[ARM Testing Update] 2021-12-27 - CoreApps 4.3, Kodi 19.3, Breath Theme and kernels
Hello ARM community.
Pretty small update this time, as we are still waiting on the Python 3.10 (and it’s rebuilds) from Arch Linux ARM.
Some highlights:
  • Most of our kernels got updated
  • CoreApps got updated to 4.3.0
  • We also updated the regular Kodi packages to 19.3 to be in line with the kodi-rpi ones
  • The Plasma theme Breath also got a big update to 21.2.0
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Mon Dec 27 13:04:06 CET 2021)
  • arm-testing community aarch64: ??? new and ??? removed package(s)
  • arm-testing core aarch64: ?? new and ?? removed package(s)
  • arm-testing extra aarch64: ??? new and ??? removed package(s)
  • arm-testing kde-unstable aarch64: ??? new and ??? removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2021-12-07         2021-12-27
                  alsa-ucm-pinephone              0.5.3-3              0.5.5-1
                        aura-browser        r35.f615dc7-2                    -
        bigscreen-image-settings-git       r01.8977fdbf-2                    -
            bigscreen-image-settings         r5.2c99c52-2                    -
                              chatty0.5.0beta3+1+g73caf3d-10.5.0beta4+5+g8ae677d-1
                                code             1.63.0-1             1.63.2-1
                          coreaction              4.2.0-2              4.3.0-1
                        corearchiver              4.2.0-2              4.3.0-1
                              corefm              4.2.0-2              4.3.0-1
                          coregarage              4.2.0-2              4.3.0-1
                            corehunt              4.2.0-2              4.3.0-1
                           coreimage              4.2.0-2              4.3.0-1
                            coreinfo              4.2.0-2              4.3.0-1
                        corekeyboard              4.2.0-2              4.3.0-1
                             corepad              4.2.0-2              4.3.0-1
                           corepaint              4.2.0-3              4.3.0-1
                             corepdf              4.2.0-2              4.3.0-1
                            corepins              4.2.0-2              4.3.0-1
                         corerenamer              4.2.0-2              4.3.0-1
                            coreshot              4.2.0-2              4.3.0-1
                           corestats              4.2.0-2              4.3.0-1
                           corestuff              4.2.0-2              4.3.0-1
                        coreterminal              4.2.0-2              4.3.0-1
                            coretime              4.2.0-2              4.3.0-1
                        coretoppings              4.2.0-3              4.3.0-1
                        coreuniverse              4.2.0-2              4.3.0-1
                        eg25-manager              0.4.2-1   0.4.2+4+gb9a5139-2
                            electron             16.0.3-1             16.0.5-1
                          electron14             14.2.2-1             14.2.3-1
                          electron15             15.3.3-1             15.3.4-1
                     element-desktop              1.9.6-1              1.9.8-1
                         element-web              1.9.6-1              1.9.8-1
                         gnome-calls               41.1-342alpha0+38+ge2acfd3-1
        gnome-settings-daemon-hybris             3.38.1-1               41.0-1
                              hwinfo              21.78-1              21.80-1
                                inxi           3.3.09.1-2           3.3.11.1-1
                                kodi               19.1-5               19.3-1
                            kodi-dev               19.1-5               19.3-1
                   kodi-eventclients               19.1-5               19.3-1
            kodi-tools-texturepacker               19.1-5               19.3-1
                           libcprime              4.2.2-2              4.3.0-1
                             libcsys              4.2.0-2              4.3.0-1
                  libpackagekit-glib              1.2.4-1              1.2.4-4
                    matcha-gtk-theme           20210924-1           20211225-1
                          megapixels              1.4.2-1              1.4.3-1
                            mmsd-tng    1.6+11+g87f4e2d-1    1.6+18+g6ee1bdc-1
               mobile-config-firefox              2.2.0-2              3.0.0-1
                     mycroft-gui-git       r679.2b1c36e-2                    -
                                 nvm             0.39.0-1             0.39.1-1
                          packagekit              1.2.4-1              1.2.4-4
                                phoc 0.9.0+162+gcf754b2-1  0.11.0+3+gb067994-1
