Hello ARM community.
A bit of everything this time.
Kalendar is a new app from KDE
Some highlights:
- Most of our kernels got updated
- Maui Apps are now version 2.1.0
- We added Kalendar to our repository
- Plasma 5.23.3 is now
- Lots of Mobile specific packages got updated
- Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sat Nov 13 15:15:16 CET 2021)
- arm-testing community aarch64: 510 new and 483 removed package(s)
- arm-testing core aarch64: 33 new and 33 removed package(s)
- arm-testing extra aarch64: 690 new and 688 removed package(s)
- arm-testing kde-unstable aarch64: 343 new and 341 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-11-13 2021-11-06
alsa-ucm-pinephone 0.5.1-1 0.5.1-2
breath2-icon-themes 1.0.18-4 1.0.19-1
breath2-wallpaper 1.0.18-4 1.0.19-1
chatty 0.4.0+308+g486c7ae-1 0.4.0+344+g9b4ea67-1
code 1.61.2-1 1.62.2-1
cxxopts 2.2.1-1 -
dkms-rtl8822cs 2020.11.20-1 2020.11.20-2
eg25-manager 0.4.1-1 0.4.1-2
electron 15.3.0-1 15.3.1-1
electron14 14.2.0-1 14.2.1-1
element-desktop 1.9.3-1 1.9.4-1
element-web 1.9.3-1 1.9.4-1
foot 1.9.2-2 1.9.2-3
foot-terminfo 1.9.2-2 1.9.2-3
gnome-calendar-mobile 41.0-2 41.1-1
gnome-calls 41.1-2 41.1-3
gnome-contacts-mobile 40.0-1 41.0-1
gnome-control-center-mobile 41.0-4 41.1-1
hwinfo 21.77-1 21.78-1
libglibutil 1.0.55-1 1.0.57-1
mmsd-tng 1.5-1 1.5+1+g2c0b779-1
mygnuhealth 1.0.4-1 1.0.5-1
numberstation 0.5.0-1 1.0.1-1
phoc 0.9.0+19+gcc74528-1 0.9.0+75+gb579b2a-1
phosh 0.14.0+15+g2460244-1 0.14.0+27+gf768849-1
pico-wizard-git r142.0db2fdb-2 r145.3577d18-2
pico-wizard-plamo-scripts r142.0db2fdb-2 r145.3577d18-2
pinephone-modem-scripts 0.20.8-3 0.20.8-4
pinephonepro-post-install 20211022-2 20211110-1
plasma-mobile-settings 20210606-1 20211105-1
plasma5-themes-breath2 1.0.18-4 1.0.19-1
prusa-slicer 2.3.3-1.1 -
sddm-breath2-theme 1.0.18-4 1.0.19-1
snapd 2.52-1 2.53.1-1
android-headers-28 - 9.0.0-1
android-headers-29 - 10.0.0-1
bigscreen-image-settings-git - r01.8977fdbf-2
kalendar - 0.1.0-1
libhybris-28-glvnd - 1533.fa2bb0c-1
phoc-hybris - 645.81f76ea-1
wlroots-hybris -0.12.0.r60.g035849b0-2
:: Different sync package(s) in repository community aarch64
acme.sh 3.0.0-1 3.0.1-1
ali 0.7.3-1 0.7.5-1
alot 0.9.1-3 0.10-1
ansible-core 2.11.6-1 2.12.0-1
antlr4 4.9.2-1 4.9.3-1
antlr4-runtime 4.9.2-2 4.9.3-2
apache-orc 1.7.0-1 1.7.1-1
arc-gtk-theme 20210412-1 20211018-1
arc-solid-gtk-theme 20210412-1 20211018-1
arch-audit-gtk 0.3.0-1 0.3.1-1
ardour 6.9-1 6.9-2
arduino-cli 0.19.0-1 0.19.3-1
at51 0.4.2-1 1.0.0-1
aurpublish r35.g0f8d149-1 r40.gf88c7ae-2
b3sum 1.1.0-1 1.2.0-1
barrier 2.3.3-1 2.4.0-1
barrier-headless 2.3.3-1 2.4.0-1
bctoolbox 5.0.46-1 5.0.49-1
blender 17:2.93.5-5 17:2.93.5-7
bucklespring 1.5.0-1 1.5.1-1
budgie-desktop 10.5.3-1 10.5.3-2
budgie-extras 1.2.90-1 1.3.0-1
buho 2.0.0-2 2.1.0-1
busybox 1.33.1-1 1.34.1-1
bzrtp 5.0.46-1 5.0.49-1
caddy 2.4.5-1 2.4.6-1
cargo-fuzz 0.10.1-1 0.10.2-1
cargo-generate 0.10.3-1 0.11.0-1
catatonit 0.1.6-1 0.1.7-1
celluloid 0.21-1 0.22-1
certbot 1.20.0-1 1.21.0-1
checkbashisms 2.20.5-1 2.21.4-1
checksec 2.4.0-1 2.5.0-1
chezmoi 2.7.4-1 2.7.5-1
cinnamon 5.0.6-1 5.0.7-1
clash 1.7.1-1 1.8.0-1
clementine1.4.0rc1+755+g568ff1f9d-11.4.0rc1+759+gd033b38c4-1
clojure 1.10.3.998-1 1.10.3.1020-1
cockatrice 2.8.0-5 2.8.0-6
communicator 2.0.0-3 2.1.0-1
conflict 20150705-4 20150705-5
containers-common 0.46.0-3 0.46.0-4
cri-o 1.22.0-1 1.22.1-1
curlie 1.6.2-1 1.6.7-1
dark-reader 4.9.40-1 4.9.42-1
debootstrap 1.0.124-1 1.0.125-1
diffoscope 189-1 192-1
dns-lexicon 3.8.1-1 3.8.2-1
dnsperf 2.7.1-1 2.8.0-1
docker-compose 2.1.0-1 2.1.1-1
doctl 1.66.0-1 1.67.0-1
dovecot-fts-xapian 1.4.13-1 1.5.1-1
duplicity 0.8.20-1 0.8.21-1
evolution-rss 0.3.96-4 0.3.96-5
fanficfare 4.6.0-1 4.7.0-1
fcitx5 5.0.9-1 5.0.10-1
fcitx5-anthy 5.0.6-1 5.0.7-1
fcitx5-chewing 5.0.6-1 5.0.7-1
fcitx5-configtool 5.0.6-1 5.0.7-1
fcitx5-gtk 5.0.8-1 5.0.9-1
fcitx5-hangul 5.0.4-1 5.0.5-1
fcitx5-m17n 5.0.5-1 5.0.6-1
fcitx5-skk 5.0.8-1 5.0.9-1
fcitx5-table-extra 5.0.5-1 5.0.6-1
firefox-dark-reader 4.9.40-1 4.9.42-1
firefox-extension-https-everywhere 2021.4.15-1 2021.7.13-1
firefox-extension-privacybadger 2021.6.8-1 2021.8.17-1
firefox-tree-style-tab 3.8.15-1 3.8.16-1
firewalld 1.0.1-1 1.0.2-1
fluajho 1.6.2-3 1.7.0-1
fzf 0.27.3-1 0.28.0-1
gajim 1.3.2-1 1.3.3-1
gala 6.0.1-1 6.2.1.r86.78a5f881-1
geary 1:40.0-3 1:40.0-4
giada 0.18.2-1 0.19.0-1
gifski 1.5.0-1 1.5.1-1
git-crypt 0.6.0-4 0.6.0-5
glances 3.2.3-1 3.2.3-2
glewlwyd 2.5.4-2 2.5.4-4
go 2:1.17.2-2 2:1.17.3-1
go-ethereum 1.10.11-1 1.10.12-1
gpsd 3.23.1-1 3.23.1-2
granite 6.1.1-1 6.1.2-1
grub-customizer 5.1.0-2 5.1.0-3
gtk-theme-elementary 6.0.0-1 6.1.0-1
haproxy 2.4.7-1 2.4.8-1
helmfile 0.140.1-1 0.142.0-1
htmldoc 1.9.12-1 1.9.13-1
htmlhint 0.16.0-1 0.16.1-1
hugo 0.88.1-1 0.89.2-1
i3status 2.13-3 2.14-1
i3status-rust 0.20.4-1 0.20.6-1
iaito 5.3.1-1 5.3.1-2
iddawc 1.0.1-1 1.1.0-1
igraph 0.9.4-1 0.9.5-1
img2pdf 0.4.2-1 0.4.3-1
index-fm 2.0.0-2 2.1.0-1
innernet 1.5.0-1 1.5.1-1
irrlicht 1.8.4-3 1.8.5-1
irrlicht-docs 1.8.4-3 1.8.5-1
iwd 1.18-1 1.19-2
jacktrip 1.4.0-1 1.4.1-1
jenkins 2.318-1 2.320-1
jmol 14.31.60-1 14.31.61-1
josm 18193-1 18303-1
jsmol 14.31.60-1 14.31.61-1
jupyterlab 3.2.1-1 3.2.3-1
kakoune 2021.10.28-1 2021.11.08-1
kchmviewer 8.0-2 8.0-3
kernel-headers-musl 4.19.88-1 4.19.88-2
kernelshark 1.3-1 2.0.2-1
kmon 1.5.5-1 1.6.0-1
knot 3.1.3-1 3.1.4-1
kubectl-ingress-nginx 0.33.0-2 1.0.4-1
lazygit 0.30.1-1 0.31.3-1
lesspipe 1.89-1 1.91-1
libcurl-compat 7.79.1-1 7.80.0-1
libcurl-gnutls 7.79.1-1 7.80.0-1
libfm-qt 0.17.1-1 1.0.0-1
libharu 2.3.0-4 2.3.0-5
libindi 1.9.2-1 1.9.3-1
liblxqt 0.17.0-1 1.0.0-1
libqtxdg 3.7.1-1 3.8.0-1
libretro-beetle-pce 1093-1 1094-1
libretro-beetle-pce-fast 1148-1 1150-1
libretro-beetle-psx 2571-1 2576-1
libretro-beetle-psx-hw 2571-1 2576-1
libretro-bsnes-hd 47-1 50-1
libretro-core-info 1.9.11-1 1.9.12-1
libretro-dolphin 32999-1 33001-1
libretro-gambatte 935-1 938-1
libretro-genesis-plus-gx 1852-1 1861-1
libretro-melonds 1977-1 1982-1
libretro-mgba 8035-1 8039-1
libretro-play 6768-1 6810-1
libretro-scummvm 93197-1 93200-1
libretro-shaders-slang 839-1 847-1
libretro-snes9x 2037-1 2041-1
libsysstat 0.4.5-1 0.4.6-1
lightdm-pantheon-greeter 6.0.1-1 6.0.1-2
liquidctl 1.7.1-1 1.7.2-1
logcli 2.3.0-2 2.4.1-1
loki 2.3.0-2 2.4.1-1
loki-canary 2.3.0-2 2.4.1-1
lxd 4.19-1 4.20-1
lximage-qt 0.17.0-1 1.0.0-1
lxqt-about 0.17.0-1 1.0.0-1
lxqt-admin 0.17.0-1 1.0.0-1
lxqt-archiver 0.4.0-1 0.5.0-1
lxqt-build-tools 0.9.0-1 0.10.0-1
lxqt-config 0.17.1-1 1.0.0-1
lxqt-globalkeys 0.17.0-1 1.0.0-1
lxqt-notificationd 0.17.0-1 1.0.0-1
lxqt-openssh-askpass 0.17.0-1 1.0.0-1
lxqt-panel 0.17.1-1 1.0.0-1
lxqt-policykit 0.17.0-1 1.0.0-1
lxqt-powermanagement 0.17.1-1 1.0.0-1
lxqt-qtplugin 0.17.0-1 1.0.0-1
lxqt-runner 0.17.0-1 1.0.0-1
lxqt-session 0.17.1-1 1.0.0-1
lxqt-sudo 0.17.0-1 1.0.0-1
lxqt-themes 0.17.0-1 1.0.0-1
mailman 2.1.35-1 2.1.37-1
mailnag-gnome-shell 40.0-1 40.0-2
maui-clip 2.0.0-2 2.1.0-1
maui-nota 2.0.0-2 2.1.0-1
maui-pix 2.0.0-2 2.1.0-1
maui-shelf 2.0.0-2 2.1.0-1
maui-station 2.0.0-2 2.1.0-1
mauikit 2.0.2-1 -
mauikit-accounts 2.0.1-1 2.1.0-1
mauikit-filebrowsing 2.0.2-1 2.1.0-1
mauikit-imagetools 2.0.1-1 2.1.0-1
mauikit-texteditor 2.0.1-1 2.1.0-1
maven 3.8.2-1 3.8.3-1
mediastreamer 5.0.46-1 5.0.49-1
minikube 1.23.2-1 1.24.0-1
mod_passenger 6.0.11-1 6.0.12-1
mosquitto 2.0.13-1 2.0.13-2
mxml 3.2-1 3.3-1
mysql-workbench 8.0.27-1 8.0.27-2
ncdu 1.16-1 1.16-2
ncompress 5.0-1 5.0-2
nemo 5.0.4-1 5.0.5-1
neovim 0.5.1-1 0.5.1-2
nextcloud 22.2.0-1 22.2.2-1
nextcloud-app-contacts 4.0.3-1 4.0.6-1
nextcloud-app-deck 1:1.5.3-1 1:1.5.5-1
nextcloud-client 1:3.3.5-1 1:3.3.6-1
