Hello ARM community.
Sorry for the long wait, but this is a huge update!
Some highlights:
- Most of our kernels got updated
- CoreApps are now updated to version 4.2.0
- New version 5.81 of KDE Frameworks
- Gnome Shell hit version 40!
- Introducing Siglo, a PineTime companion app for Phosh/GTK
- Our own Manjaro ARM Tools got updated to 2.10.0
- Also Manjaro ARM Installer is at 1.4.0
- Lots of Mobile specific packages got updated
- Some python packages got updated
If anyone wants to test kodi on the rpi:
Change to the unstable or testing branch and install kodi packages:
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
Also by default it uses the vc4-kms-v3d which means fbturbo is not installed.
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip and firewalld requires manual intervention:
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Fri Apr 16 15:47:36 CEST 2021)
- arm-testing community aarch64: 760 new and 722 removed package(s)
- arm-testing core aarch64: 36 new and 37 removed package(s)
- arm-testing extra aarch64: 360 new and 355 removed package(s)
- arm-testing kde-unstable aarch64: 349 new and 348 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-04-04 2021-04-16
atinout 0.9.1-1 0.9.1-2
callaudiod 0.1.0-1 0.1.0+4+g84ed2eb-1
calls 0.3.1+66+gd67e690-1 0.3.1+113+g436be15-1
chatty0.3.0_beta+15+g6477649-1 0.3.0_beta2-1
code 1.54.3-1 1.55.2-2
coreaction 4.1.0-1 4.2.0-1
corearchiver 4.1.0-1 4.2.0-1
corefm 4.1.0-1 4.2.0-1
coregarage 4.1.0-1 4.2.0-1
corehunt 4.1.0-1 4.2.0-1
coreimage 4.1.0-1 4.2.0-1
coreinfo 4.1.0-1 4.2.0-1
corekeyboard 4.1.0-1 4.2.0-1
corepad 4.1.0-1 4.2.0-1
corepaint 4.1.0-1 4.2.0-1
corepdf 4.1.0-1 4.2.0-1
corepins 4.1.0-1 4.2.0-1
corerenamer 4.1.0-1 4.2.0-1
coreshot 4.1.0-1 4.2.0-1
corestats 4.1.0-1 4.2.0-1
corestuff 4.1.0-1 4.2.0-1
coreterminal 4.1.0-1 4.2.0-1
coretime 4.1.0-1 4.2.0-1
coretoppings 4.1.1-1 4.2.0-2
coreuniverse 4.1.0-1 4.2.0-1
eg25-manager 0.2.1+10+gea19b02-1 0.3.0-2
electron 12.0.2-1 12.0.4-1
element-desktop 1.7.24-1 1.7.25-1
element-web 1.7.24-1 1.7.25-1
gnome-contacts-mobile 3.38.1-1 3.38.1-2
gnome-software-mobile 3.34.0-3 3.38.2-1
gnome-todo-mobile 3.28.1+33+gc03a4c1-2 3.28.1+33+gc03a4c1-3
grimshot 1.5-1 1.6-1
kodi-rpi 19.0-9 19.0-10
kodi-rpi-dev 19.0-9 19.0-10
kodi-rpi-eventclients 19.0-9 19.0-10
kodi-rpi-tools-texturepacker 19.0-9 19.0-10
libarchive-qt 2.0.2-1 2.0.4-1
libcprime 4.1.0-1 4.2.0-1
libcsys 4.1.0-1 4.2.0-1
maliit-framework 0.99.2-3 -
maliit-keyboard r2059.g77fe50ac-1 -
manjaro-arm-installer 1.3.8-1 1.4.0-1
paperdesktop-git 169.ec03059-1 -
phoc 0.7.0+1+g19a9cfe-1 0.7.0+6+g8654bbe-1
phosh 0.10.0+26+g0faac2a-1 0.10.1+8+g33f1a92-1
pinephone-manjaro-tweaks 20210405-1 20210415-1
squeekboard 1.12.0+22+g3cdced0-1 1.12.0+65+gea3da22-1
vivaldi 3.7.2218.52-1 3.7.2218.55-1
yay 10.2.0-1 10.2.1-1
android-headers - 9.0.0-1
geoclue-mobile - 2.5.7-1
hybris-usb - 0.1-2
libhybris-git - 1500.9d2860a-1
lxc-android - 0.1-2
paperde - 0.1.0beta-1
postmarketos-tweaks-app - 0.5.0-1
postmarketos-tweaks-app-phosh - 0.5.0-1
python-gatt - 0.2.6-1
siglo - 0.5.0-1
:: Different sync package(s) in repository community aarch64
acorn 1:8.1.0-1 1:8.1.1-1
adobe-source-han-sans-cn-fonts 2.002-2 2.003-1
adobe-source-han-sans-hk-fonts 2.002-2 2.003-1
adobe-source-han-sans-jp-fonts 2.002-2 2.003-1
adobe-source-han-sans-kr-fonts 2.002-2 2.003-1
adobe-source-han-sans-otc-fonts 2.002-2 2.003-1
adobe-source-han-sans-tw-fonts 2.002-2 2.003-1
aerc 0.5.2-1 0.5.2-2
almanah 0.12.3-1 0.12.3-2
android-tools 31.0.0-1 31.0.0-2
ansible-base 2.10.7-1 2.10.8-1
ansible-lint 5.0.6-1 5.0.7-2
arc-gtk-theme 20210127-1 20210412-1
arc-solid-gtk-theme 20210127-1 20210412-1
arch-audit-gtk 0.2.0-1 0.3.0-1
archlinux-repro 20201114-1 20210408-1
arduino-cli 0.17.0-1 0.18.1-1
asciidoctor 2.0.12-1 2.0.12-2
avr-gcc 10.2.0-1 10.3.0-1
aws-c-common 0.5.1-1 0.5.3-1
aws-cli 1.19.33-1 1.19.49-1
awxkit 18.0.0-1 19.0.0-1
bcc 0.18.0-2 0.19.0-1
bcc-tools 0.18.0-2 0.19.0-1
bchoppr 1.10.4-1 1.10.6-1
bctoolbox 4.5.1-1 4.5.3-1
bitwarden_rs-web 2.19.0-1 2.19.0.b-1
blender 17:2.92.0-1 17:2.92.0-2
bmake 20200902-1 20210314-1
bookworm 1.1.2-2 1.1.2-3
bpftrace 0.11.4-2 0.12.0-1
bpython 0.20-4 0.21-1
bslizr 1.2.12-1 1.2.14-1
budgie-desktop 10.5.2-210.5.2+24+g7a5dcfda-1
budgie-extras 1.1.0-1 1.1.0-2
buildah 1.20.0-1 1.20.0-2
bzrtp 4.5.1-1 4.5.3-1
cairo-dock-plug-ins 3.4.1-16 3.4.1-17
calcurse 4.7.0-1 4.7.1-1
calibre 5.13.0-1 5.14.0-1
capnet-assist 2.2.5-2 2.2.5-3
cargo-crev 0.19.1-1 0.19.2-1
cargo-watch 7.6.1-1 7.7.0-2
carla 2.2.0-2 2.3.0-1
cataclysm-dda 0.E.3-1 0.E.3-2
cataclysm-dda-tiles 0.E.3-1 0.E.3-2
ccls 0.20201219-3 0.20210330-1
ceph 15.2.8-2 15.2.10-1
ceph-libs 15.2.8-2 15.2.10-1
ceph-mgr 15.2.8-2 15.2.10-1
certbot 1.13.0-1 1.14.0-1
certbot-apache 1.13.0-1 1.14.0-1
certbot-dns-cloudflare 1.13.0-1 1.14.0-1
certbot-dns-cloudxns 1.13.0-1 1.14.0-1
certbot-dns-digitalocean 1.13.0-1 1.14.0-1
certbot-dns-dnsimple 1.13.0-1 1.14.0-1
certbot-dns-dnsmadeeasy 1.13.0-1 1.14.0-1
certbot-dns-gehirn 1.13.0-1 1.14.0-1
certbot-dns-google 1.13.0-1 1.14.0-1
certbot-dns-linode 1.13.0-1 1.14.0-1
certbot-dns-luadns 1.13.0-1 1.14.0-1
certbot-dns-nsone 1.13.0-1 1.14.0-1
certbot-dns-ovh 1.13.0-1 1.14.0-1
certbot-dns-rfc2136 1.13.0-1 1.14.0-1
certbot-dns-route53 1.13.0-1 1.14.0-1
certbot-dns-sakuracloud 1.13.0-1 1.14.0-1
certbot-nginx 1.13.0-1 1.14.0-1
cherrytree 0.99.32-1 0.99.34-1
chezmoi 2.0.7-1 2.0.10-1
ciano 0.2.4-1 0.2.4-2
clash 1.4.2-1 1.5.0-1
clipmenu 6.2.0-1 6.2.0-2
clojure 1.10.3.814-1 1.10.3.822-1
cmus 2.8.0-5 2.9.1-1
cockpit 241-1 242-1
cockpit-machines 241-1 243-1
cockpit-pcp 241-1 242-1
cockpit-podman 29-1 30-1
copyq 3.13.0-1 4.0.0-1
cython 0.29.22-1 0.29.23-1.1
cython2 0.29.22-1 0.29.23-1.1
dark-reader 4.9.30-1 4.9.31-2
dart 2.12.2-1 2.12.4-1
dcd 1:0.13.1-1 1:0.13.2-1
diffstat 1.63-1 1.64-1
dillo 3.0.5-8 3.0.5-10
docker 1:20.10.5-1 1:20.10.6-1
docker-compose 1.28.6-1 1.29.1-1
doctl 1.58.0-1 1.59.0-1
dpkg 1.20.5-2 1.20.7.1-1
dwdiff 2.1.3-2 2.1.4-1
ecasound 2.9.3-3 2.9.3-4
eclib 20210318-2 20210415-1
efm-langserver 0.0.26-2 0.0.29-1
emacs-nox 27.1-2 27.2-1
eolie 0.9.101-1 0.9.101-2
epic4 2.10.9-1 2.10.10-1
erlang 23.2.5-1 23.3.1-1
erlang-docs 23.0-1 23.3-1
erlang-nox 23.2.5-1 23.3.1-1
erlang-unixodbc 23.2.5-1 23.3.1-1
eslint 7.23.0-1 7.24.0-1
espeak-ng 1.50-2 1.50-4
espeak-ng-espeak 1.50-2 1.50-4
etckeeper 1.18.16-1 1.18.16-2
eteroj.lv2 0.8.0-1 0.10.0-1
evolution-rss 0.3.96-3 0.3.96-4
facter 3.14.16-1 3.14.16-2.1
fcitx-anthy 0.2.3-2 0.2.4-1
fcitx5-anthy 5.0.4-1 5.0.5-1
feeluown 3.7.5-1 3.7.6-1
fig2dev 3.2.8-1 3.2.8.a-1
filebin 3.6.0-1 3.6.1-1
firefox-clearurls 1.21.0-2 1.21.0-3
firefox-dark-reader 4.9.30-1 4.9.31-2
firefox-stylus 1.5.17-1 1.5.17-2
firefox-temporary-containers 1.9.2-2 1.9.2-3
firefox-tree-style-tab 3.7.4-1 3.7.4-2
firefox-tridactyl 1.21.1-1 1.21.1-2
firefox-ublock-origin 1.34.0-1 1.34.0-2
firewalld 0.9.3-1 0.9.3-2
fscrypt 0.2.9-1 0.3.0-1
fstrm 0.6.0-2 0.6.1-1
fwupd 1.5.8-1 1.5.9-1
fzf 0.26.0-1 0.27.0-1
gajim 1.2.2-2 1.3.1-1
gala3.3.2.r114.381e1d64-13.3.2.r134.c74298b4-1
gdal 3.0.4-20 3.0.4-21
gftp 2.0.19-10 2.7.0b-1
gif2png 3.0.0-1 3.0.0-2
gimp-plugin-gmic 2.9.6-1 2.9.7-1
gitea 1.13.6-1 1.13.7-1
glabels 3.4.1-7 3.4.1-8
glfw-doc 3.3.3-1 3.3.4-1
