Hello ARM community.
Another update for you guys to test!
More devices are now getting support
Some highlights:
- Most of our kernels got updated
- Firefox has a new release with 96.0.2
- PHP got updated to 8.1.0
- This also has the split up linux-firmware package, so it should have gotten smaller for our needs
- Lots of Mobile specific packages got updated
- Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sat Jan 22 11:03:28 CET 2022)
- arm-testing community aarch64: 380 new and 357 removed package(s)
- arm-testing core aarch64: 49 new and 38 removed package(s)
- arm-testing extra aarch64: 295 new and 294 removed package(s)
- arm-testing kde-unstable aarch64: 179 new and 179 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-01-16 2022-01-22
ap6398s-firmware 2020.04-5 2020.04-6
chatty 0.6.0beta1-10.6.0beta1+15+g657c2ea1-1
element-desktop 1.9.8-2 1.9.9-1
element-web 1.9.8-2 1.9.9-1
gnome-control-center-mobile 41.2-4 41.2-5
phoc 0.11.0+28+gf4f80af-1 0.11.0+28+gf4f80af-2
phosh0.14.1+129+ge674d01-10.14.1+162+g43d2f31-1
python-tinydb 4.5.2-2 4.6.0-1
yt-dlp 2021.12.27-2 2022.01.21-1
gtking-pro-post-install - 20220121-1
m5-post-install - 20220119-1
vim3l-post-install - 20220119-1
:: Different sync package(s) in repository community aarch64
aerc 0.6.0-1 0.7.1-1
alglib 3.17.0-1 3.18.0-1
aqbanking 6.3.0-2 6.4.1-1
archlinux-repro 20211221-1 20220116-1
arcus 4.12.0-1 4.13.0-1
ardour 6.9-3 6.9-4
asciidoc 9.1.1-4 10.1.1-1
audacity 1:2.4.1-4 1:2.4.1-7
aws-cli 1.22.24-1 1.22.38-1
aws-vault 6.3.1-1 6.4.0-1
babel-cli 7.16.0-1 7.16.8-1
babel-core 7.16.7-1 7.16.10-1
binaryen 1:104-1 1:105-1
bonnie++ 1.98-1 2.00a-1
btop 1.1.4-1 1.2.0-1
cage 0.1.4-1 0.1.4-3
calibre 5.34.0-2 5.35.0-1
camlp5 8.0-2 8.0-3
cargo-c 0.9.6-1 0.9.7-1
cargo-fuzz 0.10.2-1 0.11.0-1
cargo-release 0.19.1-1 0.19.3-1
cargo-udeps 0.1.25-1 0.1.26-1
cereal 1.3.0-1 1.3.1-1
cgdb 0.7.1-3 0.8.0-1
chezmoi 2.9.5-1 2.10.0-1
chrono-date 3.0.1-1 3.0.1-2
cinnamon 5.2.7-1 5.2.7-2
cinnamon-control-center 5.2.1-1 5.2.1-4
cinnamon-settings-daemon 5.2.0-1 5.2.0-2
cmark-gfm 0.29.0.gfm.0-2 0.29.0.gfm.2-2
cocogitto 4.0.1-2 4.1.0-1
containers-common 0.46.0-8 0.47.0-1
coq 8.14.1-2 8.15.0-1
coq-doc 8.14.1-2 8.15.0-1
coqide 8.14.1-2 8.15.0-1
coturn 4.5.2-2 4.5.2-3
cpp-hocon 0.3.0-8 0.3.0-9
cppcheck 2.6-2 2.6.3-1
crictl 1.22.0-1 1.23.0-1
critest 1.22.0-1 1.23.0-1
crun 1.4-1 1.4.1-1
cue 0.4.0-1 0.4.1-1
cura 4.12.1-1 4.13.0-1
cura-binary-data 4.12.0-1 4.13.0-1
cura-resources-materials 4.12.0-1 4.13.0-1
curaengine 4.12.0-1 4.13.0-1
darkstat 3.0.719-4 3.0.721-1
dart-sass 1.48.0-1 1.49.0-1
dbmate 1.12.1-2 1.13.0-1
desmume 0.9.11-7 0.9.11-8
docker-scan 0.16.0-1 0.17.0-1
dpdk 21.08-1 21.11-1
dpkg 1.20.9-1 1.21.1-1
dqlite 1.9.0-1 1.9.1-1
efm-langserver 0.0.38-1 0.0.40-1
elinks 0.14.3-2 0.15.0-1
emscripten 3.0.0-1 3.1.1-1
facter 3.14.21-2 3.14.22-2
fceux 2.5.0-1 2.6.1-1
featherpad 1.1.0-1 1.1.1-1
firefox-decentraleyes 2.0.16-1 2.0.16-2
foliate 2.6.3-1 2.6.4-1
fpc 3.2.2-1 3.2.2-2
fq 0.0.3-1 0.0.4-1
freeipmi 1.6.8-3 1.6.9-1
freepats-general-midi 20210329-1 20210329-2
fuse-overlayfs 1.8-1 1.8.1-1
gala 6.3.0-1 6.3.0-2
gambit-c 4.9.3-2 4.9.4-1
gcompris-qt 2.0-1 2.1-1
geary 1:40.0-5 1:40.0-6
gimp-plugin-gmic 3.0.1-1 3.0.2-1
global 6.6.7-2 6.6.8-1
go-yq 4.16.2-1 4.17.2-1
gopass 1.13.0-1 1.13.1-1
gpac 1:1.0.1-1 1:1.0.1-2
grails 5.0.3-1 5.1.1-1
grails-docs 5.0.3-1 5.1.1-1
grpc 1.43.0-2 1.43.0-3
grpc-cli 1.43.0-2 1.43.0-3
gtk-layer-shell 0.6.0-1 0.6.0-2
homebank 5.5.3-1 5.5.4-1
hostapd 2.9-5 2.10-1
hugo 0.91.2-1 0.92.0-1
hypercorn 0.13.1-1 0.13.2-1
i3status-rust 0.20.7-1 0.21.2-1
ibus-m17n 1.4.8-1 1.4.9-1
icewm 2.9.4-1 2.9.5-1
inotify-tools 3.21.9.6-1 3.22.1.0-1
interception-caps2esc 0.3.2-1 0.3.2-2
interception-tools 0.6.8-1 0.6.8-2
ipython 7.31.0-1 8.0.1-1
jenkins 2.329-1 2.331-1
jmol 14.32.10-1 14.32.14-1
josm 18303-1 18360-1
jruby 9.3.2.0-1 9.3.3.0-1
jsmol 14.32.10-1 14.32.14-1
jupyter-server 1.13.3-1 1.13.4-1
kanshi 1.2.0-1 1.2.0-2
kbfs 5.9.0-1 5.9.1-1
kcm-wacomtablet 1:3.2.0-4 1:3.2.0-5
kcov 39-1 40-1
keepalived 2.2.4-2 2.2.7-1
kernelshark 2.0.2-1 2.1.0-1
keybase 5.9.0-1 5.9.1-1
keybase-gui 5.9.0-1 5.9.1-1
kicad 6.0.0-2 6.0.1-2
kicad-library-3d 6.0.0-2 6.0.1-1
kicad-library 6.0.0-2 6.0.1-1
knot-resolver 5.4.3-1 5.4.4-1
kstars 1:3.5.6-2 1:3.5.7-1
kube-linter 0.2.4-1 0.2.5-1
lazygit 0.32.1-1 0.32.2-1
