Hello ARM community.
Rather small update this time. Enjoy!
Maliit keyboard in Plasma
Some highlights:
- A couple of kernels got updated
- Maliit keyboard and framework updated to 2.1.0
- A new point release brings thunderbird to 91.1.1
- LibreOffice is now version 7.2.1
- And Matray is now updated to 1.1.1
- Lots of Mobile specific packages got updated
- Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Enable the service with
sudo systemctl enable waydroid-container. - Run
pkexec setup-waydroidas root user - Reboot.
- You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Tue Sep 21 19:09:08 CEST 2021)
- arm-testing community aarch64: 189 new and 183 removed package(s)
- arm-testing core aarch64: 24 new and 24 removed package(s)
- arm-testing extra aarch64: 252 new and 250 removed package(s)
- arm-testing kde-unstable aarch64: 127 new and 127 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-09-16 2021-09-21
anbox 0_git20210625-1 0_git20210625-2
callaudiod 0.1.0+4+g84ed2eb-3 0.1.1-1
chatty 0.4.0-1 0.4.0+47+g0fbe816-1
eg25-manager 0.4.0-7 0.4.0-9
gnome-control-center-mobile 3.38.6-2 40.1-1
gnome-initial-setup-mobile 3.38.5-1 41.0-1
gnome-software-mobile 3.38.2-1 41.0-1.2
matray 1.1.0-1 1.1.1-1
pamac-mobile-integration 20210912-3 20210918-1
pinephone-post-install 20210612-2 20210919-2
timeshift20.11.1+28+gefed117-120.11.1+28+gefed117-2
vivaldi 4.2.2406.44-1 4.2.2406.48-1
waydroid-image 17.1_20210913-1 17.1_20210920-1
waydroid r30.15bbf62-2 r30.15bbf62-2.12
:: Different sync package(s) in repository community aarch64
acpid 2.0.32-2 2.0.33-1
anki 2.1.15-1 -
asciidoc 9.1.0-1 9.1.1-2
autoconf-archive 1:2021.02.19-1 1:2021.02.19-2
babel-core 7.15.4-1 7.15.5-1
baidupcs-go 3.8.2-1 3.8.3-1
bctoolbox 5.0.18-1 5.0.23-1
bzrtp 5.0.18-1 5.0.23-1
cargo-c 0.9.2-1 0.9.3-1
cargo-generate 0.8.0-1 0.10.0-1
catatonit 0.1.5-2 0.1.6-1
cimg 2.9.8-1 2.9.9-1
cobalt 0.17.0-1 0.17.1-1
coffeescript 2.5.1-1 2.6.0-1
containers-common 0.44.0-1 0.44.1-1
crun 1.0-1 1.0-2
dark-reader 4.9.34-1 4.9.35-1
dart 2.14.1-1 2.14.2-1
diffoscope 183-1 184-1
dns-over-https 2.2.5-1 2.3.0-1
drumstick 2.3.1-1 2.4.0-1
dua-cli 2.14.3-1 2.14.7-1
dust 0.6.2-1 0.7.5-1
facter 3.14.16-5 3.14.18-1
firefox-dark-reader 4.9.34-1 4.9.35-1
gensio 2.2.8-1 2.2.9-1
go-tools 4:0.1.5-1 4:0.1.6-1
gscan2pdf 2.12.2-1 2.12.3-1
helm 3.6.3-1 3.7.0-1
helmfile 0.140.0-1 0.140.1-1
htmlhint 0.15.1-1 0.15.2-1
i2c-tools 4.2-3 4.3-1
ibus-libpinyin 1.12.0-1 1.12.1-1
innernet 1.4.1-1 1.5.0-1
inotify-tools 3.20.11.0-1 3.21.9.0-1
irker 2.19-1 2.20-1
iwd 1.17-1 1.18-1
jgmenu 4.3.0-1 4.4.0-1
jupyter-nbclassic 0.3.1-1 0.3.2-1
kak-lsp 11.0.0-2 11.0.1-1
kylin-nm 3.0.1-1 3.0.2-1
leiningen 2.9.6-1 2.9.7-1
libcurl-compat 7.78.0-1 7.79.0-2
libcurl-gnutls 7.78.0-1 7.79.0-2
libimagequant 2.15.1-1 2.16.0-1
libolm 3.2.4-1 3.2.6-1
libpinyin 2.6.0-1 2.6.1-1
lksctp-tools 1.0.17-3 1.0.19-1
maliit-framework 2.0.0-2 2.1.0-1
maliit-keyboard 2.0.0-2 2.1.0-1
matrix-appservice-irc 0.30.0-1 0.31.0-1
mauikit 2.0.1-1 2.0.2-1
mauikit-filebrowsing 2.0.1-1 2.0.2-1
mediastreamer 5.0.18-1 5.0.23-1