glfw-wayland 3.3.3-1 3.3.4-1
glfw-x11 3.3.3-1 3.3.4-1
glusterfs 1:9.0-1 1:9.1-1
gnome-applets 3.38.0-1 3.40.0-1
gnome-initial-setup 3.38.4-1 40.0-1
gnome-panel 3.38.0-1 3.40.0-1
gnome-phone-manager 0.69-15 0.69-16
gnome-shell-extension-appindicator 36-1 37-1
gnunet 0.14.0-1 0.14.1-1
go-bindata-assetfs 1.0.1-1 1.0.1-2
go-bindata-hashicorp 3.0.7+bf7910af-3 3.0.7+bf7910af-4
go-ethereum 1.10.1-1 1.10.2-1
granite 5.5.0-1 6.0.0-1
groovy-docs 2.5.0-2 3.0.7-1
grub-btrfs 4.8.1-1 4.9-1
grunt-cli 1.4.1-1 1.4.2-1
gscan2pdf 2.10.2-1 2.11.2-1
gtranslator 3.38.0-1 40.0-1
helmfile 0.137.0-4 0.138.7-1
hexchat 2.14.3-6 2.14.3-7
hiera 3.6.0-1.1 3.6.0-2
highlight 3.62-1 4.0-1
highlight-gui 3.62-1 4.0-1
hitch 1.6.0-1 1.7.0-1
hivex 1.3.19-3 1.3.19-4
home-assistant 2021.1.5-2 2021.4.4-2
hydrogen 1.0.1-1 1.0.2-1
ibus-m17n 1.4.4-1 1.4.5-1
icewm 2.2.1-1 2.3.2-1
iddawc 0.9.8-3 0.9.9-1
igraph 0.9.1-1 0.9.2-1
inter-font 3.15-2 3.18-1
jack_mixer 15.1-1 16-1.1
jedi-language-server 0.30.2-1 0.30.2-2
jenkins 2.286-1 2.288-1
jmol 14.31.35-1 14.31.36-1
josm 17580-1 17702-1
joyutils 1.7.1-1 1.7.1-2
jsmol 14.31.35-1 14.31.36-1
jupyter-nbclassic 0.2.6-1 0.2.7-1
jupyter-server 1.5.1-2 1.6.1-1
jupyter-server-mathjax 0.2.0-1 0.2.2-1
jupyterlab 3.0.12-2 3.0.14-1
kbibtex 1:0.9.2-3 1:0.9.2-4
kea 1.9.3-1 1.9.6-1
klayout 0.26.11-1 0.26.11-2
kmymoney 5.1.1-1 5.1.1-2
knot-resolver 5.3.0-1 5.3.1-1
krita-plugin-gmic 2.9.6-1 2.9.7-1
kvantum-theme-materia 20210307-1 20210410-1
languagetool 5.2-1 5.3-1
libavif 0.9.0-1 0.9.0-2
libcurl-compat 7.76.0-1 7.76.1-1
libcurl-gnutls 7.76.0-1 7.76.1-1
libmgba 0.8.4-1 0.9.0-1
libomemo 0.7.1-2 0.7.1-3
libpurple-lurch 0.6.8-4 0.7.0-1
libretro-core-info 1.9.0-1 1.9.1-1
librsync 1:2.3.1-1 1:2.3.2-1
libsigrok 0.5.2-7 0.5.2-8
libvips 8.10.3-1 8.10.6-1
liquidctl 1.5.0-2 1.6.0-1
lldpd 1.0.8-1 1.0.10-1
logcli 2.2.0-1 2.2.1-1
loki 2.2.0-1 2.2.1-1
loki-canary 2.2.0-1 2.2.1-1
lolcat 100.0.0-2 100.0.0-3
lollypop 1.4.18-1 1.4.19-1
lv2lint 0.10.0-1 0.12.0-1
lxd 4.12-2 4.13-1
lxqt-panel 0.16.1-1 0.16.1-2
lychee-link-checker 0.5.0-1 0.6.0-2
marisa 0.2.6-4 0.2.6-5
marked 2.0.1-1 2.0.3-1
materia-gtk-theme 20210322-1 20210322-2
materia-kde 20210307-1 20210410-1
matterbridge 1.22.0-2 1.22.1-1
mcollective 2.12.5-2 2.12.5-3
mdcat 0.22.3-1 0.22.4-1
mediastreamer 4.5.1-1 4.5.3-1
mediawiki 1.35.1-1 1.35.2-1
mediawiki-math 1.35.1-1 1.35.2-1
mephisto.lv2 0.14.0-1 0.16.0-1
mgba-qt 0.8.4-1 0.9.0-1
mgba-sdl 0.8.4-1 0.9.0-1
minder 1.12.0-1 1.12.0-2
minetest 5.4.0-1 5.4.1-1
minetest-common 5.4.0-1 5.4.1-1
minetest-server 5.4.0-1 5.4.1-1
minikube 1.17.1-1 1.19.0-1
minitube 3.8.1-1 3.8.2-1
mkinitcpio-utils 0.0.3-5 0.0.4-1
mksh 59-1 59.c-1
mod_passenger 6.0.8-1 6.0.8-2
moony.lv2 0.36.0-1 0.38.0-1
mosquitto 2.0.8-1 2.0.10-1
mpv 1:0.33.0-4 1:0.33.1-1
mujs 1.1.0-1 1.1.1-1
netdata 1.29.3-3 1.30.1-1
nextcloud 21.0.0-9 21.0.1-1
nextcloud-app-deck 1:1.3.1-1 1:1.4.0-1
nextcloud-app-mail 1.9.4-1 1.9.5-1
nextcloud-app-spreed 1:11.1.1-1 1:11.2.0-1
nginx-mainline 1.19.9-1 1.19.10-1
nginx-mainline-src 1.19.9-1 1.19.10-1
nginx-mod-passenger 6.0.8-1 6.0.8-2
nicotine+ 3.0.3-1 3.0.4-1
nnn 3.6-1 4.0-1
nodejs 15.13.0-1 15.14.0-1
nodejs-lts-erbium 12.21.0-2 12.22.0-1
notes-up 2.0.2-2 2.0.2-3
notmuch 0.31-3 0.31.4-2
notmuch-mutt 0.31-3 0.31.4-2
notmuch-runtime 0.31-3 0.31.4-2
notmuch-vim 0.31-3 0.31.4-2
npm 7.8.0-1 7.9.0-1
npm-check-updates 11.3.0-1 11.4.1-1
nsd 4.3.5-4 4.3.6-1
nuitka 0.6.13.2-1 0.6.13.3-1
oniguruma 6.9.6-1 6.9.7.1-1
opendmarc 1.4.0-1 1.4.0-2
openimageio 2.2.12.0-1 2.2.13.0-1
openscad 2019.05-9 2021.01-1
openshadinglanguage 1.11.12.0-1 1.11.13.0-1
opensubdiv 3.4.3-5 3.4.4-1
openttd 1.10.3-2 1.11.0-1
openttd-opensfx 1.0.0-1 1.0.1-1
openxr 1.0.14-1 1.0.15-1
operator-sdk 1.4.2-1 1.5.0-1
ortp 4.5.1-1 4.5.3-1
pam-ihosts 1.5.7-5 1.6-1
pam-krb5 4.9-1 4.10-1
pantheon-applications-menu 2.7.1-2 2.7.1-3
pantheon-calculator 1.6.0-1 1.6.0-2
pantheon-calendar 5.1.1-1 5.1.1-3
pantheon-code 3.4.1-2 3.4.1-3
pantheon-files 4.5.0-1 4.5.0-2
pantheon-music 5.0.5-2 5.0.5-3
pantheon-photos 2.7.0-2 2.7.0-3
pantheon-polkit-agent 1.0.3-1 1.0.3-2
pantheon-screenshot 1.7.1-1 1.7.1-2
pantheon-shortcut-overlay 1.1.2-1 1.1.2-2
pantheon-terminal 5.5.2-1 5.5.2-2
pantheon-videos 2.7.2-1 2.7.2-2
patchmatrix 0.22.0-1 0.24.0-1
pdf2djvu 0.9.17.1-7 0.9.17.1-8
pdfjs 2.7.570-1 2.8.335-1
pdftricks 0.3.0-1 0.3.0-2
pelican 4.5.4-1 4.6.0-1
perl-dbi-shell 11.95-9 11.97-1
perl-log-any 1.708-2 1.709-1
perl-marisa 0.2.6-4 0.2.6-5
perl-scalar-list-utils 1.55-2 1.56-1
php-mongodb 1.9.0-3 1.9.1-2
php7-mongodb 1.9.0-3 1.9.1-2
picard 2.6-1 2.6.1-1
plank 0.11.89-2 0.11.89-3
plantuml 1.2021.0-1 1.2021.4-1
plocate 1.1.6-1 1.1.7-1
promtail 2.2.0-1 2.2.1-1
puppet 6.21.1-1 6.21.1-2
puppet5 5.5.22-1 5.5.22-2
pyenv 1.2.24.1-1 1.2.26-1
python-acme 1.13.0-1 1.14.0-1
python-adal 1.2.6-1 1.2.7-1
python-aiobotocore 1.2.2-1 1.3.0-1
python-aiohttp 3.7.4-1 3.7.4.post0-1.1
python-aiopg 1.1.0-1 1.2.1-1
python-apsw 3.34.0-1 3.35.4-1
python-basictracer 3.1.0-2 3.2.0-1
python-bcc 0.18.0-2 0.19.0-1
python-boto3 1.17.33-1 1.17.49-1
python-botocore 1.20.33-1 1.20.49-1
python-braintree 4.7.0-1 4.8.0-1
python-breathe 4.28.0-1 4.29.0-1
python-browserid 0.14.0-7 0.14.0-8
python-btchip 0.1.31-1 0.1.32-1
python-cerberus 1.3.2-3 1.3.3-1
python-cfn-lint 0.48.1-1 0.48.2-1
python-cheroot 8.5.2-1 8.5.2-2
python-cherrypy 18.6.0-4 18.6.0-5
python-cloudscraper 1.2.56-1 1.2.58-1
python-construct 2.10.64-1 2.10.66-1
python-cssbeautifier 1.13.6-1 1.13.7-1
python-curtsies 0.3.4-3 0.3.5-1
python-cx-freeze 6.5.3-1 6.6-1
python-cymem 2.0.5-1 2.0.5-1.1
python-cytoolz 0.11.0-3 0.11.0-3.1
python-django-extensions 3.1.1-1 3.1.2-1
python-docker 4.4.4-1 5.0.0-1
python-docs 3.9.2-1 3.9.4-1
python-docstring-to-markdown 0.7-1 0.9-2
python-dotenv 0.16.0-1 0.17.0-1
python-faker 7.0.1-1 8.1.0-1
python-fonttools 4.21.1-1 4.22.0-1
python-furl 2.1.0-6 2.1.2-1
python-fxa 0.7.7-2 0.7.7-3
python-gdal 3.0.4-20 3.0.4-21
python-ghp-import 1.0.1-1 1.1.0-1
python-google-auth 1.28.0-1 1.28.1-1
python-google-auth-oauthlib 0.4.3-1 0.4.4-1
python-hawkauthlib 2.0.0-7 2.0.0-8
python-hcloud 1.10.0-2 1.12.0-1
python-httpcore 0.12.0-3 0.12.3-1
python-httpx 0.16.1-3 0.17.1-1
python-hypothesis 6.8.4-1 6.8.10-1
python-identify 2.2.2-1 2.2.3-1
python-internetarchive 1.9.9-1 2.0.1-1
python-jsbeautifier 1.13.6-1 1.13.7-1
python-jupyter_packaging 0.8.2-1 0.9.1-1
python-language-server 0.36.2-3 0.36.2-5
python-marisa 0.2.6-4 0.2.6-5
python-mohawk 1.1.0-3 1.1.0-4
python-monotonic 1.5-7 1.6-1
python-moto 2.0.2-1 2.0.5-1
python-nbxmpp 1.0.2-3 2.0.2-1
python-networkx 2.5-3 2.5.1-1
python-nltk 3.5-3 3.6.1-1
python-nodeenv 1.5.0-3 1.6.0-1
python-pg8000 1.19.0-1 1.19.2-1
python-phonenumbers 8.12.20-1 8.12.21-1
python-pikepdf 2.10.0-1 2.11.1-1
python-poetry 1.1.5-1 1.1.6-1
python-poetry-core 1.0.2-1 1.0.3-1
python-pyglet 1.5.14-1 1.5.16-1
python-pyicu 2.6-3 2.7.1-1
python-pymediainfo 5.0.3-1 5.0.4-1
python-pyroute2 0.5.14-2 0.5.17-1
python-pytesseract 0.3.7-2 0.3.7-3
python-pytest 6.2.2-1 6.2.3-1
python-pytest-django 4.1.0-3 4.2.0-1
python-pytools 2021.2.1-1 2021.2.3-1
python-qdarkstyle 2.8.1-3 3.0.2-1
python-qtawesome 0.6.0-5 1.0.2-1
python-quart 0.14.1-1 0.14.1-2
python-regex 2021.3.17-1 2021.4.4-1
