Hello ARM community.
Another update for you all to test!
Some highlights:
- Most of our kernels got updated
- Firefox has a new release with 96.0.1
- Same with Thunderbird with 91.5.0
- Handbrake got a big release with 1.5.1
- And KDE Frameworks got updated to 5.90
- Lots of Mobile specific packages got updated
- Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
( Sun Jan 16 20:44:22 CET 2022)
- arm-testing community aarch64: 393 new and 365 removed package(s)
- arm-testing core aarch64: 47 new and 46 removed package(s)
- arm-testing extra aarch64: 370 new and 368 removed package(s)
- arm-testing kde-unstable aarch64: 267 new and 267 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-01-07 2022-01-16
ap6398s-firmware 2020.04-4 2020.04-5
callaudiod 0.1.3-2 0.1.3-3
chatty0.5.0beta4+17+gbdcd8d8-20.5.0beta4+24+gb10a76b0-1
dkms-rtl8822cs 2020.11.20-2 2020.11.20-3
electron 16.0.6-1 16.0.7-1
electron13 13.6.6-1 13.6.7-1
electron14 14.2.3-1 14.2.4-1
electron15 15.3.4-1 15.3.5-1
gnome-calls42alpha0+48+gba00665-142alpha0+76+g8664e99-2
gnome-control-center-mobile 41.1-1 41.2-2
handbrake 1.4.2-2 1.5.1-1
handbrake-cli 1.4.2-2 1.5.1-1
kodi 19.3-1 19.3-2
kodi-dev 19.3-1 19.3-2
kodi-eventclients 19.3-1 19.3-2
kodi-rpi 19.3-4 19.3-5
kodi-rpi-dev 19.3-4 19.3-5
kodi-rpi-eventclients 19.3-4 19.3-5
kodi-rpi-tools-texturepacker 19.3-4 19.3-5
kodi-tools-texturepacker 19.3-1 19.3-2
manjaro-arm-wallpapers 20211103-1 20220109-1
phosh 0.14.1+71+gf6e7715-20.14.1+127+g279c282-1
pinephone-manjaro-tweaks 20220108-2 20220114-1
pinephone-post-install 20211118-2 20220116-1
pinephonepro-manjaro-tweaks 20220108-2 20220114-1
pinephonepro-post-install 20211110-1 20220116-1
python-gbinder 1.0.0-2 1.0.0-2
snapd 2.54.1-1 2.54.2-2
:: Different sync package(s) in repository community aarch64
agordejo 0.3.0-1 0.3.1-1
amule 1:2.3.3-3 1:2.3.3-4
android-tools 31.0.3-2 31.0.3-3
ansible 5.1.0-1 5.2.0-1
ansible-lint 5.3.1-1 5.3.2-1
arb 2.21.1-1 2.22.0-1
arch-repro-status 1.2.6-1 1.2.7-1
asciidoctor 2.0.16-1 2.0.17-1
b3sum 1.2.0-2 1.3.0-1
babel-core 7.16.5-1 7.16.7-1
benchmark 1.6.0-1 1.6.1-1
bmake 20211001-1 20211221-2
bootconfig 5.15-2 5.16-1
bpf 5.15-2 5.16-1
broot 1.8.1-1 1.9.1-1
btfs 2.24-1 2.24-2
cargo-crev 0.21.3-2 0.22.2-1
cargo-expand 1.0.11-1 1.0.14-1
cargo-release 0.18.8-1 0.19.1-1
cgroup_event_listener 5.15-2 5.16-1
cinnamon 5.0.7-5 5.2.7-1
cinnamon-control-center 5.0.2-2 5.2.1-1
cinnamon-desktop 5.0.0-2 5.2.1-1
cinnamon-menus 5.0.0-1 5.2.0-1
cinnamon-screensaver 5.0.7-1 5.2.0-1
cinnamon-session 5.0.1-1 5.2.0-1
cinnamon-settings-daemon 5.0.4-1 5.2.0-1
cinnamon-translations 5.0.2-2 5.2.2-1
cjs 5.0.1-2.1 5.2.0-1
clementine1.4.0rc1+759+gd033b38c4-21.4.0rc1+776+gcefe81d0c-1
clipgrab 3.9.7-1 3.9.7-2
coin-or-asl 1.4.3-1 1.4.4-1
coin-or-cbc 2.10.5-4 2.10.6-1
coin-or-cgl 0.60.3-1 0.60.4-1
coin-or-clp 1.17.6-1 1.17.7-1
coin-or-coinutils 2.11.4-1 2.11.6-1
coin-or-osi 0.108.6-1 0.108.7-1
conmon 1:2.0.31-1 1:2.0.32-2
containerd 1.5.9-1 1.5.9-2
copyq 5.0.0-1 6.0.1-1
cpupower 5.15-2 5.16-1
crypto++ 8.5.0-2 8.6.0-1
dart-sass 1.46.0-1 1.48.0-1
diffoscope 198-1 200-1
dnssec-tools 2.2.3-7 2.2.3-8
docker-compose 2.2.3-1 2.2.3-2
doctl 1.68.0-1 1.69.0-1
drone 2.7.3-1 2.8.0-1
drone-oss 2.7.3-1 2.8.0-1
drumkv1 0.9.23-1 0.9.24-1
dua-cli 2.14.7-1 2.16.0-1
duf 0.6.2-3 0.7.0-1
elementary-wallpapers 6.0.0-1 6.1.0-1
fanficfare 4.8.0-2 4.9.0-1
fcitx-qt5 1.2.7-1 1.2.7-2
fcitx5 5.0.12-1 5.0.13-1
fcitx5-chinese-addons 5.0.9-2 5.0.10-1
fcitx5-configtool 5.0.9-1 5.0.10-1
fcitx5-gtk 5.0.10-1 5.0.11-1
fcitx5-m17n 5.0.6-1 5.0.7-1
fcitx5-qt 5.0.8-1 5.0.9-1
filebin 3.6.1-3 3.6.2-1
firefox-tree-style-tab 3.8.18-1 3.8.19-1
firefox-ublock-origin 1.40.4-1 1.40.8-1
firewalld 1.0.2-2 1.0.3-2
freeradius 3.0.25-4 3.0.25-5
freerdp 2:2.4.1-2 2:2.5.0-1
fwupd 1.7.3-1 1.7.4-1
gdal 3.4.0-1 3.4.0-2
ghostwriter 2.1.0-1 2.1.1-1
gimp-plugin-gmic 3.0.0-3 3.0.1-1
glewlwyd 2.6.0-2 2.6.1-2
glider 0.15.2-1 0.15.3-2
go 2:1.17.6-1 2:1.17.6-2
go-ipfs 0.10.0-1 0.11.0-1
goreleaser 1.2.5-1 1.3.0-1
gping 1.2.6-1 1.2.7-1
gpio-utils 5.15-2 5.16-1
gtop 1.1.2-1 1.1.3-1
haproxy 2.5.0-1 2.5.1-1
hitch 1.7.0-1 1.7.2-2
hy 1.0a3-1 1.0a4-2
hypercorn 0.12.0-1 0.13.1-1
hyperv 5.15-2 5.16-1
ibus-table 1.14.1-2 1.15.0-1
iio-utils 5.15-2 5.16-1
iptstate 2.2.6-4 2.2.7-1
iwd 1.20-1 1.21-1
jacktrip 1.5.0-1 1.5.1-1
jenkins 2.328-1 2.329-1
jupyter-jsmol 2021.9.0-2 2022.1.0-1
jupyter-nbclassic 0.3.4-3 0.3.5-1
jupyter-server 1.13.1-2 1.13.3-1
jupyterlab 3.2.6-1 3.2.8-1
kid3 3.9.0-1 3.9.1-1
kid3-common 3.9.0-1 3.9.1-1
kid3-qt 3.9.0-1 3.9.1-1
kitty 0.24.0-1 0.24.1-1
kitty-terminfo 0.24.0-1 0.24.1-1
klayout 0.27.5-2 0.27.7-1
kompose 1.24.0-1 1.26.0-1
kubeseal 0.17.1-1 0.17.2-1
kvazaar 2.1.0-1 2.1.0-2
languagetool 5.5-2 5.6-1
latte-dock 0.10.6-1 0.10.7-1
lazygit 0.31.4-1 0.32.1-1
libime 1.0.10-2 1.0.11-1
liblscp 0.9.4-1 0.9.5-1
libolm 3.2.9-1 3.2.10-1
libosinfo 1.9.0-1 1.9.0-2
libretro-beetle-pce 1095-1 1102-1
libretro-beetle-pce-fast 1155-1 1158-1
libretro-beetle-psx 2591-1 2598-1
libretro-beetle-psx-hw 2591-1 2598-1
libretro-beetle-supergrafx 933-1 939-1
libretro-dolphin 33004-2 33006-1
libretro-gambatte 951-1 957-1
libretro-genesis-plus-gx 1872-1 1881-1
libretro-melonds 1983-1 1989-1
libretro-mgba 8041-1 8106-1
libretro-nestopia 1:68-1 1:72-1
libretro-play 6881-1 6905-1
