Hello ARM community.
A rather small update, nothing fancy.
Some highlights:
- Most of our kernels got updated
- Manjaro ARM Flasher, Manjaro ARM Installer and Manjaro ARM Tools all got updated
- Version 1.2.0 of Megapixels was released
- Siglo updated to 0.8.8
- Lots of Mobile specific packages got updated
- Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Sun Aug 8 22:50:08 CEST 2021)
- arm-testing community aarch64: 288 new and 259 removed package(s)
- arm-testing core aarch64: 18 new and 18 removed package(s)
- arm-testing extra aarch64: 67 new and 67 removed package(s)
- arm-testing kde-unstable aarch64: 244 new and 244 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-08-03 2021-08-08
electron 13.1.7-1 13.1.8-1
electron12 12.0.15-1 12.0.16-1
manjaro-arm-installer 1.4.4-1 1.4.5-1
megapixels 1.0.1-2 1.2.0-1
portfolio-file-manager 0.9.11-2 0.9.12-1
python-ytmusicapi 0.18.0-1 0.19.0-1
siglo 0.8.4-1 0.8.8-1
timeshift-autosnap 0.9-1 -
vivaldi 4.1.2369.11-1 4.1.2369.16-1
timeshift-autosnap-manjaro - 0.10-1
:: Different sync package(s) in repository community aarch64
acpica 20210604-1 20210730-1
adrdox 2.5.0-1 2.5.0-2
alacritty 0.8.0-1 0.9.0-1
arch-repro-status 1.2.3-1 1.2.4-1
avr-binutils 2.36.1-2 2.37-1
avr-gcc 11.1.0-1 11.2.0-1
babel-core 7.14.8-1 7.15.0-1
blender 17:2.93.1-5 17:2.93.2-1
borgmatic 1.5.17-1 1.5.18-1
broot 1.6.2-1 1.6.3-1
cargo-c 0.9.1-1 0.9.2-1
certbot 1.17.0-1 1.18.0-1
certbot-apache 1.17.0-1 1.18.0-1
certbot-dns-cloudflare 1.17.0-1 1.18.0-1
certbot-dns-cloudxns 1.17.0-1 1.18.0-1
certbot-dns-digitalocean 1.17.0-1 1.18.0-1
certbot-dns-dnsimple 1.17.0-1 1.18.0-1
certbot-dns-dnsmadeeasy 1.17.0-1 1.18.0-1
certbot-dns-gehirn 1.17.0-1 1.18.0-1
certbot-dns-google 1.17.0-1 1.18.0-1
certbot-dns-linode 1.17.0-1 1.18.0-1
certbot-dns-luadns 1.17.0-1 1.18.0-1
certbot-dns-nsone 1.17.0-1 1.18.0-1
certbot-dns-ovh 1.17.0-1 1.18.0-1
certbot-dns-rfc2136 1.17.0-1 1.18.0-1
certbot-dns-route53 1.17.0-1 1.18.0-1
certbot-dns-sakuracloud 1.17.0-1 1.18.0-1
certbot-nginx 1.17.0-1 1.18.0-1
chezmoi 2.1.3-1 2.1.4-1
cinnamon-settings-daemon 5.0.3-1 5.0.4-1
cockpit 249-1 250-1
cockpit-machines 248-1 249.1-1
cockpit-pcp 249-1 250-1
cockpit-podman 32-1 33-1
containerd 1.5.4-1 1.5.5-1
crash 7.2.8-1 7.3.0-1
crun 0.20.1-2 0.21-1
d-containers 0.8.0-3 0.8.0-4
d-mir-core 1.1.14-3 1.1.14-4
d-stdx-allocator 3.0.2-15 3.0.2-16
diffoscope 179-1 180-1
docker 1:20.10.7-1 1:20.10.8-1
dqlite 1.8.0-1 1.9.0-1
dust 0.6.1-2 0.6.2-1
e-antic 1.0.1-3 1.0.2-1
elixir 1.12.1-1 1.12.2-1
fcitx5-pinyin-zhwiki 1:0.2.3.20210722-1 1:0.2.3.20210804-1
firewalld 1.0.0-1 1.0.0-3
fossil 2.15.1-1 2.16-1
freeimage 3.18.0-11 3.18.0-12
fwupd 1.6.1-2 1.6.2-1
gentium-plus-font 5.000-4 6.001-1
giac 1.7.0.23-1 1.7.0.25-1
gimp-plugin-gmic 2.9.8-1 2.9.8-2
gir-to-d 0.22.0-1 0.22.0-2
github-cli 1.13.1-1 1.14.0-1
glibd 2.3.0-1 2.3.0-2
go 2:1.16.6-1 2:1.16.7-1
gopls 0.7.0-1 0.7.1-1
gpg-tui 0.7.3-1 0.7.4-1
gpsd 3.22-2 3.23-1
gtkd 3.9.0-12 3.9.0-13
hcloud 1.25.1-1 1.26.1-1
helix 0.3.0-2 0.3.0-4
himalaya 0.4.0-1 0.4.0-3
home-assistant 2021.7.4-2 2021.8.1-1
hugin 2020.0.0-6 2020.0.0-8
hugo 0.86.1-1 0.87.0-1
icewm 2.6.0-1 2.7.0-1
imv 4.2.0-3 4.3.0-1
inter-font 3.18-1 3.19-1
jenkins 2.304-1 2.305-1
jmol 14.31.48-1 14.31.49-1
josm 18004-1 18118-1
jsmol 14.31.48-1 14.31.49-1
jupyter-server 1.10.1-1 1.10.2-1
jupyterlab 3.1.1-1 3.1.4-1
