[ARM Testing Update] 2021-05-23 - Kernels, Phosh, Tesseract, Python, Thunderbird, Plasma-Mobile-Dev
Hello ARM community.
Here’s another rather small testing update, but some important things are included.
Get Manjaro on any device, even on this Flip-Phone via Manjaro Shells
Some highlights:
  • Some of our Kernels got updated
  • We fixed headset button handling and jack/mic plug in/plug out detection for the pinephone
  • More updates to our Phosh edition for the pinephone
  • Tesseract and Python updates
  • Thunderbird is now at 78.10.2
  • Lots of Mobile specific packages got updated
Click to read HowTo
If anyone wants to test kodi on the rpi:
Change to the unstable or testing branch and install kodi packages:
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sun May 23 10:36:54 CEST 2021)
  • arm-testing community aarch64: 248 new and 217 removed package(s)
  • arm-testing core aarch64: 9 new and 9 removed package(s)
  • arm-testing extra aarch64: 109 new and 97 removed package(s)
  • arm-testing kde-unstable aarch64: 81 new and 79 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE           2021-05-20           2021-05-23
                           bitwarden             1.26.3-1             1.26.4-1
                               calls  0.3.2+32+g1db1ba6-1   0.3.3+1+g2ac43f3-1
                              chatty              0.3.0-1  0.3.0+11+ge3c0d0a-1
                        eg25-manager   0.3.0+2+g64145ac-5   0.3.0+2+g64145ac-6
                       libmm-pp-glib             1.16.4-2             1.16.4-3
                    matcha-gtk-theme           20200727-1           20210520-1
                     modemmanager-pp             1.16.4-2             1.16.4-3
                               phosh 0.10.2+57+gb03323e-10.10.2+134+gb2e68d2-2
                               siglo              0.7.0-1              0.8.0-1
                         squeekboard  1.13.0+3+g0bc654b-1  1.14.0+3+g1963033-1
:: Different sync package(s) in repository community aarch64
                           alacritty              0.7.2-1              0.8.0-1
                        ansible-lint              5.0.8-1             5.0.10-2
                              ardour                6.6-2                6.7-2
                                borg             1.1.16-4             1.1.16-5
                            bugzilla              5.0.6-2              5.0.6-3
                             buildah             1.20.1-1             1.21.0-1
                             calibre             5.17.0-1             5.18.0-1
                             certbot             1.15.0-1             1.15.0-2
                    cockpit-machines                244-1              244.1-1
                          containerd              1.5.1-1              1.5.2-1
              debian-archive-keyring             2019.1-2           2021.1.1-1
                           duplicity             0.8.18-2             0.8.19-1
                              eslint             7.26.0-1             7.27.0-1
                          exfatprogs              1.1.1-1              1.1.2-1
                             freehdl             0.0.8-10             0.0.8-11
                                 fzf             0.27.0-1             0.27.1-1
                                giac            1.7.0.7-1            1.7.0.9-1
                          github-cli             1.10.1-1             1.10.3-1
                            go-tools 2:1.16+4895+c1934b75d-1         4:0.1.1-1
                               hiera              3.6.0-2              3.7.0-1
                             htmldoc             1.9.11-1             1.9.12-1
                                i2pd             2.37.0-2             2.38.0-1
                            innernet              1.2.0-1              1.3.0-1
                   jupyter-nbclassic              0.2.8-1              0.3.1-1
                      jupyter-server              1.7.0-2              1.8.0-1
                                 k9s             0.24.9-1            0.24.10-1
                                 kup              0.9.0-1              0.9.0-2
                              libc++             11.1.0-1             12.0.0-1
                           libc++abi             11.1.0-1             12.0.0-1
                  libc++experimental             11.1.0-1             12.0.0-1
                            libslirp              4.4.0-1              4.5.0-1
                             mailnag              2.2.0-2              2.2.0-3
                              marked              2.0.3-1              2.0.5-1
                             netdata             1.30.1-2             1.31.0-1
                                 npm             7.13.0-1             7.14.0-1
                                pass              1.7.3-3              1.7.3-4
                    perl-test-simple           1.302184-1           1.302185-1
                            plantuml           1.2021.5-1           1.2021.6-1
                        playitslowly              1.5.1-5              1.5.1-7
                              podman              3.1.2-1              3.1.2-2
                       podman-docker              3.1.2-1              3.1.2-2
                              puppet             6.21.1-2             6.22.1-1
                             puppet5             5.5.22-2             5.5.22-3
                        python-anyio              3.0.1-1              3.1.0-1
                     python-cfn-lint             0.49.1-1             0.49.2-1
                        python-click              8.0.0-2              8.0.1-1
                python-dogpile.cache              1.1.2-1              1.1.3-1
                        python-faker              8.2.0-1              8.2.1-1
              python-google-api-core             1.26.3-1             1.28.0-1
     python-google-api-python-client              2.4.0-1              2.5.0-1
                    python-httpretty              1.1.1-1              1.1.2-1
                   python-hypothesis             6.13.0-1             6.13.1-1
                     python-identify              2.2.4-1              2.2.5-1
                    python-justbases               0.14-3               0.15-1
                    python-justbytes               0.14-3               0.15-1
                         python-lmdb              1.1.1-1              1.2.1-1
                         python-moto              2.0.7-1              2.0.8-1
                     python-oslo-log              4.4.0-3              4.5.0-1
                       python-pg8000             1.19.4-1             1.19.5-1
                      python-pikepdf             2.12.0-1             2.12.1-1
                        python-qiniu              7.3.1-1              7.4.0-1
                         python-rich             10.2.0-1             10.2.2-1
                      python-serpent             1.30.2-5               1.40-1
                       python-sphinx              4.0.1-3              4.0.2-1
                      python-tomlkit              0.7.1-1              0.7.2-1
                      python-wcmatch              8.1.2-1                8.2-1
                     python-werkzeug              2.0.0-2              2.0.1-1
                       rust-libslirp              4.3.0-1              4.3.0-2
                      shairport-sync              3.3.7-1              3.3.8-1
                           skk-jisyo           20210509-1           20210523-1
                              skopeo              1.2.3-1              1.3.0-1
                         slirp4netns              1.1.9-1             1.1.10-1
                         stratis-cli              2.3.0-1              2.4.0-1
                               swtpm              0.5.2-1              0.5.2-2
                           tailscale              1.8.3-1              1.8.5-1
                           tesseract              4.1.1-6              4.1.1-7
                  tesseract-data-afr            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-amh            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-ara            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-asm            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-aze            2:4.0.0-2            2:4.1.0-1
             tesseract-data-aze_cyrl            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-bel            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-ben            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-bod            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-bos            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-bre            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-bul            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-cat            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-ceb            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-ces            2:4.0.0-2            2:4.1.0-1
              tesseract-data-chi_sim            2:4.0.0-2            2:4.1.0-1
              tesseract-data-chi_tra            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-chr            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-cos            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-cym            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-dan            2:4.0.0-2            2:4.1.0-1
             tesseract-data-dan_frak            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-deu            2:4.0.0-2            2:4.1.0-1
             tesseract-data-deu_frak            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-dzo            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-ell            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-eng            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-enm            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-epo            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-equ            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-est            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-eus            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-fao            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-fas            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-fil            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-fin            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-fra            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-frk            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-frm            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-fry            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-gla            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-gle            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-glg            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-grc            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-guj            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-hat            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-heb            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-hin            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-hrv            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-hun            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-hye            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-iku            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-ind            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-isl            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-ita            2:4.0.0-2            2:4.1.0-1
              tesseract-data-ita_old            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-jav            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-jpn            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-kan            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-kat            2:4.0.0-2            2:4.1.0-1
              tesseract-data-kat_old            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-kaz            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-khm            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-kir            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-kor            2:4.0.0-2            2:4.1.0-1
             tesseract-data-kor_vert            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-kur            2:4.0.0-2                    -
                  tesseract-data-lao            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-lat            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-lav            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-lit            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-ltz            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-mal            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-mar            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-mkd            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-mlt            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-mon            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-mri            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-msa            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-mya            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-nep            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-nld            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-nor            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-oci            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-ori            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-osd            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-pan            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-pol            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-por            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-pus            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-que            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-ron            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-rus            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-san            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-sin            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-slk            2:4.0.0-2            2:4.1.0-1
             tesseract-data-slk_frak            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-slv            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-snd            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-spa            2:4.0.0-2            2:4.1.0-1
              tesseract-data-spa_old            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-sqi            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-srp            2:4.0.0-2            2:4.1.0-1
             tesseract-data-srp_latn            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-sun            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-swa            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-swe            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-syr            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-tam            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-tat            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-tel            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-tgk            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-tgl            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-tha            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-tir            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-ton            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-tur            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-uig            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-ukr            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-urd            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-uzb            2:4.0.0-2            2:4.1.0-1
             tesseract-data-uzb_cyrl            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-vie            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-yid            2:4.0.0-2            2:4.1.0-1
                  tesseract-data-yor            2:4.0.0-2            2:4.1.0-1
                           throttled                0.8-2                0.9-1
                             todoman              3.9.0-2              4.0.0-1
         v2ray-domain-list-community     20210519075125-1     20210523034918-1
                         v2ray-geoip       202105130030-1       202105200028-1
                              websvn                2.5-1              2.6.1-1
              xdg-desktop-portal-wlr              0.3.0-1              0.3.0-2
                             blanket                    -              0.4.1-1
                          ocaml-base                    -             0.14.1-1
                      ocaml-hashcons                    -                1.3-1
                      ocaml-sexplib0                    -             0.14.0-2
          python-pytest-datafixtures                    -              1.0.0-1
          python-pytest-responsemock                    -              1.0.1-1
                   python-torrentool                    -              1.1.1-1
                       ruby27-augeas                    -              0.5.0-2
                   ruby27-concurrent                    -              1.1.8-1
                   ruby27-deep_merge                    -              1.2.1-1
                     ruby27-diff-lcs                    -              1.4.4-1
                        ruby27-hocon                    -              1.3.1-2
                          ruby27-hoe                    -             3.22.3-3
                   ruby27-httpclient                    -              2.8.3-2
                     ruby27-minitest                    -             5.14.3-3
                        ruby27-mocha                    -             1.12.0-1
                   ruby27-multi_json                    -             1.15.0-1
                 ruby27-power_assert                    -              2.0.0-1
          ruby27-puppet-resource_api                    -             1.8.13-1
                         ruby27-rake                    -             13.0.3-2
                         ruby27-rdoc                    -              6.3.1-1
                        ruby27-rspec                    -             3.10.0-1
                   ruby27-rspec-core                    -             3.10.1-2
           ruby27-rspec-expectations                    -             3.10.1-1
                  ruby27-rspec-mocks                    -             3.10.2-1
                ruby27-rspec-support                    -             3.10.2-1
              ruby27-semantic_puppet                    -              1.0.3-1
                       ruby27-shadow                    -              2.5.0-1
                         ruby27-sync                    -              0.5.0-1
                    ruby27-test-unit                    -              3.4.1-1
                  tesseract-data-div                    -            2:4.1.0-1
                  tesseract-data-kmr                    -            2:4.1.0-1
:: Different overlay package(s) in repository core aarch64
                               linux             5.12.5-1             5.12.6-1
                       linux-headers             5.12.5-1             5.12.6-1
                     linux-pinephone             5.12.5-1             5.12.6-2
             linux-pinephone-headers             5.12.5-1             5.12.6-2
                     uboot-pinephone         2021.01rc4-1         2021.01rc4-2
:: Different sync package(s) in repository core aarch64
                                kmod                 28-1                 29-1
                          kmod-debug                 28-1                 29-1
                                 lz4            1:1.9.3-1            1:1.9.3-2
                                zstd              1.4.9-1              1.5.0-1
:: Different sync package(s) in repository extra aarch64
                               atkmm             2.28.1-1             2.28.2-1
                          atkmm-docs             2.28.1-1             2.28.2-1
                                bind            9.16.15-1            9.16.16-1
                             cairomm             1.12.2-4             1.14.3-1
                        cairomm-docs             1.12.2-4             1.14.3-1
                            composer             2.0.13-1             2.0.14-1
                              glibmm             2.66.0-1             2.66.1-1
                         glibmm-docs             2.66.0-1             2.66.1-1
                              gtkmm3             3.24.4-1             3.24.5-1
                         gtkmm3-docs             3.24.4-1             3.24.5-1
                             ipp-usb             0.9.18-1             0.9.19-1
                            libepoxy              1.5.7-1              1.5.8-1
                         libmediaart   1.9.4+1+ga704d0b-2              1.9.5-1
                              libndp                1.7-2                1.8-1
                            liborcus             0.16.1-5             0.16.1-6
                      libphonenumber            8.12.22-1            8.12.23-1
                           libsigc++             2.10.6-1             2.10.7-1
                      libsigc++-docs             2.10.6-1             2.10.7-1
                              libwpd             0.10.3-2             0.10.3-3
                           mm-common              1.0.2-1              1.0.3-1
                             pangomm             2.46.0-1             2.46.1-1
                        pangomm-docs             2.46.0-1             2.46.1-1
               perl-extutils-depends             0.8000-4             0.8001-1
                                qemu              6.0.0-2              6.0.0-3
                     qemu-arch-extra              6.0.0-2              6.0.0-3
                  qemu-block-gluster              6.0.0-2              6.0.0-3
                    qemu-block-iscsi              6.0.0-2              6.0.0-3
                    qemu-guest-agent              6.0.0-2              6.0.0-3
                       qemu-headless              6.0.0-2              6.0.0-3
            qemu-headless-arch-extra              6.0.0-2              6.0.0-3
                         qt5-wayland     5.15.2+kde+r22-1     5.15.2+kde+r23-1
                         thunderbird            78.10.1-1            78.10.2-1
                 thunderbird-i18n-af            78.10.1-1            78.10.2-1
                 thunderbird-i18n-ar            78.10.1-1            78.10.2-1
                thunderbird-i18n-ast            78.10.1-1            78.10.2-1
                 thunderbird-i18n-be            78.10.1-1            78.10.2-1
                 thunderbird-i18n-bg            78.10.1-1            78.10.2-1
                 thunderbird-i18n-br            78.10.1-1            78.10.2-1
                 thunderbird-i18n-ca            78.10.1-1            78.10.2-1
                thunderbird-i18n-cak            78.10.1-1            78.10.2-1
                 thunderbird-i18n-cs            78.10.1-1            78.10.2-1
                 thunderbird-i18n-cy            78.10.1-1            78.10.2-1
                 thunderbird-i18n-da            78.10.1-1            78.10.2-1
                 thunderbird-i18n-de            78.10.1-1            78.10.2-1
                thunderbird-i18n-dsb            78.10.1-1            78.10.2-1
                 thunderbird-i18n-el            78.10.1-1            78.10.2-1
              thunderbird-i18n-en-gb            78.10.1-1            78.10.2-1
              thunderbird-i18n-en-us            78.10.1-1            78.10.2-1
              thunderbird-i18n-es-ar            78.10.1-1            78.10.2-1
              thunderbird-i18n-es-es            78.10.1-1            78.10.2-1
                 thunderbird-i18n-et            78.10.1-1            78.10.2-1
                 thunderbird-i18n-eu            78.10.1-1            78.10.2-1
                 thunderbird-i18n-fa            78.10.1-1            78.10.2-1
                 thunderbird-i18n-fi            78.10.1-1            78.10.2-1
                 thunderbird-i18n-fr            78.10.1-1            78.10.2-1
              thunderbird-i18n-fy-nl            78.10.1-1            78.10.2-1
              thunderbird-i18n-ga-ie            78.10.1-1            78.10.2-1
                 thunderbird-i18n-gd            78.10.1-1            78.10.2-1
                 thunderbird-i18n-gl            78.10.1-1            78.10.2-1
                 thunderbird-i18n-he            78.10.1-1            78.10.2-1
                 thunderbird-i18n-hr            78.10.1-1            78.10.2-1
                thunderbird-i18n-hsb            78.10.1-1            78.10.2-1
                 thunderbird-i18n-hu            78.10.1-1            78.10.2-1
              thunderbird-i18n-hy-am            78.10.1-1            78.10.2-1
                 thunderbird-i18n-id            78.10.1-1            78.10.2-1
                 thunderbird-i18n-is            78.10.1-1            78.10.2-1
                 thunderbird-i18n-it            78.10.1-1            78.10.2-1
                 thunderbird-i18n-ja            78.10.1-1            78.10.2-1
                 thunderbird-i18n-ka            78.10.1-1            78.10.2-1
                thunderbird-i18n-kab            78.10.1-1            78.10.2-1
                 thunderbird-i18n-kk            78.10.1-1            78.10.2-1
                 thunderbird-i18n-ko            78.10.1-1            78.10.2-1
                 thunderbird-i18n-lt            78.10.1-1            78.10.2-1
                 thunderbird-i18n-ms            78.10.1-1            78.10.2-1
              thunderbird-i18n-nb-no            78.10.1-1            78.10.2-1
                 thunderbird-i18n-nl            78.10.1-1            78.10.2-1
              thunderbird-i18n-nn-no            78.10.1-1            78.10.2-1
              thunderbird-i18n-pa-in            78.10.1-1            78.10.2-1
                 thunderbird-i18n-pl            78.10.1-1            78.10.2-1
              thunderbird-i18n-pt-br            78.10.1-1            78.10.2-1
              thunderbird-i18n-pt-pt            78.10.1-1            78.10.2-1
                 thunderbird-i18n-rm            78.10.1-1            78.10.2-1
                 thunderbird-i18n-ro            78.10.1-1            78.10.2-1
                 thunderbird-i18n-ru            78.10.1-1            78.10.2-1
                 thunderbird-i18n-si            78.10.1-1            78.10.2-1
                 thunderbird-i18n-sk            78.10.1-1            78.10.2-1
                 thunderbird-i18n-sl            78.10.1-1            78.10.2-1
                 thunderbird-i18n-sq            78.10.1-1            78.10.2-1
                 thunderbird-i18n-sr            78.10.1-1            78.10.2-1
              thunderbird-i18n-sv-se            78.10.1-1            78.10.2-1
                 thunderbird-i18n-th            78.10.1-1            78.10.2-1
                 thunderbird-i18n-tr            78.10.1-1            78.10.2-1
                 thunderbird-i18n-uk            78.10.1-1            78.10.2-1
                 thunderbird-i18n-uz            78.10.1-1            78.10.2-1
                 thunderbird-i18n-vi            78.10.1-1            78.10.2-1
              thunderbird-i18n-zh-cn            78.10.1-1            78.10.2-1
              thunderbird-i18n-zh-tw            78.10.1-1            78.10.2-1
                          atkmm-2.36                    -             2.36.1-1
                     atkmm-2.36-docs                    -             2.36.1-1
                        cairomm-1.16                    -             1.16.1-1
                   cairomm-1.16-docs                    -             1.16.1-1
                         glibmm-2.68                    -             2.68.1-1
                    glibmm-2.68-docs                    -             2.68.1-1
                           gtkmm-4.0                    -              4.0.2-1
                      gtkmm-4.0-docs                    -              4.0.2-1
                       libsigc++-3.0                    -              3.0.7-1
                  libsigc++-3.0-docs                    -              3.0.7-1
                        pangomm-2.48                    -             2.48.1-1
                   pangomm-2.48-docs                    -             2.48.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
                    akonadi-contacts21.04.0.r3007.gf7b8feae-121.04.0.r3008.ga0e5aad2-1
                                 ark21.04.0.r4523.gda30c880-121.04.0.r4525.g758ab874-1
                          artikulate21.04.0.r1380.ga978798-121.04.0.r1382.g804ed9f-1
                              breeze5.21.4.r2184.g9029eeac-15.21.4.r2187.g2db1c9a6-1
                        breeze-icons5.82.0.r1742.ge82ba721-15.82.0.r1744.g37d39fa6-1
                                buho 1.2.2.r11.g7af6469-1 1.2.2.r12.g1452b64-1
                             dolphin21.04.0.r6583.g953b25367-121.04.0.r6589.g5fca9ee72-1
                             drkonqi5.21.4.r641.geef480ca-15.21.4.r645.g54fff58b-1
                               elisa21.04.0.r2700.gd3656166-121.04.0.r2706.g86468666-1
                 extra-cmake-modules5.82.0.r3304.g9d22f7b-15.82.0.r3306.g08faec5-1
                       grantleetheme21.04.0.r320.gdcd390d-121.04.0.r321.g3223868-1
                            gwenview21.04.0.r6594.g7cc1638d-121.04.0.r6599.ge8082e36-1
                     incidenceeditor21.04.0.r711.ga921f1f-121.04.0.r722.gfc7621e-1
                            index-fm 1.2.2.r16.g01c2d6f-1 1.2.2.r21.g3848666-1
                           itinerary21.04.0.r1282.g6eb1d9c-121.04.0.r1285.g2df27eb-1
                            kalgebra21.04.0.r2028.g68e7fab-121.04.0.r2029.ge96cb59-1
                              kamoso21.04.0.r1420.g2d6e04d-121.04.0.r1424.g9d1a5da-1
                            kanagram21.04.0.r1274.ge5f6d91-121.04.0.r1275.g552fd82-1
                                kate21.04.0.r18142.g5c5ef2cc9-121.04.0.r18147.gd7b24e093-1
                             kbackup21.04.0.r357.g76bf2ed-121.04.0.r362.g5db07f6-1
                       kcalendarcore5.82.0.r1204.g58bf11594-15.82.0.r1205.gbebcf5735-1
                      kconfigwidgets5.82.0.r572.g69e5222-15.82.0.r573.g901b049-1
                         kcoreaddons5.82.0.r1220.gd7f85915-25.82.0.r1220.gd7f85915-3
                      kdebugsettings21.04.0.r802.g6721119-121.04.0.r805.g6c91a72-1
                     kdelibs4support5.82.0.r1015.g932e9bed-15.82.0.r1016.g0c3bb92f-1
                            kdenlive21.04.0.r14460.g897371d74-121.04.0.r14465.gad1326017-1
                      kdepim-runtime21.04.0.r15096.ge54ef199c-121.04.0.r15097.g2a647edde-1
                    kdeplasma-addons5.21.4.r8519.ga266b6f82-15.21.4.r8520.ga6435e48c-1
                             kdialog21.04.0.r1178.g9746cda9b-121.04.0.r1179.g1906217e5-1
