Hello ARM community.
A rather small update, but it brings in a few key components for future developments.
Manjaro ARM now boots on the Quartz64!
Some highlights:
- Most of our kernels got updated
- Introducing ButterManager and Snapper GUI to the repository for managing btrfs snapshots
- NetworkManager is updated to version 1.32
- Lots of Mobile specific packages got updated
- Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss
package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip
and firewalld
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Tue Jun 22 15:59:27 CEST 2021)
- arm-testing community aarch64: 225 new and 184 removed package(s)
- arm-testing core aarch64: 20 new and 17 removed package(s)
- arm-testing extra aarch64: 58 new and 59 removed package(s)
- arm-testing kde-unstable aarch64: 198 new and 198 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-06-17 2021-06-22
buteo-syncfw-git 0.10.6.r0.gbb85bcf-1 0.10.7.r0.gb88bd53-1
eg25-manager 0.3.0+2+g64145ac-8 0.3.0+6+gf2593b6-1
electron 13.1.2-1 13.1.3-1
electron11 11.4.7-2 11.4.9-1
electron12 12.0.11-2 12.0.12-1
glacier-gallery-git 0.2.3.r17.g7c87a52-1 0.2.3.r22.g8f8f87c-1
greetd-qtgreet 1.0.0beta-1 1.0.0-1
libcommhistory-git 1.11.9.r0.g9fe0cd4-11.11.10.r0.g334caec-1
libqofono-qt5 0.100-2 0.103-2
libva-utils 2.8.0-1.1 2.11.1-0.1
mapplauncherd-git 4.1.43.r0.g9970c11-1 4.2.3.r0.g3f37ded-1
matray 1.0.1-3 1.0.1-4
mce-git1.106.6.r0.gf4644db-21.106.7.r0.g9c6a089-1
nemo-qml-plugin-contentaction-git 0.3.18.r0.g8ae69f3-1 0.4.1.r0.g4c870ce-1
nemo-qml-plugin-devicelock-git 0.3.5.r0.g3569d10-1 0.3.6.r0.gf10be30-1
qt5-contacts-sqlite-extensions-git 0.3.13.r0.gb89ddca-2 0.3.14.r0.gcff793e-1
qt5-glacier-app-git 0.6.r4.gcb16f90-1 0.7.r0.g464593a-1
qt5-ngfd-git 0.6.5.r0.gaabfd51-1 0.7.0.r0.gac87734-1
qt5-quickcontrols-nemo-git 5.5.2.r1.gbee1f9d-1 5.5.3.r5.g28bc59c-1
qtdocgallery-gitmer.5.2.0+git12.r3.g382232a-1mer.5.2.0+git12.r40.ga8fdaf6-1
upower-mobile 0.99.11-2 0.99.11-3
vivaldi 4.0.2312.27-1 4.0.2312.33-1
voicecall-git 0.7.11.r0.ga188e61-1 0.7.11.r0.ga188e61-4
yay 10.2.3-1 10.2.3-2
buttermanager - 2.4.1-1
commhistory-daemon-git - 0.8.38.r0.g7e00f4a-1
cor-git - 0.1.21.r0.g9b06f7b-1
dsme-git - 0.83.1.r0.gd9c5940-1
fingerterm-git - 1.4.2.r0.gebcdb39-1
glacier-browser-git - 0.1.r2.gae35d42-1
glacier-settings-git - 0.1.3.r17.g9d3c1ed-1
libdsme - 0.66.6-1
libprolog - 1.2.1.r0.g0d33632-1
libtrace-ohm -1.1.8+git4.r0.g02376f9-1
maliit-nemo-keyboard-git -0.99.2.r12.g7eb4c0fa-1
mapplauncherd-booster-qtcomponents-git - 0.2.0.r2.g22a307e-1
mce-plugin-libhybris-nonandroid-git - 1.12.3.r5.g2ae52dd-1
mkcal-git - 0.5.43.r0.g40f1205-1
nemo-qml-plugin-connectivity-git - 0.2.7.r0.g891d345-1
nemo-qml-plugin-messages-git - 0.1.30.r0.g6d05d2a-1
nemo-qml-plugin-models - 0.2.1-1
nodejs-lts-fermium - 14.17.1-0.1
