[ARM Testing Update] 2021-07-21 - PlaMo Gear 21.07, Firefox, SystemD, Pipewire and kernels
Hello ARM community.
A rather small update, nothing fancy.
Some highlights:
  • A couple of our kernels got updated
  • Plasma Mobile Gear applications got updated to 21.07
  • A new bugfix release to Firefox brings it to 90.0.1
  • SystemD also got a new point release with 249.1
  • And our favorite audio system Pipewire got a new update to 0.3.32
  • Flameshot also got a new release 0.10.0
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip and firewalld requires manual intervention:
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
( Wed Jul 21 16:20:35 CEST 2021)
  • arm-testing community aarch64: 160 new and 154 removed package(s)
  • arm-testing core aarch64: 10 new and 10 removed package(s)
  • arm-testing extra aarch64: 135 new and 137 removed package(s)
  • arm-testing kde-unstable aarch64: 81 new and 81 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2021-07-19         2021-07-21
                           alligator              21.06-1              21.07-1
                           angelfish              21.06-1              21.07-1
                 breath2-icon-themes             1.0.14-1             1.0.16-1
                   breath2-wallpaper             1.0.14-1             1.0.16-1
                           calindori              21.06-1              21.07-1
                     element-desktop             1.7.30-1             1.7.33-1
                         element-web             1.7.30-1             1.7.33-1
                                kalk              21.06-1              21.07-1
                               kasts              21.06-1              21.07-1
                              kclock              21.06-1              21.07-1
                            keysmith              21.06-1              21.07-1
                                koko              21.06-1              21.07-1
                            kongress              21.06-1              21.07-1
                           krecorder              21.06-1              21.07-1
                               ktrip              21.06-1              21.07-1
                            kweather              21.06-1              21.07-1
                       plasma-dialer              21.06-2              21.07-1
                    plasma-phonebook              21.06-1              21.07-1
                     plasma-settings              21.06-1              21.07-1
              plasma5-themes-breath2             1.0.14-1             1.0.16-1
       plasma5-themes-breath2-shells             1.0.14-1             1.0.16-1
                          qmlkonsole              21.06-1              21.07-1
                  sddm-breath2-theme             1.0.14-1             1.0.16-1
                            spacebar              21.06-1              21.07-1
                             tokodon              21.06-1              21.07-1
                          youtube-dl                    -       2021.06.06-1.1
:: Different sync package(s) in repository community aarch64
                          aliyun-cli             3.0.78-1             3.0.81-1
                        ansible-core             2.11.2-1             2.11.3-1
                           aqbanking              6.3.0-1              6.3.0-2
                           argyllcms              2.1.2-1              2.2.0-1
                             aws-cli           1.19.107-1             1.20.2-1
                             blender          17:2.93.1-3          17:2.93.1-4
                                ceph            15.2.12-3            15.2.13-1
                           ceph-libs            15.2.12-3            15.2.13-1
                            ceph-mgr            15.2.12-3            15.2.13-1
                             chezmoi              2.1.1-1              2.1.2-1
                               cri-o             1.21.1-1             1.21.2-1
                               csfml                2.5-4              2.5.1-1
                           ctemplate                2.4-1                2.4-2
                                 dcd           1:0.13.4-1           1:0.13.6-1
                                dino              0.2.0-3              0.2.1-1
                                 dtc              1.6.0-3              1.6.1-1
                      efm-langserver             0.0.34-1             0.0.35-1
                      firefox-stylus             1.5.17-2             1.5.19-1
                           flameshot              0.9.0-1             0.10.0-1
                                gala3.3.2.r134.c74298b4-1              6.0.0-1
