[ARM Testing Update] 2021-10-12 - Thunderbird, KDE Frameworks, Uboot, Yay and kernels
Hello ARM community.
Some backend packages and new KDE Gear applications are here!
Some highlights:
  • Some of our kernels got updated
  • Thunderbird updated to 91.2.0
  • An updated KDE Frameworks brings it to 5.87.0
  • KDE Gear updated to 21.08.2
  • All mainline Uboot packages updated to 2021.10
  • Yay got a new major release with 11.0.0
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Tue Oct 12 19:47:56 CEST 2021)
  • arm-testing community aarch64: 253 new and 236 removed package(s)
  • arm-testing core aarch64: 24 new and 24 removed package(s)
  • arm-testing extra aarch64: 434 new and 434 removed package(s)
  • arm-testing kde-unstable aarch64: 392 new and 391 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2021-10-06         2021-10-12
                     ap6256-firmware            2020.02-7            2020.02-8
                              chatty 0.4.0+108+g6eb6149-1 0.4.0+130+g99a1db2-2
                                code             1.60.2-1             1.61.0-1
                        eg25-manager  0.4.0+47+g1f8fa88-1              0.4.1-1
                            electron             15.1.1-1             15.1.2-1
                          electron12             12.2.1-1             12.2.2-1
                          electron13             13.5.1-1             13.5.2-1
                     element-desktop              1.9.0-1              1.9.2-1
                         element-web              1.9.0-1              1.9.2-1
                                inxi           3.3.06.1-1           3.3.07.1-1
                            mmsd-tng                1.3-1     1.3+1+g8efd579-1
                                 nvm             0.38.0-1             0.39.0-1
                                phoc  0.8.0+62+g4613b16-2  0.8.0+67+gaee845b-1
                               phosh 0.13.1+37+gbf8a6d2-1 0.13.1+71+g63cc368-1
            pinephone-manjaro-tweaks           20211011-1           20211012-1
                               qcoro              0.2.0-1              0.3.0-1
                         snapper-gui    0.1.r7.gf0c67ab-1    0.1.r7.gf0c67ab-2
                           timeshift            21.09.1-1            21.09.1-2
                             vivaldi        4.3.2439.39-1        4.3.2439.44-1
                                 yay             10.3.1-2             11.0.1-2
                                fann                    -              2.2.0-5
               gnome-calendar-mobile                    -               41.0-1
                               mimic                    -            1.3.0.1-2
                        mycroft-core                    -             21.2.1-1
:: Different sync package(s) in repository community aarch64
                              acpica           20210730-1           20210930-1
                             alembic              1.8.3-1              1.8.3-2
                           argyllcms              2.2.0-1              2.2.1-1
                         aws-sdk-cpp            1.8.187-1                    -
                             blender          17:2.93.5-1          17:2.93.5-2
                           borgmatic             1.5.18-1             1.5.20-1
                             calibre             5.28.0-1             5.29.0-1
                      cargo-generate             0.10.1-1             0.10.3-1
                       cargo-release             0.17.1-1             0.18.2-1
                                cgns              4.1.2-1              4.2.0-1
                        coffeescript              2.6.0-1              2.6.1-1
                   containers-common             0.46.0-2             0.46.0-3
                          converseen            0.9.9.1-1            0.9.9.2-2
                            copr-cli               1.95-1               1.96-1
                                crun                1.1-1                1.2-1
                          diffoscope                186-1                187-1
                                dino              0.2.1-1              0.2.2-1
                          duperemove             0.11.2-1             0.11.3-1
                      emacs-php-mode             1.23.0-1             1.24.0-1
                              erlang             24.1.0-1             24.1.2-1
                          erlang-nox             24.1.0-1             24.1.2-1
                     erlang-unixodbc             24.1.0-1             24.1.2-1
                        erlang22-nox          22.3.4.20-1          22.3.4.21-1
                              eslint             7.32.0-1              8.0.0-1
               firefox-ublock-origin             1.38.2-1             1.38.4-1
                          freeradius             3.0.24-1             3.0.25-1
                                 fzf             0.27.2-1             0.27.2-2
                              gaupol               1.10-1             1.10.1-1
                                gdal              3.3.1-6              3.3.1-8
                               geany             1.37.1-1               1.38-1
                               gitea             1.14.5-1             1.15.4-1
                               gitui             0.17.1-2             0.18.0-1
                                 gmt              6.1.1-3              6.2.0-1
                             gmt-doc              6.1.1-3              6.2.0-1
  gnome-shell-extension-appindicator                 40-2                 41-1
                            gnuradio            3.9.2.0-3            3.9.3.0-1
                  gnuradio-companion            3.9.2.0-3            3.9.3.0-1
                      gnuradio-iqbal             0.38.2-1             0.38.2-2
                    gnuradio-osmosdr              0.2.3-4              0.2.3-5
                               go-yq             4.13.3-2             4.13.4-1
                        goimapnotify              2.3.5-1              2.3.7-1
                             gpg-tui              0.8.0-1              0.8.1-1
                                gqrx             2.14.4-2             2.14.4-3
                          grub-btrfs             4.10.1-1             4.10.2-1
                                hdf5             1.12.0-2             1.12.1-1
                        hdf5-openmpi             1.12.0-2             1.12.1-1
                             hexchat             2.16.0-1             2.16.0-2
                            himalaya              0.4.0-5              0.5.0-1
                             hiredis              1.0.1-1              1.0.2-1
                               hivex             1.3.20-6             1.3.21-1
                             jenkins              2.314-1              2.315-1
                                juce              5.4.7-1              6.1.2-2
                    jupyter-nbclient              0.5.3-1              0.5.4-1
                          jupyterlab             3.1.17-1             3.1.18-1
                                 k9s            0.24.15-1            0.24.15-2
                      knative-client             0.21.0-1             0.26.0-1
                             labplot              2.8.2-1              2.8.2-3
                                 lfs              1.0.0-1              1.1.0-1
                              liblzf                3.6-2                3.6-3
                            libmupdf             1.18.0-2             1.19.0-1
                            libressl              3.3.4-1              3.3.5-1
                 libretro-beetle-psx               2568-1               2571-1
              libretro-beetle-psx-hw               2568-1               2571-1
                  libretro-core-info             1.9.10-1             1.9.11-1
                   libretro-gambatte                932-1                935-1
            libretro-genesis-plus-gx               1843-1               1852-1
                   libretro-nestopia               1:62-1               1:64-1
                     libretro-snes9x               2035-1               2037-1
                      libvirt-python            1:7.3.0-1            1:7.8.0-1
                             linssid                3.6-9               3.6-10
                 lua-language-server              2.4.1-1              2.4.2-1
                                 lxc           1:4.0.10-1           1:4.0.10-2
                          mate-panel             1.26.0-3             1.26.1-1
                      matrix-synapse             1.43.0-1             1.44.0-2
                                 med              4.1.0-3              4.1.0-5
                       mod_passenger             6.0.10-1             6.0.11-1
                            molecule              3.5.1-1              3.5.2-1
                            mupdf-gl             1.18.0-2             1.19.0-1
                         mupdf-tools             1.18.0-2             1.19.0-1
                              netcdf              4.7.4-1              4.8.1-1
                      netcdf-fortran              4.5.2-2              4.5.3-2
              netcdf-fortran-openmpi              4.5.2-2              4.5.3-3
                      netcdf-openmpi              4.7.4-1              4.8.1-1
                  nextcloud-app-news             16.0.1-1             16.1.0-1
                             nfoview               1.28-2             1.28.1-1
                 nginx-mod-passenger             6.0.10-1             6.0.11-1
                                 nix             2.3.15-1             2.3.16-1
                       nlohmann-json             3.10.2-1             3.10.3-1
                           nltk-data              3.6.2-1              3.6.4-1
                              nodejs            16.10.0-1            16.11.0-1
                                 npm             7.24.2-1              8.0.0-1
                              octave              6.3.0-4              6.3.0-5
                          onionshare                2.2-5                2.4-1
                              openxr             1.0.19-1             1.0.20-1
                         passff-host            1:1.2.1-3            1:1.2.2-1
                              picard              2.6.3-1              2.6.4-1
                     pnetcdf-openmpi             1.11.0-2             1.12.2-2
                   powerdns-recursor              4.5.5-1              4.5.6-1
                           promscale              0.6.0-1              0.6.1-1
                            psi-l10n                1.4-2                1.5-1
                         psi-plugins                1.4-1                1.5-1
                              pulumi             3.13.2-1             3.14.0-1
                               pyenv              2.0.7-2              2.1.0-1
                               pymol              2.4.0-2              2.5.0-1
                             pyright            1.1.175-1            1.1.177-1
                      python-alembic              1.7.3-1              1.7.4-1
                      python-astroid              2.8.1-1              2.8.2-1
                   python-cachetools              4.2.2-1              4.2.3-1
                 python-calmjs.parse              1.2.5-5              1.3.0-1
                      python-certifi          2020.12.5-1          2021.10.8-1
                        python-click              8.0.1-1              8.0.3-1
                          python-ddt              1.4.3-1              1.4.4-1
                   python-diff-cover              6.4.1-1              6.4.2-1
                       python-docker              5.0.2-1              5.0.3-1
                         python-docs              3.9.6-1             3.10.0-1
                       python-dotenv             0.19.0-1             0.19.1-1
                        python-faker             8.14.1-1             8.14.2-1
                        python-flask              2.0.1-1              2.0.2-1
                         python-gdal              3.3.1-6              3.3.1-8
                        python-gdstk              0.7.0-1              0.8.0-1
              python-google-api-core              2.0.1-1              2.1.0-1
     python-google-api-python-client             2.22.0-1             2.24.0-1
                         python-h5py              3.2.1-1              3.3.0-1
                 python-h5py-openmpi              3.2.1-1              3.3.0-1
                    python-icalendar              4.0.7-4              4.0.8-1
                    python-ipykernel              6.0.3-2              6.4.1-1
             python-jsonrpclib-pelix              0.4.3-1            0.4.3.1-1
                 python-jupyter_core              4.8.0-1              4.8.1-1
                       python-nbxmpp              2.0.3-1              2.0.4-1
                      python-netcdf4              1.5.7-1              1.5.7-2
              python-netcdf4-openmpi              1.5.7-1              1.5.7-2
                       python-pg8000             1.21.2-1             1.21.3-1
