Hello ARM community.
A rather small update, nothing fancy.
Some highlights:
- A couple of our kernels got updated, mainline updated to 5.13
- Bitwarden updated to 1.27.0
- Some fixes in Pipewire 0.3.31
- QT 6 got a new point release with 6.1.2
- And PHP also got a new point release with 8.0.8
- Lots of Mobile specific packages got updated
- Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss
package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip
and firewalld
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Fri Jul 2 20:43:59 CEST 2021)
- arm-testing community aarch64: 262 new and 240 removed package(s)
- arm-testing core aarch64: 23 new and 23 removed package(s)
- arm-testing extra aarch64: 98 new and 105 removed package(s)
- arm-testing kde-unstable aarch64: 255 new and 254 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-06-26 2021-07-02
anbox 0_git20210320-2 0_git20210320-3
bitwarden 1.26.5-1 1.27.0-1
calls 0.3.4-1 0.3.4+28+g49c347c-1
chatty 0.3.1+59+g76e2813-1 0.3.2+18+gdcdf00a-1
electron 13.1.4-1 13.1.5-1
electron12 12.0.12-1 12.0.13-1
grimshot 1.6-1 1.6.1-1
hwinfo 21.74-1 21.75-1
phosh 0.11.0+12+g2ca82dd-1 0.12.0+2+g40bf03f-1
squeekboard 1.14.0+3+g1963033-1 1.14.0+14+g4efe57c-1
telepathy-ofono 20210417-0.1 20210417-1
wayfire 0.7.1-1 0.7.2-1
wire-desktop 3.25.2940-1 3.26.2941-1
:: Different sync package(s) in repository community aarch64
ansible 4.1.0-1 4.2.0-1
ansible-bender 0.8.1-3 0.9.0-1
arch-repro-status 1.2.2-1 1.2.3-1
ardour 6.7-2 6.7-3
awxkit 19.2.1-1 19.2.2-1
bemenu 0.6.2-1 0.6.2-2
bemenu-ncurses 0.6.2-1 0.6.2-2
bemenu-wayland 0.6.2-1 0.6.2-2
bemenu-x11 0.6.2-1 0.6.2-2
bleachbit 4.2.0-1 4.4.0-1
blender 17:2.93.0-7 17:2.93.1-1
buildah 1.21.1-1 1.21.2-1
cage 0.1.3-1 0.1.4-1
cargo-outdated 0.9.15-1 0.9.17-1
cargo-spellcheck 0.8.4-1 0.8.6-1
chezmoi 2.0.14-1 2.0.16-1
cinnamon-control-center 5.0.1-1 5.0.2-1
cinnamon-screensaver 5.0.5-1 5.0.6-1
cinnamon-settings-daemon 5.0.2-1 5.0.3-1
cinnamon-translations 5.0.1-1 5.0.2-1
cri-o 1.21.0-1 1.21.1-1
cutefish-core 0.2-1 0.3-1
cutefish-dock 0.2-1 0.3-1
cutefish-filemanager 0.2-1 0.3-1
cutefish-icons 0.2-1 0.3-1
cutefish-kwin-plugins 0.2-1 0.3-1
cutefish-launcher 0.2-1 0.3-1
cutefish-qt-plugins 0.2-1 0.3-1
cutefish-settings 0.2-1 0.3-1
cutefish-statusbar 0.2-1 0.3-1
dart 2.13.3-1 2.13.4-1
deteriorate-lv2 1.0.7-2 1.0.7-3
dns-lexicon 3.6.0-1 3.6.1-1
dovecot-fts-xapian 1.4.9b-2 1.4.10-2
drumstick 2.2.1-1 2.3.0-1
dua-cli 2.11.3-1 2.14.1-1
faudio 21.06-1 21.07-1
firefox-noscript 11.2.8-1 11.2.9-1
firejail 0.9.64.4-1 0.9.66-1
firewalld 0.9.3-3 0.9.4-1
fishui 0.2-1 0.3-1
fluxctl 1.22.2-1 1.23.0-1
gimp-help-ca 2.10.0-3 2.10.0-4
gimp-help-da 2.10.0-3 2.10.0-4
gimp-help-de 2.10.0-3 2.10.0-4
gimp-help-el 2.10.0-3 2.10.0-4
gimp-help-en 2.10.0-3 2.10.0-4
gimp-help-en_gb 2.10.0-3 2.10.0-4
gimp-help-es 2.10.0-3 2.10.0-4
gimp-help-fi 2.10.0-3 2.10.0-4
gimp-help-fr 2.10.0-3 2.10.0-4
gimp-help-it 2.10.0-3 2.10.0-4
gimp-help-ja 2.10.0-3 2.10.0-4
gimp-help-ko 2.10.0-3 2.10.0-4
gimp-help-nl 2.10.0-3 2.10.0-4
gimp-help-nn 2.10.0-3 2.10.0-4
gimp-help-pt_br 2.10.0-3 2.10.0-4
gimp-help-ro 2.10.0-3 2.10.0-4
gimp-help-ru 2.10.0-3 2.10.0-4
gimp-help-zh_cn 2.10.0-3 2.10.0-4
github-cli 1.11.0-1 1.12.0-1
goaccess 1.5-1 1.5.1-1
gpg-tui 0.6.0-1 0.6.2-1
gpodder 3.10.19-4 3.10.20-1
guitarix 0.42.1-1 0.42.1-2
hcloud 1.24.0-1 1.25.1-1
helm 3.6.1-1 3.6.2-1
hugo 0.84.0-1 0.84.4-1
i3status-rust 0.20.1-1 0.20.2-1
icewm 2.4.0-1 2.5.0-2
jack2 1.9.17-2 1.9.18-2
jack2-dbus 1.9.17-2 1.9.18-2
