053-121.12.1.r6582.gfc354236-1
kalarmcal21.12.1.r1178.gc4ba1ae-121.12.1.r1180.g0317927-1
kalgebra21.12.1.r2051.ge518111-121.12.1.r2052.g6e54f8c-1
kalk 21.12.r24.g6680a60-1 21.12.r29.gfa02582-1
kalzium21.12.1.r4296.g1b9fae17-121.12.1.r4297.g06d90c49-1
kamoso21.12.1.r1446.g11c936b-121.12.1.r1447.g2c4940b-1
kanagram21.12.1.r1298.g6593539-121.12.1.r1299.ga3c8235-1
kapidox5.90.0.r561.g40732e6-15.90.0.r562.gc93e657-1
kapman21.12.1.r634.gd05f522-121.12.1.r636.gc15ef7a-1
kapptemplate21.12.1.r965.g4669e8d-121.12.1.r966.g883e4ef-1
kasts 21.12.r8.gbd46d33-1 21.12.r10.g4483046-1
kate21.12.1.r18582.g3e8defff5-121.12.1.r18591.g16019ddf9-1
katomic21.12.1.r944.gfd879a4-121.12.1.r945.gaff8ad8-1
kbackup21.12.1.r417.gee0bd7e-121.12.1.r419.ga25d29e-1
kblackbox21.12.1.r752.g7483cc4-121.12.1.r753.geb86463-1
kblocks21.12.1.r693.g4fafa7a-121.12.1.r694.gcd784f9-1
kbounce21.12.1.r831.gfe5b551-121.12.1.r834.g92f4a6e-1
kbreakout21.12.1.r889.gfffe0b6-121.12.1.r892.g1cebe24-1
kbruch21.12.1.r834.gb52714f-121.12.1.r839.g9d87897-1
kcachegrind21.12.1.r1165.gfc64847-121.12.1.r1168.g4f966d5-1
kcachegrind-common21.12.1.r1165.gfc64847-121.12.1.r1168.g4f966d5-1
kcalc21.12.1.r1590.g59e1175-121.12.1.r1592.gc206de1-1
kcalendarcore5.90.0.r1289.gbb9216bbe-15.90.0.r1294.g2814af223-1
kcalutils21.12.1.r926.g0c1034109-121.12.1.r929.g6d2a5d3d6-1
kcharselect21.12.1.r499.g5e0b46e-121.12.1.r500.g4d9bdf2-1
kclock 21.12.r51.g6b41dda-1 21.12.r58.g16d3c93-1
kcolorchooser21.12.1.r246.g59d363b-121.12.1.r247.g76db61b-1
kconfig5.90.0.r920.g41d37407-15.90.0.r922.g724966b6-1
kconfigwidgets5.90.0.r673.g765ab0f-15.90.0.r674.gd3d7f7c-1
kcoreaddons5.90.0.r1407.g5a04ecbb-15.90.0.r1412.gf8337d48-1
kde-cli-tools5.23.5.r1890.g8939a7c-15.23.5.r1895.g4cfb608-1
kde-dev-utils21.12.1.r570.g40a0cc8-121.12.1.r571.g69a71e0-1
kdebugsettings21.12.1.r888.g406f4ac-121.12.1.r889.g02603cb-1
kdeclarative5.90.0.r970.gdd6f40c-15.90.0.r972.gc84ca6c-1
kdeconnect21.12.1.r3387.g9c303fee-121.12.1.r3389.gd97dcbb5-1
kded5.90.0.r444.gccb214d-15.90.0.r446.ge4e5fae-1
kdenetwork-filesharing21.12.1.r899.g724607d-121.12.1.r901.g528fe25-1
kdenlive21.12.1.r15554.g7b7b1cb24-121.12.1.r15571.gc898288bb-1
kdepim-addons21.12.1.r4519.g8e4335c0-121.12.1.r4527.gb5c5d769-1
kdepim-runtime21.12.1.r15441.g683fb47bd-121.12.1.r15442.g78ac82bed-1
kdeplasma-addons5.23.5.r8636.g567c2c2cd-15.23.5.r8638.g6f95cc6bb-1
kdf21.12.1.r827.g481ba17-121.12.1.r831.g398f78e-1
kdialog21.12.1.r1203.gf7ea5f6be-121.12.1.r1204.g9befdc057-1
kdiamond21.12.1.r703.gaa3320c-121.12.1.r706.g78ef219-1
kdoctools5.90.0.r646.g3460088-15.90.0.r647.g62e9371-1
kfilemetadata5.90.0.r842.g55c7070-15.90.0.r843.gc8e1ae5-1