                      python-pikepdf              3.1.1-1              3.2.0-1
                      python-plumbum              1.7.0-3              1.7.0-4
                      python-portend              2.7.1-1              3.0.0-1
                     python-pprofile              2.0.5-2              2.1.0-1
                        python-pyjwt              1.7.1-6              2.2.0-1
                        python-pykka              3.0.1-1              3.0.2-1
                     python-pytables              3.6.1-7              3.6.1-8
                    python-pywlroots             0.14.6-1             0.14.7-1
                         python-rope             0.19.0-1             0.20.1-1
                      python-tempora              4.1.1-1              4.1.2-1
                     python-werkzeug              2.0.1-1              2.0.2-1
                                qgis             3.20.3-1             3.20.3-3
                         qstopmotion              2.5.2-1              2.5.2-2
                            qwtpolar              1.1.1-5                    -
                                repo             2.16.4-1               2.17-1
                           retroarch             1.9.10-1             1.9.11-1
                       rust-analyzer           20211004-1           20211011-1
                               s-tui              1.1.1-1              1.1.3-1
                             scribus              1.5.7-5              1.5.7-6
                             scummvm              2.1.0-2              2.5.0-1
                              skopeo              1.4.1-1              1.5.0-1
                              srsgui                2.0-1                2.0-2
                          swi-prolog              8.4.0-1              8.4.0-2
                                  sz             2.1.11-1           2.1.11.2-1
                           tailscale             1.14.6-1             1.16.0-1
                                 tea              0.7.1-1              0.8.0-1
                          tekton-cli             0.20.0-1             0.21.0-1
                    telegram-desktop              3.1.1-1              3.1.9-1
                          terragrunt             0.32.2-1             0.34.0-1
                           texstudio              4.0.0-1              4.0.1-1
                         ttc-iosevka             10.3.0-1             10.3.1-1
                    ttc-iosevka-aile             10.3.0-1             10.3.1-1
                   ttc-iosevka-curly             10.3.0-1             10.3.1-1
              ttc-iosevka-curly-slab             10.3.0-1             10.3.1-1
                  ttc-iosevka-etoile             10.3.0-1             10.3.1-1
                    ttc-iosevka-slab             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss01             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss02             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss03             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss04             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss05             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss06             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss07             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss08             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss09             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss10             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss11             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss12             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss13             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss14             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss15             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss16             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss17             10.3.0-1             10.3.1-1
                    ttc-iosevka-ss18             10.3.0-1             10.3.1-1
                             urlscan              0.9.6-1              0.9.7-1
                               uwsgi          2.0.19.1-13             2.0.20-1
                    uwsgi-plugin-cgi          2.0.19.1-13             2.0.20-1
                  uwsgi-plugin-lua51          2.0.19.1-13             2.0.20-1
               uwsgi-plugin-notfound          2.0.19.1-13             2.0.20-1
                    uwsgi-plugin-php          2.0.19.1-13             2.0.20-1
                   uwsgi-plugin-php7          2.0.19.1-13             2.0.20-1
                   uwsgi-plugin-psgi          2.0.19.1-13             2.0.20-1
                 uwsgi-plugin-python          2.0.19.1-13             2.0.20-1
                   uwsgi-plugin-rack          2.0.19.1-13             2.0.20-1
                 uwsgi-plugin-webdav          2.0.19.1-13             2.0.20-1
                 uwsgi-plugin-zabbix          2.0.19.1-13             2.0.20-1
                               v2ray             4.42.2-1             4.43.0-1
                         v2ray-geoip       202110040733-1       202110070028-1
                               vigra1.11.1.r45+g8acd73a5-21.11.1.r45+g8acd73a5-3
                        vim-himalaya              0.4.0-5              0.5.0-1
           vscode-css-languageserver             1.60.0-1             1.61.0-1
          vscode-html-languageserver             1.60.0-1             1.61.0-1
          vscode-json-languageserver             1.60.0-1             1.61.0-1
                                 vtk             8.2.0-20             8.2.0-21
                         wireplumber              0.4.2-1              0.4.3-1
                    wireplumber-docs              0.4.2-1              0.4.3-1
                       wireshark-cli              3.4.8-1              3.4.9-1
                        wireshark-qt              3.4.8-1              3.4.9-1
                               yaegi             0.9.23-1             0.10.0-1
                             yoshimi              2.1.0-1              2.1.1-1
                           zeroc-ice              3.7.5-1              3.7.6-1
                              adios2                    -              2.7.1-1
                          aws-c-auth                    -              0.6.4-1
                   aws-c-compression                    -             0.2.14-1
                          aws-c-http                    -              0.6.7-1
                          aws-c-mqtt                    -              0.7.8-1
                            aws-c-s3                    -             0.1.27-1
                         aws-crt-cpp                    -             0.17.1-1
                              dunesh                    -              0.0.1-1
                          git-absorb                    -              0.6.6-2
                          git-revise                    -              0.6.0-3
                           git-sizer                    -              1.4.0-2
                              helvum                    -              0.3.1-3
                           juce-docs                    -              6.1.2-2
                      tuning-library                    -              1.1.0-1
                yaml-language-server                    -              1.0.0-2
:: Different overlay package(s) in repository core aarch64
                               linux            5.14.10-1            5.14.11-1
                       linux-headers            5.14.10-1            5.14.11-1
                     linux-pinephone            5.14.10-1            5.14.11-1
             linux-pinephone-headers            5.14.10-1            5.14.11-1
                            linux-rc           5.15.rc4-1           5.15.rc5-1
                    linux-rc-headers           5.15.rc4-1           5.15.rc5-1
                     uboot-nanopc-t4            2021.07-1            2021.10-1
            uboot-odroid-c2-mainline            2021.07-1            2021.10-1
                      uboot-pine-h64            2021.07-1            2021.10-1
                        uboot-pine64            2021.07-1            2021.10-1
                    uboot-pine64-lts            2021.07-1            2021.10-1
                      uboot-pinebook            2021.07-1            2021.10-1
                   uboot-pinebookpro            2021.07-3            2021.10-1
                       uboot-pinetab            2021.07-1            2021.10-1
                   uboot-raspberrypi            2021.07-3            2021.10-1
                        uboot-roc-cc            2021.07-1            2021.10-1
                        uboot-rock64            2021.07-1            2021.10-1
                      uboot-rockpi4b            2021.07-3            2021.10-1
                      uboot-rockpi4c            2021.07-3            2021.10-1
                     uboot-rockpro64            2021.07-3            2021.10-1
:: Different sync package(s) in repository core aarch64
                            automake             1.16.4-1             1.16.5-1
                         btrfs-progs             5.14.1-1             5.14.2-1
                              libcap               2.58-1               2.59-1
                                nano                5.8-1                5.9-1
:: Different overlay package(s) in repository extra aarch64
                            mesa-git21.3.0_devel.145704.c6b8702eb40-121.3.0_devel.146021.3e36a20a34d-1
:: Different sync package(s) in repository extra aarch64
                             akonadi            21.08.1-1            21.08.2-1
                    akonadi-calendar            21.08.1-1            21.08.2-1
              akonadi-calendar-tools            21.08.1-1            21.08.2-1
                    akonadi-contacts            21.08.1-1            21.08.2-1
               akonadi-import-wizard            21.08.1-1            21.08.2-1
                        akonadi-mime            21.08.1-1            21.08.2-1
                       akonadi-notes            21.08.1-1            21.08.2-1
                      akonadi-search            21.08.1-1            21.08.2-1
                      akonadiconsole            21.08.1-1            21.08.2-1
                           akregator            21.08.1-1            21.08.2-1
                            analitza            21.08.1-1            21.08.2-1
                              apache             2.4.50-1             2.4.51-1
                           appstream             0.14.5-2             0.14.6-1
                        appstream-qt             0.14.5-2             0.14.6-1
                                 ark            21.08.1-1            21.08.2-1
                          artikulate            21.08.1-1            21.08.2-1
                              attica             5.86.0-2             5.87.0-1
                         audiocd-kio            21.08.1-1            21.08.2-1
                        avogadrolibs             1.95.1-1             1.95.1-2
                               baloo             5.86.0-1             5.87.0-1
                       baloo-widgets            21.08.1-1            21.08.2-1
                             blinken            21.08.1-1            21.08.2-1
                            bluez-qt             5.86.0-1             5.87.0-1
                              bomber            21.08.1-1            21.08.2-1
                             booster                0.6-1                0.7-1
                                bovo            21.08.1-1            21.08.2-1
                        breeze-icons             5.86.0-1             5.87.0-1
                     calendarsupport            21.08.1-1            21.08.2-1
                            calligra             3.2.1-21             3.2.1-22
                              cantor            21.08.1-1            21.08.2-1
                            cervisia            21.08.1-1            21.08.2-1
                            chromium       94.0.4606.71-2       94.0.4606.81-1
                             digikam              7.3.0-4              7.3.0-5
                             dolphin            21.08.1-1            21.08.2-1
                     dolphin-plugins            21.08.1-1            21.08.2-1
                              dragon            21.08.1-1            21.08.2-1
                               elisa            21.08.1-1            21.08.2-1
                          eventviews            21.08.1-1            21.08.2-1
                 extra-cmake-modules             5.86.0-1             5.87.0-1
                        ffmpegthumbs            21.08.1-1            21.08.2-1
                           filelight            21.08.1-1            21.08.2-1
                             flatpak             1.11.3-1             1.12.1-1
                     flatpak-builder              1.1.2-1              1.2.0-1
                         foomatic-db         3:20210828-1         3:20211009-1
                 foomatic-db-nonfree         3:20210828-1         3:20211009-1