python-requests-hawk 1.1.0-1 1.1.0-2
python-rich 10.1.0-1 10.1.0-2
python-ruamel-yaml 0.17.2-1 0.17.4-1
python-schema 0.7.4-1 0.7.4-2
python-sphinx 3.5.2-1 3.5.4-1
python-sphinx_rtd_theme 0.5.1-2 0.5.2-1
python-sphobjinv 2.0.1-2 2.1-1
python-spyder-kernels 1.10.2-1 2.0.1-1
python-subprocess-tee 0.2.0-1 0.3.0-1
python-sympy 1.7.1-2 1.8-1
python-terminado 0.9.3-1 0.9.4-1
python-testflo 1.4.2-4 1.4.5-1
python-unicorn 1.0.2-1 1.0.2-2
python-xxhash 2.0.0-3 2.0.2-1
python2-cheroot 8.5.2-1 8.5.2-2
qcad 3.26.1.0-1 3.26.2.0-1
qjackctl 0.9.2-1 0.9.2-2
qjournalctl 0.6.2-1 0.6.3-1
qt5pas 2.6.r63484-2 2.6.r64920-1
qt6ct 0.2-5 0.3-1
qutebrowser 2.1.0-1 2.2.0-1
r2ghidra 5.1.1-2 5.2.0-1
radare2 5.1.1-1 5.2.0-1
rebuilderd 0.9.1-1 0.10.0-1
redis 6.2.1-1 6.2.1-2
remind 3.3.5-1 3.3.6-1
remmina 1:1.4.12-1 1:1.4.13-1
repo 2.12-1 2.12.2-1
rhonabwy 0.9.99-1 0.9.999-1
rssguard 3.9.0-1 3.9.1-1
rssguard-nowebengine 3.9.0-1 3.9.1-1
ruby-activesupport 6.1.3-1 6.1.3-3
ruby-addressable 2.7.0-2 2.7.0-3
ruby-async 1.23.0-2 1.23.0-3
ruby-async-dns 1.2.4-2 1.2.4-3
ruby-async-io 1.27.0-2 1.27.0-3
ruby-atk 3.4.3-1 3.4.3-2
ruby-augeas 0.5.0-4 0.5.0-5
ruby-bcrypt_pbkdf 1.1.0-1 1.1.0-2
ruby-builder 3.2.4-1 3.2.4-2
ruby-bundler 2.2.15-1 2.2.16-4
ruby-cairo 1.17.5-1 1.17.5-2
ruby-cairo-gobject 3.4.3-1 3.4.3-2
ruby-chronic 0.10.2-2 0.10.2-3
ruby-colorator 1.1.0-6 1.1.0-7
ruby-colored2 3.1.2-4 3.1.2-5
ruby-colorize 0.8.1-7 0.8.1-8
ruby-concurrent 1.1.8-1 1.1.8-2
ruby-crack 0.4.4-1 0.4.4-2
ruby-daemons 1.3.1-1 1.3.1-2
ruby-dbus 0.15.0-3 0.15.0-4
ruby-deep_merge 1.2.1-2 1.2.1-3
ruby-diff-lcs 1.4.4-1 1.4.4-2
ruby-domain_name 0.5.20190701-2 0.5.20190701-3
ruby-em-proxy 0.1.9-6 0.1.9-7
ruby-eventmachine 1.2.7-3 1.2.7-4
ruby-fakeweb 1.3.0-1 1.3.0-2
ruby-faraday 1.3.0-1 1.3.0-2
ruby-faraday-middleware 1.0.0-1 1.0.0-2
ruby-fast_gettext 2.0.3-2 2.0.3-3
ruby-ffi 1.15.0-1 1.15.0-2
ruby-forwardable-extended 2.6.0-5 2.6.0-6
ruby-gdk3 3.4.3-1 3.4.3-2
ruby-gdk_pixbuf2 3.4.3-1 3.4.3-2
ruby-gettext 3.3.7-1 3.3.7-2
ruby-gettext-setup 0.34-2 0.34-3
ruby-gio2 3.4.3-1 3.4.3-2
ruby-glib2 3.4.3-1 3.4.3-2
ruby-gobject-introspection 3.4.3-1 3.4.3-2
ruby-gpgme 2.0.20-1 2.0.20-2
ruby-gtk3 3.4.3-1 3.4.3-2
ruby-hashdiff 1.0.0-2 1.0.0-3
ruby-hitimes 2.0.0-2 2.0.0-3
ruby-hocon 1.3.1-1 1.3.1-2
ruby-hoe 3.22.3-1 3.22.3-3
ruby-hpricot 0.8.6-9.1 0.8.6-11
ruby-http-cookie 1.0.3-5 1.0.3-6
ruby-httpclient 2.8.3-7 2.8.3-8
ruby-i18n 1.8.1-1 1.8.1-3
ruby-iconv 1.0.8-1 1.0.8-2
ruby-immutable-struct 2.4.1-1 2.4.1-2
ruby-irb 1.3.4-1 1.3.5-1
ruby-jekyll-sass-converter 2.1.0-1 2.1.0-2
ruby-json 2.3.1-1 2.5.1-2
ruby-json-schema 2.8.1-2 2.8.1-3
ruby-kramdown 2.3.1-1 2.3.1-2
ruby-locale 2.1.3-2 2.1.3-3
ruby-mail 2.7.1-3 2.7.1-4
ruby-mail-gpg 0.4.4-1 0.4.4-2
ruby-manpages 0.6.1-3 0.6.1-4
ruby-marisa 0.2.6-4 0.2.6-5
ruby-maruku 0.7.3-5 0.7.3-6
ruby-mercenary 0.4.0-1 0.4.0-2
ruby-mime-types 3.3.1-1 3.3.1-2
ruby-mime-types-data 3.2020.0512-1 3.2020.0512-2
ruby-mini_mime 1.0.2-1 1.0.2-2
ruby-mini_portile 0.6.2-3 0.6.2-4
ruby-mini_portile2 2.5.0-1 2.5.0-2
ruby-minitar 0.9-2 0.9-3
ruby-minitest 5.14.3-1 5.14.3-3
ruby-minitest-global_expectations 1.0.1-2 1.0.1-3
ruby-minitest-proveit 1.0.0-1 1.0.0-2
ruby-minitest-retry 0.2.1-1 0.2.1-2
ruby-minitest-sprint 1.2.1-1 1.2.1-2
ruby-minitest-stub-const 0.6-1 0.6-2
ruby-mocha 1.12.0-1 1.12.0-2
ruby-molinillo 0.7.0-2 0.7.0-3
ruby-msgpack 1.4.2-1 1.4.2-2
ruby-multi_json 1.15.0-1 1.15.0-2
ruby-multipart-parser 0.1.1-1 0.1.1-2
ruby-multipart-post 2.1.1-2 2.1.1-3
ruby-mustache 1.1.1-1 1.1.1-2
ruby-mustermann 1.0.3-2 1.1.1-1
ruby-native-package-installer 1.1.1-1 1.1.1-2
ruby-nats-pure 0.6.2-3 0.6.2-4
ruby-ncurses 1.3.1-14 1.3.1-15
ruby-net-dns 0.8.0-6 0.8.0-7
ruby-net-ping 2.0.8-1 2.0.8-2
ruby-network_interface 0.0.2-3 0.0.2-4
ruby-nio4r 2.5.4-1 2.5.4-2
ruby-nokogiri 1.11.2-1 1.11.2-2
ruby-optimist 3.0.1-1 3.0.1-2
ruby-packetfu 1.1.13-4 1.1.13-5
ruby-paint 2.2.1-1 2.2.1-2
ruby-pango 3.4.3-1 3.4.3-2
ruby-path_expander 1.1.0-2 1.1.0-3
ruby-pathutil 0.16.2-1 0.16.2-2
ruby-pcaprub 0.12.4-6 0.12.4-7
ruby-pg 1.1.4-2 1.1.4-3
ruby-pkg-config 1.4.1-1 1.4.1-2
ruby-polyglot 0.3.5-7 0.3.5-8
ruby-power_assert 1.2.0-1 1.2.0-2
ruby-public_suffix 4.0.6-1 4.0.6-2
ruby-puppet-resource_api 1.8.13-1 1.8.13-2
ruby-rack 2.2.3-1 2.2.3-2
ruby-rack-protection 2.1.0-1 2.1.0-2
ruby-rack-test 1.1.0-3 1.1.0-4
ruby-rainbow 3.0.0-5 3.0.0-6
ruby-rake 13.0.3-1 13.0.3-2
ruby-rake-compiler 1.1.1-1 1.1.1-2
ruby-rb-fsevent 0.10.4-1 0.10.4-2
ruby-rb-inotify 0.9.10-4 0.9.10-5
ruby-rdiscount 2.2.0.2-1 2.2.0.2-2
ruby-rdoc 6.3.0-1 6.3.0-3
ruby-reline 0.2.4-1 0.2.5-1
ruby-ronn 0.7.3-9 0.7.3-10
ruby-ronn-ng 0.9.1-1 0.9.1-2
ruby-rouge 3.26.0-1 3.26.0-2
ruby-rspec 3.8.0-3 3.8.0-4
ruby-rspec-core 3.8.0-3 3.8.0-4
ruby-rspec-expectations 3.8.1-3 3.8.1-4
ruby-rspec-its 1.3.0-3 1.3.0-4
ruby-rspec-mocks 3.8.0-3 3.8.0-4
ruby-rspec-support 3.8.0-3 3.8.0-4
ruby-ruby2_keywords 0.0.4-2 0.0.4-3
ruby-rubydns 2.0.2-4 2.0.2-5
ruby-rugged 1.1.0-1 1.1.0-2
ruby-safe_yaml 1.0.5-1 1.0.5-2
ruby-samus 3.0.9-1 3.0.9-2
ruby-sass 3.7.4-2 3.7.4-3
ruby-sass-listen 4.0.0-8 4.0.0-9
ruby-sassc 2.4.0-1 2.4.0-2
ruby-sd_notify 0.1.1-1 0.1.1-2
ruby-semantic_puppet 1.0.3-1 1.0.3-2
ruby-shadow 2.5.0-5 2.5.0-6
ruby-sinatra 2.1.0-2 2.1.0-4
ruby-sqlite3 1.4.2-2 1.4.2-3
ruby-stomp 1.4.10-1 1.4.10-2
ruby-sync 0.5.0-3 0.5.0-4
ruby-sys-proctable 1.2.6-1 1.2.6-2
ruby-term-ansicolor 1.7.1-1 1.7.1-2
ruby-test-unit 3.4.0-1 3.4.0-2
ruby-test_declarative 0.0.6-1 0.0.6-2
ruby-text 1.3.1-6 1.3.1-7
ruby-thin 1.8.0-1 1.8.0-2
ruby-thor 1.1.0-1 1.1.0-2
ruby-tilt 2.0.8-4 2.0.8-5
ruby-timers 4.3.2-1 4.3.2-2
ruby-tins 1.26.0-1 1.26.0-2
ruby-titlecase 0.1.1+13+1d6b4f7-4 0.1.1+13+1d6b4f7-5
ruby-treetop 1.6.11-1 1.6.11-2
ruby-trollop 2.1.3-3 2.1.3-4
ruby-tzinfo 2.0.3-1 2.0.3-2
ruby-unf 0.2.0.beta2-3 0.2.0.beta2-5
ruby-unicorn-engine 1.0.2-1 1.0.2-2
ruby-vimrunner 0.3.4-1 0.3.4-2
ruby-webmock 3.11.1-1 3.11.2-1
ruby-yard 0.9.26-1 0.9.26-2
ruby-zeitwerk 2.4.1-1 2.4.1-2
ruby2.6 2.6.6-1 2.6.7-1
rust-analyzer 20210329-1 20210412-1
sakura 3.7.1-1 3.8.1-1
sbctl 0.1-1 0.2-1
scribus 1.5.6.1-9 1.5.6.1-11
sdcc 4.0.0-1 4.1.0-1
sherlock.lv2 0.26.0-1 0.28.0-1
siege 4.0.7-1 4.0.8-1
sigil 1.4.3-1 1.5.1-1
singular 4.2.0.p1-1 4.2.0.p2-1
skk-jisyo 20210307-1 20210411-1
sleuthkit 4.10.1-1 4.10.2-1
snapper 0.8.16-1 0.9.0-1
snd 21.2-1 21.3-1
solr 8.8.1-1 8.8.2-1
sonic-pi 3.2.2-2 3.2.2-3
spice-up 1.8.2-1 1.8.2-2
spyder 4.2.5-1 5.0.0-2
step-cli 0.15.14-1 0.15.15-1
sweethome3d 6.5-1 6.5-2
switchboard 2.4.0-1 2.4.0-2
switchboard-plug-a11y 2.2.0-1 2.2.0-2
switchboard-plug-about 2.6.3-1 2.6.3-2
switchboard-plug-applications 2.1.7-1 2.1.7-2
switchboard-plug-bluetooth 2.3.5-1 2.3.5-2
switchboard-plug-datetime 2.1.9-1 2.1.9-2
switchboard-plug-desktop 2.8.4-1 2.8.4-2
switchboard-plug-display 2.2.2-1 2.2.2-2
switchboard-plug-keyboard 2.4.1-1 2.4.1-2
switchboard-plug-locale 2.5.3-1 2.5.3-2
switchboard-plug-mouse-touchpad 2.4.2-1 2.4.2-2
switchboard-plug-network 2.3.3-1 2.3.3-2
switchboard-plug-notifications 2.1.7-1 2.1.7-2
switchboard-plug-online-accounts 2.0.1-2 2.0.1-3
switchboard-plug-parental-controls 3.0.1-1 3.0.1-2
switchboard-plug-power 2.4.2-1 2.4.2-2
switchboard-plug-printers 2.1.9-1 2.1.9-2
