Hello ARM community.
A rather small update, nothing fancy.
Introducing Vakzimation. The Plasma Mobile app for managing your vaccination certificates
Some highlights:
- A couple of our kernels got updated
- LibreOffice got a new point release with 7.1.5
- Added Vakzination and Jack2 to the repository
- Lots of Mobile specific packages got updated
- Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss
package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip
and firewalld
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Tue Jul 27 21:44:18 CEST 2021)
- arm-testing community aarch64: 295 new and 290 removed package(s)
- arm-testing core aarch64: 16 new and 16 removed package(s)
- arm-testing extra aarch64: 195 new and 192 removed package(s)
- arm-testing kde-unstable aarch64: 159 new and 157 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-07-21 2021-07-27
ap6256-firmware 2020.02-5 2020.02-7
ap6398s-firmware 2020.04-3 2020.04-4
chatty 0.3.3-1 0.3.3+16+g11c76c6-1
hwinfo 21.75-1 21.76-1
kodi-rpi 19.1-9 19.1-10
kodi-rpi-dev 19.1-9 19.1-10
kodi-rpi-eventclients 19.1-9 19.1-10
kodi-rpi-tools-texturepacker 19.1-9 19.1-10
libmm-pp-glib 1.16.6-1 1.16.8-1
modemmanager-pp 1.16.6-1 1.16.8-1
mygnuhealth 1.0.2-1 1.0.3-1
spacebar 21.07-2 21.07-3
pacutils - 0.11.0-3
vakzination - 0.1-1
:: Different sync package(s) in repository community aarch64
absl-py 0.12.0-1 0.13.0-1
aliyun-cli 3.0.81-1 3.0.82-1
android-tools 31.0.0-4 31.0.2-1
ansible 4.2.0-1 4.3.0-1
antic 0.2.4-1 0.2.4-2
apache-orc 1.6.7-4 1.6.9-1
arb 2.19.0-2 2.20.0-1
argocd 2.0.4-1 2.0.5-1
atomicparsley20210617.200601.1ac7c08-120210715.151551.e7ad03a-1
autopep8 1:1.5.7-1 1:1.5.7-2
babel-cli 7.14.5-2 7.14.8-1
babel-core 7.14.6-1 7.14.8-1
baidupcs-go 3.8.1-1 3.8.2-1
bash-bats 1.3.0-1 1.4.1-1
bcc 0.20.0-3 0.21.0-1
bcc-tools 0.20.0-3 0.21.0-1
birdfont 2.29.4-1 2.29.5-1
blender 17:2.93.1-4 17:2.93.1-5
blueberry 1.4.2-1 1.4.4-1
blueman 2.1.4-1 2.2.1-1
borg 1.1.16-5 1.1.17-1
bpftrace 0.12.0-2 0.13.0-1
buildah 1.21.3-1 1.21.4-1
capnet-assist 2.2.5-3 2.3.0-1
catfish 4.16.0-4 4.16.1-1
cdrtools 3.02a09-4 3.02a09-5
ceph 15.2.13-1 15.2.13-2
ceph-libs 15.2.13-1 15.2.13-2
ceph-mgr 15.2.13-1 15.2.13-2
cherrytree 0.99.38-1 0.99.39-2
chrono-date 3.0.0-2 3.0.1-1
cockpit 248-1 249-1
cockpit-machines 247-1 248-1
cockpit-pcp 248-1 249-1
containerd 1.5.2-1 1.5.4-1
contractor 0.3.4-3 0.3.5-1
cosign 0.3.1-2 0.6.0-1
crystal 1.0.0-3 1.1.1-1
curtail 1.1.0-3 1.2.1-1
drawing 0.8.0-1 0.8.3-1
e-antic 1.0.1-2 1.0.1-3
eclib 20210625-1 20210625-2
efm-langserver 0.0.35-1 0.0.36-1
elementary-icon-theme 5.3.1-1 6.0.0-1
elementary-wallpapers 5.5.0-2 6.0.0-1
erlang22-nox 22.3.4.11-1 22.3.4.20-1
faust 2.30.5-3 2.33.1-1
fcitx5-pinyin-zhwiki 1:0.2.3.20210704-1 1:0.2.3.20210722-1
firefox-ublock-origin 1.36.2-1 1.37.0-1
firewalld 0.9.4-1 1.0.0-1
flint 2.7.1-2 2.8.0-1
fltk 1.3.6-1 1.3.7-1
fltk-docs 1.3.6-1 1.3.7-1
fltk-examples 1.3.6-1 1.3.7-1
fluxctl 1.23.0-1 1.23.1-1
gala 6.0.0-1 6.0.0-2
geckodriver 0.26.0-1 0.29.1-1
ghostwriter 2.0.1-1 2.0.2-1
github-cli 1.12.1-1 1.13.1-1
glances 3.2.0-1 3.2.1-1
gnuradio 3.8.2.0-2 3.9.2.0-2
gnuradio-companion 3.8.2.0-2 3.9.2.0-2
go-ethereum 1.10.5-1 1.10.6-1
go-ipfs 0.9.0-1 0.9.1-1
go-md2man 2.0.0-4 2.0.1-1
gpg-tui 0.7.2-1 0.7.3-1
gping 1.2.1-1 1.2.3-1
gpsprune 20.3-1 20.4-1
gpxsee 9.0-1 9.3-1
gsoap 2.8.115-1 2.8.116-1
