[ARM Testing Update] 2021-07-30 - DesQ, Code, PulseAudio, Xorg-Server and kernels
Hello ARM community.
A rather small update, nothing fancy.
DesQ is a new desktop environment under heavy development
Some highlights:
  • A couple of our kernels got updated
  • DesQ got it’s package selection extended with lots of new Apps and Utilities
  • PulseAudio is now version 15.0
  • And Xorg-Server got updated to 1.20.13
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Fri Jul 30 22:54:18 CEST 2021)
  • arm-testing community aarch64: ??? new and ??? removed package(s)
  • arm-testing core aarch64: ?? new and ?? removed package(s)
  • arm-testing extra aarch64: ??? new and ??? removed package(s)
  • arm-testing kde-unstable aarch64: ??? new and ??? removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2021-07-27         2021-07-30
                           bitwarden             1.27.1-1             1.27.1-2
                              chatty  0.3.3+16+g11c76c6-1  0.3.3+19+g1fd48d5-1
                                code             1.57.1-1             1.58.2-1
                    desq-session-git        r50.b24bf9a-1                    -
                      desq-shell-git       r105.4d54364-1                    -
                         libdesq-git        r81.87e986b-1                    -
                       libdesqui-git        r28.3b8b76c-1                    -
                       libdesqwl-git        r26.6c72627-1                    -
                                 lxc            1 4.0.6-1                    -
                          oyster-git         r7.1418f70-1                    -
                            pacutils             0.11.0-3             0.11.0-4
            pinebookpro-post-install           20210709-2           20210728-1
              portfolio-file-manager  0.9.10+7+g4174bfa-1             0.9.11-1
                rockpi4-post-install           20210709-1           20210728-1
              rockpro64-post-install           20210709-2           20210728-1
                             vivaldi        4.0.2312.41-1        4.1.2369.11-1
                                xsel     1.2.0.20190821-1                    -
                                 yay             10.3.0-1             10.3.1-1
                  desq-apps-archiver                    -            0.0rwt1-1
                      desq-apps-docs                    -            0.0rwt1-1
                  desq-apps-dropdown                    -            0.0rwt1-1
                      desq-apps-term                    -            0.0rwt1-1
                        desq-session                    -          0.0rwt1.1-1
                          desq-shell                    -            0.0rwt1-1
                     desq-utils-lock                    -            0.0rwt1-1
               desq-utils-polkitexec                    -            0.0rwt1-1
              desq-utils-powerdaemon                    -            0.0rwt1-1
             desq-utils-powermanager                    -            0.0rwt1-1
                   desq-utils-runner                    -            0.0rwt1-1
                      desq-utils-sni                    -            0.0rwt1-1
                   desq-utils-splash                    -            0.0rwt1-1
                   desq-utils-volume                    -            0.0rwt1-1
                             libdesq                    -          0.0rwt1.1-1
                           libdesqui                    -            0.0rwt1-1
                           libdesqwl                    -            0.0rwt1-1
:: Different sync package(s) in repository community aarch64
                           bctoolbox              5.0.0-2              5.0.3-1
                                borg             1.1.17-1             1.1.17-2
                        cargo-expand              1.0.7-1              1.0.8-1
                               chuck            1.4.0.1-1            1.4.1.0-1
                             clojure         1.10.3.849-1         1.10.3.933-1
                      container-diff             0.16.0-2             0.17.0-1
                       diff-so-fancy              1.4.2-1              1.4.3-1
                              erlang               24.0-1             24.0.4-1
                          erlang-nox               24.0-1             24.0.4-1
                     erlang-unixodbc               24.0-1             24.0.4-1
                           fetchmail             6.4.19-1             6.4.20-1
                           filezilla             3.55.0-1             3.55.0-2
               firefox-ublock-origin             1.37.0-1             1.37.2-1