leatherman 1.12.6-3 1.12.7-1
lego 4.5.3-1 4.6.0-1
libblastrampoline 3.1.0-2 4.0.0-2
libgcrypt15 1.5.6-4 1.5.6-5
libindi 1.9.3-2 1.9.4-1
libmgba 0.9.2-1 0.9.3-1
libqtshadowsocks 2.1.0-13 2.1.0-14
libretro-beetle-pce-fast 1158-1 1159-1
libretro-beetle-psx 2598-1 2599-1
libretro-beetle-psx-hw 2598-1 2599-1
libretro-core-info 1.9.14-1 1.10.0-1
libretro-gambatte 957-1 958-1
libretro-genesis-plus-gx 1881-1 1882-1
libretro-mgba 8106-1 8143-1
libretro-nestopia 1:72-1 1:73-1
libretro-play 6905-1 6906-1
libretro-shaders-slang 878-1 882-1
libsavitar 4.12.0-1 4.13.0-1
libvarlink 22-1 23-1
libvirt 1:7.10.0-2 1:8.0.0-1
libvirt-storage-gluster 1:7.10.0-2 1:8.0.0-1
libvirt-storage-iscsi-direct 1:7.10.0-2 1:8.0.0-1
libwhereami 0.5.0-9 0.5.0-11
liquidctl 1.7.2-2 1.8.1-1
lollypop 1.4.27-1 1.4.28-1
lynis 3.0.5-1 3.0.7-1
mako 1.6-1 1.6-2
man-pages-cs 4.12.0-1 4.12.1-1
man-pages-da 4.12.0-1 4.12.1-1
man-pages-de 4.12.0-1 4.12.1-1
man-pages-es 4.12.0-1 4.12.1-1
man-pages-fr 4.12.0-1 4.12.1-1
man-pages-hu 4.12.0-1 4.12.1-1
man-pages-it 4.12.0-1 4.12.1-1
man-pages-mk 4.12.0-1 4.12.1-1
man-pages-nl 4.12.0-1 4.12.1-1
man-pages-pl 4.12.0-1 4.12.1-1
man-pages-pt_br 4.12.0-1 4.12.1-1
man-pages-ro 4.12.0-1 4.12.1-1
matrix-synapse 1.49.2-3 1.50.1-1
mcomix 1.3.0.dev0-4 1.3.0.dev0-5
mdcat 0.25.0-1 0.25.1-1
meilisearch 0.25.1-1 0.25.2-1
menyoki 1.5.5-1 1.5.6-1
mgba-qt 0.9.2-1 0.9.3-1
mgba-sdl 0.9.2-1 0.9.3-1
mixxx 2.3.1-2 2.3.1-3
molecule-podman 1.0.1-2 1.1.0-1
mongo-c-driver 1.20.0-1 1.20.1-1
muffin 5.2.0-1 5.2.0-2
mutter6 3.36.9-1 3.36.9-2
mvt 1.4.1-2 1.4.5-1
mysql-workbench 8.0.27-3 8.0.28-1
nextcloud 23.0.0-1 23.0.0-2
nextcloud-app-calendar 1:3.0.3-1 1:3.0.5-1
nomad 1.2.3-1 1.2.4-1
nomad-driver-containerd 0.9.2-1 0.9.3-1
npm 8.3.1-1 8.3.2-1
npm-check-updates 12.1.0-1 12.2.0-1
nrg2iso 0.4.1-1 0.4.1-2
nuitka 0.6.18.4-1 0.6.19.3-1
nushell 0.42.0-1 0.43.0-1
onionshare 2.4-3 2.5-1
openfire 4.6.7-1 4.7.0-1
openlibm 0.8.0-1 0.8.1-1
openvswitch 2.16.1-1 2.16.1-2
openxr 1.0.20-2 1.0.22-1
osbuild 45-1 46-1
owncloud-client 2.9.2.6206-1 2.10.0.6519-1
perl-inline 0.83-2 0.86-1
perl-yaml-pp 0.026-1 0.031-1
php-geoip 1.1.1-6 1.1.1-7
php-grpc 1.43.0-2 1.43.0-3
php-igbinary 3.2.6-1 3.2.7-2
php-imagick 3.7.0-1 3.7.0-2
php-memcache 8.0-1 8.0-2
php-memcached 3.1.5.r16.gbfb0a66-1 3.1.5.r16.gbfb0a66-2
php-mongodb 1.12.0-1 1.12.0-2
php-redis 5.3.5-1 5.3.6-2
php-snuffleupagus 0.7.1-1 0.7.1-2
php7-geoip 1.1.1-6 1.1.1-7
php7-grpc 1.43.0-2 1.43.0-3
php7-igbinary 3.2.6-1 3.2.7-2
php7-imagick 3.7.0-1 3.7.0-2
php7-memcache 8.0-1 8.0-2
php7-memcached 3.1.5.r16.gbfb0a66-1 3.1.5.r16.gbfb0a66-2
php7-mongodb 1.12.0-1 1.12.0-2
php7-redis 5.3.5-1 5.3.6-2
po4a 0.65-1 0.66-1
powerdns 4.5.2-3 4.5.3-1
procs 0.11.13-1 0.12.0-1
promscale 0.7.1-1 0.8.0-1
puppet 7.13.1-1 7.14.0-1
pymol 2.5.0-2 2.5.0-3
pyright 1.1.209-1 1.1.212-1
python-aioresponses 0.7.2-3 0.7.3-1
python-ansible-compat 0.5.0-3 1.0.0-2
python-asteval 0.9.25-3 0.9.26-1
python-blessed 1.19.0-3 1.19.1-1
python-boto3 1.20.24-1 1.20.38-1
python-botocore 1.23.24-1 1.23.38-1
python-cfn-lint 0.56.4-1 0.57.0-1
python-cmarkgfm 0.6.0-3 0.6.0-4
python-debian 0.1.42-3 0.1.43-1
python-debtcollector 2.3.0-3 2.4.0-1
python-dnslib 0.9.16-3 0.9.17-1
python-eyed3 1:0.9.5-4 1:0.9.5-5
python-flask-dance 5.0.0-2 5.1.0-1
python-graphql-core 3.1.7-3 3.2.0-1
python-grpcio 1.43.0-2 1.43.0-3
python-identify 2.4.3-1 2.4.4-1
python-josepy 1.11.0-1 1.12.0-1
python-keystoneclient 4.3.0-3 4.4.0-1
python-libcharon 4.12.0-1 4.13.0-1
python-mocket 3.10.3-1 3.10.4-1
python-moto 2.3.1-1 2.3.2-1
python-mpd2 3.0.4-3 3.0.5-1
python-noseofyeti 2.1.0-1 2.2.0-1
python-openmdao 3.12.0-2 3.13.0-1
python-parse-type 0.5.6-3 0.6.0-1
python-pre-commit 2.16.0-2 2.17.0-1
python-pyee 8.2.2-3 9.0.3-1
python-pynitrokey 0.4.9-2 0.4.10-1
python-pyrsistent 0.18.0-3 0.18.1-1
python-pytest-django 4.5.0-1 4.5.1-1
python-responses 0.16.0-1 0.17.0-1
python-ruamel-yaml 0.17.18-1 0.17.19-1
python-setuptools-scm 6.3.2-3 6.4.1-1
python-sphinx 4.3.2-1 4.4.0-1
python-sqlalchemy 1.4.29-1 1.4.30-1
python-svglib 1.1.0-4 1.2.0-1
python-tinycss 0.4-6 0.4-7
python-zeroconf 0.36.13-1 0.38.1-1
python2-secretstorage 1:3.1.1-1 -
qgis 3.22.2-3 3.22.3-1
quassel-client 0.13.1-9 0.14.0-1
quassel-client-qt 0.13.1-9 0.14.0-1
quassel-common 0.13.1-9 0.14.0-1
quassel-core 0.13.1-9 0.14.0-1
quassel-monolithic 0.13.1-9 0.14.0-1