            foomatic-db-nonfree-ppds         3:20210828-1         3:20211009-1
                    foomatic-db-ppds         3:20210828-1         3:20211009-1
                frameworkintegration             5.86.0-1             5.87.0-1
                     freecell-solver              6.4.0-1              6.6.0-1
                           granatier            21.08.1-1            21.08.2-1
                     grantlee-editor            21.08.1-1            21.08.2-1
                       grantleetheme            21.08.1-1            21.08.2-1
                            gwenview            21.08.1-1            21.08.2-1
                            hwdetect            2016.01-4            2021.10-1
                         imagemagick            7.1.0.9-1           7.1.0.10-1
                     imagemagick-doc            7.1.0.9-1           7.1.0.10-1
                     incidenceeditor            21.08.1-1            21.08.2-1
                            inkscape              1.1.1-1              1.1.1-2
                           itinerary            21.08.1-1            21.08.2-1
                                 juk            21.08.1-1            21.08.2-1
                                 k3b          1:21.08.1-1          1:21.08.2-1
               kaccounts-integration            21.08.1-1            21.08.2-1
                 kaccounts-providers            21.08.1-1            21.08.2-1
                         kactivities             5.86.0-1             5.87.0-1
                   kactivities-stats             5.86.0-1             5.87.0-1
                        kaddressbook            21.08.1-1            21.08.2-1
                             kajongg            21.08.1-1            21.08.2-1
                              kalarm            21.08.1-1            21.08.2-1
                           kalarmcal            21.08.1-1            21.08.2-1
                            kalgebra            21.08.1-1            21.08.2-1
                             kalzium            21.08.1-1            21.08.2-1
                              kamera            21.08.1-1            21.08.2-1
                              kamoso            21.08.1-1            21.08.2-1
                            kanagram            21.08.1-1            21.08.2-1
                             kapidox             5.86.0-1             5.87.0-1
                              kapman            21.08.1-1            21.08.2-1
                        kapptemplate            21.08.1-1            21.08.2-1
                            karchive             5.86.0-1             5.87.0-1
                                kate            21.08.1-1            21.08.2-1
                             katomic            21.08.1-1            21.08.2-1
                               kauth             5.86.0-1             5.87.0-1
                             kbackup            21.08.1-1            21.08.2-1
                           kblackbox            21.08.1-1            21.08.2-1
                             kblocks            21.08.1-1            21.08.2-1
                          kbookmarks             5.86.0-1             5.87.0-1
                             kbounce            21.08.1-1            21.08.2-1
                           kbreakout            21.08.1-1            21.08.2-1
                              kbruch            21.08.1-1            21.08.2-1
                         kcachegrind            21.08.1-1            21.08.2-1
                  kcachegrind-common            21.08.1-1            21.08.2-1
                               kcalc            21.08.1-1            21.08.2-1
                       kcalendarcore             5.86.0-1             5.87.0-1
                           kcalutils            21.08.1-1            21.08.2-1
                         kcharselect            21.08.1-1            21.08.2-1
                            kcmutils             5.86.0-1             5.87.0-1
                             kcodecs             5.86.0-1             5.87.0-1
                       kcolorchooser            21.08.1-1            21.08.2-1
                         kcompletion             5.86.0-1             5.87.0-1
                             kconfig             5.86.0-1             5.87.0-1
                      kconfigwidgets             5.86.0-1             5.87.0-1
                           kcontacts           1:5.86.0-1           1:5.87.0-1
                         kcoreaddons             5.86.0-1             5.87.0-1
                              kcrash             5.86.0-1             5.87.0-1
                               kcron            21.08.1-1            21.08.2-1
                                kdav           1:5.86.0-1           1:5.87.0-1
                         kdbusaddons             5.86.0-1             5.87.0-1
                     kde-dev-scripts            21.08.1-1            21.08.2-1
                       kde-dev-utils            21.08.1-1            21.08.2-1
                      kdebugsettings            21.08.1-1            21.08.2-1
                        kdeclarative             5.86.0-1             5.87.0-1
                          kdeconnect            21.08.1-2            21.08.2-1
                                kded             5.86.0-1             5.87.0-1
                         kdeedu-data            21.08.1-1            21.08.2-1
              kdegraphics-mobipocket            21.08.1-1            21.08.2-1
            kdegraphics-thumbnailers            21.08.1-1            21.08.2-1
                     kdelibs4support             5.86.0-1             5.87.0-1
              kdenetwork-filesharing            21.08.1-2            21.08.2-1
                            kdenlive            21.08.1-1            21.08.2-1
                       kdepim-addons            21.08.1-1            21.08.2-1
                      kdepim-runtime            21.08.1-1            21.08.2-1
                    kdesdk-kioslaves            21.08.1-1            21.08.2-1
                 kdesdk-thumbnailers            21.08.1-1            21.08.2-1
                     kdesignerplugin             5.86.0-1             5.87.0-1
                               kdesu             5.86.0-1             5.87.0-1
                           kdewebkit             5.86.0-1             5.87.0-1
                                 kdf            21.08.1-1            21.08.2-1
                             kdialog            21.08.1-1            21.08.2-1
                            kdiamond            21.08.1-1            21.08.2-1
                              kdnssd             5.86.0-1             5.87.0-1
                           kdoctools             5.86.0-1             5.87.0-1
                      keditbookmarks            21.08.1-1            21.08.2-1
                          kemoticons             5.86.0-1             5.87.0-1
                       kfilemetadata             5.86.0-1             5.87.0-1
                               kfind            21.08.1-1            21.08.2-1
                             kfloppy            21.08.1-1            21.08.2-1
                         kfourinline            21.08.1-1            21.08.2-1
                          kgeography            21.08.1-1            21.08.2-1
                                kget            21.08.1-1            21.08.2-1
                        kglobalaccel             5.86.0-1             5.87.0-1
                         kgoldrunner            21.08.1-1            21.08.2-1
                                kgpg            21.08.1-1            21.08.2-1
                          kguiaddons             5.86.0-1             5.87.0-1
                            khangman            21.08.1-1            21.08.2-1
                         khelpcenter            21.08.1-1            21.08.2-1
                           kholidays           1:5.86.0-1           1:5.87.0-1
                               khtml             5.86.0-1             5.87.0-1
                               ki18n             5.86.0-1             5.87.0-1
                         kiconthemes             5.86.0-1             5.87.0-1
                 kidentitymanagement            21.08.1-1            21.08.2-1
                           kidletime             5.86.0-1             5.87.0-1
                                 kig            21.08.1-1            21.08.2-1
                                kigo            21.08.1-1            21.08.2-1
                            killbots            21.08.1-1            21.08.2-1
                       kimageformats             5.86.0-1             5.87.0-1
                     kimagemapeditor            21.08.1-1            21.08.2-1
                               kimap            21.08.1-1            21.08.2-1
                               kinit             5.86.0-1             5.87.0-1
                                 kio             5.86.0-1             5.87.0-1
                          kio-extras            21.08.1-2            21.08.2-1
                          kio-gdrive            21.08.1-1            21.08.2-1
                        kipi-plugins            21.08.1-1            21.08.2-1
                    kirigami-gallery            21.08.1-1            21.08.2-1
                           kirigami2             5.86.0-1             5.87.0-1
                              kiriki            21.08.1-1            21.08.2-1
                         kitemmodels             5.86.0-1             5.87.0-1
                          kitemviews             5.86.0-1             5.87.0-1
                               kiten            21.08.1-1            21.08.2-1
                          kitinerary            21.08.1-1            21.08.2-2
                         kjobwidgets             5.86.0-1             5.87.0-1
                                 kjs             5.86.0-1             5.87.0-1
                            kjsembed             5.86.0-1             5.87.0-1
                        kjumpingcube            21.08.1-1            21.08.2-1
                               kldap            21.08.1-1            21.08.2-1
                           kleopatra            21.08.1-1            21.08.2-1
                            klettres            21.08.1-1            21.08.2-1
                            klickety            21.08.1-1            21.08.2-1
                              klines            21.08.1-1            21.08.2-1
                                kmag            21.08.1-1            21.08.2-1
                           kmahjongg            21.08.1-1            21.08.2-1
                               kmail            21.08.1-1            21.08.2-1
                kmail-account-wizard            21.08.1-1            21.08.2-1
                      kmailtransport            21.08.1-1            21.08.2-1
                               kmbox            21.08.1-1            21.08.2-1
                        kmediaplayer             5.86.0-1             5.87.0-1
                               kmime            21.08.1-1            21.08.2-1
                              kmines            21.08.1-1            21.08.2-1
                                kmix            21.08.1-1            21.08.2-1
                          kmousetool            21.08.1-1            21.08.2-1
                              kmouth            21.08.1-1            21.08.2-1
                              kmplot            21.08.1-1            21.08.2-1
                        knavalbattle            21.08.1-1            21.08.2-1
                            knetwalk            21.08.1-1            21.08.2-1
                           knewstuff             5.86.0-2             5.87.0-1
                             knights            21.08.1-1            21.08.2-1
                              knotes            21.08.1-1            21.08.2-1
                      knotifications             5.86.0-1             5.87.0-1
                       knotifyconfig             5.86.0-1             5.87.0-1
                                kolf            21.08.1-1            21.08.2-1
                           kollision            21.08.1-1            21.08.2-1
                         kolourpaint            21.08.1-1            21.08.2-1
                             kompare            21.08.1-1            21.08.2-1
                           konqueror            21.08.1-2            21.08.2-1
                            konquest            21.08.1-1            21.08.2-1
                             konsole            21.08.1-1            21.08.2-1
                             kontact            21.08.1-1            21.08.2-1
                    kontactinterface            21.08.1-1            21.08.2-1
                            kontrast            21.08.1-1            21.08.2-1
                        konversation            21.08.1-1            21.08.2-1
                       kopeninghours            21.08.1-1            21.08.2-1
                              kopete            21.08.1-1            21.08.2-1
                          korganizer            21.08.1-1            21.08.2-1
                       kosmindoormap            21.08.1-1            21.08.2-1