krita-plugin-gmic 2.9.8-1 2.9.8-2
latte-dock 0.9.12-1 0.10.0-1
ldc 2:1.26.0-4 2:1.27.0-1
leptonica 1.81.0-1 1.81.1-1
lesspipe 1.85-1 1.86-1
liblphobos 2:1.26.0-4 2:1.27.0-1
libretro-core-info 1.9.6-1 1.9.7-1
libtg_owt 0.git6.91d836d-1 0.git6.91d836d-2
libvips 8.11.2-2 8.11.2-3
libvirt 1:7.5.0-1 1:7.6.0-1
libvirt-storage-gluster 1:7.5.0-1 1:7.6.0-1
libvirt-storage-iscsi-direct 1:7.5.0-1 1:7.6.0-1
lnav 0.9.0-2 0.10.0-1
logcli 2.2.1-3 2.3.0-1
loki 2.2.1-3 2.3.0-1
loki-canary 2.2.1-3 2.3.0-1
lshw B.02.19.2-1 B.02.19.2-2
lua-language-server 2.3.3-1 2.3.4-1
luminancehdr 2.6.1-4 2.6.1-5
lxd 4.16-1 4.17-1
mailutils 3.12-1 3.13-1
matrix-synapse 1.37.1-1 1.39.0-2
mdbook 0.4.12-1 0.4.12-2
merkaartor 0.18.4-7 0.18.4-8
micro 2.0.9-2 2.0.10-1
mitmproxy 7.0.0-1 7.0.2-1
mkosi 9-2 10-1
mustache-d 0.1.5-3 0.1.5-4
navit 0.5.6-1 0.5.6-2
nextcloud 22.0.0-2 22.1.0-1
nextcloud-app-contacts 4.0.0-3 4.0.1-1
nextcloud-app-notes 4.1.0-3 4.1.1-1
nextcloud-app-tasks 0.14.0-1 0.14.1-1
nix 2.3.14-1 2.3.15-1
nodejs 16.6.0-1 16.6.1-1
npm 7.20.3-1 7.20.5-1
npm6 6.14.13-1 6.14.14-1
nvchecker 2.4-1 2.4-2
nvme-cli 1.14-2 1.15-1
openimageio 2.2.15.1-5 2.2.17.0-1
openscenegraph 3.6.5-8 3.6.5-9
openxr 1.0.17-1 1.0.18-1
operator-sdk 1.10.0-1 1.10.1-1
otf-font-awesome 5.15.3-1 5.15.4-1
pantheon-files 6.0.0-1 6.0.1-1
pcaudiolib 1.1-3 1.2-1
pcp 5.3.1-1 5.3.2-1
pcp-gui 5.3.1-1 5.3.2-1
pcp-pmda-activemq 5.3.1-1 5.3.2-1
pcp-pmda-bcc 5.3.1-1 5.3.2-1
pcp-pmda-bind2 5.3.1-1 5.3.2-1
pcp-pmda-bpftrace 5.3.1-1 5.3.2-1
pcp-pmda-libvirt 5.3.1-1 5.3.2-1
pcp-pmda-mysql 5.3.1-1 5.3.2-1
pcp-pmda-nginx 5.3.1-1 5.3.2-1
pcp-pmda-nutcracker 5.3.1-1 5.3.2-1
pcp-pmda-openmetrics 5.3.1-1 5.3.2-1
pcp-pmda-podman 5.3.1-1 5.3.2-1
pcp-pmda-postgresql 5.3.1-1 5.3.2-1
pcp-pmda-snmp 5.3.1-1 5.3.2-1
pcsclite 1.9.1-1 1.9.3-1
perl-term-ui 0.46-7 0.50-1
podman 3.2.2-2 3.2.3-1
podman-docker 3.2.2-2 3.2.3-1
povray 2:3.7.0.9-6 2:3.7.0.9-7
promtail 2.2.1-3 2.3.0-1
prosody 1:0.11.9-2 1:0.11.10-1
ptex 2.4.0-1 2.4.1-1
pulumi 3.7.1-1 3.9.1-1
pybind11 2.7.0-2 2.7.1-1
pyright 1.1.159-1 1.1.160-1
python-acme 1.17.0-1 1.18.0-1
python-aioitertools 0.7.1-3 0.8.0-1
python-aioredis 1.3.1-1 2.0.0-1
python-dateutil 2.8.1-6 2.8.2-1
python-django-debug-toolbar 3.2-1 3.2.1-1
python-ethtool 0.14-6 0.15-1
python-faker 8.10.3-1 8.11.0-1
python-flask-httpauth 4.2.0-1 4.4.0-1
python-fonttools 4.25.2-1 4.26.1-1
python-frozendict 1.2-8 2.0.3-1
python-gast 0.5.0-1 0.5.2-1
python-gdstk 0.6.1-1 0.7.0-1
python-gevent 21.1.2-3 21.8.0-1
python-google-auth 1.29.0-1 1.30.0-1
python-greenlet 1.1.0-1 1.1.1-1
python-hiredis 1.1.0-3 2.0.0-1
python-hypothesis 6.14.5-1 6.14.6-1
python-identify 2.2.11-1 2.2.13-1
python-json-logger 2.0.0-1 2.0.2-1
python-jupyterlab_server 2.6.1-1 2.6.2-1
python-moto 2.2.0-1 2.2.1-1
python-mt-940 4.19.0-4 4.23.0-1
python-mypy-protobuf 1.24-1 2.9-1
python-openmdao 3.10.0-1 3.11.0-1
python-pip-api 0.0.14-3 0.0.17-1
python-prance 0.21.2-1 0.21.8.0-1
python-pyenchant 3.2.0-1 3.2.1-1
python-pynetbox 6.1.2-1 6.1.3-1
python-pysol_cards 0.10.1-3 0.10.2-1
python-rich 10.6.0-1 10.7.0-1
python-schemdraw 0.9-1 0.10-1
python-tox 3.24.0-1 3.24.1-1
python2-dateutil 2.8.1-6 2.8.2-1
python2-tox 3.24.0-1 3.24.1-1
qgis 3.20.1-1 3.20.1-3
raft 0.11.1-1 0.11.2-1
rapid-photo-downloader 0.9.26-1 0.9.26-2
restic 0.12.0-1 0.12.1-1
retroarch-assets-glui 1:376-1 1:378-1
retroarch-assets-ozone 1:376-1 1:378-1
