[ARM Testing Update] 2021-09-01 - Phosh, Plamo, Plasma and kernels
Hello ARM community.
Rather small update this time. Enjoy!
Some highlights:
  • Most of our kernels got updated
  • Electron got updated to version 14.0.0
  • And Plasma got a new point release, bringing it to 5.22.5
  • PlaMo Gear got updated to 21.08
  • Also Phosh was updated to 0.13.1
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Wed Sep 1 13:57:26 CEST 2021)
  • arm-testing community aarch64: 154 new and 151 removed package(s)
  • arm-testing core aarch64: 18 new and 18 removed package(s)
  • arm-testing extra aarch64: 90 new and 90 removed package(s)
  • arm-testing kde-unstable aarch64: 315 new and 315 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE           2021-08-29           2021-09-01
                           alligator              21.07-1              21.08-1
                           angelfish              21.07-1              21.08-1
                           audiotube                0.1-2              21.08-1
                           bitwarden             1.28.2-1             1.28.2-3
                           calindori              21.07-1              21.08-1
                          callaudiod   0.1.0+4+g84ed2eb-1   0.1.0+4+g84ed2eb-2
                               calls  0.3.4+42+gcad39e0-1 41beta+20+g501398f-1
                              chatty  0.3.4+24+gb0eb83c-10.4.0beta+10+g0be949d-1
                            electron             13.2.3-1             14.0.0-1
                          electron11            11.4.12-1             11.5.0-1
                     element-desktop              1.8.1-1              1.8.2-1
                         element-web              1.8.1-1              1.8.2-1
                                kalk              21.07-1              21.08-1
                               kasts              21.07-1              21.08-1
                              kclock              21.07-1              21.08-1
                            keysmith              21.07-1              21.08-1
                                koko              21.07-1              21.08-1
                            kongress              21.07-1              21.08-1
                           krecorder              21.07-1              21.08-1
                               ktrip              21.07-1              21.08-1
                            kweather              21.07-1              21.08-1
                               phosh 0.12.1+28+ge2d34c2-2             0.13.1-1
                       plasma-dialer              21.07-1              21.08-1
                    plasma-phonebook              21.07-1              21.08-1
                     plasma-settings              21.07-1              21.08-1
                          qmlkonsole              21.07-1              21.08-1
                            spacebar              21.07-3              21.08-1
                           timeshift20.11.1.r28.gefed117-220.11.1+28+gefed117-1
                             tokodon              21.07-1              21.08-1
                         vakzination                0.1-3                0.1-4
                                vvmd                0.3-1              0.3.1-2
                          electron13                    -             13.3.0-1
                           vvmplayer                    -                1.1-1
:: Different sync package(s) in repository community aarch64
                          aliyun-cli             3.0.89-1             3.0.90-1
                 appstream-generator              0.8.4-2              0.8.5-1
                           bctoolbox              5.0.5-1             5.0.13-1
                           bibletime              3.0.1-1              3.0.2-1
                                 bpf               5.13-1               5.14-1
                       budgie-extras              1.1.0-2             1.2.90-1
                               bzrtp              5.0.5-1             5.0.13-1
                               caddy              2.4.3-1              2.4.4-1
               cgroup_event_listener               5.13-1               5.14-1
                             chezmoi              2.1.6-1              2.2.0-1
                          cockatrice              2.8.0-4              2.8.0-5
                              cosign              1.0.1-1              1.1.0-1
                            cpupower               5.13-1               5.14-1
                               cryfs             0.10.3-1             0.11.0-1
                            dfu-util               0.10-1               0.10-2
                      discord-canary            0.0.127-1                    -
                               doctl             1.63.1-1             1.64.0-1
                             e-antic              1.0.2-1              1.0.3-1
                              gifski              1.4.0-1              1.5.0-1
                          gpio-utils               5.13-1               5.14-1
                             hashcat            1:6.2.3-1            1:6.2.4-1
                              hyperv               5.13-1               5.14-1
                           iio-utils               5.13-1               5.14-1
                       jitterentropy              3.1.0-1              3.2.0-1
                                jmol           14.31.51-1           14.31.52-1
                               jsmol           14.31.51-1           14.31.52-1
                          jupyterlab              3.1.6-1              3.1.9-1
                             kak-lsp             10.0.0-1             11.0.0-1
                             kakoune         2021.08.28-1         2021.08.28-2
                          libalkimia              8.0.4-1              8.1.0-1
                         libquotient              0.6.7-1              0.6.8-1
                    linux-tools-meta               5.13-1               5.14-1
                           liquidctl              1.7.0-1              1.7.1-1
                                mame              0.234-1              0.235-1
                          mame-tools              0.234-1              0.235-1
                                mat2             0.12.1-1             0.12.2-1
                      matrix-synapse             1.39.0-2             1.40.0-1
                             mauikit              2.0.0-1              2.0.1-1
                    mauikit-accounts              2.0.0-1              2.0.1-1
                mauikit-filebrowsing              2.0.0-1              2.0.1-1
                  mauikit-imagetools              2.0.0-1              2.0.1-1
                  mauikit-texteditor              2.0.0-1              2.0.1-1
                       mediastreamer              5.0.6-1             5.0.13-1
                         meilisearch             0.20.0-1             0.21.1-1
                           miniserve             0.15.0-1             0.16.0-1
                            mmtf-cpp              1.0.0-3              1.0.0-4
              nextcloud-app-calendar            1:2.3.2-1            1:2.3.3-1
                 nextcloud-app-tasks             0.14.1-1             0.14.2-1
                       nginx-mod-njs              0.6.1-1              0.6.2-1
                      openfpgaloader              0.4.0-1              0.5.0-1
                                ortp              5.0.5-1             5.0.13-1
                                perf               5.13-1               5.14-1
                           py3status               3.38-1               3.39-1
                             pyright            1.1.164-1            1.1.165-1
                        python-aiopg              1.2.1-1              1.3.1-1
                      python-astroid              2.7.2-1              2.7.3-1
                      python-asyncpg             0.23.0-1             0.24.0-1
               python-awesomeversion             21.8.0-1             21.8.1-1
