Hello ARM community.
New KDE Plasma and lots of other stuff!
Plasma 5.23.1 is here!
Some highlights:
- Some of our kernels got updated
- KDE Plasma is now updated to 5.23.1
- And Pamac got some fixes for AUR
- LibreOffice got updated to 7.2.2
- glib2 and libffi both got updated. Did we miss any rebuilds?
- Lots of Mobile specific packages got updated
- Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Thu Oct 21 22:59:09 CEST 2021)
- arm-testing community aarch64: 325 new and 338 removed package(s)
- arm-testing core aarch64: 21 new and 22 removed package(s)
- arm-testing extra aarch64: 371 new and 370 removed package(s)
- arm-testing kde-unstable aarch64: 181 new and 174 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-10-12 2021-10-21
calls 41.0+37+g36880c3-1 41.0+52+g43fb850-1
chatty 0.4.0+172+g1d54b16-1 0.4.0+223+g58d96fb-1
code 1.61.0-1 1.61.2-1
electron 15.1.2-1 15.3.0-1
electron13 13.5.2-1 13.6.0-1
electron14 14.1.0-1 14.2.0-1
feedbackd 0.0.0+git20210531-1 0.0.0+git20211018-1
kodi-rpi 19.2-1 19.2-2
kodi-rpi-dev 19.2-1 19.2-2
kodi-rpi-eventclients 19.2-1 19.2-2
kodi-rpi-tools-texturepacker 19.2-1 19.2-2
mmsd-tng 1.3+1+g8efd579-1 1.4+3+gc162b5d-1
phoc 0.8.0+67+gaee845b-1 0.8.0+91+g75900fe-1
phosh 0.13.1+71+g63cc368-10.13.1+113+gc910e1d-1
pinephone-post-install 20210919-2 20211017-1
postmarketos-tweaks-app 0.8.0-1 0.8.1-1
postmarketos-tweaks-app-phosh 0.8.0-1 0.8.1-1
vivaldi 4.3.2439.44-1 4.3.2439.56-1
yay 11.0.1-2 11.0.2-1
pinephonepro-post-install - 20211021-1
:: Different sync package(s) in repository community aarch64
absl-py 0.13.0-1 0.14.1-1
aml 0.2.0-2 0.2.1-1
ansible-core 2.11.5-1 2.11.6-1
ansible-lint 5.2.0-1 5.2.1-1
apache-orc 1.6.9-1 1.7.0-1
arb 2.21.0-1 2.21.1-1
arch-repro-status 1.2.5-1 1.2.6-1
argocd 2.1.2-1 2.1.5-1
arrow 3.0.0-6 5.0.0-1
auto-multiple-choice 1.5.0-1 1.5.1-1
aws-c-common 0.6.12-1 0.6.14-1
awxkit 19.3.0-1 19.4.0-1
bctoolbox 5.0.32-1 5.0.36-1
blosc 1.21.0-1 1.21.1-1
btop 1.0.15-1 1.0.18-1
bzrtp 5.0.32-1 5.0.36-1
carla 2.4.0-1 2.4.1-1
cherrytree 0.99.39-2 0.99.42-1
chezmoi 2.6.0-1 2.7.1-1
cinnamon 5.0.5-1 5.0.6-1
cinnamon-screensaver 5.0.6-1 5.0.7-1
cjs 5.0.0-1 5.0.1-2.1
crystal 1.1.1-1 1.2.0-1
curator 5.7.6-5 5.7.6-6.1
dart 2.14.3-1 2.14.4-1
distrobuilder 1.3-2 2.0-1
dns-lexicon 3.7.0-1 3.8.0-1
dub 1.26.1-1 1.27.0-1
dunesh 0.0.1-1 0.1.7-1
dunst 1.6.1-2 1.7.0-1
epydoc 3.0.1-5 -
facter 3.14.18-1 3.14.19-1
fcitx5-pinyin-zhwiki 1:0.2.3.20210923-1 1:0.2.3.20211016-1
fcitx5-skk 5.0.7-1 5.0.8-1
featherpad 1.0.0-1 1.0.1-1
firefox-tree-style-tab 3.8.13-1 3.8.14-1
firefox-ublock-origin 1.38.4-1 1.38.6-1
fishui 0.4-2 0.5-1
flickcurl 1.26-11 1.26-12
flint 2.8.1-1 2.8.2-1
freerdp 2:2.4.0-1 2:2.4.0-2
fzf 0.27.2-2 0.27.3-1
gammaray 2.11.2-1 2.11.3-1
geany-plugins 1.37-4 1.38-1
giac 1.7.0.37-1 1.7.0.39-1
gimp-plugin-gmic 2.9.9-1 2.9.9-2
github-cli 2.0.0-1 2.1.0-1
gnustep-base 1.28.0-1 1.28.0-2.1
go-ethereum 1.10.9-1 1.10.10-1
gopls 0.7.2-1 0.7.3-1
gping 1.2.5-1 1.2.6-1
guake 3.7.0-2 3.8.0-1
helm 3.7.0-1 3.7.1-1
hiera 3.7.0-1 3.7.0-2
home-assistant 2021.10.3-1 2021.10.5-1
httpie 2.5.0-1 2.6.0-1
hyperfine 1.11.0-2 1.12.0-1
i3-gaps 4.19.1-1 4.20-1
i3-wm 4.19.2-1 4.20-1
igsc 0.2.3-1 0.2.4-1
jack_mixer 16-1.1 17-1
jami-daemon 20210308-1 20211004-1
jami-gnome 20210308-1 20211004-1
jenkins 2.315-1 2.317-1
jmol 14.31.57-1 14.31.59-1
jruby 9.3.0.0-1 9.3.1.0-1
jsmol 14.31.57-1 14.31.59-1
jupyterlab 3.1.18-1 3.2.1-1
klavaro 3.13-1 3.13-2
knot 3.0.8-2 3.1.3-1
knot-resolver 5.4.1-1 5.4.1-2
kodi-platform 20190726.809c5e9-28 20190726.809c5e9-31
krita-plugin-gmic 2.9.9-1 2.9.9-2
kvantum-qt5 0.20.2-1 0.20.2-2
kvazaar 2.0.0-1 2.1.0-1
leatherman 1.12.6-1 1.12.6-2
level-zero-headers 1.2.3-1 1.5.4-1
level-zero-loader 1.2.3-1 1.5.4-1
lfs 1.1.0-1 1.2.0-1
libaec 1.0.5-1 1.0.6-1
libcutefish 0.4-1 0.5-1
libfabric 1.13.0-1 1.13.2-1
libfilezilla 0.34.0-1 0.34.1-1
libjamiclient 20210301-1 20211004-1
libluv 1.41.0-1 1.42.0-1
libopensmtpd 0.6-2 0.7-1
libperconaserverclient 8.0.25_15-2 8.0.26_16-1
librdkafka 1.8.0-1 1.8.2-1
libretls 3.3.4-1 3.4.1-1
libsecp256k120201021+1209+gac05f61-120211017+1410+g9526874-2
libwhereami 0.5.0-7 0.5.0-8
libxmlb 0.3.2-1 0.3.3-1
libzim 6.3.2-1 7.0.0-1
lua-language-server 2.4.3-1 2.4.5-1
lxc 1:4.0.10-2 1:4.0.11-1
mailman 2.1.34-2 2.1.35-1
matrix-appservice-irc 0.31.0-1 0.32.0-1
matterbridge 1.22.3-2 1.23.0-1
maturin 0.11.4-1 0.11.5-1
mcollective 2.12.5-3 -
mediastreamer 5.0.32-1 5.0.36-1
mellite 3.7.0-1 3.8.0-1
minisign 0.9-1 0.10-1
mlt6 6.26.1-4 6.26.1-5
muffin 5.0.1-1 5.0.2-1