gtk-theme-elementary 5.4.2-1 6.0.0-1
hamlib 3.3-10 3.3-11
helm 3.6.2-1 3.6.3-1
helmfile 0.139.9-1 0.140.0-1
hugo 0.85.0-1 0.86.0-1
ibus-table 1.13.3-1 1.14.0-1
jack2 1.9.19-1 -
jack2-dbus 1.9.19-1 -
jenkins 2.302-1 2.303-1
jitterentropy 3.0.2-1 3.1.0-1
jmol 14.31.44-1 14.31.47-1
jsmol 14.31.44-1 14.31.47-1
jupyter-server 1.9.0-2 1.10.1-1
kitty 0.21.2-2 0.22.0-1
kitty-terminfo 0.21.2-2 0.22.0-1
klayout 0.27.2-1 0.27.3-1
kstars 1:3.5.3-1 1:3.5.4-1
kustomize 4.1.3-1 4.2.0-1
kvantum-qt5 0.20.0-1 0.20.1-1
kvantum-theme-materia 20210624-1 20210722-1
languagetool 5.3-1 5.4-1
libcontentaction 0.4.0-1 0.4.1-1
libcurl-compat 7.77.0-1 7.78.0-1
libcurl-gnutls 7.77.0-1 7.78.0-1
libdwarf 20201201-1 20210528-1
libpoly 0.1.9-1 0.1.10-1
libretro-dolphin 32990-2 32990-3
libsemigroups 1.3.7-2 1.3.7-3
libuhd 4.0.0.0-2 4.1.0.1-2
libuhd-firmware 4.0.0.0-1 4.1.0.1-1
libvirt-dbus 1.4.0-1 1.4.1-1
libvolk 2.4.1-1 2:2.5.0-1
lxcfs 4.0.8-1 4.0.9-1
materia-kde 20210624-1 20210722-1
mgard 0.1.0-1 0.1.0-2
minio 2021.07.08-1 2021.07.22-1
minio-client 2021.06.08-1 2021.06.13-1
mongo-c-driver 1.17.5-1 1.18.0-1
networkmanager-strongswan 1.5.2-1 1.5.2-2
newsboat 2.24-1 2.24-2
newsflash 1.4.1-1 1.4.2-1
nextcloud-app-bookmarks 1:4.3.0-1 1:4.4.0-1
nicotine+ 3.0.6-1 3.1.0-1
nnn 4.1.1-1 4.2-1
normaliz 3.9.0-1 3.9.0-2
npm 7.17.0-1 7.20.1-1
nsd 4.3.6-1 4.3.7-1
opam 2.0.8-1 2.0.9-1
opendht 1:2.1.10-2 1:2.1.10-3
openfire 4.6.3-1 4.6.4-1
openfortivpn 1.16.0-2 1.17.0-1
operator-sdk 1.9.0-1 1.10.0-1
osdlyrics 0.4.3-7 0.5.6-1
otf-cascadia-code 2105.24-1 2106.17-1
pacutils 0.11.0-2 -
pantheon-applications-menu 2.7.1-3 2.8.0-1
pantheon-calculator 1.6.1-1 1.6.2-1
pantheon-calendar 5.1.1-3 6.0.0-1
pantheon-code 3.4.1-3 6.0.0-1
pantheon-screenshot 1.7.1-2 6.0.0-1
pdfjs 2.9.359-1 2.10.377-1
pdfmixtool 0.6-2 1.0.2-1
perl-specio 0.43-2 0.47-1
perl-sys-virt 7.1.0-1 7.2.0-1
php-igbinary 3.2.3-1 3.2.4-1
php-imagick 3.5.0-1 3.5.1-1
php7-igbinary 3.2.3-1 3.2.4-1
php7-imagick 3.5.0-1 3.5.1-1
piping-server 0.8.4-1 0.8.5-1
polymake 4.4-4 4.4-5
postgis 3.1.2-1 3.1.3-1
proxychains-ng 4.14-2 4.15-1
pulumi 3.7.0-1 3.7.1-1
pyenv 2.0.3-1 2.0.4-1
pynac 0.7.29-2 0.7.29-3
pyright 1.1.157-1 1.1.158-1
python-aiogram 2.14.2-1 2.14.3-1
python-anyio 3.2.1-1 3.3.0-1
python-aws-sam-translator 1.37.0-1 1.38.0-1
python-bcc 0.20.0-3 0.21.0-1
python-black 21.6b0-3 21.7b0-1
python-breathe 4.30.0-1 4.30.0-2
python-cinderclient 7.4.0-1 8.0.0-1
python-dbus-next 0.2.2-2 0.2.3-1
python-dotenv 0.18.0-1 0.19.0-1
python-entrypoint2 0.2-3 0.2.4-1
python-faker 8.10.1-1 8.10.3-1
python-flake8-black 0.2.1-5 0.2.2-1
python-flexmock 0.10.4-6 0.10.5-1
python-fonttools 4.25.1-1 4.25.2-1
python-hcloud 1.12.0-1 1.13.0-1
python-hunter 3.3.6-1 3.3.8-1
python-hypothesis 6.14.3-1 6.14.4-1
python-jsonschema-objects 0.3.13-1 0.3.14-1
python-kombu 5.0.2-3 5.1.0-1
python-marshmallow 3.12.2-1 3.13.0-1
python-matplotlib 3.4.2-1 3.4.2-2
python-matrix-nio 0.18.4-1 0.18.5-1
python-matrix_client 0.3.2-3 -
python-more-itertools 8.7.0-1 8.8.0-1
python-networkx 2.5.1-2 2.6.1-1
python-pandas 1.2.5-1 1.3.1-1
python-path 16.0.0-1 16.1.0-1
python-phonenumbers 8.12.27-1 8.12.28-1
python-py3c 1.3-1 1.3.1-1
python-pygls 0.11.1-1 0.11.2-1
python-pyhamcrest 1.10.0-1 1.10.1-1
python-pykeepass 4.0.0-1 4.0.1-1
python-pyotherside 1.5.8-3 1.5.9-1
python-pyscard 2.0.0-2 2.0.1-1
python-pytest-runner 5.2-3 5.3.0-1
