Hello ARM community.
Rather small update this time. Enjoy!
Waydroid running on Manjaro Plasma Mobile on PinePhone
Some highlights:
- A couple of kernels got updated
- Waydroid got updated, now using LineageOS 17.1
- And KDE Frameworks are now at 5.86
- Vivaldi got a big update to 4.2
- We also updated ModemManager to 1.18
- Lots of Mobile specific packages got updated
- Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Enable the service with
sudo systemctl enable waydroid-container. - Reboot.
- You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Thu Sep 16 20:49:46 CEST 2021)
- arm-testing community aarch64: 259 new and 214 removed package(s)
- arm-testing core aarch64: 17 new and 14 removed package(s)
- arm-testing extra aarch64: 132 new and 135 removed package(s)
- arm-testing kde-unstable aarch64: 244 new and 244 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-09-11 2021-09-16
code 1.60.0-1 1.60.1-1
corepaint 4.2.0-2 4.2.0-3
eg25-manager 0.4.0-6 0.4.0-7
electron 14.0.0-1 14.0.1-1
electron12 12.0.18-1 12.1.1-1
electron13 13.3.0-1 13.4.0-1
element-desktop 1.8.4-0.1 1.8.4-1
element-web 1.8.4-0.1 1.8.4-1
libmm-pp-glib 1.18.0-1 1.18.0-2
modemmanager-pp 1.18.0-1 1.18.0-2
vivaldi 4.1.2369.21-1 4.2.2406.44-1
waydroid 20210730-1 r30.15bbf62-2
libgbinder - 1.1.11-1
libglibutil - 1.0.55-1
python-gbinder - 1.0.0-1
waydroid-image - 17.1_20210913-1
:: Different sync package(s) in repository community aarch64
acme-tiny 4.1.0-2 5.0.1-1
acorn 1:8.4.1-1 1:8.5.0-1
alembic 1.8.2-2 1.8.3-1
ali 0.7.2-1 0.7.3-1
anewer 0.1.5-1 0.1.6-1
ansible-core 2.11.4-1 2.11.5-1
arduino 1:1.8.15-1 1:1.8.16-1
arduino-cli 0.18.3-1 0.19.0-1
asar 3.0.3-1 3.1.0-1
atftp 0.7.4-1 0.7.5-1
auto-multiple-choice 1.4.0-10 1.5.0-1
awesome 4.3-2 4.3-3
batctl 2021.2-1 2021.3-1
binwalk 2.3.2-1 2.3.3-1
bitcoin-cli 0.21.1-2 22.0-1
bitcoin-daemon 0.21.1-2 22.0-1
bitcoin-qt 0.21.1-2 22.0-1
bitcoin-tx 0.21.1-2 22.0-1
blender 17:2.93.4-2 17:2.93.4-3
bottom 0.6.3-2 0.6.4-2
buildah 1.22.3-1 1.23.0-1
cargo-audit 0.15.0-1 0.15.2-1
cargo-udeps 0.1.22-1 0.1.23-1
ccache 4.4-1 4.4.1-1
certbot-apache 1.18.0-1 1.19.0-1
certbot-dns-cloudflare 1.18.0-1 1.19.0-1
certbot-dns-cloudxns 1.18.0-1 1.19.0-1
certbot-dns-digitalocean 1.18.0-1 1.19.0-1
certbot-dns-dnsimple 1.18.0-1 1.19.0-1
certbot-dns-dnsmadeeasy 1.18.0-1 1.19.0-1
certbot-dns-gehirn 1.18.0-1 1.19.0-1
certbot-dns-google 1.18.0-1 1.19.0-1
certbot-dns-linode 1.18.0-1 1.19.0-1
certbot-dns-luadns 1.18.0-1 1.19.0-1
certbot-dns-nsone 1.18.0-1 1.19.0-1
certbot-dns-ovh 1.18.0-1 1.19.0-1
certbot-dns-route53 1.18.0-1 1.19.0-1
certbot-dns-sakuracloud 1.18.0-1 1.19.0-1
certbot-nginx 1.18.0-1 1.19.0-1
chezmoi 2.3.0-1 2.4.0-1
clash 1.7.0-1 1.7.1-1
cobalt 0.16.5-1 0.17.0-1
cockpit 252-1 253-1
cockpit-pcp 252-1 253-1
containers-common 0.43.2-2 0.44.0-1
deno 1.13.2-1 1.14.0-1
dfu-util 0.10-3 0.11-2
dovecot-fts-xapian 1.4.12-2 1.4.13-1
fcitx5-pinyin-zhwiki 1:0.2.3.20210823-1 1:0.2.3.20210911-1
fetchmail 6.4.21-1 6.4.22-1
filezilla 3.55.1-1 3.55.1-2
fio 3.27-1 3.28-1
flawfinder 2.0.18-1 2.0.19-1
fluxctl 1.24.0-1 1.24.1-1
giac 1.7.0.29-1 1.7.0.31-1
giada 0.18.1-1 0.18.2-1
git-cliff 0.2.6-1 0.3.0-1
glewlwyd 2.5.3-2 2.5.4-1
gping 1.2.3-1 1.2.5-1
hcloud 1.28.0-1 1.28.1-1
hcxdumptool 6.2.0-1 6.2.4-1
hcxtools 6.2.0-1 6.2.4-1
home-assistant 2021.9.3-1 2021.9.6-1
hugo 0.87.0-1 0.88.1-1
jedi-language-server 0.34.2-1 0.34.3-1
jenkins 2.311-1 2.312-1
jitterentropy 3.2.0-1 3.3.0-1
josm 18118-1 18193-1
jupyterlab 3.1.11-1 3.1.12-1
jupyterlab-widgets 1.0.1-1 1.0.2-1