                    python-biopython               1.78-2               1.79-1
                        python-black             21.7b0-1             21.8b0-1
                       python-bleach              3.3.1-1              4.1.0-1
                     python-colorlog              5.0.1-1              6.4.1-1
                    python-connexion              2.7.0-3              2.9.0-1
                         python-dill              0.3.3-1              0.3.4-1
                     python-flexmock             0.10.7-1             0.10.8-1
                       python-gitlab             2.10.1-1             2.10.1-2
           python-importlib-metadata              4.6.1-1              4.8.1-1
                python-jaeger-client              4.6.0-1              4.6.1-1
            python-jupyterlab_server              2.7.0-1              2.7.2-1
                    python-markdown2              2.4.0-1              2.4.1-1
                  python-meilisearch             0.15.1-1             0.16.0-1
                python-nmigen-boards       r186.9d24c51-1       r193.cb18fc5-1
                         python-pipx             0.16.3-1             0.16.4-1
                    python-pyadi-iio              0.0.4-3              0.0.8-1
                       python-pylint              2.8.2-1             2.10.2-2
            python-pyproject2setuppy                 12-1                 20-1
                       python-pytest              6.2.4-1              6.2.5-1
           python-pytest-regressions              2.0.2-3              2.2.0-1
                  python-pyvhdlmodel             0.11.1-1             0.12.0-1
                         python-rich             10.7.0-1             10.9.0-1
          python-sphinx-argparse-cli              1.5.0-3              1.7.0-1
                     python-svgwrite              1.3.1-3              1.4.1-1
                        python-typer              0.3.2-2              0.4.0-1
                     python-userpath              1.6.0-1              1.7.0-1
                                  qd             2.3.22-3             2.3.23-1
                                rofi              1.6.1-1              1.7.0-1
                                runc              1.0.2-1              1.0.2-2
                       rust-analyzer           20210823-1           20210830-1
                          serverless             2.56.0-1             2.57.0-1
                              solaar              1.0.6-1              1.0.6-2
                       stellarsolver                1.5-1                1.8-1
                    telegram-desktop              2.9.3-1              3.0.0-1
                          terragrunt             0.31.7-1             0.31.8-1
                                tmon               5.13-1               5.14-1
                         ttc-iosevka             10.1.0-1             10.1.1-2
                    ttc-iosevka-aile             10.1.0-1             10.1.1-2
                   ttc-iosevka-curly             10.1.0-1             10.1.1-2
              ttc-iosevka-curly-slab             10.1.0-1             10.1.1-2
                  ttc-iosevka-etoile             10.1.0-1             10.1.1-2
                    ttc-iosevka-slab             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss01             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss02             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss03             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss04             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss05             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss06             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss07             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss08             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss09             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss10             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss11             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss12             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss13             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss14             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss15             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss16             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss17             10.1.0-1             10.1.1-2
                    ttc-iosevka-ss18             10.1.0-1             10.1.1-2
                               usbip               5.13-1               5.14-1
                                wabt             1.0.23-1             1.0.24-1
                         msgpack-cxx                    -              4.0.1-2
                  python-tokenize-rt                    -              4.1.0-2
:: Different overlay package(s) in repository core aarch64
                               linux            5.13.13-1             5.14.0-2
                       linux-headers            5.13.13-1             5.14.0-2
                            linux-rc           5.14.rc7-4           5.14.rc7-5
                    linux-rc-headers           5.14.rc7-4           5.14.rc7-5
                          linux-rpi4            5.10.60-1            5.10.60-2
                  linux-rpi4-headers            5.10.60-1            5.10.60-2
              raspberrypi-bootloader           20210819-1           20210825-1
            raspberrypi-bootloader-x           20210819-1           20210825-1
                   uboot-pinebookpro            2021.07-2            2021.07-3
                      uboot-rockpi4b            2021.07-2            2021.07-3
                      uboot-rockpi4c            2021.07-2            2021.07-3
                     uboot-rockpro64            2021.07-2            2021.07-3
:: Different sync package(s) in repository core aarch64
                           libgcrypt              1.9.3-1              1.9.4-1
                           man-pages               5.12-2               5.13-1
                             systemd              249.3-1              249.4-1
                        systemd-libs              249.3-1              249.4-1
                  systemd-resolvconf              249.3-1              249.4-1
                  systemd-sysvcompat              249.3-1              249.4-1
:: Different overlay package(s) in repository extra aarch64
                  khealthcertificate            21.07.0-2            21.07.0-3
                        kweathercore                0.4-1                0.5-1
                            mesa-git21.3.0_devel.143595.4d9acfa5331-121.3.0_devel.144213.eacf50c27b7-1
                    plasma-mobile-nm             5.22.4-1             5.22.5-1
                         plasma-nano             5.22.4-1             5.22.5-1
             plasma-phone-components             5.22.4-1             5.22.5-1
                   qqc2-breeze-style             5.22.4-1             5.22.5-1
:: Different sync package(s) in repository extra aarch64
                                 aom              3.1.2-1              3.1.2-2
                            aom-docs              3.1.2-1              3.1.2-2
                           appstream             0.14.4-1             0.14.5-2
                        appstream-qt             0.14.4-1             0.14.5-2
                               avahi    0.8+20+gd1e71b3-1    0.8+22+gfd482a7-1
                        avogadrolibs             1.94.0-1             1.95.1-1
                           bluedevil           1:5.22.4-1           1:5.22.5-1
                              breeze             5.22.4-1             5.22.5-1
                         breeze-grub             5.22.4-1             5.22.5-1
                          breeze-gtk             5.22.4-1             5.22.5-1
                            discover             5.22.4-1             5.22.5-1