kfind21.12.1.r2665.g8101df335-121.12.1.r2666.g617386a4f-1
kfloppy21.12.1.r783.g293ba45-121.12.1.r784.g8933745-1
kfourinline21.12.1.r1005.g7a1163b-121.12.1.r1008.gcc592a2-1
kgeography21.12.1.r1131.g8965d95-121.12.1.r1136.gd55aafb-1
kget21.12.1.r3154.ga8d2ff6c-121.12.1.r3156.g7bc2a1dd-1
kgoldrunner21.12.1.r1262.ga6c297b-121.12.1.r1263.g83f7204-1
kgpg21.12.1.r3165.g1a70bd9e-121.12.1.r3166.g81648d39-1
kguiaddons5.90.0.r423.g1dfccb3-15.90.0.r424.g5b682cb-1
khangman21.12.1.r1583.g086cfe8-121.12.1.r1586.gd651a54-1
khelpcenter21.12.1.r2693.ga34e85e7-121.12.1.r2694.gc0bdf217-1
kidentitymanagement21.12.1.r3860.g113c861d-121.12.1.r3862.g04ec5bb6-1
kig21.12.1.r3156.g63ba81e9-121.12.1.r3157.g3dae68ad-1
kigo21.12.1.r545.g190c8ae-121.12.1.r547.gf412f2d-1
killbots21.12.1.r761.ga395f22-121.12.1.r762.g530eb15-1
kimageformats5.90.0.r374.gf4edb72-15.90.0.r375.g96836e8-1
kimagemapeditor21.12.1.r478.g746f175-121.12.1.r479.g7fd3211-1
kimap21.12.1.r1158.geb2ed83-121.12.1.r1170.g200a4a5-1
kinfocenter5.23.5.r2017.g9632808-15.23.5.r2019.g86741c6-1
kio5.90.0.r5228.gef953f077-15.90.0.r5247.ga2b271cc0-1
kio-gdrive21.12.1.r579.g53b12b7-121.12.1.r581.g28b7a2e-1
kirigami-gallery21.12.1.r227.g249d5a2-121.12.1.r229.g99ba6a3-1
kirigami25.90.0.r3045.ge932767e-15.90.0.r3055.g6943a226-1
kiriki21.12.1.r436.g35ff458-121.12.1.r437.g62feda8-1
kiten21.12.1.r1171.g5d7e25e-121.12.1.r1172.gad98f08-1
kitinerary21.12.1.r2073.g4b22b18-121.12.1.r2076.g26813cf-1
kjobwidgets5.90.0.r399.g0ddc02b-15.90.0.r400.gc13609d-1
kjumpingcube21.12.1.r810.g563aea7-121.12.1.r811.g7458aa1-1
kldap21.12.1.r928.g2b86367-121.12.1.r930.g1683a9d-1
kleopatra21.12.1.r6172.gc5d6bd1b-121.12.1.r6189.gfec93520-1
klettres21.12.1.r934.g13ab026-121.12.1.r946.gba0a91e-1
klickety21.12.1.r658.gc249612-121.12.1.r659.gc62801f-1
klines21.12.1.r790.gc58a93f-121.12.1.r791.g02c9e83-1
kmag21.12.1.r715.g6cc4673-121.12.1.r716.g1fcbd5f-1
kmahjongg21.12.1.r1510.g953d16f-121.12.1.r1511.gbddf5cb-1
kmail21.12.1.r26214.g245ffaba5-121.12.1.r26224.g819a0da84-1
kmail-account-wizard21.12.1.r859.g8a52ee6-121.12.1.r860.g7a75a50-1
kmailtransport21.12.1.r1703.g2be4e10-121.12.1.r1705.g31d0a5f-1
kmbox21.12.1.r575.gb597771-121.12.1.r576.g5ebc98a-1
kmenuedit5.23.5.r985.g4574f37-15.23.5.r993.gf8ad84c-1
kmime21.12.1.r1491.g81e3758-121.12.1.r1492.g86b92ec-1
kmines21.12.1.r1748.g9d70bc2-121.12.1.r1749.ga197441-1
kmix21.12.1.r2414.g28d06221-121.12.1.r2415.g6101c0dc-1
kmousetool21.12.1.r410.gcae26c5-121.12.1.r423.gb1d0094-1
kmplot21.12.1.r1472.g6b8fc4c-121.12.1.r1473.g9df1195-1
knavalbattle21.12.1.r1414.g9f489d6-121.12.1.r1415.ga9bf890-1
knetwalk21.12.1.r679.g25ee1b4-121.12.1.r680.g477402f-1
