Hello ARM community.
This is a small update, but we do introduce the new Breath theme for our KDE Plasma users!
The new Breath theme introduces Bamboo By Night wallpaper
Some highlights:
- Most of our kernels got updated
- CoreApps got a new release with 4.3
- Introducing the new Breath theme, which will replace the current Breath2 themes
- Kodi got updated to 19.3
- Lots of updated packages for our Mobile offerings
- The regular Python updates
- And regular updates from upstream
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installed. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
Chromium will loose sync support in early March:
Arch Linux - News: Chromium losing Sync support in early March
ghostpcl>=9.53.2-2 and ghostxps>=9.53.2-2 updates require manual intervention:
The nss and zn_poly packages requires manual intervention:
Arch Linux - News: zn_poly 0.9.2-2 update requires manual intervention
The packages hplip and firewalld requires manual intervention:
Package changes:
(Mon Jan 3 18:59:50 CET 2022)
- arm-stable community aarch64: 70 new and 69 removed package(s)
- arm-stable core aarch64: 23 new and 23 removed package(s)
- arm-stable extra aarch64: 5 new and 5 removed package(s)
- arm-stable kde-unstable aarch64: 338 new and 334 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-12-13 2022-01-03
alsa-ucm-pinephone 0.5.3-3 0.5.5-1
aura-browser r35.f615dc7-2 -
bigscreen-image-settings-git r01.8977fdbf-2 -
bigscreen-image-settings r5.2c99c52-2 -
chatty0.5.0beta3+1+g73caf3d-10.5.0beta4+5+g8ae677d-1
code 1.63.0-1 1.63.2-1
coreaction 4.2.0-2 4.3.0-1
corearchiver 4.2.0-2 4.3.0-1
corefm 4.2.0-2 4.3.0-1
coregarage 4.2.0-2 4.3.0-1
corehunt 4.2.0-2 4.3.0-1
coreimage 4.2.0-2 4.3.0-1
coreinfo 4.2.0-2 4.3.0-1
corekeyboard 4.2.0-2 4.3.0-1
corepad 4.2.0-2 4.3.0-1
corepaint 4.2.0-3 4.3.0-1
corepdf 4.2.0-2 4.3.0-1
corepins 4.2.0-2 4.3.0-1
corerenamer 4.2.0-2 4.3.0-1
coreshot 4.2.0-2 4.3.0-1
corestats 4.2.0-2 4.3.0-1
corestuff 4.2.0-2 4.3.0-1
coreterminal 4.2.0-2 4.3.0-1
coretime 4.2.0-2 4.3.0-1
coretoppings 4.2.0-3 4.3.0-1
coreuniverse 4.2.0-2 4.3.0-1
eg25-manager 0.4.2-1 0.4.2+4+gb9a5139-2
electron 16.0.3-1 16.0.5-1
electron14 14.2.2-1 14.2.3-1
electron15 15.3.3-1 15.3.4-1
element-desktop 1.9.6-1 1.9.8-1
element-web 1.9.6-1 1.9.8-1
gnome-calls 41.1-342alpha0+38+ge2acfd3-1
gnome-settings-daemon-hybris 3.38.1-1 41.0-1