python-pytest-twisted 1.13.2-3 1.13.3-1
python-pyzmq 22.0.3-1 22.1.0-1
python-ruamel.yaml.clib 0.2.4-1 0.2.6-1
python-sphinx 4.1.1-1 4.1.2-1
python-threadpoolctl 2.1.0-3 2.2.0-1
python-uvloop 0.15.2-1 0.15.3-1
python-xmlschema 1.2.4-1 1.2.5-1
python-zope-proxy 4.3.5-3 4.4.0-1
python2-pytest-runner 5.2-3 5.2-4
qcad 3.26.4.2-1 3.26.4.5-1
radicale 3.0.6-2 3.0.6-3
rclone 1.55.1-1 1.56.0-1
rebuilderd 0.12.0-1 0.13.0-1
redis 6.2.4-1 6.2.5-1
rime-pinyin-zhwiki 1:0.2.3.20210704-1 1:0.2.3.20210722-1
rust-analyzer 20210719-1 20210726-1
rust-bindgen 0.58.1-1 0.59.1-1
sakura 3.8.2-1 3.8.3-1
scite 5.0.3-1 5.1.0-1
seamonkey 2.53.8-1 2.53.8.1-1
shards 0.14.1-1 0.15.0-1
singular 4.2.1-2 4.2.1-3
skaffold 1.28.0-1 1.28.1-1
smtube 20.6.0-1 21.7.0-1
soapyuhd 0.4.1-3 0.4.1-4
sound-theme-elementary 1.0-1 1.1.0-1
spdlog 1.8.5-2 1.9.0-1
squashfs-tools 4.4_git.1-1 -
squid 4.15-1 4.16-1
step-ca 0.15.15-1 0.16.0-1
strongswan 5.9.2-1 5.9.3-1
suscan 0.1.0-4 0.1.0-5
svgcleaner 0.9.5-2 0.9.5-3
switchboard-plug-printers 2.1.9-2 2.1.10-1
symengine 0.7.0-1 0.7.0-2
terraform 1.0.2-1 1.0.3-1
terragrunt 0.30.7-1 0.31.1-1
tint2 17.0-1 17.0.1-1
tldr 1.2.1-1 2.0.0-1
ttc-iosevka 7.2.6-1 7.3.2-1
ttc-iosevka-aile 7.2.6-1 7.3.2-1
ttc-iosevka-curly 7.2.6-1 7.3.2-1
ttc-iosevka-curly-slab 7.2.6-1 7.3.2-1
ttc-iosevka-etoile 7.2.6-1 7.3.2-1
ttc-iosevka-slab 7.2.6-1 7.3.2-1
ttc-iosevka-ss01 7.2.6-1 7.3.2-1
ttc-iosevka-ss02 7.2.6-1 7.3.2-1
ttc-iosevka-ss03 7.2.6-1 7.3.2-1
ttc-iosevka-ss04 7.2.6-1 7.3.2-1
ttc-iosevka-ss05 7.2.6-1 7.3.2-1
ttc-iosevka-ss06 7.2.6-1 7.3.2-1
ttc-iosevka-ss07 7.2.6-1 7.3.2-1
ttc-iosevka-ss08 7.2.6-1 7.3.2-1
ttc-iosevka-ss09 7.2.6-1 7.3.2-1
ttc-iosevka-ss10 7.2.6-1 7.3.2-1
ttc-iosevka-ss11 7.2.6-1 7.3.2-1
ttc-iosevka-ss12 7.2.6-1 7.3.2-1
ttc-iosevka-ss13 7.2.6-1 7.3.2-1
ttc-iosevka-ss14 7.2.6-1 7.3.2-1
ttc-iosevka-ss15 7.2.6-1 7.3.2-1
ttc-iosevka-ss16 7.2.6-1 7.3.2-1
ttc-iosevka-ss17 7.2.6-1 7.3.2-1
ttc-iosevka-ss18 7.2.6-1 7.3.2-1
ttf-cascadia-code 2105.24-1 2106.17-1
ttf-ibm-plex 5.1.3-1 5.2.1-1
ttf-sarasa-gothic 0.32.12-1 0.33.0-1
uglify-js 3.13.10-1 3.14.0-1
unbound 1.13.1-1 1.13.1-2
urh 2.9.2-1 2.9.2-2
urlwatch 2.23-2 2.23-3
v2ray-domain-list-community 20210718155822-1 20210725030530-1
v2ray-geoip 202107150023-1 202107220025-1
vapoursynth R53-1 R54-1
vaultwarden 1.22.1-1 1.22.2-1
vidcutter 6.0.5-2 6.0.5.1-1
vim-clap 0.26-1 0.27-1
warpinator 1.2.0-1 1.2.3-1
watchexec 1.15.3-1 1.17.0-1
waybar 0.9.7-2 0.9.7-5
wingpanel 2.3.2-4 3.0.0-1
wingpanel-indicator-bluetooth 2.1.6-1 2.1.7-1
wingpanel-indicator-datetime 2.2.5-4 2.3.0-1
wingpanel-indicator-keyboard 2.3.0-2 2.4.0-1
wingpanel-indicator-network 2.2.4-1 2.3.0-1
wingpanel-indicator-nightlight 2.0.4-1 2.1.0-1
wingpanel-indicator-notifications 2.1.4-2 6.0.0-1
wingpanel-indicator-power 2.2.0-1 6.0.0-1
wingpanel-indicator-session 2.2.8-2 2.3.0-1
wingpanel-indicator-sound 2.1.8-2 6.0.0-1
woff2-cascadia-code 2105.24-1 2106.17-1
woob 3.0-1 3.0-2
wordpress 5.7.2-1 5.8-1
xh 0.10.0-1 0.11.0-1
xonsh 0.9.27-1 0.10.0-1
yaegi 0.9.19-1 0.9.21-1
yarn 1.22.10-1 1.22.11-1
yubikey-manager 4.0.3-2 4.0.5-1
b3sum - 1.0.0-2
cargo-expand - 1.0.7-1
fulcio - 0.1.0-1
lua-language-server - 2.3.3-1
pantheon-mail - 6.0.0-1
pantheon-sideload - 6.0.0-1
python-jq - 1.1.3-3
tea - 0.7.0-2
:: Different overlay package(s) in repository core aarch64
linux 5.13.4-1 5.13.5-1
linux-headers 5.13.4-1 5.13.5-1
