Hello ARM community.
Rather small update this time. Enjoy!
Some highlights:
- Most of our kernels got updated
- QT6 got updated to 6.2.0, which should bring most of the qt5 functions to qt6
- A new point release of Mesa brings it to 21.2.3
- Pipewire got a new update to 0.3.38
- Lots of Mobile specific packages got updated
- Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sat Oct 2 22:11:27 CEST 2021)
- arm-testing community aarch64: 262 new and 258 removed package(s)
- arm-testing core aarch64: 11 new and 11 removed package(s)
- arm-testing extra aarch64: 188 new and 177 removed package(s)
- arm-testing kde-unstable aarch64: 263 new and 263 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-09-26 2021-10-02
bluetooth-vim3 1-1 1-2
calls 41.0+30+gfbb6316-1 41.0+31+g4675821-1
chatty 0.4.0+50+gccc4176-2 0.4.0+86+g73e6961-1
eg25-manager 0.4.0+6+g2bf6337-1 0.4.0+22+g5c61d41-2
electron 15.0.0-1 15.1.0-1
electron12 12.2.0-1 12.2.1-1
electron13 13.5.0-1 13.5.1-1
electron14 14.0.1-1 14.1.0-1
hwinfo 21.76-1 21.77-1
khadas-utils 4-1 4-2
libx86emu 3.2-1 3.3-1
phoc 0.8.0+47+g6132485-1 0.8.0+62+g4613b16-1
phosh 0.13.1+16+gc66b31e-3 0.13.1+33+g7621ed0-1
pinephone-manjaro-tweaks 20210928-1 20211002-4
postmarketos-tweaks-app 0.7.3+2+g11eb7c3-2 0.8.0-1
postmarketos-tweaks-app-phosh 0.7.3+2+g11eb7c3-2 0.8.0-1
vivaldi 4.2.2406.48-1 4.2.2406.54-1
vvmd 0.4-1 0.4+6+gea69c38-1
vvmplayer 1.2.1-1 1.2.1+10+gb54f14c-1
waydroid-image 17.1_20210925-1 17.1_20210930-1
waydroid r38.e990576-1 1.1.1+5+g736e9c9-1
umtp-responder - 1.3.10-1
:: Different sync package(s) in repository community aarch64
amule 1:2.3.3-1 1:2.3.3-2
arrow 3.0.0-5 3.0.0-6
aws-cli 1.20.34-1 1.20.49-1
bctoolbox 5.0.26-1 5.0.28-1
blanket 0.4.1-1 0.5.0-1
buildah 1.23.0-1 1.23.1-1
bzrtp 5.0.26-1 5.0.28-1
calibre 5.27.0-1 5.28.0-1
cawbird 1.4.1-1 1.4.2-1
ccache 4.4.1-1 4.4.2-1
chezmoi 2.5.0-1 2.5.1-1
ckermit 9.0.302-7 9.0.302-9
cockpit 253-1 254-1
cockpit-machines 251-1 253-1
cockpit-pcp 253-1 254-1
containers-common 0.46.0-1 0.46.0-2
copyq 4.1.0-1 5.0.0-1
dark-reader 4.9.37.1-1 4.9.39-1
dart 2.14.2-1 2.14.3-1
diffoscope 185-1 186-1
docker-compose 1.29.2-1 2.0.1-1
elinks 0.14.1-1 0.14.3-1
fanficfare 4.5.0-1 4.6.0-1
faudio 21.09-1 21.10-1
fcitx5 5.0.8-1 5.0.9-1
fcitx5-anthy 5.0.5-1 5.0.6-1
fcitx5-chewing 5.0.5-1 5.0.6-1
fcitx5-chinese-addons 5.0.6-2 5.0.7-1
fcitx5-gtk 5.0.7-1 5.0.8-1
fcitx5-hangul 5.0.3-1 5.0.4-1
fcitx5-kkc 5.0.5-1 5.0.6-1
fcitx5-libthai 5.0.4-1 5.0.5-1
fcitx5-qt 5.0.6-1 5.0.7-1
fcitx5-skk 5.0.6-1 5.0.7-1
fcitx5-table-extra 5.0.4-1 5.0.5-1
fcitx5-unikey 5.0.4-1 5.0.5-1
filezilla 3.55.1-2 3.55.1-3
firefox-dark-reader 4.9.37.1-1 4.9.39-1
firefox-ublock-origin 1.37.2-1 1.38.2-1
flint 2.8.0-1 2.8.1-1
gaupol 1.9-1 1.10-1
gdb-dashboard 0.11.4-1 0.14.0-1
git-cliff 0.3.0-1 0.4.0-1
git-lfs 3.0.0-1 3.0.1-1
glewlwyd 2.5.4-1 2.5.4-2
go-ethereum 1.10.8-1 1.10.9-1
goaccess 1.5.1-1 1.5.2-1
goimapnotify 2.3.3-1 2.3.5-1
goreleaser 0.180.0-1 0.180.0-2
gpxsee 9.5-1 9.7-1
grpc 1.39.1-1 1.41.0-1
grpc-cli 1.39.1-1 1.41.0-1
hidapi 0.10.1-1 0.11.0-1
home-assistant 2021.9.6-1 2021.9.7-1
hotdoc 0.13.4-1 0.13.7-1
hunspell-el 0.9-6 0.9-7
hunspell-fr 7.0-1 7.0-2
hunspell-hu 1.7-2 1.7-3
hunspell-it 2.4-9 2.4-10
hunspell-nl 2.20.19-1 2.20.19-2
hunspell-pl 20210731-1 20210731-2
hunspell-ro 3.3.10-5 3.3.10-6
iddawc 1.0.0-2 1.0.1-1
img2pdf 0.4.0-2 0.4.1-1
inotify-tools 3.21.9.5-1 3.21.9.6-1
ipython 7.27.0-1 7.28.0-1
jansson 2.13.1-1 2.14-1
jenkins 2.313-1 2.314-1
jhead 3.04-1 3.06.0.1-1
jmol 14.31.53-1 14.31.55-1
jsmol 14.31.53-1 14.31.55-1
jupyter-notebook 6.4.3-1 6.4.4-1
klayout 0.27.3-1 0.27.4-1
kquickimageeditor 0.1.3-1 0.2.0-1
ktikz 0.13.1-1 0.13.2-1
kustomize 4.2.0-1 4.4.0-1
kvantum-qt5 0.20.1-1 0.20.2-1
kvantum-theme-materia 20210722-1 20210814-1
lego 4.4.0-2 4.5.2-1
libfilezilla 0.32.0-1 0.33.0-1
libime 1.0.7-2 1.0.8-1
