[ARM Testing Update] 2021-09-26 - Calls, MMS-tng, Chatty, Pipewire, Firefox, KDE-git
Hello ARM community.
Rather another small update this time. Enjoy!
Waydroid gains popularity …
Some highlights:
  • A couple of kernels got updated
  • Chatty and mmsd-tng gained support to detect MMS provider information
  • Calls got updated to 41.0
  • Pipewire is now at 0.3.37
  • Firefox got renewed to 92.0.1
  • regular upstream updates and KDE-git packages
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Enable the service with sudo systemctl enable waydroid-container.
  • Run pkexec setup-waydroid as root user
  • Reboot.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sun Sep 26 09:33:07 CEST 2021)
  • arm-testing community aarch64: 154 new and 152 removed package(s)
  • arm-testing core aarch64: 14 new and 13 removed package(s)
  • arm-testing extra aarch64: 182 new and 178 removed package(s)
  • arm-testing kde-unstable aarch64: 134 new and 134 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE           2021-09-22           2021-09-26
                           bitwarden             1.28.2-4             1.28.3-1
                               calls               41rc-1   41.0+21+g9d27d5b-1
                              chatty  0.4.0+47+g0fbe816-2  0.4.0+50+gccc4176-1
                                code             1.60.1-1             1.60.2-1
                     element-desktop              1.8.4-1              1.8.5-2
                         element-web              1.8.4-1              1.8.5-2
               gnome-software-mobile             41.0-1.2             41.0-1.3
                            kodi-rpi              19.1-10              19.1-11
                        kodi-rpi-dev              19.1-10              19.1-11
               kodi-rpi-eventclients              19.1-10              19.1-11
        kodi-rpi-tools-texturepacker              19.1-10              19.1-11
                          libgbinder             1.1.11-1             1.1.12-1
                    matcha-gtk-theme           20210802-1           20210924-1
                          megapixels              1.3.0-1              1.3.0-2
                            mmsd-tng     1.2+2+g275a76c-1     1.2+5+g2cbc935-1
                                phoc  0.8.0+25+g228d123-1  0.8.0+47+g6132485-1
                               phosh  0.13.1+4+ga60fa3f-1 0.13.1+16+gc66b31e-2
                       python-tinydb              4.5.1-1              4.5.2-1
                           timeshift20.11.1+28+gefed117-2            21.09.1-1
                      waydroid-image      17.1_20210920-1      17.1_20210925-1
:: Different sync package(s) in repository community aarch64
                       acme-redirect              0.5.2-1              0.5.3-1
                             ansible              4.5.0-1              4.6.0-1
                                 arb             2.20.0-1             2.21.0-1
                               arcus             4.10.0-1             4.11.0-1
                           babel-cli             7.15.4-1             7.15.7-1
                                 bcc             0.21.0-1             0.22.0-1
                           bcc-tools             0.21.0-1             0.22.0-1
                           bctoolbox             5.0.23-1             5.0.26-1
                                buho              2.0.0-1              2.0.0-2
                               bzrtp             5.0.23-1             5.0.26-1
                             cargo-c              0.9.3-1              0.9.4-1
                      cargo-generate             0.10.0-1             0.10.1-1
                             chezmoi              2.4.0-1              2.5.0-1
                             clojure         1.10.3.943-2         1.10.3.986-1
                        communicator              2.0.0-2              2.0.0-3
                              conmon           1:2.0.29-1           1:2.0.30-1
                   containers-common             0.45.0-1             0.46.0-1
                              cosign              1.1.0-1              1.2.1-1
                                criu               3.15-2               3.16-1
                    cura-binary-data             4.10.0-1             4.11.0-1
            cura-resources-materials             4.10.0-1             4.11.0-1
                          curaengine             4.10.0-1             4.11.0-1
                         dark-reader             4.9.36-1           4.9.37.1-1
                          diffoscope                184-1                185-1
                      efm-langserver             0.0.36-1             0.0.37-1
                              erlang             24.0.4-2             24.1.0-1
                          erlang-nox             24.0.4-1             24.1.0-1
                     erlang-unixodbc             24.0.4-2             24.1.0-1
                fcitx5-pinyin-zhwiki   1:0.2.3.20210911-1   1:0.2.3.20210923-1
                 firefox-dark-reader             4.9.36-1           4.9.37.1-1
                      firefox-stylus             1.5.19-1             1.5.22-1
                          frotz-dumb               2.51-1               2.53-1
                       frotz-ncurses               2.51-1               2.53-1
                           frotz-sdl               2.51-1               2.53-1
                               fwupd              1.6.3-1              1.6.4-1
                             git-lfs             2.13.3-2              3.0.0-1
                           gocryptfs                2.1-1              2.2.0-1
                          goreleaser            0.179.0-2            0.180.0-1
                                gpsd               3.23-1             3.23.1-1
                          grub-btrfs                4.9-1               4.10-1
                              harvid              0.8.3-1              0.8.3-2
                            index-fm              2.0.0-1              2.0.0-2
                       inotify-tools           3.21.9.1-1           3.21.9.5-1
                             jenkins              2.312-1              2.313-1
                               jruby           9.2.19.0-1            9.3.0.0-1
                          jupyterlab             3.1.12-1             3.1.13-1
                              kcptun           20210624-1           20210922-1
                                  ko              0.8.3-1              0.9.1-1
                             kompose             1.23.0-1             1.24.0-1
                              kotlin             1.5.30-1             1.5.31-1
                         kube-linter              0.2.3-1              0.2.4-1
                            laz-perf            2:1.3.0-1            2:2.1.0-1
                                lcov               1.15-3                    -
                      libcurl-compat             7.79.0-2             7.79.1-1
                      libcurl-gnutls             7.79.0-2             7.79.1-1
                          libsavitar             4.10.0-1             4.11.0-1
                             libtpms              0.8.6-1              0.8.7-1
                             libvips             8.11.3-1             8.11.4-1
                    maliit-framework              2.1.0-1              2.1.1-1
                           maui-clip              2.0.0-1              2.0.0-2
                           maui-nota              2.0.0-1              2.0.0-2
                            maui-pix              2.0.0-1              2.0.0-2
                          maui-shelf              2.0.0-1              2.0.0-2
                        maui-station              2.0.0-1              2.0.0-2
                       mediastreamer             5.0.23-1             5.0.26-1
                            minikube             1.23.0-1             1.23.1-1
                             neochat              1.2.0-3              1.2.0-4
             nextcloud-app-bookmarks            1:4.4.1-1           1:10.0.0-1
                    nextcloud-client            1:3.3.3-2            1:3.3.4-2
     nextcloud-client-cloudproviders            1:3.3.3-2            1:3.3.4-2
                              nodejs             16.9.1-1            16.10.0-1
                                 npm             7.24.0-1             7.24.1-1
                             openbox              3.6.1-7              3.6.1-8
                                ortp             5.0.23-1             5.0.26-1