linux-pinephone 5.12.19-1 5.13.5-1
linux-pinephone-headers 5.12.19-1 5.13.5-1
linux-quartz64 5.13.0-0.8 5.14.0-0.2
linux-quartz64-headers 5.13.0-0.8 5.14.0-0.2
linux-rc 5.14.rc2-3 5.14.rc3-1
linux-rc-headers 5.14.rc2-3 5.14.rc3-1
linux-rpi4 5.10.50-2 5.10.52-1
linux-rpi4-headers 5.10.50-2 5.10.52-1
raspberrypi-bootloader 20210714-1 20210727-1
raspberrypi-bootloader-x 20210714-1 20210727-1
uboot-quartz64-bsp 2017.09-0.6 2017.09-0.8
:: Different sync package(s) in repository core aarch64
curl 7.77.0-1 7.78.0-1
man-pages 5.12-1 5.12-2
perl 5.34.0-1 5.34.0-2
:: Different overlay package(s) in repository extra aarch64
mesa-git21.3.0_devel.142713.57dcfb4e553-121.3.0_devel.142920.9cc0834ca60-1
khealthcertificate - 21.07.0-0
:: Different sync package(s) in repository extra aarch64
aom 3.1.1-1 3.1.2-1
aom-docs 3.1.1-1 3.1.2-1
archlinux-appstream-data 20210612-1 20210723-1
booster 0.5-1 0.6-1
chromium 91.0.4472.164-1 92.0.4515.107-3
clazy 1.9-3 1.10-1
composer 2.1.3-1 2.1.5-1
digikam 7.3.0-2 7.3.0-4
evince 40.3-1 40.4-1
f2fs-tools 1.14.0-1 1.14.0-2
feh 3.7-1 3.7.1-1
fmt 8.0.0-2 8.0.1-1
gdk-pixbuf2 2.42.6-1 2.42.6-2
gdk-pixbuf2-docs 2.42.6-1 2.42.6-2
gnome-desktop 1:40.2-1 1:40.3-1
gnome-sudoku 40.1-1 40.2-1
imath 3.1.0-1 3.1.1-1
jack 0.125.0-9 -
jdk-openjdk 16.0.1.u9-1 16.0.2.u7-1
jdk11-openjdk 11.0.11.u9-1 11.0.12.u7-1
jre-openjdk 16.0.1.u9-1 16.0.2.u7-1
jre-openjdk-headless 16.0.1.u9-1 16.0.2.u7-1
jre11-openjdk 11.0.11.u9-1 11.0.12.u7-1
jre11-openjdk-headless 11.0.11.u9-1 11.0.12.u7-1
ldb 1:2.3.0-1 1:2.4.0-1
libadwaita 1.0.0alpha.1-1 1.0.0alpha.2-1
libadwaita-docs 1.0.0alpha.1-1 1.0.0alpha.2-1
libbytesize 2.5-1 2.6-1
libidn 1.37-1 1.38-1
libmm-glib 1.16.6-1 1.16.8-1
libreoffice-fresh 7.1.4-1 7.1.5-1
libreoffice-fresh-af 7.1.4-1 7.1.5-1
libreoffice-fresh-am 7.1.4-1 7.1.5-1
libreoffice-fresh-ar 7.1.4-1 7.1.5-1
libreoffice-fresh-as 7.1.4-1 7.1.5-1
libreoffice-fresh-ast 7.1.4-1 7.1.5-1
libreoffice-fresh-be 7.1.4-1 7.1.5-1
libreoffice-fresh-bg 7.1.4-1 7.1.5-1
libreoffice-fresh-bn 7.1.4-1 7.1.5-1
libreoffice-fresh-bn-in 7.1.4-1 7.1.5-1
libreoffice-fresh-bo 7.1.4-1 7.1.5-1
libreoffice-fresh-br 7.1.4-1 7.1.5-1
libreoffice-fresh-brx 7.1.4-1 7.1.5-1
libreoffice-fresh-bs 7.1.4-1 7.1.5-1
libreoffice-fresh-ca 7.1.4-1 7.1.5-1
libreoffice-fresh-ca-valencia 7.1.4-1 7.1.5-1
libreoffice-fresh-ckb 7.1.4-1 7.1.5-1
libreoffice-fresh-cs 7.1.4-1 7.1.5-1
libreoffice-fresh-cy 7.1.4-1 7.1.5-1
libreoffice-fresh-da 7.1.4-1 7.1.5-1
libreoffice-fresh-de 7.1.4-1 7.1.5-1
libreoffice-fresh-dgo 7.1.4-1 7.1.5-1
libreoffice-fresh-dsb 7.1.4-1 7.1.5-1
libreoffice-fresh-dz 7.1.4-1 7.1.5-1
libreoffice-fresh-el 7.1.4-1 7.1.5-1
libreoffice-fresh-en-gb 7.1.4-1 7.1.5-1
libreoffice-fresh-en-za 7.1.4-1 7.1.5-1
libreoffice-fresh-eo 7.1.4-1 7.1.5-1
libreoffice-fresh-es 7.1.4-1 7.1.5-1
libreoffice-fresh-et 7.1.4-1 7.1.5-1
libreoffice-fresh-eu 7.1.4-1 7.1.5-1
libreoffice-fresh-fa 7.1.4-1 7.1.5-1
libreoffice-fresh-fi 7.1.4-1 7.1.5-1
libreoffice-fresh-fr 7.1.4-1 7.1.5-1
libreoffice-fresh-fur 7.1.4-1 7.1.5-1
libreoffice-fresh-fy 7.1.4-1 7.1.5-1
libreoffice-fresh-ga 7.1.4-1 7.1.5-1
libreoffice-fresh-gd 7.1.4-1 7.1.5-1
libreoffice-fresh-gl 7.1.4-1 7.1.5-1
libreoffice-fresh-gu 7.1.4-1 7.1.5-1
libreoffice-fresh-gug 7.1.4-1 7.1.5-1
libreoffice-fresh-he 7.1.4-1 7.1.5-1
libreoffice-fresh-hi 7.1.4-1 7.1.5-1
libreoffice-fresh-hr 7.1.4-1 7.1.5-1