switchboard-plug-security-privacy 2.2.2-1 2.2.4-2
switchboard-plug-sharing 2.1.4-1 2.1.4-2
switchboard-plug-sound 2.2.6-1 2.2.6-2
switchboard-plug-user-accounts 2.3.2-1 2.3.2-2
syncthing 1.14.0-1 1.15.1-1
syncthing-relaysrv 1.14.0-1 1.15.1-1
tanka 0.14.0-1 0.15.0-1
terminator 2.1.0-2 2.1.1-2
terraform 0.14.9-1 0.15.0-1
thunderbird-dark-reader 4.9.30-1 4.9.31-2
timescaledb 2.1.1-1 2.2.0-1
tmux 3.1_c-1 3.2-1
torrential 1.1.0-3 1.1.0-4
traefik 2.4.2-1 2.4.8-1
translate-toolkit 3.3.3-1 3.3.4-1
ttf-linux-libertine 5.3.0-6 5.3.0-7
ttf-sarasa-gothic 0.20.2-1 0.30.0-1
typescript 4.2.3-2 4.2.4-1
uglify-js 3.13.3-1 3.13.4-1
urh 2.9.1-1 2.9.1-1.1
urlwatch 2.22-5 2.23-1
usbredir 0.8.0-2 0.9.0-1
uthash 2.1.0-2 2.3.0-1
uutils-coreutils 0.0.4-1 0.0.6-1
uwsgi 2.0.19.1-10 2.0.19.1-11
uwsgi-plugin-cgi 2.0.19.1-10 2.0.19.1-11
uwsgi-plugin-jvm 2.0.19.1-10 2.0.19.1-11
uwsgi-plugin-lua51 2.0.19.1-10 2.0.19.1-11
uwsgi-plugin-notfound 2.0.19.1-10 2.0.19.1-11
uwsgi-plugin-php 2.0.19.1-10 2.0.19.1-11
uwsgi-plugin-php7 2.0.19.1-10 2.0.19.1-11
uwsgi-plugin-psgi 2.0.19.1-10 2.0.19.1-11
uwsgi-plugin-python 2.0.19.1-10 2.0.19.1-11
uwsgi-plugin-rack 2.0.19.1-10 2.0.19.1-11
uwsgi-plugin-webdav 2.0.19.1-10 2.0.19.1-11
uwsgi-plugin-zabbix 2.0.19.1-10 2.0.19.1-11
v2ray 4.36.2-1 4.37.3-1
v2ray-domain-list-community 20210401091829-1 20210415054336-1
v2ray-geoip 202104010913-1 202104150006-1
vals 0.10.3-1 0.10.3-2
vdirsyncer 0.16.8-6 0.16.8-7
vim-coverage-highlight 3.3-1 3.4-1
vm.lv2 0.12.0-1 0.14.0-1
vocal 2.4.2-2 2.4.2-3
wanderlust 20201022-1 20210407-1
watchexec 1.14.1-1 1.15.0-1
waybar 0.9.5-2 0.9.7-1
wcslib 7.5-1 7.6-1
weechat 3.1-1 3.1-2
wezterm20210314.114017.04b7cedd-120210405.110924.a5bb5be8-1
wingpanel 2.3.2-2 2.3.2-4
wingpanel-indicator-datetime 2.2.5-2 2.2.5-4
wingpanel-indicator-keyboard 2.3.0-1 2.3.0-2
wingpanel-indicator-notifications 2.1.4-1 2.1.4-2
wingpanel-indicator-session 2.2.8-1 2.2.8-2
wingpanel-indicator-sound 2.1.8-1 2.1.8-2
wordpress 5.7-1 5.7.1-1
wpscan 1:3.8.16-1 1:3.8.17-1
wt 4.4.0-3 4.5.0-1
wxsqlite3 4.6.4-1 4.6.9-1
x42-plugins 20210114-1 20210409-1
xdelta3 3.1.0-1 3.1.0-2
xine-lib 1.2.11-3 1.2.11-4
xkcdpass 1.17.3-3 1.17.6-1
xmms20.8DrO_o.7391.dedc33d7-30.8DrO_o.7391.dedc33d7-4.1
xonsh 0.9.24-3 0.9.27-1
yad 9.1-1 9.3-1
yaegi 0.9.6-1 0.9.16-1
yamllint 1.26.0-2 1.26.1-1
youtube-dl 2021.04.01-1 2021.04.07-1
yubico-pam 2.26-2 2.27-1
zart 2.9.6-1 2.9.7-1
zile 2.4.15-1 2.6.1-1
age - 1.0.0rc.1-2
aml - 0.2.0-2
argocd - 2.0.1-1
budgie-desktop-view - 1.1.1-1
git-credential-gopass - 1.12.0-1
gopass-hibp - 1.12.0-1
gopass-jsonapi - 1.11.1-1
gopass-summon-provider - 1.12.0-1
iaito - 5.2.0-1
innernet - 1.0.1-3
libertinus-font - 7.040-1
librttopo - 1.1.0-1
lightdm-pantheon-greeter - 5.0.4-3
neatvnc - 0.4.0-2
npm6 - 6.14.13-1
python-awesomeversion - 21.4.0-1
python-cwcwidth - 0.1.4-1.1
python-ppmd-cffi - 0.4.1-1
python-qstylizer - 0.1.10-1
python-unidiff - 0.6.0-3
qtmpris - 1.0.6-1
ruby-cri - 2.15.11-3
ruby-ed25519 - 1.2.4-3
ruby-rexml - 3.2.5-1
ruby-rr - 1.2.1-7
ruby-test-unit-rr - 1.0.5-6
ruby-webrick - 1.7.0-1
ruby2.7 - 2.7.3-1
sops - 3.7.1-3
wayvnc - 0.4.0-2
zutty - 0.8-2
:: Different overlay package(s) in repository core aarch64
linux 5.11.10-1 5.11.15-1
linux-firmware 20210208.b79d239-2 -
linux-headers 5.11.10-1 5.11.15-1
linux-nxp 5.10.23-1 5.10.23-2
linux-nxp-headers 5.10.23-1 5.10.23-2
linux-pinephone 5.11.11-1 5.11.14-1
linux-pinephone-headers 5.11.11-1 5.11.14-1
linux-rc 5.12.rc5-4 5.12.rc7-2
linux-rc-headers 5.12.rc5-4 5.12.rc7-2
linux-rpi4 5.10.25-3 5.10.27-1
linux-rpi4-headers 5.10.25-3 5.10.27-1
linux-rpi4-mainline 5.11.10-1 5.11.11-1
linux-rpi4-mainline-headers 5.11.10-1 5.11.11-1
linux-rpi4-rc 5.12.rc5-2 5.12.rc6-1
linux-rpi4-rc-headers 5.12.rc5-2 5.12.rc6-1
linux-vim 5.11.7-1 5.11.11-1
linux-vim-headers 5.11.7-1 5.11.11-1
raspberrypi-bootloader 20210315-1 20210407-1
raspberrypi-bootloader-x 20210315-1 20210407-1
:: Different sync package(s) in repository core aarch64
cryptsetup 2.3.5-1 2.3.5-4
curl 7.76.0-1 7.76.1-1
expat 2.2.10-2 2.3.0-1
file 5.40-1 5.40-2
glib2 2.68.0-5 2.68.1-1
glib2-docs 2.68.0-5 2.68.1-1
lemon 3.35.3-1 3.35.4-1
libnsl 1.3.0-1 1.3.0-2
libxcrypt 4.4.18-1 4.4.19-1
run-parts 4.8.6.1-2 4.11.2-1
sqlite 3.35.3-1 3.35.4-1
sqlite-analyzer 3.35.3-1 3.35.4-1
sqlite-doc 3.35.3-1 3.35.4-1
sqlite-tcl 3.35.3-1 3.35.4-1
systemd 248-1 248-4
systemd-libs 248-1 248-4
systemd-resolvconf 248-1 248-4
systemd-sysvcompat 248-1 248-4
:: Different overlay package(s) in repository extra aarch64
kirigami2 5.80.0-1.1 -
kwin 5.21.3-1.0 5.21.4-0
manjaro-arm-tools 2.9.4-1 2.10.0-1
mesa-git21.1.0_devel.137150.ea2c47390ad-121.1.0_devel.137820.ba8737bb860-1
pamac-cli 10.0.5-1 10.1.0rc-1
pamac-common 10.0.5-1 10.1.0rc-1
pamac-flatpak-plugin 10.0.5-1 10.1.0rc-1
pamac-gnome-integration 10.0.5-1 10.1.0rc-1
pamac-gtk 10.0.5-1 10.1.0rc-1
pamac-snap-plugin 10.0.5-1 10.1.0rc-1
plasma-mobile-nm 5.21.3-1 5.21.4-1
plasma-nano 5.21.3-1 5.21.4-1
plasma-phone-components 5.21.3-1 5.21.4-1
vlc 3.0.12-3.1 -
:: Different sync package(s) in repository extra aarch64
akregator 20.12.3-1 20.12.3-2
alacarte 3.36.0+2+gae6b92d-1 3.36.0+2+gae6b92d-2
alsa-card-profiles 1:0.3.24-1 1:0.3.25-1
amtk 5.2.0-2 5.3.1-1
aom 2.0.2-1 3.0.0-2
apparmor 3.0.1-1 3.0.1-2
asp 6-2 7-1
attica 5.80.0-1 5.81.0-1
baloo 5.80.0-1 5.81.0-1
bdf-unifont 13.0.03-1 13.0.06-1
bluedevil 1:5.21.3-1 1:5.21.4-1
bluez 5.57-1 5.58-1
bluez-cups 5.57-1 5.58-1
bluez-hid2hci 5.57-1 5.58-1
bluez-libs 5.57-1 5.58-1
bluez-plugins 5.57-1 5.58-1
bluez-qt 5.80.0-1 5.81.0-1
bluez-utils 5.57-1 5.58-1
booster 0.3-1 0.4-1
breeze 5.21.3-1 5.21.4-1
breeze-grub 5.21.3-1 5.21.4-1
breeze-gtk 5.21.3-1 5.21.4-1
breeze-icons 5.80.0-1 5.81.0-1
calligra 3.2.1-10 3.2.1-11
cbindgen 0.18.0-1 0.19.0-1
chromium 89.0.4389.114-1 89.0.4389.128-1
cifs-utils 6.12-1 6.13-1
cmake 3.20.0-1 3.20.1-1
coordgen 2.0.2-1 2.0.3-1
cups 1:2.3.3op2-1 1:2.3.3op2-2
cups-pdf 3.0.1-5 3.0.1-6
devhelp 3.38.1-1 40.0-1
digikam 7.2.0-2 7.2.0-3
discover 5.21.3-1 5.21.4-2
dleyna-connector-dbus 0.3.0-3 0.4.0-1
dleyna-core 0.6.0+2+g1c6853f-2 0.7.0-1
dleyna-renderer 0.6.0-4 0.7.0-2
dleyna-server 0.6.0+2+geb895ae-2 0.7.0-2
dnsmasq 2.84-1 2.85-1
drkonqi 5.21.3-1 5.21.4-1
ebtables 2.0.10_4-8 -
evolution 3.38.4-1 3.40.0-1
evolution-bogofilter 3.38.4-1 3.40.0-1
evolution-data-server 3.38.4-1 3.40.0-1
evolution-ews 3.38.4-1 3.40.0-1
evolution-spamassassin 3.38.4-1 3.40.0-1
exo 4.16.1-1 4.16.2-1
extra-cmake-modules 5.80.0-1 5.81.0-1
ffmpeg 2:4.3.2-5 2:4.3.2-6
file-roller 3.38.0-1 3.38.1-1
finch 2.14.2-1 2.14.3-1
folks 0.14-4 0.14-5
frameworkintegration 5.80.0-1 5.81.0-1
freetds 1.2.18-1 1.2.20-1
fuse-common 3.10.2-1 3.10.3-1
fuse3 3.10.2-1 3.10.3-1
gdk-pixbuf2 2.42.4-1 2.42.6-1
gdm 3.38.2.1-1 40.0-1
geoclue 2.5.7-2 2.5.7-3
gi-docgen 2021.2+90+g7fbbaf3-12021.2+113+gc633261-1
gn 0.1877.595e3be7-1 0.1891.dfcbc6fe-1
gnome-backgrounds 40rc-1 40.0-1
gnome-calendar 3.38.2-1 40.0-1
gnome-chess 40.0-1 40.1-1
gnome-clocks 40.0-1 40.0-2
gnome-contacts 3.38.1-1 40.0-1
gnome-control-center 3.38.5-1 40.0-1
gnome-notes 40.0-1 40.0-2
gnome-session3.38.0+14+g87d92fec-1 40.0-1
gnome-settings-daemon 3.38.1-1 40.0.1-1
gnome-shell 1:3.38.4-1 1:40.0-1
gnome-shell-extensions 3.38.2-1 40.0-2
