Hello ARM community.
Here’s another rather small testing update, but some important things are included.
We are working on getting Manjaro ARM running on the Volla Phone
Some highlights:
- Most of our kernels got updated
- Pipewire updated to 0.3.28
- Introducing Foot terminal emulator
- Also added lots of -git packages for the Nemo interface for Volla Phone
- And introducing marble-maps, which is a mobile friendly Marble app
- osk-sdl is added to the repo
- Lots of Mobile specific packages got updated
- Some python packages got updated
If anyone wants to test kodi on the rpi:
Change to the unstable or testing branch and install kodi packages:
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss
package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip
and firewalld
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Thu May 20 22:00:26 CEST 2021)
- arm-testing community aarch64: 531 new and 438 removed package(s)
- arm-testing core aarch64: 37 new and 35 removed package(s)
- arm-testing extra aarch64: 95 new and 93 removed package(s)
- arm-testing kde-unstable aarch64: 294 new and 294 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-05-14 2021-05-20
alligator 21.05-1 21.05-2
bitwarden 1.26.0-1 1.26.3-1
code 1.55.2-2 1.56.2-1
electron 12.0.7-1 12.0.9-1
element-desktop 1.7.27-1 1.7.28-1
element-web 1.7.27-1 1.7.28-1
hwinfo 21.71-1 21.74-1
kodi-rpi 19.1-4 19.1-5
kodi-rpi-dev 19.1-4 19.1-5
kodi-rpi-eventclients 19.1-4 19.1-5
kodi-rpi-tools-texturepacker 19.1-4 19.1-5
lxc-android 0.1-3 0.1-4
phosh 0.10.2+53+gd14786a-1 0.10.2+57+gb03323e-1
sensorfw-git0.11.2.r30.g65080cb-2 0.12.2.r0.g08ce125-2
snapd 2.50-1 2.50.1-1
buteo-sync-plugin-carddav-git - 0.1.6.r0.gb67977c-1
buteo-syncfw-git - 0.10.6.r0.gbb85bcf-1
fcft - 2.4.0-1
foot - 1.7.2-3
foot-terminfo - 1.7.2-3
glacier-calc-git - 0.3.1.r3.g6ba3925-1
glacier-camera-git - 0.1.2.r6.g7447f14-1
glacier-filemuncher-git - 0.3.r8.gaf14838-1
glacier-gallery-git - 0.2.3.r17.g7c87a52-1
glacier-music-git - 0.2.3.r0.gfb09d18-1
glacier-pinquery-git - 0.3.r3.ga3d3a3a-2
google-opensans-fonts-git - 1.1-1
libcommhistory-git - 1.11.9.r0.g9fe0cd4-1
libhybris-git - 1500.9d2860a-2
libiphb-git - 1.2.7.r0.gc7fd4ea-1
libngf-git - 0.28.r0.g05ea200-1
libsailfishkeyprovider-git - 1.0.7.r0.gcef4186-1
libuser - 0.63-1
mapplauncherd-git - 4.1.43.r0.g9970c11-1
mapplauncherd-qt-git - 1.1.17.r0.g944f07e-1
mce-git -1.106.6.r0.gf4644db-2
mce-headers-git - 1.28.3.r0.g9d2cb2a-1
meego-resource-git - 0.24.1.r0.g7d2e812-1
nemo-keepalive-git - 1.8.4.r0.g14b3654-1
nemo-qml-plugin-configuration-git - 0.2.3.r0.g917ed97-1
nemo-qml-plugin-contacts-git - 0.3.20.r0.gdfdedb9-1
nemo-qml-plugin-contentaction-git - 0.3.18.r0.g8ae69f3-1
nemo-qml-plugin-devicelock-git - 0.3.5.r0.g3569d10-1
nemo-qml-plugin-folderlistmodel-git - 0.0.12.r2.gf48df29-1
nemo-qml-plugin-models-git - 0.2.0.r0.gd255f9c-1
nemo-qml-plugin-notifications-git - 1.2.12.r0.g218f5da-1
nemo-qml-plugin-settings-git - 0.1.1.r0.gec557c6-1
nemo-qml-plugin-sortfiltermodel-git - r1.da3ed1d-1
nemo-qml-plugin-statusnotifier-git - 1.0.r1.g859139a-1
nemo-qml-plugin-systemsettings-git - 0.5.47.r0.gc6e14bf-1
nemo-qml-plugin-thumbnailer-git - 1.0.4.r0.gdcda58f-1
nemo-qml-plugin-time-git - 0.1.3.r0.ge9ac208-1
nemo-theme-glacier-git - 0.2.r0.g34159f3-1
profiled-git - 1.0.12.r0.g32b02ae-1
qt5-around-git - 0.2.11.r0.g41126fa-1
qt5-connman-git - 20210114.f5b49d8-1
qt5-contacts-sqlite-extensions-git - 0.3.13.r0.gb89ddca-2
qt5-dbus-extended-git - 0.0.3.r0.g3497143-1
qt5-glacier-app-git - 0.6.r4.gcb16f90-1
qt5-iodata-git -0.19.11+git1.r0.g9c9c84b-1
qt5-lipstick-git - 0.40-1
qt5-mce-git - 1.4.2.r0.g431168d-1
qt5-mlite-git - 0.3.7.r0.g7f21359-1
qt5-mlocale-git - 0.7.4.r0.gfcb7a926-1
qt5-mpris-git - 1.0.6.r0.gade1b9a-1
qt5-ngfd-git - 0.6.5.r0.gaabfd51-1
qt5-profile-git - 0.35.5.r0.gd10d69c-1
qt5-quickcontrols-nemo-git - 5.5.2.r1.gbee1f9d-1
qt5-resource-git - 1.30.6.r0.g22c940c-1
qt5-timed-git - 3.6.13.r0.g19cbb69-1
qt5-usb-moded-git - 1.9.r0.g0544b73-1
qtdocgallery-git -mer.5.2.0+git12.r3.g382232a-1
sailfish-access-control-git - 0.0.5.r0.gf858fed-1
sailfish-access-control-qt5-git - 0.0.5.r0.gf858fed-1
sailfish-user-managerd-git - 0.5.5.r0.g71f211f-1
ssu-sysinfo-git - 1.3.0.r0.g17ee5f5-1
tllist - 1.0.5-2
tut-git - 0.0.5.r0.ge9ee8f0-1
usb-moded-git -0.86.0+mer55.r2.g66317b7-1
usb-tethering - 0.1-1
voicecall-git - 0.7.11.r0.ga188e61-1
:: Different sync package(s) in repository community aarch64
alembic 1.8.0-3 1.8.1-2
ansible 3.4.0-1 4.0.0-1
ansible-core 2.11.0-2 2.11.0-4
arandr 0.1.10-5 0.1.10-6
arch-repro-status 1.0.0-1 1.2.0-1
arcus 4.8.0-4 4.9.1-1
arduino 1:1.8.14-1 1:1.8.15-1
arduino-builder 1.6.0-1 1.6.1-1
arduino-cli 0.18.1-1 0.18.3-1
avfs 1.1.3-1 1.1.4-1
babel-cli 7.13.16-1 7.14.3-1
babel-core 7.13.16-1 7.14.3-1
bat 0.18.0-2 0.18.1-1
batctl 2021.0-1 2021.1-1
blackbox 0.76-1 0.77-1
blender 17:2.92.0-5 17:2.92.0-7
bmkdep 20140112-3 20140112-4
broot 1.4.0-1 1.4.0-2
cacti 1.2.16-3 1.2.17-1
cargo-crev 0.19.2-1 0.19.4-1
cargo-release 0.13.10-1 0.13.11-1
ceph 15.2.10-1 15.2.12-1
ceph-libs 15.2.10-1 15.2.12-1