                               phosh 0.14.1+19+g4559693-1 0.14.1+56+g1b7e49c-1
                        phosh-hybris0.14.1+19+g45596931-1 0.14.1+23+g8fc370d-1
   pico-wizard-bigscreen-configs-git         r2.1be7fb2-1                    -
       pico-wizard-bigscreen-scripts       r147.da08b61-4       r154.d5ffe9a-1
                     pico-wizard-git       r147.da08b61-4       r154.d5ffe9a-1
           pico-wizard-plamo-scripts       r147.da08b61-4       r154.d5ffe9a-1
                        plank-player        r19.3ba5ba8-2                    -
                    plasma-bigscreen      r418.gad2b98a-2                    -
            pulseaudio-modules-droid        604.9c6842e-1        619.c6da109-1
                          python-cec 0.2.7.r13.gf2d4bd3-2                    -
                       python-uinput 0.11.2.r0.gbefe94a-2                    -
                               qcoro              0.3.0-2                    -
                          rpi-eeprom           20211129-1           20211213-1
                               snapd             2.53.4-1             2.54.1-1
                            spacebar              21.12-2              21.12-3
                         squeekboard1.14.0+121+g2fea092-1 1.15.0+15+g5286ff5-1
                              yt-dlp         2021.12.01-2         2021.12.27-1
          breath-classic-icon-themes                    -             21.2.0-2
            breath-classic-wallpaper                    -             21.2.0-2
                   breath-wallpapers                    -             21.2.0-2
               hadess-sensorfw-proxy                    -         26.6291246-1
                     libcec-rpi-fkms                    -              6.0.2-3
               plasma5-themes-breath                    -             21.2.0-2
       plasma5-themes-breath-classic                    -             21.2.0-2
         plasma5-themes-breath-extra                    -             21.2.0-2
     plasma5-themes-breath-migration                    -             21.2.0-2
                   sddm-breath-theme                    -             21.2.0-2
                     sensorfw-hybris                    -0.11.8.5.r0.g8f5ba90-2
:: Different sync package(s) in repository community aarch64
                            openfire              4.6.4-1              4.6.5-1
                      python-pymupdf             1.19.2-1             1.19.3-1
                          rebuilderd             0.16.6-1             0.17.0-1
                    rebuilderd-tools             0.16.6-1             0.17.0-1
:: Different overlay package(s) in repository core aarch64
                               linux             5.15.7-1            5.15.11-1
                       linux-headers             5.15.7-1            5.15.11-1
                        linux-khadas             5.15.7-1            5.15.10-1
                linux-khadas-headers             5.15.7-1            5.15.10-1
                     linux-pinephone             5.15.7-3            5.15.11-1
             linux-pinephone-headers             5.15.7-3            5.15.11-1
                  linux-pinephonepro            5.16rc4-1            5.16rc7-1
          linux-pinephonepro-headers            5.16rc4-1            5.16rc7-1
                      linux-quartz64           5.16.0-0.2           5.16.0-0.3
              linux-quartz64-headers           5.16.0-0.2           5.16.0-0.3
                            linux-rc           5.16.rc4-5           5.16.rc7-1
                    linux-rc-headers           5.16.rc4-5           5.16.rc7-1
                          linux-rpi4            5.10.83-1            5.10.88-1
                  linux-rpi4-headers            5.10.83-1            5.10.88-1
                 linux-rpi4-mainline             5.15.6-1            5.15.11-1
         linux-rpi4-mainline-headers             5.15.6-1            5.15.11-1
                       linux-rpi4-rc           5.16.rc4-1           5.16.rc6-1
               linux-rpi4-rc-headers           5.16.rc4-1           5.16.rc6-1
                     manjaro-release              21.12-1              21.12-2
              raspberrypi-bootloader           20211207-1           20211222-1
            raspberrypi-bootloader-x           20211207-1           20211222-1
                  uboot-pinephonepro       1:2021.01rc3-5       1:2021.01rc3-6
:: Different overlay package(s) in repository extra aarch64
                            mesa-git22.0.0_devel.147684.6e7ffa760f3-122.0.0_devel.148309.222487fabee-1
:: Different sync package(s) in repository extra aarch64
              gnome-shell-extensions               41.0-1               41.1-1
                  gnome-themes-extra               3.28-2  3.28+r6+g45b1d457-1
                               samba             4.15.2-3             4.15.3-1