libretro-scummvm 93200-1 93204-1
libretro-shaders-slang 862-1 878-1
libretro-snes9x 2041-1 2043-1
libspeechd 0.11.0-1 0.11.1-1
libtpms 0.9.1-1 0.9.2-1
liburcu 0.13.0-1 0.13.1-1
linux-tools-meta 5.15-2 5.16-1
logcli 2.4.1-1 2.4.2-1
loki 2.4.1-1 2.4.2-1
loki-canary 2.4.1-1 2.4.2-1
lollypop 1.4.24-2 1.4.27-1
lshw B.02.19.2-3 B.02.19.2-4
lua-language-server 2.5.6-1 2.6.0-1
lua-penlight 1.11.0-1 1.12.0-2
lua51-penlight 1.11.0-1 1.12.0-2
lua52-penlight 1.11.0-1 1.12.0-2
lua53-penlight 1.11.0-1 1.12.0-2
lutris 0.5.9.1-3 0.5.9.1-4
lv2file 0.84-3 0.91-1
lxd 4.21-1 4.22-1
lxqt-globalkeys 1.0.0-1 1.0.1-1
lychee-link-checker 0.8.1-1 0.8.2-1
mailutils 3.13-2 3.14-1
mcfly 0.5.11-2 0.5.12-1
meilisearch 0.24.0-1 0.25.1-1
miller 5.10.3-1 6.0.0-1
mongo-c-driver 1.19.1-1 1.20.0-1
muffin 5.0.2-1 5.2.0-1
mypy 0.930-1 0.931-2
nbtscan 1.7.1-1 1.7.2-1
nemo 5.0.5-1 5.2.4-1
nemo-audio-tab 5.0.0-3 5.2.0-1
nemo-emblems 5.0.0-3 5.2.0-1
nemo-fileroller 5.0.0-3 5.2.0-1
nemo-image-converter 5.0.0-3 5.2.0-1
nemo-pastebin 5.0.0-3 5.2.0-1
nemo-preview 5.0.0-3 5.2.0-1
nemo-python 5.0.0-3 5.2.0-1
nemo-seahorse 5.0.0-3 5.2.0-1
nemo-share 5.0.0-3 5.2.0-1
nemo-terminal 5.0.0-3 5.2.0-1
new-session-manager 1.5.1-1 1.5.3-1
nextcloud-app-notes 4.2.0-1 4.3.0-1
npm 8.3.0-1 8.3.1-1
npm-check-updates 12.0.5-1 12.1.0-1
octave 6.4.0-2 6.4.0-3
opencascade 7.5.3-4 1:7.5.3-1
openshadinglanguage 1.11.16.0-4 1.11.17.0-1
pacoloco 1.1-1 1.2-1
padthv1 0.9.23-1 0.9.24-1
pantheon-applications-menu 2.10.0-1 2.10.2-1
pantheon-calculator 1.7.0-1 1.7.2-1
pantheon-files 6.1.0-1 6.1.1-1
pantheon-mail 6.2.0-2 6.3.1-2
pantheon-screenshot 6.0.0-1 6.0.2-1
pantheon-shortcut-overlay 1.2.0-1 1.2.1-1
pantheon-terminal 6.0.0-1 6.0.1-1
pantheon-videos 2.8.0-1 2.8.3-1
perf 5.15-2 5.16-1
perl-return-multilevel 0.06-1 0.08-1
perl-term-table 0.015-3 0.016-1
php-imagick 3.5.1-1 3.7.0-1
php7-imagick 3.5.1-1 3.7.0-1
picard 2.7.1-1 2.7.3-1
polymake 4.5-3 4.6-1
promtail 2.4.1-1 2.4.2-1
prosody 1:0.11.11-1 1:0.11.12-1
pulumi 3.21.0-1 3.22.1-1
pynac 0.7.29-3 0.7.29-4
pyright 1.1.204-1 1.1.209-1
python-anyio 3.4.0-1 3.5.0-1
python-astroid 2.9.2-1 2.9.3-1
python-awesomeversion 21.12.0-1 22.1.0-1
python-black 21.12b0-2 21.12b0-3
python-cfn-lint 0.56.3-1 0.56.4-1
python-charset-normalizer 2.0.4-3 2.0.10-1
python-confuse 1.6.0-3 1.7.0-3
python-dateparser 1.1.0-2 1.1.0-3
python-doit 0.34.0-2 0.34.1-1
python-dulwich 0.20.28-1 0.20.30-1
python-enrich 1.2.6-4 1.2.7-1
python-gdal 3.4.0-1 3.4.0-2
python-gdstk 0.8.0-2 0.8.1-1
python-gitlab 3.0.0-1 3.1.0-1
python-google-api-core 2.3.2-2 2.4.0-2
python-google-api-python-client 2.33.0-1 2.35.0-1
python-graphql-core 3.1.6-3 3.1.7-3
python-httpx 0.21.2-1 0.21.3-1
python-identify 2.4.0-1 2.4.3-1
python-igraph 0.9.8-2 0.9.9-1
python-jellyfish 0.8.9-3 0.9.0-1
python-jupymake 0.9-12 0.9-13
python-libtmux 0.10.2-3 0.10.3-1
python-linux-procfs 0.6.3-3 0.7.0-1
python-logilab-common 1.8.2-1 1.8.3-1
python-marshmallow-sqlalchemy 0.26.1-2 0.27.0-2
python-mediafile 0.8.1-3 0.9.0-1
python-mocket 3.10.2-1 3.10.3-1
python-moto 2.3.0-1 2.3.1-1
python-olm 3.2.9-1 3.2.10-1
python-paramiko 2.9.1-1 2.9.2-1
python-path 16.2.0-3 16.3.0-1
python-phonenumbers 8.12.40-1 8.12.41-1
python-pipenv 2021.11.23-3 2022.1.8-2
python-progressbar 3.55.0-3 4.0.0-1
python-proxy.py 2.3.1-3 2.3.1-4
python-pycountry 20.7.3-5 22.1.10-2
python-pyenchant 3.2.1-3 3.2.2-1
python-pyfakefs 4.5.3-3 4.5.4-1
python-pygame-sdl21:2.1.0.r399.5777335-21:2.1.0.r403.c8c7321-2
python-pylast 4.3.0-3 4.4.0-3
python-pyppeteer 0.2.6-3 1.0.2-1
python-pypugjs 5.9.9-2 5.9.10-1
python-python-socks 2.0.1-1 2.0.2-1
python-pywlroots 0.14.11-3 0.14.12-1
python-quart 0.16.1-3 0.16.2-1
python-requests-kerberos 0.12.0-9 0.14.0-1
python-scrypt 0.8.18-3 0.8.19-1
python-sphinx-furo 2022.01.02-1 2022.01.02-2
python-unicorn 1.0.3-3 1.0.3-4
python-utils 2.7.1-1 3.1.0-1
python-voluptuous-serialize 2.4.0-5 2.5.0-1
python-wsgi-intercept 1.9.2-3 1.9.3-1
python-xmlschema 1.9.1-1 1.9.2-1
python-z3 4.8.13-2 4.8.14-1
python2-pygame-sdl21:2.1.0.r399.5777335-21:2.1.0.r403.c8c7321-2
qbittorrent 4.4.0-1 4.4.0-2
qbittorrent-nox 4.4.0-1 4.4.0-2
qjackctl 0.9.5-1 0.9.6-1
qmidictl 0.9.4-1 0.9.5-1
qmidinet 0.9.4-1 0.9.5-1
qmmp 2.0.2-1 2.0.3-1
qsynth 0.9.4-2 0.9.5-1
qt5pas 2.6.r65219-1 2.6.2.2.0-1
qtractor 0.9.24-1 0.9.25-1
qxgedit 0.9.4-1 0.9.5-1
rathole 0.3.3-1 0.3.7-1
ratpoints 2.1.3-5 2.2-1
rbutil1.4.1.r381.g94eb1df58b-11.4.1.r381.g94eb1df58b-2
renpy 7.4.8-1 7.4.11-1
renpy-demos 7.4.8-1 7.4.11-1
repo 2.19-1 2.20-1
retroarch-assets-glui 1:393-1 1:405-1
retroarch-assets-ozone 1:393-1 1:405-1
retroarch-assets-xmb 1:393-1 1:405-1
ruby-eventmachine 1.2.7-4 1.2.7-5
ruby-ffi 1.15.4-2.1 1.15.5-1
ruby-gpgme 2.0.20-2 2.0.20-3
ruby-network_interface 0.0.2-4 0.0.2-5
ruby-nio4r 2.5.7-1 2.5.7-2
ruby-pcaprub 0.12.4-7 0.12.4-8
ruby-thin 1.8.0-2 1.8.0-3
ruby-unicorn-engine 1.0.3-3 1.0.3-4
rust-analyzer 20220103-1 20220110-1
samplv1 0.9.23-1 0.9.24-1
sbt 1:1.5.6-1 1:1.5.7-1
scribus 1.5.7-9 1.5.7-12
serverless 2.70.0-1 2.71.0-1
shfmt 3.4.1-1 3.4.2-1
shotcut 21.10.31-1 21.12.24-1
sile 0.12.0-5 0.12.1-1
singular 4.2.1.p3-1 4.3.0-2
speech-dispatcher 0.11.0-1 0.11.1-1
sslscan 2.0.10-1 2.0.11-1
starship 1.1.1-1 1.2.1-1
strawberry 1.0.0-2 1.0.1-1
sundials 6.0.0-3 6.1.0-1
supercollider 3.12.1-4 3.12.2-1
supervisor 4.2.3-1 4.2.4-1