ceph-mgr 15.2.10-1 15.2.12-1
clojure 1.10.3.822-1 1.10.3.839-1
cockpit 243-1 244.1-1
cockpit-machines 243.1-1 244-1
cockpit-pcp 243-1 244.1-1
conmon 1:2.0.27-1 1:2.0.28-1
containerd 1.5.0-2 1.5.1-1
containers-common 0.38.0-2 0.38.3-2
coturn 4.5.2-1 4.5.2-2
croc 9.1.3-1 9.1.4-1
cura 4.8.0-1 4.9.1-1
cura-binary-data 4.8.0-1 4.9.1-1
cura-resources-materials 4.8.0-1 4.9.1-1
curaengine 4.8.0-3 4.9.1-1
dart 2.12.4-1 2.13.0-1
diffoscope 174-1 175-1
doctl 1.60.0-1 1.61.0-1
dscanner 0.11.0-1 0.11.1-1
efm-langserver 0.0.29-1 0.0.30-1
entr 4.8-1 4.9-1
erlang-nox 23.3.2-1 24.0-1
fcitx-mozc 2.25.4150.102-22.26.4360.102.gca82d39-1
fcitx5-mozc2.26.4206.102.e7a97d0-12.26.4360.102.gca82d39-1
findomain 4.2.0-1 4.3.0-1
firefox-extension-mailvelope 4.4.0-2 4.4.1-1
fish 3.2.2-1 3.2.2-2
fltk 1.3.5-4 1.3.6-1
fltk-docs 1.3.5-4 1.3.6-1
fltk-examples 1.3.5-4 1.3.6-1
flyspray 1.0rc9-5 1.0rc10-1
fplll 5.4.0-1 5.4.1-1
freeimage 3.18.0-8 3.18.0-9
freeradius 3.0.21-6 3.0.22-1
gameconqueror 0.17-4 0.17-5
giac 1.7.0.5-1 1.7.0.7-1
gimp-plugin-gmic 2.9.7-3 2.9.7-4
github-cli 1.9.2-1 1.10.1-1
global 6.6.5-1 6.6.6-1
google-glog 0.5.0-1 0.5.0-2
gramps 2:5.1.3-2 2:5.1.3-3
hashcat 1:6.1.1-1 1:6.2.1-1
haxe 4.2.1-1 4.2.2-1
highlight 4.0-1 4.1-1
highlight-gui 4.0-1 4.1-1
hivex 1.3.19-4 1.3.20-1
homebank 5.5.1-1 5.5.2-1
hugin 2020.0.0-2 2020.0.0-3
ibus-table 1.13.0-1 1.13.1-1
jmol 14.31.38-1 14.31.39-1
jsmol 14.31.38-1 14.31.39-1
jupyterlab 3.0.15-1 3.0.16-1
krita-plugin-gmic 2.9.7-3 2.9.7-4
kube-linter 0.2.1-1 0.2.2-1
kup 0.8.0-3 0.9.0-1
latte-dock 0.9.11-1 0.9.12-1
libffado 2.4.4-2 2.4.4-3
libimagequant 2.15.0-1 2.15.1-1
libkkc-data 0.2.7-2 0.2.7-3
libperconaserverclient 8.0.22_13-3 8.0.23_14-4
librdkafka 1.7.0-1 1.7.0-2
libsavitar 4.8.0-2 4.9.1-1
libscanmem 0.17-4 0.17-5
libvips 8.10.6-2 8.10.6-3
libvirt 1:7.1.0-3 1:7.3.0-1
libvirt-python 1:7.1.0-1 1:7.3.0-1
libvirt-storage-gluster 1:7.1.0-3 1:7.3.0-1
libvirt-storage-iscsi-direct 1:7.1.0-3 1:7.3.0-1
liquidctl 1.6.0-1 1.6.1-1
log4cxx 0.11.0-1 0.11.0-2
luminancehdr 2.6.0-12 2.6.0-13
mailnag-gnome-shell 3.38.1-2 40.0-1
matrix-appservice-irc 0.25.0-2 0.26.0-1
mediastreamer 4.5.15-1 4.5.16-1
micro 2.0.8-4 2.0.9-1
minidlna 1.3.0-1 1.3.0-2
mk-configure 0.37.0-1 0.37.0-2
molecule 3.3.0-2 3.3.1-1
movit 1.6.3-1 1.6.3-2
nebula 1.3.0-2 1.4.0-1
nextcloud 21.0.1-2 21.0.1-3
nextcloud-app-bookmarks 1:4.1.0-1 1:4.2.0-2
nodejs 16.1.0-1 16.2.0-1
npm 7.12.1-1 7.13.0-1
npm-check-updates 11.5.11-1 11.5.13-1
nuitka 0.6.14.6-1 0.6.14.7-1
ois 1.5-2 1.5.1-1
opencolorio 2.0.0-3 2.0.1-2
openethereum 3.2.5-1 3.2.6-1
openfire 4.6.2-1 4.6.3-1
openimageio 2.2.13.0-2 2.2.13.0-3
openscenegraph 3.6.5-4 3.6.5-5
openvdb 8.0.1-3 8.0.1-4
openxr 1.0.15-1 1.0.16-1
orcania 2.2.0-1 2.2.1-1
padthv1 0.9.21-1 0.9.22-1
pam-u2f 1.1.0-1 1.1.1-1
pantheon-calculator 1.6.0-2 1.6.1-1
pass 1.7.3-2 1.7.3-3
percona-server 8.0.22_13-3 8.0.23_14-4
percona-server-clients 8.0.22_13-3 8.0.23_14-4
perl-archive-extract 0.86-2 0.88-1
perl-email-simple 2.214-2 2.216-1
perl-finance-quote 1.49-3 1.49-4
perl-gnupg-interface 1.01-1 1.02-1
perl-json-parse 0.55-2 0.55-3
perl-number-misc 1.2-3 1.2-4
perl-string-util 1.26-2 1.26-3
perl-test-script 1.27-1 1.29-1
perl-test-simple 1.302183-1 1.302184-1
perl-type-tiny 1.012001-1 1.012003-1
pifpaf 3.1.4-1 3.1.5-1
pngquant 2.15.0-1 2.15.1-1
poedit 1:2.4.1-5 1:2.4.3-1
polymake 4.3-3 4.4-1
ponysay 3.0.3-3 3.0.3-4
postfixadmin 3.3.8-1 3.3.9-1
povray 2:3.7.0.8-10 2:3.7.0.8-11
powertop 2.13-1 2.14-1
prjtrellis-db r115.717478b-3 r262.f7f8375-1
procs 0.11.5-1 0.11.7-1
prusa-slicer 2.3.1-1 2.3.1-2
python-aiodns 2.0.0-4 3.0.0-1
python-aiofiles 0.6.0-3 0.7.0-1
python-alembic 1.6.2-1 1.6.2-2
python-cfn-lint 0.49.0-1 0.49.1-1
python-chameleon 3.9.0-1 3.9.1-1
python-click 8.0.0-1 8.0.0-2
python-cookiecutter 1.7.2-5 1.7.3-1
python-decorator 5.0.7-1 5.0.9-1
python-django-q 1.3.5-1 1.3.6-1
python-dnslib 0.9.14-2 0.9.16-1
python-docs 3.9.4-1 3.9.5-1
python-emoji 1.0.1-1 1.1.0-1
python-eventlet 0.31.0-1 0.31.0-2
python-faker 8.1.3-1 8.2.0-1
python-fastapi 0.63.0-1 0.65.1-1
python-flask 2.0.0-1 2.0.0-2
python-flask-cors 3.0.9-3 3.0.10-1
python-flask-migrate 2.7.0-1 3.0.0-1
python-flask-restful 0.3.8-3 0.3.9-1
python-flask-security-too 3.3.3-3 4.0.1-1
python-fpylll 0.5.5-1 0.5.6-1
python-google-api-python-client 2.3.0-1 2.4.0-1
python-graphql-core 3.1.4-1 3.1.5-1
python-hstspreload 2020.7.7-3 2020.12.22-1
python-httpretty 1.1.0-1 1.1.1-1
python-hypothesis 6.12.0-1 6.13.0-1
python-importlib_resources 5.1.2-1 5.1.3-1
python-itsdangerous 2.0.0-1 2.0.1-1
python-jaeger-client 4.4.0-1 4.5.0-1
python-jedi 0.18.0-1 0.18.0-2
python-jinja 3.0.0-1 3.0.1-1
python-jupymake 0.9-9 0.9-10
python-jupyterlab_server 2.5.1-1 2.5.2-1
python-kubernetes 12.0.1-2 17.17.0-1
python-libcharon 4.8.0-1 4.9.1-1
python-libcst 0.3.18-1 0.3.19-1
python-markdown-it-py 0.6.2-1 1.1.0-1
python-markups 3.0.0-10 3.1.1-1
python-mdit_py_plugins 0.2.6-1 0.2.8-1
python-moto 2.0.6-1 2.0.7-1
python-myst-parser 0.13.6-1 0.14.0-1
python-nltk 3.6.1-1 3.6.2-1
python-openmdao 3.9.1-1 3.9.2-1
python-openstacksdk 0.56.0-1 0.57.0-1