hwinfo 21.78-1 21.80-1
inxi 3.3.09.1-2 3.3.11.1-1
kodi 19.1-5 19.3-1
kodi-dev 19.1-5 19.3-1
kodi-eventclients 19.1-5 19.3-1
kodi-tools-texturepacker 19.1-5 19.3-1
libcprime 4.2.2-2 4.3.0-1
libcsys 4.2.0-2 4.3.0-1
libpackagekit-glib 1.2.4-1 1.2.4-4
matcha-gtk-theme 20210924-1 20211225-1
megapixels 1.4.2-1 1.4.3-1
mmsd-tng 1.6+11+g87f4e2d-1 1.6+18+g6ee1bdc-1
mobile-config-firefox 2.2.0-2 3.0.0-1
mycroft-gui-git r679.2b1c36e-2 -
nvm 0.39.0-1 0.39.1-1
packagekit 1.2.4-1 1.2.4-4
phoc 0.9.0+162+gcf754b2-1 0.11.0+3+gb067994-1
phosh 0.14.1+19+g4559693-1 0.14.1+56+g1b7e49c-1
phosh-hybris0.14.1+19+g45596931-1 0.14.1+23+g8fc370d-1
pico-wizard-bigscreen-configs-git r2.1be7fb2-1 -
plank-player r19.3ba5ba8-2 -
plasma-bigscreen r418.gad2b98a-2 -
pulseaudio-modules-droid 604.9c6842e-1 619.c6da109-1
python-cec 0.2.7.r13.gf2d4bd3-2 -
python-uinput 0.11.2.r0.gbefe94a-2 -
qcoro 0.3.0-2 -
rpi-eeprom 20211129-1 20211213-1
snapd 2.53.4-1 2.54.1-1
spacebar 21.12-2 21.12-3
squeekboard1.14.0+121+g2fea092-1 1.15.0+15+g5286ff5-1
yt-dlp 2021.12.01-2 2021.12.27-1
breath-classic-icon-themes - 21.2.0-2
breath-classic-wallpaper - 21.2.0-2
breath-wallpapers - 21.2.0-2
hadess-sensorfw-proxy - 26.6291246-1
libcec-rpi-fkms - 6.0.2-3
plasma5-themes-breath - 21.2.0-2
plasma5-themes-breath-classic - 21.2.0-2
plasma5-themes-breath-extra - 21.2.0-2
plasma5-themes-breath-migration - 21.2.0-2
sddm-breath-theme - 21.2.0-2
sensorfw-hybris -0.11.8.5.r0.g8f5ba90-2
:: Different sync package(s) in repository community aarch64
openfire 4.6.4-1 4.6.5-1
python-pymupdf 1.19.2-1 1.19.3-1
rebuilderd 0.16.6-1 0.17.0-1
rebuilderd-tools 0.16.6-1 0.17.0-1
:: Different overlay package(s) in repository core aarch64
linux 5.15.7-1 5.15.11-1
linux-headers 5.15.7-1 5.15.11-1
linux-khadas 5.15.7-1 5.15.10-1
linux-khadas-headers 5.15.7-1 5.15.10-1
linux-pinephone 5.15.7-3 5.15.11-1
linux-pinephone-headers 5.15.7-3 5.15.11-1
linux-pinephonepro 5.16rc4-1 5.16rc7-1
linux-pinephonepro-headers 5.16rc4-1 5.16rc7-1
linux-quartz64 5.16.0-0.2 5.16.0-0.3
linux-quartz64-headers 5.16.0-0.2 5.16.0-0.3
linux-rc 5.16.rc4-5 5.16.rc7-1
linux-rc-headers 5.16.rc4-5 5.16.rc7-1
linux-rpi4 5.10.83-1 5.10.88-1
linux-rpi4-headers 5.10.83-1 5.10.88-1
linux-rpi4-mainline 5.15.6-1 5.15.11-1
linux-rpi4-mainline-headers 5.15.6-1 5.15.11-1
linux-rpi4-rc 5.16.rc4-1 5.16.rc6-1
linux-rpi4-rc-headers 5.16.rc4-1 5.16.rc6-1