quassel-monolithic-qt 0.13.1-9 0.14.0-1
radicale 3.1.0-1 3.1.1-1
raft 0.11.2-1 0.11.3-1
rapid-photo-downloader 0.9.27-2 0.9.28-1
rathole 0.3.7-1 0.3.9-1
ratpoints 2.2-1 2.2.1-1
retroarch 1.9.14-2 1.10.0-1
rhit 1.6.0-1 1.7.0-1
rspamd 3.1-2 3.1-3
rubberband 2.0.0-1 2.0.1-1
ruby-mime-types 3.3.1-2 3.4.1-1
ruby-mime-types-data 3.2020.0512-2 3.2022.0105-1
ruby-mini_portile2 2.6.1-1 2.7.1-1
ruby-minitest 5.14.3-3 5.15.0-1
ruby-mocha 1.12.0-2 1.13.0-1
ruby-rdoc 6.3.1-1 6.4.0-2
ruby-sqlite3 1.4.2-3 1.4.2-5
ruby-test-unit 3.4.1-2 3.5.3-1
runc 1.0.3-1 1.1.0-1
rust-analyzer 20220110-1 20220117-1
scdoc 1.11.2-1 1.11.2-2
schroot 1.6.10-28 1.6.10-29
scite 5.1.5-1 5.1.6-1
seatd 0.6.3-1 0.6.3-2
serverless 2.71.0-1 2.72.1-1
sfizz 1.1.1-2 1.2.0-1
shntool 3.0.10-6 3.0.10-7
skaffold 1.35.1-1 1.35.2-1
soundconverter 4.0.2-1 4.0.3-1
spdlog 1.9.2-1 1.9.2-2
sqlcipher 4.4.3-1 4.5.0-1
sway 1:1.6.1-2 1:1.6.1-3
swaybg 1.1-1 1.1-2
swayidle 1.7-2 1.7.1-1
swaylock 1.5-1 1.5-2
switchboard-plug-wacom 1.0.0-1 1.0.0-2
telegram-desktop 3.4.3-2 3.4.8-1
tlp 1.5.0-3 1.5.0-4
tlp-rdw 1.5.0-3 1.5.0-4
tree-sitter 0.20.2-1 0.20.3-1
ttc-iosevka 11.2.4-1 11.2.6-1
ttc-iosevka-aile 11.2.4-1 11.2.6-1
ttc-iosevka-curly 11.2.4-1 11.2.6-1
ttc-iosevka-curly-slab 11.2.4-1 11.2.6-1
ttc-iosevka-etoile 11.2.4-1 11.2.6-1
ttc-iosevka-slab 11.2.4-1 11.2.6-1
ttc-iosevka-ss01 11.2.4-1 11.2.6-1
ttc-iosevka-ss02 11.2.4-1 11.2.6-1
ttc-iosevka-ss03 11.2.4-1 11.2.6-1
ttc-iosevka-ss04 11.2.4-1 11.2.6-1
ttc-iosevka-ss05 11.2.4-1 11.2.6-1
ttc-iosevka-ss06 11.2.4-1 11.2.6-1
ttc-iosevka-ss07 11.2.4-1 11.2.6-1
ttc-iosevka-ss08 11.2.4-1 11.2.6-1
ttc-iosevka-ss09 11.2.4-1 11.2.6-1
ttc-iosevka-ss10 11.2.4-1 11.2.6-1
ttc-iosevka-ss11 11.2.4-1 11.2.6-1
ttc-iosevka-ss12 11.2.4-1 11.2.6-1
ttc-iosevka-ss13 11.2.4-1 11.2.6-1
ttc-iosevka-ss14 11.2.4-1 11.2.6-1
ttc-iosevka-ss15 11.2.4-1 11.2.6-1
ttc-iosevka-ss16 11.2.4-1 11.2.6-1
ttc-iosevka-ss17 11.2.4-1 11.2.6-1
ttc-iosevka-ss18 11.2.4-1 11.2.6-1
ttf-ionicons 6.0.0-1 6.0.1-1
typescript 4.5.4-1 4.5.5-1
ukwm 1.2.1-1 1.2.1-2
umockdev 0.17.3-1 0.17.5-1
uranium 4.12.0-1 4.13.0-1
uutils-coreutils 0.0.8-1 0.0.12-1
uvicorn 0.16.0-3 0.17.0-1
uwsgi 2.0.20-3 2.0.20-4
uwsgi-plugin-cgi 2.0.20-3 2.0.20-4
uwsgi-plugin-lua51 2.0.20-3 2.0.20-4
uwsgi-plugin-notfound 2.0.20-3 2.0.20-4
uwsgi-plugin-php 2.0.20-3 2.0.20-4
uwsgi-plugin-php7 2.0.20-3 2.0.20-4
uwsgi-plugin-psgi 2.0.20-3 2.0.20-4
uwsgi-plugin-python 2.0.20-3 2.0.20-4
uwsgi-plugin-rack 2.0.20-3 2.0.20-4
uwsgi-plugin-webdav 2.0.20-3 2.0.20-4
uwsgi-plugin-zabbix 2.0.20-3 2.0.20-4
v2ray-domain-list-community 20220109141424-1 20220121101834-1
v2ray-geoip 202201130034-1 202201200035-1
verilator 4.216-1 4.218-1
vultr-cli 2.11.3-1 2.12.0-1
wakatime 13.1.0-3 1:1.35.0-1
watchexec 1.17.1-1 1.18.0-1
wf-recorder 0.2.1-1 0.2.1-2
wgetpaste 2.30-1 2.32-1
wlroots 0.14.1-2 0.14.1-3
xdebug 3.1.2-1 3.1.2-2
xkbsel 0.13-10 0.13-11
yt-dlp 2021.12.27-1 2022.01.21-1
bear - 3.0.18-2
bibutils - 7.2-2
certbot-dns-inwx - 2.1.3-3
hss - 1.8-5
krita-plugin-gmic - 3.0.2.1-1
mc - 4.8.27-2
python-click-option-group - 0.5.3-2
python-crcmod - 1.7-4
python-matrix-common - 1.0.0-2
python-pylink-square - 0.11.1-2
ruby-crass - 1.0.6-2
ruby-erubi - 1.10.0-2
ruby-loofah - 2.13.0-1
ruby-psych - 4.0.3-2
ruby-rails-dom-testing - 2.0.3-2
ruby-rails-html-sanitizer - 1.4.2-1
ruby-stringio - 3.0.1-2
simde - 0.7.2-1
stern - 1.21.0-2
syft - 0.35.1-1
vulture - 2.3-3
:: Different overlay package(s) in repository core aarch64
linux 5.16.1-1 5.16.2-2
linux-clockworkpi-a06 5.16.1-1 5.16.2-1
linux-clockworkpi-a06-headers 5.16.1-1 5.16.2-1
linux-headers 5.16.1-1 5.16.2-2
linux-khadas 5.15.13-1 5.15.13-5
linux-khadas-headers 5.15.13-1 5.15.13-5
linux-lts 5.15.15-1 5.15.16-1
linux-lts-headers 5.15.15-1 5.15.16-1
linux-pinephone 5.16.1-1 5.16.2-1
linux-pinephone-headers 5.16.1-1 5.16.2-1
linux-pinephonepro 5.16.1-2 5.16.2-2
linux-pinephonepro-headers 5.16.1-2 5.16.2-2
linux-quartz64 5.16.0-0.6 5.16.0-0.8
linux-quartz64-headers 5.16.0-0.6 5.16.0-0.8
linux-rpi4 5.10.90-1 5.10.92-1
linux-rpi4-headers 5.10.90-1 5.10.92-1
linux-rpi4-mainline 5.16.0-1 5.16.1-1
linux-rpi4-mainline-headers 5.16.0-1 5.16.1-1
raspberrypi-bootloader 20220104-1 20220117-1
raspberrypi-bootloader-x 20220104-1 20220117-1
uboot-pinephone 2021.10-3 2022.01-3
uboot-pinephonepro 1:2021.01rc3-6 3:2021.01rc3-2
