Hello ARM community.
A rather small update, nothing fancy.
Some highlights:
- A couple of our kernels got updated
- Thunderbird updated to 78.12.0
- An update to GnuPG should fix the default keyserver issues
- Handbrake had a new release with 1.4.0
- And added the Spot Client Spotify cient to the repository
- Lots of Mobile specific packages got updated
- Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss
package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip
and firewalld
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
( Mon Jul 19 21:09:36 CEST 2021)
- arm-testing community aarch64: 272 new and 263 removed package(s)
- arm-testing core aarch64: 20 new and 21 removed package(s)
- arm-testing extra aarch64: 158 new and 154 removed package(s)
- arm-testing kde-unstable aarch64: 237 new and 237 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-07-13 2021-07-19
chatty 0.3.2+23+gd7c04b0-1 0.3.3-1
electron 13.1.6-1 13.1.7-1
electron12 12.0.13-1 12.0.15-1
handbrake 1.3.3-4 1.4.0-1
handbrake-cli 1.3.3-4 1.4.0-1
kodi-rpi 19.1-6 19.1-9
kodi-rpi-dev 19.1-6 19.1-9
kodi-rpi-eventclients 19.1-6 19.1-9
kodi-rpi-tools-texturepacker 19.1-6 19.1-9
libpackagekit-glib 1.2.3-0.1 1.2.3-0.2
mygnuhealth 1.0.1-1 1.0.2-1
nodejs-lts-fermium 14.17.1-0.1 -
okular-mobile 20.12.1-1.2 -
packagekit 1.2.3-0.1 1.2.3-0.2
phosh 0.12.0+12+g675a75d-1 0.12.1-1
python-tinydb 4.5.0-1 4.5.1-1
snapd 2.51.1-1 2.51.3-1
vivaldi 4.0.2312.38-1 4.0.2312.41-1
spot-client - 0.1.15-1
timeshift -20.11.1.r28.gefed117-2
timeshift-autosnap - 0.9-1
:: Different sync package(s) in repository community aarch64
acpi_call-dkms 1.2.1-4 1.2.1-5
acpica 20210331-1 20210604-1
adapta-gtk-theme 3.95.0.11-1 3.95.0.11-2
agordejo 0.2.1-1 0.3.0-1
alembic 1.8.2-1 1.8.2-2
ansible-lint 5.0.12-1 5.1.2-1
arcus 4.9.1-2 4.10.0-1
bat 0.18.1-1 0.18.2-1
bctoolbox 5.0.0-1 5.0.0-2
blender 17:2.93.1-2 17:2.93.1-3
buildah 1.21.2-1 1.21.3-1
cargo-spellcheck 0.8.8-1 0.8.9-1
cargo-watch 7.8.0-1 7.8.1-1
carla 2.3.0-1 2.3.1-1
ceph 15.2.12-2 15.2.12-3
ceph-libs 15.2.12-2 15.2.12-3
ceph-mgr 15.2.12-2 15.2.12-3
cherrytree 0.99.37-1 0.99.38-1
cimg 2.9.7-1 2.9.8-1
cinnamon 5.0.4-1 5.0.5-1
clamtk 6.11-1 6.13-1
cmake-fedora 2.9.3-4 2.9.3-5
cockpit 247-1 248-1
cockpit-machines 246-1 247-1
cockpit-pcp 247-1 248-1
cpp-hocon 0.3.0-6 0.3.0-7
cura-binary-data 4.9.1-1 4.10.0-1
cura-resources-materials 4.9.1-1 4.10.0-1
curaengine 4.9.1-2 4.10.0-1
curlie 1.6.0-2 1.6.2-1
cython 0.29.23-1.1 0.29.24-1
cython2 0.29.23-1.1 0.29.24-1
diffoscope 177-1 178-1
dns-lexicon 3.6.1-1 3.6.1-2
eslint 7.30.0-1 7.31.0-1
facter 3.14.16-4 3.14.16-5
feeluown 3.7.9-1 3.7.10-1
filezilla 3.54.1-2 3.55.0-1
fio 3.26-1 3.27-1
firefox-extension-passff 1.10.6-1 1.11.2-1
firefox-tree-style-tab 3.8.7-1 3.8.8-1
flake8 1:3.9.2-1 1:3.9.2-2
freeciv 2.6.4-1 2.6.5-1
freeimage 3.18.0-10 3.18.0-11
giac 1.7.0.17-1 1.7.0.21-1
gifsicle 1.92-2 1.93-1
gimp-plugin-gmic 2.9.7-5 2.9.8-1
girara 0.3.5-1 0.3.6-1
gitui 0.16.1-1 0.16.2-1
global 6.6.6-1 6.6.7-1
gnome-pie 0.7.2-1 0.7.3-1
gnome-shell-extension-appindicator 37-1 40-1
go 2:1.16.5-1 2:1.16.6-1
go-ipfs 0.8.0-1 0.9.0-1
go-tools 4:0.1.4-1 4:0.1.5-1
gpg-tui 0.7.0-1 0.7.1-1
grafx2 2.7-3 2.8-1
hashcat 1:6.2.2-1 1:6.2.3-1
haxe 4.2.3-1 4.2.3-2
hexchat 2.14.3-8 2.14.3-9
hiawatha 10.11-3 10.12-1
home-assistant 2021.4.6-1 2021.5.3-2
hugin 2020.0.0-5 2020.0.0-6
hyperfine 1.11.0-1 1.11.0-2
ibus-m17n 1.4.5-1 1.4.6-1
inn 2.6.4-2 2.6.4-3
interception-tools 0.6.6-1 0.6.7-1
jack2 1.9.18-2 1.9.19-1
jack2-dbus 1.9.18-2 1.9.19-1
java-atk-wrapper-common 0.38.0-1 0.38.0-2
java-atk-wrapper-openjdk 0.38.0-1 0.38.0-2
java-atk-wrapper-openjdk11 0.38.0-1 0.38.0-2
java-atk-wrapper-openjdk8 0.38.0-1 0.38.0-2