manjaro-release 21.12-1 21.12-2
manjaro-system 20211212-3 20220102-2
raspberrypi-bootloader 20211207-1 20211222-1
raspberrypi-bootloader-x 20211207-1 20211222-1
uboot-pinephonepro 1:2021.01rc3-5 1:2021.01rc3-6
:: Different overlay package(s) in repository extra aarch64
mesa-git22.0.0_devel.147684.6e7ffa760f3-122.0.0_devel.148309.222487fabee-1
:: Different sync package(s) in repository extra aarch64
gnome-shell-extensions 41.0-1 41.1-1
gnome-themes-extra 3.28-2 3.28+r6+g45b1d457-1
samba 4.15.2-3 4.15.3-1
smbclient 4.15.2-3 4.15.3-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.12.0.r12666.g22f7a3c08-121.12.0.r12669.g798401bbe-1
akonadi-calendar21.12.0.r2017.g7632a98-121.12.0.r2020.gd20a612-1
akonadi-calendar-tools21.12.0.r924.g23775b6-121.12.0.r926.g512ef86-1
akonadi-contacts21.12.0.r3098.g78005bf9-121.12.0.r3100.g0679b2c0-1
akonadi-import-wizard21.12.0.r1776.ga09283d-121.12.0.r1779.g40c288b-1
akonadi-mime21.12.0.r1684.gce7b54f-121.12.0.r1685.g6f5fc3b-1
akonadi-notes21.12.0.r1048.gbc7c0d7-121.12.0.r1050.gee94a3e-1
akonadi-search21.12.0.r1158.gcb24c22-121.12.0.r1160.g170a6e4-1
akonadiconsole21.12.0.r1557.g4c5b207-121.12.0.r1561.gd393c73-1
akregator21.12.0.r6263.gc5a3aee1-121.12.0.r6279.g9cf77f85-1
alligator 21.12.r0.g8afa7e3-1 21.12.r2.g1679a66-1
amazfish 2.0.3.r3.g8b82bb1-1 2.0.3.r5.gdef0ed4-1
angelfish 21.12.r0.g6097af1-1 21.12.r5.g93340ad-1
ark21.12.0.r4657.g98e5ae5a-121.12.0.r4663.gcff83eab-1
artikulate21.12.0.r1397.g2f813c9-121.12.0.r1399.gf9b048e-1
attica5.88.0.r847.g561512a-15.89.0.r848.gacf1737-1
audiocd-kio21.12.0.r1040.g3f2ff8d-121.12.0.r1042.ge25a720-1
audiotube 21.12.r0.g7629761-1 21.12.r1.g53f466c-1
baloo5.88.0.r3020.g0b902854-15.89.0.r3023.gfd041eaf-1
baloo-widgets21.12.0.r722.g5a511a3-121.12.0.r723.g708711b-1
bigscreen-image-settings r7.4f8e730-1 r9.1560432-1
blinken21.12.0.r648.gf6d9dcf-121.12.0.r649.gacff80f-1
bluedevil1:5.23.4.r2322.g2f149345-11:5.23.4.r2333.g32dff5c1-1
bluez-qt5.88.0.r692.g7f5710c-15.89.0.r695.gd6f534f-1
bomber21.12.0.r543.g2af3a52-121.12.0.r544.g8b3b1fa-1
bovo21.12.0.r752.g3d20cc5-121.12.0.r758.g648e605-1
breeze5.23.4.r2301.g4a2a9470-15.23.4.r2306.gee5cc384-1
breeze-gtk5.23.4.r432.g0cd6ad9-15.23.4.r436.g3785fae-1
breeze-icons5.88.0.r1864.g6c12f18f-15.89.0.r1870.g3b0942a5-1
calendarsupport21.08.1.r64.g4bf3786-121.08.1.r66.gf718ed8-1
calindori 21.12.r0.g10dd294-1 21.12.r1.g4c940cd-1