boot-gtking-pro - 2022.01-1
boot-m5 - 2022.01-1
boot-vim3l - 20220119-1
:: Different sync package(s) in repository core aarch64
amd-ucode 20211216.f682ecb-1 20220119.0c6a7b3-2.1
archlinux-keyring 20220114-1 20220118-1
efivar 38-1 38-2
expat 2.4.2-1 2.4.3-1
fakeroot 1.26-1 1.27-1
gnutls 3.7.2-2 3.7.3-1
grub 2:2.06-3 2:2.06-4
hdparm 9.62-1 9.63-2
libp11-kit 0.24.0-2.1 0.24.1-1
linux-firmware 20211216.f682ecb-1 20220119.0c6a7b3-2.1
netctl 1.26-1 1.27-1
systemd 250.2-2 250.3-1
systemd-libs 250.2-2 250.3-1
systemd-resolvconf 250.2-2 250.3-1
systemd-sysvcompat 250.2-2 250.3-1
linux-firmware-bnx2x - 20220119.0c6a7b3-2.1
linux-firmware-liquidio - 20220119.0c6a7b3-2.1
linux-firmware-marvell - 20220119.0c6a7b3-2.1
linux-firmware-mellanox - 20220119.0c6a7b3-2.1
linux-firmware-nfp - 20220119.0c6a7b3-2.1
linux-firmware-qcom - 20220119.0c6a7b3-2.1
linux-firmware-qlogic - 20220119.0c6a7b3-2.1
linux-firmware-whence - 20220119.0c6a7b3-2.1
:: Different overlay package(s) in repository extra aarch64
manjaro-chrootbuild r236.g1e1d496-1 r237.g96d22f7-1
pyside2-es2 5.15.2-5.1 5.15.2.1-1
qt5-es2-base 5.15.2+kde+r289-1 5.15.2+kde+r294-1
qt5-es2-wayland 5.15.2+kde+r41-1 5.15.2+kde+r44-1
qt5-es2-xcb-private-headers 5.15.2+kde+r289-1 5.15.2+kde+r294-1
elisa-qtmm - 21.12.1-1
:: Different sync package(s) in repository extra aarch64
alsa-card-profiles 1:0.3.43-1 1:0.3.43-5
arch-rebuild-order 0.2.1-1 0.3-1
archboot-arm 2022.01-38 2022.01-60
archboot-linux-firmware 20211216.f682ecb-1 -
bind 9.16.24-1 9.16.25-1
botan 2.18.2-3 2.19.1-1
chromium 97.0.4692.71-2 97.0.4692.99-1
clamav 0.104.1-1 0.104.2-1
clazy 1.10-2 1.11-1
composer 2.2.4-1 2.2.5-1
cups-filters 1.28.10-2 1.28.11-1
ddrescue 1.25-1 1.26-1
digikam 7.4.0-2 7.5.0-1
firefox 96.0.1-1 96.0.2-1
firefox-i18n-ach 96.0.1-1 96.0.2-1
firefox-i18n-af 96.0.1-1 96.0.2-1
firefox-i18n-an 96.0.1-1 96.0.2-1
firefox-i18n-ar 96.0.1-1 96.0.2-1
firefox-i18n-ast 96.0.1-1 96.0.2-1
firefox-i18n-az 96.0.1-1 96.0.2-1
firefox-i18n-be 96.0.1-1 96.0.2-1
firefox-i18n-bg 96.0.1-1 96.0.2-1
firefox-i18n-bn 96.0.1-1 96.0.2-1
firefox-i18n-br 96.0.1-1 96.0.2-1
firefox-i18n-bs 96.0.1-1 96.0.2-1
firefox-i18n-ca 96.0.1-1 96.0.2-1
firefox-i18n-ca-valencia 96.0.1-1 96.0.2-1
firefox-i18n-cak 96.0.1-1 96.0.2-1
firefox-i18n-cs 96.0.1-1 96.0.2-1
firefox-i18n-cy 96.0.1-1 96.0.2-1
firefox-i18n-da 96.0.1-1 96.0.2-1
firefox-i18n-de 96.0.1-1 96.0.2-1
firefox-i18n-dsb 96.0.1-1 96.0.2-1
firefox-i18n-el 96.0.1-1 96.0.2-1
firefox-i18n-en-ca 96.0.1-1 96.0.2-1
firefox-i18n-en-gb 96.0.1-1 96.0.2-1
firefox-i18n-en-us 96.0.1-1 96.0.2-1
firefox-i18n-eo 96.0.1-1 96.0.2-1
firefox-i18n-es-ar 96.0.1-1 96.0.2-1
firefox-i18n-es-cl 96.0.1-1 96.0.2-1
firefox-i18n-es-es 96.0.1-1 96.0.2-1
firefox-i18n-es-mx 96.0.1-1 96.0.2-1
firefox-i18n-et 96.0.1-1 96.0.2-1
firefox-i18n-eu 96.0.1-1 96.0.2-1
firefox-i18n-fa 96.0.1-1 96.0.2-1
firefox-i18n-ff 96.0.1-1 96.0.2-1
firefox-i18n-fi 96.0.1-1 96.0.2-1
firefox-i18n-fr 96.0.1-1 96.0.2-1
firefox-i18n-fy-nl 96.0.1-1 96.0.2-1
firefox-i18n-ga-ie 96.0.1-1 96.0.2-1
firefox-i18n-gd 96.0.1-1 96.0.2-1
firefox-i18n-gl 96.0.1-1 96.0.2-1
firefox-i18n-gn 96.0.1-1 96.0.2-1
firefox-i18n-gu-in 96.0.1-1 96.0.2-1
firefox-i18n-he 96.0.1-1 96.0.2-1
firefox-i18n-hi-in 96.0.1-1 96.0.2-1
firefox-i18n-hr 96.0.1-1 96.0.2-1
firefox-i18n-hsb 96.0.1-1 96.0.2-1
firefox-i18n-hu 96.0.1-1 96.0.2-1
firefox-i18n-hy-am 96.0.1-1 96.0.2-1
firefox-i18n-ia 96.0.1-1 96.0.2-1
firefox-i18n-id 96.0.1-1 96.0.2-1
firefox-i18n-is 96.0.1-1 96.0.2-1
firefox-i18n-it 96.0.1-1 96.0.2-1
firefox-i18n-ja 96.0.1-1 96.0.2-1
firefox-i18n-ka 96.0.1-1 96.0.2-1
firefox-i18n-kab 96.0.1-1 96.0.2-1
firefox-i18n-kk 96.0.1-1 96.0.2-1
firefox-i18n-km 96.0.1-1 96.0.2-1
firefox-i18n-kn 96.0.1-1 96.0.2-1
firefox-i18n-ko 96.0.1-1 96.0.2-1
firefox-i18n-lij 96.0.1-1 96.0.2-1
firefox-i18n-lt 96.0.1-1 96.0.2-1
firefox-i18n-lv 96.0.1-1 96.0.2-1
firefox-i18n-mk 96.0.1-1 96.0.2-1
firefox-i18n-mr 96.0.1-1 96.0.2-1
firefox-i18n-ms 96.0.1-1 96.0.2-1
firefox-i18n-my 96.0.1-1 96.0.2-1
firefox-i18n-nb-no 96.0.1-1 96.0.2-1
firefox-i18n-ne-np 96.0.1-1 96.0.2-1
firefox-i18n-nl 96.0.1-1 96.0.2-1
firefox-i18n-nn-no 96.0.1-1 96.0.2-1
firefox-i18n-oc 96.0.1-1 96.0.2-1
firefox-i18n-pa-in 96.0.1-1 96.0.2-1
firefox-i18n-pl 96.0.1-1 96.0.2-1
firefox-i18n-pt-br 96.0.1-1 96.0.2-1