                             pam-u2f              1.1.1-1              1.2.0-1
                                pdal              2.3.0-2              2.3.0-3
                                 pm2              5.1.1-1              5.1.2-1
                            pngquant             2.15.1-1             2.16.0-1
                        postfixadmin             3.3.10-1             3.3.10-2
                              pulumi             3.12.0-1             3.13.0-1
                             pyright            1.1.170-1            1.1.171-1
                          python-bcc             0.21.0-1             0.22.0-1
                       python-calmjs              3.4.1-3              3.4.1-4
                     python-cfn-lint             0.54.1-1             0.54.2-1
               python-django-appconf              1.0.4-4              1.0.5-1
                python-django-filter              2.4.0-2               21.1-1
                         python-doit             0.33.1-3             0.33.1-4
                        python-faker             8.12.3-1             8.13.1-1
                     python-filetype              1.0.7-3              1.0.8-1
                    python-fonttools             4.27.0-2             4.27.1-1
                       python-imdbpy          2021.4.18-1          2021.4.18-3
            python-jupyterlab_server              2.8.1-1              2.8.2-1
               python-lazr.delegates              2.0.4-5              2.0.4-6
                    python-libcharon             4.10.0-1             4.11.0-1
                    python-maxminddb              2.0.3-3              2.1.0-1
               python-more-itertools              8.9.0-1             8.10.0-1
                      python-mutagen             1.45.1-3             1.45.1-4
                      python-natsort              7.1.1-1              7.1.1-2
                      python-pikepdf              3.0.0-1              3.1.0-1
                       python-poetry              1.1.9-1             1.1.10-1
                 python-pycryptodome             3.10.1-1             3.10.4-1
                    python-pywayland              0.4.6-1              0.4.7-1
                    python-pywlroots             0.14.4-1             0.14.6-1
                    python-rapidjson                1.2-1                1.3-1
                         python-rich            10.10.0-1            10.11.0-1
                 python-scikit-learn             0.24.2-2                1.0-1
                       python-stestr              3.2.0-2              3.2.1-1
                         python-tqdm             4.62.2-1             4.62.3-1
                    python-traitlets              5.0.5-2              5.1.0-1
                        python-ujson              4.1.0-1              4.2.0-1
                   python-voluptuous             0.12.1-1             0.12.2-1
                python2-pycryptodome             3.10.1-1             3.10.4-1
                                qgis             3.20.2-1             3.20.3-1
                          rime-emoji     0.0.0.20210427-1     0.0.0.20210909-1
                  rime-pinyin-zhwiki   1:0.2.3.20210911-1   1:0.2.3.20210923-1
                                sile             0.11.1-3             0.12.0-4
                             snapper              0.9.0-2              0.9.1-1
                             step-ca             0.17.2-1             0.17.3-1
                            step-cli             0.17.2-1             0.17.4-1
                               sweep              0.9.3-5              0.9.3-6
                           tailscale             1.14.3-1             1.14.4-1
                    telegram-desktop              3.1.0-1              3.1.1-1
             thunderbird-dark-reader             4.9.36-1           4.9.37.1-1
                    timescaledb-tune             0.11.2-2             0.11.3-1
                              tinygo             0.19.0-1             0.20.0-1
                             uranium             4.10.0-2             4.11.0-1
         v2ray-domain-list-community     20210920023411-1     20210925082813-1
                         v2ray-geoip       202109160028-1       202109230028-1
                                vals             0.10.3-2             0.14.0-1
                     vaultwarden-web             2.22.3-1             2.23.0-1
                               vvave              2.0.0-1              2.0.0-2
                        zerotier-one              1.6.5-2              1.6.6-1
                           promscale                    -              0.6.0-1
                   ssh-key-confirmer                    -                0.1-1
                    ttf-iosevka-nerd                    -              2.1.0-1
:: Different overlay package(s) in repository core aarch64
                            linux-rc           5.15.rc2-2           5.15.rc2-3
                    linux-rc-headers           5.15.rc2-2           5.15.rc2-3
                          linux-rpi4            5.10.63-1            5.10.63-2
                  linux-rpi4-headers            5.10.63-1            5.10.63-2
              raspberrypi-bootloader           20210908-1           20210923-1
            raspberrypi-bootloader-x           20210908-1           20210923-1
                     uboot-pinephone            2021.07-1            2021.07-2
                               glib2                    -           2.70.0-1.1
:: Different sync package(s) in repository core aarch64
                         btrfs-progs               5.14-1             5.14.1-1
                                curl             7.79.0-4             7.79.1-1
                                file               5.40-5               5.40-6
                            iana-etc           20210728-1           20210903-1
                          libnghttp2             1.44.0-1             1.45.0-1
                                sudo           1.9.8.p1-1           1.9.8.p2-1
:: Different overlay package(s) in repository extra aarch64
                           calamares             3.2.40-1             3.2.44-1
                             firefox               92.0-1                    -
                    firefox-i18n-ach               92.0-1                    -
                     firefox-i18n-af               92.0-1                    -
                     firefox-i18n-an               92.0-1                    -
                     firefox-i18n-ar               92.0-1                    -
                    firefox-i18n-ast               92.0-1                    -
                     firefox-i18n-az               92.0-1                    -
                     firefox-i18n-be               92.0-1                    -
                     firefox-i18n-bg               92.0-1                    -
                     firefox-i18n-bn               92.0-1                    -
                     firefox-i18n-br               92.0-1                    -
                     firefox-i18n-bs               92.0-1                    -
                     firefox-i18n-ca               92.0-1                    -
                    firefox-i18n-cak               92.0-1                    -
                     firefox-i18n-cs               92.0-1                    -
                     firefox-i18n-cy               92.0-1                    -
                     firefox-i18n-da               92.0-1                    -
                     firefox-i18n-de               92.0-1                    -
                    firefox-i18n-dsb               92.0-1                    -
                     firefox-i18n-el               92.0-1                    -
                  firefox-i18n-en-ca               92.0-1                    -
                  firefox-i18n-en-gb               92.0-1                    -
                  firefox-i18n-en-us               92.0-1                    -
                     firefox-i18n-eo               92.0-1                    -
                  firefox-i18n-es-ar               92.0-1                    -
                  firefox-i18n-es-cl               92.0-1                    -
                  firefox-i18n-es-es               92.0-1                    -
                  firefox-i18n-es-mx               92.0-1                    -
                     firefox-i18n-et               92.0-1                    -
                     firefox-i18n-eu               92.0-1                    -
                     firefox-i18n-fa               92.0-1                    -