jedi-language-server 0.33.0-1 0.33.1-1
jenkins 2.299-1 2.300-1
jmol 14.31.42-1 14.31.44-1
jsmol 14.31.42-1 14.31.44-1
jupyter-server 1.9.0-1 1.9.0-2
k9s 0.24.10-1 0.24.12-1
keepassxc 2.6.4-1 2.6.6-1
kitty 0.21.1-1 0.21.2-1
kitty-terminfo 0.21.1-1 0.21.2-1
lfs 0.7.1-1 0.7.5-1
libavif 0.9.1-1 0.9.2-1
libindi 1.9.0-1 1.9.1-1
libretro-core-info 1.9.5-1 1.9.6-1
librime-data 0.0.0.20210208-1 0.0.0.20210627-1
libtg_owt 0.git4.2d804d2-1 0.git5.f03ef05-1
libtpms 0.8.3-1 0.8.4-1
libtraceevent 1:1.3.0-1 1:1.3.3-1
libtracefs 1.2.0-1 1.2.2-1
luminancehdr 2.6.1-2 2.6.1-3
mame 0.232-1 0.233-1
mame-tools 0.232-1 0.233-1
matrix-synapse 1.34.0-3 1.37.1-1
mediawiki 1.36.0-1 1.36.1-1
mediawiki-math 1.36.0-1 1.36.1-1
minitube 3.8.2-1 3.9-1
mruby 2.1.2-1 3.0.0-1
nemo 5.0.1-1 5.0.2-1
nextcloud 21.0.2-1 21.0.3-1
nextcloud-app-calendar 1:2.2.2-1 1:2.3.0-1
nginx-mod-njs 0.6.0-1 0.6.1-1
nodejs 16.4.0-1 16.4.1-1
notmuch 0.32.1-1 0.32.2-1
notmuch-mutt 0.32.1-1 0.32.2-1
notmuch-runtime 0.32.1-1 0.32.2-1
notmuch-vim 0.32.1-1 0.32.2-1
nuitka 0.6.15.3-1 0.6.16-1
opensubdiv 3.4.4-1 3.4.4-2
papirus-icon-theme 20210601-1 20210701-1
perl-data-optlist 0.110-7 0.112-1
podman 3.2.1-1 3.2.2-1
podman-docker 3.2.1-1 3.2.2-1
prettier 2.3.1-1 2.3.2-1
puppet 6.22.1-1 6.23.0-1
py3status 3.37-1 3.38-1
pyenv 2.0.1-1 2.0.2-1
pynac 0.7.28-1 0.7.29-1
pyright 1.1.152-1 1.1.154-1
python-apispec 4.6.0-1 4.7.0-1
python-arrow 1.1.0-1 1.1.1-1
python-beniget 0.3.0-2 0.4.0-1
python-cfn-lint 0.51.0-1 0.52.0-1
python-discogs-client 2.3.0-3 2.3.12-1
python-django-modeltranslation 0.17.2-1 0.17.3-1
python-docs 3.9.5-1 3.9.6-1
python-dotenv 0.17.1-1 0.18.0-1
python-faker 8.8.2-1 8.9.0-1
python-geographiclib 1.50-3 1.52-1
python-google-api-core 1.28.0-1 1.30.0-1
python-google-api-python-client 2.5.0-1 2.10.0-1
python-importlib_resources 5.1.4-1 5.2.0-1
python-m2crypto 0.37.1-2 0.38.0-1
python-oslo-db 9.1.0-1 10.0.0-1
python-oslo-log 4.5.0-2 4.6.0-1
python-pandas 1.2.4-1 1.2.5-1
python-phonenumbers 8.12.25-1 8.12.26-1
python-poetry 1.1.6-1 1.1.7-1
python-prompt_toolkit 3.0.18-1 3.0.19-1
python-psycopg2 2.8.6-4 2.9.1-1
python-pynamodb 5.0.3-1 5.1.0-1
python-pyphen 0.10.0-1 0.11.0-1
python-regex 2021.4.4-1 2021.7.1-1
python-reportlab 3.5.67-1 3.5.68-1
python-send2trash 1.5.0-6 1.7.1-1
python-zita-audiotools 1.0.0-7 1.0.0-8
python-zita-jacktools 1.2.0-2 1.5.0-1
qbittorrent 4.3.5-1 4.3.6-1
qbittorrent-nox 4.3.5-1 4.3.6-1
qjackctl 0.9.2-2 0.9.3-1
qliveplayer 3.22.1-1 3.22.3-1
qmidinet 0.9.2-1 0.9.3-1
qutebrowser 2.2.3-1 2.3.0-1
redkite 1.3.0-1 -
remmina 1:1.4.18-1 1:1.4.19-1
renpy 7.4.4-1 7.4.6-1
renpy-demos 7.4.4-1 7.4.6-1
retroarch 1.9.5-1 1.9.6-1
rime-essay 0.0.0.20201222-1 0.0.0.20210627-1
rime-prelude 0.0.0.20210208-1 0.0.0.20210627-1
rsibreak 0.12.13-1 0.12.14-1
rust-analyzer 20210621-1 20210628-1
salt 3003.1-1 3003.1-2
serverless 2.48.0-1 2.50.0-1
shotcut 21.05.18-1 21.05.18-2
sirocco 2.0.2-1 2.1.0-1
skaffold 1.26.1-1 1.27.0-1
skk-jisyo 20210613-1 20210627-1
skopeo 1.3.0-1 1.3.1-1
snd 21.4-1 21.5-1
sslh 1.21c-1 1.21c-2
sway 1:1.6-1 1:1.6.1-1
sweethome3d 6.5-2 6.5-3
synbak 3.8.1-1 3.8.2-1
tailscale 1.8.8-1 1.10.0-1
tekton-cli 0.19.0-1 0.19.1-1
telegram-desktop 2.7.4-2 2.8.3-1
terraform-provider-libvirt 0.6.3-3 -
thrift 0.14.1-1 0.14.2-1
tor 0.4.6.5-1 0.4.6.6-1
trash-cli 0.21.6.10.1-1 0.21.6.30-1
tree-sitter 0.19.5-1 0.20.0-1
ttc-iosevka 7.1.1-1 7.2.2-2
ttc-iosevka-aile 7.1.1-1 7.2.2-2
ttc-iosevka-curly 7.1.1-1 7.2.2-2
ttc-iosevka-curly-slab 7.1.1-1 7.2.2-2
ttc-iosevka-etoile 7.1.1-1 7.2.2-2
ttc-iosevka-slab 7.1.1-1 7.2.2-2