libreoffice-fresh-hsb 7.1.4-1 7.1.5-1
libreoffice-fresh-hu 7.1.4-1 7.1.5-1
libreoffice-fresh-id 7.1.4-1 7.1.5-1
libreoffice-fresh-is 7.1.4-1 7.1.5-1
libreoffice-fresh-it 7.1.4-1 7.1.5-1
libreoffice-fresh-ja 7.1.4-1 7.1.5-1
libreoffice-fresh-ka 7.1.4-1 7.1.5-1
libreoffice-fresh-kab 7.1.4-1 7.1.5-1
libreoffice-fresh-kk 7.1.4-1 7.1.5-1
libreoffice-fresh-km 7.1.4-1 7.1.5-1
libreoffice-fresh-kmr-latn 7.1.4-1 7.1.5-1
libreoffice-fresh-kn 7.1.4-1 7.1.5-1
libreoffice-fresh-ko 7.1.4-1 7.1.5-1
libreoffice-fresh-kok 7.1.4-1 7.1.5-1
libreoffice-fresh-ks 7.1.4-1 7.1.5-1
libreoffice-fresh-lb 7.1.4-1 7.1.5-1
libreoffice-fresh-lo 7.1.4-1 7.1.5-1
libreoffice-fresh-lt 7.1.4-1 7.1.5-1
libreoffice-fresh-lv 7.1.4-1 7.1.5-1
libreoffice-fresh-mai 7.1.4-1 7.1.5-1
libreoffice-fresh-mk 7.1.4-1 7.1.5-1
libreoffice-fresh-ml 7.1.4-1 7.1.5-1
libreoffice-fresh-mn 7.1.4-1 7.1.5-1
libreoffice-fresh-mni 7.1.4-1 7.1.5-1
libreoffice-fresh-mr 7.1.4-1 7.1.5-1
libreoffice-fresh-my 7.1.4-1 7.1.5-1
libreoffice-fresh-nb 7.1.4-1 7.1.5-1
libreoffice-fresh-ne 7.1.4-1 7.1.5-1
libreoffice-fresh-nl 7.1.4-1 7.1.5-1
libreoffice-fresh-nn 7.1.4-1 7.1.5-1
libreoffice-fresh-nr 7.1.4-1 7.1.5-1
libreoffice-fresh-nso 7.1.4-1 7.1.5-1
libreoffice-fresh-oc 7.1.4-1 7.1.5-1
libreoffice-fresh-om 7.1.4-1 7.1.5-1
libreoffice-fresh-or 7.1.4-1 7.1.5-1
libreoffice-fresh-pa-in 7.1.4-1 7.1.5-1
libreoffice-fresh-pl 7.1.4-1 7.1.5-1
libreoffice-fresh-pt 7.1.4-1 7.1.5-1
libreoffice-fresh-pt-br 7.1.4-1 7.1.5-1
libreoffice-fresh-ro 7.1.4-1 7.1.5-1
libreoffice-fresh-ru 7.1.4-1 7.1.5-1
libreoffice-fresh-rw 7.1.4-1 7.1.5-1
libreoffice-fresh-sa-in 7.1.4-1 7.1.5-1
libreoffice-fresh-sat 7.1.4-1 7.1.5-1
libreoffice-fresh-sd 7.1.4-1 7.1.5-1
libreoffice-fresh-sdk 7.1.4-1 7.1.5-1
libreoffice-fresh-si 7.1.4-1 7.1.5-1
libreoffice-fresh-sid 7.1.4-1 7.1.5-1
libreoffice-fresh-sk 7.1.4-1 7.1.5-1
libreoffice-fresh-sl 7.1.4-1 7.1.5-1
libreoffice-fresh-sq 7.1.4-1 7.1.5-1
libreoffice-fresh-sr 7.1.4-1 7.1.5-1
libreoffice-fresh-sr-latn 7.1.4-1 7.1.5-1
libreoffice-fresh-ss 7.1.4-1 7.1.5-1
libreoffice-fresh-st 7.1.4-1 7.1.5-1
libreoffice-fresh-sv 7.1.4-1 7.1.5-1
libreoffice-fresh-sw-tz 7.1.4-1 7.1.5-1
libreoffice-fresh-szl 7.1.4-1 7.1.5-1
libreoffice-fresh-ta 7.1.4-1 7.1.5-1
libreoffice-fresh-te 7.1.4-1 7.1.5-1
libreoffice-fresh-tg 7.1.4-1 7.1.5-1
libreoffice-fresh-th 7.1.4-1 7.1.5-1
libreoffice-fresh-tn 7.1.4-1 7.1.5-1
libreoffice-fresh-tr 7.1.4-1 7.1.5-1
libreoffice-fresh-ts 7.1.4-1 7.1.5-1
libreoffice-fresh-tt 7.1.4-1 7.1.5-1
libreoffice-fresh-ug 7.1.4-1 7.1.5-1
libreoffice-fresh-uk 7.1.4-1 7.1.5-1
libreoffice-fresh-uz 7.1.4-1 7.1.5-1
libreoffice-fresh-ve 7.1.4-1 7.1.5-1
libreoffice-fresh-vec 7.1.4-1 7.1.5-1
libreoffice-fresh-vi 7.1.4-1 7.1.5-1
libreoffice-fresh-xh 7.1.4-1 7.1.5-1
libreoffice-fresh-zh-cn 7.1.4-1 7.1.5-1
libreoffice-fresh-zh-tw 7.1.4-1 7.1.5-1
libreoffice-fresh-zu 7.1.4-1 7.1.5-1
libsidplayfp 2.2.0-1 2.2.1-1
memcached 1.6.9-1 1.6.10-1
meson 0.58.1-1 0.59.0-2
mkvtoolnix-cli 58.0.0-6 59.0.0-1
mkvtoolnix-gui 58.0.0-6 59.0.0-1
modemmanager 1.16.6-1 1.16.8-1
mtools 1:4.0.33-1 1:4.0.34-1
openjdk-src 16.0.1.u9-1 16.0.2.u7-1
openjdk11-src 11.0.11.u9-1 11.0.12.u7-1
perl-dbd-sqlite 1.66-2 1.68-1
poppler 21.07.0-1 21.07.0-3
poppler-glib 21.07.0-1 21.07.0-3
poppler-qt5 21.07.0-1 21.07.0-3
poppler-qt6 21.07.0-1 21.07.0-3
postfix 3.6.1-1 3.6.2-1
postfix-cdb 3.6.1-1 3.6.2-1