                                dkms              2.8.4-1              2.8.5-1
                             drkonqi             5.22.4-1             5.22.5-1
                               eigen              3.3.9-1              3.4.0-1
                             freetds                1.3-1              1.3.3-1
                           freetype2             2.10.4-1             2.11.0-3
                     freetype2-demos             2.10.4-1             2.11.0-3
                      freetype2-docs             2.10.4-1             2.11.0-3
                                 gdm               40.1-1               40.1-2
                guile-bytestructures              1.0.7-1             1.0.10-1
                         imagemagick            7.1.0.4-2            7.1.0.5-1
                     imagemagick-doc            7.1.0.4-2            7.1.0.5-1
                   kactivitymanagerd             5.22.4-1             5.22.5-1
                       kde-cli-tools             5.22.4-1             5.22.5-1
                      kde-gtk-config             5.22.4-1             5.22.5-1
                         kdecoration             5.22.4-1             5.22.5-1
                       kdepim-addons            21.08.0-1            21.08.0-2
                    kdeplasma-addons             5.22.4-1             5.22.5-1
                             kgamma5             5.22.4-1             5.22.5-1
                            khotkeys             5.22.4-1             5.22.5-1
                         kinfocenter             5.22.4-1             5.22.5-1
                           kmenuedit             5.22.4-1             5.22.5-1
                             kscreen             5.22.4-1             5.22.5-1
                       kscreenlocker             5.22.4-1             5.22.5-1
                         ksshaskpass             5.22.4-1             5.22.5-1
                        ksystemstats             5.22.4-1             5.22.5-1
                         kwallet-pam             5.22.4-1             5.22.5-1
                kwayland-integration             5.22.4-1             5.22.5-1
                     kwayland-server             5.22.4-1             5.22.5-1
                                kwin             5.22.4-1             5.22.5-1
                             kwrited             5.22.4-1             5.22.5-1
                      layer-shell-qt             5.22.4-1             5.22.5-1
                              libgdm               40.1-1               40.1-2
                          libkscreen             5.22.4-1             5.22.5-1
                        libksysguard             5.22.4-1             5.22.5-1
                               milou             5.22.4-1             5.22.5-1
                             nghttp2             1.44.0-1             1.44.0-2
                      noto-fonts-cjk           20201206-2           20201206-3
                               nyacc             1.03.1-1             1.04.1-1
                              oxygen             5.22.4-1             5.22.5-1
          plasma-browser-integration             5.22.4-1             5.22.5-1
                      plasma-desktop             5.22.4-1             5.22.5-1
                        plasma-disks             5.22.4-1             5.22.5-1
                     plasma-firewall             5.22.4-1             5.22.5-1
                  plasma-integration             5.22.4-1             5.22.5-1
                           plasma-nm             5.22.4-1             5.22.5-1
                           plasma-pa             5.22.4-1             5.22.5-1
                          plasma-sdk             5.22.4-1             5.22.5-1
                plasma-systemmonitor             5.22.4-1             5.22.5-1
                  plasma-thunderbolt             5.22.4-1             5.22.5-1
                        plasma-vault             5.22.4-1             5.22.5-1
              plasma-wayland-session             5.22.4-3             5.22.5-1
                    plasma-workspace             5.22.4-3             5.22.5-1
         plasma-workspace-wallpapers             5.22.4-1             5.22.5-1
                    polkit-kde-agent             5.22.4-1             5.22.5-1
                          powerdevil             5.22.4-1             5.22.5-1
                                 qbs             1.19.2-1             1.20.0-1
                                qemu              6.0.0-3              6.1.0-1
                     qemu-arch-extra              6.0.0-3              6.1.0-1
                  qemu-block-gluster              6.0.0-3              6.1.0-1
                    qemu-block-iscsi              6.0.0-3              6.1.0-1
                    qemu-guest-agent              6.0.0-3              6.1.0-1
                       qemu-headless              6.0.0-3              6.1.0-1
            qemu-headless-arch-extra              6.0.0-3              6.1.0-1
                            qt5-base    5.15.2+kde+r215-2    5.15.2+kde+r222-1
                     qt5-declarative     5.15.2+kde+r29-1     5.15.2+kde+r30-1
                  qt5-quickcontrols2             5.15.2-1      5.15.2+kde+r8-1
                    qt5-translations             5.15.2-1     5.15.2+kde+r20-1
             qt5-xcb-private-headers    5.15.2+kde+r215-2    5.15.2+kde+r222-1
                           qtcreator             4.15.2-2              5.0.0-3
                            sddm-kcm             5.22.4-1             5.22.5-1
                      systemsettings             5.22.4-1             5.22.5-1
              xdg-desktop-portal-kde             5.22.4-1             5.22.5-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.08.0.r12561.gaf9c09ab1-121.08.0.r12562.gee9ec222c-1
                    akonadi-calendar21.08.0.r1976.g7894f7f-121.08.0.r1977.gc11c303-1
              akonadi-calendar-tools21.08.0.r893.g41c7036-121.08.0.r894.g10323b9-1
                    akonadi-contacts21.08.0.r3053.gb72d4467-121.08.0.r3054.g93c19af4-1
               akonadi-import-wizard21.08.0.r1732.g0828374-121.08.0.r1734.gdd5e516-1
                      akonadiconsole21.08.0.r1518.gaf88510-121.08.0.r1520.g120a964-1
                           akregator21.08.0.r6215.gb05cd487-121.08.0.r6218.g58f0bd02-1
                           alligator  21.07.r0.g7c37563-1  21.08.r0.g2049df7-1
                           angelfish  21.07.r8.g2d1473f-1  21.08.r2.gd75eef2-1
                                 ark21.08.0.r4611.gda40af2f-121.08.0.r4612.g552afb85-1
                         audiocd-kio21.08.0.r1031.g6d88fa2-121.08.0.r1032.g554ff48-1
                               baloo5.85.0.r3004.g509dcd8d-15.85.0.r3005.g9fb7f7fe-1
                       baloo-widgets21.08.0.r699.ged1e640-121.08.0.r701.gaa2f910-1
                             blinken21.08.0.r630.ga84bdd0-121.08.0.r631.g91d0068-1
                           bluedevil1:5.22.4.r2276.ge6ecea09-11:5.22.5.r2276.ge6ecea09-1
                            bluez-qt5.85.0.r673.g6779881-15.85.0.r675.g3e767d4-1
                              bomber21.08.0.r524.gd08dbb6-121.08.0.r525.g558fa34-1
                                bovo21.08.0.r734.g85982f7-121.08.0.r735.ga443677-1
                              breeze5.22.4.r2236.g32cf0733-15.22.5.r2239.g88518ebc-1
                         breeze-grub5.22.4.r11.g63136a9-15.22.5.r11.g63136a9-1
                          breeze-gtk5.22.4.r420.gfccd7df-15.22.5.r420.gfccd7df-1
                        breeze-icons5.85.0.r1780.gc37c21b6-15.85.0.r1781.ga1ec7a6d-1
                     calendarsupport21.08.0.r24.gcffed74-121.08.0.r30.ga6fcdf5-1
                           calindori  21.07.r2.g9becb13-1  21.08.r0.gf739058-1
                            cervisia21.08.0.r1640.g2cbf459-121.08.0.r1641.g8e8a98e-1
                            discover5.22.4.r8282.g660ba31c-15.22.5.r8289.g5ab0be59-1
                             dolphin21.08.0.r6681.gae46ab2c3-121.08.0.r6701.g653d5714a-1
                     dolphin-plugins21.08.0.r601.g04ae4bf-121.08.0.r604.gffad27d-1
