Hello ARM community.
Point releases it is!
Pinephone Pro development is going great
Some highlights:
- Most of our kernels got updated
- KDE Frameworks is now at 5.88
- Introducing Shiny Mirrors and Pibootctl
- Firefox got a point release update to 94.0.2
- Likewise did Thunderbird to 93.3.2
- PHP also got a point release with 8.0.13
- And Kalendar quickly got updated to 2.1.0
- Lots of Mobile specific packages got updated
- Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Sun Nov 21 19:53:53 CET 2021)
- arm-testing community aarch64: 331 new and 320 removed package(s)
- arm-testing core aarch64: 29 new and 26 removed package(s)
- arm-testing extra aarch64: 421 new and 422 removed package(s)
- arm-testing kde-unstable aarch64: 265 new and 266 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-11-13 2021-11-21
amazfish 2.0.2-1 2.0.3-1
chatty 0.4.0+344+g9b4ea67-10.5.0beta+24+g4da8b0b-1
code 1.62.2-1 1.62.3-1
electron 15.3.1-1 15.3.2-1
electron13 13.6.1-1 13.6.2-1
glibc-locales 2.32-2 2.33-1
kalendar 0.1.0-1 0.2.1-1
libglibutil 1.0.57-1 1.0.58-1
libmm-pp-glib 1.18.0-2 1.18.2-1
libx86emu 3.3-1 3.5-1
megapixels 1.3.0-2 1.4.2-1
modemmanager-pp 1.18.0-2 1.18.2-1
phoc 0.9.0+75+gb579b2a-1 0.9.0+156+g026ae2c-1
phosh 0.14.0+27+gf768849-1 0.14.0+31+g46b4f0f-1
pinephone-post-install 20211025-1 20211118-2
snapd 2.53.1-1 2.53.2-2
wake-mobile 1.7-1 1.8-1
xf86-video-fbturbo-git 199.f9a6ed7-4.1 -
gufw - 21.04.0-1.1
pibootctl - 0.6-1
shiny-mirrors - r149.aeaecb3-1
stationm2-post-install - 20211118-1
:: Different sync package(s) in repository community aarch64
afl 2.57b-7 2.57b-8
arch-wiki-docs 20210802-1 20211116-1
arch-wiki-lite 20200527-1 20211116-1
ardour 6.9-2 6.9-3
aws-cli 1.21.7-1 1.22.7-1
balsa 2.6.2-1 2.6.3-2
bcc 0.22.0-1 0.22.0-2
bcc-tools 0.22.0-1 0.22.0-2
bleachbit 4.4.1-1 4.4.2-1
blender 17:2.93.5-7 17:2.93.6-1
bpftrace 0.14.0-1 0.14.0-2
broot 1.7.0-1 1.7.3-1
btop 1.0.20-2 1.1.0-1
calibre 5.31.1-1 5.32.0-1
cargo-audit 0.15.2-1 0.16.0-1
cargo-crev 0.21.3-1 0.21.3-2
cargo-outdated 0.9.17-1 0.10.2-1
cargo-release 0.18.2-1 0.18.5-1
cargo-watch 8.1.1-1 8.1.2-1
ccls 0.20210330-3 0.20210330-4
cinnamon 5.0.7-1 5.0.7-3
cinnamon-control-center 5.0.2-1 5.0.2-2
cinnamon-desktop 5.0.0-1 5.0.0-2
cinnamon-menus 4.8.3-1 5.0.0-1
cinnamon-translations 5.0.2-1 5.0.2-2
clasp 3.3.6-1 3.3.7-1
clojure 1.10.3.1020-1 1.10.3.1029-1
cmake-fedora 2.9.3-5 2.9.3-6
containerd 1.5.7-1 1.5.8-1
containers-common 0.46.0-4 0.46.0-5
coolreader 3.2.59-1 3.2.59-3
crystal 1.2.1-1 1.2.2-1
dbmail 3.2.3-12 3.2.3-13
debootstrap 1.0.125-1 1.0.126-1
deno 1.14.0-1 1.16.2-1
diskus 0.6.0-2 0.7.0-1
docker 1:20.10.10-1 1:20.10.11-1
dovecot 2.3.16-1 2.3.16-2
drawing 0.8.3-1 0.8.4-1
drupal 9.2.6-1 9.2.9-1
echoping 6.0.2-9 6.0.2-10
ecryptfs-utils 111-4 111-5
electrum 4.1.3-1 4.1.5-1
elinks 0.14.3-1 0.14.3-2
esptool 3.1-1 3.2-1
exfatprogs 1.1.2-1 1.1.3-1
exim 4.95-1 4.95-2
faudio 21.10-1 21.11-1
faust 2.33.1-1 2.37.3-1
fbreader 0.99.4-9 0.99.4-10
fcitx5-chinese-addons 5.0.7-1 5.0.8-1
fcitx5-configtool 5.0.7-1 5.0.8-1
fcitx5-libthai 5.0.5-1 5.0.6-1
fcitx5-sayura 5.0.3-1 5.0.4-1
fcitx5-table-other 5.0.5-1 5.0.6-1
fcitx5-unikey 5.0.5-1 5.0.6-1
fetchmail 6.4.23-1 6.4.24-1
fio 3.28-1 3.28-2
flint 2.8.3-1 2.8.4-1
freeradius 3.0.25-1 3.0.25-2
fs-uae 3.0.5-1 3.1.53-1
fs-uae-launcher 3.0.5-2 3.1.46-1
fwupd 1.7.1-1 1.7.2-1
galculator 2.1.4-5 2.1.4-6
galculator-gtk2 2.1.4-5 -
gf2x 1.3.0-1 1.3.0-2
git-sizer 1.4.0-2 1.5.0-1
glewlwyd 2.5.4-4 2.5.4-5
glusterfs 1:9.3-2 1:10.0-2
gnome-applets 3.40.0-1 3.42.0-1
gnome-connections 40.0.1-3 41.1-1
gnome-initial-setup 40.4-1 41.0-1
gnome-panel 3.40.0-1 3.42.0-1
go-yq 4.14.1-1 4.14.2-1
gopass 1.12.8-1 1.13.0-1
goreleaser 0.184.0-1 1.0.0-1
gtop 1.1.1-1 1.1.2-1
gufw 21.04.0-1 -
gvm-libs 10.0.2-1 10.0.2-2
hugo 0.89.2-1 0.89.3-1
iptux 0.8.2-1 0.8.3-1
iwd 1.19-2 1.20-1
jami-daemon 20211004-3 20211104-1
jami-gnome 20211004-1 20211101-1
jami-qt 20211004-1 20211104-1
java-atk-wrapper-common 0.38.0-2 0.38.0-3
java-atk-wrapper-openjdk 0.38.0-2 0.38.0-3
java-atk-wrapper-openjdk11 0.38.0-2 0.38.0-3
java-atk-wrapper-openjdk8 0.38.0-2 0.38.0-3
jupyterlab 3.2.3-1 3.2.4-1
k9s 0.24.15-2 0.25.3-1
kotlin 1.5.31-1 1.6.0-1
kstars 1:3.5.5-1 1:3.5.6-1
latte-dock 0.10.3-1 0.10.4-1
ldc 3:1.28.0-1 3:1.28.0-3
lesspipe 1.91-1 1.91-2
libc++ 12.0.0-1 13.0.0-1
libc++abi 12.0.0-1 13.0.0-1
libc++experimental 12.0.0-1 13.0.0-1
libgda 5.2.10-2 5.2.10-3
libgda-jdbc 5.2.10-2 5.2.10-3
libgda-mysql 5.2.10-2 5.2.10-3
libgda-postgres 5.2.10-2 5.2.10-3
libime 1.0.8-1 1.0.9-1
libjamiclient 20211004-1 20211104-1
liblphobos 3:1.28.0-1 3:1.28.0-3
libperconaserverclient 8.0.26_16-1 8.0.26_16-2
libretro-core-info 1.9.12-1 1.9.13-1
libretro-gambatte 938-1 942-1
libretro-genesis-plus-gx 1861-1 1867-1
libretro-melonds 1982-1 1983-1
libretro-overlays 205-1 210-1
libretro-play 6810-1 6833-1
libretro-sameboy 1288-1 1720-1
libunibreak 4.3-1 5.0-1
lilv 0.24.12-1 0.24.12-2
lldpd 1.0.12-1 1.0.13-1
lowdown 0.10.0-1 0.10.0-2
lsp-plugins 1.1.30-1 1.1.30-2
luarocks 3.7.0-1 3.8.0-1
lychee-link-checker 0.8.0-1 0.8.1-1
m4ri 20200125-1 20200125-2
m4rie 20200125-1 20200125-2
magnum-plugins 2020.06-1 2020.06-2
mailutils 3.13-1 3.13-2
