[ARM Testing Update] 2021-08-24 - LibreOffice, Bitwarden, Radxa Zero and kernels
Hello ARM community.
Hot on the heals of 21.08 release!
Some highlights:
  • Most of our kernels got updated
  • Both LibreOffice suites received updates, with 7.1.5 for still and 7.2.0 for fresh
  • Bitwarden is now at version 1.28.1
  • We also introduced support for the Radxa Zero with this update
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Tue Aug 24 15:56:55 CEST 2021)
  • arm-testing community aarch64: 235 new and 214 removed package(s)
  • arm-testing core aarch64: 17 new and 17 removed package(s)
  • arm-testing extra aarch64: 286 new and 288 removed package(s)
  • arm-testing kde-unstable aarch64: 149 new and 149 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2021-08-18         2021-08-24
                               anbox      0_git20210320-4      0_git20210625-1
                 anbox-image-aarch64         0_20200520-6         0_20200520-7
                           bitwarden             1.27.1-3             1.28.1-1
                            electron             13.2.1-1             13.2.2-1
                  libpackagekit-glib            1.2.3-0.2              1.2.4-1
                              matray              1.0.2-1              1.0.3-1
                         mygnuhealth              1.0.3-1              1.0.4-1
                          packagekit            1.2.3-0.2              1.2.4-1
                            pacutils             0.11.0-4             0.11.1-1
                               snapd             2.51.5-1             2.51.6-1
                         vakzination                0.1-2                0.1-3
                             vivaldi        4.1.2369.16-1        4.1.2369.21-1
                    eg25-autorestart                    -                0.1-1
             radxa-zero-post-install                    -           20210822-1
                            waydroid                    -           20210730-1
:: Different sync package(s) in repository community aarch64
                        ansible-core             2.11.3-1             2.11.4-1
                              argocd              2.0.5-1              2.1.0-1
                               aria2             1.35.0-2             1.36.0-1
                              awxkit             19.2.2-1             19.3.0-1
                              batctl             2021.1-1             2021.2-1
                               beets1.4.9.r1031.cbc045f1-1              1.5.0-1
                             blender          17:2.93.2-2          17:2.93.3-1
                             buildah             1.22.0-1             1.22.3-1
                               cacti             1.2.17-1             1.2.18-1
                       cargo-release             0.16.0-1             0.17.0-1
                    cargo-spellcheck             0.8.11-1             0.8.13-1
                               carla              2.3.2-1              2.4.0-1
                             chezmoi              2.1.5-1              2.1.6-1
                         cni-plugins              0.9.1-4              1.0.0-1
                             cockpit                250-1                251-1
                    cockpit-machines              249.1-1                250-1
                         cockpit-pcp                250-1                251-1
                              codec2            1:0.9.2-1            1:1.0.0-1
                   containers-common             0.43.1-1             0.43.2-1
                 cutefish-calculator                0.1-2                0.4-2
                       cutefish-core                0.3-1                0.4-2
                       cutefish-dock                0.3-1                0.4-2
                cutefish-filemanager                0.3-1                0.4-2
                      cutefish-icons                0.3-1                0.4-1
               cutefish-kwin-plugins                0.3-1                0.4-2
                   cutefish-launcher                0.3-1                0.4-1
                   cutefish-settings                0.3-1                0.4-2
                  cutefish-statusbar                0.3-1                0.4-1
                 cutefish-wallpapers                0.2-1                0.4-1
                           dateutils              0.4.8-1              0.4.9-1
                          diffoscope                180-1                181-1
                                 din               50.2-1             51.1.1-1
                              elvish             0.15.0-3             0.16.1-1
                           etherwall              3.0.2-5              3.0.3-1
                               expac                 10-3                 10-4
                fcitx5-pinyin-zhwiki   1:0.2.3.20210804-1   1:0.2.3.20210823-1
            firefox-extension-passff             1.11.2-1             1.12.1-1
                            firejail             0.9.66-1             0.9.66-3
                              fishui                0.3-1                0.4-2
                             fluxctl             1.23.2-1             1.24.0-1
                               gdnsd              3.7.0-2              3.8.0-1
                            gnuradio            3.9.2.0-2            3.9.2.0-3
                  gnuradio-companion            3.9.2.0-2            3.9.2.0-3
                              gpxsee                9.3-1                9.4-1
                               gsoap            2.8.116-1            2.8.117-1
                      home-assistant           2021.8.6-1           2021.8.8-1
                       i3status-rust             0.20.3-1             0.20.4-1
                          ibus-anthy             1.5.12-1             1.5.13-1
                jedi-language-server             0.34.1-1             0.34.2-1
                                 k9s            0.24.14-1            0.24.15-1
                             kompose             1.22.0-3             1.23.0-1
                                 ldc           2:1.27.0-1           2:1.27.1-1
                              libaxc              0.3.4-2              0.3.5-1
                         libcutefish                0.2-1                0.4-1
                          liblphobos           2:1.27.0-1           2:1.27.1-1
                 libretro-beetle-pce               1082-1               1087-1
            libretro-beetle-pce-fast               1129-1               1139-1
                 libretro-beetle-psx               2544-1               2550-1
              libretro-beetle-psx-hw               2544-1               2550-1
                      libretro-citra               6978-1               6981-1
                    libretro-dolphin              32990-3              32994-1
                   libretro-gambatte                912-1                925-1
            libretro-genesis-plus-gx               1786-1               1794-1
                       libretro-mgba               7979-1               7980-1