ttc-iosevka-ss01 7.1.1-1 7.2.2-2
ttc-iosevka-ss02 7.1.1-1 7.2.2-2
ttc-iosevka-ss03 7.1.1-1 7.2.2-2
ttc-iosevka-ss04 7.1.1-1 7.2.2-2
ttc-iosevka-ss05 7.1.1-1 7.2.2-2
ttc-iosevka-ss06 7.1.1-1 7.2.2-2
ttc-iosevka-ss07 7.1.1-1 7.2.2-2
ttc-iosevka-ss08 7.1.1-1 7.2.2-2
ttc-iosevka-ss09 7.1.1-1 7.2.2-2
ttc-iosevka-ss10 7.1.1-1 7.2.2-2
ttc-iosevka-ss11 7.1.1-1 7.2.2-2
ttc-iosevka-ss12 7.1.1-1 7.2.2-2
ttc-iosevka-ss13 7.1.1-1 7.2.2-2
ttc-iosevka-ss14 7.1.1-1 7.2.2-2
ttc-iosevka-ss15 7.1.1-1 7.2.2-2
ttc-iosevka-ss16 7.1.1-1 7.2.2-2
ttc-iosevka-ss17 7.1.1-1 7.2.2-2
ttc-iosevka-ss18 7.1.1-1 7.2.2-2
ttf-sarasa-gothic 0.32.6-1 0.32.9-1
typescript 4.3.4-1 4.3.5-1
uglify-js 3.13.9-1 3.13.10-1
umockdev 0.15.5-1 0.16.0-1
v2ray-domain-list-community 20210625061329-1 20210701083009-1
v2ray-geoip 202106240309-1 202107010026-1
vaultwarden 1.21.0-1 1.22.1-1
verilator 4.200-1 4.204-1
virt-viewer 10.0-1 10.0-2
vmpk 0.8.3-1 0.8.4-1
vultr-cli 2.5.2-2 2.5.3-1
wireplumber 0.4.0-2 0.4.1-1
wireplumber-docs 0.4.0-2 0.4.1-1
wlroots 0.13.0-1 0.14.0-1
xapp 2.2.1-1 2.2.2-1
xdebug 3.0.2-2 3.0.4-1
xed 3.0.1-1 3.0.2-1
xreader 3.0.1-1 3.0.2-1
xwallpaper 0.7.0-1 0.7.1-1
zita-njbridge 0.4.4-2 0.4.8-1
zps 1.2.5-1 1.2.7-1
aspell-da - 1.6.36-1
editline - 1.17.1-2
libseat - 0.5.0-2
mellite - 3.5.5-1
mixxx - 2.3.0-1
nix - 2.3.13-2
nomad - 1.1.2-1
nomad-driver-containerd - 0.8-2
nomad-driver-lxc - 0.3.0-2
nomad-driver-nspawn - 0.7.0-2
nomad-driver-podman - 0.3.0-1
perl-cpanel-json-xs - 4.26-3
perl-goocanvas2-cairotypes - 0.001-4
perl-json-maybexs - 1.004003-2
pijul - 1.0.0_alpha.48-1
python-halo - 0.0.31-2
python-hid - 1.0.4-3
python-ijson - 3.1.4-1
python-log_symbols - 0.0.14-2
python-requests-unixsocket - 0.2.0-4
python-spinners - 0.0.24-1
shutter - 0.97-2
singularity-container - 3.8.0-1
sound-gambit - 0.6-1
:: Different overlay package(s) in repository core aarch64
gnupg 2.2.28-2.2 2.2.28-2.3
linux 5.12.13-1 5.13.0-1
linux-aml 5.12.0-1 5.13.rc5-1
linux-aml-headers 5.12.0-1 5.13.rc5-1
linux-headers 5.12.13-1 5.13.0-1
linux-pinephone 5.12.12-1 5.12.13-1
linux-pinephone-headers 5.12.12-1 5.12.13-1
linux-rpi4 5.10.44-1 5.10.46-1
linux-rpi4-headers 5.10.44-1 5.10.46-1
linux-vim 5.12.9-1 5.13.0-1
linux-vim-headers 5.12.9-1 5.13.0-1
manjaro-release 21.06-1 21.07-1
raspberrypi-bootloader 20210623-1 20210628-1
raspberrypi-bootloader-x 20210623-1 20210628-1
:: Different sync package(s) in repository core aarch64
dialog 1:1.3_20210530-1 1:1.3_20210621-1
gdbm 1.19-2 1.20-1
gpgme 1.15.1-1 1.16.0-1
iana-etc 20210202-1 20210624-1
iproute2 5.12.0-1 5.13.0-1
libksba 1.4.0-2 1.6.0-1
pcre 8.44-1 8.45-1
python-gpgme 1.15.1-1 1.16.0-1
qgpgme 1.15.1-1 1.16.0-1
:: Different overlay package(s) in repository extra aarch64
alsa-card-profiles1:0.3.30+85+ga168e4261-1 -
gst-plugin-pipewire1:0.3.30+85+ga168e4261-1 -
libdrm-pinebookpro 2.4.106-1 2.4.107-1
manjaro-arm-flasher 0.5-2 0.6-1
mesa-git21.2.0_devel.141349.b4d90b1182a-121.2.0_devel.141748.e74366b18a3-1
nm-tray-git r163.259b866-1 r202.cda09d7-1
pipewire-alsa1:0.3.30+85+ga168e4261-1 -
pipewire-docs1:0.3.30+85+ga168e4261-1 -
pipewire-jack1:0.3.30+85+ga168e4261-1 -
pipewire-media-session1:0.3.30+85+ga168e4261-1 -
pipewire-pulse1:0.3.30+85+ga168e4261-1 -
pipewire-zeroconf1:0.3.30+85+ga168e4261-1 -
qt5-es2-base 5.15.2+kde+r200-1 5.15.2+kde+r203-1
:: Different sync package(s) in repository extra aarch64
alsa-card-profiles 1:0.3.30-2 1:0.3.31-1
arch-install-scripts 24-1 24-2
blas 3.9.1-1 3.10.0-1
cblas 3.9.1-1 3.10.0-1
enchant 2.2.15-4 2.3.0-1