switchboard-plug-mouse-touchpad 6.1.0-1 6.1.0-2
switchboard-plug-online-accounts 6.2.2-1 6.3.0-1
syncthing 1.18.5-1 1.18.6-2
syncthing-relaysrv 1.18.5-1 1.18.6-2
synthv1 0.9.23-1 0.9.24-1
tailscale 1.18.2-1 1.20.1-1
taskwarrior-tui 0.17.0-1 0.18.2-1
terraform 1.1.2-1 1.1.3-1
terragrunt 0.35.12-1 0.35.20-1
texstudio 4.1.2-1 4.2.0-1
■■■■■■■ 3.31-2 3.32-1
tig 2.5.4-1 2.5.5-1
tlp 1.4.0-1 1.5.0-3
tlp-rdw 1.4.0-1 1.5.0-3
tmon 5.15-2 5.16-1
tmuxp 1.9.3-2 1.9.4-1
tomlplusplus 2.5.0-1 3.0.1-1
ttf-junicode 1.002-4 1.003-2
ttf-sarasa-gothic 0.35.7-1 0.35.8-1
ulfius 2.7.6-1 2.7.7-1
umockdev 0.17.1-1 0.17.3-1
usbip 5.15-2 5.16-1
uvicorn 0.15.0-3 0.16.0-3
v2ray-domain-list-community 20211228022859-1 20220109141424-1
v2ray-geoip 202112300030-1 202201130034-1
vscode-css-languageserver 1.63.0-1 1.63.0-2
vscode-html-languageserver 1.63.0-1 1.63.0-2
vscode-json-languageserver 1.63.0-1 1.63.0-2
waybar 0.9.8-3 0.9.9-1
wayvnc 0.4.0-2 0.4.1-1
wikicurses 1.4-5 1.4-6
wingpanel 3.0.1-4 3.0.2-4
wingpanel-indicator-datetime 2.3.1-1 2.4.0-1
wingpanel-indicator-notifications 6.0.2-1 6.0.4-1
x42-plugins 20211016-2 20220107-1
xandikos 0.2.7-1 0.2.8-1
xapp 2.2.4-3 2.2.8-1
xed 3.0.2-2 3.2.2-1
xplr 0.17.0-1 0.17.1-1
xreader 3.0.2-2 3.2.2-1
yaml-language-server 1.2.2-1 1.3.0-1
zsh-theme-powerlevel10k 1.14.6-1 1.15.0-1
coin-or-data-sample - 1.2.12-1
fcitx-qt6 - 1.2.7-2
fpc - 3.2.2-1
gdu - 5.12.1-1
glab - 1.22.0-1
gnome-appfolders-manager - 0.4.2-1
kitty-shell-integration - 0.24.1-1
lazarus - 2.2.0-1
lazarus-gtk2 - 2.2.0-1
lazarus-qt5 - 2.2.0-1
libliftoff - 0.1.0-2
ocrdesktop - 3.0-2
pastel - 0.8.1-2
pastel-docs - 0.8.1-2
python-aiohttp-openmetrics - 0.0.4-1
python-asttokens - 2.0.5-2
python-cmake-build-extension - 0.5.0-1
python-executing - 0.8.2-2
python-littleutils - 0.2.2-3
python-pure-eval - 0.2.1-2
python-rapidyaml - 0.3.0-2
python-stack-data - 0.1.4-1
rapidyaml - 0.3.0-2
sonic - 1.3.2-2
tuxcmd - 0.6.70-9
tuxcmd-modules - 0.6.70-6
wasm-pack - 0.10.2-2
wgcf - 2.2.11-1
yt-dlp - 2021.12.27-1
:: Different overlay package(s) in repository core aarch64
linux 5.15.13-1 5.16.1-1
linux-clockworkpi-a06 5.15.13-1 5.16.1-1
linux-clockworkpi-a06-headers 5.15.13-1 5.16.1-1
linux-headers 5.15.13-1 5.16.1-1
linux-pinephone 5.15.13-1 5.16.1-1
linux-pinephone-headers 5.15.13-1 5.16.1-1
linux-pinephonepro 5.16rc8-1 5.16.1-1
linux-pinephonepro-headers 5.16rc8-1 5.16.1-1
linux-quartz64 5.16.0-0.4 5.16.0-0.6
linux-quartz64-headers 5.16.0-0.4 5.16.0-0.6
linux-rpi4-mainline 5.15.13-1 5.16.0-1
linux-rpi4-mainline-headers 5.15.13-1 5.16.0-1
manjaro-system 20220112-3 20220115-1
pacman 6.0.1-6 6.0.1-7
pacman-debug 6.0.1-6 6.0.1-7
uboot-clockworkpi-a06 2021.10-1 2021.10-3
uboot-quartz64-bsp 2017.09-0.8 2017.09-0.9
uboot-vim1 2021.01-1 2021.07-1
linux-lts - 5.15.15-1
linux-lts-headers - 5.15.15-1
uboot-quartz64-a - 2022.01.rc4-1
:: Different sync package(s) in repository core aarch64
amd-ucode 20211027.1d00989-1 20211216.f682ecb-1
archlinux-keyring 20211028-1 20220114-1
bash 5.1.012-1 5.1.016-1
btrfs-progs 5.15.1-3 5.16-1
cryptsetup 2.4.2-3 2.4.3-1
ding-libs 0.6.1-3 0.6.1-4
efivar 37-4 38-1
glib2 2.70.2-1 2.70.2-2
glib2-docs 2.70.2-1 2.70.2-2
hwids 20210613-1 -
iana-etc 20211203-1 20220110-1
ifenslave 1.1.0-11 -
iproute2 5.15.0-2 5.16.0-1
lemon 3.37.1-1 3.37.2-1
linux-firmware 20211027.1d00989-1 20211216.f682ecb-1
logrotate 3.18.1-1 3.19.0-1
mdadm 4.1-2 4.2-1
pciutils 3.7.0-1 3.7.0-2
pth 2.0.7-7 -
sqlite 3.37.1-1 3.37.2-1
sqlite-analyzer 3.37.1-1 3.37.2-1
sqlite-doc 3.37.1-1 3.37.2-1
sqlite-tcl 3.37.1-1 3.37.2-1
systemd 250.1-1 250.2-2
systemd-libs 250.1-1 250.2-2
systemd-resolvconf 250.1-1 250.2-2
systemd-sysvcompat 250.1-1 250.2-2
usbutils 014-1 014-2
hwdata - 0.355-1
:: Different overlay package(s) in repository extra aarch64
manjaro-chrootbuild r234.g77c74b9-1 r236.g1e1d496-1
mesa-git22.0.0_devel.148446.795638767d1-122.0.0_devel.148890.b8d37eb1bb9-1
qt5-es2-base 5.15.2+kde+r275-1 5.15.2+kde+r289-1
qt5-es2-declarative 5.15.2+kde+r42-1 5.15.2+kde+r43-1
qt5-es2-wayland 5.15.2+kde+r38-1 5.15.2+kde+r41-1
qt5-es2-xcb-private-headers 5.15.2+kde+r275-1 5.15.2+kde+r289-1
:: Different sync package(s) in repository extra aarch64
amf-headers 1.4.21-2 1.4.23-1
archboot-arm 2022.01-11 2022.01-38
asio 1.18.2-1 1.20.0-1
attica 5.89.0-1 5.90.0-1
baloo 5.89.0-1 5.90.0-1
bind 9.16.23-3 9.16.24-1
bluez 5.62-1 5.63-1
bluez-cups 5.62-1 5.63-1
bluez-hid2hci 5.62-1 5.63-1
bluez-libs 5.62-1 5.63-1
bluez-plugins 5.62-1 5.63-1
bluez-qt 5.89.0-1 5.90.0-1
bluez-utils 5.62-1 5.63-1
breeze-icons 5.89.0-1 5.90.0-1
calligra 3.2.1-26 3.2.1-27
celt0.5.1 0.5.1.3-5 -
chromium 97.0.4692.71-1 97.0.4692.71-2
composer 2.2.3-1 2.2.4-1
double-conversion 3.1.7-1 3.2.0-1
ell 0.46-1 0.47-1
eog-plugins 3.26.7-3 3.26.8-1
extra-cmake-modules 5.89.0-1 5.90.0-1
ffnvcodec-headers 11.1.5.0-1 11.1.5.1-1
firefox 95.0.2-1 96.0.1-1
firefox-i18n-ach 95.0.2-1 96.0.1-1
firefox-i18n-af 95.0.2-1 96.0.1-1
firefox-i18n-an 95.0.2-1 96.0.1-1
firefox-i18n-ar 95.0.2-1 96.0.1-1
firefox-i18n-ast 95.0.2-1 96.0.1-1
firefox-i18n-az 95.0.2-1 96.0.1-1
firefox-i18n-be 95.0.2-1 96.0.1-1
firefox-i18n-bg 95.0.2-1 96.0.1-1
firefox-i18n-bn 95.0.2-1 96.0.1-1
firefox-i18n-br 95.0.2-1 96.0.1-1
firefox-i18n-bs 95.0.2-1 96.0.1-1
firefox-i18n-ca 95.0.2-1 96.0.1-1
firefox-i18n-ca-valencia 95.0.2-1 96.0.1-1