nextcloud-client-cloudproviders 1:3.3.5-1 1:3.3.6-1
nginx-mod-passenger 6.0.11-1 6.0.12-1
notmuch 0.34-1 0.34.1-1
notmuch-mutt 0.34-1 0.34.1-1
notmuch-runtime 0.34-1 0.34.1-1
notmuch-vim 0.34-1 0.34.1-1
npm 8.1.2-1 8.1.3-1
npm-check-updates 11.8.5-1 12.0.0-1
nuitka 0.6.17.5-1 0.6.17.6-1
nvme-cli 1.15-1 1.16-1
offlineimap 7.3.4-1 8.0.0-1
opencascade 7.5.3-2 7.5.3-3
openrct2 0.3.4.1-1 0.3.5-1
openttd 12.0-1 12.1-1
openvdb 8.1.0-1 9.0.0-1
ortp 5.0.46-1 5.0.49-1
osinfo-db 20210903-1 20211013-1
pantheon-applications-menu 2.9.0-1 2.9.1-1
pantheon-calendar 6.0.2-1 6.0.3-2
pantheon-default-settings 6.0.1-1 6.0.2-1
pantheon-files 6.0.3-1 6.0.4-1
pantheon-mail 6.2.0-1 6.2.0-2
pantheon-photos 2.7.1-1 2.7.3-1
pantheon-settings-daemon 1.0.0-1 1.1.0-1
pantheon-videos 2.7.3-1 2.8.0-1
papirus-icon-theme 20211001-1 20211101-1
passff-host 1:1.2.2-1 1:1.2.3-1
pasystray 0.7.1-2 0.8.0-1
pavucontrol-qt 0.17.0-2 1.0.0-2
pcmanfm-qt 0.17.0-1 1.0.0-1
pegtl 3.2.1-1 3.2.2-1
perl-b-keywords 1.22-2 1.23-1
perl-glib-object-introspection 0.047-7.1 0.049-1
perl-ppix-quotelike 0.017-2 0.018-1
perl-ppix-regexp 0.080-2 0.081-1
perl-sys-virt 7.7.0-1 7.8.0-1
plasma5-applets-window-buttons 0.10.0-1 0.10.1-1
plocate 1.1.12-1 1.1.13-1
podman 3.4.1-1 3.4.2-1
podman-docker 3.4.1-1 3.4.2-1
posix 2017-2 2017-3
posix-c-development 2017-2 2017-3
posix-software-development 2017-2 2017-3
posix-user-portability 2017-2 2017-3
posix-xsi 2017-2 2017-3
powerdns 4.5.1-3 4.5.2-1
powerdns-recursor 4.5.6-1 4.5.7-1
prjtrellis 1.0-5 1.1-1
profanity 1:0.11.1-1 1:0.11.1-2
profanity-gtk 1:0.11.1-1 1:0.11.1-2
promtail 2.3.0-2 2.4.1-1
prusa-slicer 2.3.1-3 2.3.3-2
pueue 1.0.3-1 1.0.4-1
pulumi 3.17.0-1 3.17.1-1
puppet 7.12.0-1 7.12.1-1
py3status 3.39-2 3.40-1
pyright 1.1.184-1 1.1.187-1
python-acme 1.20.0-1 1.21.0-1
python-antlr4 4.9.2-1 4.9.3-1
python-arrow 1.1.1-1 1.2.1-1
python-astroid 2.8.4-1 2.8.5-1
python-aws-sam-translator 1.39.0-1 1.40.0-1
python-bracex 2.2-1 2.2.1-1
python-characteristic 14.3.0-12 14.3.0-13
python-clikit 0.6.2-1 0.6.2-2
python-cogapp 3.1.0-1 3.2.0-1
python-colorlog 6.4.1-1 6.5.0-1
python-covdefaults 1.2.0-2 2.0.0-1
python-coverage 5.5-3 6.1.1-1
python-cytoolz 0.11.0-3.1 0.11.2-1
python-databases 0.4.3-1 0.5.3-1
python-dbus-deviation 0.6.1-1 0.6.1-2
python-dephell-setuptools 0.2.1-4 0.2.4-1
python-dephell-shells 0.1.3-5 0.1.5-1
python-django-extensions 3.1.3-1 3.1.5-1
python-dotenv 0.19.1-1 0.19.2-1
python-factory-boy 3.2.0-1 3.2.1-1
python-fido2 0.9.2-1 0.9.3-1
python-fields 5.0.0-10 5.0.0-11
python-fissix 19.2b1-5 21.6.6-1
python-freezegun 0.3.15-4 0.3.15-5
python-genshi 0.7.5-1 0.7.5-2
python-google-api-core 2.1.0-1 2.2.2-1
python-google-api-python-client 2.24.0-1 2.30.0-1
python-hidapi 0.10.1-1 0.11.0.2-1
python-html5lib 1.1-6 1.1-7
python-identify 2.3.3-1 2.3.5-1
python-imagesize 1.2.0-4 1.3.0-1
python-jellyfish 0.8.8-1 0.8.9-1
python-jinja 3.0.2-1 3.0.3-1
python-k5test 0.10.0-1 0.10.1-1
python-keyrings-alt 1:4.0.2-1 1:4.1.0-1
python-libusb1 1.9.3-1 2.0.1-1
python-markdown 3.3.4-1 3.3.4-2
python-matplotlib-inline 0.1.2-1 0.1.3-1
python-mocket 3.9.40-2 3.10.0-1
python-moto 2.2.10-1 2.2.13-1
python-mpmath 1.2.1-2 1.2.1-3
python-multidict 5.1.0-1 5.2.0-1
python-myst-parser 0.15.1-1 0.15.2-1
python-nltk 3.6.4-1 3.6.5-1
python-nmigen-boards r193.cb18fc5-1 r195.bd7fdd3-1
python-pandas 1.3.3-1 1.3.4-1
python-pbr 5.6.0-1 5.7.0-1
python-peewee 3.14.4-1 3.14.8-1
python-pg8000 1.22.0-1 1.22.1-1
python-phonenumbers 8.12.36-1 8.12.37-1
python-pikepdf 4.0.0-1 4.0.1-1
python-pipenv 2021.5.29-1 2021.11.9-1
python-poetry-core 1.0.3-1 1.0.7-1
python-process-tests 2.1.2-2 2.1.2-3
python-prompt_toolkit 3.0.20-1 3.0.22-1
python-psycopg2 2.9.1-1 2.9.2-1
python-pybluez 0.23-1 0.23-2
python-pycodestyle 2.7.0-2 2.8.0-1
python-pyfakefs 4.5.1-1 4.5.3-1
python-pyflakes 2.3.1-2 2.4.0-1
python-pygame 2.0.1-3 2.1.0-1
python-pylev 1.4.0-1 1.4.0-2
python-pypng 0.0.20-3 0.0.21-1
python-pysol_cards 0.12.0-1 0.14.2-1
python-pytest-asyncio 0.15.1-1 0.16.0-1
python-pytest-cov 2.12.1-3 2.12.1-4
python-pytest-isort 2.0.0-2 2.0.0-3
python-pythran 0.10.0-1 0.10.0-2
python-pytools 2021.2.8-1 2021.2.9-1
python-pyvcd 0.2.4-1 0.3.0-1
python-responses 0.14.0-1 0.15.0-1
python-rich 10.12.0-1 10.13.0-1
python-rope 0.20.1-1 0.21.1-1
python-scipy 1.7.1-1 1.7.2-1
python-shellingham 1.4.0-1 1.4.0-2
python-sphinx-click 3.0.1-1 3.0.2-1
python-sure 1.4.11-7 2.0.0-1
python-tasklib 2.4.0-1 2.4.3-1
python-toolz 0.11.1-3 0.11.2-1
python-typed-ast 1.4.3-1 1.5.0-1
python-u-msgpack 2.7.1-1 2.7.1-2
python-urwidtrees 1.0.3-5 1.0.3-6
python-wheezy-template 3.1.0-1 3.1.0-2
python-xarray 0.19.0-1 0.20.1-1
python-yarl 1.6.3-1 1.7.2-1
python2-freezegun 0.3.15-4 0.3.15-5
python2-html5lib 1.1-6 1.1-7
python2-pbr 5.6.0-1 5.7.0-1
python2-u-msgpack 2.7.1-1 2.7.1-2
qt6ct 0.5-1 0.5-2
qterminal 0.17.0-1 1.0.0-1
qtermwidget 0.17.0-2 1.0.0-1
rapydscript-ng 0.7.21-1 0.7.21-2
raylib 3.7.0-2 4.0.0-1
rclone 1.56.2-1 1.57.0-1
rebar 1:2.6.4-2 1:2.6.4-3
reprotest 0.7.16-1 0.7.18-1
restic 0.12.1-1 0.12.1-2
retroarch 1.9.11-1 1.9.13.1-1
retroarch-assets-glui 1:391-1 1:393-1
retroarch-assets-ozone 1:391-1 1:393-1
retroarch-assets-xmb 1:391-1 1:393-1
rkcommon 1.7.0-1 1.8.0-1
rspamd 3.0-1 3.1-1
rubberband 1.9.2-1 2.0.0-1
ruby-activesupport 6.1.3.2-1 6.1.4.1-1
ruby-i18n 1.8.1-3 1.8.11-1
rust-analyzer 20211101-1 20211108-1
scite 5.1.4-1 5.1.5-1
screengrab 2.2.0-1 2.3.0-1
scrot 1.6-2 1.7-1
sequoia-sq 0.25.0-1 0.25.0-2
serverless 2.64.1-1 2.66.1-1
sfizz 1.0.0-1 1.1.1-1
shellharden 4.1.2-1 4.1.3-1
shotcut 21.08.29-1 21.10.31-1
sigdigger 0.1.0-1 0.1.0-2
simple-scan 40.1-1 40.6-1
singularity-container 3.8.3-1 3.8.4-1
skopeo 1.5.0-1 1.5.1-1
solr 8.8.2-1 8.10.1-3
sonic-pi 3.2.2-3 3.3.1-1
sssd 2.6.0-1 2.6.1-1
starship 0.58.0-2 1.0.0-1
staticcheck 2021.1.1-1 2021.1.2-1
strongswan 5.9.3-1 5.9.4-1
switchboard-plug-display 2.3.1-1 2.3.2-1
switchboard-plug-locale 2.5.4-1 2.5.5-1
switchboard-plug-online-accounts 6.2.1-1 6.2.1-2
switchboard-plug-user-accounts 2.4.0-1 2.4.1-1
swtpm 0.6.1-1 0.7.0-1
sx 2.1.7-1 2.1.7-2
syncthing 1.18.3-1 1.18.4-1
syncthing-relaysrv 1.18.3-1 1.18.4-1
telegram-desktop 3.1.11-2 3.2.3-1
termdown 1.17.0-4 1.18.0-1
terragrunt 0.35.6-1 0.35.10-1
testssl.sh 3.0.5-1 3.0.6-1
texstudio 4.0.3-1 4.0.4-1
thunderbird-dark-reader 4.9.40-1 4.9.42-1
thunderbird-extension-enigmail 2.2.4-1 -
timezonemap 0.4.5.1-1 0.4.5.1-2
todoman 4.0.0-2 4.0.1-1
trace-cmd 2.9.5-1 2.9.6-1
ts-node 10.3.1-1 10.4.0-1
ttc-iosevka 10.3.4-1 11.0.1-1
ttc-iosevka-aile 10.3.4-1 11.0.1-1
ttc-iosevka-curly 10.3.4-1 11.0.1-1
ttc-iosevka-curly-slab 10.3.4-1 11.0.1-1
ttc-iosevka-etoile 10.3.4-1 11.0.1-1
ttc-iosevka-slab 10.3.4-1 11.0.1-1
ttc-iosevka-ss01 10.3.4-1 11.0.1-1
ttc-iosevka-ss02 10.3.4-1 11.0.1-1
ttc-iosevka-ss03 10.3.4-1 11.0.1-1
ttc-iosevka-ss04 10.3.4-1 11.0.1-1
ttc-iosevka-ss05 10.3.4-1 11.0.1-1
ttc-iosevka-ss06 10.3.4-1 11.0.1-1
ttc-iosevka-ss07 10.3.4-1 11.0.1-1
ttc-iosevka-ss08 10.3.4-1 11.0.1-1
ttc-iosevka-ss09 10.3.4-1 11.0.1-1
ttc-iosevka-ss10 10.3.4-1 11.0.1-1
ttc-iosevka-ss11 10.3.4-1 11.0.1-1
ttc-iosevka-ss12 10.3.4-1 11.0.1-1
ttc-iosevka-ss13 10.3.4-1 11.0.1-1
ttc-iosevka-ss14 10.3.4-1 11.0.1-1
ttc-iosevka-ss15 10.3.4-1 11.0.1-1
ttc-iosevka-ss16 10.3.4-1 11.0.1-1
ttc-iosevka-ss17 10.3.4-1 11.0.1-1
ttc-iosevka-ss18 10.3.4-1 11.0.1-1
ttf-ionicons 5.5.4-1 6.0.0-1
ttf-sarasa-gothic 0.34.7-1 0.35.0-1
ulfius 2.7.4-1 2.7.6-1
urlwatch 2.23-3 2.24-1
v2ray-domain-list-community 20211025125330-1 20211107153452-1
v2ray-geoip 202110311208-1 202111040028-1
vim-gitgutter 708.c27bfab-1 768.256702d-1
vim-surround 2.1-4 2.2-1
vscode-css-languageserver 1.61.0-1 1.62.0-1