pulseaudio-modules-nemo -14.2.30.r0.gd0dfdc3-1
pulsecore-headers - 14.2-1
qmf-qt5-git - 4.0.4.131-1
qt5-ofono-nemo-extensions-git - 1.0.27.r0.gebe45e0-4
qt5-qpa-hwcomposer-plugin - 5.15-1
quartz64-post-install - 20210618-1
snapper-gui - 0.1.r7.gf0c67ab-1
:: Different sync package(s) in repository community aarch64
age 1.0.0rc.2-1 1.0.0rc.3-1
apm 2.6.1-4 2.6.3-1
atomicparsley20210114.184825.1dbe1be-220210617.200601.1ac7c08-1
awxkit 19.2.0-1 19.2.1-1
blender 17:2.93.0-4 17:2.93.0-7
borgmatic 1.5.14-1 1.5.15-1
buildah 1.21.0-1 1.21.1-1
caddy 2.4.2-1 2.4.3-1
calc 2.12.7.1-2 2.13.0.1-1
cargo-c 0.8.1-1 0.8.2-1
cargo-udeps 0.1.21-1 0.1.22-1
ccze 0.2.1-11 0.2.1-12
cni-plugins 0.9.1-3 0.9.1-4
containers-common 0.39.0-4 0.40.1-1
croc 9.1.6-1 9.2.0-1
crun 0.20-1 0.20.1-1
dqlite 1.7.0-1 1.8.0-1
drupal 9.1.10-1 9.2.0-1
eclib 20210503-2 20210503-3
electrum 4.1.2-1 4.1.3-1
elinks 0.14.0-1 0.14.1-1
eslint 7.28.0-1 7.29.0-1
espeakup 0.80-3 0.90-1
firefox-tree-style-tab 3.8.3-1 3.8.4-1
firefox-ublock-origin 1.35.2-1 1.36.0-1
flawfinder 2.0.11-1 2.0.17-1
flint 2.7.1-1 2.7.1-2
fortune-mod 2.12.0-1 3.6.1-1
fwupd-efi 1.0-1 1.1-1
gdnsd 3.6.0-1 3.7.0-1
giac 1.7.0.13-1 1.7.0.13-2
go-ethereum 1.10.3-1 1.10.4-1
gtkwave 3.3.108-1 3.3.110-1
gtop 1.1.0-1 1.1.1-1
haproxy 2.4.0-1 2.4.1-1
helm 3.6.0-1 3.6.1-1
hugo 0.83.1-1 0.84.0-1
influxdb 2.0.6-1 2.0.7-1
iperf3 3.9-1 3.10.1-1
jedi-language-server 0.31.2-1 0.32.0-3
kconfig-hardened-check 0.5.9-2 0.5.10-1
keepass 2.47-1 2.48.1-1
kid3 3.8.6-2 3.8.7-1
kid3-common 3.8.6-2 3.8.7-1
kid3-qt 3.8.6-2 3.8.7-1
krename 5.0.1-2 5.0.1-3
latte-integrale 1.7.6-1 1.7.6-2
leptonica 1.80.0-1 1.81.0-1
libconfig 1.7.2-3 1.7.3-1
libesmtp 1.0.6-7 1.1.0-1
libmediainfo 20.09-2 21.03-1
libretro-bsnes-hd 45-1 47-1
libretro-core-info 1.9.4-1 1.9.5-1
libretro-nestopia 1:57-1 1:60-1
libretro-play 6546-1 6549-1
libretro-shaders-slang 812-1 814-1
libslirp 4.5.0-1 4.6.1-1
libzen 0.4.38-2 0.4.39-1
lv2file 0.84-2 0.84-3
lynis 2.7.5-2 3.0.4-1
maim 5.6.3-4 5.7.4-1
mathjax 3.1.4-1 3.2.0-1
matrix-appservice-irc 0.26.1-1 0.27.0-1
mediainfo 20.09-1 21.03-1
mediainfo-gui 20.09-1 21.03-1
mednafen 1.26.1-1 1.27.1-1
miniupnpc 2.1.20191224-3 2.2.2-1
miniupnpd 2.1.20191006-1 2.2.2-1
mypy 0.812-2 0.902-1
neochat 1.2.0-1 1.2.0-2
newsboat 2.23-1 2.24-1
nginx-mainline 1.19.10-1 1.21.0-1
nginx-mainline-src 1.19.10-1 1.21.0-1
npm-check-updates 11.6.0-2 11.7.1-1
ntl 11.4.4-1 11.5.0-1
openvdb 8.0.1-5 8.1.0-1
operator-sdk 1.8.0-1 1.9.0-1
perl-io-tty 1.12-11 1.16-1
perl-sub-exporter 0.987-7 0.988-1
php-imagick 3.4.4.r66.g448c1cd-3 3.5.0-1
php7-imagick 3.4.4.r66.g448c1cd-3 3.5.0-1
podman 3.2.0-1 3.2.1-1
podman-docker 3.2.0-1 3.2.1-1
prosody 1:0.11.9-1 1:0.11.9-2
pyright 1.1.149-1 1.1.151-1
python-anyio 3.1.0-1 3.2.0-1
python-backcall 0.2.0-3 0.2.0-4
python-black 21.6b0-1 21.6b0-2
python-blosc 1.10.2-1 1.10.4-1
python-characteristic 14.3.0-11 14.3.0-12