                       libretro-play               6632-1               6654-1
                    libretro-scummvm              93193-1              93195-1
              libretro-shaders-slang                816-1                823-1
                     libretro-snes9x               2014-1               2018-1
                               lldpd             1.0.11-1             1.0.12-1
                        lua-penlight             1.10.0-1             1.11.0-1
                      lua51-penlight             1.10.0-1             1.11.0-1
                      lua52-penlight             1.10.0-1             1.11.0-1
                      lua53-penlight             1.10.0-1             1.11.0-1
               matrix-appservice-irc             0.29.0-1             0.30.0-1
                             menyoki              1.5.1-1              1.5.3-1
              nextcloud-app-calendar            1:2.3.1-1            1:2.3.2-1
                    nextcloud-client              3.2.4-1              3.3.1-1
     nextcloud-client-cloudproviders              3.2.4-1              3.3.1-1
                       nlohmann-json              3.9.1-4             3.10.0-1
                             notmuch             0.32.2-1             0.32.3-1
                        notmuch-mutt             0.32.2-1             0.32.3-1
                     notmuch-runtime             0.32.2-1             0.32.3-1
                         notmuch-vim             0.32.2-1             0.32.3-1
                                 npm             7.20.6-1             7.21.0-1
                           osdlyrics              0.5.8-1              0.5.9-1
                  papirus-icon-theme           20210802-1           20210802-2
                               pdftk              3.3.0-1              3.3.1-1
                       perl-cpanplus             0.9910-2             0.9912-1
                            perl-moo           2.003006-3           2.005004-1
                      perl-type-tiny           1.012003-2           1.012004-1
                             plocate              1.1.8-1             1.1.10-1
                                 pm2              5.1.0-1              5.1.1-1
                              podman              3.2.3-1              3.3.0-1
                      podman-dnsname              1.2.0-2              1.3.1-1
                       podman-docker              3.2.3-1              3.3.0-1
                               pueue             0.12.2-1              1.0.1-2
                             pyright            1.1.162-1            1.1.163-1
                  python-aiobotocore              1.3.3-1              1.4.0-1
               python-awesomeversion             21.6.0-1             21.8.0-1
                 python-aws-xray-sdk              2.8.0-1              2.8.0-2
                    python-braintree             4.11.0-1             4.12.0-1
                      python-dulwich            0.20.24-1            0.20.25-1
                        python-faker             8.11.0-1             8.12.0-1
                     python-flexmock             0.10.6-1             0.10.7-1
                   python-flufl-lock                5.1-1                6.0-1
                    python-fonttools             4.26.1-1             4.26.2-3
                       python-gitlab              2.9.0-1             2.10.0-1
              python-google-api-core             1.30.0-1              2.0.0-1
     python-google-api-python-client             2.10.0-1             2.17.0-1
                  python-google-auth             1.31.0-1             1.32.1-1
                 python-graphql-core              3.1.5-1              3.1.6-1
                    python-httptools              0.2.0-1              0.3.0-1
                   python-hypothesis             6.14.8-1             6.15.0-1
                    python-jellyfish              0.8.3-1              0.8.8-1
                    python-mediafile  0.6.0.r12.d7bea5e-1              0.7.0-1
                         python-moto              2.2.1-1              2.2.4-1
                 python-oslo-context              3.3.0-1              3.3.1-1
           python-oslo-serialization              4.1.0-2              4.2.0-1
                   python-oslo-utils              4.9.2-1             4.10.0-1
                       python-pandas              1.3.1-1              1.3.2-1
            python-pandas-datareader              0.9.0-2             0.10.0-1
                         python-pdoc              7.3.0-1              7.3.1-1
                       python-poetry              1.1.7-1              1.1.8-1
               python-prompt_toolkit             3.0.19-1             3.0.20-1
                   python-pyacoustid              1.2.0-2              1.2.1-1
                        python-pyaml             20.4.0-4             21.8.3-1
                 python-pytest-httpx             0.12.1-1             0.13.0-1
                  python-ruamel-yaml            0.17.10-1            0.17.11-1
                    python-schemdraw               0.10-1               0.11-1
                 python-scikit-learn             0.24.2-1             0.24.2-2
                   python-send2trash              1.7.1-1              1.8.0-1
                   python-simplejson             3.17.3-1             3.17.4-1
                    python-stevedore              3.3.0-1              3.4.0-1
                 python-testfixtures             6.18.0-1             6.18.1-1
                          python-tox             3.24.2-1             3.24.3-1
                         python-tqdm             4.62.1-1             4.62.2-1
                        python-ujson              4.0.2-1              4.1.0-1
                      python-unidiff              0.6.0-3              0.7.0-1
                       python-uvloop             0.15.3-1             0.16.0-1
                      python-webtest             2.0.35-4              3.0.0-1
                         python2-tox             3.24.2-1             3.24.3-1
                         qliveplayer             3.22.4-1              4.0.0-1
                               rekor              0.3.0-1              0.3.0-2
                           retroarch              1.9.7-1              1.9.8-1
                  rime-pinyin-zhwiki   1:0.2.3.20210804-1   1:0.2.3.20210823-1
                              rspamd                2.7-2                3.0-1
             ruby-metadata-json-lint              3.0.1-1              3.0.1-2
             ruby-metadata_json_deps              0.3.0-1              0.3.0-2
                   ruby-puppet_forge              3.0.0-1              3.1.0-1
                ruby-puppet_metadata              1.0.0-1              1.1.1-1
                                runc              1.0.1-2              1.0.2-1
                       rust-analyzer           20210816-1           20210823-1
                            shotwell          2:0.30.12-1          2:0.30.13-1
                               siege              4.0.9-1              4.1.1-1