                            kpackage             5.86.0-1             5.87.0-1
                              kparts             5.86.0-1             5.87.0-1
                                kpat            21.08.1-1            21.08.2-1
                             kpeople             5.86.0-1             5.87.0-1
                        kpimtextedit            21.08.1-1            21.08.2-1
                             kpkpass            21.08.1-1            21.08.2-1
                           kplotting             5.86.0-1             5.87.0-1
                             kpmcore            21.08.1-1            21.08.2-1
                                kpty             5.86.0-1             5.87.0-1
                    kpublictransport            21.08.1-1            21.08.2-1
                      kqtquickcharts            21.08.1-1            21.08.2-1
                        kquickcharts             5.86.0-1             5.87.0-1
                                krdc            21.08.1-1            21.08.2-1
                            kreversi            21.08.1-1            21.08.2-1
                                krfb            21.08.1-1            21.08.2-1
                               kross             5.86.0-1             5.87.0-1
                  kross-interpreters            21.08.1-1            21.08.2-1
                              kruler            21.08.1-1            21.08.2-1
                             krunner             5.86.0-1             5.87.0-1
                            kservice             5.86.0-1             5.87.0-1
                             kshisen            21.08.1-1            21.08.2-1
                               ksirk            21.08.1-1            21.08.2-1
                               ksmtp            21.08.1-1            21.08.2-1
                          ksnakeduel            21.08.1-1            21.08.2-1
                          kspaceduel            21.08.1-1            21.08.2-1
                            ksquares            21.08.1-1            21.08.2-1
                             ksudoku            21.08.1-1            21.08.2-1
                          ksystemlog            21.08.1-1            21.08.2-1
                            kteatime            21.08.1-1            21.08.2-1
                         ktexteditor             5.86.0-2             5.87.0-1
                        ktextwidgets             5.86.0-1             5.87.0-1
                              ktimer            21.08.1-1            21.08.2-1
                               ktnef            21.08.1-1            21.08.2-1
                            ktorrent            21.08.1-1            21.08.2-1
                              ktouch            21.08.1-1            21.08.2-1
                          ktuberling            21.08.1-1            21.08.2-1
                             kturtle            21.08.1-1            21.08.2-1
                             kubrick            21.08.1-1            21.08.2-1
                     kunitconversion             5.86.0-1             5.87.0-1
                             kwallet             5.86.0-1             5.87.0-1
                      kwalletmanager            21.08.1-1            21.08.2-1
                               kwave            21.08.1-1            21.08.2-1
                            kwayland             5.86.0-1             5.87.0-1
                      kwidgetsaddons             5.86.0-1             5.87.0-1
                       kwindowsystem             5.86.0-1             5.87.0-1
                           kwordquiz            21.08.1-1            21.08.2-1
                              kwrite            21.08.1-1            21.08.2-1
                             kxmlgui             5.86.0-1             5.87.0-1
                       kxmlrpcclient             5.86.0-1             5.87.0-1
                          libakonadi            21.08.1-1            21.08.2-1
                         libgravatar            21.08.1-1            21.08.2-1
                             libgusb              0.3.7-1              0.3.8-1
                             libical             3.0.10-1             3.0.11-1
                            libkcddb            21.08.1-1            21.08.2-1
                     libkcompactdisc            21.08.1-1            21.08.2-1
                           libkdcraw            21.08.1-1            21.08.2-1
                         libkdegames            21.08.1-1            21.08.2-1
                           libkdepim            21.08.1-1            21.08.2-1
                  libkeduvocdocument            21.08.1-1            21.08.2-1
                           libkexiv2            21.08.1-1            21.08.2-1
                            libkgapi            21.08.1-1            21.08.2-1
                             libkipi            21.08.1-1            21.08.2-1
                             libkleo            21.08.1-1            21.08.2-1
                        libkmahjongg            21.08.1-1            21.08.2-1
                     libkomparediff2            21.08.1-1            21.08.2-1
                            libksane            21.08.1-1            21.08.2-1
                           libksieve            21.08.1-1            21.08.2-1
                         libktorrent            21.08.1-1            21.08.2-1
                   libreoffice-fresh              7.2.1-2              7.2.1-3
               libreoffice-fresh-sdk              7.2.1-2              7.2.1-3
                   libreoffice-still              7.1.6-1              7.1.6-2
               libreoffice-still-sdk              7.1.6-1              7.1.6-2
                            lokalize            21.08.1-1            21.08.2-1
                               lskat            21.08.1-1            21.08.2-1
                                luit           20201003-1           20210218-1
                          mailcommon            21.08.1-1            21.08.2-1
                        mailimporter            21.08.1-1            21.08.2-1
                              marble            21.08.1-1            21.08.2-1
                       marble-common            21.08.1-1            21.08.2-1
                         marble-maps            21.08.1-1            21.08.2-1
                           marble-qt            21.08.1-1            21.08.2-1
                        markdownpart            21.08.1-1            21.08.2-1
                       mbox-importer            21.08.1-1            21.08.2-1
                           mercurial              5.9.1-2              5.9.2-1
                          messagelib            21.08.1-1            21.08.2-1
                              minuet            21.08.1-1            21.08.2-1
                      mkvtoolnix-cli             61.0.0-2             62.0.0-1
                      mkvtoolnix-gui             61.0.0-2             62.0.0-1
                     modemmanager-qt             5.86.0-1             5.87.0-1
                   networkmanager-qt             5.86.0-1             5.87.0-1
                              opencv              4.5.3-4              4.5.4-1
                      opencv-samples              4.5.3-4              4.5.4-1
                              ostree             2021.4-1             2021.5-1
                        oxygen-icons           1:5.86.0-1           1:5.87.0-1
                    oxygen-icons-svg           1:5.86.0-1           1:5.87.0-1
                            palapeli            21.08.1-1            21.08.2-1
                              parley            21.08.1-1            21.08.2-1
                    partitionmanager            21.08.1-1            21.08.2-1
                            php-apcu             5.1.20-1             5.1.21-2
                           php7-apcu             5.1.20-1             5.1.21-2
                               picmi            21.08.1-1            21.08.2-1
                   pim-data-exporter            21.08.1-1            21.08.2-1
                    pim-sieve-editor            21.08.1-1            21.08.2-1
                           pimcommon            21.08.1-1            21.08.2-1
                       pkcs11-helper             1.27.0-1             1.27.0-2
                    plasma-framework             5.86.0-1             5.87.0-1
                              polkit              0.119-1              0.120-2
                             poppler            21.09.0-1            21.10.0-1
                        poppler-glib            21.09.0-1            21.10.0-1
                         poppler-qt5            21.09.0-1            21.10.0-1
                         poppler-qt6            21.09.0-1            21.10.0-1
                               poxml            21.08.1-1            21.08.2-1
                       print-manager            21.08.1-1            21.08.2-1
                              prison             5.86.0-1             5.87.0-1
                       python-opencv              4.5.3-4              4.5.4-1
                         qcachegrind            21.08.1-1            21.08.2-1
                  qqc2-desktop-style             5.86.0-1             5.87.0-1
                                 qwt              6.1.6-1              6.2.0-1
                           ristretto             0.11.0-1             0.12.0-1
                                rocs            21.08.1-1            21.08.2-1
                        sane-airscan            0.99.26-1            0.99.27-1
                                sbcl              2.1.7-1              2.1.9-1
                                sdl2             2.0.16-3             2.0.16-4
            signon-kwallet-extension            21.08.1-1            21.08.2-1
                            skanlite            21.08.1-1            21.08.2-1
                               solid             5.86.0-1             5.87.0-1
                              sonnet             5.86.0-1             5.87.0-1
                           spectacle            21.08.1-1            21.08.2-1
                                 srt              1.4.3-1              1.4.4-1
                                step            21.08.1-1            21.08.2-1
                             svgpart            21.08.1-1            21.08.2-1
                             sweeper            21.08.1-1            21.08.2-1
                         syndication             5.86.0-1             5.87.0-1
                 syntax-highlighting             5.86.0-1             5.87.0-2
                           syslog-ng             3.33.1-1             3.34.1-1
          telepathy-kde-accounts-kcm            21.08.1-1            21.08.2-1
              telepathy-kde-approver            21.08.1-1            21.08.2-1
          telepathy-kde-auth-handler            21.08.1-1            21.08.2-1
               telepathy-kde-call-ui            21.08.1-1            21.08.2-1
      telepathy-kde-common-internals            21.08.1-1            21.08.2-1
          telepathy-kde-contact-list            21.08.1-1            21.08.2-1
        telepathy-kde-contact-runner            21.08.1-1            21.08.2-1
       telepathy-kde-desktop-applets            21.08.1-1            21.08.2-1
  telepathy-kde-filetransfer-handler            21.08.1-1            21.08.2-1
    telepathy-kde-integration-module            21.08.1-1            21.08.2-1
             telepathy-kde-send-file            21.08.1-1            21.08.2-1
               telepathy-kde-text-ui            21.08.1-1            21.08.2-1
                        threadweaver             5.86.0-1             5.87.0-1
                         thunderbird             91.1.2-1             91.2.0-1
                 thunderbird-i18n-af             91.1.2-1             91.2.0-1
                 thunderbird-i18n-ar             91.1.2-1             91.2.0-1
                thunderbird-i18n-ast             91.1.2-1             91.2.0-1
                 thunderbird-i18n-be             91.1.2-1             91.2.0-1
                 thunderbird-i18n-bg             91.1.2-1             91.2.0-1
                 thunderbird-i18n-br             91.1.2-1             91.2.0-1
                 thunderbird-i18n-ca             91.1.2-1             91.2.0-1
                thunderbird-i18n-cak             91.1.2-1             91.2.0-1
                 thunderbird-i18n-cs             91.1.2-1             91.2.0-1
                 thunderbird-i18n-cy             91.1.2-1             91.2.0-1
                 thunderbird-i18n-da             91.1.2-1             91.2.0-1
                 thunderbird-i18n-de             91.1.2-1             91.2.0-1
                thunderbird-i18n-dsb             91.1.2-1             91.2.0-1
                 thunderbird-i18n-el             91.1.2-1             91.2.0-1
              thunderbird-i18n-en-gb             91.1.2-1             91.2.0-1
              thunderbird-i18n-en-us             91.1.2-1             91.2.0-1
              thunderbird-i18n-es-ar             91.1.2-1             91.2.0-1
              thunderbird-i18n-es-es             91.1.2-1             91.2.0-1