                              getdns              1.5.2-3              1.7.0-1
                               gitea             1.13.7-1             1.14.5-1
  gnome-shell-extension-appindicator                 40-1                 40-2
                         go-ethereum             1.10.4-1             1.10.5-1
                             gpg-tui              0.7.1-1              0.7.2-1
                             granite              6.0.0-1              6.1.0-1
                            impacket             0.9.22-1             0.9.23-1
                              kasync              0.3.0-2              0.3.0-3
                               kdav2              0.3.0-2              0.4.0-1
                              kimap2              0.3.0-2              0.4.0-1
                                knot              3.0.5-1              3.0.8-1
                                kube              0.8.0-2              0.9.0-2
                         kvantum-qt5             0.19.0-1             0.20.0-1
               kvantum-theme-materia           20210410-1           20210624-1
                            laz-perf            1:1.3.0-2            2:1.3.0-1
                              libaec              1.0.4-1              1.0.5-1
                           libfabric             1.11.2-1             1.13.0-1
                             libjcat              0.1.6-1              0.1.8-1
                             libmgba              0.9.1-1              0.9.2-1
                           libpano13             2.9.19-5             2.9.20-1
                             libxmlb              0.3.0-1              0.3.2-1
            lightdm-pantheon-greeter              5.0.4-3              6.0.0-1
                            lollypop             1.4.20-1             1.4.22-1
                         materia-kde           20210410-1           20210624-1
                        matterbridge             1.22.3-1             1.22.3-2
                             mgba-qt              0.9.1-1              0.9.2-1
                            mgba-sdl              0.9.1-1              0.9.2-1
                               mkosi                  9-1                  9-2
                     mysql-workbench             8.0.25-1             8.0.26-1
                           nextcloud             21.0.3-1             22.0.0-2
             nextcloud-app-bookmarks            1:4.2.2-2            1:4.3.0-1
                  nextcloud-app-deck            1:1.4.2-2            1:1.5.0-1
                nextcloud-app-spreed           1:11.3.0-1           1:12.0.1-1
                            openrct2              0.3.3-4              0.3.4-1
                              packer              1.7.3-1              1.7.4-1
                      pantheon-files              4.5.0-2              6.0.0-1
             pantheon-geoclue2-agent              1.0.4-1              1.0.5-1
                      pantheon-music              5.0.5-5              5.1.1-1
                     pantheon-photos              2.7.0-5              2.7.1-1
               pantheon-polkit-agent              1.0.3-2              1.0.4-1
           pantheon-shortcut-overlay              1.1.2-2              1.2.0-1
                   pantheon-terminal              5.5.2-2              6.0.0-1
                     pantheon-videos              2.7.2-3              2.7.3-1
                                pdal              2.2.0-3              2.3.0-2
                       perl-sys-virt              7.0.0-1              7.1.0-1
                       phpvirtualbox              5.2_1-5              5.2_1-6
                     profile-cleaner               2.41-1               2.42-1
                               pynac             0.7.29-1             0.7.29-2
                       python-bleach              3.3.0-1              3.3.1-1
                        python-boto3           1.17.107-1             1.18.2-1
                     python-botocore           1.20.107-1             1.21.2-1
                      python-dulwich            0.20.23-1            0.20.24-1
                          python-hid              1.0.4-4              1.0.4-5
                       python-hunter              3.3.3-1              3.3.6-1
                   python-hypothesis             6.14.2-1             6.14.3-1
                      python-iso8601             0.1.14-1             0.1.16-1
                python-octaviaclient              2.3.1-1              2.4.0-1
                     python-pathspec              0.8.1-4              0.9.0-1
                      python-pikepdf             2.15.0-1             2.15.1-1