                               ki18n5.82.0.r462.g6878ea3-25.82.0.r462.g6878ea3-3
                                 kio5.82.0.r4738.g41ba2d6f-15.82.0.r4742.g828ab431-1
                           kirigami25.82.0.r2788.gfe9ba293-15.82.0.r2789.g78369021-1
                         kitemmodels5.82.0.r538.g9b0630d-15.82.0.r538.g9b0630d-2
                          kitinerary21.04.0.r1770.gfc2ae06-121.04.0.r1789.g4f80b58-1
                           kleopatra21.04.0.r5834.g85f4b7bf-121.04.0.r5859.g7c58a35a-1
                               kmail21.04.0.r25731.g7fc0f3b1c-121.04.0.r25736.gd28e0c36c-1
                      kmailtransport21.04.0.r1602.g73fb839-121.04.0.r1603.g4866f33-1
                                kmix21.04.0.r2359.g61dc3141-121.04.0.r2365.gbec8b34b-1
                           knewstuff5.82.0.r1098.gda89aa1f-15.82.0.r1099.g68828447-1
                            kontrast21.04.0.r165.ge4cb989-121.04.0.r166.gf0423b2-1
                          korganizer21.04.0.r11365.gfa2358189-121.04.0.r11367.g419edd0d8-1
                                kpat21.04.0.r2532.g15f552d-121.04.0.r2535.g7f3a697-1
                        kpimtextedit21.04.0.r1378.g2b94f23-121.04.0.r1379.g7aa52a8-1
                           kplotting5.82.0.r279.ga85eb04-15.82.0.r280.gf0e6766-1
                    kpublictransport21.04.0.r1620.g7cc77e3-121.04.0.r1637.g41ffea5-1
                                krfb21.04.0.r1382.g5e18689-121.04.0.r1389.g4d84d14-1
                             kscreen5.21.4.r1329.g7382845-15.21.4.r1330.ge3166a4-1
                       kscreenlocker5.21.4.r847.g52a439b-15.21.4.r848.g94b3b13-1
                               ksmtp21.04.0.r347.g21100c9-121.04.0.r348.g66e416f-1
                         ktexteditor5.82.0.r2842.g2913ea2f-15.82.0.r2844.g503bbae6-1
                        ktextwidgets5.82.0.r396.gff907fe-15.82.0.r397.g88ef5c0-1
                            ktorrent21.04.0.r2746.gce382c22-121.04.0.r2747.g6c1ae6b2-1
                     kunitconversion5.82.0.r359.g385b027-15.82.0.r361.gfc798b0-1
                     kwayland-server5.21.4.r1323.g46e11af-15.21.4.r1324.g6851561-1
                                kwin5.21.4.r19418.g39e2387f9-15.21.4.r19425.g86ce04a7f-1
                              kwrite21.04.0.r18142.g5c5ef2cc9-121.04.0.r18147.gd7b24e093-1
                             kxmlgui5.82.0.r757.g5d9b57f9-15.82.0.r758.gcca89e76-1
                       kxmlrpcclient5.82.0.r444.g3cf0be2b5-15.82.0.r446.gd6b071ecb-1
                      layer-shell-qt5.21.4.r40.g525fa9b-15.21.4.r41.g9af3c35-1
                            libksane21.04.0.r525.ga5f8ae7-121.04.0.r527.g5e6e06e-1
                           libksieve21.04.0.r1524.g217f803e-121.04.0.r1525.geeb62b12-1
                        libksysguard5.21.4.r2227.g2c893a0-15.21.4.r2228.g56f2e71-1
                          mailcommon21.04.0.r1033.g5fc25c3-121.04.0.r1034.g8a737e7-1
                           maui-nota 1.2.2.r13.gef8af38-1 1.2.2.r15.gc74b6ef-1
                            maui-pix 1.2.2.r13.ge9dc5ba-1 1.2.2.r17.gbac51ed-1
                             mauikit1.2.2.r20.gb32a99e3-11.2.2.r30.g55e5d76a-1
                mauikit-filebrowsing        r46.f60128a-1 1.2.2.r17.g7bbc7a0-1
                   networkmanager-qt5.82.0.r1102.g4dc6e95-15.82.0.r1103.gbe1e011-1
                              okular21.04.0.r9328.g1954d43f0-121.04.0.r9333.g8b13d989c-1
                              parley21.04.0.r4406.g2a5c816c-121.04.0.r4407.g8e46f541-1
                      plasma-desktop5.21.4.r8465.gadfb2a680-15.21.4.r8471.g93e29d4b5-1
                        plasma-disks5.21.4.r205.g22862d9-15.21.4.r208.g5efaaee-1
                     plasma-firewall5.21.4.r489.ge5a70db-15.21.4.r491.gfdb224d-1
                    plasma-framework5.82.0.r15855.g8c443f504-15.82.0.r15856.g532817c00-1
                  plasma-integration5.21.4.r516.gc123126-15.21.4.r517.ged1c2fa-1
         plasma-workspace-wallpapers5.21.4.r263.g449a40b-15.21.4.r265.g6ab7ee5-1
                                rocs21.04.0.r3010.g1ae37cc5-121.04.0.r3014.gc0cdea56-1
                      systemsettings5.21.4.r2434.g841daea4-15.21.4.r2435.gc84cbad1-1
                               vvave 1.2.2.r11.gf76f8f8-1 1.2.2.r15.g9abcc66-1
                        ksystemstats                    -5.21.4.r166.g93e8a93-1
                    mauikit-accounts                    -         r3.c3ff058-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Old Issues
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Previous conflicts resolved.
There is a permissions warning on sudoers 750/755 but the update went fine.
thanks very much.
I have some screen brightness flicker when using while charging the pinephone.
Edit: I checked it at 84% charge and the flickering seems to have stopped.
Edit 2: The flicker issue comes and goes, at 97% it seems to have stopped again.
On Gnome on the Pinebook Pro, this update appears to have fixed the garbled terminal window within the desktop environment, which wasn’t readable for the past few weeks.
Raspberry Pi 4 Model B Rev 1.1
Linux 5.12.5-1-MANJARO-ARM
Plasma 5.21.5
:chart_with_upwards_trend:
Hi,
Odroid C4 kde up to date, not tested on the Odroid C2…
@Lila-Kuh
Did you try to build an image for your C2 ?
As you know, last time the brave C2 don’t start any more :-\