                           smbclient             4.15.2-3             4.15.3-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.12.0.r12666.g22f7a3c08-121.12.0.r12669.g798401bbe-1
                    akonadi-calendar21.12.0.r2017.g7632a98-121.12.0.r2020.gd20a612-1
              akonadi-calendar-tools21.12.0.r924.g23775b6-121.12.0.r926.g512ef86-1
                    akonadi-contacts21.12.0.r3098.g78005bf9-121.12.0.r3100.g0679b2c0-1
               akonadi-import-wizard21.12.0.r1776.ga09283d-121.12.0.r1779.g40c288b-1
                        akonadi-mime21.12.0.r1684.gce7b54f-121.12.0.r1685.g6f5fc3b-1
                       akonadi-notes21.12.0.r1048.gbc7c0d7-121.12.0.r1050.gee94a3e-1
                      akonadi-search21.12.0.r1158.gcb24c22-121.12.0.r1160.g170a6e4-1
                      akonadiconsole21.12.0.r1557.g4c5b207-121.12.0.r1561.gd393c73-1
                           akregator21.12.0.r6263.gc5a3aee1-121.12.0.r6279.g9cf77f85-1
                           alligator  21.12.r0.g8afa7e3-1  21.12.r2.g1679a66-1
                            amazfish  2.0.3.r3.g8b82bb1-1  2.0.3.r5.gdef0ed4-1
                           angelfish  21.12.r0.g6097af1-1  21.12.r5.g93340ad-1
                                 ark21.12.0.r4657.g98e5ae5a-121.12.0.r4663.gcff83eab-1
                          artikulate21.12.0.r1397.g2f813c9-121.12.0.r1399.gf9b048e-1
                              attica5.88.0.r847.g561512a-15.89.0.r848.gacf1737-1
                         audiocd-kio21.12.0.r1040.g3f2ff8d-121.12.0.r1042.ge25a720-1
                           audiotube  21.12.r0.g7629761-1  21.12.r1.g53f466c-1
                               baloo5.88.0.r3020.g0b902854-15.89.0.r3023.gfd041eaf-1
                       baloo-widgets21.12.0.r722.g5a511a3-121.12.0.r723.g708711b-1
            bigscreen-image-settings         r7.4f8e730-1         r9.1560432-1
                             blinken21.12.0.r648.gf6d9dcf-121.12.0.r649.gacff80f-1
                           bluedevil1:5.23.4.r2322.g2f149345-11:5.23.4.r2333.g32dff5c1-1
                            bluez-qt5.88.0.r692.g7f5710c-15.89.0.r695.gd6f534f-1
                              bomber21.12.0.r543.g2af3a52-121.12.0.r544.g8b3b1fa-1
                                bovo21.12.0.r752.g3d20cc5-121.12.0.r758.g648e605-1
                              breeze5.23.4.r2301.g4a2a9470-15.23.4.r2306.gee5cc384-1
                          breeze-gtk5.23.4.r432.g0cd6ad9-15.23.4.r436.g3785fae-1
                        breeze-icons5.88.0.r1864.g6c12f18f-15.89.0.r1870.g3b0942a5-1
                     calendarsupport21.08.1.r64.g4bf3786-121.08.1.r66.gf718ed8-1
                           calindori  21.12.r0.g10dd294-1  21.12.r1.g4c940cd-1
                            discover5.23.4.r8449.g96889fba-15.23.4.r8465.g5ad26c9c-1
                             dolphin21.12.0.r6767.g0d35d8963-121.12.0.r6789.gb38d7150d-1
                     dolphin-plugins21.12.0.r616.g8165f4c-121.12.0.r626.g13b59e5-1
                             drkonqi5.23.4.r709.g21505fa5-15.23.4.r718.g71e26ab4-1
                               elisa21.12.0.r2810.g3bdd406c-121.12.0.r2822.g77fcc444-1
                          eventviews21.11.90.r21.ga890598-121.11.90.r24.gae488aa-1
                 extra-cmake-modules5.88.0.r3403.gee7b870-15.89.0.r3406.gb66c9f3-1
                           filelight21.12.0.r1001.gdb697ca-121.12.0.r1006.ge72a35a-1
                frameworkintegration5.88.0.r607.g00e04dc-15.89.0.r611.g67d8390-1
                           granatier21.12.0.r949.ga070774-121.12.0.r950.g524a473-1
                     grantlee-editor21.12.0.r792.g86f5f7d-121.12.0.r796.g0a77867-1
                       grantleetheme21.12.0.r368.g592b434-121.12.0.r370.g209b928-1
                            gwenview21.12.0.r6705.g79c6bdcf-121.12.0.r6720.gc78a66ac-1
                     incidenceeditor21.12.0.r812.g86d9a83-121.12.0.r814.gc9cb4f0-1
                            index-fm 2.1.0.r13.g00cd246-2 2.1.0.r14.g32f9712-1
                           itinerary21.12.0.r1667.g6115397-121.12.0.r1689.gf72d460-1
                                 k3b1:21.12.0.r6691.gfd4a54153-11:21.12.0.r6705.gd437be436-1
               kaccounts-integration21.12.0.r1235.g01523e8-121.12.0.r1236.gf31fa24-1
                 kaccounts-providers21.12.0.r387.gd70238c-121.12.0.r388.g8a4db4b-1
                         kactivities5.88.0.r1373.g4733f47-15.89.0.r1377.g83deb15-1
                   kactivities-stats5.88.0.r384.gce9f6d2-15.89.0.r387.g1194b02-1
                   kactivitymanagerd5.23.4.r1375.gc66bf75-15.23.4.r1377.g24398d9-1
                        kaddressbook21.12.0.r6082.g4056ff0b-121.12.0.r6084.g0b741627-1
                             kajongg21.12.0.r4207.g4ec590dd-121.12.0.r4209.gb647417e-1
                              kalarm21.12.0.r6530.g63ee4ca6-121.12.0.r6556.g7aceaed3-1
                           kalarmcal21.12.0.r1171.g0ef4de1-121.12.0.r1173.gcb5e8e5-1
                                kalk  21.12.r1.g8c98f19-1  21.12.r2.gae3e849-1