                    python-pkgconfig              1.5.4-1              1.5.5-1
                       python-pyglet             1.5.16-1             1.5.18-1
                   python-s3transfer              0.4.2-1              0.5.0-1
                     python-tenacity              8.0.0-1              8.0.1-1
                      python-trimesh             3.9.21-1             3.9.23-1
             python-virtualenv-clone              0.5.4-4              0.5.5-1
                    python-xmlschema              1.2.3-3              1.2.4-1
                python-zope-hookable              5.0.1-3              5.1.0-1
                                qgis             3.20.0-2             3.20.0-3
                                 qiv              2.3.2-2              2.3.2-3
                               qtile             0.17.0-1             0.18.0-2
                           rng-tools               6.13-1               6.13-2
                       ruby-zeitwerk              2.4.1-2              2.4.2-2
                                runc              1.0.0-2              1.0.1-2
                       rust-analyzer           20210712-1           20210719-1
                                sink              0.8.0-3              0.9.0-1
                              sqlmap              1.5.4-1              1.5.7-1
                            starship             0.55.0-1             0.56.0-1
                              stubby              0.3.0-1              0.4.0-2
                              swaybg                1.0-4                1.1-1
                         switchboard              2.4.0-2              6.0.0-1
               switchboard-plug-a11y              2.2.0-2              2.3.0-1
              switchboard-plug-about              2.6.3-2              6.0.0-1
       switchboard-plug-applications              2.1.7-2              6.0.0-1
          switchboard-plug-bluetooth              2.3.5-2              2.3.6-1
           switchboard-plug-datetime              2.1.9-2              2.2.0-1
            switchboard-plug-desktop              2.8.4-2              6.0.0-1
            switchboard-plug-display              2.2.2-2              2.3.0-1
           switchboard-plug-keyboard              2.4.1-2              2.5.0-1
             switchboard-plug-locale              2.5.3-2              2.5.4-1
     switchboard-plug-mouse-touchpad              2.4.2-2              6.0.0-1
            switchboard-plug-network              2.3.3-2              2.4.0-1
      switchboard-plug-notifications              2.1.7-2              2.2.0-1
    switchboard-plug-online-accounts              2.0.1-4              6.0.0-1
  switchboard-plug-parental-controls              3.0.1-2              6.0.0-1
              switchboard-plug-power              2.4.2-2              2.5.0-1
   switchboard-plug-security-privacy              2.2.4-2              2.2.5-1
            switchboard-plug-sharing              2.1.4-2              2.1.5-1
              switchboard-plug-sound              2.2.6-2              2.2.7-1
      switchboard-plug-user-accounts              2.3.2-2              2.4.0-1
                    telegram-desktop             2.8.11-1             2.8.11-2
                   ttf-sarasa-gothic            0.32.11-1            0.32.12-1
                             utf8cpp              3.1.2-1              3.2.1-1
         v2ray-domain-list-community     20210717172626-1     20210718155822-1
                       vc-intrinsics        r73+5032643-1       r100+2d0795c-1
                                 vtk             8.2.0-19             8.2.0-20
                              weboob                2.0-2                    -
                             whipper             0.10.0-1             0.10.0-2
                           xournalpp              1.1.0-1              1.1.0-2
                                zola             0.13.0-1             0.14.0-1
                                dust                    -              0.6.1-2
                       python2-cairo                    -             1.18.2-4
                     python2-gobject                    -             3.36.1-3
                       python2-numpy                    -             1.16.6-1
                            tealdeer                    -              1.4.1-6
                                woob                    -                3.0-1
:: Different overlay package(s) in repository core aarch64
                               linux             5.13.3-1             5.13.4-1
                       linux-headers             5.13.3-1             5.13.4-1