python-pallets-sphinx-themes 1.2.2-7 1.2.2-8
python-pandas 1.2.3-2 1.2.4-1
python-pdftotext 2.1.5-2 2.1.6-1
python-pipx 0.16.1.0-1 0.16.2.1-1
python-pproxy 2.7.7-1 2.7.8-1
python-prance 0.20.2-1 0.21.2-1
python-precis_i18n 1.0.3-1 1.0.3-2
python-protego 0.1.16-3 0.1.16-4
python-purl 1.5-6 1.6-1
python-pycryptodomex 3.9.9-2 3.10.1-1
python-pydantic 1.8.1-2 1.8.2-1
python-pydocstyle 6.0.0-1 6.1.1-1
python-pygame-sdl21:2.1.0.r398.364d3bc-11:2.1.0.r399.5777335-1
python-pygithub 1.54.1-1 1.55-1
python-pykka 2.0.3-1 3.0.1-1
python-pyroute2 0.5.18-1 0.5.19-1
python-pytest-benchmark 3.4.0-1 3.4.1-1
python-pytest-checkdocs 2.5.0-1 2.6.0-1
python-pytest-cov 2.11.1-1 2.12.0-1
python-pytest-django 4.2.0-1 4.3.0-1
python-pytest-randomly 3.7.0-1 3.8.0-1
python-qasync 0.15.0-1 0.16.0-1
python-quart 0.14.1-2 0.15.0-1
python-quart-cors 0.3.0-2 0.5.0-1
python-requests-aws4auth 1.0.1-2 1.0.1-3
python-rich 10.1.0-2 10.2.0-1
python-rope 0.18.0-3 0.19.0-1
python-scapy 2.4.5-1 2.4.5-2
python-sh 1.14.1-3 1.14.2-1
python-solidpython 1.0.1-4 1.1.1-1
python-sortedcontainers 2.3.0-3 2.4.0-1
python-sphinx 4.0.1-2 4.0.1-3
python-sphinx-click 2.7.1-1 3.0.0-1
python-sqlalchemy-utils 0.37.1-1 0.37.1-2
python-subprocess-tee 0.3.0-1 0.3.1-1
python-tomlkit 0.7.0-3 0.7.1-1
python-typed-ast 1.4.2-1 1.4.3-1
python-typeguard 2.11.0-1 2.11.1-1
python-unpaddedbase64 1.1.0-7 2.1.0-1
python-userpath 1.4.2-1 1.5.0-1
python-werkzeug 2.0.0-1 2.0.0-2
python-wxpython 4.0.7.2-5 4.1.1-1
python-xlib 0.29-1 0.30-1
python-zconfig 3.5.0-5 3.6.0-1
python2-pygame-sdl21:2.1.0.r398.364d3bc-11:2.1.0.r399.5777335-1
python2-pytest-cov 2.11.1-1 2.12.0-1
python2-typing 3.7.4.3-1 3.10.0.0-1
rclone 1.54.1-1 1.55.1-1
rebuilderd 0.10.0-1 0.12.0-1
remmina 1:1.4.14-1 1:1.4.16-1
repo 2.12.2-1 2.15-1
retroarch 1.9.2-1 1.9.3-1
rgbds 0.5.0-1 0.5.1-1
ruby-augeas 0.5.0-5 0.5.0-6
ruby-concurrent 1.1.8-2 1.1.8-3
ruby-deep_merge 1.2.1-3 1.2.1-4
ruby-domain_name 0.5.20190701-3 0.5.20190701-4
ruby-hocon 1.3.1-2 1.3.1-3
ruby-http-cookie 1.0.3-6 1.0.3-7
ruby-httpclient 2.8.3-8 2.8.3-9
ruby-multi_json 1.15.0-2 1.15.0-3
ruby-power_assert 1.2.0-2 2.0.0-1
ruby-puppet-resource_api 1.8.13-2 1.8.13-3
ruby-shadow 2.5.0-6 2.5.0-7
ruby-sync 0.5.0-4 0.5.0-6
ruby-test-unit 3.4.1-1 3.4.1-2
ruby-unf 0.2.0.beta2-5 0.2.0.beta2-6
runc 1.0.0rc94-1 1.0.0rc95-1
rust-analyzer 20210510-1 20210517-1
rustup 1.24.1-1 1.24.2-1
rxvt-unicode 9.22-10 9.26-1
rxvt-unicode-terminfo 9.22-10 9.26-1
sbt 1:1.4.8-1 1:1.4.9-1
scantailor-advanced 1.0.16-3 1.0.16-4
scrapy 2.5.0-1 2.5.0-2
seamonkey 2.53.5-2 2.53.7.1-1
shfmt 3.2.4-1 3.3.0-1
sn0int 0.20.1-1 0.21.1-1
sqlitebrowser 3.12.0-1 3.12.1-1
squid 4.14-1 4.15-1
starship 0.53.0-2 0.54.0-1
stlink 1.6.1-1 1.7.0-1
supermin 5.2.0-3 5.2.1-1
swift-im 4.0.2-3 4.0.2-4
swiften 4.0.2-3 4.0.2-4
telegram-desktop 2.7.4-1 2.7.4-2
tellico 3.4-2 3.4.1-1
tesseract 4.1.1-5 4.1.1-6
tesseract-data-afr 1:4.0.0-1 2:4.0.0-2
tesseract-data-amh 1:4.0.0-1 2:4.0.0-2
tesseract-data-ara 1:4.0.0-1 2:4.0.0-2
tesseract-data-asm 1:4.0.0-1 2:4.0.0-2
tesseract-data-aze 1:4.0.0-1 2:4.0.0-2
tesseract-data-aze_cyrl 1:4.0.0-1 2:4.0.0-2
tesseract-data-bel 1:4.0.0-1 2:4.0.0-2
tesseract-data-ben 1:4.0.0-1 2:4.0.0-2
tesseract-data-bod 1:4.0.0-1 2:4.0.0-2
tesseract-data-bos 1:4.0.0-1 2:4.0.0-2
tesseract-data-bul 1:4.0.0-1 2:4.0.0-2
tesseract-data-cat 1:4.0.0-1 2:4.0.0-2
tesseract-data-ceb 1:4.0.0-1 2:4.0.0-2
tesseract-data-ces 1:4.0.0-1 2:4.0.0-2
tesseract-data-chi_sim 1:4.0.0-1 2:4.0.0-2
tesseract-data-chi_tra 1:4.0.0-1 2:4.0.0-2
tesseract-data-chr 1:4.0.0-1 2:4.0.0-2
tesseract-data-cym 1:4.0.0-1 2:4.0.0-2
tesseract-data-dan 1:4.0.0-1 2:4.0.0-2
tesseract-data-dan_frak 1:4.0.0-1 2:4.0.0-2
tesseract-data-deu 1:4.0.0-1 2:4.0.0-2
tesseract-data-deu_frak 1:4.0.0-1 2:4.0.0-2
tesseract-data-dzo 1:4.0.0-1 2:4.0.0-2
tesseract-data-ell 1:4.0.0-1 2:4.0.0-2
tesseract-data-eng 1:4.0.0-1 2:4.0.0-2
tesseract-data-enm 1:4.0.0-1 2:4.0.0-2
tesseract-data-epo 1:4.0.0-1 2:4.0.0-2
tesseract-data-equ 1:4.0.0-1 2:4.0.0-2
tesseract-data-est 1:4.0.0-1 2:4.0.0-2
tesseract-data-eus 1:4.0.0-1 2:4.0.0-2
tesseract-data-fas 1:4.0.0-1 2:4.0.0-2
tesseract-data-fin 1:4.0.0-1 2:4.0.0-2
tesseract-data-fra 1:4.0.0-1 2:4.0.0-2
tesseract-data-frk 1:4.0.0-1 2:4.0.0-2
tesseract-data-frm 1:4.0.0-1 2:4.0.0-2
tesseract-data-gle 1:4.0.0-1 2:4.0.0-2
tesseract-data-glg 1:4.0.0-1 2:4.0.0-2
tesseract-data-grc 1:4.0.0-1 2:4.0.0-2
tesseract-data-guj 1:4.0.0-1 2:4.0.0-2
tesseract-data-hat 1:4.0.0-1 2:4.0.0-2
tesseract-data-heb 1:4.0.0-1 2:4.0.0-2
tesseract-data-hin 1:4.0.0-1 2:4.0.0-2
tesseract-data-hrv 1:4.0.0-1 2:4.0.0-2
tesseract-data-hun 1:4.0.0-1 2:4.0.0-2
tesseract-data-iku 1:4.0.0-1 2:4.0.0-2
tesseract-data-ind 1:4.0.0-1 2:4.0.0-2
tesseract-data-isl 1:4.0.0-1 2:4.0.0-2
tesseract-data-ita 1:4.0.0-1 2:4.0.0-2
tesseract-data-ita_old 1:4.0.0-1 2:4.0.0-2
tesseract-data-jav 1:4.0.0-1 2:4.0.0-2
tesseract-data-jpn 1:4.0.0-1 2:4.0.0-2
tesseract-data-kan 1:4.0.0-1 2:4.0.0-2
tesseract-data-kat 1:4.0.0-1 2:4.0.0-2
tesseract-data-kat_old 1:4.0.0-1 2:4.0.0-2
tesseract-data-kaz 1:4.0.0-1 2:4.0.0-2
tesseract-data-khm 1:4.0.0-1 2:4.0.0-2
tesseract-data-kir 1:4.0.0-1 2:4.0.0-2
tesseract-data-kor 1:4.0.0-1 2:4.0.0-2
tesseract-data-kur 1:4.0.0-1 2:4.0.0-2
tesseract-data-lao 1:4.0.0-1 2:4.0.0-2
tesseract-data-lat 1:4.0.0-1 2:4.0.0-2
tesseract-data-lav 1:4.0.0-1 2:4.0.0-2
tesseract-data-lit 1:4.0.0-1 2:4.0.0-2
tesseract-data-mal 1:4.0.0-1 2:4.0.0-2
tesseract-data-mar 1:4.0.0-1 2:4.0.0-2
tesseract-data-mkd 1:4.0.0-1 2:4.0.0-2
tesseract-data-mlt 1:4.0.0-1 2:4.0.0-2
tesseract-data-msa 1:4.0.0-1 2:4.0.0-2
tesseract-data-mya 1:4.0.0-1 2:4.0.0-2
tesseract-data-nep 1:4.0.0-1 2:4.0.0-2
tesseract-data-nld 1:4.0.0-1 2:4.0.0-2
tesseract-data-nor 1:4.0.0-1 2:4.0.0-2
tesseract-data-ori 1:4.0.0-1 2:4.0.0-2
tesseract-data-pan 1:4.0.0-1 2:4.0.0-2
tesseract-data-pol 1:4.0.0-1 2:4.0.0-2
tesseract-data-por 1:4.0.0-1 2:4.0.0-2
tesseract-data-pus 1:4.0.0-1 2:4.0.0-2
tesseract-data-ron 1:4.0.0-1 2:4.0.0-2
tesseract-data-rus 1:4.0.0-1 2:4.0.0-2
tesseract-data-san 1:4.0.0-1 2:4.0.0-2
tesseract-data-sin 1:4.0.0-1 2:4.0.0-2
tesseract-data-slk 1:4.0.0-1 2:4.0.0-2
tesseract-data-slk_frak 1:4.0.0-1 2:4.0.0-2
tesseract-data-slv 1:4.0.0-1 2:4.0.0-2
tesseract-data-spa 1:4.0.0-1 2:4.0.0-2
tesseract-data-spa_old 1:4.0.0-1 2:4.0.0-2
tesseract-data-sqi 1:4.0.0-1 2:4.0.0-2
tesseract-data-srp 1:4.0.0-1 2:4.0.0-2
tesseract-data-srp_latn 1:4.0.0-1 2:4.0.0-2
tesseract-data-swa 1:4.0.0-1 2:4.0.0-2
tesseract-data-swe 1:4.0.0-1 2:4.0.0-2
tesseract-data-syr 1:4.0.0-1 2:4.0.0-2
tesseract-data-tam 1:4.0.0-1 2:4.0.0-2
tesseract-data-tel 1:4.0.0-1 2:4.0.0-2
tesseract-data-tgk 1:4.0.0-1 2:4.0.0-2
tesseract-data-tgl 1:4.0.0-1 2:4.0.0-2
tesseract-data-tha 1:4.0.0-1 2:4.0.0-2
tesseract-data-tir 1:4.0.0-1 2:4.0.0-2
tesseract-data-tur 1:4.0.0-1 2:4.0.0-2
tesseract-data-uig 1:4.0.0-1 2:4.0.0-2
tesseract-data-ukr 1:4.0.0-1 2:4.0.0-2
tesseract-data-urd 1:4.0.0-1 2:4.0.0-2
tesseract-data-uzb 1:4.0.0-1 2:4.0.0-2
tesseract-data-uzb_cyrl 1:4.0.0-1 2:4.0.0-2
tesseract-data-vie 1:4.0.0-1 2:4.0.0-2
tesseract-data-yid 1:4.0.0-1 2:4.0.0-2
texstudio 3.1.1-1 3.1.2-1
tmuxp 1.7.2-1 1.7.2-2
tpm2-tss 3.0.3-1 3.1.0-1
trace-cmd 2.9.1-3 2.9.3-2
translate-toolkit 3.3.4-1 3.3.6-1
ucblogo 6.1-1 6.2.1-1
uglify-js 3.13.6-1 3.13.7-1
uranium 4.8.0-2 4.9.1-1
uwsgi 2.0.19.1-11 2.0.19.1-12
uwsgi-plugin-cgi 2.0.19.1-11 2.0.19.1-12
uwsgi-plugin-jvm 2.0.19.1-11 -
uwsgi-plugin-lua51 2.0.19.1-11 2.0.19.1-12
uwsgi-plugin-notfound 2.0.19.1-11 2.0.19.1-12
uwsgi-plugin-php 2.0.19.1-11 2.0.19.1-12
uwsgi-plugin-php7 2.0.19.1-11 2.0.19.1-12
uwsgi-plugin-psgi 2.0.19.1-11 2.0.19.1-12
uwsgi-plugin-python 2.0.19.1-11 2.0.19.1-12
uwsgi-plugin-rack 2.0.19.1-11 2.0.19.1-12
uwsgi-plugin-webdav 2.0.19.1-11 2.0.19.1-12
uwsgi-plugin-zabbix 2.0.19.1-11 2.0.19.1-12
v2ray-domain-list-community 20210508061759-1 20210519075125-1
vigra 1.11.1-31 1.11.1-32
vigra-doc 1.11.1-31 1.11.1-32
vim-ansible 3.0-1 3.1-1
vnstat 2.6-1 2.7-1
volatility3 1.0.1-1 1.0.1-2
vultr-cli 2.5.1-1 2.5.2-1
wit 3.03a-1 3.04a-1
wordpress 5.7.1-1 5.7.2-1
wxsqlite3 4.6.9-1 4.7.2-1
xh 0.9.2-1 0.10.0-1
xplr 0.9.0-1 0.9.1-1
yaz 5.30.3-3 5.31.0-1
yder 1.4.13-1 1.4.14-1
youtube-dl 2021.04.26-1 2021.05.16-1
yubikey-manager 3.1.2-1 4.0.3-1
yubikey-manager-qt 1.2.1-1 1.2.3-1
zart 2.9.7-3 2.9.7-4
git-smash - 0.0.2-1
libgsystem - 2015.2+4+gd606bec-3
libtraceevent - 1:1.3.0-1
libtracefs - 1.2.0-1
mod_itk - 2.4.7.r04-1
ruby-crack - 0.4.4-3
ruby-hashdiff - 1.0.1-1
ruby-webmock - 3.13.0-1
s3rver - 3.7.0-1
tesseract-data-bre - 2:4.0.0-2
tesseract-data-cos - 2:4.0.0-2
tesseract-data-fao - 2:4.0.0-2
tesseract-data-fil - 2:4.0.0-2
tesseract-data-fry - 2:4.0.0-2
tesseract-data-gla - 2:4.0.0-2
tesseract-data-hye - 2:4.0.0-2
tesseract-data-kor_vert - 2:4.0.0-2
tesseract-data-ltz - 2:4.0.0-2
tesseract-data-mon - 2:4.0.0-2
tesseract-data-mri - 2:4.0.0-2
tesseract-data-oci - 2:4.0.0-2
tesseract-data-osd - 2:4.0.0-2
tesseract-data-que - 2:4.0.0-2
tesseract-data-snd - 2:4.0.0-2
tesseract-data-sun - 2:4.0.0-2
tesseract-data-tat - 2:4.0.0-2
tesseract-data-ton - 2:4.0.0-2
tesseract-data-yor - 2:4.0.0-2
:: Different overlay package(s) in repository core aarch64
linux 5.12.4-1 5.12.5-1
linux-headers 5.12.4-1 5.12.5-1
linux-pinephone 5.12.3-1 5.12.5-1
linux-pinephone-headers 5.12.3-1 5.12.5-1
linux-rc 5.13.rc1-1 5.13.rc2-1
linux-rc-headers 5.13.rc1-1 5.13.rc2-1
linux-rpi4 5.10.36-1 5.10.38-1
linux-rpi4-headers 5.10.36-1 5.10.38-1
linux-rpi4-mainline 5.12.3-1 5.12.5-1
linux-rpi4-mainline-headers 5.12.3-1 5.12.5-1
linux-vim 5.11.13-1 5.12.1-1
linux-vim-headers 5.11.13-1 5.12.1-1
uboot-edge-v 2020.02-2 2021.01-1
uboot-pinebookpro 2021.04-2 2021.04-3
uboot-pinebookpro-display 2021.07rc2-1 -
uboot-vim1 2020.04-2 2021.01-1
uboot-vim2 2020.10-1 2021.01-1
uboot-vim3l 2020.10-1 2021.01-1
linux-quartz64 - 5.12.0-0.2
linux-quartz64-headers - 5.12.0-0.2
uboot-vim3 - 2021.01-1
:: Different sync package(s) in repository core aarch64
amd-ucode 20210426.fa0efef-1 20210511.7685cf4-1
btrfs-progs 5.12-2 5.12.1-1
ca-certificates-mozilla 3.64-1 3.65-1
dialog 1:1.3_20210324-1 1:1.3_20210509-1
elfutils 0.183-3 0.184-1
libelf 0.183-3 0.184-1
libidn2 2.3.0-1 2.3.1-1
libtasn1 4.16.0-1 4.17.0-1
libtirpc 1.3.1-1 1.3.2-1
linux-api-headers 5.10.13-1 5.12.3-1
linux-firmware 20210426.fa0efef-1 20210511.7685cf4-1
nss 3.64-1 3.65-1
sudo 1.9.6.p1-1 1.9.7-1
systemd 248.2-2 248.3-2
systemd-libs 248.2-2 248.3-2
systemd-resolvconf 248.2-2 248.3-2
systemd-sysvcompat 248.2-2 248.3-2
:: Different overlay package(s) in repository extra aarch64
boxit-arm 2.1.3-6 2.1.3-7
libdrm-pinebookpro 2.4.104-1 2.4.106-1
mesa-git21.2.0_devel.139382.d81a6e5f1d3-121.2.0_devel.139599.6fcf3314d00-1
pamac-cli 10.1.1-1 10.1.2-2
pamac-common 10.1.1-1 10.1.2-2
pamac-flatpak-plugin 10.1.1-1 10.1.2-2
pamac-gnome-integration 10.1.1-1 10.1.2-2
pamac-gtk 10.1.1-1 10.1.2-2
pamac-snap-plugin 10.1.1-1 10.1.2-2
osk-sdl - 0.63-1
:: Different sync package(s) in repository extra aarch64
alsa-card-profiles 1:0.3.27-1 1:0.3.28-1
assimp 5.0.1-2 5.0.1-3
booster 0.4-1 0.5-1
calligra 3.2.1-13 3.2.1-14
dav1d 0.8.2-1 0.9.0-1
dav1d-doc 0.8.2-1 0.9.0-1
djvulibre 3.5.28-2 3.5.28-3
egl-wayland 1.1.6-1 1.1.7-1
extra-cmake-modules 5.82.0-1 5.82.0-2
flatpak 1.10.2-1 1.11.1-1
flatpak-builder 1.0.11-2 1.0.12-1
geeqie 1.6-4 1.6-6
gegl 0.4.30-2 0.4.30-3
gimp 2.10.24-3 2.10.24-4
gnome-shell 1:40.1-1 1:40.1-2
gparted 1.3.0-3 1.3.0-4
gst-plugin-opencv 1.18.4-6 1.18.4-7
gst-plugin-pipewire 1:0.3.27-1 1:0.3.28-1
gst-plugin-wpe 1.18.4-6 1.18.4-7
gst-plugins-bad 1.18.4-6 1.18.4-7
gst-plugins-bad-libs 1.18.4-6 1.18.4-7
gvim 8.2.2845-1 8.2.2859-1
hplip 1:3.21.2-1 1:3.21.4-1
imagemagick 7.0.11.12-1 7.0.11.13-2
imagemagick-doc 7.0.11.12-1 7.0.11.13-2
imake 1.0.8-2 1.0.8-3
imath 3.0.1-1 3.0.3-1
ipp-usb 0.9.17-2 0.9.18-1
kdiff3 1.9.0-2 1.9.2-1
kimageformats 5.82.0-1 5.82.0-2
kio-extras 21.04.1-1 21.04.1-2
krita 4.4.3-2 4.4.3-3
ktexteditor 5.82.0-1 5.82.0-2
libgsystem 2015.2+4+gd606bec-3 -
libidn 1.36-1 1.37-1
libportal 0.3-2 0.4-1
libpst 0.6.75-4 0.6.76-1
libpst-docs 0.6.75-4 0.6.76-1
libqmi 1.28.2-1 1.28.4-1
libunrar 1:6.0.5-1 1:6.0.6-1
libx11 1.7.0-4 1.7.1-1
libxfixes 5.0.3-4 6.0.0-1
lpsolve 5.5.2.5-4 5.5.2.11-1
marble 21.04.1-1 21.04.1-2
marble-common 21.04.1-1 21.04.1-2
marble-qt 21.04.1-1 21.04.1-2
mlt 7.0.0-4 7.0.1-1
mlt6 6.26.1-3 6.26.1-4
mpd 0.22.6-4 0.22.7-1
opencv 4.5.2-3 4.5.2-4
opencv-samples 4.5.2-3 4.5.2-4
openexr 3.0.1-2 3.0.3-1
pango 1:1.48.4-1 1:1.48.5-1
pango-docs 1:1.48.4-1 1:1.48.5-1
perl-alien-build 2.38-1 2.40-1
perl-ffi-checklib 0.27-2 0.28-1
perl-file-readbackwards 1.05-7 1.06-1
perl-http-message 6.29-1 6.32-1
pipewire-alsa 1:0.3.27-1 1:0.3.28-1
pipewire-docs 1:0.3.27-1 1:0.3.28-1
pipewire-jack 1:0.3.27-1 1:0.3.28-1
pipewire-media-session 1:0.3.27-1 1:0.3.28-1
pipewire-pulse 1:0.3.27-1 1:0.3.28-1
postgresql-old-upgrade 12.5-3 12.7-1
prometheus 2.26.0-2 2.27.1-1
python-markupsafe 2.0.0-1 2.0.1-1
python-opencv 4.5.2-3 4.5.2-4
python-pyqt5-sip 12.8.1-3 12.9.0-1
python-pyqt6-sip 13.0.0-1 13.1.0-1
qt5-base 5.15.2+kde+r192-1 5.15.2+kde+r193-1
qt5-xcb-private-headers 5.15.2+kde+r192-1 5.15.2+kde+r193-1
quadrapassel 3.38.1-1 40.1-1
r 4.0.5-4 4.1.0-1
suitesparse 5.9.0-1 5.10.0-1
tali 40.0-1 40.1-1
tomcat8 8.5.65-1 8.5.66-1
tomcat9 9.0.45-1 9.0.46-1
vim-runtime 8.2.2845-1 8.2.2859-1
xdg-dbus-proxy 0.1.2-2 0.1.2-3
xfce4-screenshooter 1.9.8-1 1.9.9-1
xfce4-settings 4.16.1-1 4.16.1-2
marble-maps - 21.04.1-2
pipewire-zeroconf - 1:0.3.28-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.04.0.r12499.gb1eeb34f1-121.04.0.r12501.g8872f3ca5-1
akonadi-calendar21.04.0.r1937.g7149985-121.04.0.r1938.g239913d-1
akonadi-contacts21.04.0.r3006.gbee0faca-121.04.0.r3007.gf7b8feae-1
akonadi-import-wizard21.04.0.r1705.g3c9dbc8-121.04.0.r1706.g1f3695f-1
akonadi-mime21.04.0.r1616.g46f211e-121.04.0.r1617.gc6fddb5-1
akonadi-notes21.04.0.r1001.g3828b7a-121.04.0.r1002.g7b48a41-1
akonadi-search21.04.0.r1088.g1df6390-121.04.0.r1090.gee5faf3-1
akonadiconsole21.04.0.r1486.gb53bd1c-121.04.0.r1487.g7f06cca-1
amazfish 2.0.0.r2.g225bef2-1 2.0.0.r8.g676e4a7-1
analitza21.04.0.r2329.gb717ec00-121.04.0.r2330.g7072e346-1
ark21.04.0.r4522.gad8f47da-121.04.0.r4523.gda30c880-1
attica5.82.0.r806.g5d9b03d-15.82.0.r807.g193dea6-1
audiocd-kio21.04.0.r1014.g00a6f5c-121.04.0.r1016.gadf966b-1
baloo5.82.0.r2979.gb94aa021-15.82.0.r2983.g946d1c21-1
blinken21.04.0.r618.g1aac674-121.04.0.r622.gbfdb290-1
bluedevil1:5.21.4.r2261.gcc950509-11:5.21.4.r2263.g4a5f7f17-1
bluez-qt5.82.0.r656.g705dee7-15.82.0.r658.g262c0f2-1
bomber21.04.0.r513.gc32f2b7-121.04.0.r515.gbad5da8-1
bovo21.04.0.r724.g1b57ca0-121.04.0.r725.gf059a95-1
breeze5.21.4.r2180.g8f7e7168-15.21.4.r2184.g9029eeac-1
breeze-icons5.82.0.r1740.g038230e0-15.82.0.r1742.ge82ba721-1
buho 1.2.2.r0.g16ebcf2-1 1.2.2.r11.g7af6469-1
calendarsupport21.04.0.r521.g298a8e3-121.04.0.r522.gb530e85-1
calindori 21.05.r1.gb7c997f-1 21.05.r8.g8a15c3d-1
discover5.21.4.r8173.geef27e49-15.21.4.r8178.g7e7a8312-1
dolphin21.04.0.r6574.g53a778c1e-121.04.0.r6583.g953b25367-1
dragon21.04.0.r997.g1fd9562-121.04.0.r999.g8517a54-1
drkonqi5.21.4.r639.g74962561-15.21.4.r641.geef480ca-1
elisa21.04.0.r2689.g3b1f0b6c-121.04.0.r2700.gd3656166-1
eventviews21.04.0.r645.g0bf78b3-121.04.0.r646.g230177b-1
extra-cmake-modules5.81.0.r3294.g7c26724-15.82.0.r3304.g9d22f7b-1
filelight21.04.0.r961.g1795f03-121.04.0.r964.g64aedd2-1
frameworkintegration5.82.0.r581.g1d78f16-15.82.0.r583.gca03ff3-1
granatier21.04.0.r911.g95a990e-121.04.0.r914.g83cbca2-1
grantleetheme21.04.0.r319.g6b3e595-121.04.0.r320.gdcd390d-1
gwenview21.04.0.r6588.g2027581c-121.04.0.r6594.g7cc1638d-1
incidenceeditor21.04.0.r710.gb721620-121.04.0.r711.ga921f1f-1
index-fm 1.2.2.r0.g21402ee-1 1.2.2.r16.g01c2d6f-1
itinerary21.04.0.r1277.g337e190-121.04.0.r1282.g6eb1d9c-1
k3b1:21.04.0.r6603.g9b98a0374-11:21.04.0.r6606.gfcc14a6e7-1
kaccounts-integration21.04.0.r1206.gf7ca47b-121.04.0.r1207.gb36372a-1
kaccounts-providers21.04.0.r376.g3d26741-121.04.0.r377.ge2cb245-1
kactivities5.82.0.r1344.g170b79a-15.82.0.r1346.g1ec930f-1
kactivities-stats5.82.0.r350.gf7dfecb-15.82.0.r352.g9a6b086-1
kactivitymanagerd5.21.4.r1348.g89ed4b8-15.21.4.r1352.g11be786-1
kaddressbook21.04.0.r5959.gc94e61d6-121.04.0.r5960.g0c1f2a83-1
kalarmcal21.04.0.r1109.g5291b78-121.04.0.r1110.gc80af67-1
kalgebra21.04.0.r2024.g95fe2d7-121.04.0.r2028.g68e7fab-1
kalk 21.05.r0.gb5247dd-1 21.05.r7.gc337d5f-1
kapidox5.82.0.r524.g2c36122-15.82.0.r525.gdae2fd7-1
kapman21.04.0.r586.g57f80d5-121.04.0.r588.gb14383b-1
kapptemplate21.04.0.r948.ga852c14-121.04.0.r950.g1511f9b-1
karchive5.82.0.r476.gb2de441-15.82.0.r481.gdd2c1b2-1
kate21.04.0.r18108.gf8109d304-121.04.0.r18142.g5c5ef2cc9-1
katomic21.04.0.r907.gd6e93de-121.04.0.r910.gf9b1196-1
kauth5.82.0.r431.g5ee37da-15.82.0.r433.g804091c-1
kbackup21.04.0.r354.g5fa213f-121.04.0.r357.g76bf2ed-1
kblackbox21.04.0.r712.gb286a3c-121.04.0.r715.gac612f7-1
kblocks21.04.0.r629.gff267e0-121.04.0.r630.gb9a23cc-1
kbookmarks5.82.0.r404.g7f1fd62-15.82.0.r405.gebd6a22-1
kbounce21.04.0.r790.ge0566e5-121.04.0.r792.g9633285-1
kbreakout21.04.0.r846.g4a9b338-121.04.0.r848.g8ea52cf-1
kbruch21.04.0.r809.gdf54486-121.04.0.r811.g3cf25d0-1
kcalendarcore5.82.0.r1200.g79b407c25-15.82.0.r1204.g58bf11594-1
kcalutils21.04.0.r832.g5b1c36893-121.04.0.r833.gf8694ddca-1
kcharselect21.04.0.r459.gf9943ba-121.04.0.r460.gb5e0b66-1
kclock 21.05.r0.gbe4073d-1 21.05.r18.g6493132-1
kcmutils5.82.0.r507.g6085d90-15.82.0.r508.gf76a674-1
kcodecs5.82.0.r363.g27f018d-15.82.0.r364.g922b582-1
kcompletion5.82.0.r437.gd41c4ef-15.82.0.r438.g9fe0547-1
kconfig5.82.0.r829.g40f2371-15.82.0.r831.g725c2cc-1
kconfigwidgets5.82.0.r570.ga55be68-15.82.0.r572.g69e5222-1
kcontacts1:5.82.0.r3233.gdb74df7e-11:5.82.0.r3238.g030d5de3-1
kcoreaddons5.82.0.r1217.g532c0201-15.82.0.r1220.gd7f85915-2
kcrash5.82.0.r379.g4ed3863-15.82.0.r384.gb79e284-1
kcron21.04.0.r767.g4b40a56-121.04.0.r769.g1dfdfa7-1
kdav1:5.82.0.r1281.gc7bd0ce-11:5.82.0.r1282.g7413107-1
kdbusaddons5.82.0.r358.g189e302-15.82.0.r360.g0b21136-1
kde-cli-tools5.21.4.r1842.g6d7f8ac-15.21.4.r1843.gf588826-1
kde-dev-utils21.04.0.r548.gde5f082-121.04.0.r552.g05ffaa6-1
kde-gtk-config5.21.4.r891.gcdcdb9d-15.21.4.r892.g31f932e-1
kdebugsettings21.04.0.r801.g1e0e9e0-121.04.0.r802.g6721119-1
kdeclarative5.82.0.r889.gbf4869e-15.82.0.r890.g88822dc-1
kdeconnect21.04.0.r3192.g036704e1-121.04.0.r3193.ge8cffe2d-1
kded5.82.0.r398.g292a1a0-15.82.0.r400.g8ecc46b-1
kdegraphics-thumbnailers21.04.0.r230.g289e6e9-121.04.0.r231.g224d34b-1
kdelibs4support5.82.0.r1013.g457a5877-15.82.0.r1015.g932e9bed-1
kdenetwork-filesharing21.04.0.r879.ga30a88c-121.04.0.r880.g5e3dc75-1
kdenlive21.04.0.r14411.g3613496aa-121.04.0.r14460.g897371d74-1
kdepim-addons21.04.0.r4090.gd65e1491-121.04.0.r4094.g1d25d8c9-1
kdepim-runtime21.04.0.r15090.g3a2a751cd-121.04.0.r15096.ge54ef199c-1
kdeplasma-addons5.21.4.r8515.g913616041-15.21.4.r8519.ga266b6f82-1
kdesdk-kioslaves21.04.0.r487.gf9c1198-121.04.0.r488.g99737ef-1
kdesignerplugin5.82.0.r321.g72df7a8-15.82.0.r322.g621b79c-1
kdesu5.82.0.r460.gb7d5d82-15.82.0.r461.g4ce5071-1
kdewebkit5.82.0.r268.gd2d8247-15.82.0.r269.gb192239-1
kdf21.04.0.r781.gae6d5f4-121.04.0.r786.g71894ce-1
kdialog21.04.0.r1175.g540a36d8f-121.04.0.r1178.g9746cda9b-1
kdiamond21.04.0.r657.gb419bf7-121.04.0.r659.gbf622b2-1
kdnssd5.82.0.r304.g9a9c94f-15.82.0.r306.g91469f4-1
kdoctools5.82.0.r604.g74b961d-15.82.0.r606.g0c9e9b8-1
keditbookmarks21.04.0.r2735.gd9ff66970-121.04.0.r2738.g5e122c923-1
kemoticons5.82.0.r369.gb05e814-15.82.0.r370.g90697c1-1
kfilemetadata5.82.0.r789.g0a3889e-15.82.0.r790.g0ee00c1-1
kfind21.04.0.r2628.g0f1e278f3-121.04.0.r2630.gd860b5c94-1
kfloppy21.04.0.r743.gec0ab42-121.04.0.r746.g72738b1-1
kfourinline21.04.0.r967.g1d7f38a-121.04.0.r970.g2a51004-1
kgamma55.21.4.r454.g86956bc-15.21.4.r455.gdb6a51b-1
kget21.04.0.r3096.g7be01882-121.04.0.r3097.gbf097710-1
kglobalaccel5.82.0.r440.gb6469a8-15.82.0.r442.g24acf8c-1
kgoldrunner21.04.0.r1219.gfc767f4-121.04.0.r1222.g92095a1-1
kguiaddons5.82.0.r361.g9d391d9-15.82.0.r362.g394eebc-1
kholidays1:5.82.0.r930.gb409c9d-11:5.82.0.r931.g9548e4a-1
khotkeys5.21.4.r2068.gfc9bf56-15.21.4.r2071.g04dcaf1-1
khtml5.82.0.r543.g76d37f0-15.82.0.r545.gec1348b-1
ki18n5.82.0.r459.g06bb2b1-15.82.0.r462.g6878ea3-2
kiconthemes5.82.0.r520.gc0b726b-15.82.0.r522.g72b9dfb-1
kidentitymanagement21.04.0.r3780.g6bec3091-121.04.0.r3781.gb5623075-1