gnome-todo 3.28.1+33+gc03a4c1-1 3.28.1+34+g1b5336f-1
gnome-tweaks 3.34.1-1 40.0-1
gnome-weather 3.36.1-1 40.0-1
gpaste 3.38.6-1 3.40.1-1
graphene 1.10.4-1 1.10.6-1
grilo-plugins 1:0.3.13-1 1:0.3.13-2
gsettings-desktop-schemas 40.0-2 40.0-3
gst-plugin-opencv 1.18.4-3 1.18.4-4
gst-plugin-pipewire 1:0.3.24-1 1:0.3.25-1
gst-plugin-wpe 1.18.4-3 1.18.4-4
gst-plugins-bad 1.18.4-3 1.18.4-4
gst-plugins-bad-libs 1.18.4-3 1.18.4-4
gthumb 3.10.2-1 3.10.3-1
gtk-update-icon-cache 1:4.2.0-2 1:4.2.0-5
gtk-vnc 1.0.0-2 1.2.0-1
gtk3 1:3.24.28-1 1:3.24.28-4
gtk4 1:4.2.0-2 1:4.2.0-5
gtk4-docs 1:4.2.0-2 1:4.2.0-5
ibus-typing-booster 2.10.2-1 2.11.2-1
imagemagick 7.0.11.6-1 7.0.11.7-1
imagemagick-doc 7.0.11.6-1 7.0.11.7-1
inkscape 1.0.2-4 1.0.2-5
ipset 7.10-1 7.11-1
irqbalance 1.7.0-1 1.8.0-1
kactivities 5.80.0-1 5.81.0-1
kactivities-stats 5.80.0-1 5.81.0-1
kactivitymanagerd 5.21.3-1 5.21.4-1
kapidox 5.80.0-1 5.81.0-1
karchive 5.80.0-1 5.81.0-1
kauth 5.80.0-1 5.81.0-1
kbookmarks 5.80.0-1 5.81.0-1
kcalendarcore 5.80.0-1 5.81.0-1
kcmutils 5.80.0-1 5.81.0-1
kcodecs 5.80.0-1 5.81.0-1
kcompletion 5.80.0-1 5.81.0-1
kconfig 5.80.0-1 5.81.0-1
kconfigwidgets 5.80.0-1 5.81.0-1
kcontacts 1:5.80.0-1 1:5.81.0-1
kcoreaddons 5.80.0-1 5.81.0-1
kcrash 5.80.0-1 5.81.0-1
kdav 1:5.80.0-1 1:5.81.0-1
kdbusaddons 5.80.0-1 5.81.0-1
kde-cli-tools 5.21.3-1 5.21.4-1
kde-gtk-config 5.21.3-1 5.21.4-1
kdeclarative 5.80.0-1 5.81.0-1
kdecoration 5.21.3-1 5.21.4-1
kded 5.80.0-1 5.81.0-1
kdelibs4support 5.80.0-1 5.81.0-1
kdenlive 20.12.3-1 20.12.3-2
kdeplasma-addons 5.21.3-1 5.21.4-1
kdesignerplugin 5.80.0-1 5.81.0-1
kdesu 5.80.0-1 5.81.0-1
kdewebkit 5.80.0-1 5.81.0-1
kdnssd 5.80.0-1 5.81.0-1
kdoctools 5.80.0-1 5.81.0-1
kemoticons 5.80.0-1 5.81.0-1
kfilemetadata 5.80.0-1 5.81.0-1
kgamma5 5.21.3-1 5.21.4-1
kglobalaccel 5.80.0-2 5.81.0-1
kguiaddons 5.80.0-1 5.81.0-1
kholidays 1:5.80.0-1 1:5.81.0-1
khotkeys 5.21.3-1 5.21.4-1
khtml 5.80.0-1 5.81.0-1
ki18n 5.80.0-1 5.81.0-1
kiconthemes 5.80.0-2 5.81.0-1
kidletime 5.80.0-1 5.81.0-1
kimageformats 5.80.0-1 5.81.0-1
kinfocenter 5.21.3-1 5.21.4-1
kinit 5.80.0-1 5.81.0-1
kio 5.80.1-2 5.81.0-1
kirigami2 5.80.0-1 5.81.0-1
kitemmodels 5.80.0-1 5.81.0-1
kitemviews 5.80.0-1 5.81.0-1
kitinerary 20.12.3-1 20.12.3-2
kjobwidgets 5.80.0-1 5.81.0-1
kjs 5.80.0-1 5.81.0-1
kjsembed 5.80.0-1 5.81.0-1
kmediaplayer 5.80.0-1 5.81.0-1
kmenuedit 5.21.3-1 5.21.4-1
knewstuff 5.80.0-1 5.81.0-1
knotifications 5.80.0-1 5.81.0-1
knotifyconfig 5.80.0-1 5.81.0-1
kpackage 5.80.0-1 5.81.0-1
kparts 5.80.0-1 5.81.0-1
kpeople 5.80.0-1 5.81.0-1
kplotting 5.80.0-1 5.81.0-1
kpty 5.80.0-1 5.81.0-1
kquickcharts 5.80.0-1 5.81.0-1
kross 5.80.0-1 5.81.0-1
kross-interpreters 20.12.3-1 20.12.3-2
krunner 5.80.0-1 5.81.0-1
kscreen 5.21.3-1 5.21.4-1
kscreenlocker 5.21.3-1 5.21.4-1
kservice 5.80.0-1 5.81.0-1
ksshaskpass 5.21.3-1 5.21.4-1
ksysguard 5.21.3-1 5.21.4-1
ktexteditor 5.80.0-1 5.81.0-1
ktextwidgets 5.80.0-1 5.81.0-1
kunitconversion 5.80.0-1 5.81.0-1
kwallet 5.80.0-1 5.81.0-1
kwallet-pam 5.21.3-1 5.21.4-1
kwayland 5.80.0-1 5.81.0-1
kwayland-integration 5.21.3-1 5.21.4-1
kwayland-server 5.21.3-1 5.21.4-1
kwidgetsaddons 5.80.0-1 5.81.0-1
kwin 5.21.3-1 5.21.4-1
kwindowsystem 5.80.0-1 5.81.0-1
kwrited 5.21.3-1 5.21.4-1
kxmlgui 5.80.0-1 5.81.0-1
kxmlrpcclient 5.80.0-1 5.81.0-1
lablgtk2 2.18.11-2 2.18.11-3
libbluray 1.2.1-1 1.3.0-1
libcdr 0.1.6-3 0.1.7-1
libcmis 0.5.2-6 0.5.2-7
libcups 1:2.3.3op2-1 1:2.3.3op2-2
libdrm 2.4.104-1 2.4.105-1
libfido2 1.6.0-1 1.7.0-2
libgdm 3.38.2.1-1 40.0-1
libgweather 3.36.1-2 40.0-1
libhandy 1.2.0-2 1.2.1-1
libheif 1.11.0-2 1.11.0-3
libkscreen 5.21.3-1 5.21.4-1
libksysguard 5.21.3.1-1 5.21.4-1
libmwaw 0.3.17-1 0.3.18-1
libpurple 2.14.2-1 2.14.3-1
libqalculate 3.17.0-1 3.18.0-1
libreoffice-fresh 7.1.2-1 7.1.2-2
libreoffice-fresh-sdk 7.1.2-1 7.1.2-2
libreoffice-still 7.0.5-1 7.0.5-2
libreoffice-still-sdk 7.0.5-1 7.0.5-2
librsvg 2:2.50.3-1 2:2.50.4-1
libsynctex 2020.54586-11 2020.54586-12
libunrar 1:6.0.4-1 1:6.0.5-1
libupnp 1.14.4-1 1.14.5-1
libva-mesa-driver 21.0.1-1 21.0.2-1
libwebsockets 4.1.6-1 4.1.6-2
libxkbcommon 1.1.0-2 1.2.1-1
libxkbcommon-doc 1.1.0-2 1.2.1-1
libxkbcommon-x11 1.1.0-2 1.2.1-1
liferea 1.13.4-1 1.13.5-1
lua 5.4.2-1 5.4.3-1
mesa 21.0.1-1 21.0.2-1
mesa-vdpau 21.0.1-1 21.0.2-1
meson 0.57.1-1 0.57.2-1
metis 5.1.0.p10-1 5.1.0.p10-2
milou 5.21.3-1 5.21.4-1
mkvtoolnix-cli 55.0.0-2 56.1.0-1
mkvtoolnix-gui 55.0.0-2 56.1.0-1
mlt 6.24.0-1 6.26.1-1
modemmanager-qt 5.80.0-1 5.81.0-1
msmtp 1.8.13-1 1.8.14-1
msmtp-mta 1.8.13-1 1.8.14-1
mutter 3.38.4-2 40.0-3
networkmanager-qt 5.80.0-1 5.81.0-1
opencl-mesa 21.0.1-1 21.0.2-1
opencv 4.5.1-1 4.5.2-2
opencv-samples 4.5.1-1 4.5.2-2
oxygen 5.21.3-1 5.21.4-1
oxygen-icons 1:5.80.0-1 1:5.81.0-1
oxygen-icons-svg 1:5.80.0-1 1:5.81.0-1
p7zip 1:17.03-1 1:17.04-1
pahole 1.20-2 1.21-1
perl-crypt-openssl-guess 0.11-5 0.12-1
perl-digest-hmac 1.03-9 1.04-1
perl-net-cidr-lite 0.21-9 0.22-1
pidgin 2.14.2-1 2.14.3-1
pipewire-alsa 1:0.3.24-1 1:0.3.25-1
pipewire-docs 1:0.3.24-1 1:0.3.25-1
pipewire-jack 1:0.3.24-1 1:0.3.25-1
pipewire-media-session 1:0.3.24-1 1:0.3.25-1
pipewire-pulse 1:0.3.24-1 1:0.3.25-1
plasma-browser-integration 5.21.3-1 5.21.4-1
plasma-desktop 5.21.3-1 5.21.4-1
plasma-disks 5.21.3-1 5.21.4-1
plasma-firewall 5.21.3-1 5.21.4-1
plasma-framework 5.80.0-1 5.81.0-1
plasma-integration 5.21.3-1 5.21.4-1
plasma-nm 5.21.3-1 5.21.4-1
plasma-pa 5.21.3-1 5.21.4-1
plasma-sdk 5.21.3-1 5.21.4-1
plasma-systemmonitor 5.21.3-1 5.21.4-1
plasma-thunderbolt 5.21.3-1 5.21.4-1
plasma-vault 5.21.3-1 5.21.4-1
plasma-wayland-protocols 1.2.0-2 1.2.1-1
plasma-wayland-session 5.21.3-1 5.21.4-1
plasma-workspace 5.21.3-1 5.21.4-1
plasma-workspace-wallpapers 5.21.3-1 5.21.4-1
polkit-kde-agent 5.21.3-1 5.21.4-1
poppler 21.03.0-1 21.04.0-2
poppler-glib 21.03.0-1 21.04.0-2
poppler-qt5 21.03.0-1 21.04.0-2
poppler-qt6 21.03.0-1 21.04.0-2
portaudio 1:19.6.0-7 1:19.7.0-1
postfix 3.5.9-2 3.5.10-1
postfix-cdb 3.5.9-2 3.5.10-1
postfix-ldap 3.5.9-2 3.5.10-1
postfix-lmdb 3.5.9-2 3.5.10-1
postfix-mysql 3.5.9-2 3.5.10-1
postfix-pcre 3.5.9-2 3.5.10-1
postfix-pgsql 3.5.9-2 3.5.10-1
postfix-sqlite 3.5.9-2 3.5.10-1
powerdevil 5.21.3-1 5.21.4-1
prison 5.80.0-1 5.81.0-1
protobuf 3.15.6-1 3.15.7-1
psutils 2.04-1 2.05-1
purpose 5.80.0-1 5.81.0-1
pyside6 6.0.2-1 6.0.3-1
python 3.9.2-1 3.9.3-1.1
python-astroid 2.5.2-1 2.5.3-1
python-django 3.1.7-1 3.2-1
python-protobuf 3.15.6-1 3.15.7-1
python-tests 3.9.2-1 3.9.3-1.1
qalculate-gtk 3.17.0-1 3.18.0-1
qqc2-desktop-style 5.80.0-1 5.81.0-1
qt5-base 5.15.2-5 5.15.2+kde+r172-1
qt5-declarative 5.15.2-1 5.15.2+kde+r24-1
qt5-svg 5.15.2-2 5.15.2+kde+r5-1
qt5-tools 5.15.2-3 5.15.2+kde+r17-1
qt5-wayland 5.15.2-1 5.15.2+kde+r19-1
qt5-xcb-private-headers 5.15.2-5 5.15.2+kde+r172-1
rav1e 0.4.0-1 0.4.1-1
rrdtool 1.7.2-5 1.7.2-7
ruby 2.7.2-1 3.0.1-1
ruby-docs 2.7.2-1 3.0.1-1
rubygems 3.2.13-1 3.2.15-1
sane-airscan 0.99.24-1 0.99.25-1
sddm-kcm 5.21.3-1 5.21.4-1
seahorse 1:3.38.1-1 1:40.0-1
shiboken6 6.0.2-1 6.0.3-1
sof-firmware 1.6.1-1 1.7-2
solid 5.80.0-1 5.81.0-1
sonnet 5.80.0-1 5.81.0-1
subversion 1.14.1-1 1.14.1-2
syndication 5.80.0-1 5.81.0-1
syntax-highlighting 5.80.0-1 5.81.0-1
systemsettings 5.21.3-1 5.21.4-1
texlive-bin 2020.54586-11 2020.54586-12