                             freecad             0.19.2-2             0.19.2-3
                             freerdp            2:2.3.2-1            2:2.4.0-1
                      fuse-overlayfs                1.6-1                1.7-1
                         geoipupdate              4.7.1-1              4.8.0-1
                            glewlwyd              2.5.2-2              2.5.3-1
                                haxe              4.2.3-2              4.2.3-3
                      home-assistant           2021.5.3-2           2021.7.4-2
                                jmol           14.31.47-1           14.31.48-1
                               jsmol           14.31.47-1           14.31.48-1
                          jupyterlab              3.1.0-1              3.1.1-1
                                khal             0.10.3-1             0.10.4-1
                             klavaro               3.11-1               3.13-1
                             libdsme             0.66.3-1                    -
                        libfilezilla             0.30.0-1             0.31.0-1
                           libkeccak                1.2-2              1.2.1-1
            libretro-beetle-pce-fast               1127-1               1129-1
                 libretro-beetle-psx               2538-1               2544-1
              libretro-beetle-psx-hw               2538-1               2544-1
                  libretro-bsnes2014              1:566-1              1:577-1
                   libretro-gambatte                908-1                912-1
            libretro-genesis-plus-gx               1580-1               1786-1
                       libretro-mgba               7842-1               7979-1
                       libretro-play               6549-1               6632-1
              libretro-shaders-slang                814-1                816-1
                          libtracefs              1.2.3-1              1.2.4-1
        lightdm-gtk-greeter-settings              1.2.2-5              1.2.2-6
                                mame              0.233-1              0.234-1
                          mame-tools              0.233-1              0.234-1
                       mediastreamer              5.0.0-1              5.0.3-1
                   nodejs-lts-erbium            12.22.3-1            12.22.4-2
                  nodejs-lts-fermium            14.17.3-1            14.17.4-1
                           nvchecker                2.3-4                2.4-1
                                 oha              0.4.4-1              0.4.6-1
                                opam              2.0.9-1              2.1.0-1
                       pantheon-mail              6.0.0-1              6.1.0-1
                             presage              0.9.1-1                    -
                       python-abydos              0.5.0-1              0.5.0-2
                       python-cftime              1.4.1-1              1.5.0-1
               python-discogs-client             2.3.12-1             2.3.12-2
                     python-django-q              1.3.9-1              1.3.9-2
                         python-flit              3.2.0-2              3.2.0-3
                    python-flit-core              3.2.0-2              3.2.0-3
                   python-matplotlib              3.4.2-2              3.4.2-3
                   python-matrix-nio             0.18.5-1             0.18.6-1
                          python-mss              6.0.0-3              6.1.0-1
                        python-param             1.10.1-1             1.11.1-1
                        python-partd              1.1.0-3              1.2.0-1
                     python-pdfminer           20201018-2           20201018-3
                      python-pikepdf             2.16.0-1             2.16.1-1
                         python-pivy              0.6.5-3              0.6.6-1
            python-py_stringmatching              0.4.2-1              0.4.2-2
                 python-pyscreenshot                2.3-1                3.0-1
                     python-pyspnego              0.1.5-1              0.1.6-1
                   python-pytest-mpi                0.4-3                0.5-1
             python-pyvirtualdisplay                2.1-1                2.2-1
        python-pyxdameraulevenshtein              1.6.1-1              1.7.0-1
                    python-qstylizer             0.1.10-1              0.2.0-1
                    python-schemdraw                0.8-2                0.9-1
             python-securesystemslib             0.20.0-1             0.20.1-1
                  python-sounddevice              0.4.1-2              0.4.2-1