firefox-i18n-pt-pt 96.0.1-1 96.0.2-1
firefox-i18n-rm 96.0.1-1 96.0.2-1
firefox-i18n-ro 96.0.1-1 96.0.2-1
firefox-i18n-ru 96.0.1-1 96.0.2-1
firefox-i18n-si 96.0.1-1 96.0.2-1
firefox-i18n-sk 96.0.1-1 96.0.2-1
firefox-i18n-sl 96.0.1-1 96.0.2-1
firefox-i18n-son 96.0.1-1 96.0.2-1
firefox-i18n-sq 96.0.1-1 96.0.2-1
firefox-i18n-sr 96.0.1-1 96.0.2-1
firefox-i18n-sv-se 96.0.1-1 96.0.2-1
firefox-i18n-ta 96.0.1-1 96.0.2-1
firefox-i18n-te 96.0.1-1 96.0.2-1
firefox-i18n-th 96.0.1-1 96.0.2-1
firefox-i18n-tl 96.0.1-1 96.0.2-1
firefox-i18n-tr 96.0.1-1 96.0.2-1
firefox-i18n-trs 96.0.1-1 96.0.2-1
firefox-i18n-uk 96.0.1-1 96.0.2-1
firefox-i18n-ur 96.0.1-1 96.0.2-1
firefox-i18n-uz 96.0.1-1 96.0.2-1
firefox-i18n-vi 96.0.1-1 96.0.2-1
firefox-i18n-xh 96.0.1-1 96.0.2-1
firefox-i18n-zh-cn 96.0.1-1 96.0.2-1
firefox-i18n-zh-tw 96.0.1-1 96.0.2-1
flatpak 1.12.3-1 1.12.4-1
flatpak-builder 1.2.1-1 1.2.2-1
folks 0.15.3+6+gdb1de866-1 0.15.4-1
geeqie 1.6-6 1.7.1-1
gnome-control-center 41.2-2 41.2-3
gnome-settings-daemon 41.0-1 41.0-2
gnumeric 1.12.50-3 1.12.51-1
goffice 0.10.50-1 0.10.51-1
gst-plugin-opencv 1.18.5-4 1.18.5-5
gst-plugin-pipewire 1:0.3.43-1 1:0.3.43-5
gst-plugin-wpe 1.18.5-4 1.18.5-5
gst-plugins-bad 1.18.5-4 1.18.5-5
gst-plugins-bad-libs 1.18.5-4 1.18.5-5
gtk-update-icon-cache 1:4.6.0-1 1:4.6.0-2
gtk4 1:4.6.0-1 1:4.6.0-2
gtk4-demos 1:4.6.0-1 1:4.6.0-2
gtk4-docs 1:4.6.0-1 1:4.6.0-2
gvim 8.2.3890-1 8.2.4106-1
ibus-typing-booster 2.15.11-1 2.15.15-1
imath 3.1.3-4 3.1.4-1
jack-example-tools 1-1 1-2
jack2 1.9.20-1 1.9.20-3
jack2-dbus 1.9.20-1 1.9.20-3
jack2-docs 1.9.20-1 1.9.20-3
kconfigwidgets 5.90.0-1 5.90.1-1
krita 5.0.2-1 5.0.2-2
libappimage 1.0.3-5 1.0.4-1
libfido2 1.9.0-2 1.10.0-1
libical 3.0.12-1 3.0.13-1
libinput 1.19.3-1 1.19.3-2
libphonenumber 8.12.39-3 8.12.41-1
libuv 1.42.0-1 1.43.0-1
libwacom 1.12-1 2.0.0-2
libwebp 1.2.1-2 1.2.2-1
libwebsockets 4.3.0-1 4.3.1-1
libxml2 2.9.12-6 2.9.12-7
lighttpd 1.4.63-1 1.4.64-1
lua-lpeg 1.0.2-3 1.0.2-4
lua51-lpeg 1.0.2-3 1.0.2-4
lua52-lpeg 1.0.2-3 1.0.2-4
lua53-lpeg 1.0.2-3 1.0.2-4
mc 4.8.27-1 -
meson 0.61.0-4 0.61.1-1
mutter 41.3-1 41.3-2
neon 0.32.1-1 0.32.2-1
perl-http-message 6.34-1 6.35-1
perl-io-socket-ssl 2.072-1 2.073-1
php 8.0.14-1 8.1.2-1
php-apache 8.0.14-1 8.1.2-1
php-apcu 5.1.21-2 5.1.21-3
php-cgi 8.0.14-1 8.1.2-1
php-dblib 8.0.14-1 8.1.2-1
php-embed 8.0.14-1 8.1.2-1
php-enchant 8.0.14-1 8.1.2-1
php-fpm 8.0.14-1 8.1.2-1
php-gd 8.0.14-1 8.1.2-1
php-imap 8.0.14-1 8.1.2-1
php-intl 8.0.14-1 8.1.2-1
php-odbc 8.0.14-1 8.1.2-1
php-pgsql 8.0.14-1 8.1.2-1
php-phpdbg 8.0.14-1 8.1.2-1
php-pspell 8.0.14-1 8.1.2-1
php-snmp 8.0.14-1 8.1.2-1
php-sodium 8.0.14-1 8.1.2-1
php-sqlite 8.0.14-1 8.1.2-1
php-tidy 8.0.14-1 8.1.2-1
php-xsl 8.0.14-1 8.1.2-1
php7-apcu 5.1.21-2 5.1.21-3
pipewire-alsa 1:0.3.43-1 1:0.3.43-5
pipewire-docs 1:0.3.43-1 1:0.3.43-5
pipewire-jack 1:0.3.43-1 1:0.3.43-5
pipewire-pulse 1:0.3.43-1 1:0.3.43-5
pipewire-v4l2 1:0.3.43-1 1:0.3.43-5
pipewire-zeroconf 1:0.3.43-1 1:0.3.43-5
pkgstats 3.1.1-1 3.2.0-1
power-profiles-daemon 0.10.1-1 0.10.1-2
python-attrs 21.3.0-1 21.4.0-1
python-setuptools 1:59.1.0-1 1:59.1.1-1
qca-qt5 2.3.4-1 2.3.4-2
qca-qt6 2.3.4-1 2.3.4-2
qt5-base 5.15.2+kde+r291-1 5.15.2+kde+r294-1
qt5-quickcontrols2 5.15.2+kde+r9-1 5.15.2+kde+r10-1
qt5-virtualkeyboard 5.15.2+kde+r4-1 5.15.2+kde+r6-1
qt5-wayland 5.15.2+kde+r41-1 5.15.2+kde+r44-1
qt5-xcb-private-headers 5.15.2+kde+r291-1 5.15.2+kde+r294-1
qtcreator 6.0.1-1 6.0.2-1
rest 0.8.1-3 0.8.1+r4+ge5ee6ef-1
rust 1:1.58.0-1 1:1.58.1-1
rust-src 1:1.58.0-1 1:1.58.1-1
samba 4.15.3-2 4.15.4-1
smbclient 4.15.3-2 4.15.4-1
soundtouch 2.3.0-2 2.3.1-1
spirv-tools 2021.3-1 2021.4-1
syslog-ng 3.35.1-2 3.35.1-3
texmacs 2.1-1 2.1.1-1
thunderbird 91.5.0-1 91.5.0-2
thunderbird-i18n-af 91.5.0-1 91.5.0-2
thunderbird-i18n-ar 91.5.0-1 91.5.0-2
thunderbird-i18n-ast 91.5.0-1 91.5.0-2
thunderbird-i18n-be 91.5.0-1 91.5.0-2
thunderbird-i18n-bg 91.5.0-1 91.5.0-2
thunderbird-i18n-br 91.5.0-1 91.5.0-2
thunderbird-i18n-ca 91.5.0-1 91.5.0-2
thunderbird-i18n-cak 91.5.0-1 91.5.0-2
thunderbird-i18n-cs 91.5.0-1 91.5.0-2
thunderbird-i18n-cy 91.5.0-1 91.5.0-2
thunderbird-i18n-da 91.5.0-1 91.5.0-2
thunderbird-i18n-de 91.5.0-1 91.5.0-2
thunderbird-i18n-dsb 91.5.0-1 91.5.0-2
thunderbird-i18n-el 91.5.0-1 91.5.0-2
thunderbird-i18n-en-gb 91.5.0-1 91.5.0-2
thunderbird-i18n-en-us 91.5.0-1 91.5.0-2