               singularity-container              3.8.0-1              3.8.1-1
                              skopeo              1.4.0-1              1.4.1-1
                            smbnetfs              0.6.3-1              0.6.3-2
                                sslh              1.21c-2               1.22-1
                         staticcheck             2021.1-1           2021.1.1-1
                             step-ca             0.16.0-1             0.16.2-1
                             stunnel               5.59-1               5.60-1
                            swayidle                1.6-1                1.7-2
            switchboard-plug-display              2.3.0-1              2.3.1-1
                           tailscale             1.12.3-1             1.12.4-1
                           terraform              1.0.4-1              1.0.5-1
                            texmaker              5.1.0-1              5.1.1-1
                                 tor            0.4.6.6-1            0.4.6.7-1
                         ttc-iosevka             10.0.0-1             10.1.0-1
                    ttc-iosevka-aile             10.0.0-1             10.1.0-1
                   ttc-iosevka-curly             10.0.0-1             10.1.0-1
              ttc-iosevka-curly-slab             10.0.0-1             10.1.0-1
                  ttc-iosevka-etoile             10.0.0-1             10.1.0-1
                    ttc-iosevka-slab             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss01             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss02             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss03             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss04             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss05             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss06             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss07             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss08             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss09             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss10             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss11             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss12             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss13             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss14             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss15             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss16             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss17             10.0.0-1             10.1.0-1
                    ttc-iosevka-ss18             10.0.0-1             10.1.0-1
                   ttf-sarasa-gothic             0.34.1-1             0.34.2-1
                            usbredir              0.9.0-1             0.11.0-1
                             uvicorn             0.14.0-2             0.15.0-1
                        vim-nerdtree            6.10.10-1            6.10.11-1
                           vultr-cli              2.7.0-1              2.8.0-1
                             web-ext              6.2.0-1              6.3.0-1
                             wezterm20210502.154244.3f7122cb-120210814.124438.54e29167-1
                         wireplumber              0.4.1-2              0.4.2-1
                    wireplumber-docs              0.4.1-2              0.4.2-1
                                xwax                1.7-2                1.8-1
                               yaegi             0.9.21-1             0.9.22-1
                           cargo-asm                    -             0.1.16-1
               cutefish-screenlocker                    -                0.4-1
                   cutefish-terminal                    -                0.4-2
                      discord-canary                    -            0.0.126-1
                               grobi                    -              0.6.0-2
                 kernel-modules-hook                    -              0.1.7-2
                                lego                    -              4.4.0-2
                             myrepos                    -         1.20180726-6
                             nushell                    -             0.35.0-3
                     pacman-bintrans                    -              0.1.0-1
               pacman-bintrans-tools                    -              0.1.0-1
                  perl-shell-command                    -               0.06-3
            prometheus-bird-exporter                    -              1.2.6-1
                      python-astroid                    -              2.7.2-1
                        python-isort                    -              5.9.3-1
                       python-mccabe                    -              0.6.1-8
                       python-pylint                    -              2.8.2-1
                                vcsh                    -              2.0.0-1
:: Different overlay package(s) in repository core aarch64
                     boot-radxa-zero            2020.09-0            2020.09-1
                            linux-rc           5.14.rc6-1           5.14.rc7-3
                    linux-rc-headers           5.14.rc6-1           5.14.rc7-3
                          linux-rpi4            5.10.59-1            5.10.60-1
                  linux-rpi4-headers            5.10.59-1            5.10.60-1
              raspberrypi-bootloader           20210812-1           20210819-1
            raspberrypi-bootloader-x           20210812-1           20210819-1
:: Different sync package(s) in repository core aarch64
                           amd-ucode   20210716.b7c134f-1   20210818.c46b8c3-1
                   archlinux-keyring           20210802-1           20210820-1
                               audit              3.0.3-1              3.0.4-1
                          cryptsetup              2.3.6-1              2.4.0-1
                           e2fsprogs             1.46.3-3             1.46.4-1
                               glib2             2.68.3-1             2.68.4-1
                          glib2-docs             2.68.3-1             2.68.4-1
                      linux-firmware   20210716.b7c134f-1   20210818.c46b8c3-1
                             openssh              8.6p1-1              8.7p1-1
                        python-audit              3.0.3-1              3.0.4-1
:: Different overlay package(s) in repository extra aarch64
                  khealthcertificate            21.07.0-1            21.07.0-2
                              libnma             1.8.30-1             1.8.32-1
:: Different sync package(s) in repository extra aarch64
                                bind            9.16.19-1            9.16.20-1
                          cifs-utils               6.13-2               6.13-3
                            composer              2.1.5-1              2.1.6-1
                             enchant              2.3.0-1              2.3.1-1