libretro-beetle-pce 1087-1 1091-1
libretro-beetle-pce-fast 1139-1 1145-1
libretro-beetle-psx 2558-1 2565-1
libretro-beetle-psx-hw 2558-1 2565-1
libretro-beetle-supergrafx 923-1 927-1
libretro-dolphin 32996-1 32999-1
libretro-gambatte 928-1 930-1
libretro-genesis-plus-gx 1810-1 1841-1
libretro-melonds 1801-1 1976-1
libretro-overlays 204-1 205-1
libretro-play 6698-1 6765-1
libretro-scummvm 93195-1 93197-1
libretro-shaders-slang 835-1 839-1
libretro-snes9x 2018-1 2035-1
libtpms 0.8.7-1 0.9.0-1
lightdm-pantheon-greeter 6.0.0-1 6.0.1-1
lshw B.02.19.2-2 B.02.19.2-3
lua-language-server 2.3.6-1 2.4.1-1
lxd 4.18-1 4.19-1
mame 0.235-1 0.236-1
mame-tools 0.235-1 0.236-1
man-pages-zh_cn 1.6.3.5-1 1.6.3.6-1
man-pages-zh_tw 1.6.3.5-1 1.6.3.6-1
mandoc 1.14.5-4 1.14.6-1
mate-applet-dock 20.04.0-1 21.10.0-1
materia-kde 20210722-1 20210814-1
mediastreamer 5.0.26-1 5.0.28-1
mediawiki 1.36.1-1 1.36.2-1
mediawiki-math 1.36.1-1 1.36.2-1
minio-client 2021.06.13-1 2021.09.23-1
mitmproxy 7.0.3-1 7.0.4-1
moreutils 0.65-2 0.66-1
mumble 1.3.4-8 1.3.4-9
murmur 1.3.4-8 1.3.4-9
nextcloud 22.1.1-1 22.2.0-1
nextcloud-app-calendar 1:2.3.3-1 1:2.3.4-1
nextcloud-client 1:3.3.4-2 1:3.3.5-1
nextcloud-client-cloudproviders 1:3.3.4-2 1:3.3.5-1
nlopt 2.7.0-1 2.7.0-2
nnn 4.2-1 4.3-1
notmuch 0.33.1-1 0.33.2-1
notmuch-mutt 0.33.1-1 0.33.2-1
notmuch-runtime 0.33.1-1 0.33.2-1
notmuch-vim 0.33.1-1 0.33.2-1
octave 6.2.0-1 6.3.0-4
openvswitch 2.15.1-1 2.16.0-1
ortp 5.0.26-1 5.0.28-1
pantheon-applications-menu 2.8.2-1 2.9.0-1
pantheon-calendar 6.0.1-1 6.0.2-1
pantheon-code 6.0.0-1 6.0.1-1
pantheon-files 6.0.2-2 6.0.3-1
pantheon-mail 6.1.1-1 6.2.0-1
pantheon-sideload 6.0.1-1 6.0.2-1
papirus-icon-theme 20210901-1 20211001-1
partclone 0.3.17-2 0.3.18-1
pcsclite 1.9.3-1 1.9.4-1
perl-test-simple 1.302187-1 1.302188-1
php-grpc 1.39.1-1 1.41.0-1
php7-grpc 1.39.1-1 1.41.0-1
podman 3.3.1-1 3.4.0-1
podman-docker 3.3.1-1 3.4.0-1
polymake 4.4-5 4.5-1
profanity 1:0.11.0-1 1:0.11.1-1
profanity-gtk 1:0.11.0-1 1:0.11.1-1
pulumi 3.13.0-1 3.13.2-1
pyright 1.1.171-1 1.1.173-1
python-alembic 1.7.1-1 1.7.3-1
python-anyio 3.3.1-1 3.3.2-1
python-apispec 5.1.0-1 5.1.1-1
python-argon2_cffi 20.1.0-3 21.1.0-1
python-aws-sam-translator 1.38.0-1 1.39.0-1
python-blessed 1.18.1-1 1.19.0-1
python-boto3 1.18.34-1 1.18.49-1
python-botocore 1.21.34-1 1.21.49-1
python-confuse 1.5.0-1 1.6.0-1
python-database-knotinfo 2021.9.1-1 2021.10.1-1
python-distlib 0.3.2-1 0.3.3-1
python-elementpath 2.3.1-1 2.3.2-1
python-faker 8.13.2-1 8.14.0-1
python-furl 2.1.2-1 2.1.3-1
python-google-auth 1.33.1-1 1.34.0-1
python-graphene 3.0.0b7-1 3.0.0b8-1
python-graphviz 0.16-2 0.17-1
python-greenlet 1.1.1-1 1.1.2-1
python-grpcio 1.39.1-1 1.41.0-1
python-identify 2.2.15-1 2.3.0-1
python-jupymake 0.9-10 0.9-11
python-jupyter_core 4.7.1-1 4.8.0-1
python-maxminddb 2.1.0-1 2.2.0-1
python-mediafile 0.8.0-1 0.8.1-1
python-memory-allocator 0.1.0-1 0.1.1-1
python-moto 2.2.7-1 2.2.8-1
python-netcdf4 1.5.6-1 1.5.7-1
python-netcdf4-openmpi 1.5.6-1 1.5.7-1
python-pastel 0.2.0-3 0.2.1-1
python-pyglet 1.5.20-1 1.5.21-1
python-pynest2d 4.8.0-4 4.10.0-1
python-pynitrokey 0.4.4-1 0.4.5-1
python-rapidjson 1.3-1 1.4-1
python-sympy 1.8-1 1.9-1
python-tasklib 2.3.0-1 2.4.0-1
python-testfixtures 6.18.2-1 6.18.3-1
python-testpath 0.4.4-3 0.5.0-1
python-unidecode 1.3.0-1 1.3.2-1
python2-distlib 0.3.2-1 0.3.3-1
qt5ct 1.3-1 1.5-1
qt6ct 0.4-1 0.5-1
qtikz 0.13.1-1 0.13.2-1
r10k 3.11.0-1 3.11.0-2
r2ghidra 5.4.1-1 5.4.1-2
radare2 5.4.0-1 5.4.2-1
renpy 7.4.7-1 7.4.8-1
renpy-demos 7.4.7-1 7.4.8-1
retroarch 1.9.9-1 1.9.10-1
retroarch-assets-glui 1:382-1 1:384-1
retroarch-assets-ozone 1:382-1 1:384-1
retroarch-assets-xmb 1:382-1 1:384-1
rhonabwy 1.0.0-2 1.1.0-1
rssguard 4.0.2-1 4.0.3-1
rssguard-nowebengine 4.0.2-1 4.0.3-1
ruby-nokogiri 1.12.2-1 1.12.5-1
rust-analyzer 20210920-1 20210927-1
scite 5.1.1-1 5.1.4-1
