Hello ARM community.
This update was a long time coming.
But it’s here!
Some highlights:
- Most of our kernels got updated
- KDE Frameworks is now at 5.82
- A few updates to Gnome brings it to 40.1
- All the Maui apps have a new stable release
- Plasma Mobile now has a combined release schedule, 21.05 was just released
- Lots of Mobile specific packages got updated
- Some python packages got updated
If anyone wants to test kodi on the rpi:
Change to the unstable or testing branch and install kodi packages:
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip and firewalld requires manual intervention:
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Fri May 14 17:16:38 CEST 2021)
- arm-testing community aarch64: 399 new and 369 removed package(s)
- arm-testing core aarch64: 30 new and 31 removed package(s)
- arm-testing extra aarch64: 537 new and 612 removed package(s)
- arm-testing kde-unstable aarch64: 236 new and 235 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-05-07 2021-05-14
alligator 0.1-0 21.05-1
angelfish 1.8.0-1 21.05-1
bitwarden 1.24.6-1 1.26.0-1
breath2-icon-themes 1.0.10-1 1.0.11-2
breath2-wallpaper 1.0.10-1 1.0.11-2
calindori 1.4-1 21.05-1
eg25-manager 0.3.0+2+g64145ac-3 0.3.0+2+g64145ac-5
element-desktop 1.7.26-1 1.7.27-1
element-web 1.7.26-1 1.7.27-1
gnome-contacts-mobile 3.38.1-2 3.38.1-3
kalk 0.2-1 21.05-1
kclock 0.4.0-0 21.05-1
kodi-rpi 19.0-10 19.1-4
kodi-rpi-dev 19.0-10 19.1-4
kodi-rpi-eventclients 19.0-10 19.1-4
kodi-rpi-tools-texturepacker 19.0-10 19.1-4
koko 0.1+r520.9159df6-1 21.05-1
kongress 1.0-0 21.05-1
krecorder 0.1-1 21.05-1
libmm-pp-glib 1.16.2-1 1.16.4-2
maui-clip 1.1.0-1.1 -
maui-nota 1.2.1-1.1 -
modemmanager-pp 1.16.2-1 1.16.4-2
peruse 1.2.r281.g2bda54c-1 1.80-2
phosh 0.10.2+20+g0472e0f-1 0.10.2+53+gd14786a-1
plasma-dialer 0.3-1 21.05-1
plasma-phonebook 0.1-0 21.05-1
plasma-settings 0.2-0.1 21.05-1
plasma5-themes-breath2 1.0.10-1 1.0.11-2
qmlkonsole 0.1-1 21.05-1
sddm-breath2-theme 1.0.10-1 1.0.11-2
spacebar 0.2-1 21.05-1
spacebear-git r35.75f33e6-1 -
user-manager-git5.19.90.r501.g1b71858-1 -
vivaldi 3.8.2259.40-1 3.8.2259.42-1
wire-desktop 3.24.2939-1 3.25.2940-1
yay 10.2.1-1 10.2.2-1
ktrip - 21.05-1
wake-mobile - 1.7-1
:: Different sync package(s) in repository community aarch64
acme-redirect 0.5.0-1 0.5.1-1
android-tools 31.0.0-2 31.0.0-3
ansible 3.3.0-2 3.4.0-1
apache-orc 1.6.7-2 1.6.7-3
arch-repro-status 0.1.0-1 1.0.0-1
arcus 4.8.0-3 4.8.0-4
arduino 1:1.8.13-3 1:1.8.14-1
arduino-builder 1.5.4-2 1.6.0-1
arrow 3.0.0-1 3.0.0-2
autofs 5.1.7-1 -
avr-gcc 10.3.0-1 11.1.0-1
aws-cli 1.19.55-1 1.19.72-1
baidupcs-go 3.7.2-2 3.7.9-1
bcc 0.19.0-1 0.20.0-1
bcc-tools 0.19.0-1 0.20.0-1
bctoolbox 4.5.13-1 4.5.15-1
bfgminer 5.5.0-3 -
bitlbee 3.6-2 -
borg 1.1.16-3 1.1.16-4
broot 1.3.1-1 1.4.0-1
buho 1.2.1-1 1.2.2-1
bzrtp 4.5.13-1 4.5.15-1
cargo-c 0.8.0-1 0.8.1-1
cawbird 1.4-1 1.4.1-1
ccache 4.2.1-1 4.3-1
cclive 0.9.3-23 0.9.3-24
cgminer 4.10.0-4 -
cgoban 1.9.14-4 -
chezmoi 2.0.11-1 2.0.12-1
chrony 4.0-1 4.1-1
clash 1.5.0-1 1.6.0-1
clementine1.4.0rc1+495+g10bf5dc17-21.4.0rc1+495+g10bf5dc17-3
cmst 2020.11.01-1 -
cockatrice 2.8.0-2 2.8.0-3
collectd 5.12.0-3 -
communicator 1.2.1-1 1.2.2-1
containerd 1.5.0-1 1.5.0-2
coolreader 3.2.55-1 3.2.57-1
croc 9.1.2-1 9.1.3-1
curaengine 4.8.0-2 4.8.0-3
deadbeef 1.8.4-1 -
dee 1.2.7-11 -
deepin-qt5platform-plugins 5.0.21-1 5.0.23-2
deno 1.9.2-1 1.10.1-1
diffoscope 173-1 174-1
dnstracer 1.10-1 -
docker-compose 1.29.1-2 1.29.2-1
dropbear 2020.81-2 2020.81-3
dropbear-scp 2020.81-2 2020.81-3
drumstick 2.1.1-1 2.2.0-1
dua-cli 2.11.1-1 2.11.3-1
encfs 1.9.5-2 1.9.5-4
erlang 23.3.2-1 24.0-1
erlang-cl 1.2.4-2 1.2.4-3
erlang-docs 23.3-1 24.0-1
erlang-unixodbc 23.3.2-1 24.0-1
eslint 7.25.0-1 7.26.0-1
etherwall 3.0.2-3 3.0.2-4
etl 1.4.0-1 1.4.1-1
exploitdb 20210316-1 20210508-1
fcitx5-gtk 5.0.6-2 5.0.7-1
filezilla 3.53.1-1 3.54.1-2
findomain 4.1.1-1 4.2.0-1
fingerterm 1.4.1-1 1.4.2-1
fish 3.2.1-1 3.2.2-1
flake8 1:3.9.1-1 1:3.9.2-1
flatbuffers 1.12.0-3 2.0.0-1
gdal 3.2.2-2 3.2.3-1
git-lfs 2.13.3-1 2.13.3-2
gmock 1.10.0-3 -
gmrun 1.1w-1 1.2w-1
gnokii 0.6.31-19 -
gnome-phone-manager 0.69-16 -
gnuchess 6.2.7-1 6.2.8-1
gnunet 0.14.1-1 -
gnurl 7.72.0-1 -
google-glog 0.4.0-2 0.5.0-1
gopass 1.12.5-1 1.12.6-1
gopls 0.6.4-2 0.6.11-1
grails 4.0.6-1 4.0.10-1
grails-docs 4.0.6-1 4.0.10-1
grpc 1.36.4-1 1.36.4-2
grpc-cli 1.36.4-1 1.36.4-2
gtest 1.10.0-3 1.10.0-6
gxkb 0.9.1-1 0.9.2-1
hyperion 1.03.2-23 1.03.2-24
i3status-rust 0.14.7-1 0.20.1-1
ibus-table 1.12.6-1 1.13.0-1
icewm 2.3.3-1 2.3.4-1
imwheel 1.0.0pre12-5 1.0.0pre12-6
index-fm 1.2.1-1 1.2.2-1
interception-tools 0.6.5-1 0.6.6-1
iodine 0.7.0-4 0.7.0-5
jedit 5.6.0-1 -
jenkins 2.291-1 2.293-1
jmol 14.31.36-1 14.31.38-1
jsmol 14.31.36-1 14.31.38-1
jupyter-nbclassic 0.2.7-1 0.2.8-1
jupyter-server 1.6.4-1 1.7.0-2
jupyterlab 3.0.14-1 3.0.15-1
k9s 0.24.8-1 0.24.9-1
kio-fuse 5.0.1-1 -
klayout 0.27-1 0.27-2
kodi-platform 20190726.809c5e9-22 20190726.809c5e9-23
kupfer 320-2 321-1
ld-lsb 3-7 3-8
libappletdecoration 0.8.1-3 -
libfilezilla 0.27.1-1 0.28.0-2
libimagequant 2.14.1-1 2.15.0-1
libmgba 0.9.0-1 0.9.1-1
liboping 1.10.0-8 -
librdkafka 1.6.1-1 1.7.0-1
lxd 4.13-1 4.14-1
matrix-synapse 1.29.0-1 1.33.2-1
maui-clip 1.1.0-1 1.1.1-1
maui-nota 1.2.1-1 1.2.2-1
maui-pix 1.2.1-2 1.2.2-2
maui-shelf 1.1.0-1 1.1.1-1
maui-station 1.2.1-2 1.2.2-1
mauikit 1.2.1-1 1.2.2-3
maxima-ecl 5.44.0-2 5.44.0-3
mdbook 0.4.7-1 0.4.8-1
mdcat 0.22.4-1 0.22.4-2
mediaelch 2.8.6-1 2.8.12-1
mediastreamer 4.5.13-1 4.5.15-1
medusa 2.2-9 2.2-10
mgba-qt 0.9.0-1 0.9.1-1
mgba-sdl 0.9.0-1 0.9.1-1
minder 1.12.0-2 1.12.2-1
mksh 59.c-1 -
mldonkey 3.1.7-1 -
molecule 3.3.0-1 3.3.0-2
mosh 1.3.2-13 1.3.2-14
mpop 1.4.8-1 1.4.13-1
mumble 1.3.4-4 1.3.4-5
murmur 1.3.4-4 1.3.4-5
mysql-workbench 8.0.24-2 8.0.25-1
nbd 3.21-1 3.21-2
netdata 1.30.1-1 1.30.1-2
newsflash 1.4.0-3 1.4.1-1
nload 0.7.4-6 0.7.4-7
nlohmann-json 3.9.1-1 3.9.1-2
npm 7.11.2-1 7.12.1-1