                     linux-pinephone            5.12.17-1            5.12.19-1
             linux-pinephone-headers            5.12.17-1            5.12.19-1
:: Different sync package(s) in repository core aarch64
                           amd-ucode   20210511.7685cf4-1   20210716.b7c134f-1
                      linux-firmware   20210511.7685cf4-1   20210716.b7c134f-1
                             systemd                249-3              249.1-1
                        systemd-libs                249-3              249.1-1
                  systemd-resolvconf                249-3              249.1-1
                  systemd-sysvcompat                249-3              249.1-1
:: Different overlay package(s) in repository extra aarch64
                             firefox               90.0-1             90.0.1-1
                    firefox-i18n-ach               90.0-1             90.0.1-1
                     firefox-i18n-af               90.0-1             90.0.1-1
                     firefox-i18n-an               90.0-1             90.0.1-1
                     firefox-i18n-ar               90.0-1             90.0.1-1
                    firefox-i18n-ast               90.0-1             90.0.1-1
                     firefox-i18n-az               90.0-1             90.0.1-1
                     firefox-i18n-be               90.0-1             90.0.1-1
                     firefox-i18n-bg               90.0-1             90.0.1-1
                     firefox-i18n-bn               90.0-1             90.0.1-1
                     firefox-i18n-br               90.0-1             90.0.1-1
                     firefox-i18n-bs               90.0-1             90.0.1-1
                     firefox-i18n-ca               90.0-1             90.0.1-1
                    firefox-i18n-cak               90.0-1             90.0.1-1
                     firefox-i18n-cs               90.0-1             90.0.1-1
                     firefox-i18n-cy               90.0-1             90.0.1-1
                     firefox-i18n-da               90.0-1             90.0.1-1
                     firefox-i18n-de               90.0-1             90.0.1-1
                    firefox-i18n-dsb               90.0-1             90.0.1-1
                     firefox-i18n-el               90.0-1             90.0.1-1
                  firefox-i18n-en-ca               90.0-1             90.0.1-1
                  firefox-i18n-en-gb               90.0-1             90.0.1-1
                  firefox-i18n-en-us               90.0-1             90.0.1-1
                     firefox-i18n-eo               90.0-1             90.0.1-1
                  firefox-i18n-es-ar               90.0-1             90.0.1-1
                  firefox-i18n-es-cl               90.0-1             90.0.1-1
                  firefox-i18n-es-es               90.0-1             90.0.1-1
                  firefox-i18n-es-mx               90.0-1             90.0.1-1
                     firefox-i18n-et               90.0-1             90.0.1-1
                     firefox-i18n-eu               90.0-1             90.0.1-1
                     firefox-i18n-fa               90.0-1             90.0.1-1
                     firefox-i18n-ff               90.0-1             90.0.1-1
                     firefox-i18n-fi               90.0-1             90.0.1-1
                     firefox-i18n-fr               90.0-1             90.0.1-1
                  firefox-i18n-fy-nl               90.0-1             90.0.1-1
                  firefox-i18n-ga-ie               90.0-1             90.0.1-1
                     firefox-i18n-gd               90.0-1             90.0.1-1
                     firefox-i18n-gl               90.0-1             90.0.1-1
                     firefox-i18n-gn               90.0-1             90.0.1-1
                  firefox-i18n-gu-in               90.0-1             90.0.1-1
                     firefox-i18n-he               90.0-1             90.0.1-1
                  firefox-i18n-hi-in               90.0-1             90.0.1-1
                     firefox-i18n-hr               90.0-1             90.0.1-1
                    firefox-i18n-hsb               90.0-1             90.0.1-1
                     firefox-i18n-hu               90.0-1             90.0.1-1
                  firefox-i18n-hy-am               90.0-1             90.0.1-1
                     firefox-i18n-ia               90.0-1             90.0.1-1
                     firefox-i18n-id               90.0-1             90.0.1-1
                     firefox-i18n-is               90.0-1             90.0.1-1
                     firefox-i18n-it               90.0-1             90.0.1-1