vscode-html-languageserver 1.61.0-1 1.62.0-1
vscode-json-languageserver 1.61.0-1 1.62.0-1
vtk 9.0.3-3 9.1.0-2
vultr-cli 2.9.0-1 2.10.0-1
vvave 2.0.0-2 2.1.0-1
wallutils 5.9.0-3 5.10.0-1
wingpanel 3.0.1-1 3.0.1-4
wingpanel-indicator-datetime 2.3.0-1 2.3.1-1
wingpanel-indicator-network 2.3.0-1 2.3.1-1
wingpanel-indicator-notifications 6.0.1-1 6.0.2-1
wpscan 1:3.8.19-3.1 1:3.8.20-1
wt 4.5.0-3 4.5.0-4
xdg-desktop-portal-wlr 0.4.0-3 0.5.0-1
xf86-video-qxl 0.1.5.r16.g52c421c-1 0.1.5.r16.g52c421c-2
xplr 0.15.2-1 0.16.3-1
yaml-language-server 1.1.0-1 1.2.0-1
yggdrasil 0.4.0-1 0.4.2-1
yosys 0.10-2.1 0.11-1
you-get 0.4.1545-1 0.4.1555-1
yubioath-desktop 5.0.5-1 5.1.0-2
zanshin 0.5.71-3 -
zaproxy 2.10.0-1 2.11.0-1
zellij 0.19.0-2 0.20.1-1
zerotier-one 1.6.6-1 1.8.2-1
cxxopts - 3.0.0-1
dbmate - 1.12.1-2
gsocket - 1.4.33-1
lttng-ust2.12 - 2.12.0-2
pop-gtk-theme - 5.4.5-2
pop-icon-theme -2.1.0.r2415.a5a10f9725-1
python-aiosignal - 1.2.0-1
python-bcj-cffi - 0.5.1-2
python-frozenlist - 1.2.0-1
python-imaplib2 - 3.6-2
python-proxy.py - 2.3.1-1
python-python-socks - 1.2.4-1
python-sarif-om - 1.0.4-1
ropr - 0.2.14-1
sscg - 3.0.1-1
stochas - 1.3.5-1
wails - 1.16.8-1
wasi-compiler-rt - 12.0.1-1
wasi-libc++ - 12.0.1-1
wasi-libc++abi - 12.0.1-1
wasi-libc - 0+222+ad51334-1
wasmtime - 0.31.0-1
zsa-udev - 2.1.3-2
zsa-wally - 2.1.3-2
zsa-wally-cli - 2.0.1-3
:: Different overlay package(s) in repository core aarch64
linux 5.15.1-3 5.15.2-1
linux-headers 5.15.1-3 5.15.2-1
linux-pinephone 5.15.0-1 5.15.2-1
linux-pinephone-headers 5.15.0-1 5.15.2-1
linux-pinephonepro 5.14.14-1 5.15.2-1
linux-pinephonepro-headers 5.14.14-1 5.15.2-1
linux-rpi4 5.10.76-2 5.10.78-1
linux-rpi4-headers 5.10.76-2 5.10.78-1
linux-rpi4-mainline 5.15.0-3 5.15.1-1
linux-rpi4-mainline-headers 5.15.0-3 5.15.1-1
raspberrypi-bootloader 20211102-1 20211108-1
raspberrypi-bootloader-x 20211102-1 20211108-1
:: Different sync package(s) in repository core aarch64
amd-ucode 20210919.d526e04-1 20211027.1d00989-1
btrfs-progs 5.14.2-1 5.15-1
curl 7.79.1-1 7.80.0-1
glib2 2.70.0-2.1 2.70.1-1
glib2-docs 2.70.0-2.1 2.70.1-1
gnupg 2.2.29-1 2.2.32-1
iana-etc 20210903-1 20211025-1
iw 5.9-1 5.16-1
libcap 2.59-1 2.60-1
libgpg-error 1.42-1 1.43-1
libpipeline 1.5.3-1 1.5.4-1
libseccomp 2.5.2-1 2.5.3-1
libtasn1 4.17.0-1 4.18.0-1
linux-firmware 20210919.d526e04-1 20211027.1d00989-1
ncurses 6.2-2 6.3-1
pinentry 1.1.1-1 1.2.0-1
sudo 1.9.8.p2-1 1.9.8.p2-1.1
systemd 249.5-3 249.6-3
systemd-libs 249.5-3 249.6-3
systemd-resolvconf 249.5-3 249.6-3
systemd-sysvcompat 249.5-3 249.6-3
:: Different overlay package(s) in repository extra aarch64
kwin 5.23.2-1.2 -
libpamac 11.1.3-1 11.2.0-1
libpamac-flatpak-plugin 11.1.3-1 11.2.0-1
libpamac-snap-plugin 11.1.3-1 11.2.0-1
mesa-git22.0.0_devel.146711.68a62226e4d-122.0.0_devel.146897.c4d904101c0-1
pamac-cli 10.2.2-6 10.3.0-1
pamac-gnome-integration 10.2.2-6 10.3.0-1
pamac-gtk 10.2.2-6 10.3.0-1
plasma-mobile-nm 5.23.2-1 5.23.3-1
plasma-nano 5.23.2-1 5.23.3-1
plasma-phone-components 5.23.2-2 5.23.3-1
python-pyqt5 5.15.5-1 -
qqc2-breeze-style 5.23.2-1 5.23.3-1
:: Different sync package(s) in repository extra aarch64
adwaita-icon-theme 40.1.1-1 41.0-1
akonadi 21.08.2-1 21.08.3-1
akonadi-calendar 21.08.2-1 21.08.3-1
akonadi-calendar-tools 21.08.2-1 21.08.3-1
akonadi-contacts 21.08.2-1 21.08.3-1
akonadi-import-wizard 21.08.2-1 21.08.3-1
akonadi-mime 21.08.2-1 21.08.3-1
akonadi-notes 21.08.2-1 21.08.3-1
akonadi-search 21.08.2-1 21.08.3-1
akonadiconsole 21.08.2-1 21.08.3-1
akregator 21.08.2-1 21.08.3-1
alsa-card-profiles 1:0.3.39-1 1:0.3.40-1
analitza 21.08.2-1 21.08.3-1
ark 21.08.2-1 21.08.3-1
artikulate 21.08.2-1 21.08.3-1
at-spi2-core 2.40.3-1 2.42.0-1
audiocd-kio 21.08.2-1 21.08.3-1
avogadrolibs 1.95.1-3 1.95.1-6
baloo-widgets 21.08.2-1 21.08.3-1
blinken 21.08.2-1 21.08.3-1
bluedevil 1:5.23.2-1 1:5.23.3-1
bomber 21.08.2-1 21.08.3-1
bovo 21.08.2-1 21.08.3-1
breeze 5.23.2-1 5.23.3-1
breeze-grub 5.23.2-1 5.23.3-1
breeze-gtk 5.23.2-1 5.23.3-1
calendarsupport 21.08.2-1 21.08.3-1
cantor 21.08.2-1 21.08.3-1
cervisia 21.08.2-1 21.08.3-1
cheese 3.38.0-1 41.0-2
clamav 0.104.0-1 0.104.1-1
composer 2.1.11-1 2.1.12-1
cups 1:2.3.3op2-3 1:2.3.3op2-4
discover 5.23.2-1 5.23.3-2
dolphin 21.08.2-1 21.08.3-1
dolphin-plugins 21.08.2-1 21.08.3-1
dragon 21.08.2-1 21.08.3-1
drkonqi 5.23.2-1 5.23.3-1
elisa 21.08.2-1 21.08.3-1
ell 0.44-1 0.45-1
epiphany 40.3-1 41.0-1
eventviews 21.08.2-1 21.08.3-1
evince 40.4-1 41.2-1
evolution 3.40.4-1 3.42.1-1
evolution-bogofilter 3.40.4-1 3.42.1-1
evolution-data-server 3.40.4-1 3.42.1-1
evolution-ews 3.40.4-1 3.42.1-1
evolution-spamassassin 3.40.4-1 3.42.1-1
ffmpeg 2:4.4-6 2:4.4.1-1
ffmpegthumbs 21.08.2-1 21.08.3-1
filelight 21.08.2-1 21.08.3-1
firefox 94.0-1 94.0.1-1
firefox-i18n-ach 94.0-1 94.0.1-1
firefox-i18n-af 94.0-1 94.0.1-1
firefox-i18n-an 94.0-1 94.0.1-1
firefox-i18n-ar 94.0-1 94.0.1-1
firefox-i18n-ast 94.0-1 94.0.1-1
firefox-i18n-az 94.0-1 94.0.1-1
firefox-i18n-be 94.0-1 94.0.1-1
firefox-i18n-bg 94.0-1 94.0.1-1
firefox-i18n-bn 94.0-1 94.0.1-1
firefox-i18n-br 94.0-1 94.0.1-1
firefox-i18n-bs 94.0-1 94.0.1-1
firefox-i18n-ca 94.0-1 94.0.1-1
firefox-i18n-ca-valencia 94.0-1 94.0.1-1
firefox-i18n-cak 94.0-1 94.0.1-1
firefox-i18n-cs 94.0-1 94.0.1-1
firefox-i18n-cy 94.0-1 94.0.1-1
firefox-i18n-da 94.0-1 94.0.1-1
firefox-i18n-de 94.0-1 94.0.1-1
firefox-i18n-dsb 94.0-1 94.0.1-1
firefox-i18n-el 94.0-1 94.0.1-1
firefox-i18n-en-ca 94.0-1 94.0.1-1
firefox-i18n-en-gb 94.0-1 94.0.1-1
firefox-i18n-en-us 94.0-1 94.0.1-1
firefox-i18n-eo 94.0-1 94.0.1-1
firefox-i18n-es-ar 94.0-1 94.0.1-1
firefox-i18n-es-cl 94.0-1 94.0.1-1
firefox-i18n-es-es 94.0-1 94.0.1-1
firefox-i18n-es-mx 94.0-1 94.0.1-1
firefox-i18n-et 94.0-1 94.0.1-1
firefox-i18n-eu 94.0-1 94.0.1-1
firefox-i18n-fa 94.0-1 94.0.1-1
firefox-i18n-ff 94.0-1 94.0.1-1
firefox-i18n-fi 94.0-1 94.0.1-1
firefox-i18n-fr 94.0-1 94.0.1-1
firefox-i18n-fy-nl 94.0-1 94.0.1-1
firefox-i18n-ga-ie 94.0-1 94.0.1-1
firefox-i18n-gd 94.0-1 94.0.1-1
firefox-i18n-gl 94.0-1 94.0.1-1
firefox-i18n-gn 94.0-1 94.0.1-1
firefox-i18n-gu-in 94.0-1 94.0.1-1
firefox-i18n-he 94.0-1 94.0.1-1
firefox-i18n-hi-in 94.0-1 94.0.1-1
firefox-i18n-hr 94.0-1 94.0.1-1
firefox-i18n-hsb 94.0-1 94.0.1-1
firefox-i18n-hu 94.0-1 94.0.1-1
firefox-i18n-hy-am 94.0-1 94.0.1-1
firefox-i18n-ia 94.0-1 94.0.1-1
firefox-i18n-id 94.0-1 94.0.1-1
firefox-i18n-is 94.0-1 94.0.1-1
firefox-i18n-it 94.0-1 94.0.1-1
firefox-i18n-ja 94.0-1 94.0.1-1
firefox-i18n-ka 94.0-1 94.0.1-1
firefox-i18n-kab 94.0-1 94.0.1-1
firefox-i18n-kk 94.0-1 94.0.1-1
firefox-i18n-km 94.0-1 94.0.1-1
firefox-i18n-kn 94.0-1 94.0.1-1
firefox-i18n-ko 94.0-1 94.0.1-1
firefox-i18n-lij 94.0-1 94.0.1-1
firefox-i18n-lt 94.0-1 94.0.1-1
firefox-i18n-lv 94.0-1 94.0.1-1
firefox-i18n-mk 94.0-1 94.0.1-1
firefox-i18n-mr 94.0-1 94.0.1-1
firefox-i18n-ms 94.0-1 94.0.1-1
firefox-i18n-my 94.0-1 94.0.1-1
firefox-i18n-nb-no 94.0-1 94.0.1-1
firefox-i18n-ne-np 94.0-1 94.0.1-1
firefox-i18n-nl 94.0-1 94.0.1-1
firefox-i18n-nn-no 94.0-1 94.0.1-1
firefox-i18n-oc 94.0-1 94.0.1-1
firefox-i18n-pa-in 94.0-1 94.0.1-1
firefox-i18n-pl 94.0-1 94.0.1-1
firefox-i18n-pt-br 94.0-1 94.0.1-1
firefox-i18n-pt-pt 94.0-1 94.0.1-1
firefox-i18n-rm 94.0-1 94.0.1-1
firefox-i18n-ro 94.0-1 94.0.1-1
firefox-i18n-ru 94.0-1 94.0.1-1
firefox-i18n-si 94.0-1 94.0.1-1
firefox-i18n-sk 94.0-1 94.0.1-1
firefox-i18n-sl 94.0-1 94.0.1-1
firefox-i18n-son 94.0-1 94.0.1-1
firefox-i18n-sq 94.0-1 94.0.1-1
firefox-i18n-sr 94.0-1 94.0.1-1
firefox-i18n-sv-se 94.0-1 94.0.1-1
firefox-i18n-ta 94.0-1 94.0.1-1
firefox-i18n-te 94.0-1 94.0.1-1
firefox-i18n-th 94.0-1 94.0.1-1
firefox-i18n-tl 94.0-1 94.0.1-1