mitmproxy 7.0.2-1 7.0.3-1
molecule 3.4.0-1 3.5.1-1
molecule-docker 0.3.3-2 1.0.2-1
molecule-podman 0.3.0-2 1.0.1-1
mpv 1:0.33.1-2 1:0.33.1-3
newsboat 2.24-2 2.25-1
nextcloud-app-contacts 4.0.2-1 4.0.3-1
nextcloud-app-spreed 1:12.1.1-1 1:12.2.0-1
nextcloud-client 1:3.3.3-1 1:3.3.3-2
nextcloud-client-cloudproviders 1:3.3.3-1 1:3.3.3-2
node-gyp 8.1.0-2 8.2.0-1
nomad 1.1.4-1 1.1.5-1
notmuch 0.32.3-1 0.33.1-1
notmuch-mutt 0.32.3-1 0.33.1-1
notmuch-runtime 0.32.3-1 0.33.1-1
notmuch-vim 0.32.3-1 0.33.1-1
npm 7.23.0-1 7.24.0-1
open-iscsi 2.1.4-1 2.1.5-1
opentimelineio 0.13-1 0.13-2
optional-lite 3.4.0-1 3.5.0-1
ortp 5.0.18-1 5.0.23-1
owncloud-client 2.9.0.5150-1 2.9.0.5150-2
pan 0.146-3 0.147-1
perl-dbd-pg 3.9.0-1 3.9.1-1
perl-email-sender 1.300031-8 2.500-1
perl-proc-processtable 0.59-3 0.60-1
perl-test-simple 1.302186-1 1.302187-1
perl-yaml-libyaml 0.75-6 0.83-1
phrase-pinyin-data 0.10.5-1 0.11.0-1
pinyin-data 0.10.2-1 0.11.0-1
postgis 3.1.3-1 3.1.4-1
prettier 2.3.2-1 2.4.1-1
pyenv 2.0.6-1 2.0.7-2
pyright 1.1.168-1 1.1.169-1
python-aiogram 2.14.3-1 2.15-1
python-breathe 4.30.0-2 4.31.0-1
python-build 0.6.0-1 0.7.0-1
python-cvxopt 1.2.6-1 1.2.7-1
python-debian 0.1.40-2 0.1.41-1
python-decorator 5.0.9-1 5.1.0-1
python-dnspython 1:1.16.0-3 1:2.1.0-1
python-elementpath 2.2.3-2 2.3.1-1
python-faker 8.12.1-2 8.12.3-1
python-flexmock 0.10.9-1 0.10.10-1
python-gitpython 3.1.18-1 3.1.24-1
python-google-api-python-client 2.19.1-1 2.21.0-1
python-google-auth 1.33.0-1 1.33.1-1
python-identify 2.2.14-1 2.2.15-1
python-itemadapter 0.3.0-1 0.4.0-1
python-jaeger-client 4.7.0-1 4.8.0-1
python-jsonschema-objects 0.3.14-1 0.3.15-1
python-keystoneauth1 4.3.1-2 4.4.0-1
python-keystoneclient 4.2.0-1 4.3.0-1
python-moto 2.2.6-1 2.2.7-1
python-mypy-protobuf 2.9-1 -
python-olm 3.2.4-1 3.2.6-1
python-pandas 1.3.2-1 1.3.3-1
python-pefile 2021.5.24-1 2021.9.3-1
python-pg8000 1.21.1-1 1.21.2-1
python-poetry 1.1.8-1 1.1.9-1
python-pyliblo 0.10.0-7 0.10.0-8
python-pymupdf 1.18.17-1 1.18.19-1
python-pynitrokey 0.4.3.1-1 0.4.4-1
python-pytest-randomly 3.8.0-1 3.9.0-1
python-pytest-rerunfailures 10.1-1 10.2-1
python-pytest-socket 0.4.0-1 0.4.1-1
python-pywlroots 0.14.3-1 0.14.4-1
python-qasync 0.21.0-1 0.22.0-1
python-rapidjson 1.1-1 1.2-1
python-regex 2021.7.6-1 2021.8.28-1
python-rich 10.9.0-1 10.10.0-1
python-sqlparse 0.4.1-3 0.4.2-1
python-thrift 0.14.0-1 0.14.1-1
python-tox 3.24.3-1 3.24.4-1
python-watchdog 0.10.6-1 0.10.7-1
python2-tox 3.24.3-1 3.24.4-1
qtile 0.18.0-2 0.18.1-2
r10k 3.10.0-1 3.11.0-1
rclone 1.56.0-1 1.56.1-1
rebuilderd 0.13.0-1 0.14.0-1
ruby-faraday 1.7.2-1 1.8.0-1
ruby-hocon 1.3.1-3 1.3.1-4
ruby27-hocon 1.3.1-2 1.3.1-3
rust-analyzer 20210913-1 20210920-1
seatd 0.6.1-2 0.6.2-1
shutter 0.98-1 0.99-1
skaffold 1.31.0-1 1.32.0-1
sonic-visualiser 4.3-2 4.4-1
sslh 1.22.b-1 1.22.c-1
subdownloader 2.1.0-5 2.1.0-6
syncthing 1.18.1-1 1.18.2-1
syncthing-relaysrv 1.18.1-1 1.18.2-1
tailscale 1.14.2-1 1.14.3-1
tclap 1.2.2-2 1.2.3-1
telegram-desktop 3.0.1-1 3.1.0-1
terraform 1.0.6-1 1.0.7-1