mate-screensaver 1.26.0-1 1.26.1-1
matrix-synapse 1.46.0-1 1.47.0-1
maturin 0.11.5-1 0.12.0-1
mcqd 1.0.0-2 1.0.0-3
mellite 3.9.0-1 3.10.1-1
metacity 3.40.0-1 3.42.0-1
miller 5.10.2-1 5.10.3-1
minio 2021.09.03-1 2021.11.09-1
minio-client 2021.09.23-1 2021.11.05-1
minitube 3.9.1-1 3.9.2-1
mkinitcpio-systemd-tool 36-1 37-1
molecule-vagrant 0.6.3-1 0.6.3-2
monitoring-plugins 2.3.1-1 2.3.1-2
mozo 1.26.0-2 1.26.1-1
munin 2.0.67-2 2.0.68-1
munin-node 2.0.67-2 2.0.68-1
nebula 1.4.0-1 1.5.0-1
nemo-fileroller 5.0.0-1 5.0.0-2
nemo-image-converter 5.0.0-1 5.0.0-2
nemo-preview 5.0.0-1 5.0.0-2
nemo-python 5.0.0-1 5.0.0-2
nemo-seahorse 5.0.0-1 5.0.0-2
nemo-share 5.0.0-1 5.0.0-2
nemo-terminal 5.0.0-1 5.0.0-2
nextcloud 22.2.2-1 22.2.3-1
nextcloud-app-news 16.2.0-1 16.2.1-1
nextcloud-app-notes 4.1.1-1 4.2.0-1
nix 2.3.16-1 2.4-1
nodejs 16.11.1-1 17.1.0-1
nomad 1.1.6-1 1.2.0-1
notion 1:4.0.2-2 1:4.0.2-3
npm-check-updates 12.0.0-1 12.0.1-1
nss-pam-ldapd 0.9.11-3 0.9.11-4
nuitka 0.6.17.6-1 0.6.17.7-1
nushell 0.39.0-1 0.40.0-1
opam 2.1.0-1 2.1.1-1
openapi-generator 5.2.0-1 5.3.0-1
openbsd-netcat 1.217_2-1 1.218_2-1
opendht 1:2.3.1-11:2.3.1.r7+ga89e4d62-1
opendkim 2.10.3-7 2.11.0beta-1
openshadinglanguage 1.11.14.2-1 1.11.16.0-1
opensips 3.1.2-2 3.1.2-3
otf-cascadia-code 2108.26-1 2110.31-1
oxipng 5.0.0-1 5.0.1-1
pacoloco 1.0-2 1.1-1
pamixer 1.5-1 1.5-2
parallel 20200322-1 20211022-1
pcsc-tools 1.5.7-1 1.5.8-1
pd-gem 0.94-6 0.94-7
pdfarranger 1.7.1-1 1.8.0-1
percona-server 8.0.26_16-1 8.0.26_16-2
percona-server-clients 8.0.26_16-1 8.0.26_16-2
perl-scalar-list-utils 1.56-2 1.60-1
powerdns 4.5.2-1 4.5.2-2
profile-cleaner 2.42-1 2.43-1
ptex 2.4.1-1 2.4.1-2
pulumi 3.17.1-1 3.18.0-1
pyenv 2.2.0-1 2.2.1-1
pyright 1.1.187-1 1.1.188-1
python-aiobotocore 1.4.2-1 2.0.0-1
python-aiounittest 1.4.0-1 1.4.1-1
python-bcc 0.22.0-1 0.22.0-2
python-black 21.10b0-1 21.11b1-1
python-boto3 1.19.7-1 1.20.7-1
python-botocore 1.22.7-1 1.23.7-1
python-braintree 4.12.0-1 4.13.0-1
python-cleo 0.7.6-4 0.8.1-1
python-cloudscraper 1.2.58-1 1.2.58-2
python-copr 1.113-1 1.114-1
python-dateutil 2.8.2-1 2.8.2-2
python-django-allauth 0.45.0-1 0.46.0-1
python-elementpath 2.3.2-1 2.4.0-1
python-flexmock 0.10.10-1 0.11.0-1
python-fonttools 4.27.1-1 4.28.0-1
python-freezegun 0.3.15-5 0.3.15-6
python-google-api-python-client 2.30.0-1 2.31.0-1
python-graphene 3.0.0b8-1 3.0.0-1
python-h5py 3.5.0-1 3.6.0-1
python-h5py-openmpi 3.5.0-1 3.6.0-1
python-html5-parser 0.4.9-5 0.4.10-1
python-html5lib 1.1-7 1.1-8
python-isort 5.9.3-1 5.10.1-1
python-jupyter_packaging 0.11.0-1 0.11.1-1
python-ldap 3.3.1-4 3.3.1-5
python-markdown 3.3.4-2 3.3.6-1
python-matplotlib 3.4.3-1 3.5.0-1
python-moto 2.2.13-1 2.2.15-1
python-peewee 3.14.8-1 3.14.8-2
python-pg8000 1.22.1-1 1.23.0-1
python-pipenv 2021.11.9-1 2021.11.15-1
python-pwntools 4.6.0-1 4.7.0-1
python-pymupdf 1.19.1-1 1.19.2-1
python-pytest-expect 1.1.0-6 1.1.0-7
python-pywlroots 0.14.9-1 0.14.11-1
python-regex 2021.8.28-1 2021.11.10-1
python-rfc6555 0.0.0-3 0.0.0-4
python-rich 10.13.0-1 10.14.0-1
python-rjsmin 1.1.0-3 1.2.0-1
python-schemdraw 0.11-1 0.12-1
python-scikit-learn 1.0-1 1.0.1-1
python-selectors2 2.0.2-1 2.0.2-2
python-tox 3.24.4-1 3.24.4-2
python-u-msgpack 2.7.1-2 2.7.1-3
python-uritemplate 3.0.1-3 3.0.1-4
python-xapp 2.2.1-1 2.2.1-2
python2-dateutil 2.8.2-1 -
python2-freezegun 0.3.15-5 -
python2-html5lib 1.1-7 1.1-8
python2-pytest-expect 1.1.0-6 -
python2-pytest-mock 2.0.0-4 -
python2-rfc6555 0.0.0-3 -
python2-selectors2 2.0.2-1 -
python2-tox 3.24.4-1 -
python2-u-msgpack 2.7.1-2 -
python2-uritemplate 3.0.1-3 -
qgis 3.22.0-1 3.22.1-1
quassel-client 0.13.1-8 0.13.1-9
quassel-client-qt 0.13.1-8 0.13.1-9
quassel-common 0.13.1-8 0.13.1-9
quassel-core 0.13.1-8 0.13.1-9
quassel-monolithic 0.13.1-8 0.13.1-9
quassel-monolithic-qt 0.13.1-8 0.13.1-9
recoll 1.31.0-1 1.31.2-1
redmine 4.2.2-2.1 4.2.3-1
retroarch 1.9.13.1-1 1.9.13.2-1
rocksdb 6.23.3-1 6.26.0-1
rtaudio 5.1.0-3 5.2.0-1
rust-analyzer 20211108-1 20211115-1
rustup 1.24.3-1 1.24.3-2
samurai 1.2-1 1.2-2
sarg 2.4.0-1 2.4.0-3
scdoc 1.11.1-2 1.11.2-1
serverless 2.66.1-1 2.66.2-1
singular 4.2.1-3 4.2.1.p2-1
skaffold 1.34.0-1 1.35.0-1
sleuthkit 4.11.0-1 4.11.1-1
snd 21.8-1 21.9-1
solr 8.10.1-3 8.11.0-1
spirv-llvm-translator 12.0.0-1 13.0.0-1
sqlx-cli 0.5.7-1 0.5.9-1
squid 5.2-1 5.2-3
sratom 0.6.8-1 0.6.8-3
sssd 2.6.1-1 2.6.1-2
step-ca 0.17.6-1 0.18.0-1
step-cli 0.17.7-1 0.18.0-1
strongswan 5.9.4-1 5.9.4-2
stylelint 14.0.1-1 14.1.0-1
stylelint-config-standard 23.0.0-1 24.0.0-1
suil 0.10.10-1 0.10.10-2
sylpheed 3.7.0-5 3.7.0-6
tailscale 1.16.2-1 1.18.0-1
telegram-desktop 3.2.3-1 3.2.5-1
tellico 3.4.1-1 3.4.2-1
terraform 1.0.10-1 1.0.11-1
tigervnc 1.11.0-6 1.12.0-1
ttf-cascadia-code 2108.26-1 2110.31-1
uranium 4.11.0-1 4.11.0-2
v2ray-domain-list-community 20211107153452-1 20211115045842-1
v2ray-geoip 202111040028-1 202111180029-1
vc-intrinsics r100+2d0795c-1 r100+2d0795c-2
vscode-css-languageserver 1.62.0-1 1.62.3-1
vscode-html-languageserver 1.62.0-1 1.62.3-1
vscode-json-languageserver 1.62.0-1 1.62.3-1
wasi-compiler-rt 12.0.1-1 13.0.0-1
wasi-libc++ 12.0.1-1 13.0.0-2
wasi-libc++abi 12.0.1-1 13.0.0-2
wasi-libc 0+222+ad51334-1 0+222+ad51334-2