npm-check-updates 11.5.10-1 11.5.11-1
nsjail 3.0-2 3.0-3
nvchecker 2.3-1 2.3-2
opendmarc 1.4.0-2 1.4.1.1-1
openshadinglanguage 1.11.13.0-4 1.11.14.0-1
ortp 4.5.13-1 4.5.15-1
paps 0.7.1-2 -
pdf2djvu 0.9.17.1-9 -
perl-cgi 4.51-1 4.52-1
perl-test2-suite 0.000139-1 0.000140-1
photoflare 1.6.7.1-1 1.6.8-1
php-grpc 1.36.4-1 1.36.4-2
php7-grpc 1.36.4-1 1.36.4-2
pifpaf 3.1.1-1 3.1.4-1
plasma5-applets-window-buttons 0.8.1-3 0.9.0-1
pngquant 2.14.1-1 2.15.0-1
polipo 1.1.1-4 -
polyml 5.8.1-1 5.8.2-1
ponymix 5-3 -
powerdns 4.4.1-2 4.4.1-3
powerdns-recursor 4.4.3-1 4.4.3-2
prettier 2.2.1-1 2.3.0-1
proj 8.0.0-3 8.0.1-1
projectm 3.1.12-1 3.1.12-2
projectm-pulseaudio 3.1.12-1 3.1.12-2
projectm-sdl 3.1.12-1 3.1.12-2
proselint 0.10.2-6 -
prosody 1:0.11.8-1 1:0.11.9-1
python-alembic 1.4.3-3 1.6.2-1
python-anyio 2.2.0-1 3.0.1-1
python-apispec 4.4.0-1 4.4.1-1
python-awesomeversion 21.4.0-1 21.5.0-1
python-babel 2.9.0-1 2.9.1-1
python-bcc 0.19.0-1 0.20.0-1
python-black 21.5b0-1 21.5b1-1
python-boto3 1.17.55-1 1.17.72-1
python-botocore 1.20.55-1 1.20.72-1
python-braintree 4.8.0-1 4.9.0-1
python-cerberus 1.3.3-1 1.3.4-1
python-click 7.1.2-4 8.0.0-1
python-click-threading 0.4.4-9 0.4.4-10
python-cookiecutter 1.7.2-3 1.7.2-5
python-engineio 4.0.0-1 4.1.0-1
python-eventlet 0.30.2-1 0.31.0-1
python-faker 8.1.2-1 8.1.3-1
python-flask 1.1.2-4 2.0.0-1
python-flask-sqlalchemy 2.4.4-3 2.5.1-1
python-flatbuffers 1.12.0-3 2.0.0-1
python-fs 2.4.13-1 2.4.13-2
python-funcy 1.15-2 1.16-1
python-gdal 3.2.2-2 3.2.3-1
python-geoip2 4.1.0-3 4.2.0-1
python-google-api-core 1.26.1-1 1.26.3-1
python-google-api-python-client 1.12.8-1 2.3.0-1
python-grpcio 1.36.4-1 1.36.4-2
python-httpretty 1.0.5-1 1.1.0-1
python-hypothesis 6.10.1-1 6.12.0-1
python-itsdangerous 1.1.0-6 2.0.0-1
python-jinja 2.11.3-2 3.0.0-1
python-joblib 1.0.0-1 1.0.1-1
python-jupyter_packaging 0.10.1-1 0.10.2-1
python-jupyterlab_server 2.5.0-1 2.5.1-1
python-kitchen 1.2.6-5 -
python-ldap 3.3.1-3 3.3.1-4
python-magic 5.39-3 5.40-1
python-marshmallow 3.11.1-1 3.12.1-1
python-meilisearch 0.14.1-1 0.14.2-1
python-mocket 3.9.40-1 3.9.40-2
python-openapi-spec-validator 0.3.0-1 0.3.1-1
python-openmdao 3.8.0-1 3.9.1-1
python-oslo-db 8.6.0-1 9.0.0-1
python-oslo-utils 4.8.0-1 4.9.0-1
python-ovirt-engine-sdk 4.4.10-1 4.4.12-1
python-owslib 0.23.0-1 0.24.1-1
python-pandas 1.2.3-1 1.2.3-2
python-parso 1:0.8.1-1 1:0.8.2-1
python-phonenumbers 8.12.22-1 8.12.23-1
python-pikepdf 2.11.4-1 2.12.0-1
python-pudb 2020.1-1 2021.1-1
python-pycares 3.1.1-3 4.0.0-1
python-pydocstyle 5.1.1-3 6.0.0-1
python-pygame 2.0.1-1 2.0.1-2
python-pygls 0.10.3-1 0.10.3-2
python-pyotp 2.4.1-1 2.6.0-2
python-pytest-benchmark 3.2.3-4 3.4.0-1
python-pytest-celery 0.0.0a1-4 0.0.0-1
python-pytest-checkdocs 2.3.0-1 2.5.0-1
python-pytest-httpx 0.11.0-1 0.12.0-1
python-pytest-isort 1.3.0-1 2.0.0-1
python-pytest-randomly 3.5.0-2 3.7.0-1
python-pywinrm 0.4.1-4 0.4.2-1
python-reportlab 3.5.66-1 3.5.67-1
python-rfc3339-validator 0.1.3-1 0.1.4-1
python-rfc3986 1.4.0-3 1.5.0-1
python-s3transfer 0.4.1-1 0.4.2-1
python-scikit-learn 0.24.1-1 0.24.2-1
python-serpent 1.30.2-3 1.30.2-5
python-socketio 5.0.4-1 5.2.1-1
python-sphinx 3.5.4-2 4.0.1-2
python-sqlalchemy-utils 0.36.8-3 0.37.1-1
python-sshtunnel 0.1.5-5 0.4.0-1
python-typeguard 2.10.0-3 2.11.0-1
python-websocket-client 0.58.0-1 0.59.0-1
python-websockets 8.1-3 9.0.1-3
python-werkzeug 1.0.1-4 2.0.0-1
python-wtforms 2.2.1-10 2.3.3-1
python-zeroconf 0.29.0-1 0.29.0-2
qgis 3.18.2-2 3.18.2-3
qmmp 1.4.5-1 1.4.6-1
qpress 1.1-3 1.1-4
redmine 4.1.1-2 4.2.1-1
remmina 1:1.4.13-1 1:1.4.14-1
rpm-tools 4.16.1.2-1 4.16.1.3-1
rtv 1.27.0-3 -
ruby-activesupport 6.1.3-3 6.1.3.2-1
ruby-cairo 1.17.5-2 1.17.5-3
ruby-crack 0.4.4-2 -
ruby-hashdiff 1.0.0-3 -
ruby-json-schema 2.8.1-3 -
ruby-rdoc 6.3.0-3 6.3.1-1
ruby-ronn-ng 0.9.1-3 0.9.1-4
ruby-rspec-its 1.3.0-4 -
ruby-webmock 3.11.2-1 -
runc 1.0.0rc93-2 1.0.0rc94-1
rust-analyzer 20210503-1 20210510-1
sbctl 0.3-1 0.4-2
screenkey 1.4-1 1.4-2
siege 4.0.8-1 4.0.9-1
skk-jisyo 20210411-1 20210509-1
ssr 0.5.0-3 0.5.0-4
step-ca 0.15.14-1 0.15.15-1
swi-prolog 8.2.3-1 8.2.4-1
syncthing 1.15.1-1 1.16.1-1
syncthing-relaysrv 1.15.1-1 1.16.1-1
tailscale 1.8.1-1 1.8.3-1
tcptrace 6.6.7-6 -
termite 15-3 15-4
termite-terminfo 15-3 15-4
termtosvg 1.1.0-2 -
terraform 0.15.1-1 0.15.3-1
terragrunt 0.29.0-1 0.29.2-1
testssl.sh 3.0.4-1 3.0.5-1
tnftp 20151004-4 20200705-1
tor 0.4.5.7-1 0.4.5.8-1
towncrier 19.9.0rc1-3 21.3.0-1
toxcore 1:0.2.12-1 1:0.2.12-2
ttc-iosevka 5.2.1-2 6.1.3-1
ttc-iosevka-aile 5.2.1-2 6.1.3-1
ttc-iosevka-curly 5.2.1-2 6.1.3-1
ttc-iosevka-curly-slab 5.2.1-2 6.1.3-1
ttc-iosevka-etoile 5.2.1-2 6.1.3-1
ttc-iosevka-slab 5.2.1-2 6.1.3-1
ttc-iosevka-ss01 5.2.1-2 6.1.3-1
ttc-iosevka-ss02 5.2.1-2 6.1.3-1
ttc-iosevka-ss03 5.2.1-2 6.1.3-1
ttc-iosevka-ss04 5.2.1-2 6.1.3-1
ttc-iosevka-ss05 5.2.1-2 6.1.3-1
ttc-iosevka-ss06 5.2.1-2 6.1.3-1
ttc-iosevka-ss07 5.2.1-2 6.1.3-1
ttc-iosevka-ss08 5.2.1-2 6.1.3-1
ttc-iosevka-ss09 5.2.1-2 6.1.3-1
ttc-iosevka-ss10 5.2.1-2 6.1.3-1
ttc-iosevka-ss11 5.2.1-2 6.1.3-1
ttc-iosevka-ss12 5.2.1-2 6.1.3-1
ttc-iosevka-ss13 5.2.1-2 6.1.3-1
ttc-iosevka-ss14 5.2.1-2 6.1.3-1
ttc-iosevka-ss15 5.2.1-2 6.1.3-1
ttc-iosevka-ss16 5.2.1-2 6.1.3-1
ttc-iosevka-ss17 5.2.1-2 6.1.3-1
uget 2.2.3-3 2.2.3-4
uglify-js 3.13.5-1 3.13.6-1
umockdev 0.15.4-1 0.15.5-1
uncrustify 0.72.0-1 0.73.0-1
unionfs-fuse 2.1-1 2.1-2
v2ray-domain-list-community 20210507022421-1 20210508061759-1
v2ray-geoip 202105070029-1 202105130030-1
vaultwarden-web 2.19.0.d-1 2.20.1-1
vicious 2.4.1-2 2.5.0-1
vmpk 0.8.2-1 0.8.3-1
vultr-cli 2.5.0-2 2.5.1-1
vvave 1.2.1-1 1.2.2-1
wifite 1:87.r139.918a499-3 2:2.5.8-1
wireplumber 0.3.0-1 0.3.95-1
xcursor-premium 0.3-9 0.3-10
xkcdpass 1.17.6-1 -
yosys 0.9-11 0.9-12
youtube-viewer 1:3.9.0-1 -
zinnia 0.06-6 -
aspell-es - 1.11-8
efl - 1.25.1-6
efl-docs - 1.25.1-6
glide - 0.5.8-2
hunspell-it - 2.4-9
hunspell-ro - 3.3.10-5
hyphen-it - 20071127-5
mauikit-filebrowsing - 1.2.2-2