                              dragon21.08.0.r1010.g75b3036-121.08.0.r1011.gaeba124-1
                             drkonqi5.22.4.r684.gace905b0-15.22.5.r684.gace905b0-1
                               elisa21.08.0.r2758.g28ab3ff6-121.08.0.r2765.g130a6355-1
                          eventviews21.07.80.r22.g36ab7aa-121.08.0.r28.gfc75086-1
                        ffmpegthumbs21.08.0.r192.g9e7b1cd-121.08.0.r194.g2e06153-1
                           filelight21.08.0.r983.ge640b40-121.08.0.r985.g32be16a-1
                           granatier21.08.0.r928.gf0bc639-121.08.0.r930.gc86a329-1
                     grantlee-editor21.08.0.r765.g7458ee2-121.08.0.r766.gbaa3e34-1
                            gwenview21.08.0.r6655.ga9dc7758-121.08.0.r6656.gbd41e8ae-1
                            index-fm  2.0.0.r9.g91b9e98-1 2.0.0.r10.g6ee02ec-1
                           itinerary21.08.0.r1435.g3519b25-121.08.0.r1436.gcec3571-1
                                 juk21.08.0.r3110.ga1b028be-121.08.0.r3111.g811cd6c0-1
                                 k3b1:21.08.0.r6671.ge5d8e4579-11:21.08.0.r6674.g08de2191e-1
                         kactivities5.85.0.r1359.gb11fa28-15.85.0.r1360.g8ceb7b0-1
                   kactivitymanagerd5.22.4.r1366.g6536521-15.22.5.r1366.g6536521-1
                        kaddressbook21.08.0.r6032.g05df43c7-121.08.0.r6034.gdaa868d9-1
                             kajongg21.08.0.r4196.gf578c92a-121.08.0.r4197.g6455a6ad-1
                              kalarm21.08.0.r6444.ge911e84b-121.08.0.r6455.g0cfb501d-1
                            kalgebra21.08.0.r2040.g3738f5b-121.08.0.r2041.ge08e3d8-1
                                kalk  21.07.r5.g7f968c3-1  21.08.r0.gcd8b9de-1
                             kalzium21.08.0.r4268.g149ad8d8-121.08.0.r4269.g501f78a1-1
                              kamera21.08.0.r655.g975c8f5-121.08.0.r664.gf261878-1
                              kamoso21.08.0.r1430.g0fcab25-121.08.0.r1431.g4a12797-1
                            kanagram21.08.0.r1285.gf761457-121.08.0.r1286.g3ff75b1-1
                              kapman21.08.0.r604.gc4883f7-121.08.0.r606.g4c5d88b-1
                        kapptemplate21.08.0.r956.gb948162-121.08.0.r957.geea69a9-1
                            karchive5.85.0.r502.gb48d3f4-15.85.0.r504.g4573a2c-1
                               kasts  21.07.r9.g4efca61-1  21.08.r0.gc0fff75-1
                                kate21.08.0.r18334.gf91b702ac-121.08.0.r18339.g4e38cc0a9-1
                             katomic21.08.0.r919.g676b3f1-121.08.0.r920.g7b5c821-1
                               kauth5.85.0.r445.gfb6c512-15.85.0.r446.g9473e2d-1
                             kbackup21.08.0.r393.gcd1f6b5-121.08.0.r394.gddcd002-1
                           kblackbox21.08.0.r726.g56e775a-121.08.0.r727.g865ff49-1
                             kblocks21.08.0.r670.g1fdb68e-121.08.0.r671.ge1978e5-1
                          kbookmarks5.85.0.r416.g79e6438-15.85.0.r419.g459cfb9-1
                             kbounce21.08.0.r808.ge96a31e-121.08.0.r809.gc062586-1
                           kbreakout21.08.0.r864.ge6381a2-121.08.0.r865.g9e21fa5-1
                              kbruch21.08.0.r816.gef98da6-121.08.0.r817.gfed951b-1
                         kcachegrind21.08.0.r1151.ge04e43e-121.08.0.r1152.gbe3f69d-1
                  kcachegrind-common21.08.0.r1151.ge04e43e-121.08.0.r1152.gbe3f69d-1
                               kcalc21.08.0.r1518.gf0b3fee-121.08.0.r1520.g7d2dc72-1
                           kcalutils21.08.0.r864.g23a775923-121.08.0.r865.gac8e66378-1
                         kcharselect21.08.0.r475.g714122d-121.08.0.r476.g428e547-1
                              kclock 21.07.r27.g03f1e79-1  21.08.r0.gfd706d6-1
                            kcmutils5.85.0.r539.gedc1510-15.85.0.r542.gdf129f8-1
                             kcodecs5.85.0.r382.g36e5682-15.85.0.r383.g4bfa1d6-1
                       kcolorchooser21.08.0.r229.gbe6cf4d-121.08.0.r230.gb7268d9-1
                         kcompletion5.85.0.r453.g9553e4d-15.85.0.r454.g6956438-1
                             kconfig5.85.0.r857.g3259a6e-15.85.0.r860.g7ad396a-1
                      kconfigwidgets5.85.0.r613.g56185bb-15.85.0.r616.g321de25-1
                           kcontacts1:5.85.0.r3250.g4d5c37f0-11:5.85.0.r3251.geb873f27-1
                         kcoreaddons5.85.0.r1273.gdb7f2594-15.85.0.r1277.g13a43b4f-1
                                kdav1:5.85.0.r1296.ge087771-11:5.85.0.r1297.g70adea3-1
                       kde-cli-tools5.22.4.r1861.gbb9b116-15.22.5.r1861.gbb9b116-1
                       kde-dev-utils21.08.0.r562.g9d0f3b4-121.08.0.r563.g3600e04-1
                      kde-gtk-config5.22.4.r910.g31496c4-15.22.5.r910.g31496c4-1
                      kdebugsettings21.08.0.r845.g575150f-121.08.0.r847.g3135e76-1
                        kdeclarative5.85.0.r910.g68f4ba0-15.85.0.r915.g66c5bb0-1
                          kdeconnect21.08.0.r3309.g066d798e-121.08.0.r3310.ga5f7fe37-1
                         kdecoration5.22.4.r269.gbd1fc8d-15.22.5.r269.gbd1fc8d-1
                                kded5.85.0.r414.g88483c6-15.85.0.r415.g1d31ebc-1
                            kdenlive21.08.0.r14775.ga8f6552ce-121.08.0.r14776.gf44f74d7d-1
                       kdepim-addons21.08.0.r4319.g6032b8bc-121.08.0.r4321.g5d98491b-1
                      kdepim-runtime21.08.0.r15255.gd55edc301-121.08.0.r15258.gede051c7c-1
                    kdeplasma-addons5.22.4.r8581.g5eab20a03-15.22.5.r8582.g84a58cb76-1
                     kdesignerplugin5.85.0.r332.g11b29ea-15.85.0.r333.ga429b2e-1
                                 kdf21.08.0.r797.g44c6e09-121.08.0.r798.gb35a14a-1
                             kdialog21.08.0.r1188.gafed367a3-121.08.0.r1189.g7df2eaaf7-1
                            kdiamond21.08.0.r670.gb374f30-121.08.0.r671.g0e63a0f-1
                              kdnssd5.85.0.r321.g1909661-15.85.0.r322.g93b28af-1
                           kdoctools5.85.0.r625.gc799e16-15.85.0.r626.g88a63e3-1
                      keditbookmarks21.08.0.r2745.gac885dcce-121.08.0.r2747.ge96a0c3cc-1
                          kemoticons5.85.0.r382.g349334a-15.85.0.r383.g4e614f9-1
                            keysmith  21.07.r3.g3c0fc62-1  21.08.r0.gf1e01dc-1
                       kfilemetadata5.85.0.r805.g2e14ab0-15.85.0.r806.g92c7ced-1
                               kfind21.08.0.r2644.gd3be9a828-121.08.0.r2645.g52d84144f-1
                             kfloppy21.08.0.r756.ga4a1563-121.08.0.r757.g486bdef-1
                         kfourinline21.08.0.r983.g9ca5e9c-121.08.0.r985.g9723882-1
                             kgamma55.22.4.r457.g45f405d-15.22.5.r457.g45f405d-1
                          kgeography21.08.0.r1111.g5fab02b-121.08.0.r1113.gdaf74c4-1
                                kget21.08.0.r3120.g6ad6fe8c-121.08.0.r3121.g8d673262-1
                        kglobalaccel5.85.0.r457.g13268e2-15.85.0.r462.g4baa4cb-1
                         kgoldrunner21.08.0.r1241.g95ae027-121.08.0.r1242.g2de3f71-1
                                kgpg21.08.0.r3131.gce487cde-121.08.0.r3133.ge606950b-1
                          kguiaddons5.85.0.r386.g640f107-15.85.0.r387.gc2cf397-1
                            khangman21.08.0.r1564.gcbc467e-121.08.0.r1565.ga82efb3-1
                  khealthcertificate        r70.ab96f6f-1        r73.5d4e42e-1
                         khelpcenter21.08.0.r2677.g322c8a6e-121.08.0.r2678.gebc327a7-1
                           kholidays1:5.85.0.r955.g559cfb4-11:5.85.0.r956.gbc5d97e-1
                            khotkeys5.22.4.r2091.g925d5d9-15.22.5.r2091.g925d5d9-1
                               khtml5.85.0.r554.ga2275b8-15.85.0.r555.gb10f364-1
                               ki18n5.85.0.r476.g567f51f-15.85.0.r477.gfe5d6d7-1
                         kiconthemes5.85.0.r538.g2d9a393-15.85.0.r541.g3ef834c-1
                 kidentitymanagement21.08.0.r3817.g823fa374-121.08.0.r3818.g6392a75e-1
                           kidletime5.85.0.r312.ge3e65c0-15.85.0.r314.gd028a87-1