                       gnome-desktop             1:40.3-1             1:40.4-1
                             gnu-efi             3.0.13-1             3.0.14-1
                     grml-zsh-config             0.19.0-1             0.19.0-2
                              gthumb             3.10.3-1             3.10.4-1
               gtk-update-icon-cache            1:4.2.1-2            1:4.4.0-1
                                gtk4            1:4.2.1-2            1:4.4.0-1
                          gtk4-demos            1:4.2.1-2            1:4.4.0-1
                           gtk4-docs            1:4.2.1-2            1:4.4.0-1
                                ibus             1.5.24-1             1.5.25-2
                           json-glib              1.6.4-1              1.6.6-1
                      json-glib-docs              1.6.4-1              1.6.6-1
                             konsole            21.08.0-2            21.08.0-3
                           libfprint             1.92.1-1             1.94.0-1
                             libibus             1.5.24-1             1.5.25-2
                   libreoffice-fresh              7.1.5-2              7.2.0-1
                libreoffice-fresh-af              7.1.5-1              7.2.0-1
                libreoffice-fresh-am              7.1.5-1              7.2.0-1
                libreoffice-fresh-ar              7.1.5-1              7.2.0-1
                libreoffice-fresh-as              7.1.5-1              7.2.0-1
               libreoffice-fresh-ast              7.1.5-1              7.2.0-1
                libreoffice-fresh-be              7.1.5-1              7.2.0-1
                libreoffice-fresh-bg              7.1.5-1              7.2.0-1
                libreoffice-fresh-bn              7.1.5-1              7.2.0-1
             libreoffice-fresh-bn-in              7.1.5-1              7.2.0-1
                libreoffice-fresh-bo              7.1.5-1              7.2.0-1
                libreoffice-fresh-br              7.1.5-1              7.2.0-1
               libreoffice-fresh-brx              7.1.5-1              7.2.0-1
                libreoffice-fresh-bs              7.1.5-1              7.2.0-1
                libreoffice-fresh-ca              7.1.5-1              7.2.0-1
       libreoffice-fresh-ca-valencia              7.1.5-1              7.2.0-1
               libreoffice-fresh-ckb              7.1.5-1              7.2.0-1
                libreoffice-fresh-cs              7.1.5-1              7.2.0-1
                libreoffice-fresh-cy              7.1.5-1              7.2.0-1
                libreoffice-fresh-da              7.1.5-1              7.2.0-1
                libreoffice-fresh-de              7.1.5-1              7.2.0-1
               libreoffice-fresh-dgo              7.1.5-1              7.2.0-1
               libreoffice-fresh-dsb              7.1.5-1              7.2.0-1
                libreoffice-fresh-dz              7.1.5-1              7.2.0-1
                libreoffice-fresh-el              7.1.5-1              7.2.0-1
             libreoffice-fresh-en-gb              7.1.5-1              7.2.0-1
             libreoffice-fresh-en-za              7.1.5-1              7.2.0-1
                libreoffice-fresh-eo              7.1.5-1              7.2.0-1
                libreoffice-fresh-es              7.1.5-1              7.2.0-1
                libreoffice-fresh-et              7.1.5-1              7.2.0-1
                libreoffice-fresh-eu              7.1.5-1              7.2.0-1
                libreoffice-fresh-fa              7.1.5-1              7.2.0-1
                libreoffice-fresh-fi              7.1.5-1              7.2.0-1
                libreoffice-fresh-fr              7.1.5-1              7.2.0-1
               libreoffice-fresh-fur              7.1.5-1              7.2.0-1
                libreoffice-fresh-fy              7.1.5-1              7.2.0-1
                libreoffice-fresh-ga              7.1.5-1              7.2.0-1
                libreoffice-fresh-gd              7.1.5-1              7.2.0-1
                libreoffice-fresh-gl              7.1.5-1              7.2.0-1
                libreoffice-fresh-gu              7.1.5-1              7.2.0-1
               libreoffice-fresh-gug              7.1.5-1              7.2.0-1
                libreoffice-fresh-he              7.1.5-1              7.2.0-1
                libreoffice-fresh-hi              7.1.5-1              7.2.0-1
                libreoffice-fresh-hr              7.1.5-1              7.2.0-1
               libreoffice-fresh-hsb              7.1.5-1              7.2.0-1
                libreoffice-fresh-hu              7.1.5-1              7.2.0-1
                libreoffice-fresh-id              7.1.5-1              7.2.0-1
                libreoffice-fresh-is              7.1.5-1              7.2.0-1
                libreoffice-fresh-it              7.1.5-1              7.2.0-1
                libreoffice-fresh-ja              7.1.5-1              7.2.0-1
                libreoffice-fresh-ka              7.1.5-1              7.2.0-1
               libreoffice-fresh-kab              7.1.5-1              7.2.0-1
                libreoffice-fresh-kk              7.1.5-1              7.2.0-1
                libreoffice-fresh-km              7.1.5-1              7.2.0-1
          libreoffice-fresh-kmr-latn              7.1.5-1              7.2.0-1
                libreoffice-fresh-kn              7.1.5-1              7.2.0-1
                libreoffice-fresh-ko              7.1.5-1              7.2.0-1
               libreoffice-fresh-kok              7.1.5-1              7.2.0-1
                libreoffice-fresh-ks              7.1.5-1              7.2.0-1
                libreoffice-fresh-lb              7.1.5-1              7.2.0-1
                libreoffice-fresh-lo              7.1.5-1              7.2.0-1
                libreoffice-fresh-lt              7.1.5-1              7.2.0-1
                libreoffice-fresh-lv              7.1.5-1              7.2.0-1
               libreoffice-fresh-mai              7.1.5-1              7.2.0-1
                libreoffice-fresh-mk              7.1.5-1              7.2.0-1
                libreoffice-fresh-ml              7.1.5-1              7.2.0-1
                libreoffice-fresh-mn              7.1.5-1              7.2.0-1
               libreoffice-fresh-mni              7.1.5-1              7.2.0-1
                libreoffice-fresh-mr              7.1.5-1              7.2.0-1
                libreoffice-fresh-my              7.1.5-1              7.2.0-1
                libreoffice-fresh-nb              7.1.5-1              7.2.0-1
                libreoffice-fresh-ne              7.1.5-1              7.2.0-1
                libreoffice-fresh-nl              7.1.5-1              7.2.0-1
                libreoffice-fresh-nn              7.1.5-1              7.2.0-1
                libreoffice-fresh-nr              7.1.5-1              7.2.0-1
               libreoffice-fresh-nso              7.1.5-1              7.2.0-1