retroarch-assets-xmb 1:376-1 1:378-1
rime-essay 0.0.0.20210627-1 0.0.0.20210805-1
rime-pinyin-zhwiki 1:0.2.3.20210722-1 1:0.2.3.20210804-1
rubber 1.5.1-3 1.6.0-1
ruby-faraday 1.3.0-2 1.6.0-1
ruby-faraday-middleware 1.0.0-2 1.1.0-1
ruby-rake 13.0.3-2 13.0.6-1
ruby-ruby2_keywords 0.0.4-3 0.0.5-1
scrot 1.6-1 1.6-2
serverless 2.52.0-1 2.53.0-1
shfmt 3.3.0-1 3.3.1-1
skaffold 1.28.1-1 1.29.0-1
skopeo 1.3.1-1 1.4.0-1
slirp4netns 1.1.11-1 1.1.12-1
smartdns 33-1 34-1
squid 4.16-1 5.1-1
syncthing 1.18.0-1 1.18.1-1
syncthing-relaysrv 1.18.0-1 1.18.1-1
tailscale 1.12.1-1 1.12.3-1
telegram-desktop 2.9.0-2 2.9.0-4
terraform 1.0.3-2 1.0.4-1
tilix 1.9.4-3 1.9.4-4
traefik 2.4.8-1 2.4.13-1
ttc-iosevka 7.3.2-1 9.0.1-1
ttc-iosevka-aile 7.3.2-1 9.0.1-1
ttc-iosevka-curly 7.3.2-1 9.0.1-1
ttc-iosevka-curly-slab 7.3.2-1 9.0.1-1
ttc-iosevka-etoile 7.3.2-1 9.0.1-1
ttc-iosevka-slab 7.3.2-1 9.0.1-1
ttc-iosevka-ss01 7.3.2-1 9.0.1-1
ttc-iosevka-ss02 7.3.2-1 9.0.1-1
ttc-iosevka-ss03 7.3.2-1 9.0.1-1
ttc-iosevka-ss04 7.3.2-1 9.0.1-1
ttc-iosevka-ss05 7.3.2-1 9.0.1-1
ttc-iosevka-ss06 7.3.2-1 9.0.1-1
ttc-iosevka-ss07 7.3.2-1 9.0.1-1
ttc-iosevka-ss08 7.3.2-1 9.0.1-1
ttc-iosevka-ss09 7.3.2-1 9.0.1-1
ttc-iosevka-ss10 7.3.2-1 9.0.1-1
ttc-iosevka-ss11 7.3.2-1 9.0.1-1
ttc-iosevka-ss12 7.3.2-1 9.0.1-1
ttc-iosevka-ss13 7.3.2-1 9.0.1-1
ttc-iosevka-ss14 7.3.2-1 9.0.1-1
ttc-iosevka-ss15 7.3.2-1 9.0.1-1
ttc-iosevka-ss16 7.3.2-1 9.0.1-1
ttc-iosevka-ss17 7.3.2-1 9.0.1-1
ttc-iosevka-ss18 7.3.2-1 9.0.1-1
ttf-font-awesome 5.15.3-1 5.15.4-1
ttf-ionicons 5.5.2-1 5.5.3-1
v2ray-domain-list-community 20210802121239-1 20210806154034-1
v2ray-geoip 202108020308-1 202108050026-1
vigra 1.11.1-351.11.1.r45+g8acd73a5-2
vigra-doc 1.11.1-35 -
viking 1.9-1 1.9-2
warpinator 1.2.4-1 1.2.4-2
xdotool 3.20160805.1-3 3.20210804.2-1
xh 0.11.0-1 0.12.0-1
yamllint 1.26.1-1 1.26.2-1
zathura 0.4.7-1 0.4.8-1
zathura-pdf-mupdf 0.3.6-5 0.3.7-1
zerotier-one 1.6.5-1 1.6.5-2
igsc - 0.2.3-1
intel-metee - 3.1.0-1
intel-metee-doc - 3.1.0-1
python-latex2mathml - 3.61.0-1
python-nbval - 0.9.6-2
python-xmljson - 0.2.1-1
python-ziafont - 0.2-1
python-ziamath - 0.3-1
r10k - 3.10.0-1
ruby-faraday-em_http - 1.0.0-1
ruby-faraday-em_synchrony - 1.0.0-1
ruby-faraday-excon - 1.1.0-1
ruby-faraday-httpclient - 1.0.1-1
ruby-faraday-net_http - 1.0.1-1
ruby-faraday-net_http_persistent - 1.2.0-1
ruby-faraday-patron - 1.0.0-1
ruby-faraday-rack - 1.0.0-1
ruby-json-schema - 2.8.1-4
ruby-log4r - 1.1.10-3
ruby-metadata-json-lint - 3.0.0-1
ruby-metadata_json_deps - 0.2.0-1
ruby-puppet_forge - 3.0.0-1
ruby-puppet_metadata - 0.4.0-1
ruby-rspec-its - 1.3.0-5
ruby-spdx-licenses - 1.3.0-1
sad - 0.4.8-4
sequoia-sop - 0.24.0-1
sequoia-sq - 0.25.0-1
sequoia-sqv - 1.0.0-1
vim-himalaya - 0.4.0-3
:: Different overlay package(s) in repository core aarch64
linux 5.13.7-1 5.13.9-1
linux-headers 5.13.7-1 5.13.9-1
linux-pinephone 5.13.7-1 5.13.9-1
linux-pinephone-headers 5.13.7-1 5.13.9-1
linux-quartz64 5.14.0-0.3 5.14.0-0.5
linux-quartz64-headers 5.14.0-0.3 5.14.0-0.5
linux-rc 5.14.rc4-1 5.14.rc4-2
linux-rc-headers 5.14.rc4-1 5.14.rc4-2
manjaro-arm-keyring 20210731-1 20210807-1
manjaro-keyring 20210622-1 20210807-2
:: Different sync package(s) in repository core aarch64
automake 1.16.3-1 1.16.4-1
btrfs-progs 5.13-1 5.13.1-1
diffutils 3.7-3 3.8-1
e2fsprogs 1.46.3-1 1.46.3-3