keepass 2.48.1-1 2.49-1
kstars 1:3.5.4-1 1:3.5.5-1
kubeone 1.2.3-1 1.3.0-1
latte-dock 0.10.1-1 0.10.2-1
libfilezilla 0.31.1-1 0.32.0-1
libindi 1.9.1-1 1.9.2-1
libopenshot 0.2.5-10 0.2.7-1
libopenshot-audio 0.2.0-1 0.2.2-1
libquotient 0.6.8-1 0.6.9-1
libseat 0.5.0-2 -
libtpms 0.8.5-2 0.8.6-1
lucky-commit 2.0.5-1 2.0.5-2
marked 3.0.3-1 3.0.4-1
mate-themes 3.22.22-1 3.22.23-1
meilisearch 0.21.1-1 0.22.0-1
minitube 3.9-1 3.9.1-1
monit 5.28.1-1 5.29.0-1
mosquitto 2.0.11-1 2.0.12-1
nextcloud-app-deck 1:1.5.2-1 1:1.5.3-1
nextcloud-client 1:3.3.0-1 1:3.3.3-1
nextcloud-client-cloudproviders 1:3.3.0-1 1:3.3.3-1
nomad-driver-containerd 0.9.1-1 0.9.2-1
nushell 0.35.0-3 0.37.0-1
openlibm 0.7.5-1 0.8.0-1
openshot 2.5.1-4 2.6.1-1
opensubdiv 3.4.4-5 3.4.4-6
operator-sdk 1.11.0-1 1.12.0-1
otf-cascadia-code 2106.17-1 2108.26-1
pcp 5.3.2-1 5.3.3-1
pcp-gui 5.3.2-1 5.3.3-1
pcp-pmda-activemq 5.3.2-1 5.3.3-1
pcp-pmda-bcc 5.3.2-1 5.3.3-1
pcp-pmda-bind2 5.3.2-1 5.3.3-1
pcp-pmda-bpftrace 5.3.2-1 5.3.3-1
pcp-pmda-libvirt 5.3.2-1 5.3.3-1
pcp-pmda-mysql 5.3.2-1 5.3.3-1
pcp-pmda-nginx 5.3.2-1 5.3.3-1
pcp-pmda-nutcracker 5.3.2-1 5.3.3-1
pcp-pmda-openmetrics 5.3.2-1 5.3.3-1
pcp-pmda-podman 5.3.2-1 5.3.3-1
pcp-pmda-postgresql 5.3.2-1 5.3.3-1
pcp-pmda-snmp 5.3.2-1 5.3.3-1
perl-sys-virt 7.5.0-1 7.7.0-1
perl-test-mockmodule 0.176.0-3 0.177.0-1
perl-text-template 1.59-2 1.60-1
postorius 1.3.4-2 1.3.5-1
pueue 1.0.1-2 1.0.3-1
pulumi 3.11.0-1 3.12.0-1
pyright 1.1.166-1 1.1.168-1
python-astroid 2.7.3-1 2.8.0-1
python-bidict 0.21.2-2 0.21.3-1
python-cfn-lint 0.54.0-1 0.54.1-1
python-cogapp 3.0.0-5 3.1.0-1
python-debtcollector 2.2.0-3 2.3.0-1
python-django-environ 0.4.5-5 0.7.0-1
python-django-haystack 3.0-4 3.1.1-1
python-django-mailman3 1.3.5-2 1.3.7-1
python-eventlet 0.31.1-1 0.32.0-1
python-fonttools 4.26.2-3 4.27.0-2
python-jupyter_packaging 0.10.4-1 0.10.5-1
python-lsp-server 1.2.1-2 1.2.1-3
python-mailmanclient 3.3.2-1 3.3.3-1
python-markups 3.1.1-1 3.1.2-1
python-mechanize 1:0.4.5-4 1:0.4.6-1
python-more-itertools 8.8.0-1 8.9.0-1
python-networkx 2.6.2-1 2.6.3-1
python-neutronclient 7.5.0-1 7.6.0-1
python-openmdao 3.11.0-1 3.12.0-1
python-openstackclient 5.5.0-1 5.6.0-1
python-oslotest 4.4.1-4 4.5.0-1
python-pillow 8.3.1-1 8.3.2-1
python-pook 1.0.1-4 1.0.2-1
python-progressbar 3.53.1-5 3.53.3-1
python-pyglet 1.5.18-1 1.5.20-1
python-pytest-mock 3.1.1-1 3.6.1-1
python-pytest-xprocess 0.16.0-1 0.18.1-1
python-pythran 0.9.12.post1-1 0.10.0-1
python-qasync 0.20.0-1 0.21.0-1
python-ruamel-yaml 0.17.15-1 0.17.16-1
python-sane 2.8.3-6 2.9.1-1
python-setuptools-scm 6.3.1-1 6.3.2-1
python-sphinx 4.1.2-1 4.2.0-1
python-sphinx_rtd_theme 0.5.2-1 1.0.0-1
python-sphinxcontrib-bibtex 2.3.0-1 2.4.1-1
python-subprocess-tee 0.3.2-1 0.3.4-1
rime-pinyin-zhwiki 1:0.2.3.20210823-1 1:0.2.3.20210911-1
ruby-faraday 1.7.0-1 1.7.2-1
rust-analyzer 20210906-1 20210913-1
serverless 2.57.0-1 2.59.0-1
sniffglue 0.13.0-1 0.13.1-1
soapysdr 0.8.0-1 0.8.1-1
sqlx-cli 0.5.5-2 0.5.7-1
streamlink 2.3.0-1 2.4.0-1
swappy 1.3.1-1 1.4.0-1
thrift 0.14.2-1 0.15.0-1
ttc-iosevka 10.1.1-2 10.2.0-1
ttc-iosevka-aile 10.1.1-2 10.2.0-1
ttc-iosevka-curly 10.1.1-2 10.2.0-1
ttc-iosevka-curly-slab 10.1.1-2 10.2.0-1
ttc-iosevka-etoile 10.1.1-2 10.2.0-1
ttc-iosevka-slab 10.1.1-2 10.2.0-1
ttc-iosevka-ss01 10.1.1-2 10.2.0-1
ttc-iosevka-ss02 10.1.1-2 10.2.0-1
ttc-iosevka-ss03 10.1.1-2 10.2.0-1
ttc-iosevka-ss04 10.1.1-2 10.2.0-1
ttc-iosevka-ss05 10.1.1-2 10.2.0-1
ttc-iosevka-ss06 10.1.1-2 10.2.0-1
ttc-iosevka-ss07 10.1.1-2 10.2.0-1