               python-sphinx-autoapi              1.8.1-1              1.8.2-1
                 python-textdistance              4.2.0-1              4.2.1-1
             python-virtualenv-clone              0.5.5-1              0.5.6-1
                    python-wurlitzer              2.0.0-3              2.1.1-1
                               qt6ct                0.3-1                0.4-1
                         qutebrowser              2.3.0-1              2.3.1-1
                              spdlog              1.9.0-1              1.9.1-1
                             systemc              2.3.3-1              2.3.3-2
                           tailscale             1.12.0-1             1.12.1-1
                           trace-cmd              2.9.3-2              2.9.5-1
                  ttf-jetbrains-mono              2.225-1              2.241-1
                   ttf-sarasa-gothic             0.33.0-1             0.33.1-1
                             uvicorn             0.14.0-1             0.14.0-2
                         v2ray-geoip       202107220025-1       202107290023-1
                           verilator              4.210-1              4.210-2
                           wingpanel              3.0.0-1              3.0.0-2
                                xplr             0.14.4-1             0.14.5-1
                          youtube-dl         2021.06.06-1                    -
                                 zaz              1.0.0-9              1.0.1-1
                          gtkdatabox                    -              1.0.0-1
                               helix                    -              0.3.0-2
              pantheon-notifications                    -              6.0.0-1
                 pantheon-onboarding                    -              6.0.0-1
:: Different overlay package(s) in repository core aarch64
                               linux             5.13.5-1             5.13.6-1
                       linux-headers             5.13.5-1             5.13.6-1
                            linux-rc           5.14.rc3-2           5.14.rc3-5
                    linux-rc-headers           5.14.rc3-2           5.14.rc3-5
                              pacman              6.0.0-3              6.0.0-4
                        pacman-debug              6.0.0-3              6.0.0-4
                   uboot-pinebookpro            2021.07-1            2021.07-2
               uboot-pinebookpro-bsp                1.5-9               1.5-10
                      uboot-rockpi4b            2021.07-1            2021.07-2
                      uboot-rockpi4c            2021.07-1            2021.07-2
                     uboot-rockpro64            2021.07-1            2021.07-2
:: Different sync package(s) in repository core aarch64
                             iputils           20210202-1           20210722-1
                           libcap-ng              0.8.2-1              0.8.2-3
                             libidn2              2.3.1-1              2.3.2-1
                                sudo           1.9.7.p1-1           1.9.7.p2-1
                        python-capng                    -              0.8.2-3
:: Different overlay package(s) in repository extra aarch64
            archlinux-appstream-data           20210423-1                    -
                          libadwaita1.1.0.r1547.g660d529-1                    -
:: Different sync package(s) in repository extra aarch64
                  alsa-card-profiles           1:0.3.32-1           1:0.3.32-2
                      appstream-glib             0.7.18-2                    -
                                bind            9.16.18-1            9.16.19-1
                              cantor            21.04.3-1            21.04.3-2
                            cbindgen             0.19.0-1             0.20.0-1
                      geoip-database           20210622-1           20210727-1
                geoip-database-extra           20210622-1           20210727-1
                 gst-plugin-pipewire           1:0.3.32-1           1:0.3.32-2
                               ipset               7.12-1               7.14-1
                                 ldb            1:2.4.0-1            2:2.3.0-1
                           libfprint             1.92.0-1             1.92.1-1
                              libgnt             2.14.1-1             2.14.2-1
                               libnm             1.32.4-1                    -
                            libpulse               14.2-3               15.0-1
                        libqalculate             3.19.0-1             3.20.1-1
                          malcontent              0.9.0-1             0.10.1-1