thunderbird-dark-reader 4.9.34-1 4.9.35-1
tinyxml 2.6.2-7 2.6.2-8
ttf-sarasa-gothic 0.34.2-1 0.34.3-1
ukui-biometric-auth 1.2.1-1 1.2.2-1
ukui-panel 3.0.3.1-1 3.0.4-1
ukui-screensaver 3.0.1-1 3.0.2-1
ukui-sidebar 3.0.1-1 3.1.1-1
uutils-coreutils 0.0.7-1 0.0.7-2
v2ray 4.41.1-1 4.42.2-1
v2ray-domain-list-community 20210910080130-1 20210920023411-1
v2ray-geoip 202109102251-1 202109160028-1
vim-nerdtree 6.10.11-1 6.10.12-1
vultr-cli 2.8.2-1 2.8.3-1
wavemon 0.9.3-1 0.9.4-1
weechat 3.2-1 3.2.1-1
xfce4-whiskermenu-plugin 2.5.3-1 2.6.0-1
xh 0.12.0-2 0.13.0-1
xonsh 0.10.0-1 0.10.1-1
zim 0.73.5-1 0.74.0-1
goreleaser - 0.179.0-2
ko - 0.8.3-1
python-fire - 0.4.0-1
python-nkdfu - 0.1-1
rebuilderd-tools - 0.14.0-1
ruby-jwt - 2.2.3-1
shotgun - 2.2.1-1
timescaledb-tune - 0.11.2-2
:: Different overlay package(s) in repository core aarch64
linux 5.14.5-1 5.14.6-1
linux-headers 5.14.5-1 5.14.6-1
linux-pinephone 5.14.3-1 5.14.6-1
linux-pinephone-headers 5.14.3-1 5.14.6-1
linux-quartz64 5.15.0-0.1 5.15.0-0.2
linux-quartz64-headers 5.15.0-0.1 5.15.0-0.2
linux-rc 5.15.rc1-2 5.15.rc2-1
linux-rc-headers 5.15.rc1-2 5.15.rc2-1
manjaro-keyring 20210807-2 20210910-2
:: Different sync package(s) in repository core aarch64
audit 3.0.4-1 3.0.5-1
btrfs-progs 5.13.1-1 5.14-1
cryptsetup 2.4.0-1 2.4.1-1
curl 7.78.0-1 7.79.0-3
grep 3.6-1 3.7-1
inetutils 2.1-1 2.2-1
libcap 2.56-1 2.58-1
libedit 20210714_3.1-1 20210910_3.1-1
links 2.23-1 2.24-2
openssh 8.7p1-1 8.7p1-2
pam 1.5.1-1 1.5.2-1
pkgconf 1.7.3-1 1.8.0-1
python-audit 3.0.4-1 3.0.5-1
sudo 1.9.8-1 1.9.8.p1-1
xz 5.2.5-1 5.2.5-2
:: Different overlay package(s) in repository extra aarch64
mesa-git21.3.0_devel.144712.138463d3c3e-121.3.0_devel.145040.6f9f350622b-1
:: Different sync package(s) in repository extra aarch64
alsa-card-profiles 1:0.3.35-1 1:0.3.36-1
bdf-unifont 13.0.06-1 14.0.01-1
bftpd 5.7-1 6.0-1
bind 9.16.20-1 9.16.21-1
c-client 2007f-11 2007f-13
clamav 0.103.3-1 0.104.0-1
cmake 3.21.2-2 3.21.3-1
ell 0.43-1 0.44-1
finch 2.14.6-2 2.14.7-1
gst-libav 1.18.4-1 1.18.5-1
gst-plugin-gtk 1.18.4-2 1.18.5-1
gst-plugin-opencv 1.18.4-11 1.18.5-1
gst-plugin-pipewire 1:0.3.35-1 1:0.3.36-1
gst-plugin-qmlgl 1.18.4-2 1.18.5-1
gst-plugin-wpe 1.18.4-11 1.18.5-1
gst-plugins-bad 1.18.4-11 1.18.5-1
gst-plugins-bad-libs 1.18.4-11 1.18.5-1
gst-plugins-base 1.18.4-1 1.18.5-1
gst-plugins-base-libs 1.18.4-1 1.18.5-1
gst-plugins-good 1.18.4-2 1.18.5-1
gst-plugins-ugly 1.18.4-2 1.18.5-1
gst-python 1.18.4-1 1.18.5-1
gstreamer 1.18.4-1 1.18.5-1
gstreamer-docs 1.18.4-1 1.18.5-1
gstreamer-vaapi 1.18.4-1 1.18.5-1
imagemagick 7.1.0.7-1 7.1.0.8-1
imagemagick-doc 7.1.0.7-1 7.1.0.8-1
imap 2007f-11 2007f-13
konqueror 21.08.1-1 21.08.1-2
libfido2 1.7.0-2 1.8.0-1
libinput 1.18.1-1 1.19.0-1
libmm-glib 1.18.0-1 1.18.2-1
libnotify 0.7.9-1 0.7.9-2
libpurple 2.14.6-2 2.14.7-1
libreoffice-fresh 7.2.0-2 7.2.1-2
libreoffice-fresh-af 7.2.0-1 7.2.1-1
libreoffice-fresh-am 7.2.0-1 7.2.1-1
libreoffice-fresh-ar 7.2.0-1 7.2.1-1
libreoffice-fresh-as 7.2.0-1 7.2.1-1
libreoffice-fresh-ast 7.2.0-1 7.2.1-1
libreoffice-fresh-be 7.2.0-1 7.2.1-1