python-elementpath 2.2.2-1 2.2.3-1
python-et-xmlfile 1.0.1-9 1.1-1
python-fields 5.0.0-9 5.0.0-10
python-flufl.bounce 3.0.2-1 4.0-1
python-gitlab 2.7.1-1 2.8.0-1
python-gitpython 3.1.17-1 3.1.18-1
python-httpcore 0.13.3-1 0.13.6-1
python-httpx 0.18.1-1 0.18.2-1
python-josepy 1.8.0-1 1.8.0-2
python-libtmux 0.9.0-1 0.10.1-1
python-matplotlib 3.4.1-2 3.4.2-1
python-matrix-nio 0.18.2-1 0.18.3-1
python-meilisearch 0.14.2-1 0.15.1-1
python-miniupnpc 2.1.20191224-3 2.2.2-1
python-praw 7.2.0-1 7.3.0-1
python-process-tests 2.1.2-1 2.1.2-2
python-pyee 8.1.0-2 8.1.0-3
python-pygit2 1.5.0-1 1.6.1-1
python-pygls 0.10.3-2 0.10.3-3
python-pyicu 2.7.3-1 2.7.4-1
python-pyppeteer 0.2.5-1 0.2.5-2
python-pytest-cache 1.0-8 -
python-pytest-cov 2.12.1-1 2.12.1-3
python-pytest-helpers-namespace 2019.1.8-3 2021.4.29-1
python-pytest-isort 2.0.0-1 2.0.0-2
python-pytest-timeout 1.4.2-3 1.4.2-4
python-pytest-xdist 2.2.1-1 2.3.0-1
python-rich 10.3.0-1 10.4.0-1
python-scipy 1.6.3-1 1.7.0-1
python-starlette 0.13.8-3 0.14.2-1
python-terminado 0.9.4-1 0.10.1-1
python-xlsxwriter 1.4.0-1 1.4.3-1
python2-characteristic 14.3.0-11 -
python2-fields 5.0.0-9 -
python2-process-tests 2.1.2-1 -
python2-pytest-cache 1.0-8 -
python2-pytest-cov 2.12.1-1 -
python2-pytest-timeout 1.4.2-3 1.4.2-4
qgis 3.18.3-2 3.20.0-1
qtermwidget 0.17.0-1 0.17.0-2
raft 0.11.0-1 0.11.1-1
recoll 1.30.1-1 1.31.0-1
remind 3.3.6-1 3.3.7-1
rofimoji 5.1.0-2 5.2.0-2
rsnapshot 1.4.3-1 1.4.4-1
ruby27-semantic_puppet 1.0.3-1 1.0.3-2
rust-analyzer 20210614-1 20210621-1
scribus 1.5.6.1-14 1.5.7-1
singular 4.2.1-1 4.2.1-2
skaffold 1.26.0-1 1.26.1-1
skk-jisyo 20210523-1 20210613-1
slirp4netns 1.1.10-1 1.1.11-1
sopel 7.1.0-1 7.1.1-1
sshfs 3.7.1-1 3.7.2-1
starship 0.54.0-1 0.55.0-1
streamlink 2.1.1-1 2.2.0-1
tcsh 6.22.03-1 6.22.04-1
terragrunt 0.30.3-1 0.30.7-1
tmuxp 1.8.2-1 1.9.2-1
tor 0.4.5.9-1 0.4.6.5-1
tpm2-tools 5.1-1 5.1.1-1
ttf-ionicons 5.5.1-1 5.5.2-1
ttf-sarasa-gothic 0.32.4-1 0.32.6-1
typescript 4.3.2-1 4.3.4-1
v2ray-domain-list-community 20210616081836-1 20210621183458-1
v2ray-geoip 202106100026-1 202106170022-1
virt-viewer 9.0-1 10.0-1
vultr-cli 2.5.2-1 2.5.2-2
wxsqlite3 4.7.2-1 4.7.3-1
yoshimi 2.0.1-1 2.0.2-1
criu - 3.15-2
distrobuilder - 1.2-2
dovecot-fts-xapian - 1.4.9b-1
endless-sky - 0.9.13-2
endless-sky-high-dpi - 0.9.13-2
freeipmi - 1.6.8-3
goimapnotify - 2.3.2-1
html-xml-utils - 8.0-2
leocad - 21.06-2
pypiserver - 1.4.2-1
python-beniget - 0.3.0-2
python-cligj - 0.7.2-1
python-fiona - 1.8.20-1
python-memory-allocator - 0.1.0-1
python-pythran - 0.9.11-2
python-setuptools-declarative-requirements - 1.2.0-1
python-setuptools-scm-git-archive - 1.1-2
sieve-connect - 0.90-2
ssh-audit - 2.4.0-2
ttf-monoid - 0.61-7
wasmer - 2.0.0-2
xsimd - 7.5.0-1
:: Different overlay package(s) in repository core aarch64
linux 5.12.11-1 5.12.12-1