                                 kig21.08.0.r3145.g4e77085b-121.08.0.r3146.g2f7309b0-1
                                kigo21.08.0.r524.ge4b9861-121.08.0.r526.g7a92072-1
                            killbots21.08.0.r737.g3d36709-121.08.0.r738.gee08736-1
                       kimageformats5.85.0.r355.gabd550c-15.85.0.r357.g1d2b51d-1
                     kimagemapeditor21.08.0.r470.g909a43c-121.08.0.r471.g0b688f0-1
                               kimap21.08.0.r1108.g2abb127-121.08.0.r1109.gf7cda63-1
                         kinfocenter5.22.4.r1891.ga6de8d5-15.22.5.r1896.g239ca59-1
                               kinit5.85.0.r409.gc1393bc-15.85.0.r410.g70e7178-1
                                 kio5.85.0.r4946.g85c5815e-15.85.0.r4954.geaa2729e-1
                          kio-extras21.08.0.r7102.g2f1225b9-121.08.0.r7104.gb46ec2e8-1
                          kio-gdrive21.08.0.r566.g578cd9a-121.08.0.r567.g1d425ba-1
                        kipi-plugins21.08.0.r12061.g955fc31c6-121.08.0.r12062.gda7ccada7-1
                    kirigami-gallery21.08.0.r213.g381565a-121.08.0.r214.ge6bfbf4-1
                           kirigami25.85.0.r2866.ga5bbb63d-15.85.0.r2870.g70c05b2c-1
                              kiriki21.08.0.r420.g552e0a1-121.08.0.r421.g9ab6806-1
                         kitemmodels5.85.0.r555.g2829a12-15.85.0.r556.g192a2be-1
                          kitemviews5.85.0.r337.ga2b3908-15.85.0.r338.g2eb5c08-1
                               kiten21.08.0.r1146.g028b49c-121.08.0.r1147.gf71fae4-1
                          kitinerary21.08.0.r1898.g921dbf0-121.08.0.r1921.g0f39336-1
                         kjobwidgets5.85.0.r374.gb87dc09-15.85.0.r376.g0e49b67-1
                        kjumpingcube21.08.0.r786.gd7f52c4-121.08.0.r788.g458b5ce-1
                           kleopatra21.08.0.r5967.gf63b94cb-121.08.0.r5970.g2552ed53-1
                            klettres21.08.0.r914.g6ec4462-121.08.0.r915.gabb53f5-1
                            klickety21.08.0.r636.g4e8266e-121.08.0.r637.gc086690-1
                              klines21.08.0.r766.g8d25ecc-121.08.0.r769.g33a870b-1
                                kmag21.08.0.r693.g7051a15-121.08.0.r695.gfa4d7f1-1
                           kmahjongg21.08.0.r1470.g4934d8b-121.08.0.r1471.g4608d0e-1
                kmail-account-wizard21.08.0.r808.g6a8e44a-121.08.0.r810.gf8d1938-1
                      kmailtransport21.08.0.r1646.gff70e5a-121.08.0.r1648.g5e06237-1
                           kmenuedit5.22.4.r971.g4b52f0c-15.22.5.r971.g4b52f0c-1
                               kmime21.08.0.r1451.g615cc69-121.08.0.r1456.g53b7462-1
                              kmines21.08.0.r1720.geb178d9-121.08.0.r1722.gb8a94d6-1
                                kmix21.08.0.r2380.g4e33bdb8-121.08.0.r2382.g304af5fc-1
                              kmouth21.08.0.r692.g434a8a6-121.08.0.r695.g19aeff2-1
                              kmplot21.08.0.r1464.g484cd7c-121.08.0.r1465.gd296b34-1
                        knavalbattle21.08.0.r1388.g3deb389-121.08.0.r1389.g3022b1b-1
                            knetwalk21.08.0.r657.g893d1df-121.08.0.r658.ged8d6c5-1
                           knewstuff5.85.0.r1197.gbd32c365-15.85.0.r1199.g824e3d31-1
                             knights21.08.0.r1049.g9855fd8-121.08.0.r1050.gbc8f3d2-1
                              knotes21.08.0.r3502.ga24d98ae-121.08.0.r3505.gc853dcaf-1
                      knotifications5.85.0.r673.gba5fbe7-15.85.0.r675.gda2521e-1
                       knotifyconfig5.85.0.r351.g79996cf-15.85.0.r352.g6f824e7-1
                                koko 21.07.r25.gd3c4c4d-1  21.08.r0.gcf0f874-1
                                kolf21.08.0.r1441.g2e86d44-121.08.0.r1443.g6ea5e84-1
                           kollision21.08.0.r493.g80b1ae3-121.08.0.r494.g05b9c34-1
                         kolourpaint21.08.0.r2353.gd26a4739-121.08.0.r2362.ge33b2fb6-1
                             kompare21.08.0.r1105.gd41a4cf-121.08.0.r1106.g857f92a-1
                            kongress  21.07.r0.g8150560-1  21.08.r0.gacca390-1
                           konqueror21.08.0.r14930.g16233d7b4-121.08.0.r14935.g7754bd4e7-1
                            konquest21.08.0.r897.g42c00e1-121.08.0.r898.g3ad1f6d-1
                             konsole21.08.0.r7922.g2684bc7f-121.08.0.r7927.g40cf8519-1
                             kontact21.08.0.r5376.g951a3fd5-121.08.0.r5379.geab83a86-1
                    kontactinterface21.08.0.r628.gd333f9e-121.08.0.r629.gc966691-1
                            kontrast21.08.0.r171.g8e90006-121.08.0.r174.g6ed1279-1
                        konversation21.08.0.r8990.g063aab07-121.08.0.r8993.gd3623ee6-1
                          korganizer21.08.0.r11469.ga9c703ee6-121.08.0.r11473.g86d997565-1
                       kosmindoormap21.08.0.r631.g9125e47-121.08.0.r633.g5957e06-1
                            kpackage5.85.0.r695.gff52520-15.85.0.r696.g188e725-1
                              kparts5.85.0.r521.gb584212-15.85.0.r524.g804a2f0-1
                                kpat21.08.0.r2562.g02b8387-121.08.0.r2563.gc34a94a-1
                             kpeople5.85.0.r1341.g98ca126-15.85.0.r1343.g4d8a6f9-1
                        kpimtextedit21.08.0.r1406.g1853009-121.08.0.r1407.gafafbc1-1
                           kplotting5.85.0.r291.g8cbd04e-15.85.0.r293.g2c423a0-1
                             kpmcore21.08.0.r1196.gf466467-121.08.0.r1197.g00e6b77-1
                    kpublictransport21.08.0.r1734.g0d3ee98b-121.08.0.r1738.g52d7f5d5-1
                                krdc21.08.0.r1532.ge42e5f0-121.08.0.r1537.gab2a1a3-1
                           krecorder  21.07.r2.gfd5e12a-1  21.08.r0.g3133d3c-1
                            kreversi21.08.0.r1224.g5644cfa-121.08.0.r1226.g394eab6-1
                                krfb21.08.0.r1410.gcb86f9c-121.08.0.r1415.gdf9e6d6-1
                              kruler21.08.0.r698.g91ab1d1-121.08.0.r701.ge556d0a-1
                             krunner5.85.0.r666.g8620c39-15.85.0.r667.gae64d40-1
                             kscreen5.22.4.r1343.g5f55e79-15.22.5.r1344.g0cd0cb0-1
                       kscreenlocker5.22.4.r866.g838a067-15.22.5.r866.g838a067-1
                            kservice5.85.0.r937.gb45dda2-15.85.0.r940.gb758304-1
                             kshisen21.08.0.r1201.g83c41fe-121.08.0.r1202.ge43cf2c-1
                               ksirk21.08.0.r960.g16df763-121.08.0.r961.gfa60d1e-1
                               ksmtp21.08.0.r364.g51fce68-121.08.0.r365.gf50bff4-1
                          ksnakeduel21.08.0.r808.g65bc0d4-121.08.0.r809.g27dabac-1
                          kspaceduel21.08.0.r633.gee74017-121.08.0.r634.gb10a003-1
                            ksquares21.08.0.r516.g1984f26-121.08.0.r517.gcf195bb-1
                         ksshaskpass5.22.4.r197.gcc50f63-15.22.5.r197.gcc50f63-1
                             ksudoku21.08.0.r1049.g0865090-121.08.0.r1050.g721bdf1-1
                           ksysguard5.22.4.r3511.ga571c444-15.22.5.r3511.ga571c444-1
                          ksystemlog21.08.0.r655.gbd31996-121.08.0.r657.gfd6a0cc-1
                        ksystemstats5.22.4.r184.gbbfce43-15.22.5.r187.g8622236-1
                            kteatime21.08.0.r724.ga51c5b3-121.08.0.r725.g02ab1f6-1
                         ktexteditor5.85.0.r2932.g5752f356-15.85.0.r2937.g9662b146-1
                        ktextwidgets5.85.0.r409.g8a6af64-15.85.0.r411.gc996af7-1
                              ktimer21.08.0.r468.g08ad6e6-121.08.0.r470.g4705ed6-1
                            ktorrent21.08.0.r2772.gb6741c0b-121.08.0.r2773.gddef52b4-1
                              ktouch21.08.0.r2138.g066e658-121.08.0.r2139.gae43a86-1
                               ktrip  21.07.r7.gb5a7eb8-1  21.08.r0.gd9ea44f-1
                          ktuberling21.08.0.r1012.gf2c8ad3-121.08.0.r1013.gf0f1508-1
                             kturtle21.08.0.r1117.g598a847-121.08.0.r1118.gcfc622b-1
                             kubrick21.08.0.r370.gf280c16-121.08.0.r371.gfa18f41-1
                     kunitconversion5.85.0.r373.gf8808e7-15.85.0.r375.g2a57f9d-1