                libreoffice-fresh-oc              7.1.5-1              7.2.0-1
                libreoffice-fresh-om              7.1.5-1              7.2.0-1
                libreoffice-fresh-or              7.1.5-1              7.2.0-1
             libreoffice-fresh-pa-in              7.1.5-1              7.2.0-1
                libreoffice-fresh-pl              7.1.5-1              7.2.0-1
                libreoffice-fresh-pt              7.1.5-1              7.2.0-1
             libreoffice-fresh-pt-br              7.1.5-1              7.2.0-1
                libreoffice-fresh-ro              7.1.5-1              7.2.0-1
                libreoffice-fresh-ru              7.1.5-1              7.2.0-1
                libreoffice-fresh-rw              7.1.5-1              7.2.0-1
             libreoffice-fresh-sa-in              7.1.5-1              7.2.0-1
               libreoffice-fresh-sat              7.1.5-1              7.2.0-1
                libreoffice-fresh-sd              7.1.5-1              7.2.0-1
               libreoffice-fresh-sdk              7.1.5-2              7.2.0-1
                libreoffice-fresh-si              7.1.5-1              7.2.0-1
               libreoffice-fresh-sid              7.1.5-1              7.2.0-1
                libreoffice-fresh-sk              7.1.5-1              7.2.0-1
                libreoffice-fresh-sl              7.1.5-1              7.2.0-1
                libreoffice-fresh-sq              7.1.5-1              7.2.0-1
                libreoffice-fresh-sr              7.1.5-1              7.2.0-1
           libreoffice-fresh-sr-latn              7.1.5-1              7.2.0-1
                libreoffice-fresh-ss              7.1.5-1              7.2.0-1
                libreoffice-fresh-st              7.1.5-1              7.2.0-1
                libreoffice-fresh-sv              7.1.5-1              7.2.0-1
             libreoffice-fresh-sw-tz              7.1.5-1              7.2.0-1
               libreoffice-fresh-szl              7.1.5-1              7.2.0-1
                libreoffice-fresh-ta              7.1.5-1              7.2.0-1
                libreoffice-fresh-te              7.1.5-1              7.2.0-1
                libreoffice-fresh-tg              7.1.5-1              7.2.0-1
                libreoffice-fresh-th              7.1.5-1              7.2.0-1
                libreoffice-fresh-tn              7.1.5-1              7.2.0-1
                libreoffice-fresh-tr              7.1.5-1              7.2.0-1
                libreoffice-fresh-ts              7.1.5-1              7.2.0-1
                libreoffice-fresh-tt              7.1.5-1              7.2.0-1
                libreoffice-fresh-ug              7.1.5-1              7.2.0-1
                libreoffice-fresh-uk              7.1.5-1              7.2.0-1
                libreoffice-fresh-uz              7.1.5-1              7.2.0-1
                libreoffice-fresh-ve              7.1.5-1              7.2.0-1
               libreoffice-fresh-vec              7.1.5-1              7.2.0-1
                libreoffice-fresh-vi              7.1.5-1              7.2.0-1
                libreoffice-fresh-xh              7.1.5-1              7.2.0-1
             libreoffice-fresh-zh-cn              7.1.5-1              7.2.0-1
             libreoffice-fresh-zh-tw              7.1.5-1              7.2.0-1
                libreoffice-fresh-zu              7.1.5-1              7.2.0-1
                   libreoffice-still              7.0.6-4              7.1.5-1
                libreoffice-still-af              7.0.6-1              7.1.5-1
                libreoffice-still-am              7.0.6-1              7.1.5-1
                libreoffice-still-ar              7.0.6-1              7.1.5-1
                libreoffice-still-as              7.0.6-1              7.1.5-1
               libreoffice-still-ast              7.0.6-1              7.1.5-1
                libreoffice-still-be              7.0.6-1              7.1.5-1
                libreoffice-still-bg              7.0.6-1              7.1.5-1
                libreoffice-still-bn              7.0.6-1              7.1.5-1
             libreoffice-still-bn-in              7.0.6-1              7.1.5-1
                libreoffice-still-bo              7.0.6-1              7.1.5-1
                libreoffice-still-br              7.0.6-1              7.1.5-1
               libreoffice-still-brx              7.0.6-1              7.1.5-1
                libreoffice-still-bs              7.0.6-1              7.1.5-1
                libreoffice-still-ca              7.0.6-1              7.1.5-1
       libreoffice-still-ca-valencia              7.0.6-1              7.1.5-1
               libreoffice-still-ckb              7.0.6-1              7.1.5-1
                libreoffice-still-cs              7.0.6-1              7.1.5-1
                libreoffice-still-cy              7.0.6-1              7.1.5-1
                libreoffice-still-da              7.0.6-1              7.1.5-1
                libreoffice-still-de              7.0.6-1              7.1.5-1
               libreoffice-still-dgo              7.0.6-1              7.1.5-1
               libreoffice-still-dsb              7.0.6-1              7.1.5-1
                libreoffice-still-dz              7.0.6-1              7.1.5-1
                libreoffice-still-el              7.0.6-1              7.1.5-1
             libreoffice-still-en-gb              7.0.6-1              7.1.5-1
             libreoffice-still-en-za              7.0.6-1              7.1.5-1
                libreoffice-still-eo              7.0.6-1              7.1.5-1
                libreoffice-still-es              7.0.6-1              7.1.5-1
                libreoffice-still-et              7.0.6-1              7.1.5-1
                libreoffice-still-eu              7.0.6-1              7.1.5-1
                libreoffice-still-fa              7.0.6-1              7.1.5-1
                libreoffice-still-fi              7.0.6-1              7.1.5-1
                libreoffice-still-fr              7.0.6-1              7.1.5-1
               libreoffice-still-fur              7.0.6-1              7.1.5-1
                libreoffice-still-fy              7.0.6-1              7.1.5-1
                libreoffice-still-ga              7.0.6-1              7.1.5-1
                libreoffice-still-gd              7.0.6-1              7.1.5-1
                libreoffice-still-gl              7.0.6-1              7.1.5-1
                libreoffice-still-gu              7.0.6-1              7.1.5-1
               libreoffice-still-gug              7.0.6-1              7.1.5-1
                libreoffice-still-he              7.0.6-1              7.1.5-1
                libreoffice-still-hi              7.0.6-1              7.1.5-1
                libreoffice-still-hr              7.0.6-1              7.1.5-1
               libreoffice-still-hsb              7.0.6-1              7.1.5-1