mysql-workbench 8.0.26-1 8.0.27-1
nemo 5.0.3-1 5.0.4-1
neomutt 20210205-1 20211015-1
netcdf-cxx 4.3.1-2 4.3.1-3
networkmanager-l2tp 1.8.6-5 1.20.0-1
nextcloud-app-bookmarks 1:10.0.0-1 1:10.0.2-1
nextcloud-app-spreed 1:12.2.0-1 1:12.2.1-1
nginx-mod-njs 0.6.2-1 0.7.0-1
nlohmann-json 3.10.3-1 3.10.4-1
nomacs 1:3.17.2206-3 1:3.17.2206-5
npm 8.0.0-1 8.1.0-1
nsd 4.3.7-1 4.3.8-1
oha 0.4.6-1 0.4.7-1
onionshare 2.4-1 2.4-2
opendht 1:2.1.10-3 1:2.3.1-1
opensips 3.1.2-1 3.1.2-2
opensmtpd-filter-dkimsign 0.5-1 0.5-2
opentimelineio 0.13-3 0.13-4
opentoonz 1.5.0-2 1.5.0-3
openttd 1.11.2-5 12.0-1
openttd-opengfx 0.6.1-1 7.1-1
optional-lite 3.5.0-1 -
ortp 5.0.32-1 5.0.36-1
percona-server 8.0.25_15-2 8.0.26_16-1
percona-server-clients 8.0.25_15-2 8.0.26_16-1
perl-glib-object-introspection 0.047-6 0.047-7.1
perl-net-dns-sec 1.18-3 1.19-1
perl-pegex 0.70-4 0.75-1
piping-server 0.8.5-1 0.9.1-1
plasma5-applets-thermal-monitor 1.3.0-1 1.3.0-2
plasma5-applets-window-buttons 0.9.0-1 0.9.0-3
poco 1.11.0-1 1.11.0-2
podman 3.4.0-1 3.4.1-1
podman-docker 3.4.0-1 3.4.1-1
procs 0.11.9-1 0.11.10-1
pulumi 3.14.0-1 3.15.0-1
puppet 6.23.0-1 7.12.0-1
puppet5 5.5.22-3 -
pv 1.6.6-3 1.6.20-1
pyright 1.1.178-1 1.1.180-1
python-anyio 3.3.3-1 3.3.4-1
python-astroid 2.8.2-1 2.8.3-1
python-authheaders 0.13.0-3 0.14.1-1
python-blosc 1.10.4-1 1.10.6-1
python-bracex 2.1.1-1 2.2-1
python-cbor2 5.4.1-2 5.4.2-1
python-cftime 1.5.0-1 1.5.1-1
python-cloudpickle 1.6.0-1 2.0.0-1
python-cx-freeze 6.7-1 6.8.1-1
python-dask 2021.3.0-1 2021.9.1-1
python-debian 0.1.41-1 0.1.42-1
python-debugpy 1.5.0-1 1.5.1-1
python-distributed 2021.3.0-1 2021.9.1-1
python-django-environ 0.7.0-1 0.8.0-1
python-elasticsearch-curator 5.7.6-5 5.7.6-6.1
python-fido2 0.9.1-1 0.9.2-1
python-flake8-isort 4.0.0-4 4.1.1-1
python-fsspec 0.8.7-1 2021.10.1-1
python-h5py 3.3.0-1 3.5.0-1
python-h5py-openmpi 3.3.0-1 3.5.0-1
python-icalendar 4.0.8-1 4.0.9-1
python-igraph 0.9.6-1 0.9.7-1
python-importlib_resources 5.2.2-1 5.3.0-1
python-jupyter_packaging 0.10.6-1 0.11.0-1
python-lsp-server 1.2.1-3 1.2.4-3
python-marshmallow 3.13.0-2 3.14.0-1
python-meilisearch 0.16.0-1 0.16.2-1
python-memory-allocator 0.1.1-1 0.1.2-1
python-moto 2.2.8-1 2.2.9-1
python-mpi4py 3.0.3-3 3.1.1-1
python-pdfminer 20201018-3 20201018-4
python-pg8000 1.21.3-1 1.22.0-1
python-phonenumbers 8.12.33-1 8.12.34-1
python-pillow 8.3.2-1 8.4.0-1
python-progressbar 3.53.3-1 3.55.0-1
python-pyarrow 3.0.0-1 5.0.0-1
python-pycares 4.0.0-1 4.1.2-1
python-pyls-spyder 0.3.2-1 0.4.0-1
python-pymupdf 1.18.19-1 1.19.0-1
python-pyspnego 0.1.6-1 0.2.0-3
python-pywlroots 0.14.7-1 0.14.9-1
python-qstylizer 0.2.0-1 0.2.1-1
python-qtawesome 1.0.2-1 1.0.3-1
python-qtpy 1.9.0-5 1.11.2-1
python-rapidjson 1.4-1 1.5-1
python-reportlab 3.6.1-1 3.6.2-1
python-smbprotocol 1.5.0-1 1.7.0-1
python-smmap 1:4.0.0-1 1:5.0.0-1
python-spyder-kernels 2.0.1-1 2.1.3-1
python-stevedore 3.4.0-1 3.5.0-1
python-structlog 21.1.0-1 21.2.0-1
python-tzlocal 2.1-3 4.0.1-1
python-wurlitzer 2.1.1-1 3.0.2-1
python-xarray 0.17.0-1 0.19.0-1
python-zeroconf 0.36.4-1 0.36.8-1
python-zope-schema 6.1.0-1 6.1.1-1
python-zopfli 0.1.8-1 0.1.9-1
python-zstandard 0.15.2-1 0.16.0-1
python2-gobject 3.36.1-3 3.36.1-4.1
qcad 3.26.4.8-1 3.26.4.10-1
qtractor 0.9.23-1 0.9.24-1
rebuilderd 0.14.2-1 0.15.0-1
rebuilderd-tools 0.14.2-1 0.15.0-1
redmine 4.2.2-1 4.2.2-2.1
remmina 1:1.4.20-1 1:1.4.21-1
retroarch-assets-glui 1:384-1 1:391-1
retroarch-assets-ozone 1:384-1 1:391-1
retroarch-assets-xmb 1:384-1 1:391-1
revive 1.1.0-1 1.1.2-1
rhonabwy 1.1.0-1 1.1.1-1
rime-pinyin-zhwiki 1:0.2.3.20210923-1 1:0.2.3.20211016-1
roundcubemail 1.4.11-1 1.5.0-1
rssguard 4.0.3-1 4.0.4-1
rssguard-nowebengine 4.0.3-1 4.0.4-1
ruby-faraday-middleware 1.1.0-1 1.2.0-1
ruby-ffi 1.15.4-1 1.15.4-2.1
ruby-json 2.5.1-3 2.6.0-1
ruby2.6 2.6.8-1 2.6.8-2.1
ruby2.7 2.7.4-1 2.7.4-2.1
ruby27-augeas 0.5.0-3 -
ruby27-concurrent 1.1.8-1 -
ruby27-deep_merge 1.2.1-1 -
ruby27-diff-lcs 1.4.4-1 -
ruby27-hocon 1.3.1-3 -
ruby27-hoe 3.22.3-3 -
ruby27-httpclient 2.8.3-2 -
ruby27-minitest 5.14.3-3 -
ruby27-mocha 1.12.0-1 -
ruby27-multi_json 1.15.0-1 -
ruby27-power_assert 2.0.0-1 -
ruby27-puppet-resource_api 1.8.13-1 -
ruby27-rake 13.0.3-2 -
ruby27-rdoc 6.3.1-1 -
ruby27-rspec 3.10.0-1 -
ruby27-rspec-core 3.10.1-2 -
ruby27-rspec-expectations 3.10.1-1 -
ruby27-rspec-mocks 3.10.2-1 -
ruby27-rspec-support 3.10.2-1 -
ruby27-semantic_puppet 1.0.3-2 -
ruby27-shadow 2.5.0-1 -
ruby27-sync 0.5.0-1 -
ruby27-test-unit 3.4.1-1 -
rust-analyzer 20211011-1 20211018-1