firefox-i18n-tr 94.0-1 94.0.1-1
firefox-i18n-trs 94.0-1 94.0.1-1
firefox-i18n-uk 94.0-1 94.0.1-1
firefox-i18n-ur 94.0-1 94.0.1-1
firefox-i18n-uz 94.0-1 94.0.1-1
firefox-i18n-vi 94.0-1 94.0.1-1
firefox-i18n-xh 94.0-1 94.0.1-1
firefox-i18n-zh-cn 94.0-1 94.0.1-1
firefox-i18n-zh-tw 94.0-1 94.0.1-1
fmt 8.0.1-1 8.0.1-2
folks 0.14-5 0.15.3+6+gdb1de866-1
foomatic-db 3:20211009-1 3:20211106-1
foomatic-db-nonfree 3:20211009-1 3:20211106-1
foomatic-db-nonfree-ppds 3:20211009-1 3:20211106-1
foomatic-db-ppds 3:20211009-1 3:20211106-1
fprintd 1.94.0-1 1.94.1-1
gc 8.2.0-1 8.2.0-2
gcr 3.40.0-1 3.41.0-1
gdm 40.1-2 41.0-1
ghex 3.18.4-2 3.41.0-1
gjs 2:1.68.3-2.1 2:1.70.0-1
gn 0.1934.69ec4fca-1 0.1938.0153d369-1
gnome-backgrounds 40.1-1 41.0-1
gnome-builder 3.40.1-1 41.1-2
gnome-calculator 40.1-1 41.0-1
gnome-calendar 40.2-1 41.1-1
gnome-characters 40.0-1 41.0-1
gnome-chess 40.1-1 41.1-1
gnome-clocks 40.0-2 41.0-1
gnome-contacts 40.0-1 41.0-2
gnome-control-center 40.0-1 41.1-2
gnome-desktop 1:40.4-1 1:41.1-1
gnome-font-viewer 40.0-1 41.0-1
gnome-maps 40.4-1 41.1-2
gnome-music 1:40.1.1-1 1:41.0-1
gnome-remote-desktop 40.1-1 41.1-1
gnome-settings-daemon 40.0.1-2 41.0-1
gnome-shell 1:40.5-1 1:41.1-1
gnome-shell-extensions 40.4-1 41.0-1
gnome-software 40.4-1 41.1-1
gnome-software-packagekit-plugin 40.4-1 41.1-1
gnome-system-monitor 40.1-1 41.0-1
gnome-terminal 3.40.3-1 3.42.1-1
gnome-user-docs 40.4-1 41.0-1
gnome-weather 40.1-1 41.0-1
gnote 40.1-1 41.1-1
gpaste 3.40.2-1 3.42.1-1
granatier 21.08.2-1 21.08.3-1
grantlee-editor 21.08.2-1 21.08.3-1
grantleetheme 21.08.2-1 21.08.3-1
gst-plugin-pipewire 1:0.3.39-1 1:0.3.40-1
gucharmap 13.0.8-1 14.0.1-1
gvim 8.2.3441-1 8.2.3582-1
gwenview 21.08.2-1 21.08.3-1
harfbuzz 3.1.0-1 3.1.1-1
harfbuzz-icu 3.1.0-1 3.1.1-1
hitori 3.38.2-1 3.38.3-1
hplip 1:3.21.8-1 1:3.21.10-1
icedtea-web 1.8.6-1 1.8.8-1
icedtea-web-doc 1.8.6-1 1.8.8-1
incidenceeditor 21.08.2-1 21.08.3-1
iso-codes 4.7.0-1 4.8.0-1
itinerary 21.08.2-1 21.08.3-1
itstool 1:2.0.6-2 1:2.0.7-1
jdk-openjdk 17.u35-1 17.0.1.u12-1
jdk11-openjdk 11.0.12.u7-1 11.0.13.u8-1
jre-openjdk 17.u35-1 17.0.1.u12-1
jre-openjdk-headless 17.u35-1 17.0.1.u12-1
jre11-openjdk 11.0.12.u7-1 11.0.13.u8-1
jre11-openjdk-headless 11.0.12.u7-1 11.0.13.u8-1
juk 21.08.2-1 21.08.3-1
k3b 1:21.08.2-1 1:21.08.3-1
kaccounts-integration 21.08.2-1 21.08.3-1
kaccounts-providers 21.08.2-1 21.08.3-1
kactivitymanagerd 5.23.2-1 5.23.3-1
kaddressbook 21.08.2-1 21.08.3-1
kajongg 21.08.2-1 21.08.3-1
kalarm 21.08.2-1 21.08.3-1
kalarmcal 21.08.2-1 21.08.3-1
kalgebra 21.08.2-1 21.08.3-1
kalzium 21.08.2-2 21.08.3-2
kamera 21.08.2-1 21.08.3-1
kamoso 21.08.2-1 21.08.3-1
kanagram 21.08.2-1 21.08.3-1
kapman 21.08.2-1 21.08.3-1
kapptemplate 21.08.2-1 21.08.3-1
kate 21.08.2-2 21.08.3-1
katomic 21.08.2-1 21.08.3-1
kbackup 21.08.2-1 21.08.3-1
kblackbox 21.08.2-1 21.08.3-1
kblocks 21.08.2-1 21.08.3-1
kbounce 21.08.2-1 21.08.3-1
kbreakout 21.08.2-1 21.08.3-1
kbruch 21.08.2-1 21.08.3-1
kcachegrind 21.08.2-1 21.08.3-1
kcachegrind-common 21.08.2-1 21.08.3-1
kcalc 21.08.2-1 21.08.3-1
kcalutils 21.08.2-1 21.08.3-1
kcharselect 21.08.2-1 21.08.3-1
kcolorchooser 21.08.2-1 21.08.3-1
kcron 21.08.2-1 21.08.3-1
kde-cli-tools 5.23.2-1 5.23.3-1
kde-dev-scripts 21.08.2-1 21.08.3-1
kde-dev-utils 21.08.2-1 21.08.3-1
kde-gtk-config 5.23.2-1 5.23.3-1
kdebugsettings 21.08.2-1 21.08.3-1
kdeconnect 21.08.2-1 21.08.3-1
kdecoration 5.23.2-1 5.23.3-1
kdeedu-data 21.08.2-1 21.08.3-1
kdegraphics-mobipocket 21.08.2-1 21.08.3-1
kdegraphics-thumbnailers 21.08.2-1 21.08.3-1
kdenetwork-filesharing 21.08.2-1 21.08.3-1
kdenlive 21.08.2-1 21.08.3-1
kdepim-addons 21.08.2-1 21.08.3-1
kdepim-runtime 21.08.2-1 21.08.3-1
kdeplasma-addons 5.23.2-1 5.23.3-1
kdesdk-kioslaves 21.08.2-1 21.08.3-1
kdesdk-thumbnailers 21.08.2-1 21.08.3-1
kdf 21.08.2-1 21.08.3-1
kdialog 21.08.2-1 21.08.3-1
kdiamond 21.08.2-1 21.08.3-1
keditbookmarks 21.08.2-1 21.08.3-1
kfind 21.08.2-1 21.08.3-1
kfloppy 21.08.2-1 21.08.3-1
kfourinline 21.08.2-1 21.08.3-1
kgamma5 5.23.2-1 5.23.3-1
kgeography 21.08.2-1 21.08.3-1
kget 21.08.2-1 21.08.3-1
kgoldrunner 21.08.2-1 21.08.3-1
kgpg 21.08.2-1 21.08.3-1
khangman 21.08.2-1 21.08.3-1
khelpcenter 21.08.2-1 21.08.3-1
khotkeys 5.23.2-1 5.23.3-1
kidentitymanagement 21.08.2-1 21.08.3-1
kig 21.08.2-1 21.08.3-1
kigo 21.08.2-1 21.08.3-1
killbots 21.08.2-1 21.08.3-1
kimagemapeditor 21.08.2-1 21.08.3-1
kimap 21.08.2-1 21.08.3-1
kinfocenter 5.23.2-1 5.23.3-1
kio-extras 21.08.2-1 21.08.3-1
kio-gdrive 21.08.2-1 21.08.3-1
kipi-plugins 21.08.2-1 21.08.3-1
kirigami-gallery 21.08.2-1 21.08.3-1
kiriki 21.08.2-1 21.08.3-1
kismet 2021_08_R1-1 2021_08_R1-2
kiten 21.08.2-1 21.08.3-1
kitinerary 21.08.2-3 21.08.3-1
kjumpingcube 21.08.2-1 21.08.3-1
kldap 21.08.2-1 21.08.3-1
kleopatra 21.08.2-1 21.08.3-1
klettres 21.08.2-1 21.08.3-1
klickety 21.08.2-1 21.08.3-1
klines 21.08.2-1 21.08.3-1
kmag 21.08.2-1 21.08.3-1
kmahjongg 21.08.2-1 21.08.3-1
kmail 21.08.2-1 21.08.3-1
kmail-account-wizard 21.08.2-1 21.08.3-1
kmailtransport 21.08.2-1 21.08.3-1
kmbox 21.08.2-1 21.08.3-1
kmenuedit 5.23.2-1 5.23.3-1
kmime 21.08.2-1 21.08.3-1
kmines 21.08.2-1 21.08.3-1
kmix 21.08.2-1 21.08.3-1
kmousetool 21.08.2-1 21.08.3-1
kmouth 21.08.2-1 21.08.3-1
kmplot 21.08.2-1 21.08.3-1
knavalbattle 21.08.2-1 21.08.3-1
knetwalk 21.08.2-1 21.08.3-1
knights 21.08.2-1 21.08.3-1
knotes 21.08.2-1 21.08.3-1
kolf 21.08.2-1 21.08.3-1
kollision 21.08.2-1 21.08.3-1
kolourpaint 21.08.2-1 21.08.3-1
kompare 21.08.2-1 21.08.3-1
konqueror 21.08.2-1 21.08.3-1
konquest 21.08.2-1 21.08.3-1
konsole 21.08.2-1 21.08.3-1
kontact 21.08.2-1 21.08.3-1
kontactinterface 21.08.2-1 21.08.3-1
kontrast 21.08.2-1 21.08.3-1
konversation 21.08.2-1 21.08.3-1
kopeninghours 21.08.2-1 21.08.3-1
kopete 21.08.2-1 21.08.3-1
korganizer 21.08.2-1 21.08.3-1
kosmindoormap 21.08.2-1 21.08.3-1
kpat 21.08.2-1 21.08.3-1
kpimtextedit 21.08.2-1 21.08.3-1
kpkpass 21.08.2-1 21.08.3-1
kpmcore 21.08.2-1 21.08.3-1
kpublictransport 21.08.2-1 21.08.3-1
kqtquickcharts 21.08.2-1 21.08.3-1
krdc 21.08.2-1 21.08.3-1
kreversi 21.08.2-1 21.08.3-1
krfb 21.08.2-1 21.08.3-1
kross-interpreters 21.08.2-1 21.08.3-1
kruler 21.08.2-1 21.08.3-1
kscreen 5.23.2-1 5.23.3-1
kscreenlocker 5.23.2-1 5.23.3-1
kshisen 21.08.2-1 21.08.3-1
ksirk 21.08.2-1 21.08.3-1
ksmtp 21.08.2-1 21.08.3-1
ksnakeduel 21.08.2-1 21.08.3-1
kspaceduel 21.08.2-1 21.08.3-1
ksquares 21.08.2-1 21.08.3-1
ksshaskpass 5.23.2-1 5.23.3-1
ksudoku 21.08.2-1 21.08.3-1
ksystemlog 21.08.2-1 21.08.3-1
ksystemstats 5.23.2-1 5.23.3-1
kteatime 21.08.2-1 21.08.3-1
ktimer 21.08.2-1 21.08.3-1
ktnef 21.08.2-1 21.08.3-1
ktorrent 21.08.2-1 21.08.3-1
ktouch 21.08.2-1 21.08.3-1
ktuberling 21.08.2-1 21.08.3-1
kturtle 21.08.2-1 21.08.3-1
kubrick 21.08.2-1 21.08.3-1
kwallet-pam 5.23.2-1 5.23.3-1
kwalletmanager 21.08.2-1 21.08.3-1
kwave 21.08.2-1 21.08.3-1
kwayland-integration 5.23.2-1 5.23.3-1
kwayland-server 5.23.2-1 5.23.3-1
kwin 5.23.2-1 5.23.3-1
kwordquiz 21.08.2-1 21.08.3-1
kwrite 21.08.2-2 21.08.3-1
kwrited 5.23.2-1 5.23.3-1
layer-shell-qt 5.23.2-1 5.23.3-1
libakonadi 21.08.2-1 21.08.3-1
libcups 1:2.3.3op2-3 1:2.3.3op2-4
libdazzle 3.42.0-1 3.42.0.1-1
libdrm 2.4.107-1 2.4.108-1
libevdev 1.11.0-1 1.12.0-1
libexttextcat 3.4.5-2 3.4.6-1
libfido2 1.8.0-1 1.9.0-1
libfprint 1.94.1-1 1.94.2-1
libgdm 40.1-2 41.0-1
libgnome-games-support 1.8.1-1 1.8.2-1
libgravatar 21.08.2-1 21.08.3-1
libheif 1.12.0-1 1.12.0-2
libkcddb 21.08.2-1 21.08.3-1
libkcompactdisc 21.08.2-1 21.08.3-1
libkdcraw 21.08.2-1 21.08.3-1
libkdegames 21.08.2-1 21.08.3-1
libkdepim 21.08.2-1 21.08.3-1
libkeduvocdocument 21.08.2-1 21.08.3-1
libkexiv2 21.08.2-1 21.08.3-1