thunderbird-i18n-es-ar 91.5.0-1 91.5.0-2
thunderbird-i18n-es-es 91.5.0-1 91.5.0-2
thunderbird-i18n-et 91.5.0-1 91.5.0-2
thunderbird-i18n-eu 91.5.0-1 91.5.0-2
thunderbird-i18n-fi 91.5.0-1 91.5.0-2
thunderbird-i18n-fr 91.5.0-1 91.5.0-2
thunderbird-i18n-fy-nl 91.5.0-1 91.5.0-2
thunderbird-i18n-ga-ie 91.5.0-1 91.5.0-2
thunderbird-i18n-gd 91.5.0-1 91.5.0-2
thunderbird-i18n-gl 91.5.0-1 91.5.0-2
thunderbird-i18n-he 91.5.0-1 91.5.0-2
thunderbird-i18n-hr 91.5.0-1 91.5.0-2
thunderbird-i18n-hsb 91.5.0-1 91.5.0-2
thunderbird-i18n-hu 91.5.0-1 91.5.0-2
thunderbird-i18n-hy-am 91.5.0-1 91.5.0-2
thunderbird-i18n-id 91.5.0-1 91.5.0-2
thunderbird-i18n-is 91.5.0-1 91.5.0-2
thunderbird-i18n-it 91.5.0-1 91.5.0-2
thunderbird-i18n-ja 91.5.0-1 91.5.0-2
thunderbird-i18n-ka 91.5.0-1 91.5.0-2
thunderbird-i18n-kab 91.5.0-1 91.5.0-2
thunderbird-i18n-kk 91.5.0-1 91.5.0-2
thunderbird-i18n-ko 91.5.0-1 91.5.0-2
thunderbird-i18n-lt 91.5.0-1 91.5.0-2
thunderbird-i18n-ms 91.5.0-1 91.5.0-2
thunderbird-i18n-nb-no 91.5.0-1 91.5.0-2
thunderbird-i18n-nl 91.5.0-1 91.5.0-2
thunderbird-i18n-nn-no 91.5.0-1 91.5.0-2
thunderbird-i18n-pa-in 91.5.0-1 91.5.0-2
thunderbird-i18n-pl 91.5.0-1 91.5.0-2
thunderbird-i18n-pt-br 91.5.0-1 91.5.0-2
thunderbird-i18n-pt-pt 91.5.0-1 91.5.0-2
thunderbird-i18n-rm 91.5.0-1 91.5.0-2
thunderbird-i18n-ro 91.5.0-1 91.5.0-2
thunderbird-i18n-ru 91.5.0-1 91.5.0-2
thunderbird-i18n-sk 91.5.0-1 91.5.0-2
thunderbird-i18n-sl 91.5.0-1 91.5.0-2
thunderbird-i18n-sq 91.5.0-1 91.5.0-2
thunderbird-i18n-sr 91.5.0-1 91.5.0-2
thunderbird-i18n-sv-se 91.5.0-1 91.5.0-2
thunderbird-i18n-th 91.5.0-1 91.5.0-2
thunderbird-i18n-tr 91.5.0-1 91.5.0-2
thunderbird-i18n-uk 91.5.0-1 91.5.0-2
thunderbird-i18n-uz 91.5.0-1 91.5.0-2
thunderbird-i18n-vi 91.5.0-1 91.5.0-2
thunderbird-i18n-zh-cn 91.5.0-1 91.5.0-2
thunderbird-i18n-zh-tw 91.5.0-1 91.5.0-2
tomcat8 8.5.74-1 8.5.75-1
tomcat9 9.0.57-1 9.0.58-1
tree 1.8.0-2 2.0.1-2
vim-runtime 8.2.3890-1 8.2.4106-1
vulkan-html-docs 1:1.2.175-1 1:1.2.203-1
vulkan-icd-loader 1.2.202-1 1.2.203-1
vulkan-tools 1.2.199-1 1.2.203-1
vulkan-validation-layers 1.2.199-1 1.2.203-1
webkit2gtk 2.34.3-1 2.34.4-1
webkit2gtk-4.1 2.34.3-1 2.34.4-1
webkit2gtk-5.0 2.34.3-1 2.34.4-1
wpewebkit 2.34.3-1 2.34.4-1
zabbix-agent 5.4.7-2 5.4.9-1
zabbix-agent2 5.4.7-2 5.4.9-1
zabbix-frontend-php 5.4.7-2 5.4.9-1
zabbix-proxy 5.4.7-2 5.4.9-1
zabbix-server 5.4.7-2 5.4.9-1
zeitgeist 1.0.3+3+g702fdbac-3 1.0.4-1
librest - 0.9.0-1
librest-docs - 0.9.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.12.1.r12679.g80cd33827-121.12.1.r12681.g9f131336c-1
akonadi-contacts21.12.1.r3108.gc5ba92f1-121.12.1.r3109.g5c37312c-1
akonadi-mime21.12.1.r1690.g5c1c338-121.12.1.r1691.g31ce516-1
akonadi-notes21.12.1.r1053.geeda5b6-121.12.1.r1054.gcc50e4c-1
angelfish 21.12.r41.g8f94328-1 21.12.r43.g0d9c8e6-1
ark21.12.1.r4681.g475a9cc4-121.12.1.r4682.g519d8587-1
audiocd-kio21.12.1.r1045.g706bf38-121.12.1.r1046.g9fab120-1
baloo5.90.0.r3027.g7ddbf92c-15.90.0.r3029.g5ec9408c-1
bigscreen-image-settings r9.1560432-1 r11.a858c6b-1
bluedevil1:5.23.5.r2356.g3e4c8e96-11:5.23.5.r2358.g45ade9f1-1
bomber21.12.1.r547.g3a516d6-121.12.1.r548.g051157c-1
breeze5.23.5.r2326.g3a81753d-15.23.5.r2331.g2f926402-1
breeze-gtk5.23.5.r441.g7e7caf2-15.23.5.r442.g3a328da-1
discover5.23.5.r8477.gcdb3e432-15.23.5.r8498.g8b45c204-1
dolphin21.12.1.r6809.gd38396171-121.12.1.r6814.gb81d3fbbb-1
dragon21.12.1.r1021.g8f3c2c7-121.12.1.r1022.gaf16f17-1
drkonqi5.23.5.r721.g6edee6f3-15.23.5.r723.g967f6b99-1
elisa21.12.1.r2846.gbda79fc5-121.12.1.r2848.g17ed3ad6-1
eventviews21.12.1.r782.gcdda877-121.12.1.r783.g85700d9-1
extra-cmake-modules5.90.0.r3416.g2ce35e2-15.90.0.r3425.g13d2e4a-1
filelight21.12.1.r1022.g6962769-121.12.1.r1023.g1b923ad-1
frameworkintegration5.90.0.r618.gb07d220-15.90.0.r619.g7c22639-1
granatier21.12.1.r954.g8d47735-121.12.1.r956.g910bc47-1
gwenview21.12.1.r6745.gb6be40e2-121.12.1.r6748.g84c6c47f-1
incidenceeditor21.12.1.r830.g4fe2162-121.12.1.r831.g48e9b7f-1
index-fm 2.1.0.r22.gc40859a-1 2.1.0.r23.gd06cb23-1
k3b1:21.12.1.r6706.gfd52bf022-11:21.12.1.r6708.g8febdb005-1
kaddressbook21.12.1.r6095.g12010ccd-121.12.1.r6097.gaed71b23-1
kalarm21.12.1.r6573.g629228f8-121.12.1.r6579.g20409053-1
kalgebra21.12.1.r2049.g0e09358-121.12.1.r2051.ge518111-1
kamera21.12.1.r693.ge84c6fa-121.12.1.r695.gd67ef5b-1