linux-headers 5.12.11-1 5.12.12-1
linux-pinephone 5.12.11-1 5.12.12-1
linux-pinephone-headers 5.12.11-1 5.12.12-1
linux-quartz64 5.12.0-0.2 5.13.0-0.4
linux-quartz64-headers 5.12.0-0.2 5.13.0-0.4
linux-rc 5.13.rc6-1 5.13.rc7-1
linux-rc-headers 5.13.rc6-1 5.13.rc7-1
linux-rpi4 5.10.43-1 5.10.44-1
linux-rpi4-headers 5.10.43-1 5.10.44-1
boot-jetson-nano - 20210621-1
rpi-eeprom - 20210611-1
uboot-quartz64-bsp - 2017.09-0.6
:: Different sync package(s) in repository core aarch64
gnupg 2.2.28-1 2.2.28-2
lemon 3.35.5-2 3.36.0-1
mkinitcpio-busybox 1.32.1-3 1.33.1-1
sqlite 3.35.5-2 3.36.0-1
sqlite-analyzer 3.35.5-2 3.36.0-1
sqlite-doc 3.35.5-2 3.36.0-1
sqlite-tcl 3.35.5-2 3.36.0-1
:: Different overlay package(s) in repository extra aarch64
calamares-arm-oem 20210614-1 20210621-1
libpamac 11.0.0-2 11.0.1-2
libpamac-flatpak-plugin 11.0.0-2 11.0.1-2
libpamac-snap-plugin 11.0.0-2 11.0.1-2
libva 2.11.0-0.1 2.12.0-0.1
mesa-git21.2.0_devel.140990.aa14851340f-121.2.0_devel.141349.b4d90b1182a-1
okular 21.04.2-1.1 21.04.2-2
pamac-cli 10.1.3-1 10.1.3-3
pamac-common 10.1.3-1 -
pamac-flatpak-plugin 10.1.2-2 -
pamac-gnome-integration 10.1.3-1 10.1.3-3
pamac-gtk 10.1.3-1 10.1.3-3
pamac-snap-plugin 10.1.2-2 -
:: Different sync package(s) in repository extra aarch64
bind 9.16.16-1 9.16.18-1
chromium 91.0.4472.106-1 91.0.4472.114-1
cmake 3.20.4-1 3.20.5-1
cmark 0.29.0-2 0.30.0-2
cyrus-sasl 2.1.27-4 2.1.27-5
cyrus-sasl-gssapi 2.1.27-4 2.1.27-5
cyrus-sasl-ldap 2.1.27-4 2.1.27-5
cyrus-sasl-sql 2.1.27-4 2.1.27-5
discover 5.22.1-1 5.22.1-2
dracut 053-1 055-1
editorconfig-core-c 0.12.4-1 0.12.5-1
exiv2 0.27.3-1 0.27.4-2
flatpak 1.11.1-2 1.11.2-1
graphviz 2.47.2-1 2.47.3-1
hunspell-en_au 2020.12.07-2 2020.12.07-3
hunspell-en_ca 2020.12.07-2 2020.12.07-3
hunspell-en_gb 2020.12.07-2 2020.12.07-3
hunspell-en_us 2020.12.07-2 2020.12.07-3
imagemagick 7.1.0.0-1 7.1.0.1-1
imagemagick-doc 7.1.0.0-1 7.1.0.1-1
kdenlive 21.04.2-1 21.04.2-2
libhandy 1.2.2-1 1.2.3-1
libnm 1.30.4-3 1.32.0-1
libsidplayfp 2.1.2-1 2.2.0-1
mkvtoolnix-cli 58.0.0-1 58.0.0-2
mkvtoolnix-gui 58.0.0-1 58.0.0-2
mono 6.12.0.107-1 6.12.0.122-1
mtools 1:4.0.29-1 1:4.0.31-1
networkmanager 1.30.4-3 1.32.0-1
nm-cloud-setup 1.30.4-3 1.32.0-1
openvpn 2.5.2-1 2.5.3-1
perl-libwww 6.54-2 6.55-1
polkit-qt5 0.113.0-2 0.114.0-1
prometheus 2.27.1-1 2.28.0-1
python-pip 20.3.2-1 20.3.3-1
python2-pip 20.3.2-1 20.3.3-1
qbs 1.19.0-1 1.19.1-1
qt5-base 5.15.2+kde+r196-1 5.15.2+kde+r199-1
qt5-script 5.15.4-1 5.15.5-2
qt5-webengine 5.15.4-3 5.15.5-1
qt5-xcb-private-headers 5.15.2+kde+r196-1 5.15.2+kde+r199-1
rust 1:1.52.1-3 1:1.53.0-1
rust-docs 1:1.52.1-3 1:1.53.0-1
syslog-ng 3.32.1-1 3.32.1-2
upower 0.99.11-3 0.99.12-2
vlc 3.0.15-2 3.0.16-1
llvm11 - 11.1.0-3
llvm11-libs - 11.1.0-3
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi-contacts21.04.2.r3012.g2ad01454-121.04.2.r3016.g683e2200-1