                libreoffice-still-hu              7.0.6-1              7.1.5-1
                libreoffice-still-id              7.0.6-1              7.1.5-1
                libreoffice-still-is              7.0.6-1              7.1.5-1
                libreoffice-still-it              7.0.6-1              7.1.5-1
                libreoffice-still-ja              7.0.6-1              7.1.5-1
                libreoffice-still-ka              7.0.6-1              7.1.5-1
               libreoffice-still-kab              7.0.6-1              7.1.5-1
                libreoffice-still-kk              7.0.6-1              7.1.5-1
                libreoffice-still-km              7.0.6-1              7.1.5-1
          libreoffice-still-kmr-latn              7.0.6-1              7.1.5-1
                libreoffice-still-kn              7.0.6-1              7.1.5-1
                libreoffice-still-ko              7.0.6-1              7.1.5-1
               libreoffice-still-kok              7.0.6-1              7.1.5-1
                libreoffice-still-ks              7.0.6-1              7.1.5-1
                libreoffice-still-lb              7.0.6-1              7.1.5-1
                libreoffice-still-lo              7.0.6-1              7.1.5-1
                libreoffice-still-lt              7.0.6-1              7.1.5-1
                libreoffice-still-lv              7.0.6-1              7.1.5-1
               libreoffice-still-mai              7.0.6-1              7.1.5-1
                libreoffice-still-mk              7.0.6-1              7.1.5-1
                libreoffice-still-ml              7.0.6-1              7.1.5-1
                libreoffice-still-mn              7.0.6-1              7.1.5-1
               libreoffice-still-mni              7.0.6-1              7.1.5-1
                libreoffice-still-mr              7.0.6-1              7.1.5-1
                libreoffice-still-my              7.0.6-1              7.1.5-1
                libreoffice-still-nb              7.0.6-1              7.1.5-1
                libreoffice-still-ne              7.0.6-1              7.1.5-1
                libreoffice-still-nl              7.0.6-1              7.1.5-1
                libreoffice-still-nn              7.0.6-1              7.1.5-1
                libreoffice-still-nr              7.0.6-1              7.1.5-1
               libreoffice-still-nso              7.0.6-1              7.1.5-1
                libreoffice-still-oc              7.0.6-1              7.1.5-1
                libreoffice-still-om              7.0.6-1              7.1.5-1
                libreoffice-still-or              7.0.6-1              7.1.5-1
             libreoffice-still-pa-in              7.0.6-1              7.1.5-1
                libreoffice-still-pl              7.0.6-1              7.1.5-1
                libreoffice-still-pt              7.0.6-1              7.1.5-1
             libreoffice-still-pt-br              7.0.6-1              7.1.5-1
                libreoffice-still-ro              7.0.6-1              7.1.5-1
                libreoffice-still-ru              7.0.6-1              7.1.5-1
                libreoffice-still-rw              7.0.6-1              7.1.5-1
             libreoffice-still-sa-in              7.0.6-1              7.1.5-1
               libreoffice-still-sat              7.0.6-1              7.1.5-1
                libreoffice-still-sd              7.0.6-1              7.1.5-1
               libreoffice-still-sdk              7.0.6-4              7.1.5-1
                libreoffice-still-si              7.0.6-1              7.1.5-1
               libreoffice-still-sid              7.0.6-1              7.1.5-1
                libreoffice-still-sk              7.0.6-1              7.1.5-1
                libreoffice-still-sl              7.0.6-1              7.1.5-1
                libreoffice-still-sq              7.0.6-1              7.1.5-1
                libreoffice-still-sr              7.0.6-1              7.1.5-1
           libreoffice-still-sr-latn              7.0.6-1              7.1.5-1
                libreoffice-still-ss              7.0.6-1              7.1.5-1
                libreoffice-still-st              7.0.6-1              7.1.5-1
                libreoffice-still-sv              7.0.6-1              7.1.5-1
             libreoffice-still-sw-tz              7.0.6-1              7.1.5-1
               libreoffice-still-szl              7.0.6-1              7.1.5-1
                libreoffice-still-ta              7.0.6-1              7.1.5-1
                libreoffice-still-te              7.0.6-1              7.1.5-1
                libreoffice-still-tg              7.0.6-1              7.1.5-1
                libreoffice-still-th              7.0.6-1              7.1.5-1
                libreoffice-still-tn              7.0.6-1              7.1.5-1
                libreoffice-still-tr              7.0.6-1              7.1.5-1
                libreoffice-still-ts              7.0.6-1              7.1.5-1
                libreoffice-still-tt              7.0.6-1              7.1.5-1
                libreoffice-still-ug              7.0.6-1              7.1.5-1
                libreoffice-still-uk              7.0.6-1              7.1.5-1
                libreoffice-still-uz              7.0.6-1              7.1.5-1
                libreoffice-still-ve              7.0.6-1              7.1.5-1
               libreoffice-still-vec              7.0.6-1              7.1.5-1
                libreoffice-still-vi              7.0.6-1              7.1.5-1
                libreoffice-still-xh              7.0.6-1              7.1.5-1
             libreoffice-still-zh-cn              7.0.6-1              7.1.5-1
             libreoffice-still-zh-tw              7.0.6-1              7.1.5-1
                libreoffice-still-zu              7.0.6-1              7.1.5-1
                             libsoup2.72.0+10+gfe1e295d-1             2.74.0-1
                   libva-mesa-driver             21.1.6-1           21.2.1-1.1
                           linux-atm              2.5.2-6              2.5.2-7
                                mesa             21.1.6-1           21.2.1-1.1
                          mesa-vdpau             21.1.6-1           21.2.1-1.1
                            nftables            1:0.9.9-6            1:1.0.0-1
                             ocl-icd              2.3.0-1              2.3.1-1
                         opencl-mesa             21.1.6-1           21.2.1-1.1
                               pango           1:1.48.9-1           1:1.48.9-2
                          pango-docs           1:1.48.9-1           1:1.48.9-2
                         perl-libwww               6.55-1               6.56-1
                            pkgstats              3.1.0-1              3.1.1-1
          prometheus-mysqld-exporter             0.12.1-3             0.13.0-1
                      python-astroid              2.6.2-1                    -
                        python-isort              5.8.0-1                    -