wireshark-cli 3.4.9-1 3.4.10-1
wireshark-qt 3.4.9-1 3.4.10-1
woff2-cascadia-code 2108.26-1 2110.31-1
x42-plugins 20211016-1 20211016-2
xed 3.0.2-1 3.0.2-2
xfce4-whiskermenu-plugin 2.6.1-1 2.6.2-1
xh 0.13.0-1 0.14.0-1
xplr 0.16.3-1 0.16.4-1
xreader 3.0.2-1 3.0.2-2
yubico-pam 2.27-1 2.27-2
binocle - 0.2.0-1
cargo-pgx - 0.2.5-1
drone - 2.5.0-1
drone-cli - 1.4.0-2
drone-oss - 2.5.0-1
drone-runner-docker - 1.8.0-1
drone-runner-exec - 1.0.0beta.9-3
drone-runner-ssh - 1.0.1-3
encpipe - 0.5-2
gerbera - 1.9.2-1
lsp-plugins-docs - 1.1.30-2
nemo-audio-tab - 5.0.0-2
nemo-emblems - 5.0.0-2
nemo-pastebin - 5.0.0-2
nix-docs - 2.4-1
promscale_extension - 0.3.0-1
rocksndiamonds-contrib - 5-1
rtaudio-docs - 5.2.0-1
testu01 - 1.2.3-4
:: Different overlay package(s) in repository core aarch64
linux 5.15.2-1 5.15.4-1
linux-headers 5.15.2-1 5.15.4-1
linux-pinephone 5.15.2-1 5.15.3-2
linux-pinephone-headers 5.15.2-1 5.15.3-2
linux-pinephonepro 5.15.2-1 5.15.3-2
linux-pinephonepro-headers 5.15.2-1 5.15.3-2
linux-rc 5.15.rc7-2 5.16.rc1-6
linux-rc-headers 5.15.rc7-2 5.16.rc1-6
pacman-mirrors 4.21.5-1 4.22.0-3
linux-odroid - 5.15.2-1
linux-odroid-headers - 5.15.2-1
uboot-stationm2-bsp - 2017.09-0.8
:: Different sync package(s) in repository core aarch64
audit 3.0.5-1 3.0.6-2
cryptsetup 2.4.1-3 2.4.2-1
debuginfod 0.185-1 0.186-1
dialog 1:1.3_20210621-1 1:1.3_20211107-1
elfutils 0.185-1 0.186-1
gnupg 2.2.32-1 2.2.32-2
json-c 0.15-1 0.15-2
krb5 1.19.2-1 1.19.2-2
libelf 0.185-1 0.186-1
libldap 2.4.59-2 2.6.0-2
nfs-utils 2.5.4-1 2.5.4-2
nfsidmap 2.5.4-1 2.5.4-2
openldap 2.4.59-2 2.6.0-2
pambase 20210605-2 20211111-1
pcre2 10.37-1 10.39-1
python-audit 3.0.5-1 3.0.6-2
sudo 1.9.8.p2-1.1 1.9.8.p2-3
:: Different overlay package(s) in repository extra aarch64
manjaro-chrootbuild r230.g62a16d0-1 r233.g5210353-1
mesa-git22.0.0_devel.146897.c4d904101c0-122.0.0_devel.147366.724a38eb944-1
okular 21.08.2-1 21.08.3-1
python-es2-pyqt5 5.15.4-4.3 5.15.6-1
qt5-es2-base 5.15.2+kde+r211-1 5.15.2+kde+r256-1
qt5-es2-declarative 5.15.2+kde+r29-1 5.15.2+kde+r41-1
qt5-es2-wayland 5.15.2+kde+r29-1 5.15.2+kde+r36-1
qt5-es2-xcb-private-headers 5.15.2+kde+r211-1 5.15.2+kde+r256-1
:: Different sync package(s) in repository extra aarch64
389-ds-base 2.0.10-1 2.0.10-2
apache 2.4.51-1 2.4.51-2
apr-util 1.6.1-8 1.6.1-9
assimp 5.0.1-3 5.1.1-1
attica 5.87.0-1 5.88.0-1
baloo 5.87.0-1 5.88.0-1
bind 9.16.22-1 9.16.23-1
bluez-qt 5.87.0-1 5.88.0-1
breeze-icons 5.87.0-1 5.88.0-1
cheese 41.0-2 41.1-1
chromium 95.0.4638.69-2 96.0.4664.45-1
clang 12.0.1-1 13.0.0-2
claws-mail 4.0.0-2 4.0.0-3
clazy 1.10-1 1.10-2
cmake 3.21.4-1 3.22.0-1
compiler-rt 12.0.1-2 13.0.0-1
cups-filters 1.28.10-1 1.28.10-2
cyrus-sasl 2.1.27-5 2.1.27-6
cyrus-sasl-gssapi 2.1.27-5 2.1.27-6
cyrus-sasl-ldap 2.1.27-5 2.1.27-6
cyrus-sasl-sql 2.1.27-5 2.1.27-6
dhclient 4.4.2.P1-1 4.4.2.P1-2
dhcp 4.4.2.P1-1 4.4.2.P1-2
dkms 2.8.6-2 3.0.1-1
ell 0.45-1 0.46-1
ethtool 1:5.14-1 1:5.15-1
evince 41.2-1 41.3-1
evolution 3.42.1-1 3.42.1-2
evolution-bogofilter 3.42.1-1 3.42.1-2
evolution-data-server 3.42.1-1 3.42.1-2
evolution-spamassassin 3.42.1-1 3.42.1-2
extra-cmake-modules 5.87.0-1 5.88.0-1
firefox 94.0.1-1 94.0.2-2
firefox-i18n-ach 94.0.1-1 94.0.2-2
firefox-i18n-af 94.0.1-1 94.0.2-2
firefox-i18n-an 94.0.1-1 94.0.2-2
firefox-i18n-ar 94.0.1-1 94.0.2-2
firefox-i18n-ast 94.0.1-1 94.0.2-2
firefox-i18n-az 94.0.1-1 94.0.2-2
firefox-i18n-be 94.0.1-1 94.0.2-2
firefox-i18n-bg 94.0.1-1 94.0.2-2
firefox-i18n-bn 94.0.1-1 94.0.2-2
firefox-i18n-br 94.0.1-1 94.0.2-2
firefox-i18n-bs 94.0.1-1 94.0.2-2
firefox-i18n-ca 94.0.1-1 94.0.2-2
firefox-i18n-ca-valencia 94.0.1-1 94.0.2-2
firefox-i18n-cak 94.0.1-1 94.0.2-2
firefox-i18n-cs 94.0.1-1 94.0.2-2
firefox-i18n-cy 94.0.1-1 94.0.2-2
firefox-i18n-da 94.0.1-1 94.0.2-2
firefox-i18n-de 94.0.1-1 94.0.2-2
firefox-i18n-dsb 94.0.1-1 94.0.2-2
firefox-i18n-el 94.0.1-1 94.0.2-2
firefox-i18n-en-ca 94.0.1-1 94.0.2-2
firefox-i18n-en-gb 94.0.1-1 94.0.2-2
firefox-i18n-en-us 94.0.1-1 94.0.2-2
firefox-i18n-eo 94.0.1-1 94.0.2-2
firefox-i18n-es-ar 94.0.1-1 94.0.2-2
firefox-i18n-es-cl 94.0.1-1 94.0.2-2
firefox-i18n-es-es 94.0.1-1 94.0.2-2
firefox-i18n-es-mx 94.0.1-1 94.0.2-2
firefox-i18n-et 94.0.1-1 94.0.2-2
firefox-i18n-eu 94.0.1-1 94.0.2-2
firefox-i18n-fa 94.0.1-1 94.0.2-2
firefox-i18n-ff 94.0.1-1 94.0.2-2
firefox-i18n-fi 94.0.1-1 94.0.2-2
firefox-i18n-fr 94.0.1-1 94.0.2-2
firefox-i18n-fy-nl 94.0.1-1 94.0.2-2
firefox-i18n-ga-ie 94.0.1-1 94.0.2-2
firefox-i18n-gd 94.0.1-1 94.0.2-2
firefox-i18n-gl 94.0.1-1 94.0.2-2
firefox-i18n-gn 94.0.1-1 94.0.2-2
firefox-i18n-gu-in 94.0.1-1 94.0.2-2
firefox-i18n-he 94.0.1-1 94.0.2-2
firefox-i18n-hi-in 94.0.1-1 94.0.2-2
firefox-i18n-hr 94.0.1-1 94.0.2-2
firefox-i18n-hsb 94.0.1-1 94.0.2-2
firefox-i18n-hu 94.0.1-1 94.0.2-2
firefox-i18n-hy-am 94.0.1-1 94.0.2-2
firefox-i18n-ia 94.0.1-1 94.0.2-2
firefox-i18n-id 94.0.1-1 94.0.2-2
firefox-i18n-is 94.0.1-1 94.0.2-2
firefox-i18n-it 94.0.1-1 94.0.2-2
firefox-i18n-ja 94.0.1-1 94.0.2-2
firefox-i18n-ka 94.0.1-1 94.0.2-2
firefox-i18n-kab 94.0.1-1 94.0.2-2
firefox-i18n-kk 94.0.1-1 94.0.2-2
firefox-i18n-km 94.0.1-1 94.0.2-2
firefox-i18n-kn 94.0.1-1 94.0.2-2
firefox-i18n-ko 94.0.1-1 94.0.2-2