ttc-iosevka-ss08 10.1.1-2 10.2.0-1
ttc-iosevka-ss09 10.1.1-2 10.2.0-1
ttc-iosevka-ss10 10.1.1-2 10.2.0-1
ttc-iosevka-ss11 10.1.1-2 10.2.0-1
ttc-iosevka-ss12 10.1.1-2 10.2.0-1
ttc-iosevka-ss13 10.1.1-2 10.2.0-1
ttc-iosevka-ss14 10.1.1-2 10.2.0-1
ttc-iosevka-ss15 10.1.1-2 10.2.0-1
ttc-iosevka-ss16 10.1.1-2 10.2.0-1
ttc-iosevka-ss17 10.1.1-2 10.2.0-1
ttc-iosevka-ss18 10.1.1-2 10.2.0-1
ttf-cascadia-code 2106.17-1 2108.26-1
typescript 4.4.2-1 4.4.3-1
ukui-media 3.0.1-1 3.0.3.1-1
v2ray-geoip 202109090028-1 202109102251-1
vaultwarden-web 2.21.1-1 2.22.3-1
verilator 4.210-2 4.212-1
vim-fugitive 3.4-1 3.4-2
web-ext 6.3.0-1 6.4.0-1
wlroots 0.14.1-1 0.14.1-2
woff2-cascadia-code 2106.17-1 2108.26-1
xdiskusage 1.54-1 1.60-1
xh 0.12.0-1 0.12.0-2
xtrabackup 8.0.25_17-1 8.0.26_18-1
python-ansible-compat - 0.5.0-1
python-cbor2 - 5.4.1-2
python-keycloak - 0.26.1-1
python-ufolib2 - 0.11.2-2
rhvoice - 1.4.2-3
rhvoice-language-brazilian-portuguese - 1.4.2-3
rhvoice-language-english - 1.4.2-3
rhvoice-language-esperanto - 1.4.2-3
rhvoice-language-georgian - 1.4.2-3
rhvoice-language-kyrgyz - 1.4.2-3
rhvoice-language-macedonian - 1.4.2-3
rhvoice-language-russian - 1.4.2-3
rhvoice-language-tatar - 1.4.2-3
rhvoice-language-ukrainian - 1.4.2-3
rhvoice-voice-alan - 1.4.2-3
rhvoice-voice-aleksandr - 1.4.2-3
rhvoice-voice-aleksandr-hq - 1.4.2-3
rhvoice-voice-anatol - 1.4.2-3
rhvoice-voice-anna - 1.4.2-3
rhvoice-voice-arina - 1.4.2-3
rhvoice-voice-artemiy - 1.4.2-3
rhvoice-voice-azamat - 1.4.2-3
rhvoice-voice-bdl - 1.4.2-3
rhvoice-voice-clb - 1.4.2-3
rhvoice-voice-elena - 1.4.2-3
rhvoice-voice-evgeniy-eng - 1.4.2-3
rhvoice-voice-evgeniy-rus - 1.4.2-3
rhvoice-voice-irina - 1.4.2-3
rhvoice-voice-kiko - 1.4.2-3
rhvoice-voice-leticia-f123 - 1.4.2-3
rhvoice-voice-natalia - 1.4.2-3
rhvoice-voice-natia - 1.4.2-3
rhvoice-voice-nazgul - 1.4.2-3
rhvoice-voice-pavel - 1.4.2-3
rhvoice-voice-slt - 1.4.2-3
rhvoice-voice-spomenka - 1.4.2-3
rhvoice-voice-talgat - 1.4.2-3
rhvoice-voice-victoria - 1.4.2-3
rhvoice-voice-volodymyr - 1.4.2-3
rhvoice-voice-yuriy - 1.4.2-3
ruby-scanf - 1.0.0-1
seatd - 0.6.1-2
:: Different overlay package(s) in repository core aarch64
fakeroot-qemu 1.25.3-1 1.26-1
linux 5.14.2-1 5.14.5-1
linux-headers 5.14.2-1 5.14.5-1
linux-pinephone 5.14.2-2 5.14.3-1
linux-pinephone-headers 5.14.2-2 5.14.3-1
linux-quartz64 5.14.0-0.7 5.15.0-0.1
linux-quartz64-headers 5.14.0-0.7 5.15.0-0.1
linux-rc 5.14.rc7-5 5.15.rc1-2
linux-rc-headers 5.14.rc7-5 5.15.rc1-2
pacman 6.0.1-5 6.0.1-6
pacman-debug 6.0.1-5 6.0.1-6
:: Different sync package(s) in repository core aarch64
fakeroot 1.25.3-2 1.26-1
netctl 1.25-1 1.26-1
sudo 1.9.7.p2-1 1.9.8-1
brotli - 1.0.9-4
brotli-testdata - 1.0.9-4
python-brotli - 1.0.9-4
:: Different overlay package(s) in repository extra aarch64
mesa-git21.3.0_devel.144490.43c4f5eb63e-121.3.0_devel.144712.138463d3c3e-1
:: Different sync package(s) in repository extra aarch64
archlinux-appstream-data 20210902-1 20210921-1
attica 5.85.0-1 5.86.0-1
baloo 5.85.0-1 5.86.0-1
bluez-qt 5.85.0-1 5.86.0-1
breeze-icons 5.85.0-1 5.86.0-1
brotli 1.0.9-4 -
brotli-testdata 1.0.9-4 -
chromium 93.0.4577.63-1 93.0.4577.82-1
composer 2.1.6-1 2.1.8-1
devtools 20210202-2 20210202-3
dkms 2.8.6-1 2.8.6-2
dnsmasq 2.85-1 2.86-1
extra-cmake-modules 5.85.0-1 5.86.0-1
fftw 3.3.9-1 3.3.10-1
fluidsynth 2.2.2-1 2.2.3-1
frameworkintegration 5.85.0-1 5.86.0-1
gd 2.3.2-4 2.3.3-1
gdb 10.2-2 11.1-1
gdb-common 10.2-2 11.1-1
ghostpcl 9.54.0-2 9.54.0-3
ghostscript 9.54.0-2 9.54.0-3