                     firefox-i18n-ff               92.0-1                    -
                     firefox-i18n-fi               92.0-1                    -
                     firefox-i18n-fr               92.0-1                    -
                  firefox-i18n-fy-nl               92.0-1                    -
                  firefox-i18n-ga-ie               92.0-1                    -
                     firefox-i18n-gd               92.0-1                    -
                     firefox-i18n-gl               92.0-1                    -
                     firefox-i18n-gn               92.0-1                    -
                  firefox-i18n-gu-in               92.0-1                    -
                     firefox-i18n-he               92.0-1                    -
                  firefox-i18n-hi-in               92.0-1                    -
                     firefox-i18n-hr               92.0-1                    -
                    firefox-i18n-hsb               92.0-1                    -
                     firefox-i18n-hu               92.0-1                    -
                  firefox-i18n-hy-am               92.0-1                    -
                     firefox-i18n-ia               92.0-1                    -
                     firefox-i18n-id               92.0-1                    -
                     firefox-i18n-is               92.0-1                    -
                     firefox-i18n-it               92.0-1                    -
                     firefox-i18n-ja               92.0-1                    -
                     firefox-i18n-ka               92.0-1                    -
                    firefox-i18n-kab               92.0-1                    -
                     firefox-i18n-kk               92.0-1                    -
                     firefox-i18n-km               92.0-1                    -
                     firefox-i18n-kn               92.0-1                    -
                     firefox-i18n-ko               92.0-1                    -
                    firefox-i18n-lij               92.0-1                    -
                     firefox-i18n-lt               92.0-1                    -
                     firefox-i18n-lv               92.0-1                    -
                     firefox-i18n-mk               92.0-1                    -
                     firefox-i18n-mr               92.0-1                    -
                     firefox-i18n-ms               92.0-1                    -
                     firefox-i18n-my               92.0-1                    -
                  firefox-i18n-nb-no               92.0-1                    -
                  firefox-i18n-ne-np               92.0-1                    -
                     firefox-i18n-nl               92.0-1                    -
                  firefox-i18n-nn-no               92.0-1                    -
                     firefox-i18n-oc               92.0-1                    -
                  firefox-i18n-pa-in               92.0-1                    -
                     firefox-i18n-pl               92.0-1                    -
                  firefox-i18n-pt-br               92.0-1                    -
                  firefox-i18n-pt-pt               92.0-1                    -
                     firefox-i18n-rm               92.0-1                    -
                     firefox-i18n-ro               92.0-1                    -
                     firefox-i18n-ru               92.0-1                    -
                     firefox-i18n-si               92.0-1                    -
                     firefox-i18n-sk               92.0-1                    -
                     firefox-i18n-sl               92.0-1                    -
                    firefox-i18n-son               92.0-1                    -
                     firefox-i18n-sq               92.0-1                    -
                     firefox-i18n-sr               92.0-1                    -
                  firefox-i18n-sv-se               92.0-1                    -
                     firefox-i18n-ta               92.0-1                    -
                     firefox-i18n-te               92.0-1                    -
                     firefox-i18n-th               92.0-1                    -
                     firefox-i18n-tr               92.0-1                    -
                     firefox-i18n-uk               92.0-1                    -
                     firefox-i18n-ur               92.0-1                    -
                     firefox-i18n-uz               92.0-1                    -
                     firefox-i18n-vi               92.0-1                    -
                     firefox-i18n-xh               92.0-1                    -
                  firefox-i18n-zh-cn               92.0-1                    -
                  firefox-i18n-zh-tw               92.0-1                    -
:: Different sync package(s) in repository extra aarch64
                  alsa-card-profiles           1:0.3.36-1           1:0.3.37-1
                              apache             2.4.48-1             2.4.49-1
                             brasero3.12.2+106+g46b9d116-1             3.12.3-1
                              brltty                6.3-4                6.4-1
                            chromium       93.0.4577.82-2       94.0.4606.61-1
                          cifs-utils               6.13-3               6.14-1
                               cmark             0.30.1-1             0.30.2-1
                             ethtool             1:5.13-1             1:5.14-1
                                 feh              3.7.1-1              3.7.2-1
                           freetype2             2.11.0-3             2.11.0-4
                     freetype2-demos             2.11.0-3             2.11.0-4
                      freetype2-docs             2.11.0-3             2.11.0-4
                                  gd              2.3.3-1              2.3.3-2
                     glib-networking           1:2.68.2-1           1:2.70.0-1
           gsettings-desktop-schemas               40.0-3               41.0-1
                               gssdp              1.2.3-1            1.4.0.1-1
                 gst-plugin-pipewire           1:0.3.36-1           1:0.3.37-1
                             haveged             1.9.14-1             1.9.14-2
                            inkscape                1.1-6              1.1.1-1
                        jsonrpc-glib             3.38.0-1             3.40.0-1
                       libatomic_ops             7.6.10-2             7.6.12-1
                         libblockdev               2.25-2               2.26-1
                            libglvnd              1.3.3-1              1.3.4-1
                              libmtp             1.1.18-1             1.1.19-1
                        libsidplayfp              2.2.2-1              2.3.0-1
                             libsoup             2.74.0-1             2.74.0-2
                           mercurial              5.9.1-1              5.9.1-2
                      mkvtoolnix-cli             61.0.0-1             61.0.0-2
                      mkvtoolnix-gui             61.0.0-1             61.0.0-2
                            mousepad              0.5.6-1              0.5.7-1
                                neon             0.31.2-1             0.32.1-1
                  perl-io-socket-ssl              2.071-1              2.072-1
                                 php             8.0.10-1             8.0.11-1
                          php-apache             8.0.10-1             8.0.11-1
                             php-cgi             8.0.10-1             8.0.11-1
                           php-dblib             8.0.10-1             8.0.11-1
                           php-embed             8.0.10-1             8.0.11-1
                         php-enchant             8.0.10-1             8.0.11-1
                             php-fpm             8.0.10-1             8.0.11-1
                              php-gd             8.0.10-1             8.0.11-1
                            php-imap             8.0.10-1             8.0.11-1
                            php-intl             8.0.10-1             8.0.11-1
                            php-odbc             8.0.10-1             8.0.11-1
                           php-pgsql             8.0.10-1             8.0.11-1
                          php-phpdbg             8.0.10-1             8.0.11-1