mauikit-imagetools - 1.2.2-1
mauikit-texteditor - 1.2.2-1
mythes-it - 2.0.9l-6
mythes-ro - 3.3-7
procinfo-ng - 2.0.304-8
python-aiounittest - 1.4.0-1
python-sphinxcontrib-log-cabinet - 1.0.1-1
python-zxcvbn - 4.4.28-1
ruby-red-colors - 0.1.1-1
vim-spell-af - 20190731-2
vim-spell-am - 20190731-2
vim-spell-bg - 20190731-2
vim-spell-br - 20190731-2
vim-spell-ca - 20190731-2
vim-spell-cs - 20190731-2
vim-spell-cy - 20190731-2
vim-spell-da - 20190731-2
vim-spell-de - 20190731-2
vim-spell-el - 20190731-2
vim-spell-en - 20190731-2
vim-spell-eo - 20190731-2
vim-spell-es - 20190731-2
vim-spell-fo - 20190731-2
vim-spell-fr - 20190731-2
vim-spell-ga - 20190731-2
vim-spell-gd - 20190731-2
vim-spell-gl - 20190731-2
vim-spell-he - 20190731-2
vim-spell-hr - 20190731-2
vim-spell-hu - 20190731-2
vim-spell-id - 20190731-2
vim-spell-it - 20190731-2
vim-spell-ku - 20190731-2
vim-spell-la - 20190731-2
vim-spell-lt - 20190731-2
vim-spell-lv - 20190731-2
vim-spell-mg - 20190731-2
vim-spell-mi - 20190731-2
vim-spell-ms - 20190731-2
vim-spell-nb - 20190731-2
vim-spell-nl - 20190731-2
vim-spell-nn - 20190731-2
vim-spell-ny - 20190731-2
vim-spell-pl - 20190731-2
vim-spell-pt - 20190731-2
vim-spell-ro - 20190731-2
vim-spell-ru - 20190731-2
vim-spell-rw - 20190731-2
vim-spell-sk - 20190731-2
vim-spell-sl - 20190731-2
vim-spell-sr - 20190731-2
vim-spell-sv - 20190731-2
vim-spell-sw - 20190731-2
vim-spell-tet - 20190731-2
vim-spell-th - 20190731-2
vim-spell-tl - 20190731-2
vim-spell-tn - 20190731-2
vim-spell-uk - 20190731-2
vim-spell-yi - 20190731-2
vim-spell-zu - 20190731-2
xplr - 0.9.0-1
zram-generator - 0.3.2-1
:: Different overlay package(s) in repository core aarch64
linux 5.12.2-2 5.12.4-1
linux-headers 5.12.2-2 5.12.4-1
linux-pinephone 5.12.2-2 5.12.3-1
linux-pinephone-headers 5.12.2-2 5.12.3-1
linux-rc 5.12.rc8-3 5.13.rc1-1
linux-rc-headers 5.12.rc8-3 5.13.rc1-1
linux-rpi4 5.10.35-1 5.10.36-1
linux-rpi4-headers 5.10.35-1 5.10.36-1
linux-rpi4-mainline 5.12.1-1 5.12.3-1
linux-rpi4-mainline-headers 5.12.1-1 5.12.3-1
pacman 5.2.2-4 5.2.2-6
pacman-debug 5.2.2-4 5.2.2-6
raspberrypi-bootloader 20210507-1 20210513-1
raspberrypi-bootloader-x 20210507-1 20210513-1
uboot-pinebookpro-display 2021.07rc1-1 2021.07rc2-1
:: Different sync package(s) in repository core aarch64
bash 5.1.004-1 5.1.008-1
btrfs-progs 5.11.1-1 5.12-2
device-mapper 2.03.11-5 2.03.12-1
file 5.40-2 5.40-3
glib2 2.68.1-1 2.68.2-1
glib2-docs 2.68.1-1 2.68.2-1
hdparm 9.60-1 9.61-1
lvm2 2.03.11-5 2.03.12-1
procinfo-ng 2.0.304-8 -
readline 8.1.0-2 8.1.001-1
sdparm 1.11-1 1.12-1
systemd 248-5 248.2-2
systemd-libs 248-5 248.2-2
systemd-resolvconf 248-5 248.2-2
systemd-sysvcompat 248-5 248.2-2
vi 1:070224-4 1:070224-5
:: Different overlay package(s) in repository extra aarch64
mesa-git21.2.0_devel.138945.3326861f4f4-121.2.0_devel.139382.d81a6e5f1d3-1
network-manager-applet 1.18.0-1 1.22.0-1
nm-connection-editor 1.18.0-1 1.22.0-1
:: Different sync package(s) in repository extra aarch64
abook 0.6.1-6 -
adwaita-icon-theme 40.1-1 40.1.1-1
akonadi 21.04.0-1 21.04.1-1
akonadi-calendar 21.04.0-1 21.04.1-1
akonadi-calendar-tools 21.04.0-1 21.04.1-1
akonadi-contacts 21.04.0-1 21.04.1-1
akonadi-import-wizard 21.04.0-1 21.04.1-1
akonadi-mime 21.04.0-1 21.04.1-1
akonadi-notes 21.04.0-1 21.04.1-1
akonadi-search 21.04.0-1 21.04.1-1
akonadiconsole 21.04.0-1 21.04.1-1
akregator 21.04.0-1 21.04.1-1
analitza 21.04.0-1 21.04.1-1
apache 2.4.46-3 2.4.47-1
ark 21.04.0-1 21.04.1-1
artikulate 21.04.0-1 21.04.1-1
aspell-es 1.11-8 -
attica 5.81.0-1 5.82.0-1
audiocd-kio 21.04.0-1 21.04.1-1
baloo 5.81.0-1 5.82.0-1
baloo-widgets 21.04.0-1 21.04.1-1
blinken 21.04.0-1 21.04.1-1
bluez-qt 5.81.0-1 5.82.0-1
bomber 21.04.0-1 21.04.1-1
botan 2.18.0-1 2.18.1-1
bovo 21.04.0-1 21.04.1-1
breeze-icons 5.81.0-1 5.82.0-1
bullet 3.08-2 3.17-1
bullet-docs 3.08-2 3.17-1
calendarsupport 21.04.0-1 21.04.1-1
cantor 21.04.0-1 21.04.1-1
cervisia 21.04.0-1 21.04.1-1
chrome-gnome-shell 10.1-5 -
chromium 90.0.4430.93-1 90.0.4430.212-1
cvsps 3.13-3 -
dolphin 21.04.0-1 21.04.1-1
dolphin-plugins 21.04.0-1 21.04.1-1
dragon 21.04.0-1 21.04.1-1
ecl 20.4.24-2 21.2.1-1
efl 1.25.1-4 -
efl-docs 1.25.1-4 -
elisa 21.04.0-1 21.04.1-1
ethtool 1:5.10-1 1:5.12-1
eventviews 21.04.0-1 21.04.1-1
extra-cmake-modules 5.81.0-1 5.82.0-1
feh 3.6.3-1 3.7-1
ffmpegthumbs 21.04.0-1 21.04.1-1
filelight 21.04.0-1 21.04.1-1
flac 1.3.3-2 1.3.3-3
flac-doc 1.3.3-2 1.3.3-3
font-bh-ttf 1.0.3-7 -
frameworkintegration 5.81.0-1 5.82.0-1
fvwm 2.6.9-3 -
galera 26.4.7-1 26.4.8-1
gdb 10.1-4 10.2-1
gdb-common 10.1-4 10.2-1
gnome-calendar 40.0-1 40.1-1
gnome-shell1:40.0+67+g79acae417-1 1:40.1-1
gnome-shell-extensions 40.0-2 40.1-1
granatier 21.04.0-1 21.04.1-1
grantlee-editor 21.04.0-1 21.04.1-1
grantleetheme 21.04.0-1 21.04.1-1
gtk-update-icon-cache 1:4.2.0-5 1:4.2.1-1
gtk4 1:4.2.0-5 1:4.2.1-1
gtk4-demos 1:4.2.0-5 1:4.2.1-1
gtk4-docs 1:4.2.0-5 1:4.2.1-1
gtkglext 1.2.0-12 1.2.0-13
gtkmathview 0.8.0-8 0.8.0-9
gvim 8.2.2815-1 8.2.2845-1
gwenview 21.04.0-1 21.04.1-1
hefur 1.0-2 1.0-3
hunspell-it 2.4-9 -
hunspell-ro 3.3.10-5 -
hyphen-it 20071127-5 -
imagemagick 7.0.11.11-1 7.0.11.12-1
imagemagick-doc 7.0.11.11-1 7.0.11.12-1
incidenceeditor 21.04.0-1 21.04.1-1
itinerary 21.04.0-1 21.04.1-1
java-activation-gnu 1.1.2-2 -
java-bcel 6.2-2 -
java-commons-net1 1.4.1-4 -
java-gnumail 1.1.2-4 -
java-inetlib 1.1.2-4 -
java-jdepend 2.9.1-4 -
java-jsch 0.1.55-2 -
java-resolver 1.2-4 -
joe 4.6-2 -
juk 21.04.0-1 21.04.1-1
k3b 1:21.04.0-1 1:21.04.1-1
kaccounts-integration 21.04.0-1 21.04.1-1
kaccounts-providers 21.04.0-1 21.04.1-1
kactivities 5.81.0-1 5.82.0-1
kactivities-stats 5.81.0-1 5.82.0-1
kaddressbook 21.04.0-1 21.04.1-1
kajongg 21.04.0-1 21.04.1-1
kalarm 21.04.0-1 21.04.1-1
kalarmcal 21.04.0-1 21.04.1-1
kalgebra 21.04.0-1 21.04.1-1
kalzium 21.04.0-1 21.04.1-1
kamera 21.04.0-1 21.04.1-1
kamoso 21.04.0-1 21.04.1-1
kanagram 21.04.0-1 21.04.1-1
kapidox 5.81.0-1 5.82.0-1
kapman 21.04.0-1 21.04.1-1
