[ARM Testing Update] 2021-08-29 - MMSD-TNG, Code, Pipewire and kernels
Hello ARM community.
Rather small update this time. Enjoy!
Some highlights:
  • Most of our kernels got updated
  • Added mmsd-tng and vvmd to the repository
  • Code got updated to 1.59.1
  • And a new point release brings Pipewire to 0.3.34
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sun Aug 29 21:31:49 CEST 2021)
  • arm-testing community aarch64: 183 new and 173 removed package(s)
  • arm-testing core aarch64: 13 new and 13 removed package(s)
  • arm-testing extra aarch64: 191 new and 190 removed package(s)
  • arm-testing kde-unstable aarch64: 217 new and 217 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2021-08-24         2021-08-29
                           bitwarden             1.28.1-1             1.28.2-1
                     blender-2.7-es22.79b.r71421.e045fe53f1b-72.79b.r71421.e045fe53f1b-9
                                code             1.58.2-1             1.59.1-1
                            electron             13.2.2-1             13.2.3-1
                          electron12            12.0.17-1            12.0.18-1
                nemo-qml-plugin-dbus             2.1.24-2             2.1.25-1
                     pico-wizard-git       r142.0db2fdb-1       r142.0db2fdb-2
           pico-wizard-plamo-scripts       r142.0db2fdb-1       r142.0db2fdb-2
            pinephone-manjaro-tweaks           20210811-2           20210826-2
                   python-ytmusicapi           0.18.0-2.1             0.18.0-3
                               snapd             2.51.6-1             2.51.7-1
                            mmsd-tng                    -              1.1.1-1
                               qcoro                    -              0.1.0-1
                                vvmd                    -                0.3-1
:: Different sync package(s) in repository community aarch64
                          aliyun-cli             3.0.82-1             3.0.89-1
                   arch-repro-status              1.2.4-1              1.2.5-1
                                 bat             0.18.2-1             0.18.3-1
                           bettercap             2.31.1-1             2.32.0-1
                        cargo-expand              1.0.8-1              1.0.9-1
                       cargo-release             0.17.0-1             0.17.1-1
                              ccache                4.3-1                4.4-1
                   containers-common             0.43.2-1             0.43.2-2
                            copr-cli               1.94-1               1.95-1
          deepin-qt5platform-plugins             5.0.23-3             5.0.40-1
                                deno             1.13.0-1             1.13.2-1
                          diffoscope                181-1                182-1
                      discord-canary            0.0.126-1            0.0.127-1
                              elvish             0.16.1-1             0.16.3-1
                            fail2ban             0.11.2-1             0.11.2-2
                             fig2dev            3.2.8.a-1            3.2.8.b-1
              firefox-tree-style-tab             3.8.11-1             3.8.12-1
                            fuse-zip              0.7.1-1              0.7.2-1
                          github-cli             1.14.0-1              2.0.0-1
                             glances              3.2.1-1              3.2.2-1
                         go-ethereum             1.10.7-1             1.10.8-1
                              gopass             1.12.7-1             1.12.8-1
                              gpxsee                9.4-1                9.5-1
                             granite              6.1.0-1              6.1.1-1
                                 hex              0.4.1-1              0.4.2-2
                            homebank              5.5.2-1              5.5.3-1
                                i2pd             2.38.0-2             2.39.0-1
                          ibus-table             1.14.0-1             1.14.1-1
                             ipython             7.26.0-1             7.27.0-1
                                 iwd               1.16-1               1.17-1
                             jenkins              2.307-1              2.308-1
                             kakoune         2020.09.01-1         2021.08.28-1
                           kdiskmark              2.2.0-1              2.2.1-1
                          keepalived              2.2.3-1              2.2.4-1
                              kotlin             1.5.21-1             1.5.30-1
                         kube-linter              0.2.2-1              0.2.3-1
                          latte-dock             0.10.0-1             0.10.1-1
                             lazygit             0.28.2-1               0.29-1
                         libstatgrab               0.92-2             0.92.1-1
                            logwatch              7.5.5-1              7.5.6-1
                            lollypop             1.4.22-1             1.4.23-1
                              marked              3.0.0-1              3.0.2-1
                           menumaker            0.99.12-1            0.99.13-1
                               micro             2.0.10-1             2.0.10-2
                           miniserve             0.14.0-1             0.15.0-1
                           nextcloud             22.1.0-1             22.1.1-1
             nextcloud-app-bookmarks            1:4.4.0-1            1:4.4.1-1
              nextcloud-app-contacts              4.0.1-1              4.0.2-1
                nextcloud-app-spreed           1:12.0.1-1           1:12.1.0-1
                    nextcloud-client              3.3.1-1            1:3.3.0-1
     nextcloud-client-cloudproviders              3.3.1-1            1:3.3.0-1
                  nginx-mod-auth-pam              1.5.2-3              1.5.3-1
                              ngircd                 26-1               26.1-1
                       nlohmann-json             3.10.0-1             3.10.1-1
                              nodejs             16.7.0-1             16.8.0-1