libkgapi 21.08.2-1 21.08.3-1
libkipi 21.08.2-1 21.08.3-1
libkleo 21.08.2-1 21.08.3-1
libkmahjongg 21.08.2-1 21.08.3-1
libkomparediff2 21.08.2-1 21.08.3-1
libksane 21.08.2-1 21.08.3-1
libkscreen 5.23.2-1 5.23.3-1
libksieve 21.08.2-1 21.08.3-1
libksysguard 5.23.2-1 5.23.3-1
libktorrent 21.08.2-1 21.08.3-1
libnautilus-extension 40.2+7+g67c7bdbf8-1 41.1-1
libphonenumber 8.12.33-1 8.12.36-1
libpst 0.6.76-2 0.6.76-3
libpst-docs 0.6.76-2 0.6.76-3
libreoffice-still 7.1.6-3 7.1.7-1
libreoffice-still-af 7.1.6-1 7.1.7-1
libreoffice-still-am 7.1.6-1 7.1.7-1
libreoffice-still-ar 7.1.6-1 7.1.7-1
libreoffice-still-as 7.1.6-1 7.1.7-1
libreoffice-still-ast 7.1.6-1 7.1.7-1
libreoffice-still-be 7.1.6-1 7.1.7-1
libreoffice-still-bg 7.1.6-1 7.1.7-1
libreoffice-still-bn 7.1.6-1 7.1.7-1
libreoffice-still-bn-in 7.1.6-1 7.1.7-1
libreoffice-still-bo 7.1.6-1 7.1.7-1
libreoffice-still-br 7.1.6-1 7.1.7-1
libreoffice-still-brx 7.1.6-1 7.1.7-1
libreoffice-still-bs 7.1.6-1 7.1.7-1
libreoffice-still-ca 7.1.6-1 7.1.7-1
libreoffice-still-ca-valencia 7.1.6-1 7.1.7-1
libreoffice-still-ckb 7.1.6-1 7.1.7-1
libreoffice-still-cs 7.1.6-1 7.1.7-1
libreoffice-still-cy 7.1.6-1 7.1.7-1
libreoffice-still-da 7.1.6-1 7.1.7-1
libreoffice-still-de 7.1.6-1 7.1.7-1
libreoffice-still-dgo 7.1.6-1 7.1.7-1
libreoffice-still-dsb 7.1.6-1 7.1.7-1
libreoffice-still-dz 7.1.6-1 7.1.7-1
libreoffice-still-el 7.1.6-1 7.1.7-1
libreoffice-still-en-gb 7.1.6-1 7.1.7-1
libreoffice-still-en-za 7.1.6-1 7.1.7-1
libreoffice-still-eo 7.1.6-1 7.1.7-1
libreoffice-still-es 7.1.6-1 7.1.7-1
libreoffice-still-et 7.1.6-1 7.1.7-1
libreoffice-still-eu 7.1.6-1 7.1.7-1
libreoffice-still-fa 7.1.6-1 7.1.7-1
libreoffice-still-fi 7.1.6-1 7.1.7-1
libreoffice-still-fr 7.1.6-1 7.1.7-1
libreoffice-still-fur 7.1.6-1 7.1.7-1
libreoffice-still-fy 7.1.6-1 7.1.7-1
libreoffice-still-ga 7.1.6-1 7.1.7-1
libreoffice-still-gd 7.1.6-1 7.1.7-1
libreoffice-still-gl 7.1.6-1 7.1.7-1
libreoffice-still-gu 7.1.6-1 7.1.7-1
libreoffice-still-gug 7.1.6-1 7.1.7-1
libreoffice-still-he 7.1.6-1 7.1.7-1
libreoffice-still-hi 7.1.6-1 7.1.7-1
libreoffice-still-hr 7.1.6-1 7.1.7-1
libreoffice-still-hsb 7.1.6-1 7.1.7-1
libreoffice-still-hu 7.1.6-1 7.1.7-1
libreoffice-still-id 7.1.6-1 7.1.7-1
libreoffice-still-is 7.1.6-1 7.1.7-1
libreoffice-still-it 7.1.6-1 7.1.7-1
libreoffice-still-ja 7.1.6-1 7.1.7-1
libreoffice-still-ka 7.1.6-1 7.1.7-1
libreoffice-still-kab 7.1.6-1 7.1.7-1
libreoffice-still-kk 7.1.6-1 7.1.7-1
libreoffice-still-km 7.1.6-1 7.1.7-1
libreoffice-still-kmr-latn 7.1.6-1 7.1.7-1
libreoffice-still-kn 7.1.6-1 7.1.7-1
libreoffice-still-ko 7.1.6-1 7.1.7-1
libreoffice-still-kok 7.1.6-1 7.1.7-1
libreoffice-still-ks 7.1.6-1 7.1.7-1
libreoffice-still-lb 7.1.6-1 7.1.7-1
libreoffice-still-lo 7.1.6-1 7.1.7-1
libreoffice-still-lt 7.1.6-1 7.1.7-1
libreoffice-still-lv 7.1.6-1 7.1.7-1
libreoffice-still-mai 7.1.6-1 7.1.7-1
libreoffice-still-mk 7.1.6-1 7.1.7-1
libreoffice-still-ml 7.1.6-1 7.1.7-1
libreoffice-still-mn 7.1.6-1 7.1.7-1
libreoffice-still-mni 7.1.6-1 7.1.7-1
libreoffice-still-mr 7.1.6-1 7.1.7-1
libreoffice-still-my 7.1.6-1 7.1.7-1
libreoffice-still-nb 7.1.6-1 7.1.7-1
libreoffice-still-ne 7.1.6-1 7.1.7-1
libreoffice-still-nl 7.1.6-1 7.1.7-1
libreoffice-still-nn 7.1.6-1 7.1.7-1
libreoffice-still-nr 7.1.6-1 7.1.7-1
libreoffice-still-nso 7.1.6-1 7.1.7-1
libreoffice-still-oc 7.1.6-1 7.1.7-1
libreoffice-still-om 7.1.6-1 7.1.7-1
libreoffice-still-or 7.1.6-1 7.1.7-1
libreoffice-still-pa-in 7.1.6-1 7.1.7-1
libreoffice-still-pl 7.1.6-1 7.1.7-1
libreoffice-still-pt 7.1.6-1 7.1.7-1
libreoffice-still-pt-br 7.1.6-1 7.1.7-1
libreoffice-still-ro 7.1.6-1 7.1.7-1
libreoffice-still-ru 7.1.6-1 7.1.7-1
libreoffice-still-rw 7.1.6-1 7.1.7-1
libreoffice-still-sa-in 7.1.6-1 7.1.7-1
libreoffice-still-sat 7.1.6-1 7.1.7-1
libreoffice-still-sd 7.1.6-1 7.1.7-1
libreoffice-still-sdk 7.1.6-3 7.1.7-1
libreoffice-still-si 7.1.6-1 7.1.7-1
libreoffice-still-sid 7.1.6-1 7.1.7-1
libreoffice-still-sk 7.1.6-1 7.1.7-1
libreoffice-still-sl 7.1.6-1 7.1.7-1
libreoffice-still-sq 7.1.6-1 7.1.7-1
libreoffice-still-sr 7.1.6-1 7.1.7-1
libreoffice-still-sr-latn 7.1.6-1 7.1.7-1
libreoffice-still-ss 7.1.6-1 7.1.7-1
libreoffice-still-st 7.1.6-1 7.1.7-1
libreoffice-still-sv 7.1.6-1 7.1.7-1
libreoffice-still-sw-tz 7.1.6-1 7.1.7-1
libreoffice-still-szl 7.1.6-1 7.1.7-1
libreoffice-still-ta 7.1.6-1 7.1.7-1
libreoffice-still-te 7.1.6-1 7.1.7-1
libreoffice-still-tg 7.1.6-1 7.1.7-1
libreoffice-still-th 7.1.6-1 7.1.7-1
libreoffice-still-tn 7.1.6-1 7.1.7-1
libreoffice-still-tr 7.1.6-1 7.1.7-1
libreoffice-still-ts 7.1.6-1 7.1.7-1
libreoffice-still-tt 7.1.6-1 7.1.7-1
libreoffice-still-ug 7.1.6-1 7.1.7-1
libreoffice-still-uk 7.1.6-1 7.1.7-1
libreoffice-still-uz 7.1.6-1 7.1.7-1
libreoffice-still-ve 7.1.6-1 7.1.7-1
libreoffice-still-vec 7.1.6-1 7.1.7-1
libreoffice-still-vi 7.1.6-1 7.1.7-1
libreoffice-still-xh 7.1.6-1 7.1.7-1
libreoffice-still-zh-cn 7.1.6-1 7.1.7-1
libreoffice-still-zh-tw 7.1.6-1 7.1.7-1
libreoffice-still-zu 7.1.6-1 7.1.7-1
libwebsockets 4.2.2-1 4.3.0-1
libytnef 1:1.9.3-1 1:2.0-2
llvm10 10.0.1-9.1 -
llvm10-libs 10.0.1-9.1 -
lokalize 21.08.2-1 21.08.3-1
lskat 21.08.2-1 21.08.3-1
mailcommon 21.08.2-1 21.08.3-1
mailimporter 21.08.2-1 21.08.3-1
malcontent 0.10.2-1 0.10.3-1
marble 21.08.2-1 21.08.3-1
marble-common 21.08.2-1 21.08.3-1
marble-maps 21.08.2-1 21.08.3-1
marble-qt 21.08.2-1 21.08.3-1
mariadb 10.6.4-1 10.6.5-1
mariadb-clients 10.6.4-1 10.6.5-1
mariadb-libs 10.6.4-1 10.6.5-1
markdownpart 21.08.2-1 21.08.3-1
mbox-importer 21.08.2-1 21.08.3-1
mescc-tools 0.7.0-1 1.3-1
messagelib 21.08.2-1 21.08.3-1
milou 5.23.2-1 5.23.3-1
minuet 21.08.2-1 21.08.3-1
mlt 7.2.0-1 7.2.0-2
mpd 0.23.3-1 0.23.4-1
mutter 40.5-1 41.1-1
mytop 10.6.4-1 10.6.5-1
nautilus 40.2+7+g67c7bdbf8-1 41.1-1
opencv 4.5.4-5 4.5.4-6
opencv-samples 4.5.4-5 4.5.4-6
openjdk-src 17.u35-1 17.0.1.u12-1
openjdk11-src 11.0.12.u7-1 11.0.13.u8-1
orca 40.0-1 41.0-1
oxygen 5.23.2-1 5.23.3-1
palapeli 21.08.2-1 21.08.3-1
parley 21.08.2-1 21.08.3-1
partitionmanager 21.08.2-1 21.08.3-1
perl-uri 5.09-2 5.10-1
picmi 21.08.2-1 21.08.3-1
pim-data-exporter 21.08.2-1 21.08.3-1
pim-sieve-editor 21.08.2-1 21.08.3-1
pimcommon 21.08.2-1 21.08.3-1
pipewire-alsa 1:0.3.39-1 1:0.3.40-1
pipewire-docs 1:0.3.39-1 1:0.3.40-1
pipewire-jack 1:0.3.39-1 1:0.3.40-1
pipewire-media-session 1:0.4.0-1 1:0.4.1-1
pipewire-media-session-docs 1:0.4.0-1 1:0.4.1-1
pipewire-pulse 1:0.3.39-1 1:0.3.40-1
pipewire-v4l2 1:0.3.39-1 1:0.3.40-1
pipewire-zeroconf 1:0.3.39-1 1:0.3.40-1
plasma-browser-integration 5.23.2-1 5.23.3-1
plasma-desktop 5.23.2-2 5.23.3-1
plasma-disks 5.23.2-1 5.23.3-1
plasma-firewall 5.23.2-1 5.23.3-1
plasma-integration 5.23.2-1 5.23.3-1
plasma-nm 5.23.2-1 5.23.3-1
plasma-pa 5.23.2-1 5.23.3-1
plasma-sdk 5.23.2-1 5.23.3-1
plasma-systemmonitor 5.23.2-1 5.23.3-1
plasma-thunderbolt 5.23.2-1 5.23.3-1
plasma-vault 5.23.2-1 5.23.3-1
plasma-wayland-protocols 1.4.0-1 1.5-1
plasma-wayland-session 5.23.2-1 5.23.3-1
plasma-workspace 5.23.2-1 5.23.3-1
plasma-workspace-wallpapers 5.23.2-1 5.23.3-1
polari 40.1-1 41.0-1
polkit-kde-agent 5.23.2-1 5.23.3-1
postfix 3.6.2-2 3.6.3-1
postfix-cdb 3.6.2-2 3.6.3-1
postfix-ldap 3.6.2-2 3.6.3-1
postfix-lmdb 3.6.2-2 3.6.3-1
postfix-mysql 3.6.2-2 3.6.3-1
postfix-pcre 3.6.2-2 3.6.3-1
postfix-pgsql 3.6.2-2 3.6.3-1
postfix-sqlite 3.6.2-2 3.6.3-1
powerdevil 5.23.2-1 5.23.3-1
poxml 21.08.2-1 21.08.3-1
print-manager 21.08.2-1 21.08.3-1
prometheus 2.30.3-1 2.31.1-1
python-lxml 4.6.3-1 4.6.4-1
python-lxml-docs 4.6.3-1 4.6.4-1
python-opencv 4.5.4-5 4.5.4-6
python-pyqt5 5.15.6-1 5.15.6-2
qcachegrind 21.08.2-1 21.08.3-1
qt5-declarative 5.15.2+kde+r36-1 5.15.2+kde+r39-1