knewstuff5.90.0.r1278.g4062ccc4-15.90.0.r1282.geb376f0a-1
knights21.12.1.r1091.g796b56b-121.12.1.r1092.gbd58c3c-1
knotes21.12.1.r3580.g91454f95-121.12.1.r3582.g60629988-1
knotifications5.90.0.r715.g8351ff1-15.90.0.r716.g70d8ef3-1
kolf21.12.1.r1468.g552efc4-121.12.1.r1469.g10a1a8f-1
kollision21.12.1.r514.gbd9ac5c-121.12.1.r515.gf8a2aaf-1
kolourpaint21.12.1.r2380.g69621b50-121.12.1.r2381.gec495309-1
kompare21.12.1.r1120.gb8572be-121.12.1.r1121.gec386a7-1
konqueror21.12.1.r15031.g961e7e26e-121.12.1.r15032.g25278ea6b-1
konquest21.12.1.r915.g521e85b-121.12.1.r916.g03a37df-1
konsole21.12.1.r8213.g4a26a4d6-121.12.1.r8234.g6e9f13ff-1
kontact21.12.1.r5458.gd90d16fa-121.12.1.r5461.gb0189689-1
kontrast21.12.1.r190.g84747e7-121.12.1.r191.gdee4c22-1
konversation21.12.1.r9063.g83c67fb2-121.12.1.r9069.g3cc696ae-1
korganizer21.12.1.r11616.g9d0795b5d-121.12.1.r11619.g59e837b04-1
kosmindoormap21.12.1.r690.g0ec2add-121.12.1.r691.gb44f80a-1
kparts5.90.0.r566.g127ba7f-15.90.0.r567.g6ea96c5-1
kpat21.12.1.r2593.g404b683-121.12.1.r2594.g466db0f-1
kpimtextedit21.12.1.r1506.g839bf20-121.12.1.r1510.g359a2f4-1
kpkpass21.12.1.r266.gc6e6f4b-121.12.1.r267.g8be3794-1
kquickimageeditor r65.g60ffd96-1 r67.g14c01c4-1
krdc21.12.1.r1557.gf25efb3-121.12.1.r1558.gebc00cb-1
kreversi21.12.1.r1251.g1843f20-121.12.1.r1252.g2dcc3a2-1
krfb21.12.1.r1462.g25f5492-121.12.1.r1464.g18e76cf-1
kruler21.12.1.r721.gda1143b-121.12.1.r722.g06a099c-1
krunner5.90.0.r726.ga1d553a-15.90.0.r727.gd02eaf1-1
kscreen5.23.5.r1421.g96fd0ef-15.23.5.r1423.g8bd4c09-1
kscreenlocker5.23.5.r895.g0dc4c6f-15.23.5.r901.g13ae653-1
kservice5.90.0.r988.geee4a93-15.90.0.r989.gebbfcdf-1
kshisen21.12.1.r1221.gb12b65b-121.12.1.r1222.g244f9dd-1
ksirk21.12.1.r994.g04f0e74-121.12.1.r1008.g79ebe6e-1
ksmtp21.12.1.r418.g2b0e31c-121.12.1.r419.g00a4bf4-1
ksnakeduel21.12.1.r829.g360567a-121.12.1.r832.g5a7b633-1
kspaceduel21.12.1.r657.gf3a271c-121.12.1.r658.gc9bc7a5-1
ksquares21.12.1.r543.g218f167-121.12.1.r546.g73cdc27-1
ksudoku21.12.1.r1087.g168f8cb-121.12.1.r1090.g7c71d50-1
ksystemlog21.12.1.r688.gfb02675-121.12.1.r689.gbcba66e-1
ksystemstats5.23.5.r215.g906fe79-15.23.5.r216.g75dad23-1
kteatime21.12.1.r737.g7d728ce-121.12.1.r738.g989eb55-1
ktexteditor5.90.0.r3076.g2619badc-15.90.0.r3088.ge18a682d-1
ktimer21.12.1.r494.g5f13bb8-121.12.1.r495.gf48a9a6-1
ktnef21.12.1.r697.g97a2081-121.12.1.r698.g0a79d4f-1
ktorrent21.12.1.r2818.gcfcec895-121.12.1.r2821.g7b61ed1b-1
ktouch21.12.1.r2162.g519c577-121.12.1.r2163.gcb23ab7-1
ktrip 21.12.r4.g043d04c-1 21.12.r5.g95f6a7b-1
ktuberling21.12.1.r1029.g9e826b2-121.12.1.r1030.g51ee790-1
kturtle21.12.1.r1149.g33d4d83-121.12.1.r1151.g3ac4c62-1