libreoffice-fresh-bg 7.2.0-1 7.2.1-1
libreoffice-fresh-bn 7.2.0-1 7.2.1-1
libreoffice-fresh-bn-in 7.2.0-1 7.2.1-1
libreoffice-fresh-bo 7.2.0-1 7.2.1-1
libreoffice-fresh-br 7.2.0-1 7.2.1-1
libreoffice-fresh-brx 7.2.0-1 7.2.1-1
libreoffice-fresh-bs 7.2.0-1 7.2.1-1
libreoffice-fresh-ca 7.2.0-1 7.2.1-1
libreoffice-fresh-ca-valencia 7.2.0-1 7.2.1-1
libreoffice-fresh-ckb 7.2.0-1 7.2.1-1
libreoffice-fresh-cs 7.2.0-1 7.2.1-1
libreoffice-fresh-cy 7.2.0-1 7.2.1-1
libreoffice-fresh-da 7.2.0-1 7.2.1-1
libreoffice-fresh-de 7.2.0-1 7.2.1-1
libreoffice-fresh-dgo 7.2.0-1 7.2.1-1
libreoffice-fresh-dsb 7.2.0-1 7.2.1-1
libreoffice-fresh-dz 7.2.0-1 7.2.1-1
libreoffice-fresh-el 7.2.0-1 7.2.1-1
libreoffice-fresh-en-gb 7.2.0-1 7.2.1-1
libreoffice-fresh-en-za 7.2.0-1 7.2.1-1
libreoffice-fresh-eo 7.2.0-1 7.2.1-1
libreoffice-fresh-es 7.2.0-1 7.2.1-1
libreoffice-fresh-et 7.2.0-1 7.2.1-1
libreoffice-fresh-eu 7.2.0-1 7.2.1-1
libreoffice-fresh-fa 7.2.0-1 7.2.1-1
libreoffice-fresh-fi 7.2.0-1 7.2.1-1
libreoffice-fresh-fr 7.2.0-1 7.2.1-1
libreoffice-fresh-fur 7.2.0-1 7.2.1-1
libreoffice-fresh-fy 7.2.0-1 7.2.1-1
libreoffice-fresh-ga 7.2.0-1 7.2.1-1
libreoffice-fresh-gd 7.2.0-1 7.2.1-1
libreoffice-fresh-gl 7.2.0-1 7.2.1-1
libreoffice-fresh-gu 7.2.0-1 7.2.1-1
libreoffice-fresh-gug 7.2.0-1 7.2.1-1
libreoffice-fresh-he 7.2.0-1 7.2.1-1
libreoffice-fresh-hi 7.2.0-1 7.2.1-1
libreoffice-fresh-hr 7.2.0-1 7.2.1-1
libreoffice-fresh-hsb 7.2.0-1 7.2.1-1
libreoffice-fresh-hu 7.2.0-1 7.2.1-1
libreoffice-fresh-id 7.2.0-1 7.2.1-1
libreoffice-fresh-is 7.2.0-1 7.2.1-1
libreoffice-fresh-it 7.2.0-1 7.2.1-1
libreoffice-fresh-ja 7.2.0-1 7.2.1-1
libreoffice-fresh-ka 7.2.0-1 7.2.1-1
libreoffice-fresh-kab 7.2.0-1 7.2.1-1
libreoffice-fresh-kk 7.2.0-1 7.2.1-1
libreoffice-fresh-km 7.2.0-1 7.2.1-1
libreoffice-fresh-kmr-latn 7.2.0-1 7.2.1-1
libreoffice-fresh-kn 7.2.0-1 7.2.1-1
libreoffice-fresh-ko 7.2.0-1 7.2.1-1
libreoffice-fresh-kok 7.2.0-1 7.2.1-1
libreoffice-fresh-ks 7.2.0-1 7.2.1-1
libreoffice-fresh-lb 7.2.0-1 7.2.1-1
libreoffice-fresh-lo 7.2.0-1 7.2.1-1
libreoffice-fresh-lt 7.2.0-1 7.2.1-1
libreoffice-fresh-lv 7.2.0-1 7.2.1-1
libreoffice-fresh-mai 7.2.0-1 7.2.1-1
libreoffice-fresh-mk 7.2.0-1 7.2.1-1
libreoffice-fresh-ml 7.2.0-1 7.2.1-1
libreoffice-fresh-mn 7.2.0-1 7.2.1-1
libreoffice-fresh-mni 7.2.0-1 7.2.1-1
libreoffice-fresh-mr 7.2.0-1 7.2.1-1
libreoffice-fresh-my 7.2.0-1 7.2.1-1
libreoffice-fresh-nb 7.2.0-1 7.2.1-1
libreoffice-fresh-ne 7.2.0-1 7.2.1-1
libreoffice-fresh-nl 7.2.0-1 7.2.1-1
libreoffice-fresh-nn 7.2.0-1 7.2.1-1
libreoffice-fresh-nr 7.2.0-1 7.2.1-1
libreoffice-fresh-nso 7.2.0-1 7.2.1-1
libreoffice-fresh-oc 7.2.0-1 7.2.1-1
libreoffice-fresh-om 7.2.0-1 7.2.1-1
libreoffice-fresh-or 7.2.0-1 7.2.1-1
libreoffice-fresh-pa-in 7.2.0-1 7.2.1-1
libreoffice-fresh-pl 7.2.0-1 7.2.1-1
libreoffice-fresh-pt 7.2.0-1 7.2.1-1
libreoffice-fresh-pt-br 7.2.0-1 7.2.1-1
libreoffice-fresh-ro 7.2.0-1 7.2.1-1
libreoffice-fresh-ru 7.2.0-1 7.2.1-1
libreoffice-fresh-rw 7.2.0-1 7.2.1-1
libreoffice-fresh-sa-in 7.2.0-1 7.2.1-1
libreoffice-fresh-sat 7.2.0-1 7.2.1-1