firefox-i18n-lij 94.0.1-1 94.0.2-2
firefox-i18n-lt 94.0.1-1 94.0.2-2
firefox-i18n-lv 94.0.1-1 94.0.2-2
firefox-i18n-mk 94.0.1-1 94.0.2-2
firefox-i18n-mr 94.0.1-1 94.0.2-2
firefox-i18n-ms 94.0.1-1 94.0.2-2
firefox-i18n-my 94.0.1-1 94.0.2-2
firefox-i18n-nb-no 94.0.1-1 94.0.2-2
firefox-i18n-ne-np 94.0.1-1 94.0.2-2
firefox-i18n-nl 94.0.1-1 94.0.2-2
firefox-i18n-nn-no 94.0.1-1 94.0.2-2
firefox-i18n-oc 94.0.1-1 94.0.2-2
firefox-i18n-pa-in 94.0.1-1 94.0.2-2
firefox-i18n-pl 94.0.1-1 94.0.2-2
firefox-i18n-pt-br 94.0.1-1 94.0.2-2
firefox-i18n-pt-pt 94.0.1-1 94.0.2-2
firefox-i18n-rm 94.0.1-1 94.0.2-2
firefox-i18n-ro 94.0.1-1 94.0.2-2
firefox-i18n-ru 94.0.1-1 94.0.2-2
firefox-i18n-si 94.0.1-1 94.0.2-2
firefox-i18n-sk 94.0.1-1 94.0.2-2
firefox-i18n-sl 94.0.1-1 94.0.2-2
firefox-i18n-son 94.0.1-1 94.0.2-2
firefox-i18n-sq 94.0.1-1 94.0.2-2
firefox-i18n-sr 94.0.1-1 94.0.2-2
firefox-i18n-sv-se 94.0.1-1 94.0.2-2
firefox-i18n-ta 94.0.1-1 94.0.2-2
firefox-i18n-te 94.0.1-1 94.0.2-2
firefox-i18n-th 94.0.1-1 94.0.2-2
firefox-i18n-tl 94.0.1-1 94.0.2-2
firefox-i18n-tr 94.0.1-1 94.0.2-2
firefox-i18n-trs 94.0.1-1 94.0.2-2
firefox-i18n-uk 94.0.1-1 94.0.2-2
firefox-i18n-ur 94.0.1-1 94.0.2-2
firefox-i18n-uz 94.0.1-1 94.0.2-2
firefox-i18n-vi 94.0.1-1 94.0.2-2
firefox-i18n-xh 94.0.1-1 94.0.2-2
firefox-i18n-zh-cn 94.0.1-1 94.0.2-2
firefox-i18n-zh-tw 94.0.1-1 94.0.2-2
foomatic-db 3:20211106-1 3:20211116-1
foomatic-db-nonfree 3:20211106-1 3:20211116-1
foomatic-db-nonfree-ppds 3:20211106-1 3:20211116-1
foomatic-db-ppds 3:20211106-1 3:20211116-1
frameworkintegration 5.87.0-1 5.88.0-1
gdm 41.0-1 41.0+r15+g23ebe617-1
git 2.33.1-1 2.34.0-1
glslang 11.6.0-1 11.7.0-1
gnome-builder 41.1-2 41.2-1
gnome-builder-libide-docs 41.1-2 41.2-1
gnome-screenshot 40.0-2 41.0-1
gtk-vnc 1.2.0-1 1.3.0-1
imagemagick 7.1.0.13-1 7.1.0.14-1
imagemagick-doc 7.1.0.13-1 7.1.0.14-1
kactivities 5.87.0-1 5.88.0-1
kactivities-stats 5.87.0-1 5.88.0-1
kapidox 5.87.0-1 5.88.0-1
karchive 5.87.0-1 5.88.0-1
kauth 5.87.0-1 5.88.0-1
kbookmarks 5.87.0-1 5.88.0-1
kcalendarcore 5.87.0-1 5.88.0-1
kcmutils 5.87.0-1 5.88.0-1
kcodecs 5.87.0-1 5.88.0-1
kcompletion 5.87.0-1 5.88.0-1
kconfig 5.87.0-1 5.88.0-1
kconfigwidgets 5.87.0-1 5.88.0-1
kcontacts 1:5.87.0-1 1:5.88.0-1
kcoreaddons 5.87.0-1 5.88.0-1
kcrash 5.87.0-1 5.88.0-1
kdav 1:5.87.0-1 1:5.88.0-1
kdbusaddons 5.87.0-1 5.88.0-1
kdeclarative 5.87.0-1 5.88.0-1
kded 5.87.0-1 5.88.0-1
kdelibs4support 5.87.0-1 5.88.0-1
kdesignerplugin 5.87.0-1 5.88.0-1
kdesu 5.87.0-1 5.88.0-1
kdevelop 5.6.2-5 5.6.2-6
kdewebkit 5.87.0-1 5.88.0-1
kdnssd 5.87.0-1 5.88.0-1
kdoctools 5.87.0-1 5.88.0-1
kemoticons 5.87.0-1 5.88.0-1
kfilemetadata 5.87.0-1 5.88.0-1
kglobalaccel 5.87.0-1 5.88.0-1
kguiaddons 5.87.0-1 5.88.0-1
kholidays 1:5.87.0-1 1:5.88.0-1
khtml 5.87.0-1 5.88.0-1
ki18n 5.87.0-1 5.88.0-1
kiconthemes 5.87.0-1 5.88.0-1
kidletime 5.87.0-1 5.88.0-1
kimageformats 5.87.0-2 5.88.0-1
kinit 5.87.0-1 5.88.0-1
kio 5.87.0-1 5.88.0-1
kirigami2 5.87.0-1 5.88.0-1
kitemmodels 5.87.0-1 5.88.0-1
kitemviews 5.87.0-1 5.88.0-1
kjobwidgets 5.87.0-1 5.88.0-1
kjs 5.87.0-1 5.88.0-1
kjsembed 5.87.0-1 5.88.0-1
kldap 21.08.3-1 21.08.3-2
kmediaplayer 5.87.0-1 5.88.0-1
knewstuff 5.87.0-1 5.88.0-1
knotifications 5.87.0-1 5.88.0-1
knotifyconfig 5.87.0-1 5.88.0-1
kpackage 5.87.0-1 5.88.0-1
kparts 5.87.0-1 5.88.0-1
kpeople 5.87.0-1 5.88.0-1
kplotting 5.87.0-1 5.88.0-1
kpty 5.87.0-1 5.88.0-1
kquickcharts 5.87.0-1 5.88.0-1
kross 5.87.0-1 5.88.0-1
krunner 5.87.0-1 5.88.0-1
kservice 5.87.0-1 5.88.0-1
ktexteditor 5.87.0-1 5.88.0-1
ktextwidgets 5.87.0-1 5.88.0-1
kunitconversion 5.87.0-1 5.88.0-1
kwallet 5.87.0-1 5.88.0-1
kwayland 5.87.0-1 5.88.0-1
kwidgetsaddons 5.87.0-1 5.88.0-1
kwindowsystem 5.87.0-1 5.88.0-1
kxmlgui 5.87.0-1 5.88.0-1
kxmlrpcclient 5.87.0-1 5.88.0-1
ldb 2:2.4.1-1 2:2.4.1-2
libcheese 41.0-2 41.1-1
libclc 12.0.1-1 13.0.0-1
libgdm 41.0-1 41.0+r15+g23ebe617-1
libjpeg-turbo 2.1.1-1 2.1.2-1
libmbim 1.26.0-2 1.26.2-1
libopenmpt 0.5.12-3 0.5.13-1
libqrtr-glib 1.0.0-1 1.2.0-1
libreoffice-fresh 7.2.2-2 7.2.2-3
libreoffice-fresh-sdk 7.2.2-2 7.2.2-3
libreoffice-still 7.1.7-1 7.1.7-2
libreoffice-still-sdk 7.1.7-1 7.1.7-2
librsvg 2:2.52.3-1 2:2.52.4-1
libunrar 1:6.0.7-1 1:6.1.2-1
libva-mesa-driver 21.2.4-1 21.2.5-1
lighttpd 1.4.61-1 1.4.61-2
lld 12.0.1-1 13.0.0-1
lldb 12.0.1-1 13.0.0-1
llvm 12.0.1-5.1 13.0.0-3
llvm-libs 12.0.1-5.1 13.0.0-3
llvm-ocaml 12.0.1-5.1 13.0.0-3
mesa 21.2.4-1 21.2.5-1
mesa-vdpau 21.2.4-1 21.2.5-1
mkvtoolnix-cli 62.0.0-1 63.0.0-1
mkvtoolnix-gui 62.0.0-1 63.0.0-1
modemmanager-qt 5.87.0-1 5.88.0-1
mysql-python 1.2.5-4 -
networkmanager-qt 5.87.0-1 5.88.0-1
nss_ldap 265-7 265-8
nuspell 5.0.0-1 5.0.1-1
openal 1.21.1-1 1.21.1-2
openal-examples 1.21.1-1 1.21.1-2
opencl-mesa 21.2.4-1 21.2.5-1
openmp 12.0.1-1 13.0.0-1
oxygen-icons 1:5.87.0-1 1:5.88.0-1
oxygen-icons-svg 1:5.87.0-1 1:5.88.0-1
pam_ldap 186-7 186-8
php 8.0.12-1 8.0.13-1
php-apache 8.0.12-1 8.0.13-1
php-cgi 8.0.12-1 8.0.13-1
php-dblib 8.0.12-1 8.0.13-1
php-embed 8.0.12-1 8.0.13-1
php-enchant 8.0.12-1 8.0.13-1
php-fpm 8.0.12-1 8.0.13-1
php-gd 8.0.12-1 8.0.13-1
php-imap 8.0.12-1 8.0.13-1
php-intl 8.0.12-1 8.0.13-1
php-odbc 8.0.12-1 8.0.13-1