             nomad-driver-containerd                0.9-1              0.9.1-1
                                 npm             7.21.0-1             7.21.1-1
                                npm6            6.14.14-1            6.14.15-1
                 openshadinglanguage          1.11.14.0-3          1.11.14.2-1
                              openxr             1.0.18-1             1.0.19-1
                           osdlyrics              0.5.9-1             0.5.10-1
                     pacman-bintrans              0.1.0-1              0.1.1-1
               pacman-bintrans-tools              0.1.0-1              0.1.1-1
          pantheon-applications-menu              2.8.0-1              2.8.1-1
                   pantheon-calendar              6.0.0-1              6.0.1-1
           pantheon-default-settings              6.0.0-1              6.0.0-2
                      pantheon-files              6.0.1-1              6.0.2-1
                   pantheon-sideload              6.0.0-1              6.0.1-1
         perl-class-data-inheritable               0.08-9               0.09-1
         perl-class-method-modifiers               2.12-7               2.13-1
                      perl-data-dump               1.23-7               1.25-1
               perl-devel-stacktrace               2.03-5               2.04-1
                perl-exception-class               1.44-5               1.45-1
                    perl-file-remove               1.58-2               1.60-1
                     perl-file-slurp            9999.28-2            9999.32-1
                        perl-log-any              1.709-2              1.710-1
                perl-params-validate               1.29-6               1.30-1
                      perl-role-tiny           2.001004-3           2.002004-1
               perl-software-license           0.103014-4           0.104001-1
                      perl-sub-quote           2.006003-4           2.006006-1
                       perl-sys-virt              7.4.0-1              7.5.0-1
                      perl-test-deep              1.128-3              1.130-1
               perl-test-differences               0.64-7               0.68-1
                perl-test-nowarnings               1.04-6               1.06-1
                  perl-test-warnings              0.026-7              0.031-1
                               pound                3.0-3              3.0.1-1
                              pulumi             3.10.1-1             3.11.0-1
                               pyenv              2.0.4-1              2.0.5-1
                             pyright            1.1.163-1            1.1.164-1
                             pysolfc             2.10.1-2             2.12.0-1
                  python-aiobotocore              1.4.0-1              1.4.1-1
                   python-aioconsole              0.3.1-1              0.3.2-1
                    python-bitstring              3.1.7-3              3.1.9-1
                         python-cfgv              3.3.0-2              3.3.1-1
                     python-cherrypy             18.6.0-5             18.6.1-1
                         python-copr              1.111-1              1.112-1
         python-cryptography-vectors              3.4.7-1              3.4.8-1
                        python-faker             8.12.0-1             8.12.1-1
                       python-gitlab             2.10.0-1             2.10.1-1
     python-google-api-python-client             2.17.0-1             2.18.0-1
                       python-hcloud             1.13.0-1             1.16.0-1
                   python-hypothesis             6.15.0-1             6.16.0-1
              python-internetarchive              2.0.3-1              2.1.0-1
                     python-jwcrypto              0.9.1-1                1.0-1
                   python-kiwisolver              1.3.1-3              1.3.2-1
                 python-openstacksdk             0.58.0-1             0.59.0-1
                      python-osc-lib              2.4.1-1              2.4.2-1
                         python-pdoc              7.3.1-1              7.4.0-1
                 python-phonenumbers            8.12.30-1            8.12.31-1
                      python-pymupdf            1.18.16-1            1.18.17-1
                       python-qasync             0.18.1-1             0.19.0-1
                     python-queuelib              1.6.1-1              1.6.2-1
                  python-ruamel-yaml            0.17.11-1            0.17.13-1
             python-securesystemslib             0.20.1-1             0.21.0-1
               python-setuptools-scm              6.0.1-1              6.1.0-1
                   python-simplejson             3.17.4-1             3.17.5-1
                       python-stestr              3.2.0-1              3.2.0-2
                    python-terminado             0.10.1-1             0.11.1-1
                   python-tldextract              3.1.0-1              3.1.1-1
                   python-wsgiproxy2              0.5.0-1              0.5.1-1
                                qcad           3.26.4.5-1           3.26.4.7-1
                                qmmp              1.5.1-1              2.0.0-1
                         rawtherapee              1:5.8-1              1:5.8-2
                           seamonkey           2.53.8.1-1             2.53.9-1
                          serverless             2.54.0-1             2.56.0-1
                            shotwell          2:0.30.13-1          2:0.30.14-1
                           skk-jisyo           20210718-1           20210822-1
                            smartdns                 34-1                 35-1
                            smplayer             21.1.0-1             21.8.0-1
                           ssh-audit              2.4.0-2              2.5.0-1
                                sslh               1.22-1             1.22.b-1
                            starship             0.56.0-2             0.57.0-1
                             step-ca             0.16.2-1             0.17.1-1
                            swift-im              4.0.2-5              4.0.2-6
                             swiften              4.0.2-5              4.0.2-6