ghostxps 9.54.0-2 9.54.0-3
gimp 2.10.26-1 2.10.28-1
gtkmm-4.0 4.2.0-2 4.4.0-1
gtkmm-4.0-docs 4.2.0-2 4.4.0-1
gvim 8.2.3412-1 8.2.3441-1
imagemagick 7.1.0.6-1 7.1.0.7-1
imagemagick-doc 7.1.0.6-1 7.1.0.7-1
jemalloc 1:5.2.1-3 1:5.2.1-5
kactivities 5.85.0-1 5.86.0-1
kactivities-stats 5.85.0-1 5.86.0-1
kapidox 5.85.0-1 5.86.0-1
karchive 5.85.0-1 5.86.0-1
kauth 5.85.0-1 5.86.0-1
kbookmarks 5.85.0-1 5.86.0-1
kcalendarcore 5.85.0-1 5.86.0-1
kcmutils 5.85.0-1 5.86.0-1
kcodecs 5.85.0-1 5.86.0-1
kcompletion 5.85.0-1 5.86.0-1
kconfig 5.85.0-1 5.86.0-1
kconfigwidgets 5.85.0-1 5.86.0-1
kcontacts 1:5.85.0-1 1:5.86.0-1
kcoreaddons 5.85.0-1 5.86.0-1
kcrash 5.85.0-1 5.86.0-1
kdav 1:5.85.0-1 1:5.86.0-1
kdbusaddons 5.85.0-1 5.86.0-1
kdeclarative 5.85.0-1 5.86.0-1
kded 5.85.0-1 5.86.0-1
kdelibs4support 5.85.0-1 5.86.0-1
kdesignerplugin 5.85.0-1 5.86.0-1
kdesu 5.85.0-1 5.86.0-1
kdewebkit 5.85.0-1 5.86.0-1
kdnssd 5.85.0-1 5.86.0-1
kdoctools 5.85.0-1 5.86.0-1
kemoticons 5.85.0-1 5.86.0-1
kfilemetadata 5.85.0-1 5.86.0-1
kglobalaccel 5.85.0-1 5.86.0-1
kguiaddons 5.85.0-1 5.86.0-1
kholidays 1:5.85.0-1 1:5.86.0-1
khtml 5.85.0-1 5.86.0-1
ki18n 5.85.0-1 5.86.0-1
kiconthemes 5.85.0-1 5.86.0-1
kidletime 5.85.0-1 5.86.0-1
kimageannotator 0.5.1-1 0.5.2-1
kimageformats 5.85.0-1 5.86.0-1
kinit 5.85.0-1 5.86.0-1
kio 5.85.0-1 5.86.0-1
kirigami2 5.85.0-1 5.86.0-1
kitemmodels 5.85.0-1 5.86.0-1
kitemviews 5.85.0-1 5.86.0-1
kjobwidgets 5.85.0-1 5.86.0-1
kjs 5.85.0-1 5.86.0-1
kjsembed 5.85.0-1 5.86.0-1
kmediaplayer 5.85.0-1 5.86.0-1
knewstuff 5.85.0-1 5.86.0-1
knotifications 5.85.0-1 5.86.0-1
knotifyconfig 5.85.0-1 5.86.0-1
kpackage 5.85.0-1 5.86.0-1
kparts 5.85.0-1 5.86.0-1
kpeople 5.85.0-1 5.86.0-1
kplotting 5.85.0-1 5.86.0-1
kpty 5.85.0-1 5.86.0-1
kquickcharts 5.85.0-1 5.86.0-1
kross 5.85.0-1 5.86.0-1
krunner 5.85.0-1 5.86.0-1
kservice 5.85.0-1 5.86.0-1
ktexteditor 5.85.0-1 5.86.0-1
ktextwidgets 5.85.0-1 5.86.0-1
kunitconversion 5.85.0-1 5.86.0-1
kwallet 5.85.0-1 5.86.0-1
kwayland 5.85.0-1 5.86.0-1
kwidgetsaddons 5.85.0-1 5.86.0-1
kwindowsystem 5.85.0-1 5.86.0-1
kxmlgui 5.85.0-1 5.86.0-1
kxmlrpcclient 5.85.0-1 5.86.0-1
ladspa 1.16-1 1.17-1
libass 0.15.1-1 0.15.2-1
libbpf 0.4.0-1 0.5.0-1
libexif 0.6.22-1 0.6.23-1
libmm-glib 1.16.10-1 1.18.0-1
libwebp 1.2.1-1 1.2.1-2
libxkbcommon 1.3.0-1 1.3.1-1
libxkbcommon-doc 1.3.0-1 1.3.1-1
libxkbcommon-x11 1.3.0-1 1.3.1-1
modemmanager 1.16.10-1 1.18.0-1
modemmanager-qt 5.85.0-1 5.86.0-1
mutt 2.1.2-1 2.1.3-1
networkmanager-qt 5.85.0-1 5.86.0-1
oxygen-icons 1:5.85.0-1 1:5.86.0-1
oxygen-icons-svg 1:5.85.0-1 1:5.86.0-1
pango 1:1.48.9-2 1:1.48.10-1
pango-docs 1:1.48.9-2 1:1.48.10-1
plasma-framework 5.85.0-2 5.86.0-1
prison 5.85.0-1 5.86.0-1
purpose 5.85.0-1 5.86.0-1
python-brotli 1.0.9-4 -
qca-qt5 2.3.3-1 2.3.4-1
qca-qt6 2.3.3-1 2.3.4-1
qqc2-desktop-style 5.85.0-1 5.86.0-1
qt5-base 5.15.2+kde+r222-2 5.15.2+kde+r224-1
qt5-xcb-private-headers 5.15.2+kde+r222-2 5.15.2+kde+r224-1
qtcreator 5.0.0-3 5.0.1-1
sdl2_mixer 2.0.4-6 2.0.4-7
solid 5.85.0-1 5.86.0-1
sonnet 5.85.0-1 5.86.0-1
syndication 5.85.0-1 5.86.0-1
syntax-highlighting 5.85.0-1 5.86.0-1
threadweaver 5.85.0-1 5.86.0-1
thunar 4.16.8-1 4.16.9-1
tomcat8 8.5.70-1 8.5.71-1
vim-runtime 8.2.3412-1 8.2.3441-1
wireguard-tools 1.0.20210424-1 1.0.20210914-1
xkeyboard-config 2.33-1 2.33-2
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.08.1.r12575.g7cc57d6a2-121.08.1.r12587.g58d60c677-1
akonadi-calendar21.08.1.r1984.g1192e6d-121.08.1.r1987.gd71f672-1