php-pgsql 8.0.12-1 8.0.13-1
php-phpdbg 8.0.12-1 8.0.13-1
php-pspell 8.0.12-1 8.0.13-1
php-snmp 8.0.12-1 8.0.13-1
php-sodium 8.0.12-1 8.0.13-1
php-sqlite 8.0.12-1 8.0.13-1
php-tidy 8.0.12-1 8.0.13-1
php-xsl 8.0.12-1 8.0.13-1
php7 7.4.25-1 7.4.26-1
php7-apache 7.4.25-1 7.4.26-1
php7-cgi 7.4.25-1 7.4.26-1
php7-dblib 7.4.25-1 7.4.26-1
php7-embed 7.4.25-1 7.4.26-1
php7-enchant 7.4.25-1 7.4.26-1
php7-fpm 7.4.25-1 7.4.26-1
php7-gd 7.4.25-1 7.4.26-1
php7-imap 7.4.25-1 7.4.26-1
php7-intl 7.4.25-1 7.4.26-1
php7-odbc 7.4.25-1 7.4.26-1
php7-pgsql 7.4.25-1 7.4.26-1
php7-phpdbg 7.4.25-1 7.4.26-1
php7-pspell 7.4.25-1 7.4.26-1
php7-snmp 7.4.25-1 7.4.26-1
php7-sodium 7.4.25-1 7.4.26-1
php7-sqlite 7.4.25-1 7.4.26-1
php7-tidy 7.4.25-1 7.4.26-1
php7-xsl 7.4.25-1 7.4.26-1
plasma-framework 5.87.0-1 5.88.0-1
plasma-meta 5.23-1 5.23-2
polly 12.0.1-1 13.0.0-1
postfix 3.6.3-1 3.6.3-2
postfix-cdb 3.6.3-1 3.6.3-2
postfix-ldap 3.6.3-1 3.6.3-2
postfix-lmdb 3.6.3-1 3.6.3-2
postfix-mysql 3.6.3-1 3.6.3-2
postfix-pcre 3.6.3-1 3.6.3-2
postfix-pgsql 3.6.3-1 3.6.3-2
postfix-sqlite 3.6.3-1 3.6.3-2
postgresql 13.4-1 13.4-3
postgresql-docs 13.4-1 13.4-3
postgresql-libs 13.4-1 13.4-3
postgresql-old-upgrade 12.8-1 12.8-3
prison 5.87.0-1 5.88.0-1
prometheus-node-exporter 1.2.2-1 1.3.0-1
purpose 5.87.0-1 5.88.0-1
python-shiboken2 5.15.2-9 5.15.2-10
qpdf 10.3.2-1 10.4.0-1
qqc2-desktop-style 5.87.0-1 5.88.0-1
qt5-3d 5.15.2+kde+r33-1 5.15.2+kde+r33-2
qt5-base 5.15.2+kde+r254-1 5.15.2+kde+r257-1
qt5-declarative 5.15.2+kde+r39-1 5.15.2+kde+r41-1
qt5-quick3d 5.15.2+kde+r19-1 5.15.2+kde+r19-3
qt5-tools 5.15.2+kde+r17-3 5.15.2+kde+r17-4
qt5-websockets 5.15.2-1 5.15.2+kde+r4-1
qt5-xcb-private-headers 5.15.2+kde+r254-1 5.15.2+kde+r257-1
qt6-3d 6.2.1-1 6.2.1-2
qt6-quick3d 6.2.1-1 6.2.1-2
qt6-tools 6.2.1-1 6.2.1-3
qtcreator 5.0.3-1 5.0.3-2
qtkeychain-qt5 0.13.1-1 0.13.2-1
qtkeychain-qt6 0.13.1-1 0.13.2-1
quazip 1.1-1 1.2-1
quota-tools 1:4.06-1 1:4.06-2
rust 1:1.56.0-1 1:1.56.1-3
rust-docs 1:1.56.0-1 -
samba 4.15.2-1 4.15.2-2
scons 4.2.0-1 4.3.0-1
seahorse 1:41.0-1 1:41.0-2
shiboken6 6.2.1-1 6.2.1-2
smbclient 4.15.2-1 4.15.2-2
solid 5.87.0-1 5.88.0-1
sonnet 5.87.0-1 5.88.0-1
syndication 5.87.0-1 5.88.0-1
syntax-highlighting 5.87.0-2 5.88.0-1
threadweaver 5.87.0-1 5.88.0-1
thunderbird 91.3.0-1 91.3.2-1
thunderbird-i18n-af 91.3.0-1 91.3.2-1
thunderbird-i18n-ar 91.3.0-1 91.3.2-1
thunderbird-i18n-ast 91.3.0-1 91.3.2-1
thunderbird-i18n-be 91.3.0-1 91.3.2-1
thunderbird-i18n-bg 91.3.0-1 91.3.2-1
thunderbird-i18n-br 91.3.0-1 91.3.2-1
thunderbird-i18n-ca 91.3.0-1 91.3.2-1
thunderbird-i18n-cak 91.3.0-1 91.3.2-1
thunderbird-i18n-cs 91.3.0-1 91.3.2-1
thunderbird-i18n-cy 91.3.0-1 91.3.2-1
thunderbird-i18n-da 91.3.0-1 91.3.2-1
thunderbird-i18n-de 91.3.0-1 91.3.2-1
thunderbird-i18n-dsb 91.3.0-1 91.3.2-1
thunderbird-i18n-el 91.3.0-1 91.3.2-1
thunderbird-i18n-en-gb 91.3.0-1 91.3.2-1
thunderbird-i18n-en-us 91.3.0-1 91.3.2-1
thunderbird-i18n-es-ar 91.3.0-1 91.3.2-1
thunderbird-i18n-es-es 91.3.0-1 91.3.2-1
thunderbird-i18n-et 91.3.0-1 91.3.2-1
thunderbird-i18n-eu 91.3.0-1 91.3.2-1
thunderbird-i18n-fi 91.3.0-1 91.3.2-1
thunderbird-i18n-fr 91.3.0-1 91.3.2-1
thunderbird-i18n-fy-nl 91.3.0-1 91.3.2-1
thunderbird-i18n-ga-ie 91.3.0-1 91.3.2-1
thunderbird-i18n-gd 91.3.0-1 91.3.2-1
thunderbird-i18n-gl 91.3.0-1 91.3.2-1
thunderbird-i18n-he 91.3.0-1 91.3.2-1
thunderbird-i18n-hr 91.3.0-1 91.3.2-1
thunderbird-i18n-hsb 91.3.0-1 91.3.2-1
thunderbird-i18n-hu 91.3.0-1 91.3.2-1
thunderbird-i18n-hy-am 91.3.0-1 91.3.2-1
thunderbird-i18n-id 91.3.0-1 91.3.2-1
thunderbird-i18n-is 91.3.0-1 91.3.2-1
thunderbird-i18n-it 91.3.0-1 91.3.2-1
thunderbird-i18n-ja 91.3.0-1 91.3.2-1
thunderbird-i18n-ka 91.3.0-1 91.3.2-1
thunderbird-i18n-kab 91.3.0-1 91.3.2-1
thunderbird-i18n-kk 91.3.0-1 91.3.2-1
thunderbird-i18n-ko 91.3.0-1 91.3.2-1
thunderbird-i18n-lt 91.3.0-1 91.3.2-1
thunderbird-i18n-ms 91.3.0-1 91.3.2-1
thunderbird-i18n-nb-no 91.3.0-1 91.3.2-1
thunderbird-i18n-nl 91.3.0-1 91.3.2-1
thunderbird-i18n-nn-no 91.3.0-1 91.3.2-1
thunderbird-i18n-pa-in 91.3.0-1 91.3.2-1
thunderbird-i18n-pl 91.3.0-1 91.3.2-1
thunderbird-i18n-pt-br 91.3.0-1 91.3.2-1
thunderbird-i18n-pt-pt 91.3.0-1 91.3.2-1
thunderbird-i18n-rm 91.3.0-1 91.3.2-1
thunderbird-i18n-ro 91.3.0-1 91.3.2-1
thunderbird-i18n-ru 91.3.0-1 91.3.2-1
thunderbird-i18n-sk 91.3.0-1 91.3.2-1
thunderbird-i18n-sl 91.3.0-1 91.3.2-1
thunderbird-i18n-sq 91.3.0-1 91.3.2-1
thunderbird-i18n-sr 91.3.0-1 91.3.2-1
thunderbird-i18n-sv-se 91.3.0-1 91.3.2-1
thunderbird-i18n-th 91.3.0-1 91.3.2-1
thunderbird-i18n-tr 91.3.0-1 91.3.2-1
thunderbird-i18n-uk 91.3.0-1 91.3.2-1
thunderbird-i18n-uz 91.3.0-1 91.3.2-1
thunderbird-i18n-vi 91.3.0-1 91.3.2-1
thunderbird-i18n-zh-cn 91.3.0-1 91.3.2-1
thunderbird-i18n-zh-tw 91.3.0-1 91.3.2-1
unzip 6.0-15 6.0-16
vulkan-broadcom 21.2.4-1 21.2.5-1
vulkan-mesa-layers 21.2.4-1 21.2.5-1
vulkan-panfrost 21.2.4-1 21.2.5-1
vulkan-radeon 21.2.4-1 21.2.5-1
vulkan-swrast 21.2.4-1 21.2.5-1
x2goclient 4.1.2.2-2 4.1.2.2-3
xfce4-sensors-plugin 1.4.1-1 1.4.2-1
xfwm4 4.16.1-2 4.16.1-3
xterm 369-1 370-1
zabbix-agent 5.4.5-1 5.4.7-2
zabbix-agent2 5.4.5-1 5.4.7-2
zabbix-frontend-php 5.4.5-1 5.4.7-2
zabbix-proxy 5.4.5-1 5.4.7-2