              switchboard-plug-about              6.0.0-1              6.0.1-1
    switchboard-plug-online-accounts              6.1.0-1              6.2.0-1
              switchboard-plug-power              2.5.0-1              2.6.0-1
                           tailscale             1.12.4-1             1.14.0-1
                                 tea              0.7.0-2              0.7.1-1
                          terragrunt             0.31.3-1             0.31.7-1
                         timescaledb              2.4.0-4              2.4.1-1
                               toxic             0.10.1-1             0.11.1-1
                             traefik             2.4.13-1              2.5.1-1
                        ttf-ibm-plex              5.2.1-1              5.2.1-2
                          typescript              4.3.5-1              4.4.2-1
                          ufw-extras                0.5-2              0.6.0-1
                            umockdev             0.16.1-1             0.16.2-1
                             unbound             1.13.1-2             1.13.2-1
                           unclutter              1:1.5-2              1:1.6-1
                         v2ray-geoip       202108190022-1       202108260024-1
                                vcsh              2.0.0-1              2.0.1-1
                                 vym              2.7.1-3              2.8.8-1
       wingpanel-indicator-bluetooth              2.1.7-1              2.1.8-1
           wingpanel-indicator-power              6.0.0-1              6.1.0-1
                       wireshark-cli              3.4.7-1              3.4.8-1
                        wireshark-qt              3.4.7-1              3.4.8-1
                                xplr             0.14.5-1             0.14.6-1
                               yaegi             0.9.22-1             0.9.23-1
                             yoshimi              2.0.2-1              2.1.0-1
                                zola             0.14.0-1             0.14.1-2
                               zutty                0.9-1                0.9-2
                                 duf                    -              0.6.2-3
                              fisher                    -              4.3.0-2
                              miller                    -             5.10.2-1
                            miniflux                    -             2.0.32-2
                  python-lsp-jsonrpc                    -              1.0.0-1
                   python-lsp-server                    -              1.2.1-2
                              tracer                    -              0.7.8-1
:: Different overlay package(s) in repository core aarch64
                               linux            5.13.12-1            5.13.13-1
                       linux-headers            5.13.12-1            5.13.13-1
                     linux-pinephone            5.13.12-2            5.13.13-1
             linux-pinephone-headers            5.13.12-2            5.13.13-1
                            linux-rc           5.14.rc7-3           5.14.rc7-4
                    linux-rc-headers           5.14.rc7-3           5.14.rc7-4
:: Different sync package(s) in repository core aarch64
                          libarchive              3.5.1-1              3.5.2-1
                              libcap               2.51-1               2.53-1
                             openssl            1.1.1.k-1            1.1.1.l-1
                   openssl-cryptodev            1.1.1.k-1            1.1.1.l-1
                           run-parts             4.11.2-1                5.3-1
                            usbutils                013-1                014-1
                            xfsprogs             5.12.0-1             5.13.0-1
:: Different overlay package(s) in repository extra aarch64
                             firefox             91.0.1-1             91.0.2-1
                    firefox-i18n-ach             91.0.1-1             91.0.2-1
                     firefox-i18n-af             91.0.1-1             91.0.2-1
                     firefox-i18n-an             91.0.1-1             91.0.2-1
                     firefox-i18n-ar             91.0.1-1             91.0.2-1
                    firefox-i18n-ast             91.0.1-1             91.0.2-1
                     firefox-i18n-az             91.0.1-1             91.0.2-1
                     firefox-i18n-be             91.0.1-1             91.0.2-1
                     firefox-i18n-bg             91.0.1-1             91.0.2-1
                     firefox-i18n-bn             91.0.1-1             91.0.2-1
                     firefox-i18n-br             91.0.1-1             91.0.2-1
                     firefox-i18n-bs             91.0.1-1             91.0.2-1
                     firefox-i18n-ca             91.0.1-1             91.0.2-1
                    firefox-i18n-cak             91.0.1-1             91.0.2-1
                     firefox-i18n-cs             91.0.1-1             91.0.2-1
                     firefox-i18n-cy             91.0.1-1             91.0.2-1
                     firefox-i18n-da             91.0.1-1             91.0.2-1
                     firefox-i18n-de             91.0.1-1             91.0.2-1
                    firefox-i18n-dsb             91.0.1-1             91.0.2-1
                     firefox-i18n-el             91.0.1-1             91.0.2-1
                  firefox-i18n-en-ca             91.0.1-1             91.0.2-1
                  firefox-i18n-en-gb             91.0.1-1             91.0.2-1
                  firefox-i18n-en-us             91.0.1-1             91.0.2-1
                     firefox-i18n-eo             91.0.1-1             91.0.2-1
                  firefox-i18n-es-ar             91.0.1-1             91.0.2-1
                  firefox-i18n-es-cl             91.0.1-1             91.0.2-1
                  firefox-i18n-es-es             91.0.1-1             91.0.2-1
                  firefox-i18n-es-mx             91.0.1-1             91.0.2-1
                     firefox-i18n-et             91.0.1-1             91.0.2-1
                     firefox-i18n-eu             91.0.1-1             91.0.2-1