seamonkey 2.53.9-1 2.53.9.1-1
shfmt 3.3.1-1 3.4.0-2
solaar 1.0.6-2 1.0.7-1
step-cli 0.17.4-1 0.17.6-1
sundials 5.7.0-1 5.8.0-1
swi-prolog 8.2.4-1 8.4.0-1
switchboard-plug-applications 6.0.0-1 6.0.1-1
switchboard-plug-keyboard 2.5.0-1 2.5.1-1
switchboard-plug-mouse-touchpad 6.0.0-1 6.1.0-1
switchboard-plug-online-accounts 6.2.0-1 6.2.1-1
tailscale 1.14.4-1 1.14.6-1
terraform 1.0.7-1 1.0.8-1
terragrunt 0.31.10-1 0.32.2-1
thunderbird-dark-reader 4.9.37.1-1 4.9.39-1
timescaledb 2.4.1-1 2.4.2-1
tlp 1.3.1-2 1.4.0-1
tlp-rdw 1.3.1-2 1.4.0-1
tpm2-pkcs11 1.6.0-1 1.7.0-2
tpm2-tools 5.1.1-1 5.2-1
translate-shell 0.9.6.11-2 0.9.6.12-1
ttf-liberation 2.1.4-1 2.1.5-1
ukui-session-manager 3.0.1-1 3.0.4-1
v2ray-domain-list-community 20210927113941-1 20211001023210-1
v2ray-geoip 202109230028-1 202109300030-1
vapoursynth R54-1 R56-1
vim-ale 3.1.0-1 3.1.0-2
weechat 3.2.1-1 3.3-1
wingpanel 3.0.0-2 3.0.1-1
wingpanel-indicator-notifications 6.0.0-1 6.0.1-1
wpscan 1:3.8.18-1 1:3.8.19-1
yarn 1.22.11-1 1.22.14-1
yubikey-touch-detector 1.9.1-1 1.9.3-1
zeromq 4.3.4-1 4.3.4-2
btop - 1.0.12-1
libwslay - 1.1.1-3
ublock-origin - 1.38.2-1
:: Different overlay package(s) in repository core aarch64
linux 5.14.8-1 5.14.9-2
linux-headers 5.14.8-1 5.14.9-2
linux-pinephone 5.14.8-2 5.14.9-3
linux-pinephone-headers 5.14.8-2 5.14.9-3
linux-rpi4-mainline 5.12.17-2 5.14.9-1
linux-rpi4-mainline-headers 5.12.17-2 5.14.9-1
linux-rpi4-rc 5.12.rc8-1 5.15.rc3-1
linux-rpi4-rc-headers 5.12.rc8-1 5.15.rc3-1
:: Different sync package(s) in repository core aarch64
bison 3.7.6-1 3.8.1-1
libssh2 1.9.0-3 1.10.0-1
run-parts 5.4-1 5.5-1
:: Different sync package(s) in repository extra aarch64
alsa-card-profiles 1:0.3.37-1 1:0.3.38-1
archlinux-appstream-data 20210921-1 20210929-1
attica 5.86.0-1 5.86.0-2
chromium 94.0.4606.61-1 94.0.4606.71-1
egl-wayland 1.1.8-1 1:1.1.7-1
freecell-solver 6.2.0-1 6.4.0-1
ghostpcl 9.54.0-3 9.55.0-2
ghostscript 9.54.0-3 9.55.0-2
ghostxps 9.54.0-3 9.55.0-2
gnome-shell 1:40.4-1 1:40.5-1
graphviz 2.49.0-1 2.49.1-1
gst-plugin-pipewire 1:0.3.37-1 1:0.3.38-1
haveged 1.9.14-2 1.9.15-1
hspell 1.4-3 1.4-4
hunspell-de 20161207-6 20161207-7
hunspell-en_au 2020.12.07-3 2020.12.07-4
hunspell-en_ca 2020.12.07-3 2020.12.07-4
hunspell-en_gb 2020.12.07-3 2020.12.07-4
hunspell-en_us 2020.12.07-3 2020.12.07-4
hunspell-es_any 1:2.6-1 1:2.6-2
hunspell-es_ar 1:2.6-1 1:2.6-2
hunspell-es_bo 1:2.6-1 1:2.6-2
hunspell-es_cl 1:2.6-1 1:2.6-2
hunspell-es_co 1:2.6-1 1:2.6-2
hunspell-es_cr 1:2.6-1 1:2.6-2
hunspell-es_cu 1:2.6-1 1:2.6-2
hunspell-es_do 1:2.6-1 1:2.6-2
hunspell-es_ec 1:2.6-1 1:2.6-2
hunspell-es_es 1:2.6-1 1:2.6-2
hunspell-es_gt 1:2.6-1 1:2.6-2
hunspell-es_hn 1:2.6-1 1:2.6-2
hunspell-es_mx 1:2.6-1 1:2.6-2
hunspell-es_ni 1:2.6-1 1:2.6-2
hunspell-es_pa 1:2.6-1 1:2.6-2
hunspell-es_pe 1:2.6-1 1:2.6-2
hunspell-es_pr 1:2.6-1 1:2.6-2
hunspell-es_py 1:2.6-1 1:2.6-2
hunspell-es_sv 1:2.6-1 1:2.6-2
hunspell-es_uy 1:2.6-1 1:2.6-2
hunspell-es_ve 1:2.6-1 1:2.6-2
hunspell-he 1.4-3 1.4-4
hyphen-es 1:2.6-1 1:2.6-2
imlib2 1.7.3-1 1.7.4-1
kio-extras 21.08.1-1 21.08.1-2
libraqm 0.7.2-1 0.7.2-2
libsoup 2.74.0-2 2.74.0-3
libupnp 1.14.8-1 1.14.12-1
libva-mesa-driver 21.2.2-1 21.2.3-1
libzip 1.7.3-2 1.8.0-1
mesa 21.2.2-1 21.2.3-1
mesa-vdpau 21.2.2-1 21.2.3-1
meson 0.59.1-1 0.59.2-1
mutter 40.4-1 40.5-1
mythes-es 1:2.6-1 1:2.6-2
nghttp2 1.44.0-2 1.45.0-1
opencl-mesa 21.2.2-1 21.2.3-1
perl-alien-build 2.41-1 2.42-1
pipewire-alsa 1:0.3.37-1 1:0.3.38-1
pipewire-docs 1:0.3.37-1 1:0.3.38-1
pipewire-jack 1:0.3.37-1 1:0.3.38-1
pipewire-media-session 1:0.3.37-1 1:0.3.38-1
pipewire-pulse 1:0.3.37-1 1:0.3.38-1
pipewire-zeroconf 1:0.3.37-1 1:0.3.38-1
postgresql 13.3-3 13.4-1
postgresql-docs 13.3-3 13.4-1
postgresql-libs 13.3-3 13.4-1
prometheus 2.30.0-1 2.30.2-1
pyside6 6.1.3-1 6.2.0-2
qt5-base 5.15.2+kde+r227-1 5.15.2+kde+r228-1