scummvm 2.5.0-1 2.5.0-3
seamonkey 2.53.9.1-1 2.53.9.1-2.1
serverless 2.60.3-1 2.64.1-1
shards 0.15.0-1 0.16.0-1
squeak-vm 4.10.2.2614-5 4.10.2.2614-6.1
sssd 2.5.2-2 2.6.0-1
step-cli 0.17.6-1 0.17.7-1
strawberry 0.9.3-3 1.0.0-1
sway 1:1.6.1-1 1:1.6.1-2
sz 2.1.11.2-1 2.1.12-1
tailscale 1.16.0-1 1.16.1-1
tanka 0.17.3-1 0.18.2-1
task 2.6.0-1 2.6.1-1
terragrunt 0.35.2-1 0.35.3-1
timescaledb-tune 0.11.3-1 0.12.0-1
transmission-remote-gtk 1.4.1-2 1.4.2-1
ts-node 10.2.1-1 10.3.0-1
ttc-iosevka 10.3.1-1 10.3.3-1
ttc-iosevka-aile 10.3.1-1 10.3.3-1
ttc-iosevka-curly 10.3.1-1 10.3.3-1
ttc-iosevka-curly-slab 10.3.1-1 10.3.3-1
ttc-iosevka-etoile 10.3.1-1 10.3.3-1
ttc-iosevka-slab 10.3.1-1 10.3.3-1
ttc-iosevka-ss01 10.3.1-1 10.3.3-1
ttc-iosevka-ss02 10.3.1-1 10.3.3-1
ttc-iosevka-ss03 10.3.1-1 10.3.3-1
ttc-iosevka-ss04 10.3.1-1 10.3.3-1
ttc-iosevka-ss05 10.3.1-1 10.3.3-1
ttc-iosevka-ss06 10.3.1-1 10.3.3-1
ttc-iosevka-ss07 10.3.1-1 10.3.3-1
ttc-iosevka-ss08 10.3.1-1 10.3.3-1
ttc-iosevka-ss09 10.3.1-1 10.3.3-1
ttc-iosevka-ss10 10.3.1-1 10.3.3-1
ttc-iosevka-ss11 10.3.1-1 10.3.3-1
ttc-iosevka-ss12 10.3.1-1 10.3.3-1
ttc-iosevka-ss13 10.3.1-1 10.3.3-1
ttc-iosevka-ss14 10.3.1-1 10.3.3-1
ttc-iosevka-ss15 10.3.1-1 10.3.3-1
ttc-iosevka-ss16 10.3.1-1 10.3.3-1
ttc-iosevka-ss17 10.3.1-1 10.3.3-1
ttc-iosevka-ss18 10.3.1-1 10.3.3-1
ttf-sarasa-gothic 0.34.4-1 0.34.6-1
typescript 4.4.3-1 4.4.4-1
ukui-biometric-auth 1.2.2-1 1.2.2-2
ukui-greeter 3.0.2-1 3.0.2-2
ukui-screensaver 3.0.2-1 3.0.2-2
unhide 20130526-3 20210124-1
v2ray-domain-list-community 20211005043132-1 20211018134657-1
v2ray-geoip 202110070028-1 202110140026-1
v4l2loopback-dkms 0.12.5-1 0.12.5-2
vapoursynth R56-1 R57-1
vaultwarden 1.22.2-1 1.23.0-1
vaultwarden-web 2.23.0-1 2.23.0.c-1
verilator 4.212-1 4.214-1
virt-install 3.2.0-1 3.2.0-3
virt-manager 3.2.0-1 3.2.0-3
vultr-cli 2.8.4-1 2.8.5-1
wasmer 2.0.0-2 2.0.0-3.1
woob 3.0-2 3.0-3
wpscan 1:3.8.19-1 1:3.8.19-3.1
x42-plugins 20211012-1 20211016-1
xapp 2.2.3-1 2.2.4-1
xfce4-whiskermenu-plugin 2.6.0-1 2.6.1-1
xsimd 7.6.0-1 8.0.3-1
yarn 1.22.15-1 1.22.17-1
yosys 0.10-1 0.10-2.1
zim 0.74.1-1 0.74.2-1
zim-tools 2.1.0-1 3.0.0-1
zoxide 0.7.5-1 0.7.8-1
jami-qt - 20211004-1
jenv - 0.5.4.r12.7053916-1
kubeconform - 0.4.12-1
perl-yaml-pp - 0.026-1
python-krb5 - 0.1.2-1
python-lsp-black - 1.0.0-2
python-pytest-dependency - 0.5.1-1
python-pytest-order - 1.0.0-1
python-pytz-deprecation-shim - 0.1.0.post0-1
python-tzdata - 2021.4-1
rkcommon - 1.7.0-1
v4l2loopback-utils - 0.12.5-2
zellij - 0.19.0-2
:: Different overlay package(s) in repository core aarch64
glib2 2.70.0-1.1 -
linux 5.14.12-1 5.14.14-1
linux-headers 5.14.12-1 5.14.14-1
linux-pinephone 5.14.12-1 5.14.14-1
linux-pinephone-headers 5.14.12-1 5.14.14-1
linux-rc 5.15.rc5-1 5.15.rc6-2
linux-rc-headers 5.15.rc5-1 5.15.rc6-2
uboot-pinephone 2021.10-1 2021.10-2
:: Different sync package(s) in repository core aarch64
file 5.40-6 5.41-1
glib2 2.70.0-1 2.70.0-2.1
glib2-docs 2.70.0-1 2.70.0-2.1
libffi 3.3-4 3.4.2-4
libp11-kit 0.24.0-1 0.24.0-2.1
make 4.3-3 4.3-3.1
python 3.9.7-1 3.9.7-2.1
python-tests 3.9.7-1 3.9.7-2.1
systemd 249.4-2 249.5-2
systemd-libs 249.4-2 249.5-2
systemd-resolvconf 249.4-2 249.5-2
systemd-sysvcompat 249.4-2 249.5-2
tzdata 2021c-1 2021d-1
:: Different overlay package(s) in repository extra aarch64
libpamac 11.1.0-1 11.1.3-1
libpamac-flatpak-plugin 11.1.0-1 11.1.3-1
libpamac-snap-plugin 11.1.0-1 11.1.3-1
manjaro-arm-tools 2.10.3-1 2.10.4-1
manjaro-settings-manager 0.5.6-8 0.5.6-9
manjaro-settings-manager-kcm 0.5.6-8 0.5.6-9
mesa-git21.3.0_devel.146021.3e36a20a34d-122.0.0_devel.146279.d31ca63527e-1
pamac-cli 10.2.0-1 10.2.2-5
pamac-gnome-integration 10.2.0-1 10.2.2-5
pamac-gtk 10.2.0-1 10.2.2-5
plasma-mobile-nm 5.22.5-1 5.23.1-1
plasma-nano 5.22.5-1 5.23.1-1
plasma-phone-components 5.22.5-1 5.23.1-1
qqc2-breeze-style 5.22.5-1.1 5.23.1-1
:: Different sync package(s) in repository extra aarch64
aom 3.1.3-2 3.2.0-1
aom-docs 3.1.3-2 3.2.0-1
archlinux-appstream-data 20210929-1 20211018-1
audacious-plugins 4.1-4 4.1-5
bluedevil 1:5.22.5-1 1:5.23.1-1
breeze 5.22.5-1 5.23.1-1
breeze-grub 5.22.5-1 5.23.1-1
breeze-gtk 5.22.5-1 5.23.1-1
chromium 94.0.4606.81-1 95.0.4638.54-2.1
discover 5.22.5-2 5.23.1-1
drkonqi 5.22.5-1 5.23.1-1
ecl 21.2.1-1 21.2.1-2.1
finch 2.14.7-1 2.14.8-1
git 2.33.0-1 2.33.1-1
gjs 2:1.68.3-1 2:1.68.3-2.1
gobject-introspection 1.70.0-1 1.70.0-2.1
gobject-introspection-runtime 1.70.0-1 1.70.0-2.1
graphviz 2.49.1-1 2.49.2-1