                     firefox-i18n-fa             91.0.1-1             91.0.2-1
                     firefox-i18n-ff             91.0.1-1             91.0.2-1
                     firefox-i18n-fi             91.0.1-1             91.0.2-1
                     firefox-i18n-fr             91.0.1-1             91.0.2-1
                  firefox-i18n-fy-nl             91.0.1-1             91.0.2-1
                  firefox-i18n-ga-ie             91.0.1-1             91.0.2-1
                     firefox-i18n-gd             91.0.1-1             91.0.2-1
                     firefox-i18n-gl             91.0.1-1             91.0.2-1
                     firefox-i18n-gn             91.0.1-1             91.0.2-1
                  firefox-i18n-gu-in             91.0.1-1             91.0.2-1
                     firefox-i18n-he             91.0.1-1             91.0.2-1
                  firefox-i18n-hi-in             91.0.1-1             91.0.2-1
                     firefox-i18n-hr             91.0.1-1             91.0.2-1
                    firefox-i18n-hsb             91.0.1-1             91.0.2-1
                     firefox-i18n-hu             91.0.1-1             91.0.2-1
                  firefox-i18n-hy-am             91.0.1-1             91.0.2-1
                     firefox-i18n-ia             91.0.1-1             91.0.2-1
                     firefox-i18n-id             91.0.1-1             91.0.2-1
                     firefox-i18n-is             91.0.1-1             91.0.2-1
                     firefox-i18n-it             91.0.1-1             91.0.2-1
                     firefox-i18n-ja             91.0.1-1             91.0.2-1
                     firefox-i18n-ka             91.0.1-1             91.0.2-1
                    firefox-i18n-kab             91.0.1-1             91.0.2-1
                     firefox-i18n-kk             91.0.1-1             91.0.2-1
                     firefox-i18n-km             91.0.1-1             91.0.2-1
                     firefox-i18n-kn             91.0.1-1             91.0.2-1
                     firefox-i18n-ko             91.0.1-1             91.0.2-1
                    firefox-i18n-lij             91.0.1-1             91.0.2-1
                     firefox-i18n-lt             91.0.1-1             91.0.2-1
                     firefox-i18n-lv             91.0.1-1             91.0.2-1
                     firefox-i18n-mk             91.0.1-1             91.0.2-1
                     firefox-i18n-mr             91.0.1-1             91.0.2-1
                     firefox-i18n-ms             91.0.1-1             91.0.2-1
                     firefox-i18n-my             91.0.1-1             91.0.2-1
                  firefox-i18n-nb-no             91.0.1-1             91.0.2-1
                  firefox-i18n-ne-np             91.0.1-1             91.0.2-1
                     firefox-i18n-nl             91.0.1-1             91.0.2-1
                  firefox-i18n-nn-no             91.0.1-1             91.0.2-1
                     firefox-i18n-oc             91.0.1-1             91.0.2-1
                  firefox-i18n-pa-in             91.0.1-1             91.0.2-1
                     firefox-i18n-pl             91.0.1-1             91.0.2-1
                  firefox-i18n-pt-br             91.0.1-1             91.0.2-1
                  firefox-i18n-pt-pt             91.0.1-1             91.0.2-1
                     firefox-i18n-rm             91.0.1-1             91.0.2-1
                     firefox-i18n-ro             91.0.1-1             91.0.2-1
                     firefox-i18n-ru             91.0.1-1             91.0.2-1
                     firefox-i18n-si             91.0.1-1             91.0.2-1
                     firefox-i18n-sk             91.0.1-1             91.0.2-1
                     firefox-i18n-sl             91.0.1-1             91.0.2-1
                    firefox-i18n-son             91.0.1-1             91.0.2-1
                     firefox-i18n-sq             91.0.1-1             91.0.2-1
                     firefox-i18n-sr             91.0.1-1             91.0.2-1
                  firefox-i18n-sv-se             91.0.1-1             91.0.2-1
                     firefox-i18n-ta             91.0.1-1             91.0.2-1
                     firefox-i18n-te             91.0.1-1             91.0.2-1
                     firefox-i18n-th             91.0.1-1             91.0.2-1
                     firefox-i18n-tr             91.0.1-1             91.0.2-1
                     firefox-i18n-uk             91.0.1-1             91.0.2-1
                     firefox-i18n-ur             91.0.1-1             91.0.2-1
                     firefox-i18n-uz             91.0.1-1             91.0.2-1
                     firefox-i18n-vi             91.0.1-1             91.0.2-1
                     firefox-i18n-xh             91.0.1-1             91.0.2-1
                  firefox-i18n-zh-cn             91.0.1-1             91.0.2-1
                  firefox-i18n-zh-tw             91.0.1-1             91.0.2-1
:: Different sync package(s) in repository extra aarch64
                         389-ds-base              2.0.7-1              2.0.8-1
                        alertmanager             0.22.2-1             0.23.0-1
                  alsa-card-profiles           1:0.3.33-1           1:0.3.34-1
                               bluez               5.60-1               5.61-1
                          bluez-cups               5.60-1               5.61-1
                       bluez-hid2hci               5.60-1               5.61-1
                          bluez-libs               5.60-1               5.61-1
                       bluez-plugins               5.60-1               5.61-1
                         bluez-utils               5.60-1               5.61-1
                          bubblewrap              0.4.1-2              0.5.0-1
                     bubblewrap-suid              0.4.1-2              0.5.0-1
                          cairo-perl              1.108-1              1.109-1
                               cmake             3.21.1-1             3.21.2-2
                        cups-filters             1.28.9-1            1.28.10-1
                             devhelp               40.0-2               40.1-1