kubrick21.12.1.r390.gba77482-121.12.1.r391.g1741ca2-1
kwalletmanager21.12.1.r1233.g4010fa1-121.12.1.r1234.g98680e4-1
kwave21.12.1.r3760.g22dd3b9d-121.12.1.r3761.gd4d48784-1
kwayland5.90.0.r1139.g1fc53f8-15.90.0.r1141.g2848f62-1
kwayland-server5.23.5.r1445.gbf4a7cb-15.23.5.r1447.g79956bc-1
kweather 21.12.r14.g5987ba0-1 21.12.r20.g1927f1b-1
kweathercore 0.5.r4.gc983d1f-1 0.5.r5.g4305095-1
kwin5.23.5.r20661.g58a835863-15.23.5.r20698.g858da39fa-1
kwordquiz21.12.1.r1163.g7ebeaaf-121.12.1.r1165.g45773e6-1
kwrite21.12.1.r18582.g3e8defff5-121.12.1.r18591.g16019ddf9-1
kxmlgui5.90.0.r840.gde04beae-15.90.0.r841.ga73a5fa6-1
libakonadi21.12.1.r12681.g9f131336c-121.12.1.r12688.ga84cbd6c2-1
libgravatar21.12.1.r400.gd34fd8a-121.12.1.r403.gbb9cdfe-1
libkdepim21.12.1.r885.g7d21338-121.12.1.r886.ge14d844-1
libkeduvocdocument21.12.1.r1807.g5ef59ee-121.12.1.r1808.g7bebaf5-1
libkgapi21.12.1.r1333.g9f7c704-121.12.1.r1334.gc314dcc-1
libkleo21.12.1.r1054.g4c4a4ee-121.12.1.r1064.gb49d0fb-1
libkscreen5.23.5.r1618.gb7c7987-15.23.5.r1619.ge90d719-1
libksieve21.12.1.r1654.g00e2e64b-121.12.1.r1664.g4da15ab0-1
libksysguard5.23.5.r2345.ga391297-15.23.5.r2349.gf901b29-1
lokalize21.12.1.r1791.gb36926fc-121.12.1.r1792.gc56347c8-1
lskat21.12.1.r834.g99cf543-121.12.1.r835.ge1db51b-1
mailcommon21.12.1.r1190.gaf3b166-121.12.1.r1196.g7f93181-1
mailimporter21.12.1.r497.g73ec791-121.12.1.r500.g9451fa1-1
maliit-framework2.1.1.r19.ga4160187-12.1.1.r21.gf7e0718b-1
maliit-keyboard2.1.0.r14.g1dca7d07-12.1.0.r273.g4b8907de-1
marble21.12.1.r13381.g831753419-121.12.1.r13384.g8361c5eaf-1
marble-common21.12.1.r13381.g831753419-121.12.1.r13384.g8361c5eaf-1
marble-qt21.12.1.r13381.g831753419-121.12.1.r13384.g8361c5eaf-1
markdownpart21.12.1.r97.gee4e679-121.12.1.r98.g090dfd8-1
maui-clip 2.1.0.r4.ga0b1ecb-1 2.1.0.r5.gbb2e613-1
maui-pix 2.1.0.r9.g850fbdd-1 2.1.0.r10.ga36539b-1
maui-shell r124.e26c914-1 r134.2950c52-1
mauikit2.1.0.r68.g21943817-12.1.0.r70.g42554c0e-1
mbox-importer21.12.1.r546.gb97de3e-121.12.1.r549.gcfede23-1
messagelib21.12.1.r6352.g66ec48d78-121.12.1.r6367.ga41aec6d5-1
minuet21.12.1.r591.gc60215e-121.12.1.r592.g8a5b56a-1
modemmanager-qt5.90.0.r540.g581855b-15.90.0.r541.g2dda828-1
mycroft-bigscreen21.2.2.r4874.g3d963cee40-121.2.2.r4874.g3d963cee40-2
mycroft-gui r716.a3a4700-1 r717.5b01471-1
neochat21.12.r52.gb236e61e-121.12.r53.g5a1198d2-1
networkmanager-qt5.90.0.r1137.gfeda187-15.90.0.r1140.g771421a-1
okular21.12.1.r9580.gc9e09be0a-121.12.1.r9591.g9cded33c8-1
oxygen5.23.5.r4445.g43686cf5-15.23.5.r4447.g4dfa2e8e-1
palapeli21.12.1.r1261.g28287a9-121.12.1.r1262.g713174a-1
parley21.12.1.r4497.gb82bef76-121.12.1.r4498.g19fa281c-1