gst-plugin-opencv 1.18.5-1 1.18.5-2
gst-plugin-wpe 1.18.5-1 1.18.5-2
gst-plugins-bad 1.18.5-1 1.18.5-2
gst-plugins-bad-libs 1.18.5-1 1.18.5-2
guile 2.2.7-1 2.2.7-2.1
guile2.0 2.0.14-5 2.0.14-6.1
htop 3.1.0-1 3.1.1-1
kactivitymanagerd 5.22.5-1 5.23.1-1
kde-cli-tools 5.22.5-1 5.23.1-1
kde-gtk-config 5.22.5-1 5.23.1-1
kdecoration 5.22.5-1 5.23.1-1
kdeplasma-addons 5.22.5-1 5.23.1-1
kgamma5 5.22.5-1 5.23.1-1
khotkeys 5.22.5-1 5.23.1-1
kinfocenter 5.22.5-1 5.23.1-1
kmenuedit 5.22.5-1 5.23.1-1
kscreen 5.22.5-1 5.23.1-1
kscreenlocker 5.22.5-1 5.23.1-1
ksshaskpass 5.22.5-1 5.23.1-1
ksystemstats 5.22.5-1 5.23.1-1
kwallet-pam 5.22.5-1 5.23.1-1
kwayland-integration 5.22.5-1 5.23.1-1
kwayland-server 5.22.5-1 5.23.1-1
kwin 5.22.5-1 5.23.1-1
kwrited 5.22.5-1 5.23.1-1
layer-shell-qt 5.22.5-1 5.23.1-1
libgnt 2.14.2-1 2.14.3-1
libkscreen 5.22.5-1 5.23.1-1
libksysguard 5.22.5-1 5.23.1-1
libpurple 2.14.7-1 2.14.8-1
libreoffice-fresh 7.2.1-3 7.2.2-1
libreoffice-fresh-af 7.2.1-1 7.2.2-1
libreoffice-fresh-am 7.2.1-1 7.2.2-1
libreoffice-fresh-ar 7.2.1-1 7.2.2-1
libreoffice-fresh-as 7.2.1-1 7.2.2-1
libreoffice-fresh-ast 7.2.1-1 7.2.2-1
libreoffice-fresh-be 7.2.1-1 7.2.2-1
libreoffice-fresh-bg 7.2.1-1 7.2.2-1
libreoffice-fresh-bn 7.2.1-1 7.2.2-1
libreoffice-fresh-bn-in 7.2.1-1 7.2.2-1
libreoffice-fresh-bo 7.2.1-1 7.2.2-1
libreoffice-fresh-br 7.2.1-1 7.2.2-1
libreoffice-fresh-brx 7.2.1-1 7.2.2-1
libreoffice-fresh-bs 7.2.1-1 7.2.2-1
libreoffice-fresh-ca 7.2.1-1 7.2.2-1
libreoffice-fresh-ca-valencia 7.2.1-1 7.2.2-1
libreoffice-fresh-ckb 7.2.1-1 7.2.2-1
libreoffice-fresh-cs 7.2.1-1 7.2.2-1
libreoffice-fresh-cy 7.2.1-1 7.2.2-1
libreoffice-fresh-da 7.2.1-1 7.2.2-1
libreoffice-fresh-de 7.2.1-1 7.2.2-1
libreoffice-fresh-dgo 7.2.1-1 7.2.2-1
libreoffice-fresh-dsb 7.2.1-1 7.2.2-1
libreoffice-fresh-dz 7.2.1-1 7.2.2-1
libreoffice-fresh-el 7.2.1-1 7.2.2-1
libreoffice-fresh-en-gb 7.2.1-1 7.2.2-1
libreoffice-fresh-en-za 7.2.1-1 7.2.2-1
libreoffice-fresh-eo 7.2.1-1 7.2.2-1
libreoffice-fresh-es 7.2.1-1 7.2.2-1
libreoffice-fresh-et 7.2.1-1 7.2.2-1
libreoffice-fresh-eu 7.2.1-1 7.2.2-1
libreoffice-fresh-fa 7.2.1-1 7.2.2-1
libreoffice-fresh-fi 7.2.1-1 7.2.2-1
libreoffice-fresh-fr 7.2.1-1 7.2.2-1
libreoffice-fresh-fur 7.2.1-1 7.2.2-1
libreoffice-fresh-fy 7.2.1-1 7.2.2-1
libreoffice-fresh-ga 7.2.1-1 7.2.2-1
libreoffice-fresh-gd 7.2.1-1 7.2.2-1
libreoffice-fresh-gl 7.2.1-1 7.2.2-1
libreoffice-fresh-gu 7.2.1-1 7.2.2-1
libreoffice-fresh-gug 7.2.1-1 7.2.2-1
libreoffice-fresh-he 7.2.1-1 7.2.2-1
libreoffice-fresh-hi 7.2.1-1 7.2.2-1
libreoffice-fresh-hr 7.2.1-1 7.2.2-1
libreoffice-fresh-hsb 7.2.1-1 7.2.2-1
libreoffice-fresh-hu 7.2.1-1 7.2.2-1
libreoffice-fresh-id 7.2.1-1 7.2.2-1
libreoffice-fresh-is 7.2.1-1 7.2.2-1
libreoffice-fresh-it 7.2.1-1 7.2.2-1
libreoffice-fresh-ja 7.2.1-1 7.2.2-1
libreoffice-fresh-ka 7.2.1-1 7.2.2-1
libreoffice-fresh-kab 7.2.1-1 7.2.2-1
libreoffice-fresh-kk 7.2.1-1 7.2.2-1
libreoffice-fresh-km 7.2.1-1 7.2.2-1
libreoffice-fresh-kmr-latn 7.2.1-1 7.2.2-1
libreoffice-fresh-kn 7.2.1-1 7.2.2-1
libreoffice-fresh-ko 7.2.1-1 7.2.2-1
libreoffice-fresh-kok 7.2.1-1 7.2.2-1
libreoffice-fresh-ks 7.2.1-1 7.2.2-1
libreoffice-fresh-lb 7.2.1-1 7.2.2-1
libreoffice-fresh-lo 7.2.1-1 7.2.2-1
libreoffice-fresh-lt 7.2.1-1 7.2.2-1
libreoffice-fresh-lv 7.2.1-1 7.2.2-1
libreoffice-fresh-mai 7.2.1-1 7.2.2-1
libreoffice-fresh-mk 7.2.1-1 7.2.2-1
libreoffice-fresh-ml 7.2.1-1 7.2.2-1
libreoffice-fresh-mn 7.2.1-1 7.2.2-1
libreoffice-fresh-mni 7.2.1-1 7.2.2-1
libreoffice-fresh-mr 7.2.1-1 7.2.2-1
libreoffice-fresh-my 7.2.1-1 7.2.2-1
libreoffice-fresh-nb 7.2.1-1 7.2.2-1
libreoffice-fresh-ne 7.2.1-1 7.2.2-1
libreoffice-fresh-nl 7.2.1-1 7.2.2-1
libreoffice-fresh-nn 7.2.1-1 7.2.2-1
libreoffice-fresh-nr 7.2.1-1 7.2.2-1
libreoffice-fresh-nso 7.2.1-1 7.2.2-1
libreoffice-fresh-oc 7.2.1-1 7.2.2-1
libreoffice-fresh-om 7.2.1-1 7.2.2-1
libreoffice-fresh-or 7.2.1-1 7.2.2-1
libreoffice-fresh-pa-in 7.2.1-1 7.2.2-1
libreoffice-fresh-pl 7.2.1-1 7.2.2-1
libreoffice-fresh-pt 7.2.1-1 7.2.2-1
libreoffice-fresh-pt-br 7.2.1-1 7.2.2-1
libreoffice-fresh-ro 7.2.1-1 7.2.2-1
libreoffice-fresh-ru 7.2.1-1 7.2.2-1
libreoffice-fresh-rw 7.2.1-1 7.2.2-1
libreoffice-fresh-sa-in 7.2.1-1 7.2.2-1
libreoffice-fresh-sat 7.2.1-1 7.2.2-1
libreoffice-fresh-sd 7.2.1-1 7.2.2-1
libreoffice-fresh-sdk 7.2.1-3 7.2.2-1
libreoffice-fresh-si 7.2.1-1 7.2.2-1
libreoffice-fresh-sid 7.2.1-1 7.2.2-1
libreoffice-fresh-sk 7.2.1-1 7.2.2-1
libreoffice-fresh-sl 7.2.1-1 7.2.2-1
libreoffice-fresh-sq 7.2.1-1 7.2.2-1
libreoffice-fresh-sr 7.2.1-1 7.2.2-1