postfix-ldap 3.6.1-1 3.6.2-1
postfix-lmdb 3.6.1-1 3.6.2-1
postfix-mysql 3.6.1-1 3.6.2-1
postfix-pcre 3.6.1-1 3.6.2-1
postfix-pgsql 3.6.1-1 3.6.2-1
postfix-sqlite 3.6.1-1 3.6.2-1
python-dbusmock 0.23.0-1 0.23.1-1
python-fastimport 0.9.12-1 0.9.13-1
python-requests 2.25.1-1 2.26.0-1
python-tomli 1.0.4-1 1.1.0-1
python2-requests 2.25.1-1 2.26.0-1
qbs 1.19.1-1 1.19.2-1
strace 5.12-1 5.13-1
tdb 1.4.4-1 1.4.5-1
tevent 1:0.10.2-3 1:0.11.0-1
vulkan-headers 1:1.2.184-1 1:1.2.185-1
vulkan-icd-loader 1.2.184-1 1.2.185-1
webkit2gtk 2.32.2-1 2.32.3-1
wpewebkit 2.32.2-1 2.32.3-1
xfce4-sensors-plugin 1.3.95-1 1.4.1-1
zabbix-agent 5.4.2-1 5.4.3-1
zabbix-agent2 5.4.2-1 5.4.3-1
zabbix-frontend-php 5.4.2-1 5.4.3-1
zabbix-proxy 5.4.2-1 5.4.3-1
zabbix-server 5.4.2-1 5.4.3-1
jack2 - 1.9.19-1
jack2-dbus - 1.9.19-1
squashfs-tools - 4.5-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.04.3.r12527.g78ccf477a-121.04.3.r12530.g4c8cccb19-1
akonadi-search21.04.3.r1107.g26c21d0-121.04.3.r1108.g51f8114-1
akregator21.04.3.r6188.g12c82b62-121.04.3.r6190.ge54d48e1-1
alligator 21.06.r11.g7c37563-1 21.07.r0.g7c37563-1
angelfish 21.06.r26.g6c07c3d-1 21.07.r1.g76419ba-1
ark21.04.3.r4604.g6548b395-121.04.3.r4605.gdcb2f928-1
baloo-widgets21.04.3.r680.g5a3b20a-121.04.3.r681.gd686783-1
bluedevil1:5.22.3.r2269.gfaade374-11:5.22.3.r2271.gd506eedd-1
breeze5.22.3.r2222.g5b0ea0f6-15.22.3.r2224.gb6374c27-2
breeze-icons5.84.0.r1759.ge396413f-15.84.0.r1760.gbf37a9d3-1
buho 1.2.2.r31.g0db48ec-1 1.2.2.r36.g54ea38b-1
calendarsupport21.04.3.r567.ga773765-121.04.3.r575.g6d55d7f-1
calindori 21.06.r13.g08c5859-1 21.07.r0.g08c5859-1
discover5.22.3.r8234.ga75a100c-15.22.3.r8241.gf55d73e2-1
dolphin21.04.3.r6656.g32c1bd718-121.04.3.r6661.g393c659c9-1
dolphin-plugins21.04.3.r593.g87e219d-121.04.3.r595.g9ac2c24-1
elisa21.04.3.r2736.g7fb3d070-121.04.3.r2742.g77152c3a-1
eventviews21.04.3.r670.g381f3ec-121.04.3.r674.g4e41f50-1
extra-cmake-modules5.84.0.r3351.g027797a-15.84.0.r3352.g72e9fb9-1
gwenview21.04.3.r6646.g5681c504-121.04.3.r6649.gb10fe5b8-1
incidenceeditor21.04.3.r743.gf49fe33-121.04.3.r747.gfcc5ae2-1
index-fm 1.2.2.r99.gace6e6b-11.2.2.r106.g12e4c02-1
itinerary21.04.3.r1378.gfff8e96-121.04.3.r1398.ga158782-1
k3b1:21.04.3.r6654.gc63fd9665-11:21.04.3.r6655.g3456f6562-1
kaccounts-providers21.04.3.r382.g2f7fb54-121.04.3.r383.gaf778e5-1
kactivitymanagerd5.22.3.r1355.g9cabb88-15.22.3.r1358.gc237fe5-1
kalarm21.04.3.r6410.g503c8fd5-121.04.3.r6418.gf9aa4353-1
kalk 21.06.r10.g2412914-1 21.07.r0.g2412914-1
kamera21.04.3.r654.g9eadd76-121.04.3.r655.g975c8f5-1
kamoso21.04.3.r1427.gfda571b-121.04.3.r1428.gda4ba0d-1
kanagram21.04.3.r1280.g871912c-121.04.3.r1283.g2bd976e-1
kapidox5.84.0.r542.g0326b90-15.84.0.r548.gcf9ced6-1
kasts 21.06.r78.gfc99ec5-1 21.07.r2.g85798eb-1
kate21.04.3.r18293.gd317129cd-121.04.3.r18298.g1c5dc7c8e-1
kblocks21.04.3.r664.g59ca52a-121.04.3.r665.gc497aa0-1
kclock 21.06.r28.g71d7c4b-1 21.07.r18.g69eddad-1
kcmutils5.84.0.r528.ge7ef632-15.84.0.r529.g431b5db-1
kcolorchooser21.04.3.r224.g29e79c1-121.04.3.r225.gf937de8-1
kconfigwidgets5.84.0.r599.g83a1edf-15.84.0.r602.gbcde63c-1
kcoreaddons5.84.0.r1247.gc1eea322-15.84.0.r1249.gf5f64064-1
kde-cli-tools5.22.3.r1845.gddccf63-15.22.3.r1851.gaa866b6-1
kde-dev-utils21.04.3.r556.g6d918c3-121.04.3.r558.geff6b70-1
kde-gtk-config5.22.3.r895.g93da65a-15.22.3.r896.g971adfc-1