fontconfig 2:2.13.93-4 2:2.13.94-1
fprintd 1.90.9-1 1.92.0-1
gd 2.3.2-3 2.3.2-4
glu 9.0.1-2 9.0.2-1
gst-plugin-pipewire 1:0.3.30-2 1:0.3.31-1
imath 3.0.4-2 3.0.5-1
kdsoap 1.10.0-1 2.0.0-1
kdsoap-ws-discovery-client git20200927-1 git20200927-2
kimageformats 5.83.0-2 5.83.0-3
kio-extras 21.04.2-1 21.04.2-2
lapack 3.9.1-1 3.10.0-1
lapack-doc 3.9.1-1 3.10.0-1
lapacke 3.9.1-1 3.10.0-1
libcerf 1:1.16-1 1:1.17-1
libfprint 1.90.7-1 1.92.0-1
libgit2 1:1.1.0-1 1:1.1.1-1
libnm 1.32.0-1 1.32.2-1
mariadb 10.5.10-1 10.5.11-1
mariadb-clients 10.5.10-1 10.5.11-1
mariadb-libs 10.5.10-1 10.5.11-1
mytop 10.5.10-1 10.5.11-1
networkmanager 1.32.0-1 1.32.2-1
nm-cloud-setup 1.32.0-1 1.32.2-1
pango 1:1.48.5-1 1:1.48.6-1
pango-docs 1:1.48.5-1 1:1.48.6-1
php 8.0.7-1 8.0.8-1
php-apache 8.0.7-1 8.0.8-1
php-cgi 8.0.7-1 8.0.8-1
php-dblib 8.0.7-1 8.0.8-1
php-embed 8.0.7-1 8.0.8-1
php-enchant 8.0.7-1 8.0.8-1
php-fpm 8.0.7-1 8.0.8-1
php-gd 8.0.7-1 8.0.8-1
php-imap 8.0.7-1 8.0.8-1
php-intl 8.0.7-1 8.0.8-1
php-odbc 8.0.7-1 8.0.8-1
php-pgsql 8.0.7-1 8.0.8-1
php-phpdbg 8.0.7-1 8.0.8-1
php-pspell 8.0.7-1 8.0.8-1
php-snmp 8.0.7-1 8.0.8-1
php-sodium 8.0.7-1 8.0.8-1
php-sqlite 8.0.7-1 8.0.8-1
php-tidy 8.0.7-1 8.0.8-1
php-xsl 8.0.7-1 8.0.8-1
pipewire-alsa 1:0.3.30-2 1:0.3.31-1
pipewire-docs 1:0.3.30-2 1:0.3.31-1
pipewire-jack 1:0.3.30-2 1:0.3.31-1
pipewire-media-session 1:0.3.30-2 1:0.3.31-1
pipewire-pulse 1:0.3.30-2 1:0.3.31-1
pipewire-zeroconf 1:0.3.30-2 1:0.3.31-1
powerdevil 5.22.2.1-1 5.22.2.1-2
pyalpm 0.10.4-1 0.10.5-1
pyside6 6.1.1-1 6.1.2-1
python-asgiref 3.3.4-1 3.4.1-1
python-django 3.2.4-1 3.2.5-1
qt5-base 5.15.2+kde+r203-1 5.15.2+kde+r207-1
qt5-xcb-private-headers 5.15.2+kde+r203-1 5.15.2+kde+r207-1
qt6-3d 6.1.1-1 6.1.2-1
qt6-5compat 6.1.1-1 6.1.2-1
qt6-base 6.1.1-1 6.1.2-1
qt6-charts 6.1.1-1 6.1.2-1
qt6-datavis3d 6.1.1-1 6.1.2-1
qt6-declarative 6.1.1-1 6.1.2-1
qt6-doc 6.1.1-1 6.1.2-1
qt6-examples 6.1.1-1 6.1.2-1
qt6-imageformats 6.1.1-1 6.1.2-1
qt6-lottie 6.1.1-1 6.1.2-1
qt6-networkauth 6.1.1-1 6.1.2-1
qt6-quick3d 6.1.1-1 6.1.2-1
qt6-quickcontrols2 6.1.1-1 6.1.2-1
qt6-quicktimeline 6.1.1-1 6.1.2-1
qt6-scxml 6.1.1-1 6.1.2-1
qt6-shadertools 6.1.1-1 6.1.2-1
qt6-svg 6.1.1-1 6.1.2-1
qt6-tools 6.1.1-1 6.1.2-1
qt6-translations 6.1.1-1 6.1.2-1
qt6-virtualkeyboard 6.1.1-1 6.1.2-1
qt6-wayland 6.1.1-1 6.1.2-1
rubygems 3.2.19-1 3.2.21-1
shiboken6 6.1.1-1 6.1.2-1
tomcat10 10.0.7-1 10.0.8-1
tomcat8 8.5.68-1 8.5.69-1
tomcat9 9.0.48-1 9.0.50-1
unison 2.51.2-10 2.51.3-1
zita-resampler 1.6.2-3 1.8.0-1
adobe-source-sans-fonts - 3.042-1
adobe-source-serif-fonts - 4.004-2
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi-calendar21.04.2.r1943.g1b0574f-121.04.2.r1944.gf896763-1
akonadi-calendar-tools21.04.2.r868.g42ea166-121.04.2.r869.g7e8b4be-1
akonadi-contacts21.04.2.r3018.gd44c6a3d-121.04.2.r3019.g3ebd8c70-1
akonadi-import-wizard21.04.2.r1711.g1c2dd7a-121.04.2.r1713.g868f978-1
akonadi-mime21.04.2.r1622.g66d238f-121.04.2.r1623.g3edcb1b-1
akonadi-notes21.04.2.r1006.g44ff2e9-121.04.2.r1007.gf075b89-1
akonadi-search21.04.2.r1099.g5e6c95e-121.04.2.r1100.g19cde5a-1
akonadiconsole21.04.2.r1494.g53f2254-121.04.2.r1495.gbcbd584-1
akregator21.04.2.r6162.g6e37bcd1-121.04.2.r6167.gbbef7d65-1
alligator 21.06.r1.g840fa21-1 21.06.r3.g6494e0e-1
ark21.04.2.r4546.gbc4de85d-121.04.2.r4549.g179fb90e-1
attica5.83.0.r820.g040d354-15.83.0.r820.g040d354-2
baloo5.83.0.r2992.gfae7732d-15.83.0.r2992.gfae7732d-2
bluez-qt5.83.0.r663.g814d455-15.83.0.r664.gffacc11-2
breeze5.22.2.r2217.gb81a5be7-15.22.2.1.r2218.gfce6f4e0-1