libreoffice-fresh-sr-latn 7.2.1-1 7.2.2-1
libreoffice-fresh-ss 7.2.1-1 7.2.2-1
libreoffice-fresh-st 7.2.1-1 7.2.2-1
libreoffice-fresh-sv 7.2.1-1 7.2.2-1
libreoffice-fresh-sw-tz 7.2.1-1 7.2.2-1
libreoffice-fresh-szl 7.2.1-1 7.2.2-1
libreoffice-fresh-ta 7.2.1-1 7.2.2-1
libreoffice-fresh-te 7.2.1-1 7.2.2-1
libreoffice-fresh-tg 7.2.1-1 7.2.2-1
libreoffice-fresh-th 7.2.1-1 7.2.2-1
libreoffice-fresh-tn 7.2.1-1 7.2.2-1
libreoffice-fresh-tr 7.2.1-1 7.2.2-1
libreoffice-fresh-ts 7.2.1-1 7.2.2-1
libreoffice-fresh-tt 7.2.1-1 7.2.2-1
libreoffice-fresh-ug 7.2.1-1 7.2.2-1
libreoffice-fresh-uk 7.2.1-1 7.2.2-1
libreoffice-fresh-uz 7.2.1-1 7.2.2-1
libreoffice-fresh-ve 7.2.1-1 7.2.2-1
libreoffice-fresh-vec 7.2.1-1 7.2.2-1
libreoffice-fresh-vi 7.2.1-1 7.2.2-1
libreoffice-fresh-xh 7.2.1-1 7.2.2-1
libreoffice-fresh-zh-cn 7.2.1-1 7.2.2-1
libreoffice-fresh-zh-tw 7.2.1-1 7.2.2-1
libreoffice-fresh-zu 7.2.1-1 7.2.2-1
libsrtp 1:2.4.0-1 1:2.4.2-1
libva-mesa-driver 21.2.3-1 21.2.4-1
llvm 12.0.1-4 12.0.1-5.1
llvm-libs 12.0.1-4 12.0.1-5.1
llvm-ocaml 12.0.1-4 12.0.1-5.1
llvm10 10.0.1-8 10.0.1-9.1
llvm10-libs 10.0.1-8 10.0.1-9.1
llvm11 11.1.0-4 11.1.0-5.1
llvm11-libs 11.1.0-4 11.1.0-5.1
lua53-lgi 0.9.2-3 0.9.2-4.1
malcontent 0.10.1-1 0.10.2-1
mencoder 38157-4 38322-1
mesa 21.2.3-1 21.2.4-1
mesa-vdpau 21.2.3-1 21.2.4-1
milou 5.22.5-1 5.23.1-1
mlt 7.0.1-1 7.0.1-2
mpd 0.22.11-1 0.23.1-1
mpg123 1.29.0-1 1.29.1-1
mplayer 38157-4 38322-1
ocaml-ctypes 0.17.1-6 0.17.1-8.1
opencl-mesa 21.2.3-1 21.2.4-1
oxygen 5.22.5-1 5.23.1-1
php 8.0.11-1 8.0.12-1
php-apache 8.0.11-1 8.0.12-1
php-cgi 8.0.11-1 8.0.12-1
php-dblib 8.0.11-1 8.0.12-1
php-embed 8.0.11-1 8.0.12-1
php-enchant 8.0.11-1 8.0.12-1
php-fpm 8.0.11-1 8.0.12-1
php-gd 8.0.11-1 8.0.12-1
php-imap 8.0.11-1 8.0.12-1
php-intl 8.0.11-1 8.0.12-1
php-odbc 8.0.11-1 8.0.12-1
php-pgsql 8.0.11-1 8.0.12-1
php-phpdbg 8.0.11-1 8.0.12-1
php-pspell 8.0.11-1 8.0.12-1
php-snmp 8.0.11-1 8.0.12-1
php-sodium 8.0.11-1 8.0.12-1
php-sqlite 8.0.11-1 8.0.12-1
php-tidy 8.0.11-1 8.0.12-1
php-xsl 8.0.11-1 8.0.12-1
php7 7.4.24-1 7.4.25-1
php7-apache 7.4.24-1 7.4.25-1
php7-cgi 7.4.24-1 7.4.25-1
php7-dblib 7.4.24-1 7.4.25-1
php7-embed 7.4.24-1 7.4.25-1
php7-enchant 7.4.24-1 7.4.25-1
php7-fpm 7.4.24-1 7.4.25-1
php7-gd 7.4.24-1 7.4.25-1
php7-imap 7.4.24-1 7.4.25-1
php7-intl 7.4.24-1 7.4.25-1
php7-odbc 7.4.24-1 7.4.25-1
php7-pgsql 7.4.24-1 7.4.25-1
php7-phpdbg 7.4.24-1 7.4.25-1
php7-pspell 7.4.24-1 7.4.25-1
php7-snmp 7.4.24-1 7.4.25-1
php7-sodium 7.4.24-1 7.4.25-1
php7-sqlite 7.4.24-1 7.4.25-1
php7-tidy 7.4.24-1 7.4.25-1
php7-xsl 7.4.24-1 7.4.25-1
pidgin 2.14.7-1 2.14.8-1
plasma-browser-integration 5.22.5-1 5.23.1-1
plasma-desktop 5.22.5-1 5.23.1-1
plasma-disks 5.22.5-1 5.23.1-1
plasma-firewall 5.22.5-1 5.23.1-1
plasma-integration 5.22.5-1 5.23.1-1
plasma-meta 5.22-1 5.23-1
plasma-nm 5.22.5-1 5.23.1-1
plasma-pa 5.22.5-1 5.23.1-1
plasma-sdk 5.22.5-1 5.23.1-1
plasma-systemmonitor 5.22.5-1 5.23.1-1
plasma-thunderbolt 5.22.5-1 5.23.1-1
plasma-vault 5.22.5-1 5.23.1-1
plasma-wayland-session 5.22.5-2 5.23.1-1
plasma-workspace 5.22.5-2 5.23.1-1
plasma-workspace-wallpapers 5.22.5-1 5.23.1-1
polkit-kde-agent 5.22.5-1 5.23.1-1
power-profiles-daemon 0.10.0-1 0.10.0-2
powerdevil 5.22.5-1 5.23.1-1
python-cffi 1.14.6-1 1.14.6-2.1
python-feedparser 5.2.1-9 6.0.1-2
python-gobject 3.40.1-1 3.40.1-2.1
python-pyqt5 5.15.4-1 5.15.5-1
python-pyqt5-networkauth 5.15.4-1 5.15.5-1
python-pyqt5-webengine 5.15.4-1 5.15.5-1
python-qscintilla-qt5 2.13.0-1 2.13.1-1
python-qscintilla-qt6 2.13.0-1 2.13.1-1
python-sgmllib 5.2.1-9 -
python2 2.7.18-4 2.7.18-5.1
python2-cffi 1.14.6-1 1.14.6-2.1
python2-feedparser 5.2.1-9 -
qemu 6.1.0-2 6.1.0-5
qemu-arch-extra 6.1.0-2 6.1.0-5
qemu-block-gluster 6.1.0-2 6.1.0-5
qemu-block-iscsi 6.1.0-2 6.1.0-5
qemu-guest-agent 6.1.0-2 6.1.0-5
qemu-headless 6.1.0-2 6.1.0-5
qemu-headless-arch-extra 6.1.0-2 6.1.0-5
qt5-base 5.15.2+kde+r237-1 5.15.2+kde+r251-1
qt5-declarative 5.15.2+kde+r33-1 5.15.2+kde+r36-1
qt5-doc 5.15.2-1 5.15.2-2
qt5-examples 5.15.2-1 5.15.2-2
qt5-svg 5.15.2+kde+r7-1 5.15.2+kde+r13-1
qt5-wayland 5.15.2+kde+r33-1 5.15.2+kde+r34-1
qt5-webengine 5.15.6-2 5.15.6-4
qt5-xcb-private-headers 5.15.2+kde+r237-1 5.15.2+kde+r251-1
qtkeychain-qt5 0.12.0-1 0.12.0-2
qtkeychain-qt6 0.12.0-1 0.12.0-2
ruby 3.0.2-1 3.0.2-2.1
ruby-docs 3.0.2-1 3.0.2-2.1
sddm-kcm 5.22.5-1 5.23.1-1
sip 6.3.0-1 6.3.1-1
systemsettings 5.22.5-1 5.23.1-1
thunderbird 91.2.0-1 91.2.0-2.1
thunderbird-i18n-af 91.2.0-1 91.2.0-2.1