kamoso21.12.1.r1444.g22fd818-121.12.1.r1446.g11c936b-1
kate21.12.1.r18573.gd883d7506-121.12.1.r18580.g37d6cbbbf-1
katomic21.12.1.r943.ga6754db-121.12.1.r944.gfd879a4-1
kblackbox21.12.1.r748.g6f83278-121.12.1.r750.g6e8e796-1
kblocks21.12.1.r692.gdab92f9-121.12.1.r693.g4fafa7a-1
kbounce21.12.1.r829.gb56fbe5-121.12.1.r831.gfe5b551-1
kbreakout21.12.1.r887.gd3e3f59-121.12.1.r889.gfffe0b6-1
kcalc21.12.1.r1587.g611635b-121.12.1.r1590.g59e1175-1
kcharselect21.12.1.r498.gf9d3f26-121.12.1.r499.g5e0b46e-1
kcmutils5.90.0.r595.g04f083c-15.90.0.r596.g7903acd-1
kcolorchooser21.12.1.r245.g5e611a0-121.12.1.r246.g59d363b-1
kconfigwidgets5.90.0.r672.g36a6ecb-15.90.0.r673.g765ab0f-1
kcontacts1:5.90.0.r3302.g7b5ae610-11:5.90.0.r3303.g363a9487-1
kcoreaddons5.90.0.r1395.g82f17c3b-15.90.0.r1407.g5a04ecbb-1
kcrash5.90.0.r430.ge289bfe-15.90.0.r431.g007908c-1
kcron21.12.1.r819.gc49b1dc-121.12.1.r820.g1b2056b-1
kde-cli-tools5.23.5.r1889.g6833373-15.23.5.r1890.g8939a7c-1
kdebugsettings21.12.1.r886.g86acb9f-121.12.1.r888.g406f4ac-1
kdeclarative5.90.0.r966.gfe9838d-15.90.0.r970.gdd6f40c-1
kdenlive21.12.1.r15533.gb8db16251-121.12.1.r15546.gfaede6fba-1
kdepim-addons21.12.1.r4500.gf52a224c-121.12.1.r4519.g8e4335c0-1
kdepim-runtime21.12.1.r15437.g94e4d7b4d-121.12.1.r15440.g0dff1f368-1
kdeplasma-addons5.23.5.r8635.ga215954f7-15.23.5.r8636.g567c2c2cd-1
kdf21.12.1.r824.g29b2d9b-121.12.1.r827.g481ba17-1
kdiamond21.12.1.r693.gd6607b7-121.12.1.r703.gaa3320c-1
keditbookmarks21.12.1.r2758.ga087de28b-121.12.1.r2759.gae988d9e5-1
kfilemetadata5.90.0.r841.gebbf317-15.90.0.r842.g55c7070-1
kfloppy21.12.1.r782.g753e1c8-121.12.1.r783.g293ba45-1
kfourinline21.12.1.r1004.gef1e18b-121.12.1.r1005.g7a1163b-1
kgoldrunner21.12.1.r1261.g3e851d3-121.12.1.r1262.ga6c297b-1
kgpg21.12.1.r3164.ga09bb2e3-121.12.1.r3165.g1a70bd9e-1
khealthcertificate 21.12.r0.gb5cc474-1 21.12.r1.g950d2e3-1
kholidays1:5.90.0.r989.gf46efdf-11:5.90.0.r990.gcc48aaa-1
ki18n5.90.0.r538.ge8cc238-15.90.0.r540.ge548c46-1
kiconthemes5.90.0.r580.g06f0dfa-15.90.0.r582.g8a6d70c-1
kidentitymanagement21.12.1.r3858.gfabb8a9d-121.12.1.r3860.g113c861d-1
kigo21.12.1.r544.g2bd5174-121.12.1.r545.g190c8ae-1
killbots21.12.1.r760.gbb9aa2c-121.12.1.r761.ga395f22-1
kimap21.12.1.r1157.gcbd599a-121.12.1.r1158.geb2ed83-1
kio5.90.0.r5216.g69bc157aa-15.90.0.r5227.g9b8ea6a46-1
kirigami25.90.0.r3036.g7d601cdb-15.90.0.r3045.ge932767e-1
kiriki21.12.1.r435.g103920b-121.12.1.r436.g35ff458-1
kitemmodels5.90.0.r588.g48837d8-15.90.0.r590.g616e959-1
kitinerary21.12.1.r2062.g3239e67-121.12.1.r2073.g4b22b18-1
kjumpingcube21.12.1.r809.g2bf25d5-121.12.1.r810.g563aea7-1
kldap21.12.1.r923.g5dc86d7-121.12.1.r928.g2b86367-1
kleopatra21.12.1.r6161.g183c899a-121.12.1.r6172.gc5d6bd1b-1
klickety21.12.1.r657.g6c0227f-121.12.1.r658.gc249612-1
klines21.12.1.r789.g4b33b5b-121.12.1.r790.gc58a93f-1
kmahjongg21.12.1.r1499.g1fc2447-121.12.1.r1510.g953d16f-1
kmail21.12.1.r26211.g05c1c3eae-121.12.1.r26214.g245ffaba5-1
kmailtransport21.12.1.r1700.gf8be230-121.12.1.r1703.g2be4e10-1
kmbox21.12.1.r574.g72710f4-121.12.1.r575.gb597771-1
kmenuedit5.23.5.r984.g9241428-15.23.5.r985.g4574f37-1
kmines21.12.1.r1746.g0bbf4a6-121.12.1.r1748.g9d70bc2-1
knavalbattle21.12.1.r1413.gf3bf924-121.12.1.r1414.g9f489d6-1
knetwalk21.12.1.r677.g5308724-121.12.1.r679.g25ee1b4-1
knewstuff5.90.0.r1273.gc6a95ea8-15.90.0.r1275.g9a6830ca-1
knights21.12.1.r1090.gd975786-121.12.1.r1091.g796b56b-1
knotes21.12.1.r3579.g457a236b-121.12.1.r3580.g91454f95-1
kolf21.12.1.r1467.g9a63204-121.12.1.r1468.g552efc4-1
kollision21.12.1.r513.g182427c-121.12.1.r514.gbd9ac5c-1
konquest21.12.1.r913.g88d1e4b-121.12.1.r915.g521e85b-1
konsole21.12.1.r8208.g465c89d5-121.12.1.r8213.g4a26a4d6-1
kontact21.12.1.r5457.ga9249c79-121.12.1.r5458.gd90d16fa-1
kontactinterface21.12.1.r660.g6e4a99a-121.12.1.r661.gd10db89-1
kopeninghours21.12.1.r312.g231f08f-121.12.1.r313.ga7c8653-1
korganizer21.12.1.r11610.ge096a8530-121.12.1.r11615.g6bd98be15-1
kosmindoormap21.12.1.r689.g306d701-121.12.1.r690.g0ec2add-1
kpackage5.90.0.r731.g97777a3-15.90.0.r732.gf40d773-1
kpat21.12.1.r2592.g91e4552-121.12.1.r2593.g404b683-1
kpeople5.90.0.r1362.g1b00199-15.90.0.r1363.g788f81e-1
kpimtextedit21.12.1.r1501.g2730909-121.12.1.r1506.g839bf20-1
kpkpass21.12.1.r265.g475d4ef-121.12.1.r266.gc6e6f4b-1
kpmcore21.12.1.r1234.g72b4142-121.12.1.r1241.ge2f097f-1