threadweaver 5.80.0-1 5.81.0-1
tomcat-native 1.2.26-1 1.2.28-1
tomcat10 10.0.4-1 10.0.5-1
tomcat8 8.5.63-1 8.5.65-1
tomcat9 9.0.44-1 9.0.45-1
vala 0.52.0-1 0.52.2-1
vlc 3.0.12-3 3.0.12-4
vorbis-tools 1.4.2-1 1.4.2-2
vulkan-broadcom 21.0.1-1 21.0.2-1
vulkan-headers 1:1.2.173-1 1:1.2.174-1
vulkan-html-docs 1:1.2.173-1 1:1.2.174-1
vulkan-mesa-layers 21.0.1-1 21.0.2-1
vulkan-radeon 21.0.1-1 21.0.2-1
vulkan-swrast 21.0.1-1 21.0.2-1
wpebackend-fdo 1.8.2-1 1.8.3-1
xdg-desktop-portal-kde 5.21.3-1 5.21.4-1
xf86-input-libinput 0.30.0-1 1.0.0-1
xfce4-settings 4.16.0-1 4.16.1-1
xorg-server 1.20.10-3 1.20.11-1
xorg-server-common 1.20.10-3 1.20.11-1
xorg-server-devel 1.20.10-3 1.20.11-1
xorg-server-xephyr 1.20.10-3 1.20.11-1
xorg-server-xnest 1.20.10-3 1.20.11-1
xorg-server-xvfb 1.20.10-3 1.20.11-1
xorg-xwayland 21.1.0-1 21.1.1-1
zabbix-agent 5.2.5-1 5.2.6-1
zabbix-agent2 5.2.5-1 5.2.6-1
zabbix-frontend-php 5.2.5-1 5.2.6-1
zabbix-proxy 5.2.5-1 5.2.6-1
zabbix-server 5.2.5-1 5.2.6-1
aom-docs - 3.0.0-2
gdk-pixbuf2-docs - 2.42.6-1
gtk3-demos - 1:3.24.28-4
gtk3-docs - 1:3.24.28-4
gtk4-demos - 1:4.2.0-5
pytest-pacman - 0.1-1
python-opencv - 4.5.2-2
python-pytest-pacman - 0.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi20.12.2.r12474.g82c621a1e-120.12.3.r12484.g69df5152e-1
akonadi-calendar20.12.2.r1916.geef1bbf-120.12.3.r1920.gf2fea67-1
akonadi-calendar-tools20.12.3.r855.g9656768-120.12.3.r859.gb022da8-1
akonadi-contacts20.12.2.r2988.g1d32a51b-120.12.3.r2994.g4b34a6b0-1
akonadi-import-wizard20.12.2.r1693.g8e9e54f-120.12.3.r1697.ge0c0479-1
akonadi-mime20.12.2.r1604.g7aee356-120.12.3.r1608.g34dfe23-1
akonadi-notes20.12.2.r992.g5305c2e-120.12.3.r996.g5b56725-1
akonadi-search20.12.2.r1073.gbcfb7b9-120.12.3.r1080.g970bf08-1
akonadiconsole20.12.3.r1475.g369dd50-120.12.3.r1478.g5bd4c44-1
akregator20.12.3.r6082.g6969aea6-120.12.3.r6107.g141afcb3-1
analitza20.12.2.r2324.g66251bf2-120.12.3.r2325.gb9bae14e-1
ark20.12.2.r4498.g0171728f-120.12.3.r4508.g95fe9127-1
artikulate20.12.2.r1377.g4ec0047-120.12.3.r1378.g78963af-1
attica5.80.0.r797.gd8deade-15.80.0.r801.g240d07d-1
audiocd-kio20.12.3.r1011.g10f647f-120.12.3.r1012.gcf1325b-1
baloo5.80.0.r2939.g097eb7d0-15.80.0.r2953.ged7eb3c1-1
baloo-widgets20.12.2.r676.g6b36922-120.12.3.r677.g8edfb07-1
blinken20.12.2.r615.g8ef251c-120.12.3.r616.g4969edb-1
bluedevil1:5.21.0.r2244.gc711dfe7-11:5.21.3.r2255.g4b560040-1
bluez-qt5.80.0.r644.g013e7b5-15.80.0.r648.g344294c-1
bomber20.12.2.r510.gc2ecc8f-120.12.3.r511.g7b34d7e-1
bovo20.12.2.r721.gcefadb2-120.12.3.r722.g5801c21-1
breeze5.21.0.r2166.g80aeb86c-15.21.3.r2169.gd201a1f1-1
breeze-grub 5.21.0.r8.g2c1d5e7-1 5.21.3.r8.g2c1d5e7-1
breeze-gtk5.21.0.r412.ge989639-15.21.3.r413.gc57938a-1
breeze-icons5.80.0.r1724.gff3cc2de-15.80.0.r1730.g219d014d-1
buho 1.2.1.r5.g84c1cb7-1 1.2.1.r6.g7fb580a-1
calendarsupport20.12.2.r501.g5b394e8-120.12.3.r506.g6cb3e17-1
calindori 1.4.r9.gc05f1f0-1 1.4.r10.g44271c2-1
cervisia20.12.2.r1632.g4eb5d8e-120.12.3.r1634.g2285818-1
discover5.21.0.r8053.g662f5ce2-15.21.3.r8102.g95afc5ed-1
dolphin20.12.2.r6531.g69881f93b-120.12.3.r6545.g208481478-1
dolphin-plugins20.12.2.r560.g6bc584e-120.12.3.r561.gd7f03ea-1
dragon20.12.3.r995.g56e66c3-120.12.3.r996.gd8688c0-1
drkonqi5.21.0.r593.g42aca174-15.21.3.r614.g8ce0d2df-1
elisa20.12.3.r2654.gc75c1cac-120.12.3.r2667.gf51c4402-1
eventviews20.12.2.r622.ge6933fe-120.12.3.r626.g42cb93e-1
extra-cmake-modules5.80.0.r3275.gd88db6a-15.80.0.r3281.gec86df3-1
filelight20.12.2.r948.g52915b7-120.12.3.r951.g66cf709-1
frameworkintegration5.80.0.r573.gb8da0f3-15.80.0.r577.gf53ab45-1
granatier20.12.2.r905.g58e3541-120.12.3.r909.g0a2ac13-1
grantlee-editor20.12.3.r734.g7f8d4be-120.12.3.r738.gc8aef7b-1
grantleetheme20.12.2.r309.ga238ac9-120.12.3.r313.g3500a67-1
gwenview20.12.3.r6548.g75588f73-120.12.3.r6557.gbf23ad3a-1
incidenceeditor20.12.2.r695.g1466e01-120.12.3.r701.ga3ed0c9-1
itinerary20.12.3.r1238.g2e1ddab-120.12.3.r1262.gdba157f-1
juk20.12.3.r3098.g476c201e-120.12.3.r3099.g5059f84b-1
k3b1:20.12.3.r6600.g73bb928ab-11:20.12.3.r6601.g724f8ae94-1
kaccounts-integration20.12.2.r1205.g423deda-120.12.3.r1205.g423deda-1
kaccounts-providers20.12.2.r374.g297cd85-120.12.3.r374.g297cd85-1
kactivities5.80.0.r1335.g04f61a7-15.80.0.r1339.g9fbbc04-1
kactivities-stats5.80.0.r340.g12cc0bf-15.80.0.r345.g5da7f8c-1
kactivitymanagerd5.21.0.r1333.g70226e8-15.21.3.r1341.g7cdd9c3-1
kaddressbook20.12.2.r5941.g78394da9-120.12.3.r5946.ge2661cb1-1
kajongg20.12.2.r4179.g44663590-120.12.3.r4180.g6e04e94e-1
kalarm20.12.3.r6345.gf054bf96-120.12.3.r6350.g6e91e424-1
kalarmcal20.12.2.r1098.gb6e7ecb-120.12.3.r1102.g30d349e-1
kalgebra20.12.2.r2016.g8002ccd-120.12.3.r2017.gd9d7fc0-1
kalzium20.12.2.r4246.g588a2e7d-120.12.3.r4248.g8728cc85-1
kamera20.12.3.r648.g1545cf6-120.12.3.r650.gc3c0bff-1
kamoso20.12.3.r1417.geb8c618-120.12.3.r1418.ge4cbead-1
kanagram20.12.2.r1271.gaf3a2a1-120.12.3.r1272.g081344b-1
kapidox5.80.0.r519.gc41f1bb-15.80.0.r521.g10593cb-1
kapman20.12.2.r577.g7b402c2-120.12.3.r578.gd7d703b-1
kapptemplate20.12.2.r946.gee7d314-120.12.3.r947.g522b80d-1
karchive5.80.0.r462.g1065010-15.80.0.r469.g4da55cf-1
kate20.12.2.r17991.gac0842e6f-120.12.3.r18016.gba26d1ed5-1
katomic20.12.2.r904.g1f0d58d-120.12.3.r905.gc53aa06-1
kauth5.80.0.r421.g4fb774d-15.80.0.r427.g70c94a5-1
kbackup20.12.2.r351.g9a6860a-120.12.3.r352.g2ce1fc8-1
kblackbox20.12.2.r709.gde572d6-120.12.3.r710.g4509053-1
kblocks20.12.2.r625.g38b3e7a-120.12.3.r626.gb919841-1
kbookmarks5.80.0.r395.g03ef2d8-15.80.0.r400.gcf7659a-1
kbounce20.12.2.r787.gbfae1e2-120.12.3.r788.g223a807-1
kbreakout20.12.2.r843.gf97feab-120.12.3.r844.g2b28e16-1
kbruch20.12.2.r805.g850ef21-120.12.3.r807.g08ef14c-1
kcachegrind20.12.2.r1143.g55e1a9b-120.12.3.r1145.g2037095-1
kcachegrind-common20.12.2.r1143.g55e1a9b-120.12.3.r1145.g2037095-1
kcalc20.12.2.r1480.g3d4e60d-120.12.3.r1481.g596b529-1
kcalendarcore5.80.0.r1188.gac71748d3-15.80.0.r1193.g23a7ddd80-1
kcalutils20.12.2.r822.g20d06ee57-120.12.3.r826.g446775693-1
kcharselect20.12.2.r455.g6700cbe-120.12.3.r457.gad8d0c4-1
kclock 0.4.0.r49.g8f57bcb-1 0.4.0.r57.ge8f982d-1
kcmutils5.80.0.r487.g6227a8e-15.80.0.r494.ge078521-1
kcodecs5.80.0.r353.g61107e6-15.80.0.r357.gf968501-1
kcolorchooser20.12.3.r213.g1417e95-120.12.3.r214.g2abe7d1-1
kcompletion5.79.0.r426.g808bccb-15.80.0.r432.ga54c6ba-1
kconfig5.80.0.r806.ge5aa388-15.80.0.r815.g163cebc-1
kconfigwidgets5.80.0.r550.g942704d-15.80.0.r557.g6893da9-1
kcontacts1:5.80.0.r3225.g9d7dc0fa-11:5.80.0.r3230.gd3f3a182-1
kcoreaddons5.80.0.r1196.gac9f6000-15.80.0.r1205.gdfd8e51f-1
kcrash5.80.0.r366.g658f35a-15.80.0.r372.g45c86cb-1
kcron20.12.2.r760.g6f7bc3b-120.12.3.r762.ga4e35cb-1
kdav1:5.80.0.r1272.gf3fd27a-11:5.80.0.r1276.g2e4e265-1
kdbusaddons5.80.0.r346.ge31e79b-15.80.0.r352.g1392ad1-1
kde-cli-tools5.21.0.r1831.gb87017b-15.21.3.r1834.g8dfe577-1
kde-dev-scripts20.12.2.r4123.g1c7b507-120.12.3.r4126.gbcf19d8-1
kde-dev-utils20.12.2.r545.g95fc502-120.12.3.r546.g9277695-1
kde-gtk-config5.21.0.r882.gaa601b6-15.21.3.r886.gf734519-1
kdebugsettings20.12.2.r790.g3e60e49-120.12.3.r794.gd1f88e7-1
kdeclarative5.80.0.r876.g85f764d-15.80.0.r880.g4f8797f-1
kdeconnect20.12.3.r3172.g9a58c34a-120.12.3.r3180.gb00acad7-1