                      mkvtoolnix-cli             59.0.0-1             59.0.0-2
                      mkvtoolnix-gui             59.0.0-1             59.0.0-2
                      networkmanager             1.32.4-1                    -
                            nftables            1:0.9.9-1            1:0.9.9-6
                      nm-cloud-setup             1.32.4-1                    -
                              okular            21.04.3-2                    -
                       pipewire-alsa           1:0.3.32-1           1:0.3.32-2
                       pipewire-docs           1:0.3.32-1           1:0.3.32-2
                       pipewire-jack           1:0.3.32-1           1:0.3.32-2
              pipewire-media-session           1:0.3.32-1           1:0.3.32-2
                      pipewire-pulse           1:0.3.32-1           1:0.3.32-2
                   pipewire-zeroconf           1:0.3.32-1           1:0.3.32-2
              plasma-wayland-session             5.22.4-1             5.22.4-2
                    plasma-workspace             5.22.4-1             5.22.4-2
                          pulseaudio               14.2-3               15.0-1
                pulseaudio-bluetooth               14.2-3               15.0-1
                pulseaudio-equalizer               14.2-3               15.0-1
                     pulseaudio-jack               14.2-3               15.0-1
                     pulseaudio-lirc               14.2-3               15.0-1
                      pulseaudio-rtp               14.2-3               15.0-1
                 pulseaudio-zeroconf               14.2-3               15.0-1
                       qalculate-gtk             3.19.0-1             3.20.1-1
                               rsync              3.2.3-3              3.2.3-4
                                rust           1:1.53.0-2           1:1.54.0-1
                           rust-docs           1:1.53.0-2           1:1.54.0-1
                                step            21.04.3-1            21.04.3-2
                            tomcat10             10.0.8-1             10.0.9-1
                         xorg-server            1.20.12-1            1.20.13-1
                  xorg-server-common            1.20.12-1            1.20.13-1
                   xorg-server-devel            1.20.12-1            1.20.13-1
                  xorg-server-xephyr            1.20.12-1            1.20.13-1
                   xorg-server-xnest            1.20.12-1            1.20.13-1
                    xorg-server-xvfb            1.20.12-1            1.20.13-1
                         libfreeaptx                    -              0.1.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
                                 ark21.04.3.r4606.g8330d104-121.04.3.r4608.g8f550c80-1
                       baloo-widgets21.04.3.r681.gd686783-121.04.3.r682.g7c1aaf3-1
                           bluedevil1:5.22.3.r2273.g1b7b91fe-11:5.22.4.r2273.g1b7b91fe-1
                              breeze5.22.3.r2225.g5c385621-15.22.4.r2225.g5c385621-1
                         breeze-grub5.22.3.r11.g63136a9-15.22.4.r11.g63136a9-1
                          breeze-gtk5.22.3.r420.gfccd7df-15.22.4.r420.gfccd7df-1
                        breeze-icons5.84.0.r1761.g3771dae6-15.84.0.r1764.g3d6a7fb4-1
                     calendarsupport21.07.80.r9.g6d55d7f-121.07.80.r12.gcfa15bb-1
                            discover5.22.3.r8241.gf55d73e2-15.22.4.r8244.g1e06426b-1
                     dolphin-plugins21.04.3.r596.g773e4b2-121.04.3.r597.g81a72bf-1
                             drkonqi5.22.3.r672.gf511b225-15.22.4.r672.gf511b225-1
                          eventviews21.07.80.r7.g4e41f50-121.07.80.r8.g2f6dc20-1
                frameworkintegration5.84.0.r589.g4aa5e78-15.84.0.r590.g83123c6-1
                            gwenview21.04.3.r6649.gb10fe5b8-121.04.3.r6650.gb292af50-1
                            index-fm1.2.2.r111.gb46e17c-11.2.2.r114.g4d8ee62-1
                                 k3b1:21.04.3.r6655.g3456f6562-11:21.04.3.r6656.gebb6283ae-1
               kaccounts-integration21.04.3.r1210.g7660f66-121.04.3.r1211.g90bb6da-1
                   kactivitymanagerd5.22.3.r1359.gb4b0fec-15.22.4.r1360.gb3214fa-1
                                kalk  21.07.r0.g2412914-1  21.07.r2.g9bb86f2-1
                            karchive5.84.0.r496.ge657605-15.84.0.r498.g9ab5f2b-1
                               kasts  21.07.r4.g9384f3c-1  21.07.r7.g0b33c62-1
                                kate21.04.3.r18299.g8328b53fb-121.04.3.r18306.gd3dd58cb9-1
                           kcalutils21.04.3.r855.g697195969-121.04.3.r856.ga2b6d716f-1
                              kclock 21.07.r19.g56f360a-1 21.07.r23.g34b2ae8-1