                 thunderbird-i18n-et             91.1.2-1             91.2.0-1
                 thunderbird-i18n-eu             91.1.2-1             91.2.0-1
                 thunderbird-i18n-fi             91.1.2-1             91.2.0-1
                 thunderbird-i18n-fr             91.1.2-1             91.2.0-1
              thunderbird-i18n-fy-nl             91.1.2-1             91.2.0-1
              thunderbird-i18n-ga-ie             91.1.2-1             91.2.0-1
                 thunderbird-i18n-gd             91.1.2-1             91.2.0-1
                 thunderbird-i18n-gl             91.1.2-1             91.2.0-1
                 thunderbird-i18n-he             91.1.2-1             91.2.0-1
                 thunderbird-i18n-hr             91.1.2-1             91.2.0-1
                thunderbird-i18n-hsb             91.1.2-1             91.2.0-1
                 thunderbird-i18n-hu             91.1.2-1             91.2.0-1
              thunderbird-i18n-hy-am             91.1.2-1             91.2.0-1
                 thunderbird-i18n-id             91.1.2-1             91.2.0-1
                 thunderbird-i18n-is             91.1.2-1             91.2.0-1
                 thunderbird-i18n-it             91.1.2-1             91.2.0-1
                 thunderbird-i18n-ja             91.1.2-1             91.2.0-1
                 thunderbird-i18n-ka             91.1.2-1             91.2.0-1
                thunderbird-i18n-kab             91.1.2-1             91.2.0-1
                 thunderbird-i18n-kk             91.1.2-1             91.2.0-1
                 thunderbird-i18n-ko             91.1.2-1             91.2.0-1
                 thunderbird-i18n-lt             91.1.2-1             91.2.0-1
                 thunderbird-i18n-ms             91.1.2-1             91.2.0-1
              thunderbird-i18n-nb-no             91.1.2-1             91.2.0-1
                 thunderbird-i18n-nl             91.1.2-1             91.2.0-1
              thunderbird-i18n-nn-no             91.1.2-1             91.2.0-1
              thunderbird-i18n-pa-in             91.1.2-1             91.2.0-1
                 thunderbird-i18n-pl             91.1.2-1             91.2.0-1
              thunderbird-i18n-pt-br             91.1.2-1             91.2.0-1
              thunderbird-i18n-pt-pt             91.1.2-1             91.2.0-1
                 thunderbird-i18n-rm             91.1.2-1             91.2.0-1
                 thunderbird-i18n-ro             91.1.2-1             91.2.0-1
                 thunderbird-i18n-ru             91.1.2-1             91.2.0-1
                 thunderbird-i18n-sk             91.1.2-1             91.2.0-1
                 thunderbird-i18n-sl             91.1.2-1             91.2.0-1
                 thunderbird-i18n-sq             91.1.2-1             91.2.0-1
                 thunderbird-i18n-sr             91.1.2-1             91.2.0-1
              thunderbird-i18n-sv-se             91.1.2-1             91.2.0-1
                 thunderbird-i18n-th             91.1.2-1             91.2.0-1
                 thunderbird-i18n-tr             91.1.2-1             91.2.0-1
                 thunderbird-i18n-uk             91.1.2-1             91.2.0-1
                 thunderbird-i18n-uz             91.1.2-1             91.2.0-1
                 thunderbird-i18n-vi             91.1.2-1             91.2.0-1
              thunderbird-i18n-zh-cn             91.1.2-1             91.2.0-1
              thunderbird-i18n-zh-tw             91.1.2-1             91.2.0-1
                            umbrello            21.08.1-1            21.08.2-1
               xfce4-cpugraph-plugin              1.2.4-1              1.2.5-1
                             yakuake            21.08.1-1            21.08.2-1
                        zabbix-agent              5.4.3-1              5.4.4-1
                       zabbix-agent2              5.4.3-1              5.4.4-1
                 zabbix-frontend-php              5.4.3-1              5.4.4-1
                        zabbix-proxy              5.4.3-1              5.4.4-1
                       zabbix-server              5.4.3-1              5.4.4-1
                    zeroconf-ioslave            21.08.1-1            21.08.2-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.08.1.r12608.g94cf64af0-121.08.2.r12615.g246c2ee74-1
                    akonadi-calendar21.08.1.r1992.gc4e1756-121.08.2.r1997.g276e9a8-1
              akonadi-calendar-tools21.08.1.r908.g2d171cd-121.08.2.r909.gc820464-1
                    akonadi-contacts21.08.1.r3067.g2ba39cb9-121.08.2.r3070.g3fb27ed5-1
                        akonadi-mime21.08.1.r1657.gafeaa4f-121.08.2.r1660.g2b02921-1
                       akonadi-notes21.08.1.r1029.g3b6fc2d-121.08.2.r1032.g87092b2-1
                      akonadi-search21.08.1.r1130.gf22f09a-121.08.2.r1134.g2f008e9-1
                      akonadiconsole21.08.1.r1535.g190e66c-121.08.2.r1538.gf6676d2-1
                           akregator21.08.1.r6233.g26dfea7c-121.08.2.r6238.gaf5420b6-1
                           alligator  21.08.r3.g57c21ce-1  21.08.r5.g8743342-1
                            analitza21.08.1.r2331.ga435e3d2-121.08.2.r2333.g0ef48bb4-1
                                 ark21.08.1.r4618.gd9196f40-121.08.2.r4619.g171f8cbb-1
                          artikulate21.08.1.r1392.g9fc756c-121.08.2.r1393.ge3199a7-1
                              attica5.86.0.r839.g0679900-15.87.0.r842.gba026a4-1
                         audiocd-kio21.08.1.r1033.g9b99f39-121.08.2.r1033.g9b99f39-1
                               baloo5.86.0.r3010.g519e05d4-15.87.0.r3013.gcbf8efe8-1
                       baloo-widgets21.08.1.r706.g0d5331f-121.08.2.r707.g46269e3-1
                             blinken21.08.1.r637.g76afdb6-121.08.2.r637.g76afdb6-1
                           bluedevil1:5.22.5.r2292.g9b75ae06-11:5.22.5.r2294.gb4197ece-1
                            bluez-qt5.86.0.r682.g6157ab5-15.87.0.r684.gd585562-1
                              bomber21.08.1.r530.gbb1409d-121.08.2.r531.gb7cd635-1
                                bovo21.08.1.r740.g7c81071-121.08.2.r742.g02ad3ca-1
                              breeze5.22.5.r2281.g219cd7b1-15.22.5.r2288.gee06e262-1
                        breeze-icons5.86.0.r1798.ge871246a-15.87.0.r1805.gdc3990f8-1
                                buho  2.0.0.r8.gcf17a8c-1  2.0.0.r9.g85d954a-1
                     calendarsupport21.08.1.r42.ge9f81a0-121.08.1.r45.g3de8926-1
                            cervisia21.08.1.r1643.g2fd2688-121.08.2.r1643.g2fd2688-1
                            discover5.22.5.r8344.gd63e93dd-15.22.5.r8355.gf94c7978-1
                              disman5.22.4.r1808.g431141e-15.22.4.r1810.g82fb1b8-1
                             dolphin21.08.1.r6717.g8f0f12309-121.08.2.r6722.g73082d2e4-1
                     dolphin-plugins21.08.1.r607.g405f8b3-121.08.2.r608.g551a0f7-1
                              dragon21.08.1.r1013.gb70091f-121.08.2.r1013.gb70091f-1
                             drkonqi5.22.5.r701.g8b0c56f8-15.22.5.r704.gfc4d0ff6-1
                               elisa21.08.1.r2781.gafcbfca2-121.08.2.r2782.g6089288a-1
                          eventviews21.08.1.r59.g18ea3f9-121.08.2.r54.gc767443-1
                 extra-cmake-modules5.86.0.r3377.ga18543d-15.87.0.r3379.ge8a4dc1-1
                        ffmpegthumbs21.08.1.r196.gda3e9f2-121.08.2.r196.gda3e9f2-1
                           filelight21.08.1.r988.gc86cf39-121.08.2.r989.g2b70311-1
                frameworkintegration5.86.0.r601.gfe2fa4a-15.87.0.r603.g58bd1b6-1
                           granatier21.08.1.r935.g85520aa-121.08.2.r936.gc246393-1
                     grantlee-editor21.08.1.r775.gd9bb70a-121.08.2.r776.g6c92b88-1
                       grantleetheme21.08.1.r350.gc9171bc-121.08.2.r353.g1fbee51-1
                            gwenview21.08.1.r6680.g6e7df9e1-121.08.2.r6682.gcce25ca4-1
                     incidenceeditor21.08.1.r789.g0046fb4-121.08.2.r792.g2ee2d85-1
                            index-fm 2.0.0.r34.gc522af3-1 2.0.0.r36.g5702dbc-1
                           itinerary21.08.1.r1480.gb0fed00-121.08.2.r1491.g1a0f14d-1
                                 juk21.08.1.r3114.g404b3b87-121.08.2.r3114.g404b3b87-1
                                 k3b1:21.08.1.r6678.ge0d203af8-11:21.08.2.r6678.ge0d203af8-1
               kaccounts-integration21.08.1.r1227.gef9f8f3-121.08.2.r1228.g6cbf8be-1
                 kaccounts-providers21.08.1.r384.g7be401f-121.08.2.r384.g7be401f-1
                         kactivities5.86.0.r1365.gc6fc1c2-15.87.0.r1367.g4f7a69b-1
                   kactivities-stats5.86.0.r375.g0b75d37-15.87.0.r378.gece9abd-1
                   kactivitymanagerd5.22.5.r1370.g23f7802-15.22.5.r1373.g242b7cf-1
                        kaddressbook21.08.1.r6053.g6c431398-121.08.2.r6056.gc9d88a2a-1
                             kajongg21.08.1.r4200.gf294e35c-121.08.2.r4201.g67011c84-1
                              kalarm21.08.1.r6474.g91c2ce16-121.08.2.r6477.g228934a2-1
                           kalarmcal21.08.1.r1148.gfe25b13-121.08.2.r1149.ga2da000-1
                            kalgebra21.08.1.r2042.gfe5ef5c-121.08.2.r2042.gfe5ef5c-1
                             kalzium21.08.1.r4271.g60a829a7-121.08.2.r4271.g60a829a7-1
                              kamoso21.08.1.r1432.g2a2174e-121.08.2.r1432.g2a2174e-1
                            kanagram21.08.1.r1287.g7ea7c3a-121.08.2.r1287.g7ea7c3a-1
                             kapidox5.86.0.r554.gfd15a04-15.87.0.r555.gcef6bf9-1
                              kapman21.08.1.r611.g13119ff-121.08.2.r612.g068adca-1
                        kapptemplate21.08.1.r958.g050e474-121.08.2.r958.g050e474-1
                            karchive5.86.0.r513.gd923e57-15.87.0.r516.g11877f5-1
                               kasts 21.08.r43.g4c73f1c-1 21.08.r53.g9f9bcb6-1
                                kate21.08.1.r18387.gd65bb8298-121.08.2.r18402.g5d1f08489-1
                             katomic21.08.1.r924.gc68ab34-121.08.2.r925.gb21514e-1
                               kauth5.86.0.r451.g4fbf8b5-15.87.0.r453.g9b30ab8-1
                             kbackup21.08.1.r396.g54cf1cb-121.08.2.r397.gdf98a41-1
                           kblackbox21.08.1.r732.ga2ca9ef-121.08.2.r733.g7280dd3-1
                             kblocks21.08.1.r676.g3c04d36-121.08.2.r677.gbb65a4f-1
                          kbookmarks5.86.0.r425.gfe79ef8-15.87.0.r429.g6fc266d-1
                             kbounce21.08.1.r812.g27fa900-121.08.2.r813.g94de5c1-1
                           kbreakout21.08.1.r870.g314d0ba-121.08.2.r871.g7055181-1
                              kbruch21.08.1.r821.g28abed1-121.08.2.r822.g0e8880a-1
                         kcachegrind21.08.1.r1157.g3dff972-121.08.2.r1157.g3dff972-1
                  kcachegrind-common21.08.1.r1157.g3dff972-121.08.2.r1157.g3dff972-1
                               kcalc21.08.1.r1540.gd47e6ab-121.08.2.r1541.gdcb5a4f-1
                       kcalendarcore5.86.0.r1245.gab236054b-15.87.0.r1249.g09b13eb60-1
                           kcalutils21.08.1.r889.g88bcf29bd-121.08.2.r891.gb612016cb-1
                         kcharselect21.08.1.r479.g6fd5f06-121.08.2.r480.g959dc04-1
                              kclock 21.08.r15.g5c0192c-1 21.08.r17.g9047003-1
                            kcmutils5.86.0.r552.g5c84500-15.87.0.r559.gf028f4f-1
                             kcodecs5.86.0.r390.g30223c7-15.87.0.r393.g3e33f7d-1
                       kcolorchooser21.08.1.r233.g6c6137b-121.08.2.r234.g7def5b5-1
                         kcompletion5.86.0.r461.g85f769e-15.87.0.r464.g2c10527-1
                             kconfig5.86.0.r870.g4fceed0-15.87.0.r875.g9b44f49-1
                      kconfigwidgets5.86.0.r624.g3334e04-15.87.0.r629.g19aa762-1
                           kcontacts1:5.86.0.r3264.g3971b627-11:5.87.0.r3267.gd5187854-1
                         kcoreaddons5.86.0.r1301.gf94016ad-15.87.0.r1304.g230511de-1
                              kcrash5.86.0.r412.g551216e-15.87.0.r418.g882232d-1
                               kcron21.08.1.r796.g2c70204-121.08.2.r802.g5df10c6-1
                                kdav1:5.86.0.r1303.gdb91e09-11:5.87.0.r1306.geae96c6-1
                         kdbusaddons5.86.0.r383.g6e1c7c9-15.87.0.r385.gf143ca2-1
                       kde-cli-tools5.22.5.r1869.g612fbeb-15.22.5.r1872.g427e05b-1
                     kde-dev-scripts21.08.1.r4141.g0fbd8db-121.08.2.r4141.g0fbd8db-1
                       kde-dev-utils21.08.1.r564.ge869fcf-121.08.2.r564.ge869fcf-1
                      kde-gtk-config5.22.5.r915.g3186ef0-15.22.5.r916.g21d547e-1
               kde-telephony-support21.08.1.r431.g5459aa4-121.08.1.r431.gfb7a278-1
                      kdebugsettings21.08.1.r853.g9a398a3-121.08.2.r854.g02f0e67-1
                        kdeclarative5.86.0.r928.ga05b311-15.87.0.r930.g6282eb7-1
                          kdeconnect21.08.1.r3334.g5dfbd6bb-121.08.2.r3335.g83f8b1ce-1
                         kdecoration5.22.5.r275.gc9dcc47-15.22.5.r277.g5285f9d-1
                                kded5.86.0.r421.gd21a20d-15.87.0.r423.g8d7b6a9-1
                         kdeedu-data21.08.1.r15.g8dc3dee-121.08.2.r15.g8dc3dee-1
              kdegraphics-mobipocket21.08.1.r260.g0b01751-121.08.2.r261.ga9aa775-1