kapptemplate 21.04.0-1 21.04.1-1
karchive 5.81.0-1 5.82.0-1
kate 21.04.0-1 21.04.1-1
katomic 21.04.0-1 21.04.1-1
kauth 5.81.0-1 5.82.0-1
kbackup 21.04.0-1 21.04.1-1
kblackbox 21.04.0-1 21.04.1-1
kblocks 21.04.0-1 21.04.1-1
kbookmarks 5.81.0-1 5.82.0-1
kbounce 21.04.0-1 21.04.1-1
kbreakout 21.04.0-1 21.04.1-1
kbruch 21.04.0-1 21.04.1-1
kcachegrind 21.04.0-1 21.04.1-1
kcachegrind-common 21.04.0-1 21.04.1-1
kcalc 21.04.0-1 21.04.1-1
kcalendarcore 5.81.0-1 5.82.0-1
kcalutils 21.04.0-1 21.04.1-1
kcharselect 21.04.0-1 21.04.1-1
kcmutils 5.81.0-1 5.82.0-1
kcodecs 5.81.0-1 5.82.0-1
kcolorchooser 21.04.0-1 21.04.1-1
kcompletion 5.81.0-1 5.82.0-1
kconfig 5.81.0-1 5.82.0-1
kconfigwidgets 5.81.0-1 5.82.0-1
kcontacts 1:5.81.0-1 1:5.82.0-1
kcoreaddons 5.81.0-1 5.82.0-1
kcrash 5.81.0-1 5.82.0-1
kcron 21.04.0-1 21.04.1-1
kdav 1:5.81.0-1 1:5.82.0-1
kdbusaddons 5.81.0-1 5.82.0-1
kde-dev-scripts 21.04.0-1 21.04.1-1
kde-dev-utils 21.04.0-1 21.04.1-1
kdebugsettings 21.04.0-1 21.04.1-1
kdeclarative 5.81.0-1 5.82.0-1
kdeconnect 21.04.0-1 21.04.1-1
kded 5.81.0-1 5.82.0-1
kdeedu-data 21.04.0-1 21.04.1-1
kdegraphics-mobipocket 21.04.0-1 21.04.1-1
kdegraphics-thumbnailers 21.04.0-1 21.04.1-1
kdelibs4support 5.81.0-1 5.82.0-1
kdenetwork-filesharing 21.04.0-1 21.04.1-1
kdenlive 21.04.0-3 21.04.1-1
kdepim-addons 21.04.0-1 21.04.1-1
kdepim-runtime 21.04.0-1 21.04.1-1
kdesdk-kioslaves 21.04.0-1 21.04.1-1
kdesdk-thumbnailers 21.04.0-1 21.04.1-1
kdesignerplugin 5.81.0-1 5.82.0-1
kdesu 5.81.0-1 5.82.0-1
kdewebkit 5.81.0-1 5.82.0-1
kdf 21.04.0-1 21.04.1-1
kdialog 21.04.0-1 21.04.1-1
kdiamond 21.04.0-1 21.04.1-1
kdnssd 5.81.0-1 5.82.0-1
kdoctools 5.81.0-1 5.82.0-1
keditbookmarks 21.04.0-1 21.04.1-1
kemoticons 5.81.0-1 5.82.0-1
kfilemetadata 5.81.0-1 5.82.0-1
kfind 21.04.0-1 21.04.1-1
kfloppy 21.04.0-1 21.04.1-1
kfourinline 21.04.0-1 21.04.1-1
kgeography 21.04.0-1 21.04.1-1
kget 21.04.0-1 21.04.1-1
kglobalaccel 5.81.0-1 5.82.0-1
kgoldrunner 21.04.0-1 21.04.1-1
kgpg 21.04.0-1 21.04.1-1
kguiaddons 5.81.0-1 5.82.0-1
khangman 21.04.0-1 21.04.1-1
khelpcenter 21.04.0-1 21.04.1-1
kholidays 1:5.81.0-1 1:5.82.0-1
khtml 5.81.0-1 5.82.0-1
ki18n 5.81.0-1 5.82.0-1
kiconthemes 5.81.0-1 5.82.0-1
kidentitymanagement 21.04.0-1 21.04.1-1
kidletime 5.81.0-1 5.82.0-1
kig 21.04.0-1 21.04.1-1
kigo 21.04.0-1 21.04.1-1
killbots 21.04.0-1 21.04.1-1
kimageformats 5.81.0-2 5.82.0-1
kimagemapeditor 21.04.0-1 21.04.1-1
kimap 21.04.0-1 21.04.1-1
kinit 5.81.0-1 5.82.0-1
kio 5.81.0-1 5.82.0-1
kio-extras 21.04.0-2 21.04.1-1
kio-gdrive 21.04.0-1 21.04.1-1
kipi-plugins 21.04.0-1 21.04.1-1
kirigami-gallery 21.04.0-1 21.04.1-1
kirigami2 5.81.0-1 5.82.0-1
kiriki 21.04.0-1 21.04.1-1
kismet 2020_12_R3-3 2020_12_R3-4
kitemmodels 5.81.0-1 5.82.0-1
kitemviews 5.81.0-1 5.82.0-1
kiten 21.04.0-1 21.04.1-1
kitinerary 21.04.0-2 21.04.1-1
kjobwidgets 5.81.0-1 5.82.0-1
kjs 5.81.0-1 5.82.0-1
kjsembed 5.81.0-1 5.82.0-1
kjumpingcube 21.04.0-1 21.04.1-1
kldap 21.04.0-1 21.04.1-1
kleopatra 21.04.0-1 21.04.1-1
klettres 21.04.0-1 21.04.1-1
klickety 21.04.0-1 21.04.1-1
klines 21.04.0-1 21.04.1-1
kmag 21.04.0-1 21.04.1-1
kmahjongg 21.04.0-1 21.04.1-1
kmail 21.04.0-1 21.04.1-1
kmail-account-wizard 21.04.0-1 21.04.1-1
kmailtransport 21.04.0-1 21.04.1-1
kmbox 21.04.0-1 21.04.1-1
kmediaplayer 5.81.0-1 5.82.0-1
kmime 21.04.0-1 21.04.1-1
kmines 21.04.0-1 21.04.1-1
kmix 21.04.0-1 21.04.1-1
kmousetool 21.04.0-1 21.04.1-1
kmouth 21.04.0-1 21.04.1-1
kmplot 21.04.0-1 21.04.1-1
knavalbattle 21.04.0-1 21.04.1-1
knetwalk 21.04.0-1 21.04.1-1
knewstuff 5.81.0-1 5.82.0-1
knights 21.04.0-1 21.04.1-1
knotes 21.04.0-1 21.04.1-1
knotifications 5.81.0-1 5.82.0-1
knotifyconfig 5.81.0-1 5.82.0-1
kolf 21.04.0-1 21.04.1-1
kollision 21.04.0-1 21.04.1-1
kolourpaint 21.04.0-1 21.04.1-1
kompare 21.04.0-1 21.04.1-1
konqueror 21.04.0-1 21.04.1-1
konquest 21.04.0-1 21.04.1-1
konsole 21.04.0-2 21.04.1-1
kontact 21.04.0-1 21.04.1-1
kontactinterface 21.04.0-1 21.04.1-1
kontrast 21.04.0-1 21.04.1-1
konversation 21.04.0-1 21.04.1-1
kopeninghours 21.04.0-1 21.04.1-1
kopete 21.04.0-1 21.04.1-1
korganizer 21.04.0-1 21.04.1-1
kosmindoormap 21.04.0-1 21.04.1-1
kpackage 5.81.0-1 5.82.0-1
kparts 5.81.0-1 5.82.0-1
kpat 21.04.0-1 21.04.1-1
kpeople 5.81.0-1 5.82.0-1
kpimtextedit 21.04.0-1 21.04.1-1
kpkpass 21.04.0-1 21.04.1-1
kplotting 5.81.0-1 5.82.0-1
kpmcore 21.04.0-1 21.04.1-1
kpty 5.81.0-1 5.82.0-1
kpublictransport 21.04.0-1 21.04.1-1
kqtquickcharts 21.04.0-1 21.04.1-1
kquickcharts 5.81.0-1 5.82.0-1
krdc 21.04.0-1 21.04.1-1
kreversi 21.04.0-1 21.04.1-1
krfb 21.04.0-1 21.04.1-1
kross 5.81.0-1 5.82.0-1
kross-interpreters 21.04.0-1 21.04.1-1
kruler 21.04.0-1 21.04.1-1
krunner 5.81.0-1 5.82.0-1
kservice 5.81.0-1 5.82.0-1
kshisen 21.04.0-1 21.04.1-1
ksirk 21.04.0-1 21.04.1-1
ksmtp 21.04.0-1 21.04.1-1
ksnakeduel 21.04.0-1 21.04.1-1
kspaceduel 21.04.0-1 21.04.1-1
ksquares 21.04.0-1 21.04.1-1
ksudoku 21.04.0-1 21.04.1-1
ksystemlog 21.04.0-1 21.04.1-1
kteatime 21.04.0-1 21.04.1-1
ktexteditor 5.81.0-1 5.82.0-1
ktextwidgets 5.81.0-1 5.82.0-1
ktimer 21.04.0-1 21.04.1-1
ktnef 21.04.0-1 21.04.1-1
ktorrent 21.04.0-1 21.04.1-1
ktouch 21.04.0-1 21.04.1-1
ktuberling 21.04.0-1 21.04.1-1
kturtle 21.04.0-1 21.04.1-1
kubrick 21.04.0-1 21.04.1-1
kunitconversion 5.81.0-1 5.82.0-1
kwallet 5.81.0-1 5.82.0-1
kwalletmanager 21.04.0-1 21.04.1-1
kwave 21.04.0-1 21.04.1-1
kwayland 5.81.0-1 5.82.0-1
kwidgetsaddons 5.81.0-1 5.82.0-1
kwindowsystem 5.81.0-1 5.82.0-1
kwordquiz 21.04.0-1 21.04.1-1
kwrite 21.04.0-1 21.04.1-1
kxmlgui 5.81.0-1 5.82.0-1
kxmlrpcclient 5.81.0-1 5.82.0-1
lablgtk2 2.18.11-3 2.18.11-6
libakonadi 21.04.0-1 21.04.1-1
libgravatar 21.04.0-1 21.04.1-1
libkcddb 21.04.0-1 21.04.1-1
libkcompactdisc 21.04.0-1 21.04.1-1
libkdcraw 21.04.0-1 21.04.1-1
libkdegames 21.04.0-1 21.04.1-1
libkdepim 21.04.0-1 21.04.1-1
libkeduvocdocument 21.04.0-1 21.04.1-1
libkexiv2 21.04.0-1 21.04.1-1
libkgapi 21.04.0-1 21.04.1-1
libkipi 21.04.0-1 21.04.1-1
libkleo 21.04.0-1 21.04.1-1