                              kamera21.12.0.r680.gdd297cc-121.12.0.r688.g4667902-1
                              kamoso21.12.0.r1440.g5d9f42f-121.12.0.r1443.g0fe4bf4-1
                             kapidox5.88.0.r559.gcc9f645-15.89.0.r560.g49edb94-1
                              kapman21.12.0.r628.g2a1cebe-121.12.0.r630.g6ec03bf-1
                            karchive5.88.0.r521.g6bf564d-15.89.0.r524.g9826deb-1
                               kasts  21.12.r3.gb3dac26-1  21.12.r8.gbd46d33-1
                                kate21.12.0.r18485.g7af8ed574-121.12.0.r18504.g33a748a44-1
                             katomic21.12.0.r937.gc24a180-121.12.0.r938.g4f654f2-1
                               kauth5.88.0.r459.g0ccaa85-15.89.0.r462.gf3a71ab-1
                             kbackup21.12.0.r405.gfa783c6-121.12.0.r412.g520846c-1
                             kblocks21.12.0.r687.g48fa730-121.12.0.r688.gaa4549a-1
                          kbookmarks5.88.0.r437.gd88275d-15.89.0.r440.gf5b71d9-1
                             kbounce21.12.0.r824.gb4a2815-121.12.0.r826.ge3ee41b-1
                              kbruch21.12.0.r828.g4ef20cc-121.12.0.r832.g3b9a697-1
                               kcalc21.12.0.r1583.ga97d90b-121.12.0.r1586.g76b445d-1
                       kcalendarcore5.88.0.r1274.gc78a5be3e-15.89.0.r1280.g3f4e3085a-1
                           kcalutils21.12.0.r908.g4bbc9e5cd-121.12.0.r910.g5c7bae14a-1
                         kcharselect21.12.0.r489.ge87c76f-121.12.0.r495.ga05aec1-1
                              kclock 21.12.r11.g3a695c4-1 21.12.r45.g8dad90d-1
                            kcmutils5.88.0.r574.gd82e565-15.89.0.r581.g6dc8911-1
                             kcodecs5.88.0.r399.g120e31a-15.89.0.r400.gf28a11f-1
                       kcolorchooser21.12.0.r240.g100efc6-121.12.0.r243.g9e08450-1
                         kcompletion5.88.0.r471.g4015189-15.89.0.r477.gdee8727-1
                             kconfig5.88.0.r897.g574508b9-15.89.0.r903.geac8e43e-1
                      kconfigwidgets5.88.0.r650.g2dbecbb-15.89.0.r655.g58f5ba3-1
                           kcontacts1:5.88.0.r3293.gc0bd98e8-11:5.89.0.r3297.ge2f5ea26-1
                         kcoreaddons5.88.0.r1361.gf76888c7-15.89.0.r1367.g6bc5b25a-1
                              kcrash5.88.0.r422.g3fed76d-15.89.0.r424.g413f7ca-1
                               kcron21.12.0.r817.g7d33ce9-121.12.0.r819.gc49b1dc-1
                                kdav1:5.88.0.r1311.ga16c713-11:5.89.0.r1312.gfa45b9b-1
                         kdbusaddons5.88.0.r391.g49489c6-15.89.0.r393.gb072811-1
                       kde-cli-tools5.23.4.r1880.g992d52b-15.23.4.r1883.gfdbc0c0-1
                      kde-gtk-config5.23.4.r918.g2abea72-15.23.4.r919.g967d7aa-1
                      kdebugsettings21.12.0.r872.g048439b-121.12.0.r878.g678bdac-1
                        kdeclarative5.88.0.r949.gd97523f-15.89.0.r955.g4d6df0e-1
                          kdeconnect21.12.0.r3371.gf8c59e7f-121.12.0.r3381.gad7b5b42-1
                                kded5.88.0.r432.g794b9ed-15.89.0.r435.g74f7c14-1
              kdegraphics-mobipocket21.12.0.r262.g0881310-121.12.0.r265.g8e1b8b9-1
            kdegraphics-thumbnailers21.12.0.r238.g28aeb62-121.12.0.r246.g30c74ed-1
                     kdelibs4support5.88.0.r1056.gf6b3ef9d-15.89.0.r1059.ga4344821-1
              kdenetwork-filesharing21.12.0.r897.gd30447b-121.12.0.r898.gc681404-1
                            kdenlive21.12.0.r15362.g8b0a5ea55-121.12.0.r15407.g837a609a8-1
                       kdepim-addons21.12.0.r4434.g7cb38b88-121.12.0.r4471.gd6cb54ab-1
                      kdepim-runtime21.12.0.r15411.g1c7cb773b-121.12.0.r15419.g337347715-1
                    kdeplasma-addons5.23.4.r8612.ga6c4aa1ae-15.23.4.r8618.g48a2a2af4-1
                     kdesignerplugin5.88.0.r342.gc8d492b-15.89.0.r344.gb3898de-1
                               kdesu5.88.0.r484.gd2a88c2-15.89.0.r486.g81f0ae9-1
                           kdewebkit5.88.0.r289.g794c703-15.89.0.r290.g482c569-1
                                 kdf21.12.0.r815.g2bd4832-121.12.0.r819.g027bbd0-1
                             kdialog21.12.0.r1200.g52ebbedce-121.12.0.r1201.g9a0b7dc5b-1
                            kdiamond21.12.0.r688.gd782122-121.12.0.r689.g50cd38c-1
                              kdnssd5.88.0.r334.gd40f997-15.89.0.r336.g2e15dd4-1
                           kdoctools5.88.0.r638.g50d9d7e-15.89.0.r639.ga1bc92e-1
                      keditbookmarks21.12.0.r2753.g509efd64d-121.12.0.r2758.ga087de28b-1
                          kemoticons5.88.0.r398.g943af5f-15.89.0.r399.g8135d51-1
                            keysmith  21.12.r0.gf7bccdc-1  21.12.r3.ge8c2d5c-1
                       kfilemetadata5.88.0.r827.g75c565d-15.89.0.r830.gbd93146-1
                               kfind21.12.0.r2658.g372a4c400-121.12.0.r2661.g332a789e4-1
                             kfloppy21.12.0.r772.gd99e2b3-121.12.0.r775.g8f29131-1