                          php-pspell             8.0.10-1             8.0.11-1
                            php-snmp             8.0.10-1             8.0.11-1
                          php-sodium             8.0.10-1             8.0.11-1
                          php-sqlite             8.0.10-1             8.0.11-1
                            php-tidy             8.0.10-1             8.0.11-1
                             php-xsl             8.0.10-1             8.0.11-1
                                php7             7.4.23-1             7.4.24-1
                         php7-apache             7.4.23-1             7.4.24-1
                            php7-cgi             7.4.23-1             7.4.24-1
                          php7-dblib             7.4.23-1             7.4.24-1
                          php7-embed             7.4.23-1             7.4.24-1
                        php7-enchant             7.4.23-1             7.4.24-1
                            php7-fpm             7.4.23-1             7.4.24-1
                             php7-gd             7.4.23-1             7.4.24-1
                           php7-imap             7.4.23-1             7.4.24-1
                           php7-intl             7.4.23-1             7.4.24-1
                           php7-odbc             7.4.23-1             7.4.24-1
                          php7-pgsql             7.4.23-1             7.4.24-1
                         php7-phpdbg             7.4.23-1             7.4.24-1
                         php7-pspell             7.4.23-1             7.4.24-1
                           php7-snmp             7.4.23-1             7.4.24-1
                         php7-sodium             7.4.23-1             7.4.24-1
                         php7-sqlite             7.4.23-1             7.4.24-1
                           php7-tidy             7.4.23-1             7.4.24-1
                            php7-xsl             7.4.23-1             7.4.24-1
                       pipewire-alsa           1:0.3.36-1           1:0.3.37-1
                       pipewire-docs           1:0.3.36-1           1:0.3.37-1
                       pipewire-jack           1:0.3.36-1           1:0.3.37-1
              pipewire-media-session           1:0.3.36-1           1:0.3.37-1
                      pipewire-pulse           1:0.3.36-1           1:0.3.37-1
                   pipewire-zeroconf           1:0.3.36-1           1:0.3.37-1
                        python-numpy             1.20.3-1             1.21.2-1
                       python-pycurl           7.43.0.6-4             7.44.1-1
                            qt5-base    5.15.2+kde+r224-1    5.15.2+kde+r227-1
             qt5-xcb-private-headers    5.15.2+kde+r224-1    5.15.2+kde+r227-1
                                sddm             0.19.0-6             0.19.0-7
                               xterm                368-1                369-1
                             firefox                    -           92.0.1-1.1
                    firefox-i18n-ach                    -             92.0.1-1
                     firefox-i18n-af                    -             92.0.1-1
                     firefox-i18n-an                    -             92.0.1-1
                     firefox-i18n-ar                    -             92.0.1-1
                    firefox-i18n-ast                    -             92.0.1-1
                     firefox-i18n-az                    -             92.0.1-1
                     firefox-i18n-be                    -             92.0.1-1
                     firefox-i18n-bg                    -             92.0.1-1
                     firefox-i18n-bn                    -             92.0.1-1
                     firefox-i18n-br                    -             92.0.1-1
                     firefox-i18n-bs                    -             92.0.1-1
                     firefox-i18n-ca                    -             92.0.1-1
            firefox-i18n-ca-valencia                    -             92.0.1-1
                    firefox-i18n-cak                    -             92.0.1-1
                     firefox-i18n-cs                    -             92.0.1-1
                     firefox-i18n-cy                    -             92.0.1-1
                     firefox-i18n-da                    -             92.0.1-1
                     firefox-i18n-de                    -             92.0.1-1
                    firefox-i18n-dsb                    -             92.0.1-1
                     firefox-i18n-el                    -             92.0.1-1
                  firefox-i18n-en-ca                    -             92.0.1-1
                  firefox-i18n-en-gb                    -             92.0.1-1
                  firefox-i18n-en-us                    -             92.0.1-1
                     firefox-i18n-eo                    -             92.0.1-1
                  firefox-i18n-es-ar                    -             92.0.1-1
                  firefox-i18n-es-cl                    -             92.0.1-1
                  firefox-i18n-es-es                    -             92.0.1-1
                  firefox-i18n-es-mx                    -             92.0.1-1
                     firefox-i18n-et                    -             92.0.1-1
                     firefox-i18n-eu                    -             92.0.1-1
                     firefox-i18n-fa                    -             92.0.1-1
                     firefox-i18n-ff                    -             92.0.1-1
                     firefox-i18n-fi                    -             92.0.1-1
                     firefox-i18n-fr                    -             92.0.1-1
                  firefox-i18n-fy-nl                    -             92.0.1-1
                  firefox-i18n-ga-ie                    -             92.0.1-1
                     firefox-i18n-gd                    -             92.0.1-1
                     firefox-i18n-gl                    -             92.0.1-1
                     firefox-i18n-gn                    -             92.0.1-1
                  firefox-i18n-gu-in                    -             92.0.1-1
                     firefox-i18n-he                    -             92.0.1-1
                  firefox-i18n-hi-in                    -             92.0.1-1
                     firefox-i18n-hr                    -             92.0.1-1
                    firefox-i18n-hsb                    -             92.0.1-1
                     firefox-i18n-hu                    -             92.0.1-1
                  firefox-i18n-hy-am                    -             92.0.1-1
                     firefox-i18n-ia                    -             92.0.1-1
                     firefox-i18n-id                    -             92.0.1-1
                     firefox-i18n-is                    -             92.0.1-1
                     firefox-i18n-it                    -             92.0.1-1
                     firefox-i18n-ja                    -             92.0.1-1
                     firefox-i18n-ka                    -             92.0.1-1
                    firefox-i18n-kab                    -             92.0.1-1
                     firefox-i18n-kk                    -             92.0.1-1
                     firefox-i18n-km                    -             92.0.1-1
                     firefox-i18n-kn                    -             92.0.1-1
                     firefox-i18n-ko                    -             92.0.1-1
                    firefox-i18n-lij                    -             92.0.1-1
                     firefox-i18n-lt                    -             92.0.1-1
                     firefox-i18n-lv                    -             92.0.1-1
                     firefox-i18n-mk                    -             92.0.1-1
                     firefox-i18n-mr                    -             92.0.1-1
                     firefox-i18n-ms                    -             92.0.1-1
                     firefox-i18n-my                    -             92.0.1-1
                  firefox-i18n-nb-no                    -             92.0.1-1
                  firefox-i18n-ne-np                    -             92.0.1-1
                     firefox-i18n-nl                    -             92.0.1-1
                  firefox-i18n-nn-no                    -             92.0.1-1
                     firefox-i18n-oc                    -             92.0.1-1
                  firefox-i18n-pa-in                    -             92.0.1-1