qtcreator 5.0.2-4 5.0.3-1
qtkeychain-qt5 0.12.0-2 0.13.1-1
qtkeychain-qt6 0.12.0-2 0.13.1-1
rocs 21.08.2-1 21.08.3-1
samba 4.15.1-1 4.15.2-1
sddm-kcm 5.23.2-1 5.23.3-1
seahorse 1:40.0-1 1:41.0-1
signon-kwallet-extension 21.08.2-1 21.08.3-1
skanlite 21.08.2-1 21.08.3-1
smbclient 4.15.1-1 4.15.2-1
spectacle 21.08.2-1 21.08.3-1
step 21.08.2-1 21.08.3-1
sushi 3.38.1-1 41.0-1
svgpart 21.08.2-1 21.08.3-1
sweeper 21.08.2-1 21.08.3-1
swell-foop 40.1-1 41.0.1-1
sysprof 3.40.1-1 3.42.1-1
systemsettings 5.23.2-1 5.23.3-1
tali 40.2-1 40.4-1
tcl 8.6.11-1 8.6.12-1
telepathy-kde-accounts-kcm 21.08.2-1 21.08.3-1
telepathy-kde-approver 21.08.2-1 21.08.3-1
telepathy-kde-auth-handler 21.08.2-1 21.08.3-1
telepathy-kde-call-ui 21.08.2-1 21.08.3-1
telepathy-kde-common-internals 21.08.2-1 21.08.3-1
telepathy-kde-contact-list 21.08.2-1 21.08.3-1
telepathy-kde-contact-runner 21.08.2-1 21.08.3-1
telepathy-kde-desktop-applets 21.08.2-1 21.08.3-1
telepathy-kde-filetransfer-handler 21.08.2-1 21.08.3-1
telepathy-kde-integration-module 21.08.2-1 21.08.3-1
telepathy-kde-send-file 21.08.2-1 21.08.3-1
telepathy-kde-text-ui 21.08.2-1 21.08.3-1
tk 8.6.11.1-1 8.6.12-1
tomcat10 10.0.12-1 10.0.13-1
tomcat8 8.5.72-1 8.5.73-1
tomcat9 9.0.54-1 9.0.55-1
tracker3 3.2.0-2 3.2.1-1
tracker3-docs 3.2.0-2 3.2.1-1
tracker3-miners 3.2.0+6+gfffef2772-2 3.2.1-1
umbrello 21.08.2-1 21.08.3-1
unzip 6.0-14 6.0-15
vim-runtime 8.2.3441-1 8.2.3582-1
vte-common 0.66.0-1 0.66.1-1
vte3 0.66.0-1 0.66.1-1
wireplumber 0.4.4-4 0.4.5-2
wireplumber-docs 0.4.4-4 0.4.5-2
xdg-desktop-portal-gtk 1.10.0-1 1.10.0-3
xdg-desktop-portal-kde 5.23.2-1 5.23.3-1
xf86-input-elographics 1.4.2-2 1.4.2-3
xf86-input-evdev 2.10.6-2 2.10.6-3
xf86-input-libinput 1.2.0-1 1.2.0-2
xf86-input-synaptics 1.9.1-2 1.9.1-3
xf86-input-void 1.4.1-5 1.4.1-6
xf86-input-wacom 0.40.0-1 0.40.0-2
xf86-video-amdgpu 21.0.0-1 21.0.0-2
xf86-video-dummy 0.3.8-4 0.3.8-5
xf86-video-fbdev 0.5.0-2 0.5.0-3
xf86-video-nouveau 1.0.17-1 1.0.17-2
xf86-video-sisusb 0.9.7-3 0.9.7-4
xf86-video-vesa 2.5.0-1 2.5.0-2
xorg-server 1.20.13-3 21.1.1-3
xorg-server-common 1.20.13-3 21.1.1-3
xorg-server-devel 1.20.13-3 21.1.1-3
xorg-server-xephyr 1.20.13-3 21.1.1-3
xorg-server-xnest 1.20.13-3 21.1.1-3
xorg-server-xvfb 1.20.13-3 21.1.1-3
xorg-xwayland 21.1.2.901-1 21.1.3-1
yakuake 21.08.2-1 21.08.3-1
yelp 40.3-1 41.1-1
zeroconf-ioslave 21.08.2-1 21.08.3-1
avogadrolibs-qt5 - 1.95.1-6
gnome-builder-libide-docs - 41.1-2
libcheese - 41.0-2
mauikit - 2.1.0-1
xdg-desktop-portal-gnome - 41.1-1
zanshin - 0.5.71-3
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.08.2.r12637.g8c8d2c338-121.08.3.r12641.gd980d752b-1
akonadi-calendar21.08.2.r1999.g02556b7-121.08.3.r2002.g8711f1c-1
akonadi-calendar-tools21.08.2.r909.gc820464-121.08.3.r913.g80a0864-1
akonadi-contacts21.08.2.r3078.gdfdc82e3-121.08.3.r3083.gaf29725a-1
akonadi-import-wizard21.08.2.r1762.g824188e-121.08.3.r1766.g1ee56f6-1
akonadi-mime21.08.2.r1662.g6ee9d55-121.08.3.r1667.g9930b5c-1
akonadi-notes21.08.2.r1032.g87092b2-121.08.3.r1036.g4dd9907-1
akonadi-search21.08.2.r1135.g4d296d0-121.08.3.r1139.g37c2594-1
akonadiconsole21.08.2.r1540.gd275168-121.08.3.r1545.g1d32d54-1
akregator21.08.2.r6243.gf1e01ee6-121.08.3.r6248.g2fc625a3-1
amazfish 2.0.1.r0.g34365e4-1 2.0.1.r1.g943c4d5-1
analitza21.08.2.r2334.g7ec50877-121.08.3.r2334.g7ec50877-1
ark21.08.2.r4633.gd27870ec-121.08.3.r4638.g0860f58f-1
artikulate21.08.2.r1393.ge3199a7-121.08.3.r1394.gdd917e0-1
audiocd-kio21.08.2.r1036.gf197775-121.08.3.r1036.gf197775-1
baloo-widgets21.08.2.r708.gf894732-121.08.3.r711.gd9798fd-1
bigscreen-image-settings r5.2c99c52-3 r6.88a2eb4-2
blinken21.08.2.r640.g35e8a00-121.08.3.r642.gff8383a-1
bluedevil1:5.23.2.r2300.g5d5bd024-11:5.23.3.r2301.g7b7d222f-1
bomber21.08.2.r535.gc727617-121.08.3.r538.g9057b0b-1
bovo21.08.2.r746.g089ad5c-121.08.3.r748.gf341042-1
breeze5.23.2.r2291.g945ba0cc-15.23.3.r2293.gdbd4af9b-1
breeze-grub5.23.2.r11.g63136a9-15.23.3.r11.g63136a9-1
breeze-gtk5.23.2.r427.g4e3d0c7-15.23.3.r427.g4e3d0c7-1
breeze-icons5.87.0.r1822.gd12e9b3b-15.87.0.r1826.g95aa75e3-1
buho 2.0.0.r10.g5d6b3b4-1 2.1.0.r0.g5d6b3b4-1
calendarsupport21.08.1.r45.g3de8926-121.08.1.r50.gca8aa23-1
cervisia21.08.2.r1644.geaa75c0-121.08.3.r1645.gb665439-1
discover5.23.2.r8391.g7c1505c1-15.23.3.r8408.geaf32bc7-1
disman5.23.2.r1811.gca36775-15.23.3.r1811.gca36775-1
dolphin21.08.2.r6730.g81c32c18a-121.08.3.r6731.gaa9a80fba-1
dolphin-plugins21.08.2.r609.ga5d0bf7-121.08.3.r613.gff6247a-1
dragon21.08.2.r1015.gf2f8c11-121.08.3.r1016.g89c76c9-1
drkonqi5.23.2.r705.gaea7570b-15.23.3.r705.gaea7570b-1
elisa21.08.2.r2789.g6cf74777-121.08.3.r2791.g1d55d2e8-1
eventviews21.08.2.r59.g686ceb5-121.08.2.r64.g16b30dc-1
extra-cmake-modules5.87.0.r3384.g8f7831c-15.87.0.r3386.g32fdb17-1
ffmpegthumbs21.08.2.r198.g160cf82-121.08.3.r199.ga08b3cb-1
filelight21.08.2.r994.gf938d92-121.08.3.r998.gd329edc-1
granatier21.08.2.r941.g54bf99b-121.08.3.r944.gbb777d1-1
grantlee-editor21.08.2.r777.g1227d35-121.08.3.r782.g5c3d70d-1
grantleetheme21.08.2.r355.gc54c81a-121.08.3.r358.g5b86439-1
gwenview21.08.2.r6686.g76f2826c-121.08.3.r6690.g59a1d995-1
incidenceeditor21.08.2.r794.g7bb60eb-121.08.3.r799.gb59b538-1
index-fm 2.0.0.r47.g2ca25d5-1 2.1.0.r7.gc9ec50d-1
itinerary21.08.2.r1543.ge957e2a-121.08.3.r1575.g465c1b1-1
juk21.08.2.r3119.g6e4bef55-121.08.3.r3122.g1959c02e-1
k3b1:21.08.2.r6682.g64c4eaa8f-11:21.08.3.r6684.gc325ddf83-1
kaccounts-integration21.08.2.r1228.g6cbf8be-121.08.3.r1230.g85da40d-1
kaccounts-providers21.08.2.r384.g7be401f-121.08.3.r385.g88a4a50-1
kactivities-stats5.87.0.r378.gece9abd-15.87.0.r379.gc86c301-1
kactivitymanagerd5.23.2.r1374.g3ad18a6-15.23.3.r1374.g3ad18a6-1
kaddressbook21.08.2.r6063.gcf931f85-121.08.3.r6067.ge514b6c6-1
kajongg21.08.2.r4202.gc041597a-121.08.3.r4204.g616965a3-1
kalarm21.08.2.r6509.g520ce508-121.08.3.r6515.gf9faf644-1
kalarmcal21.08.2.r1151.g15381eb-121.08.3.r1158.g38ecac9-1
kalgebra21.08.2.r2043.gf9c5e20-121.08.3.r2044.gfe74119-1
kalzium21.08.2.r4271.g60a829a7-121.08.3.r4273.g30587045-1
kamera21.08.2.r668.gecc8995-121.08.3.r669.g2f33e88-1
kamoso21.08.2.r1433.g00024fd-121.08.3.r1437.gdffbc0d-1
kanagram21.08.2.r1288.g3d18602-121.08.3.r1289.g038e41f-1
kapman21.08.2.r617.g52f8290-121.08.3.r620.g5eb9603-1
kapptemplate21.08.2.r959.g95eb4fb-121.08.3.r962.ga02f4f8-1
kasts 21.08.r72.g76b242d-1 21.08.r83.geb13598-1
kate21.08.2.r18434.ge4b4ff04f-121.08.3.r18444.g6a9295d01-1
katomic21.08.2.r930.g92052d8-121.08.3.r933.g351bf1f-1
kbackup21.08.2.r398.g4fe285e-121.08.3.r400.gb4e1e02-1
kblackbox21.08.2.r736.gb339cb7-121.08.3.r739.gb75ac92-1
kblocks21.08.2.r679.gfe18028-121.08.3.r681.g170f68e-1
kbounce21.08.2.r816.gf06d589-121.08.3.r819.g31f56ba-1
kbreakout21.08.2.r874.g7d4fd5e-121.08.3.r876.gdec8b86-1
kbruch21.08.2.r824.ge25c3ae-121.08.3.r826.g716b297-1
kcachegrind21.08.2.r1158.g03099a9-121.08.3.r1159.g1c8b855-1
kcachegrind-common21.08.2.r1158.g03099a9-121.08.3.r1159.g1c8b855-1
kcalc21.08.2.r1543.g299c14c-121.08.3.r1545.g25457d7-1
kcalendarcore5.87.0.r1260.gc2f07c4b5-15.87.0.r1261.g59b895fd3-1
kcalutils21.08.2.r892.gd7dcdac52-121.08.3.r896.g605e1ab6b-1
kcharselect21.08.2.r482.g5051e0d-121.08.3.r484.ga2d353b-1
kclock 21.08.r19.g72a2fcf-1 21.08.r24.gc823d39-1
kcolorchooser21.08.2.r237.ge668d53-121.08.3.r238.g98b5213-1
kconfigwidgets5.87.0.r638.g07d0426-25.87.0.r644.g8e274e4-1
kcontacts1:5.87.0.r3284.g19cd2ccf-11:5.87.0.r3285.g09e464bc-1
kcoreaddons5.87.0.r1328.g3d458e76-15.87.0.r1329.g37d4c69f-1
kcron21.08.2.r811.g9ea3bef-121.08.3.r811.g9ea3bef-1
kde-cli-tools5.23.2.r1874.g2363ff7-15.23.3.r1876.g173befe-1
kde-dev-scripts21.08.2.r4141.g0fbd8db-121.08.3.r4141.g0fbd8db-1