libkmahjongg 21.04.0-1 21.04.1-1
libkomparediff2 21.04.0-1 21.04.1-1
libksane 21.04.0-1 21.04.1-1
libksieve 21.04.0-1 21.04.1-1
libktorrent 21.04.0-1 21.04.1-1
libmwaw 0.3.18-1 0.3.19-1
libphonenumber 8.12.21-1 8.12.22-1
libplacebo 3.120.2-1 3.120.3-1
libpqxx 6.4.5-2 7.5.2-1
libreoffice-still 7.0.5-4 7.0.6-1
libreoffice-still-af 7.0.5-1 7.0.6-1
libreoffice-still-am 7.0.5-1 7.0.6-1
libreoffice-still-ar 7.0.5-1 7.0.6-1
libreoffice-still-as 7.0.5-1 7.0.6-1
libreoffice-still-ast 7.0.5-1 7.0.6-1
libreoffice-still-be 7.0.5-1 7.0.6-1
libreoffice-still-bg 7.0.5-1 7.0.6-1
libreoffice-still-bn 7.0.5-1 7.0.6-1
libreoffice-still-bn-in 7.0.5-1 7.0.6-1
libreoffice-still-bo 7.0.5-1 7.0.6-1
libreoffice-still-br 7.0.5-1 7.0.6-1
libreoffice-still-brx 7.0.5-1 7.0.6-1
libreoffice-still-bs 7.0.5-1 7.0.6-1
libreoffice-still-ca 7.0.5-1 7.0.6-1
libreoffice-still-ca-valencia 7.0.5-1 7.0.6-1
libreoffice-still-ckb 7.0.5-1 7.0.6-1
libreoffice-still-cs 7.0.5-1 7.0.6-1
libreoffice-still-cy 7.0.5-1 7.0.6-1
libreoffice-still-da 7.0.5-1 7.0.6-1
libreoffice-still-de 7.0.5-1 7.0.6-1
libreoffice-still-dgo 7.0.5-1 7.0.6-1
libreoffice-still-dsb 7.0.5-1 7.0.6-1
libreoffice-still-dz 7.0.5-1 7.0.6-1
libreoffice-still-el 7.0.5-1 7.0.6-1
libreoffice-still-en-gb 7.0.5-1 7.0.6-1
libreoffice-still-en-za 7.0.5-1 7.0.6-1
libreoffice-still-eo 7.0.5-1 7.0.6-1
libreoffice-still-es 7.0.5-1 7.0.6-1
libreoffice-still-et 7.0.5-1 7.0.6-1
libreoffice-still-eu 7.0.5-1 7.0.6-1
libreoffice-still-fa 7.0.5-1 7.0.6-1
libreoffice-still-fi 7.0.5-1 7.0.6-1
libreoffice-still-fr 7.0.5-1 7.0.6-1
libreoffice-still-fur 7.0.5-1 7.0.6-1
libreoffice-still-fy 7.0.5-1 7.0.6-1
libreoffice-still-ga 7.0.5-1 7.0.6-1
libreoffice-still-gd 7.0.5-1 7.0.6-1
libreoffice-still-gl 7.0.5-1 7.0.6-1
libreoffice-still-gu 7.0.5-1 7.0.6-1
libreoffice-still-gug 7.0.5-1 7.0.6-1
libreoffice-still-he 7.0.5-1 7.0.6-1
libreoffice-still-hi 7.0.5-1 7.0.6-1
libreoffice-still-hr 7.0.5-1 7.0.6-1
libreoffice-still-hsb 7.0.5-1 7.0.6-1
libreoffice-still-hu 7.0.5-1 7.0.6-1
libreoffice-still-id 7.0.5-1 7.0.6-1
libreoffice-still-is 7.0.5-1 7.0.6-1
libreoffice-still-it 7.0.5-1 7.0.6-1
libreoffice-still-ja 7.0.5-1 7.0.6-1
libreoffice-still-ka 7.0.5-1 7.0.6-1
libreoffice-still-kab 7.0.5-1 7.0.6-1
libreoffice-still-kk 7.0.5-1 7.0.6-1
libreoffice-still-km 7.0.5-1 7.0.6-1
libreoffice-still-kmr-latn 7.0.5-1 7.0.6-1
libreoffice-still-kn 7.0.5-1 7.0.6-1
libreoffice-still-ko 7.0.5-1 7.0.6-1
libreoffice-still-kok 7.0.5-1 7.0.6-1
libreoffice-still-ks 7.0.5-1 7.0.6-1
libreoffice-still-lb 7.0.5-1 7.0.6-1
libreoffice-still-lo 7.0.5-1 7.0.6-1
libreoffice-still-lt 7.0.5-1 7.0.6-1
libreoffice-still-lv 7.0.5-1 7.0.6-1
libreoffice-still-mai 7.0.5-1 7.0.6-1
libreoffice-still-mk 7.0.5-1 7.0.6-1
libreoffice-still-ml 7.0.5-1 7.0.6-1
libreoffice-still-mn 7.0.5-1 7.0.6-1
libreoffice-still-mni 7.0.5-1 7.0.6-1
libreoffice-still-mr 7.0.5-1 7.0.6-1
libreoffice-still-my 7.0.5-1 7.0.6-1
libreoffice-still-nb 7.0.5-1 7.0.6-1
libreoffice-still-ne 7.0.5-1 7.0.6-1
libreoffice-still-nl 7.0.5-1 7.0.6-1
libreoffice-still-nn 7.0.5-1 7.0.6-1
libreoffice-still-nr 7.0.5-1 7.0.6-1
libreoffice-still-nso 7.0.5-1 7.0.6-1
libreoffice-still-oc 7.0.5-1 7.0.6-1
libreoffice-still-om 7.0.5-1 7.0.6-1
libreoffice-still-or 7.0.5-1 7.0.6-1
libreoffice-still-pa-in 7.0.5-1 7.0.6-1
libreoffice-still-pl 7.0.5-1 7.0.6-1
libreoffice-still-pt 7.0.5-1 7.0.6-1
libreoffice-still-pt-br 7.0.5-1 7.0.6-1
libreoffice-still-ro 7.0.5-1 7.0.6-1
libreoffice-still-ru 7.0.5-1 7.0.6-1
libreoffice-still-rw 7.0.5-1 7.0.6-1
libreoffice-still-sa-in 7.0.5-1 7.0.6-1
libreoffice-still-sat 7.0.5-1 7.0.6-1
libreoffice-still-sd 7.0.5-1 7.0.6-1
libreoffice-still-sdk 7.0.5-4 7.0.6-1
libreoffice-still-si 7.0.5-1 7.0.6-1
libreoffice-still-sid 7.0.5-1 7.0.6-1
libreoffice-still-sk 7.0.5-1 7.0.6-1
libreoffice-still-sl 7.0.5-1 7.0.6-1
libreoffice-still-sq 7.0.5-1 7.0.6-1
libreoffice-still-sr 7.0.5-1 7.0.6-1
libreoffice-still-sr-latn 7.0.5-1 7.0.6-1
libreoffice-still-ss 7.0.5-1 7.0.6-1
libreoffice-still-st 7.0.5-1 7.0.6-1
libreoffice-still-sv 7.0.5-1 7.0.6-1
libreoffice-still-sw-tz 7.0.5-1 7.0.6-1
libreoffice-still-szl 7.0.5-1 7.0.6-1
libreoffice-still-ta 7.0.5-1 7.0.6-1
libreoffice-still-te 7.0.5-1 7.0.6-1
libreoffice-still-tg 7.0.5-1 7.0.6-1
libreoffice-still-th 7.0.5-1 7.0.6-1
libreoffice-still-tn 7.0.5-1 7.0.6-1
libreoffice-still-tr 7.0.5-1 7.0.6-1
libreoffice-still-ts 7.0.5-1 7.0.6-1
libreoffice-still-tt 7.0.5-1 7.0.6-1
libreoffice-still-ug 7.0.5-1 7.0.6-1
libreoffice-still-uk 7.0.5-1 7.0.6-1
libreoffice-still-uz 7.0.5-1 7.0.6-1
libreoffice-still-ve 7.0.5-1 7.0.6-1
libreoffice-still-vec 7.0.5-1 7.0.6-1
libreoffice-still-vi 7.0.5-1 7.0.6-1
libreoffice-still-xh 7.0.5-1 7.0.6-1
libreoffice-still-zh-cn 7.0.5-1 7.0.6-1
libreoffice-still-zh-tw 7.0.5-1 7.0.6-1
libreoffice-still-zu 7.0.5-1 7.0.6-1
libupnp 1.14.6-1 1.14.7-1
libva-mesa-driver 21.0.3-3 21.1.0-1
libwnck3 3.36.0-1 40.0-1
lokalize 21.04.0-1 21.04.1-1
lskat 21.04.0-1 21.04.1-1
mailcommon 21.04.0-1 21.04.1-1
mailimporter 21.04.0-1 21.04.1-1
marble 21.04.0-1 21.04.1-1
marble-common 21.04.0-1 21.04.1-1
marble-qt 21.04.0-1 21.04.1-1
mariadb 10.5.9-1 10.5.10-1
mariadb-clients 10.5.9-1 10.5.10-1
mariadb-libs 10.5.9-1 10.5.10-1
markdownpart 21.04.0-1 21.04.1-1
mbox-importer 21.04.0-1 21.04.1-1
md4c 0.4.7-1 0.4.8-1
mercurial 5.8-1 5.8-2
mesa 21.0.3-3 21.1.0-1
mesa-vdpau 21.0.3-3 21.1.0-1
meson 0.58.0-1 0.58.0-2
messagelib 21.04.0-2 21.04.1-1
minuet 21.04.0-1 21.04.1-1
modemmanager-qt 5.81.0-1 5.82.0-1
mousepad 0.5.4-1 0.5.5-2
mpg123 1.26.5-1 1.27.2-1
mutter 40.0+69+geaf75f070-1 40.1-1
mythes-it 2.0.9l-6 -
mythes-ro 3.3-7 -
mytop 10.5.9-1 10.5.10-1
networkmanager-qt 5.81.0-1 5.82.0-1
okular 21.04.0-1 21.04.1-1
opencl-clhpp 2.0.13-1 2.0.14-1
opencl-headers 2:2020.12.18-1 2:2021.04.29-1
opencl-mesa 21.0.3-3 21.1.0-1
oxygen-icons 1:5.81.0-1 1:5.82.0-1
oxygen-icons-svg 1:5.81.0-1 1:5.82.0-1
palapeli 21.04.0-1 21.04.1-1
parley 21.04.0-1 21.04.1-1
partitionmanager 21.04.0-1 21.04.1-1
perl-crypt-openssl-guess 0.12-1 0.13-1
perl-mime-types 2.19-1 2.20-1
picmi 21.04.0-1 21.04.1-1
pim-data-exporter 21.04.0-1 21.04.1-1
pim-sieve-editor 21.04.0-1 21.04.1-1
pimcommon 21.04.0-1 21.04.1-1
plasma-framework 5.81.0-1 5.82.0-1
poxml 21.04.0-1 21.04.1-1
print-manager 21.04.0-1 21.04.1-1
prison 5.81.0-1 5.82.0-1
prometheus-blackbox-exporter 0.18.0-3 0.19.0-1
protobuf 3.15.8-1 3.16.0-1
protobuf-c 1.3.3-3 1.3.3-4
purpose 5.81.0-1 5.82.0-1
putty 0.74-1 0.75-1
pyqt-builder 1.9.1-1 1.10.0-1
python 3.9.4-1.1 3.9.5-2
python-astroid 2.5.5-1 2.5.6-1
python-django 3.2.2-1 3.2.3-1
python-markupsafe 1.1.1-7 2.0.0-1
python-pep517 0.10.0-1 0.10.0-2
python-protobuf 3.15.8-1 3.16.0-1
python-pybullet 3.08-2 3.17-1
python-setuptools 1:56.0.0-1 1:56.1.0-1
python-six 1.15.0-3 1.16.0-1
python-tests 3.9.4-1.1 3.9.5-2
python-virtualenv 20.4.4-1 20.4.6-1
python2-pep517 0.10.0-1 0.10.0-2
python2-six 1.15.0-3 1.16.0-1
python2-virtualenv 20.4.4-1 20.4.6-1
qbs 1.18.2-1 1.19.0-1
qcachegrind 21.04.0-1 21.04.1-1
qpdf 10.3.1-1 10.3.2-1
qqc2-desktop-style 5.81.0-1 5.82.0-1
qt5-wayland 5.15.2+kde+r19-1 5.15.2+kde+r22-1
rocs 21.04.0-1 21.04.1-1
rp-pppoe 3.14-3 3.15-2
rust 1:1.52.0-1 1:1.52.1-1
rust-docs 1:1.52.0-1 1:1.52.1-1
shaderc 2020.5-1 2021.0-1
signon-kwallet-extension 21.04.0-1 21.04.1-1
sip 6.0.3-1 6.1.0-1
solid 5.81.0-1 5.82.0-1
sonnet 5.81.0-1 5.82.0-1
spectacle 21.04.0-1 21.04.1-1
spirv-tools 2020.7-1 2021.1-1
step 21.04.0-1 21.04.1-1
svgpart 21.04.0-1 21.04.1-1
sweeper 21.04.0-1 21.04.1-1
syndication 5.81.0-1 5.82.0-1
syntax-highlighting 5.81.0-1 5.82.0-1
syslog-ng 3.31.2-1 3.32.1-1
telepathy-kde-accounts-kcm 21.04.0-1 21.04.1-1
telepathy-kde-approver 21.04.0-1 21.04.1-1
telepathy-kde-auth-handler 21.04.0-1 21.04.1-1
telepathy-kde-call-ui 21.04.0-1 21.04.1-1
telepathy-kde-common-internals 21.04.0-1 21.04.1-1
telepathy-kde-contact-list 21.04.0-1 21.04.1-1
telepathy-kde-contact-runner 21.04.0-1 21.04.1-1
telepathy-kde-desktop-applets 21.04.0-1 21.04.1-1
telepathy-kde-filetransfer-handler 21.04.0-1 21.04.1-1
telepathy-kde-integration-module 21.04.0-1 21.04.1-1
telepathy-kde-send-file 21.04.0-1 21.04.1-1
telepathy-kde-text-ui 21.04.0-1 21.04.1-1
texmacs 1.99.19-1 1.99.20-1
threadweaver 5.81.0-1 5.82.0-1
uim 1.8.8-5 -
umbrello 21.04.0-1 21.04.1-1
usbguard 1.0.0-2 1.0.0-3
vim-runtime 8.2.2815-1 8.2.2845-1
vim-spell-af 20190731-2 -
vim-spell-am 20190731-2 -
vim-spell-bg 20190731-2 -
vim-spell-br 20190731-2 -
vim-spell-ca 20190731-2 -
vim-spell-cs 20190731-2 -
vim-spell-cy 20190731-2 -
vim-spell-da 20190731-2 -
vim-spell-de 20190731-2 -
vim-spell-el 20190731-2 -
vim-spell-en 20190731-2 -
vim-spell-eo 20190731-2 -
vim-spell-es 20190731-2 -
vim-spell-fo 20190731-2 -
vim-spell-fr 20190731-2 -
vim-spell-ga 20190731-2 -
vim-spell-gd 20190731-2 -
vim-spell-gl 20190731-2 -
vim-spell-he 20190731-2 -
vim-spell-hr 20190731-2 -
vim-spell-hu 20190731-2 -
vim-spell-id 20190731-2 -
vim-spell-it 20190731-2 -
vim-spell-ku 20190731-2 -
vim-spell-la 20190731-2 -
vim-spell-lt 20190731-2 -
vim-spell-lv 20190731-2 -
vim-spell-mg 20190731-2 -
vim-spell-mi 20190731-2 -
vim-spell-ms 20190731-2 -
vim-spell-nb 20190731-2 -
vim-spell-nl 20190731-2 -
vim-spell-nn 20190731-2 -
vim-spell-ny 20190731-2 -
vim-spell-pl 20190731-2 -
vim-spell-pt 20190731-2 -
vim-spell-ro 20190731-2 -
vim-spell-ru 20190731-2 -
vim-spell-rw 20190731-2 -
vim-spell-sk 20190731-2 -
vim-spell-sl 20190731-2 -
vim-spell-sr 20190731-2 -
vim-spell-sv 20190731-2 -
vim-spell-sw 20190731-2 -
vim-spell-tet 20190731-2 -
vim-spell-th 20190731-2 -
vim-spell-tl 20190731-2 -
vim-spell-tn 20190731-2 -
vim-spell-uk 20190731-2 -
vim-spell-yi 20190731-2 -
vim-spell-zu 20190731-2 -
virglrenderer 0.8.2-1 0.9.1-1
vlc 3.0.13-1 3.0.14-1
vulkan-broadcom 21.0.3-3 21.1.0-1
vulkan-headers 1:1.2.177-1 1:1.2.178-1
vulkan-mesa-layers 21.0.3-3 21.1.0-1
vulkan-radeon 21.0.3-3 21.1.0-1
vulkan-swrast 21.0.3-3 21.1.0-1
w3m 0.5.3.git20200507-20.5.3.git20210102_6-1
webkit2gtk 2.32.0-2 2.32.1-1
wpebackend-fdo 1.8.3-1 1.9.92-1
wpewebkit 2.32.0-2 2.32.1-1
xalan-java 2.7.2-3 -
xdg-desktop-portal 1.8.0-1 1.8.1-1
xerces2-java 2.12.1-1 -
yakuake 21.04.0-1 21.04.1-1
zeroconf-ioslave 21.04.0-1 21.04.1-1
kio-fuse - 5.0.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.04.0.r12495.g1857ebaf0-121.04.0.r12499.gb1eeb34f1-1
akonadi-calendar21.04.0.r1933.g7402b73-121.04.0.r1937.g7149985-1
akonadi-calendar-tools21.04.0.r861.gbb343d6-121.04.0.r865.g7e11fb9-1
akonadi-contacts21.04.0.r3002.gff3759f1-121.04.0.r3006.gbee0faca-1
akonadi-import-wizard21.04.0.r1701.gb327524-121.04.0.r1705.g3c9dbc8-1
akonadi-mime21.04.0.r1613.ga4122be-121.04.0.r1616.g46f211e-1
akonadi-notes21.04.0.r998.g09463de-121.04.0.r1001.g3828b7a-1
akonadi-search21.04.0.r1085.g6f7bd8e-121.04.0.r1088.g1df6390-1
akonadiconsole21.04.0.r1483.g10803d2-121.04.0.r1486.gb53bd1c-1
akregator21.04.0.r6119.gf88c7eec-121.04.0.r6123.g0e844d97-1
amazfish 1.9.9.r1.gc8b22c5-1 2.0.0.r2.g225bef2-1
ark21.04.0.r4521.gef64cfdb-121.04.0.r4522.gad8f47da-1
attica5.81.0.r806.g5d9b03d-15.82.0.r806.g5d9b03d-1
baloo5.81.0.r2979.gb94aa021-15.82.0.r2979.gb94aa021-1
bluedevil1:5.21.4.r2257.g05ab0754-11:5.21.4.r2261.gcc950509-1
bluez-qt5.81.0.r656.g705dee7-15.82.0.r656.g705dee7-1
breeze5.21.4.r2176.g3c70ee66-15.21.4.r2180.g8f7e7168-1
breeze-gtk5.21.4.r418.g4091eb0-15.21.4.r420.gfccd7df-1
breeze-icons5.81.0.r1734.ga7868107-15.82.0.r1740.g038230e0-1
buho 1.2.1.r12.g16ebcf2-1 1.2.2.r0.g16ebcf2-1
calendarsupport21.04.0.r517.ge58a41d-121.04.0.r521.g298a8e3-1
calindori 1.4.r14.gd68a289-1 21.05.r1.gb7c997f-1
discover5.21.4.r8160.gaf981612-15.21.4.r8173.geef27e49-1
dolphin21.04.0.r6559.gf9e3d9c8a-121.04.0.r6574.g53a778c1e-1
drkonqi5.21.4.r633.g3c48c539-15.21.4.r639.g74962561-1
elisa21.04.0.r2688.g07f3abbe-121.04.0.r2689.g3b1f0b6c-1
eventviews21.04.0.r642.g63c9b40-121.04.0.r645.g0bf78b3-1
frameworkintegration5.81.0.r581.g1d78f16-15.82.0.r581.g1d78f16-1
grantlee-editor21.04.0.r740.ge79323b-121.04.0.r743.ga6b8da3-1