jconvolver 1.1.0-1 1.1.0-2
jenkins 2.301-1 2.302-1
jupyter-nbconvert 6.0.7-3 6.1.0-1
kitty 0.21.2-1 0.21.2-2
kitty-terminfo 0.21.2-1 0.21.2-2
kmon 1.5.3-1 1.5.4-1
kodi-platform 20190726.809c5e9-23 20190726.809c5e9-27
kotlin 1.5.20-1 1.5.21-1
krita-plugin-gmic 2.9.7-5 2.9.8-1
lcalc 2.0.2-1 2.0.3-1
leatherman 1.12.4-2 1.12.6-1
libcontentaction 0.3.18-1 0.4.0-1
libfilezilla 0.28.0-2 0.30.0-1
libmodsecurity 1:3.0.4-5 1:3.0.5-1
libperconaserverclient 8.0.23_14-5 8.0.25_15-2
libretro-dolphin 32989-1 32990-2
libsavitar 4.9.1-1 4.10.0-1
libsemigroups 1.3.7-1 1.3.7-2
libtg_owt 0.git5.f03ef05-1 0.git6.91d836d-1
libtracefs 1.2.2-1 1.2.3-1
libvips 8.11.2-1 8.11.2-2
libwhereami 0.5.0-6 0.5.0-7
ltris 1.2.2-1 1.2.3-1
lv2lint 0.12.0-1 0.14.0-1
lxc 1:4.0.9-1 1:4.0.10-1
man-pages-cs 4.10.0-1 4.10.0-2
man-pages-da 4.10.0-1 4.10.0-2
man-pages-de 4.10.0-1 4.10.0-2
man-pages-es 4.10.0-1 4.10.0-2
man-pages-fr 4.10.0-1 4.10.0-2
man-pages-it 4.10.0-1 4.10.0-2
man-pages-mk 4.10.0-1 4.10.0-2
man-pages-nl 4.10.0-1 4.10.0-2
man-pages-pl 4.10.0-1 4.10.0-2
man-pages-pt_br 4.10.0-1 4.10.0-2
man-pages-ro 4.10.0-1 4.10.0-2
mbedtls 2.26.0-1 2.27.0-1
mdcat 0.23.0-1 0.23.2-1
mitmproxy 6.0.2-1 7.0.0-1
modem-manager-gui 0.0.20-1 0.0.20-2
mongo-c-driver 1.17.4-2 1.17.5-1
moony.lv2 0.38.0-1 0.40.0-1
neko 2.3.0-4 2.3.0-5
neochat 1.2.0-2 1.2.0-3
netdata 1.31.0-2 1.31.0-3
nextcloud-app-calendar 1:2.3.0-3 1:2.3.1-1
nextcloud-app-mail 1.9.5-2 1.10.1-1
nextcloud-app-tasks 0.13.6-2 0.14.0-1
nodejs 16.4.2-1 16.5.0-1
nodejs-lts-dubnium 10.24.0-2 -
nodejs-lts-erbium 12.22.0-2 12.22.3-1
nodejs-lts-fermium 14.16.0-2 14.17.3-1
npm-check-updates 11.8.2-1 11.8.3-1
openapi-generator 5.1.1-1 5.2.0-1
openblas 0.3.15-1 0.3.17-1
opencolorio 2.0.1-2 2.0.1-3
opendht 1:2.1.10-1 1:2.1.10-2
openimageio 2.2.15.1-4 2.2.15.1-5
openscenegraph 3.6.5-7 3.6.5-8
os-prober 1.78-1 1.79-1
patchmatrix 0.24.0-1 0.26.0-1
patroneo 2.1.0-1 2.2.0-1
percona-server 8.0.23_14-5 8.0.25_15-2
percona-server-clients 8.0.23_14-5 8.0.25_15-2
perl-alien-cmake3 0.06-1 0.08-1
perl-sys-virt 6.8.0-2 7.0.0-1
perl-term-readline-gnu 1.41-1 1.42-1
php-mongodb 1.9.1-3 1.10.0-1
php7-mongodb 1.9.1-3 1.10.0-1
piping-server 0.8.2-2 0.8.4-1
pound 3.0-2 3.0-3
povray 2:3.7.0.9-2 2:3.7.0.9-6
powerdns 4.4.1-5 4.5.0-1
profanity 1:0.10.0-1 1:0.11.0-1
profanity-gtk 1:0.10.0-1 1:0.11.0-1
pulumi 3.6.1-2 3.7.0-1
pybind11 2.6.2-2 2.7.0-1
pyright 1.1.156-1 1.1.157-1
python-aiobotocore 1.3.2-1 1.3.3-1
python-aioconsole 0.3.0-1 0.3.1-1
python-braintree 4.10.0-1 4.11.0-1
python-btrees 4.8.0-1 4.9.2-1
python-cmarkgfm 0.5.3-1 0.6.0-1
python-django-allauth 0.44.0-1 0.45.0-1
python-eventlet 0.31.0-2 0.31.1-1
python-faker 8.10.0-1 8.10.1-1
python-fonttools 4.24.4-1 4.25.1-1
python-fuse 1.0.3-1 1.0.4-1
python-gdspy 1.6.6-1 1.6.7-1
python-importlib-metadata 4.6.0-1 4.6.1-1
python-itemadapter 0.2.0-1 0.3.0-1
python-jaeger-client 4.5.0-1 4.6.0-1
python-jeepney 0.6.0-4 0.7.0-1
python-jsonschema-objects 0.3.12-2 0.3.13-1
python-ldap3 2.9-1 2.9.1-1
python-libcharon 4.9.1-1 4.10.0-1
python-matrix-nio 0.18.3-1 0.18.4-1
python-moto 2.0.11-1 2.1.0-1
python-octaviaclient 2.3.0-1 2.3.1-1
python-openmdao 3.9.2-1 3.10.0-1
python-openstacksdk 0.57.0-1 0.58.0-1
python-oslo-config 8.7.0-1 8.7.1-1
python-pikepdf 2.14.2-1 2.15.0-1
python-pillow 8.3.0-1 8.3.1-1
python-pymongo 3.11.4-1 3.12.0-1
python-pythondialog 3.5.1-2 3.5.2-1
python-pythran 0.9.11-2 0.9.12.post1-1
python-sphinx 4.1.0-1 4.1.1-1
python-tenacity 7.0.0-1 8.0.0-1
python-testfixtures 6.17.1-1 6.18.0-1
python-testtools 2.4.0-3 2.5.0-1
python-texttable 1.6.3-3 1.6.4-1
python-tox 3.23.1-1 3.24.0-1
python-trimesh 3.9.20-1 3.9.21-1
python-uncertainties 3.1.5-1 3.1.6-1