                         kfourinline21.12.0.r999.g7c28d33-121.12.0.r1001.g38d1a2e-1
                             kgamma55.23.4.r465.g939a73a-15.23.4.r468.ga7d3e96-1
                                kget21.12.0.r3137.g1e6341ba-121.12.0.r3142.g172877bf-1
                        kglobalaccel5.88.0.r486.gb5299df-15.89.0.r489.gd7f922b-1
                                kgpg21.12.0.r3143.gd5c6d5a6-121.12.0.r3146.g71e54375-1
                          kguiaddons5.88.0.r407.g6f85228-15.89.0.r414.g9c8a589-1
                            khangman21.12.0.r1579.g3978275-121.12.0.r1581.g6d9a585-1
                         khelpcenter21.12.0.r2689.g53426c45-121.12.0.r2692.gec493baf-1
                           kholidays1:5.88.0.r980.gd83220b-11:5.89.0.r983.geadc878-1
                            khotkeys5.23.4.r2106.g02ae7ea-15.23.4.r2109.g3c4fbfa-1
                               khtml5.88.0.r566.g8854bd5-15.89.0.r567.g1d5fd34-1
                               ki18n5.88.0.r525.g9bd1f86-15.89.0.r529.g178b7db-1
                         kiconthemes5.88.0.r573.g4e48ca5-15.89.0.r575.gf5a65ba-1
                 kidentitymanagement21.12.0.r3851.gab3c3bcd-121.12.0.r3853.g82b35671-1
                           kidletime5.88.0.r332.g517352b-15.89.0.r336.g789622d-1
                            killbots21.12.0.r753.g66f76e8-121.12.0.r754.ga9d6555-1
                       kimageformats5.88.0.r369.g81603ed-15.89.0.r371.g3234772-1
                               kimap21.12.0.r1150.g2dd2ed5-121.12.0.r1152.gbff4db1-1
                         kinfocenter5.23.4.r2003.g464f754-15.23.4.r2010.g004fe9d-1
                               kinit5.88.0.r424.gb1a1da6-15.89.0.r425.gcdcc3b3-1
                                 kio5.88.0.r5128.g870bbd91-15.89.0.r5157.g15ef3f77f-1
                          kio-extras21.12.0.r7170.g380640a5-121.12.0.r7174.g0bb11925-1
                     kirigami-addons 1:0.2.r12.g17233e2-1 1:0.2.r13.g8c3c1c4-1
                           kirigami25.88.0.r2977.gbffc33bb-15.89.0.r2995.gc6e322a0-1
                         kitemmodels5.88.0.r571.g2c3108a-15.89.0.r584.gacf9032-1
                          kitemviews5.88.0.r352.g8b3909b-15.89.0.r354.g0749b38-1
                          kitinerary21.12.0.r2040.g675db3c-121.12.0.r2042.gfac0eb2-1
                         kjobwidgets5.88.0.r392.g89b8bea-15.89.0.r395.g9aab5a3-1
                                 kjs5.88.0.r348.g9fe09cd-15.89.0.r349.g1fa7e5a-1
                            kjsembed5.88.0.r313.gcc96775-15.89.0.r314.g71a3201-1
                        kjumpingcube21.12.0.r803.ge2794de-121.12.0.r806.g7bef7d9-1
                               kldap21.12.0.r916.g0d88fc6-121.12.0.r918.g68f100f-1
                           kleopatra21.12.0.r6124.gac014d57-121.12.0.r6143.gcea56e01-1
                            klickety21.12.0.r652.g5a785cd-121.12.0.r653.g5072858-1
                                kmag21.12.0.r704.g9cefc5b-121.12.0.r706.g91c80c3-1
                           kmahjongg21.12.0.r1495.ge8a691e-121.12.0.r1498.g8c1941f-1
                               kmail21.12.0.r26166.g3af8ebff3-121.12.0.r26186.g19a5a7773-1
                kmail-account-wizard21.12.0.r848.g0542177-121.12.0.r852.gdbd255e-1
                      kmailtransport21.12.0.r1693.g0f1b76d-121.12.0.r1695.g5d7ea6b-1
                               kmbox21.12.0.r566.g084131c-121.12.0.r568.gabfe498-1
                        kmediaplayer5.88.0.r304.g7c327a0-15.89.0.r305.gaf78aa1-1
                               kmime21.12.0.r1481.gcaa9862-121.12.0.r1483.g719eaf2-1
                              kmines21.12.0.r1739.g3ce1824-121.12.0.r1741.gb9603ee-1
                          kmousetool21.12.0.r406.g734af5b-121.12.0.r409.g924bddf-1
                            knetwalk21.12.0.r673.gbdf20be-121.12.0.r674.gd1cc69f-1
                           knewstuff5.88.0.r1246.g508b9f84-15.89.0.r1249.g9f5d2084-1
                             knights21.12.0.r1078.gdda8d69-121.12.0.r1080.g5ed4b12-1
                              knotes21.12.0.r3556.g48f4a076-121.12.0.r3570.gc86cf350-1
                      knotifications5.88.0.r697.gdf26abf-15.89.0.r706.gd3b9a8c-1
                       knotifyconfig5.88.0.r363.ga7f5609-15.89.0.r367.g58c4a55-1
                                koko  21.12.r0.g5f0531a-1  21.12.r3.gc447d10-1
                                kolf21.12.0.r1460.g186782c-121.12.0.r1462.g8dcc44b-1
                           kollision21.12.0.r508.g95a968e-121.12.0.r510.g940f51f-1
                         kolourpaint21.12.0.r2376.gb6d6d541-121.12.0.r2377.g36d8b5aa-1
                           konqueror21.12.0.r15010.g3e960d9ef-121.12.0.r15022.g06fdda7c4-1
                             konsole21.12.0.r8135.gbf34fcb1-121.12.0.r8152.g02e21a81-1
                             kontact21.12.0.r5441.gb24e7cdc-121.12.0.r5447.gf305fc91-1
                    kontactinterface21.12.0.r654.gcfbd821-121.12.0.r655.g4d37f7b-1
