[global]
workgroup = Manjaro
server string = Samba Server
server role = standalone server
log file = /var/log/samba/log.%m
max log size = 50
guest account = nobody
map to guest = Bad Password
client min protocol = NT1
server min protocol = NT1
[public]
path = /srv/samba
public = yes
writable = yes
printable = no
Please, how look your actual smb.conf file ?
On my side I can’t access samba with LXQt
Well, mine is very different and longer. Never touched it.
I can access my NAS, but not mount the shared folder in it.
I’ve try to modify the smb.conf as yours, didn’t help
I have no clue…
Hi!
There are a lot of files in /var/log/samba which one should I provide you?
also something, there are no recent logs, even if I’ve just tried to reach the NAS.
By the way, from an other OS, I have no problem to reach the files through samba.
Thanks
Hello, in my case running waydroid show-full-ui no windows is started when using HW rendering and no error in log; while in logcat I can find several times the following errors:
04-27 13:37:49.086 65 65 E GRALLOC-GBM: failed to create BO, size=1920x1044, fmt=5, usage=4
04-27 13:37:49.086 76 313 E GraphicBufferAllocator: Failed to allocate (1920 x 1044) layerCount 1 format 5 usage b00: 5
04-27 13:37:49.086 76 313 E BufferQueueProducer: [BootAnimation#0] dequeueBuffer: createGraphicBuffer failed
Hi! Still not able to reach my NAS. I’ve uninstalled Manjaro-setting-samba and intall it again. It’s said everything’s ok and reboot. By the terminal if I ask samba, here’s what it says:
$ samba
[2022/04/28 18:26:51, 0] ../../lib/util/debug.c:1224(reopen_one_log)
reopen_one_log: Unable to open new log file '/var/log/samba/log.samba': Permission denied
reopen_one_log: Unable to open new log file '/var/log/samba/%m.log': Permission denied
[2022/04/28 18:26:51.832998, 0] ../../source4/samba/server.c:621(binary_smbd_main)
samba version 4.16.0 started.
Copyright Andrew Tridgell and the Samba Team 1992-2022
[2022/04/28 18:26:51.835253, 0] ../../lib/util/become_daemon.c:119(exit_daemon)
exit_daemon: daemon failed to start: Failed to cleanup temporary files, error code 22
Should I uninstall Manjaro-setting-samba and then uninstall samba, and reinstall everything?
Thank you
Hi robg,
Thank you for the ideas, but…
libunwind was already installed and the samba version seems to be the latest one 4.16.0-4.
To tell the truth I am not comfortable leaving stable to unstable. I might just be patient and wait for the next upgrade…