python-whitenoise 5.2.0-2 5.3.0-1
python-xlsxwriter 1.4.3-1 1.4.4-1
python-z3 4.8.11-1 4.8.12-1
python2-tox 3.23.1-1 3.24.0-1
qliveplayer 3.22.3-1 3.22.4-1
rekor 0.1.1-1 0.2.0-1
retroarch 1.9.6-2 1.9.6-3
ruby-atk 3.4.3-2 3.4.5-1
ruby-bundler 2.2.23-1 2.2.24-1
ruby-cairo-gobject 3.4.3-2 3.4.5-1
ruby-gdk3 3.4.3-2 3.4.5-1
ruby-gdk_pixbuf2 3.4.3-2 3.4.5-1
ruby-gio2 3.4.3-2 3.4.5-1
ruby-glib2 3.4.3-2 3.4.5-1
ruby-gobject-introspection 3.4.3-2 3.4.5-1
ruby-gtk3 3.4.3-2 3.4.5-1
ruby-pango 3.4.3-2 3.4.5-1
ruby-red-colors 0.1.1-1 0.3.0-1
ruby2.7 2.7.3-1 2.7.4-1
sbt 1:1.5.4-1 1:1.5.5-1
serverless 2.51.1-1 2.52.0-1
shadowsocks-libev 3.3.5-2 3.3.5-3
shutter 0.97-2 0.97-3
sigutils 0.1.0-3 0.1.0-4
skaffold 1.27.0-1 1.28.0-1
skanlite 2.2.0-1 -
skk-jisyo 20210704-1 20210718-1
spdlog 1.8.5-1 1.8.5-2
sssd 2.5.1-1 2.5.2-1
sweethome3d 6.5-3 6.5.2-1
tailscale 1.10.1-1 1.10.2-1
tekton-cli 0.19.1-1 0.20.0-1
telegram-desktop 2.8.4-3 2.8.11-1
ttf-joypixels 6.5.0-1 6.6.0-1
ttf-sarasa-gothic 0.32.10-1 0.32.11-1
uranium 4.9.1-1 4.10.0-2
v2ray-domain-list-community 20210711091359-1 20210717172626-1
v2ray-geoip 202107080024-1 202107150023-1
variety 0.8.5-1 0.8.5-2
vigra 1.11.1-34 1.11.1-35
vigra-doc 1.11.1-34 1.11.1-35
vim-nerdtree 6.10.9-1 6.10.10-1
vultr-cli 2.6.0-2 2.7.0-1
wakatime 13.1.0-1 13.1.0-2
wallutils 5.9.0-2 5.9.0-3
waybar 0.9.7-1 0.9.7-2
wireshark-cli 3.4.6-1 3.4.7-1
wireshark-qt 3.4.6-1 3.4.7-1
x42-plugins 20210409-1 20210714-1
xmldiff 2.4-2 2.4-3
xournalpp 1.0.20-2 1.1.0-1
xtrabackup 8.0.23_16-1 8.0.25_17-1
zart 2.9.7-5 -
zathura-cb 0.1.8-2 0.1.9-1
zathura-ps 0.2.6-2 0.2.7-1
bottom - 0.6.3-2
cargo-flamegraph - 0.4.0-1
peco - 0.5.10-3
python-dbus-next - 0.2.2-2
python-pywayland - 0.4.5-1
python-pywlroots - 0.14.3-1
python-xkbcommon - 0.4-1
python2-setuptools-scm - 5.0.2-3
rhit - 1.5.3-1
rst2pdf - 0.98-2
silicon - 0.4.3-1
:: Different overlay package(s) in repository core aarch64
gnupg 2.2.28-2.3 -
linux 5.13.1-2 5.13.3-1
linux-headers 5.13.1-2 5.13.3-1
linux-pinephone 5.12.16-1 5.12.17-1
linux-pinephone-headers 5.12.16-1 5.12.17-1
linux-rc 5.14.rc1-3 5.14.rc2-3
linux-rc-headers 5.14.rc1-3 5.14.rc2-3
linux-rpi4 5.10.48-1 5.10.50-2
linux-rpi4-headers 5.10.48-1 5.10.50-2
linux-rpi4-mainline 5.12.15-1 5.12.17-2
linux-rpi4-mainline-headers 5.12.15-1 5.12.17-2
manjaro-system 20210612-3 20210716-1
raspberrypi-bootloader 20210709-1 20210714-1
raspberrypi-bootloader-x 20210709-1 20210714-1
:: Different sync package(s) in repository core aarch64
btrfs-progs 5.12.1-1 5.13-1
ca-certificates-mozilla 3.67-1 3.68-1
gnupg 2.2.28-2 2.2.29-1
less 1:581.2-1 1:590-1
mkinitcpio 30-1 30-2
nss 3.67-1 3.68-1
rpcbind 1.2.5-3 1.2.6-1
:: Different overlay package(s) in repository extra aarch64
calamares 3.2.34-8 3.2.40-1
calamares-arm-oem 20210621-1 20210715-1
calamares-qml 3.2.40-0.1 3.2.40-0.2
ckbcomp 1.194-1 1.204-1
mesa-git21.2.0_devel.142376.c70f45c7596-121.3.0_devel.142713.57dcfb4e553-1
okular 21.04.2-2 21.04.3-1
:: Different sync package(s) in repository extra aarch64
adobe-source-sans-fonts 3.042-1 3.046-1
ant 1.10.10-1 1.10.11-1
ant-doc 1.10.10-1 1.10.11-1
calligra 3.2.1-15 3.2.1-16
chromium 91.0.4472.114-1 91.0.4472.164-1
claws-mail 3.18.0-1 4.0.0-2
cmake 3.20.5-1 3.21.0-1
cmark 0.30.0-2 0.30.1-1
devtools 20210202-1 20210202-2
evince 40.2-1 40.3-1
ffcall 2.3-1 2.4-1
fmt 7.1.3-1 8.0.0-2
freetds 1.2.21-1 1.3-1
gst-plugin-opencv 1.18.4-8 1.18.4-9
gst-plugin-wpe 1.18.4-8 1.18.4-9
gst-plugins-bad 1.18.4-8 1.18.4-9
gst-plugins-bad-libs 1.18.4-8 1.18.4-9
hplip 1:3.21.4-1 1:3.21.6-1
hwloc 2.4.1-1 2.5.0-1
imagemagick 7.1.0.2-2 7.1.0.4-1
imagemagick-doc 7.1.0.2-2 7.1.0.4-1
imath 3.0.5-1 3.1.0-1
ipset 7.11-1 7.12-1