                     firefox-i18n-pl                    -             92.0.1-1
                  firefox-i18n-pt-br                    -             92.0.1-1
                  firefox-i18n-pt-pt                    -             92.0.1-1
                     firefox-i18n-rm                    -             92.0.1-1
                     firefox-i18n-ro                    -             92.0.1-1
                     firefox-i18n-ru                    -             92.0.1-1
                     firefox-i18n-si                    -             92.0.1-1
                     firefox-i18n-sk                    -             92.0.1-1
                     firefox-i18n-sl                    -             92.0.1-1
                    firefox-i18n-son                    -             92.0.1-1
                     firefox-i18n-sq                    -             92.0.1-1
                     firefox-i18n-sr                    -             92.0.1-1
                  firefox-i18n-sv-se                    -             92.0.1-1
                     firefox-i18n-ta                    -             92.0.1-1
                     firefox-i18n-te                    -             92.0.1-1
                     firefox-i18n-th                    -             92.0.1-1
                     firefox-i18n-tl                    -             92.0.1-1
                     firefox-i18n-tr                    -             92.0.1-1
                    firefox-i18n-trs                    -             92.0.1-1
                     firefox-i18n-uk                    -             92.0.1-1
                     firefox-i18n-ur                    -             92.0.1-1
                     firefox-i18n-uz                    -             92.0.1-1
                     firefox-i18n-vi                    -             92.0.1-1
                     firefox-i18n-xh                    -             92.0.1-1
                  firefox-i18n-zh-cn                    -             92.0.1-1
                  firefox-i18n-zh-tw                    -             92.0.1-1
                          gssdp-docs                    -            1.4.0.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.08.1.r12591.gcf7789927-121.08.1.r12601.g9b6b7b937-1
                    akonadi-calendar21.08.1.r1989.g3fd3365-121.08.1.r1990.g8eecf47-1
              akonadi-calendar-tools21.08.1.r900.g0a8982d-121.08.1.r907.gfde30f6-1
                    akonadi-contacts21.08.1.r3066.g9a05d8d3-121.08.1.r3067.g2ba39cb9-1
               akonadi-import-wizard21.08.1.r1745.g0fc338f-121.08.1.r1757.gdbf4e2e-1
                        akonadi-mime21.08.1.r1652.ga2973ce-121.08.1.r1654.gd440a08-1
                       akonadi-notes21.08.1.r1028.g6af8bed-121.08.1.r1029.g3b6fc2d-1
                      akonadi-search21.08.1.r1129.g34cc65b-121.08.1.r1130.gf22f09a-1
                      akonadiconsole21.08.1.r1529.g65a1e13-121.08.1.r1530.gf049430-1
                           akregator21.08.1.r6225.gb5a43fac-121.08.1.r6227.gbbf73e45-1
                           angelfish 21.08.r15.gc908fc5-1 21.08.r17.gd4141bf-1
                                 ark21.08.1.r4612.g552afb85-121.08.1.r4613.g3c563880-1
                              attica5.86.0.r834.g0dbf2b6-15.86.0.r836.g04bd6dc-1
                             blinken21.08.1.r631.g91d0068-121.08.1.r635.g1b32fef-1
                           bluedevil1:5.22.5.r2287.g6555054b-11:5.22.5.r2288.g33fe33f0-1
                              bomber21.08.1.r525.g558fa34-121.08.1.r527.gfff4ec7-1
                              breeze5.22.5.r2265.gbb70d9c5-15.22.5.r2274.g96c522e6-1
                          breeze-gtk5.22.5.r424.ga961433-15.22.5.r427.g4e3d0c7-1
                        breeze-icons5.86.0.r1790.g2e367293-15.86.0.r1791.g94941edf-1
                     calendarsupport21.08.1.r38.g00fa3cc-121.08.1.r39.g8d58fdf-1
                            discover5.22.5.r8306.g5acf6ff6-15.22.5.r8326.ga815b7c0-1
                             dolphin21.08.1.r6706.gcaa4afc15-121.08.1.r6709.gd3f427a6d-1
                     dolphin-plugins21.08.1.r604.gffad27d-121.08.1.r606.gffcc33d-1
                               elisa21.08.1.r2776.g578a8878-121.08.1.r2777.g92b5ca8c-1
                          eventviews21.08.1.r44.ge4d1e83-121.08.1.r49.g623caea-1
                           granatier21.08.1.r931.g82eb599-121.08.1.r932.g186d30f-1
                     grantlee-editor21.08.1.r772.g536e258-121.08.1.r774.g4470014-1
                       grantleetheme21.08.1.r347.g68f3c9e-121.08.1.r348.g15e5d95-1
                            gwenview21.08.1.r6677.g2a066715-121.08.1.r6679.g9d753ca3-1
                            index-fm 2.0.0.r21.g00e5b39-1 2.0.0.r23.gd95c4cd-1
                           itinerary21.08.1.r1456.g4d15bb8-121.08.1.r1459.g24dd357-1
                               kasts 21.08.r19.g6121f66-1 21.08.r28.g78986c5-1
                                kate21.08.1.r18369.g41e34a863-121.08.1.r18372.gba4d4ccc0-1
                           kbreakout21.08.1.r866.g56f83fc-121.08.1.r867.ge54c382-1
                         kcachegrind21.08.1.r1154.gb65ced6-121.08.1.r1156.g9579e5d-1
                  kcachegrind-common21.08.1.r1154.gb65ced6-121.08.1.r1156.g9579e5d-1
                       kcalendarcore5.86.0.r1240.g8da06215b-15.86.0.r1241.gbd6b9749f-1
                           kcalutils21.08.1.r875.gf6da0419b-121.08.1.r887.gdb9db0bdb-1
                              kclock  21.08.r3.g3d800cf-1  21.08.r4.g1562abc-1
                      kdebugsettings21.08.1.r851.gc90d09b-121.08.1.r853.g9a398a3-1
                          kdeconnect21.08.1.r3328.g47c34f80-121.08.1.r3330.g695e3675-1
              kdenetwork-filesharing21.08.1.r893.g2bb027c-121.08.1.r894.g73404b4-1
                            kdenlive21.08.1.r14944.gd64fe2d97-121.08.1.r14963.g4c0163c5b-1
                       kdepim-addons21.08.1.r4339.gb392c577-121.08.1.r4345.g1b86d024-1
                      kdepim-runtime21.08.1.r15298.g9f8120a10-121.08.1.r15313.gd9501a73f-1
                    kdeplasma-addons5.22.5.r8587.g93c87009c-15.22.5.r8588.g45df7c29a-1
                                kget21.08.1.r3122.g01e48861-121.08.1.r3123.g6c7c70c1-1
                  khealthcertificate        r73.5d4e42e-1        r81.8c5253b-1
                 kidentitymanagement21.08.1.r3823.g1aefd8b5-121.08.1.r3824.g42e84edb-1
                       kimageformats5.86.0.r359.g45cd128-15.86.0.r360.g6458c9a-1
                               kimap21.08.1.r1116.g49d0b4d-121.08.1.r1117.g8cf1e3d-1
                         kinfocenter5.22.5.r1930.ga4b4b5c-15.22.5.r1931.g0224c1c-1
                                 kio5.86.0.r5002.gcca84b63-15.86.0.r5003.g402abea0-1
                          kio-extras21.08.1.r7119.g2b112d58-121.08.1.r7124.g363542c5-1
                           kirigami25.86.0.r2894.g59e3ee77-15.86.0.r2905.gda6d5b19-1
                          kitinerary21.08.1.r1943.gc47f77e-121.08.1.r1951.g987b502-1
                               kldap21.08.1.r888.g0736944-121.08.1.r889.g944a745-1
                           kleopatra21.08.1.r5998.g107abfdb-121.08.1.r6001.g777c179b-1
                               kmail21.08.1.r25970.g6b9c2c8dd-121.08.1.r25977.g5930caf36-1
                kmail-account-wizard21.08.1.r820.g7cfb5bc-121.08.1.r822.g5f3958e-1
                      kmailtransport21.08.1.r1660.g798e269-121.08.1.r1664.gf8a77cb-1
                               kmbox21.08.1.r544.g0ac9465-121.08.1.r545.g316e720-1
                               kmime21.08.1.r1460.g1818a41-121.08.1.r1461.g071aeac-1
                                kmix21.08.1.r2382.g304af5fc-121.08.1.r2383.g0ef1805b-1
                           knewstuff5.86.0.r1210.g606522b9-15.86.0.r1212.gf687c5ab-1
                              knotes21.08.1.r3520.ge4304278-121.08.1.r3522.g8b0d1ff7-1
                           konqueror21.08.1.r14950.g631f6df83-121.08.1.r14955.g1414698ee-1
                             konsole21.08.1.r7947.g7383c16d-121.08.1.r7960.g8489c8e1-1
                             kontact21.08.1.r5386.g107a6a4b-121.08.1.r5388.g85c965e9-1
                    kontactinterface21.08.1.r635.g7acfd78-121.08.1.r636.g9d836e9-1
                          korganizer21.08.1.r11502.g9e36933f8-121.08.1.r11507.g72020d62e-1
                         kpeoplesink       r74.g69c548a-1       r75.gb79c4af-1
                        kpimtextedit21.08.1.r1450.g977151e-121.08.1.r1451.gfad0740-1
                                krdc21.08.1.r1539.g8111867-121.08.1.r1540.g8610267-1
                             krunner5.86.0.r670.gd53c5c2-15.86.0.r675.gf178b55-1
                             kscreen5.22.5.r1366.g7ca8821-15.22.5.r1367.g38c258a-1