qt5-wayland 5.15.2+kde+r31-1 5.15.2+kde+r33-1
qt5-xcb-private-headers 5.15.2+kde+r227-1 5.15.2+kde+r228-1
qt6-3d 6.1.3-1 6.2.0-1
qt6-5compat 6.1.3-1 6.2.0-1
qt6-base 6.1.3-1 6.2.0-1
qt6-charts 6.1.3-1 6.2.0-1
qt6-datavis3d 6.1.3-1 6.2.0-1
qt6-declarative 6.1.3-1 6.2.0-1
qt6-doc 6.1.3-1 6.2.0-1
qt6-examples 6.1.3-1 6.2.0-1
qt6-imageformats 6.1.3-1 6.2.0-1
qt6-lottie 6.1.3-1 6.2.0-1
qt6-networkauth 6.1.3-1 6.2.0-1
qt6-quick3d 6.1.3-1 6.2.0-1
qt6-quickcontrols2 6.1.3-1 -
qt6-quicktimeline 6.1.3-1 6.2.0-1
qt6-scxml 6.1.3-1 6.2.0-1
qt6-shadertools 6.1.3-1 6.2.0-1
qt6-svg 6.1.3-1 6.2.0-1
qt6-tools 6.1.3-1 6.2.0-1
qt6-translations 6.1.3-1 6.2.0-1
qt6-virtualkeyboard 6.1.3-1 6.2.0-2
qt6-wayland 6.1.3-1 6.2.0-1
qtcreator 5.0.1-1 5.0.2-1
rygel 1:0.40.1-1 1:0.40.2-1
sdl2 2.0.16-2 2.0.16-3
shaderc 2021.1-2 2021.2-1
shiboken6 6.1.3-1 6.2.0-1
spirv-tools 2021.1-1 2021.3-1
stellarium 0.21.1-2 0.21.2-1
thunderbird 91.1.1-1 91.1.2-1
thunderbird-i18n-af 91.1.1-1 91.1.2-1
thunderbird-i18n-ar 91.1.1-1 91.1.2-1
thunderbird-i18n-ast 91.1.1-1 91.1.2-1
thunderbird-i18n-be 91.1.1-1 91.1.2-1
thunderbird-i18n-bg 91.1.1-1 91.1.2-1
thunderbird-i18n-br 91.1.1-1 91.1.2-1
thunderbird-i18n-ca 91.1.1-1 91.1.2-1
thunderbird-i18n-cak 91.1.1-1 91.1.2-1
thunderbird-i18n-cs 91.1.1-1 91.1.2-1
thunderbird-i18n-cy 91.1.1-1 91.1.2-1
thunderbird-i18n-da 91.1.1-1 91.1.2-1
thunderbird-i18n-de 91.1.1-1 91.1.2-1
thunderbird-i18n-dsb 91.1.1-1 91.1.2-1
thunderbird-i18n-el 91.1.1-1 91.1.2-1
thunderbird-i18n-en-gb 91.1.1-1 91.1.2-1
thunderbird-i18n-en-us 91.1.1-1 91.1.2-1
thunderbird-i18n-es-ar 91.1.1-1 91.1.2-1
thunderbird-i18n-es-es 91.1.1-1 91.1.2-1
thunderbird-i18n-et 91.1.1-1 91.1.2-1
thunderbird-i18n-eu 91.1.1-1 91.1.2-1
thunderbird-i18n-fi 91.1.1-1 91.1.2-1
thunderbird-i18n-fr 91.1.1-1 91.1.2-1
thunderbird-i18n-fy-nl 91.1.1-1 91.1.2-1
thunderbird-i18n-ga-ie 91.1.1-1 91.1.2-1
thunderbird-i18n-gd 91.1.1-1 91.1.2-1
thunderbird-i18n-gl 91.1.1-1 91.1.2-1
thunderbird-i18n-he 91.1.1-1 91.1.2-1
thunderbird-i18n-hr 91.1.1-1 91.1.2-1
thunderbird-i18n-hsb 91.1.1-1 91.1.2-1
thunderbird-i18n-hu 91.1.1-1 91.1.2-1
thunderbird-i18n-hy-am 91.1.1-1 91.1.2-1
thunderbird-i18n-id 91.1.1-1 91.1.2-1
thunderbird-i18n-is 91.1.1-1 91.1.2-1
thunderbird-i18n-it 91.1.1-1 91.1.2-1
thunderbird-i18n-ja 91.1.1-1 91.1.2-1
thunderbird-i18n-ka 91.1.1-1 91.1.2-1
thunderbird-i18n-kab 91.1.1-1 91.1.2-1
thunderbird-i18n-kk 91.1.1-1 91.1.2-1
thunderbird-i18n-ko 91.1.1-1 91.1.2-1
thunderbird-i18n-lt 91.1.1-1 91.1.2-1
thunderbird-i18n-ms 91.1.1-1 91.1.2-1
thunderbird-i18n-nb-no 91.1.1-1 91.1.2-1
thunderbird-i18n-nl 91.1.1-1 91.1.2-1
thunderbird-i18n-nn-no 91.1.1-1 91.1.2-1
thunderbird-i18n-pa-in 91.1.1-1 91.1.2-1
thunderbird-i18n-pl 91.1.1-1 91.1.2-1
thunderbird-i18n-pt-br 91.1.1-1 91.1.2-1
thunderbird-i18n-pt-pt 91.1.1-1 91.1.2-1
thunderbird-i18n-rm 91.1.1-1 91.1.2-1
thunderbird-i18n-ro 91.1.1-1 91.1.2-1
thunderbird-i18n-ru 91.1.1-1 91.1.2-1
thunderbird-i18n-sk 91.1.1-1 91.1.2-1
thunderbird-i18n-sl 91.1.1-1 91.1.2-1
thunderbird-i18n-sq 91.1.1-1 91.1.2-1
thunderbird-i18n-sr 91.1.1-1 91.1.2-1
thunderbird-i18n-sv-se 91.1.1-1 91.1.2-1
thunderbird-i18n-th 91.1.1-1 91.1.2-1
thunderbird-i18n-tr 91.1.1-1 91.1.2-1
thunderbird-i18n-uk 91.1.1-1 91.1.2-1
thunderbird-i18n-uz 91.1.1-1 91.1.2-1
thunderbird-i18n-vi 91.1.1-1 91.1.2-1
thunderbird-i18n-zh-cn 91.1.1-1 91.1.2-1
thunderbird-i18n-zh-tw 91.1.1-1 91.1.2-1
tomcat10 10.0.11-1 10.0.12-1
tomcat9 9.0.53-1 9.0.54-1
udisks2 2.9.3-1 2.9.4-1
vulkan-broadcom 21.2.2-1 21.2.3-1
vulkan-headers 1:1.2.191-1 1:1.2.194-1
vulkan-icd-loader 1.2.191-1 1.2.194-1
vulkan-mesa-layers 21.2.2-1 21.2.3-1
vulkan-panfrost 21.2.2-1 21.2.3-1
vulkan-radeon 21.2.2-1 21.2.3-1
vulkan-swrast 21.2.2-1 21.2.3-1
vulkan-tools 1.2.190-1 1.2.194-1
vulkan-validation-layers 1.2.190-1 1.2.194-1
xfce4-cpugraph-plugin 1.2.3-1 1.2.4-1