discover5.23.4.r8449.g96889fba-15.23.4.r8465.g5ad26c9c-1
dolphin21.12.0.r6767.g0d35d8963-121.12.0.r6789.gb38d7150d-1
dolphin-plugins21.12.0.r616.g8165f4c-121.12.0.r626.g13b59e5-1
drkonqi5.23.4.r709.g21505fa5-15.23.4.r718.g71e26ab4-1
elisa21.12.0.r2810.g3bdd406c-121.12.0.r2822.g77fcc444-1
eventviews21.11.90.r21.ga890598-121.11.90.r24.gae488aa-1
extra-cmake-modules5.88.0.r3403.gee7b870-15.89.0.r3406.gb66c9f3-1
filelight21.12.0.r1001.gdb697ca-121.12.0.r1006.ge72a35a-1
frameworkintegration5.88.0.r607.g00e04dc-15.89.0.r611.g67d8390-1
granatier21.12.0.r949.ga070774-121.12.0.r950.g524a473-1
grantlee-editor21.12.0.r792.g86f5f7d-121.12.0.r796.g0a77867-1
grantleetheme21.12.0.r368.g592b434-121.12.0.r370.g209b928-1
gwenview21.12.0.r6705.g79c6bdcf-121.12.0.r6720.gc78a66ac-1
incidenceeditor21.12.0.r812.g86d9a83-121.12.0.r814.gc9cb4f0-1
index-fm 2.1.0.r13.g00cd246-2 2.1.0.r14.g32f9712-1
itinerary21.12.0.r1667.g6115397-121.12.0.r1689.gf72d460-1
k3b1:21.12.0.r6691.gfd4a54153-11:21.12.0.r6705.gd437be436-1
kaccounts-integration21.12.0.r1235.g01523e8-121.12.0.r1236.gf31fa24-1
kaccounts-providers21.12.0.r387.gd70238c-121.12.0.r388.g8a4db4b-1
kactivities5.88.0.r1373.g4733f47-15.89.0.r1377.g83deb15-1
kactivities-stats5.88.0.r384.gce9f6d2-15.89.0.r387.g1194b02-1
kactivitymanagerd5.23.4.r1375.gc66bf75-15.23.4.r1377.g24398d9-1
kaddressbook21.12.0.r6082.g4056ff0b-121.12.0.r6084.g0b741627-1
kajongg21.12.0.r4207.g4ec590dd-121.12.0.r4209.gb647417e-1
kalarm21.12.0.r6530.g63ee4ca6-121.12.0.r6556.g7aceaed3-1
kalarmcal21.12.0.r1171.g0ef4de1-121.12.0.r1173.gcb5e8e5-1
kalk 21.12.r1.g8c98f19-1 21.12.r2.gae3e849-1
kamera21.12.0.r680.gdd297cc-121.12.0.r688.g4667902-1
kamoso21.12.0.r1440.g5d9f42f-121.12.0.r1443.g0fe4bf4-1
kapidox5.88.0.r559.gcc9f645-15.89.0.r560.g49edb94-1
kapman21.12.0.r628.g2a1cebe-121.12.0.r630.g6ec03bf-1
karchive5.88.0.r521.g6bf564d-15.89.0.r524.g9826deb-1
kasts 21.12.r3.gb3dac26-1 21.12.r8.gbd46d33-1
kate21.12.0.r18485.g7af8ed574-121.12.0.r18504.g33a748a44-1
katomic21.12.0.r937.gc24a180-121.12.0.r938.g4f654f2-1
kauth5.88.0.r459.g0ccaa85-15.89.0.r462.gf3a71ab-1
kbackup21.12.0.r405.gfa783c6-121.12.0.r412.g520846c-1
kblocks21.12.0.r687.g48fa730-121.12.0.r688.gaa4549a-1
kbookmarks5.88.0.r437.gd88275d-15.89.0.r440.gf5b71d9-1
kbounce21.12.0.r824.gb4a2815-121.12.0.r826.ge3ee41b-1
kbruch21.12.0.r828.g4ef20cc-121.12.0.r832.g3b9a697-1
kcalc21.12.0.r1583.ga97d90b-121.12.0.r1586.g76b445d-1
kcalendarcore5.88.0.r1274.gc78a5be3e-15.89.0.r1280.g3f4e3085a-1
kcalutils21.12.0.r908.g4bbc9e5cd-121.12.0.r910.g5c7bae14a-1
kcharselect21.12.0.r489.ge87c76f-121.12.0.r495.ga05aec1-1
kclock 21.12.r11.g3a695c4-1 21.12.r45.g8dad90d-1
kcmutils5.88.0.r574.gd82e565-15.89.0.r581.g6dc8911-1
kcodecs5.88.0.r399.g120e31a-15.89.0.r400.gf28a11f-1
kcolorchooser21.12.0.r240.g100efc6-121.12.0.r243.g9e08450-1
kcompletion5.88.0.r471.g4015189-15.89.0.r477.gdee8727-1
kconfig5.88.0.r897.g574508b9-15.89.0.r903.geac8e43e-1
kconfigwidgets5.88.0.r650.g2dbecbb-15.89.0.r655.g58f5ba3-1
kcontacts1:5.88.0.r3293.gc0bd98e8-11:5.89.0.r3297.ge2f5ea26-1
kcoreaddons5.88.0.r1361.gf76888c7-15.89.0.r1367.g6bc5b25a-1
kcrash5.88.0.r422.g3fed76d-15.89.0.r424.g413f7ca-1
kcron21.12.0.r817.g7d33ce9-121.12.0.r819.gc49b1dc-1
kdav1:5.88.0.r1311.ga16c713-11:5.89.0.r1312.gfa45b9b-1
kdbusaddons5.88.0.r391.g49489c6-15.89.0.r393.gb072811-1
kde-cli-tools5.23.4.r1880.g992d52b-15.23.4.r1883.gfdbc0c0-1
kde-gtk-config5.23.4.r918.g2abea72-15.23.4.r919.g967d7aa-1
kdebugsettings21.12.0.r872.g048439b-121.12.0.r878.g678bdac-1
kdeclarative5.88.0.r949.gd97523f-15.89.0.r955.g4d6df0e-1
kdeconnect21.12.0.r3371.gf8c59e7f-121.12.0.r3381.gad7b5b42-1
kded5.88.0.r432.g794b9ed-15.89.0.r435.g74f7c14-1
kdegraphics-mobipocket21.12.0.r262.g0881310-121.12.0.r265.g8e1b8b9-1
kdegraphics-thumbnailers21.12.0.r238.g28aeb62-121.12.0.r246.g30c74ed-1
kdelibs4support5.88.0.r1056.gf6b3ef9d-15.89.0.r1059.ga4344821-1
kdenetwork-filesharing21.12.0.r897.gd30447b-121.12.0.r898.gc681404-1
kdenlive21.12.0.r15362.g8b0a5ea55-121.12.0.r15407.g837a609a8-1
kdepim-addons21.12.0.r4434.g7cb38b88-121.12.0.r4471.gd6cb54ab-1
kdepim-runtime21.12.0.r15411.g1c7cb773b-121.12.0.r15419.g337347715-1
kdeplasma-addons5.23.4.r8612.ga6c4aa1ae-15.23.4.r8618.g48a2a2af4-1
kdesignerplugin5.88.0.r342.gc8d492b-15.89.0.r344.gb3898de-1
kdesu5.88.0.r484.gd2a88c2-15.89.0.r486.g81f0ae9-1
kdewebkit5.88.0.r289.g794c703-15.89.0.r290.g482c569-1
kdf21.12.0.r815.g2bd4832-121.12.0.r819.g027bbd0-1
kdialog21.12.0.r1200.g52ebbedce-121.12.0.r1201.g9a0b7dc5b-1
kdiamond21.12.0.r688.gd782122-121.12.0.r689.g50cd38c-1
kdnssd5.88.0.r334.gd40f997-15.89.0.r336.g2e15dd4-1
kdoctools5.88.0.r638.g50d9d7e-15.89.0.r639.ga1bc92e-1
keditbookmarks21.12.0.r2753.g509efd64d-121.12.0.r2758.ga087de28b-1
kemoticons5.88.0.r398.g943af5f-15.89.0.r399.g8135d51-1
keysmith 21.12.r0.gf7bccdc-1 21.12.r3.ge8c2d5c-1
kfilemetadata5.88.0.r827.g75c565d-15.89.0.r830.gbd93146-1
kfind21.12.0.r2658.g372a4c400-121.12.0.r2661.g332a789e4-1
kfloppy21.12.0.r772.gd99e2b3-121.12.0.r775.g8f29131-1
kfourinline21.12.0.r999.g7c28d33-121.12.0.r1001.g38d1a2e-1
kgamma55.23.4.r465.g939a73a-15.23.4.r468.ga7d3e96-1
kget21.12.0.r3137.g1e6341ba-121.12.0.r3142.g172877bf-1
kglobalaccel5.88.0.r486.gb5299df-15.89.0.r489.gd7f922b-1
kgpg21.12.0.r3143.gd5c6d5a6-121.12.0.r3146.g71e54375-1
kguiaddons5.88.0.r407.g6f85228-15.89.0.r414.g9c8a589-1
khangman21.12.0.r1579.g3978275-121.12.0.r1581.g6d9a585-1
khelpcenter21.12.0.r2689.g53426c45-121.12.0.r2692.gec493baf-1
kholidays1:5.88.0.r980.gd83220b-11:5.89.0.r983.geadc878-1
khotkeys5.23.4.r2106.g02ae7ea-15.23.4.r2109.g3c4fbfa-1
khtml5.88.0.r566.g8854bd5-15.89.0.r567.g1d5fd34-1
ki18n5.88.0.r525.g9bd1f86-15.89.0.r529.g178b7db-1
kiconthemes5.88.0.r573.g4e48ca5-15.89.0.r575.gf5a65ba-1
kidentitymanagement21.12.0.r3851.gab3c3bcd-121.12.0.r3853.g82b35671-1
kidletime5.88.0.r332.g517352b-15.89.0.r336.g789622d-1
killbots21.12.0.r753.g66f76e8-121.12.0.r754.ga9d6555-1
kimageformats5.88.0.r369.g81603ed-15.89.0.r371.g3234772-1
kimap21.12.0.r1150.g2dd2ed5-121.12.0.r1152.gbff4db1-1
kinfocenter5.23.4.r2003.g464f754-15.23.4.r2010.g004fe9d-1
kinit5.88.0.r424.gb1a1da6-15.89.0.r425.gcdcc3b3-1
kio5.88.0.r5128.g870bbd91-15.89.0.r5157.g15ef3f77f-1
kio-extras21.12.0.r7170.g380640a5-121.12.0.r7174.g0bb11925-1
kirigami-addons 1:0.2.r12.g17233e2-1 1:0.2.r13.g8c3c1c4-1
kirigami25.88.0.r2977.gbffc33bb-15.89.0.r2995.gc6e322a0-1
kitemmodels5.88.0.r571.g2c3108a-15.89.0.r584.gacf9032-1
kitemviews5.88.0.r352.g8b3909b-15.89.0.r354.g0749b38-1
kitinerary21.12.0.r2040.g675db3c-121.12.0.r2042.gfac0eb2-1
kjobwidgets5.88.0.r392.g89b8bea-15.89.0.r395.g9aab5a3-1
kjs5.88.0.r348.g9fe09cd-15.89.0.r349.g1fa7e5a-1
kjsembed5.88.0.r313.gcc96775-15.89.0.r314.g71a3201-1
kjumpingcube21.12.0.r803.ge2794de-121.12.0.r806.g7bef7d9-1
kldap21.12.0.r916.g0d88fc6-121.12.0.r918.g68f100f-1
kleopatra21.12.0.r6124.gac014d57-121.12.0.r6143.gcea56e01-1
klickety21.12.0.r652.g5a785cd-121.12.0.r653.g5072858-1
kmag21.12.0.r704.g9cefc5b-121.12.0.r706.g91c80c3-1
kmahjongg21.12.0.r1495.ge8a691e-121.12.0.r1498.g8c1941f-1
kmail21.12.0.r26166.g3af8ebff3-121.12.0.r26186.g19a5a7773-1
kmail-account-wizard21.12.0.r848.g0542177-121.12.0.r852.gdbd255e-1