kidletime5.82.0.r297.g2fd4d9c-15.82.0.r299.ge8a8e90-1
kigo21.04.0.r505.gcb155d1-121.04.0.r508.g19a52c2-1
killbots21.04.0.r720.gf3583d1-121.04.0.r722.g1e79961-1
kimageformats5.82.0.r335.g62f9af9-15.82.0.r337.ge358bb0-1
kimap21.04.0.r1086.g21ab06f-121.04.0.r1087.g49216c4-1
kinfocenter5.21.4.r1828.g85ed039-15.21.4.r1833.gf5003ef-1
kinit5.82.0.r395.g0d64e3c-15.82.0.r397.g961753f-1
kio5.82.0.r4720.g6c501459-15.82.0.r4738.g41ba2d6f-1
kio-extras21.04.0.r7007.g42f00fc1-121.04.0.r7019.g0c7c503f-1
kio-gdrive21.04.0.r553.gb73b92b-121.04.0.r554.g603e8cf-1
kipi-plugins21.04.0.r12059.ge72ef84fa-121.04.0.r12060.g5fe710f54-1
kirigami25.82.0.r2778.g11baf9ed-15.82.0.r2788.gfe9ba293-1
kiriki21.04.0.r410.g3190306-121.04.0.r412.gba75fed-1
kitemmodels5.82.0.r536.g11a3839-15.82.0.r538.g9b0630d-1
kitemviews5.82.0.r323.g4560636-15.82.0.r324.g01a7f48-1
kitinerary21.04.0.r1752.gda45806-121.04.0.r1770.gfc2ae06-1
kjobwidgets5.82.0.r359.g96421aa-15.82.0.r361.gf6cd893-1
kjs5.82.0.r324.g2def7e8-15.82.0.r325.g18a6ffd-1
kjsembed5.82.0.r291.g15051fa-15.82.0.r293.gf000f77-1
kjumpingcube21.04.0.r771.g537fcdf-121.04.0.r775.g3f8c02e-1
kleopatra21.04.0.r5822.g01f8c6af-121.04.0.r5834.g85f4b7bf-1
klettres21.04.0.r904.ga11a60f-121.04.0.r906.g12c900c-1
klickety21.04.0.r618.g584b8fe-121.04.0.r620.g30e4a2f-1
klines21.04.0.r732.g914d8d8-121.04.0.r734.g2303fa7-1
kmag21.04.0.r679.g27f0644-121.04.0.r683.g7398913-1
kmahjongg21.04.0.r1457.g032621f-121.04.0.r1459.g3880caa-1
kmail21.04.0.r25721.g6a9873997-121.04.0.r25731.g7fc0f3b1c-1
kmailtransport21.04.0.r1601.g696c03f-121.04.0.r1602.g73fb839-1
kmbox21.04.0.r516.g2790933-121.04.0.r518.g3603e0c-1
kmediaplayer5.82.0.r282.gec1df64-15.82.0.r285.g9d178bf-1
kmenuedit5.21.4.r966.g3031e2f-15.21.4.r968.g2742003-1
kmime21.04.0.r1429.gfc6d12e-121.04.0.r1431.gcbbc2eb-1
kmines21.04.0.r1705.g60cab27-121.04.0.r1708.g2d2ce86-1
kmix21.04.0.r2358.g9dc0fba8-121.04.0.r2359.g61dc3141-1
kmousetool21.04.0.r383.gbc1f3f6-121.04.0.r387.g3e256a8-1
kmouth21.04.0.r682.g32f259e-121.04.0.r689.g23385b6-1
knetwalk21.04.0.r644.g87da352-121.04.0.r645.g36949c9-1
knewstuff5.82.0.r1089.g38d18b87-15.82.0.r1098.gda89aa1f-1
knotes21.04.0.r3450.g1e4815bc-121.04.0.r3451.gc8c8a09a-1
knotifications5.82.0.r650.ga0598cc-15.82.0.r652.g5cfd915-1
knotifyconfig5.82.0.r338.g6210b2d-15.82.0.r339.g1e157ab-1
kolf21.04.0.r1413.g1537135-121.04.0.r1414.g22a424b-1
kollision21.04.0.r480.g1a6f7be-121.04.0.r482.g5ebf1b6-1
kompare21.04.0.r1097.g6fab2b7-121.04.0.r1099.gc934559-1
kongress r199.g1d77510-1 r203.g7cd88d6-1
konqueror21.04.0.r14895.g7e9aed1cd-121.04.0.r14898.g73dd84388-1
konquest21.04.0.r882.g856b31d-121.04.0.r886.g025296d-1
konsole21.04.0.r7796.g110d705f-121.04.0.r7797.ge03a4680-1
kontact21.04.0.r5313.g14d1b543-121.04.0.r5314.gffb6c9fb-1
kontrast21.04.0.r164.g011f9d9-121.04.0.r165.ge4cb989-1
konversation21.04.0.r8947.g99dc337b-121.04.0.r8948.ga912c134-1
korganizer21.04.0.r11364.g5624ecf3c-121.04.0.r11365.gfa2358189-1
kosmindoormap21.04.0.r596.gc2acfdb-121.04.0.r598.g9c3ab76-1
kpackage5.82.0.r657.g2d408fc-15.82.0.r658.g1383496-1
kparts5.82.0.r502.g8bfdd25-15.82.0.r505.g9c67cf3-1
kpat21.04.0.r2530.gb516ade-121.04.0.r2532.g15f552d-1
kpeople5.82.0.r1315.g1edd4d0-15.82.0.r1317.g84b08fa-1
kpimtextedit21.04.0.r1377.ge2831e4-121.04.0.r1378.g2b94f23-1
kpkpass21.04.0.r213.g1a72fe1-121.04.0.r214.g7c34faf-1
kplotting5.82.0.r278.gf3e5ee8-15.82.0.r279.ga85eb04-1
kpmcore21.04.0.r1191.gce39e14-121.04.0.r1192.gf018824-1
kpty5.82.0.r321.gb17ae81-15.82.0.r322.g50d257f-1
kpublictransport21.04.0.r1617.gf8ef74a-121.04.0.r1620.g7cc77e3-1
kquickcharts5.82.0.r452.gef279a2-15.82.0.r453.g64ecbe3-1
krecorder r96.g53444ff-1 r105.g7b053d1-1
kreversi21.04.0.r1209.g4b3e682-121.04.0.r1212.gab43d70-1
kross5.82.0.r322.gdd27630-15.82.0.r323.g752c6c2-1
krunner5.82.0.r621.gef6c25d-15.82.0.r626.gbe1569d-1
kservice5.82.0.r907.gb347ca5-15.82.0.r910.g352f3cc-1
kshisen21.04.0.r1177.g0952936-121.04.0.r1179.g1bb38f7-1
ksmtp21.04.0.r345.gdefe997-121.04.0.r347.g21100c9-1
ksnakeduel21.04.0.r788.g66c407a-121.04.0.r790.g9d21e6d-1
kspaceduel21.04.0.r615.g6067319-121.04.0.r618.ge89b150-1
ksquares21.04.0.r506.g532241e-121.04.0.r508.g81035e0-1
ksshaskpass5.21.4.r195.g37bc83d-15.21.4.r196.gdaa2679-1
ksystemlog21.04.0.r630.g80d6c53-121.04.0.r634.gf575aeb-1
ktexteditor5.82.0.r2832.g4e4bd09a-15.82.0.r2842.g2913ea2f-1
ktextwidgets5.82.0.r394.g83faea5-15.82.0.r396.gff907fe-1
ktimer21.04.0.r455.gb072859-121.04.0.r457.g19eb39b-1
ktnef21.04.0.r643.g4ee2612-121.04.0.r644.g01c8435-1
ktorrent21.04.0.r2737.gdc691bab-121.04.0.r2746.gce382c22-1
ktouch21.04.0.r2127.gbbe35bc-121.04.0.r2129.g1031773-1
ktrip 21.05.r3.g9c70d13-1 21.05.r6.g945e9e5-1
kturtle21.04.0.r1106.g2c6e143-121.04.0.r1109.g5fa3fb6-1
kunitconversion5.82.0.r358.g5893dbb-15.82.0.r359.g385b027-1
kwallet5.82.0.r1063.g192e0a4-15.82.0.r1065.g635efda-1
kwalletmanager21.04.0.r1183.g9b108af-121.04.0.r1187.g24647bc-1
kwayland5.82.0.r1084.g9ac92ee-15.82.0.r1085.gca1ddbe-1
kwayland-server5.21.4.r1322.g0525ea4-15.21.4.r1323.g46e11af-1
kweather 0.4.r70.ge7f7921-1 0.4.r86.gbab7626-1