js78 78.11.0-1 78.12.0-1
kimageformats 5.84.0-1 5.84.0-2
kio 5.84.0-1 5.84.0-2
kismet 2020_12_R3-5 2021_06_R1-1
krita 4.4.5-2 4.4.5-3
kseexpr 4.0.2.0-1 4.0.3.0-1
libmp4v2 4.1.6-1 5.0.0-1
libuv 1.41.0-1 1.41.1-1
libva-mesa-driver 21.1.4-1 21.1.5-1
libwebsockets 4.2.0-1 4.2.1-1
mercurial 5.8-2 5.8.1-1
mesa 21.1.4-1 21.1.5-1
mesa-vdpau 21.1.4-1 21.1.5-1
mkvtoolnix-cli 58.0.0-2 58.0.0-6
mkvtoolnix-gui 58.0.0-2 58.0.0-6
mpg123 1.28.0-1 1.28.2-1
mtools 1:4.0.32-1 1:4.0.33-1
mutt 2.1-1 2.1.1-1
namcap 3.2.10-2 3.2.10-3
ncftp 3.2.6-3 3.2.6-4
noto-fonts-emoji 20200916-1 20210625-1
okular 21.04.3-1 21.04.3-2
opencl-mesa 21.1.4-1 21.1.5-1
opencv 4.5.3-1 4.5.3-2
opencv-samples 4.5.3-1 4.5.3-2
openexr 3.0.5-1 3.0.5-2
ostree 2021.2-1 2021.3-1
perl-http-message 6.32-2 6.33-1
perl-net-dns 1.31-3 1.32-1
plasma-systemmonitor 5.22.3-1 5.22.3-2
prometheus-node-exporter 1.1.2-2 1.2.0-1
python-opencv 4.5.3-1 4.5.3-2
python-setuptools 1:57.1.0-1 1:57.2.0-1
python-virtualenv 20.4.7-1 20.5.0-1
python2-virtualenv 20.4.7-1 20.5.0-1
qt5-base 5.15.2+kde+r209-1 5.15.2+kde+r210-1
qt5-wayland 5.15.2+kde+r28-1 5.15.2+kde+r29-1
qt5-xcb-private-headers 5.15.2+kde+r209-1 5.15.2+kde+r210-1
qtcreator 4.15.1-2 4.15.2-1
rhash 1.4.1-1 1.4.2-1
ruby 3.0.1-1 3.0.2-1
ruby-docs 3.0.1-1 3.0.2-1
samba 4.14.5-1 4.14.6-1
smbclient 4.14.5-1 4.14.6-1
talloc 2.3.2-1 2.3.3-1
tdb 1.4.3-4 1.4.4-1
thunderbird 78.11.0-1 78.12.0-1
thunderbird-i18n-af 78.11.0-1 78.12.0-1
thunderbird-i18n-ar 78.11.0-1 78.12.0-1
thunderbird-i18n-ast 78.11.0-1 78.12.0-1
thunderbird-i18n-be 78.11.0-1 78.12.0-1
thunderbird-i18n-bg 78.11.0-1 78.12.0-1
thunderbird-i18n-br 78.11.0-1 78.12.0-1
thunderbird-i18n-ca 78.11.0-1 78.12.0-1
thunderbird-i18n-cak 78.11.0-1 78.12.0-1
thunderbird-i18n-cs 78.11.0-1 78.12.0-1
thunderbird-i18n-cy 78.11.0-1 78.12.0-1
thunderbird-i18n-da 78.11.0-1 78.12.0-1
thunderbird-i18n-de 78.11.0-1 78.12.0-1
thunderbird-i18n-dsb 78.11.0-1 78.12.0-1
thunderbird-i18n-el 78.11.0-1 78.12.0-1
thunderbird-i18n-en-gb 78.11.0-1 78.12.0-1
thunderbird-i18n-en-us 78.11.0-1 78.12.0-1
thunderbird-i18n-es-ar 78.11.0-1 78.12.0-1
thunderbird-i18n-es-es 78.11.0-1 78.12.0-1
thunderbird-i18n-et 78.11.0-1 78.12.0-1
thunderbird-i18n-eu 78.11.0-1 78.12.0-1
thunderbird-i18n-fa 78.11.0-1 78.12.0-1
thunderbird-i18n-fi 78.11.0-1 78.12.0-1
thunderbird-i18n-fr 78.11.0-1 78.12.0-1
thunderbird-i18n-fy-nl 78.11.0-1 78.12.0-1
thunderbird-i18n-ga-ie 78.11.0-1 78.12.0-1
thunderbird-i18n-gd 78.11.0-1 78.12.0-1
thunderbird-i18n-gl 78.11.0-1 78.12.0-1
thunderbird-i18n-he 78.11.0-1 78.12.0-1
thunderbird-i18n-hr 78.11.0-1 78.12.0-1
thunderbird-i18n-hsb 78.11.0-1 78.12.0-1
thunderbird-i18n-hu 78.11.0-1 78.12.0-1
thunderbird-i18n-hy-am 78.11.0-1 78.12.0-1
thunderbird-i18n-id 78.11.0-1 78.12.0-1
thunderbird-i18n-is 78.11.0-1 78.12.0-1
thunderbird-i18n-it 78.11.0-1 78.12.0-1
thunderbird-i18n-ja 78.11.0-1 78.12.0-1
thunderbird-i18n-ka 78.11.0-1 78.12.0-1
thunderbird-i18n-kab 78.11.0-1 78.12.0-1
thunderbird-i18n-kk 78.11.0-1 78.12.0-1
thunderbird-i18n-ko 78.11.0-1 78.12.0-1
thunderbird-i18n-lt 78.11.0-1 78.12.0-1
thunderbird-i18n-ms 78.11.0-1 78.12.0-1
thunderbird-i18n-nb-no 78.11.0-1 78.12.0-1
thunderbird-i18n-nl 78.11.0-1 78.12.0-1
thunderbird-i18n-nn-no 78.11.0-1 78.12.0-1
thunderbird-i18n-pa-in 78.11.0-1 78.12.0-1
thunderbird-i18n-pl 78.11.0-1 78.12.0-1
thunderbird-i18n-pt-br 78.11.0-1 78.12.0-1
thunderbird-i18n-pt-pt 78.11.0-1 78.12.0-1
thunderbird-i18n-rm 78.11.0-1 78.12.0-1
thunderbird-i18n-ro 78.11.0-1 78.12.0-1
thunderbird-i18n-ru 78.11.0-1 78.12.0-1
thunderbird-i18n-si 78.11.0-1 78.12.0-1
thunderbird-i18n-sk 78.11.0-1 78.12.0-1
thunderbird-i18n-sl 78.11.0-1 78.12.0-1
thunderbird-i18n-sq 78.11.0-1 78.12.0-1