kdecoration5.21.0.r254.g9410cb5-15.21.3.r256.gafe430f-1
kded5.80.0.r389.g2353103-15.80.0.r393.gb0bf656-1
kdeedu-data20.12.2.r15.g8dc3dee-120.12.3.r15.g8dc3dee-1
kdegraphics-mobipocket20.12.2.r258.g036fd81-120.12.3.r258.g036fd81-1
kdelibs4support5.79.0.r1003.ga1a1c1a4-15.80.0.r1007.g572f3b54-1
kdenlive20.12.3.r14258.gf4dabe7f5-120.12.3.r14337.g543b8cc75-1
kdepim-addons20.12.3.r4035.g51f49171-120.12.3.r4051.gd9ce1b02-1
kdepim-runtime20.12.2.r15062.g9d7fe30f0-120.12.3.r15072.g2eca2d116-1
kdeplasma-addons5.21.0.r8484.gd479c78b6-15.21.3.r8497.gf7a25f465-1
kdesdk-kioslaves20.12.2.r487.gf9c1198-120.12.3.r487.gf9c1198-1
kdesdk-thumbnailers20.12.2.r68.gb71f553-120.12.3.r68.gb71f553-1
kdesignerplugin5.80.0.r313.g3d38a41-15.80.0.r318.g7b118c8-1
kdesu5.80.0.r448.ga7f811d-15.80.0.r453.g23f34bd-1
kdewebkit5.79.0.r259.gf2b87cc-15.80.0.r264.g57d8ec2-1
kdf20.12.2.r779.g2264b14-120.12.3.r779.g2264b14-1
kdialog20.12.2.r1171.g6657eb574-120.12.3.r1172.gc97605380-1
kdiamond20.12.2.r654.g399339e-120.12.3.r655.gd5d245c-1
kdnssd5.80.0.r295.ga7158bb-15.80.0.r299.g36057ea-1
kdoctools5.80.0.r597.g793baa8-15.80.0.r600.g2737ea8-1
keditbookmarks20.12.2.r2732.gcdde48e50-120.12.3.r2734.gf8939368f-1
kemoticons5.80.0.r361.geba0e1f-15.80.0.r365.g54a56b4-1
kfilemetadata5.80.0.r771.g91d6f59-15.80.0.r776.ge9ffd77-1
kfind20.12.2.r2615.g51cc5aa3e-120.12.3.r2622.g9bb481599-1
kfloppy20.12.2.r738.gb00a470-120.12.3.r740.g99ab544-1
kfourinline20.12.2.r963.g85d037d-120.12.3.r965.g8e0b27b-1
kgamma55.21.0.r445.g77553e8-15.21.3.r446.g34d3a19-1
kgeography20.12.2.r1100.gfa2a53b-120.12.3.r1105.g982bae9-1
kget20.12.3.r3091.gbb455273-120.12.3.r3092.g00f5fd5e-1
kgoldrunner20.12.2.r1216.g09f9811-120.12.3.r1217.gf9286f9-1
kgpg20.12.2.r3111.gf3990e47-120.12.3.r3112.gc620b3d8-1
kguiaddons5.80.0.r349.gda49268-15.80.0.r355.g144a759-1
khangman20.12.2.r1552.g0ff1e25-120.12.3.r1553.ga0af62f-1
khelpcenter20.12.2.r2652.g5484b476-120.12.3.r2654.g1bd474d2-1
kholidays1:5.80.0.r918.gfb2b896-11:5.80.0.r926.g5b526c8-1
khotkeys5.21.0.r2062.g65890d9-15.21.3.r2063.gd3c119e-1
khtml5.79.0.r532.gc27fc10-15.80.0.r538.g5f61d47-1
ki18n5.80.0.r449.g2d3b6fe-15.80.0.r452.ga04cdc6-1
kiconthemes5.80.0.r505.gb36a237-15.80.0.r511.g1014c84-1
kidentitymanagement20.12.2.r3767.g209c9e5d-120.12.3.r3771.gbfd29ad5-1
kidletime5.80.0.r288.g9568a39-15.80.0.r291.g77cda21-1
kig20.12.2.r3115.g2a0c0ba0-120.12.3.r3117.g2ad8949c-1
kigo20.12.2.r502.g85692eb-120.12.3.r503.ge5774f3-1
killbots20.12.2.r717.g9c87c3e-120.12.3.r718.gd531413-1
kimageformats5.80.0.r323.g2755f74-15.80.0.r329.g224f892-1
kimagemapeditor20.12.3.r454.g6f28d0b-120.12.3.r455.ge15a8ed-1
kimap20.12.2.r1075.g9a32f1b-120.12.3.r1079.g284c67e-1
kinfocenter5.21.0.r1800.gc42aa16-15.21.3.r1802.g876c3aa-1
kinit5.80.0.r384.g824f579-15.80.0.r390.g1a3e3b8-1
kio5.80.0.r4608.gdb71aef6-15.80.0.r4650.gcdace1e5-1
kio-extras20.12.3.r6986.gb235e6e6-120.12.3.r6991.gb204230d-1
kio-gdrive20.12.3.r551.gc1eda10-120.12.3.r552.gd6898be-1
kipi-plugins20.12.3.r12058.g97feceaa3-120.12.3.r12059.ge72ef84fa-1
kirigami-gallery20.12.2.r193.g2977763-120.12.3.r198.g34fdb39-1
kirigami25.80.0.r2726.gfb2a7db8-15.80.0.r2752.gfd2548e8-1
kiriki20.12.2.r407.gf41b7b5-120.12.3.r408.gd517cca-1
kitemmodels5.80.0.r523.gbfb3867-15.80.0.r529.g38787d3-1
kitemviews5.80.0.r314.g8513135-15.80.0.r319.gaf5b12e-1
kiten20.12.2.r1132.ga84aa45-120.12.3.r1134.ge49662d-1
kitinerary20.12.2.r1697.g9814ddd-120.12.3.r1708.g4943496-1
kjobwidgets5.80.0.r349.g6435a9f-15.80.0.r355.gc5781ab-1
kjs5.80.0.r316.g1f6c85a-15.80.0.r320.g71224d1-1
kjsembed5.79.0.r281.g5d60c50-15.80.0.r286.gc491def-1
kjumpingcube20.12.2.r768.g743dc3d-120.12.3.r769.gcefddb2-1
kldap20.12.2.r836.g40e8b49-120.12.3.r841.g882d973-1
kleopatra20.12.3.r5772.g7f416826-120.12.3.r5783.gf881116a-1
klettres20.12.2.r900.gcf521e9-120.12.3.r900.gcf521e9-1
klickety20.12.2.r607.g6debdf8-120.12.3.r609.g25b91ec-1
klines20.12.2.r729.g8c6cd66-120.12.3.r730.g2467b89-1
kmag20.12.2.r677.ge892328-120.12.3.r678.g77931cd-1
kmahjongg20.12.2.r1447.gc7f353b-120.12.3.r1449.gd264c69-1
kmail20.12.3.r25636.g8443f9c88-120.12.3.r25661.g709fb9a0d-1
kmail-account-wizard20.12.3.r770.g82d977b-120.12.3.r775.g9eee0c0-1
kmailtransport20.12.2.r1586.g9ec34d3-120.12.3.r1592.g6b3ba37-1
kmbox20.12.2.r506.g133e1c2-120.12.3.r510.gb172a78-1
kmediaplayer5.79.0.r273.gaf93f13-15.80.0.r278.gbb7e44a-1
kmenuedit5.21.0.r957.g0248922-15.21.3.r959.gc2befff-1
kmime20.12.2.r1420.g0e7ef26-120.12.3.r1424.gbdad959-1
kmines20.12.2.r1701.g10fe6ae-120.12.3.r1702.g6a8f728-1
kmix20.12.3.r2355.g44cf1b34-120.12.3.r2356.gfda6e5fc-1
kmousetool20.12.2.r383.gbc1f3f6-120.12.3.r383.gbc1f3f6-1
kmouth20.12.2.r682.g32f259e-120.12.3.r682.g32f259e-1
kmplot20.12.2.r1447.g5e3fffe-120.12.3.r1450.g879b2d0-1
knavalbattle20.12.2.r1357.gf3864fb-120.12.3.r1358.g3240679-1
knetwalk20.12.2.r641.g65794d1-120.12.3.r642.gfb66dc7-1
knewstuff5.80.0.r1068.g2f2499cc-15.80.0.r1074.ga90a326f-1
knights20.12.3.r1039.g9000e91-120.12.3.r1040.g7213f0b-1
knotes20.12.2.r3428.ga09a5d72-120.12.3.r3437.gb8726078-1
knotifications5.80.0.r631.g85d7912-15.80.0.r644.gff4647e-1
knotifyconfig5.80.0.r328.g3af435c-15.80.0.r332.g9045be0-1
kolf20.12.3.r1410.g2b43183-120.12.3.r1411.g2e5a74d-1
kollision20.12.3.r477.g6645b5c-120.12.3.r478.g276597b-1
kolourpaint20.12.3.r2336.g0dfd68ad-120.12.3.r2337.gdbb0164f-1
kompare20.12.2.r1095.g95da14b-120.12.3.r1096.gb136844-1
konqueror20.12.3.r14879.g779c1f43e-120.12.3.r14885.g0cdc2185c-1
konquest20.12.3.r878.ge6f67a1-120.12.3.r880.g2ed447b-1
konsole20.12.2.r7750.gba81c56a-120.12.3.r7760.gc66d1139-1
kontact20.12.2.r5278.gdc031be5-120.12.3.r5297.gc62597aa-1
kontactinterface20.12.2.r598.gee97fa8-120.12.3.r602.g236327d-1
kontrast20.12.2.r157.g13c7fc0-120.12.3.r158.gaeb811f-1
konversation20.12.3.r8944.g9288fab5-120.12.3.r8945.gbc117e30-1
korganizer20.12.2.r11311.gcbda659ed-120.12.3.r11320.ga0fb045e6-1
kosmindoormap20.12.2.r591.g8f62cfd-220.12.3.r594.g794672e-1
kpackage5.80.0.r645.ga665887-15.80.0.r652.g3465e4e-1
kparts5.80.0.r487.gfc14959-15.80.0.r491.g6ea154f-1
kpatience20.12.3.r2525.ge420437-120.12.3.r2526.gf779df0-1
kpeople5.80.0.r1304.g144d6a9-15.80.0.r1309.g262301f-1
kpimtextedit20.12.2.r1354.gf4ded88-120.12.3.r1363.gb8ac085-1
kpkpass20.12.2.r204.g0b4a6a2-120.12.3.r208.g9e9523f-1
kplotting5.80.0.r270.g7ce7156-15.80.0.r273.g382288b-1
kpmcore20.12.2.r1191.gce39e14-120.12.3.r1191.gce39e14-1
kpty5.80.0.r311.g36e200c-15.80.0.r316.g9b2af2d-1
kpublictransport20.12.2.r1566.ga9135c3-120.12.3.r1579.g291fd20-1
kqtquickcharts20.12.2.r74.g264af68-120.12.3.r74.g264af68-1
kquickcharts5.80.0.r432.g2f868bf-15.80.0.r435.ge080adc-1
krdc20.12.3.r1501.gccaed1c-120.12.3.r1502.g8750c1b-1
kreversi20.12.3.r1204.g64fefc2-120.12.3.r1206.gbc78176-1
krfb20.12.3.r1377.g730e4d7-120.12.3.r1378.g0afcfc8-1
kross5.79.0.r313.g65b6c62-15.80.0.r317.g4b8548a-1
kross-interpreters20.12.2.r722.g8d54326-120.12.3.r722.g8d54326-1
kruler20.12.3.r680.g6efab8c-120.12.3.r682.g4b6a1d5-1
krunner5.80.0.r594.g60c2088-15.80.0.r601.gd56637f-1
kscreen5.21.0.r1314.g47006b9-15.21.3.r1318.g197de6d-1
kscreenlocker5.21.0.r825.g63a4166-15.21.3.r831.gaef2a2e-1
kservice5.80.0.r885.g2536db8-15.80.0.r889.gf6d98db-1
kshisen20.12.3.r1174.g66b50ab-120.12.3.r1175.ga04351f-1
ksirk20.12.3.r951.g3d8e528-120.12.3.r953.g2d977b6-1