                             kwallet5.85.0.r1084.g767b840-15.85.0.r1085.g541d972-1
                         kwallet-pam5.22.4.r253.g258c428-15.22.5.r253.g258c428-1
                      kwalletmanager21.08.0.r1207.g4179fca-121.08.0.r1208.g0a74834-1
                               kwave21.08.0.r3740.ga889c432-121.08.0.r3741.gf5b71808-1
                kwayland-integration5.22.4.r181.gba8376d-15.22.5.r184.g71736b3-1
                     kwayland-server5.22.4.r1369.g8385537-15.22.5.r1374.gcc0ed74-1
                            kweather 21.07.r22.gdccfaa0-1  21.08.r0.g442c888-1
                        kweathercore    0.4.r6.g93ab451-1    0.5.r0.gb6ef51c-1
                      kwidgetsaddons5.85.0.r863.g995cda63-15.85.0.r865.gba2252ec-1
                                kwin5.22.4.r19855.g1dc749333-15.22.5.r19903.g63b16cdf9-1
                       kwindowsystem5.85.0.r612.g8bba48b-15.85.0.r615.ga5f86f1-1
                              kwinft5.22.4.r19227.gd958fcec3-15.22.4.r19253.g433e5ca4b-1
                           kwordquiz21.08.0.r1140.g81820a6-121.08.0.r1141.g2e60dd3-1
                              kwrite21.08.0.r18334.gf91b702ac-121.08.0.r18339.g4e38cc0a9-1
                             kwrited5.22.4.r482.g9548753-15.22.5.r482.g9548753-1
                             kxmlgui5.85.0.r798.gd12e8f62-15.85.0.r803.gfc5844a8-1
                          libakonadi21.08.0.r12561.gaf9c09ab1-121.08.0.r12562.gee9ec222c-1
                             libkleo21.08.0.r928.g1792abb-121.08.0.r929.gb95f62e-1
                            libksane21.08.0.r555.g0316b3a-121.08.0.r556.gcef1e7c-1
                          libkscreen5.22.4.r1588.g8e78076-15.22.5.r1588.g8e78076-1
                           libksieve21.08.0.r1580.gbe0aec6d-121.08.0.r1582.gfb564e6c-1
                        libksysguard5.22.4.r2281.g7665918-15.22.5.r2286.gde2cf64-1
                         libquotient     r2062.g6d55a2c-1     r2064.g06a8ef6-1
                            lokalize21.08.0.r1768.ge30edb2-121.08.0.r1769.gfccb25a-1
                               lskat21.08.0.r813.g132338e-121.08.0.r814.g016a650-1
                          mailcommon21.08.0.r1100.gf705987-121.08.0.r1101.g6572d14-1
                     maliit-keyboard    r2097.g14b96f8e-1    r2103.g430c8326-1
                        markdownpart21.08.0.r82.g6480932-121.08.0.r83.g8f25b96-1
                           maui-clip  2.0.0.r3.ga6ebc76-1  2.0.0.r4.gf00b830-1
                             mauikit 2.0.0.r9.gd9eda446-1 2.0.1.r1.g99825889-1
                    mauikit-accounts  2.0.0.r0.gd9f46d9-1  2.0.1.r0.gbb4a052-1
                mauikit-filebrowsing  2.0.0.r8.g534416f-1  2.0.1.r0.g27eb236-1
                  mauikit-imagetools  2.0.0.r3.g4d4e9b7-1  2.0.1.r0.g99dd3ed-1
                  mauikit-texteditor  2.0.0.r1.g7dfdbde-1  2.0.1.r0.g4075d1c-1
                       mbox-importer21.08.0.r510.gba0b08c-121.08.0.r511.g8077b59-1
                               milou5.22.4.r748.gc10c48c-15.22.5.r748.gc10c48c-1
                              minuet21.08.0.r582.gfd585f8-121.08.0.r583.g8171e20-1
                             neochat    r1835.gc9935804-1    r1836.g1d5b7dee-1
                   networkmanager-qt5.85.0.r1116.gd48b86f-15.85.0.r1117.g26b6bff-1
                              okular21.08.0.r9435.geee71036a-121.08.0.r9443.gb80d3614e-1
                              oxygen5.22.4.r4424.g758c7aed-15.22.5.r4424.g758c7aed-1
                            palapeli21.08.0.r1231.g772fc8c-121.08.0.r1233.gc33f37d-1
                              parley21.08.0.r4439.g4e7116c3-121.08.0.r4455.g55172e88-1
                    partitionmanager21.08.0.r1530.gd4afb41-121.08.0.r1531.g90b0aa2-1
                   pim-data-exporter21.08.0.r2443.g99770684-121.08.0.r2445.g4256f6e4-1
                    pim-sieve-editor21.08.0.r1506.gf077fd4-121.08.0.r1508.g728ebed-1
                           pimcommon21.07.80.r1095.g2a5773c-121.07.80.r1096.ga9a66f6-1
          plasma-browser-integration5.22.3.r1273.g670d76b1-15.22.5.r1277.g1166fca0-1
                      plasma-desktop5.22.4.r8589.g329867e8c-15.22.5.r8591.gc3cc2b2d1-1
                       plasma-dialer  21.07.r2.gde002cf-1  21.08.r0.g93c5974-1
                        plasma-disks5.22.4.r226.gc9ddc9d-15.22.5.r227.gcc30860-1
                     plasma-firewall5.22.4.r503.g92efb24-15.22.5.r504.gc9a8709-1
                    plasma-framework5.85.0.r15965.g48bb0cb3a-15.85.0.r15970.g0a519d059-1
                  plasma-integration5.22.4.r523.g62dbb6a-15.22.5.r528.g841b917-1
                    plasma-mobile-nm5.22.3.r3076.g9289bfbc-15.22.3.r3078.g7d10d426-1
                         plasma-nano5.21.5.r155.g306c3f3-15.21.5.r157.g15d9b10-1
                           plasma-nm5.22.3.r3076.g9289bfbc-15.22.5.r3078.g7d10d426-1
                           plasma-pa5.22.4.r956.g34fecad-15.22.5.r958.g3538c92-1
             plasma-phone-components5.22.3.r1447.g81a9b81e-15.22.5.r1455.g31448728-1
                    plasma-phonebook  21.07.r5.g7f2dac8-1  21.08.r0.g45fc014-1
                          plasma-sdk5.22.4.r2275.g745f7845-15.22.5.r2276.gf5abde09-1
                     plasma-settings 21.07.r10.gc9ceb70-1  21.08.r0.g137a5da-1
                plasma-systemmonitor5.22.4.r481.ge9abcd1-15.22.5.r482.gf5c01df-1
                  plasma-thunderbolt5.22.4.r135.g5186a62-15.22.5.r135.g5186a62-1
                        plasma-vault5.22.4.r339.gab42eca-15.22.5.r340.g2b093e8-1
            plasma-wayland-protocols1.3.0.r1029.g7732ae4-11.3.0.r1030.g9a11267-1
              plasma-wayland-session5.22.4.r10577.g7a0686b4e-15.22.5.r10592.gf9aa31d02-1
                    plasma-workspace5.22.4.r10577.g7a0686b4e-15.22.5.r10592.gf9aa31d02-1
         plasma-workspace-wallpapers5.22.4.r282.g1a81932-15.22.5.r282.g1a81932-1
                    polkit-kde-agent5.22.4.r502.g9fabd61-15.22.5.r502.g9fabd61-1
                          powerdevil5.22.4.r2461.g497647f1-15.22.5.r2461.g497647f1-1
                       print-manager21.08.0.r1035.ga41de84-121.08.0.r1036.g25d47cd-1
                             purpose5.85.0.r874.g94243ac-15.85.0.r877.g6bfb832-1
                         qcachegrind21.08.0.r1151.ge04e43e-121.08.0.r1152.gbe3f69d-1
                          qmlkonsole  21.07.r0.g6b630f5-1  21.08.r4.g88fc6e6-1
                   qqc2-breeze-style5.22.4.r222.gb6524b6-15.22.5.r223.gef75e0b-1
                  qqc2-desktop-style5.85.0.r518.g44636fc-15.85.0.r519.g4982473-1
                                rocs21.08.0.r3026.gecdb6a31-121.08.0.r3027.ga686a428-1
                            sddm-kcm5.22.4.r593.ga7ef765-15.22.5.r593.ga7ef765-1
                               solid5.85.0.r701.g623cd17-15.85.0.r702.g9874be2-1
                              sonnet5.85.0.r629.g780ad31-15.85.0.r630.g5bcee2a-1
                            spacebar  21.07.r9.g6d59c7b-1  21.08.r1.g138f5e7-1
                           spectacle21.08.0.r1154.ga7d958a-121.08.0.r1158.gdda0c7e-1
                                step21.08.0.r1155.g2b2c1cc-121.08.0.r1156.g0e4bf04-1
                             svgpart21.08.0.r179.ga6fa58c-121.08.0.r182.gb602ba5-1
                             sweeper21.08.0.r528.gba2e86a-121.08.0.r531.gb52ca18-1
                         syndication5.85.0.r837.gf71da59-15.85.0.r838.gb27c491-1
                 syntax-highlighting5.85.0.r1678.g408084f7-15.85.0.r1683.g439f8cbf-1
                      systemsettings5.22.4.r2485.ga83f8d9e-15.22.5.r2488.gb3efa174-1
                        threadweaver5.85.0.r508.ge4efefc-15.85.0.r509.gd92be43-1
                             tokodon  21.07.r7.gb8fd218-1  21.08.r0.g52ed8b0-1
                               vvave 2.0.0.r11.g1b54bf8-1 2.0.0.r14.g2eb4073-1
                            wrapland5.22.4.r1538.g8396e07-15.22.4.r1550.gdfa699d-1
              xdg-desktop-portal-kde5.22.4.r378.g48b1670-15.22.5.r379.g711f13d-1
                             yakuake21.08.0.r732.g8339bac-121.08.0.r733.g246229c-1
                    zeroconf-ioslave21.08.0.r358.ga2f2ac0-121.08.0.r359.gd6c98e6-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been located and fixed yet.