breeze-icons5.83.0.r1754.g0a3ab844-15.83.0.r1754.g0a3ab844-2
buho 1.2.2.r25.g623328b-1 1.2.2.r29.g5cb0188-1
calendarsupport21.04.2.r548.gbdd983c-121.04.2.r555.g2ac1a78-1
discover5.22.2.1.r8210.g982ac596-15.22.2.1.r8214.gb4be338e-1
dolphin21.04.2.r6621.g216068bd7-121.04.2.r6624.gcc962cae4-1
dolphin-plugins21.04.2.r579.gbfbea81-121.04.2.r584.gf9309d9-1
dragon21.04.2.r1002.gee142db-121.04.2.r1003.g16c7b9f-1
drkonqi5.22.2.1.r651.g7de900d3-15.22.2.1.r657.g8d7ff484-1
elisa21.04.2.r2726.gad91882f-121.04.2.r2727.gee28f06a-1
eventviews21.04.2.r661.gdb38ce8-121.04.2.r662.gb75379f-1
extra-cmake-modules5.83.0.r3326.g9e63248-15.83.0.r3330.g58731b0-2
ffmpegthumbs21.04.2.r186.g13c89b9-121.04.2.r188.g00f9186-1
filelight21.04.2.r973.g6b7a453-121.04.2.r975.ge6664ed-1
frameworkintegration5.83.0.r587.g254467b-15.83.0.r587.g254467b-2
granatier21.04.2.r920.g0be7bc4-121.04.2.r921.g9c7e554-1
grantlee-editor21.04.2.r747.g9a2aef5-121.04.2.r748.g78d239e-1
grantleetheme21.04.2.r325.gd54967c-121.04.2.r326.g99e0d43-1
gwenview21.04.2.r6620.g9763d196-121.04.2.r6628.g89bfe886-1
incidenceeditor21.04.2.r727.g2f550a0-121.04.2.r728.gfd12b98-1
index-fm 1.2.2.r67.ge6a4f2f-1 1.2.2.r76.g4985fd8-1
itinerary21.04.2.r1331.g142589f-121.04.2.r1339.g6d444ee-1
k3b1:21.04.2.r6635.g48c4376c7-11:21.04.2.r6644.gcaa29afe2-1
kaccounts-providers21.04.2.r377.ge2cb245-121.04.2.r381.gd5e0c45-1
kactivities5.83.0.r1350.g0fa2366-15.83.0.r1350.g0fa2366-2
kactivities-stats5.83.0.r358.gc6c3655-15.83.0.r358.gc6c3655-2
kaddressbook21.04.2.r5987.g2139dc89-121.04.2.r5991.gbb5f088e-1
kalarm21.04.2.r6388.g25afc764-121.04.2.r6390.g76656661-1
kalarmcal21.04.2.r1115.ga8e996f-121.04.2.r1116.gc3d0dc8-1
kalk 21.06.r4.g71f8cbe-1 21.06.r5.g0ef70be-1
kapidox5.83.0.r530.g0e9021e-15.83.0.r530.g0e9021e-2
karchive5.83.0.r487.gd5e1928-15.83.0.r489.g8c290d1-1
kasts 21.06.r25.g03081ed-1 21.06.r33.gacef37f-1
kate21.04.2.r18238.gff6318286-121.04.2.r18252.g1cea8a677-1
kauth5.83.0.r437.g3d69fa9-15.83.0.r437.g3d69fa9-2
kbackup21.04.2.r375.g46ca1f4-121.04.2.r376.g79be946-1
kblackbox21.04.2.r719.g2d5a886-121.04.2.r721.g77a58d5-1
kblocks21.04.2.r635.gf020ddf-121.04.2.r637.g4ee95b8-1
kbookmarks5.83.0.r409.g4270cd1-15.83.0.r409.g4270cd1-2
kbounce21.04.2.r797.gd4295c9-121.04.2.r799.gfdce48d-1
kbreakout21.04.2.r852.g3347459-121.04.2.r855.gc80c29c-1
kcalc21.04.2.r1506.g945ab22-121.04.2.r1507.gf4f095a-1
kcalendarcore5.83.0.r1216.gdd6cfda70-15.83.0.r1216.gdd6cfda70-2
kcalutils21.04.2.r848.g3f45545b3-121.04.2.r849.g6a7b3bb6f-1
kcmutils5.83.0.r518.g14c94b8-15.83.0.r521.g276a88e-2
kcodecs5.83.0.r372.gf0ff68d-15.83.0.r372.gf0ff68d-2
kcolorchooser21.04.2.r220.g1d56f55-121.04.2.r222.g255ab9a-1
kcompletion5.83.0.r445.g1c592f7-15.83.0.r445.g1c592f7-2
kconfig5.83.0.r841.g74a861c-15.83.0.r841.g74a861c-2
kconfigwidgets5.83.0.r589.gcda5b24-15.83.0.r591.geb4f326-2
kcontacts1:5.83.0.r3243.g97085a69-11:5.83.0.r3243.g97085a69-2
kcoreaddons5.83.0.r1234.g885eb01c-15.83.0.r1237.g200239c1-2
kcrash5.83.0.r389.ge536b60-15.83.0.r389.ge536b60-2
kdav1:5.83.0.r1288.g735ff1b-11:5.83.0.r1288.g735ff1b-2
kdbusaddons5.83.0.r366.g12b8637-15.83.0.r367.g80a309c-2
kde-gtk-config5.22.2.1.r894.g666717b-15.22.2.1.r895.g93da65a-1
kdeclarative5.83.0.r898.g51d942f-15.83.0.r900.gf5a17e9-2
kdeconnect21.04.2.r3260.g4d868a2e-121.04.2.r3269.g0d2a15c4-1
kded5.83.0.r405.gabec334-15.83.0.r406.g1dadf7a-2
kdegraphics-mobipocket21.04.2.r258.g036fd81-121.04.2.r259.g9c61298-1
kdegraphics-thumbnailers21.04.2.r232.gcade343-121.04.2.r233.g3f941f1-1