                     firefox-i18n-ja               90.0-1             90.0.1-1
                     firefox-i18n-ka               90.0-1             90.0.1-1
                    firefox-i18n-kab               90.0-1             90.0.1-1
                     firefox-i18n-kk               90.0-1             90.0.1-1
                     firefox-i18n-km               90.0-1             90.0.1-1
                     firefox-i18n-kn               90.0-1             90.0.1-1
                     firefox-i18n-ko               90.0-1             90.0.1-1
                    firefox-i18n-lij               90.0-1             90.0.1-1
                     firefox-i18n-lt               90.0-1             90.0.1-1
                     firefox-i18n-lv               90.0-1             90.0.1-1
                     firefox-i18n-mk               90.0-1             90.0.1-1
                     firefox-i18n-mr               90.0-1             90.0.1-1
                     firefox-i18n-ms               90.0-1             90.0.1-1
                     firefox-i18n-my               90.0-1             90.0.1-1
                  firefox-i18n-nb-no               90.0-1             90.0.1-1
                  firefox-i18n-ne-np               90.0-1             90.0.1-1
                     firefox-i18n-nl               90.0-1             90.0.1-1
                  firefox-i18n-nn-no               90.0-1             90.0.1-1
                     firefox-i18n-oc               90.0-1             90.0.1-1
                  firefox-i18n-pa-in               90.0-1             90.0.1-1
                     firefox-i18n-pl               90.0-1             90.0.1-1
                  firefox-i18n-pt-br               90.0-1             90.0.1-1
                  firefox-i18n-pt-pt               90.0-1             90.0.1-1
                     firefox-i18n-rm               90.0-1             90.0.1-1
                     firefox-i18n-ro               90.0-1             90.0.1-1
                     firefox-i18n-ru               90.0-1             90.0.1-1
                     firefox-i18n-si               90.0-1             90.0.1-1
                     firefox-i18n-sk               90.0-1             90.0.1-1
                     firefox-i18n-sl               90.0-1             90.0.1-1
                    firefox-i18n-son               90.0-1             90.0.1-1
                     firefox-i18n-sq               90.0-1             90.0.1-1
                     firefox-i18n-sr               90.0-1             90.0.1-1
                  firefox-i18n-sv-se               90.0-1             90.0.1-1
                     firefox-i18n-ta               90.0-1             90.0.1-1
                     firefox-i18n-te               90.0-1             90.0.1-1
                     firefox-i18n-th               90.0-1             90.0.1-1
                     firefox-i18n-tr               90.0-1             90.0.1-1
                     firefox-i18n-uk               90.0-1             90.0.1-1
                     firefox-i18n-ur               90.0-1             90.0.1-1
                     firefox-i18n-uz               90.0-1             90.0.1-1
                     firefox-i18n-vi               90.0-1             90.0.1-1
                     firefox-i18n-xh               90.0-1             90.0.1-1
                  firefox-i18n-zh-cn               90.0-1             90.0.1-1
                  firefox-i18n-zh-tw               90.0-1             90.0.1-1
                        kweathercore                0.3-1                0.4-1
:: Different sync package(s) in repository extra aarch64
                  alsa-card-profiles           1:0.3.31-1           1:0.3.32-1
                         amf-headers             1.4.18-2             1.4.21-1
                               bftpd                5.6-2                5.7-1
                            calligra             3.2.1-16             3.2.1-17
                             cfitsio             1:3.49-1            1:4.0.0-1
                             ethtool             1:5.12-1             1:5.13-1
                             gparted              1.3.0-4              1.3.1-1
                            graphviz             2.47.3-1             2.48.0-1
                 gst-plugin-pipewire           1:0.3.31-1           1:0.3.32-1
                            libmp4v2              5.0.0-1              5.0.1-1
                             libmwaw             0.3.19-1             0.3.20-1
                               libnm             1.32.2-1             1.32.4-1
                               libuv             1.41.1-1             1.42.0-1
                             mariadb            10.5.11-1             10.6.3-1