                            kcmutils5.84.0.r529.g431b5db-15.84.0.r531.g2fdc32c-1
                      kconfigwidgets5.84.0.r602.gbcde63c-15.84.0.r605.g9fc356a-1
                         kcoreaddons5.84.0.r1249.gf5f64064-15.84.0.r1251.g4a24d363-1
                              kcrash5.84.0.r402.g701cd36-15.84.0.r403.gdc45a01-1
                       kde-cli-tools5.22.3.r1853.g1915f1a-15.22.4.r1855.g0101c06-1
                      kde-gtk-config5.22.3.r896.g971adfc-15.22.4.r896.g971adfc-1
                          kdeconnect21.04.3.r3299.ga3082de5-121.04.3.r3301.g55b946f8-1
                         kdecoration5.22.3.r268.g1dabf57-15.22.4.r268.g1dabf57-1
                       kdepim-addons21.04.2.r4239.g4180eccf-121.04.3.r4239.g4180eccf-1
                      kdepim-runtime21.04.3.r15148.g47b49d185-121.04.3.r15149.gd47c29c4d-1
                    kdeplasma-addons5.22.3.r8564.ga54e96603-15.22.4.r8565.g6bd45a9d7-1
                            kdisplay5.22.0.r1448.g0cb3d65-15.22.0.r1450.g1fa20e2-1
                          kemoticons5.84.0.r378.gd8d5133-15.84.0.r379.gde2d0fb-1
                            keysmith  21.07.r1.g503fdde-1  21.07.r3.g3c0fc62-1
                             kgamma55.22.3.r456.g5885d2f-15.22.4.r456.g5885d2f-1
                            khotkeys5.22.3.r2086.g1b06be5-15.22.4.r2086.g1b06be5-1
                 kidentitymanagement21.04.3.r3796.g8c900018-121.04.3.r3797.ge8dad504-1
                               kimap21.04.3.r1101.ge0538b4-121.04.3.r1102.g08437b8-1
                         kinfocenter5.22.3.r1863.g53b7155-15.22.4.r1863.g53b7155-1
                          kio-extras21.04.3.r7094.g5dff395e-121.04.3.r7095.g767d1ff8-1
                     kirigami-addons   0.2.r36.gb197d98-1  1:0.2.r6.gc4f3e01-1
                           kirigami25.84.0.r2842.g253eedef-15.84.0.r2844.g39ef8c89-1
                          kitinerary21.04.3.r1843.gedce84c-121.04.3.r1846.g1b797aa-1
                               kldap21.04.3.r871.ge0f59be-121.04.3.r872.g1a0513d-1
                           kleopatra21.04.3.r5913.gbb92dfd2-121.04.3.r5914.gace1bb63-1
                               kmail21.04.2.r25806.g4b85ab9c2-121.04.3.r25854.gfcf8afc62-1
                               kmbox21.04.3.r529.geffe162-121.04.3.r530.g52c7c32-1
                           kmenuedit5.22.3.r968.g2742003-15.22.4.r968.g2742003-1
                               kmime21.04.3.r1441.gebb0fc1-121.04.3.r1442.gc6d4a1d-1
                             kontact21.04.3.r5347.gb9c29459-121.04.3.r5348.g3a26ab1b-1
                          korganizer21.04.3.r11420.gdbd8f4552-121.04.3.r11422.g94909cbf3-1
                            kpackage5.84.0.r683.g0aaf95f-15.84.0.r684.g7b77a77-1
                        kpimtextedit21.04.3.r1393.g3874363-121.04.3.r1394.gab26ddd-1
                           krecorder  21.07.r0.gb90079d-1  21.07.r2.gfd5e12a-1
                             kscreen5.22.3.r1338.g845c8ab-15.22.4.r1338.g845c8ab-1
                       kscreenlocker5.22.3.r861.g7964776-15.22.4.r861.g7964776-1
                         ksshaskpass5.22.3.r196.gdaa2679-15.22.4.r196.gdaa2679-1
                           ksysguard5.22.3.r3508.g4d304e1e-15.22.4.r3508.g4d304e1e-1
                        ksystemstats5.22.3.r177.g65c605e-15.22.4.r177.g65c605e-1
                               ktrip  21.07.r0.g4e972de-1  21.07.r5.g7317bbf-1
                         kwallet-pam5.22.3.r250.g3bdf94a-15.22.4.r250.g3bdf94a-1
                kwayland-integration5.22.3.r179.g5901512-15.22.4.r179.g5901512-1
                     kwayland-server5.22.3.r1356.g9735031-15.22.4.r1360.g7655551-1
                            kweather  21.07.r4.gf0e720e-1  21.07.r7.g15ebb4f-1
                        kweathercore 21.05.r12.g4690eee-1    0.4.r0.gd47574f-1
                                kwin5.22.3.r19692.g9f00c29c6-15.22.4.r19697.g09f786a20-1
                       kwindowsystem5.84.0.r599.g26e295a-15.84.0.r600.g2ee7179-1
                              kwrite21.04.3.r18299.g8328b53fb-121.04.3.r18306.gd3dd58cb9-1
                             kwrited5.22.3.r480.g682279c-15.22.4.r480.g682279c-1
                             kxmlgui5.84.0.r790.g917b743d-15.84.0.r791.gab6959ef-1
                             libkleo21.04.3.r915.g30afaf4-121.04.3.r916.g39c10dd-1
                          libkscreen5.22.3.r1586.g618f24d-15.22.4.r1586.g618f24d-1
                           libksieve21.04.3.r1552.gc4525c0b-121.04.3.r1557.g5f57bc1b-1
                        libksysguard5.22.3.r2259.g2dac54c-15.22.4.r2259.g2dac54c-1
                         libquotient     r2025.gcddf3c6-1     r2032.g7ee1681-1
                     maliit-keyboard    r2088.g81bfdd24-2    r2097.g14b96f8e-1
                            maui-pix 1.2.2.r67.g1736d0f-1 1.2.2.r69.g52ea825-1