kpublictransport21.12.1.r1974.gc9a5ff3e-121.12.1.r1975.g09e7a7a7-1
kreversi21.12.1.r1249.ga9564de-121.12.1.r1251.g1843f20-1
krunner5.90.0.r724.g5c25c5b-15.90.0.r726.ga1d553a-1
kservice5.90.0.r986.g658d45b-15.90.0.r988.geee4a93-1
kshisen21.12.1.r1220.g2237330-121.12.1.r1221.gb12b65b-1
ksirk21.12.1.r993.gf20e972-121.12.1.r994.g04f0e74-1
ksmtp21.12.1.r417.gf7cd01a-121.12.1.r418.g2b0e31c-1
ksnakeduel21.12.1.r827.g2a816e6-121.12.1.r829.g360567a-1
kspaceduel21.12.1.r656.ge5d89ba-121.12.1.r657.gf3a271c-1
ksquares21.12.1.r541.gb520593-121.12.1.r543.g218f167-1
ksudoku21.12.1.r1086.g80cf900-121.12.1.r1087.g168f8cb-1
ksystemlog21.12.1.r687.g697521f-121.12.1.r688.gfb02675-1
ktexteditor5.90.0.r3065.g3b319194-15.90.0.r3075.g690e16d5-1
ktorrent21.12.1.r2817.ga6710080-121.12.1.r2818.gcfcec895-1
ktrip 21.12.r3.gdd83cfe-1 21.12.r4.g043d04c-1
kwallet-pam5.23.5.r262.g4059813-15.23.5.r264.g2da1635-1
kwalletmanager21.12.1.r1232.gccf9577-121.12.1.r1233.g4010fa1-1
kwayland-integration5.23.5.r198.gc5804d4-15.23.5.r199.gb05afab-1
kwin5.23.5.r20625.gb2d401cdd-15.23.5.r20660.gb572aadfd-1
kwrite21.12.1.r18573.gd883d7506-121.12.1.r18580.g37d6cbbbf-1
kxmlgui5.90.0.r839.g661e2409-15.90.0.r840.gde04beae-1
libakonadi21.12.1.r12679.g80cd33827-121.12.1.r12681.g9f131336c-1
libgravatar21.12.1.r399.g10beb4e-121.12.1.r400.gd34fd8a-1
libkdegames21.12.1.r2209.gb6aa9373-121.12.1.r2213.g3d856df7-1
libkdepim21.12.1.r882.g54ae219-121.12.1.r884.g68b1d56-1
libkleo21.12.1.r1052.gbf2fb68-121.12.1.r1054.g4c4a4ee-1
libkmahjongg21.12.1.r467.g15d7e55-121.12.1.r471.gd7ded5b-1
libksieve21.12.1.r1648.gcee7f65e-121.12.1.r1653.gc07c5d9f-1
libksysguard5.23.5.r2341.g8e414a8-15.23.5.r2344.g4f050ee-1
libktorrent21.12.1.r542.g327358a-121.12.1.r543.g9ef1b0f-1
lskat21.12.1.r833.g429064c-121.12.1.r834.g99cf543-1
mailcommon21.12.1.r1187.gb3cea9f-121.12.1.r1190.gaf3b166-1
maliit-framework2.1.1.r15.gbab3baf5-12.1.1.r17.g8d0da0f9-1
maliit-keyboard2.1.0.r12.gd06ad9b6-12.1.0.r14.g1dca7d07-1
maui-shell r98.e3a2271-1 r113.4bf7457-1
mauikit2.1.0.r64.gf237521d-12.1.0.r68.g21943817-1
messagelib21.12.1.r6343.g54c9eb21d-121.12.1.r6352.g66ec48d78-1
neochat21.12.r48.g24644887-121.12.r49.gfc9e4fc9-1
okular21.12.1.r9577.gcc0e12856-121.12.1.r9580.gc9e09be0a-1
palapeli21.12.1.r1260.ga153f7c-121.12.1.r1261.g28287a9-1
partitionmanager21.12.1.r1568.g31bdb87-121.12.1.r1587.g87eb4cd-1
picmi21.12.1.r547.gdec1ad3-121.12.1.r549.g86a750f-1
pim-data-exporter21.12.1.r2553.g7ba163d1-121.12.1.r2567.g75525856-1
pim-sieve-editor21.12.1.r1557.g2fe1139-121.12.1.r1573.g9b55f98-1
pimcommon21.12.1.r1172.g074c9c7-121.12.1.r1177.g843b0f3-1
plasma-bigscreen r442.g790dffc-1 r445.g5519eac-1
plasma-desktop5.23.5.r9008.g57dae632b-15.23.5.r9019.g30a50aca0-1
plasma-dialer 21.12.r13.g14e96f1-1 21.12.r14.g2294e44-1
plasma-framework5.90.0.r16157.g146402c4e-15.90.0.r16161.ga83321120-1
plasma-phone-components5.23.5.r1600.gdd4000d8-1 -
plasma-sdk5.23.5.r2303.gf5349c30-15.23.5.r2319.g661ec095-1
plasma-settings 21.12.r7.g911cea2-1 21.12.r8.g211395a-1
plasma-systemmonitor5.23.5.r538.ge633796-15.23.5.r539.gffd9c7f-1
plasma-wayland-session5.23.5.r11269.g0bb2cbe28-15.23.5.r11312.g41897540c-1
plasma-workspace5.23.5.r11269.g0bb2cbe28-15.23.5.r11312.g41897540c-1
plasma-workspace-wallpapers5.23.5.r316.gad868bc-15.23.5.r320.gb34ecb0-1
plasmatube 21.12.r0.g7f2cd93-1 21.12.r2.g9acf6c1-1
powerdevil5.23.5.r2512.gac52ad35-15.23.5.r2513.gadd7ff87-1
purpose5.90.0.r938.g05ec607-15.90.0.r939.ga121450-1
qmlkonsole 21.12.r9.g06ba226-1 21.12.r11.g69661ea-1
qqc2-desktop-style5.90.0.r558.g53cfeba-15.90.0.r565.g0ab6a7a-1
sddm0.19.0.r115.gbfdb514-10.19.0.r120.gd6aa2d3-1
sddm-kcm5.23.5.r640.g5cb51e8-15.23.5.r641.g2c8bbb0-1
solid5.90.0.r740.ge3dc1a2-15.90.0.r742.g2f305a7-1
sonnet5.90.0.r670.ga2276eb-15.90.0.r671.ge468a47-1
spectacle21.12.1.r1281.ge41d85d-121.12.1.r1282.g1de84d5-1
svgpart21.12.1.r198.g25f719a-121.12.1.r201.gce42c15-1
sweeper21.12.1.r551.gffa030c-121.12.1.r552.g6929402-1
systemsettings5.23.5.r2597.ga08ce248-15.23.5.r2601.gfa203a7b-1
tokodon 21.12.r16.g12dd675-1 21.12.r18.g9fd0e6a-1
umbrello21.12.1.r8329.gd0ba65c0e-121.12.1.r8331.g86a322d6a-1
vvave 2.1.0.r20.g7c8f958-1 2.1.0.r22.g514ebe8-1
xdg-desktop-portal-kde5.23.5.r418.g9934795-15.23.5.r429.g33d8d36-1
plasma-mobile -5.23.5.r1603.g1eee1935c-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