                       kscreenlocker5.22.5.r876.g716e099-15.22.5.r877.g0f5cfa6-1
                               ksmtp21.08.1.r378.g38a4c09-121.08.1.r382.g0e6878d-1
                              ktouch21.08.1.r2141.gbd68c2a-121.08.1.r2142.g645d8e8-1
                                kwin5.22.5.r20032.gc29c437e5-15.22.5.r20049.g45ee1969c-1
                              kwinft5.22.4.r19304.g1b438d8a7-15.22.4.r19336.g2f902d1fd-1
                              kwrite21.08.1.r18369.g41e34a863-121.08.1.r18372.gba4d4ccc0-1
                          libakonadi21.08.1.r12591.gcf7789927-121.08.1.r12601.g9b6b7b937-1
                         libgravatar21.08.1.r371.g3b0380a-121.08.1.r372.g8e07a3f-1
                           libkdepim21.08.1.r852.g7b05740-121.08.1.r853.gd542c71-1
                            libkgapi21.08.1.r1297.g636bd28-121.08.1.r1299.g424b7c6-1
                             libkleo21.08.1.r937.g1c22ac4-121.08.1.r954.gd86eda3-1
                            libksane21.08.1.r561.gd9ab411-121.08.1.r562.g6db0765-1
                        libksysguard5.22.5.r2306.gf349605-15.22.5.r2307.ge00ac4a-1
                            lokalize21.08.1.r1777.gb19ef8f3-121.08.1.r1780.g749a2e88-1
                          mailcommon21.08.1.r1117.gce67d3e-121.08.1.r1118.g8072f1b-1
                        mailimporter21.08.1.r475.ga9dd033-121.08.1.r476.g12a62c7-1
                    maliit-framework0.99.1.r81.g75180246-10.99.1.r94.ga9ab4948-1
                     maliit-keyboard    r2119.g4b005d09-1    r2126.g70d2cda1-1
                            maui-pix  2.0.0.r9.g43a2ceb-1 2.0.0.r11.g8d11039-1
                             mauikit 2.0.2.r4.gcccbdf31-12.0.2.r10.ga4725085-1
                    mauikit-accounts  2.0.1.r0.gbb4a052-1  2.0.1.r1.g2699dbe-1
                mauikit-filebrowsing  2.0.2.r1.g817b688-1  2.0.2.r6.g9434330-1
                  mauikit-imagetools  2.0.1.r0.g99dd3ed-1  2.0.1.r2.g3910642-1
                  mauikit-texteditor  2.0.1.r0.g4075d1c-1  2.0.1.r3.g13b6a5b-1
                       mbox-importer21.08.1.r519.ga2c0a5e-121.08.1.r521.gb839f11-1
                          messagelib21.08.1.r6193.gfc3a38fb-121.08.1.r6198.g3e06094a-1
                             neochat    r1859.g9d4151dd-1    r1876.g71d01593-1
                              okular21.08.1.r9479.gd5b20d761-121.08.1.r9484.g6d2623a02-1
                   pim-data-exporter21.08.1.r2455.gd16e1bc7-121.08.1.r2457.g6ca2e55f-1
                    pim-sieve-editor21.08.1.r1513.g820300a-121.08.1.r1515.gc2d87d2-1
                           pimcommon21.07.80.r1111.gc9284f7-121.07.80.r1112.gf5dd396-1
                      plasma-desktop5.22.5.r8624.g808716db8-15.22.5.r8633.g61d7c9b7b-1
                       plasma-dialer  21.08.r3.g270dfd0-1  21.08.r7.ge75b129-1
                     plasma-firewall5.22.5.r518.g9a22ae0-15.22.5.r519.g5651dda-1
                    plasma-mobile-nm5.22.5.r3098.g72dbf30a-15.22.5.r3100.g3efb2054-1
                         plasma-nano5.21.5.r159.gd9b5281-15.21.5.r160.ga0f98ca-1
                           plasma-nm5.22.5.r3099.gac5d3fe2-15.22.5.r3100.g3efb2054-1
                           plasma-pa5.22.5.r973.g0bd635c-15.22.5.r976.g198f47b-1
             plasma-phone-components5.22.5.r1471.ge6c27636-15.22.5.r1473.gabf5be8c-1
                    plasma-phonebook  21.08.r8.g129f8dc-1  21.08.r9.g9edaa37-1
                     plasma-settings 21.08.r14.g0177e5b-1 21.08.r16.gdfe97e6-1
                plasma-systemmonitor5.22.5.r485.gea280be-15.22.5.r486.g2c298d8-1
                  plasma-thunderbolt5.22.5.r146.gd6ff877-15.22.5.r147.gccb8695-1
              plasma-wayland-session5.22.5.r10662.g33c492951-15.22.5.r10671.gb6a5217c5-1
                    plasma-workspace5.22.5.r10662.g33c492951-15.22.5.r10671.gb6a5217c5-1
         plasma-workspace-wallpapers5.22.5.r292.g55d7b3b-15.22.5.r293.gabb3a91-1
                          powerdevil5.22.5.r2476.gd68a8365-15.22.5.r2480.g52f44e41-1
                       print-manager21.08.1.r1045.g2b2be60-121.08.1.r1046.g37c9d66-1
                             purpose5.86.0.r887.g4f6f524-15.86.0.r890.gcbbbd37-1
                         qcachegrind21.08.1.r1154.gb65ced6-121.08.1.r1156.g9579e5d-1
                            sddm-kcm5.22.5.r606.g8c7624a-15.22.5.r607.gdefdc85-1
                           spectacle21.08.1.r1168.g9e04460-121.08.1.r1172.g1f8fa57-1
                             svgpart21.08.1.r182.gb602ba5-121.08.1.r183.gc7f46a9-1
                 syntax-highlighting5.86.0.r1696.gd277eb41-15.86.0.r1697.gedf0f349-1
                      systemsettings5.22.5.r2503.gf5ce0514-15.22.5.r2508.gbcb8e868-1
                         vakzination        r94.aba88d2-1        r96.999d7c2-1
                            wrapland5.22.4.r1595.g52ae265-15.22.4.r1599.ge051dd4-1
              xdg-desktop-portal-kde5.22.5.r385.ga2b7c05-15.22.5.r386.g8e21923-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Old Issues
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Pushed some more packages:
User philip created a snapshot of branch ‘arm-unstable’ to ‘arm-testing’.
  • arm-testing community aarch64: 3 new and 3 removed package(s)
  • arm-testing core aarch64: 4 new and 4 removed package(s)
                             PACKAGE          arm-testing         arm-unstable
                            mmsd-tng     1.2+5+g2cbc935-1     1.2+6+g3669f4c-1
               mobile-config-firefox              2.2.0-1              2.2.0-2
                            waydroid     r30.15bbf62-2.12        r38.e990576-1
                               linux             5.14.7-1             5.14.8-1
                       linux-headers             5.14.7-1             5.14.8-1
                     linux-pinephone             5.14.7-1             5.14.8-1
             linux-pinephone-headers             5.14.7-1             5.14.8-1
firefox-i18n missing.
Hi,
Is it the good place to speak about calamares for arm ?
In august you (the dev) introduce calamares for the arm, what a nice improvement, 1 month later this great function is unfortunately not present to build the images.
Yeah, that’s because the manjaro-arm-tools package in the x64 repo is not updated to a version that has it yet.
You can install the tools directly from gitlab though, to get it.
I built an image for the Odroid n2 KDE, at first boot impossible to log in, wrong username, wrong password…
I’m sure what I set, strange.
How to avoid at first boot the log in ?
__
SOLUTION
I re flash the image and re do the install, I only change the password (a longer one), it works now.
Samba and VNC doesn’t work.
I pushed another set of packages:
User philip created a snapshot of branch 'arm-unstable' to 'arm-testing'.
 - arm-testing community aarch64:  84 new and 84 removed package(s)
 - arm-testing core aarch64:  7 new and 7 removed package(s)
 - arm-testing extra aarch64:  19 new and 18 removed package(s)
                              chatty  0.4.0+50+gccc4176-1  0.4.0+50+gccc4176-2
                        eg25-manager              0.4.0-9   0.4.0+6+g2bf6337-1
                          electron13             13.4.0-1             13.5.0-1
                     element-desktop              1.8.5-2              1.9.0-1
                         element-web              1.8.5-2              1.9.0-1
                            mmsd-tng     1.2+6+g3669f4c-1     1.2+7+g3e0ee86-1
                               phosh 0.13.1+16+gc66b31e-2 0.13.1+16+gc66b31e-3
            pinephone-manjaro-tweaks           20210911-1           20210927-1
                            cairosvg              2.1.3-5                    -
                          cargo-edit              0.7.0-2              0.8.0-1
                         cargo-watch              8.0.0-1              8.1.1-1
                              codec2            1:1.0.0-1            1:1.0.1-1
                                crun                1.0-2                1.1-1
                      dnscrypt-proxy              2.1.0-1              2.1.1-1
                             dnsperf              2.7.0-1              2.7.1-1
                               fastd                 19-1                 22-1
                       geany-plugins               1.37-3               1.37-4
                                giac           1.7.0.31-1           1.7.0.33-1
                               gitui             0.16.2-1             0.17.1-2
                     gnome-subtitles                1.6-2                1.7-1
                        goimapnotify              2.3.2-1              2.3.3-1
                          grub-btrfs               4.10-1             4.10.1-1