akonadi-search21.04.2.r1096.gb4eb1a4-121.04.2.r1099.g5e6c95e-1
akonadiconsole21.04.2.r1491.g51f6550-121.04.2.r1492.g042c5f5-1
akregator21.04.2.r6149.g6d7224f1-121.04.2.r6159.g6bd05c73-1
angelfish 21.06.r9.gba77dd7-1 21.06.r10.g0861230-1
attica5.83.0.r818.g68b4a0a-15.83.0.r820.g040d354-1
baloo5.83.0.r2990.gac8622e5-15.83.0.r2992.gfae7732d-1
bluez-qt5.83.0.r662.g7981287-15.83.0.r663.g814d455-1
breeze5.22.0.r2216.g44c36a8a-15.22.0.r2217.gb81a5be7-1
breeze-icons5.83.0.r1752.g4f9badf6-15.83.0.r1754.g0a3ab844-1
buho 1.2.2.r21.gc2ec80b-1 1.2.2.r23.g13ab408-1
calendarsupport21.04.2.r539.gfa9ad2e-121.04.2.r548.gbdd983c-1
calindori 21.06.r3.g7c02410-1 21.06.r4.g2b9bfcc-1
discover5.22.0.r8207.g17de49c3-15.22.0.r8209.g6c14423c-1
dolphin21.04.2.r6608.gf8fccec14-121.04.2.r6610.g5e79f27ae-1
drkonqi5.22.0.r648.gb3d75b38-15.22.0.r651.g7de900d3-1
elisa21.04.2.r2722.g086853a4-121.04.2.r2725.gc23e3212-1
extra-cmake-modules5.83.0.r3323.gc3bada8-15.83.0.r3325.g65c50ed-1
filelight21.04.2.r968.gdbae689-121.04.2.r973.g6b7a453-1
frameworkintegration5.83.0.r586.ga8986c7-15.83.0.r587.g254467b-1
grantlee-editor21.04.2.r746.gc49daa5-121.04.2.r747.g9a2aef5-1
gwenview21.04.2.r6618.g53330827-121.04.2.r6619.g3f269685-1
index-fm 1.2.2.r54.g16b2ad9-1 1.2.2.r62.ga9945a2-1
itinerary21.04.2.r1325.g9778350-121.04.2.r1329.gf5e1972-1
kactivities5.83.0.r1349.g92832d8-15.83.0.r1350.g0fa2366-1
kactivities-stats5.83.0.r356.g6c0afc7-15.83.0.r357.g3423532-1
kaddressbook21.04.2.r5974.g4df5c2ee-121.04.2.r5987.g2139dc89-1
kajongg21.04.2.r4186.gfe75232f-121.04.2.r4192.g94794aef-1
kalarm21.04.2.r6384.g51620133-121.04.2.r6388.g25afc764-1
kalgebra21.04.2.r2031.g0d339a4-121.04.2.r2033.g7da0ef8-1
karchive5.83.0.r486.gd9f727b-15.83.0.r487.gd5e1928-1
kasts 21.06.r9.g0c7e5ca-1 21.06.r20.gf42c011-1
kate21.04.2.r18222.gd61ad889e-121.04.2.r18230.g553dede89-1
kauth5.83.0.r436.g6b59cbf-15.83.0.r437.g3d69fa9-1
kbackup21.04.2.r374.g2334cf5-121.04.2.r375.g46ca1f4-1
kbookmarks5.83.0.r408.g35319dc-15.83.0.r409.g4270cd1-1
kcalc21.04.2.r1496.gb0d8681-121.04.2.r1504.gb3b91f3-1
kcalendarcore5.83.0.r1213.ge497e0a4c-15.83.0.r1216.gdd6cfda70-1
kcharselect21.04.2.r463.gde270f8-121.04.2.r466.g1846940-1
kclock 21.06.r8.g56f2491-1 21.06.r11.gcde0e5b-1
kcmutils5.83.0.r517.g1ebddb5-15.83.0.r518.g14c94b8-1
kcodecs5.83.0.r370.g6067fc3-15.83.0.r372.gf0ff68d-1
kcompletion5.83.0.r444.g57b17e8-15.83.0.r445.g1c592f7-1
kconfig5.83.0.r839.gc5a8157-15.83.0.r841.g74a861c-1
kconfigwidgets5.83.0.r582.g4e2c3ab-15.83.0.r587.ge48ec4f-1
kcontacts1:5.83.0.r3242.g96fb2310-11:5.83.0.r3243.g97085a69-1
kcoreaddons5.83.0.r1229.g7527e2a9-15.83.0.r1231.g6b20aed8-1
kcrash5.83.0.r388.g2211c9e-15.83.0.r389.ge536b60-1
kcron21.04.2.r770.g4db14db-121.04.2.r773.gd10d4db-1
kdav1:5.83.0.r1286.g3d074ed-11:5.83.0.r1288.g735ff1b-1
kdbusaddons5.83.0.r365.g065df36-15.83.0.r366.g12b8637-1