thunderbird-i18n-ar 91.2.0-1 91.2.0-2.1
thunderbird-i18n-ast 91.2.0-1 91.2.0-2.1
thunderbird-i18n-be 91.2.0-1 91.2.0-2.1
thunderbird-i18n-bg 91.2.0-1 91.2.0-2.1
thunderbird-i18n-br 91.2.0-1 91.2.0-2.1
thunderbird-i18n-ca 91.2.0-1 91.2.0-2.1
thunderbird-i18n-cak 91.2.0-1 91.2.0-2.1
thunderbird-i18n-cs 91.2.0-1 91.2.0-2.1
thunderbird-i18n-cy 91.2.0-1 91.2.0-2.1
thunderbird-i18n-da 91.2.0-1 91.2.0-2.1
thunderbird-i18n-de 91.2.0-1 91.2.0-2.1
thunderbird-i18n-dsb 91.2.0-1 91.2.0-2.1
thunderbird-i18n-el 91.2.0-1 91.2.0-2.1
thunderbird-i18n-en-gb 91.2.0-1 91.2.0-2.1
thunderbird-i18n-en-us 91.2.0-1 91.2.0-2.1
thunderbird-i18n-es-ar 91.2.0-1 91.2.0-2.1
thunderbird-i18n-es-es 91.2.0-1 91.2.0-2.1
thunderbird-i18n-et 91.2.0-1 91.2.0-2.1
thunderbird-i18n-eu 91.2.0-1 91.2.0-2.1
thunderbird-i18n-fi 91.2.0-1 91.2.0-2.1
thunderbird-i18n-fr 91.2.0-1 91.2.0-2.1
thunderbird-i18n-fy-nl 91.2.0-1 91.2.0-2.1
thunderbird-i18n-ga-ie 91.2.0-1 91.2.0-2.1
thunderbird-i18n-gd 91.2.0-1 91.2.0-2.1
thunderbird-i18n-gl 91.2.0-1 91.2.0-2.1
thunderbird-i18n-he 91.2.0-1 91.2.0-2.1
thunderbird-i18n-hr 91.2.0-1 91.2.0-2.1
thunderbird-i18n-hsb 91.2.0-1 91.2.0-2.1
thunderbird-i18n-hu 91.2.0-1 91.2.0-2.1
thunderbird-i18n-hy-am 91.2.0-1 91.2.0-2.1
thunderbird-i18n-id 91.2.0-1 91.2.0-2.1
thunderbird-i18n-is 91.2.0-1 91.2.0-2.1
thunderbird-i18n-it 91.2.0-1 91.2.0-2.1
thunderbird-i18n-ja 91.2.0-1 91.2.0-2.1
thunderbird-i18n-ka 91.2.0-1 91.2.0-2.1
thunderbird-i18n-kab 91.2.0-1 91.2.0-2.1
thunderbird-i18n-kk 91.2.0-1 91.2.0-2.1
thunderbird-i18n-ko 91.2.0-1 91.2.0-2.1
thunderbird-i18n-lt 91.2.0-1 91.2.0-2.1
thunderbird-i18n-ms 91.2.0-1 91.2.0-2.1
thunderbird-i18n-nb-no 91.2.0-1 91.2.0-2.1
thunderbird-i18n-nl 91.2.0-1 91.2.0-2.1
thunderbird-i18n-nn-no 91.2.0-1 91.2.0-2.1
thunderbird-i18n-pa-in 91.2.0-1 91.2.0-2.1
thunderbird-i18n-pl 91.2.0-1 91.2.0-2.1
thunderbird-i18n-pt-br 91.2.0-1 91.2.0-2.1
thunderbird-i18n-pt-pt 91.2.0-1 91.2.0-2.1
thunderbird-i18n-rm 91.2.0-1 91.2.0-2.1
thunderbird-i18n-ro 91.2.0-1 91.2.0-2.1
thunderbird-i18n-ru 91.2.0-1 91.2.0-2.1
thunderbird-i18n-sk 91.2.0-1 91.2.0-2.1
thunderbird-i18n-sl 91.2.0-1 91.2.0-2.1
thunderbird-i18n-sq 91.2.0-1 91.2.0-2.1
thunderbird-i18n-sr 91.2.0-1 91.2.0-2.1
thunderbird-i18n-sv-se 91.2.0-1 91.2.0-2.1
thunderbird-i18n-th 91.2.0-1 91.2.0-2.1
thunderbird-i18n-tr 91.2.0-1 91.2.0-2.1
thunderbird-i18n-uk 91.2.0-1 91.2.0-2.1
thunderbird-i18n-uz 91.2.0-1 91.2.0-2.1
thunderbird-i18n-vi 91.2.0-1 91.2.0-2.1
thunderbird-i18n-zh-cn 91.2.0-1 91.2.0-2.1
thunderbird-i18n-zh-tw 91.2.0-1 91.2.0-2.1
vulkan-broadcom 21.2.3-1 21.2.4-1
vulkan-mesa-layers 21.2.3-1 21.2.4-1
vulkan-panfrost 21.2.3-1 21.2.4-1
vulkan-radeon 21.2.3-1 21.2.4-1
vulkan-swrast 21.2.3-1 21.2.4-1
wayland 1.19.0-1 1.19.0-2.1
wayland-docs 1.19.0-1 1.19.0-2.1
xdg-desktop-portal-kde 5.22.5-1 5.23.1-1
xscreensaver 6.01-1 6.02-1
libopenmpt - 0.5.12-3
mokutil - 0.5.0-1
python-sgmllib3k - 1.0.0-2
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.08.2.r12617.g14039b8f5-121.08.2.r12631.g93214347f-1
akonadi-calendar21.08.2.r1997.g276e9a8-121.08.2.r1998.g14267ba-1
akonadi-contacts21.08.2.r3070.g3fb27ed5-121.08.2.r3073.g280e389c-1
akonadi-import-wizard21.08.2.r1760.gd7ed78d-121.08.2.r1761.g7058a4f-1
akonadiconsole21.08.2.r1538.gf6676d2-121.08.2.r1539.gf829eb2-1
akregator21.08.2.r6238.gaf5420b6-121.08.2.r6240.gbef212dd-1
angelfish 21.08.r33.g1757260-1 21.08.r35.ga4409bb-1
ark21.08.2.r4619.g171f8cbb-121.08.2.r4621.gc31afbce-1
blinken21.08.2.r637.g76afdb6-121.08.2.r638.g2e4891e-1
bluedevil1:5.22.5.r2294.gb4197ece-11:5.23.1.r2295.gfcd8d68c-1
bomber21.08.2.r532.g7eb9b0c-121.08.2.r534.g0869ce2-1
bovo21.08.2.r742.g02ad3ca-121.08.2.r744.g1421b72-1
breeze5.22.5.r2289.g7f9f732a-15.23.1.r2289.g7f9f732a-1
breeze-grub5.22.5.r11.g63136a9-15.23.1.r11.g63136a9-1
breeze-gtk5.22.5.r427.g4e3d0c7-15.23.1.r427.g4e3d0c7-1
breeze-icons5.87.0.r1810.gf44b1342-15.87.0.r1812.gc0a4f65e-1
discover5.22.5.r8362.ge78ff92c-15.23.1.r8385.g198dde85-1
disman5.22.4.r1810.g82fb1b8-15.22.4.r1811.gca36775-1
drkonqi5.22.5.r704.gfc4d0ff6-15.23.1.r705.gaea7570b-1
elisa21.08.2.r2783.ga4c31304-121.08.2.r2784.gce301cbc-1
extra-cmake-modules5.87.0.r3379.ge8a4dc1-15.87.0.r3380.ge62246c-1
frameworkintegration5.87.0.r603.g58bd1b6-15.87.0.r604.g5ad2efd-1
granatier21.08.2.r936.gc246393-121.08.2.r937.g813ae8f-1
grantleetheme21.08.2.r353.g1fbee51-121.08.2.r354.g99c7a94-1
gwenview21.08.2.r6682.gcce25ca4-121.08.2.r6683.gc3b9e549-1
incidenceeditor21.08.2.r792.g2ee2d85-121.08.2.r793.g2499675-1
itinerary21.08.2.r1491.g1a0f14d-121.08.2.r1499.g0e0021b-1