Workaround: Ignore the update to the linux package until it’s fixed upstream.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Workaround: Downgrade Vivaldi to a version before 4.1.2369.11
Old Issues
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
9/1 today… 8/29 in title?
Sorry, my fault. Changed. :slight_smile:
If it was my timezone. It would be 2/9 :wink::australia:
@Strit looks like my issues with external screen on PBPRO are gone with 5.14 kernel. The second screen is working out-of-the-box and in general the feat. seems to work more reliable as it is turning on the screen almost immediately (previously there was some delay in recognizing the second screen)…
Since this update my pinebook pro is no longer charging with the USB C Port. KDE Plasma says it’s charging, but the red charging light is not on and the power is decreasing. I downgraded back to Linux 5.13.13 and it worked correctly again.
This could be a result of the change in the rockchip GPIO driver, that is preparing for rk356x support.
It is pretty weird though.
I did however notice that it still charges when it’s powered off. Even the red charging LED is on.
no problems on pinephone.
Also, last update removed the warning toast on start about the failed to update 1 file…
:slight_smile:
Since the update my power light on the PineBook Pro is staying red (all HW
seems to be working (I am using barrel plug power))…In the log I see:
Plasma indexer and obsolete Pulse module…not sure why Power indicator is staying red unless it is indicating kernel issues…
Update: philm’s new push below resolved my issue with the power light staying red/amber. Thanks!
Got rid of the pulse deprecated Pulse module error be removing the line from /etc/pulse/default.pa …if anybody else does not like seeing this error.
To get rid of the baloo_file core dump, purge the DB by balooctl purge, then re-enable baloo with balooctl enable
I pushed some more updates, mostly related to mobile
User philip created a snapshot of branch 'arm-unstable' to 'arm-testing'.
 - arm-testing community aarch64:  10 new and 9 removed package(s)
 - arm-testing core aarch64:  2 new and 2 removed package(s)
 - arm-testing kde-unstable aarch64:  31 new and 31 removed package(s)
                             PACKAGE           2021-09-01           2021-09-02
                  alsa-ucm-pinephone              0.4.0-1              0.5.0-1
                               calls 41beta+20+g501398f-1 41beta+21+gb8f6287-1
                        eg25-manager              0.4.0-1              0.4.0-2
                         gtk3-mobile            3.24.29-1            3.24.30-1
                       libmm-pp-glib1.18rc1+2+ga20f2c05-21.18rc1+6+gfa19b2b9-1
               mobile-config-firefox              2.1.0-1              2.2.0-1
                     modemmanager-pp1.18rc1+2+ga20f2c05-21.18rc1+6+gfa19b2b9-1
                                phoc   0.8.0+4+g73f12d3-1  0.8.0+12+gbe21b6d-1
                               siglo              0.8.8-1             0.8.14-1
                    iio-sensor-proxy                    -                3.3-0
                     linux-pinephone            5.13.13-1             5.14.0-1
             linux-pinephone-headers            5.13.13-1             5.14.0-1
                             dolphin21.08.0.r6701.g653d5714a-121.08.0.r6702.g27bfcde4e-1
                 extra-cmake-modules5.85.0.r3361.g3a75f89-15.85.0.r3363.g6561e3a-1
                           itinerary21.08.0.r1436.gcec3571-121.08.0.r1439.g8a25d70-1
                           kcalutils21.08.0.r865.gac8e66378-121.08.0.r866.g67b0ea331-1
                              kclock  21.08.r0.gfd706d6-1  21.08.r2.g51f3f5c-1
                         kcoreaddons5.85.0.r1277.g13a43b4f-15.85.0.r1278.g2cdb5127-1
                       kdepim-addons21.08.0.r4321.g5d98491b-121.08.0.r4323.gca443751-1
                         kinfocenter5.22.5.r1896.g239ca59-15.22.5.r1898.g23969ec-1
                                 kio5.85.0.r4954.geaa2729e-15.85.0.r4955.g451044fa-1
                          kio-extras21.08.0.r7104.gb46ec2e8-121.08.0.r7105.ga3c1c8ba-1
                          kitinerary21.08.0.r1921.g0f39336-121.08.0.r1923.g0f46893-1
                           kleopatra21.08.0.r5970.g2552ed53-121.08.0.r5971.g04170a83-1
                       kosmindoormap21.08.0.r633.g5957e06-121.08.0.r636.gb112375-1
                                kpty5.85.0.r339.g3d4ebc6-15.85.0.r340.gfb28723-1
                    kpublictransport21.08.0.r1738.g52d7f5d5-121.08.0.r1740.ge1bb3ed0-1
                             kscreen5.22.5.r1344.g0cd0cb0-15.22.5.r1345.g78c65e1-1
                            kwayland5.85.0.r1107.g887dbd1-15.85.0.r1108.ge2ae850-1
                     kwayland-server5.22.5.r1374.gcc0ed74-15.22.5.r1375.gbb39b06-1
                            kweather  21.08.r0.g442c888-1  21.08.r2.gd99813f-1
                                kwin5.22.5.r19903.g63b16cdf9-15.22.5.r19911.g0a2c51148-1
                       kwindowsystem5.85.0.r615.ga5f86f1-15.85.0.r617.g59b849d-1
                          libkscreen5.22.5.r1588.g8e78076-15.22.5.r1589.gf88cb0e-1
                        libksysguard5.22.5.r2286.gde2cf64-15.22.5.r2287.g168038e-1
                         libquotient     r2064.g06a8ef6-1     r2066.g45d0e42-1
                          mailcommon21.08.0.r1101.g6572d14-121.08.0.r1103.gcc3e3fc-1
             plasma-phone-components5.22.5.r1455.g31448728-15.22.5.r1456.g464141c0-1
            plasma-wayland-protocols1.3.0.r1030.g9a11267-11.3.0.r1033.g2464dac-1
              plasma-wayland-session5.22.5.r10592.gf9aa31d02-15.22.5.r10600.ga40dc17ea-1
                    plasma-workspace5.22.5.r10592.gf9aa31d02-15.22.5.r10600.ga40dc17ea-1
                          powerdevil5.22.5.r2461.g497647f1-15.22.5.r2462.g9fa3e568-1
                 syntax-highlighting5.85.0.r1683.g439f8cbf-15.85.0.r1685.g5780ab44-1
Hi,
Odroid c4 kde up to date.