libdecor - 0.1.0-3
qt6-connectivity - 6.2.0-1
qt6-location - 6.2.0-1
qt6-multimedia - 6.2.0-1
qt6-remoteobjects - 6.2.0-1
qt6-sensors - 6.2.0-1
qt6-serialbus - 6.2.0-1
qt6-serialport - 6.2.0-1
qt6-webchannel - 6.2.0-1
qt6-webengine - 6.2.0-1
qt6-websockets - 6.2.0-1
qt6-webview - 6.2.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.08.1.r12604.gd7d907e67-121.08.1.r12605.g0f35c31d1-1
akonadi-mime21.08.1.r1654.gd440a08-121.08.1.r1657.gafeaa4f-1
akregator21.08.1.r6228.gfbf4fabc-121.08.1.r6232.gc9548b0e-1
alligator 21.08.r2.g7c0b49e-1 21.08.r3.g57c21ce-1
angelfish 21.08.r20.g1ebd161-1 21.08.r32.g54a3278-1
ark21.08.1.r4614.gc0a94112-121.08.1.r4616.g37fe1d86-1
artikulate21.08.1.r1390.g78f1bbb-121.08.1.r1391.gb7db159-1
attica5.86.0.r836.g04bd6dc-15.86.0.r838.gcea26ce-1
baloo5.86.0.r3008.g8909640a-15.86.0.r3009.gfbde0825-1
blinken21.08.1.r635.g1b32fef-121.08.1.r636.g658c602-1
bluedevil1:5.22.5.r2288.g33fe33f0-11:5.22.5.r2289.g747a7523-1
bluez-qt5.86.0.r679.gba3af75-15.86.0.r680.ge03e846-1
bomber21.08.1.r527.gfff4ec7-121.08.1.r528.gd8a5366-1
bovo21.08.1.r736.g1bf6fc5-121.08.1.r737.g9870611-1
breeze5.22.5.r2276.g59605fd9-15.22.5.r2278.g244fdf47-1
breeze-icons5.86.0.r1792.g264bb9a5-15.86.0.r1797.g3546be1c-1
buho 2.0.0.r7.g185655a-1 2.0.0.r8.gcf17a8c-1
calendarsupport21.08.1.r40.gc588b5f-121.08.1.r41.g209ac95-1
discover5.22.5.r8336.g11e72936-15.22.5.r8341.gc0e9cb93-1
dolphin21.08.1.r6709.gd3f427a6d-121.08.1.r6713.g0c44dfe2b-1
elisa21.08.1.r2777.g92b5ca8c-121.08.1.r2779.g72d00c48-1
eventviews21.08.1.r49.g623caea-121.08.1.r53.g5d49101-1
extra-cmake-modules5.86.0.r3370.g3df459c-15.86.0.r3373.g63bec55-1
ffmpegthumbs21.08.1.r194.g2e06153-121.08.1.r195.ge5a6c80-1
filelight21.08.1.r985.g32be16a-121.08.1.r987.ge4ed3d0-1
frameworkintegration5.86.0.r598.g0a57fd9-15.86.0.r599.gf03f0cc-1
granatier21.08.1.r932.g186d30f-121.08.1.r933.g39afb2b-1
incidenceeditor21.08.1.r774.ga820ee5-121.08.1.r775.geebaeee-1
index-fm 2.0.0.r24.gb4f358a-1 2.0.0.r28.ga1f6fd4-1
itinerary21.08.1.r1460.g21893b1-121.08.1.r1469.gba37b5e-1
kaccounts-integration21.08.1.r1224.gea8f0d8-121.08.1.r1227.gef9f8f3-1
kactivities5.86.0.r1363.g207c2dc-15.86.0.r1364.g055e28e-1
kactivities-stats5.86.0.r372.g195fbd2-15.86.0.r373.g12e6329-1
kajongg21.08.1.r4197.g6455a6ad-121.08.1.r4198.g03581a33-1
kalarm21.08.1.r6466.g82369401-121.08.1.r6467.gaf6d8076-1
kalzium21.08.1.r4269.g501f78a1-121.08.1.r4270.ged71402a-1
kamera21.08.1.r666.g28de32a-121.08.1.r667.gecb976b-1
kapidox5.86.0.r553.g8ac0bf3-15.86.0.r554.gfd15a04-1
kapman21.08.1.r608.gdcad1c6-121.08.1.r609.g95e2b09-1
karchive5.86.0.r507.g858a749-15.86.0.r508.gc98027a-1
kasts 21.08.r29.g06e8d8d-1 21.08.r36.ge4ee0f1-1
kate21.08.1.r18372.gba4d4ccc0-121.08.1.r18376.ga0079d4d0-1
katomic21.08.1.r921.g482ba5a-121.08.1.r922.g9edd30f-1
kauth5.86.0.r449.ga6a0c5a-15.86.0.r450.ge97374f-1
kblackbox21.08.1.r728.g90fc514-121.08.1.r730.gf7ee576-1
kblocks21.08.1.r673.g59a2487-121.08.1.r674.gabafa86-1
kbookmarks5.86.0.r422.g7d0378a-15.86.0.r423.g2faa427-1
kbounce21.08.1.r809.gc062586-121.08.1.r810.g5f4d15f-1
kbreakout21.08.1.r867.ge54c382-121.08.1.r868.gbd2d0b8-1
kbruch21.08.1.r818.g8f9399b-121.08.1.r820.gc65da2b-1
kcalc21.08.1.r1537.gee7a3ab-121.08.1.r1539.g9b7ab9d-1
kcalendarcore5.86.0.r1241.gbd6b9749f-15.86.0.r1242.gd63c5be27-1
kcalutils21.08.1.r887.gdb9db0bdb-121.08.1.r888.gdfd6586bb-1
kcharselect21.08.1.r477.g2b0ce35-121.08.1.r478.gaf274dc-1
kclock 21.08.r8.g48d1d79-1 21.08.r9.g41f6e3b-1
kcmutils5.86.0.r550.g1e9c4fe-15.86.0.r551.ge83d6bd-1
kcodecs5.86.0.r388.gbf88853-15.86.0.r389.gc7c3258-1
kcolorchooser21.08.1.r231.gac2e3ae-121.08.1.r232.g9ea71fc-1
kcompletion5.86.0.r459.g764f6bd-15.86.0.r460.g609fbac-1
kconfig5.86.0.r866.g5617e6d-15.86.0.r869.g1e42d79-1
kconfigwidgets5.86.0.r621.g652be62-15.86.0.r622.ge121348-1
kcontacts1:5.86.0.r3254.g7ff774b3-11:5.86.0.r3255.g3515c746-1