                        konversation21.12.0.r9016.g50661e8c-121.12.0.r9039.gd3f02251-1
                       kopeninghours21.12.0.r292.ga094ba3-121.12.0.r309.gbeeb1f7-1
                              kopete21.12.0.r16404.g0a9b454ea-121.12.0.r16405.g69f6c3115-1
                          korganizer21.12.0.r11566.ge56c71fbe-121.12.0.r11583.g59e8d8757-1
                       kosmindoormap21.12.0.r681.gc1179ec-121.12.0.r684.g294be65-1
                            kpackage5.88.0.r713.gbdd5ea0-15.89.0.r720.gb59d2a4-1
                              kparts5.88.0.r548.gc0b3950-15.89.0.r561.g36ac74f-1
                             kpeople5.88.0.r1356.g1a1a1eb-15.89.0.r1360.gf433de3-1
                        kpeoplevcard   0.1.r16.ge0e3028-1   0.1.r17.gebf9df1-1
                        kpimtextedit21.12.0.r1486.geda7f8a-121.12.0.r1489.g598242f-1
                             kpkpass21.12.0.r255.gbd86911-121.12.0.r259.g7842876-1
                           kplotting5.88.0.r305.g9229510-15.89.0.r307.g680e6bd-1
                             kpmcore21.12.0.r1213.g31921c5-121.12.0.r1215.g68c8fec-1
                                kpty5.88.0.r352.g6624ef0-15.89.0.r356.ge621b54-1
                    kpublictransport21.12.0.r1948.ge0cd6df3-121.12.0.r1965.ga0d9cdd9-1
                        kquickcharts5.88.0.r489.ge04c5ab-15.89.0.r490.g0f460cd-1
                   kquickimageeditor       r64.g335a8b8-1       r65.g60ffd96-1
                                krdc21.12.0.r1551.g2fcc61d-121.12.0.r1552.g5a61504-1
                           krecorder  21.12.r4.g98c1d88-1 21.12.r18.g9d2f74a-1
                            kreversi21.12.0.r1244.g7ecf18f-121.12.0.r1245.gb997ddd-1
                                krfb21.12.0.r1455.g8a12611-121.12.0.r1456.gb13a8e9-1
                               kross5.88.0.r344.g24008ce-15.89.0.r345.gb9c16b5-1
                              kruler21.12.0.r715.ga94386c-121.12.0.r717.gd81b7fb-1
                             krunner5.88.0.r699.gdb49ba9-15.89.0.r706.g955bb1d-1
                             kscreen5.23.4.r1404.gbbc2d2a-15.23.4.r1415.g9aebf99-1
                       kscreenlocker5.23.4.r889.g1f092a8-15.23.4.r891.g084e6ab-1
                            kservice5.88.0.r968.gd667e5b-15.89.0.r976.gbc52d3d-1
                             kshisen21.12.0.r1215.ga8c407e-121.12.0.r1217.g38f9e1f-1
                               ksmtp21.12.0.r410.g9691e4a-121.12.0.r412.gb145213-1
                          ksnakeduel21.12.0.r824.gb4e5dbb-121.12.0.r825.g6811d23-1
                          kspaceduel21.12.0.r651.gced4dae-121.12.0.r654.g0630633-1
                            ksquares21.12.0.r535.gdd92485-121.12.0.r537.g91adb89-1
                             ksudoku21.12.0.r1077.g8787e2f-121.12.0.r1079.gc399b0a-1
                           ksysguard5.23.4.r3519.g6a3c7e8a-15.23.4.r3522.g267933a4-1
                          ksystemlog21.12.0.r680.ge50f627-121.12.0.r683.gb7a1734-1
                        ksystemstats5.23.4.r210.g03fa8a7-15.23.4.r212.g399afab-1
                            kteatime21.12.0.r732.g4e97433-121.12.0.r735.g7c7f252-1
                         ktexteditor5.88.0.r3009.g85faeac6-15.89.0.r3014.g1b9bbc51-1
                        ktextwidgets5.88.0.r427.gb4aa1e2-15.89.0.r429.gb09962f-1
                              ktimer21.12.0.r483.g6bbc628-121.12.0.r489.g0041e27-1
                               ktnef21.12.0.r690.g832e475-121.12.0.r692.geada534-1
                            ktorrent21.12.0.r2794.g85f73ce6-121.12.0.r2797.g97398417-1
                               ktrip  21.12.r0.g1000251-1  21.12.r3.gdd83cfe-1
                          ktuberling21.12.0.r1027.gc34f5e7-121.12.0.r1028.g909494e-1
                             kturtle21.12.0.r1136.g2904f2a-121.12.0.r1141.g8d051eb-1
                             kubrick21.12.0.r383.gcc18542-121.12.0.r385.g9938bec-1
                     kunitconversion5.88.0.r392.ged7c211-15.89.0.r395.g61487e6-1
                             kwallet5.88.0.r1103.g724a590-15.89.0.r1107.g2da9b6b-1
                         kwallet-pam5.23.4.r259.g1d65ed8-15.23.4.r260.g32d6ead-1
                      kwalletmanager21.12.0.r1221.g12290f1-121.12.0.r1223.g5b40fe6-1
                            kwayland5.88.0.r1125.gbc0d375-15.89.0.r1127.gaeefdb6-1
                kwayland-integration5.23.4.r194.g8cd4f71-15.23.4.r196.g56771c0-1
                     kwayland-server5.23.4.r1429.gfab63da-15.23.4.r1434.g3c6264d-1
                            kweather  21.12.r5.gc0e639d-1  21.12.r7.gc69b931-1
                        kweathercore    0.5.r3.g21d7195-1    0.5.r4.gc983d1f-1
                      kwidgetsaddons5.88.0.r896.g0bf15291-15.89.0.r899.gdd13b793-1
                                kwin5.23.4.r20475.g92d334531-15.23.4.r20532.g4f2c3a00c-1
                       kwindowsystem5.88.0.r642.ge895381-15.89.0.r648.g9d5cf1a-1
                              kwinft5.23.3.r19902.g2a4211c3b-15.23.3.r19942.g83004fd51-1