mpfr 4.1.0-2 4.1.0.p13-1
texinfo 6.8-1 6.8-2
util-linux 2.37.1-1 2.37.1-3
util-linux-libs 2.37.1-1 2.37.1-3
:: Different overlay package(s) in repository extra aarch64
manjaro-arm-flasher 0.6-1 0.7-1
manjaro-arm-tools 2.10.2-1 2.10.3-1
mesa-git21.3.0_devel.143163.f5b9d16823a-121.3.0_devel.143354.d2d642cc014-1
:: Different sync package(s) in repository extra aarch64
alsa-card-profiles 1:0.3.32-2 1:0.3.33-1
arch-rebuild-order 0.2-1 0.2-2
calligra 3.2.1-18 3.2.1-19
chromium 92.0.4515.107-3 92.0.4515.131-1
gegl 0.4.30-5 0.4.30-6
gimp 2.10.24-5 2.10.24-6
gst-plugin-opencv 1.18.4-10 1.18.4-11
gst-plugin-pipewire 1:0.3.32-2 1:0.3.33-1
gst-plugin-wpe 1.18.4-10 1.18.4-11
gst-plugins-bad 1.18.4-10 1.18.4-11
gst-plugins-bad-libs 1.18.4-10 1.18.4-11
gtk3 1:3.24.30-1 1:3.24.30-2
gtk3-demos 1:3.24.30-1 1:3.24.30-2
gtk3-docs 1:3.24.30-1 1:3.24.30-2
imagemagick 7.1.0.4-1 7.1.0.4-2
imagemagick-doc 7.1.0.4-1 7.1.0.4-2
ipset 7.14-1 7.15-1
kimageformats 5.84.0-2 5.84.0-3
kio-extras 21.04.3-1 21.04.3-2
krita 4.4.5-3 4.4.7-1
libbsd 0.10.0-2 0.11.3-1
libinput 1.18.0-1 1.18.1-1
libmbim 1.26.0-1 1.26.0-2
libqmi 1.28.6-1 1.30.0-1
libwacom 1.10-1 1.11-1
marble 21.04.3-1 21.04.3-2
marble-common 21.04.3-1 21.04.3-2
marble-maps 21.04.3-1 21.04.3-2
marble-qt 21.04.3-1 21.04.3-2
opencv 4.5.3-2 4.5.3-4
opencv-samples 4.5.3-2 4.5.3-4
openexr 3.0.5-2 3.1.1-1
pipewire-alsa 1:0.3.32-2 1:0.3.33-1
pipewire-docs 1:0.3.32-2 1:0.3.33-1
pipewire-jack 1:0.3.32-2 1:0.3.33-1
pipewire-media-session 1:0.3.32-2 1:0.3.33-1
pipewire-pulse 1:0.3.32-2 1:0.3.33-1
pipewire-zeroconf 1:0.3.32-2 1:0.3.33-1
plasma-wayland-session 5.22.4-2 5.22.4-3
plasma-workspace 5.22.4-2 5.22.4-3
prometheus-node-exporter 1.2.0-1 1.2.2-1
python-astroid 2.6.1-1 2.6.2-1
python-django 3.2.5-1 3.2.6-1
python-opencv 4.5.3-2 4.5.3-4
python-prometheus_client 0.10.1-1 0.11.0-1
python-pylint 2.8.1-1 2.8.2-1
python-tomli 1.1.0-2 1.2.0-1
python-virtualenv 20.6.0-1 20.7.0-1
python2-backports.entry-points-selectable 1.1.0-1 1.1.0-2
python2-virtualenv 20.6.0-1 20.7.0-1
qt5-3d 5.15.2+kde+r26-1 5.15.2+kde+r32-1
qtcreator 4.15.2-1 4.15.2-2
re2 1:20210601-1 1:20210801-1
stellarium 0.21.1-1 0.21.1-2
tomcat8 8.5.69-1 8.5.70-1
udisks2 2.9.2-1 2.9.3-1
vlc 3.0.16-2 3.0.16-3
xorg-server 1.20.13-1 1.20.13-2
xorg-server-common 1.20.13-1 1.20.13-2
xorg-server-devel 1.20.13-1 1.20.13-2
xorg-server-xephyr 1.20.13-1 1.20.13-2
xorg-server-xnest 1.20.13-1 1.20.13-2
xorg-server-xvfb 1.20.13-1 1.20.13-2
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.04.3.r12533.g61dc5a751-121.04.3.r12537.gd86b8df41-1
akonadi-calendar21.04.3.r1959.g76c6501-121.04.3.r1960.g2cebba0-1
akonadi-calendar-tools21.04.3.r878.gb2ab190-121.04.3.r879.ged042a7-1
akonadi-contacts21.04.3.r3028.g76b0d406-121.04.3.r3040.g128ed7c0-1
akonadi-import-wizard21.04.3.r1722.g75337ed-121.04.3.r1723.gc0bdc86-1
akonadi-mime21.04.3.r1631.g7fc4fcf-121.04.3.r1632.gd1f5c99-1
akonadi-notes21.04.3.r1015.gc21120f-121.04.3.r1016.g846761c-1
akonadi-search21.04.3.r1110.g10b87f2-121.04.3.r1112.g69ed14e-1
akonadiconsole21.04.3.r1502.gfa07fb0-121.04.3.r1503.gedf648f-1
akregator21.04.3.r6192.gd8d346aa-121.04.3.r6207.g609cf5bb-1
angelfish 21.07.r3.ga434e27-1 21.07.r5.g912496b-1
ark21.04.3.r4608.g8f550c80-121.04.3.r4609.g57196499-1
audiocd-kio21.04.3.r1023.g523fd27-121.04.3.r1024.g649fd98-1
baloo-widgets21.04.3.r684.g3396374-121.04.3.r687.gd367fea-1