kcoreaddons5.86.0.r1298.g61ce6c7b-15.86.0.r1299.g9b0faeba-1
kcrash5.86.0.r409.gf0a9e01-15.86.0.r410.gf2a66dc-1
kcron21.08.1.r780.g884a2d1-121.08.1.r783.g2a06e09-1
kdav1:5.86.0.r1301.g4e4571a-11:5.86.0.r1302.gc871e9f-1
kdbusaddons5.86.0.r381.gd645ec3-15.86.0.r382.gd80c80a-1
kde-cli-tools5.22.5.r1865.g75e9d72-15.22.5.r1866.gd4aedfe-1
kdeclarative5.86.0.r925.gfc38a94-15.86.0.r926.g76a8be0-1
kded5.86.0.r419.g6731b81-15.86.0.r420.gd605eef-1
kdelibs4support5.86.0.r1037.g34b4edc2-15.86.0.r1038.g756e5326-1
kdenlive21.08.1.r14973.g293f0edd6-121.08.1.r15042.g8953bd569-1
kdepim-addons21.08.1.r4345.g1b86d024-121.08.1.r4347.ge67aba19-1
kdepim-runtime21.08.1.r15314.g7643c5915-121.08.1.r15322.g99a309316-1
kdesignerplugin5.86.0.r336.g9733059-15.86.0.r337.g3a2a5c3-1
kdesu5.86.0.r476.ge88b633-15.86.0.r477.gfee2530-1
kdewebkit5.86.0.r283.g787f1a3-15.86.0.r284.gbafbfc7-1
kdf21.08.1.r804.g608d3f6-121.08.1.r805.gce25940-1
kdialog21.08.1.r1189.g7df2eaaf7-121.08.1.r1190.g788c0a912-1
kdiamond21.08.1.r672.gf4459d8-121.08.1.r673.g2d5c609-1
kdnssd5.86.0.r326.g695a135-15.86.0.r327.g99e2a79-1
kdoctools5.86.0.r629.gfbd4377-15.86.0.r630.gf1c6874-1
keditbookmarks21.08.1.r2748.gb8b636c66-121.08.1.r2749.g30e3c4628-1
kemoticons5.86.0.r387.g1c526eb-15.86.0.r388.ga50269e-1
kfilemetadata5.86.0.r809.gec8cde7-15.86.0.r810.g5528059-1
kfind21.08.1.r2645.g52d84144f-121.08.1.r2646.g8dbab6b80-1
kfloppy21.08.1.r759.gc62b879-121.08.1.r760.gd899571-1
kfourinline21.08.1.r985.g9723882-121.08.1.r986.g2d9b3aa-1
kgamma55.22.5.r459.g57abda6-15.22.5.r460.geccd6bd-1
kget21.08.1.r3123.g6c7c70c1-121.08.1.r3124.g5a432300-1
kglobalaccel5.86.0.r469.ge928938-15.86.0.r472.gcabd26a-1
kgoldrunner21.08.1.r1242.g2de3f71-121.08.1.r1243.g3fe3425-1
kgpg21.08.1.r3133.ge606950b-121.08.1.r3136.gc56a46a2-1
kguiaddons5.86.0.r392.g22c428e-15.86.0.r395.g37ef8c4-1
khangman21.08.1.r1566.g58a1700-121.08.1.r1567.g8830264-1
khealthcertificate r81.8c5253b-1 r85.98d610a-1
khelpcenter21.08.1.r2679.gaa802c99-121.08.1.r2682.g34d7a1c6-1
kholidays1:5.86.0.r961.gb1500cd-11:5.86.0.r962.g14db7cf-1
khtml5.86.0.r558.g5756c1e-15.86.0.r559.g6c48d2d-1
ki18n5.86.0.r480.g8a8d70c-15.86.0.r481.g66f9797-1
kiconthemes5.86.0.r544.gf721a67-15.86.0.r545.g6afc1b8-1
kidentitymanagement21.08.1.r3825.g321702d3-121.08.1.r3829.gcc9d4b98-1
kidletime5.86.0.r318.geb71712-15.86.0.r319.gc5e5c3f-1
kigo21.08.1.r526.g7a92072-121.08.1.r527.gda9a0f0-1
killbots21.08.1.r740.g8a2b782-121.08.1.r741.gcdb9ef4-1
kimageformats5.86.0.r360.g6458c9a-15.86.0.r361.g2f9e09f-1
kimap21.08.1.r1118.g066cc22-121.08.1.r1130.g2304e67-1
kinfocenter5.22.5.r1934.g874d5d2-15.22.5.r1939.g09b3d5e-1
kinit5.86.0.r414.g11a0ffc-15.86.0.r415.g1f6827f-1
kio5.86.0.r5003.g402abea0-15.86.0.r5006.g594ea929-1
kio-extras21.08.1.r7125.g98855307-121.08.1.r7130.g2fa7899d-1
kirigami-gallery21.08.1.r215.gb1b8234-121.08.1.r216.g71886e0-1
kirigami25.86.0.r2907.g2a3a3889-15.86.0.r2910.ge2819a96-1
kiriki21.08.1.r421.g9ab6806-121.08.1.r422.g945af37-1
kitemviews5.86.0.r342.g30e9515-15.86.0.r343.gd29beff-1
kiten21.08.1.r1148.g3eeccd9-121.08.1.r1149.g97a5741-1
kitinerary21.08.1.r1961.g81b7c2a-121.08.1.r1962.g5a69849-1
kjs5.86.0.r337.g2cf609d-15.86.0.r338.g86af51a-1
kjsembed5.86.0.r306.gaaf5dd2-15.86.0.r307.g41872ea-1
kjumpingcube21.08.1.r789.g53fde8d-121.08.1.r790.g6e644d3-1
kleopatra21.08.1.r6001.g777c179b-121.08.1.r6002.g6df7e800-1
klettres21.08.1.r916.gd84f133-121.08.1.r922.g1a65565-1
klickety21.08.1.r638.g30e0336-121.08.1.r639.geeea4c9-1
klines21.08.1.r771.gb28676e-121.08.1.r772.gdf4e50c-1
kmag21.08.1.r695.gfa4d7f1-121.08.1.r696.g8d16514-1
kmahjongg21.08.1.r1471.g4608d0e-121.08.1.r1473.g8b3e491-1
kmail21.08.1.r25983.g0e0da7785-121.08.1.r25989.g2ddcb9298-1
kmail-account-wizard21.08.1.r824.g30e4c9a-121.08.1.r825.g121a4ae-1
kmailtransport21.08.1.r1666.gf4dda58-121.08.1.r1668.g375f51d-1
kmbox21.08.1.r545.g316e720-121.08.1.r547.g11eca5f-1