zabbix-server 5.4.5-1 5.4.7-2
rust-src - 1:1.56.1-3
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.08.3.r12641.gd980d752b-121.08.3.r12647.gb55abe809-1
akonadi-calendar21.08.3.r2002.g8711f1c-121.08.3.r2005.g45e9f2d-1
akonadi-calendar-tools21.08.3.r913.g80a0864-121.08.3.r916.gc0b8834-1
akonadi-contacts21.08.3.r3083.gaf29725a-121.08.3.r3085.gd9589f26-1
akonadi-import-wizard21.08.3.r1766.g1ee56f6-121.08.3.r1769.g8a63030-1
akonadi-mime21.08.3.r1667.g9930b5c-121.08.3.r1672.g7b2b0b2-1
akonadi-notes21.08.3.r1036.g4dd9907-121.08.3.r1038.ga26fc7b-1
akonadi-search21.08.3.r1139.g37c2594-121.08.3.r1142.g2414159-1
akonadiconsole21.08.3.r1545.g1d32d54-121.08.3.r1547.g02d61ae-1
akregator21.08.3.r6248.g2fc625a3-121.08.3.r6252.g2d498a83-1
amazfish 2.0.1.r1.g943c4d5-1 2.0.3.r2.g3c68bf6-1
angelfish 21.08.r36.ga43f050-1 21.08.r39.g74300ab-1
ark21.08.3.r4638.g0860f58f-121.08.3.r4639.gb11947b3-1
attica5.87.0.r844.gf3cca48-15.88.0.r845.gdb45008-1
audiocd-kio21.08.3.r1036.gf197775-121.08.3.r1037.gc940048-1
aura-browser r34.5cc98ff-1 r35.f615dc7-1
baloo5.87.0.r3014.ga9af0cc4-15.88.0.r3017.g07c0227a-1
bigscreen-image-settings r6.88a2eb4-2 r7.4f8e730-1
bluedevil1:5.23.3.r2301.g7b7d222f-11:5.23.3.r2307.g6e52d830-1
bluez-qt5.87.0.r688.gd8c5b4a-15.88.0.r689.g7cb9ab9-1
bovo21.08.3.r748.gf341042-121.08.3.r749.gf86aa73-1
breeze5.23.3.r2293.gdbd4af9b-15.23.3.r2296.geaf874e6-1
breeze-gtk5.23.3.r427.g4e3d0c7-15.23.3.r430.gc18f2a4-1
breeze-icons5.87.0.r1826.g95aa75e3-15.88.0.r1844.gd78695d5-1
calendarsupport21.08.1.r50.gca8aa23-121.08.1.r53.gfecca81-1
discover5.23.3.r8408.geaf32bc7-15.23.3.r8414.g0cd9956a-1
dolphin21.08.3.r6731.gaa9a80fba-121.08.3.r6732.g5bb6bf8d1-1
elisa21.08.3.r2791.g1d55d2e8-121.08.3.r2794.gdf7598ec-1
eventviews21.08.2.r64.g16b30dc-121.11.80.r6.g716daf7-1
extra-cmake-modules5.87.0.r3386.g32fdb17-15.88.0.r3388.gaa21958-1
ffmpegthumbs21.08.3.r199.ga08b3cb-121.08.3.r200.g4da5496-1
frameworkintegration5.87.0.r604.g5ad2efd-15.88.0.r605.g9099300-1
grantlee-editor21.08.3.r782.g5c3d70d-121.08.3.r784.g8434a6a-1
grantleetheme21.08.3.r358.g5b86439-121.08.3.r360.g172b127-1
gwenview21.08.3.r6690.g59a1d995-121.08.3.r6693.ga6c80184-1
incidenceeditor21.08.3.r799.gb59b538-121.08.3.r802.g6f0ea41-1
index-fm 2.1.0.r7.gc9ec50d-1 2.1.0.r11.g5d99424-1
itinerary21.08.3.r1575.g465c1b1-121.08.3.r1611.gee8bd26-1
k3b1:21.08.3.r6684.gc325ddf83-11:21.08.3.r6687.g7e3b88800-1
kaccounts-integration21.08.3.r1230.g85da40d-121.08.3.r1232.g4fcd38f-1
kactivities5.87.0.r1368.g6fec7a7-15.88.0.r1370.gc4f1b30-1
kactivities-stats5.87.0.r379.gc86c301-15.88.0.r380.g16eb3de-1
kaddressbook21.08.3.r6067.ge514b6c6-121.08.3.r6070.g0b453a10-1
kalarm21.08.3.r6515.gf9faf644-121.08.3.r6517.gac26a471-1
kalarmcal21.08.3.r1158.g38ecac9-121.08.3.r1160.g07bedeb-1
kalgebra21.08.3.r2044.gfe74119-121.08.3.r2045.g5b8694a-1
kanagram21.08.3.r1289.g038e41f-121.08.3.r1291.g65cda3b-1
kapidox5.87.0.r557.gcef5476-15.88.0.r558.gcca4aab-1
karchive5.87.0.r517.g7800f6a-15.88.0.r518.g8ab6047-1
kasts 21.08.r83.geb13598-1 21.08.r88.g226176f-1
kate21.08.3.r18444.g6a9295d01-121.08.3.r18449.gd7e4e78b6-1
kauth5.87.0.r455.g860a435-15.88.0.r456.g15ab513-1
kbackup21.08.3.r400.gb4e1e02-121.08.3.r401.g0e9739d-1
kblocks21.08.3.r681.g170f68e-121.08.3.r682.g288c6d8-1
kbookmarks5.87.0.r430.g668c2f2-15.88.0.r434.ge2180e4-1
kbreakout21.08.3.r876.gdec8b86-121.08.3.r879.gd23d1d2-1
kcalc21.08.3.r1545.g25457d7-121.08.3.r1548.gf4c9c38-1
kcalendarcore5.87.0.r1261.g59b895fd3-15.88.0.r1266.g08b10b1bf-1
kcalutils21.08.3.r896.g605e1ab6b-121.08.3.r899.g5e1983a04-1
kcmutils5.87.0.r563.g0cecb6d-15.88.0.r565.g714fca2-1
kcodecs5.87.0.r394.g742c02d-15.88.0.r397.g28fac03-1
kcolorchooser21.08.3.r238.g98b5213-121.08.3.r239.g6d68886-1
kcompletion5.87.0.r467.g64d39bd-15.88.0.r469.g77932c9-1
kconfig5.87.0.r880.gc64a73a-15.88.0.r882.gc3be6d0-1
kconfigwidgets5.87.0.r644.g8e274e4-15.88.0.r646.g97b50c5-1
kcontacts1:5.87.0.r3285.g09e464bc-11:5.88.0.r3289.g6cd2a8e3-1
kcoreaddons5.87.0.r1329.g37d4c69f-15.88.0.r1337.ge82b37b6-1
kcrash5.87.0.r419.gaa5b886-15.88.0.r421.g725c53d-1
kcron21.08.3.r811.g9ea3bef-121.08.3.r813.g4453e39-1
kdav1:5.87.0.r1307.gfc3e8c0-11:5.88.0.r1309.g5954e1e-1
kdbusaddons5.87.0.r386.gaa92f6f-15.88.0.r389.g2e761e3-1
kdebugsettings21.08.3.r861.gc5b254f-121.08.3.r862.g8496f6a-1
kdeclarative5.87.0.r940.g23c43a4-15.88.0.r944.g4b0f685-1
kdeconnect21.08.3.r3356.gac770bec-121.08.3.r3360.g55f0a814-1
kdecoration5.23.3.r279.g6e5e600-15.23.3.r280.ga84273e-1
kded5.87.0.r427.g94b5318-15.88.0.r428.g2dd450f-1
kdegraphics-mobipocket21.08.3.r261.ga9aa775-121.08.3.r262.g0881310-1
kdelibs4support5.87.0.r1051.g9a71fe9c-15.88.0.r1052.gcfae8b72-1
kdenlive21.08.3.r15192.g343721d23-121.08.3.r15268.gfac1ac2e7-1
kdepim-addons21.08.3.r4406.g47d24b2e-121.08.3.r4420.g29eb2d0f-1
kdepim-runtime21.08.3.r15379.gbf8d4a844-121.08.3.r15386.gdd94559e7-1
kdeplasma-addons5.23.3.r8605.g508fde690-15.23.3.r8607.g668c6b7d4-1
kdesignerplugin5.87.0.r340.gca3e138-15.88.0.r341.ge4d65c0-1
kdesu5.87.0.r480.ge37c3bc-15.88.0.r482.g0424805-1
kdewebkit5.87.0.r287.g71a1ccf-15.88.0.r288.g0209b11-1
kdf21.08.3.r812.g60736f6-121.08.3.r813.g48cc89e-1
kdialog21.08.3.r1196.g259732bb4-121.08.3.r1197.g376deeba7-1