                           kwordquiz21.12.0.r1160.g294106f-121.12.0.r1162.gf222613-1
                              kwrite21.12.0.r18485.g7af8ed574-121.12.0.r18504.g33a748a44-1
                             kwrited5.23.4.r491.ga74515e-15.23.4.r493.gf80898d-1
                             kxmlgui5.88.0.r827.g11c9cc80-15.89.0.r832.g207e15c5-1
                       kxmlrpcclient5.88.0.r467.g7da4928e7-15.89.0.r469.g16510e720-1
                          libakonadi21.12.0.r12666.g22f7a3c08-121.12.0.r12669.g798401bbe-1
                         libgravatar21.12.0.r392.g4e7e0df-121.12.0.r394.gb7c6625-1
                     libkcompactdisc21.12.0.r389.g4f2835f-121.12.0.r391.ge62b8ec-1
                         libkdegames21.12.0.r2200.g547e5ce3-121.12.0.r2201.g186856e6-1
                           libkdepim21.12.0.r876.g95970c5-121.12.0.r878.g49da121-1
                  libkeduvocdocument21.12.0.r1798.ge8b0d15-121.12.0.r1800.g84cf675-1
                            libkgapi21.12.0.r1325.g36eaa86-121.12.0.r1328.g110c199-1
                             libkipi21.12.0.r1257.gcf973e4-121.12.0.r1258.g86845ff-1
                             libkleo21.12.0.r1038.g11cb536-121.12.0.r1046.geefdd28-1
                            libksane21.12.0.r577.g1560d47-121.12.0.r585.ged7d424-1
                          libkscreen5.23.4.r1609.gcf0921f-15.23.4.r1614.g45c724c-1
                           libksieve21.12.0.r1635.g1ec2a153-121.12.0.r1637.gf63a2eeb-1
                        libksysguard5.23.4.r2331.ga0d7092-15.23.4.r2335.g973aa3e-1
                               lskat21.12.0.r829.gc7639a1-121.12.0.r830.gef9ccaf-1
                          mailcommon21.12.0.r1165.g3bda971-121.12.0.r1177.g0b5c49e-1
                        mailimporter21.12.0.r492.g5662d97-121.12.0.r494.g6b6fea1-1
                     maliit-keyboard    r2128.gd842b36a-1    r2132.g08c6e629-1
                              marble21.12.0.r13375.gdb5957820-121.12.0.r13379.g6f7a6a324-1
                       marble-common21.12.0.r13375.gdb5957820-121.12.0.r13379.g6f7a6a324-1
                           marble-qt21.12.0.r13375.gdb5957820-121.12.0.r13379.g6f7a6a324-1
                            maui-pix  2.1.0.r3.g4c77aba-2  2.1.0.r4.gfaf7c6c-1
                             mauikit2.1.0.r17.ge932ac27-22.1.0.r21.g01b824cf-1
                    mauikit-accounts  2.1.0.r1.g709da19-2  2.1.0.r2.g2bab928-1
                mauikit-filebrowsing  2.1.0.r9.g7c06d8a-1 2.1.0.r13.gddab09e-1
                  mauikit-imagetools  2.1.0.r7.geb592bd-2  2.1.0.r8.gcc1235c-1
                  mauikit-texteditor  2.1.0.r1.ge150080-2  2.1.0.r2.g265aa2a-1
                       mbox-importer21.12.0.r538.g3b830ba-121.12.0.r542.gbd11994-1
                          messagelib21.12.0.r6311.ga8e46dc5-121.12.0.r6317.g7a0799f6-1
                               milou5.23.4.r756.gb458f34-15.23.4.r757.gc120a0b-1
                     modemmanager-qt5.88.0.r533.g80ddbd1-15.89.0.r536.gfeaa1ad-1
             mycroft-skill-installer        r86.a59a02e-1        r86.a59a02e-2
                             neochat 21.12.r2.gd0e04e0c-121.12.r28.g67bc66ee-1
                   networkmanager-qt5.88.0.r1129.gbc00557-15.89.0.r1132.gfe57e1a-1
                              okular21.12.0.r9550.g09a2b506e-121.12.0.r9554.g3792d8d56-1
                              oxygen5.23.4.r4441.g1ae0dd85-15.23.4.r4443.gca7d43f1-1
                        oxygen-icons1:5.88.0.r5.gbff159d-11:5.89.0.r5.gbff159d-1
                    oxygen-icons-svg1:5.88.0.r5.gbff159d-11:5.89.0.r5.gbff159d-1
                    partitionmanager21.12.0.r1545.gdffa270-121.12.0.r1546.g4f17fc5-1
                               picmi21.12.0.r542.ge72c031-121.12.0.r543.g6299ea6-1
   pico-wizard-bigscreen-configs-git         r2.1be7fb2-1         r3.c10252e-1
                   pim-data-exporter21.12.0.r2531.g2e40c66c-121.12.0.r2537.gfc6dca52-1
                    pim-sieve-editor21.12.0.r1543.ge9820f1-121.12.0.r1547.g89d1ef1-1
                           pimcommon21.07.80.r1155.g3a041b1-121.07.80.r1157.g3aa13d7-1
                    plasma-bigscreen      r421.g2ca0e4f-1      r427.g362d2c0-1
          plasma-browser-integration5.23.4.r1295.g51649511-15.23.4.r1297.g30590ecb-1
                       plasma-camera  1.0.r108.g54c9966-1  1.0.r109.gf202cf0-1
                      plasma-desktop5.23.4.r8865.gd8fe26740-15.23.4.r8923.g2cef3c07b-1
                       plasma-dialer  21.12.r4.g7f08493-1  21.12.r7.gd097b9b-1
                        plasma-disks5.23.4.r243.g840dc45-15.23.4.r245.g6bc2dfb-1
                     plasma-firewall5.23.4.r553.ge3c549a-15.23.4.r558.g3401766-1
                    plasma-framework5.88.0.r16126.g7feec7ce6-15.89.0.r16134.g83b82a4a7-1
                  plasma-integration5.23.4.r541.g64eabb7-15.23.4.r544.gfd9a07e-1
                    plasma-mobile-nm5.23.4.r3151.g8e782601-15.23.4.r3155.g086fab2d-1
                         plasma-nano5.23.4.r170.g4ea8ecc-15.23.4.r172.g3fb52ce-1