                               elisa            21.08.0-1            21.08.0-2
                                 ell               0.42-1               0.43-1
                             flatpak             1.11.2-1             1.11.3-1
                     flatpak-builder             1.0.14-2              1.1.1-1
                         foomatic-db         3:20210528-1         3:20210828-1
                 foomatic-db-nonfree         3:20210528-1         3:20210828-1
            foomatic-db-nonfree-ppds         3:20210528-1         3:20210828-1
                    foomatic-db-ppds         3:20210528-1         3:20210828-1
                             fprintd             1.92.0-1             1.94.0-1
                                 gdl             3.34.0-2             3.40.0-1
                      geoip-database           20210727-1           20210824-1
                geoip-database-extra           20210727-1           20210824-1
                     glib-networking           1:2.68.1-1           1:2.68.2-1
                             glslang             11.5.0-1             11.6.0-1
                 gst-plugin-pipewire           1:0.3.33-1           1:0.3.34-1
                            help2man             1.48.4-1             1.48.5-1
                              kdiff3              1.9.2-1              1.9.3-1
                               krita              4.4.7-1              4.4.8-2
                          libplacebo            3.120.3-2            3.120.3-3
                              libssh              0.9.5-1              0.9.6-1
                         libssh-docs              0.9.5-1              0.9.6-1
                                 mpd            0.22.10-1            0.22.11-1
                                mutt              2.1.1-1              2.1.2-1
                           perl-fcgi               0.79-4               0.82-1
                  perl-file-sharedir              1.116-5              1.118-1
                                 php              8.0.9-1             8.0.10-1
                          php-apache              8.0.9-1             8.0.10-1
                             php-cgi              8.0.9-1             8.0.10-1
                           php-dblib              8.0.9-1             8.0.10-1
                           php-embed              8.0.9-1             8.0.10-1
                         php-enchant              8.0.9-1             8.0.10-1
                             php-fpm              8.0.9-1             8.0.10-1
                              php-gd              8.0.9-1             8.0.10-1
                            php-imap              8.0.9-1             8.0.10-1
                            php-intl              8.0.9-1             8.0.10-1
                            php-odbc              8.0.9-1             8.0.10-1
                           php-pgsql              8.0.9-1             8.0.10-1
                          php-phpdbg              8.0.9-1             8.0.10-1
                          php-pspell              8.0.9-1             8.0.10-1
                            php-snmp              8.0.9-1             8.0.10-1
                          php-sodium              8.0.9-1             8.0.10-1
                          php-sqlite              8.0.9-1             8.0.10-1
                            php-tidy              8.0.9-1             8.0.10-1
                             php-xsl              8.0.9-1             8.0.10-1
                                php7             7.4.22-1             7.4.23-1
                         php7-apache             7.4.22-1             7.4.23-1
                            php7-cgi             7.4.22-1             7.4.23-1
                          php7-dblib             7.4.22-1             7.4.23-1
                          php7-embed             7.4.22-1             7.4.23-1
                        php7-enchant             7.4.22-1             7.4.23-1
                            php7-fpm             7.4.22-1             7.4.23-1
                             php7-gd             7.4.22-1             7.4.23-1
                           php7-imap             7.4.22-1             7.4.23-1
                           php7-intl             7.4.22-1             7.4.23-1
                           php7-odbc             7.4.22-1             7.4.23-1
                          php7-pgsql             7.4.22-1             7.4.23-1
                         php7-phpdbg             7.4.22-1             7.4.23-1
                         php7-pspell             7.4.22-1             7.4.23-1
                           php7-snmp             7.4.22-1             7.4.23-1
                         php7-sodium             7.4.22-1             7.4.23-1
                         php7-sqlite             7.4.22-1             7.4.23-1
                           php7-tidy             7.4.22-1             7.4.23-1
                            php7-xsl             7.4.22-1             7.4.23-1
                       pipewire-alsa           1:0.3.33-1           1:0.3.34-1
                       pipewire-docs           1:0.3.33-1           1:0.3.34-1
                       pipewire-jack           1:0.3.33-1           1:0.3.34-1
              pipewire-media-session           1:0.3.33-1           1:0.3.34-1
                      pipewire-pulse           1:0.3.33-1           1:0.3.34-1
                   pipewire-zeroconf           1:0.3.33-1           1:0.3.34-1
                          prometheus             2.29.1-1             2.29.2-1
                 python-cryptography              3.4.7-1              3.4.8-1
                      python-twisted             21.2.0-4             21.7.0-1
                               samba             4.14.6-1             4.14.7-1
                             shaderc             2021.1-1             2021.1-2
                           smbclient             4.14.6-1             4.14.7-1
                    source-highlight              3.1.9-5              3.1.9-6
                              upower            0.99.12-2            0.99.13-1
                      vulkan-headers          1:1.2.187-1          1:1.2.188-1
                   vulkan-icd-loader            1.2.187-1            1.2.188-1
                           xorg-xrdb              1.2.0-2              1.2.1-1