kmediaplayer5.86.0.r297.g7315fa5-15.86.0.r298.g5caa888-1
kmenuedit5.22.5.r973.g7dd69ed-15.22.5.r974.gc97ffdd-1
kmines21.08.1.r1724.g7fa5e75-121.08.1.r1725.gcb261ac-1
kmousetool21.08.1.r399.ga0ccf22-121.08.1.r400.g78f1c5f-1
kmouth21.08.1.r695.g19aeff2-121.08.1.r696.g8ca1477-1
knavalbattle21.08.1.r1392.g34e09c4-121.08.1.r1394.gede3048-1
knetwalk21.08.1.r660.g83c5aa5-121.08.1.r661.g15e7676-1
knewstuff5.86.0.r1219.g44b5113d-15.86.0.r1223.gde50a5a0-1
knights21.08.1.r1051.g6cfa479-121.08.1.r1052.g616f289-1
knotes21.08.1.r3522.g8b0d1ff7-121.08.1.r3523.gbb94f2a4-1
knotifications5.86.0.r682.gf0ce72d-15.86.0.r683.g4125c87-1
knotifyconfig5.86.0.r355.gee646b9-15.86.0.r356.gda5baef-1
kolf21.08.1.r1444.g7dc7698-121.08.1.r1445.g19201f8-1
kollision21.08.1.r494.g05b9c34-121.08.1.r495.g32aeb50-1
kongress 21.08.r2.gbd051df-1 21.08.r3.g9607077-1
konqueror21.08.1.r14955.g1414698ee-121.08.1.r14973.gb9b155ad6-1
konquest21.08.1.r898.g3ad1f6d-121.08.1.r899.g0e15def-1
konsole21.08.1.r7960.g8489c8e1-121.08.1.r7964.gce18a9c8-1
konversation21.08.1.r8996.g178389ed-121.08.1.r8997.g26af4e87-1
kopeninghours21.08.1.r271.gb3177a0-121.08.1.r272.gb8b07a8-1
kopete21.08.1.r16399.gec24d08f0-121.08.1.r16400.gd7c8d986d-1
korganizer21.08.1.r11511.g815cfcee2-121.08.1.r11513.gbe5eeebde-1
kosmindoormap21.08.1.r657.g56c4904-121.08.1.r659.g5db3431-1
kpackage5.86.0.r699.g3e01da3-15.86.0.r700.gf6fdfcf-1
kparts5.86.0.r528.gfa6ae49-15.86.0.r529.ge1f3201-1
kpat21.08.1.r2565.gd715b7a-121.08.1.r2566.gbcdf1b4-1
kpeople5.86.0.r1346.g96ddb92-15.86.0.r1347.g6407f6f-1
kpeoplevcard 0.1.r15.g0d12452-1 0.1.r16.ge0e3028-1
kpimtextedit21.08.1.r1453.ge4d8ae4-121.08.1.r1454.ge2d3186-1
kplotting5.86.0.r296.g3060059-15.86.0.r297.gf1188f4-1
kpmcore21.08.1.r1199.g2734c58-121.08.1.r1200.g6f2be13-1
kpty5.86.0.r343.g75750f0-15.86.0.r344.ga82cd5c-1
kpublictransport21.08.1.r1843.g89b48a76-121.08.1.r1844.gb2f4ffd3-1
kquickcharts5.86.0.r480.g627c40f-15.86.0.r481.g37bc6bb-1
kquickimageeditor r60.g6107676-1 r61.gbd11196-1
krdc21.08.1.r1540.g8610267-121.08.1.r1541.g0f3509b-1
krecorder 21.08.r4.g93865a4-1 21.08.r5.g1a6ec64-1
kreversi21.08.1.r1227.g7a8fb0c-121.08.1.r1228.g9894b17-1
krfb21.08.1.r1416.gf72674d-121.08.1.r1417.gfb909ea-1
kross5.86.0.r337.g7db053c-15.86.0.r338.g5215ada-1
kruler21.08.1.r702.g97633ef-121.08.1.r706.ge1ac753-1
krunner5.86.0.r675.gf178b55-15.86.0.r684.gb8457fc-1
kservice5.86.0.r947.g362951e-15.86.0.r948.g0605955-1
kshisen21.08.1.r1203.ge0961d9-121.08.1.r1204.geef16c7-1
ksirk21.08.1.r965.g9a4fe5d-121.08.1.r966.g1233e6c-1
ksmtp21.08.1.r383.g691b693-121.08.1.r391.g678d702-1
ksnakeduel21.08.1.r810.ga84f637-121.08.1.r811.g8b648b2-1
kspaceduel21.08.1.r635.geb4e797-121.08.1.r637.g7aa404e-1
ksquares21.08.1.r518.g3c1a44e-121.08.1.r519.gd9b9090-1
ksudoku21.08.1.r1056.g6a7a8b0-121.08.1.r1057.g5262ac8-1
ksysguard5.22.5.r3511.ga571c444-15.22.5.r3513.g1e92e723-1
ksystemlog21.08.1.r661.g60929a8-121.08.1.r662.g7e1468d-1
ksystemstats5.22.5.r197.gc5aba84-15.22.5.r199.gf555323-1
ktexteditor5.86.0.r2944.g30f6cf19-15.86.0.r2946.g855fb066-1
ktextwidgets5.86.0.r415.ge76a94f-15.86.0.r416.ga677b68-1
ktimer21.08.1.r471.g3c7d517-121.08.1.r472.gb5f92d1-1
ktnef21.08.1.r669.g7ab3a4e-121.08.1.r670.gcf2dac4-1
ktouch21.08.1.r2143.g5d3d6cd-121.08.1.r2145.gf55dbf4-1
kubrick21.08.1.r371.gfa18f41-121.08.1.r372.gd8360ca-1
kunitconversion5.86.0.r378.g6e34b50-15.86.0.r379.g82c3867-1
kwallet5.86.0.r1091.gf379e5f-15.86.0.r1092.g09cf911-1
kwalletmanager21.08.1.r1212.gbdf10cf-121.08.1.r1213.gd12f13a-1
kwayland5.86.0.r1114.gc662581-15.86.0.r1115.g0760f77-1
kwayland-server5.22.5.r1393.g67e629a-15.22.5.r1394.gca07c76-1
kwidgetsaddons5.86.0.r878.g76ecd700-15.86.0.r879.gf9b0de3a-1
kwin5.22.5.r20056.gef06b8ed9-15.22.5.r20077.g8c908c69b-1
kwindowsystem5.86.0.r628.g5d08848-15.86.0.r629.g32a2021-1
kwrite21.08.1.r18372.gba4d4ccc0-121.08.1.r18376.ga0079d4d0-1