kdelibs4support5.82.0.r1023.gee8bd6c6-15.83.0.r1023.gee8bd6c6-2
kdepim-addons21.04.2.r4142.gaa21bb42-121.04.2.r4182.g56a89c3c-1
kdepim-runtime21.04.2.r15126.g18bc7e436-121.04.2.r15132.gdf1a495bb-1
kdeplasma-addons5.22.2.1.r8535.g0bab97f6b-15.22.2.1.r8547.g8a8ba22a2-1
kdesignerplugin5.83.0.r327.g5a75ff1-15.83.0.r327.g5a75ff1-2
kdesu5.83.0.r466.g1980f27-15.83.0.r466.g1980f27-2
kdewebkit5.82.0.r273.g8f16e7c-15.83.0.r273.g8f16e7c-2
kdf21.04.2.r787.g8ebda46-121.04.2.r789.g18fb281-1
kdiamond21.04.2.r660.g7ff443b-121.04.2.r663.g2e79b99-1
kdnssd5.83.0.r314.gbecf0ea-15.83.0.r314.gbecf0ea-2
kdoctools5.83.0.r612.g70e1ca7-15.83.0.r612.g70e1ca7-2
keditbookmarks21.04.2.r2738.g5e122c923-121.04.2.r2739.gfc1e52c7a-1
kemoticons5.83.0.r375.gd716cdb-15.83.0.r375.gd716cdb-2
kfilemetadata5.83.0.r797.g16c2da9-15.83.0.r797.g16c2da9-2
kgamma55.22.2.1.r455.gdb6a51b-15.22.2.1.r456.g5885d2f-1
kget21.04.2.r3099.g06f334d4-121.04.2.r3108.g85a2f746-1
kglobalaccel5.83.0.r449.g05fafb1-15.83.0.r450.ge32cc99-2
kgoldrunner21.04.2.r1224.gb5994ad-121.04.2.r1226.gb5325c0-1
kguiaddons5.83.0.r375.g0cd8751-15.83.0.r376.g2a9ae43-2
khangman21.04.2.r1557.g7f579fb-121.04.2.r1558.gd42fff7-1
khelpcenter21.04.2.r2669.gcb558930-121.04.2.r2670.g8ad58850-1
kholidays1:5.83.0.r940.g94f52b4-11:5.83.0.r940.g94f52b4-2
khtml5.82.0.r548.g8540c72-15.83.0.r548.g8540c72-2
ki18n5.83.0.r468.g0826840-15.83.0.r468.g0826840-2
kiconthemes5.83.0.r527.g1bc8432-15.83.0.r528.g4dbe2df-2
kidentitymanagement21.04.2.r3784.g8a99ae7e-121.04.2.r3785.ge6290153-1
kidletime5.83.0.r305.g5e3bada-15.83.0.r305.g5e3bada-2
kigo21.04.2.r510.gac7465a-121.04.2.r513.gb11bf39-1
killbots21.04.2.r724.g32c950b-121.04.2.r725.g11e9d29-1
kimageformats5.83.0.r343.g1b2bf6e-15.83.0.r343.g1b2bf6e-2
kimap21.04.2.r1092.g5c60902-121.04.2.r1094.g0fe0e54-1
kinit5.83.0.r402.g9d3629e-15.83.0.r402.g9d3629e-2
kio5.83.0.r4814.gc881bae5-15.83.0.r4820.g44d9f763-2
kio-extras21.04.2.r7062.g932c70eb-121.04.2.r7063.ga5e17084-1
kirigami25.83.0.r2818.gc7ed245d-15.83.0.r2820.ga7689f8d-2
kitemmodels5.82.0.r544.g48bf306-15.83.0.r544.g48bf306-2
kitemviews5.83.0.r329.gc590771-15.83.0.r329.gc590771-2
kiten21.04.2.r1139.g148bd1e-121.04.2.r1140.g10c4ca4-1
kitinerary21.04.2.r1810.ge456b67-121.04.2.r1813.gc0f6757-1
kjobwidgets5.83.0.r367.g2206ec1-15.83.0.r367.g2206ec1-2
kjs5.83.0.r328.g0d0145a-15.83.0.r328.g0d0145a-2
kjsembed5.82.0.r297.gf32de40-15.83.0.r297.gf32de40-2
kldap21.04.2.r863.ga63a231-121.04.2.r864.gda9332a-1
kleopatra21.04.2.r5896.g3fe2c461-121.04.2.r5907.g08d42db6-1
kmag21.04.2.r686.g745e2fb-121.04.2.r687.g8a3d886-1
kmail-account-wizard21.04.2.r783.g62c32d0-121.04.2.r784.g4ff0660-1
kmailtransport21.04.2.r1612.gf1ec5f4-121.04.2.r1613.g5f549b4-1
kmbox21.04.2.r521.gcef25bd-121.04.2.r522.g5d18026-1
kmediaplayer5.82.0.r289.g7c9045b-15.83.0.r289.g7c9045b-2
kmime21.04.2.r1434.g00b4a86-121.04.2.r1435.gd813506-1
kmix21.04.2.r2368.g400c9a59-121.04.2.r2369.g28a3450a-1
knewstuff5.83.0.r1178.gc1c9e09d-15.83.0.r1178.gc1c9e09d-2
knotes21.04.2.r3464.g875e7b1a-121.04.2.r3466.g330d3c98-1
knotifications5.83.0.r663.g7837d42-15.83.0.r664.g8afb010-2
knotifyconfig5.82.0.r345.g38fd196-15.83.0.r345.g38fd196-2
konqueror21.04.2.r14908.g2e8d30e3e-121.04.2.r14912.g5ef5bf6a2-1
konsole21.04.2.r7854.gc5aa11c3-121.04.2.r7862.g7cbbc88c-1
kontact21.04.2.r5325.g6a52ea45-121.04.2.r5328.g56050423-1
kontactinterface21.04.2.r613.gf10a1c5-121.04.2.r615.gd712c47-1
konversation21.04.2.r8973.g72499d41-121.04.2.r8980.g179805d3-1
kopeninghours21.04.2.r265.g2d24fcf-121.04.2.r266.g95e49b8-1