                    perl-fcgi-client                    -               0.09-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.08.0.r12560.gce740211a-121.08.0.r12561.gaf9c09ab1-1
                    akonadi-calendar21.08.0.r1973.g6a48eb5-121.08.0.r1976.g7894f7f-1
                    akonadi-contacts21.08.0.r3049.g1c29e2c5-121.08.0.r3053.gb72d4467-1
               akonadi-import-wizard21.08.0.r1728.gc01c991-121.08.0.r1732.g0828374-1
                        akonadi-mime21.08.0.r1638.g2d649d0-121.08.0.r1639.gddb8661-1
                      akonadi-search21.08.0.r1119.gcd996be-121.08.0.r1120.g2413dce-1
                      akonadiconsole21.08.0.r1516.g0f462f4-121.08.0.r1518.gaf88510-1
                           akregator21.08.0.r6213.gdd54f9c4-121.08.0.r6215.gb05cd487-1
                           angelfish  21.07.r7.g54f06d5-1  21.07.r8.g2d1473f-1
                              attica5.85.0.r830.gd0a134a-15.85.0.r831.g8473ba1-1
                       baloo-widgets21.08.0.r697.gaeda53f-121.08.0.r699.ged1e640-1
                           bluedevil1:5.22.4.r2275.g6557286a-11:5.22.4.r2276.ge6ecea09-1
                              bomber21.08.0.r521.g52c9ed0-121.08.0.r524.gd08dbb6-1
                                bovo21.08.0.r732.g66396f2-121.08.0.r734.g85982f7-1
                              breeze5.22.4.r2234.gfc30c11a-15.22.4.r2236.g32cf0733-1
                        breeze-icons5.85.0.r1777.g6d9155e7-15.85.0.r1780.gc37c21b6-1
                     calendarsupport21.08.0.r23.gf4024cd-121.08.0.r24.gcffed74-1
                            discover5.22.4.r8275.gdcdfe76b-15.22.4.r8282.g660ba31c-1
                             dolphin21.08.0.r6679.ge76bf5cb1-121.08.0.r6681.gae46ab2c3-1
                             drkonqi5.22.4.r683.g75d86806-15.22.4.r684.gace905b0-1
                               elisa21.08.0.r2753.g268f78d4-121.08.0.r2758.g28ab3ff6-1
                          eventviews21.07.80.r20.g8546471-121.07.80.r22.g36ab7aa-1
                frameworkintegration5.85.0.r594.gaa33981-15.85.0.r595.g53915cc-1
                           granatier21.08.0.r925.gb30c3bc-121.08.0.r928.gf0bc639-1
                            gwenview21.08.0.r6653.g5ab33f15-121.08.0.r6655.ga9dc7758-1
                     incidenceeditor21.08.0.r758.g23951f4-121.08.0.r761.g38d8631-1
                           itinerary21.08.0.r1434.gaf41337-121.08.0.r1435.g3519b25-1
                                 k3b1:21.08.0.r6669.g57244a4a2-11:21.08.0.r6671.ge5d8e4579-1
                         kactivities5.85.0.r1358.ga15ef9b-15.85.0.r1359.gb11fa28-1
                   kactivitymanagerd5.22.4.r1363.ge8b063d-15.22.4.r1366.g6536521-1
                        kaddressbook21.08.0.r6028.g68316021-121.08.0.r6032.g05df43c7-1
                              kalarm21.08.0.r6443.g229e30b8-121.08.0.r6444.ge911e84b-1
                              kapman21.08.0.r603.gf7203b6-121.08.0.r604.gc4883f7-1
                            karchive5.85.0.r501.gddef030-15.85.0.r502.gb48d3f4-1
                                kate21.08.0.r18329.g0dbfebcb4-121.08.0.r18334.gf91b702ac-1
                             katomic21.08.0.r917.g47ca0e1-121.08.0.r919.g676b3f1-1
                               kauth5.85.0.r444.ga478e23-15.85.0.r445.gfb6c512-1
                           kblackbox21.08.0.r725.g4682f86-121.08.0.r726.g56e775a-1
                             kblocks21.08.0.r668.g13cf37d-121.08.0.r670.g1fdb68e-1
                          kbookmarks5.85.0.r415.ga1a6901-15.85.0.r416.g79e6438-1
                             kbounce21.08.0.r806.g641a0b4-121.08.0.r808.ge96a31e-1
                           kbreakout21.08.0.r863.g33eb537-121.08.0.r864.ge6381a2-1
                           kcalutils21.08.0.r863.g396a4445d-121.08.0.r864.g23a775923-1
                              kclock 21.07.r26.gbbed814-1 21.07.r27.g03f1e79-1
                            kcmutils5.85.0.r538.g0f75ac4-15.85.0.r539.gedc1510-1
                             kcodecs5.85.0.r380.g5d13346-15.85.0.r382.g36e5682-1
                         kcompletion5.85.0.r452.g2397f79-15.85.0.r453.g9553e4d-1
                             kconfig5.85.0.r855.g4f8ed9b-15.85.0.r857.g3259a6e-1
                      kconfigwidgets5.85.0.r612.g233f3c2-15.85.0.r613.g56185bb-1
                         kcoreaddons5.85.0.r1270.g4c36440c-15.85.0.r1273.gdb7f2594-1
                         kdbusaddons5.85.0.r374.gfa42997-15.85.0.r375.gd30aaf7-1
                       kde-cli-tools5.22.4.r1860.g866d730-15.22.4.r1861.gbb9b116-1
                      kde-gtk-config5.22.4.r908.g50b9cd5-15.22.4.r910.g31496c4-1
                      kdebugsettings21.08.0.r838.g91247b5-121.08.0.r845.g575150f-1
                        kdeclarative5.85.0.r908.g37c280d-15.85.0.r910.g68f4ba0-1
                         kdecoration5.22.4.r268.g1dabf57-15.22.4.r269.gbd1fc8d-1
                                kded5.85.0.r413.ge013683-15.85.0.r414.g88483c6-1
                     kdelibs4support5.85.0.r1033.g5b253fa5-15.85.0.r1034.gcbb5134a-1
                            kdenlive21.08.0.r14774.g2d7992617-121.08.0.r14775.ga8f6552ce-1
                       kdepim-addons21.08.0.r4299.g8981fb3d-121.08.0.r4319.g6032b8bc-1
                      kdepim-runtime21.08.0.r15203.g4bbe0fe52-121.08.0.r15255.gd55edc301-1
                    kdeplasma-addons5.22.4.r8578.ged9064dcc-15.22.4.r8581.g5eab20a03-1
                     kdesignerplugin5.85.0.r331.gc2529e3-15.85.0.r332.g11b29ea-1
                           kdewebkit5.85.0.r279.g977967d-15.85.0.r280.g3050935-1
                            kdiamond21.08.0.r668.g7fc116c-121.08.0.r670.gb374f30-1
                              kdnssd5.85.0.r318.gf5e6f53-15.85.0.r321.g1909661-1
                           kdoctools5.85.0.r624.g32dace3-15.85.0.r625.gc799e16-1
                          kemoticons5.85.0.r381.g9adbf11-15.85.0.r382.g349334a-1
                       kfilemetadata5.85.0.r804.g37f293b-15.85.0.r805.g2e14ab0-1
                         kfourinline21.08.0.r981.ga16283e-121.08.0.r983.g9ca5e9c-1
                             kgamma55.22.4.r456.g5885d2f-15.22.4.r457.g45f405d-1
                         kgoldrunner21.08.0.r1238.g3c80544-121.08.0.r1241.g95ae027-1
                          kguiaddons5.85.0.r385.g363f67f-15.85.0.r386.g640f107-1
                  khealthcertificate        r68.05a8e52-1        r70.ab96f6f-1