blinken21.04.3.r627.g7ca2a7a-121.04.3.r628.ga97495d-1
bomber21.04.3.r520.g3512757-121.04.3.r521.g52c9ed0-1
bovo21.04.3.r731.g856c46e-121.04.3.r732.g66396f2-1
breeze5.22.4.r2225.g5c385621-15.22.4.r2227.g42315644-1
breeze-icons5.84.0.r1766.g2f468e61-15.84.0.r1767.g04a13e27-1
calendarsupport21.07.80.r12.gcfa15bb-121.07.80.r13.g6855ff7-1
cervisia21.04.3.r1639.g3007798-121.04.3.r1640.g2cbf459-1
discover5.22.4.r8247.g1c28a1cc-15.22.4.r8258.gaec33274-1
dolphin21.04.3.r6661.g393c659c9-121.04.3.r6673.g68ae758f4-1
dolphin-plugins21.04.3.r597.g81a72bf-121.04.3.r599.gf51b224-1
dragon21.04.3.r1007.g3a2d074-121.04.3.r1008.g727feec-1
drkonqi5.22.4.r672.gf511b225-15.22.4.r677.g922746e7-1
elisa21.04.3.r2742.g77152c3a-121.04.3.r2746.g25948c70-1
eventviews21.07.80.r11.g092aeb4-121.07.80.r13.g0765c30-1
extra-cmake-modules5.84.0.r3352.g72e9fb9-15.84.0.r3357.g602e481-1
ffmpegthumbs21.04.3.r189.g76a13b3-121.04.3.r190.g7dc382a-1
filelight21.04.3.r979.ge2f90c0-121.04.3.r980.gdd1887c-1
granatier21.04.3.r924.ge3d3c9a-121.04.3.r925.gb30c3bc-1
grantlee-editor21.04.3.r759.g0890ce9-121.04.3.r761.gd7bc71f-1
grantleetheme21.04.3.r333.g20debce-121.04.3.r339.gf169f6e-1
gwenview21.04.3.r6650.gb292af50-121.04.3.r6651.g659d788b-1
incidenceeditor21.04.3.r748.g454e216-121.04.3.r749.g28a7552-1
index-fm1.2.2.r116.g826fde5-11.2.2.r119.gc84fe5e-1
itinerary21.04.3.r1400.gd9cfd32-121.04.3.r1424.gc0cb465-1
juk21.04.3.r3108.g0e63bb44-121.04.3.r3109.g4694fe0f-1
k3b1:21.04.3.r6660.g56fed98f6-11:21.04.3.r6666.gcec4c4bc0-1
kaccounts-integration21.04.3.r1212.g7571d86-121.04.3.r1213.g1c40dc4-1
kactivities-stats5.84.0.r365.g8662452-15.84.0.r366.g1d6630f-1
kactivitymanagerd5.22.4.r1360.gb3214fa-15.22.4.r1361.g2977ccb-1
kaddressbook21.04.3.r6007.gc027d7fd-121.04.3.r6021.gac4df746-1
kajongg21.04.3.r4195.gf8c5ac9e-121.04.3.r4196.gf578c92a-1
kalarm21.04.3.r6431.gb64ccf88-121.04.3.r6436.g584e9789-1
kalarmcal21.04.3.r1134.g73e5c63-121.04.3.r1135.gd8835e3-1
kalgebra21.04.3.r2039.gd170a8d-121.04.3.r2040.g3738f5b-1
kalzium21.04.3.r4254.gbad28991-121.04.3.r4255.ge6aecd1b-1
kamoso21.04.3.r1428.gda4ba0d-121.04.3.r1429.g37ed426-1
kanagram21.04.3.r1283.g2bd976e-121.04.3.r1285.gf761457-1
kapman21.04.3.r602.gdf5602c-121.04.3.r603.gf7203b6-1
kapptemplate21.04.3.r954.g39dbb12-121.04.3.r955.gbf03e61-1
kate21.04.3.r18306.gd3dd58cb9-121.04.3.r18323.g8fb90faec-1
katomic21.04.3.r916.gac8eb01-121.04.3.r917.g47ca0e1-1
kbackup21.04.3.r389.g54a4a86-121.04.3.r390.g1aab938-1
kblackbox21.04.3.r724.gc63d2e3-121.04.3.r725.g4682f86-1
kblocks21.04.3.r665.gc497aa0-121.04.3.r666.g24ec0b5-1
kbounce21.04.3.r804.g1ff4d8d-121.04.3.r805.g7b942ee-1
kbreakout21.04.3.r861.g3613978-121.04.3.r862.g70ea259-1
kbruch21.04.3.r815.ge3701fb-121.04.3.r816.gef98da6-1
kcachegrind21.04.3.r1150.g0e6745f-121.04.3.r1151.ge04e43e-1
kcachegrind-common21.04.3.r1150.g0e6745f-121.04.3.r1151.ge04e43e-1
kcalc21.04.3.r1511.g6e9f4ed-121.04.3.r1512.gc909e5d-1
kcalendarcore5.84.0.r1227.gaa08db3d6-15.84.0.r1228.g673aa4c57-1
kcalutils21.04.3.r856.ga2b6d716f-121.04.3.r857.g34750c5b0-1
kcharselect21.04.3.r468.g53bc45e-121.04.3.r469.g54c67b1-1
kclock 21.07.r23.g34b2ae8-1 21.07.r24.gbb1d00e-1
kcmutils5.84.0.r531.g2fdc32c-15.84.0.r534.g8475ccd-1
kcolorchooser21.04.3.r225.gf937de8-121.04.3.r226.gf67480a-1
kcompletion5.84.0.r448.g7a0b9d2-15.84.0.r449.gae3b73a-1
kconfig5.84.0.r849.gdcc5f65-15.84.0.r851.g17c1795-1