kdeconnect21.04.3.r3289.gac53f3f3-121.04.3.r3295.gec88335b-1
kdelibs4support5.84.0.r1027.gbd5c6518-15.84.0.r1028.g16e15649-1
kdeplasma-addons5.22.3.r8557.g718cbaede-15.22.3.r8563.gd5e671c7f-1
kdoctools5.84.0.r616.g1a544d9-15.84.0.r617.g7f217be-1
keysmith 21.06.r8.g818ed69-1 21.07.r1.g503fdde-1
kget21.04.3.r3117.g003064ad-121.04.3.r3118.g0012b007-1
kholidays1:5.84.0.r945.ga00d0fe-11:5.84.0.r947.ga0bb438-1
khotkeys5.22.3.r2078.ge95171d-15.22.3.r2086.g1b06be5-1
kidentitymanagement21.04.3.r3795.g5a86412f-121.04.3.r3796.g8c900018-1
kimageformats5.84.0.r347.g7f56d83-15.84.0.r348.gfbeef55-1
kinfocenter5.22.3.r1861.g07fdf4a-15.22.3.r1863.g53b7155-1
kinit5.84.0.r405.ge6668c4-15.84.0.r406.g2a5d047-1
kio5.84.0.r4857.gf070c2a8-15.84.0.r4869.g63df4f25-1
kio-extras21.04.3.r7092.g2f2f6253-121.04.3.r7094.g5dff395e-1
kio-gdrive21.04.3.r562.g7b06d00-121.04.3.r564.g20d635f-1
kirigami25.84.0.r2840.gbdfac7d0-15.84.0.r2842.g253eedef-1
kitinerary21.04.3.r1832.g964e622-121.04.3.r1843.gedce84c-1
kldap21.04.3.r869.g4ae869e-121.04.3.r870.g7b455c9-1
klettres21.04.3.r912.g6f0aff5-121.04.3.r913.gda6529b-1
klines21.04.3.r755.g37f5f5f-121.04.3.r761.g2b02c75-1
kmail-account-wizard21.04.3.r791.gd0b9f1a-121.04.3.r793.gf4aab22-1
kmines21.04.3.r1715.g58f37a8-121.04.3.r1716.ga7fef85-1
kmix21.04.3.r2372.g04491098-121.04.3.r2374.g9f1eeb70-1
kmousetool21.04.3.r387.g3e256a8-121.04.3.r388.gc4b2d98-1
kmplot21.04.3.r1459.g6cdacb6-121.04.3.r1461.g2a626fb-1
knetwalk21.04.3.r651.g71b9db7-121.04.3.r653.g0fb8139-1
knotes21.04.3.r3473.g1891433d-121.04.3.r3474.gef6ef817-1
koko 21.06.r23.g1b02c9d-1 21.07.r5.gd4dacb8-1
kolourpaint21.04.3.r2349.g5849a5f2-121.04.3.r2350.g48141741-1
kongress 21.06.r7.g8150560-1 21.07.r0.g8150560-1
konqueror21.04.3.r14917.gd825e73d9-121.04.3.r14922.g7c14c663d-1
konsole21.04.3.r7892.gfb69c183-121.04.3.r7896.ga6b2bd53-1
kontact21.04.3.r5346.ged3f1b15-121.04.3.r5347.gb9c29459-1
kontactinterface21.04.3.r621.g7bec405-121.04.3.r622.gb5c1933-1
kontrast21.04.3.r169.gb64bb54-121.04.3.r170.gc62ac8f-1
konversation21.04.3.r8987.geb3708e7-121.04.3.r8988.ge7560658-1
korganizer21.04.3.r11410.ge4b327b64-121.04.3.r11416.gf032f3c8b-1
kparts5.84.0.r514.g8b81bf4-15.84.0.r515.g5d0c684-1
kpublictransport21.04.2.r1692.g7d976ae5-121.04.3.r1703.gf36365e-1
krdc21.04.3.r1529.gdb18bb3-121.04.3.r1531.gd7c1899-1
krecorder 21.06.r7.gb90079d-1 21.07.r0.gb90079d-1
kruler21.04.3.r691.gbdd7e07-121.04.3.r692.gf64ae61-1
krunner5.84.0.r646.ge067c4f-15.84.0.r648.g9fe605e-1
kscreen5.22.3.r1337.g413adfe-15.22.3.r1338.g845c8ab-1
kscreenlocker5.22.3.r858.gf78ccfc-15.22.3.r861.g7964776-1
ksudoku21.04.3.r1046.g245abab-121.04.3.r1047.g7a05a76-1
ksystemstats5.22.3.r176.g5f93a3f-15.22.3.r177.g65c605e-1
ktrip 21.06.r26.g4e972de-1 21.07.r0.g4e972de-1
kunitconversion5.84.0.r369.geed860d-15.84.0.r370.g92eea5a-1
kwayland5.84.0.r1098.g05ded8f-15.84.0.r1101.g311f60b-1
kwayland-server5.22.3.r1345.g9fe2aa5-15.22.3.r1354.gff642af-1
kweather 21.06.r40.g5076241-1 21.07.r1.g5076241-1
kwidgetsaddons5.84.0.r837.ga4b21dac-15.84.0.r838.g21f35a46-1
kwin5.22.3.r19651.gb344afd8c-15.22.3.r19688.g5317ca9da-1
kwinft5.22.0.r19035.gc2a9a76b5-15.22.0.r19048.gb52c6dd24-1
kwrite21.04.3.r18293.gd317129cd-121.04.3.r18298.g1c5dc7c8e-1
kwrited5.22.3.r479.g8d34f29-15.22.3.r480.g682279c-1
libakonadi21.04.3.r12527.g78ccf477a-121.04.3.r12530.g4c8cccb19-1
libkleo21.04.3.r914.g9f79f52-121.04.3.r915.g30afaf4-1