firefox-i18n-cak 95.0.2-1 96.0.1-1
firefox-i18n-cs 95.0.2-1 96.0.1-1
firefox-i18n-cy 95.0.2-1 96.0.1-1
firefox-i18n-da 95.0.2-1 96.0.1-1
firefox-i18n-de 95.0.2-1 96.0.1-1
firefox-i18n-dsb 95.0.2-1 96.0.1-1
firefox-i18n-el 95.0.2-1 96.0.1-1
firefox-i18n-en-ca 95.0.2-1 96.0.1-1
firefox-i18n-en-gb 95.0.2-1 96.0.1-1
firefox-i18n-en-us 95.0.2-1 96.0.1-1
firefox-i18n-eo 95.0.2-1 96.0.1-1
firefox-i18n-es-ar 95.0.2-1 96.0.1-1
firefox-i18n-es-cl 95.0.2-1 96.0.1-1
firefox-i18n-es-es 95.0.2-1 96.0.1-1
firefox-i18n-es-mx 95.0.2-1 96.0.1-1
firefox-i18n-et 95.0.2-1 96.0.1-1
firefox-i18n-eu 95.0.2-1 96.0.1-1
firefox-i18n-fa 95.0.2-1 96.0.1-1
firefox-i18n-ff 95.0.2-1 96.0.1-1
firefox-i18n-fi 95.0.2-1 96.0.1-1
firefox-i18n-fr 95.0.2-1 96.0.1-1
firefox-i18n-fy-nl 95.0.2-1 96.0.1-1
firefox-i18n-ga-ie 95.0.2-1 96.0.1-1
firefox-i18n-gd 95.0.2-1 96.0.1-1
firefox-i18n-gl 95.0.2-1 96.0.1-1
firefox-i18n-gn 95.0.2-1 96.0.1-1
firefox-i18n-gu-in 95.0.2-1 96.0.1-1
firefox-i18n-he 95.0.2-1 96.0.1-1
firefox-i18n-hi-in 95.0.2-1 96.0.1-1
firefox-i18n-hr 95.0.2-1 96.0.1-1
firefox-i18n-hsb 95.0.2-1 96.0.1-1
firefox-i18n-hu 95.0.2-1 96.0.1-1
firefox-i18n-hy-am 95.0.2-1 96.0.1-1
firefox-i18n-ia 95.0.2-1 96.0.1-1
firefox-i18n-id 95.0.2-1 96.0.1-1
firefox-i18n-is 95.0.2-1 96.0.1-1
firefox-i18n-it 95.0.2-1 96.0.1-1
firefox-i18n-ja 95.0.2-1 96.0.1-1
firefox-i18n-ka 95.0.2-1 96.0.1-1
firefox-i18n-kab 95.0.2-1 96.0.1-1
firefox-i18n-kk 95.0.2-1 96.0.1-1
firefox-i18n-km 95.0.2-1 96.0.1-1
firefox-i18n-kn 95.0.2-1 96.0.1-1
firefox-i18n-ko 95.0.2-1 96.0.1-1
firefox-i18n-lij 95.0.2-1 96.0.1-1
firefox-i18n-lt 95.0.2-1 96.0.1-1
firefox-i18n-lv 95.0.2-1 96.0.1-1
firefox-i18n-mk 95.0.2-1 96.0.1-1
firefox-i18n-mr 95.0.2-1 96.0.1-1
firefox-i18n-ms 95.0.2-1 96.0.1-1
firefox-i18n-my 95.0.2-1 96.0.1-1
firefox-i18n-nb-no 95.0.2-1 96.0.1-1
firefox-i18n-ne-np 95.0.2-1 96.0.1-1
firefox-i18n-nl 95.0.2-1 96.0.1-1
firefox-i18n-nn-no 95.0.2-1 96.0.1-1
firefox-i18n-oc 95.0.2-1 96.0.1-1
firefox-i18n-pa-in 95.0.2-1 96.0.1-1
firefox-i18n-pl 95.0.2-1 96.0.1-1
firefox-i18n-pt-br 95.0.2-1 96.0.1-1
firefox-i18n-pt-pt 95.0.2-1 96.0.1-1
firefox-i18n-rm 95.0.2-1 96.0.1-1
firefox-i18n-ro 95.0.2-1 96.0.1-1
firefox-i18n-ru 95.0.2-1 96.0.1-1
firefox-i18n-si 95.0.2-1 96.0.1-1
firefox-i18n-sk 95.0.2-1 96.0.1-1
firefox-i18n-sl 95.0.2-1 96.0.1-1
firefox-i18n-son 95.0.2-1 96.0.1-1
firefox-i18n-sq 95.0.2-1 96.0.1-1
firefox-i18n-sr 95.0.2-1 96.0.1-1
firefox-i18n-sv-se 95.0.2-1 96.0.1-1
firefox-i18n-ta 95.0.2-1 96.0.1-1
firefox-i18n-te 95.0.2-1 96.0.1-1
firefox-i18n-th 95.0.2-1 96.0.1-1
firefox-i18n-tl 95.0.2-1 96.0.1-1
firefox-i18n-tr 95.0.2-1 96.0.1-1
firefox-i18n-trs 95.0.2-1 96.0.1-1
firefox-i18n-uk 95.0.2-1 96.0.1-1
firefox-i18n-ur 95.0.2-1 96.0.1-1
firefox-i18n-uz 95.0.2-1 96.0.1-1
firefox-i18n-vi 95.0.2-1 96.0.1-1
firefox-i18n-xh 95.0.2-1 96.0.1-1
firefox-i18n-zh-cn 95.0.2-1 96.0.1-1
firefox-i18n-zh-tw 95.0.2-1 96.0.1-1
flatpak 1.12.2-1 1.12.3-1
flatpak-builder 1.2.0-1 1.2.1-1
fmt 8.0.1-2 8.1.1-1
frameworkintegration 5.89.0-1 5.90.0-2
gdm 41.0+r15+g23ebe617-1 41.3-1
gjs 2:1.70.0-2 2:1.70.0-3
glu 9.0.2-1 9.0.2-2
gnome-control-center 41.2-1 41.2-2
gnome-desktop 1:41.2-1 1:41.3-1
gnome-session 40.1.1-1 41.3-1
gnome-shell 1:41.2-2 1:41.3-1
gnuplot 5.4.2-1 5.4.3-1
gobject-introspection 1.70.0-4 1.70.0-5
gobject-introspection-runtime 1.70.0-4 1.70.0-5
gupnp 1:1.4.1-1 1:1.4.3-1
haveged 1.9.16-1 1.9.17-1
inkscape 1.1.1-5 1.1.1-7
jack2 1.9.19-2 1.9.20-1
jack2-dbus 1.9.19-2 1.9.20-1
js78 78.15.0-1 78.15.0-2
kactivities 5.89.0-1 5.90.0-1
kactivities-stats 5.89.0-1 5.90.0-1
kapidox 5.89.0-2 5.90.0-1
karchive 5.89.0-1 5.90.0-1
kauth 5.89.0-1 5.90.0-1
kbookmarks 5.89.0-1 5.90.0-1
kcalendarcore 5.89.0-1 5.90.0-1
kcmutils 5.89.0-1 5.90.0-1
kcodecs 5.89.0-1 5.90.0-1
kcompletion 5.89.0-1 5.90.0-1
kconfig 5.89.0-1 5.90.0-1
kconfigwidgets 5.89.0-1 5.90.0-1
kcontacts 1:5.89.0-1 1:5.90.0-1
kcoreaddons 5.89.0-1 5.90.0-1
kcrash 5.89.0-1 5.90.0-1
kdav 1:5.89.0-1 1:5.90.0-1
kdbusaddons 5.89.0-1 5.90.0-1
kdeclarative 5.89.0-1 5.90.0-1
kded 5.89.0-1 5.90.0-1
kdelibs4support 5.89.0-1 5.90.0-1
kdesignerplugin 5.89.0-1 5.90.0-1
kdesu 5.89.0-1 5.90.0-1
kdewebkit 5.89.0-1 5.90.0-1
kdnssd 5.89.0-1 5.90.0-1
kdoctools 5.89.0-1 5.90.0-1
kemoticons 5.89.0-1 5.90.0-1
kexec-tools 2.0.21-1 2.0.23-1
kfilemetadata 5.89.0-1 5.90.0-1
kglobalaccel 5.89.0-1 5.90.0-1
kguiaddons 5.89.0-1 5.90.0-1
kholidays 1:5.89.0-1 1:5.90.0-1
khtml 5.89.0-1 5.90.0-1
ki18n 5.89.0-1 5.90.0-1
kiconthemes 5.89.0-1 5.90.0-1
kidletime 5.89.0-1 5.90.0-1
kimageformats 5.89.0-1 5.90.0-1
kinit 5.89.0-1 5.90.0-1
kio 5.89.0-1 5.90.0-1
kirigami2 5.89.0-1 5.90.0-1
kitemmodels 5.89.0-1 5.90.0-1
kitemviews 5.89.0-1 5.90.0-1
kitinerary 21.12.1-1 21.12.1-2
kjobwidgets 5.89.0-1 5.90.0-1
kjs 5.89.0-1 5.90.0-1
kjsembed 5.89.0-1 5.90.0-1
kmediaplayer 5.89.0-1 5.90.0-1
knewstuff 5.89.0-1 5.90.0-1
knotifications 5.89.0-1 5.90.0-1
knotifyconfig 5.89.0-1 5.90.0-1
kpackage 5.89.0-1 5.90.0-1
kparts 5.89.0-1 5.90.0-1
kpeople 5.89.0-1 5.90.0-1
kplotting 5.89.0-1 5.90.0-1
kpty 5.89.0-1 5.90.0-1
kquickcharts 5.89.0-1 5.90.0-1
krfb 21.12.1-1 21.12.1-2
kross 5.89.0-1 5.90.0-1
krunner 5.89.0-1 5.90.0-1
kservice 5.89.0-1 5.90.0-1
ktexteditor 5.89.0-1 5.90.0-1
ktextwidgets 5.89.0-1 5.90.0-1
kunitconversion 5.89.0-1 5.90.0-1
kwallet 5.89.0-1 5.90.0-1