akonadi-calendar-tools21.08.1.r898.gc804ef5-121.08.1.r900.g0a8982d-1
akonadi-contacts21.08.1.r3061.g94013a3a-121.08.1.r3064.g3849f713-1
akonadi-import-wizard21.08.1.r1739.gf5e8060-121.08.1.r1743.g225698e-1
akonadi-mime21.08.1.r1648.g3dd0baa-121.08.1.r1651.g1083dd0-1
akonadi-notes21.08.1.r1025.g2552b56-121.08.1.r1027.g1464a2e-1
akonadi-search21.08.1.r1126.gf440581-121.08.1.r1127.g8401fa9-1
akonadiconsole21.08.1.r1526.g89dc082-121.08.1.r1529.g65a1e13-1
akregator21.08.1.r6222.g6f6395e6-121.08.1.r6225.gb5a43fac-1
angelfish 21.08.r9.gf8e31f6-1 21.08.r10.g909da15-1
attica5.85.0.r834.g0dbf2b6-15.86.0.r834.g0dbf2b6-1
baloo5.85.0.r3008.g8909640a-15.86.0.r3008.g8909640a-1
bluedevil1:5.22.5.r2280.gde1e0734-11:5.22.5.r2286.gecfbaddd-1
bluez-qt5.85.0.r679.gba3af75-15.86.0.r679.gba3af75-1
breeze5.22.5.r2242.g3082f37f-15.22.5.r2257.g1b6dc846-1
breeze-gtk5.22.5.r422.g4db54ea-15.22.5.r424.ga961433-1
breeze-icons5.85.0.r1789.g9089f648-15.86.0.r1790.g2e367293-1
buho 2.0.0.r5.g343a468-1 2.0.0.r7.g185655a-1
calendarsupport21.08.1.r33.gbd875a6-121.08.1.r36.g5449ae3-1
calindori 21.08.r0.gf739058-1 21.08.r1.g5add1b8-1
discover5.22.5.r8298.g48ee793f-15.22.5.r8304.g4c9538dd-1
dolphin21.08.1.r6705.gde7c7ca27-121.08.1.r6706.gcaa4afc15-1
drkonqi5.22.5.r684.gace905b0-15.22.5.r698.gf31ee17e-1
eventviews21.08.1.r37.g755eaa6-121.08.1.r39.g2f75642-1
extra-cmake-modules5.85.0.r3365.g4282b34-15.86.0.r3366.g6005d78-1
frameworkintegration5.85.0.r598.g0a57fd9-15.86.0.r598.g0a57fd9-1
grantlee-editor21.08.1.r770.g421e4df-121.08.1.r772.g536e258-1
grantleetheme21.08.1.r344.g22b988b-121.08.1.r345.gc8462fc-1
gwenview21.08.1.r6662.g33d6203c-121.08.1.r6676.g69e0d06e-1
incidenceeditor21.08.1.r768.gf7a43aa-121.08.1.r770.g053b758-1
index-fm 2.0.0.r13.g9cb6e72-1 2.0.0.r18.ge90331e-1
itinerary21.08.1.r1449.gb408488-121.08.1.r1450.g35704d3-1
k3b1:21.08.1.r6674.g08de2191e-11:21.08.1.r6675.g9e099ffe9-1
kaccounts-integration21.08.1.r1218.g3a0486d-121.08.1.r1221.g4c3deb8-1
kactivities5.85.0.r1363.g207c2dc-15.86.0.r1363.g207c2dc-1
kactivities-stats5.85.0.r372.g195fbd2-15.86.0.r372.g195fbd2-1
kaddressbook21.08.1.r6040.g62ccc2ec-121.08.1.r6045.ge7cf4a23-1
kalarm21.08.1.r6463.g0af8aa34-121.08.1.r6465.g542abb2d-1
kalarmcal21.08.1.r1145.g4deaf3c-121.08.1.r1146.g321d543-1
kamera21.08.1.r665.gd8ad7f5-121.08.1.r666.g28de32a-1
kapidox5.85.0.r553.g8ac0bf3-15.86.0.r553.g8ac0bf3-1
karchive5.85.0.r507.g858a749-15.86.0.r507.g858a749-1
kasts 21.08.r7.g938a517-1 21.08.r9.gd7ac052-1
kate21.08.1.r18345.g2636bb3a9-121.08.1.r18365.g915aa496b-1
kauth5.85.0.r449.ga6a0c5a-15.86.0.r449.ga6a0c5a-1
kbackup21.08.1.r394.gddcd002-121.08.1.r395.gf140c80-1
kbookmarks5.85.0.r422.g7d0378a-15.86.0.r422.g7d0378a-1
kbreakout21.08.1.r865.g9e21fa5-121.08.1.r866.g56f83fc-1
kcachegrind21.08.1.r1152.gbe3f69d-121.08.1.r1154.gb65ced6-1
kcachegrind-common21.08.1.r1152.gbe3f69d-121.08.1.r1154.gb65ced6-1
kcalc21.08.1.r1522.g1524f0a-121.08.1.r1530.gc94d383-1
kcalendarcore5.85.0.r1239.g10cfe8918-15.86.0.r1239.g10cfe8918-1
kcalutils21.08.1.r871.g7ffcc18f3-121.08.1.r873.g6f9860860-1
kcmutils5.85.0.r548.g5e7c27f-15.86.0.r548.g5e7c27f-1
kcodecs5.85.0.r386.g5e7feae-15.86.0.r386.g5e7feae-1
kcompletion5.85.0.r457.g04f8bcb-15.86.0.r457.g04f8bcb-1
kconfig5.85.0.r863.g7827501-15.86.0.r863.g7827501-1
kconfigwidgets5.85.0.r621.g652be62-15.86.0.r621.g652be62-1
kcontacts1:5.85.0.r3254.g7ff774b3-11:5.86.0.r3254.g7ff774b3-1
kcoreaddons5.85.0.r1292.g49d1ce7f-15.86.0.r1297.g7f17d726-1
kcrash5.85.0.r409.gf0a9e01-15.86.0.r409.gf0a9e01-1
kcron21.08.1.r778.gec9a965-121.08.1.r779.g57e8a16-1