                     mariadb-clients            10.5.11-1             10.6.3-1
                        mariadb-libs            10.5.11-1             10.6.3-1
                               mytop            10.5.11-1             10.6.3-1
                      networkmanager             1.32.2-1             1.32.4-1
                      nm-cloud-setup             1.32.2-1             1.32.4-1
                       pipewire-alsa           1:0.3.31-1           1:0.3.32-1
                       pipewire-docs           1:0.3.31-1           1:0.3.32-1
                       pipewire-jack           1:0.3.31-1           1:0.3.32-1
              pipewire-media-session           1:0.3.31-1           1:0.3.32-1
                      pipewire-pulse           1:0.3.31-1           1:0.3.32-1
                   pipewire-zeroconf           1:0.3.31-1           1:0.3.32-1
                               putty               0.75-1               0.76-1
                       python-pep517             0.10.0-2             0.11.0-1
               python-qscintilla-qt5             2.12.1-1             2.13.0-1
               python-qscintilla-qt6             2.12.1-1             2.13.0-1
                   python-setuptools           1:57.2.0-1           1:57.4.0-1
                   python-virtualenv             20.5.0-1             20.6.0-1
                       python2-cairo             1.18.2-4                    -
                     python2-gobject             3.36.1-3                    -
                       python2-numpy             1.16.6-1                    -
                      python2-pep517             0.10.0-2             0.11.0-1
                  python2-virtualenv             20.5.0-1             20.6.0-1
                               scons              3.1.2-4              4.1.0-2
                                vpnc   1:0.5.3.r468.r81-2  1:0.5.3.r496.r153-2
                                zimg              3.0.1-2              3.0.2-1
                        python-tomli                    -              1.0.4-1
:: Different overlay package(s) in repository kde-unstable aarch64
                           akregator21.04.3.r6187.gf56fb990-121.04.3.r6188.g12c82b62-1
                           alligator  21.06.r6.ga92562e-1 21.06.r11.g7c37563-1
                           angelfish 21.06.r18.g1b2d7ed-1 21.06.r26.g6c07c3d-1
                                 ark21.04.3.r4602.g78dc03ab-121.04.3.r4604.g6548b395-1
                              breeze5.22.3.r2221.g162767a6-15.22.3.r2222.g5b0ea0f6-1
                        breeze-icons5.84.0.r1758.gc6fad5c9-15.84.0.r1759.ge396413f-1
                           calindori  21.06.r9.g5adf21b-1 21.06.r13.g08c5859-1
                            discover5.22.3.r8233.g65664178-15.22.3.r8234.ga75a100c-1
                             dolphin21.04.3.r6651.g2c7a1f4b4-121.04.3.r6656.g32c1bd718-1
                     dolphin-plugins21.04.3.r592.g4f9910b-121.04.3.r593.g87e219d-1
                 extra-cmake-modules5.84.0.r3349.g95d1808-15.84.0.r3351.g027797a-1
                            index-fm 1.2.2.r98.g6efbb91-1 1.2.2.r99.gace6e6b-1
                           itinerary21.04.3.r1377.g81e25e1-121.04.3.r1378.gfff8e96-1
                                 k3b1:21.04.3.r6652.gfbea53425-11:21.04.3.r6654.gc63fd9665-1
                   kactivities-stats5.84.0.r362.g80c6b1d-15.84.0.r365.g8662452-1
                                kalk  21.06.r6.g01bce47-1 21.06.r10.g2412914-1
                               kasts 21.06.r72.gdf07359-1 21.06.r78.gfc99ec5-1
                                kate21.04.3.r18291.g809548bf0-121.04.3.r18293.gd317129cd-1
                             kbackup21.04.3.r386.g61a7e6f-121.04.3.r387.g54d03c1-1
                       kcalendarcore5.84.0.r1225.gdb39bb52c-15.84.0.r1226.g92da321bd-1
                              kclock 21.06.r17.g8536da1-1 21.06.r28.g71d7c4b-1
                            kcmutils5.84.0.r525.ga362ddf-15.84.0.r528.ge7ef632-1
                             kcodecs5.84.0.r375.gc58a80e-15.84.0.r376.ga091bc4-1
                         kdbusaddons5.84.0.r371.ge821326-15.84.0.r372.gd810bd0-1
                       kdepim-addons21.04.2.r4237.g329f63a7-121.04.2.r4239.g4180eccf-1
                      kdepim-runtime21.04.3.r15146.gf0c467fff-121.04.3.r15148.g47b49d185-1
                    kdeplasma-addons5.22.3.r8556.gf600a856f-15.22.3.r8557.g718cbaede-1
                            keysmith  21.06.r2.ga25a720-1  21.06.r8.g818ed69-1
                            khotkeys5.22.3.r2074.gcaad4c1-15.22.3.r2078.ge95171d-1
                                 kio5.84.0.r4850.gf0664a0c-15.84.0.r4857.gf070c2a8-1