                             mauikit1.2.2.r160.g9dcedcd0-11.2.2.r167.g21371ec4-1
                mauikit-filebrowsing 1.2.2.r71.ged8ac30-1 1.2.2.r72.g34d99f6-1
                  mauikit-imagetools 1.2.2.r18.ge45ee3c-1 1.2.2.r19.g977cd44-1
                  mauikit-texteditor 1.2.2.r11.g40a45c4-3 1.2.2.r12.g5808dc0-1
                          messagelib21.04.3.r6075.g1de22472-121.04.3.r6078.g53cf1bcc-1
                               milou5.22.3.r745.g65c72f4-15.22.4.r745.g65c72f4-1
                   networkmanager-qt5.84.0.r1110.g898e976-15.84.0.r1113.ga66c9d1-1
                              oxygen5.22.3.r4423.g9de84e89-15.22.4.r4423.g9de84e89-1
                           pimcommon21.04.3.r1068.gd756b01-121.04.3.r1069.gc4cfdbb-1
                      plasma-desktop5.22.3.r8561.gbf53339ca-15.22.4.r8564.g8783a5b5a-1
                        plasma-disks5.22.3.r224.gd64d104-15.22.4.r224.gd64d104-1
                     plasma-firewall5.22.3.r498.g72f090a-15.22.4.r499.gfe33df5-1
                    plasma-framework5.84.0.r15924.g71c8f7e29-15.84.0.r15926.gfa1f9f562-1
                  plasma-integration5.22.3.r520.g9a2ef93-15.22.4.r521.g61c99d0-1
                    plasma-mobile-nm5.22.3.r3063.gf891c384-15.22.3.r3064.gbc73e7b4-1
                           plasma-nm5.22.3.r3063.gf891c384-15.22.3.r3064.gbc73e7b4-1
                           plasma-pa5.22.3.r953.ga765482-15.22.4.r955.ga0738d9-1
             plasma-phone-components5.22.3.r1440.g66411f24-15.22.3.r1441.g3922cd51-1
                          plasma-sdk5.22.3.r2273.g3d24bfcc-15.22.4.r2273.g3d24bfcc-1
                plasma-systemmonitor5.22.3.r471.g06b0ed9-15.22.4.r471.g06b0ed9-1
                  plasma-thunderbolt5.22.3.r134.gff4b4f9-15.22.4.r134.gff4b4f9-1
                        plasma-vault5.22.3.r337.g299b13f-15.22.4.r338.g076e3f1-1
            plasma-wayland-protocols1.3.0.r1027.gad543cf-11.3.0.r1028.g8d33090-1
              plasma-wayland-session5.22.3.r10471.gbffbbde68-15.22.4.r10479.gb9fb75973-1
                    plasma-workspace5.22.3.r10471.gbffbbde68-15.22.4.r10479.gb9fb75973-1
         plasma-workspace-wallpapers5.22.3.r281.g4fc06b7-15.22.4.r281.g4fc06b7-1
                    polkit-kde-agent5.22.3.r499.g6aa608d-15.22.4.r499.g6aa608d-1
                          powerdevil5.22.3.r2450.ge4fcbbf0-15.22.4.r2452.g30cf83f7-1
                             purpose5.84.0.r866.gdf5ee75-15.84.0.r867.g599e08d-1
                   qqc2-breeze-style5.22.3.r220.gdcfd65f-15.22.4.r220.gdcfd65f-1
                            sddm-kcm5.22.3.r590.gd77c138-15.22.4.r590.gd77c138-1
                           spectacle21.04.3.r1133.g56f50c5-121.04.3.r1134.g0aec65b-1
                 syntax-highlighting5.84.0.r1635.g90f56236-15.84.0.r1635.g90f56236-2
                      systemsettings5.22.3.r2460.gf5691ea6-15.22.4.r2464.g18e962bd-1
                         vakzination        r65.aeffa11-1        r66.bdd4188-1
              xdg-desktop-portal-kde5.22.3.r374.g96ead88-15.22.4.r374.g96ead88-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Old Issues
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Update went well no problems, also ran the new keyboard firmware updater on the pinebook with no problems
All fine on the PBP.
I’ve been noticing these messages on startup on the Pinebook Pro recently. Copied them from the dmesg output:
[    2.355896] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.356895] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.357710] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.358464] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.359211] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.360090] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.360780] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.361468] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.362155] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.362843] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.363533] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.364222] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.364911] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.365600] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.366289] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.366978] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.367742] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.368463] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
[    2.369180] debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
Hard week?
No. The reporting tools have been down for a few days, so we didn’t have the package number stats for this one. :wink:
Fair enough… I’ll let you off then. :upside_down_face:
