Hello ARM community.
Here’s another rather small testing update, but some important things are included.
Cutefish is a plasma/kirigami based desktop environment with a focus on touch
Some highlights:
- Most of our kernels got updated, plus we added
linux-aml
which is specifically packaged for AMLogic boards -
Electron got updated to version 13. Version 12 is available with
electron12
package - The Cutefish desktop is now in the repository
- Mesa is updated to version 21.1.1
- QT6 got a new point release with version 6.1.0
- An update to perl 5.34 resulted in lots of perl packages getting updated. Did we miss a rebuild?
- Lots of Mobile specific packages got updated
- Many python packages got updated
If anyone wants to test kodi on the rpi:
Change to the unstable or testing branch and install kodi packages:
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss
package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip
and firewalld
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Sun May 30 15:41:30 CEST 2021)
- arm-testing community aarch64: 704 new and 687 removed package(s)
- arm-testing core aarch64: 30 new and 28 removed package(s)
- arm-testing extra aarch64: 307 new and 296 removed package(s)
- arm-testing kde-unstable aarch64: 388 new and 382 removed package(s)
- arm-testing mobile aarch64: 0 new and 2 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-05-23 2021-05-30
alsa-ucm-pinephone 0.3.1-11 0.4.0-1
calls 0.3.3+1+g2ac43f3-1 0.3.3+1+g2ac43f3-4
chatty 0.3.0+11+ge3c0d0a-1 0.3.1+9+gd637a4e-1
electron 12.0.9-1 13.0.1-1
element-desktop 1.7.28-1 1.7.29-1
element-web 1.7.28-1 1.7.29-1
kirigami-addons 1:0.1-1 -
kodi-rpi 19.1-5 19.1-6
kodi-rpi-dev 19.1-5 19.1-6
kodi-rpi-eventclients 19.1-5 19.1-6
kodi-rpi-tools-texturepacker 19.1-5 19.1-6
libmm-pp-glib 1.16.4-3 1.16.4-4
modemmanager-pp 1.16.4-3 1.16.4-4
oc4-post-install 20210125-1 20210530-1
ofonoctl 0.4.0-5.3 0.4.0-6
on2-post-install 20210125-1 20210528-1
phosh0.10.2+134+gb2e68d2-20.10.2+167+gee065b5-1
pinephone-manjaro-tweaks 20210415-1 20210529-2
plasma-dialer 21.05-1 21.05-2
postmarketos-tweaks-app 0.5.0-1 0.6.1+9+g9c1e940-1
postmarketos-tweaks-app-phosh 0.5.0-1 0.6.1+9+g9c1e940-1
rpi-imager 1.6.1-2 1.6.2-1
siglo 0.8.0-1 0.8.0-2
snapd 2.50.1-1 2.51-1
spectral-matrix-git 218.r643.gd600947-1 -
upower-mobile 0.99.11-1 0.99.11-2
audiotube - 0.1-1
electron12 - 12.0.9-1
fuzzel - 1.5.4-1
python-ytmusicapi - 0.17.3-1
:: Different sync package(s) in repository community aarch64
ack 3.5.0-1 3.5.0-2
acpica 20210105-1 20210331-1
age 1.0.0rc.1-2 1.0.0rc.2-1
airspy 1.0.9-2 1.0.10-1
ali 0.5.4-4 0.6.1-1
ansible-core 2.11.0-4 2.11.1-1
ansible-lint 5.0.10-2 5.0.11-1
apitrace 9.0-4 10.0-1
archlinux-repro 20210422-1 20210529-1
argocd 2.0.1-1 2.0.3-1
b4 0.6.2-2 0.7.0-1
backuppc 4.4.0-3 4.4.0-4
baidupcs-go 3.7.9-1 3.8.0-1
bettercap 2.31.0-1 2.31.1-1
biber 1:2.15-1 1:2.15-2
caddy 2.3.0-1 2.4.1-1
catfish 4.16.0-3 4.16.0-4
chezmoi 2.0.12-1 2.0.13-1
cimg 2.9.4-1 2.9.6-1
clojure 1.10.3.839-1 1.10.3.849-1
cobalt 0.16.4-1 0.16.5-1
cockpit 244.1-1 245-1
cockpit-pcp 244.1-1 245-1
cockpit-podman 30-1 31-1
coq 8.13.1-1 8.13.2-1
coq-doc 8.13.1-1 8.13.2-1
coqide 8.13.1-1 8.13.2-1
cpanminus 1.7044-4 1.7044-5
cpp-hocon 0.3.0-4 0.3.0-5
d-feet 0.3.15-3 0.3.16-1
dante 1.4.2-4 1.4.3-1
dark-reader 4.9.32-1 4.9.33-1
dart 2.13.0-1 2.13.1-1
dd_rescue 1.99.8-3 1.99.9-1
diff-so-fancy 1.4.0-1 1.4.1-1
diffoscope 175-1 176-1
distcc 3.3.5-3 3.4-3
djview 4.12-1 4.12-2
dnssec-tools 2.2.3-6 2.2.3-7
dot2tex 2.11.3-3 2.11.3-4
drumkv1 0.9.21-2 0.9.22-1
epic4 2.10.10-1 2.10.10-2
esmska 1.9.2-1 -
exfalso 4.4.0-1 -
facter 3.14.16-2.1 3.14.16-3
fcitx5-material-color 0.0.0.20201212-2 0.2.1-1
feeluown-kuwo 0.1.3-1 0.1.4-1
firefox-dark-reader 4.9.32-1 4.9.33-1
fluxctl 1.21.1-2 1.22.2-1
freeradius 3.0.22-1 3.0.22-2
gauche 0.9.10-2 0.9.10-3
gdal 3.2.3-1 3.2.3-2
gdnsd 3.5.0-2 3.5.1-1
geotag 0.103-2 0.103-3
glances 3.1.5-2 3.1.7-1
glyr 1.0.10-2 1.0.10-3
go-tools 4:0.1.1-1 4:0.1.2-1
goaccess 1.4.6-2 1.5-1
gpick 0.2.6rc1-10 0.2.6-1
gpscorrelate 2.0-1 2.0-2
gpxsee 8.9-1 9.0-1
grunt-cli 1.4.2-1 1.4.3-1
gummi 2:0.8.1-2 2:0.8.2-1
hamlib 3.3-9 3.3-10
haproxy 2.3.10-1 2.4.0-1
hcloud 1.22.1-1 1.23.0-1
hcxdumptool 6.1.6-1 6.2.0-1
hcxtools 6.1.6-1 6.2.0-1
helm 3.5.4-1 3.6.0-1
helmfile 0.138.7-1 0.139.7-1
hexchat 2.14.3-7 2.14.3-8
hivex 1.3.20-1 1.3.20-5
imvirt 0.9.6-7 0.9.6-8
inn 2.6.4-1 2.6.4-2
innotop 1.11.4-5 1.11.4-6
ipython 7.23.1-1 7.24.0-1
jedi-language-server 0.30.2-2 0.30.3-1
jenkins 2.293-1 2.295-1
jmol 14.31.39-1 14.31.40-1
jsmol 14.31.39-1 14.31.40-1
knockd 0.7-4 0.8-1
ksnip 1.8.2-3 1.9.0-1
kubeseal 0.15.0-1 0.16.0-1
kvirc 5.0.0-3 5.0.0-4
kyotocabinet 1.2.78-1 1.2.79-1
leatherman 1.12.2-3 1.12.4-1
libchardet 1.0.5-1 1.0.6-1
libcurl-compat 7.76.1-1 7.77.0-1
libcurl-gnutls 7.76.1-1 7.77.0-1
libinfinity 0.7.1-2 0.7.2-1
libolm 3.2.2-1 3.2.3-1
libqb 1.0.5-2 2.0.3-1
libsass 3.6.4-1 3.6.5-1
libwhereami 0.5.0-4 0.5.0-5
log4cplus 2.0.5-1 2.0.6-1
lolcat 100.0.0-3 100.0.1-1
ls++ 1:0.36-5 1:0.36-6
ltris 1.2.1-1 1.2.2-1
luminancehdr 2.6.0-13 2.6.1-1
mame 0.231-1 0.232-1
mame-tools 0.231-1 0.232-1
marisa 0.2.6-5 0.2.6-6
marked 2.0.5-1 2.0.6-1
matrix-synapse 1.33.2-1 1.34.0-3
minikube 1.19.0-1 1.20.0-1
mkosi 8-1 9-1
nemiver 0.9.6-8 0.9.6-9
nextcloud 21.0.1-3 21.0.2-1
nextcloud-app-calendar 1:2.2.1-1 1:2.2.2-1
nextcloud-app-news 15.4.3-1 15.4.5-1
node-gyp 8.0.0-1 8.1.0-1
npm 7.14.0-1 7.15.0-1
ntk 1.3.1000-5 1.3.1001-1
openblas 0.3.14-1 0.3.15-1
openimageio 2.2.13.0-3 2.2.14.0-1
openipmi 2.0.30-1 2.0.31-1
openttd 1.11.2-1 1.11.2-4
operator-sdk 1.5.0-1 1.8.0-1
otf-cascadia-code 2102.25-1 2105.24-1
owncloud-client 2.7.6.3261-1 2.8.2.4246-1
pcp 5.3.0-1 5.3.0-2
pcp-gui 5.3.0-1 5.3.0-2
pcp-pmda-activemq 5.3.0-1 5.3.0-2
pcp-pmda-bcc 5.3.0-1 5.3.0-2
pcp-pmda-bind2 5.3.0-1 5.3.0-2
pcp-pmda-bpftrace 5.3.0-1 5.3.0-2
pcp-pmda-libvirt 5.3.0-1 5.3.0-2
pcp-pmda-mysql 5.3.0-1 5.3.0-2
pcp-pmda-nginx 5.3.0-1 5.3.0-2
pcp-pmda-nutcracker 5.3.0-1 5.3.0-2
pcp-pmda-openmetrics 5.3.0-1 5.3.0-2
pcp-pmda-podman 5.3.0-1 5.3.0-2
pcp-pmda-postgresql 5.3.0-1 5.3.0-2
pcp-pmda-snmp 5.3.0-1 5.3.0-2
pcsc-perl 1.4.14-11 1.4.14-12
perl-acme-alien-dontpanic 2.2900-1 2.2900-3
perl-algorithm-annotate 0.10-11 0.10-12
perl-algorithm-diff 1.201-1 1:1.201-2
perl-alien-base-modulebuild 1.15-1 1.15-3
perl-alien-cmake3 0.05-3 0.05-5
perl-alien-sdl 1.446-10 1.446-11
perl-anyevent-i3 0.17-6 0.17-7
perl-app-borgrestore 3.4.4-1 3.4.4-2
perl-app-cli 0.50-3 0.52-1
perl-archive-cpio 0.10-5 0.10-6
perl-archive-extract 0.88-1 0.88-2
perl-array-compare 3.0.3-1 3.0.8-1
perl-authen-sasl 2.16-8 2.16-9
perl-b-hooks-endofscope 0.24-3 0.24-4
perl-b-keywords 1.22-1 1.22-2
perl-berkeleydb 0.55-9 0.55-10
perl-cairo-gobject 1.004-10 1.004-11
perl-canary-stability 2013-3 2013-4
perl-carp-assert 0.21-3 0.21-4
perl-cgi 4.52-1 4.52-2
perl-cgi-fast 2.15-3 2.15-4
perl-cgi-formbuilder 3.10-3 3.10-4
perl-cgi-session 4.48-7 4.48-8
perl-class-load-xs 0.10-8 0.10-9
perl-class-method-modifiers 2.12-6 2.12-7
perl-class-methodmaker 2.24-9 2.24-10
perl-class-tiny 1.008-1 1.008-2
perl-color-calc 1.074-6 1.074-7
perl-config-grammar 1.12-6 1.12-7
perl-convert-asn1 0.27-6 0.27-7
perl-convert-tnef 0.18-8 0.18-9
perl-convert-uulib 1.5-8 1.5-9
perl-cpan-meta-check 0.014-6 0.014-7