korganizer21.04.2.r11391.g045966b02-121.04.2.r11395.ged70d5136-1
kosmindoormap21.04.2.r614.gdd1d0a8-121.04.2.r615.g8d46d30-1
kpackage5.83.0.r670.g5cb0ec5-15.83.0.r671.gf617caf-2
kparts5.83.0.r510.g577607c-15.83.0.r510.g577607c-2
kpat21.04.2.r2553.g27477e7-121.04.2.r2555.g4e44cd3-1
kpeople5.82.0.r1333.gb793989-15.83.0.r1333.gb793989-2
kpeoplesink r68.g9533e23-1 r69.g889321f-3
kpimtextedit21.04.2.r1386.gb4c8fd8-121.04.2.r1387.gc173318-1
kpkpass21.04.2.r218.ga182f77-121.04.2.r225.g3e64e9b-1
kplotting5.83.0.r284.g4f0e792-15.83.0.r284.g4f0e792-2
kpty5.83.0.r328.gbbfabe3-15.83.0.r328.gbbfabe3-2
kpublictransport21.04.2.r1685.g8c9777f4-121.04.2.r1688.g1c5cf816-1
kquickcharts5.82.0.r463.g6ec02ab-15.83.0.r463.g6ec02ab-2
kquicksyntaxhighlighter r1.g69d2f40-2 -
kross5.82.0.r327.gce48a10-15.83.0.r327.gce48a10-2
kruler21.04.2.r688.gfe6e2fe-121.04.2.r689.g5d12ffa-1
krunner5.82.0.r633.g28b5d54-15.83.0.r635.g8e246cc-2
kscreen5.22.2.1.r1335.ge958e6c-15.22.2.1.r1336.ge6feadd-1
kscreenlocker5.22.2.1.r854.g01ebc2c-15.22.2.1.r856.g372a234-1
kservice5.83.0.r920.gd0b3434-15.83.0.r921.gfc55736-2
kshisen21.04.2.r1192.ga835d04-121.04.2.r1193.gaaf1e14-1
ksmtp21.04.2.r350.g108f328-121.04.2.r351.g169f0fe-1
ksnakeduel21.04.2.r791.g2c074eb-121.04.2.r792.g4240078-1
kspaceduel21.04.2.r620.g35aa5a3-121.04.2.r621.gf4072ce-1
ktexteditor5.82.0.r2892.gdb1d2a0a-15.83.0.r2896.ge3c373a6-2
ktextwidgets5.83.0.r401.g1bec4bc-15.83.0.r401.g1bec4bc-2
ktnef21.04.2.r648.gd374f3e-121.04.2.r649.g0325699-1
ktorrent21.04.2.r2749.g0e891e0b-121.04.2.r2753.g81378576-1
ktouch21.04.2.r2133.g7496746-121.04.2.r2134.g59d2fbf-1
ktrip 21.06.r17.gb03efd0-1 21.06.r21.g7d13e51-1
kubrick21.04.2.r362.gcd11cfe-121.04.2.r363.g6b31f81-1
kunitconversion5.83.0.r367.gbe47ed6-15.83.0.r367.gbe47ed6-2
kwallet5.83.0.r1072.g1725111-15.83.0.r1072.g1725111-2
kwalletmanager21.04.2.r1196.g039e8dd-121.04.2.r1197.g0cf5f7a-1
kwayland5.83.0.r1092.g2bcebf1-15.83.0.r1093.g2634a19-2
kwayland-integration5.22.2.1.r178.ge419293-15.22.2.1.r179.g5901512-1
kwayland-server5.22.2.1.r1340.g3481dbc-15.22.2.1.r1341.g63bd0e3-1
kwidgetsaddons5.83.0.r830.g980f2242-15.83.0.r830.g980f2242-2
kwin5.22.2.1.r19589.g6260c0354-15.22.2.1.r19597.gf54d7a269-1
kwindowsystem5.83.0.r596.g5413356-15.83.0.r596.g5413356-2
kwrite21.04.2.r18238.gff6318286-121.04.2.r18252.g1cea8a677-1
kwrited5.22.2.1.r478.gb687e84-15.22.2.1.r479.g8d34f29-1
kxmlgui5.83.0.r783.g61eaf5cf-15.83.0.r784.g8df0baa5-2
kxmlrpcclient5.82.0.r450.g179493558-15.83.0.r450.g179493558-2
layer-shell-qt5.21.5.r41.g9af3c35-15.21.5.r42.gf6084b2-1
libgravatar21.04.2.r352.g9c0bd2d-121.04.2.r353.g8714f65-1
libkdegames21.04.2.r2176.gd266fa40-121.04.2.r2179.g27e8411d-1
libkdepim21.04.2.r832.g7a57630-121.04.2.r833.g148711e-1
libkgapi21.04.2.r1279.g373fb68-121.04.2.r1280.g4d67b6d-1
libkleo21.04.2.r904.g9207554-121.04.2.r907.g33b28a9-1
libkmahjongg21.04.2.r451.g48071bc-121.04.2.r452.g51782b7-1
libksane21.04.2.r538.g8386ec5-121.04.2.r539.g9a3ab2a-1
libksieve21.04.2.r1532.gb4336e9d-121.04.2.r1533.gefe5c81a-1
libktorrent21.04.2.r517.g852b0b4-121.04.2.r519.gdb6f72a-1
libquotient r2001.g466fe1a-1 r2002.gac8a448-1
mailcommon21.04.2.r1040.g04587be-121.04.2.r1041.g3e6fa73-1
mailimporter21.04.2.r455.g8eafa65-121.04.2.r456.g62c206b-1
maliit-framework0.99.1.r63.g932d1b01-10.99.1.r65.g2d2b7ac3-1
maliit-keyboard r2088.g81bfdd24-1 r2088.g81bfdd24-2
marble21.04.2.r13313.g06b07adfd-121.04.2.r13314.g227816388-1
marble-common21.04.2.r13313.g06b07adfd-121.04.2.r13314.g227816388-1
marble-qt21.04.2.r13313.g06b07adfd-121.04.2.r13314.g227816388-1