                gst-editing-services             1.18.4-1             1.18.5-1
              jupyter-server-mathjax              0.2.3-1              0.2.3-2
                          jupyterlab             3.1.13-1             3.1.14-1
                                 kup              0.9.1-1              0.9.1-2
                              lhapdf              6.3.0-3              6.4.0-1
                             mellite              3.6.0-1              3.7.0-1
                            miniflux             2.0.32-2             2.0.33-1
                              neovim              0.5.0-1              0.5.1-1
                            onefetch             2.10.2-1             2.10.2-2
                          python-ddt              1.4.2-1              1.4.3-1
          python-django-crispy-forms             1.12.0-1             1.13.0-1
                        python-faker             8.13.1-1             8.13.2-1
                python-feedgenerator              1.9.1-3              1.9.2-1
     python-google-api-python-client             2.21.0-1             2.22.0-1
             python-jsonrpclib-pelix              0.4.2-1              0.4.3-1
            python-jupyter_packaging             0.10.5-1             0.10.6-1
                   python-matrix-nio             0.18.6-1             0.18.7-1
                 python-phonenumbers            8.12.31-1            8.12.33-1
                       python-pygit2              1.6.1-1              1.6.1-2
                 python-pytest-xdist              2.3.0-2              2.4.0-1
                        python-qiniu              7.4.1-1              7.5.0-1
                      python-ufolib2             0.11.3-1             0.11.4-1
                   python-validators             0.18.1-3             0.18.2-1
                          rebuilderd             0.14.0-1             0.14.2-1
                    rebuilderd-tools             0.14.0-1             0.14.2-1
                          rosegarden              21.06-1            21.06.1-1
                         ruby-rugged              1.1.1-1              1.2.0-1
                           scenarist        0.7.2.rc12a-1         0.7.2.rc13-1
                          serverless             2.59.0-1             2.60.0-1
                           skk-jisyo           20210822-1           20210926-1
                               smb4k              3.1.0-1              3.1.1-1
                            starship             0.57.0-1             0.58.0-2
                           texstudio              3.1.2-1              4.0.0-1
                         ttc-iosevka             10.2.0-1             10.3.0-1
                    ttc-iosevka-aile             10.2.0-1             10.3.0-1
                   ttc-iosevka-curly             10.2.0-1             10.3.0-1
              ttc-iosevka-curly-slab             10.2.0-1             10.3.0-1
                  ttc-iosevka-etoile             10.2.0-1             10.3.0-1
                    ttc-iosevka-slab             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss01             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss02             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss03             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss04             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss05             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss06             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss07             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss08             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss09             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss10             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss11             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss12             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss13             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss14             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss15             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss16             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss17             10.2.0-1             10.3.0-1
                    ttc-iosevka-ss18             10.2.0-1             10.3.0-1
                          ukui-panel              3.0.4-1              3.0.5-1
         v2ray-domain-list-community     20210925082813-1     20210927113941-1
                            valabind              1.8.0-1              1.8.0-2
                               yosys               0.9-14               0.10-1
                                 zim             0.74.0-1             0.74.1-1
                                 fst                    -            0.120.0-1
                            linux-rc           5.15.rc2-3           5.15.rc3-1
                    linux-rc-headers           5.15.rc2-3           5.15.rc3-1
                           amd-ucode   20210818.c46b8c3-1   20210919.d526e04-1
                           coreutils               8.32-1                9.0-1
                      linux-firmware   20210818.c46b8c3-1   20210919.d526e04-1
                             openssh              8.7p1-2              8.8p1-1
                              tzdata              2021a-2              2021b-1
                              basket              2.49b-4              2.49b-5
                            calligra             3.2.1-20             3.2.1-21
                            discover             5.22.5-1             5.22.5-2
                         egl-wayland              1.1.7-1              1.1.8-1
                             fluxbox              1.3.7-61.3.7+205+g1d19662c-1
                           knewstuff             5.86.0-1             5.86.0-2
                         ktexteditor             5.86.0-1             5.86.0-2
                             libgit2            1:1.1.1-1            1:1.2.0-1
                        libgit2-glib           0.99.0.1-5           0.99.0.1-6
                            libinput             1.19.0-1             1.19.1-1
                             libraqm              0.7.1-1              0.7.2-1
                              libtar             1.2.20-5             1.2.20-6
                            nitrogen              1.6.1-3              1.6.1-4
                     qt5-declarative     5.15.2+kde+r30-1     5.15.2+kde+r31-1
                         qt5-wayland     5.15.2+kde+r30-1     5.15.2+kde+r31-1
                            tracker3              3.2.0-1              3.2.0-2
                       tracker3-docs              3.2.0-1              3.2.0-2
                                vala             0.52.5-1             0.54.1-1
                            libsoup3                    -              3.0.0-2
Looks like there is a breaking change in the OpenSSH 8.8p1… (OpenSSH: Release Notes)
Incompatibility is more likely when connecting to older SSH
implementations that have not been upgraded or have not closely tracked
improvements in the SSH protocol. For these cases, it may be necessary
to selectively re-enable RSA/SHA1 to allow connection and/or user
authentication via the HostkeyAlgorithms and PubkeyAcceptedAlgorithms
options. For example, the following stanza in ~/.ssh/config will enable
RSA/SHA1 for host and user authentication for a single destination host:
Host old-host
    HostkeyAlgorithms +ssh-rsa
    PubkeyAcceptedAlgorithms +ssh-rsa
We recommend enabling RSA/SHA1 only as a stopgap measure until legacy
implementations can be upgraded or reconfigured with another key type
(such as ECDSA or Ed25519).
Most of my existing SSH commands are no longer working properly, unless I add the aforementioned settings to my .ssh/config for the host in question.
Or you can add this to the bottom of /etc/ssh/ssh_config and it will take effect for all hosts and for all users.
Arch Linux does not mention this change on their News page.
And according to this in the release notes:
The incompatibility stuff should only effect users if they connect to servers with openssh 7.2 or older that has not had it’s keys updated yet.
I think it is regarding to the old Debian and Ubuntu servers, which might not update openssh for some reason.
Doesn’t it also depends on how the sshd is configured on the system? So if the server admin still uses rsa based keys he may eventually do so with newer versions as well, wouldn’t it?
same for me, I am getting 404 error
Well, they are there.