kdnssd5.87.0.r330.g9346560-15.88.0.r332.g5171df6-1
kdoctools5.87.0.r633.g7b3b282-15.88.0.r636.g0a783f3-1
kemoticons5.87.0.r392.g2d0fb37-15.88.0.r394.g7d544ea-1
kfilemetadata5.87.0.r821.g4168135-15.88.0.r822.gae5c27b-1
kfind21.08.3.r2651.g7611ffc3c-121.08.3.r2654.g8dc3ebd60-1
kfloppy21.08.3.r767.g5d3ac08-121.08.3.r769.gd28f087-1
kfourinline21.08.3.r993.gbf4db28-121.08.3.r994.ga508900-1
kgeography21.08.3.r1117.gbe842ae-121.08.3.r1121.g7ef837a-1
kglobalaccel5.87.0.r478.g8a213c7-15.88.0.r481.gbf94e3e-1
kguiaddons5.87.0.r401.gfb8e713-15.88.0.r403.ge4c581e-1
khangman21.08.3.r1574.g7b41816-121.08.3.r1575.gd93791d-1
khealthcertificate r91.939ca62-1 r100.e4b5201-1
kholidays1:5.87.0.r976.gb5ca25d-11:5.88.0.r978.gddc6dfa-1
khotkeys5.23.3.r2101.g13fe346-15.23.3.r2102.g97f9339-1
khtml5.87.0.r562.ge5a450c-15.88.0.r563.g2190241-1
ki18n5.87.0.r507.g7d228aa-15.88.0.r517.g97ee556-1
kiconthemes5.87.0.r563.g7e6668a-15.88.0.r566.g3a33ccd-1
kidentitymanagement21.08.3.r3839.g4a5a73b6-121.08.3.r3842.g2eefc943-1
kidletime5.87.0.r329.g348e16c-15.88.0.r330.g88ee5e4-1
kig21.08.3.r3150.g58e0adae-121.08.3.r3151.g7babddb9-1
kimageformats5.87.0.r364.gfb66044-15.88.0.r366.gd3da56b-1
kimap21.08.3.r1136.g6ecda24-121.08.3.r1142.gdcb38ab-1
kinfocenter5.23.3.r1981.g5be3b7f-15.23.3.r1983.g0962f6b5-1
kinit5.87.0.r420.g71fa9fe-15.88.0.r422.gea40949-1
kio5.87.0.r5080.gc4f26e93-15.88.0.r5096.g32df02e2-1
kio-extras21.08.3.r7165.ga197b68a-121.08.3.r7166.gfc086a65-1
kipi-plugins21.08.3.r12067.gede22cc82-121.08.3.r12068.g851648034-1
kirigami25.87.0.r2949.g67cd5f99-15.88.0.r2958.g6e3a5167-1
kitemmodels5.87.0.r566.g5ad1fdb-15.88.0.r568.g036e47c-1
kitemviews5.87.0.r348.g065a809-15.88.0.r350.gbedc6e2-1
kiten21.08.3.r1156.gf9edbac-121.08.3.r1157.g21cfe72-1
kitinerary21.08.3.r2011.gca9c3cc-121.08.3.r2023.g2814c9a-1
kjobwidgets5.87.0.r386.g82170a6-15.88.0.r389.g0ea41c0-1
kjs5.87.0.r344.g4962744-15.88.0.r345.g3c48e79-1
kjsembed5.87.0.r311.g5529fa3-15.88.0.r312.g89ca6b7-1
kldap21.08.3.r904.g4d89193-121.08.3.r906.g621c0aa-1
kleopatra21.08.3.r6044.g2cbbadb4-121.08.3.r6064.gd41b933f-1
klettres21.08.3.r929.g8a3fff3-121.08.3.r931.gdccb4c9-1
kmag21.08.3.r701.gc710811-121.08.3.r702.g7137c9d-1
kmail21.08.3.r26065.g9a5d30a4d-121.08.3.r26108.ge67efaee7-1
kmail-account-wizard21.08.3.r834.g186e742-121.08.3.r836.g28da23f-1
kmailtransport21.08.3.r1681.g21b9c8c-121.08.3.r1684.g9987ced-1
kmbox21.08.3.r552.g2ea0979-121.08.3.r554.g8ed8b7f-1
kmediaplayer5.87.0.r302.gf8e48e5-15.88.0.r303.gdfc9aa0-1
kmenuedit5.23.3.r978.gd45a96f-15.23.3.r979.g226cbaa-1
kmime21.08.3.r1468.g749a036-121.08.3.r1472.gc11600f-1
kmix21.08.3.r2410.gd4956d90-121.08.3.r2411.g724f5b9a-1
kmousetool21.08.3.r403.gf5cd69e-121.08.3.r404.g4590e04-1
knetwalk21.08.3.r669.gb03e4a1-121.08.3.r670.g99f382b-1
knewstuff5.87.0.r1232.g79cb8f54-15.88.0.r1234.g46b49168-1
knights21.08.3.r1073.g6db6467-121.08.3.r1074.g61a38d9-1
knotes21.08.3.r3542.g49aabda2-121.08.3.r3545.g9967d439-1
knotifications5.87.0.r695.gd1f7b41-15.88.0.r696.g45f0304-1
knotifyconfig5.87.0.r360.g53e6f12-15.88.0.r361.g1b9a0a1-1
kolf21.08.3.r1453.g170d53c-121.08.3.r1455.gd2da0d4-1
kolourpaint21.08.3.r2371.g0faef09d-121.08.3.r2374.g56fb4a8e-1
konqueror21.08.3.r15000.gfd8ef32ef-121.08.3.r15001.g028955b8d-1
konsole21.08.3.r8007.g34317ba6-121.08.3.r8048.g7e42fcc2-1
kontact21.08.3.r5417.gdc6fd4e8-121.08.3.r5419.g3c59f5f0-1
kontactinterface21.08.3.r644.ga23d784-121.08.3.r645.g376ac09-1
korganizer21.08.3.r11549.g6289b2007-121.08.3.r11551.g3ba80989e-1
kpackage5.87.0.r709.ge62b778-15.88.0.r711.gca489bc-1
kparts5.87.0.r541.g481299d-15.88.0.r542.gc37ecff-1
kpeople5.87.0.r1353.ge1cfdc0-15.88.0.r1354.g20f8b0d-1
kpimtextedit21.08.3.r1470.g4ae6911-121.08.3.r1476.g6c0f25f-1
kpkpass21.08.3.r247.g55638af-121.08.3.r249.g0f1c9ce-1
kplotting5.87.0.r302.ga33dcde-15.88.0.r303.g505bb37-1
kpmcore21.08.3.r1205.ge9fc875-121.08.3.r1206.g172b76f-1
kpty5.87.0.r348.gb1852d5-15.88.0.r350.gfc8e502-1
kpublictransport21.08.3.r1937.g94cc704a-121.08.3.r1943.g5cd02188-1
kquickcharts5.87.0.r486.g9d1ec29-15.88.0.r488.g32fe4f8-1
krecorder 21.08.r8.ge812d62-1 21.08.r9.g6af8673-1
krfb21.08.3.r1443.g30455f6-121.08.3.r1451.g2c6cb1e-1
kross5.87.0.r342.g578ae99-15.88.0.r343.g14bbf84-1
krunner5.87.0.r695.g98af4e8-15.88.0.r697.g4afed93-1
kscreen5.23.3.r1381.gc6c8b50-15.23.3.r1387.g4198b65-1
kscreenlocker5.23.3.r887.ga267458-15.23.3.r888.gd8eb103-1
kservice5.87.0.r960.g19ceb64-15.88.0.r961.g465f20c-1
ksirk21.08.3.r985.gb4b3d0f-121.08.3.r987.g45e5a1c-1
ksmtp21.08.3.r398.gc732a72-121.08.3.r400.g4ee1f28-1
ksudoku21.08.3.r1070.g220cd86-121.08.3.r1071.ga488b7d-1
ksysguard5.23.3.r3516.g6b0c2ca2-15.23.3.r3517.g1eba0028-1
ktexteditor5.87.0.r2989.gb3d3eb3a-15.88.0.r2996.ge3ec93f2-1
ktextwidgets5.87.0.r422.gd97c4a1-15.88.0.r424.g95e9014-1
ktimer21.08.3.r478.g51760ca-121.08.3.r480.g75b68b3-1
ktnef21.08.3.r678.g71e560f-121.08.3.r682.g7333736-1
ktorrent21.08.3.r2790.ga2939b32-121.08.3.r2792.gc938a739-1
ktouch21.08.3.r2151.g865ba57-121.08.3.r2152.gc1bbb05-1
ktuberling21.08.3.r1018.gb35a474-121.08.3.r1019.g3a04f6e-1
kturtle21.08.3.r1130.g37c45ef-121.08.3.r1131.gbc34937-1
kubrick21.08.3.r379.g5596133-121.08.3.r380.g2fc3b3e-1
kunitconversion5.87.0.r384.ge1714f9-15.88.0.r386.g83ab7a8-1