                         python-mako              1.1.4-1              1.1.5-1
                       python-mccabe              0.6.1-8                    -
                       python-pylint              2.8.2-1                    -
                              snappy              1.1.8-2              1.1.9-1
                          soundtouch                2.2-1              2.3.0-1
                                tidy             5.7.45-1              5.8.0-1
                     tracker3-miners              3.1.2-1              3.1.2-2
                     vulkan-broadcom             21.1.6-1           21.2.1-1.1
                      vulkan-headers          1:1.2.186-1          1:1.2.187-1
                   vulkan-icd-loader            1.2.186-1            1.2.187-1
                  vulkan-mesa-layers             21.1.6-1           21.2.1-1.1
                       vulkan-radeon             21.1.6-1           21.2.1-1.1
                       vulkan-swrast             21.1.6-1           21.2.1-1.1
                         libtomcrypt                    -             1.18.2-1
                     vulkan-panfrost                    -           21.2.1-1.1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.08.0.r12559.gb0ff923f6-121.08.0.r12560.gce740211a-1
                        akonadi-mime21.08.0.r1637.g365d1a7-121.08.0.r1638.g2d649d0-1
                       akonadi-notes21.08.0.r1021.gf727062-121.08.0.r1022.g0e92d47-1
                      akonadi-search21.08.0.r1117.g429d8fd-121.08.0.r1119.gcd996be-1
                      akonadiconsole21.08.0.r1507.g30bd800-121.08.0.r1516.g0f462f4-1
                                 ark21.08.0.r4610.g80b46edb-121.08.0.r4611.gda40af2f-1
                              attica5.85.0.r829.g943437d-15.85.0.r830.gd0a134a-1
                               baloo5.85.0.r3003.g2cea245a-15.85.0.r3004.g509dcd8d-1
                       baloo-widgets21.08.0.r694.g70ec4e1-121.08.0.r697.gaeda53f-1
                             blinken21.08.0.r628.ga97495d-121.08.0.r630.ga84bdd0-1
                        breeze-icons5.85.0.r1772.gaf27e281-15.85.0.r1777.g6d9155e7-1
                                buho  2.0.0.r0.g54ea38b-1  2.0.0.r2.g745e3b4-1
                     calendarsupport21.08.0.r20.gfc8619e-121.08.0.r23.gf4024cd-1
                            discover5.22.4.r8261.g8a771881-15.22.4.r8275.gdcdfe76b-1
                             dolphin21.08.0.r6677.g0ed31f10c-121.08.0.r6679.ge76bf5cb1-1
                     dolphin-plugins21.08.0.r600.ga0a4b6f-121.08.0.r601.g04ae4bf-1
                               elisa21.08.0.r2751.gd69ad3c8-121.08.0.r2753.g268f78d4-1
                          eventviews21.07.80.r19.g93776ac-121.07.80.r20.g8546471-1
                        ffmpegthumbs21.08.0.r190.g7dc382a-121.08.0.r192.g9e7b1cd-1
                            gwenview21.08.0.r6652.g3a0b5cd4-121.08.0.r6653.g5ab33f15-1
                            index-fm  2.0.0.r5.g818bd9f-1  2.0.0.r9.g91b9e98-1
                              kalarm21.08.0.r6441.gc8d41145-121.08.0.r6443.g229e30b8-1
                             kalzium21.08.0.r4255.ge6aecd1b-121.08.0.r4268.g149ad8d8-1
                              kamoso21.08.0.r1429.g37ed426-121.08.0.r1430.g0fcab25-1
                                kate21.08.0.r18325.ga94a3781b-121.08.0.r18329.g0dbfebcb4-1
                             kblocks21.08.0.r666.g24ec0b5-121.08.0.r668.g13cf37d-1
                               kcalc21.08.0.r1517.g96d87f0-121.08.0.r1518.gf0b3fee-1
                         kcharselect21.08.0.r470.g91d8e7b-121.08.0.r475.g714122d-1
                              kclock 21.07.r24.gbb1d00e-1 21.07.r26.gbbed814-1
                             kcodecs5.85.0.r379.g9638b2d-15.85.0.r380.g5d13346-1
                             kconfig5.85.0.r854.g98e74c2-15.85.0.r855.g4f8ed9b-1
                      kconfigwidgets5.85.0.r609.g1fad95e-15.85.0.r612.g233f3c2-1
                           kcontacts1:5.85.0.r3249.g0139b880-11:5.85.0.r3250.g4d5c37f0-1
                         kcoreaddons5.85.0.r1267.ged4a5b45-15.85.0.r1270.g4c36440c-1
                       kde-cli-tools5.22.4.r1859.gafa56d3-15.22.4.r1860.g866d730-1
                      kdebugsettings21.08.0.r837.g35e36de-121.08.0.r838.g91247b5-1
                          kdeconnect21.08.0.r3308.ge213eb50-121.08.0.r3309.g066d798e-1
            kdegraphics-thumbnailers21.08.0.r235.ga26b83c-121.08.0.r236.g918502e-1
                     kdelibs4support5.85.0.r1032.g476732ba-15.85.0.r1033.g5b253fa5-1
              kdenetwork-filesharing21.08.0.r889.g0abade9-121.08.0.r890.g3fd6518-1
                            kdenlive21.08.0.r14773.g736c714c9-121.08.0.r14774.g2d7992617-1
                       kdepim-addons21.08.0.r4298.g2407d85b-121.08.0.r4299.g8981fb3d-1
                      kdepim-runtime21.08.0.r15187.ge73eb393d-121.08.0.r15203.g4bbe0fe52-1
                    kdeplasma-addons5.22.4.r8576.gf5609a152-15.22.4.r8578.ged9064dcc-1
                            kdisplay5.22.4.r1450.g1fa20e2-15.22.4.r1453.g063f13b-1
                      keditbookmarks21.08.0.r2743.g0d54808cd-121.08.0.r2745.gac885dcce-1
                               kfind21.08.0.r2643.gd1dc939db-121.08.0.r2644.gd3be9a828-1
                                kget21.08.0.r3119.gcfe2bbb1-121.08.0.r3120.g6ad6fe8c-1
                                kgpg21.08.0.r3129.gf892e2fd-121.08.0.r3131.gce487cde-1
                          kguiaddons5.85.0.r383.g4566708-15.85.0.r385.g363f67f-1
                            khotkeys5.22.4.r2088.g5e2bbcc-15.22.4.r2090.g1ec3eef-1
                               ki18n5.85.0.r475.g302a3d3-15.85.0.r476.g567f51f-1
                 kidentitymanagement21.08.0.r3815.g7f5c1c82-121.08.0.r3817.g823fa374-1
                                kigo21.08.0.r521.g2c02486-121.08.0.r522.g625cfd7-1
                       kimageformats5.85.0.r351.g28099ee-15.85.0.r354.gaade392-1
                         kinfocenter5.22.4.r1879.g29f7177-15.22.4.r1885.gc186bca-1
                          kio-extras21.08.0.r7098.ge6afe2f9-121.08.0.r7099.g57453699-1
                          kio-gdrive21.08.0.r565.gae07881-121.08.0.r566.g578cd9a-1
                     kirigami-addons  1:0.2.r6.gc4f3e01-1  1:0.2.r8.gb19a9f9-1
                           kirigami25.85.0.r2863.gc8e04b6d-15.85.0.r2865.g9efc15ba-1
                         kitemmodels5.85.0.r552.gdd7b8e2-15.85.0.r554.g2d173d2-1
                          kitemviews5.85.0.r335.gf244f43-15.85.0.r336.ga5a735c-1
                          kitinerary21.08.0.r1874.g9a01b21-121.08.0.r1888.gc06e62c-1
                               kldap21.08.0.r881.gf876ba4-121.08.0.r883.g0ed5bf0-1
                           kleopatra21.08.0.r5944.gaa59b873-121.08.0.r5960.g2c00747e-1
                              kmines21.08.0.r1717.g2b23d0f-121.08.0.r1718.gfbc18fa-1
                        knavalbattle21.08.0.r1385.gb2634cb-121.08.0.r1386.g6b111a7-1
                            knetwalk21.08.0.r656.g424c743-121.08.0.r657.g893d1df-1
                              knotes21.08.0.r3498.g54f8ec3a-121.08.0.r3501.g85cf3485-1
                                koko 21.07.r21.g9b48c5a-1 21.07.r25.gd3c4c4d-1