kde-dev-scripts21.04.2.r4132.g8b1162a-121.04.2.r4134.gf26db2d-1
kdebugsettings21.04.2.r808.g93c237b-121.04.2.r809.gf363133-1
kdeclarative5.83.0.r897.g4b6b175-15.83.0.r898.g51d942f-1
kdeconnect21.04.2.r3232.gf33fed6f-121.04.2.r3251.gfb8646b3-1
kded5.83.0.r404.gb7a1dd8-15.83.0.r405.gabec334-1
kdegraphics-thumbnailers21.04.2.r231.g224d34b-121.04.2.r232.gcade343-1
kdelibs4support5.82.0.r1021.g8cc57d3e-15.82.0.r1023.gee8bd6c6-1
kdenlive21.04.2.r14523.gee7a141b1-121.04.2.r14524.g185b30362-1
kdepim-addons21.04.2.r4128.gce6182b3-121.04.2.r4130.gc6212fc9-1
kdepim-runtime21.04.2.r15118.gc5bae74d7-121.04.2.r15122.g84efdeae9-1
kdesdk-thumbnailers21.04.2.r82.g736fabf-121.04.2.r83.gb498057-1
kdesignerplugin5.83.0.r326.gbb2a8ce-15.83.0.r327.g5a75ff1-1
kdesu5.83.0.r464.g78cd928-15.83.0.r466.g1980f27-1
kdewebkit5.82.0.r271.gefee461-15.82.0.r273.g8f16e7c-1
kdialog21.04.2.r1180.gd4f172738-121.04.2.r1181.g8b80e3786-1
kdnssd5.83.0.r311.gac26712-15.83.0.r314.gbecf0ea-1
kdoctools5.83.0.r611.g9d5ab52-15.83.0.r612.g70e1ca7-1
kemoticons5.83.0.r374.g716775b-15.83.0.r375.gd716cdb-1
kfilemetadata5.83.0.r793.g32ac7f7-15.83.0.r797.g16c2da9-1
kfloppy21.04.2.r749.ge3ecf6a-121.04.2.r750.g2aad2a3-1
kfourinline21.04.2.r974.g3e4a6f2-121.04.2.r975.gcabd9a4-1
kglobalaccel5.83.0.r447.g6d281dd-15.83.0.r448.gc586603-1
kguiaddons5.83.0.r367.ge5263d1-15.83.0.r370.g897f832-1
kholidays1:5.83.0.r935.gd8497e9-11:5.83.0.r939.ga040cdc-1
khtml5.82.0.r547.g5ac7996-15.82.0.r548.g8540c72-1
ki18n5.83.0.r467.gd0beae8-15.83.0.r468.g0826840-1
kiconthemes5.83.0.r526.g5a974b7-15.83.0.r527.g1bc8432-1
kidletime5.83.0.r304.g21faaef-15.83.0.r305.g5e3bada-1
kigo21.04.2.r509.gacd3663-121.04.2.r510.gac7465a-1
kimageformats5.83.0.r341.gef6be2c-15.83.0.r343.g1b2bf6e-1
kimagemapeditor21.04.2.r458.gfceb8af-121.04.2.r465.ga69f3d1-1
kimap21.04.2.r1091.g6eddbfb-121.04.2.r1092.g5c60902-1
kinfocenter5.22.0.r1849.g0a630f5-15.22.0.r1851.g144d702-1
kinit5.83.0.r400.g2ca0a1d-15.83.0.r402.g9d3629e-1
kio5.83.0.r4788.gb012616b-15.83.0.r4803.geae7e8f5-1
kio-extras21.04.2.r7057.g63dbd5f7-121.04.2.r7060.g2289e25d-1
kio-gdrive21.04.2.r555.ga7f26c5-121.04.2.r556.g9824d74-1
kirigami25.83.0.r2811.g8f128b17-15.83.0.r2815.g2965a0bf-1
kitemmodels5.82.0.r542.g2df6568-15.82.0.r544.g48bf306-1
kitemviews5.83.0.r327.g0da5de7-15.83.0.r329.gc590771-1
kiten21.04.2.r1138.g54e1359-121.04.2.r1139.g148bd1e-1
kitinerary21.04.2.r1807.g59f1aba-121.04.2.r1808.g15906f3-1
kjobwidgets5.83.0.r364.gfc520a5-15.83.0.r366.g7a542d1-1
kjs5.83.0.r327.g553d5a5-15.83.0.r328.g0d0145a-1
kjsembed5.82.0.r296.g704b86e-15.82.0.r297.gf32de40-1
kleopatra21.04.2.r5874.g63f6116b-121.04.2.r5886.g86365f33-1
kmag21.04.2.r684.g5bac8b7-121.04.2.r686.g745e2fb-1
kmahjongg21.04.2.r1461.g0c18f1c-121.04.2.r1464.g80e61ed-1
kmailtransport21.04.2.r1609.ga273799-121.04.2.r1611.g5943484-1