kdav1:5.85.0.r1300.gbb550f6-11:5.86.0.r1300.gbb550f6-1
kdbusaddons5.85.0.r380.g54bc427-15.86.0.r381.gd645ec3-1
kde-cli-tools5.22.5.r1862.g927db99-15.22.5.r1864.gf75b811-1
kde-gtk-config5.22.5.r910.g31496c4-15.22.5.r912.g94c85f5-1
kdebugsettings21.08.1.r848.gabcfb20-121.08.1.r850.gb41d7c2-1
kdeclarative5.85.0.r922.gbfe8ca1-15.86.0.r922.gbfe8ca1-1
kdeconnect21.08.1.r3321.gdb697c56-121.08.1.r3325.g9d5dcc99-1
kdecoration5.22.5.r269.gbd1fc8d-15.22.5.r271.g957feca-1
kded5.85.0.r418.gb278fc4-15.86.0.r418.gb278fc4-1
kdelibs4support5.85.0.r1037.g34b4edc2-15.86.0.r1037.g34b4edc2-1
kdenetwork-filesharing21.08.1.r892.gc00b69f-121.08.1.r893.g2bb027c-1
kdenlive21.08.0.r14776.gf44f74d7d-121.08.1.r14881.g81d83a72b-1
kdepim-addons21.08.1.r4330.g432ec4f4-121.08.1.r4339.gb392c577-1
kdepim-runtime21.08.1.r15275.g6ef03229b-121.08.1.r15288.gaeb77f624-1
kdeplasma-addons5.22.5.r8583.g350b81a81-15.22.5.r8585.g9e62a25f0-1
kdesignerplugin5.85.0.r336.g9733059-15.86.0.r336.g9733059-1
kdesu5.85.0.r476.ge88b633-15.86.0.r476.ge88b633-1
kdewebkit5.85.0.r283.g787f1a3-15.86.0.r283.g787f1a3-1
kdf21.08.1.r801.gc53ce1a-121.08.1.r803.g64c8456-1
kdnssd5.85.0.r326.g695a135-15.86.0.r326.g695a135-1
kdoctools5.85.0.r629.gfbd4377-15.86.0.r629.gfbd4377-1
keditbookmarks21.08.1.r2747.ge96a0c3cc-121.08.1.r2748.gb8b636c66-1
kemoticons5.85.0.r387.g1c526eb-15.86.0.r387.g1c526eb-1
kfilemetadata5.85.0.r809.gec8cde7-15.86.0.r809.gec8cde7-1
kfloppy21.08.1.r757.g486bdef-121.08.1.r758.gd252d04-1
kgamma55.22.5.r457.g45f405d-15.22.5.r459.g57abda6-1
kget21.08.1.r3121.g8d673262-121.08.1.r3122.g01e48861-1
kglobalaccel5.85.0.r468.gc5ee700-15.86.0.r468.gc5ee700-1
kguiaddons5.85.0.r391.ga846d64-15.86.0.r391.ga846d64-1
kholidays1:5.85.0.r959.g3a5164e-11:5.86.0.r960.g4287dd7-1
khotkeys5.22.5.r2092.gfe5c2a8-15.22.5.r2094.gc6f4cb9-1
khtml5.85.0.r558.g5756c1e-15.86.0.r558.g5756c1e-1
ki18n5.85.0.r480.g8a8d70c-15.86.0.r480.g8a8d70c-1
kiconthemes5.85.0.r544.gf721a67-15.86.0.r544.gf721a67-1
kidentitymanagement21.08.1.r3821.g4a32d4d5-121.08.1.r3822.g6472f7ce-1
kidletime5.85.0.r318.geb71712-15.86.0.r318.geb71712-1
kimageformats5.85.0.r359.g45cd128-15.86.0.r359.g45cd128-1
kimap21.08.1.r1112.g5f3509e-121.08.1.r1114.g8373182-1
kinfocenter5.22.5.r1922.g003f003-15.22.5.r1929.gf263079-1
kinit5.85.0.r413.ga0c6715-15.86.0.r413.ga0c6715-1
kio5.85.0.r4965.gae2f5eb9-15.86.0.r4984.gfb48159b-1
kio-extras21.08.1.r7115.g90d10ae7-121.08.1.r7116.g395ae54b-1
kirigami25.85.0.r2886.g07abb970-15.86.0.r2889.gd97773ed-1
kitemmodels5.85.0.r559.gfa3b693-15.86.0.r559.gfa3b693-1
kitemviews5.85.0.r341.g39dc29e-15.86.0.r341.g39dc29e-1
kitinerary21.08.1.r1934.g1864c3e-121.08.1.r1940.g731b078-1
kjobwidgets5.85.0.r379.ge71984a-15.86.0.r379.ge71984a-1
kjs5.85.0.r337.g2cf609d-15.86.0.r337.g2cf609d-1
kjsembed5.85.0.r306.gaaf5dd2-15.86.0.r306.gaaf5dd2-1
kldap21.08.1.r885.g599501c-121.08.1.r887.g8d01d48-1
kleopatra21.08.1.r5991.gba72eade-121.08.1.r5996.g24dd062d-1
kmail21.08.1.r25957.g3fd1720a9-121.08.1.r25968.g9aaf1ab55-1
kmail-account-wizard21.08.1.r816.g9cadf59-121.08.1.r820.g7cfb5bc-1
kmailtransport21.08.1.r1656.g08cf010-121.08.1.r1658.gaabd283-1
kmbox21.08.1.r541.gf32ef3c-121.08.1.r543.gd622575-1
kmediaplayer5.85.0.r297.g7315fa5-15.86.0.r297.g7315fa5-1
kmenuedit5.22.5.r971.g4b52f0c-15.22.5.r973.g7dd69ed-1
kmime21.08.1.r1458.g103179b-121.08.1.r1459.gb438f9f-1
knewstuff5.85.0.r1204.g5c08bbb3-15.86.0.r1207.g37a38190-1
knotes21.08.1.r3516.g6cf6d5b7-121.08.1.r3519.g4d173e29-1
knotifications5.85.0.r680.g471bd77-15.86.0.r680.g471bd77-1