kwallet5.87.0.r1095.g6d9b433-15.88.0.r1098.g56b030b-1
kwalletmanager21.08.3.r1218.g16a7520-121.08.3.r1219.gb4a9ec6-1
kwave21.08.3.r3753.gd750ce47-121.08.3.r3755.g4176cefc-1
kwayland5.87.0.r1121.g31e2e6c-15.88.0.r1122.gf4f18ac-1
kwayland-server5.23.3.r1417.g22be724-15.23.3.r1424.gbb4fe8e-1
kwidgetsaddons5.87.0.r890.g4e6e81e5-15.88.0.r892.gfa1524d9-1
kwin5.23.2.r20235.g4206046f1-15.23.3.r20368.gf07c66f04-1
kwindowsystem5.87.0.r638.gbf78944-15.88.0.r639.gb9a563b-1
kwinft5.23.3.r19697.gd934df77c-15.23.3.r19775.g43e59510f-1
kwordquiz21.08.3.r1150.g1fdadf4-121.08.3.r1152.gfe38a55-1
kwrite21.08.3.r18444.g6a9295d01-121.08.3.r18449.gd7e4e78b6-1
kwrited5.23.3.r488.gdd0bac8-15.23.3.r489.g52a1aa0-1
kxmlgui5.87.0.r823.g9415aac0-15.88.0.r824.g07255b8a-1
kxmlrpcclient5.87.0.r463.gc6a3dc2a2-15.88.0.r464.g9d36e8a99-1
libakonadi21.08.3.r12641.gd980d752b-121.08.3.r12647.gb55abe809-1
libgravatar21.08.3.r380.g7aad39b-121.08.3.r382.g1ba7083-1
libkdepim21.08.3.r864.g8cd39b5-121.08.3.r866.gb306bc6-1
libkgapi21.08.3.r1317.g59617b2-121.08.3.r1319.g7c286d7-1
libkleo21.08.3.r1000.ga02d98a-121.08.3.r1012.g51f2bd6-1
libkscreen5.23.3.r1603.gc8073ac-15.23.3.r1604.ge755e97-1
libksieve21.08.3.r1611.g3e333526-121.08.3.r1620.g40f50104-1
libksysguard5.23.3.r2320.g29a27e8-15.23.3.r2322.gcabef91-1
libquotient r2141.gfb30d455-1 r2174.g02fa42b8-1
mailcommon21.08.3.r1144.gde9c5f2-121.08.3.r1151.geacdfca-1
mailimporter21.08.3.r483.gff9e4e8-121.08.3.r485.gb3cd987-1
marble21.08.3.r13371.g8732cff23-121.08.3.r13372.ga16a81c30-1
marble-common21.08.3.r13371.g8732cff23-121.08.3.r13372.ga16a81c30-1
marble-qt21.08.3.r13371.g8732cff23-121.08.3.r13372.ga16a81c30-1
maui-clip 2.1.0.r1.g64de394-1 2.1.0.r1.g840cc6f-1
maui-pix 2.1.0.r1.gb334232-1 2.1.0.r2.g3fe0a8e-1
mauikit 2.1.0.r7.g80ff8fe0-12.1.0.r13.ga6a5a7ed-1
mauikit-filebrowsing 2.1.0.r3.g0e78054-1 2.1.0.r5.g5f8a2f1-1
mbox-importer21.08.3.r528.g59e389d-121.08.3.r530.g832b06f-1
messagelib21.08.3.r6278.g9a618f48-121.08.3.r6288.gd2854f8d-1
modemmanager-qt5.87.0.r530.ge7883fc-15.88.0.r531.g52f68cb-1
neochat r1935.g8089e5bd-1 r1953.gbf08303a-1
networkmanager-qt5.87.0.r1126.g0b7b27d-15.88.0.r1127.gd79e9a1-1
okular21.08.3.r9521.gea9e53311-121.08.3.r9524.gc701758f7-1
oxygen-icons1:5.87.0.r5.gbff159d-11:5.88.0.r5.gbff159d-1
oxygen-icons-svg1:5.87.0.r5.gbff159d-11:5.88.0.r5.gbff159d-1
parley21.08.3.r4486.g533eb8ff-121.08.3.r4487.g7784a8d5-1
pico-wizard-git r145.3577d18-3 r145.3577d18-5
pico-wizard-plamo-scripts r145.3577d18-3 r145.3577d18-5
pim-data-exporter21.08.3.r2517.g74b1a139-121.08.3.r2519.g19a6a824-1
pim-sieve-editor21.08.3.r1530.gd7a3901-121.08.3.r1532.gdb7c0ec-1
pimcommon21.07.80.r1139.g8fbfc2f-121.07.80.r1145.gd0ec3a8-1
plank-player r20.5a1e21b-1 r21.cee6654-1
plasma-bigscreen r417.g1a5ec8c-1 r418.gad2b98a-1
plasma-desktop5.23.3.r8766.g55f900647-15.23.3.r8785.gb23f7f80b-1
plasma-dialer-mm 21.08.r11.g2997fa9-1 21.08.r11.g2997fa9-2
plasma-firewall5.23.3.r539.gac3e706-15.23.3.r541.g38ca729-1
plasma-framework5.87.0.r16080.ge7acbf6ab-15.88.0.r16100.g82998d90d-1
plasma-integration5.23.3.r538.gc0ebd87-15.23.3.r539.g25caaed-1
plasma-mobile-nm5.23.1.r3121.gb03c7e8f-15.23.1.r3122.g9196a015-1
plasma-nm5.23.3.r3121.gb03c7e8f-15.23.3.r3122.g9196a015-1
plasma-pa5.23.3.r995.g09829d3-15.23.3.r997.g73f9984-1
plasma-phone-components5.23.3.r1523.gf81271d3-15.23.3.r1526.ga63dcf2d-1
plasma-settings 21.08.r38.g3633e3a-1 21.08.r39.g7f34ffc-1
plasma-systemmonitor5.23.3.r512.g944918c-15.23.3.r514.g09e92cf-1
plasma-thunderbolt5.23.3.r155.g89de525-15.23.3.r156.g579cef8-1
plasma-vault5.23.3.r352.g33ac112-15.23.3.r354.gf8b184b-1
plasma-wayland-session5.23.3.r10922.gbc0e8bd70-15.23.3.r10956.g644588739-1
plasma-workspace5.23.3.r10922.gbc0e8bd70-15.23.3.r10956.g644588739-1
plasma-workspace-wallpapers5.23.3.r299.g6e8f317-15.23.3.r301.g6419f26-1
powerdevil5.23.3.r2494.g927e16a6-15.23.3.r2496.ge82df04a-1
poxml21.08.3.r277.ge2d4dfb-121.08.3.r278.g047949f-1
print-manager21.08.3.r1068.g1e94d30-121.08.3.r1070.g91744cb-1
prison5.87.0.r342.g1f6e04f-15.88.0.r345.ga85739e-1
purpose5.87.0.r907.g4265534-15.88.0.r911.g6c362bf-1
qqc2-desktop-style5.87.0.r544.ga561d4d-15.88.0.r546.gbe2c437-1
sddm-kcm5.23.3.r617.g841aff7-15.23.3.r619.g4b4875c-1
solid5.87.0.r723.g48c606b-15.88.0.r725.g59dc501-1
sonnet5.87.0.r649.g803f059-15.88.0.r658.gb6d376d-1
spacebar 21.08.r25.g2a97a46-1 21.08.r31.g1b168e3-1
spacebar-mm 21.08.r8.g0e6f86f-1 -
spectacle21.08.3.r1209.g164ca64-121.08.3.r1213.g03f5d2c-1
step21.08.3.r1162.g9bb1e19-121.08.3.r1163.gaaee8af-1
syndication5.87.0.r847.ga24df19-15.88.0.r848.gd1aca33-1
syntax-highlighting5.87.0.r1733.gbacdacf6-15.88.0.r1748.g5d62ad3f-1
systemsettings5.23.3.r2563.g70055638-15.23.3.r2566.g266f884f-1
telepathy-kde-text-ui21.08.3.r2026.g4da58cd-121.08.3.r2027.g443bf31-1
threadweaver5.87.0.r518.ga51420d-15.88.0.r520.g50372a3-1
tokodon 21.08.r19.g824b75f-1 21.08.r22.g659c13e-1
umbrello21.08.3.r8270.g8160ef4c8-121.08.3.r8271.g788fcb8b4-1
vvave 2.1.0.r2.g2bbc4ed-1 2.1.0.r4.g3333d67-1
wrapland5.23.3.r1652.gbd2e3208-15.23.3.r1685.g1a201798-1
xdg-desktop-portal-kde5.23.3.r396.gb1712a0-15.23.3.r397.gb07660a-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