                           kirigami25.84.0.r2837.g040e6136-15.84.0.r2840.gbdfac7d0-1
                          kitinerary21.04.3.r1831.gb1464cd-121.04.3.r1832.g964e622-1
                         kjobwidgets5.84.0.r369.gf058ddb-15.84.0.r370.g45f58fd-1
                              klines21.04.3.r753.ga981203-121.04.3.r755.g37f5f5f-1
                                kmix21.04.3.r2371.gdd7e4de8-121.04.3.r2372.g04491098-1
                           knewstuff5.84.0.r1184.g5bb2707b-15.84.0.r1186.g6c373eb2-1
                                koko 21.06.r17.gdcd1ea2-1 21.06.r23.g1b02c9d-1
                            kongress  21.06.r3.g7bd2104-1  21.06.r7.g8150560-1
                             konsole21.04.3.r7891.gdc92c593-121.04.3.r7892.gfb69c183-1
                        konversation21.04.3.r8986.gf06db9ae-121.04.3.r8987.geb3708e7-1
                            kpackage5.84.0.r678.g0e03365-15.84.0.r683.g0aaf95f-1
                         kpeoplesink       r69.g889321f-3       r70.g59cc131-1
                           krecorder  21.06.r3.g3976840-1  21.06.r7.gb90079d-1
                            kreversi21.04.3.r1218.g2abe20f-121.04.3.r1219.gf14fd6f-1
                                krfb21.04.3.r1407.g75bff9d-121.04.3.r1409.g0eaf1bc-1
                       kscreenlocker5.22.3.r857.gad1fa64-15.22.3.r858.gf78ccfc-1
                            ktorrent21.04.3.r2755.gd3a3239c-121.04.3.r2756.g00ec970e-1
                               ktrip 21.06.r23.g57bd918-1 21.06.r26.g4e972de-1
                     kwayland-server5.22.3.r1344.g3789090-15.22.3.r1345.g9fe2aa5-1
                            kweather 21.06.r35.gce3bb20-1 21.06.r40.g5076241-1
                      kwidgetsaddons5.84.0.r835.g6a72f111-15.84.0.r837.ga4b21dac-1
                                kwin5.22.3.r19646.g9e5cb836a-15.22.3.r19651.gb344afd8c-1
                              kwrite21.04.3.r18291.g809548bf0-121.04.3.r18293.gd317129cd-1
                         libkdegames21.04.3.r2185.g9295393e-121.04.3.r2186.gb4c5b960-1
                         libktorrent21.04.3.r520.g614e231-121.04.3.r521.ged0e045-1
                         libquotient     r2012.gd85c63f-1     r2023.ge4bfe89-1
                        markdownpart21.04.3.r76.gcf104d8-121.04.3.r79.gba9ecf0-1
                           maui-nota 1.2.2.r52.gf3a839c-1 1.2.2.r53.g9e2d63e-1
                            maui-pix 1.2.2.r59.g5d0378f-1 1.2.2.r62.ge828aa0-1
                             mauikit1.2.2.r147.g48060a91-11.2.2.r152.g0012b03f-1
                mauikit-filebrowsing 1.2.2.r64.ga123902-3 1.2.2.r67.g60d945d-1
                  mauikit-imagetools 1.2.2.r16.g9f9e1a4-3 1.2.2.r17.g470723e-1
                    partitionmanager21.04.3.r1528.gc0565bd-121.04.3.r1529.g5264203-1
                      plasma-desktop5.22.3.r8545.g1afe75a8b-15.22.3.r8553.g54e5468e5-1
                       plasma-dialer  21.06.r7.g06e0f9a-1 21.06.r11.gfcc384e-1
                    plasma-framework5.84.0.r15915.g2ec68a614-15.84.0.r15921.g75c31c08d-1
             plasma-phone-components5.22.3.r1425.g4942e0e3-15.22.3.r1427.g27a3d33b-1
                    plasma-phonebook  21.06.r5.g75158f9-1 21.06.r11.gc712939-1
                     plasma-settings  21.06.r9.ge10e1e1-1 21.06.r12.gc824f2a-1
                plasma-systemmonitor5.22.3.r466.gc3fb6e0-15.22.3.r468.ge20cb86-1
              plasma-wayland-session5.22.3.r10440.g27704daf4-15.22.3.r10449.g746ac9503-1
                    plasma-workspace5.22.3.r10440.g27704daf4-15.22.3.r10449.g746ac9503-1
                             purpose5.84.0.r863.g313092d-15.84.0.r864.g3469d7c-1
                          qmlkonsole  21.06.r4.g13dd175-1  21.06.r7.g6b630f5-1
                            spacebar 21.06.r23.g6bc8d92-1 21.06.r27.g5ce9e9e-1
                                step21.04.3.r1153.g28928cf-121.04.3.r1154.g6bf2042-1
                             svgpart21.04.3.r173.g5e2839c-121.04.3.r174.g4fd95bd-1
                             tokodon 21.06.r13.g1768eb9-1 21.06.r19.geb4d447-1
                               vvave 1.2.2.r53.g4cdfbe5-1 1.2.2.r55.g4b8fb82-1
                             yakuake21.04.3.r723.gf920d67-121.04.3.r724.gc1a2abe-1
                    zeroconf-ioslave21.04.3.r353.g4db270b-121.04.3.r355.g370f3e4-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Old Issues
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Hi,
Odroid c2 kde unstable and Odroid c4 kde testing are up to date.
How to find the improvements for the devices (c2, c4, n2…) in the new kernel, packages installed ?
After a succeed update I build a new image…
You would have to check the diff/changelog on kernel.org to see what changes have been committed.
Bluetooth needed a full power cycle to work again on PineBook Pro.