libreoffice-fresh-sd 7.2.0-1 7.2.1-1
libreoffice-fresh-sdk 7.2.0-2 7.2.1-2
libreoffice-fresh-si 7.2.0-1 7.2.1-1
libreoffice-fresh-sid 7.2.0-1 7.2.1-1
libreoffice-fresh-sk 7.2.0-1 7.2.1-1
libreoffice-fresh-sl 7.2.0-1 7.2.1-1
libreoffice-fresh-sq 7.2.0-1 7.2.1-1
libreoffice-fresh-sr 7.2.0-1 7.2.1-1
libreoffice-fresh-sr-latn 7.2.0-1 7.2.1-1
libreoffice-fresh-ss 7.2.0-1 7.2.1-1
libreoffice-fresh-st 7.2.0-1 7.2.1-1
libreoffice-fresh-sv 7.2.0-1 7.2.1-1
libreoffice-fresh-sw-tz 7.2.0-1 7.2.1-1
libreoffice-fresh-szl 7.2.0-1 7.2.1-1
libreoffice-fresh-ta 7.2.0-1 7.2.1-1
libreoffice-fresh-te 7.2.0-1 7.2.1-1
libreoffice-fresh-tg 7.2.0-1 7.2.1-1
libreoffice-fresh-th 7.2.0-1 7.2.1-1
libreoffice-fresh-tn 7.2.0-1 7.2.1-1
libreoffice-fresh-tr 7.2.0-1 7.2.1-1
libreoffice-fresh-ts 7.2.0-1 7.2.1-1
libreoffice-fresh-tt 7.2.0-1 7.2.1-1
libreoffice-fresh-ug 7.2.0-1 7.2.1-1
libreoffice-fresh-uk 7.2.0-1 7.2.1-1
libreoffice-fresh-uz 7.2.0-1 7.2.1-1
libreoffice-fresh-ve 7.2.0-1 7.2.1-1
libreoffice-fresh-vec 7.2.0-1 7.2.1-1
libreoffice-fresh-vi 7.2.0-1 7.2.1-1
libreoffice-fresh-xh 7.2.0-1 7.2.1-1
libreoffice-fresh-zh-cn 7.2.0-1 7.2.1-1
libreoffice-fresh-zh-tw 7.2.0-1 7.2.1-1
libreoffice-fresh-zu 7.2.0-1 7.2.1-1
librsvg 2:2.50.7-1 2:2.52.0-1
libxi 1.7.10-3 1.8-1
modemmanager 1.18.0-1 1.18.2-1
msmtp 1.8.15-1 1.8.16-1
msmtp-mta 1.8.15-1 1.8.16-1
perl-crypt-openssl-rsa 0.31-6 0.32-1
perl-libwww 6.56-1 6.57-1
pidgin 2.14.6-2 2.14.7-1
pipewire-alsa 1:0.3.35-1 1:0.3.36-1
pipewire-docs 1:0.3.35-1 1:0.3.36-1
pipewire-jack 1:0.3.35-1 1:0.3.36-1
pipewire-media-session 1:0.3.35-1 1:0.3.36-1
pipewire-pulse 1:0.3.35-1 1:0.3.36-1
pipewire-zeroconf 1:0.3.35-1 1:0.3.36-1
prometheus 2.29.2-1 2.30.0-1
pstoedit 3.75-5 3.76-1
python-pytest-qt 3.3.0-4 4.0.2-1
python-virtualenv 20.7.2-1 20.8.0-1
python2-virtualenv 20.7.2-1 20.8.0-1
qt5-virtualkeyboard 5.15.2-1 5.15.2+kde+r4-1
qtav 1.13.0-1 1.13.0-2
thunar 4.16.9-1 4.16.10-1
thunderbird 91.1.0-2 91.1.1-1
thunderbird-i18n-af 91.1.0-2 91.1.1-1
thunderbird-i18n-ar 91.1.0-2 91.1.1-1
thunderbird-i18n-ast 91.1.0-2 91.1.1-1
thunderbird-i18n-be 91.1.0-2 91.1.1-1
thunderbird-i18n-bg 91.1.0-2 91.1.1-1
thunderbird-i18n-br 91.1.0-2 91.1.1-1
thunderbird-i18n-ca 91.1.0-2 91.1.1-1
thunderbird-i18n-cak 91.1.0-2 91.1.1-1
thunderbird-i18n-cs 91.1.0-2 91.1.1-1
thunderbird-i18n-cy 91.1.0-2 91.1.1-1
thunderbird-i18n-da 91.1.0-2 91.1.1-1
thunderbird-i18n-de 91.1.0-2 91.1.1-1
thunderbird-i18n-dsb 91.1.0-2 91.1.1-1
thunderbird-i18n-el 91.1.0-2 91.1.1-1
thunderbird-i18n-en-gb 91.1.0-2 91.1.1-1
thunderbird-i18n-en-us 91.1.0-2 91.1.1-1
thunderbird-i18n-es-ar 91.1.0-2 91.1.1-1
thunderbird-i18n-es-es 91.1.0-2 91.1.1-1
thunderbird-i18n-et 91.1.0-2 91.1.1-1
thunderbird-i18n-eu 91.1.0-2 91.1.1-1
thunderbird-i18n-fi 91.1.0-2 91.1.1-1
thunderbird-i18n-fr 91.1.0-2 91.1.1-1
thunderbird-i18n-fy-nl 91.1.0-2 91.1.1-1
thunderbird-i18n-ga-ie 91.1.0-2 91.1.1-1
thunderbird-i18n-gd 91.1.0-2 91.1.1-1
thunderbird-i18n-gl 91.1.0-2 91.1.1-1
thunderbird-i18n-he 91.1.0-2 91.1.1-1
thunderbird-i18n-hr 91.1.0-2 91.1.1-1