kwayland 5.89.0-1 5.90.0-1
kwidgetsaddons 5.89.0-1 5.90.0-1
kwindowsystem 5.89.0-1 5.90.0-1
kxmlgui 5.89.0-1 5.90.0-1
kxmlrpcclient 5.89.0-1 5.90.0-1
libetebase 0.5.1-1 0.5.1-2
libgdm 41.0+r15+g23ebe617-1 41.3-1
libgusb 0.3.8-1 0.3.10-1
libnautilus-extension 41.1-2 41.2-1
libreoffice-fresh 7.2.5-1 7.2.5-4
libreoffice-fresh-sdk 7.2.5-1 7.2.5-4
libreoffice-still 7.1.8-3 7.1.8-5
libreoffice-still-sdk 7.1.8-3 7.1.8-5
libsigsegv 2.13-1 2.14-1
libtorrent-rasterbar 1:1.2.15-1 1:2.0.5-1
libva-mesa-driver 21.3.3-2 21.3.4-1
libxcomp 3.5.99.22-1 3.5.99.26-1
mercurial 6.0-3 6.0.1-1
mesa 21.3.3-2 21.3.4-1
mesa-vdpau 21.3.3-2 21.3.4-1
meson 0.60.3-1 0.61.0-4
mkvtoolnix-cli 63.0.0-1 64.0.0-1
mkvtoolnix-gui 63.0.0-1 64.0.0-1
modemmanager-qt 5.89.0-1 5.90.0-1
mtools 1:4.0.36-1 1:4.0.37-1
mutter 41.2-2 41.3-1
nautilus 41.1-2 41.2-1
ndctl 72-1 72.1-1
networkmanager-qt 5.89.0-1 5.90.0-1
nx-headers 3.5.99.22-1 3.5.99.26-1
nx-x11 3.5.99.22-1 3.5.99.26-1
nxagent 3.5.99.22-1 3.5.99.26-1
nxproxy 3.5.99.22-1 3.5.99.26-1
opencl-clhpp 2.0.15-1 2.0.16-1
opencl-mesa 21.3.3-2 21.3.4-1
oxygen-icons 1:5.89.0-1 1:5.90.0-1
oxygen-icons-svg 1:5.89.0-1 1:5.90.0-1
perl-file-which 1.24-2 1.27-1
perl-template-toolkit 3.009-2 3.010-1
plasma-framework 5.89.0-1 5.90.0-1
plasma-wayland-protocols 1.5-1 1.6.0-1
poppler 21.11.0-1 22.01.0-1
poppler-glib 21.11.0-1 22.01.0-1
poppler-qt5 21.11.0-1 22.01.0-1
poppler-qt6 21.11.0-1 22.01.0-1
postfix 3.6.3-3 3.6.4-1
postfix-cdb 3.6.3-3 3.6.4-1
postfix-ldap 3.6.3-3 3.6.4-1
postfix-lmdb 3.6.3-3 3.6.4-1
postfix-mysql 3.6.3-3 3.6.4-1
postfix-pcre 3.6.3-3 3.6.4-1
postfix-pgsql 3.6.3-3 3.6.4-1
postfix-sqlite 3.6.3-3 3.6.4-1
prison 5.89.0-1 5.90.0-1
purpose 5.89.0-1 5.90.0-1
pyside2 5.15.2-5 5.15.2.1-1
python-setuptools 1:57.4.0-6 1:59.1.0-1
python-shiboken2 5.15.2-13 5.15.2.1-1
python-tomli-w 0.4.0-3 1.0.0-3
qqc2-desktop-style 5.89.0-1 5.90.0-1
qt5-base 5.15.2+kde+r276-1 5.15.2+kde+r291-1
qt5-declarative 5.15.2+kde+r42-1 5.15.2+kde+r43-1
qt5-svg 5.15.2+kde+r15-1 5.15.2+kde+r16-1
qt5-wayland 5.15.2+kde+r38-1 5.15.2+kde+r41-1
qt5-xcb-private-headers 5.15.2+kde+r276-1 5.15.2+kde+r291-1
qt6-base 6.2.2-4 6.2.2-5
ristretto 0.12.1-1 0.12.2-1
rpcsvc-proto 1.4.2-1 1.4.3-1
rtmpdump 1:2.4.r96.fa8646d-6 1:2.4.r99.f1b83c1-1
rust 1:1.57.0-1 1:1.58.0-1
rust-src 1:1.57.0-1 1:1.58.0-1
rygel 1:0.40.2-3 1:0.40.3-1
sdl2 2.0.18-3 2.0.20-1
sdl2_ttf 2.0.15-2 2.0.18-1
solid 5.89.0-1 5.90.0-1
sonnet 5.89.0-1 5.90.0-1
soundtouch 2.3.0-1 2.3.0-2
strace 5.15-1 5.16-1
syndication 5.89.0-1 5.90.0-1
syntax-highlighting 5.89.0-1 5.90.0-1
threadweaver 5.89.0-1 5.90.0-1
thunderbird 91.4.1-1 91.5.0-1
thunderbird-i18n-af 91.4.1-1 91.5.0-1
thunderbird-i18n-ar 91.4.1-1 91.5.0-1
thunderbird-i18n-ast 91.4.1-1 91.5.0-1
thunderbird-i18n-be 91.4.1-1 91.5.0-1
thunderbird-i18n-bg 91.4.1-1 91.5.0-1
thunderbird-i18n-br 91.4.1-1 91.5.0-1
thunderbird-i18n-ca 91.4.1-1 91.5.0-1
thunderbird-i18n-cak 91.4.1-1 91.5.0-1
thunderbird-i18n-cs 91.4.1-1 91.5.0-1
thunderbird-i18n-cy 91.4.1-1 91.5.0-1
thunderbird-i18n-da 91.4.1-1 91.5.0-1
thunderbird-i18n-de 91.4.1-1 91.5.0-1
thunderbird-i18n-dsb 91.4.1-1 91.5.0-1
thunderbird-i18n-el 91.4.1-1 91.5.0-1
thunderbird-i18n-en-gb 91.4.1-1 91.5.0-1
thunderbird-i18n-en-us 91.4.1-1 91.5.0-1
thunderbird-i18n-es-ar 91.4.1-1 91.5.0-1
thunderbird-i18n-es-es 91.4.1-1 91.5.0-1
thunderbird-i18n-et 91.4.1-1 91.5.0-1
thunderbird-i18n-eu 91.4.1-1 91.5.0-1
thunderbird-i18n-fi 91.4.1-1 91.5.0-1
thunderbird-i18n-fr 91.4.1-1 91.5.0-1
thunderbird-i18n-fy-nl 91.4.1-1 91.5.0-1
thunderbird-i18n-ga-ie 91.4.1-1 91.5.0-1
thunderbird-i18n-gd 91.4.1-1 91.5.0-1
thunderbird-i18n-gl 91.4.1-1 91.5.0-1
thunderbird-i18n-he 91.4.1-1 91.5.0-1
thunderbird-i18n-hr 91.4.1-1 91.5.0-1
thunderbird-i18n-hsb 91.4.1-1 91.5.0-1
thunderbird-i18n-hu 91.4.1-1 91.5.0-1
thunderbird-i18n-hy-am 91.4.1-1 91.5.0-1
thunderbird-i18n-id 91.4.1-1 91.5.0-1
thunderbird-i18n-is 91.4.1-1 91.5.0-1
thunderbird-i18n-it 91.4.1-1 91.5.0-1
thunderbird-i18n-ja 91.4.1-1 91.5.0-1
thunderbird-i18n-ka 91.4.1-1 91.5.0-1
thunderbird-i18n-kab 91.4.1-1 91.5.0-1
thunderbird-i18n-kk 91.4.1-1 91.5.0-1
thunderbird-i18n-ko 91.4.1-1 91.5.0-1
thunderbird-i18n-lt 91.4.1-1 91.5.0-1
thunderbird-i18n-ms 91.4.1-1 91.5.0-1
thunderbird-i18n-nb-no 91.4.1-1 91.5.0-1
thunderbird-i18n-nl 91.4.1-1 91.5.0-1
thunderbird-i18n-nn-no 91.4.1-1 91.5.0-1
thunderbird-i18n-pa-in 91.4.1-1 91.5.0-1
thunderbird-i18n-pl 91.4.1-1 91.5.0-1
thunderbird-i18n-pt-br 91.4.1-1 91.5.0-1
thunderbird-i18n-pt-pt 91.4.1-1 91.5.0-1
thunderbird-i18n-rm 91.4.1-1 91.5.0-1
thunderbird-i18n-ro 91.4.1-1 91.5.0-1
thunderbird-i18n-ru 91.4.1-1 91.5.0-1
thunderbird-i18n-sk 91.4.1-1 91.5.0-1
thunderbird-i18n-sl 91.4.1-1 91.5.0-1
thunderbird-i18n-sq 91.4.1-1 91.5.0-1
thunderbird-i18n-sr 91.4.1-1 91.5.0-1
thunderbird-i18n-sv-se 91.4.1-1 91.5.0-1
thunderbird-i18n-th 91.4.1-1 91.5.0-1
thunderbird-i18n-tr 91.4.1-1 91.5.0-1
thunderbird-i18n-uk 91.4.1-1 91.5.0-1
thunderbird-i18n-uz 91.4.1-1 91.5.0-1
thunderbird-i18n-vi 91.4.1-1 91.5.0-1
thunderbird-i18n-zh-cn 91.4.1-1 91.5.0-1
thunderbird-i18n-zh-tw 91.4.1-1 91.5.0-1
tomcat10 10.0.14-1 10.0.15-1
tomcat8 8.5.73-1 8.5.74-1
tomcat9 9.0.56-1 9.0.57-1
unison 2.51.4-1 2.51.5-1
vala 0.54.5-1 0.54.6-1
vulkan-broadcom 21.3.3-2 21.3.4-1
vulkan-headers 1:1.2.202-1 1:1.2.203-1