perl-cpan-perl-releases 5.20191220-2 5.20191220-3
perl-cpanplus 0.9910-1 0.9910-2
perl-cpanplus-dist-arch 1.32-6 1.32-7
perl-crypt-blowfish 2.14-11 2.14-12
perl-crypt-des 2.07-11 2.07-12
perl-crypt-openssl-dsa 0.20-1 0.20-2
perl-crypt-simple 0.06-10 0.06-11
perl-crypt-smbhash 0.12-8 0.12-9
perl-curses 1.36-8 1.37-1
perl-curses-ui 0.9609-7 0.9609-8
perl-cwd-guard 0.05-6 0.05-7
perl-danga-socket 1.61-9 1.61-10
perl-data-dump 1.23-6 1.23-7
perl-data-hierarchy 0.34-11 0.34-12
perl-data-messagepack 1.01-1 1.01-2
perl-data-munge 0.097-3 0.097-4
perl-data-optlist 0.110-6 0.110-7
perl-data-perl 0.002011-1 0.002011-2
perl-data-random 0.13-4 0.13-5
perl-data-section 0.200007-4 0.200007-5
perl-data-structure-util 0.16-10 0.16-11
perl-data-uuid 1.221-8 1.226-2
perl-data-validate-ip 0.27-4 0.27-5
perl-datetime 1.54-1 1.54-2
perl-datetime-calendar-julian 0.04-6 0.04-7
perl-datetime-cron-simple 0.2-11 0.2-12
perl-datetime-event-ical 0.13-6 0.13-7
perl-datetime-event-recurrence 0.19-6 0.19-7
perl-datetime-format-builder 0.8100-7 0.8100-8
perl-datetime-format-ical 0.09-9 0.09-10
perl-datetime-format-strptime 1.75-4 1.75-5
perl-dbd-odbc 1.60-4 1.61-1
perl-dbd-pg 3.8.1-2 3.9.0-1
perl-dbd-sqlite2 0.38-4 0.38-5
perl-dbd-sybase 1.16-5 1.16-6
perl-dbi-shell 11.97-1 11.97-2
perl-devel-checkbin 0.04-6 0.04-7
perl-devel-checkcompiler 0.07-6 0.07-7
perl-devel-checklib 1.14-2 1.14-3
perl-devel-globaldestruction 0.14-6 0.14-7
perl-devel-leak 0.03-10 0.03-11
perl-devel-patchperl 1.64-2 1.64-3
perl-devel-stacktrace 2.03-4 2.03-5
perl-device-serialport 1.04-15 1.04-16
perl-digest-bubblebabble 0.02-6 0.02-7
perl-dir-self 0.11-6 0.11-7
perl-dist-checkconflicts 0.11-6 0.11-7
perl-djabberd 0.85-7 0.85-8
perl-djabberd-rosterstorage-sqlite 1.00-9 1.00-10
perl-email-address-xs 1.04-3 1.04-4
perl-email-sender 1.300031-7 1.300031-8
perl-encode-imaputf7 1.05-4 1.05-5
perl-env-shellwords 0.02-3 0.02-4
perl-eval-closure 0.14-6 0.14-7
perl-exception-class 1.44-4 1.44-5
perl-extutils-config 0.008-6 0.008-7
perl-extutils-cppguess 0.21-2 0.22-1
perl-extutils-helpers 0.026-6 0.026-7
perl-extutils-installpaths 0.012-4 0.012-5
perl-file-copy-recursive-reduced 0.006-4 0.006-5
perl-file-find-rule-perl 1.15-3 1.15-4
perl-file-homedir 1.006-1 1.006-2
perl-file-next 1.18-2 1.18-3
perl-file-path-expand 1.02-13 1.02-14
perl-file-path-tiny 0.9-4 0.9-5
perl-file-pushd 1.016-3 1.016-4
perl-file-rsyncp 0.76-1 0.76-2
perl-file-sharedir-install 0.13-4 0.13-5
perl-file-sharedir-projectdistdir 1.000009-3 1.000009-4
perl-file-slurp-tiny 0.004-6 0.004-7
perl-file-tail 1.3-6 1.3-7
perl-file-type 0.22-11 0.22-12
perl-filesys-df 0.92-11 0.92-12
perl-finance-quote 1.49-4 1.49-5
perl-font-afm 1.20-9 1.20-10
perl-function-parameters 2.001003-4 2.001003-5
perl-fuse 0.16.1-11 0.16.1-12
perl-gd 2.72-1 2.73-1
perl-glib-object-introspection 0.047-5 0.047-6
perl-gnupg-interface 1.02-1 1.02-2
perl-graphics-colornames-www 1.13-8 1.13-9
perl-graphics-tiff 12-1 12-2
perl-graphviz 2.24-6 2.24-7
perl-gssapi 0.28-17 0.28-18
perl-gtk3-imageview 6-1 9-1
perl-hook-lexwrap 0.26-3 0.26-4
perl-html-element-extended 1.18-8 1.18-9
perl-html-form 6.03-7 6.03-8
perl-html-formatter 2.16-6 2.16-7
perl-html-highlight 0.20-11 0.20-12
perl-html-scrubber 0.17-3 0.17-4
perl-html-strip 2.10-8 2.10-9
perl-html-tableextract 2.15-4 2.15-5
perl-html-tagfilter 1.03-12 1.03-13
perl-html-template-expr 0.07-11 0.07-12
perl-ical-parser 1.21-6 1.21-7
perl-image-info 1.41-4 1.41-5
perl-image-sane 5-2 5-3
perl-import-into 1.002005-6 1.002005-7
perl-importer 0.026-1 0.026-2
perl-inline-c 0.81-2 0.81-3
perl-inline-cpp 0.80-3 0.80-4
perl-inline-filters 0.20-3 0.20-4
perl-inline-java 0.58-9 0.58-10
perl-io-all 0.87-3 0.87-4
perl-io-bufferedselect 1.0-9 1.0-10
perl-io-captureoutput 1.1105-2 1.1105-3
perl-io-digest 0.11-6 0.11-7
perl-io-dirent 0.05-13 0.05-14
perl-io-multiplex 1.16-6 1.16-7
perl-io-pager 0.40-3 0.40-4
perl-io-tee 0.65-3 0.65-4
perl-io-tty 1.12-10 1.12-11
perl-ipc-shareable 0.61-6 0.61-7
perl-json 2.97001-2 4.03-1
perl-json-parse 0.55-3 0.55-4
perl-json-webtoken 0.10-5 0.10-6
perl-json-xs 4.0-4 4.0-5
perl-lchown 1.01-12 1.01-13
perl-ldap 0.66-2 0.67-1
perl-lingua-en-inflect 1.905-1 1.905-2
perl-linux-pid 0.04-13 0.04-14
perl-list-allutils 0.16-2 0.16-3
perl-list-someutils 0.56-4 0.56-5
perl-list-utilsby 0.11-4 0.11-5
perl-local-lib 2.000024-3 2.000024-4
perl-locale-codes 3.62-2 3.62-3
perl-locale-po 0.27-6 0.27-7
perl-log-any 1.709-1 1.709-2
perl-log-any-adapter-log4perl 0.09-3 0.09-4
perl-log-any-adapter-tap 0.003003-3 0.003003-4
perl-log-message 0.08-6 0.08-7
perl-log-message-simple 0.10-6 0.10-7
perl-mail-box-parser-c 3.008-8 3.010-2
perl-mail-imapclient 3.43-1 3.43-2
perl-mail-message 3.007-3 3.007-4
perl-mail-sendmail 0.79-11 0.79-12
perl-mail-spf-query 1.999.1-11 1.999.1-12
perl-mail-transport-dbx 0.07-19 0.07-20
perl-marisa 0.2.6-5 0.2.6-6
perl-math-base85 0.4-3 0.4-4
perl-math-random-isaac 1.004-7 1.004-8
perl-mediawiki-api 0.41-4 0.52-1
perl-mime-base32 1.303-6 1.303-7
perl-mime-tools 5.509-8 5.509-9
perl-module-build-tiny 0.039-6 0.039-7
perl-module-build-xsutil 0.19-4 0.19-5
perl-module-find 0.13-6 0.13-7
perl-module-implementation 0.09-6 0.09-7
perl-module-install 1.19-4 1.19-5
perl-module-pluggable 5.2-6 5.2-7
perl-module-scandeps 1.31-1 1.31-2
perl-moo 2.003006-2 2.003006-3
perl-moox-handlesvia 0.001009-1 0.001009-2
perl-moox-late 0.100-1 0.100-2
perl-moox-types-mooselike 0.29-6 0.29-7
perl-mouse 2.5.10-2 2.5.10-3
perl-mro-compat 0.13-5 0.13-6
perl-namespace-autoclean 0.29-2 0.29-3
perl-namespace-clean 0.27-6 0.27-7
perl-net-dbus 1.2.0-2 1.2.0-3
perl-net-dns-sec 1.18-1 1.18-3
perl-net-dropbox-api 1.9-9 1.9-10
perl-net-idn-encode 2.500-3 2.500-4
perl-net-ip-minimal 0.06-6 0.06-7
perl-net-ipv4addr 0.10-12 0.10-13
perl-net-ipv6addr 0.2-12 0.2-13
perl-net-jabber 2.0-11 2.0-12
perl-net-ldap-server 0.43-8 0.43-9
perl-net-libidn 0.12-18 0.12-19
perl-net-libidn2 1.01-1 1.01-2
perl-net-oauth 0.28-10 0.28-11
perl-net-openssh 0.80-1 0.80-2
perl-net-snmp 6.0.1-8 6.0.1-9
perl-net-telnet 3.04-6 3.04-7
perl-net-xmpp 1.05-6 1.05-7
perl-ntlm 1.09-5 1.09-6
perl-number-bytes-human 0.11-4 0.11-5
perl-number-misc 1.2-4 1.2-5
perl-object-accessor 0.48-6 0.48-7
perl-object-event 1.23-7 1.23-8
perl-object-multitype 0.05-11 0.05-12
perl-object-realize-later 0.21-3 0.21-4
perl-package-constants 0.06-6 0.06-7
perl-package-deprecationmanager 0.17-6 0.17-7
perl-package-stash 0.39-1 0.39-2
perl-package-stash-xs 0.29-4 0.29-5
perl-padwalker 2.5-1 2.5-2
perl-par 1.017-1 1.017-2
perl-par-dist 0.51-1 0.51-2
perl-par-packer 1.052-2 1.052-4
perl-parallel-forkmanager 2.02-2 2.02-3
perl-params-classify 0.015-4 0.015-5
perl-params-util 1.102-1 1.102-2
perl-params-validate 1.29-5 1.29-6
perl-params-validationcompiler 0.30-3 0.30-4
perl-parse-yapp 1.21-3 1.21-4
perl-path-class 0.37-6 0.37-7
perl-path-finddev 0.5.3-3 0.5.3-4
perl-path-isdev 1.001003-3 1.001003-4
perl-path-tiny 0.118-1 0.118-2
perl-pegex 0.70-3 0.70-4
perl-perl-critic 1.140-1 1.140-2
perl-perl-minimumversion 1.40-1 1.40-2
perl-pkgconfig 0.25026-1 0.25026-2
perl-pkgconfig-libpkgconf 0.11-2 0.11-3
perl-pod-parser 1.63-1 1.63-2
perl-pod-spell 1.20-3 1.20-4
perl-poe-component-client-dns 1.054-6 1.054-7
perl-poe-component-client-http 0.949-6 0.949-7
perl-poe-component-client-keepalive 0.272-7 0.272-8
perl-poe-component-ikc 0.2402-6 0.2402-7
perl-poe-component-resolver 0.921-6 0.921-7
perl-ppi 1.270-2 1.270-3
perl-ppix-quotelike 0.017-1 0.017-2
perl-ppix-regexp 0.080-1 0.080-2
perl-ppix-utilities 1.001000-3 1.001000-4
perl-ppix-utils 0.003-1 0.003-2
perl-probe-perl 0.03-3 0.03-4
perl-proc-processtable 0.59-2 0.59-3
perl-proc-simple 1.32-6 1.32-7
perl-regexp-common 2017060201-3 2017060201-4
perl-regexp-shellish 0.93-11 0.93-12
perl-rename 1.10-1 1.10-2
perl-return-multilevel 0.05-3 0.05-4
perl-role-tiny 2.001004-2 2.001004-3
perl-scalar-list-utils 1.56-1 1.56-2
perl-scope-guard 0.21-3 0.21-4
perl-sdl 2.548-5 2.548-6
perl-sgmls 1:1.1-7 1:1.1-8
perl-shell-config-generate 0.34-2 0.34-3
perl-shell-guess 0.09-3 0.09-4
perl-soap-lite 1.27-5 1.27-6
perl-software-license 0.103014-3 0.103014-4
perl-sort-naturally 1.03-6 1.03-7
perl-sort-versions 1.62-6 1.62-7
perl-statistics-descriptive 3.0800-1 3.0800-2
perl-strictures 2.000006-3 2.000006-4
perl-string-crc32 2-1 2-2
perl-string-format 1.18-3 1.18-4
perl-string-util 1.26-3 1.26-4
perl-sub-exporter 0.987-6 0.987-7
perl-sub-exporter-progressive 0.001013-6 0.001013-7
perl-sub-handlesvia 0.016-1 0.016-2
perl-sub-identify 0.14-8 0.14-9
perl-sub-info 0.002-7 0.002-8
perl-sub-install 0.928-6 0.928-7
perl-sub-name 0.26-2 0.26-3
perl-sub-override 0.09-2 0.09-3
perl-sub-quote 2.006003-3 2.006003-4
perl-super 1.20190531-3 1.20190531-4
perl-switch 2.17-6 2.17-7
perl-sys-meminfo 0.99-2 0.99-3
perl-sys-syscall 0.25-7 0.25-8
perl-sys-virt 6.3.0-2 6.8.0-2
perl-task-weaken 1.06-3 1.06-4
perl-term-animation 2.6-7 2.6-8
perl-term-extendedcolor 0.504-2 0.504-3
perl-term-progressbar 2.22-4 2.22-5
perl-term-read-password 0.11-10 0.11-11
perl-term-readline-gnu 1.36-4 1.38-1
perl-term-table 0.015-2 0.015-3
perl-term-ui 0.46-6 0.46-7
perl-test-differences 0.64-6 0.64-7
perl-test-exception 0.43-6 0.43-7
perl-test-exit 0.11-3 0.11-4
perl-test-failwarnings 0.008-4 0.008-5
perl-test-fatal 0.016-1 0.016-2
perl-test-file 1.448-1 1.448-2
perl-test-inter 1.09-3 1.09-4
perl-test-leaktrace 0.17-1 0.17-2
perl-test-minimumversion 0.101082-3 0.101082-4
perl-test-mock-guard 0.10-3 0.10-4
perl-test-mockmodule 0.176.0-1 0.176.0-3
perl-test-mocktime 0.17-4 0.17-5
perl-test-more-utf8 0.05-4 0.05-5
perl-test-needs 0.002006-3 0.002009-2
perl-test-number-delta 1.06-5 1.06-6
perl-test-object 0.08-3 0.08-4
perl-test-output 1.033-1 1.033-2
perl-test-requires 0.11-2 0.11-3
perl-test-requiresinternet 0.05-6 0.05-7
perl-test-script 1.29-1 1.29-2
perl-test-simple 1.302185-1 1.302185-2
perl-test-spec 0.54-4 0.54-5
perl-test-subcalls 1.10-3 1.10-4
perl-test-trap 0.3.4-3 0.3.4-4
perl-test-utf8 1.01-4 1.01-5
perl-test-warnings 0.026-6 0.026-7
perl-test-without-module 0.20-6 0.20-7
perl-test-yaml 1.07-4 1.07-5
perl-test2-suite 0.000140-1 0.000140-2
perl-text-charwidth 0.04-19 0.04-20
perl-text-kakasi 2.04-20 2.04-21
perl-text-markdown 1.000031-10 1.000031-11
perl-text-soundex 3.05-8 3.05-9
perl-text-template 1.59-1 1.59-2
perl-text-vfile-asdata 0.08-7 0.08-8
perl-throwable 0.200013-6 0.200013-7
perl-tidy 20210111-1 20210402-1
perl-tie-cphash 2.000-6 2.000-7
perl-tie-hash-indexed 0.05-19 0.05-20
perl-time-format 1.12-7 1.12-8
perl-time-human 1.03-11 1.03-12
perl-time-modules 2013.0912-6 2013.0912-7
perl-tk-tablematrix 1.23-22 1.23-23
perl-tree-dag-node 1.31-2 1.32-1
perl-type-tiny 1.012003-1 1.012003-2
perl-types-serialiser 1.0-6 1.0-7
perl-unicode-string 2.10-4 2.10-5
perl-unicode-stringprep 1.105-6 1.105-7
perl-unix-syslog 1.1-14 1.1-15
perl-user-identity 0.99-3 0.99-4
perl-variable-magic 0.62-5 0.62-6
perl-version-compare 0.14-4 0.14-5
perl-www-mechanize 1.96-1 2.03-1
perl-www-sms 0.09-12 0.09-13
perl-x11-protocol 0.56-11 0.56-12
perl-x11-protocol-other 30-6 30-7
perl-xml-atom 0.42-2 0.43-1
perl-xml-libxml-prettyprint 0.006-5 0.006-6
perl-xml-libxml-simple 0.99-4 0.99-5
perl-xml-libxslt 1.99-2 1.99-3
perl-xml-rss 1.60-4 1.60-5
perl-xml-smart 1.79-7 1.79-8
perl-xml-stream 1.24-6 1.24-7
perl-xml-writer 0.625-6 0.625-7
perl-xml-xpath 1.44-3 1.44-4
perl-yaml-libyaml 0.75-5 0.75-6
perl-yaml-tiny 1.73-4 1.73-5
perlbrew 0.89-1 0.89-2
perlio-via-dynamic 0.14-6 0.14-7
plan9port 20200205-1 20210527-1
playitslowly 1.5.1-7 1.5.1-8
polymake 4.4-1 4.4-2
pork 0.99.8.1-19 0.99.8.1-20
powerdns-recursor 4.4.3-2 4.5.1-1
pppusage 0.2.5-11 0.2.5-12
pragha 1.3.4-2 1.3.4-3
premake 5.0a15-1 5.0a16-1
psensor 1.2.1-1 1.2.1-2
py3status 3.36-2 3.37-1
pyenv 1.2.27-1 2.0.0-1
python-ansicolor 0.2.6-9 0.3.2-1
python-apispec 4.4.1-1 4.4.2-1
python-atom 0.6.0-3 0.6.0-4
python-build 0.3.1-1 0.4.0-1
python-cfgv 3.2.0-3 3.3.0-1
python-click-repl 0.1.6-4 0.1.6-5
python-cliff 3.7.0-1 3.8.0-1
python-crc16 0.1.1-6 0.1.1-7
python-designateclient 4.2.0-1 4.3.0-1
python-dulwich 0.20.21-1 0.20.23-1
python-ecdsa 0.16.1-1 0.17.0-1
python-execnet 1.8.0-1 1.8.1-1
python-eyed3 1:0.9.5-2 1:0.9.5-3
python-faker 8.2.1-1 8.4.0-1
python-flask 2.0.0-2 2.0.1-1
python-fonttools 4.22.1-1 4.23.1-1
python-fuse 1.0.0-3 1.0.1-1
python-gdal 3.2.3-1 3.2.3-2
python-greenlet 1.0.0-2 1.1.0-1
python-httpretty 1.1.2-1 1.1.3-1
python-hypothesis 6.13.1-1 6.13.7-1
python-identify 2.2.5-1 2.2.6-1
python-internetarchive 2.0.2-1 2.0.3-1
python-ipdb 0.13.7-1 0.13.8-1
python-magnumclient 3.4.0-1 3.5.0-1
python-manhole 1.6.0-5 1.7.0-1
python-marisa 0.2.6-5 0.2.6-6
python-neutronclient 7.3.0-1 7.4.0-1
python-novaclient 17.4.0-1 17.5.0-1
python-octaviaclient 2.2.0-2 2.3.0-1
python-olm 3.2.2-1 3.2.3-1
python-osc 1.7.4-3 1.7.6-1
python-osc-lib 2.2.1-3 2.3.0-1
python-oslo-config 8.3.2-3 8.4.0-1
python-oslo-context 3.2.0-1 3.3.0-1
python-periphery 2.2.0-1 2.3.0-1
python-phonenumbers 8.12.23-1 8.12.24-1
python-pyicu 2.7.2-1 2.7.3-1
python-pytest-checkdocs 2.6.0-1 2.7.0-1
python-pytest-repeat 0.8.0-3 0.9.0-1
python-pytest-socket 0.3.5-2 0.4.0-1
python-pytest-subtests 0.4.0-1 0.5.0-1
python-qiniu 7.4.0-1 7.4.1-1
python-queuelib 1.5.0-7 1.6.0-1
python-remoto 1.1.4-2 1.2.1-1
python-requests-mock 1.9.2-1 1.9.3-1
python-ropper 1.13.5-2 1.13.6-1
python-setuptools-rust 0.11.6-2 0.12.0-1
python-sphinxcontrib-htmlhelp 1.0.3-6 2.0.0-1
python-sphinxcontrib-serializinghtml 1.1.4-6 1.1.5-1
python-sqlalchemy-i18n 1.0.3-4 1.1.0-1
python-sysv_ipc 1.0.1-2 1.1.0-1
python-tqdm 4.60.0-1 4.61.0-1
python-trimesh 3.9.14-1 3.9.14-2
python-watchdog 0.10.5-1 0.10.6-1
python-xmlsec 1.3.10-1 1.3.11-1
python-yaspin 1.5.0-1 2.0.0-1
python2-ecdsa 0.16.1-1 0.17.0-1
python2-execnet 1.8.0-1 1.8.1-1
qgis 3.18.2-3 3.18.3-1
qjournalctl 0.6.3-1 0.6.3-2
qliveplayer 3.22.0-1 3.22.1-1
qmidictl 0.9.2-1 0.9.3-1
qmmp 1.4.6-1 1.5.0-1
qsynth 0.9.2-1 0.9.3-1
qtractor 0.9.21-1 0.9.22-1
quodlibet 4.4.0-1 4.4.0-2
qutebrowser 2.2.1-1 2.2.2-1
qxgedit 0.9.2-1 0.9.3-1
rabbitmq 3.8.14-1 3.8.16-1
rabbitmqadmin 3.8.14-1 3.8.16-1
remmina 1:1.4.16-1 1:1.4.17-1
ruby-augeas 0.5.0-6 0.5.0-8
ruby-bcrypt_pbkdf 1.1.0-2 1.1.0-3
ruby-bundler 2.2.17-1 2.2.18-1
ruby-ed25519 1.2.4-3 1.2.4-4
ruby-marisa 0.2.6-5 0.2.6-6
ruby-msgpack 1.4.2-2 1.4.2-3
ruby-sys-proctable 1.2.6-2 1.2.6-3
ruby27-augeas 0.5.0-2 0.5.0-3
rust-analyzer 20210517-1 20210524-1
rust-bindgen 0.57.0-1 0.58.1-1
rxvt-unicode 9.26-1 9.26-2
rxvt-unicode-terminfo 9.26-1 9.26-2
s3fs-fuse 1.87-1 1.88-1
samplv1 0.9.21-1 0.9.22-1
sassc 3.6.1-2 3.6.2-2