            kdegraphics-thumbnailers21.08.1.r237.g2c062c3-121.08.2.r237.g2c062c3-1
                     kdelibs4support5.86.0.r1039.g6ca3642e-15.87.0.r1043.gc90c74dc-1
              kdenetwork-filesharing21.08.1.r894.g73404b4-121.08.2.r894.g73404b4-1
                            kdenlive21.08.1.r15082.gadefe8c4d-121.08.2.r15086.ga644d42ce-1
                       kdepim-addons21.08.1.r4350.g6a40c27f-121.08.2.r4358.ga2c668e2-1
                      kdepim-runtime21.08.1.r15328.g0ef2e7479-121.08.2.r15332.g32e303f82-1
                    kdeplasma-addons5.22.5.r8591.g92a15b4f8-15.22.5.r8592.gbb2203dde-1
                    kdesdk-kioslaves21.08.1.r499.gf0b4adb-121.08.2.r499.gf0b4adb-1
                 kdesdk-thumbnailers21.08.1.r85.g29d3ad1-121.08.2.r85.g29d3ad1-1
                     kdesignerplugin5.86.0.r338.g67c435f-15.87.0.r340.gca3e138-1
                               kdesu5.86.0.r478.g21466d1-15.87.0.r480.ge37c3bc-1
                           kdewebkit5.86.0.r285.gdf48eaa-15.87.0.r287.g71a1ccf-1
                                 kdf21.08.1.r806.g03ea2d4-121.08.2.r807.g2848d1e-1
                             kdialog21.08.1.r1191.g8d6641e80-121.08.2.r1192.g90451ad7e-1
                            kdiamond21.08.1.r675.ga1a1351-121.08.2.r676.g5b43cdb-1
                            kdisplay5.22.4.r1453.g063f13b-15.22.4.r1455.g34844c0-1
                              kdnssd5.86.0.r328.g97c6458-15.87.0.r330.g9346560-1
                           kdoctools5.86.0.r631.g587c85c-15.87.0.r633.g7b3b282-1
                      keditbookmarks21.08.1.r2749.g30e3c4628-121.08.2.r2750.g29c8cd5b5-1
                          kemoticons5.86.0.r389.g7c8e975-15.87.0.r391.g1fc0725-1
                       kfilemetadata5.86.0.r811.g07374fe-15.87.0.r813.g64bffb5-1
                               kfind21.08.1.r2647.g2501ae6f4-121.08.2.r2648.gc7db97afc-1
                             kfloppy21.08.1.r762.g3d08134-121.08.2.r763.gf350cd6-1
                         kfourinline21.08.1.r988.g9024e77-121.08.2.r989.g290023c-1
                             kgamma55.22.5.r461.gd072c6c-15.22.5.r463.gc082f80-1
                          kgeography21.08.1.r1114.gde7a833-121.08.2.r1114.gde7a833-1
                                kget21.08.1.r3126.gab362007-121.08.2.r3126.gab362007-1
                        kglobalaccel5.86.0.r474.g5243a35-15.87.0.r476.g40c9eb0-1
                         kgoldrunner21.08.1.r1245.ga882085-121.08.2.r1246.g044c18f-1
                                kgpg21.08.1.r3137.gae0165c9-121.08.2.r3137.gae0165c9-1
                          kguiaddons5.86.0.r396.gb4c0d28-15.87.0.r399.g7713ec5-1
                            khangman21.08.1.r1568.g2b2f81e-121.08.2.r1568.g2b2f81e-1
                         khelpcenter21.08.1.r2683.g01585a72-121.08.2.r2684.g3ea4be64-1
                           kholidays1:5.86.0.r963.g9dde043-11:5.87.0.r966.g1c8c456-1
                            khotkeys5.22.5.r2096.g5658da5-15.22.5.r2098.gb99fa8d-1
                               khtml5.86.0.r560.gf713b26-15.87.0.r562.ge5a450c-1
                               ki18n5.86.0.r482.ge5c6854-15.87.0.r501.g0a85a58-1
                         kiconthemes5.86.0.r553.g7ef9c76-15.87.0.r558.g2b97107-1
                 kidentitymanagement21.08.1.r3830.gc10327f8-121.08.2.r3833.gfa7fe4e4-1
                           kidletime5.86.0.r320.g0941cc3-15.87.0.r322.g75f32f3-1
                                 kig21.08.1.r3147.g4a74fd8e-121.08.2.r3147.g4a74fd8e-1
                                kigo21.08.1.r529.g0464d41-121.08.2.r530.g2fd42f6-1
                            killbots21.08.1.r743.g927c36e-121.08.2.r744.ge430256-1
                       kimageformats5.86.0.r362.g904c251-15.87.0.r364.gfb66044-1
                     kimagemapeditor21.08.1.r473.g4708bdb-121.08.2.r473.g4708bdb-1
                               kimap21.08.1.r1131.g537f99e-121.08.2.r1132.g624e345-1
                         kinfocenter5.22.5.r1950.g145b3e5-15.22.5.r1962.g515dc22-1
                               kinit5.86.0.r416.ge4e9681-15.87.0.r419.g39b3d3d-1
                                 kio5.86.0.r5013.g6cb36c01-15.87.0.r5033.g9004e8dd-1
                          kio-extras21.08.1.r7132.g8173cc28-121.08.2.r7144.g2cda5518-1
                          kio-gdrive21.08.1.r570.ge9f6561-121.08.2.r570.ge9f6561-1
                        kipi-plugins21.08.1.r12063.g7a8168133-121.08.2.r12063.g7a8168133-1
                     kirigami-addons  1:0.2.r9.g4951077-1 1:0.2.r11.g8343013-1
                    kirigami-gallery21.08.1.r217.g0d73dad-121.08.2.r221.g6dfe1f5-1
                           kirigami25.86.0.r2917.g350f38f8-15.87.0.r2922.gb739a9ca-1
                              kiriki21.08.1.r424.gcd9a068-121.08.2.r425.g097d865-1
                         kitemmodels5.86.0.r559.gfa3b693-15.87.0.r564.gef7b4a1-1
                          kitemviews5.86.0.r344.g42b2f95-15.87.0.r347.g2cddd86-1
                               kiten21.08.1.r1150.ge6fe0d1-121.08.2.r1151.gaad01ed-1
                          kitinerary21.08.1.r1966.gb67d722-121.08.2.r1974.g0f87ef1-1
                         kjobwidgets5.86.0.r381.g237121b-15.87.0.r384.g9263307-1
                                 kjs5.86.0.r339.gc41c720-15.87.0.r341.g1daea23-1
                            kjsembed5.86.0.r308.gf908042-15.87.0.r310.g1b57e96-1
                        kjumpingcube21.08.1.r792.g9533ab2-121.08.2.r793.ged0b741-1
                               kldap21.08.1.r894.g6754b36-121.08.2.r897.g8edeb04-1
                           kleopatra21.08.1.r6004.g3b225f73-121.08.2.r6007.g7479e271-1
                            klettres21.08.1.r923.ga133223-121.08.2.r924.g2cedadb-1
                            klickety21.08.1.r641.gd39602b-121.08.2.r642.g3459208-1
                              klines21.08.1.r774.g35c2e65-121.08.2.r775.g6b9cb70-1
                                kmag21.08.1.r697.gdba69e1-121.08.2.r698.g3610e86-1
                           kmahjongg21.08.1.r1475.g6ca3ebf-121.08.2.r1476.gb0d0459-1
                               kmail21.08.1.r26013.g011acfc7e-121.08.2.r26020.gdf6790e49-1
                kmail-account-wizard21.08.1.r825.g121a4ae-121.08.2.r826.g1054e67-1
                               kmbox21.08.1.r547.g11eca5f-121.08.2.r548.gb2fa39a-1
                        kmediaplayer5.86.0.r299.g12d1a43-15.87.0.r301.gd7776a0-1
                           kmenuedit5.22.5.r974.gc97ffdd-15.22.5.r976.gcc2ebaa-1
                               kmime21.08.1.r1461.g071aeac-121.08.2.r1463.g604b68c-1
                              kmines21.08.1.r1727.g9886e4e-121.08.2.r1728.geaa083c-1
                                kmix21.08.1.r2384.g90037ea2-121.08.2.r2384.g90037ea2-1
                          kmousetool21.08.1.r401.ga707790-121.08.2.r402.g07fd0bc-1
                              kmouth21.08.1.r697.g11ae211-121.08.2.r698.g3b31510-1
                              kmplot21.08.1.r1467.g8976beb-121.08.2.r1467.g8976beb-1
                        knavalbattle21.08.1.r1396.g7bc42f5-121.08.2.r1397.ga1df1ab-1
                            knetwalk21.08.1.r663.g59e4562-121.08.2.r664.g1b6ac42-1
                           knewstuff5.86.0.r1224.gbc05a72b-15.87.0.r1226.g8d358d66-1
                             knights21.08.1.r1057.g21a2385-121.08.2.r1058.g5777135-1
                              knotes21.08.1.r3526.gc2976200-121.08.2.r3530.g0aefed6d-1
                      knotifications5.86.0.r688.g2f56e9f-15.87.0.r691.gfdc0fff-1
                       knotifyconfig5.86.0.r357.ge5c166a-15.87.0.r359.g3415b87-1
                                koko 21.08.r21.g04e8548-1 21.08.r24.g9c01a42-1
                                kolf21.08.1.r1447.gb46dc7b-121.08.2.r1448.g8bfb7b9-1
                           kollision21.08.1.r497.g5382e51-121.08.2.r498.g8b7ac9f-1
                         kolourpaint21.08.1.r2366.g852be4a4-121.08.2.r2368.g62680ac2-1
                             kompare21.08.1.r1111.g86bf9d8-121.08.2.r1111.g86bf9d8-1
                            kongress  21.08.r3.g9607077-1  21.08.r4.g7a5eed5-1
                           konqueror21.08.1.r14981.g1d8f4e874-121.08.2.r14983.g4f96b58ef-1
                            konquest21.08.1.r901.g34f8dd2-121.08.2.r902.g9fa7c8e-1
                             konsole21.08.1.r7965.g9fd65c9b-121.08.2.r7970.g2e07ede4-1
                             kontact21.08.1.r5390.g694772fb-121.08.2.r5391.g64ab4026-1
                    kontactinterface21.08.1.r637.gf566e4f-121.08.2.r640.gcb8dbe2-1
                            kontrast21.08.1.r176.gf47bed7-121.08.2.r184.g31f3975-1
                        konversation21.08.1.r9000.g7d8174ca-121.08.2.r9000.g7d8174ca-1
                       kopeninghours21.08.1.r272.gb8b07a8-121.08.2.r274.g6c8e88d-1
                          korganizer21.08.1.r11519.ge2751f59a-121.08.2.r11524.g0712d595b-1
                       kosmindoormap21.08.1.r660.gf3fe9bb-121.08.2.r660.gf3fe9bb-1
                            kpackage5.86.0.r701.g491fd1e-15.87.0.r704.g5a70933-1
                              kparts5.86.0.r531.gcd0d00a-15.87.0.r535.ge8847d9-1
                                kpat21.08.1.r2568.gb52fa9e-121.08.2.r2569.g2570b95-1
                             kpeople5.86.0.r1348.g0677b4e-15.87.0.r1351.g6d9d32e-1
                        kpimtextedit21.08.1.r1456.gbbda184-121.08.2.r1458.g70b320a-1
                             kpkpass21.08.1.r242.g9dd3732-121.08.2.r243.g9cfaabb-1
                           kplotting5.86.0.r298.ga377fbc-15.87.0.r301.g0dce0dd-1
                             kpmcore21.08.1.r1200.g6f2be13-121.08.2.r1200.g6f2be13-1
                                kpty5.86.0.r345.g52db068-15.87.0.r347.g88997f4-1
                    kpublictransport21.08.1.r1868.g93802234-121.08.2.r1890.g635bb22a-1
                      kqtquickcharts21.08.1.r74.g264af68-121.08.2.r74.g264af68-1
                        kquickcharts5.86.0.r483.g8e8f8a3-15.87.0.r486.g9d1ec29-1
                   kquickimageeditor       r61.gbd11196-1       r63.g91b9b28-1
                                krdc21.08.1.r1543.gaf97f48-121.08.2.r1544.gc833d93-1
                           krecorder  21.08.r5.g1a6ec64-1  21.08.r7.gb4384ed-1
                            kreversi21.08.1.r1230.gfa2c775-121.08.2.r1232.ge132230-1
                                krfb21.08.1.r1419.g3bf587a-121.08.2.r1421.gc820758-1
                               kross5.86.0.r339.gb29a377-15.87.0.r341.gd944054-1
                  kross-interpreters21.08.1.r723.g473116a-121.08.2.r723.g473116a-1
                              kruler21.08.1.r707.g9399f32-121.08.2.r708.gf90ef06-1
                             krunner5.86.0.r688.gf7a6318-15.87.0.r692.g573c971-1
                             kscreen5.22.5.r1370.g3c6cf37-15.22.5.r1373.g04803df-1
                       kscreenlocker5.22.5.r879.ge5617ef-15.22.5.r881.gaafe47b-1
                            kservice5.86.0.r951.gc642fa3-15.87.0.r954.g36a438f-1
                             kshisen21.08.1.r1206.gfbf5fa8-121.08.2.r1207.g3c67ecf-1
                               ksirk21.08.1.r968.g0ca946f-121.08.2.r969.g1e80bbe-1
                               ksmtp21.08.1.r393.g03b8ec6-121.08.2.r395.g4fba022-1
                          ksnakeduel21.08.1.r813.ga2313cb-121.08.2.r814.g1e4ff1a-1
                          kspaceduel21.08.1.r639.g385b245-121.08.2.r640.gb59d81c-1
                            ksquares21.08.1.r525.gf488fbb-121.08.2.r526.g315c72d-1
                         ksshaskpass5.22.5.r200.g2d7b461-15.22.5.r202.g6f98560-1
                             ksudoku21.08.1.r1059.gcf9bce6-121.08.2.r1062.gbbc39cd-1
                          ksystemlog21.08.1.r672.g997690a-121.08.2.r674.gf7382a9-1
                        ksystemstats5.22.5.r204.g4729ebd-15.22.5.r206.g266d64c-1
                            kteatime21.08.1.r726.g3fbc0e0-121.08.2.r727.g25afb78-1
                         ktexteditor5.86.0.r2955.g52df41bd-15.87.0.r2957.g0432601c-1
                        ktextwidgets5.86.0.r418.gd88b4f7-15.87.0.r421.ga993f02-1
                              ktimer21.08.1.r473.g79e3887-121.08.2.r474.gb31f845-1
                               ktnef21.08.1.r670.gcf2dac4-121.08.2.r673.g2bb8971-1
                            ktorrent21.08.1.r2779.g849bb675-121.08.2.r2780.g087255f1-1
                              ktouch21.08.1.r2146.gcf83f80-121.08.2.r2147.ge435715-1
                          ktuberling21.08.1.r1016.gf222be0-121.08.2.r1016.gf222be0-1
                             kturtle21.08.1.r1125.g197b953-121.08.2.r1125.g197b953-1
                             kubrick21.08.1.r374.gdd0c729-121.08.2.r375.g50a2de2-1
                     kunitconversion5.86.0.r380.g2b31259-15.87.0.r383.ge3e3b4b-1
                             kwallet5.86.0.r1093.gdcf7c83-15.87.0.r1095.g6d9b433-1
                         kwallet-pam5.22.5.r257.g3107d36-15.22.5.r259.g1d65ed8-1
                      kwalletmanager21.08.1.r1214.g4f24426-121.08.2.r1215.g1bc55c2-1
                               kwave21.08.1.r3742.gad9cbef2-121.08.2.r3742.gad9cbef2-1
                            kwayland5.86.0.r1118.g1a70c7f-15.87.0.r1120.gf97c2e5-1
                kwayland-integration5.22.5.r191.g5938091-15.22.5.r193.g1791ee6-1
                     kwayland-server5.22.5.r1397.g72aa44c-15.22.5.r1399.g1160726-1
                        kweathercore    0.5.r1.g2be08aa-1    0.5.r3.g21d7195-1