kde-dev-utils21.08.2.r566.ge045dfd-121.08.3.r567.gc8e4a24-1
kde-gtk-config5.23.2.r916.g21d547e-15.23.3.r916.g21d547e-1
kde-telephony-daemon21.08.2.r431.g7d70505-121.08.2.r431.gd23a470-1
kdebugsettings21.08.2.r859.g6f0486b-121.08.3.r861.gc5b254f-1
kdeclarative5.87.0.r935.gf05126c-15.87.0.r940.g23c43a4-1
kdeconnect21.08.2.r3353.g4462b748-121.08.3.r3356.gac770bec-1
kdecoration5.23.2.r278.g70a98b4-15.23.3.r279.g6e5e600-1
kdeedu-data21.08.2.r15.g8dc3dee-121.08.3.r15.g8dc3dee-1
kdegraphics-mobipocket21.08.2.r261.ga9aa775-121.08.3.r261.ga9aa775-1
kdegraphics-thumbnailers21.08.2.r237.g2c062c3-121.08.3.r237.g2c062c3-1
kdelibs4support5.87.0.r1049.gc175d7c8-15.87.0.r1051.g9a71fe9c-1
kdenetwork-filesharing21.08.2.r895.g3d576da-121.08.3.r895.g3d576da-1
kdenlive21.08.2.r15133.gf19c2faa8-121.08.3.r15192.g343721d23-1
kdepim-addons21.08.2.r4396.ge9745bac-121.08.3.r4406.g47d24b2e-1
kdepim-runtime21.08.2.r15354.g2657333bf-121.08.3.r15379.gbf8d4a844-1
kdeplasma-addons5.23.2.r8603.gb7bcc632c-15.23.3.r8605.g508fde690-1
kdesdk-kioslaves21.08.2.r499.gf0b4adb-121.08.3.r500.g069c3f8-1
kdesdk-thumbnailers21.08.2.r85.g29d3ad1-121.08.3.r86.g002e2df-1
kdf21.08.2.r808.gdd1e942-121.08.3.r812.g60736f6-1
kdialog21.08.2.r1195.g92c091e27-121.08.3.r1196.g259732bb4-1
kdiamond21.08.2.r681.ge62c240-121.08.3.r684.g88cfdc8-1
kdisplay5.23.2.r1456.gc03ddcb-15.23.3.r1456.gc03ddcb-1
keditbookmarks21.08.2.r2751.gaf57bcc7b-121.08.3.r2753.g509efd64d-1
kfilemetadata5.87.0.r820.g4c5fc34-15.87.0.r821.g4168135-1
kfind21.08.2.r2649.g58ec9d805-121.08.3.r2651.g7611ffc3c-1
kfloppy21.08.2.r766.g73168b7-121.08.3.r767.g5d3ac08-1
kfourinline21.08.2.r991.gfee1dfd-121.08.3.r993.gbf4db28-1
kgamma55.23.2.r463.gc082f80-15.23.3.r463.gc082f80-1
kgeography21.08.2.r1116.g7547c4a-121.08.3.r1117.gbe842ae-1
kget21.08.2.r3130.g09654d47-121.08.3.r3132.g08cabf2e-1
kgoldrunner21.08.2.r1249.g74ba2b0-121.08.3.r1253.g1e9968f-1
kgpg21.08.2.r3139.g8702bef8-121.08.3.r3140.gc1870899-1
khangman21.08.2.r1570.g4b1448f-121.08.3.r1574.g7b41816-1
khealthcertificate r88.a3147ee-1 r91.939ca62-1
khelpcenter21.08.2.r2685.g8f90ac0d-121.08.3.r2686.g65fd4bc1-1
khotkeys5.23.2.r2100.g6b8e5f7-15.23.3.r2101.g13fe346-1
ki18n5.87.0.r506.g0a53773-15.87.0.r507.g7d228aa-1
kidentitymanagement21.08.2.r3834.ga07df567-121.08.3.r3839.g4a5a73b6-1
kig21.08.2.r3148.g86879a0d-121.08.3.r3150.g58e0adae-1
kigo21.08.2.r531.gd8f75b3-121.08.3.r534.g64aae3a-1
killbots21.08.2.r746.gd3280b7-121.08.3.r749.ge5382fc-1
kimagemapeditor21.08.2.r474.g6b89cdc-121.08.3.r475.g269bdaa-1
kimap21.08.2.r1132.g624e345-121.08.3.r1136.g6ecda24-1
kinfocenter5.23.2.r1977.g7741f5e-15.23.3.r1981.g5be3b7f-1
kio5.87.0.r5079.g19460119-15.87.0.r5080.gc4f26e93-1
kio-extras21.08.2.r7163.g20a614cd-121.08.3.r7165.ga197b68a-1
kio-gdrive21.08.2.r572.g104f0a1-121.08.3.r574.g4f22785-1
kipi-plugins21.08.2.r12065.g6dcbb7939-121.08.3.r12067.gede22cc82-1
kirigami-gallery21.08.2.r222.g7e096c1-121.08.3.r223.g7c8b00c-1
kirigami25.87.0.r2940.gbca3e9fd-15.87.0.r2949.g67cd5f99-1
kiriki21.08.2.r426.g34776cd-121.08.3.r428.g6895dd7-1
kiten21.08.2.r1153.gaab542d-121.08.3.r1156.gf9edbac-1
kitinerary21.08.2.r2004.g3bb9e15-121.08.3.r2011.gca9c3cc-1
kjs5.87.0.r342.gbc087c7-15.87.0.r344.g4962744-1
kjumpingcube21.08.2.r796.g5834c92-121.08.3.r799.gf6d0b72-1
kldap21.08.2.r900.g7c696bc-121.08.3.r904.g4d89193-1
kleopatra21.08.2.r6028.g15369499-121.08.3.r6044.g2cbbadb4-1
klettres21.08.2.r926.g1f5f9d9-121.08.3.r929.g8a3fff3-1
klickety21.08.2.r644.g7c96198-121.08.3.r646.g642c273-1
klines21.08.2.r777.ged8c1e2-121.08.3.r780.g1bdd4f6-1
kmag21.08.2.r700.g9491a1e-121.08.3.r701.gc710811-1
kmahjongg21.08.2.r1489.g30d5f94-121.08.3.r1491.ga86ad79-1
kmail21.08.2.r26052.gaf176d476-121.08.3.r26065.g9a5d30a4d-1
kmail-account-wizard21.08.2.r828.g2688611-121.08.3.r834.g186e742-1
kmailtransport21.08.2.r1676.gfb2ce5f-121.08.3.r1681.g21b9c8c-1
kmbox21.08.2.r548.gb2fa39a-121.08.3.r552.g2ea0979-1
kmenuedit5.23.2.r977.g4324089-15.23.3.r978.gd45a96f-1
kmime21.08.2.r1465.gda644ef-121.08.3.r1468.g749a036-1
kmines21.08.2.r1729.g70226a0-121.08.3.r1733.g0946a64-1
kmix21.08.2.r2387.ga54f7609-121.08.3.r2410.gd4956d90-1
kmousetool21.08.2.r402.g07fd0bc-121.08.3.r403.gf5cd69e-1
kmouth21.08.2.r700.g6333e61-121.08.3.r701.gf98f284-1
kmplot21.08.2.r1468.g98750ca-121.08.3.r1469.g02df1a6-1
knavalbattle21.08.2.r1401.gd04aa35-121.08.3.r1404.gab89187-1
knetwalk21.08.2.r666.g72f7c98-121.08.3.r669.gb03e4a1-1
knewstuff5.87.0.r1231.gd188429a-15.87.0.r1232.g79cb8f54-1
knights21.08.2.r1071.gdc554ea-121.08.3.r1073.g6db6467-1
knotes21.08.2.r3537.gfe29d5d3-121.08.3.r3542.g49aabda2-1
knotifications5.87.0.r694.gad6ee92-15.87.0.r695.gd1f7b41-1
koko 21.08.r24.g9c01a42-1 21.08.r25.gf006354-1
kolf21.08.2.r1450.g5602407-121.08.3.r1453.g170d53c-1
kollision21.08.2.r499.g48f2325-121.08.3.r502.g74866d5-1
kolourpaint21.08.2.r2370.g1e310e4d-121.08.3.r2371.g0faef09d-1
kompare21.08.2.r1112.g02abf26-121.08.3.r1113.gebd124b-1
konqueror21.08.2.r14998.g6846952d7-121.08.3.r15000.gfd8ef32ef-1
konquest21.08.2.r904.g2bf16fe-121.08.3.r906.gaba7d97-1
konsole21.08.2.r8006.g6eb30ff3-121.08.3.r8007.g34317ba6-1
kontact21.08.2.r5413.gb982d1fa-121.08.3.r5417.gdc6fd4e8-1
kontactinterface21.08.2.r641.g36833a8-121.08.3.r644.ga23d784-1
kontrast21.08.2.r186.g58973b6-121.08.3.r187.gbaff6d0-1
konversation21.08.2.r9003.ge5ea5c0d-121.08.3.r9008.g63b1a650-1
kopeninghours21.08.2.r285.g9f5979a-121.08.3.r286.g7fcfdec-1
kopete21.08.2.r16401.gb0c532ffa-121.08.3.r16401.gb0c532ffa-1
korganizer21.08.2.r11539.g4f37ae5c5-121.08.3.r11549.g6289b2007-1
kosmindoormap21.08.2.r665.g2b5b726-121.08.3.r675.gf3ca558-1
kpackage5.87.0.r707.g1d12349-15.87.0.r709.ge62b778-1
kpat21.08.2.r2570.g252f068-121.08.3.r2572.g69af8f6-1
kpimtextedit21.08.2.r1465.g84ad45c-121.08.3.r1470.g4ae6911-1
kpkpass21.08.2.r244.g035d905-121.08.3.r247.g55638af-1
kpmcore21.08.2.r1201.g282cfdc-121.08.3.r1205.ge9fc875-1
kpublictransport21.08.2.r1928.gb9c6df76-121.08.3.r1937.g94cc704a-1
kqtquickcharts21.08.2.r74.g264af68-121.08.3.r74.g264af68-1
krdc21.08.2.r1547.g0f3702d-121.08.3.r1548.gb9ef3f3-1
kreversi21.08.2.r1234.g6ce0dbd-121.08.3.r1237.ge73b98b-1
krfb21.08.2.r1439.g1d23966-121.08.3.r1443.g30455f6-1
kross-interpreters21.08.2.r723.g473116a-121.08.3.r723.g473116a-1
kruler21.08.2.r711.gcbf43c2-121.08.3.r713.g7d66843-1
kscreen5.23.2.r1379.ga6dfc26-15.23.3.r1381.gc6c8b50-1
kscreenlocker5.23.2.r885.g546fcc3-15.23.3.r887.ga267458-1
kservice5.87.0.r958.gcd6868e-15.87.0.r960.g19ceb64-1
kshisen21.08.2.r1208.gc02f182-121.08.3.r1211.g0d449f0-1
ksirk21.08.2.r983.g70ae166-121.08.3.r985.gb4b3d0f-1
ksmtp21.08.2.r395.g4fba022-121.08.3.r398.gc732a72-1
ksnakeduel21.08.2.r816.ge31949e-121.08.3.r819.g80427b3-1
kspaceduel21.08.2.r641.g366e404-121.08.3.r643.g01e6055-1
ksquares21.08.2.r527.g255bc8a-121.08.3.r530.g46e15c3-1
ksshaskpass5.23.2.r202.g6f98560-15.23.3.r202.g6f98560-1
ksudoku21.08.2.r1068.g4d63504-121.08.3.r1070.g220cd86-1
ksysguard5.23.2.r3514.g17497174-15.23.3.r3516.g6b0c2ca2-1
ksystemlog21.08.2.r677.g33c9f9d-121.08.3.r679.g86a91eb-1
ksystemstats5.23.2.r208.g15a0383-15.23.3.r208.g15a0383-1
kteatime21.08.2.r729.gcb16438-121.08.3.r730.g01c8d90-1
ktexteditor5.87.0.r2971.g3a87b99d-15.87.0.r2989.gb3d3eb3a-1
ktimer21.08.2.r476.g0535645-121.08.3.r478.g51760ca-1
ktnef21.08.2.r674.gce684e6-121.08.3.r678.g71e560f-1
ktorrent21.08.2.r2786.g853ef1e1-121.08.3.r2790.ga2939b32-1
ktouch21.08.2.r2149.g9c6295b-121.08.3.r2151.g865ba57-1
ktuberling21.08.2.r1017.gd0393af-121.08.3.r1018.gb35a474-1
kturtle21.08.2.r1127.g98b6090-121.08.3.r1130.g37c45ef-1
kubrick21.08.2.r377.gda097b9-121.08.3.r379.g5596133-1
kwallet-pam5.23.2.r259.g1d65ed8-15.23.3.r259.g1d65ed8-1