ksmtp20.12.2.r334.g49b2874-120.12.3.r338.ge448b1f-1
ksnakeduel20.12.3.r785.gd0848f0-120.12.3.r786.g011692a-1
kspaceduel20.12.3.r612.g5f55bce-120.12.3.r613.g89b8ef9-1
ksquares20.12.3.r503.gddb98cd-120.12.3.r504.gee731e6-1
ksshaskpass5.21.0.r186.gc186537-15.21.3.r187.g6da7660-1
ksudoku20.12.3.r1037.g948c839-120.12.3.r1038.g8a0a4d3-1
ksysguard5.21.0.r3495.gbc64affe-15.21.3.r3497.gf4c1c15f-1
ksystemlog20.12.2.r622.g830aa1d-120.12.3.r626.g22ad30d-1
kteatime20.12.2.r707.gd6edcd0-120.12.3.r710.gd412ef5-1
ktexteditor5.80.0.r2775.g7dfa4816-15.80.0.r2797.g189a2e0c-1
ktextwidgets5.80.0.r382.g28d5027-15.80.0.r386.g09b635d-1
ktimer20.12.2.r451.g2cac2d5-120.12.3.r452.ge7c988d-1
ktnef20.12.2.r632.ga63e2e1-120.12.3.r636.gc5189ba-1
ktorrent20.12.3.r2732.gfa6b7a38-120.12.3.r2735.gfa3a6441-1
ktouch20.12.2.r2122.g4c4e5d9-120.12.3.r2123.g584b3b8-1
ktuberling20.12.3.r993.gf92e649-120.12.3.r994.g2cb9d55-1
kturtle20.12.2.r1103.g0a2e913-120.12.3.r1104.g1d2c263-1
kubrick20.12.3.r358.g4759701-120.12.3.r359.gb0c8695-1
kunitconversion5.80.0.r349.gdc81767-15.80.0.r353.g3779944-1
kwallet5.80.0.r1052.gbba12a1-15.80.0.r1057.g97c3060-1
kwallet-pam5.21.0.r236.g55d6954-15.21.3.r236.g55d6954-1
kwalletmanager20.12.2.r1174.g0604bfa-120.12.3.r1175.g292b2bd-1
kwave20.12.3.r3732.g3b8c119a-120.12.3.r3733.gdbf24bb2-1
kwayland5.80.0.r1060.g91b5a89-15.80.0.r1065.g26974c7-1
kwayland-integration5.21.0.r164.gfdfaca8-15.21.3.r165.g94b8299-1
kwayland-server5.21.0.r1287.g076b1d5-15.21.3.r1297.ga035d90-1
kweather 0.4.r54.g0b67229-1 0.4.r56.gbfa210e-1
kwidgetsaddons5.80.0.r785.gefbaf35d-15.80.0.r794.gabf30660-1
kwin5.21.0.r19135.g9168ced30-15.21.3.r19187.gbd7300215-1
kwindowsystem5.80.0.r566.gc6968eb-15.80.0.r572.g6cd7a52-1
kwinft5.20.90.r18683.g5cbb8df5b-15.20.90.r18701.g9e24ebcac-1
kwordquiz20.12.2.r1130.g671bd65-120.12.3.r1131.gbd369b7-1
kwrite20.12.2.r17991.gac0842e6f-120.12.3.r18016.gba26d1ed5-1
kwrited5.21.0.r471.ga14f8b4-15.21.3.r471.ga14f8b4-1
kxmlgui5.80.0.r731.g63d2ede-15.80.0.r738.gd8e4a18-1
kxmlrpcclient5.79.0.r434.gdc6561966-15.80.0.r438.gfcc4487d2-1
libakonadi20.12.2.r12474.g82c621a1e-120.12.3.r12484.g69df5152e-1
libgravatar20.12.2.r337.gf4c7eb1-120.12.3.r341.g08176a7-1
libkcddb20.12.2.r730.g26f095e-120.12.3.r730.g26f095e-1
libkcompactdisc20.12.2.r384.g1771e18-120.12.3.r384.g1771e18-1
libkdcraw20.12.2.r1144.g91a7df0-120.12.3.r1144.g91a7df0-1
libkdegames20.12.2.r2170.gefb845d0-120.12.3.r2170.gefb845d0-1
libkdepim20.12.2.r818.g5ab293f-120.12.3.r822.gb2901f2-1
libkeduvocdocument20.12.2.r1782.g3bf1f7b-120.12.3.r1782.g3bf1f7b-1
libkexiv220.12.2.r812.gd9dcdee-120.12.3.r812.gd9dcdee-1
libkgapi20.12.2.r1260.g79081ac-120.12.3.r1264.gd8387ee-1
libkipi20.12.2.r1247.g2fa92a1-120.12.3.r1247.g2fa92a1-1
libkleo20.12.2.r782.ga7f7089-120.12.3.r813.g36633c0-1
libkmahjongg20.12.2.r444.g2825e26-120.12.3.r444.g2825e26-1
libkomparediff220.12.2.r334.g8df3eca-120.12.3.r334.g8df3eca-1
libksane20.12.2.r511.g94015db-120.12.3.r516.g12cc1a3-1
libkscreen5.21.0.r1567.g8615b0b-15.21.3.r1569.g6df597b-1
libksieve20.12.2.r1505.gb559fe24-120.12.3.r1512.g404eb2f4-1
libksysguard5.21.0.r2086.g66882a0-15.21.3.r2093.g04e6ca9-1
libktorrent20.12.2.r510.g6940ea5-120.12.3.r510.g6940ea5-1
lokalize20.12.2.r1753.gc1a2fcb-120.12.3.r1754.g0adef52-1
lskat20.12.3.r795.g57fe206-120.12.3.r796.g1c3e7f5-1
mailcommon20.12.2.r1008.gd39553b-120.12.3.r1015.g384f9bc-1
mailimporter20.12.2.r438.g091a271-120.12.3.r442.g2e01c62-1
maliit-keyboard r2077.g320d08b2-1 r2079.g1a8af6de-1
marble20.12.2.r13289.g070623fd3-120.12.3.r13296.g7d532cc46-1
marble-common20.12.2.r13289.g070623fd3-120.12.3.r13296.g7d532cc46-1
marble-qt20.12.2.r13289.g070623fd3-120.12.3.r13296.g7d532cc46-1
markdownpart20.12.2.r62.g830ecff-120.12.3.r63.g0957c59-1
mbox-importer20.12.2.r484.g1eba1e0-120.12.3.r488.g9fb1102-1
messagelib20.12.2.r5860.g8dc86487-120.12.3.r5883.g60612a05-1
milou5.21.0.r732.g6961c82-15.21.3.r733.gd1babfb-1
minuet20.12.2.r568.g634ddcb-120.12.3.r569.g03d2652-1
modemmanager-qt5.80.0.r497.g6531b1d-15.80.0.r501.gf4a8f4f-1
networkmanager-qt5.80.0.r1090.g56ac5a3-15.80.0.r1094.g3825386-1
okular20.12.3.r9253.g1786e6c99-120.12.3.r9273.g6b26a2b4b-1
oxygen5.21.0.r4408.g458d196d-15.21.3.r4408.g458d196d-1
palapeli20.12.3.r1205.ge23ef85-120.12.3.r1207.g6b4dc7c-1
parley20.12.2.r4396.gfa6df3e1-120.12.3.r4400.ge38bf8d0-1
partitionmanager20.12.2.r1518.gbdb0d25-120.12.3.r1521.g03dd7cb-1
pim-data-exporter20.12.2.r2390.g65c2250c-120.12.3.r2399.ga3764670-1
pim-sieve-editor20.12.2.r1447.gccf70d7-120.12.3.r1460.g9084bad-1
pimcommon20.12.2.r1025.g081f1d3-120.12.3.r1032.g695bd58-1
plasma-browser-integration5.21.0.r1225.g797369e2-15.21.3.r1229.g3d8f384b-1
plasma-desktop5.21.0.r8292.gf4eb3fb15-15.21.3.r8333.ge83a00980-1
plasma-disks5.21.0.r187.gcbdd49f-15.21.3.r196.gab86d00-1
plasma-firewall5.21.0.r476.ge752747-15.21.3.r478.g83dde94-1
plasma-framework5.80.0.r15807.g93598ec18-15.80.0.r15819.g4fdaec615-1
plasma-integration5.21.0.r509.gce1d3c9-15.21.3.r510.g6073423-1
plasma-nm5.21.0.r3024.g2a974269-15.21.3.r3032.g8f37efe9-1
plasma-pa5.21.0.r921.g52cb6b0-15.21.3.r928.gbf040ca-1
plasma-sdk5.21.0.r2255.gc6926424-15.21.3.r2262.gac2ff615-1
plasma-systemmonitor5.21.0.r387.gb120af5-15.21.3.r394.g8157210-1
plasma-thunderbolt5.21.0.r123.g0da825d-15.21.3.r124.gfab2180-1
plasma-vault5.21.0.r318.gb3bc9bd-15.21.3.r324.ge19840e-1
plasma-wayland-protocols1.2.0.r1022.ge4bc4e0-11.2.1.r1023.g742b637-1
plasma-wayland-session5.21.0.r10103.g4bc6709e4-15.21.3.r10130.g340667e70-1
plasma-workspace5.21.0.r10103.g4bc6709e4-15.21.3.r10130.g340667e70-1
plasma-workspace-wallpapers5.21.0.r254.gfe61ea3-15.21.3.r254.gfe61ea3-1
polkit-kde-agent5.21.0.r486.gb357d97-15.21.3.r487.g4dfb8b0-1
powerdevil5.21.0.r2420.g2e5512d0-15.21.3.r2423.gb70ccefd-1
poxml20.12.2.r277.ge2d4dfb-120.12.3.r277.ge2d4dfb-1
print-manager20.12.2.r1016.ged23ed6-120.12.3.r1017.gf7fd64c-1
prison5.80.0.r301.gea4a2ea-15.80.0.r304.g183140c-1
purpose5.80.0.r838.g9f8a2ca-15.80.0.r843.gb51accf-1
qcachegrind20.12.2.r1143.g55e1a9b-120.12.3.r1145.g2037095-1
qqc2-desktop-style5.80.0.r468.g5930de3-15.80.0.r475.g666b05b-1
rocs20.12.2.r3005.g6d26a1ff-120.12.3.r3009.gfb7c6b4a-1
sddm-kcm5.21.0.r571.g7949a4c-15.21.3.r573.g1575235-1
signon-kwallet-extension20.12.2.r64.g47e187d-120.12.3.r64.g47e187d-1
solid5.80.0.r654.gc15437b-15.80.0.r661.g01881b3-1
sonnet5.80.0.r595.g09601ac-15.80.0.r601.gfe0b5ba-1
spacebar r361.g2388d52-1 r362.g1b75d6a-1
spectacle20.12.3.r1067.gbe8ee0f-120.12.3.r1069.g903852d-1
step20.12.2.r1145.gf40e2d5-120.12.3.r1147.g391c16f-1
svgpart20.12.3.r155.g7a8de92-120.12.3.r156.ged9ac35-1
sweeper20.12.2.r511.g0ea4c1a-120.12.3.r512.gb582a5f-1
syndication5.79.0.r813.g2d46b97-15.80.0.r818.g41ba486-1
syntax-highlighting5.80.0.r1558.g38ca36a7-15.80.0.r1565.g74924114-1
systemsettings5.21.0.r2382.g1ec8b707-15.21.3.r2395.gba7c40a8-1
telepathy-kde-common-internals20.12.2.r1992.gef7ef33-120.12.3.r1993.g48d6a2e-1
threadweaver5.80.0.r483.gb06056f-15.80.0.r487.g0869ab1-1
umbrello20.12.2.r8225.ge4317f9f0-120.12.3.r8226.g598500713-1
xdg-desktop-portal-kde5.21.0.r343.g1138af1-15.21.3.r348.gb7ead49-1
yakuake20.12.2.r709.g02e2181-120.12.3.r709.g02e2181-1
kopeninghours -20.12.3.r264.g498bcac-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