vulkan-mesa-layers 21.3.3-2 21.3.4-1
vulkan-panfrost 21.3.3-2 21.3.4-1
vulkan-radeon 21.3.3-2 21.3.4-1
vulkan-swrast 21.3.3-2 21.3.4-1
wireplumber 0.4.5-2 0.4.7-1
wireplumber-docs 0.4.5-2 0.4.7-1
archboot-linux-firmware - 20211216.f682ecb-1
jack-example-tools - 1-1
jack2-docs - 1.9.20-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.12.1.r12676.g6b10d8a19-121.12.1.r12679.g80cd33827-1
akonadi-calendar21.12.1.r2022.gc573dfd-121.12.1.r2024.g557c407-1
akonadi-calendar-tools21.12.1.r927.g15e10a0-121.12.1.r929.g0756f97-1
akonadi-contacts21.12.1.r3103.gb8f4f6c2-121.12.1.r3108.gc5ba92f1-1
akonadi-import-wizard21.12.1.r1782.g848d67f-121.12.1.r1784.gaf7db9a-1
akonadi-mime21.12.1.r1687.g9354615-121.12.1.r1690.g5c1c338-1
akonadi-notes21.12.1.r1051.g8cc62b9-121.12.1.r1053.geeda5b6-1
akonadi-search21.12.1.r1162.ga3198e5-121.12.1.r1170.gb7cd0b6-1
akonadiconsole21.12.1.r1562.gf4524a7-121.12.1.r1564.g0146b72-1
akregator21.12.1.r6286.g183e602d-121.12.1.r6293.ga6878055-1
alligator 21.12.r5.gff6c7ed-1 21.12.r6.g093872c-1
ark21.12.1.r4677.g3f1b6195-121.12.1.r4681.g475a9cc4-1
attica5.89.0.r851.g89562a3-15.90.0.r853.g9663430-1
audiocd-kio21.12.1.r1043.ge35dff3-121.12.1.r1045.g706bf38-1
audiotube 21.12.r1.g53f466c-1 21.12.r5.g2c0b13f-1
baloo5.89.0.r3025.g66270e43-15.90.0.r3026.g0af8400a-1
bluedevil1:5.23.5.r2349.g7feac6e5-11:5.23.5.r2356.g3e4c8e96-1
bluez-qt5.89.0.r698.g1c9d609-15.90.0.r699.gd76537c-1
breeze5.23.5.r2311.g769587bd-15.23.5.r2321.g95972782-1
breeze-gtk5.23.5.r437.g3ba7133-15.23.5.r441.g7e7caf2-1
breeze-icons5.89.0.r1874.g172d6c0f-15.90.0.r1876.g9b4abf62-1
buho 2.1.0.r2.ga34c52f-1 2.1.0.r4.gefd07ed-1
calendarsupport21.12.1.r649.gb4dd35e-121.12.1.r653.g57733af-1
discover5.23.5.r8473.g288ea57e-15.23.5.r8477.gcdb3e432-1
dolphin21.12.1.r6802.g3abc4cfcd-121.12.1.r6807.gc21a02bca-1
drkonqi5.23.5.r718.g71e26ab4-15.23.5.r720.gd252ea08-1
elisa21.12.1.r2830.g536fc3b4-121.12.1.r2846.gbda79fc5-1
eventviews21.12.1.r779.g5886b89-121.12.1.r782.gcdda877-1
extra-cmake-modules5.89.0.r3414.gca8f9bc-15.90.0.r3416.g2ce35e2-1
filelight21.12.1.r1011.gabced07-121.12.1.r1022.g6962769-1
frameworkintegration5.89.0.r614.gbe0f5dc-15.90.0.r616.g675802e-1
grantlee-editor21.12.1.r797.g1f35562-121.12.1.r801.g0b1df37-1
grantleetheme21.12.1.r371.g6523214-121.12.1.r373.g9286145-1
gwenview21.12.1.r6725.g8baa7f2d-121.12.1.r6742.g876ac001-1
incidenceeditor21.12.1.r826.gfbe0469-121.12.1.r830.g4fe2162-1
index-fm 2.1.0.r19.g9724172-1 2.1.0.r22.gc40859a-1
itinerary21.12.1.r1705.g2b35698-121.12.1.r1706.gb78710f-1
juk21.12.1.r3125.g6fcefadc-121.12.1.r3127.gcbfe6541-1
kaccounts-integration21.12.1.r1237.g89184d2-121.12.1.r1238.g660436a-1
kactivities5.89.0.r1378.g865024f-15.90.0.r1379.g6d1bce3-1
kactivities-stats5.89.0.r389.gb5aa386-15.90.0.r391.gf7df24a-1
kactivitymanagerd5.23.5.r1377.g24398d9-15.23.5.r1380.gd52963c-1
kaddressbook21.12.1.r6089.g991996ca-121.12.1.r6095.g12010ccd-1
kalarm21.12.1.r6564.gc7c8bc8d-121.12.1.r6573.g629228f8-1
kalarmcal21.12.1.r1175.g200af2a-121.12.1.r1178.gc4ba1ae-1
kalgebra21.12.1.r2048.g4ba153a-121.12.1.r2049.g0e09358-1
kalk 21.12.r14.ged5f7c7-1 21.12.r23.g7a78bec-1
kapidox5.89.0.r560.g49edb94-15.90.0.r561.g40732e6-1
karchive5.89.0.r526.gc362095-15.90.0.r527.g41aa616-1
kate21.12.1.r18543.gb30c80f90-121.12.1.r18564.g3ecf3844b-1
kauth5.89.0.r470.g36a1f0a-15.90.0.r472.g4df29a7-1
kbackup21.12.1.r415.gc4a1d4c-121.12.1.r417.gee0bd7e-1
kbookmarks5.89.0.r443.gda04cb6-15.90.0.r445.gbf39fcc-1
kcalendarcore5.89.0.r1284.gacfb3660a-15.90.0.r1287.g070bd9771-1
kcalutils21.12.1.r911.g6380edb72-121.12.1.r925.g7df05d9c8-1
kcmutils5.89.0.r590.g60ac2bf-15.90.0.r593.g397763b-1
kcodecs5.89.0.r406.g67a263a-15.90.0.r407.gb040304-1
kcolorchooser21.12.1.r244.g46a0ed4-121.12.1.r245.g5e611a0-1
kcompletion5.89.0.r478.g678f587-15.90.0.r480.ga8c209e-1
kconfig5.89.0.r914.gb0bf9e03-15.90.0.r916.ga05de4ec-1
kconfigwidgets5.89.0.r662.ge3e3b7b-15.90.0.r667.g71436a6-1
kcontacts1:5.89.0.r3299.ge1fcf377-11:5.90.0.r3301.g58dca1dc-1
kcoreaddons5.89.0.r1385.g52edc611-15.90.0.r1390.ged3a474e-1
kcrash5.89.0.r427.gb4f5130-15.90.0.r429.gb7a9cf0-1
kdav1:5.89.0.r1324.ge019bc0-11:5.90.0.r1325.g073931b-1
kdbusaddons5.89.0.r401.gb456e54-15.90.0.r403.gd4940d5-1
kde-cli-tools5.23.5.r1885.gab65915-15.23.5.r1889.g6833373-1
kde-gtk-config5.23.5.r919.g967d7aa-15.23.5.r921.g97e8672-1
kdeclarative5.89.0.r960.gfb39951-15.90.0.r965.gf0f1eaf-1
kdeconnect21.12.1.r3386.g21b2f53b-121.12.1.r3387.g9c303fee-1
kdecoration5.23.5.r281.g4091b18-15.23.5.r284.g34a954f-1
kded5.89.0.r440.g8c76fa4-15.90.0.r442.gdc35680-1
kdegraphics-thumbnailers21.12.1.r248.gfcf0bcf-121.12.1.r250.gc75d717-1
kdelibs4support5.89.0.r1063.g94cea8da-15.90.0.r1064.gde7fdf71-1
kdenlive21.12.1.r15479.ga1af4b70a-121.12.1.r15519.g3eee3d5c0-1
kdepim-addons21.12.1.r4476.gdd0d9d2b-121.12.1.r4497.g587ff95d-1
kdepim-runtime21.12.1.r15431.g8cf7b9c61-121.12.1.r15437.g94e4d7b4d-1
kdeplasma-addons5.23.5.r8628.g5abdd7e0c-15.23.5.r8635.ga215954f7-1
kdesignerplugin5.89.0.r345.ged58ad3-15.90.0.r346.g03b3d17-1
kdesu5.89.0.r489.g4b0b8e2-15.90.0.r490.g1ec9de1-1
kdewebkit5.89.0.r291.g56b36c5-15.90.0.r292.g5767074-1
kdf21.12.1.r823.g4ff0880-121.12.1.r824.g29b2d9b-1
kdnssd5.89.0.r338.g4760c6d-15.90.0.r339.gd31614d-1
kdoctools5.89.0.r643.g3933efb-15.90.0.r646.g3460088-1
kemoticons5.89.0.r400.g8b675ac-15.90.0.r401.g4efbd3c-1