kcoreaddons5.84.0.r1251.g4a24d363-15.84.0.r1260.gfd2a526b-1
kcron21.04.3.r776.gc138442-121.04.3.r777.g4c6e344-1
kdav1:5.84.0.r1290.gd47ce67-11:5.84.0.r1291.gea8d353-1
kde-cli-tools5.22.4.r1856.gd940b78-15.22.4.r1859.gafa56d3-1
kde-dev-utils21.04.3.r558.geff6b70-121.04.3.r559.g53c8482-1
kdebugsettings21.04.3.r833.g66b577d-121.04.3.r834.g37eaded-1
kdeconnect21.04.3.r3302.gcf8ada2b-121.04.3.r3305.g2d674d8b-1
kdegraphics-thumbnailers21.04.3.r234.gb335558-121.04.3.r235.ga26b83c-1
kdelibs4support5.84.0.r1029.gf886651a-15.84.0.r1030.g9029e796-1
kdepim-runtime21.04.3.r15152.gdeb4e7272-121.04.3.r15168.g12f0a0e41-1
kdeplasma-addons5.22.4.r8568.g547d4c76a-15.22.4.r8569.gd31c13559-1
kdf21.04.3.r793.g9b46f31-121.04.3.r794.g026d092-1
kdialog21.04.3.r1184.g4c144a1f6-121.04.3.r1185.g36c930b64-1
kdiamond21.04.3.r667.g087b030-121.04.3.r668.g7fc116c-1
kfind21.04.3.r2639.g1e525b4bd-121.04.3.r2640.g71dfb8180-1
kfloppy21.04.3.r753.g77af6be-121.04.3.r754.g999a9a9-1
kfourinline21.04.3.r980.gff9f466-121.04.3.r981.ga16283e-1
kgeography21.04.3.r1110.gc64e87c-121.04.3.r1111.g5fab02b-1
kget21.04.3.r3118.g0012b007-121.04.3.r3119.gcfe2bbb1-1
kglobalaccel5.84.0.r453.gac6c8df-15.84.0.r454.g355e20c-1
kgoldrunner21.04.3.r1237.gc613e06-121.04.3.r1238.g3c80544-1
kgpg21.04.3.r3128.g374d7a3b-121.04.3.r3129.gf892e2fd-1
khangman21.04.3.r1563.ga228cef-121.04.3.r1564.gcbc467e-1
khelpcenter21.04.3.r2675.g0657272e-121.04.3.r2677.g322c8a6e-1
khotkeys5.22.4.r2086.g1b06be5-15.22.4.r2088.g5e2bbcc-1
kidentitymanagement21.04.3.r3797.ge8dad504-121.04.3.r3804.g1329decb-1
kig21.04.3.r3143.g96186b6a-121.04.3.r3144.g935b487f-1
kigo21.04.3.r520.g08ebecf-121.04.3.r521.g2c02486-1
killbots21.04.3.r734.g41654e3-121.04.3.r735.g9a89476-1
kimagemapeditor21.04.3.r469.g9c81281-121.04.3.r470.g909a43c-1
kimap21.04.3.r1102.g08437b8-121.04.3.r1103.g61ec98b-1
kinfocenter5.22.4.r1865.g8a215f1-15.22.4.r1866.g2e4a2ae-1
kio5.84.0.r4874.g2c01ea96-15.84.0.r4885.g0f028a15-1
kio-extras21.04.3.r7096.g1d2655f1-121.04.3.r7098.ge6afe2f9-1
kio-gdrive21.04.3.r564.g20d635f-121.04.3.r565.gae07881-1
kirigami-gallery21.04.3.r211.g09e7613-121.04.3.r213.g381565a-1
kirigami25.84.0.r2846.g537e2132-15.84.0.r2847.g2545d845-1
kiriki21.04.3.r418.g6065eb4-121.04.3.r419.gd1d767e-1
kitemmodels5.84.0.r547.gb703c6f-15.84.0.r549.g4a40dd7-1
kiten21.04.3.r1142.g4553fc6-121.04.3.r1143.g8115656-1
kitinerary21.04.3.r1860.g236a36f-121.04.3.r1863.g13a53fa-1
kjumpingcube21.04.3.r783.g54f2ba1-121.04.3.r784.g7772574-1
kldap21.04.3.r872.g1a0513d-121.04.3.r874.g717c9a5-1
kleopatra21.04.3.r5915.g9de140ce-121.04.3.r5931.ge658a11c-1
klettres21.04.3.r913.gda6529b-121.04.3.r914.g6ec4462-1
klickety21.04.3.r632.gd6320f6-121.04.3.r633.gf244a5d-1
klines21.04.3.r761.g2b02c75-121.04.3.r762.g18475b8-1
kmag21.04.3.r689.gdb43b34-121.04.3.r692.g22e28dd-1
kmahjongg21.04.3.r1467.ge50f3b1-121.04.3.r1468.g5f0ecda-1
kmail-account-wizard21.04.3.r795.g35d4ddf-121.04.3.r796.gbb43520-1
kmailtransport21.04.3.r1620.g74fa6eb-121.04.3.r1626.gdfbd8fa-1
kmbox21.04.3.r531.g0315daf-121.04.3.r532.g1dbd7e6-1
kmime21.04.3.r1443.g30e622a-121.04.3.r1445.g4d7c3cd-1
kmines21.04.3.r1716.ga7fef85-121.04.3.r1717.g2b23d0f-1
kmix21.04.3.r2374.g9f1eeb70-121.04.3.r2375.gb5d115f0-1
kmplot21.04.3.r1461.g2a626fb-121.04.3.r1462.gf98fba7-1
knavalbattle21.04.3.r1384.gdc5a678-121.04.3.r1385.gb2634cb-1