                           plasma-nm5.23.4.r3151.g8e782601-15.23.4.r3155.g086fab2d-1
                           plasma-pa5.23.4.r1008.g1af7aad-15.23.4.r1013.g275fdcd-1
             plasma-phone-components5.23.4.r1534.g2b1e6f12-15.23.4.r1556.g54f10f9f-1
                    plasma-phonebook  21.12.r0.gc57726b-1  21.12.r1.g287a539-1
                          plasma-sdk5.23.4.r2292.gb13a413a-15.23.4.r2293.gdbc2222c-1
                     plasma-settings  21.12.r0.gad3d85a-1  21.12.r5.g7a8be38-1
                plasma-systemmonitor5.23.4.r526.gca879c1-15.23.4.r533.g85db72e-1
                  plasma-thunderbolt5.23.4.r159.g2d98206-15.23.4.r161.gd4afb3d-1
                        plasma-vault5.23.4.r357.g730fde2-15.23.4.r361.g64d604d-1
              plasma-wayland-session5.23.4.r11042.g25d581060-15.23.4.r11154.ga1fdb95d8-1
                    plasma-workspace5.23.4.r11042.g25d581060-15.23.4.r11154.ga1fdb95d8-1
         plasma-workspace-wallpapers5.23.4.r301.g6419f26-15.23.4.r303.gcb62f13-1
                          powerdevil5.23.4.r2501.g0569b6a2-15.23.4.r2509.g9b8a9dfd-1
                               poxml21.12.0.r279.g7b9c282-121.12.0.r281.g183b2c7-1
                       print-manager21.12.0.r1080.g2b27d68-121.12.0.r1086.gb8e53b2-1
                              prison5.88.0.r346.g8c0686f-15.89.0.r350.ge7c2eab-1
                       pulseaudio-qt 1.3.0.r15.g73ca791-1 1.3.0.r16.g162fb4e-1
                             purpose5.88.0.r921.g9ff6577-15.89.0.r932.g2c1b6c8-1
                               qcoro0.3.0.r174.g817dad2-1                    -
                          qmlkonsole  21.12.r0.gaebc895-1  21.12.r9.g06ba226-1
                   qqc2-breeze-style5.23.4.r233.g94298f3-15.23.4.r235.g05a8d95-1
                  qqc2-desktop-style5.88.0.r550.g7c97810-15.89.0.r552.g8d0e1b6-1
                                rocs21.12.0.r3052.g5a4aaed3-121.12.0.r3053.g97a1f41c-1
                            sddm-kcm5.23.4.r628.gfd8b2e9-15.23.4.r630.g129e84a-1
                               solid5.88.0.r729.gc44f590-15.89.0.r735.gb5a7e81-1
                              sonnet5.88.0.r660.gc662d58-15.89.0.r663.gb7d61e2-1
                            spacebar  21.12.r2.g4567548-1  21.12.r4.ge7c577f-1
                           spectacle21.12.0.r1247.g67ea15c-121.12.0.r1263.g3d4bbe9-1
                             svgpart21.12.0.r189.g4d20cfd-121.12.0.r191.gec70167-1
                             sweeper21.12.0.r545.ged4e95e-121.12.0.r547.g1c1dcfb-1
                         syndication5.88.0.r850.gccb1905-15.89.0.r853.ge72415c-1
                 syntax-highlighting5.88.0.r1761.g720099c7-15.89.0.r1777.gaef89153-1
                      systemsettings5.23.4.r2575.g2a64b6d8-15.23.4.r2588.ge9ea12f2-1
          telepathy-kde-accounts-kcm21.12.0.r1201.g092e874-121.12.0.r1206.g3ce3bd2-1
                        threadweaver5.88.0.r522.g6a723eb-15.89.0.r524.g392e211-1
                             tokodon  21.12.r0.g821832d-1 21.12.r15.g751c2da-1
                            umbrello21.12.0.r8280.gaa7932073-121.12.0.r8281.g5b860d44d-1
                         vakzination  21.12.r0.g8484ef7-1  21.12.r1.g6a66058-1
                               vvave  2.1.0.r7.g4f75712-1  2.1.0.r8.ga09a705-1
              xdg-desktop-portal-kde5.23.4.r410.g5c7d8ff-15.23.4.r415.g13cd59f-1
                             yakuake21.12.0.r744.ga9abf3d-121.12.0.r759.g6bbf2e4-1
                         kwin-hybris                    -5.23.4.r20505.gda8925d7e-1
                          lottie-qml                    -        r24.0db824c-1
                   mycroft-bigscreen                    -21.2.2.r4874.g3d963cee40-1
                         mycroft-gui                    -       r715.cceee1c-2
       pico-wizard-bigscreen-configs                    -         r3.c10252e-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
New Breath theme not applying correctly
With the update to the new Breath theme, a migration package tries to apply the new theme correctly.
However this is not getting done for Plasma’s Lockscreen, Splashscreen and the SDDM theme.
So please go through your settings after updating to make sure the themes are correctly applied.
Plasma Mobile switch to ModemManager
With the PlaMo Gear 21.12 release, Plasma Mobile is now using ModemManager as the telephony stack. So in order to use SIM capabilities, you need to switch from using oFono to ModemManager.
Fix: Run sudo systemctl disable --now ofono ofonoctl && sudo systemctl enable --now ModemManager. You might have to reboot your phone for Plasma Mobile to pick up this change.
Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Old Issues
Plasma Mobile has does not launch after update
This was caused by an error in kwin 5.23.2 which only affects installs based on openGLES (qt5-es2).
Fix: Update to kwin 5.23.2-1.2 or above.
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
alarm repos back to business.