                            khotkeys5.22.4.r2090.g1ec3eef-15.22.4.r2091.g925d5d9-1
                               khtml5.85.0.r553.gf3a98a4-15.85.0.r554.ga2275b8-1
                         kiconthemes5.85.0.r536.g40d092d-15.85.0.r538.g2d9a393-1
                           kidletime5.85.0.r311.g1fb8340-15.85.0.r312.ge3e65c0-1
                                kigo21.08.0.r522.g625cfd7-121.08.0.r524.ge4b9861-1
                            killbots21.08.0.r735.g9a89476-121.08.0.r737.g3d36709-1
                       kimageformats5.85.0.r354.gaade392-15.85.0.r355.gabd550c-1
                         kinfocenter5.22.4.r1885.gc186bca-15.22.4.r1891.ga6de8d5-1
                               kinit5.85.0.r408.g396a0d3-15.85.0.r409.gc1393bc-1
                                 kio5.85.0.r4925.ga379d1b4-15.85.0.r4946.g85c5815e-1
                          kio-extras21.08.0.r7099.g57453699-121.08.0.r7102.g2f1225b9-1
                           kirigami25.85.0.r2865.g9efc15ba-15.85.0.r2866.ga5bbb63d-1
                              kiriki21.08.0.r419.gd1d767e-121.08.0.r420.g552e0a1-1
                         kitemmodels5.85.0.r554.g2d173d2-15.85.0.r555.g2829a12-1
                          kitemviews5.85.0.r336.ga5a735c-15.85.0.r337.ga2b3908-1
                          kitinerary21.08.0.r1888.gc06e62c-121.08.0.r1898.g921dbf0-1
                         kjobwidgets5.85.0.r373.gdd7a427-15.85.0.r374.gb87dc09-1
                                 kjs5.85.0.r333.gc185445-15.85.0.r334.g18a1876-1
                            kjsembed5.85.0.r302.g7b4ec52-15.85.0.r303.g58c98d2-1
                        kjumpingcube21.08.0.r784.g7772574-121.08.0.r786.gd7f52c4-1
                           kleopatra21.08.0.r5960.g2c00747e-121.08.0.r5967.gf63b94cb-1
                            klickety21.08.0.r634.g0b9b09e-121.08.0.r636.g4e8266e-1
                              klines21.08.0.r763.ge9a3a51-121.08.0.r766.g8d25ecc-1
                           kmahjongg21.08.0.r1468.g5f0ecda-121.08.0.r1470.g4934d8b-1
                      kmailtransport21.08.0.r1641.g014924e-121.08.0.r1646.gff70e5a-1
                               kmbox21.08.0.r537.g13fa9f3-121.08.0.r538.g9c2d473-1
                        kmediaplayer5.85.0.r293.gb43ad1c-15.85.0.r294.g62ae572-1
                           kmenuedit5.22.4.r970.ge312ac2-15.22.4.r971.g4b52f0c-1
                              kmines21.08.0.r1718.gfbc18fa-121.08.0.r1720.geb178d9-1
                                kmix21.08.0.r2378.g33e80f14-121.08.0.r2380.g4e33bdb8-1
                        knavalbattle21.08.0.r1386.g6b111a7-121.08.0.r1388.g3deb389-1
                           knewstuff5.85.0.r1196.gee390b03-15.85.0.r1197.gbd32c365-1
                              knotes21.08.0.r3501.g85cf3485-121.08.0.r3502.ga24d98ae-1
                      knotifications5.85.0.r672.g087e474-15.85.0.r673.gba5fbe7-1
                       knotifyconfig5.85.0.r350.gebd2dca-15.85.0.r351.g79996cf-1
                                kolf21.08.0.r1439.g8d1de09-121.08.0.r1441.g2e86d44-1
                           kollision21.08.0.r490.ge5fde57-121.08.0.r493.g80b1ae3-1
                         kolourpaint21.08.0.r2351.g3a3515b9-121.08.0.r2353.gd26a4739-1
                           konqueror21.08.0.r14929.gacfd16712-121.08.0.r14930.g16233d7b4-1
                            konquest21.08.0.r895.gafbcde6-121.08.0.r897.g42c00e1-1
                             konsole21.08.0.r7921.g9691d3f2-121.08.0.r7922.g2684bc7f-1
                             kontact21.08.0.r5375.gcb509c5b-121.08.0.r5376.g951a3fd5-1
                       kopeninghours21.08.0.r269.g9ef45c1-121.08.0.r270.ge9138d0-1
                          korganizer21.08.0.r11467.g5f13e6f3e-121.08.0.r11469.ga9c703ee6-1
                       kosmindoormap21.08.0.r630.g7ce3863-121.08.0.r631.g9125e47-1
                            kpackage5.85.0.r692.gf3fff45-15.85.0.r695.gff52520-1
                              kparts5.85.0.r519.g1187e96-15.85.0.r521.gb584212-1
                                kpat21.08.0.r2561.g5291a71-121.08.0.r2562.g02b8387-1
                             kpeople5.85.0.r1340.g3712e51-15.85.0.r1341.g98ca126-1
                        kpeoplevcard   0.1.r13.gda150a4-1   0.1.r14.gc6a135a-1
                             kpkpass21.08.0.r235.gd8294ec-121.08.0.r236.g2e358f4-1
                           kplotting5.85.0.r290.g9259a3f-15.85.0.r291.g8cbd04e-1
                             kpmcore21.08.0.r1195.gc47ee6c-121.08.0.r1196.gf466467-1
                    kpublictransport21.08.0.r1732.g7597a141-121.08.0.r1734.g0d3ee98b-1
                            kreversi21.08.0.r1222.g668dbbd-121.08.0.r1224.g5644cfa-1
                               kross5.85.0.r333.g87fb2aa-15.85.0.r334.g5108482-1
                             krunner5.85.0.r663.g0deb66d-15.85.0.r666.g8620c39-1
                             kscreen5.22.4.r1340.g4922979-15.22.4.r1343.g5f55e79-1
                       kscreenlocker5.22.4.r865.ge31b987-15.22.4.r866.g838a067-1
                            kservice5.85.0.r934.gf06e57d-15.85.0.r937.gb45dda2-1
                             kshisen21.08.0.r1199.g74d5caa-121.08.0.r1201.g83c41fe-1
                               ksirk21.08.0.r959.g2ecfb4d-121.08.0.r960.g16df763-1
                          ksnakeduel21.08.0.r804.g9519f69-121.08.0.r808.g65bc0d4-1
                          kspaceduel21.08.0.r629.ge419eee-121.08.0.r633.gee74017-1
                            ksquares21.08.0.r515.gb36c79b-121.08.0.r516.g1984f26-1
                         ksshaskpass5.22.4.r196.gdaa2679-15.22.4.r197.gcc50f63-1
                        ksystemstats5.22.4.r178.gc702da6-15.22.4.r184.gbbfce43-1
                         ktexteditor5.85.0.r2927.gab06e10a-15.85.0.r2932.g5752f356-1
                        ktextwidgets5.85.0.r408.gd0980b7-15.85.0.r409.g8a6af64-1
                               ktnef21.08.0.r661.g3d85473-121.08.0.r662.g6a0defe-1
                            ktorrent21.08.0.r2765.g023def08-121.08.0.r2772.gb6741c0b-1
                             kwallet5.85.0.r1083.g80e8806-15.85.0.r1084.g767b840-1
                         kwallet-pam5.22.4.r251.gbcc5922-15.22.4.r253.g258c428-1
                            kwayland5.85.0.r1106.g41bed39-15.85.0.r1107.g887dbd1-1
                kwayland-integration5.22.4.r180.g88c55e8-15.22.4.r181.gba8376d-1