sbt 1:1.4.9-1 1:1.5.1-1
shotwell 2:0.30.11-1 2:0.30.12-1
simple-scan 40.0-1 40.1-1
singular 4.2.0.p2-1 4.2.0.p3-1
skaffold 1.20.0-1 1.25.0-1
smb4k 3.0.7-1 3.1.0-1
snd 21.3-1 21.4-1
soundconverter 4.0.0-1 4.0.1-1
spyder 5.0.0-2 5.0.1-1
sssd 2.4.2-1 2.5.0-1
staticcheck 2020.2.4-1 2021.1-1
strawberry 0.9.3-1 0.9.3-2
strip-nondeterminism 1.9.0-1 1.9.0-2
strongswan 5.9.1-1 5.9.2-1
stunnel 5.57-1 5.59-1
supermin 5.2.1-1 5.2.1-2
synthv1 0.9.21-1 0.9.22-1
tailscale 1.8.5-1 1.8.6-1
tcpreplay 4.3.3-1 4.3.4-1
tekton-cli 0.15.0-3 0.18.0-1
terraform 0.15.3-1 0.15.4-1
throttled 0.9-1 0.9.2-1
thunderbird-dark-reader 4.9.32-1 4.9.33-1
timescaledb 2.2.1-1 2.3.0-1
tor 0.4.5.8-1 0.4.5.8-2
tpm2-tools 5.0-1 5.1-1
ts-node 9.1.1-1 10.0.0-1
ttf-cascadia-code 2102.25-1 2105.24-1
typescript 4.2.4-1 4.3.2-1
uglify-js 3.13.7-1 3.13.8-1
unibilium 2.1.0-2 2.1.1-1
uwsgi 2.0.19.1-12 2.0.19.1-13
uwsgi-plugin-cgi 2.0.19.1-12 2.0.19.1-13
uwsgi-plugin-lua51 2.0.19.1-12 2.0.19.1-13
uwsgi-plugin-notfound 2.0.19.1-12 2.0.19.1-13
uwsgi-plugin-php 2.0.19.1-12 2.0.19.1-13
uwsgi-plugin-php7 2.0.19.1-12 2.0.19.1-13
uwsgi-plugin-psgi 2.0.19.1-12 2.0.19.1-13
uwsgi-plugin-python 2.0.19.1-12 2.0.19.1-13
uwsgi-plugin-rack 2.0.19.1-12 2.0.19.1-13
uwsgi-plugin-webdav 2.0.19.1-12 2.0.19.1-13
uwsgi-plugin-zabbix 2.0.19.1-12 2.0.19.1-13
v2ray 4.38.3-1 4.39.2-1
v2ray-domain-list-community 20210523034918-1 20210527065138-1
v2ray-geoip 202105200028-1 202105270041-1
vaultwarden-web 2.20.1-1 2.20.3-1
wake 0.19.1-5 0.20.0-1
websocat 1.7.0-2 1.8.1-1
weechat 3.1-2 3.1-3
whipper 0.9.0-3 0.10.0-1
wireplumber 0.3.95-1 0.3.96-1
woff2-cascadia-code 2102.25-1 2105.24-1
wt 4.5.0-1 4.5.0-2
xca 2.3.0-1 2.4.0-1
xmms20.8DrO_o.7391.dedc33d7-4.10.8DrO_o.7391.dedc33d7-5
xplr 0.9.1-1 0.13.1-1
yaegi 0.9.16-1 0.9.17-1
yaws 2.0.8-1 2.0.9-1
you-get 0.4.1520-1 0.4.1525-1
yubikey-touch-detector 1.9.0-2 1.9.1-1
znc 1.8.2-2 1.8.2-3
zsh-theme-powerlevel10k 1.13.0-1 1.14.6-1
authoscope - 0.8.0-1
cutefish-calculator - 0.1-2
cutefish-core - 0.1-1
cutefish-dock - 0.1-1
cutefish-filemanager - 0.1-2
cutefish-icons - 0.1-1
cutefish-kwin-plugins - 0.1-1
cutefish-launcher - 0.1-2
cutefish-qt-plugins - 0.1-1
cutefish-settings - 0.1-2
cutefish-statusbar - 0.1-2
cutefish-wallpapers - 0.1-1
fishui - 0.1-1
libcutefish - 0.1-1
python-django-csp - 3.7-1
release-cli - 0.8.0-1
wireplumber-docs - 0.3.96-1
:: Different overlay package(s) in repository core aarch64
linux 5.12.6-1 5.12.8-1
linux-headers 5.12.6-1 5.12.8-1
linux-pinephone 5.12.6-2 5.12.8-1
linux-pinephone-headers 5.12.6-2 5.12.8-1
linux-rc 5.13.rc2-1 5.13.rc3-3
linux-rc-headers 5.13.rc2-1 5.13.rc3-3
linux-rpi4 5.10.38-1 5.10.39-1
linux-rpi4-headers 5.10.38-1 5.10.39-1
linux-rpi4-mainline 5.12.5-1 5.12.6-1
linux-rpi4-mainline-headers 5.12.5-1 5.12.6-1
raspberrypi-bootloader 20210513-1 20210525-1
raspberrypi-bootloader-x 20210513-1 20210525-1
uboot-odroid-c4 2015.01.189-1 2015.01.189-2
uboot-odroid-hc4 2015.01.189-1 2015.01.189-2
uboot-odroid-n2 2015.01.189-1 2015.01.189-2
uboot-odroid-n2-plus 2015.01.189-1 2015.01.189-2
uboot-raspberrypi 2020.10-2 2021.04-1
linux-aml - 5.12.0-1
linux-aml-headers - 5.12.0-1
:: Different sync package(s) in repository core aarch64
ca-certificates-mozilla 3.65-1 3.66-1
cryptsetup 2.3.5-4 2.3.6-1
curl 7.76.1-1 7.77.0-1
expat 2.3.0-1 2.4.1-1
libldap 2.4.58-2 2.4.58-3
libnl 3.5.0-2 3.5.0-3
links 2.22-1 2.23-1
nspr 4.30-1 4.31-1
nss 3.65-1 3.66-1
openldap 2.4.58-2 2.4.58-3
perl 5.32.1-1 5.34.0-1
:: Different overlay package(s) in repository extra aarch64
mesa-git21.2.0_devel.139941.474eaa25ad2-121.2.0_devel.140212.17d7b0bb8f0-1
kirigami-addons - 1:0.2-1
:: Different sync package(s) in repository extra aarch64
alertmanager 0.21.0-3 0.22.1-1
apparmor 3.0.1-2 3.0.1-3
asio 1.18.1-1 1.18.2-1
atkmm 2.28.2-1 2.28.2-2
atkmm-2.36 2.36.1-1 2.36.1-2
atkmm-2.36-docs 2.36.1-1 2.36.1-2
atkmm-docs 2.28.2-1 2.28.2-2
cairo-perl 1.107-2 1.107-3
cairomm 1.14.3-1 1.14.3-2
cairomm-1.16 1.16.1-1 1.16.1-2
cairomm-1.16-docs 1.16.1-1 1.16.1-2
cairomm-docs 1.14.3-1 1.14.3-2
chromium 90.0.4430.212-1 91.0.4472.77-1
claws-mail 3.17.8-1 3.17.8-2
cmake 3.20.2-1 3.20.3-1
dhclient 4.4.2-2 4.4.2.P1-1
dhcp 4.4.2-2 4.4.2.P1-1
finch 2.14.4-1 2.14.4-2
foomatic-db 3:20210222-1 3:20210528-1
foomatic-db-nonfree 3:20210222-1 3:20210528-1
foomatic-db-nonfree-ppds 3:20210222-1 3:20210528-1
foomatic-db-ppds 3:20210222-1 3:20210528-1
gdb 10.2-1 10.2-2
gdb-common 10.2-1 10.2-2
glib-perl 1.329.3-1 1.329.3-2
glibmm 2.66.1-1 2.66.1-2
glibmm-2.68 2.68.1-1 2.68.1-2
glibmm-2.68-docs 2.68.1-1 2.68.1-2
glibmm-docs 2.66.1-1 2.66.1-2
gn 0.1891.dfcbc6fe-1 0.1897.dba01723-1
gnumeric 1.12.49-1 1.12.49-2
graphicsmagick 1.3.36-2 1.3.36-3
graphviz 2.47.1-1 2.47.1-2
gtk2-perl 1.24993-2 1.24993-3
gtkmm-4.0 4.0.2-1 4.2.0-2
gtkmm-4.0-docs 4.0.2-1 4.2.0-2
gtkmm3 3.24.5-1 3.24.5-2
gtkmm3-docs 3.24.5-1 3.24.5-2
gupnp 1.2.4-1 1.2.6-1
gvim 8.2.2859-1 8.2.2891-1
hitori 3.38.1-1 3.38.2-1
imagemagick 7.0.11.13-2 7.0.11.13-3
imagemagick-doc 7.0.11.13-2 7.0.11.13-3
inkscape 1.0.2-6 1.1-1
irssi 1.2.3-1 1.2.3-2
kcolorpicker 0.1.5-1 0.1.6-1
kdeconnect 21.04.1-1 21.04.1-2
kimageannotator 0.4.2-1 0.5.0-1
libcaca 0.99.beta19-4 0.99.beta19-5
libdrm 2.4.105-1 2.4.106-1
libetonyek 0.1.9-2 0.1.10-1
libinput 1.17.2-2 1.17.3-1
libproxy 0.4.17-1 0.4.17-2
libproxy-webkit 0.4.17-1 0.4.17-2
libpurple 2.14.4-1 2.14.4-2
libqalculate 3.18.0-2 3.19.0-1
librsvg 2:2.50.5-1 2:2.50.6-1
libsigc++ 2.10.7-1 2.10.7-2
libsigc++-3.0 3.0.7-1 3.0.7-2
libsigc++-3.0-docs 3.0.7-1 3.0.7-2
libsigc++-docs 2.10.7-1 2.10.7-2
libsynctex 2020.54586-14 2021.58686-3
libva-mesa-driver 21.1.0-1 21.1.1-1
libxml++ 3.2.2-1 3.2.3-1
libxml++-docs 3.2.2-1 3.2.3-1
libxml++2.6 2.42.0-1 2.42.1-1
libxml++2.6-docs 2.42.0-1 2.42.1-1
llvm10 10.0.1-4 10.0.1-5
llvm10-libs 10.0.1-4 10.0.1-5
mesa 21.1.0-1 21.1.1-1
mesa-vdpau 21.1.0-1 21.1.1-1
mpd 0.22.7-1 0.22.8-1
mutter 40.1-1 40.1-2
net-snmp 5.9-3 5.9.1-1
opencl-mesa 21.1.0-1 21.1.1-1
pango-perl 1.227-13 1.227-14
pangomm 2.46.1-1 2.46.1-2
pangomm-2.48 2.48.1-1 2.48.1-2
pangomm-2.48-docs 2.48.1-1 2.48.1-2
pangomm-docs 2.46.1-1 2.46.1-2
perl-alien-build 2.40-1 2.40-3
perl-alien-libxml2 0.17-1 0.17-2
perl-anyevent 4:7.17-3 4:7.17-4
perl-appconfig 1.71-7 1.71-8
perl-archive-zip 1.68-3 1.68-5
perl-async-interrupt 1.26-2 1.26-3
perl-autovivification 0.18-6 0.18-7
perl-bit-vector 7.4-11 7.4-12
perl-business-isbn 3.004-7 3.004-8
perl-business-isbn-data 20140910.003-7 20140910.003-8
perl-business-ismn 1.201-4 1.201-5
perl-business-issn 1.003-4 1.003-5
perl-bytes-random-secure 0.29-8 0.29-9
perl-capture-tiny 0.48-4 0.48-5
perl-carp-clan 6.08-3 6.08-4
perl-class-inspector 1.36-3 1.36-4
perl-clone 0.45-2 0.45-3
perl-common-sense 3.75-2 3.75-3
perl-compress-bzip2 2.28-1 2.28-2
perl-config-autoconf 0.317-4 0.317-5
perl-config-simple 4.59-12 4.59-13
perl-convert-binhex 1.125-7 1.125-8
perl-cpan-meta 2.150010-9 2.150010-10
perl-crypt-openssl-bignum 0.09-5 0.09-6
perl-crypt-openssl-guess 0.13-1 0.13-2
perl-crypt-openssl-random 0.15-6 0.15-7
perl-crypt-openssl-rsa 0.31-5 0.31-6
perl-crypt-passwdmd5 1.41-1 1.41-2
perl-crypt-random-seed 0.03-5 0.03-6
perl-crypt-random-tesha2 0.01-6 0.01-7
perl-crypt-ssleay 0.73_04-14 0.73_04-15
perl-data-compare 1.25-8 1.25-9
perl-data-uniqid 0.12-8 0.12-9
perl-date-calc 6.4-7 6.4-8
perl-date-manip 6.85-1 6.85-2
perl-date-simple 3.03-9 3.03-10
perl-dbd-mariadb 1.21-1 1.21-2
perl-dbd-mysql 4.050-6 4.050-7
perl-dbd-sqlite 1.66-1 1.66-2
perl-dbi 1.643-2 1.643-3
perl-digest-hmac 1.04-1 1.04-2
perl-digest-nilsimsa 0.06-20 0.06-21
perl-digest-sha1 2.13-15 2.13-16
perl-email-date-format 1.005-7 1.005-8
perl-encode-locale 1.05-7 1.05-8
perl-error 0.17029-2 0.17029-3
perl-ev 4.33-2 4.33-3
perl-exporter-tiny 1.002002-2 1.002002-3
perl-extutils-depends 0.8001-1 0.8001-2
perl-extutils-libbuilder 0.08-7 0.08-8
perl-extutils-pkgconfig 1.16-7 1.16-8
perl-fcgi 0.79-3 0.79-4
perl-ffi-checklib 0.28-1 0.28-2
perl-file-basedir 0.08-5 0.08-6
perl-file-copy-recursive 0.45-3 0.45-4
perl-file-desktopentry 0.22-7 0.22-8
perl-file-find-rule 0.34-7 0.34-8
perl-file-listing 6.14-1 6.14-2
perl-file-mimeinfo 0.30-1 0.30-2
perl-file-readbackwards 1.06-1 1.06-2
perl-file-sharedir 1.116-4 1.116-5
perl-file-slurper 0.012-4 0.012-5
perl-file-which 1.24-1 1.24-2
perl-guard 1.023-11 1.023-12
perl-html-parser 3.76-1 3.76-2
perl-html-tagset 3.20-10 3.20-11
perl-html-template 2.97-6 2.97-7
perl-http-cookies 6.10-1 6.10-2
perl-http-daemon 6.06-2 6.06-3
perl-http-date 6.05-3 6.05-4
perl-http-message 6.32-1 6.32-2
perl-http-negotiate 6.01-8 6.01-9
perl-image-exiftool 12.25-1 12.26-2
perl-inc-latest 0.500-7 0.500-8
perl-io-html 1.004-1 1.004-2
perl-io-socket-inet6 2.72-7 2.72-8
perl-io-socket-ssl 2.070-1 2.071-1
perl-ipc-run3 0.048-8 0.048-9
perl-ipc-system-simple 1.30-2 1.30-3
perl-libintl-perl 1.32-1 1.32-2
perl-libwww 6.54-1 6.54-2
perl-lingua-translit 0.28-5 0.28-6
perl-list-moreutils 0.430-1 0.430-2
perl-list-moreutils-xs 0.430-1 0.430-2
perl-locale-gettext 1.07-10 1.07-11
perl-log-log4perl 1.54-1 1.54-2
perl-lwp-mediatypes 6.02-8 6.02-9
perl-lwp-protocol-https 6.10-1 6.10-2
perl-mail-authenticationresults 2.20210112-1 2.20210112-2
perl-mail-dkim 1.20200907-1 1.20200907-2
perl-mail-spf 2.9.0-7 2.9.0-8
perl-mailtools 2.21-4 2.21-5
perl-mime-charset 1.012.2-7 1.012.2-8
perl-mime-lite 3.031-3 3.031-4
perl-mime-types 2.20-1 2.21-1
perl-module-build 0.4231-3 0.4231-5
perl-mozilla-ca 20200520-3 20200520-4
perl-mp3-info 1.26-5 1.26-6
perl-net-cidr-lite 0.22-1 0.22-2
perl-net-dns 1.31-1 1.31-3
perl-net-dns-resolver-mock 1.20200215-3 1.20200215-4
perl-net-dns-resolver-programmable 0.009-6 0.009-7
perl-net-http 6.21-1 6.21-2
perl-net-ip 1.26-8 1.26-9
perl-net-server 2.010-1 2.010-2
perl-net-ssleay 1.90-1 1.90-2
perl-netaddr-ip 4.079-10 4.079-11
perl-number-compare 0.03-10 0.03-11
perl-perl4-corelibs 0.004-6 0.004-7
perl-perlio-utf8-strict 0.007-6 0.007-7
perl-socket6 0.29-5 0.29-6
perl-sort-key 1.33-9 1.33-10
perl-sys-hostname-long 1.5-7 1.5-8
perl-template-toolkit 3.009-1 3.009-2
perl-term-readkey 2.38-5 2.38-6
perl-test-pod 1.52-5 1.52-6
perl-text-bibtex 0.85-6 0.85-7
perl-text-csv 2.00-1 2.00-2
perl-text-glob 0.11-7 0.11-8
perl-text-iconv 1.7-19 1.7-20
perl-text-patch 1.8-8 1.8-9
perl-text-roman 3.5-7 3.5-8
perl-tie-cycle 1.225-5 1.225-6
perl-tie-simple 1.04-8 1.04-9
perl-timedate 2.33-2 2.33-3
perl-tk 804.036-2 804.036-3
perl-try-tiny 0.30-5 0.30-6
perl-unicode-linebreak 2019.001-3 2019.001-4
perl-uri 5.09-1 5.09-2
perl-www-robotrules 6.02-8 6.02-9
perl-xml-libxml 2.0207-1 2.0207-2
perl-xml-parser 2.46-2 2.46-3
perl-xml-simple 2.25-5 2.25-6
perl-xml-twig 3.52-7 3.52-8
perl-yaml 1.30-2 1.30-3
perl-yaml-syck 1.34-1 1.34-2
pidgin 2.14.4-1 2.14.4-2
postgresql 13.2-2 13.3-2
postgresql-docs 13.2-2 13.3-2
postgresql-libs 13.2-2 13.3-2
postgresql-old-upgrade 12.7-1 12.7-2
pulseaudio-qt 1.2-2 1.3-1
pyside6 6.0.4-1 6.1.0-1
python 3.9.5-2 3.9.5-3
python-attrs 20.3.0-3 21.2.0-1
python-django 3.2.3-1 3.2.3-2
python-numpy 1.20.2-1 1.20.3-1
python-pyqt6-3d 6.0.3-1 6.1.0-1
python-pyqt6 6.0.3-1 6.1.0-1
python-pyqt6-networkauth 6.0.3-1 6.1.0-1
python-service-identity 18.1.0-7 21.1.0-1
python-setuptools 1:56.1.0-1 1:56.2.0-1
python-tests 3.9.5-2 3.9.5-3
python-urllib3 1.26.4-1 1.26.4-2
python-urllib3-doc 1.26.4-1 1.26.4-2
python-virtualenv 20.4.6-1 20.4.7-1
python2-attrs 20.3.0-3 21.2.0-1
python2-urllib3 1.26.4-1 1.26.4-2
python2-virtualenv 20.4.6-1 20.4.7-1
qalculate-gtk 3.18.0-1 3.19.0-1
qt5-base 5.15.2+kde+r193-1 5.15.2+kde+r196-1
qt5-declarative 5.15.2+kde+r24-1 5.15.2+kde+r26-1
qt5-xcb-private-headers 5.15.2+kde+r193-1 5.15.2+kde+r196-1
qt6-3d 6.0.4-1 6.1.0-1
qt6-5compat 6.0.4-1 6.1.0-1
qt6-base 6.0.4-1 6.1.0-1
qt6-declarative 6.0.4-1 6.1.0-1
qt6-doc 6.0.4-1 6.1.0-1
qt6-examples 6.0.4-1 6.1.0-1
qt6-imageformats 6.0.4-1 6.1.0-1
qt6-networkauth 6.0.4-1 6.1.0-1
qt6-quick3d 6.0.4-1 6.1.0-1
qt6-quickcontrols2 6.0.4-1 6.1.0-1
qt6-quicktimeline 6.0.4-1 6.1.0-1
qt6-shadertools 6.0.4-1 6.1.0-1
qt6-svg 6.0.4-1 6.1.0-1
qt6-tools 6.0.4-1 6.1.0-1
qt6-translations 6.0.4-1 6.1.0-1
qt6-wayland 6.0.4-1 6.1.0-1
razor 2.85-15 2.85-16
rebuilderd-website 0.5.1-1 0.5.2-1
rrdtool 1.7.2-7 1.7.2-8
shiboken6 6.0.4-1 6.1.0-1
spamassassin 3.4.6-1 3.4.6-2
subversion 1.14.1-2 1.14.1-3
suitesparse 5.10.0-1 5.10.1-1
texlive-bibtexextra 2020.56991-1 2021.58697-1
texlive-bin 2020.54586-14 2021.58686-3
texlive-core 2020.57066-2 2021.58710-2
texlive-fontsextra 2020.57042-1 2021.58704-1
texlive-formatsextra 2020.56699-1 2021.57972-1
texlive-games 2020.56833-1 2021.56833-1
texlive-humanities 2020.57034-1 2021.58589-1
texlive-langchinese 2020.57044-1 2021.58583-1
texlive-langcyrillic 2020.56674-1 2021.58426-1
texlive-langextra 2020.56781-1 2021.58019-1
texlive-langgreek 2020.56956-1 2021.57684-1
texlive-langjapanese 2020.57025-1 2021.58632-1
texlive-langkorean 2020.56915-1 2021.58468-1
texlive-latexextra 2020.57067-1 2021.58668-2
texlive-music 2020.56473-1 2021.58331-1
texlive-pictures 2020.57065-1 2021.58558-1
texlive-pstricks 2020.56758-1 2021.58293-1
texlive-publishers 2020.57058-1 2021.58683-1
texlive-science 2020.57068-1 2021.58667-1
usbguard 1.0.0-3 1.0.0-4
vim-runtime 8.2.2859-1 8.2.2891-1
vulkan-broadcom 21.1.0-1 21.1.1-1
vulkan-mesa-layers 21.1.0-1 21.1.1-1
vulkan-radeon 21.1.0-1 21.1.1-1
vulkan-swrast 21.1.0-1 21.1.1-1
x2goserver 4.1.0.3-9 4.1.0.3-10
xfce4-screenshooter 1.9.9-1 1.9.9-2
zxing-cpp 1.1.1-1 1.2.0-1
lib2geom - 1.1-1
libxml++-5.0 - 5.0.1-1
libxml++-5.0-docs - 5.0.1-1
python-pyqt6-charts - 6.1.0-1
python-pyqt6-datavisualization - 6.1.0-1
qt6-datavis3d - 6.1.0-1
qt6-lottie - 6.1.0-1
qt6-scxml - 6.1.0-1
qt6-virtualkeyboard - 6.1.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.04.0.r12501.g8872f3ca5-121.04.1.r12502.g37b955fcb-1
akonadi-calendar21.04.0.r1938.g239913d-121.04.1.r1939.gb9233c7-1
akonadi-calendar-tools21.04.0.r865.g7e11fb9-121.04.1.r865.g7e11fb9-1
akonadi-contacts21.04.0.r3008.ga0e5aad2-121.04.1.r3009.gc2b05057-1
akonadi-import-wizard21.04.0.r1706.g1f3695f-121.04.1.r1707.gfe1bd30-1
akonadi-mime21.04.0.r1617.gc6fddb5-121.04.1.r1618.g6d19ae9-1
akonadi-notes21.04.0.r1002.g7b48a41-121.04.1.r1003.g2411b4d-1
akonadi-search21.04.0.r1090.gee5faf3-121.04.1.r1091.gb2d99d7-1
akonadiconsole21.04.0.r1487.g7f06cca-121.04.1.r1488.g06fc599-1
akregator21.04.0.r6123.g0e844d97-121.04.1.r6125.gedbc1a08-1
analitza21.04.0.r2330.g7072e346-121.04.1.r2330.g7072e346-1
angelfish 1.8.0.r18.g5b64a57-1 21.05.r22.gf8ebefa-1
ark21.04.0.r4525.g758ab874-121.04.1.r4529.g2df36575-1
artikulate21.04.0.r1382.g804ed9f-121.04.1.r1384.g9c5d1cd-1
attica5.82.0.r807.g193dea6-15.82.0.r808.g9298061-1
audiocd-kio21.04.0.r1016.gadf966b-121.04.1.r1016.gadf966b-1
baloo5.82.0.r2983.g946d1c21-15.82.0.r2984.gde207e48-1
baloo-widgets21.04.0.r679.g38ef1b5-121.04.1.r679.g38ef1b5-1
blinken21.04.0.r622.gbfdb290-121.04.1.r622.gbfdb290-1
bluedevil1:5.21.4.r2263.g4a5f7f17-11:5.21.5.r2264.g4eaa5678-1
bluez-qt5.82.0.r658.g262c0f2-15.82.0.r659.ga9b57fe-1
bomber21.04.0.r515.gbad5da8-121.04.1.r515.gbad5da8-1
bovo21.04.0.r725.gf059a95-121.04.1.r725.gf059a95-1
breeze5.21.4.r2187.g2db1c9a6-15.21.5.r2190.g29f1ef63-1
breeze-grub 5.21.4.r8.g2c1d5e7-1 5.21.5.r8.g2c1d5e7-1
breeze-gtk5.21.4.r420.gfccd7df-15.21.5.r420.gfccd7df-1
breeze-icons5.82.0.r1744.g37d39fa6-15.82.0.r1745.g869d91dd-1
buho 1.2.2.r12.g1452b64-1 1.2.2.r14.gcf9edb1-1
calendarsupport21.04.0.r522.gb530e85-121.04.1.r523.g6a9459c-1
calindori 21.05.r8.g8a15c3d-1 21.05.r10.g4959ce6-1
cervisia21.04.0.r1636.g9d6cb9e-121.04.1.r1636.g9d6cb9e-1
discover5.21.4.r8178.g7e7a8312-15.21.5.r8192.g7ecb9a26-1
dolphin21.04.0.r6589.g5fca9ee72-121.04.1.r6591.g83c9108f8-1
dolphin-plugins21.04.0.r563.g0833cfa-121.04.1.r563.g0833cfa-1
dragon21.04.0.r999.g8517a54-121.04.1.r999.g8517a54-1
drkonqi5.21.4.r645.g54fff58b-15.21.5.r645.g54fff58b-1
elisa21.04.0.r2706.g86468666-121.04.1.r2711.g6ff6557e-1
eventviews21.04.0.r646.g230177b-121.04.1.r647.gc23f610-1
extra-cmake-modules5.82.0.r3306.g08faec5-15.82.0.r3315.g068d861-1
ffmpegthumbs21.04.0.r171.g648104f-121.04.1.r171.g648104f-1
filelight21.04.0.r964.g64aedd2-121.04.1.r965.g4aef27e-1
frameworkintegration5.82.0.r583.gca03ff3-15.82.0.r584.gfdc29c8-1
granatier21.04.0.r914.g83cbca2-121.04.1.r914.g83cbca2-1
grantlee-editor21.04.0.r743.ga6b8da3-121.04.1.r743.ga6b8da3-1
grantleetheme21.04.0.r321.g3223868-121.04.1.r322.gdc8e1c0-1
gwenview21.04.0.r6599.ge8082e36-121.04.1.r6602.g79f1c25e-1
incidenceeditor21.04.0.r722.gfc7621e-121.04.1.r724.g5125eb6-1
index-fm 1.2.2.r21.g3848666-1 1.2.2.r35.gfbefa58-1
itinerary21.04.0.r1285.g2df27eb-121.04.1.r1291.g4cee68a-1
juk21.04.0.r3104.ge35afcaa-121.04.1.r3104.ge35afcaa-1
k3b1:21.04.0.r6606.gfcc14a6e7-11:21.04.1.r6608.gb937dc2d9-1
kaccounts-integration21.04.0.r1207.gb36372a-121.04.1.r1207.gb36372a-1
kaccounts-providers21.04.0.r377.ge2cb245-121.04.1.r377.ge2cb245-1
kactivities5.82.0.r1346.g1ec930f-15.82.0.r1347.g3a68484-1
kactivities-stats5.82.0.r352.g9a6b086-15.82.0.r354.gc57b33a-1
kactivitymanagerd5.21.4.r1352.g11be786-15.21.5.r1352.g11be786-1
kaddressbook21.04.0.r5960.g0c1f2a83-121.04.1.r5961.g1658ded1-1
kajongg21.04.0.r4182.gc4ac8a81-121.04.1.r4182.gc4ac8a81-1
kalarm21.04.0.r6374.g71b15a11-121.04.1.r6379.g1d7a4567-1
kalarmcal21.04.0.r1110.gc80af67-121.04.1.r1111.g434fdb4-1
kalgebra21.04.0.r2029.ge96cb59-121.04.1.r2029.ge96cb59-1
kalk 21.05.r7.gc337d5f-1 21.05.r13.g69e6c19-1
kalzium21.04.0.r4250.geb121dfc-121.04.1.r4250.geb121dfc-1
kamera21.04.0.r650.gc3c0bff-121.04.1.r652.g124b8b8-1
kamoso21.04.0.r1424.g9d1a5da-121.04.1.r1424.g9d1a5da-1
kanagram21.04.0.r1275.g552fd82-121.04.1.r1276.g0641c71-1
kapman21.04.0.r588.gb14383b-121.04.1.r588.gb14383b-1
kapptemplate21.04.0.r950.g1511f9b-121.04.1.r950.g1511f9b-1
karchive5.82.0.r481.gdd2c1b2-15.82.0.r482.gfe6334a-1
kate21.04.0.r18147.gd7b24e093-121.04.1.r18184.gc095d67e6-1
katomic21.04.0.r910.gf9b1196-121.04.1.r910.gf9b1196-1
kauth5.82.0.r433.g804091c-15.82.0.r434.g9db4fd8-1
kbackup21.04.0.r362.g5db07f6-121.04.1.r366.ga2bef66-1
kblackbox21.04.0.r715.gac612f7-121.04.1.r715.gac612f7-1
kblocks21.04.0.r630.gb9a23cc-121.04.1.r630.gb9a23cc-1
kbookmarks5.82.0.r405.gebd6a22-15.82.0.r406.g7370299-1
kbounce21.04.0.r792.g9633285-121.04.1.r792.g9633285-1
kbreakout21.04.0.r848.g8ea52cf-121.04.1.r848.g8ea52cf-1
kbruch21.04.0.r811.g3cf25d0-121.04.1.r812.gc716aa2-1
kcachegrind21.04.0.r1146.g15e2900-121.04.1.r1146.g15e2900-1
kcachegrind-common21.04.0.r1146.g15e2900-121.04.1.r1146.g15e2900-1
kcalc21.04.0.r1488.g2c3db73-121.04.1.r1492.g21279fa-1
kcalendarcore5.82.0.r1205.gbebcf5735-15.82.0.r1207.g879b76a77-1
kcalutils21.04.0.r833.gf8694ddca-121.04.1.r834.g9a96b023f-1
kcharselect21.04.0.r460.gb5e0b66-121.04.1.r460.gb5e0b66-1
kclock 21.05.r18.g6493132-1 21.05.r23.gf1119b6-1
kcmutils5.82.0.r508.gf76a674-15.82.0.r509.g2ce8763-1
kcodecs5.82.0.r364.g922b582-15.82.0.r366.g5563b3e-1
kcolorchooser21.04.0.r215.ge5f8b89-121.04.1.r215.ge5f8b89-1
kcompletion5.82.0.r438.g9fe0547-15.82.0.r440.g9c73ac7-1
kconfig5.82.0.r831.g725c2cc-15.82.0.r836.ge4a9b97-1
kconfigwidgets5.82.0.r573.g901b049-15.82.0.r576.g7e15135-1
kcontacts1:5.82.0.r3238.g030d5de3-11:5.82.0.r3239.g231101ce-1
kcoreaddons5.82.0.r1220.gd7f85915-35.82.0.r1222.g8acabc6d-1
kcrash5.82.0.r384.gb79e284-15.82.0.r385.gdf59acb-1
kcron21.04.0.r769.g1dfdfa7-121.04.1.r770.g4db14db-1
kdav1:5.82.0.r1282.g7413107-11:5.82.0.r1283.gf01e7af-1
kdbusaddons5.82.0.r360.g0b21136-15.82.0.r362.g5cc8df6-1
kde-cli-tools5.21.4.r1843.gf588826-15.21.5.r1845.gddccf63-1
kde-dev-scripts21.04.0.r4129.g329a38f-121.04.1.r4130.gcfc51d2-1
kde-dev-utils21.04.0.r552.g05ffaa6-121.04.1.r552.g05ffaa6-1
kde-gtk-config5.21.4.r892.g31f932e-15.21.5.r894.g666717b-1
kdebugsettings21.04.0.r805.g6c91a72-121.04.1.r806.g0cf9c21-1
kdeclarative5.82.0.r890.g88822dc-15.82.0.r891.g23f570d-1
kdeconnect21.04.0.r3193.ge8cffe2d-121.04.1.r3201.g7b56c1d3-1
kdecoration5.21.4.r264.ga067a6e-15.21.5.r265.g319d174-1
kded5.82.0.r400.g8ecc46b-15.82.0.r402.ge6bb77c-1
kdeedu-data21.04.0.r15.g8dc3dee-121.04.1.r15.g8dc3dee-1
kdegraphics-mobipocket21.04.0.r258.g036fd81-121.04.1.r258.g036fd81-1
kdegraphics-thumbnailers21.04.0.r231.g224d34b-121.04.1.r231.g224d34b-1
kdelibs4support5.82.0.r1016.g0c3bb92f-15.82.0.r1018.g8015119a-1
kdenetwork-filesharing21.04.0.r880.g5e3dc75-121.04.1.r880.g5e3dc75-1
kdenlive21.04.0.r14465.gad1326017-121.04.1.r14478.g9b89f4ee3-1
kdepim-addons21.04.0.r4094.g1d25d8c9-121.04.1.r4100.g1006f2ba-1
kdepim-runtime21.04.0.r15097.g2a647edde-121.04.1.r15112.g971144673-1
kdeplasma-addons5.21.4.r8520.ga6435e48c-15.21.5.r8520.ga6435e48c-1
kdesdk-kioslaves21.04.0.r488.g99737ef-121.04.1.r488.g99737ef-1
kdesdk-thumbnailers21.04.0.r68.gb71f553-121.04.1.r68.gb71f553-1
kdesignerplugin5.82.0.r322.g621b79c-15.82.0.r324.g1406e59-1
kdesu5.82.0.r461.g4ce5071-15.82.0.r462.g8a2c65c-1
kdf21.04.0.r786.g71894ce-121.04.1.r787.g8ebda46-1
kdialog21.04.0.r1179.g1906217e5-121.04.1.r1179.g1906217e5-1
kdiamond21.04.0.r659.gbf622b2-121.04.1.r659.gbf622b2-1
kdnssd5.82.0.r306.g91469f4-15.82.0.r308.gb883495-1
kdoctools5.82.0.r606.g0c9e9b8-15.82.0.r607.gbb39bd9-1
keditbookmarks21.04.0.r2738.g5e122c923-121.04.1.r2738.g5e122c923-1
kemoticons5.82.0.r370.g90697c1-15.82.0.r372.g489b3d9-1
keysmith 0.1.r215.gfb953ed-1 0.1.r217.g2719c6b-1
kfilemetadata5.82.0.r790.g0ee00c1-15.82.0.r791.g27c7d9c-1
kfind21.04.0.r2630.gd860b5c94-121.04.1.r2631.gb23e8823d-1
kfloppy21.04.0.r746.g72738b1-121.04.1.r746.g72738b1-1
kfourinline21.04.0.r970.g2a51004-121.04.1.r970.g2a51004-1
kgamma55.21.4.r455.gdb6a51b-15.21.5.r455.gdb6a51b-1
kgeography21.04.0.r1107.g037c1a7-121.04.1.r1107.g037c1a7-1
kget21.04.0.r3097.gbf097710-121.04.1.r3097.gbf097710-1
kglobalaccel5.82.0.r442.g24acf8c-15.82.0.r444.g9a48818-1
kgoldrunner21.04.0.r1222.g92095a1-121.04.1.r1222.g92095a1-1
kgpg21.04.0.r3115.g611b5c0f-121.04.1.r3120.gf26e870a-1
kguiaddons5.82.0.r362.g394eebc-15.82.0.r363.g2054352-1
khangman21.04.0.r1555.gb96a400-121.04.1.r1556.ga0ea4a4-1