thunderbird-i18n-hsb 91.1.0-2 91.1.1-1
thunderbird-i18n-hu 91.1.0-2 91.1.1-1
thunderbird-i18n-hy-am 91.1.0-2 91.1.1-1
thunderbird-i18n-id 91.1.0-2 91.1.1-1
thunderbird-i18n-is 91.1.0-2 91.1.1-1
thunderbird-i18n-it 91.1.0-2 91.1.1-1
thunderbird-i18n-ja 91.1.0-2 91.1.1-1
thunderbird-i18n-ka 91.1.0-2 91.1.1-1
thunderbird-i18n-kab 91.1.0-2 91.1.1-1
thunderbird-i18n-kk 91.1.0-2 91.1.1-1
thunderbird-i18n-ko 91.1.0-2 91.1.1-1
thunderbird-i18n-lt 91.1.0-2 91.1.1-1
thunderbird-i18n-ms 91.1.0-2 91.1.1-1
thunderbird-i18n-nb-no 91.1.0-2 91.1.1-1
thunderbird-i18n-nl 91.1.0-2 91.1.1-1
thunderbird-i18n-nn-no 91.1.0-2 91.1.1-1
thunderbird-i18n-pa-in 91.1.0-2 91.1.1-1
thunderbird-i18n-pl 91.1.0-2 91.1.1-1
thunderbird-i18n-pt-br 91.1.0-2 91.1.1-1
thunderbird-i18n-pt-pt 91.1.0-2 91.1.1-1
thunderbird-i18n-rm 91.1.0-2 91.1.1-1
thunderbird-i18n-ro 91.1.0-2 91.1.1-1
thunderbird-i18n-ru 91.1.0-2 91.1.1-1
thunderbird-i18n-sk 91.1.0-2 91.1.1-1
thunderbird-i18n-sl 91.1.0-2 91.1.1-1
thunderbird-i18n-sq 91.1.0-2 91.1.1-1
thunderbird-i18n-sr 91.1.0-2 91.1.1-1
thunderbird-i18n-sv-se 91.1.0-2 91.1.1-1
thunderbird-i18n-th 91.1.0-2 91.1.1-1
thunderbird-i18n-tr 91.1.0-2 91.1.1-1
thunderbird-i18n-uk 91.1.0-2 91.1.1-1
thunderbird-i18n-uz 91.1.0-2 91.1.1-1
thunderbird-i18n-vi 91.1.0-2 91.1.1-1
thunderbird-i18n-zh-cn 91.1.0-2 91.1.1-1
thunderbird-i18n-zh-tw 91.1.0-2 91.1.1-1
unicode-character-database 13.0.0-1 14.0.0-1
varnish 6.6.1-2 7.0.0-1
vulkan-icd-loader 1.2.190-1 1.2.191-1
wayland-protocols 1.22-1 1.23-1
webkit2gtk 2.32.3-1 2.32.4-1
wpewebkit 2.32.3-1 2.32.4-1
xf86-input-libinput 1.1.0-1 1.2.0-1
xorgproto 2021.4-1 2021.5-1
power-profiles-daemon - 0.9.0-4
wayland-utils - 1.0.0-2
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.08.1.r12587.g58d60c677-121.08.1.r12588.g14868f1c9-1
akonadi-contacts21.08.1.r3064.g3849f713-121.08.1.r3065.g4b2ab3e6-1
angelfish 21.08.r10.g909da15-1 21.08.r15.gc908fc5-1
bluedevil1:5.22.5.r2286.gecfbaddd-11:5.22.5.r2287.g6555054b-1
breeze5.22.5.r2257.g1b6dc846-15.22.5.r2263.g3fc6f79e-1
calendarsupport21.08.1.r36.g5449ae3-121.08.1.r38.g00fa3cc-1
calindori 21.08.r1.g5add1b8-1 21.08.r2.g5217d44-1
discover5.22.5.r8304.g4c9538dd-15.22.5.r8305.g1f519711-1
dragon21.08.1.r1011.gaeba124-121.08.1.r1012.g1f1d89c-1
elisa21.08.1.r2768.g0dd33183-121.08.1.r2776.g578a8878-1
eventviews21.08.1.r39.g2f75642-121.08.1.r41.g856e4a0-1
granatier21.08.1.r930.gc86a329-121.08.1.r931.g82eb599-1
gwenview21.08.1.r6676.g69e0d06e-121.08.1.r6677.g2a066715-1
index-fm 2.0.0.r18.ge90331e-1 2.0.0.r21.g00e5b39-1
itinerary21.08.1.r1450.g35704d3-121.08.1.r1456.g4d15bb8-1
k3b1:21.08.1.r6675.g9e099ffe9-11:21.08.1.r6677.gae173289a-1
kaccounts-integration21.08.1.r1221.g4c3deb8-121.08.1.r1222.g18ac4be-1
kapman21.08.1.r606.g4c5d88b-121.08.1.r608.gdcad1c6-1
kasts 21.08.r9.gd7ac052-1 21.08.r19.g6121f66-1
kate21.08.1.r18365.g915aa496b-121.08.1.r18369.g41e34a863-1
katomic21.08.1.r920.g7b5c821-121.08.1.r921.g482ba5a-1
kblackbox21.08.1.r727.g865ff49-121.08.1.r728.g90fc514-1
kbruch21.08.1.r817.gfed951b-121.08.1.r818.g8f9399b-1