Make sure you are not using the manjaro.re mirror, as that has issues these days.
But I think I know why. Will fix it.
Just uploaded firefox-i18n 92.0.1-1.1 to both unstable and testing branches, which hopefully should fix this issue.
Pushed more packages here:
 - arm-testing community aarch64:  4 new and 4 removed package(s)
 - arm-testing core aarch64:  2 new and 2 removed package(s)
 - arm-testing kde-unstable aarch64:  91 new and 91 removed package(s)
                               calls   41.0+21+g9d27d5b-1   41.0+30+gfbb6316-1
                          electron12             12.1.2-1             12.2.0-1
                          obs-studio             27.0.1-1             27.1.1-1
            pinephone-manjaro-tweaks           20210927-1           20210928-1
                     linux-pinephone             5.14.8-1             5.14.8-2
             linux-pinephone-headers             5.14.8-1             5.14.8-2
                             akonadi21.08.1.r12601.g9b6b7b937-121.08.1.r12604.gd7d907e67-1
               akonadi-import-wizard21.08.1.r1757.gdbf4e2e-121.08.1.r1758.gedec9c8-1
                      akonadiconsole21.08.1.r1530.gf049430-121.08.1.r1533.g64cf187-1
                           akregator21.08.1.r6227.gbbf73e45-121.08.1.r6228.gfbf4fabc-1
                           alligator  21.08.r1.g38dca0b-1  21.08.r2.g7c0b49e-1
                           angelfish 21.08.r17.gd4141bf-1 21.08.r20.g1ebd161-1
                                 ark21.08.1.r4613.g3c563880-121.08.1.r4614.gc0a94112-1
                              breeze5.22.5.r2274.g96c522e6-15.22.5.r2276.g59605fd9-1
                        breeze-icons5.86.0.r1791.g94941edf-15.86.0.r1792.g264bb9a5-1
                     calendarsupport21.08.1.r39.g8d58fdf-121.08.1.r40.gc588b5f-1
                            discover5.22.5.r8326.ga815b7c0-15.22.5.r8336.g11e72936-1
                 extra-cmake-modules5.86.0.r3368.gdc86450-15.86.0.r3370.g3df459c-1
                     incidenceeditor21.08.1.r771.g944ba09-121.08.1.r774.ga820ee5-1
                            index-fm 2.0.0.r23.gd95c4cd-1 2.0.0.r24.gb4f358a-1
                           itinerary21.08.1.r1459.g24dd357-121.08.1.r1460.g21893b1-1
                        kaddressbook21.08.1.r6048.gca4e283a-121.08.1.r6050.g018281b8-1
                              kalarm21.08.1.r6465.g542abb2d-121.08.1.r6466.g82369401-1
                               kasts 21.08.r28.g78986c5-1 21.08.r29.g06e8d8d-1
                               kcalc21.08.1.r1536.g671e923-121.08.1.r1537.gee7a3ab-1
                         kcharselect21.08.1.r476.g428e547-121.08.1.r477.g2b0ce35-1
                              kclock  21.08.r4.g1562abc-1  21.08.r8.g48d1d79-1
                            kcmutils5.86.0.r549.g0ddc970-15.86.0.r550.g1e9c4fe-1
                             kconfig5.86.0.r865.g3090534-15.86.0.r866.g5617e6d-1
                               kcron21.08.1.r779.g57e8a16-121.08.1.r780.g884a2d1-1
                                kdav1:5.86.0.r1300.gbb550f6-11:5.86.0.r1301.g4e4571a-1
                          kdeconnect21.08.1.r3330.g695e3675-121.08.1.r3333.gee85a5d5-1
                                kded5.86.0.r418.gb278fc4-15.86.0.r419.g6731b81-1
            kdegraphics-thumbnailers21.08.1.r236.g918502e-121.08.1.r237.g2c062c3-1
                            kdenlive21.08.1.r14963.g4c0163c5b-121.08.1.r14973.g293f0edd6-1
                      kdepim-runtime21.08.1.r15313.gd9501a73f-121.08.1.r15314.g7643c5915-1
                    kdeplasma-addons5.22.5.r8588.g45df7c29a-15.22.5.r8589.g6cc2388c8-1
                                 kdf21.08.1.r803.g64c8456-121.08.1.r804.g608d3f6-1
                             kfloppy21.08.1.r758.gd252d04-121.08.1.r759.gc62b879-1
                        kglobalaccel5.86.0.r468.gc5ee700-15.86.0.r469.ge928938-1
                 kidentitymanagement21.08.1.r3824.g42e84edb-121.08.1.r3825.g321702d3-1
                               kimap21.08.1.r1117.g8cf1e3d-121.08.1.r1118.g066cc22-1
                         kinfocenter5.22.5.r1931.g0224c1c-15.22.5.r1934.g874d5d2-1
                          kio-extras21.08.1.r7124.g363542c5-121.08.1.r7125.g98855307-1
                           kirigami25.86.0.r2905.gda6d5b19-15.86.0.r2907.g2a3a3889-1
                          kitinerary21.08.1.r1951.g987b502-121.08.1.r1961.g81b7c2a-1
                               kmail21.08.1.r25977.g5930caf36-121.08.1.r25983.g0e0da7785-1
                kmail-account-wizard21.08.1.r822.g5f3958e-121.08.1.r824.g30e4c9a-1
                      kmailtransport21.08.1.r1664.gf8a77cb-121.08.1.r1666.gf4dda58-1
                        knavalbattle21.08.1.r1390.g1fcbe9d-121.08.1.r1392.g34e09c4-1
                           knewstuff5.86.0.r1212.gf687c5ab-15.86.0.r1219.g44b5113d-1
                                koko 21.08.r15.gd42ac89-1 21.08.r16.gfabe235-1
                             kontact21.08.1.r5388.g85c965e9-121.08.1.r5389.g4f3b1b85-1
                          korganizer21.08.1.r11507.g72020d62e-121.08.1.r11511.g815cfcee2-1
                        kpeoplevcard   0.1.r14.gc6a135a-1   0.1.r15.g0d12452-1
                        kpimtextedit21.08.1.r1451.gfad0740-121.08.1.r1453.ge4d8ae4-1
                    kpublictransport21.08.1.r1842.ga4e371bd-121.08.1.r1843.g89b48a76-1
                           krecorder  21.08.r3.g2214cdf-1  21.08.r4.g93865a4-1
                             kscreen5.22.5.r1367.g38c258a-15.22.5.r1368.ga8143d4-1
                               ksmtp21.08.1.r382.g0e6878d-121.08.1.r383.g691b693-1
                          ksystemlog21.08.1.r660.gca438d0-121.08.1.r661.g60929a8-1
                              ktimer21.08.1.r470.g4705ed6-121.08.1.r471.g3c7d517-1
                              ktouch21.08.1.r2142.g645d8e8-121.08.1.r2143.g5d3d6cd-1
                      kwalletmanager21.08.1.r1210.ga5e4b13-121.08.1.r1212.gbdf10cf-1
                            kweather 21.08.r12.g4de9ad6-1 21.08.r19.g3735c3e-1
                        kweathercore    0.5.r0.gb6ef51c-1    0.5.r1.g2be08aa-1
                                kwin5.22.5.r20049.g45ee1969c-15.22.5.r20056.gef06b8ed9-1
                              kwinft5.22.4.r19336.g2f902d1fd-15.22.4.r19339.g626fd5de1-1
                          libakonadi21.08.1.r12601.g9b6b7b937-121.08.1.r12604.gd7d907e67-1
                            libkcddb21.08.1.r736.g24d5755-121.08.1.r739.ge4cae29-1
                           libkdepim21.08.1.r853.gd542c71-121.08.1.r854.g094931a-1
                           libksieve21.08.1.r1593.g09806745-121.08.1.r1597.g8e8a9b1f-1
                         libktorrent21.08.1.r526.gb7edbf4-121.08.1.r539.gbf23d9a-1
                          mailcommon21.08.1.r1118.g8072f1b-121.08.1.r1121.gcd065dc-1
                             mauikit2.0.2.r10.ga4725085-12.0.2.r11.gc4531477-1
                          messagelib21.08.1.r6198.g3e06094a-121.08.1.r6199.g2730222f-1
                              okular21.08.1.r9484.g6d2623a02-121.08.1.r9486.gb22bba31f-1
                    pim-sieve-editor21.08.1.r1515.gc2d87d2-121.08.1.r1516.gf0e7e2f-1
                           pimcommon21.07.80.r1112.gf5dd396-121.07.80.r1115.g10e79a0-1
                      plasma-desktop5.22.5.r8633.g61d7c9b7b-15.22.5.r8637.gb4895ef0e-1
                       plasma-dialer  21.08.r7.ge75b129-1  21.08.r8.g8cc6788-1
                     plasma-firewall5.22.5.r519.g5651dda-15.22.5.r521.g9d7e427-1
                    plasma-framework5.86.0.r15988.gb3ca8b5ef-15.86.0.r15989.gef9e3f25f-1
                    plasma-mobile-nm5.22.5.r3100.g3efb2054-15.22.5.r3101.g5f46da62-1
                           plasma-nm5.22.5.r3100.g3efb2054-15.22.5.r3101.g5f46da62-1
                           plasma-pa5.22.5.r976.g198f47b-15.22.5.r977.ga99ad04-1
             plasma-phone-components5.22.5.r1473.gabf5be8c-15.22.5.r1475.gfa9b0c97-1
                    plasma-phonebook  21.08.r9.g9edaa37-1 21.08.r11.gcc8a2fa-1
                     plasma-settings 21.08.r16.gdfe97e6-1 21.08.r19.g1b5e8d5-1
                  plasma-thunderbolt5.22.5.r147.gccb8695-15.22.5.r149.gee3a87b-1
         plasma-workspace-wallpapers5.22.5.r293.gabb3a91-15.22.5.r294.gc329bc2-1
                            sddm-kcm5.22.5.r607.gdefdc85-15.22.5.r609.g7066534-1
                           spectacle21.08.1.r1172.g1f8fa57-121.08.1.r1175.g8db2717-1
                      systemsettings5.22.5.r2508.gbcb8e868-15.22.5.r2511.g30a9c4c0-1
                             tokodon  21.08.r2.g6b35a2f-1  21.08.r4.g70103f5-1
                         vakzination        r96.999d7c2-1        r97.66a1534-1
                             yakuake21.08.1.r733.g246229c-121.08.1.r734.g916fb92-1