knetwalk21.04.3.r654.g85a36d1-121.04.3.r655.gfe0cc84-1
knewstuff5.84.0.r1188.g54d6dcab-15.84.0.r1190.g6402da6b-1
knights21.04.3.r1048.g593573b-121.04.3.r1049.g9855fd8-1
knotes21.04.3.r3477.g02cd958d-121.04.3.r3494.g52f0e087-1
koko 21.07.r7.g7f7d241-1 21.07.r20.gf442440-1
kolf21.04.3.r1431.g91ecf4f-121.04.3.r1438.g8386d3d-1
kollision21.04.3.r486.g3bfd59a-121.04.3.r490.ge5fde57-1
kolourpaint21.04.3.r2350.g48141741-121.04.3.r2351.g3a3515b9-1
kompare21.04.3.r1103.g6f0305b-121.04.3.r1105.gd41a4cf-1
konqueror21.04.3.r14922.g7c14c663d-121.04.3.r14924.g57907035a-1
konquest21.04.3.r891.g7309631-121.04.3.r893.gc3ec8a2-1
konsole21.04.3.r7908.g414f933f-121.04.3.r7916.g99b39594-1
kontact21.04.3.r5351.g1ebc9a57-121.04.3.r5368.gf5cb1a94-1
kontactinterface21.04.3.r623.g4f8ba48-121.04.3.r624.g48b9253-1
kontrast21.04.3.r170.gc62ac8f-121.04.3.r171.g8e90006-1
konversation21.04.3.r8988.ge7560658-121.04.3.r8990.g063aab07-1
korganizer21.04.3.r11428.gae4950ddc-121.04.3.r11450.g518c0af72-1
kosmindoormap21.04.3.r619.geb851a4-121.04.3.r628.g4ffe68e-1
kpackage5.84.0.r684.g7b77a77-15.84.0.r686.g6492079-1
kpat21.04.3.r2560.g40ec2ed-121.04.3.r2561.g5291a71-1
kpeoplesink r70.g59cc131-1 r71.g1a47210-1
kpimtextedit21.04.3.r1394.gab26ddd-121.04.3.r1395.ge49b70c-1
kpkpass21.04.3.r230.g394482f-121.04.3.r231.g9878df2-1
krdc21.04.3.r1531.gd7c1899-121.04.3.r1532.ge42e5f0-1
kreversi21.04.3.r1219.gf14fd6f-121.04.3.r1220.g8303f0f-1
krfb21.04.3.r1409.g0eaf1bc-121.04.3.r1410.gcb86f9c-1
kruler21.04.3.r692.gf64ae61-121.04.3.r693.gca54623-1
krunner5.84.0.r650.gcc01f58-15.84.0.r654.gcac7b97-1
kshisen21.04.3.r1197.g448c2ee-121.04.3.r1199.g74d5caa-1
ksirk21.04.3.r958.g762ccee-121.04.3.r959.g2ecfb4d-1
ksmtp21.04.3.r359.g4c722cc-121.04.3.r360.g252e4a1-1
ksnakeduel21.04.3.r799.gce16717-121.04.3.r800.g5e44a0c-1
kspaceduel21.04.3.r625.g4b314f8-121.04.3.r627.g704594a-1
ksquares21.04.3.r512.gffc6ab6-121.04.3.r513.g01ea286-1
ksudoku21.04.3.r1047.g7a05a76-121.04.3.r1048.ga204d83-1
ksystemlog21.04.3.r648.ga5b2adc-121.04.3.r649.g2889185-1
kteatime21.04.3.r719.g28209c4-121.04.3.r720.gd35c30d-1
ktexteditor5.84.0.r2906.g96182d63-15.84.0.r2908.g2f2a691f-1
ktimer21.04.3.r466.g3495155-121.04.3.r467.g5691357-1
ktnef21.04.3.r656.gb1891cd-121.04.3.r657.g6db4839-1
ktorrent21.04.3.r2756.g00ec970e-121.04.3.r2761.g421ddfee-1
ktouch21.04.3.r2137.g62ffc8a-121.04.3.r2138.g066e658-1
ktuberling21.04.3.r1003.g75890ff-121.04.3.r1004.g323ddab-1
kturtle21.04.3.r1113.g94c8f6d-121.04.3.r1116.g57ace23-1
kubrick21.04.3.r365.gc949aa8-121.04.3.r366.g56f5df7-1
kwallet5.84.0.r1078.g60c8e9d-15.84.0.r1079.gaea7be1-1
kwalletmanager21.04.3.r1201.gedd21a2-121.04.3.r1203.g6dc0a94-1
kwave21.04.3.r3738.ga4cf7ac2-121.04.3.r3739.g9357ded2-1
kwayland-server5.22.4.r1361.g02267a3-15.22.4.r1363.gf527cc2-1
kweather 21.07.r10.gd70d011-1 21.07.r22.gdccfaa0-1
kweathercore 0.4.r4.g35b7c5c-1 0.4.r5.gf6196b4-1
kwin5.22.4.r19705.gb90d92a8f-15.22.4.r19719.g1041ef827-1
kwinft5.22.0.r19054.g177a84db9-15.22.0.r19123.g8c03f21df-1
kwrite21.04.3.r18306.gd3dd58cb9-121.04.3.r18323.g8fb90faec-1
libakonadi21.04.3.r12533.g61dc5a751-121.04.3.r12537.gd86b8df41-1
libgravatar21.04.3.r359.g8ace9f1-121.04.3.r360.g81e937a-1
libkdegames21.04.3.r2186.gb4c5b960-121.04.3.r2187.gf5381404-1
libkdepim21.04.3.r841.g24a530e-121.04.3.r842.g10f77da-1
libkgapi21.04.3.r1287.g81197c8-121.04.3.r1288.g1cfd76a-1
libkleo21.04.3.r917.g0608fbe-121.04.3.r918.gc5adace-1