kcalc21.08.1.r1530.gc94d383-121.08.1.r1536.g671e923-1
kcalendarcore5.86.0.r1239.g10cfe8918-15.86.0.r1240.g8da06215b-1
kcodecs5.86.0.r386.g5e7feae-15.86.0.r388.gbf88853-1
kcompletion5.86.0.r457.g04f8bcb-15.86.0.r458.g6b74042-1
kconfig5.86.0.r863.g7827501-15.86.0.r864.g0b0a446-1
kde-cli-tools5.22.5.r1864.gf75b811-15.22.5.r1865.g75e9d72-1
kdebugsettings21.08.1.r850.gb41d7c2-121.08.1.r851.gc90d09b-1
kdeclarative5.86.0.r922.gbfe8ca1-15.86.0.r923.gefef008-1
kdeconnect21.08.1.r3325.g9d5dcc99-121.08.1.r3328.g47c34f80-1
kdecoration5.22.5.r271.g957feca-15.22.5.r273.g343cade-1
kdenlive21.08.1.r14881.g81d83a72b-121.08.1.r14944.gd64fe2d97-1
kdepim-runtime21.08.1.r15288.gaeb77f624-121.08.1.r15295.g6662d58bc-1
kdeplasma-addons5.22.5.r8585.g9e62a25f0-15.22.5.r8587.g93c87009c-1
kdiamond21.08.1.r671.g0e63a0f-121.08.1.r672.gf4459d8-1
kguiaddons5.86.0.r391.ga846d64-15.86.0.r392.g22c428e-1
khangman21.08.1.r1565.ga82efb3-121.08.1.r1566.g58a1700-1
khelpcenter21.08.1.r2678.gebc327a7-121.08.1.r2679.gaa802c99-1
kholidays1:5.86.0.r960.g4287dd7-11:5.86.0.r961.gb1500cd-1
khotkeys5.22.5.r2094.gc6f4cb9-15.22.5.r2095.g3bfd01f-1
killbots21.08.1.r738.gee08736-121.08.1.r740.g8a2b782-1
kinfocenter5.22.5.r1929.gf263079-15.22.5.r1930.ga4b4b5c-1
kinit5.86.0.r413.ga0c6715-15.86.0.r414.g11a0ffc-1
kio5.86.0.r4984.gfb48159b-15.86.0.r4996.gf301322d-1
kio-extras21.08.1.r7116.g395ae54b-121.08.1.r7119.g2b112d58-1
kio-gdrive21.08.1.r568.g7607e00-121.08.1.r569.gfaab51e-1
kirigami25.86.0.r2889.gd97773ed-15.86.0.r2893.gcc0dd9da-1
kiten21.08.1.r1147.gf71fae4-121.08.1.r1148.g3eeccd9-1
kitinerary21.08.1.r1940.g731b078-121.08.1.r1941.g909055b-1
kjumpingcube21.08.1.r788.g458b5ce-121.08.1.r789.g53fde8d-1
kleopatra21.08.1.r5996.g24dd062d-121.08.1.r5998.g107abfdb-1
klettres21.08.1.r915.gabb53f5-121.08.1.r916.gd84f133-1
klickety21.08.1.r637.gc086690-121.08.1.r638.g30e0336-1
klines21.08.1.r769.g33a870b-121.08.1.r771.gb28676e-1
kmail21.08.1.r25968.g9aaf1ab55-121.08.1.r25970.g6b9c2c8dd-1
kmailtransport21.08.1.r1658.gaabd283-121.08.1.r1659.gb49ee72-1
kmines21.08.1.r1722.gb8a94d6-121.08.1.r1724.g7fa5e75-1
knetwalk21.08.1.r659.gf294dfd-121.08.1.r660.g83c5aa5-1
knewstuff5.86.0.r1207.g37a38190-15.86.0.r1209.ge31b2b07-1
knights21.08.1.r1050.gbc8f3d2-121.08.1.r1051.g6cfa479-1
knotes21.08.1.r3519.g4d173e29-121.08.1.r3520.ge4304278-1
knotifications5.86.0.r680.g471bd77-15.86.0.r681.g37e7a37-1
koko 21.08.r12.g25ea616-1 21.08.r15.gd42ac89-1
kolf21.08.1.r1443.g6ea5e84-121.08.1.r1444.g7dc7698-1
kolourpaint21.08.1.r2363.gcfe3d636-121.08.1.r2364.g85bdf6d6-1
konqueror21.08.1.r14936.g80c20b528-121.08.1.r14950.g631f6df83-1
konsole21.08.1.r7942.g51ab3770-121.08.1.r7947.g7383c16d-1
kopete21.08.1.r16397.ga5ea75f5f-121.08.1.r16399.gec24d08f0-1
kpimtextedit21.08.1.r1424.g4038649-121.08.1.r1447.g008ea3d-1
kpublictransport21.08.1.r1841.gc558aafe-121.08.1.r1842.ga4e371bd-1
kquickimageeditor r59.gde1a380-1 r60.g6107676-1
kservice5.86.0.r944.g927daaf-15.86.0.r947.g362951e-1
kshisen21.08.1.r1202.ge43cf2c-121.08.1.r1203.ge0961d9-1
ksmtp21.08.1.r372.g5d96c21-121.08.1.r374.gb33f063-1