partitionmanager21.12.1.r1590.gbb6cd82-121.12.1.r1592.gfc385fd-1
picmi21.12.1.r549.g86a750f-121.12.1.r551.g6ef67a7-1
pico-wizard-bigscreen-scripts r161.d390d01-1 r163.52a17c8-1
pico-wizard-git r161.d390d01-1 r163.52a17c8-1
pico-wizard-plamo-scripts r161.d390d01-1 r163.52a17c8-1
pim-data-exporter21.12.1.r2567.g75525856-121.12.1.r2569.gadeeecee-1
pim-sieve-editor21.12.1.r1573.g9b55f98-121.12.1.r1576.g9eb2c20-1
pimcommon21.12.1.r1182.g5b7da9b-121.12.1.r1185.gb9d4be1-1
plasma-camera 1.0.r110.g521998d-1 1.0.r111.gebfa55b-1
plasma-desktop5.23.5.r9021.gc826f4477-15.23.5.r9054.gc2b411372-1
plasma-dialer 21.12.r14.g2294e44-1 21.12.r17.g0173c3f-1
plasma-disks5.23.5.r248.gd6de6b0-15.23.5.r251.g97a0988-1
plasma-firewall5.23.5.r570.gb132d3a-15.23.5.r571.g074cff1-1
plasma-framework5.90.0.r16161.ga83321120-15.90.0.r16164.g97ac87871-1
plasma-mobile5.23.5.r1603.g1eee1935c-15.23.5.r1605.gb8d096322-1
plasma-mobile-nm5.23.5.r3165.g5aebff4c-15.23.5.r3176.g19591cad-1
plasma-nm5.23.5.r3165.g5aebff4c-15.23.5.r3176.g19591cad-1
plasma-pa5.23.5.r1024.gfd17988-15.23.5.r1025.g8d68687-1
plasma-settings 21.12.r8.g211395a-1 21.12.r21.gf325ed1-1
plasma-systemmonitor5.23.5.r539.gffd9c7f-15.23.5.r542.g5fe71c9-1
plasma-thunderbolt5.23.5.r172.gb16fbae-15.23.5.r175.gc3f759b-1
plasma-vault5.23.5.r365.g3378b46-15.23.5.r370.g22d69fa-1
plasma-wayland-session5.23.5.r11312.g41897540c-15.23.5.r11346.g99d0f172e-1
plasma-workspace5.23.5.r11312.g41897540c-15.23.5.r11346.g99d0f172e-1
plasma-workspace-wallpapers5.23.5.r320.gb34ecb0-15.23.5.r323.g18b610a-1
print-manager21.12.1.r1094.g56bda9c-121.12.1.r1096.g07034d5-1
purpose5.90.0.r939.ga121450-15.90.0.r942.ge87fded-1
qcachegrind21.12.1.r1165.gfc64847-121.12.1.r1168.g4f966d5-1
qqc2-desktop-style5.90.0.r565.g0ab6a7a-15.90.0.r568.g6db6c43-1
rocs21.12.1.r3054.g04f302c1-121.12.1.r3055.g796465a3-1
sddm0.19.0.r120.gd6aa2d3-10.19.0.r129.g6b8e837-1
solid5.90.0.r742.g2f305a7-15.90.0.r745.gfe40ef2-1
spectacle21.12.1.r1282.g1de84d5-121.12.1.r1288.g27fc4d8-1
step21.12.1.r1166.gcc6ede7-121.12.1.r1167.g9b7e6c3-1
svgpart21.12.1.r201.gce42c15-121.12.1.r202.gf23c51b-1
sweeper21.12.1.r552.g6929402-121.12.1.r553.g975483f-1
syndication5.90.0.r858.g83e8128-15.90.0.r859.gb42f5e1-1
syntax-highlighting5.90.0.r1792.g4014f250-15.90.0.r1804.g0be21923-1
systemsettings5.23.5.r2601.gfa203a7b-15.23.5.r2605.geceb4c53-1
tokodon 21.12.r18.g9fd0e6a-1 21.12.r19.gfb8334c-1
umbrello21.12.1.r8331.g86a322d6a-121.12.1.r8338.g0b089c897-1
yakuake21.12.1.r764.gbd62dfb-121.12.1.r765.gea12c06-1
zeroconf-ioslave21.12.1.r365.gbea72b5-121.12.1.r366.g06c00b7-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