kxmlgui5.86.0.r809.g0f2608f3-15.86.0.r811.gbb118bd9-1
kxmlrpcclient5.86.0.r458.ga1ec55b43-15.86.0.r459.g714b1e73f-1
libakonadi21.08.1.r12604.gd7d907e67-121.08.1.r12605.g0f35c31d1-1
libkcddb21.08.1.r739.ge4cae29-121.08.1.r740.g3a8472e-1
libkdegames21.08.1.r2188.g14d1d4d0-121.08.1.r2189.ga048f7d8-1
libkdepim21.08.1.r854.g094931a-121.08.1.r855.g977acb7-1
libkeduvocdocument21.08.1.r1791.g4966f86-121.08.1.r1793.g3f907e0-1
libkgapi21.08.1.r1299.g424b7c6-121.08.1.r1302.gb8b5313-1
libkleo21.08.1.r954.gd86eda3-121.08.1.r955.g991d6b9-1
libkmahjongg21.08.1.r457.g7e5db07-121.08.1.r458.g8ace4be-1
libksane21.08.1.r562.g6db0765-121.08.1.r563.g559a8e7-1
libksieve21.08.1.r1597.g8e8a9b1f-121.08.1.r1598.gcaadde17-1
libquotient r2106.gf7e15e7-1 r2108.g92024f2-1
lskat21.08.1.r814.g016a650-121.08.1.r815.gf3b9b56-1
markdownpart21.08.1.r83.g8f25b96-121.08.1.r84.gf86b5b1-1
maui-clip 2.0.0.r9.gf3cb75f-1 2.0.0.r10.gf53a40f-1
maui-nota 2.0.0.r8.gbfe9d04-1 2.0.0.r10.gda9c6d5-1
maui-pix 2.0.0.r11.g8d11039-1 2.0.0.r13.gfe41a0d-1
mauikit2.0.2.r11.gc4531477-12.0.2.r17.g82f76780-1
mauikit-filebrowsing 2.0.2.r6.g9434330-1 2.0.2.r9.ga5e630d-1
mauikit-imagetools 2.0.1.r2.g3910642-1 2.0.1.r3.g195a229-1
mauikit-texteditor 2.0.1.r3.g13b6a5b-1 2.0.1.r4.ge073d99-1
messagelib21.08.1.r6199.g2730222f-121.08.1.r6208.g45143c00-1
modemmanager-qt5.86.0.r523.gc4fd1f1-15.86.0.r524.g76245e8-1
neochat r1876.g71d01593-1 r1877.g886ee1f5-1
networkmanager-qt5.86.0.r1121.g95baae9-15.86.0.r1122.g2daa96c-1
okular21.08.1.r9486.gb22bba31f-121.08.1.r9493.g8b3dfcb3f-1
palapeli21.08.1.r1235.g3294210-121.08.1.r1236.g8cb26c8-1
parley21.08.1.r4456.g10cf6ea4-121.08.1.r4463.g5dd6616d-1
partitionmanager21.08.1.r1531.g90b0aa2-121.08.1.r1532.g4fbf432-1
picmi21.08.1.r527.g99639fb-121.08.1.r528.ge5c5cfb-1
pim-data-exporter21.08.1.r2457.g6ca2e55f-121.08.1.r2460.g9dd40fc3-1
pimcommon21.07.80.r1115.g10e79a0-121.07.80.r1117.gd1a20b6-1
plasma-browser-integration5.22.5.r1281.g50950913-15.22.5.r1282.gd9cfc2d8-1
plasma-desktop5.22.5.r8637.gb4895ef0e-15.22.5.r8644.gdd5db629e-1
plasma-framework5.86.0.r15989.gef9e3f25f-15.86.0.r15991.ga30874488-1
plasma-nano5.21.5.r160.ga0f98ca-15.22.5.r160.ga0f98ca-1
plasma-phone-components5.22.5.r1475.gfa9b0c97-15.22.5.r1480.gf599a689-1
plasma-sdk5.22.5.r2280.g2e8f59ef-15.22.5.r2281.g6f96cc78-1
plasma-settings 21.08.r19.g1b5e8d5-1 21.08.r20.g57a5971-1
plasma-systemmonitor5.22.5.r486.g2c298d8-15.22.5.r487.g7eef12c-1
plasma-wayland-session5.22.5.r10671.gb6a5217c5-15.22.5.r10688.ge6cab5d96-1
plasma-workspace5.22.5.r10671.gb6a5217c5-15.22.5.r10688.ge6cab5d96-1
plasma-workspace-wallpapers5.22.5.r294.gc329bc2-15.22.5.r295.g33f33bd-1
powerdevil5.22.5.r2480.g52f44e41-15.22.5.r2481.g3a7ce4c3-1
print-manager21.08.1.r1046.g37c9d66-121.08.1.r1047.g28c3484-1
prison5.86.0.r333.g9105c2d-15.86.0.r335.gdc2d70d-1
pulseaudio-qt 1.3.0.r1.gb035878-1 1.3.0.r2.g4ae69e6-1
purpose5.86.0.r890.gcbbbd37-15.86.0.r892.g632d5f6-1
qqc2-desktop-style5.86.0.r525.gd726db4-15.86.0.r528.gb11703c-1
sddm-kcm5.22.5.r609.g7066534-15.22.5.r610.gc285d4c-1
solid5.86.0.r708.g66059b9-15.86.0.r709.gd99c1da-1
sonnet5.86.0.r634.gff5ae47-15.86.0.r635.g82b3dcb-1
spectacle21.08.1.r1175.g8db2717-121.08.1.r1176.g66073db-1
svgpart21.08.1.r183.gc7f46a9-121.08.1.r184.g04ea6ce-1
sweeper21.08.1.r532.gc610982-121.08.1.r535.g44ca1d4-1
syndication5.86.0.r841.gec613d1-15.86.0.r842.gf59386b-1
syntax-highlighting5.86.0.r1697.gedf0f349-15.86.0.r1698.g8d9f042d-1
systemsettings5.22.5.r2511.g30a9c4c0-15.22.5.r2515.g107b67e9-1
threadweaver5.86.0.r512.gd9c6fbc-15.86.0.r513.ga51d9f1-1
tokodon 21.08.r4.g70103f5-1 21.08.r5.g3f882da-1
vakzination r97.66a1534-1 r100.6fd20e0-1
vvave 2.0.0.r22.g61b6756-1 2.0.0.r26.g439701a-1
xdg-desktop-portal-kde5.22.5.r386.g8e21923-15.22.5.r389.g4e485d8-1
yakuake21.08.1.r734.g916fb92-121.08.1.r735.g2d43e7e-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