libkomparediff221.04.3.r337.g9827753-121.04.3.r339.ge9ed555-1
libksane21.04.3.r549.gcd38e98-121.04.3.r550.g8f338bd-1
libkscreen5.22.3.r1585.g19fb52b-15.22.3.r1586.g618f24d-1
libksieve21.04.3.r1551.gfc1ed601-121.04.3.r1552.gc4525c0b-1
libksysguard5.22.3.r2252.g375ee5b-15.22.3.r2259.g2dac54c-1
libquotient r2023.ge4bfe89-1 r2025.gcddf3c6-1
mailcommon21.04.3.r1057.gc8d5a1d-121.04.3.r1058.g1a92909-1
marble21.04.3.r13317.gf08f15fd3-121.04.3.r13322.gb973663cb-1
marble-common21.04.3.r13317.gf08f15fd3-121.04.3.r13322.gb973663cb-1
marble-qt21.04.3.r13317.gf08f15fd3-121.04.3.r13322.gb973663cb-1
maui-clip 1.1.1.r8.gb3d9db9-4 1.1.1.r9.ga430a4e-1
maui-nota 1.2.2.r53.g9e2d63e-1 1.2.2.r58.g05d675a-1
maui-pix 1.2.2.r62.ge828aa0-1 1.2.2.r67.g1736d0f-1
mauikit1.2.2.r152.g0012b03f-11.2.2.r160.g9dcedcd0-1
mauikit-accounts r9.398b635-1 r10.d9f46d9-1
mauikit-filebrowsing 1.2.2.r67.g60d945d-1 1.2.2.r71.ged8ac30-1
mauikit-imagetools 1.2.2.r17.g470723e-1 1.2.2.r18.ge45ee3c-1
minuet21.04.3.r577.ga4303ed-121.04.3.r579.gdc33ba7-1
okular21.04.3.r9397.g1d9081766-121.04.3.r9403.g21bc8bd02-1
oxygen5.22.3.r4422.g5c8c3271-15.22.3.r4423.g9de84e89-1
parley21.04.3.r4414.gdc7ae8d4-121.04.3.r4416.g1f5f767e-1
pimcommon21.04.3.r1064.g6dfebc4-121.04.3.r1068.gd756b01-1
plasma-browser-integration5.22.3.r1267.gb9e54d8c-15.22.3.r1269.g4c28b9a1-1
plasma-desktop5.22.3.r8553.g54e5468e5-15.22.3.r8560.g73e9001bb-1
plasma-dialer 21.06.r11.gfcc384e-1 21.07.r2.gde002cf-1
plasma-disks5.22.3.r221.gaaf1ef6-15.22.3.r224.gd64d104-1
plasma-firewall5.22.3.r497.g8e86ae7-15.22.3.r498.g72f090a-1
plasma-framework5.84.0.r15921.g75c31c08d-15.84.0.r15923.g32bfd1ed0-1
plasma-integration5.22.3.r519.gf7c25d9-15.22.3.r520.g9a2ef93-1
plasma-pa5.22.3.r951.ge87dcf3-15.22.3.r953.ga765482-1
plasma-phone-components5.22.3.r1427.g27a3d33b-15.22.3.r1440.g66411f24-1
plasma-phonebook 21.06.r11.gc712939-1 21.07.r5.g7f2dac8-1
plasma-sdk5.22.3.r2272.g32b423a6-15.22.3.r2273.g3d24bfcc-1
plasma-settings 21.06.r12.gc824f2a-1 21.07.r4.g7f74746-1
plasma-systemmonitor5.22.3.r468.ge20cb86-15.22.3.r471.g06b0ed9-1
plasma-vault5.22.3.r336.g2b49118-15.22.3.r337.g299b13f-1
plasma-wayland-session5.22.3.r10449.g746ac9503-15.22.3.r10469.g32c9f4a5f-1
plasma-workspace5.22.3.r10449.g746ac9503-15.22.3.r10469.g32c9f4a5f-1
plasma-workspace-wallpapers5.22.3.r280.ge462299-15.22.3.r281.g4fc06b7-1
polkit-kde-agent5.22.3.r498.g12157d1-15.22.3.r499.g6aa608d-1
powerdevil5.22.3.r2442.g93e441d9-15.22.3.r2449.ga2f04548-1
purpose5.84.0.r864.g3469d7c-15.84.0.r866.gdf5ee75-1
qmlkonsole 21.06.r7.g6b630f5-1 21.07.r0.g6b630f5-1
rocs21.04.2.r3022.gc2e0af1d-121.04.3.r3022.gc2e0af1d-1
sddm-kcm5.22.3.r588.gc51c2a1-15.22.3.r590.gd77c138-1
solid5.84.0.r690.g9829c51-15.84.0.r693.g80310ba-1
spacebar 21.06.r27.g5ce9e9e-1 21.07.r1.gbbf0609-1
spectacle21.04.3.r1132.g874b5b0-121.04.3.r1133.g56f50c5-1
svgpart21.04.3.r174.g4fd95bd-121.04.3.r176.ga5f3adc-1
syntax-highlighting5.84.0.r1630.ga2bb6f45-15.84.0.r1635.g90f56236-1
systemsettings5.22.3.r2453.g07fcc030-15.22.3.r2457.gd5b4e3ca-1
tokodon 21.06.r19.geb4d447-1 21.07.r3.geb4d447-1
vvave 1.2.2.r55.g4b8fb82-1 1.2.2.r58.g5ca7e7d-1
yakuake21.04.3.r724.gc1a2abe-121.04.3.r727.g76c4132-1
zeroconf-ioslave21.04.3.r355.g370f3e4-121.04.3.r356.g0bb67c4-1
khealthcertificate - r67.735d6be-1
vakzination - r65.aeffa11-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