knotifyconfig5.85.0.r355.gee646b9-15.86.0.r355.gee646b9-1
koko 21.08.r4.g4437b03-1 21.08.r12.g25ea616-1
konsole21.08.1.r7941.gab25bd0a-121.08.1.r7942.g51ab3770-1
kontact21.08.1.r5382.gdeba0f99-121.08.1.r5386.g107a6a4b-1
kontactinterface21.08.1.r633.g73a7a65-121.08.1.r634.gaaf989a-1
kopete20.12.2.r16394.g1decd7b40-121.08.1.r16397.ga5ea75f5f-1
korganizer21.08.1.r11497.g85fb36087-121.08.1.r11502.g9e36933f8-1
kosmindoormap21.08.1.r647.g14f654a-121.08.1.r657.g56c4904-1
kpackage5.85.0.r699.g3e01da3-15.86.0.r699.g3e01da3-1
kparts5.85.0.r527.gcb16108-15.86.0.r528.gfa6ae49-1
kpeople5.85.0.r1346.g96ddb92-15.86.0.r1346.g96ddb92-1
kpimtextedit21.08.1.r1409.g490343b-121.08.1.r1424.g4038649-1
kpkpass21.08.1.r239.gfd23c58-121.08.1.r241.g9730a32-1
kplotting5.85.0.r296.g3060059-15.86.0.r296.g3060059-1
kpty5.85.0.r343.g75750f0-15.86.0.r343.g75750f0-1
kpublictransport21.08.1.r1836.gc41cbf5e-121.08.1.r1841.gc558aafe-1
kquickcharts5.85.0.r480.g627c40f-15.86.0.r480.g627c40f-1
kquickimageeditor r56.g9273b40-1 r59.gde1a380-1
krdc21.08.1.r1537.gab2a1a3-121.08.1.r1539.g8111867-1
krecorder 21.08.r2.gb7676d0-1 21.08.r3.g2214cdf-1
kross5.85.0.r337.g7db053c-15.86.0.r337.g7db053c-1
kruler21.08.1.r701.ge556d0a-121.08.1.r702.g97633ef-1
krunner5.85.0.r670.gd53c5c2-15.86.0.r670.gd53c5c2-1
kscreen5.22.5.r1352.g7b2ecb9-15.22.5.r1361.g0f5d8dd-1
kscreenlocker5.22.5.r871.g7157c9a-15.22.5.r876.g716e099-1
kservice5.85.0.r944.g927daaf-15.86.0.r944.g927daaf-1
ksmtp21.08.1.r368.g0caf31f-121.08.1.r372.g5d96c21-1
ksshaskpass5.22.5.r197.gcc50f63-15.22.5.r199.g1940b3e-1
ksystemlog21.08.1.r659.g83fd7a3-121.08.1.r660.gca438d0-1
ksystemstats5.22.5.r193.g207b896-15.22.5.r195.g328fb1f-1
ktexteditor5.85.0.r2942.g6fae77cf-15.86.0.r2943.g6507add2-1
ktextwidgets5.85.0.r414.g8901446-15.86.0.r414.g8901446-1
ktnef21.08.1.r665.g8ff8b40-121.08.1.r668.gd23f1e0-1
kunitconversion5.85.0.r378.g6e34b50-15.86.0.r378.g6e34b50-1
kwallet5.85.0.r1091.gf379e5f-15.86.0.r1091.gf379e5f-1
kwallet-pam5.22.5.r253.g258c428-15.22.5.r255.ga5dd462-1
kwalletmanager21.08.1.r1208.g0a74834-121.08.1.r1210.ga5e4b13-1
kwayland5.85.0.r1114.gc662581-15.86.0.r1114.gc662581-1
kwayland-integration5.22.5.r186.g11769dd-15.22.5.r189.gda7ddbb-1
kwayland-server5.22.5.r1386.ga6a4760-15.22.5.r1388.gf6fa493-1
kweather 21.08.r8.gb00ec36-1 21.08.r11.g1208e0a-1
kwidgetsaddons5.85.0.r874.g05a6fcfd-15.86.0.r874.g05a6fcfd-1
kwin5.22.5.r19986.gabe6b4153-15.22.5.r20000.g35ff7eb0e-1
kwindowsystem5.85.0.r628.g5d08848-15.86.0.r628.g5d08848-1
kwinft5.22.4.r19295.g053293198-15.22.4.r19304.g1b438d8a7-1
kwrite21.08.1.r18345.g2636bb3a9-121.08.1.r18365.g915aa496b-1
kwrited5.22.5.r482.g9548753-15.22.5.r484.g25fc24c-1
kxmlgui5.85.0.r808.g319b9318-15.86.0.r809.g0f2608f3-1
kxmlrpcclient5.85.0.r458.ga1ec55b43-15.86.0.r458.ga1ec55b43-1
layer-shell-qt5.21.5.r43.g331505a-15.21.5.r46.g06815f2-1
libakonadi21.08.1.r12575.g7cc57d6a2-121.08.1.r12587.g58d60c677-1
libgravatar21.08.1.r369.gbb3111c-121.08.1.r370.g7a5a285-1
libkdepim21.08.1.r850.gf067cdb-121.08.1.r851.g98eefb0-1
libkgapi21.08.1.r1296.gad7e812-121.08.1.r1297.g636bd28-1
libkleo21.08.1.r933.g7a08864-121.08.1.r935.gadc7cac-1
libkscreen5.22.5.r1591.g94b5c19-15.22.5.r1594.g29eee17-1
libksieve21.08.1.r1586.gfaa0e310-121.08.1.r1591.g50f92b36-1
libksysguard5.22.5.r2302.g8f49602-15.22.5.r2306.gf349605-1
libquotient r2081.g9e548e0-1 r2104.g88a51b8-1
mailcommon21.08.1.r1112.gbc29098-121.08.1.r1115.ge92f626-1
mailimporter21.08.1.r473.g45e02ff-121.08.1.r474.ga51c10c-1
maliit-framework0.99.1.r71.g3ef56e25-10.99.1.r79.g3bf69f37-1