                                kolf21.08.0.r1438.g8386d3d-121.08.0.r1439.g8d1de09-1
                           konqueror21.08.0.r14928.gc9a57d30f-121.08.0.r14929.gacfd16712-1
                             konsole21.08.0.r7919.g3d967a59-121.08.0.r7921.g9691d3f2-1
                       kopeninghours21.08.0.r267.g81cc4e5-121.08.0.r269.g9ef45c1-1
                          korganizer21.08.0.r11460.gc94c1c1bc-121.08.0.r11467.g5f13e6f3e-1
                       kosmindoormap21.08.0.r628.g4ffe68e-121.08.0.r630.g7ce3863-1
                    kpublictransport21.08.0.r1724.g7fb6f77f-121.08.0.r1732.g7597a141-1
                   kquickimageeditor       r52.gd68391b-1       r54.gf34e8b4-1
                             kscreen5.22.4.r1339.g5fdd5ed-15.22.4.r1340.g4922979-1
                            kservice5.85.0.r931.gc1ccc2d-15.85.0.r934.gf06e57d-1
                          ksnakeduel21.08.0.r802.g6d1d2a7-121.08.0.r804.g9519f69-1
                          kspaceduel21.08.0.r627.g704594a-121.08.0.r629.ge419eee-1
                             ksudoku21.08.0.r1048.ga204d83-121.08.0.r1049.g0865090-1
                           ksysguard5.22.4.r3509.gcfd3a0f8-15.22.4.r3511.ga571c444-1
                          ksystemlog21.08.0.r652.g5e50432-121.08.0.r655.gbd31996-1
                        ksystemstats5.22.4.r177.g65c605e-15.22.4.r178.gc702da6-1
                         ktexteditor5.85.0.r2921.g15d17611-15.85.0.r2927.gab06e10a-1
                        ktextwidgets5.85.0.r407.g30acf54-15.85.0.r408.gd0980b7-1
                            ktorrent21.08.0.r2763.g63832ef7-121.08.0.r2765.g023def08-1
                               ktrip  21.07.r6.g1a9d591-1  21.07.r7.gb5a7eb8-1
                          ktuberling21.08.0.r1004.g323ddab-121.08.0.r1012.gf2c8ad3-1
                             kubrick21.08.0.r366.g56f5df7-121.08.0.r370.gf280c16-1
                             kwallet5.85.0.r1082.g4638b89-15.85.0.r1083.g80e8806-1
                               kwave21.08.0.r3739.g9357ded2-121.08.0.r3740.ga889c432-1
                            kwayland5.85.0.r1104.gc253809-15.85.0.r1106.g41bed39-1
                     kwayland-server5.22.4.r1366.g9a7578d-15.22.4.r1367.g671d70d-1
                      kwidgetsaddons5.85.0.r847.g6b294099-15.85.0.r859.g5dfafee5-1
                                kwin5.22.4.r19777.g1fbd99b57-15.22.4.r19814.g6f6944058-1
                       kwindowsystem5.85.0.r609.g441a306-15.85.0.r610.gc7c49f9-1
                              kwinft5.22.4.r19218.g01e39c224-15.22.4.r19227.gd958fcec3-1
                              kwrite21.08.0.r18325.ga94a3781b-121.08.0.r18329.g0dbfebcb4-1
                          libakonadi21.08.0.r12559.gb0ff923f6-121.08.0.r12560.gce740211a-1
                           libkdepim21.08.0.r846.g57bad32-121.08.0.r847.gc51e41b-1
                             libkleo21.08.0.r923.gb3bb0ce-121.08.0.r925.g8ab5857-1
                            libksane21.08.0.r553.g644e071-121.08.0.r555.g0316b3a-1
                        libksysguard5.22.4.r2271.gea38a1f-15.22.4.r2273.g8df517f-1
                         libktorrent21.08.0.r524.ga3f8f37-121.08.0.r525.g2b6b0d8-1
                         libquotient     r2045.g5276e43-1     r2060.g6953e55-1
                          mailcommon21.08.0.r1093.g45d8e6c-121.08.0.r1098.gd9eaa0b-1
                              marble21.08.0.r13326.gd34223487-121.08.0.r13327.gb20787a0c-1
                       marble-common21.08.0.r13326.gd34223487-121.08.0.r13327.gb20787a0c-1
                           marble-qt21.08.0.r13326.gd34223487-121.08.0.r13327.gb20787a0c-1
                           maui-clip  2.0.0.r1.g9edd324-1  2.0.0.r2.g1ba0529-1
                           maui-nota  2.0.0.r1.g23828ea-1  2.0.0.r3.gc65f54d-1
                            maui-pix  2.0.0.r1.gb75ac86-1  2.0.0.r4.g5e04d12-1
                             mauikit 2.0.0.r4.g45044100-1 2.0.0.r7.gae562355-1
                mauikit-filebrowsing  2.0.0.r4.g644cd72-1  2.0.0.r6.g399bc48-1
                       mbox-importer21.08.0.r509.gd851cfc-121.08.0.r510.gba0b08c-1
                              minuet21.08.0.r580.ga23c7c7-121.08.0.r582.gfd585f8-1
                             neochat    r1819.g94c4bbc3-1    r1825.gd1451780-1
                              okular21.08.0.r9424.gd9cb0c907-121.08.0.r9427.g7c2bac7d2-1
                              parley21.08.0.r4417.g670f8f95-121.08.0.r4420.g0cb87151-1
                               picmi21.08.0.r526.ge88c260-121.08.0.r527.g99639fb-1
                   pim-data-exporter21.08.0.r2438.g9edc82b9-121.08.0.r2443.g99770684-1
                    pim-sieve-editor21.08.0.r1502.g5345fa3-121.08.0.r1505.g8bbd34b-1
                           pimcommon21.07.80.r1088.gab86d0c-121.07.80.r1089.g1aea133-1
          plasma-browser-integration5.22.3.r1271.g6e2f76be-15.22.3.r1273.g670d76b1-1
                       plasma-camera  1.0.r103.g527fa8e-1  1.0.r104.g2ee0aaf-1
                      plasma-desktop5.22.4.r8582.g10a1805ed-15.22.4.r8588.gcfbcd374d-1
                    plasma-mobile-nm5.22.3.r3070.g3213592c-15.22.3.r3071.g54319f29-1
                         plasma-nano5.21.5.r151.gcf01c43-15.21.5.r153.g0149d86-1
                           plasma-nm5.22.3.r3070.g3213592c-15.22.3.r3071.g54319f29-1
                          plasma-sdk5.22.4.r2273.g3d24bfcc-15.22.4.r2274.g02e980eb-1
                     plasma-settings  21.07.r9.ge9abd2c-1 21.07.r10.gc9ceb70-1
                plasma-systemmonitor5.22.4.r476.gf170e40-15.22.4.r477.g2aba8c3-1
                  plasma-thunderbolt5.22.4.r134.gff4b4f9-15.22.4.r135.g5186a62-1
         plasma-workspace-wallpapers5.22.4.r281.g4fc06b7-15.22.4.r282.g1a81932-1
                          powerdevil5.22.4.r2458.ga9ab770e-15.22.4.r2459.gbaae8bdb-1
                  qqc2-desktop-style5.85.0.r515.g509f0f7-15.85.0.r517.g49b4811-1
                                sddm0.19.0.r59.g37a39d0-10.19.0.r60.g72e337f-1
                               solid5.85.0.r699.g0e7d56e-15.85.0.r700.gd439b89-1
                            spacebar  21.07.r8.g842fa38-1  21.07.r9.g6d59c7b-1
                           spectacle21.08.0.r1149.g1d53cd0-121.08.0.r1153.gb753cbe-1
                 syntax-highlighting5.85.0.r1647.g35cf6684-15.85.0.r1673.ge9ddb9ab-1
                      systemsettings5.22.4.r2481.g87be1c58-15.22.4.r2482.gfc607095-1
                         vakzination        r85.163310d-1        r89.ca87f0e-1
                               vvave  2.0.0.r2.g7416427-1  2.0.0.r8.g8437f37-1
                             yakuake21.08.0.r729.g7053b39-121.08.0.r732.g8339bac-1
                    zeroconf-ioslave21.08.0.r357.gb6713ee-121.08.0.r358.ga2f2ac0-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
A workaround can be to downgrade Vivaldi to a version before 4.1.2369.11
Old Issues
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Hi,
Odroid c4 up to date, no issue.
I don’t find in the repo the manjaro-arm-tools version 2.10.3 (testing or unstable repo x86_64)
The Manjaro x64 packages does not seem to have been updated in a while.
I see there is a waydroid package listed. Do I just install the waydroid package or is there more to getting it working?