kactivities5.87.0.r1367.g4f7a69b-15.87.0.r1368.g6fec7a7-1
kactivitymanagerd5.22.5.r1373.g242b7cf-15.23.1.r1373.g242b7cf-1
kaddressbook21.08.2.r6057.g2edcd803-121.08.2.r6059.g4b6c39ee-1
kalarm21.08.2.r6477.g228934a2-121.08.2.r6490.g48695c30-1
kalk 21.08.r3.g2d612d3-1 21.08.r4.g5880f7a-1
kapman21.08.2.r612.g068adca-121.08.2.r614.gc8a073d-1
kasts 21.08.r53.g9f9bcb6-1 21.08.r56.gdd5b79f-1
kate21.08.2.r18404.g7f769010b-121.08.2.r18413.ga92f86c43-1
katomic21.08.2.r926.g13657d9-121.08.2.r927.g28c7b23-1
kblackbox21.08.2.r733.g7280dd3-121.08.2.r734.g62100e4-1
kbreakout21.08.2.r871.g7055181-121.08.2.r872.g45efcce-1
kcalendarcore5.87.0.r1251.ge6e016ea0-15.87.0.r1254.g1691d1f2f-1
kclock 21.08.r17.g9047003-1 21.08.r18.gaaece45-1
kcompletion5.87.0.r465.g1f7fa17-15.87.0.r466.g1d8d074-1
kconfig5.87.0.r875.g9b44f49-15.87.0.r879.g605383b-1
kconfigwidgets5.87.0.r629.g19aa762-15.87.0.r636.g678a6ef-1
kcontacts1:5.87.0.r3268.gf8ab76af-11:5.87.0.r3271.g2b9ece91-1
kcoreaddons5.87.0.r1305.gcb7df721-15.87.0.r1321.gb1c0b041-1
kcron21.08.2.r802.g5df10c6-121.08.2.r804.gf8dce93-1
kde-cli-tools5.22.5.r1872.g427e05b-15.23.1.r1873.g5ab245f-1
kde-gtk-config5.22.5.r916.g21d547e-15.23.1.r916.g21d547e-1
kde-telephony-daemon21.08.1.r431.gd73b404-121.08.2.r431.gb0f552d-1
kde-telephony-plugin-declarative21.08.1.r431.g883e705-121.08.2.r431.gc124c35-1
kdeclarative5.87.0.r930.g6282eb7-15.87.0.r931.gc661dcf-1
kdeconnect21.08.2.r3336.gf596972b-121.08.2.r3343.g2d8fd766-1
kdecoration5.22.5.r277.g5285f9d-15.23.1.r277.g5285f9d-1
kdenlive21.08.2.r15095.g0d472bec2-121.08.2.r15115.g996dad59b-1
kdepim-addons21.08.2.r4358.ga2c668e2-121.08.2.r4368.g19dee201-1
kdepim-runtime21.08.2.r15336.g880ac1ba3-121.08.2.r15342.g775ba9e93-1
kdeplasma-addons5.22.5.r8592.gbb2203dde-15.23.1.r8595.g921202841-1
kdiamond21.08.2.r676.g5b43cdb-121.08.2.r677.g9946e96-1
kdisplay5.22.4.r1455.g34844c0-15.22.4.r1456.gc03ddcb-1
kfilemetadata5.87.0.r814.g17eccd0-15.87.0.r817.g6dfcd50-1
kgamma55.22.5.r463.gc082f80-15.23.1.r463.gc082f80-1
kgeography21.08.2.r1114.gde7a833-121.08.2.r1115.gbafa56c-1
kget21.08.2.r3126.gab362007-121.08.2.r3128.g8288f7a1-1
kholidays1:5.87.0.r966.g1c8c456-11:5.87.0.r973.gbd84d74-1
khotkeys5.22.5.r2098.gb99fa8d-15.23.1.r2098.gb99fa8d-1
ki18n5.87.0.r501.g0a85a58-15.87.0.r504.gc6d6f9d-1
kinfocenter5.22.5.r1967.gbfde0d0-15.23.1.r1971.gc3cb026-1
kio5.87.0.r5035.g31cba76e-15.87.0.r5050.g8e87461c-1
kio-extras21.08.2.r7144.g2cda5518-121.08.2.r7161.gd6e40ca9-1
kirigami25.87.0.r2925.g241c5e64-15.87.0.r2929.gfc817a5c-1
kitinerary21.08.2.r1974.g0f87ef1-121.08.2.r1998.g4e1f6e5-1
kleopatra21.08.2.r6007.g7479e271-121.08.2.r6014.gebf19c3f-1
kmail21.08.2.r26025.g510deb422-121.08.2.r26038.gfdb3df4e4-1
kmailtransport21.08.2.r1672.g73611cd-121.08.2.r1675.gde344d6-1
kmenuedit5.22.5.r976.gcc2ebaa-15.23.1.r976.gcc2ebaa-1
knavalbattle21.08.2.r1397.ga1df1ab-121.08.2.r1398.g5bf31d4-1
knewstuff5.87.0.r1226.g8d358d66-15.87.0.r1228.g6979bf80-1
knights21.08.2.r1065.g0e3ba23-121.08.2.r1068.ge383017-1
knotes21.08.2.r3530.g0aefed6d-121.08.2.r3532.g034816f2-1
kolourpaint21.08.2.r2368.g62680ac2-121.08.2.r2369.g49d7a915-1
konqueror21.08.2.r14983.g4f96b58ef-121.08.2.r14994.gcf5ab5865-1
konsole21.08.2.r7972.g4f81a645-121.08.2.r7986.gca7842a6-1
kontact21.08.2.r5391.g64ab4026-121.08.2.r5392.ga0977199-1
korganizer21.08.2.r11525.g19c882f17-121.08.2.r11535.gb9d383288-1
kosmindoormap21.08.2.r660.gf3fe9bb-121.08.2.r661.geb1e1f7-1
kparts5.87.0.r535.ge8847d9-15.87.0.r536.geb7a0a3-1
kpublictransport21.08.2.r1894.gfd91ed35-121.08.2.r1915.g4ccb9ee3-1
krdc21.08.2.r1544.gc833d93-121.08.2.r1545.g3e27720-1
krfb21.08.2.r1422.g97cbf48-121.08.2.r1428.g00c3d1c-1
kross5.87.0.r341.gd944054-15.87.0.r342.g578ae99-1
kscreen5.22.5.r1374.g4a5a806-15.23.1.r1376.gd24c1e4-1
kscreenlocker5.22.5.r881.gaafe47b-15.23.1.r883.g69e1385-1
kservice5.87.0.r954.g36a438f-15.87.0.r955.g5e1cfd1-1
ksirk21.08.2.r969.g1e80bbe-121.08.2.r980.gc9ef1c6-1
ksshaskpass5.22.5.r202.g6f98560-15.23.1.r202.g6f98560-1
ksysguard5.22.5.r3513.g1e92e723-15.23.1.r3513.g1e92e723-1
ksystemlog21.08.2.r674.gf7382a9-121.08.2.r675.gb56f4be-1
ksystemstats5.22.5.r206.g266d64c-15.23.1.r206.g266d64c-1
ktexteditor5.87.0.r2957.g0432601c-15.87.0.r2962.ga9606626-1
ktorrent21.08.2.r2781.gaab6ebf1-121.08.2.r2783.g025b322b-1
kwallet-pam5.22.5.r259.g1d65ed8-15.23.1.r259.g1d65ed8-1
kwave21.08.2.r3744.gbb6b490f-121.08.2.r3748.gb07b5249-1
kwayland-integration5.22.5.r193.g1791ee6-15.23.1.r193.g1791ee6-1
kwayland-server5.22.5.r1399.g1160726-15.23.1.r1402.g173c0b0-1