ksnakeduel21.08.1.r809.g27dabac-121.08.1.r810.ga84f637-1
kspaceduel21.08.1.r634.gb10a003-121.08.1.r635.geb4e797-1
ksquares21.08.1.r517.gcf195bb-121.08.1.r518.g3c1a44e-1
ksystemstats5.22.5.r195.g328fb1f-15.22.5.r197.gc5aba84-1
ktorrent21.08.1.r2777.gc87029dd-121.08.1.r2778.ge4a201b9-1
kwayland-server5.22.5.r1388.gf6fa493-15.22.5.r1391.g7354d8d-1
kweather 21.08.r11.g1208e0a-1 21.08.r12.g4de9ad6-1
kwidgetsaddons5.86.0.r874.g05a6fcfd-15.86.0.r878.g76ecd700-1
kwin5.22.5.r20000.g35ff7eb0e-15.22.5.r20018.gcf7cc0d43-1
kwordquiz21.08.1.r1146.g6ca5430-121.08.1.r1147.gc5725a0-1
kwrite21.08.1.r18365.g915aa496b-121.08.1.r18369.g41e34a863-1
libakonadi21.08.1.r12587.g58d60c677-121.08.1.r12588.g14868f1c9-1
libkleo21.08.1.r935.gadc7cac-121.08.1.r936.gfb48fe2-1
libquotient r2104.g88a51b8-1 r2106.gf7e15e7-1
lokalize21.08.1.r1769.gfccb25a-121.08.1.r1777.gb19ef8f3-1
mailcommon21.08.1.r1115.ge92f626-121.08.1.r1116.g2a20c75-1
maliit-framework0.99.1.r79.g3bf69f37-10.99.1.r81.g75180246-1
maliit-keyboard r2113.g94350854-1 r2119.g4b005d09-1
maui-clip 2.0.0.r7.g1688cd2-1 2.0.0.r9.gf3cb75f-1
maui-nota 2.0.0.r6.g9689cfc-1 2.0.0.r8.gbfe9d04-1
mauikit2.0.1.r17.g94f4a141-1 2.0.2.r4.gcccbdf31-1
mauikit-filebrowsing 2.0.1.r4.g7b9f7d4-1 2.0.2.r1.g817b688-1
messagelib21.08.1.r6191.g42131120-121.08.1.r6192.gd09a316a-1
okular21.08.1.r9471.ge6c6e5225-121.08.1.r9479.gd5b20d761-1
oxygen5.22.5.r4429.g1afa6e27-15.22.5.r4430.gd29cd5a0-1
parley21.08.1.r4455.g55172e88-121.08.1.r4456.g10cf6ea4-1
pim-data-exporter21.08.1.r2454.gee3deea9-121.08.1.r2455.gd16e1bc7-1
plasma-desktop5.22.5.r8616.gb5b6a472d-15.22.5.r8621.g4d037821e-1
plasma-firewall5.22.5.r516.g785acb5-15.22.5.r517.g878f576-1
plasma-framework5.86.0.r15979.gb869a784a-15.86.0.r15986.g7b597edc9-1
plasma-mobile-nm5.22.3.r3094.g1963a3de-15.22.5.r3098.g72dbf30a-1
plasma-nm5.22.5.r3097.g9ddd19e1-15.22.5.r3098.g72dbf30a-1
plasma-pa5.22.5.r968.g61a0851-15.22.5.r969.g9dbf39e-1
plasma-phone-components5.22.5.r1468.gc4903c25-15.22.5.r1470.g1e01aa53-1
plasma-settings 21.08.r9.g8847cd2-1 21.08.r14.g0177e5b-1
plasma-thunderbolt5.22.5.r143.g6d4ef24-15.22.5.r145.g760edc5-1
plasma-wayland-session5.22.5.r10651.g47c897e94-15.22.5.r10655.g5dfcc0374-1
plasma-workspace5.22.5.r10651.g47c897e94-15.22.5.r10655.g5dfcc0374-1
plasma-workspace-wallpapers5.22.5.r290.ga50a8dc-15.22.5.r292.g55d7b3b-1
powerdevil5.22.5.r2474.gc3efed30-15.22.5.r2476.gd68a8365-1
print-manager21.08.1.r1044.g85ca95c-121.08.1.r1045.g2b2be60-1
purpose5.86.0.r883.g41ff4e1-15.86.0.r885.g14f1182-1
qqc2-desktop-style5.86.0.r524.gedc9094-15.86.0.r525.gd726db4-1
sddm-kcm5.22.5.r603.g5e09c6b-15.22.5.r606.g8c7624a-1
spacebar 21.08.r4.g7cb0f94-1 21.08.r5.g7f4a52a-1
spectacle21.08.1.r1167.gf89f2bc-121.08.1.r1168.g9e04460-1
systemsettings5.22.5.r2496.g8f9b9c88-15.22.5.r2497.g7791a403-1
telepathy-kde-accounts-kcm21.08.1.r1195.gd0ffbec-121.08.1.r1196.g27af480-1
umbrello21.08.1.r8264.g7a8d1cfb0-121.08.1.r8265.g50ef037a5-1
vakzination r93.ae8475e-1 r94.aba88d2-1
vvave 2.0.0.r19.ga185d28-1 2.0.0.r22.g61b6756-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