khelpcenter21.04.0.r2657.g0ca1368f-121.04.1.r2657.g0ca1368f-1
kholidays1:5.82.0.r931.g9548e4a-11:5.82.0.r932.g2cd577b-1
khotkeys5.21.4.r2071.g04dcaf1-15.21.5.r2071.g04dcaf1-1
ki18n5.82.0.r462.g6878ea3-35.82.0.r464.ga07971a-1
kiconthemes5.82.0.r522.g72b9dfb-15.82.0.r524.g1012036-1
kidentitymanagement21.04.0.r3781.gb5623075-121.04.1.r3782.g28881265-1
kidletime5.82.0.r299.ge8a8e90-15.82.0.r301.g050c4fc-1
kig21.04.0.r3128.g6183de08-121.04.1.r3128.g6183de08-1
kigo21.04.0.r508.g19a52c2-121.04.1.r508.g19a52c2-1
killbots21.04.0.r722.g1e79961-121.04.1.r722.g1e79961-1
kimagemapeditor21.04.0.r457.gb85486b-121.04.1.r457.gb85486b-1
kimap21.04.0.r1087.g49216c4-121.04.1.r1088.ga50c518-1
kinfocenter5.21.4.r1833.gf5003ef-15.21.5.r1836.ga3051a4-1
kinit5.82.0.r397.g961753f-15.82.0.r398.g66439a3-1
kio5.82.0.r4742.g828ab431-15.82.0.r4749.g90ff8140-1
kio-extras21.04.0.r7019.g0c7c503f-121.04.1.r7025.g116ced33-1
kio-gdrive21.04.0.r554.g603e8cf-121.04.1.r554.g603e8cf-1
kipi-plugins21.04.0.r12060.g5fe710f54-121.04.1.r12060.g5fe710f54-1
kirigami-addons5.79.0.r26.gb87abcd-1 0.2.r36.gb197d98-1
kirigami-gallery21.04.0.r200.gf5dfdca-121.04.1.r204.g2d22278-1
kirigami25.82.0.r2789.g78369021-15.82.0.r2801.g8e05755e-1
kiriki21.04.0.r412.gba75fed-121.04.1.r412.gba75fed-1
kitemmodels5.82.0.r538.g9b0630d-25.82.0.r539.g01029bf-1
kitemviews5.82.0.r324.g01a7f48-15.82.0.r325.gb2c9531-1
kiten21.04.0.r1136.gd03f5bb-121.04.1.r1137.gd50753d-1
kitinerary21.04.0.r1789.g4f80b58-121.04.1.r1791.ge85a1a9-1
kjobwidgets5.82.0.r361.gf6cd893-15.82.0.r362.gda3b9ff-1
kjsembed5.82.0.r293.gf000f77-15.82.0.r294.ga577d74-1
kjumpingcube21.04.0.r775.g3f8c02e-121.04.1.r775.g3f8c02e-1
kldap21.04.0.r853.g380d52e-121.04.1.r856.g212285f-1
kleopatra21.04.0.r5859.g7c58a35a-121.04.1.r5862.g760ad715-1
klettres21.04.0.r906.g12c900c-121.04.1.r908.g4b85c78-1
klickety21.04.0.r620.g30e4a2f-121.04.1.r620.g30e4a2f-1
klines21.04.0.r734.g2303fa7-121.04.1.r734.g2303fa7-1
kmag21.04.0.r683.g7398913-121.04.1.r683.g7398913-1
kmahjongg21.04.0.r1459.g3880caa-121.04.1.r1459.g3880caa-1
kmail21.04.0.r25736.gd28e0c36c-121.04.1.r25736.gd28e0c36c-1
kmail-account-wizard21.04.0.r779.g549a0ea-121.04.1.r779.g549a0ea-1
kmailtransport21.04.0.r1603.g4866f33-121.04.1.r1604.g5a30a0b-1
kmbox21.04.0.r518.g3603e0c-121.04.1.r518.g3603e0c-1
kmediaplayer5.82.0.r285.g9d178bf-15.82.0.r286.g818e582-1
kmenuedit5.21.4.r968.g2742003-15.21.5.r968.g2742003-1
kmime21.04.0.r1431.gcbbc2eb-121.04.1.r1431.gcbbc2eb-1
kmines21.04.0.r1708.g2d2ce86-121.04.1.r1708.g2d2ce86-1
kmix21.04.0.r2365.gbec8b34b-121.04.1.r2365.gbec8b34b-1
kmousetool21.04.0.r387.g3e256a8-121.04.1.r387.g3e256a8-1
kmouth21.04.0.r689.g23385b6-121.04.1.r690.g31a81c4-1
kmplot21.04.0.r1457.g0f8a6f5-121.04.1.r1458.g0a5391d-1
knavalbattle21.04.0.r1360.g23ecdc2-121.04.1.r1360.g23ecdc2-1
knetwalk21.04.0.r645.g36949c9-121.04.1.r645.g36949c9-1
knewstuff5.82.0.r1099.g68828447-15.82.0.r1150.ge1d40ecb-1
knights21.04.0.r1045.gb000e44-121.04.1.r1045.gb000e44-1
knotes21.04.0.r3451.gc8c8a09a-121.04.1.r3452.g1fc19747-1
knotifications5.82.0.r652.g5cfd915-15.82.0.r656.gd85b187-1
knotifyconfig5.82.0.r339.g1e157ab-15.82.0.r341.gfadf187-1
kolf21.04.0.r1414.g22a424b-121.04.1.r1414.g22a424b-1
kollision21.04.0.r482.g5ebf1b6-121.04.1.r482.g5ebf1b6-1
kolourpaint21.04.0.r2338.g164d1948-121.04.1.r2339.g460595d5-1
kompare21.04.0.r1099.gc934559-121.04.1.r1099.gc934559-1
kongress r203.g7cd88d6-1 21.05.r4.g7cd88d6-1
konqueror21.04.0.r14898.g73dd84388-121.04.1.r14899.gc088ee10a-1
konquest21.04.0.r886.g025296d-121.04.1.r886.g025296d-1
konsole21.04.0.r7797.ge03a4680-121.04.1.r7801.g1cda384e-1
kontact21.04.0.r5314.gffb6c9fb-121.04.1.r5316.gf6f773d2-1
kontactinterface21.04.0.r608.g98bfd2c-121.04.1.r610.g880d567-1
kontrast21.04.0.r166.gf0423b2-121.04.1.r166.gf0423b2-1
konversation21.04.0.r8948.ga912c134-121.04.1.r8950.g9ce17b18-1
kopeninghours21.04.0.r265.g2d24fcf-121.04.1.r265.g2d24fcf-1
korganizer21.04.0.r11367.g419edd0d8-121.04.1.r11367.g419edd0d8-1
kosmindoormap21.04.0.r598.g9c3ab76-121.04.1.r601.g4a1cadf-1
kpackage5.82.0.r658.g1383496-15.82.0.r659.g2e761f3-1
kparts5.82.0.r505.g9c67cf3-15.82.0.r506.g4dcd25c-1
kpat21.04.0.r2535.g7f3a697-121.04.1.r2542.gade49f9-1
kpeople5.82.0.r1317.g84b08fa-15.82.0.r1319.gad1afe3-1
kpimtextedit21.04.0.r1379.g7aa52a8-121.04.1.r1380.gb7966ce-1
kpkpass21.04.0.r214.g7c34faf-121.04.1.r215.ga5daca8-1
kplotting5.82.0.r280.gf0e6766-15.82.0.r281.g41f6e16-1
kpmcore21.04.0.r1192.gf018824-121.04.1.r1192.gf018824-1
kpty5.82.0.r322.g50d257f-15.82.0.r325.g231faa0-1
kpublictransport21.04.0.r1637.g41ffea5-121.04.1.r1639.gf5ee9a3-1
kqtquickcharts21.04.0.r74.g264af68-121.04.1.r74.g264af68-1
kquickcharts5.82.0.r453.g64ecbe3-15.82.0.r454.g4023aa6-1
krdc21.04.0.r1504.g8d3e6a8-121.04.1.r1504.g8d3e6a8-1
krecorder r105.g7b053d1-1 21.05.r12.ge65db0a-1
kreversi21.04.0.r1212.gab43d70-121.04.1.r1212.gab43d70-1
krfb21.04.0.r1389.g4d84d14-121.04.1.r1389.g4d84d14-1
kross5.82.0.r323.g752c6c2-15.82.0.r324.g6664a5a-1
kross-interpreters21.04.0.r722.g8d54326-121.04.1.r722.g8d54326-1
kruler21.04.0.r683.ga339db9-121.04.1.r683.ga339db9-1
krunner5.82.0.r626.gbe1569d-15.82.0.r627.gf60ec40-1
kscreen5.21.4.r1330.ge3166a4-15.21.5.r1331.gefc7de1-1
kscreenlocker5.21.4.r848.g94b3b13-15.21.5.r850.g4913b97-1
kservice5.82.0.r910.g352f3cc-15.82.0.r911.g2986322-1
kshisen21.04.0.r1179.g1bb38f7-121.04.1.r1179.g1bb38f7-1
ksirk21.04.0.r955.g2e2802d-121.04.1.r955.g2e2802d-1
ksmtp21.04.0.r348.g66e416f-121.04.1.r348.g66e416f-1
ksnakeduel21.04.0.r790.g9d21e6d-121.04.1.r790.g9d21e6d-1
kspaceduel21.04.0.r618.ge89b150-121.04.1.r618.ge89b150-1
ksquares21.04.0.r508.g81035e0-121.04.1.r508.g81035e0-1
ksshaskpass5.21.4.r196.gdaa2679-15.21.5.r196.gdaa2679-1
ksudoku21.04.0.r1040.gd68d5e8-121.04.1.r1040.gd68d5e8-1
ksysguard5.21.4.r3503.g5b75d854-15.21.5.r3503.g5b75d854-1
ksystemlog21.04.0.r634.gf575aeb-121.04.1.r635.g66c0bd7-1
ksystemstats5.21.4.r166.g93e8a93-15.21.5.r169.g6abf71d-1
kteatime21.04.0.r712.g048e691-121.04.1.r712.g048e691-1
ktexteditor5.82.0.r2844.g503bbae6-15.82.0.r2851.gedef8135-1
ktextwidgets5.82.0.r397.g88ef5c0-15.82.0.r398.g93d3f80-1
ktimer21.04.0.r457.g19eb39b-121.04.1.r458.g9122030-1
ktnef21.04.0.r644.g01c8435-121.04.1.r645.g71a9ae1-1
ktorrent21.04.0.r2747.g6c1ae6b2-121.04.1.r2747.g6c1ae6b2-1
ktouch21.04.0.r2129.g1031773-121.04.1.r2132.g226f24a-1
ktrip 21.05.r6.g945e9e5-1 21.05.r11.g2e76e7c-1
ktuberling21.04.0.r996.g355a044-121.04.1.r996.g355a044-1
kturtle21.04.0.r1109.g5fa3fb6-121.04.1.r1110.gf3a82c7-1
kubrick21.04.0.r361.gde000c9-121.04.1.r361.gde000c9-1
kunitconversion5.82.0.r361.gfc798b0-15.82.0.r362.gca29af6-1
kwallet5.82.0.r1065.g635efda-15.82.0.r1067.g66794c9-1
kwallet-pam5.21.4.r242.g96e0e42-15.21.5.r244.gb93e8c6-1
kwalletmanager21.04.0.r1187.g24647bc-121.04.1.r1188.gf593224-1
kwave21.04.0.r3734.gccbd284f-121.04.1.r3734.gccbd284f-1
kwayland5.82.0.r1085.gca1ddbe-15.82.0.r1086.g8bc536d-1
kwayland-integration5.21.4.r173.gcaec340-15.21.5.r173.gcaec340-1
kwayland-server5.21.4.r1324.g6851561-15.21.5.r1332.gbd7b0f5-1
kweather 0.4.r86.gbab7626-1 0.4.r93.gce3bc81-1
kwidgetsaddons5.82.0.r813.gd74d6fac-15.82.0.r817.gd375f5a7-1
kwin5.21.4.r19425.g86ce04a7f-15.21.5.r19461.geb27d312a-1
kwindowsystem5.82.0.r588.gcac726b-15.82.0.r590.g6b16989-1
kwordquiz21.04.0.r1135.g9690f4f-121.04.1.r1135.g9690f4f-1