kwidgetsaddons5.82.0.r809.gc2daa371-15.82.0.r813.gd74d6fac-1
kwin5.21.4.r19386.gb9b58b6e6-15.21.4.r19418.g39e2387f9-1
kwinft5.20.90.r18720.g0b73dae39-15.20.90.r18731.g2f7c75edb-1
kwordquiz21.04.0.r1133.gf35bff0-121.04.0.r1135.g9690f4f-1
kwrite21.04.0.r18108.gf8109d304-121.04.0.r18142.g5c5ef2cc9-1
kwrited5.21.4.r477.gf2b3dec-15.21.4.r478.gb687e84-1
kxmlgui5.82.0.r752.g9aef7a7f-15.82.0.r757.g5d9b57f9-1
kxmlrpcclient5.82.0.r443.g25fd65f8c-15.82.0.r444.g3cf0be2b5-1
libakonadi21.04.0.r12499.gb1eeb34f1-121.04.0.r12501.g8872f3ca5-1
libgravatar21.04.0.r347.gc18e7aa-121.04.0.r348.g22a723c-1
libkcddb21.04.0.r731.g39d1f4f-121.04.0.r736.g24d5755-1
libkcompactdisc21.04.0.r384.g1771e18-121.04.0.r386.g4f9a6d2-1
libkdcraw21.04.0.r1147.g06ad4c3-121.04.0.r1148.g4af2f68-1
libkdegames21.04.0.r2174.gcd0dc330-121.04.0.r2175.g40f1d5da-1
libkdepim21.04.0.r827.g1e772f6-121.04.0.r828.gd9453c2-1
libkeduvocdocument21.04.0.r1787.gce505e8-121.04.0.r1791.g4966f86-1
libkexiv221.04.0.r813.gff82a6f-121.04.0.r815.gb0e00f4-1
libkgapi21.04.0.r1272.g99808eb-121.04.0.r1274.g8ff5d23-1
libkleo21.04.0.r868.g703a387-121.04.0.r872.g03b1e46-1
libkmahjongg21.04.0.r445.g8abbd01-121.04.0.r448.gc7aa7ac-1
libkomparediff221.04.0.r334.g8df3eca-121.04.0.r336.g36da81f-1
libksane21.04.0.r518.gdf26f29-121.04.0.r525.ga5f8ae7-1
libkscreen5.21.4.r1577.g3de67e2-15.21.4.r1578.gada0797-1
libksieve21.04.0.r1523.gf5830fa7-121.04.0.r1524.g217f803e-1
libksysguard5.21.4.r2223.g795def2-15.21.4.r2227.g2c893a0-1
libktorrent21.04.0.r510.g6940ea5-121.04.0.r515.g56be4b3-1
libquotient r1977.g0c8a819-1 r1979.g7761c2b-1
lskat21.04.0.r798.gd3b071e-121.04.0.r801.g1f6ab84-1
mailcommon21.04.0.r1032.gce01fc9-121.04.0.r1033.g5fc25c3-1
mailimporter21.04.0.r448.g0c88874-121.04.0.r449.gfe70972-1
marble21.04.0.r13305.g6424c2b1d-121.04.0.r13307.g81d173986-1
marble-common21.04.0.r13305.g6424c2b1d-121.04.0.r13307.g81d173986-1
marble-qt21.04.0.r13305.g6424c2b1d-121.04.0.r13307.g81d173986-1
markdownpart21.04.0.r65.gbfd443a-121.04.0.r68.g5d7c59f-1
maui-clip 1.1.1.r0.gd0690b8-1 1.1.1.r3.gc0636b4-1
maui-nota 1.2.2.r1.gf42d352-1 1.2.2.r13.gef8af38-1
maui-pix 1.2.2.r0.g327d024-1 1.2.2.r13.ge9dc5ba-1
mauikit 1.2.2.r5.gc9c922f0-11.2.2.r20.gb32a99e3-1
mauikit-filebrowsing r36.93a9bde-1 r46.f60128a-1
messagelib21.04.0.r5933.g6488be32-121.04.0.r5946.g8c89a6f0-1
milou5.21.4.r741.ge5b5a0a-15.21.4.r742.gd36b220-1
modemmanager-qt5.82.0.r505.gd355355-15.82.0.r507.g44b735c-1
neochat r1660.g8f403012-1 r1664.g179139c6-1
networkmanager-qt5.82.0.r1100.g5b71e55-15.82.0.r1102.g4dc6e95-1
okular21.04.0.r9322.g3ff6ff35b-121.04.0.r9328.g1954d43f0-1
oxygen5.21.4.r4414.g85e6c9e8-15.21.4.r4415.ga5a7f382-1
palapeli21.04.0.r1217.g493f0c2-121.04.0.r1221.g8c7b0b6-1
pim-data-exporter21.04.0.r2406.gcd6ac2ac-121.04.0.r2408.g77fec9d6-1
pim-sieve-editor21.04.0.r1472.g3906e0c-121.04.0.r1474.g58e2564-1
pimcommon21.04.0.r1049.gc29a711-121.04.0.r1050.gea35021-1
plasma-browser-integration5.21.4.r1250.gffe37ebf-15.21.4.r1254.gcedda05a-1
plasma-desktop5.21.4.r8446.gf2f21e54a-15.21.4.r8465.gadfb2a680-1
plasma-dialer 21.05.r11.gacf9c6a-1 21.05.r21.g0ff5a8b-1
plasma-firewall5.21.4.r488.g45d86b7-15.21.4.r489.ge5a70db-1
plasma-framework5.82.0.r15850.g9a8613612-15.82.0.r15855.g8c443f504-1
plasma-nano5.21.4.r144.gfb9fac9-15.21.4.r146.g47f2857-1
plasma-nm5.21.4.r3044.g7e42256f-15.21.4.r3046.gd5df9379-1
plasma-pa5.21.4.r940.g66e97be-15.21.4.r942.g1982415-1
plasma-phone-components5.21.4.r1394.g866f52e3-15.21.4.r1401.g70794cd9-1
plasma-phonebook r232.gb22a40f-1 r245.ga14896c-1
plasma-sdk5.21.4.r2267.g2debfd05-15.21.4.r2268.gc69fe2ca-1
plasma-settings r879.gd3293e4-1 r880.g7d1294e-1
plasma-systemmonitor5.21.4.r426.g3ada685-15.21.4.r431.ge13a2ba-1
plasma-wayland-session5.21.4.r10265.g901cb4a7f-15.21.4.r10283.g512135a65-1
plasma-workspace5.21.4.r10265.g901cb4a7f-15.21.4.r10283.g512135a65-1
plasma-workspace-wallpapers5.21.4.r257.gaed7cb3-15.21.4.r263.g449a40b-1
polkit-kde-agent5.21.4.r492.g1dd5955-15.21.4.r494.g644acd1-1
powerdevil5.21.4.r2433.g3a86d909-15.21.4.r2435.g9c0011a4-1
print-manager21.04.0.r1021.g7429802-121.04.0.r1025.g52f0d1e-1
prison5.82.0.r309.g9102227-15.82.0.r312.g8ee4c59-1
purpose5.82.0.r852.g853010e-15.82.0.r853.ge72823b-1
qqc2-desktop-style5.82.0.r482.g54308c4-15.82.0.r484.g7927dfc-1
sddm-kcm5.21.4.r580.g6d236b6-15.21.4.r585.gaa73d52-1
solid5.82.0.r668.g3bdef38-15.82.0.r669.g2ef5994-1
sonnet5.82.0.r611.g61b4183-15.82.0.r612.gf22c7ae-1
spacebar r386.gf4f47a1-1 r394.g01b942b-1
spectacle21.04.0.r1093.gb2d111a-121.04.0.r1095.g5ea0904-1
svgpart21.04.0.r159.g3b49dfc-121.04.0.r163.g466a7b8-1
syndication5.82.0.r823.g256a953-15.82.0.r824.g6d4da68-1
syntax-highlighting5.82.0.r1580.g717399ea-15.82.0.r1583.ge425acd3-1
systemsettings5.21.4.r2429.g50a47f40-15.21.4.r2434.g841daea4-1
threadweaver5.82.0.r491.g4f1ef2a-15.82.0.r496.ge102103-1
umbrello21.04.0.r8246.g7bc661137-121.04.0.r8248.gcf9dae8f9-1
vvave 1.2.2.r0.g4d66b10-1 1.2.2.r11.gf76f8f8-1
xdg-desktop-portal-kde5.21.4.r361.gf7c1523-15.21.4.r364.gf4ef1a2-1
yakuake21.04.0.r710.g21ad0b5-121.04.0.r719.g528c400-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