kweather 21.08.r21.g673c9f5-1 21.08.r22.g6ef18e3-1
kwidgetsaddons5.87.0.r887.g4def632c-15.87.0.r888.g90f536cc-1
kwin5.22.5.r20111.gcc5b47ee3-15.23.1.r20180.gc7c63ba26-1
kwinft5.22.4.r19453.g413dc1681-15.22.4.r19523.g84fcc28d3-1
kwrite21.08.2.r18404.g7f769010b-121.08.2.r18413.ga92f86c43-1
kwrited5.22.5.r488.gdd0bac8-15.23.1.r488.gdd0bac8-1
kxmlgui5.87.0.r817.g649dcebe-15.87.0.r821.gbdc23e11-1
libakonadi21.08.2.r12617.g14039b8f5-121.08.2.r12631.g93214347f-1
libkdepim21.08.2.r858.g55c24f5-121.08.2.r860.g15f16ce-1
libkgapi21.08.2.r1303.gc0cc877-121.08.2.r1305.g6d6dfc5-1
libkleo21.08.2.r959.gd6fbbb9-121.08.2.r963.gb72f5db-1
libksane21.08.2.r566.g9d073a2-121.08.2.r570.g04cf024-1
libkscreen5.22.5.r1599.g8c74fbb-15.23.1.r1600.g7eb0390-1
libksysguard5.22.5.r2312.g3aedbff-15.23.1.r2313.gb5622a8-1
libquotient r2128.gde164d6-1 r2133.g9ee0efb-1
lokalize21.08.2.r1783.g4c693627-121.08.2.r1784.gd3b99739-1
mailcommon21.08.2.r1127.g08b00d2-121.08.2.r1134.gceb9339-1
maliit-framework0.99.1.r94.ga9ab4948-10.99.1.r97.g9599fd9b-1
marble21.08.2.r13356.g8aadc3eb8-121.08.2.r13368.gbe4e4b953-1
marble-common21.08.2.r13356.g8aadc3eb8-121.08.2.r13368.gbe4e4b953-1
marble-qt21.08.2.r13356.g8aadc3eb8-121.08.2.r13368.gbe4e4b953-1
maui-clip 2.0.0.r17.g7eacb63-1 2.0.0.r18.gfb7266a-1
maui-pix 2.0.0.r19.g94a7cc2-1 2.0.0.r20.g44ec50c-1
mauikit2.0.2.r58.ga4af621a-12.0.2.r61.g0e2bac1a-1
mauikit-filebrowsing 2.0.2.r19.gf548745-1 2.0.2.r20.g7658602-1
messagelib21.08.2.r6243.gb2260569-121.08.2.r6254.g1bb6ab2d-1
milou5.22.5.r754.gfe6e4e3-15.23.1.r754.gfe6e4e3-1
minuet21.08.2.r584.gd10a058-121.08.2.r586.g4331695-1
neochat r1906.g7bb7b785-1 r1917.g65cc3928-1
okular21.08.2.r9500.g7ccdd513b-121.08.2.r9509.gd61a7ddf1-1
oxygen5.22.5.r4434.g1d771cca-15.23.1.r4434.g1d771cca-1
pim-data-exporter21.08.2.r2464.g35747153-121.08.2.r2465.g0e75fb49-1
pim-sieve-editor21.08.2.r1518.ge4b0b61-121.08.2.r1519.g134a157-1
pimcommon21.07.80.r1127.gd4a00d2-121.07.80.r1128.g06ae9ac-1
plasma-bigscreen r410.gdd9335f-1 r411.g7344fe3-1
plasma-browser-integration5.22.5.r1284.g506c044c-15.23.1.r1286.g8b49cef7-1
plasma-desktop5.22.5.r8679.g85bc11712-15.23.1.r8709.g1d0ec8b23-1
plasma-dialer-mm 21.08.r10.g0e74d95-1 21.08.r10.g0e74d95-3
plasma-disks5.22.5.r237.g925c7eb-15.23.1.r238.g77533da-1
plasma-firewall5.22.5.r527.g9d47888-15.23.1.r531.gb17aa4a-1
plasma-framework5.87.0.r16033.g9f69e691c-15.87.0.r16044.gbd8c296ab-1
plasma-integration5.22.5.r536.gb17aaf9-15.23.1.r536.gb17aaf9-1
plasma-mobile-nm5.22.5.r3108.g4da37afb-15.23.1.r3118.g6dab6159-1
plasma-nm5.22.5.r3108.g4da37afb-15.23.1.r3117.g7166eb4c-1
plasma-pa5.22.5.r988.g2e2259d-15.23.1.r989.ga04e52f-1
plasma-phone-components5.22.5.r1502.g7df05e09-15.23.1.r1509.gd7b72904-1
plasma-sdk5.22.5.r2286.g83823c9d-15.23.1.r2287.g7d1c42d4-1
plasma-settings 21.08.r26.g8c25cc5-1 21.08.r31.g8908df7-1
plasma-systemmonitor5.22.5.r498.g1153882-15.23.1.r505.g4ff4dca-1
plasma-thunderbolt5.22.5.r153.ga265f72-15.23.1.r153.ga265f72-1
plasma-vault5.22.5.r347.g233e004-15.23.1.r347.g233e004-1
plasma-wayland-protocols1.3.0.r1036.g07e6f76-11.4.0.r1038.g070ea05-1
plasma-wayland-session5.22.5.r10713.g38fea41d2-15.23.1.r10746.g01a74949f-1
plasma-workspace5.22.5.r10713.g38fea41d2-15.23.1.r10746.g01a74949f-1
plasma-workspace-wallpapers5.22.5.r297.gc305370-15.23.1.r298.gedd3390-1
polkit-kde-agent5.22.5.r507.g3f64adb-15.23.1.r507.g3f64adb-1
powerdevil5.22.5.r2484.g81ebb3ee-15.23.1.r2488.g983f8609-1
print-manager21.08.2.r1061.g2b5ca30-121.08.2.r1062.g5ae8470-1
purpose5.87.0.r898.g76b1224-15.87.0.r902.g216ecc5-1
qqc2-breeze-style5.22.5.r232.ga254696-15.23.1.r232.ga254696-1
qqc2-desktop-style5.87.0.r536.gb018a93-15.87.0.r541.g939176f-1
sddm0.19.0.r65.g690be07-10.19.0.r84.gc7e8a9f-1
sddm-kcm5.22.5.r613.gb27eff6-15.23.1.r615.ga71f6a4-1
spectacle21.08.2.r1180.g3eadf12-121.08.2.r1185.g3c91729-1
syntax-highlighting5.87.0.r1711.g0cbe697f-15.87.0.r1727.g6de91621-1
systemsettings5.22.5.r2533.g4ed04a78-15.23.1.r2550.gc815c7a9-1
umbrello21.08.2.r8265.g50ef037a5-121.08.2.r8269.g2d28d3030-1
vvave 2.0.0.r59.g974db24-1 2.0.0.r60.gfc21878-1
wrapland5.22.4.r1640.g5b12d354-15.22.4.r1644.g2c19a619-1
xdg-desktop-portal-kde5.22.5.r392.g5985b08-15.23.1.r394.g483099f-1
aura-browser - r33.2c4005d-1
bigscreen-image-settings - r5.2c99c52-1
calls-daemon -21.08.2.r431.ge2faca0-1
kde-telephony-meta -21.08.2.r431.gf42ca1b-1
plank-player - r19.3ba5ba8-1
python-cec - 0.2.7.r13.gf2d4bd3-1
python-uinput - 0.11.2.r0.gbefe94a-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