kwrite21.04.0.r18147.gd7b24e093-121.04.1.r18184.gc095d67e6-1
kwrited5.21.4.r478.gb687e84-15.21.5.r478.gb687e84-1
kxmlgui5.82.0.r758.gcca89e76-15.82.0.r760.g778badac-1
kxmlrpcclient5.82.0.r446.gd6b071ecb-15.82.0.r447.gc11427d55-1
layer-shell-qt5.21.4.r41.g9af3c35-15.21.5.r41.g9af3c35-1
libakonadi21.04.0.r12501.g8872f3ca5-121.04.1.r12502.g37b955fcb-1
libgravatar21.04.0.r348.g22a723c-121.04.1.r349.g6941b9e-1
libkcddb21.04.0.r736.g24d5755-121.04.1.r736.g24d5755-1
libkcompactdisc21.04.0.r386.g4f9a6d2-121.04.1.r386.g4f9a6d2-1
libkdcraw21.04.0.r1148.g4af2f68-121.04.1.r1148.g4af2f68-1
libkdegames21.04.0.r2175.g40f1d5da-121.04.1.r2175.g40f1d5da-1
libkdepim21.04.0.r828.gd9453c2-121.04.1.r829.gdc21970-1
libkeduvocdocument21.04.0.r1791.g4966f86-121.04.1.r1791.g4966f86-1
libkexiv221.04.0.r815.gb0e00f4-121.04.1.r815.gb0e00f4-1
libkgapi21.04.0.r1274.g8ff5d23-121.04.1.r1276.g0f1a1fe-1
libkipi21.04.0.r1250.geea9c7b-121.04.1.r1250.geea9c7b-1
libkleo21.04.0.r872.g03b1e46-121.04.1.r881.gb45c40d-1
libkmahjongg21.04.0.r448.gc7aa7ac-121.04.1.r448.gc7aa7ac-1
libkomparediff221.04.0.r336.g36da81f-121.04.1.r336.g36da81f-1
libksane21.04.0.r527.g5e6e06e-121.04.1.r529.gce99272-1
libkscreen5.21.4.r1578.gada0797-15.21.5.r1578.gada0797-1
libksieve21.04.0.r1525.geeb62b12-121.04.1.r1526.g8e90710e-1
libksysguard5.21.4.r2228.g56f2e71-15.21.5.r2232.g3ab65f7-1
libktorrent21.04.0.r515.g56be4b3-121.04.1.r515.g56be4b3-1
lokalize21.04.0.r1756.g0ef5691-121.04.1.r1757.g1586fab-1
lskat21.04.0.r801.g1f6ab84-121.04.1.r801.g1f6ab84-1
mailcommon21.04.0.r1034.g8a737e7-121.04.1.r1035.gdabdc14-1
mailimporter21.04.0.r449.gfe70972-121.04.1.r451.g3054952-1
marble21.04.0.r13307.g81d173986-121.04.1.r13309.g64de32f42-1
marble-common21.04.0.r13307.g81d173986-121.04.1.r13309.g64de32f42-1
marble-qt21.04.0.r13307.g81d173986-121.04.1.r13309.g64de32f42-1
markdownpart21.04.0.r68.g5d7c59f-121.04.1.r69.g6a610bf-1
maui-clip 1.1.1.r3.gc0636b4-1 1.1.1.r4.g148deda-1
maui-nota 1.2.2.r15.gc74b6ef-1 1.2.2.r24.g7c9b6ce-1
maui-pix 1.2.2.r17.gbac51ed-1 1.2.2.r23.g182219a-1
mauikit1.2.2.r30.g55e5d76a-12.2.2.r49.g58a4fa6d-1
mauikit-filebrowsing 1.2.2.r17.g7bbc7a0-1 1.2.2.r28.g21cc7d1-1
mbox-importer21.04.0.r492.gc4bc6f0-121.04.1.r492.gc4bc6f0-1
messagelib21.04.0.r5946.g8c89a6f0-121.04.0.r5965.g42a922ac-1
milou5.21.4.r742.gd36b220-15.21.5.r742.gd36b220-1
minuet21.04.0.r573.g85a0ed2-121.04.1.r573.g85a0ed2-1
neochat r1664.g179139c6-1 r1720.gb37152ff-1
networkmanager-qt5.82.0.r1103.gbe1e011-15.82.0.r1104.g57b9743-1
okular21.04.0.r9333.g8b13d989c-121.04.1.r9333.g8b13d989c-1
oxygen5.21.4.r4415.ga5a7f382-15.21.5.r4415.ga5a7f382-1
palapeli21.04.0.r1221.g8c7b0b6-121.04.1.r1221.g8c7b0b6-1
parley21.04.0.r4407.g8e46f541-121.04.1.r4407.g8e46f541-1
partitionmanager21.04.0.r1524.g2b7cf50-121.04.1.r1524.g2b7cf50-1
peruse 1.80.r6.g25247a1-1 1.80.r10.g8e9dec6-1
picmi21.04.0.r523.g4e8e0d8-121.04.1.r523.g4e8e0d8-1
pim-data-exporter21.04.0.r2408.g77fec9d6-121.04.1.r2409.g83aaa2d2-1
pim-sieve-editor21.04.0.r1474.g58e2564-121.04.1.r1476.g34c1346-1
pimcommon21.04.0.r1050.gea35021-121.04.1.r1051.g0e243ee-1
plasma-browser-integration5.21.4.r1254.gcedda05a-15.21.5.r1254.gcedda05a-1
plasma-camera 1.0.r102.gaf63172-1 1.0.r103.g527fa8e-1
plasma-desktop5.21.4.r8471.g93e29d4b5-15.21.5.r8480.g7452d5c9b-1
plasma-dialer 21.05.r21.g0ff5a8b-1 21.05.r37.g5ca8ae7-1
plasma-disks5.21.4.r208.g5efaaee-15.21.5.r208.g5efaaee-1
plasma-firewall5.21.4.r491.gfdb224d-15.21.5.r491.gfdb224d-1
plasma-framework5.82.0.r15856.g532817c00-15.82.0.r15858.gba1bf63e0-1
plasma-integration5.21.4.r517.ged1c2fa-15.21.5.r517.ged1c2fa-1
plasma-nano5.21.4.r146.g47f2857-15.21.5.r146.g47f2857-1
plasma-nm5.21.4.r3046.gd5df9379-15.21.5.r3051.g9005f258-1
plasma-pa5.21.4.r942.g1982415-15.21.5.r945.gffdeb49-1
plasma-phone-components5.21.4.r1401.g70794cd9-15.21.4.r1403.g17899f59-1
plasma-phonebook r245.ga14896c-1 21.05.r26.gab4187e-1
plasma-sdk5.21.4.r2268.gc69fe2ca-15.21.5.r2269.g17f23ef8-1
plasma-settings r880.g7d1294e-1 21.05.r2.g7d1294e-1
plasma-systemmonitor5.21.4.r431.ge13a2ba-15.21.5.r435.g2255865-1
plasma-thunderbolt5.21.4.r131.g4040d01-15.21.5.r131.g4040d01-1
plasma-vault5.21.4.r332.geb439e8-15.21.5.r333.geeba90d-1
plasma-wayland-session5.21.4.r10283.g512135a65-15.21.5.r10328.g46c784099-1
plasma-workspace5.21.4.r10283.g512135a65-15.21.5.r10328.g46c784099-1
plasma-workspace-wallpapers5.21.4.r265.g6ab7ee5-15.21.5.r268.gbf1c8c2-1
polkit-kde-agent5.21.4.r494.g644acd1-15.21.5.r497.gaa6f7c5-1
powerdevil5.21.4.r2435.g9c0011a4-15.21.5.r2436.gf66333c5-1
poxml21.04.0.r277.ge2d4dfb-121.04.1.r277.ge2d4dfb-1
print-manager21.04.0.r1025.g52f0d1e-121.04.1.r1025.g52f0d1e-1
prison5.82.0.r312.g8ee4c59-15.82.0.r313.g56d8d03-1
purpose5.82.0.r853.ge72823b-15.82.0.r855.gd985896-1
qcachegrind21.04.0.r1146.g15e2900-121.04.1.r1146.g15e2900-1
qmlkonsole r87.g51d8906-1 21.05.r1.g51d8906-1
qqc2-desktop-style5.82.0.r484.g7927dfc-15.82.0.r485.gdc00d5e-1
rocs21.04.0.r3014.gc0cdea56-121.04.1.r3016.g80c7c4a9-1
sddm-kcm5.21.4.r585.gaa73d52-15.21.5.r585.gaa73d52-1
signon-kwallet-extension21.04.0.r64.g47e187d-121.04.1.r64.g47e187d-1
solid5.82.0.r669.g2ef5994-15.82.0.r672.ga6b0cca-1
sonnet5.82.0.r612.gf22c7ae-15.82.0.r614.gfe0e8bd-1
spacebar r394.g01b942b-1 21.05.r12.g9f3a670-1
spectacle21.04.0.r1095.g5ea0904-121.04.1.r1099.ge3591e0-1
step21.04.0.r1150.gcad0ff4-121.04.1.r1150.gcad0ff4-1
svgpart21.04.0.r163.g466a7b8-121.04.1.r163.g466a7b8-1
sweeper21.04.0.r514.g38eec9d-121.04.1.r518.g7c73cbf-1
syndication5.82.0.r824.g6d4da68-15.82.0.r825.g91e4653-1
syntax-highlighting5.82.0.r1583.ge425acd3-15.82.0.r1586.g09d72d8a-1
systemsettings5.21.4.r2435.gc84cbad1-15.21.5.r2436.gcef4ec6d-1
telepathy-kde-accounts-kcm21.04.0.r1192.g5a27a75-121.04.1.r1192.g5a27a75-1
telepathy-kde-approver21.04.0.r293.g45db24b-121.04.1.r293.g45db24b-1
telepathy-kde-auth-handler21.04.0.r276.g48e529c-121.04.1.r276.g48e529c-1
telepathy-kde-call-ui21.04.0.r445.g8815182-121.04.1.r445.g8815182-1
telepathy-kde-common-internals21.04.0.r1993.g48d6a2e-121.04.1.r1993.g48d6a2e-1
telepathy-kde-contact-list21.04.0.r1084.gd88224a-121.04.1.r1084.gd88224a-1
telepathy-kde-contact-runner21.04.0.r252.g6d4f602-121.04.1.r252.g6d4f602-1
telepathy-kde-desktop-applets21.04.0.r992.g4a74f96-121.04.1.r992.g4a74f96-1
telepathy-kde-filetransfer-handler21.04.0.r219.gd345782-121.04.1.r219.gd345782-1
telepathy-kde-integration-module21.04.0.r390.g08eac55-121.04.1.r390.g08eac55-1
telepathy-kde-send-file21.04.0.r227.g53297c0-121.04.1.r227.g53297c0-1
telepathy-kde-text-ui21.04.0.r2019.g2cae1c7-121.04.1.r2019.g2cae1c7-1
threadweaver5.82.0.r496.ge102103-15.82.0.r497.gee8e878-1
umbrello21.04.0.r8248.gcf9dae8f9-121.04.1.r8257.g9b481200c-1
vvave 1.2.2.r15.g9abcc66-1 1.2.2.r16.g5ea8a80-1
xdg-desktop-portal-kde5.21.4.r364.gf4ef1a2-15.21.5.r366.gabe6410-1
yakuake21.04.0.r719.g528c400-121.04.1.r719.g528c400-1
zeroconf-ioslave21.04.0.r336.g9bfa090-121.04.1.r336.g9bfa090-1
alligator - 21.05.r6.ga334e64-1
koko - 21.05.r12.g4fbf9dd-1
marble-maps -21.04.0.r13309.g64de32f42-1
pico-wizard-git - r125.bf62c5c-1
pico-wizard-plamo-scripts - r125.bf62c5c-1
pulseaudio-qt - 1.3.0.r0.g204f0ca-1
:: Different overlay package(s) in repository mobile aarch64
kquickimageeditor r36.gd044a7a-1.2 -
ktrip 0.99.5-1.4 -
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