thunderbird-i18n-sr 78.11.0-1 78.12.0-1
thunderbird-i18n-sv-se 78.11.0-1 78.12.0-1
thunderbird-i18n-th 78.11.0-1 78.12.0-1
thunderbird-i18n-tr 78.11.0-1 78.12.0-1
thunderbird-i18n-uk 78.11.0-1 78.12.0-1
thunderbird-i18n-uz 78.11.0-1 78.12.0-1
thunderbird-i18n-vi 78.11.0-1 78.12.0-1
thunderbird-i18n-zh-cn 78.11.0-1 78.12.0-1
thunderbird-i18n-zh-tw 78.11.0-1 78.12.0-1
unison 2.51.3-1 2.51.4-1
varnish 6.6.0-2 6.6.1-1
vulkan-broadcom 21.1.4-1 21.1.5-1
vulkan-extra-layers 1.2.170.0-1 1.2.182.0-1
vulkan-extra-tools 1.2.170.0-1 1.2.182.0-1
vulkan-headers 1:1.2.182-1 1:1.2.184-1
vulkan-icd-loader 1.2.182-1 1.2.184-1
vulkan-mesa-layers 21.1.4-1 21.1.5-1
vulkan-radeon 21.1.4-1 21.1.5-1
vulkan-swrast 21.1.4-1 21.1.5-1
vulkan-tools 1.2.182-1 1.2.184-1
vulkan-validation-layers 1.2.182-1 1.2.184-1
wpewebkit 2.32.1-1 2.32.2-1
python-platformdirs - 2.0.2-1
python2-backports.entry-points-selectable - 1.1.0-1
python2-platformdirs - 2.0.2-1
skanlite - 2.2.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.04.3.r12519.g0bc009687-121.04.3.r12527.g78ccf477a-1
akonadi-calendar21.04.3.r1957.gc471bcd-121.04.3.r1958.gbaae021-1
akonadi-contacts21.04.3.r3025.gb91ab23d-121.04.3.r3027.g7dd573ce-1
akonadi-mime21.04.3.r1629.ga655c95-121.04.3.r1630.g5012eb8-1
akonadi-notes21.04.3.r1013.g3ddecb2-121.04.3.r1014.g4dc5575-1
akonadi-search21.04.3.r1106.g49c9837-121.04.3.r1107.g26c21d0-1
akregator21.04.3.r6177.ga8a3a2ee-121.04.3.r6187.gf56fb990-1
angelfish 21.06.r13.gccfa889-1 21.06.r18.g1b2d7ed-1
ark21.04.3.r4593.g6f262cdd-121.04.3.r4602.g78dc03ab-1
attica5.84.0.r822.ga90893d-15.84.0.r824.g328f2d9-1
baloo5.83.0.r2993.g62c03736-15.84.0.r2995.gc28a53c6-1
bluedevil1:5.22.3.r2268.g87b46065-11:5.22.3.r2269.gfaade374-1
bluez-qt5.83.0.r665.g9a25983-15.84.0.r668.gba48b66-1
bomber21.04.3.r518.gc837d17-121.04.3.r519.g0902c55-1
breeze5.22.3.r2220.g7f793949-15.22.3.r2221.g162767a6-1
breeze-icons5.83.0.r1755.geec9a2c4-15.84.0.r1758.gc6fad5c9-1
buho 1.2.2.r30.gbb2429b-1 1.2.2.r31.g0db48ec-1
calendarsupport21.04.3.r566.ge222d75-121.04.3.r567.ga773765-1
calindori 21.06.r6.gf760462-1 21.06.r9.g5adf21b-1
discover5.22.3.r8232.g5f7751f4-15.22.3.r8233.g65664178-1
dolphin21.04.3.r6645.g3fdd93db9-121.04.3.r6651.g2c7a1f4b4-1
dolphin-plugins21.04.3.r591.g6f8984f-121.04.3.r592.g4f9910b-1
dragon21.04.3.r1006.gd9f5cfa-121.04.3.r1007.g3a2d074-1
drkonqi5.22.3.r665.gcaa06a2c-15.22.3.r672.gf511b225-1
eventviews21.04.3.r669.gff0d774-121.04.3.r670.g381f3ec-1
extra-cmake-modules5.84.0.r3340.g9d45e55-15.84.0.r3349.g95d1808-1
frameworkintegration5.83.0.r588.gef4ec10-15.84.0.r589.g4aa5e78-1
granatier21.04.3.r923.g82225d9-121.04.3.r924.ge3d3c9a-1
grantlee-editor21.04.3.r754.g9870fa0-121.04.3.r757.gd920171-1
grantleetheme21.04.3.r331.g05475f0-121.04.3.r332.gc2d1dd4-1
gwenview21.04.3.r6644.gb9a21ed5-121.04.3.r6646.g5681c504-1
incidenceeditor21.04.3.r742.gb91c878-121.04.3.r743.gf49fe33-1
index-fm 1.2.2.r94.g6bbd63c-1 1.2.2.r98.g6efbb91-1
itinerary21.04.3.r1362.gb9d1eeb-121.04.3.r1377.g81e25e1-1
kaccounts-integration21.04.3.r1209.g3b5ef30-121.04.3.r1210.g7660f66-1
kactivities5.83.0.r1351.g5c286e5-15.84.0.r1353.g03eacef-1
kactivities-stats5.83.0.r360.g802b063-15.84.0.r362.g80c6b1d-1
kalarm21.04.3.r6402.g59f6695d-121.04.3.r6410.g503c8fd5-1
kalarmcal21.04.3.r1121.g667bf5f-121.04.3.r1123.gc773ba4-1
kalk 21.06.r5.g0ef70be-1 21.06.r6.g01bce47-1
kalzium21.04.3.r4253.g1481dd2b-121.04.3.r4254.gbad28991-1
kapidox5.84.0.r540.g2fc5e0d-15.84.0.r542.g0326b90-1
kapman21.04.3.r599.g98d5783-121.04.3.r601.g19d549f-1
karchive5.84.0.r492.g2a1acbd-15.84.0.r496.ge657605-1
kasts 21.06.r67.g041b1ed-1 21.06.r72.gdf07359-1
kate21.04.3.r18283.g11ed6456b-121.04.3.r18291.g809548bf0-1