                      kwidgetsaddons5.86.0.r884.gc6d0e713-15.87.0.r887.g4def632c-1
                                kwin5.22.5.r20088.ge6c77a1dd-15.22.5.r20102.g310684f1a-1
                       kwindowsystem5.86.0.r632.gd8d358c-15.87.0.r635.g64908e8-1
                              kwinft5.22.4.r19439.g155d17577-15.22.4.r19441.gee2767ffe-1
                           kwordquiz21.08.1.r1148.gf29ed6d-121.08.2.r1148.gf29ed6d-1
                              kwrite21.08.1.r18387.gd65bb8298-121.08.2.r18402.g5d1f08489-1
                             kwrited5.22.5.r486.g53b0bc0-15.22.5.r488.gdd0bac8-1
                             kxmlgui5.86.0.r814.g90a9ab2f-15.87.0.r817.g649dcebe-1
                       kxmlrpcclient5.86.0.r460.g206418f1c-15.87.0.r462.g1096d5b98-1
                      layer-shell-qt5.21.5.r48.g5b280a4-15.21.5.r50.g662afeb-1
                          libakonadi21.08.1.r12608.g94cf64af0-121.08.2.r12615.g246c2ee74-1
                         libgravatar21.08.1.r372.g8e07a3f-121.08.2.r375.g1854243-1
                            libkcddb21.08.1.r741.g8f27c69-121.08.2.r741.g8f27c69-1
                     libkcompactdisc21.08.1.r388.gd787fba-121.08.2.r388.gd787fba-1
                           libkdcraw21.08.1.r1149.gcf46fe0-121.08.2.r1150.gaac85a3-1
                         libkdegames21.08.1.r2189.ga048f7d8-121.08.2.r2191.gf73b13fe-1
                           libkdepim21.08.1.r856.gb794dc3-121.08.2.r858.g55c24f5-1
                  libkeduvocdocument21.08.1.r1793.g3f907e0-121.08.2.r1794.g48d1a52-1
                           libkexiv221.08.1.r816.gf21e55a-121.08.2.r817.gbceb615-1
                             libkipi21.08.1.r1251.ge411a22-121.08.2.r1252.g4524dcb-1
                             libkleo21.08.1.r956.geb8d21d-121.08.2.r959.gd6fbbb9-1
                        libkmahjongg21.08.1.r459.ga08193b-121.08.2.r460.ga0e3a1c-1
                     libkomparediff221.08.1.r340.gadbac13-121.08.2.r341.gc0ec97e-1
                            libksane21.08.1.r565.gf5f3613-121.08.2.r566.g9d073a2-1
                          libkscreen5.22.5.r1597.ge49294c-15.22.5.r1599.g8c74fbb-1
                           libksieve21.08.1.r1600.g2c977b60-121.08.2.r1601.ge6a8a4dd-1
                        libksysguard5.22.5.r2310.g532f6fb-15.22.5.r2312.g3aedbff-1
                         libktorrent21.08.1.r539.gbf23d9a-121.08.2.r540.g2cb44d0-1
                            lokalize21.08.1.r1783.g4c693627-121.08.2.r1783.g4c693627-1
                               lskat21.08.1.r819.g79da282-121.08.2.r820.ge77fa1d-1
                          mailcommon21.08.1.r1122.g76ee778-121.08.2.r1127.g08b00d2-1
                        mailimporter21.08.1.r476.g12a62c7-121.08.2.r478.ga084d09-1
                              marble21.08.1.r13356.g8aadc3eb8-121.08.2.r13356.g8aadc3eb8-1
                       marble-common21.08.1.r13356.g8aadc3eb8-121.08.2.r13356.g8aadc3eb8-1
                           marble-qt21.08.1.r13356.g8aadc3eb8-121.08.2.r13356.g8aadc3eb8-1
                        markdownpart21.08.1.r85.gc621680-121.08.2.r86.g011ad11-1
                           maui-clip 2.0.0.r10.gf53a40f-1 2.0.0.r13.g96adae4-1
                           maui-nota 2.0.0.r10.gda9c6d5-1 2.0.0.r13.g85803da-1
                            maui-pix 2.0.0.r18.g67c0b84-1 2.0.0.r19.g94a7cc2-1
                             mauikit2.0.2.r33.ga0635262-12.0.2.r57.g8372f8e8-1
                mauikit-filebrowsing 2.0.2.r14.gd7877cc-1 2.0.2.r19.gf548745-1
                  mauikit-imagetools  2.0.1.r3.g195a229-1  2.0.1.r4.gc5fa31f-1
                  mauikit-texteditor  2.0.1.r4.ge073d99-1  2.0.1.r5.g791c0c4-1
                       mbox-importer21.08.1.r522.gf6d82bb-121.08.2.r523.g1155f11-1
                          messagelib21.08.1.r6224.g2bbdfb0d-121.08.2.r6236.g17f8c44c-1
                               milou5.22.5.r752.g683cc43-15.22.5.r754.gfe6e4e3-1
                              minuet21.08.1.r584.gd10a058-121.08.2.r584.gd10a058-1
                     modemmanager-qt5.86.0.r525.g835aaa3-15.87.0.r526.g593f7c0-1
                             neochat    r1897.g6b331ca8-1    r1903.ge6c594f3-1
                   networkmanager-qt5.86.0.r1124.g025ea91-15.87.0.r1125.g7e50258-1
                              okular21.08.1.r9496.g458c72a9c-121.08.2.r9500.g7ccdd513b-1
                              oxygen5.22.5.r4431.g6a16cdd7-15.22.5.r4434.g1d771cca-1
                        oxygen-icons1:5.86.0.r5.gbff159d-11:5.87.0.r5.gbff159d-1
                    oxygen-icons-svg1:5.86.0.r5.gbff159d-11:5.87.0.r5.gbff159d-1
                            palapeli21.08.1.r1239.gb04597b-121.08.2.r1246.ga26da71-1
                              parley21.08.1.r4464.g015a76e0-121.08.2.r4464.g015a76e0-1
                    partitionmanager21.08.1.r1533.g6339ca2-121.08.2.r1533.g6339ca2-1
                               picmi21.08.1.r529.g6efe5f4-121.08.2.r538.g2eac3fb-1
                   pim-data-exporter21.08.1.r2463.g6eaee33a-121.08.2.r2464.g35747153-1
                    pim-sieve-editor21.08.1.r1517.gbbc59ea-121.08.2.r1518.ge4b0b61-1
                           pimcommon21.07.80.r1122.gcb26eff-121.07.80.r1127.gd4a00d2-1
                    plasma-bigscreen      r408.gaa02776-2      r409.g86e6990-1
          plasma-browser-integration5.22.5.r1282.gd9cfc2d8-15.22.5.r1283.g3d6a6e00-1
                      plasma-desktop5.22.5.r8656.gfdf8fe566-15.22.5.r8675.gd0ac6437d-1
                    plasma-dialer-mm  21.08.r8.g8cc6788-1  21.08.r8.g8cc6788-2
                        plasma-disks5.22.5.r234.g312e170-15.22.5.r237.g925c7eb-1
                     plasma-firewall5.22.5.r524.g2151c71-15.22.5.r527.g9d47888-1
                    plasma-framework5.86.0.r16010.g1f0df3dd2-15.87.0.r16031.gb174e5bbf-1
                  plasma-integration5.22.5.r535.g3c3c907-15.22.5.r536.gb17aaf9-1
                    plasma-mobile-nm5.22.5.r3106.ge184d80c-15.22.5.r3107.g5033dbf7-1
                         plasma-nano5.22.5.r162.g7992bc4-15.22.5.r164.gf9c3547-1
                           plasma-nm5.22.5.r3105.g7e8d428f-15.22.5.r3107.g5033dbf7-1
                           plasma-pa5.22.5.r980.gac5ce03-15.22.5.r988.g2e2259d-1
             plasma-phone-components5.22.5.r1497.gd14f2123-15.22.5.r1501.g957e5126-1
                    plasma-phonebook 21.08.r12.g3c6b0b9-1 21.08.r15.g6151285-1
                          plasma-sdk5.22.5.r2283.geb65c653-15.22.5.r2286.g83823c9d-1
                     plasma-settings 21.08.r23.g54e230a-1 21.08.r26.g8c25cc5-1
                plasma-systemmonitor5.22.5.r490.gd870377-15.22.5.r497.gd083499-1
                  plasma-thunderbolt5.22.5.r152.g7974058-15.22.5.r153.ga265f72-1
                        plasma-vault5.22.5.r346.gfc93945-15.22.5.r347.g233e004-1
              plasma-wayland-session5.22.5.r10695.g79f5b3dff-15.22.5.r10708.g776879004-1
                    plasma-workspace5.22.5.r10695.g79f5b3dff-15.22.5.r10708.g776879004-1
         plasma-workspace-wallpapers5.22.5.r296.g1655902-15.22.5.r297.gc305370-1
                    polkit-kde-agent5.22.5.r506.g0b7c377-15.22.5.r507.g3f64adb-1
                          powerdevil5.22.5.r2483.gd3feb5f8-15.22.5.r2484.g81ebb3ee-1
                               poxml21.08.1.r277.ge2d4dfb-121.08.2.r277.ge2d4dfb-1
                       print-manager21.08.1.r1060.gc5416fd-121.08.2.r1061.g2b5ca30-1
                              prison5.86.0.r336.g4a3d3c7-15.87.0.r339.gc93839a-1
                       pulseaudio-qt  1.3.0.r3.gab0b972-1  1.3.0.r4.g127cfb8-1
                             purpose5.86.0.r893.gc4dc113-15.87.0.r897.gaa61332-1
                         qcachegrind21.08.1.r1157.g3dff972-121.08.2.r1157.g3dff972-1
                   qqc2-breeze-style5.22.5.r229.gdd4e4c4-15.22.5.r232.ga254696-1
                  qqc2-desktop-style5.86.0.r531.gdb1f8d8-15.87.0.r535.g1b61747-1
                                rocs21.08.1.r3044.gf0400004-121.08.2.r3044.gf0400004-1
                            sddm-kcm5.22.5.r611.gdf72242-15.22.5.r613.gb27eff6-1
            signon-kwallet-extension21.08.1.r65.g82912be-121.08.2.r65.g82912be-1
                               solid5.86.0.r711.g60a57f0-15.87.0.r714.g8395746-1
                              sonnet5.86.0.r640.g51e6972-15.87.0.r643.g9359ac5-1
                            spacebar  21.08.r5.g7f4a52a-1  21.08.r8.g0e6f86f-1
                         spacebar-mm  21.08.r5.g7f4a52a-1  21.08.r8.g0e6f86f-1
                           spectacle21.08.1.r1177.gc95f6db-121.08.2.r1180.g3eadf12-1
                                step21.08.1.r1157.g9df45cd-121.08.2.r1157.g9df45cd-1
                             svgpart21.08.1.r185.g37d56ba-121.08.2.r186.g5d5278d-1
                             sweeper21.08.1.r536.g15331af-121.08.2.r537.g23d1afb-1
                         syndication5.86.0.r843.g5886582-15.87.0.r846.g7d4c917-1
                 syntax-highlighting5.86.0.r1707.gde22f18d-15.87.0.r1710.g0b2c0dc5-1
                      systemsettings5.22.5.r2516.gba3dedd4-15.22.5.r2533.g4ed04a78-1
          telepathy-kde-accounts-kcm21.08.1.r1196.g27af480-121.08.2.r1197.g89dbbff-1
              telepathy-kde-approver21.08.1.r295.g4f4fc32-121.08.2.r295.g4f4fc32-1
          telepathy-kde-auth-handler21.08.1.r277.g1db14c4-121.08.2.r277.g1db14c4-1
               telepathy-kde-call-ui21.08.1.r445.g8815182-121.08.2.r445.g8815182-1
      telepathy-kde-common-internals21.08.1.r1994.g4d6f30e-121.08.2.r1995.g1916354-1
          telepathy-kde-contact-list21.08.1.r1085.g6ede63e-121.08.2.r1085.g6ede63e-1
        telepathy-kde-contact-runner21.08.1.r253.g9fa10bb-121.08.2.r253.g9fa10bb-1
       telepathy-kde-desktop-applets21.08.1.r995.gc1eb268-121.08.2.r995.gc1eb268-1
  telepathy-kde-filetransfer-handler21.08.1.r220.g3eb1cbb-121.08.2.r220.g3eb1cbb-1
    telepathy-kde-integration-module21.08.1.r391.g52b0f46-121.08.2.r391.g52b0f46-1
               telepathy-kde-text-ui21.08.1.r2022.g56586fc-121.08.2.r2023.gd729dc6-1
                        threadweaver5.86.0.r514.g45d5296-15.87.0.r517.g1b3b341-1
                             tokodon  21.08.r7.g84a61e2-1  21.08.r9.g0568460-1
                            umbrello21.08.1.r8265.g50ef037a5-121.08.2.r8265.g50ef037a5-1
                               vvave 2.0.0.r50.gaa1ed40-1 2.0.0.r56.g2d49b50-1
                            wrapland5.22.4.r1601.g89845e24-15.22.4.r1603.gcbeab520-1
              xdg-desktop-portal-kde5.22.5.r391.gecf9623-15.22.5.r392.g5985b08-1
                             yakuake21.08.1.r737.gf21268b-121.08.2.r737.gf21268b-1
                    zeroconf-ioslave21.08.1.r360.gbfa66db-121.08.2.r360.gbfa66db-1
                kde-telephony-daemon                    -21.08.1.r431.gd73b404-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Old Issues
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Nice, the Odroid C2 is still alive for the devs.
I’ll try to test it this weekend.
I updated the uboot package. Hopefully it still works.
silky smooth update on pinephone :+1:
My Pinebook Pro no longer boots after applying the latest uboot package from the SSD :frowning:
You mean uboot on the eMMC?
Exactly. And root on SSD
Not much have changed in that regard, so not sure why that is messed up. Is the PARTUUID’s still correct?
Hmmm seems to be a more general issue with the device as it doesn’t even boot from microSD 21.08 release. Screen is just blank and orange led is staying on… will investigate later.
Hmmm definitely seems to be an issue with eMMC. Could just get it boot from microSD after hardware disabling the eMMC… not sure what went wrong with the uboot flashing though as I was using the same statements as always to put it onto the eMMC…
So this was quite a journey… At the end the following approach worked for me:
  1. hardware disable the eMMC to be able to boot from microSD
  2. download a copy of the spi_bin from images.postmarketos.org and install it to the SPI
  3. re-enable eMMC and reboot
  4. uboot in SPI takes over and boots properly with eMMC enabled again
  5. boot from microSD and reflash latest stable (21.08) to eMMC (overwrites everything!!)
  6. clear SPI
  7. reboot from eMMC
  8. change boot config to use root on SSD
Have a working system again, but didn’t reflash the newer uboot 2021-10 to eMMC right now…
I have the exact same problem with uboot-pinebookpro 2021.10. The pinebook doesn’t want to boot with that version. It just gets stuck on the amber light. Display stays completely black. It’s not even showing the pre-kernel-loading uboot stuff.
I went through the exact same steps as appelgriebsch to get it to boot again (without having seen his comments :slight_smile: ).
Additionally, I tried re-flashing uboot 2021.10, and that again borked the boot.
After that I went back and forth a few times between 2021.10 and 2021.07 (last one I had in the cache) and that seems to confirm that there is a problem with 2021.10 package.
Hm. Thanks for testing. I wonder why it has issues. There was no real changes between 2021.07 and 2021.10 for the Pinebook Pro, as far as I can see.
Anyone have UART outputs for it?
EDIT: Reverted uboot-pinebookpro to version 2021.07-3, until we find out why it does not work.
My device also wouldn’t boot after updating uboot, but I managed to replace it with the old version by jumping through some of the hoops above.
Pushed another batch to Testing branch.