libkmahjongg21.04.3.r455.g5593450-121.04.3.r456.ga02d1ab-1
libkscreen5.22.4.r1586.g618f24d-15.22.4.r1587.g237850e-1
libksieve21.04.3.r1559.gec618362-121.04.3.r1561.g3f445143-1
libksysguard5.22.4.r2259.g2dac54c-15.22.4.r2269.gb1dd1be-1
libktorrent21.04.3.r521.ged0e045-121.04.3.r522.gfb083f5-1
libquotient r2035.g72643d2-1 r2039.gbf6303c-1
lokalize21.04.3.r1767.g3541bb0-121.04.3.r1768.ge30edb2-1
lskat21.04.3.r809.g7885937-121.04.3.r810.g1ddcf41-1
mailcommon21.04.3.r1076.g1eac913-121.04.3.r1078.g917ad47-1
mailimporter21.04.3.r463.g21c0351-121.04.3.r464.g9bd4688-1
marble21.04.3.r13322.gb973663cb-121.04.3.r13324.g9eb9c7494-1
marble-common21.04.3.r13322.gb973663cb-121.04.3.r13324.g9eb9c7494-1
marble-qt21.04.3.r13322.gb973663cb-121.04.3.r13324.g9eb9c7494-1
markdownpart21.04.3.r79.gba9ecf0-121.04.3.r80.g641b90a-1
mbox-importer21.04.3.r504.g99b2e67-121.04.3.r505.gb65ac8c-1
messagelib21.04.3.r6098.gbd96fddc-121.04.3.r6108.g5845a92a-1
minuet21.04.3.r579.gdc33ba7-121.04.3.r580.ga23c7c7-1
neochat r1795.gde7354f0-1 r1813.g9e4d0ddc-1
okular21.04.3.r9408.g263952458-121.04.3.r9409.g139b822b0-1
palapeli21.04.3.r1227.g2df0f22-121.04.3.r1228.g4d18ee6-1
partitionmanager21.04.3.r1529.g5264203-121.04.3.r1530.gd4afb41-1
pim-data-exporter21.04.3.r2423.g492127c1-121.04.3.r2425.g8be761a9-1
pim-sieve-editor21.04.3.r1495.g057b6a9-121.04.3.r1497.g4443cf4-1
pimcommon21.04.3.r1069.gc4cfdbb-121.07.80.r1070.gb6962a2-1
plasma-browser-integration5.22.3.r1269.g4c28b9a1-15.22.3.r1271.g6e2f76be-1
plasma-desktop5.22.4.r8565.gefb9823aa-15.22.4.r8570.g6749d08aa-1
plasma-firewall5.22.4.r499.gfe33df5-15.22.4.r501.g28fa5f5-1
plasma-framework5.84.0.r15928.g42e64f455-15.84.0.r15929.g435df1385-1
plasma-integration5.22.4.r521.g61c99d0-15.22.4.r522.gb4ca236-1
plasma-mobile-nm5.22.3.r3066.g3a86df12-15.22.3.r3067.g99ed744a-1
plasma-nm5.22.3.r3066.g3a86df12-15.22.3.r3067.g99ed744a-1
plasma-phone-components5.22.3.r1442.g5ab4624f-15.22.3.r1443.g7ef6c9c7-1
plasma-settings 21.07.r7.g1915342-1 21.07.r8.gaca9de5-1
plasma-systemmonitor5.22.4.r472.g8bc52a3-15.22.4.r475.g2b4bc3d-1
plasma-wayland-session5.22.4.r10482.g14bcd88cc-15.22.4.r10496.g07c5365e1-1
plasma-workspace5.22.4.r10482.g14bcd88cc-15.22.4.r10496.g07c5365e1-1
polkit-kde-agent5.22.4.r499.g6aa608d-15.22.4.r501.g4c2c54a-1
powerdevil5.22.4.r2453.g013f76a4-15.22.4.r2457.geccf6a12-1
print-manager21.04.3.r1033.g927adec-121.04.3.r1034.g66346a7-1
purpose5.84.0.r867.g599e08d-15.84.0.r869.g23c142a-1
qcachegrind21.04.3.r1150.g0e6745f-121.04.3.r1151.ge04e43e-1
qqc2-breeze-style5.22.4.r220.gdcfd65f-15.22.4.r221.gbee656e-1
sddm0.19.0.r50.g8b9ffb4-10.19.0.r51.g8a929e0-1
sddm-kcm5.22.4.r590.gd77c138-15.22.4.r592.gd26553b-1
solid5.84.0.r693.g80310ba-15.84.0.r694.gec915ed-1
spacebar 21.07.r5.g27b884f-1 21.07.r6.gc80303c-1
spectacle21.04.3.r1134.g0aec65b-121.04.3.r1135.gd463449-1
step21.04.3.r1154.g6bf2042-121.04.3.r1155.g2b2c1cc-1
svgpart21.04.3.r176.ga5f3adc-121.04.3.r177.gff5753d-1
sweeper21.04.3.r526.g2d5be70-121.04.3.r527.g04cbc19-1
systemsettings5.22.4.r2470.ga8e7e1dc-15.22.4.r2475.gf7be996c-1
vakzination r68.690b1a6-1 r81.9c73f33-1
wrapland5.22.0.r1497.ge908f22-15.22.0.r1534.g82d772e-1
xdg-desktop-portal-kde5.22.4.r375.g66640c6-15.22.4.r377.g8c80da1-1
zeroconf-ioslave21.04.3.r356.g0bb67c4-121.04.3.r357.gb6713ee-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