katomic21.04.3.r913.g943bd88-121.04.3.r916.gac8eb01-1
kauth5.84.0.r439.gf48b5bf-15.84.0.r441.gef65bd6-1
kbackup21.04.3.r380.g4ccaae3-121.04.3.r386.g61a7e6f-1
kblackbox21.04.3.r723.g6ca4526-121.04.3.r724.gc63d2e3-1
kblocks21.04.3.r663.g4b38480-121.04.3.r664.g59ca52a-1
kbookmarks5.84.0.r410.gad346c1-15.84.0.r412.g80d61ce-1
kbounce21.04.3.r801.gf8f667b-121.04.3.r804.g1ff4d8d-1
kbreakout21.04.3.r858.g86ab50b-121.04.3.r861.g3613978-1
kcalendarcore5.83.0.r1219.ga2df8844b-15.84.0.r1225.gdb39bb52c-1
kcalutils21.04.3.r854.g11d58ffb1-121.04.3.r855.g697195969-1
kclock 21.06.r15.g2385a20-1 21.06.r17.g8536da1-1
kcmutils5.83.0.r523.g2411f4c-15.84.0.r525.ga362ddf-1
kcodecs5.84.0.r372.gf0ff68d-15.84.0.r375.gc58a80e-1
kcompletion5.84.0.r446.g54e95d0-15.84.0.r448.g7a0b9d2-1
kconfig5.84.0.r846.gbd53bb3-15.84.0.r849.gdcc5f65-1
kconfigwidgets5.84.0.r595.g9381bbe-15.84.0.r599.g83a1edf-1
kcontacts1:5.83.0.r3244.g2f7f8bcb-11:5.84.0.r3246.gafa4ae75-1
kcoreaddons5.84.0.r1241.g4cd7e789-15.84.0.r1247.gc1eea322-1
kcrash5.84.0.r399.g4921623-15.84.0.r402.g701cd36-1
kdav1:5.83.0.r1289.g2795a0d-11:5.84.0.r1290.gd47ce67-1
kdbusaddons5.84.0.r370.g29dfe25-15.84.0.r371.ge821326-1
kde-dev-scripts21.04.3.r4137.g8f98b13-121.04.3.r4138.g0262243-1
kdebugsettings21.04.3.r827.g370cdc2-121.04.3.r831.g82ea95e-1
kdeclarative5.83.0.r901.g580a694-15.84.0.r903.g9f07247-1
kdeconnect21.04.3.r3278.g296de907-121.04.3.r3289.gac53f3f3-1
kded5.83.0.r409.g01943ff-15.84.0.r411.g5c3ef36-1
kdelibs4support5.83.0.r1026.g44dee8c4-15.84.0.r1027.gbd5c6518-1
kdepim-addons21.04.2.r4233.g72caee05-121.04.2.r4237.g329f63a7-1
kdepim-runtime21.04.3.r15145.g74ef1624e-121.04.3.r15146.gf0c467fff-1
kdeplasma-addons5.22.3.r8553.g77b88b999-15.22.3.r8556.gf600a856f-1
kdesignerplugin5.83.0.r328.g0b12b99-15.84.0.r329.g8141fca-1
kdesu5.83.0.r468.g3daa918-15.84.0.r470.g45a82b6-1
kdewebkit5.83.0.r274.gefed877-15.84.0.r276.g9e20914-1
kdf21.04.3.r790.gb2a8614-121.04.3.r793.g9b46f31-1
kdiamond21.04.3.r665.g639f619-121.04.3.r667.g087b030-1
kdnssd5.83.0.r315.g4ba7121-15.84.0.r316.g5a5e100-1
kdoctools5.84.0.r614.gb87709c-15.84.0.r616.g1a544d9-1
kemoticons5.83.0.r376.gbeed4ec-15.84.0.r378.gd8d5133-1
kfilemetadata5.83.0.r798.g3847089-15.84.0.r800.gdf7a567-1
kfind21.04.3.r2634.gdce809f04-121.04.3.r2639.g1e525b4bd-1
kfloppy21.04.3.r752.g691d766-121.04.3.r753.g77af6be-1
kfourinline21.04.3.r977.gdc073b4-121.04.3.r980.gff9f466-1
kget21.04.3.r3116.gc75a0da8-121.04.3.r3117.g003064ad-1
kglobalaccel5.84.0.r451.g86899db-15.84.0.r453.gac6c8df-1
kgoldrunner21.04.3.r1234.g79209db-121.04.3.r1236.gb6c375d-1
kguiaddons5.84.0.r377.g9047512-15.84.0.r380.g45b830a-1
khangman21.04.3.r1562.gd6f7474-121.04.3.r1563.ga228cef-1
kholidays1:5.83.0.r943.gd0c15ca-11:5.84.0.r945.ga00d0fe-1
khtml5.83.0.r550.g7734b7f-15.84.0.r551.ga34c800-1
ki18n5.84.0.r470.g4ef749b-15.84.0.r472.gf3e663b-1
kiconthemes5.84.0.r531.g7edcfab-15.84.0.r533.g52064e0-1
kidentitymanagement21.04.3.r3792.g0b2875ba-121.04.3.r3795.g5a86412f-1
kidletime5.83.0.r306.g1e5792e-15.84.0.r308.gec6e0b6-1
kig21.04.3.r3140.gdcb670bd-121.04.3.r3143.g96186b6a-1
kigo21.04.3.r518.g9a11075-121.04.3.r520.g08ebecf-1
killbots21.04.3.r732.g7da9165-121.04.3.r734.g41654e3-1
kimageformats5.83.0.r344.g3266a9c-15.84.0.r347.g7f56d83-1
kimap21.04.3.r1100.ga376bc4-121.04.3.r1101.ge0538b4-1
kinit5.84.0.r403.g88e23a2-15.84.0.r405.ge6668c4-1
kio5.84.0.r4833.g36f1814b-15.84.0.r4850.gf0664a0c-1
kio-extras21.04.3.r7088.gcec49d39-121.04.3.r7092.g2f2f6253-1
kio-gdrive21.04.3.r560.g44f483d-121.04.3.r562.g7b06d00-1
kirigami25.84.0.r2828.ga1b3913e-15.84.0.r2837.g040e6136-1
kiriki21.04.3.r417.gec9e2ef-121.04.3.r418.g6065eb4-1
kitemmodels5.83.0.r545.g755cdd1-15.84.0.r547.gb703c6f-1