markdownpart21.04.2.r71.g3bcb59e-121.04.2.r73.g9189ff3-1
maui-clip 1.1.1.r6.ge2ad9ab-1 1.1.1.r8.gb3d9db9-1
maui-nota 1.2.2.r38.gbd9302c-1 1.2.2.r44.g82927e9-1
maui-pix 1.2.2.r39.ga3c2b86-1 1.2.2.r50.g7b5b00d-1
mauikit2.2.2.r100.gd9ba87c9-12.2.2.r114.g9ec618c8-1
mauikit-accounts r3.c3ff058-1 r6.8f01110-1
mauikit-filebrowsing 1.2.2.r48.g887cabe-1 1.2.2.r57.g0134185-1
mbox-importer21.04.2.r495.g4e6522a-121.04.2.r497.g56b4d69-1
messagelib21.04.2.r6049.g890724f2-121.04.2.r6054.g8274c804-1
milou5.22.2.1.r744.g01f3b8b-15.22.2.1.r745.g65c72f4-1
modemmanager-qt5.82.0.r510.gc2d3596-15.83.0.r510.gc2d3596-2
neochat r1774.g92eb06aa-1 r1779.g6bbb4b49-1
networkmanager-qt5.82.0.r1107.g677b986-15.83.0.r1107.g677b986-2
okular21.04.2.r9377.gbded651d9-121.04.2.r9382.gd8845025f-1
oxygen5.22.2.1.r4416.g0b1b8ff7-15.22.2.1.r4422.g5c8c3271-1
oxygen-icons1:5.82.0.r5.gbff159d-11:5.83.0.r5.gbff159d-2
oxygen-icons-svg1:5.82.0.r5.gbff159d-11:5.83.0.r5.gbff159d-2
pim-data-exporter21.04.2.r2413.g16a0cbc6-121.04.2.r2414.g54219a58-1
pimcommon21.04.2.r1055.g5dd16c8-121.04.2.r1056.ga49b86c-1
plasma-browser-integration5.22.2.1.r1263.g3f5613ae-15.22.2.1.r1266.gdc031190-1
plasma-desktop5.22.2.1.r8525.g948fb7d5a-15.22.2.1.r8531.gf3e9dbf86-1
plasma-firewall5.22.2.1.r494.gcdf6465-15.22.2.1.r496.gbdd33c0-1
plasma-framework5.83.0.r15888.g8953e77ec-15.83.0.r15899.gd809e9e4d-1
plasma-integration5.22.2.1.r518.g7b512cc-15.22.2.1.r519.gf7c25d9-1
plasma-nano5.21.5.r150.gefb823e-15.21.5.r151.gcf01c43-1
plasma-nm5.22.2.1.r3058.g52d08d51-15.22.2.1.r3060.g1f6b9980-1
plasma-pa5.22.2.1.r947.g0fdf808-15.22.2.1.r948.ga6d63ee-1
plasma-phone-components5.22.2.1.r1421.gbacfccd3-15.22.2.1.r1422.g844be837-1
plasma-systemmonitor5.22.2.1.r455.gb7d2634-15.22.2.1.r459.g03165f5-1
plasma-wayland-session5.22.2.1.r10411.g60ab32584-15.22.2.1.r10417.g211897b07-1
plasma-workspace5.22.2.1.r10411.g60ab32584-15.22.2.1.r10417.g211897b07-1
plasma-workspace-wallpapers5.22.2.1.r275.g6188c5b-15.22.2.1.r276.gdadaf13-1
powerdevil5.22.2.1.r2441.gfe3d1dfb-15.22.2.1.r2442.g93e441d9-1
print-manager21.04.2.r1026.g88a09c9-121.04.2.r1028.ga67b660-1
prison5.82.0.r318.gdad8665-15.83.0.r318.gdad8665-2
purpose5.82.0.r861.g7ae34b9-15.83.0.r861.g7ae34b9-2
qmlkonsole 21.06.r2.g9ba0d8d-1 21.06.r3.g8ec415c-1
qqc2-desktop-style5.82.0.r492.g5a1561c-15.83.0.r492.g5a1561c-2
qt5-es2-base 5.15.2+kde+r203-1 -
sddm-kcm5.22.2.1.r586.gf4e241d-15.22.2.1.r587.g4fd430d-1
solid5.83.0.r680.gef0b0df-15.83.0.r682.g8f12a27-2
sonnet5.83.0.r619.g248722a-15.83.0.r619.g248722a-2
spacebar 21.06.r8.gc6edf0e-1 21.06.r18.g126ded9-1
spectacle21.04.2.r1113.gd5fdfc8-121.04.2.r1114.ge5f0001-1
svgpart21.04.2.r166.gcca88a1-121.04.2.r168.gc4138f0-1
syndication5.82.0.r831.gfaf12a7-15.83.0.r831.gfaf12a7-2
syntax-highlighting5.83.0.r1609.g58a8047f-15.83.0.r1614.ga83a61be-1
systemsettings5.22.2.1.r2444.gf046054a-15.22.2.1.r2446.g45956103-1
telepathy-kde-approver21.04.2.r293.g45db24b-121.04.2.r294.g6594053-1
telepathy-kde-desktop-applets21.04.2.r992.g4a74f96-121.04.2.r993.g24d97f9-1
threadweaver5.83.0.r501.g156fdb6-15.83.0.r501.g156fdb6-2
tokodon 21.06.r9.g41f79ed-1 21.06.r11.g99c47b5-1
vvave 1.2.2.r30.gbf74851-1 1.2.2.r40.gd794531-1
xdg-desktop-portal-kde5.22.2.1.r369.g0a7996e-15.22.2.1.r371.gdbfd020-1
yakuake21.04.2.r721.g172cf89-121.04.2.r722.g0eb3a30-1
zeroconf-ioslave21.04.2.r349.g373ceaa-121.04.2.r351.g2df5266-1
linux-aml - 5.13.0-0.5
linux-aml-headers - 5.13.0-0.5
mauikit-imagetools - 1.2.2.r14.g3d4db50-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