grantleetheme21.04.0.r316.g4404baa-121.04.0.r319.g6b3e595-1
gwenview21.04.0.r6580.g9dd9fc77-121.04.0.r6588.g2027581c-1
incidenceeditor21.04.0.r707.g2c53c91-121.04.0.r710.gb721620-1
index-fm 1.2.1.r58.g21402ee-1 1.2.2.r0.g21402ee-1
itinerary21.04.0.r1276.g68dac97-121.04.0.r1277.g337e190-1
juk21.04.0.r3103.g8da3155e-121.04.0.r3104.ge35afcaa-1
kactivities5.81.0.r1344.g170b79a-15.82.0.r1344.g170b79a-1
kactivities-stats5.81.0.r350.gf7dfecb-15.82.0.r350.gf7dfecb-1
kactivitymanagerd5.21.4.r1347.g7d9cdb6-15.21.4.r1348.g89ed4b8-1
kaddressbook21.04.0.r5955.g48b2ad51-121.04.0.r5959.gc94e61d6-1
kalarm21.04.0.r6369.gb86cc0ff-121.04.0.r6374.g71b15a11-1
kalarmcal21.04.0.r1105.g1812655-121.04.0.r1109.g5291b78-1
kalk 0.2.r68.g6a00a4e-1 21.05.r0.gb5247dd-1
kapidox5.81.0.r524.g2c36122-15.82.0.r524.g2c36122-1
karchive5.81.0.r476.gb2de441-15.82.0.r476.gb2de441-1
kate21.04.0.r18105.gb4366e99c-121.04.0.r18108.gf8109d304-1
kauth5.81.0.r431.g5ee37da-15.82.0.r431.g5ee37da-1
kbookmarks5.81.0.r404.g7f1fd62-15.82.0.r404.g7f1fd62-1
kcalendarcore5.81.0.r1198.g2c8ad6d7d-15.82.0.r1200.g79b407c25-1
kcalutils21.04.0.r829.g945d78eea-121.04.0.r832.g5b1c36893-1
kclock 0.4.0.r83.g7b5c19e-1 21.05.r0.gbe4073d-1
kcmutils5.81.0.r507.g6085d90-15.82.0.r507.g6085d90-1
kcodecs5.81.0.r363.g27f018d-15.82.0.r363.g27f018d-1
kcompletion5.81.0.r437.gd41c4ef-15.82.0.r437.gd41c4ef-1
kconfig5.81.0.r827.gf3e8853-15.82.0.r829.g40f2371-1
kconfigwidgets5.81.0.r569.g4e07ea6-15.82.0.r570.ga55be68-1
kcontacts1:5.81.0.r3233.gdb74df7e-11:5.82.0.r3233.gdb74df7e-1
kcoreaddons5.81.0.r1216.g7ac3b201-15.82.0.r1217.g532c0201-1
kcrash5.81.0.r379.g4ed3863-15.82.0.r379.g4ed3863-1
kdav1:5.81.0.r1281.gc7bd0ce-11:5.82.0.r1281.gc7bd0ce-1
kdbusaddons5.81.0.r357.g400365a-15.82.0.r358.g189e302-1
kde-cli-tools5.21.4.r1835.ga72c880-15.21.4.r1842.g6d7f8ac-1
kde-dev-scripts21.04.0.r4128.gc530806-121.04.0.r4129.g329a38f-1
kde-gtk-config5.21.4.r888.g82e01e1-15.21.4.r891.gcdcdb9d-1
kdebugsettings21.04.0.r797.gb869f9e-121.04.0.r801.g1e0e9e0-1
kdeclarative5.81.0.r889.gbf4869e-15.82.0.r889.gbf4869e-1
kdeconnect21.04.0.r3188.g153bc227-121.04.0.r3192.g036704e1-1
kdecoration5.21.4.r259.g5b318a3-15.21.4.r264.ga067a6e-1
kded5.81.0.r398.g292a1a0-15.82.0.r398.g292a1a0-1
kdelibs4support5.81.0.r1011.g48bf4e1f-15.82.0.r1013.g457a5877-1
kdenlive21.04.0.r14393.g6cb21c200-121.04.0.r14411.g3613496aa-1
kdepim-addons21.04.0.r4080.g57191d38-121.04.0.r4090.gd65e1491-1
kdepim-runtime20.12.3.r15079.g46ac490b6-121.04.0.r15090.g3a2a751cd-1
kdeplasma-addons5.21.4.r8511.g725017d08-15.21.4.r8515.g913616041-1
kdesignerplugin5.81.0.r321.g72df7a8-15.82.0.r321.g72df7a8-1
kdesu5.81.0.r460.gb7d5d82-15.82.0.r460.gb7d5d82-1
kdewebkit5.81.0.r267.ge131752-15.82.0.r268.gd2d8247-1
kdf21.04.0.r780.g58163e7-121.04.0.r781.gae6d5f4-1
kdnssd5.81.0.r304.g9a9c94f-15.82.0.r304.g9a9c94f-1
kdoctools5.81.0.r604.g74b961d-15.82.0.r604.g74b961d-1
kemoticons5.81.0.r369.gb05e814-15.82.0.r369.gb05e814-1
kfilemetadata5.81.0.r789.g0a3889e-15.82.0.r789.g0a3889e-1
kgamma55.21.4.r449.ge60884b-15.21.4.r454.g86956bc-1
kget21.04.0.r3095.gde22b7e2-121.04.0.r3096.g7be01882-1
kglobalaccel5.81.0.r440.gb6469a8-15.82.0.r440.gb6469a8-1
kguiaddons5.81.0.r361.g9d391d9-15.82.0.r361.g9d391d9-1
kholidays1:5.81.0.r930.gb409c9d-11:5.82.0.r930.gb409c9d-1
khotkeys5.21.4.r2064.g02caef4-15.21.4.r2068.gfc9bf56-1
khtml5.81.0.r541.g8534295-15.82.0.r543.g76d37f0-1
ki18n5.81.0.r459.g06bb2b1-15.82.0.r459.g06bb2b1-1
kiconthemes5.81.0.r520.gc0b726b-15.82.0.r520.gc0b726b-1
kidentitymanagement21.04.0.r3777.gf454549b-121.04.0.r3780.g6bec3091-1
kidletime5.81.0.r297.g2fd4d9c-15.82.0.r297.g2fd4d9c-1
kimageformats5.81.0.r333.g780f342-15.82.0.r335.g62f9af9-1
kimap21.04.0.r1083.g2758e23-121.04.0.r1086.g21ab06f-1
kinfocenter5.21.4.r1826.g0f08232-15.21.4.r1828.g85ed039-1
kinit5.81.0.r395.g0d64e3c-15.82.0.r395.g0d64e3c-1
kio5.81.0.r4712.ga0833670-15.82.0.r4720.g6c501459-1
kio-extras21.04.0.r7005.g7380d965-121.04.0.r7007.g42f00fc1-1
kirigami25.81.0.r2769.gfa503643-15.82.0.r2778.g11baf9ed-1
kitemmodels5.81.0.r533.ge52ae3b-15.82.0.r536.g11a3839-1
kitemviews5.81.0.r323.g4560636-15.82.0.r323.g4560636-1
kitinerary21.04.0.r1721.geeb9c4e-121.04.0.r1752.gda45806-1
kjobwidgets5.81.0.r359.g96421aa-15.82.0.r359.g96421aa-1
kjs5.81.0.r324.g2def7e8-15.82.0.r324.g2def7e8-1
kjsembed5.81.0.r289.gc92dcda-15.82.0.r291.g15051fa-1
kldap21.04.0.r850.g3d2613a-121.04.0.r853.g380d52e-1
kleopatra21.04.0.r5799.g419f8be9-121.04.0.r5822.g01f8c6af-1
kmail21.04.0.r25704.gc9d9d5ce0-121.04.0.r25721.g6a9873997-1
kmail-account-wizard21.04.0.r776.g75978a2-121.04.0.r779.g549a0ea-1
kmailtransport21.04.0.r1598.g94e68c4-121.04.0.r1601.g696c03f-1
kmbox21.04.0.r513.g962e7fe-121.04.0.r516.g2790933-1
kmediaplayer5.81.0.r281.gdd9983e-15.82.0.r282.gec1df64-1
kmenuedit5.21.4.r963.g9633caf-15.21.4.r966.g3031e2f-1
kmime21.04.0.r1426.ga9fc910-121.04.0.r1429.gfc6d12e-1
kmplot21.04.0.r1452.ga839461-121.04.0.r1457.g0f8a6f5-1
knewstuff5.81.0.r1089.g38d18b87-15.82.0.r1089.g38d18b87-1
knotes21.04.0.r3445.gf367f456-121.04.0.r3450.g1e4815bc-1
knotifications5.81.0.r650.ga0598cc-15.82.0.r650.ga0598cc-1
knotifyconfig5.81.0.r338.g6210b2d-15.82.0.r338.g6210b2d-1
kongress r198.g3568497-1 r199.g1d77510-1
konqueror21.04.0.r14893.ge9bc7c5d3-121.04.0.r14895.g7e9aed1cd-1
kontact21.04.0.r5307.gf64a9924-121.04.0.r5313.g14d1b543-1
kontactinterface21.04.0.r605.g363f919-121.04.0.r608.g98bfd2c-1
korganizer21.04.0.r11356.gadf6e83c9-121.04.0.r11364.g5624ecf3c-1
kosmindoormap21.04.0.r595.gd5d8bb2-121.04.0.r596.gc2acfdb-1
kpackage5.81.0.r657.g2d408fc-15.82.0.r657.g2d408fc-1
kparts5.81.0.r502.g8bfdd25-15.82.0.r502.g8bfdd25-1
kpeople5.81.0.r1315.g1edd4d0-15.82.0.r1315.g1edd4d0-1
kpimtextedit21.04.0.r1369.ga2859d6-121.04.0.r1377.ge2831e4-1
kpkpass21.04.0.r210.g3dc9d40-121.04.0.r213.g1a72fe1-1
kplotting5.81.0.r278.gf3e5ee8-15.82.0.r278.gf3e5ee8-1
kpty5.81.0.r321.gb17ae81-15.82.0.r321.gb17ae81-1
kpublictransport21.04.0.r1612.gfae064e-121.04.0.r1617.gf8ef74a-1