kitemviews5.84.0.r330.g2716299-15.84.0.r332.gf2786d0-1
kitinerary21.04.3.r1820.g5058071-121.04.3.r1831.gb1464cd-1
kjobwidgets5.84.0.r368.g9c6142f-15.84.0.r369.gf058ddb-1
kjs5.83.0.r329.gca14caf-15.84.0.r331.g1157752-1
kjsembed5.83.0.r298.g9de8ed7-15.84.0.r300.g1e8b825-1
kjumpingcube21.04.3.r781.g2238a93-121.04.3.r783.g54f2ba1-1
kldap21.04.3.r868.g174e41b-121.04.3.r869.g4ae869e-1
klickety21.04.3.r630.gf8576a2-121.04.3.r632.gd6320f6-1
klines21.04.3.r743.g7aa89f1-121.04.3.r753.ga981203-1
kmahjongg21.04.3.r1466.g1b677ae-121.04.3.r1467.ge50f3b1-1
kmail-account-wizard21.04.3.r790.g8a1654a-121.04.3.r791.gd0b9f1a-1
kmbox21.04.3.r528.g3176ee3-121.04.3.r529.geffe162-1
kmediaplayer5.83.0.r290.gd16226b-15.84.0.r291.g8385c6b-1
kmime21.04.3.r1440.g43a6ce0-121.04.3.r1441.gebb0fc1-1
kmines21.04.3.r1713.gd98ba9e-121.04.3.r1715.g58f37a8-1
knavalbattle21.04.3.r1381.gbe44ade-121.04.3.r1384.gdc5a678-1
knetwalk21.04.3.r650.g319553b-121.04.3.r651.g71b9db7-1
knewstuff5.83.0.r1182.g6788cf4f-15.84.0.r1184.g5bb2707b-1
knotifications5.84.0.r666.g4e638d1-15.84.0.r668.g3009331-1
knotifyconfig5.83.0.r346.g1725410-15.84.0.r348.gbbcae0e-1
kolf21.04.3.r1430.gfb632a5-121.04.3.r1431.g91ecf4f-1
kollision21.04.3.r485.gbe33dc3-121.04.3.r486.g3bfd59a-1
kolourpaint21.04.3.r2348.g11e1c189-121.04.3.r2349.g5849a5f2-1
kompare21.04.3.r1102.gc5cfcde-121.04.3.r1103.g6f0305b-1
konqueror21.04.3.r14913.g30aea7bcb-121.04.3.r14917.gd825e73d9-1
konquest21.04.3.r890.g38d88bd-121.04.3.r891.g7309631-1
konsole21.04.3.r7882.g26018e3a-121.04.3.r7891.gdc92c593-1
kontact21.04.3.r5341.g222bece2-121.04.3.r5346.ged3f1b15-1
kontactinterface21.04.3.r620.g9ea7cf2-121.04.3.r621.g7bec405-1
korganizer21.04.3.r11403.g281f79894-121.04.3.r11410.ge4b327b64-1
kpackage5.84.0.r675.g9acb251-15.84.0.r678.g0e03365-1
kparts5.83.0.r512.g4dbc8b4-15.84.0.r514.g8b81bf4-1
kpeople5.83.0.r1335.gb6b58af-15.84.0.r1337.g3f4ab34-1
kpimtextedit21.04.3.r1392.gc08755a-121.04.3.r1393.g3874363-1
kplotting5.83.0.r285.g48b6d33-15.84.0.r287.g96be9c3-1
kpty5.83.0.r330.g03a517a-15.84.0.r331.g09b4e06-1
kquickcharts5.83.0.r464.gec46053-15.84.0.r466.g09e9642-1
kreversi21.04.3.r1216.gc9646c1-121.04.3.r1218.g2abe20f-1
kross5.83.0.r328.g7d48e4f-15.84.0.r330.g2e0b5b7-1
krunner5.83.0.r642.gbcd11b6-15.84.0.r646.ge067c4f-1
kservice5.84.0.r922.g2900204-15.84.0.r924.g0b569b0-1
kshisen21.04.3.r1195.g782afbf-121.04.3.r1197.g448c2ee-1
ksmtp21.04.3.r357.g6357856-121.04.3.r358.g5969962-1
ksnakeduel21.04.3.r796.gb4178a5-121.04.3.r799.gce16717-1
kspaceduel21.04.3.r623.g026456a-121.04.3.r625.g4b314f8-1
ksquares21.04.3.r511.gd306032-121.04.3.r512.gffc6ab6-1
ksystemstats5.22.3.r174.g0639a7f-15.22.3.r176.g5f93a3f-1
ktexteditor5.83.0.r2903.g6a7e6286-15.84.0.r2906.g96182d63-1
ktextwidgets5.84.0.r402.g3399228-15.84.0.r404.g042f5a7-1
ktnef21.04.3.r654.g3cb0be9-121.04.3.r655.ga27e7de-1
ktouch21.04.3.r2136.g3f40f66-121.04.3.r2137.g62ffc8a-1
kunitconversion5.83.0.r368.gfafa510-15.84.0.r369.geed860d-1
kwallet5.84.0.r1075.gf5fc49b-15.84.0.r1078.g60c8e9d-1
kwallet-pam5.22.3.r248.ge91fcbe-15.22.3.r250.g3bdf94a-1
kwalletmanager21.04.3.r1199.gbdc66ef-121.04.3.r1201.gedd21a2-1
kwave21.04.3.r3737.gc6213fa5-121.04.3.r3738.ga4cf7ac2-1
kwayland5.83.0.r1095.g2adaa15-15.84.0.r1098.g05ded8f-1
kwayland-server5.22.3.r1343.g893e4a1-15.22.3.r1344.g3789090-1
kweather 21.06.r30.gb5e8a76-1 21.06.r35.gce3bb20-1
kwidgetsaddons5.84.0.r833.gbac6de40-15.84.0.r835.g6a72f111-1
kwin5.22.3.r19639.g23129c09c-15.22.3.r19646.g9e5cb836a-1
kwindowsystem5.84.0.r597.gcb33999-15.84.0.r599.g26e295a-1
kwinft5.22.0.r18970.g15ebb3fb5-15.22.0.r19035.gc2a9a76b5-1
kwrite21.04.3.r18283.g11ed6456b-121.04.3.r18291.g809548bf0-1
kxmlgui5.84.0.r785.g4c6acb75-15.84.0.r790.g917b743d-1