c2 and n2 not tested…
I pushed another set of more mobile-friendly updates …
 - arm-testing community aarch64:  56 new and 53 removed package(s)
 - arm-testing core aarch64:  1 new and 0 removed package(s)
 - arm-testing extra aarch64:  30 new and 29 removed package(s)
 - arm-testing kde-unstable aarch64:  17 new and 17 removed package(s)
                          callaudiod   0.1.0+4+g84ed2eb-2   0.1.0+4+g84ed2eb-3
                               calls 41beta+21+gb8f6287-1 41beta+29+g2df221c-1
                               abuse               0.8-11              0.9.0-1
                        ansible-lint              5.1.2-1              5.1.3-1
                                  b4              0.7.3-1              0.8.0-1
                             blender          17:2.93.3-1          17:2.93.4-1
                               chafa              1.6.1-1              1.8.0-1
                             cockpit                251-1                252-1
                         cockpit-pcp                251-1                252-1
                      cockpit-podman                 33-1                 34-1
                            edbrowse              3.7.6-2                    -
                              faudio              21.08-1              21.09-1
                                  go             2:1.17-1             2:1.17-2
                             jenkins              2.308-1              2.309-1
                       jupyter-jsmol           2021.3.0-1           2021.9.0-1
                          jupyterlab              3.1.9-1             3.1.10-1
                  jupyterlab-widgets              1.0.0-1              1.0.1-1
                             kak-lsp             11.0.0-1             11.0.0-2
                 libretro-beetle-psx               2550-1               2558-1
              libretro-beetle-psx-hw               2550-1               2558-1
                  libretro-core-info              1.9.7-1              1.9.8-1
            libretro-genesis-plus-gx               1794-1               1809-1
                       libretro-mgba               7980-1               8015-1
                   libretro-nestopia               1:60-1               1:62-1
                       libretro-play               6654-1               6684-1
                           msgpack-c              3.3.0-2              4.0.0-1
                         msgpack-cxx              4.0.1-2              4.0.2-1
                      nginx-mainline             1.21.1-1             1.21.2-1
                  nginx-mainline-src             1.21.1-1             1.21.2-1
                            normaliz              3.9.0-2              3.9.1-1
          pantheon-applications-menu              2.8.1-1              2.8.2-1
           pantheon-default-settings              6.0.0-2              6.0.1-1
                      pantheon-files              6.0.2-1              6.0.2-2
                       pantheon-mail              6.1.0-1              6.1.1-1
                              podman              3.3.0-1              3.3.1-1
                       podman-docker              3.3.0-1              3.3.1-1
                     python-daiquiri              3.0.0-3              3.0.1-1
                      python-fastapi             0.66.0-1             0.68.1-1
                 python-glanceclient              3.4.0-1              3.5.0-1
                   python-hypothesis             6.16.0-1             6.17.0-1
                       python-libcst             0.3.19-1             0.3.20-1
                     python-pyfakefs              4.5.0-1              4.5.1-1
                       python-pyodbc             4.0.31-1             4.0.32-1
                     python-pyroute2             0.5.19-1             0.5.19-2
             python-pytest-freezegun              0.4.2-3              0.4.2-4
               python-pytest-twisted             1.13.3-1             1.13.4-1
                  python-ruamel-yaml            0.17.13-1            0.17.14-1
                   python-tldextract              3.1.1-1              3.1.2-1
            python-typing_extensions           3.10.0.0-1           3.10.0.2-1
                      ruby-nats-pure              0.7.0-1              0.7.2-1
               singularity-container              3.8.1-1              3.8.2-1
         v2ray-domain-list-community     20210816014827-1     20210901054852-1
                      weechat-matrix              0.3.0-2              0.3.0-3
                               goxel                    -             0.10.7-2
           vscode-css-languageserver                    -             1.59.1-1
          vscode-html-languageserver                    -             1.59.1-1
          vscode-json-languageserver                    -             1.59.1-1
            uboot-odroid-c4-mainline                    -            2021.07-1
                       meson64-tools                    -           20200803-1
                            chromium      92.0.4515.159-1       93.0.4577.63-1
                             dolphin            21.08.0-1            21.08.0-2
                           mercurial              5.8.1-1              5.9.1-1
                      mkvtoolnix-cli             60.0.0-1             61.0.0-1
                      mkvtoolnix-gui             60.0.0-1             61.0.0-1
                       python-django              3.2.6-1              3.2.7-1
                   python-fastimport             0.9.13-1             0.9.14-1
                              qt6-3d              6.1.2-1              6.1.3-1
                         qt6-5compat              6.1.2-1              6.1.3-1
                            qt6-base              6.1.2-1              6.1.3-1
                          qt6-charts              6.1.2-1              6.1.3-1
                       qt6-datavis3d              6.1.2-1              6.1.3-1
                     qt6-declarative              6.1.2-1              6.1.3-1
                             qt6-doc              6.1.2-1              6.1.3-1
                        qt6-examples              6.1.2-1              6.1.3-1
                    qt6-imageformats              6.1.2-1              6.1.3-1
                          qt6-lottie              6.1.2-1              6.1.3-1
                     qt6-networkauth              6.1.2-1              6.1.3-1
                         qt6-quick3d              6.1.2-1              6.1.3-1
                  qt6-quickcontrols2              6.1.2-1              6.1.3-1
                   qt6-quicktimeline              6.1.2-1              6.1.3-1
                           qt6-scxml              6.1.2-1              6.1.3-1
                     qt6-shadertools              6.1.2-1              6.1.3-1
                             qt6-svg              6.1.2-1              6.1.3-1
                           qt6-tools              6.1.2-2              6.1.3-1
                    qt6-translations              6.1.2-1              6.1.3-1
                 qt6-virtualkeyboard              6.1.2-1              6.1.3-1
                         qt6-wayland              6.1.2-1              6.1.3-1
                                 re2         1:20210801-1         1:20210901-1
                              breeze5.22.5.r2239.g88518ebc-15.22.5.r2240.ge63d64ae-1
                          breeze-gtk5.22.5.r420.gfccd7df-15.22.5.r421.g58344d6-1
                            discover5.22.5.r8289.g5ab0be59-15.22.5.r8290.g7674dae2-1
                     incidenceeditor21.08.0.r761.g38d8631-121.08.0.r762.ga434518-1
                   kactivitymanagerd5.22.5.r1366.g6536521-15.22.5.r1367.g73e9cb5-1
                        kdeclarative5.85.0.r915.g66c5bb0-15.85.0.r917.ge137fdf-1
                         kinfocenter5.22.5.r1898.g23969ec-15.22.5.r1900.g6b4f8ae-1
                           kirigami25.85.0.r2870.g70c05b2c-15.85.0.r2874.g19ddd16e-1
                     kwayland-server5.22.5.r1375.gbb39b06-15.22.5.r1378.g12f273e-1
                                kwin5.22.5.r19911.g0a2c51148-15.22.5.r19915.g0042d2d8c-1
                        libksysguard5.22.5.r2287.g168038e-15.22.5.r2288.g6372f0f-1
          plasma-browser-integration5.22.5.r1277.g1166fca0-15.22.5.r1278.g9d9726f2-1
                      plasma-desktop5.22.5.r8591.gc3cc2b2d1-15.22.5.r8592.g6d54c27d8-1
                    plasma-framework5.85.0.r15970.g0a519d059-15.85.0.r15971.gf393bace8-1
                          plasma-sdk5.22.5.r2276.gf5abde09-15.22.5.r2277.g956ce673-1
              plasma-wayland-session5.22.5.r10600.ga40dc17ea-15.22.5.r10603.gf9ae5830e-1
                    plasma-workspace5.22.5.r10600.ga40dc17ea-15.22.5.r10603.gf9ae5830e-1
I’ll test it as soon as possible.
It does not boot the kernel yet. It’s purely for our testing.
I looked the c4, the only update I found is the kernel
5.14.0-2 to 5.14.0-3
should I up date uboot ? the kernel ? both ?
Unless you want a not-booting device, stick to just the updates that’s presented. :slight_smile:
OK, I don’t install both.
In the future, how to build an image without issue ?
Pretty sure the current profile for the Odroid C4 just works.