maliit-keyboard r2105.ge373c9fc-1 r2113.g94350854-1
maui-clip 2.0.0.r6.g2a69c67-1 2.0.0.r7.g1688cd2-1
maui-pix 2.0.0.r4.g5e04d12-1 2.0.0.r9.g43a2ceb-1
mauikit 2.0.1.r7.gfbb3e9da-12.0.1.r17.g94f4a141-1
mauikit-filebrowsing 2.0.1.r3.g7ec385a-1 2.0.1.r4.g7b9f7d4-1
mbox-importer21.08.1.r516.g42efae8-121.08.1.r519.ga2c0a5e-1
messagelib21.08.1.r6179.ge28d6ce3-121.08.1.r6191.g42131120-1
milou5.22.5.r748.gc10c48c-15.22.5.r750.gb598453-1
modemmanager-qt5.85.0.r523.gc4fd1f1-15.86.0.r523.gc4fd1f1-1
neochat r1858.gaf299257-1 r1859.g9d4151dd-1
networkmanager-qt5.85.0.r1121.g95baae9-15.86.0.r1121.g95baae9-1
okular21.08.1.r9466.g3a513f34b-121.08.1.r9471.ge6c6e5225-1
oxygen5.22.5.r4426.g30a5d585-15.22.5.r4429.g1afa6e27-1
oxygen-icons1:5.85.0.r5.gbff159d-11:5.86.0.r5.gbff159d-1
oxygen-icons-svg1:5.85.0.r5.gbff159d-11:5.86.0.r5.gbff159d-1
pim-data-exporter21.08.1.r2451.gaf562344-121.08.1.r2454.gee3deea9-1
pim-sieve-editor21.08.1.r1511.ga77b0c7-121.08.1.r1513.g820300a-1
pimcommon21.07.80.r1106.ge73d898-121.07.80.r1110.gbbbee26-1
plasma-browser-integration5.22.5.r1278.g9d9726f2-15.22.5.r1280.g6a09d84a-1
plasma-desktop5.22.5.r8607.g81dbc710b-15.22.5.r8616.gb5b6a472d-1
plasma-dialer 21.08.r2.gae2c182-1 21.08.r3.g270dfd0-1
plasma-disks5.22.5.r229.g920cbc0-15.22.5.r232.g76f263d-1
plasma-firewall5.22.5.r510.g6558f6c-15.22.5.r516.g785acb5-1
plasma-framework5.85.0.r15979.gb869a784a-15.86.0.r15979.gb869a784a-1
plasma-integration5.22.5.r532.g04ac5f9-15.22.5.r534.gb8df483-1
plasma-mobile-nm5.22.3.r3090.g06eacc57-15.22.3.r3094.g1963a3de-1
plasma-nano5.21.5.r158.g85d2916-15.21.5.r159.gd9b5281-1
plasma-nm5.22.5.r3090.g06eacc57-15.22.5.r3097.g9ddd19e1-1
plasma-pa5.22.5.r964.ga54c0e6-15.22.5.r968.g61a0851-1
plasma-phone-components5.22.5.r1462.g30344fd6-15.22.5.r1468.gc4903c25-1
plasma-phonebook 21.08.r6.g7ab0b99-1 21.08.r8.g129f8dc-1
plasma-sdk5.22.5.r2278.g28233174-15.22.5.r2280.g2e8f59ef-1
plasma-settings 21.08.r3.g3c44ea6-1 21.08.r9.g8847cd2-1
plasma-systemmonitor5.22.5.r483.g4da01f9-15.22.5.r485.gea280be-1
plasma-thunderbolt5.22.5.r140.g4c9d324-15.22.5.r143.g6d4ef24-1
plasma-vault5.22.5.r342.g83b045a-15.22.5.r345.g89b8e20-1
plasma-wayland-session5.22.5.r10631.g368143329-15.22.5.r10651.g47c897e94-1
plasma-workspace5.22.5.r10631.g368143329-15.22.5.r10651.g47c897e94-1
plasma-workspace-wallpapers5.22.5.r283.g2c3ee31-15.22.5.r290.ga50a8dc-1
polkit-kde-agent5.22.5.r502.g9fabd61-15.22.5.r504.ga704857-1
powerdevil5.22.5.r2469.g7b7e37df-15.22.5.r2474.gc3efed30-1
print-manager21.08.1.r1040.g710cbb9-121.08.1.r1044.g85ca95c-1
prison5.85.0.r333.g9105c2d-15.86.0.r333.g9105c2d-1
purpose5.85.0.r880.g32bb1ad-15.86.0.r883.g41ff4e1-1
qcachegrind21.08.1.r1152.gbe3f69d-121.08.1.r1154.gb65ced6-1
qqc2-breeze-style5.22.5.r223.gef75e0b-15.22.5.r226.g79a2163-1
qqc2-desktop-style5.85.0.r523.g316fed5-15.86.0.r524.gedc9094-1
sddm0.19.0.r62.gd2b4ad0-10.19.0.r63.g83e1ae5-1
sddm-kcm5.22.5.r598.g9022354-15.22.5.r603.g5e09c6b-1
solid5.85.0.r707.g483eba0-15.86.0.r707.g483eba0-1
sonnet5.85.0.r634.gff5ae47-15.86.0.r634.gff5ae47-1
spacebar 21.08.r2.g5bd9368-1 21.08.r4.g7cb0f94-1
syndication5.85.0.r841.gec613d1-15.86.0.r841.gec613d1-1
syntax-highlighting5.85.0.r1696.gd277eb41-15.86.0.r1696.gd277eb41-1
systemsettings5.22.5.r2490.gd0362a47-15.22.5.r2496.g8f9b9c88-1
threadweaver5.85.0.r512.gd9c6fbc-15.86.0.r512.gd9c6fbc-1
vvave 2.0.0.r17.gada7ee6-1 2.0.0.r19.ga185d28-1
xdg-desktop-portal-kde5.22.5.r383.gdbb4364-15.22.5.r385.ga2b7c05-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