                     kwayland-server5.22.4.r1367.g671d70d-15.22.4.r1369.g8385537-1
                      kwidgetsaddons5.85.0.r859.g5dfafee5-15.85.0.r863.g995cda63-1
                                kwin5.22.4.r19814.g6f6944058-15.22.4.r19855.g1dc749333-1
                       kwindowsystem5.85.0.r610.gc7c49f9-15.85.0.r612.g8bba48b-1
                              kwrite21.08.0.r18329.g0dbfebcb4-121.08.0.r18334.gf91b702ac-1
                             kwrited5.22.4.r481.g42c83af-15.22.4.r482.g9548753-1
                             kxmlgui5.85.0.r796.g63156af4-15.85.0.r798.gd12e8f62-1
                       kxmlrpcclient5.85.0.r454.gfeaaab040-15.85.0.r455.g2b6d42ae4-1
                      layer-shell-qt5.21.5.r42.gf6084b2-15.21.5.r43.g331505a-1
                          libakonadi21.08.0.r12560.gce740211a-121.08.0.r12561.gaf9c09ab1-1
                         libkdegames21.08.0.r2187.gf5381404-121.08.0.r2188.g14d1d4d0-1
                             libkleo21.08.0.r925.g8ab5857-121.08.0.r928.g1792abb-1
                        libkmahjongg21.08.0.r456.ga02d1ab-121.08.0.r457.g7e5db07-1
                          libkscreen5.22.4.r1587.g237850e-15.22.4.r1588.g8e78076-1
                           libksieve21.08.0.r1578.g4f8c2c48-121.08.0.r1580.gbe0aec6d-1
                        libksysguard5.22.4.r2273.g8df517f-15.22.4.r2281.g7665918-1
                         libktorrent21.08.0.r525.g2b6b0d8-121.08.0.r526.gb7edbf4-1
                         libquotient     r2060.g6953e55-1     r2062.g6d55a2c-1
                               lskat21.08.0.r810.g1ddcf41-121.08.0.r813.g132338e-1
                          mailcommon21.08.0.r1098.gd9eaa0b-121.08.0.r1100.gf705987-1
                        markdownpart21.08.0.r80.g641b90a-121.08.0.r82.g6480932-1
                           maui-clip  2.0.0.r2.g1ba0529-1  2.0.0.r3.ga6ebc76-1
                             mauikit 2.0.0.r7.gae562355-1 2.0.0.r9.gd9eda446-1
                mauikit-filebrowsing  2.0.0.r6.g399bc48-1  2.0.0.r8.g534416f-1
                  mauikit-imagetools  2.0.0.r2.g3fb2d7c-1  2.0.0.r3.g4d4e9b7-1
                          messagelib21.08.0.r6131.geb6be669-121.08.0.r6150.g8c3174ec-1
                               milou5.22.4.r747.gf7c2897-15.22.4.r748.gc10c48c-1
                             neochat    r1825.gd1451780-1    r1835.gc9935804-1
                              okular21.08.0.r9427.g7c2bac7d2-121.08.0.r9435.geee71036a-1
                              oxygen5.22.4.r4423.g9de84e89-15.22.4.r4424.g758c7aed-1
                            palapeli21.08.0.r1228.g4d18ee6-121.08.0.r1231.g772fc8c-1
                              parley21.08.0.r4420.g0cb87151-121.08.0.r4439.g4e7116c3-1
                    pim-sieve-editor21.08.0.r1505.g8bbd34b-121.08.0.r1506.gf077fd4-1
                           pimcommon21.07.80.r1089.g1aea133-121.07.80.r1095.g2a5773c-1
                      plasma-desktop5.22.4.r8588.gcfbcd374d-15.22.4.r8589.g329867e8c-1
                        plasma-disks5.22.4.r224.gd64d104-15.22.4.r226.gc9ddc9d-1
                     plasma-firewall5.22.4.r501.g28fa5f5-15.22.4.r503.g92efb24-1
                    plasma-framework5.85.0.r15946.g730889c89-15.85.0.r15965.g48bb0cb3a-1
                  plasma-integration5.22.4.r522.gb4ca236-15.22.4.r523.g62dbb6a-1
                    plasma-mobile-nm5.22.3.r3071.g54319f29-15.22.3.r3076.g9289bfbc-1
                         plasma-nano5.21.5.r153.g0149d86-15.21.5.r155.g306c3f3-1
                           plasma-nm5.22.3.r3071.g54319f29-15.22.3.r3076.g9289bfbc-1
                           plasma-pa5.22.4.r955.ga0738d9-15.22.4.r956.g34fecad-1
             plasma-phone-components5.22.3.r1444.gc0ff474e-15.22.3.r1447.g81a9b81e-1
                          plasma-sdk5.22.4.r2274.g02e980eb-15.22.4.r2275.g745f7845-1
                plasma-systemmonitor5.22.4.r477.g2aba8c3-15.22.4.r481.ge9abcd1-1
            plasma-wayland-protocols1.3.0.r1028.g8d33090-11.3.0.r1029.g7732ae4-1
              plasma-wayland-session5.22.4.r10540.g5d7726252-15.22.4.r10577.g7a0686b4e-1
                    plasma-workspace5.22.4.r10540.g5d7726252-15.22.4.r10577.g7a0686b4e-1
                    polkit-kde-agent5.22.4.r501.g4c2c54a-15.22.4.r502.g9fabd61-1
                          powerdevil5.22.4.r2459.gbaae8bdb-15.22.4.r2461.g497647f1-1
                       print-manager21.08.0.r1034.g66346a7-121.08.0.r1035.ga41de84-1
                              prison5.85.0.r326.ge95c14c-15.85.0.r328.gd82575e-1
                             purpose5.85.0.r872.gba798d7-15.85.0.r874.g94243ac-1
                  qqc2-desktop-style5.85.0.r517.g49b4811-15.85.0.r518.g44636fc-1
                                sddm0.19.0.r60.g72e337f-10.19.0.r62.gd2b4ad0-1
                            sddm-kcm5.22.4.r592.gd26553b-15.22.4.r593.ga7ef765-1
                               solid5.85.0.r700.gd439b89-15.85.0.r701.g623cd17-1
                              sonnet5.85.0.r628.g037df8e-15.85.0.r629.g780ad31-1
                           spectacle21.08.0.r1153.gb753cbe-121.08.0.r1154.ga7d958a-1
                             sweeper21.08.0.r527.g04cbc19-121.08.0.r528.gba2e86a-1
                 syntax-highlighting5.85.0.r1673.ge9ddb9ab-15.85.0.r1678.g408084f7-1
                      systemsettings5.22.4.r2482.gfc607095-15.22.4.r2485.ga83f8d9e-1
                        threadweaver5.85.0.r507.gf4b4ad4-15.85.0.r508.ge4efefc-1
                         vakzination        r89.ca87f0e-1        r90.f158025-1
                               vvave  2.0.0.r8.g8437f37-1 2.0.0.r11.g1b54bf8-1
                            wrapland5.22.4.r1536.g6d7ebc9-15.22.4.r1538.g8396e07-1
              xdg-desktop-portal-kde5.22.4.r377.g8c80da1-15.22.4.r378.g48b1670-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
A workaround can be to downgrade Vivaldi to a version before 4.1.2369.11
Old Issues
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
all good on the PBP!
Hello!
Out of curiosity, you added vvmd, but did not seem to include vvm player:
Which I would have assumed you would want to for the GUI front end. Was there any reason you didn’t include vvm player?
I can look into packages vvmplayer. :slight_smile:
Sounds good! I just wanted to make sure you were aware of it.
Got it packaged now and I believe I got the dependencies correct. Will upload it to unstable branch.
Awesome!