kmediaplayer5.82.0.r288.gf63aabc-15.82.0.r289.g7c9045b-1
kmix21.04.2.r2367.ged18b68d-121.04.2.r2368.g400c9a59-1
knavalbattle21.04.2.r1378.g866bcbc-121.04.2.r1379.g70ebfeb-1
knewstuff5.83.0.r1175.gb53a1a4d-15.83.0.r1178.gc1c9e09d-1
knotes21.04.2.r3460.g5a3e2a33-121.04.2.r3462.g472a32b7-1
knotifications5.83.0.r660.g323418f-15.83.0.r663.g7837d42-1
knotifyconfig5.82.0.r343.gcc773de-15.82.0.r344.gf267604-1
koko 21.06.r2.g6dc2200-1 21.06.r8.g2e87dcb-1
kongress 21.06.r2.g4c2f21b-1 21.06.r3.g7bd2104-1
konqueror21.04.2.r14904.gfb9f052e4-121.04.2.r14907.gff02a25ea-1
konsole21.04.2.r7829.gacad0e34-121.04.2.r7838.g10e0abd9-1
kontact21.04.2.r5323.g62544fe0-121.04.2.r5324.g116c663c-1
konversation21.04.2.r8968.g30099b04-121.04.2.r8972.gf14918f2-1
korganizer21.04.2.r11378.g8575f281f-121.04.2.r11388.g459fb1046-1
kosmindoormap21.04.2.r612.gf2a1151-121.04.2.r614.gdd1d0a8-1
kpackage5.83.0.r668.g36cf5e2-15.83.0.r670.g5cb0ec5-1
kparts5.83.0.r508.g1d6b59c-15.83.0.r509.g7efe521-1
kpat21.04.2.r2548.gc30fa25-121.04.2.r2553.g27477e7-1
kpeople5.82.0.r1329.g85aac13-15.82.0.r1332.g4128996-1
kpeoplevcard 0.1.r11.gba721cb-1 0.1.r12.g04e0c18-1
kpimtextedit21.04.2.r1384.g1729196-121.04.2.r1385.gf98c2e6-1
kplotting5.83.0.r283.g40b6613-15.83.0.r284.g4f0e792-1
kpty5.83.0.r327.gaacc592-15.83.0.r328.gbbfabe3-1
kpublictransport21.04.2.r1671.g94a1db3-121.04.2.r1678.g93a0ac10-1
kquickcharts5.82.0.r461.g12d18ba-15.82.0.r463.g6ec02ab-1
krdc21.04.2.r1524.g93ba7b5-121.04.2.r1525.gd59e362-1
krfb21.04.2.r1397.g073cec3-121.04.2.r1399.g0316c37-1
kross5.82.0.r326.g4c67e48-15.82.0.r327.gce48a10-1
krunner5.82.0.r632.g0a770bc-15.82.0.r633.g28b5d54-1
kscreen5.22.0.r1333.g5178938-15.22.0.r1335.ge958e6c-1
kservice5.83.0.r916.g5b57328-15.83.0.r919.g04319a2-1
kshisen21.04.2.r1187.g1666233-121.04.2.r1191.g4e93806-1
ksystemlog21.04.2.r636.g95a942e-121.04.2.r640.gae84fb5-1
ktexteditor5.82.0.r2878.g821d0f1f-15.82.0.r2890.g8e45dcd5-1
ktextwidgets5.83.0.r400.gc2efa56-15.83.0.r401.g1bec4bc-1
ktrip 21.06.r14.g19158ee-1 21.06.r16.gb35a850-1
kunitconversion5.83.0.r365.gb1914c1-15.83.0.r366.g5d0b597-1
kwallet5.83.0.r1070.g1a0dabb-15.83.0.r1072.g1725111-1
kwallet-pam5.22.0.r244.gb93e8c6-15.22.0.r248.ge91fcbe-1
kwayland5.83.0.r1091.g9ef1184-15.83.0.r1092.g2bcebf1-1
kwayland-server5.22.0.r1334.g53fa053-15.22.0.r1338.g125a119-1
kweather 21.06.r4.g22689d7-1 21.06.r23.gc33b809-1
kwidgetsaddons5.83.0.r826.gddc6cd2d-15.83.0.r829.g80771830-1
kwin5.22.0.r19554.g2f3a425c5-15.22.0.r19570.g19699e9a2-1
kwindowsystem5.83.0.r595.gdc0cc57-15.83.0.r596.g5413356-1
kwinft5.22.0.r18909.g1620a5368-15.22.0.r18960.g58b46353e-1
kwrite21.04.2.r18222.gd61ad889e-121.04.2.r18230.g553dede89-1
kxmlgui5.83.0.r775.g2fac5e05-15.83.0.r781.g5d1001ba-1
kxmlrpcclient5.82.0.r449.g8381cc83b-15.82.0.r450.g179493558-1
libkdegames21.04.2.r2175.g40f1d5da-121.04.2.r2176.gd266fa40-1
