[ARM Stable Update] 2023-05-27 - Kernels, Firmware, Pipewire, Phosh, KDE Gear, Qemu
Hello ARM community,
this is my second stable update for our aarch64 architecture.
Most already know that we had some staff changes in our Manjaro ARM team. You might already have noticed that Dan left the team and the company. Therefore we have also to see when the next install medias for ARM SBCs and devices will been created. Dan did a lot for the ARM branch of Manjaro, including endless testing of boards and devices. Before releasing any image for an ARM device it needs to been tested on the device itself. You can find untested development builds at github.
Therefore I’ll act as the interim release manager until we found the right staff member for this job.
Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
Update Announcement
With this update we have added a lot of new stuff. Beside kernel updates you may find some to Apple Silicon and Station M3.
Some highlights:
  • Some Kernels got renewed
  • Linux-Firmware got its monthly update
  • Firefox got updated to 112.0.2 and Thunderbird to 102.10.1
  • Pipewire is at 0.3.70
  • Phoc and Phosh are now at 0.27.0
  • KDE Gear 23.04.0 includes now some Mobile Gear apps
  • QEmu is now at 8.0.0
  • Pamac-Dev got more updates to GTK4 to be more mobile friendly
  • callaudiod got renewed to 0.1.8
  • chatty is now at 0.7.3
  • Small updates to XFCE
End Of Life kernels (will be removed from repo soon):
  • linux60 (EOL on 2023-01-12) (removed from repository)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The PHP package has been updated to 8.2. If you still need 8.1, use php-legacy packages.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes (Thu May 4 07:18:02 CEST 2023)
  • arm-stable community aarch64: 528 new and 516 removed package(s)
  • arm-stable core aarch64: 53 new and 53 removed package(s)
  • arm-stable extra aarch64: 687 new and 681 removed package(s)
  • arm-stable kde-unstable aarch64: 407 new and 407 removed package(s)
See the full package list here
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
2023-02-16
Docker 23 not starting
Since the update to Docker 23, upstream is now inforcing new paths for apparmor related stuff. But there has been changes to dependencies yet. So Docker 23 will error on start.
Fix: Install apparmor from the repositories.
2023-01-03
Ethernet and Wifi not working right on kernel 6.1.2+ on some devices
Some devices have been reported to not have properly working ethernet and wifi after the update to kernel 6.1.2 and above.
Fix: Kernel 6.1.5-2 and above should have working ethernet and wifi again.
Reduced video playback performance in mpv
There has been reports of video playback performance in mpv has regressed since an update to mpv.
Fix: MPV now needs a vd-lavc-dr=no parameter to play hw acceleration supported 1080p videos smoothly.
Touch input on Firefox with Phosh not working in Firefox 108
Since the update to Firefox 108, the touch input does not work. Seems to be an issue with a couple of the changes the mobile-config brings in. PostMarketOS likely won’t fix this in their source, so we might need to carry a patch for this.
2022-11-20
OpenSSL 1.1 library not found
Some applications might still be looking for openssl 1.1.
Solution: Install openssl-1.1 package with sudo pacman -S openssl-1.1.
2022-10-31
Firefox shows wrong colors when playing video on Raspberry Pi 4
Since Mesa 22.2, Firefox has been showing weird colors when playing video on the Raspberry Pi 4. This is caused by an issue in upstream mesa, which was recently fixed.
Fix: Update to mesa 22.2.3-0.1 in the repository, which includes this fix.
Chromium in Wayland crashes with --in-process-gpu
Since Mesa 22.2.0, Chromium running in wayland sessions seems to crash when running with the --in-process-gpu option. Running in X11 seems fine, although it’s slow.
Fix: Update to Mesa 22.3.2 was reported to work here.
2022-10-21
Plasma Mobile Dialer seems to be unreliable
Plasma Dialer 22.09 seems to have issues switching audio profiles and as such might require manual switching. Sometimes audio is completely missing.
Reduced video performance on youtube
Some may encounter reduced video playback performance on YouTube in Firefox with the new Mesa 22.2 drivers.
No workaround at this time.
Old Issues
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
[Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Hi,
Odroid m1 up to date, other devices (c2, n2, c4) not tested for the moment.
Post scriptum : please don’t delete this post, or flag by the community… I think it’s good to know which devices are working or not, the other solution for the dev team is to create a pool after each update with a Manjaro arm supported devices list, let the user select one or more devices .
The user feedback is a part of the software development.
edit 2023.05.30 : the other devices (c2, n2, c4) are now up to date, the odroid c2 is working like a charm :slight_smile:
no issue to build a new stable image for each devices.
Arch Git migration is completed, and Alarm will follow soon.
and ManjaroArm?
vakzination needs a rebuild against the updated kitinerary:
[kevin@plasma-mobile ~]$ vakzination
vakzination: error while loading shared libraries: libKPimItinerary.so.5: cannot open shared object file: No such file or directory
(Not that anybody would still be asking for Covid19 vaccination/recovery certificates around here, but still.)
The library soname is now libKPim5Itinerary.so.5. Hacking the binary with patchelf --replace-needed libKPimItinerary.so.5 libKPim5Itinerary.so.5 vakzination makes it work.
I reat at tips and tricks.
Is this setting also need for Manjaro arm desktop?
The guide posted above is to use kodi as a standalone media server for maximum benefit. Hardware decoding for h264/h265 on the rpi is only possible outside of a desktop environment.
To tell you the truth here I run kodi in my DE 99% of the time. I use kodi every day. The only change I have in my config.txt for my pi4 is this which I leave and hardly ever change is:
arm_freq=2000
#gpu_mem=64
This works for most video’s that I have although there is no HW decoding but I do not have a UHD monitor or run my monitor at 1920x1280. If I do need hardware decoding for a h26/h265 video that has been encoded with a high bitrate I simply exit the DE with a CTRL-SHFT-F2 and log in at the prompt as my regular user and run kodi-standalong. When I am through with the video I go back to my DE with CTRL-SHFT-F7. If I like the video then I convert it to something manageable with handbrake for my DE.
It is good or sad to know.
I commented out gpu_mem=128.lol