kxmlrpcclient5.83.0.r451.g330436966-15.84.0.r452.gdcaf14c9e-1
libakonadi21.04.3.r12519.g0bc009687-121.04.3.r12527.g78ccf477a-1
libkdegames21.04.3.r2181.g4e7bbf7f-121.04.3.r2185.g9295393e-1
libkdepim21.04.3.r839.gc514137-121.04.3.r840.ge2cbe34-1
libkgapi21.04.3.r1285.g9c05e62-121.04.3.r1286.gab3d548-1
libkleo21.04.3.r913.g1ff8583-121.04.3.r914.g9f79f52-1
libkmahjongg21.04.3.r453.g0d54bba-121.04.3.r455.g5593450-1
libkomparediff221.04.3.r336.g36da81f-121.04.3.r337.g9827753-1
libksieve21.04.3.r1545.g3300d331-121.04.3.r1551.gfc1ed601-1
libquotient r2006.g74dda96-1 r2012.gd85c63f-1
lskat21.04.3.r805.gb70ac1d-121.04.3.r809.g7885937-1
mailcommon21.04.3.r1053.g53624c3-121.04.3.r1057.gc8d5a1d-1
mailimporter21.04.3.r461.g3677c0d-121.04.3.r462.gaaac664-1
marble21.04.3.r13316.g0fe8ffc99-121.04.3.r13317.gf08f15fd3-1
marble-common21.04.3.r13316.g0fe8ffc99-121.04.3.r13317.gf08f15fd3-1
marble-qt21.04.3.r13316.g0fe8ffc99-121.04.3.r13317.gf08f15fd3-1
maui-clip 1.1.1.r8.gb3d9db9-2 1.1.1.r8.gb3d9db9-4
maui-nota 1.2.2.r49.gedc609a-1 1.2.2.r52.gf3a839c-1
maui-pix 1.2.2.r56.gee6e755-1 1.2.2.r59.g5d0378f-1
mauikit2.2.2.r114.g9ec618c8-11.2.2.r147.g48060a91-1
mauikit-accounts r8.3324a33-1 r9.398b635-1
mauikit-filebrowsing 1.2.2.r64.ga123902-1 1.2.2.r64.ga123902-3
mauikit-imagetools 1.2.2.r16.g9f9e1a4-1 1.2.2.r16.g9f9e1a4-3
mauikit-texteditor 1.2.2.r8.g8a7b033-1 1.2.2.r11.g40a45c4-3
messagelib21.04.3.r6066.g38461aa2-121.04.3.r6075.g1de22472-1
modemmanager-qt5.83.0.r513.gaf2046f-15.84.0.r515.gd228c82-1
neochat r1783.g35aac4e3-1 r1785.gae60834c-1
networkmanager-qt5.83.0.r1109.gc4f8663-15.84.0.r1110.g898e976-1
okular21.04.3.r9393.g5447aa102-121.04.3.r9397.g1d9081766-1
oxygen-icons1:5.83.0.r5.gbff159d-21:5.84.0.r5.gbff159d-1
oxygen-icons-svg1:5.83.0.r5.gbff159d-21:5.84.0.r5.gbff159d-1
palapeli21.04.3.r1225.gfd17215-121.04.3.r1226.gd3f694b-1
pimcommon21.04.3.r1063.g88519b7-121.04.3.r1064.g6dfebc4-1
plasma-browser-integration5.22.3.r1266.gdc031190-15.22.3.r1267.gb9e54d8c-1
plasma-desktop5.22.3.r8544.g424e9b2e4-15.22.3.r8545.g1afe75a8b-1
plasma-dialer 21.06.r5.g6566de5-1 21.06.r7.g06e0f9a-1
plasma-disks5.22.3.r220.gc883001-15.22.3.r221.gaaf1ef6-1
plasma-framework5.83.0.r15909.g057b74476-15.84.0.r15915.g2ec68a614-1
plasma-mobile-nm5.21.4.r3061.gf6e45d40-15.21.4.r3063.gf891c384-1
plasma-nm5.22.3.r3062.ge3474d8f-15.22.3.r3063.gf891c384-1
plasma-pa5.22.3.r950.g6ff7099-15.22.3.r951.ge87dcf3-1
plasma-phone-components5.22.3.r1423.g7c8fc779-15.22.3.r1425.g4942e0e3-1
plasma-settings 21.06.r2.g968453c-1 21.06.r9.ge10e1e1-1
plasma-systemmonitor5.22.3.r465.g2aa482c-15.22.3.r466.gc3fb6e0-1
plasma-wayland-protocols1.3.0.r1026.g0b07950-11.3.0.r1027.gad543cf-1
plasma-wayland-session5.22.3.r10433.g70a69b00c-15.22.3.r10440.g27704daf4-1
plasma-workspace5.22.3.r10433.g70a69b00c-15.22.3.r10440.g27704daf4-1
plasma-workspace-wallpapers5.22.3.r279.g5bf6b8d-15.22.3.r280.ge462299-1
prison5.83.0.r320.geb20509-15.84.0.r323.g4fee056-1
purpose5.83.0.r862.g2ca6b6b-15.84.0.r863.g313092d-1
qqc2-breeze-style r200.g2453dba-15.22.3.r220.gdcfd65f-1
qqc2-desktop-style5.83.0.r498.gf5307d1-15.84.0.r502.g4db9bbb-1
rocs21.04.2.r3018.g528540e7-121.04.2.r3022.gc2e0af1d-1
solid5.84.0.r687.gcde7831-15.84.0.r690.g9829c51-1
sonnet5.84.0.r620.g430697e-15.84.0.r622.g7f36a22-1
spacebar 21.06.r22.gecc0155-1 21.06.r23.g6bc8d92-1
spectacle21.04.3.r1131.g2f344ce-121.04.3.r1132.g874b5b0-1
syndication5.83.0.r832.g468e4ca-15.84.0.r834.g43f3876-1
syntax-highlighting5.83.0.r1623.gd5c4d1fe-15.84.0.r1630.ga2bb6f45-1
threadweaver5.83.0.r502.g79794c5-15.84.0.r504.gb7953f0-1
vvave 1.2.2.r48.g709b880-1 1.2.2.r53.g4cdfbe5-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