kquickcharts5.81.0.r451.g26c0c73-15.82.0.r452.gef279a2-1
krecorder r94.g3a86adc-1 r96.g53444ff-1
krfb21.04.0.r1381.g68866dc-121.04.0.r1382.g5e18689-1
kross5.81.0.r320.gf122890-15.82.0.r322.gdd27630-1
krunner5.81.0.r618.ga1740e5-15.82.0.r621.gef6c25d-1
kscreen5.21.4.r1323.g4b0f09f-15.21.4.r1329.g7382845-1
kscreenlocker5.21.4.r836.g7ef4e50-15.21.4.r847.g52a439b-1
kservice5.81.0.r907.gb347ca5-15.82.0.r907.gb347ca5-1
ksmtp21.04.0.r342.gf4aefa7-121.04.0.r345.gdefe997-1
ksshaskpass5.21.4.r191.g3310435-15.21.4.r195.g37bc83d-1
ksysguard5.21.4.r3501.gebf85f87-15.21.4.r3503.g5b75d854-1
ktexteditor5.81.0.r2826.g110c91d3-15.82.0.r2832.g4e4bd09a-1
ktextwidgets5.81.0.r394.g83faea5-15.82.0.r394.g83faea5-1
ktnef21.04.0.r640.gf780a03-121.04.0.r643.g4ee2612-1
ktorrent21.04.0.r2736.g3cec5197-121.04.0.r2737.gdc691bab-1
ktrip0.99.5.r16.ge9608a8-1 21.05.r3.g9c70d13-1
kunitconversion5.81.0.r358.g5893dbb-15.82.0.r358.g5893dbb-1
kwallet5.81.0.r1063.g192e0a4-15.82.0.r1063.g192e0a4-1
kwallet-pam5.21.4.r238.g6c85df1-15.21.4.r242.g96e0e42-1
kwayland5.81.0.r1081.gd0fecf1-15.82.0.r1084.g9ac92ee-1
kwayland-integration5.21.4.r168.gd1dc90b-15.21.4.r173.gcaec340-1
kwayland-server5.21.4.r1311.gd640d1c-15.21.4.r1322.g0525ea4-1
kwidgetsaddons5.81.0.r805.g5c768976-15.82.0.r809.gc2daa371-1
kwin5.21.4.r19319.gbaf3ddea7-15.21.4.r19386.gb9b58b6e6-1
kwindowsystem5.81.0.r588.gcac726b-15.82.0.r588.gcac726b-1
kwrite21.04.0.r18105.gb4366e99c-121.04.0.r18108.gf8109d304-1
kwrited5.21.4.r473.g6237496-15.21.4.r477.gf2b3dec-1
kxmlgui5.81.0.r751.g2554dfa7-15.82.0.r752.g9aef7a7f-1
kxmlrpcclient5.81.0.r441.g6846715ee-15.82.0.r443.g25fd65f8c-1
layer-shell-qt5.21.4.r36.g7d46bd6-15.21.4.r40.g525fa9b-1
libakonadi21.04.0.r12495.g1857ebaf0-121.04.0.r12499.gb1eeb34f1-1
libgravatar21.04.0.r344.g0c8d730-121.04.0.r347.gc18e7aa-1
libkdegames21.04.0.r2173.gc27165eb-121.04.0.r2174.gcd0dc330-1
libkdepim21.04.0.r824.g06e4977-121.04.0.r827.g1e772f6-1
libkgapi21.04.0.r1269.gcd89f8d-121.04.0.r1272.g99808eb-1
libkleo21.04.0.r856.g85c593a-121.04.0.r868.g703a387-1
libkscreen5.21.4.r1573.g3a7821b-15.21.4.r1577.g3de67e2-1
libksieve21.04.0.r1519.ge2b23db1-121.04.0.r1523.gf5830fa7-1
libksysguard5.21.4.r2217.g4b89479-15.21.4.r2223.g795def2-1
libquotient r1976.gf89ece6-1 r1977.g0c8a819-1
mailcommon21.04.0.r1029.g69725fe-121.04.0.r1032.gce01fc9-1
mailimporter21.04.0.r445.g6c98c05-121.04.0.r448.g0c88874-1
marble21.04.0.r13304.g8957fd690-121.04.0.r13305.g6424c2b1d-1
marble-common21.04.0.r13304.g8957fd690-121.04.0.r13305.g6424c2b1d-1
marble-qt21.04.0.r13304.g8957fd690-121.04.0.r13305.g6424c2b1d-1
maui-clip 1.1.0.r14.gd0690b8-1 1.1.1.r0.gd0690b8-1
maui-nota 1.2.1.r35.gab0dbc5-1 1.2.2.r1.gf42d352-1
maui-pix 1.2.1.r37.g327d024-1 1.2.2.r0.g327d024-1
mauikit1.2.1.r139.g6b0f399a-1 1.2.2.r5.gc9c922f0-1
mauikit-filebrowsing r34.267b862-1 r36.93a9bde-1
mbox-importer21.04.0.r489.g2d58ab2-121.04.0.r492.gc4bc6f0-1
messagelib21.04.0.r5922.g1d0ed197-121.04.0.r5933.g6488be32-1
milou5.21.4.r737.g9eefca5-15.21.4.r741.ge5b5a0a-1
modemmanager-qt5.81.0.r504.g3368386-15.82.0.r505.gd355355-1
neochat r1655.gf20501fe-1 r1660.g8f403012-1
networkmanager-qt5.81.0.r1099.g44468d1-15.82.0.r1100.g5b71e55-1
okular21.04.0.r9304.g34b8c1e72-121.04.0.r9322.g3ff6ff35b-1
oxygen5.21.4.r4411.g60706eb2-15.21.4.r4414.g85e6c9e8-1
oxygen-icons1:5.81.0.r5.gbff159d-11:5.82.0.r5.gbff159d-1
oxygen-icons-svg1:5.81.0.r5.gbff159d-11:5.82.0.r5.gbff159d-1
parley21.04.0.r4404.gdcf01c57-121.04.0.r4406.g2a5c816c-1
pim-data-exporter21.04.0.r2403.g5ed57b7b-121.04.0.r2406.gcd6ac2ac-1
pim-sieve-editor21.04.0.r1468.g1260cc4-121.04.0.r1472.g3906e0c-1
pimcommon21.04.0.r1046.ga44e051-121.04.0.r1049.gc29a711-1
plasma-browser-integration5.21.4.r1245.g5405143d-15.21.4.r1250.gffe37ebf-1
plasma-desktop5.21.4.r8417.g74e95a2a0-15.21.4.r8446.gf2f21e54a-1
plasma-dialer 0.3.r19.g3921ecb-1 21.05.r11.gacf9c6a-1
plasma-disks5.21.4.r200.gf51003f-15.21.4.r205.g22862d9-1
plasma-firewall5.21.4.r484.gb7623b3-15.21.4.r488.g45d86b7-1
plasma-framework5.81.0.r15849.ga9372fb6a-15.82.0.r15850.g9a8613612-1
plasma-integration5.21.4.r512.g68f7d1b-15.21.4.r516.gc123126-1
plasma-nm5.21.4.r3041.ged9ac713-15.21.4.r3044.g7e42256f-1
plasma-pa5.21.4.r937.g8b3b582-15.21.4.r940.g66e97be-1
plasma-phone-components5.21.4.r1389.g8852ad01-15.21.4.r1394.g866f52e3-1
plasma-phonebook r216.g4524c5b-1 r232.gb22a40f-1
plasma-sdk5.21.4.r2264.ge9ee7a4a-15.21.4.r2267.g2debfd05-1
plasma-settings r871.g09ceccd-1 r879.gd3293e4-1
plasma-systemmonitor5.21.4.r418.g38b2876-15.21.4.r426.g3ada685-1
plasma-thunderbolt5.21.4.r130.g50c56a4-15.21.4.r131.g4040d01-1
plasma-vault5.21.4.r330.g03c7ff3-15.21.4.r332.geb439e8-1
plasma-wayland-session5.21.4.r10245.gbc0e09345-15.21.4.r10265.g901cb4a7f-1
plasma-workspace5.21.4.r10245.gbc0e09345-15.21.4.r10265.g901cb4a7f-1
plasma-workspace-wallpapers5.21.4.r255.g7bf46a9-15.21.4.r257.gaed7cb3-1
polkit-kde-agent5.21.4.r489.g312fd58-15.21.4.r492.g1dd5955-1
powerdevil5.21.4.r2430.gd7c1181a-15.21.4.r2433.g3a86d909-1
print-manager21.04.0.r1020.gf7a3057-121.04.0.r1021.g7429802-1
prison5.81.0.r307.gd795030-15.82.0.r309.g9102227-1
purpose5.81.0.r848.g3a9554b-15.82.0.r852.g853010e-1
qmlkonsole r83.ga10b9fc-1 r87.g51d8906-1
qqc2-desktop-style5.81.0.r481.ga5477e9-15.82.0.r482.g54308c4-1
sddm-kcm5.21.4.r576.g28f3a33-15.21.4.r580.g6d236b6-1
solid5.81.0.r667.g51da9c9-15.82.0.r668.g3bdef38-1
sonnet5.81.0.r610.gc844d7a-15.82.0.r611.g61b4183-1
spacebar r370.g032ba29-1 r386.gf4f47a1-1
svgpart21.04.0.r158.gacf1ca4-121.04.0.r159.g3b49dfc-1
syndication5.81.0.r822.gae3f065-15.82.0.r823.g256a953-1
syntax-highlighting5.81.0.r1578.gf292e54f-15.82.0.r1580.g717399ea-1
systemsettings5.21.4.r2424.g1c7b26f0-15.21.4.r2429.g50a47f40-1
threadweaver5.81.0.r491.g4f1ef2a-15.82.0.r491.g4f1ef2a-1
umbrello21.04.0.r8241.ge01b8ac44-121.04.0.r8246.g7bc661137-1
vvave 1.2.1.r36.g4d66b10-1 1.2.2.r0.g4d66b10-1
xdg-desktop-portal-kde5.21.4.r353.g3cd683a-15.21.4.r361.gf7c1523-1
peruse - 1.80.r6.g25247a1-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