kwalletmanager21.08.2.r1216.g8e3b8ac-121.08.3.r1218.g16a7520-1
kwave21.08.2.r3751.g9f6b6f38-121.08.3.r3753.gd750ce47-1
kwayland-integration5.23.2.r193.g1791ee6-15.23.3.r193.g1791ee6-1
kwayland-server5.23.2.r1412.g226dac7-15.23.3.r1417.g22be724-1
kwidgetsaddons5.87.0.r889.g01148ada-15.87.0.r890.g4e6e81e5-1
kwinft5.23.2.r19664.g909e71aa0-15.23.3.r19697.gd934df77c-1
kwordquiz21.08.2.r1149.gfab2ecb-121.08.3.r1150.g1fdadf4-1
kwrite21.08.2.r18434.ge4b4ff04f-121.08.3.r18444.g6a9295d01-1
kwrited5.23.2.r488.gdd0bac8-15.23.3.r488.gdd0bac8-1
libakonadi21.08.2.r12637.g8c8d2c338-121.08.3.r12641.gd980d752b-1
libgravatar21.08.2.r376.g285d035-121.08.3.r380.g7aad39b-1
libkcddb21.08.2.r741.g8f27c69-121.08.3.r741.g8f27c69-1
libkcompactdisc21.08.2.r388.gd787fba-121.08.3.r388.gd787fba-1
libkdcraw21.08.2.r1150.gaac85a3-121.08.3.r1150.gaac85a3-1
libkdegames21.08.2.r2193.g4e196299-121.08.3.r2197.g231f757e-1
libkdepim21.08.2.r861.g788140a-121.08.3.r864.g8cd39b5-1
libkeduvocdocument21.08.2.r1795.gf479a71-121.08.3.r1798.ge8b0d15-1
libkexiv221.08.2.r817.gbceb615-121.08.3.r817.gbceb615-1
libkgapi21.08.2.r1313.g6b5e362-121.08.3.r1317.g59617b2-1
libkipi21.08.2.r1252.g4524dcb-121.08.3.r1252.g4524dcb-1
libkleo21.08.2.r982.g844069f-121.08.3.r1000.ga02d98a-1
libkmahjongg21.08.2.r461.gf27bcdd-121.08.3.r462.g10fdcc4-1
libkomparediff221.08.2.r341.gc0ec97e-121.08.3.r341.gc0ec97e-1
libksane21.08.2.r575.gdd9d73c-121.08.3.r576.ge3e816b-1
libkscreen5.23.2.r1600.g7eb0390-15.23.3.r1603.gc8073ac-1
libksieve21.08.2.r1605.gba2e6eea-121.08.3.r1611.g3e333526-1
libksysguard5.23.2.r2318.gb59351f-15.23.3.r2320.g29a27e8-1
libktorrent21.08.2.r540.g2cb44d0-121.08.3.r541.g9a0b173-1
libquotient r2135.g316069f3-1 r2141.gfb30d455-1
lokalize21.08.2.r1786.ga0dc91dd-121.08.3.r1787.gfa2e35fc-1
lskat21.08.2.r822.g515f9a3-121.08.3.r825.g876d5ff-1
mailcommon21.08.2.r1137.gbfa0172-121.08.3.r1144.gde9c5f2-1
mailimporter21.08.2.r479.ge987679-121.08.3.r483.gff9e4e8-1
marble21.08.2.r13370.ge5663fbc4-121.08.3.r13371.g8732cff23-1
marble-common21.08.2.r13370.ge5663fbc4-121.08.3.r13371.g8732cff23-1
marble-qt21.08.2.r13370.ge5663fbc4-121.08.3.r13371.g8732cff23-1
markdownpart21.08.2.r88.g8e7ebeb-121.08.3.r90.g7780621-1
maui-clip 2.0.0.r24.g0c0c36e-1 2.1.0.r1.g64de394-1
maui-nota 2.0.0.r15.g4183c35-1 2.1.0.r1.g36c626a-1
maui-pix 2.0.0.r22.g4039d8d-1 2.1.0.r1.gb334232-1
mauikit2.0.2.r68.gb968d7a2-1 2.1.0.r7.g80ff8fe0-1
mauikit-accounts 2.0.1.r2.g709da19-1 2.1.0.r1.g709da19-1
mauikit-filebrowsing 2.0.2.r27.g38ef818-1 2.1.0.r3.g0e78054-1
mauikit-imagetools 2.0.1.r5.g1c23d87-1 2.1.0.r0.g1c23d87-1
mauikit-texteditor 2.0.1.r6.g119b288-1 2.1.0.r0.g119b288-1
mbox-importer21.08.2.r524.g1d8178a-121.08.3.r528.g59e389d-1
messagelib21.08.2.r6272.g41fc6c08-121.08.3.r6278.g9a618f48-1
milou5.23.2.r754.gfe6e4e3-15.23.3.r754.gfe6e4e3-1
minuet21.08.2.r587.g4e06437-121.08.3.r588.g4014033-1
modem-daemon21.08.2.r431.g9021c6d-121.08.2.r431.gadff20f-1
neochat r1932.g0568bed6-1 r1935.g8089e5bd-1
okular21.08.2.r9513.gaceed15e8-121.08.3.r9521.gea9e53311-1
oxygen5.23.2.r4436.gbf968845-15.23.3.r4436.gbf968845-1
palapeli21.08.2.r1248.geaf6b70-121.08.3.r1250.gb90750e-1
parley21.08.2.r4482.g12fb3344-121.08.3.r4486.g533eb8ff-1
partitionmanager21.08.2.r1534.gd951b24-121.08.3.r1535.g26ef5d3-1
picmi21.08.2.r539.gb8b35cc-121.08.3.r540.gad0e92e-1
pim-data-exporter21.08.2.r2467.g0e088381-121.08.3.r2517.g74b1a139-1
pim-sieve-editor21.08.2.r1521.g07a2837-121.08.3.r1530.gd7a3901-1
pimcommon21.07.80.r1130.gd6c7f36-121.07.80.r1139.g8fbfc2f-1
plasma-bigscreen r415.g77ee17d-3 r417.g1a5ec8c-1
plasma-browser-integration5.23.2.r1293.gbe44af33-15.23.3.r1295.g51649511-1
plasma-desktop5.23.2.r8751.g889157588-15.23.3.r8766.g55f900647-1
plasma-dialer 21.08.r10.g0e74d95-1 21.08.r11.g2997fa9-1
plasma-dialer-mm 21.08.r10.g0e74d95-4 21.08.r11.g2997fa9-1
plasma-disks5.23.2.r241.g5f2a41c-15.23.3.r242.gafc0180-1
plasma-firewall5.23.2.r534.gdd6cf90-15.23.3.r539.gac3e706-1
plasma-framework5.87.0.r16070.gd2ae32c44-15.87.0.r16080.ge7acbf6ab-1
plasma-integration5.23.2.r537.g30fb7de-15.23.3.r538.gc0ebd87-1
plasma-mobile-nm5.23.1.r3120.gb64ecdb9-15.23.1.r3121.gb03c7e8f-1
plasma-nano5.22.5.r164.gf9c3547-15.22.5.r169.gd386b77-1
plasma-nm5.23.2.r3120.gb64ecdb9-15.23.3.r3121.gb03c7e8f-1
plasma-pa5.23.2.r990.g6b8483f-15.23.3.r995.g09829d3-1
plasma-phone-components5.23.2.r1513.g25e0f99f-15.23.3.r1523.gf81271d3-1
plasma-sdk5.23.2.r2289.g55a21c5b-15.23.3.r2290.gf1046280-1
plasma-settings 21.08.r37.gfb4e50f-1 21.08.r38.g3633e3a-1
plasma-systemmonitor5.23.2.r510.g40df277-15.23.3.r512.g944918c-1
plasma-thunderbolt5.23.2.r153.ga265f72-15.23.3.r155.g89de525-1
plasma-vault5.23.2.r349.ge87c709-15.23.3.r352.g33ac112-1
plasma-wayland-protocols1.4.0.r1040.gfcc237f-11.4.0.r1043.g54293a5-1
plasma-wayland-session5.23.2.r10892.gd39592c3c-15.23.3.r10922.gbc0e8bd70-1
plasma-workspace5.23.2.r10892.gd39592c3c-15.23.3.r10922.gbc0e8bd70-1
plasma-workspace-wallpapers5.23.2.r298.gedd3390-15.23.3.r299.g6e8f317-1
polkit-kde-agent5.23.2.r508.gb1fdc29-15.23.3.r509.gb843d78-1
powerdevil5.23.2.r2492.g2d633682-15.23.3.r2494.g927e16a6-1
poxml21.08.2.r277.ge2d4dfb-121.08.3.r277.ge2d4dfb-1
print-manager21.08.2.r1066.gee1b30b-121.08.3.r1068.g1e94d30-1
pulseaudio-qt 1.3.0.r5.g68a90d9-1 1.3.0.r15.g73ca791-1
purpose5.87.0.r906.g3444f2e-15.87.0.r907.g4265534-1
qcachegrind21.08.2.r1158.g03099a9-121.08.3.r1159.g1c8b855-1
qqc2-breeze-style5.23.2.r232.ga254696-15.23.3.r232.ga254696-1
qqc2-desktop-style5.87.0.r543.gca56913-15.87.0.r544.ga561d4d-1
rocs21.08.2.r3049.g0a54c2bb-121.08.3.r3050.g22def093-1
sddm0.19.0.r92.gd9adf87-20.19.0.r95.g6a7d25f-1
sddm-kcm5.23.2.r617.g841aff7-25.23.3.r617.g841aff7-1
signon-kwallet-extension21.08.2.r65.g82912be-121.08.3.r66.g6412dd2-1
solid5.87.0.r719.g561b6e4-15.87.0.r723.g48c606b-1
sonnet5.87.0.r647.g38a1c2d-15.87.0.r649.g803f059-1
spacebar 21.08.r22.g84998b1-1 21.08.r25.g2a97a46-1
spectacle21.08.2.r1204.g9187981-121.08.3.r1209.g164ca64-1
step21.08.2.r1160.g37e8b0e-121.08.3.r1162.g9bb1e19-1
svgpart21.08.2.r187.g09f4b7b-121.08.3.r188.gf788118-1
sweeper21.08.2.r539.g7235b9d-121.08.3.r541.gcae12ab-1
syntax-highlighting5.87.0.r1731.g0e8365dc-15.87.0.r1733.gbacdacf6-1
systemsettings5.23.2.r2558.gc65db2ec-15.23.3.r2563.g70055638-1
telepathy-kde-accounts-kcm21.08.2.r1198.gca69974-121.08.3.r1199.g97ac460-1
telepathy-kde-approver21.08.2.r295.g4f4fc32-121.08.3.r296.gb977aa3-1
telepathy-kde-auth-handler21.08.2.r277.g1db14c4-121.08.3.r278.ga91acfa-1
telepathy-kde-call-ui21.08.2.r445.g8815182-121.08.3.r445.g8815182-1
telepathy-kde-common-internals21.08.2.r1996.g367b372-121.08.3.r1997.g86dbde3-1
telepathy-kde-contact-list21.08.2.r1085.g6ede63e-121.08.3.r1086.gcf85701-1
telepathy-kde-contact-runner21.08.2.r253.g9fa10bb-121.08.3.r254.gc9a7d36-1
telepathy-kde-desktop-applets21.08.2.r995.gc1eb268-121.08.3.r996.gd101941-1
telepathy-kde-filetransfer-handler21.08.2.r220.g3eb1cbb-121.08.3.r221.g2a49068-1
telepathy-kde-integration-module21.08.2.r391.g52b0f46-121.08.3.r392.g16ab09b-1
telepathy-kde-send-file21.08.2.r229.g5c27a83-121.08.3.r230.g34d5b10-1
telepathy-kde-text-ui21.08.2.r2024.ga72376e-121.08.3.r2026.g4da58cd-1
tokodon 21.08.r17.ge894751-1 21.08.r19.g824b75f-1
umbrello21.08.2.r8269.g2d28d3030-121.08.3.r8270.g8160ef4c8-1
vvave 2.0.0.r65.gd6b7536-1 2.1.0.r2.g2bbc4ed-1
wrapland5.23.2.r1644.g2c19a619-15.23.3.r1652.gbd2e3208-1
xdg-desktop-portal-kde5.23.2.r395.g02ffa42-15.23.3.r396.gb1712a0-1
yakuake21.08.2.r738.g5716724-121.08.3.r741.gc197b08-1
zeroconf-ioslave21.08.2.r361.g04765a5-121.08.3.r362.g13a3f15-1
pico-wizard-git - r145.3577d18-3
pico-wizard-plamo-scripts - r145.3577d18-3
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