libkdepim21.04.2.r831.g7709e80-121.04.2.r832.g7a57630-1
libkleo21.04.2.r892.g525fb65-121.04.2.r902.g997bce9-1
libkmahjongg21.04.2.r448.gc7aa7ac-121.04.2.r451.g48071bc-1
libksane21.04.2.r529.gce99272-121.04.2.r537.g1a57ace-1
libkscreen5.22.0.r1582.g3b3c78f-15.22.0.r1583.gd916c2a-1
lokalize21.04.2.r1759.g07fa320-121.04.2.r1765.gc4d0843-1
maliit-keyboard r2084.g7fa6308e-1 r2088.g81bfdd24-1
maui-clip 1.1.1.r4.g148deda-1 1.1.1.r5.gd32d0fd-1
maui-nota 1.2.2.r36.gbed4091-1 1.2.2.r37.gbcc1844-1
maui-pix 1.2.2.r34.gfd57b21-1 1.2.2.r37.g32f5dad-1
mauikit2.2.2.r75.g3d99a423-12.2.2.r91.g39f93829-1
mauikit-filebrowsing 1.2.2.r40.g9226e44-1 1.2.2.r43.g08ccdca-1
messagelib21.04.2.r6018.gbc7b861a-121.04.2.r6040.gd53fb428-1
modemmanager-qt5.82.0.r509.g553bfcb-15.82.0.r510.gc2d3596-1
neochat r1757.g9961483f-1 r1770.g211f6004-1
networkmanager-qt5.82.0.r1106.g83ec746-15.82.0.r1107.g677b986-1
okular21.04.2.r9371.g96135236c-121.04.2.r9377.gbded651d9-1
oxygen5.22.0.r4415.ga5a7f382-15.22.0.r4416.g0b1b8ff7-1
parley21.04.2.r4409.g32cb840a-121.04.2.r4410.g5f463910-1
plasma-browser-integration5.22.0.r1261.gb24e2d7d-15.22.0.r1263.g3f5613ae-1
plasma-desktop5.22.0.r8493.g81e433848-15.22.0.r8504.g59cf85008-1
plasma-disks5.22.0.r214.gf6191b3-15.22.0.r215.g1b3667c-1
plasma-framework5.83.0.r15878.g44a8e6c1e-15.83.0.r15886.gb2f821ad2-1
plasma-nm5.22.0.r3057.ge8c90783-15.22.0.r3058.g52d08d51-1
plasma-pa5.22.0.r946.gda83ea3-15.22.0.r947.g0fdf808-1
plasma-phone-components5.22.0.r1420.g7ef50d4a-15.22.0.r1421.gbacfccd3-1
plasma-systemmonitor5.22.0.r452.gee54596-15.22.0.r453.gcfe7b0d-1
plasma-vault5.22.0.r335.gb971ea2-15.22.0.r336.g2b49118-1
plasma-wayland-session5.22.0.r10391.g70edbdfd2-15.22.0.r10409.g018fc0dee-1
plasma-workspace5.22.0.r10391.g70edbdfd2-15.22.0.r10409.g018fc0dee-1
plasma-workspace-wallpapers5.22.0.r274.g85f50aa-15.22.0.r275.g6188c5b-1
powerdevil5.22.0.r2440.g5c5df988-15.22.0.r2441.gfe3d1dfb-1
prison5.82.0.r317.g8690fd5-15.82.0.r318.gdad8665-1
purpose5.82.0.r860.ga28fab0-15.82.0.r861.g7ae34b9-1
qqc2-desktop-style5.82.0.r490.g568363f-15.82.0.r491.gf9598d7-1
sddm-kcm5.22.0.r585.gaa73d52-15.22.0.r586.gf4e241d-1
solid5.83.0.r676.gdd6b1c8-15.83.0.r679.g0e98339-1
sonnet5.83.0.r618.g965b56d-15.83.0.r619.g248722a-1
spacebar 21.06.r2.g5457a15-1 21.06.r7.g2ace395-1
spectacle21.04.2.r1109.g0f7c130-121.04.2.r1111.gd6b13e4-1
sweeper21.04.2.r520.g10e3008-121.04.2.r521.g6399bd3-1
syndication5.82.0.r827.gcb77b6b-15.82.0.r831.gfaf12a7-1
syntax-highlighting5.83.0.r1595.g163c36c9-15.83.0.r1604.g7820533e-1
systemsettings5.22.0.r2441.g3245a297-15.22.0.r2443.g7b42e31e-1
threadweaver5.83.0.r499.g8b92b77-15.83.0.r501.g156fdb6-1
tokodon 21.06.r4.g8035b8f-1 21.06.r7.gf6ff075-1
vvave 1.2.2.r23.g37c29bb-1 1.2.2.r26.g58b2c24-1
wrapland5.22.0.r1471.gfd438e9-15.22.0.r1474.g64c4443-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