                             PACKAGE          arm-testing         arm-unstable
                              chatty 0.4.0+130+g99a1db2-2 0.4.0+172+g1d54b16-1
                            kodi-rpi              19.1-11               19.2-1
                        kodi-rpi-dev              19.1-11               19.2-1
               kodi-rpi-eventclients              19.1-11               19.2-1
        kodi-rpi-tools-texturepacker              19.1-11               19.2-1
                   rpi4-post-install           20210126-1           20211014-1
                           timeshift            21.09.1-2            21.09.1-3
                             ansible              4.6.0-1              4.7.0-1
                          aws-c-auth              0.6.4-1              0.6.5-1
                        aws-c-common             0.6.11-1             0.6.12-1
                            aws-c-io             0.10.9-1            0.10.10-1
                             blender          17:2.93.5-2          17:2.93.5-3
                          bs1770gain              0.6.0-4                    -
                                btop             1.0.14-1             1.0.15-1
                    cargo-spellcheck             0.8.13-1             0.8.14-1
                            clipgrab              3.9.6-1              3.9.7-1
                        erlang22-nox          22.3.4.21-1                    -
                           filezilla             3.55.1-3             3.56.0-1
                          goreleaser            0.180.0-2            0.182.1-1
                              groovy              3.0.8-1              3.0.9-1
                         groovy-docs              3.0.7-1              3.0.9-1
                      home-assistant           2021.9.7-1          2021.10.3-1
                             img2pdf              0.4.1-1              0.4.2-1
                               ksnip              1.9.0-1              1.9.1-1
                        languagetool                5.4-1                5.5-1
                        libfilezilla             0.33.0-1             0.34.0-1
                         libopenshot              0.2.7-1              0.2.7-2
                            libretls              3.3.1-2              3.3.4-1
                           libtg_owt     0.git6.91d836d-2     0.git7.575fb17-1
                 lua-language-server              2.4.2-1              2.4.3-1
                        lucky-commit              2.0.5-2              2.1.0-1
                       mediathekview             13.8.0-1             13.8.0-2
                             mod_itk          2.4.7.r04-1          2.4.7.r04-2
                                mpop             1.4.13-1             1.4.15-1
                              nodejs            16.11.0-1            16.11.1-1
                   nodejs-lts-erbium            12.22.4-2            12.22.7-1
                  nodejs-lts-fermium            14.17.4-1            14.18.1-1
                      opentimelineio               0.13-2               0.13-3
                     owncloud-client         2.9.0.5150-2         2.9.1.5500-1
                             pyright            1.1.177-1            1.1.178-1
                        python-anyio              3.3.2-1              3.3.3-1
                       python-calmjs              3.4.1-4              3.4.2-1
                     python-progress                1.5-5                1.6-1
                  python-statsmodels             0.12.2-2             0.13.0-1
                    python2-progress                1.5-5                1.6-1
                                 snd               21.7-1               21.8-1
                               sndio              1.7.0-3              1.8.1-1
                           terraform              1.0.8-1              1.0.9-1
                          terragrunt             0.34.0-1             0.35.2-1
                             tinyssh           20210319-1           20210601-2
                     tinyssh-convert                0.2-6                    -
                ukui-session-manager              3.0.4-1              3.0.5-1
                              waybar              0.9.8-1              0.9.8-2
                             web-ext              6.4.0-1              6.5.0-1
                         x42-plugins           20210714-1           20211012-1
                             yoshimi              2.1.1-1            2.1.1.1-1
                      aws-c-sdkutils                    -              0.1.1-1
                               linux            5.14.11-1            5.14.12-1
                       linux-headers            5.14.11-1            5.14.12-1
                     linux-pinephone            5.14.11-1            5.14.12-1
             linux-pinephone-headers            5.14.11-1            5.14.12-1
                          linux-rpi4            5.10.63-2            5.10.73-1
                  linux-rpi4-headers            5.10.63-2            5.10.73-1
                 linux-rpi4-mainline             5.14.9-1            5.14.12-1
         linux-rpi4-mainline-headers             5.14.9-1            5.14.12-1
                       linux-rpi4-rc           5.15.rc4-1           5.15.rc5-1
               linux-rpi4-rc-headers           5.15.rc4-1           5.15.rc5-1
                           linux-vim             5.13.5-1            5.14.10-1
                   linux-vim-headers             5.13.5-1            5.14.10-1
                      manjaro-system           20210716-1           20211013-1
              raspberrypi-bootloader           20210923-1           20211013-1
            raspberrypi-bootloader-x           20210923-1           20211013-1
                     uboot-pinephone            2021.07-4            2021.10-1
                               bison              3.8.1-1              3.8.2-1
                          libnghttp2             1.45.0-1             1.45.1-1
                                 aom              3.1.3-1              3.1.3-2
                            aom-docs              3.1.3-1              3.1.3-2
                               bluez               5.61-1               5.62-1
                          bluez-cups               5.61-1               5.62-1
                       bluez-hid2hci               5.61-1               5.62-1
                          bluez-libs               5.61-1               5.62-1
                       bluez-plugins               5.61-1               5.62-1
                         bluez-utils               5.61-1               5.62-1
                             flatpak             1.12.1-1             1.12.2-1
                              gthumb             3.10.4-1             3.12.0-1
                         jdk-openjdk          16.0.2.u7-1             17.u35-1
                         jre-openjdk          16.0.2.u7-1             17.u35-1
                jre-openjdk-headless          16.0.2.u7-1             17.u35-1
                           libfprint             1.94.0-1             1.94.1-1
                        libqalculate             3.20.1-1             3.21.0-1
                         openjdk-src          16.0.2.u7-1             17.u35-1
                             purpose             5.86.0-1             5.87.0-1
                        pyqt-builder             1.11.0-1             1.12.0-1
                 python-cryptography              3.4.8-2             35.0.0-1
                      python-urllib3             1.26.6-1             1.26.7-1
                  python-urllib3-doc             1.26.6-1             1.26.7-1
                     python2-urllib3             1.26.6-1             1.26.7-1
                       qalculate-gtk             3.20.1-1             3.21.0-1
                     qt5-declarative     5.15.2+kde+r32-1     5.15.2+kde+r33-1
                               rygel           1:0.40.2-1           1:0.40.2-2
                                 sip              6.2.0-2              6.3.0-1
                             akonadi21.08.2.r12615.g246c2ee74-121.08.2.r12617.g14039b8f5-1
               akonadi-import-wizard21.08.1.r1759.g31f5d52-121.08.2.r1760.gd7ed78d-1
                           angelfish 21.08.r32.g54a3278-1 21.08.r33.g1757260-1
                              bomber21.08.2.r531.gb7cd635-121.08.2.r532.g7eb9b0c-1
                              breeze5.22.5.r2288.gee06e262-15.22.5.r2289.g7f9f732a-1
                        breeze-icons5.87.0.r1805.gdc3990f8-15.87.0.r1810.gf44b1342-1
                            discover5.22.5.r8355.gf94c7978-15.22.5.r8362.ge78ff92c-1
                              dragon21.08.2.r1013.gb70091f-121.08.2.r1014.gd0e51f3-1
                               elisa21.08.2.r2782.g6089288a-121.08.2.r2783.ga4c31304-1
                            index-fm 2.0.0.r36.g5702dbc-1 2.0.0.r37.g0101ea4-1
                        kaddressbook21.08.2.r6056.gc9d88a2a-121.08.2.r6057.g2edcd803-1
                              kamera21.08.1.r667.gecb976b-121.08.2.r667.gecb976b-1
                                kate21.08.2.r18402.g5d1f08489-121.08.2.r18404.g7f769010b-1
                             katomic21.08.2.r925.gb21514e-121.08.2.r926.g13657d9-1
                       kcalendarcore5.87.0.r1249.g09b13eb60-15.87.0.r1251.ge6e016ea0-1
                         kcompletion5.87.0.r464.g2c10527-15.87.0.r465.g1f7fa17-1
                           kcontacts1:5.87.0.r3267.gd5187854-11:5.87.0.r3268.gf8ab76af-1
                         kcoreaddons5.87.0.r1304.g230511de-15.87.0.r1305.gcb7df721-1
                       kde-dev-utils21.08.2.r564.ge869fcf-121.08.2.r565.gdf6d2d4-1
               kde-telephony-support21.08.1.r431.gfb7a278-1                    -
                      kdebugsettings21.08.2.r854.g02f0e67-121.08.2.r856.g3c1afd4-1
                          kdeconnect21.08.2.r3335.g83f8b1ce-121.08.2.r3336.gf596972b-1
                     kdelibs4support5.87.0.r1043.gc90c74dc-15.87.0.r1044.g60f08c91-1
                            kdenlive21.08.2.r15086.ga644d42ce-121.08.2.r15095.g0d472bec2-1
                      kdepim-runtime21.08.2.r15332.g32e303f82-121.08.2.r15336.g880ac1ba3-1
                       kfilemetadata5.87.0.r813.g64bffb5-15.87.0.r814.g17eccd0-1
                         kiconthemes5.87.0.r558.g2b97107-15.87.0.r560.gc231a31-1
                         kinfocenter5.22.5.r1962.g515dc22-15.22.5.r1967.gbfde0d0-1
                                 kio5.87.0.r5033.g9004e8dd-15.87.0.r5035.g31cba76e-1
                     kirigami-addons 1:0.2.r11.g8343013-1 1:0.2.r12.g17233e2-1
                           kirigami25.87.0.r2922.gb739a9ca-15.87.0.r2925.g241c5e64-1
                               kmail21.08.2.r26020.gdf6790e49-121.08.2.r26025.g510deb422-1
                      kmailtransport21.08.1.r1668.g375f51d-121.08.2.r1672.g73611cd-1
                             knights21.08.2.r1058.g5777135-121.08.2.r1065.g0e3ba23-1
                             konsole21.08.2.r7970.g2e07ede4-121.08.2.r7972.g4f81a645-1
                    kontactinterface21.08.2.r640.gcb8dbe2-121.08.2.r641.g36833a8-1
                              kopete21.08.1.r16400.gd7c8d986d-121.08.2.r16401.gb0c532ffa-1
                          korganizer21.08.2.r11524.g0712d595b-121.08.2.r11525.g19c882f17-1
                        kpimtextedit21.08.2.r1458.g70b320a-121.08.2.r1463.g1db48c0-1
                    kpublictransport21.08.2.r1890.g635bb22a-121.08.2.r1894.gfd91ed35-1
                                krfb21.08.2.r1421.gc820758-121.08.2.r1422.g97cbf48-1
                              kruler21.08.2.r708.gf90ef06-121.08.2.r709.gde32389-1
                             kscreen5.22.5.r1373.g04803df-15.22.5.r1374.g4a5a806-1
                             ksudoku21.08.2.r1062.gbbc39cd-121.08.2.r1064.g39527e7-1
                            ktorrent21.08.2.r2780.g087255f1-121.08.2.r2781.gaab6ebf1-1
                               kwave21.08.2.r3742.gad9cbef2-121.08.2.r3744.gbb6b490f-1
                                kwin5.22.5.r20102.g310684f1a-15.22.5.r20111.gcc5b47ee3-1
                              kwinft5.22.4.r19441.gee2767ffe-15.22.4.r19453.g413dc1681-1
                              kwrite21.08.2.r18402.g5d1f08489-121.08.2.r18404.g7f769010b-1
                          libakonadi21.08.2.r12615.g246c2ee74-121.08.2.r12617.g14039b8f5-1
                            libkgapi21.08.1.r1302.gb8b5313-121.08.2.r1303.gc0cc877-1
                         libquotient     r2124.g7b516cd-1     r2128.gde164d6-1
                     maliit-keyboard    r2126.g70d2cda1-1    r2128.gd842b36a-1
                           maui-clip 2.0.0.r13.g96adae4-1 2.0.0.r17.g7eacb63-1
                             mauikit2.0.2.r57.g8372f8e8-12.0.2.r58.ga4af621a-1
                          messagelib21.08.2.r6236.g17f8c44c-121.08.2.r6243.gb2260569-1
                             neochat    r1903.ge6c594f3-1    r1906.g7bb7b785-1
                    plasma-bigscreen      r409.g86e6990-1      r410.gdd9335f-1
          plasma-browser-integration5.22.5.r1283.g3d6a6e00-15.22.5.r1284.g506c044c-1
                      plasma-desktop5.22.5.r8675.gd0ac6437d-15.22.5.r8679.g85bc11712-1
                       plasma-dialer  21.08.r8.g8cc6788-1 21.08.r10.g0e74d95-1
                    plasma-dialer-mm  21.08.r8.g8cc6788-2 21.08.r10.g0e74d95-1
                    plasma-framework5.87.0.r16031.gb174e5bbf-15.87.0.r16033.g9f69e691c-1
                    plasma-mobile-nm5.22.5.r3107.g5033dbf7-15.22.5.r3108.g4da37afb-1
                           plasma-nm5.22.5.r3107.g5033dbf7-15.22.5.r3108.g4da37afb-1
             plasma-phone-components5.22.5.r1501.g957e5126-15.22.5.r1502.g7df05e09-1
                plasma-systemmonitor5.22.5.r497.gd083499-15.22.5.r498.g1153882-1
              plasma-wayland-session5.22.5.r10708.g776879004-15.22.5.r10713.g38fea41d2-1
                    plasma-workspace5.22.5.r10708.g776879004-15.22.5.r10713.g38fea41d2-1
                             purpose5.87.0.r897.gaa61332-15.87.0.r898.g76b1224-1
                          qmlkonsole  21.08.r6.g8f53d7d-1 21.08.r11.g1c753e0-1
                  qqc2-desktop-style5.87.0.r535.g1b61747-15.87.0.r536.gb018a93-1
                 syntax-highlighting5.87.0.r1710.g0b2c0dc5-15.87.0.r1711.g0cbe697f-1
          telepathy-kde-accounts-kcm21.08.2.r1197.g89dbbff-121.08.2.r1198.gca69974-1
      telepathy-kde-common-internals21.08.2.r1995.g1916354-121.08.2.r1996.g367b372-1
             telepathy-kde-send-file21.08.1.r229.g5c27a83-121.08.2.r229.g5c27a83-1
               telepathy-kde-text-ui21.08.2.r2023.gd729dc6-121.08.2.r2024.ga72376e-1
                               vvave 2.0.0.r56.g2d49b50-1 2.0.0.r59.g974db24-1
                            wrapland5.22.4.r1603.gcbeab520-15.22.4.r1640.g5b12d354-1
Edit: just in case this may help some other newb like yours truly:
To fix the uboot 2021.10 issue, you have to disable the eMMC on the board switch, then insert an SD card with a recent manjaro arm image on it, power up the pinebook pro, and while the u-boot countdown is rolling you flip the eMMC switch back, so it boots from your existing installation.
Then reinstall the uboot-pinebookpro package from pamac (doing so will downgrade it to 2021.07, as of present date) and run the dd commands listed on pamac’s update log.
Hi, couple of questions, hope I’m not being overly off-topic - after updating, I have the same uboot issue on my Pinebook Pro - the led stays orange and it won’t boot.
I’ve disabled the eMMC through the hardware switch but still can’t seem to boot from the SD card (same behavior - with borked SD image or no SD card, pressing the power button does nothing; with a supposedly working SD card (Armbian_21.08.1_Pinebook-pro_hirsute_edge_5.13.12_xfce_desktop.img) the led lights up orange but still won’t boot either).
Did you have to mess around with the SPI to make it boot from SD, or did it work outright after bypassing the eMMC switch?
Assuming I do manage to boot from some other SD card image, is simple to manually restore the previous working uboot without having to nuke my whole existing installation?
Thanks!
For some reason there is no sound output on my Raspberry Pi after last update (I got it today 2021.10.15). IF I remember correctly, it is on testing branch. The DE is XFCE
Will start googling for this issue asap
This is a known issue, see this post.