kfilemetadata5.89.0.r832.gfc9a604-15.90.0.r840.g409f360-1
kfind21.12.1.r2662.g343b0968d-121.12.1.r2663.gdc4548b2c-1
kfloppy21.12.1.r779.g9d7f359-121.12.1.r782.g753e1c8-1
kgamma55.23.5.r468.ga7d3e96-15.23.5.r470.g0c79ad3-1
kglobalaccel5.89.0.r494.g370cecf-15.90.0.r496.gd5956ce-1
kgpg21.12.1.r3161.g772f464e-121.12.1.r3163.gc54a6e56-1
kguiaddons5.89.0.r419.g8fb5545-15.90.0.r421.ge5d124e-1
kholidays1:5.89.0.r985.g88a671d-11:5.90.0.r987.g3510edc-1
khotkeys5.23.5.r2109.g3c4fbfa-15.23.5.r2111.g52442ab-1
khtml5.89.0.r569.gc39ba3c-15.90.0.r571.g04aa173-1
ki18n5.89.0.r532.gfb77bec-15.90.0.r537.g0d6156d-1
kiconthemes5.89.0.r579.g133f6f2-15.90.0.r580.g06f0dfa-1
kidentitymanagement21.12.1.r3855.g482bf46e-121.12.1.r3857.g25116f29-1
kidletime5.89.0.r338.g0c820f4-15.90.0.r339.g6a491c6-1
kimageformats5.89.0.r373.g56376ff-15.90.0.r374.gf4edb72-1
kimap21.12.1.r1153.g8d29d79-121.12.1.r1156.gb858b2c-1
kinfocenter5.23.5.r2013.gf86062f-15.23.5.r2016.g8bd47ff-1
kinit5.89.0.r426.gb41502f-15.90.0.r427.g85cfd29-1
kio5.89.0.r5176.g442248369-15.90.0.r5196.ged2347f77-1
kio-extras21.12.1.r7187.g6c6eec30-121.12.1.r7188.gb8cdf940-1
kirigami-addons 1:0.2.r14.gafac294-1 1:0.2.r17.gb89134e-1
kirigami25.89.0.r3015.g54a028e5-15.90.0.r3029.g0f7f5751-1
kitemmodels5.89.0.r585.ge5e9acc-15.90.0.r587.g2da9716-1
kitemviews5.89.0.r356.ga507212-15.90.0.r357.gcbfcd01-1
kitinerary21.12.1.r2052.gc5e0d2c-121.12.1.r2061.g347b972-1
kjobwidgets5.89.0.r396.g06d6539-15.90.0.r398.g4f66474-1
kjs5.89.0.r350.g098f649-15.90.0.r351.gf82423c-1
kjsembed5.89.0.r315.g42c8713-15.90.0.r316.g8d9697d-1
kldap21.12.1.r919.g11f6055-121.12.1.r922.g9161898-1
kleopatra21.12.1.r6153.g0c8a90d4-121.12.1.r6161.g183c899a-1
klickety21.12.1.r656.ga6504b7-121.12.1.r657.g6c0227f-1
kmag21.12.1.r714.g8d32c4e-121.12.1.r715.g6cc4673-1
kmail21.12.1.r26203.g06848bf8d-121.12.1.r26209.g9e75a7608-1
kmail-account-wizard21.12.1.r858.gb3f8aa9-121.12.1.r859.g8a52ee6-1
kmailtransport21.12.1.r1696.g78e64e5-121.12.1.r1699.gc1f1dfa-1
kmbox21.12.1.r570.g6eab796-121.12.1.r573.g2344c31-1
kmediaplayer5.89.0.r307.gd333f1b-15.90.0.r308.gc05fce1-1
kmenuedit5.23.5.r982.g5ea90ec-15.23.5.r984.g9241428-1
kmime21.12.1.r1486.g0b7ba6a-121.12.1.r1490.g548ec26-1
knewstuff5.89.0.r1270.g093a7d82-15.90.0.r1273.gc6a95ea8-1
knights21.12.1.r1088.g2ae9261-121.12.1.r1089.ga4472f5-1
knotes21.12.1.r3576.g70e81d72-121.12.1.r3579.g457a236b-1
knotifications5.89.0.r710.g0172cc4-15.90.0.r711.gbbff176-1
knotifyconfig5.89.0.r370.g7f4a343-15.90.0.r371.g6be6b81-1
koko 21.12.r3.gc447d10-1 21.12.r5.ge0b1732-1
kompare21.12.1.r1118.g720270d-121.12.1.r1120.gb8572be-1
kongress 21.12.r1.g8cace2b-1 21.12.r2.ga7ed6c3-1
konqueror21.12.1.r15029.g5980c6b6c-121.12.1.r15031.g961e7e26e-1
konsole21.12.1.r8197.g7f2e1064-121.12.1.r8208.g465c89d5-1
kontact21.12.1.r5451.gf225d959-121.12.1.r5457.ga9249c79-1
kontactinterface21.12.1.r656.g6c6fa11-121.12.1.r659.g8095252-1
kopeninghours21.12.1.r311.g3aba292-121.12.1.r312.g231f08f-1
korganizer21.12.1.r11606.g45e0830dc-121.12.1.r11610.ge096a8530-1
kpackage5.89.0.r725.ge4f0bc1-15.90.0.r727.gb424124-1
kparts5.89.0.r563.gd13e377-15.90.0.r564.g7ce4f00-1
kpat21.12.1.r2589.g6da929e-121.12.1.r2591.gde4019a-1
kpeople5.89.0.r1361.g6a855bc-15.90.0.r1362.g1b00199-1
kpimtextedit21.12.1.r1496.gbb5cb44-121.12.1.r1500.g10fdef5-1
kpkpass21.12.1.r260.gdd94a5a-121.12.1.r264.g7c483f3-1
kplotting5.89.0.r309.g71dfe9a-15.90.0.r310.gb3b5c16-1
kpmcore21.12.1.r1223.g5ffc5c6-121.12.1.r1227.gd7912e2-1
kpty5.89.0.r357.g16e9534-15.90.0.r358.g47e5b45-1
kpublictransport21.12.1.r1972.g92473226-121.12.1.r1974.gc9a5ff3e-1
kquickcharts5.89.0.r492.g2935a5b-15.90.0.r493.gec6b51d-1
krdc21.12.1.r1555.ge25aac6-121.12.1.r1557.gf25efb3-1
krecorder 21.12.r29.ge291528-1 21.12.r30.g66ff680-1
krfb21.12.1.r1461.g96eb21d-121.12.1.r1462.g25f5492-1
kross5.89.0.r346.g7c0417e-15.90.0.r347.g8f93338-1
kruler21.12.1.r719.g3c1b71c-121.12.1.r721.gda1143b-1
krunner5.89.0.r719.g75fb5df-15.90.0.r723.gba60868-1
kscreen5.23.5.r1419.gb499dec-15.23.5.r1421.g96fd0ef-1
kscreenlocker5.23.5.r892.g9390ecc-15.23.5.r895.g0dc4c6f-1
kservice5.89.0.r981.gf0cf6eb-15.90.0.r985.g5c562de-1
kshisen21.12.1.r1219.g872a53d-121.12.1.r1220.g2237330-1
ksmtp21.12.1.r414.g5795128-121.12.1.r417.gf7cd01a-1
ksshaskpass5.23.5.r202.g6f98560-15.23.5.r204.g64cdcc2-1
ksudoku21.12.1.r1084.g8d480e1-121.12.1.r1086.g80cf900-1
ksystemlog21.12.1.r686.gb96f5d4-121.12.1.r687.g697521f-1
ksystemstats5.23.5.r213.g67f836e-15.23.5.r215.g906fe79-1
ktexteditor5.89.0.r3048.gb83f75b7-15.90.0.r3055.g3be086c2-1
ktextwidgets5.89.0.r431.geb06bed-15.90.0.r433.gce673c7-1
ktimer21.12.1.r491.gf2f0b21-121.12.1.r494.g5f13bb8-1
ktnef21.12.1.r693.ga46386c-121.12.1.r696.gf80e339-1
ktorrent21.12.1.r2815.ga2c42bda-121.12.1.r2816.g6e297f9e-1
ktouch21.12.1.r2160.gf445552-121.12.1.r2162.g519c577-1
kubrick21.12.1.r387.g04ade45-121.12.1.r388.g0c7c60a-1
kunitconversion5.89.0.r398.g338da46-15.90.0.r401.g2018d65-1
kwallet5.89.0.r1116.g82a24e0-15.90.0.r1119.g1dc5e3f-1
kwallet-pam5.23.5.r260.g32d6ead-15.23.5.r262.g4059813-1
kwayland5.89.0.r1133.g54b6fba-15.90.0.r1136.gb6e1ce8-1
kwayland-integration5.23.5.r196.g56771c0-15.23.5.r198.gc5804d4-1
kwayland-server5.23.5.r1438.g705e530-15.23.5.r1445.gbf4a7cb-1
kwidgetsaddons5.89.0.r904.g2eba9824-15.90.0.r906.g6a0cdc02-1
kwin5.23.5.r20584.gd13c39bec-15.23.5.r20621.gbd3dd7ce3-1
kwindowsystem5.89.0.r657.g6e3d645-15.90.0.r660.g483f3ef-1
kwrite21.12.1.r18543.gb30c80f90-121.12.1.r18564.g3ecf3844b-1
kwrited5.23.5.r494.g15b0d6a-15.23.5.r496.g532de01-1
kxmlgui5.89.0.r835.g70236757-15.90.0.r838.ga3113504-1
kxmlrpcclient5.89.0.r470.g2f40b68fb-15.90.0.r471.g270c75bb0-1
layer-shell-qt5.23.5.r51.g80f6a62-15.23.5.r53.g14982d6-1
libakonadi21.12.1.r12676.g6b10d8a19-121.12.1.r12679.g80cd33827-1
libgravatar21.12.1.r395.g8b46854-121.12.1.r397.ge974ccd-1
libkcddb21.12.1.r745.g9945594-121.12.1.r751.g58c0fe3-1
libkdegames21.12.1.r2206.g05f412d6-121.12.1.r2209.gb6aa9373-1
libkdepim21.12.1.r879.gb762a31-121.12.1.r882.g54ae219-1
libkgapi21.12.1.r1330.gaef55ab-121.12.1.r1333.g9f7c704-1
libkipi21.12.1.r1258.g86845ff-121.12.1.r1276.gf61a329-1
libkleo21.12.1.r1049.g7de57b5-121.12.1.r1052.gbf2fb68-1
libkmahjongg21.12.1.r466.gab6d7a6-121.12.1.r467.g15d7e55-1
libksane21.12.1.r585.ged7d424-121.12.1.r587.g1e8c721-1
libkscreen5.23.5.r1615.g3fae3ed-15.23.5.r1618.gb7c7987-1
libksieve21.12.1.r1639.gb68213a7-121.12.1.r1646.g9e0d6b54-1
libksysguard5.23.5.r2338.g4f2d889-15.23.5.r2340.gb430901-1
mailcommon21.12.1.r1182.g62cce34-121.12.1.r1186.ga2a3357-1
mailimporter21.12.1.r495.g7ff25d6-121.12.1.r497.g73ec791-1
maliit-framework 2.1.1.r7.g700565e2-12.1.1.r15.gbab3baf5-1
maliit-keyboard r2132.g08c6e629-1 2.1.0.r6.g08c6e629-1
maui-clip 2.1.0.r3.g71430ea-1 2.1.0.r4.ga0b1ecb-1
maui-nota 2.1.0.r6.g333089c-1 2.1.0.r7.g447b683-1
maui-pix 2.1.0.r7.g627abe6-1 2.1.0.r9.g850fbdd-1
maui-shell r92.e2ae2ae-1 r96.7843cc7-1
mauikit2.1.0.r51.g18903126-12.1.0.r64.gf237521d-1
mauikit-accounts 2.1.0.r4.gaec143f-1 2.1.0.r5.gd8608a5-1
mauikit-filebrowsing 2.1.0.r16.g95e8fb0-1 2.1.0.r17.g74b8627-1
mauikit-texteditor 2.1.0.r4.gd12b366-1 2.1.0.r5.g19545b1-1
mbox-importer21.12.1.r544.gd954913-121.12.1.r546.gb97de3e-1
messagelib21.12.1.r6335.g6b84627dc-121.12.1.r6342.gaaeeee753-1
milou5.23.5.r758.g4845fba-15.23.5.r760.gd785c79-1
modemmanager-qt5.89.0.r538.g35b5678-15.90.0.r539.gc0e5f75-1
mycroft-gui r715.cceee1c-2 r716.a3a4700-1
networkmanager-qt5.89.0.r1135.gd96b4e9-15.90.0.r1136.gcb133d6-1
oxygen5.23.5.r4443.gca7d43f1-15.23.5.r4445.g43686cf5-1
oxygen-icons1:5.89.0.r5.gbff159d-11:5.90.0.r5.gbff159d-1
oxygen-icons-svg1:5.89.0.r5.gbff159d-11:5.90.0.r5.gbff159d-1
palapeli21.12.1.r1256.g6eb281f-121.12.1.r1260.ga153f7c-1
partitionmanager21.12.1.r1557.gd24f5cd-121.12.1.r1567.gfb8249c-1
pico-wizard-bigscreen-scripts r158.fc8d499-2 r161.d390d01-1
pico-wizard-git r158.fc8d499-2 r161.d390d01-1
pico-wizard-plamo-scripts r158.fc8d499-2 r161.d390d01-1
pim-data-exporter21.12.1.r2550.g8b2bf2d0-121.12.1.r2553.g7ba163d1-1
pim-sieve-editor21.12.1.r1551.g62a0cf2-121.12.1.r1555.g0cdb664-1
pimcommon21.12.1.r1159.gd86ae09-121.12.1.r1167.g0bd13f5-1
plasma-bigscreen r431.g75ec9fc-1 r441.g1893006-1
plasma-browser-integration5.23.5.r1298.gf8fb2803-15.23.5.r1301.g8a856a0c-1
plasma-desktop5.23.5.r8971.g7557477d2-15.23.5.r9001.g8fb84c2fc-1
plasma-disks5.23.5.r246.g978c0a9-15.23.5.r248.gd6de6b0-1
plasma-firewall5.23.5.r562.g300d20f-15.23.5.r569.g7adfe62-1
plasma-framework5.89.0.r16142.g37e79c5ac-15.90.0.r16150.g402bea797-1
plasma-integration5.23.5.r544.gfd9a07e-15.23.5.r546.g99c7332-1
plasma-mobile-nm5.23.5.r3162.gb1f803fb-15.23.5.r3165.g5aebff4c-1
plasma-mobile-settings 20211203-2 -
plasma-nm5.23.5.r3162.gb1f803fb-15.23.5.r3165.g5aebff4c-1
plasma-pa5.23.5.r1017.g1accb11-15.23.5.r1024.gfd17988-1
plasma-phone-components5.23.5.r1592.gf9717311-15.23.5.r1598.gf4f743a8-1
plasma-sdk5.23.5.r2294.gcbc56e98-15.23.5.r2300.g1b801288-1
plasma-settings 21.12.r5.g7a8be38-1 21.12.r7.g911cea2-1
plasma-systemmonitor5.23.5.r536.g0780593-15.23.5.r538.ge633796-1
plasma-thunderbolt5.23.5.r170.g34c7d11-15.23.5.r172.gb16fbae-1
plasma-vault5.23.5.r362.ge1a1ae2-15.23.5.r365.g3378b46-1
plasma-wayland-protocols1.4.0.r1044.g13a9897-11.4.0.r1045.g64b9d6a-1
plasma-wayland-session5.23.5.r11231.gb51911895-15.23.5.r11267.ga1902c429-1
plasma-workspace5.23.5.r11231.gb51911895-15.23.5.r11267.ga1902c429-1
plasma-workspace-wallpapers5.23.5.r304.g1b21101-15.23.5.r314.gcbabd4d-1
polkit-kde-agent5.23.5.r512.g4965ecb-15.23.5.r516.g4294f03-1
powerdevil5.23.5.r2510.gc1f25601-15.23.5.r2512.gac52ad35-1
print-manager21.12.1.r1090.g62e754e-121.12.1.r1094.g56bda9c-1
prison5.89.0.r353.g5f1f8d5-15.90.0.r354.gcd0c81b-1
purpose5.89.0.r936.g6dd4fbd-15.90.0.r938.g05ec607-1
qqc2-desktop-style5.89.0.r556.ga673947-15.90.0.r557.g5d887aa-1
sddm-kcm5.23.5.r635.gad63db3-15.23.5.r639.g8c6b2c1-1
solid5.89.0.r738.g513079d-15.90.0.r740.ge3dc1a2-1
sonnet5.89.0.r665.g447726f-15.90.0.r667.g2113770-1
spectacle21.12.1.r1278.g6f4cba2-121.12.1.r1281.ge41d85d-1
svgpart21.12.1.r192.g4c0910a-121.12.1.r197.ge007dce-1
sweeper21.12.1.r549.g37f4bc7-121.12.1.r551.gffa030c-1
syndication5.89.0.r854.g42043f8-15.90.0.r855.g0161711-1
syntax-highlighting5.89.0.r1785.gc20e5157-15.90.0.r1791.gdf34089d-1
systemsettings5.23.5.r2593.gc3bee37d-15.23.5.r2597.ga08ce248-1
threadweaver5.89.0.r528.g1c641e6-15.90.0.r529.gacc4b95-1
umbrello21.12.1.r8312.g9b829af9f-121.12.1.r8327.g164e4ea28-1
vvave 2.1.0.r15.g9da7bea-1 2.1.0.r20.g7c8f958-1
xdg-desktop-portal-kde5.23.5.r415.g13cd59f-15.23.5.r418.g9934795-1
raspberrypi-bigscreen-resolution-fix - r2.ede1763-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