kmailtransport21.12.0.r1693.g0f1b76d-121.12.0.r1695.g5d7ea6b-1
kmbox21.12.0.r566.g084131c-121.12.0.r568.gabfe498-1
kmediaplayer5.88.0.r304.g7c327a0-15.89.0.r305.gaf78aa1-1
kmime21.12.0.r1481.gcaa9862-121.12.0.r1483.g719eaf2-1
kmines21.12.0.r1739.g3ce1824-121.12.0.r1741.gb9603ee-1
kmousetool21.12.0.r406.g734af5b-121.12.0.r409.g924bddf-1
knetwalk21.12.0.r673.gbdf20be-121.12.0.r674.gd1cc69f-1
knewstuff5.88.0.r1246.g508b9f84-15.89.0.r1249.g9f5d2084-1
knights21.12.0.r1078.gdda8d69-121.12.0.r1080.g5ed4b12-1
knotes21.12.0.r3556.g48f4a076-121.12.0.r3570.gc86cf350-1
knotifications5.88.0.r697.gdf26abf-15.89.0.r706.gd3b9a8c-1
knotifyconfig5.88.0.r363.ga7f5609-15.89.0.r367.g58c4a55-1
koko 21.12.r0.g5f0531a-1 21.12.r3.gc447d10-1
kolf21.12.0.r1460.g186782c-121.12.0.r1462.g8dcc44b-1
kollision21.12.0.r508.g95a968e-121.12.0.r510.g940f51f-1
kolourpaint21.12.0.r2376.gb6d6d541-121.12.0.r2377.g36d8b5aa-1
konqueror21.12.0.r15010.g3e960d9ef-121.12.0.r15022.g06fdda7c4-1
konsole21.12.0.r8135.gbf34fcb1-121.12.0.r8152.g02e21a81-1
kontact21.12.0.r5441.gb24e7cdc-121.12.0.r5447.gf305fc91-1
kontactinterface21.12.0.r654.gcfbd821-121.12.0.r655.g4d37f7b-1
konversation21.12.0.r9016.g50661e8c-121.12.0.r9039.gd3f02251-1
kopeninghours21.12.0.r292.ga094ba3-121.12.0.r309.gbeeb1f7-1
kopete21.12.0.r16404.g0a9b454ea-121.12.0.r16405.g69f6c3115-1
korganizer21.12.0.r11566.ge56c71fbe-121.12.0.r11583.g59e8d8757-1
kosmindoormap21.12.0.r681.gc1179ec-121.12.0.r684.g294be65-1
kpackage5.88.0.r713.gbdd5ea0-15.89.0.r720.gb59d2a4-1
kparts5.88.0.r548.gc0b3950-15.89.0.r561.g36ac74f-1
kpeople5.88.0.r1356.g1a1a1eb-15.89.0.r1360.gf433de3-1
kpeoplevcard 0.1.r16.ge0e3028-1 0.1.r17.gebf9df1-1
kpimtextedit21.12.0.r1486.geda7f8a-121.12.0.r1489.g598242f-1
kpkpass21.12.0.r255.gbd86911-121.12.0.r259.g7842876-1
kplotting5.88.0.r305.g9229510-15.89.0.r307.g680e6bd-1
kpmcore21.12.0.r1213.g31921c5-121.12.0.r1215.g68c8fec-1
kpty5.88.0.r352.g6624ef0-15.89.0.r356.ge621b54-1
kpublictransport21.12.0.r1948.ge0cd6df3-121.12.0.r1965.ga0d9cdd9-1
kquickcharts5.88.0.r489.ge04c5ab-15.89.0.r490.g0f460cd-1
kquickimageeditor r64.g335a8b8-1 r65.g60ffd96-1
krdc21.12.0.r1551.g2fcc61d-121.12.0.r1552.g5a61504-1
krecorder 21.12.r4.g98c1d88-1 21.12.r18.g9d2f74a-1
kreversi21.12.0.r1244.g7ecf18f-121.12.0.r1245.gb997ddd-1
krfb21.12.0.r1455.g8a12611-121.12.0.r1456.gb13a8e9-1
kross5.88.0.r344.g24008ce-15.89.0.r345.gb9c16b5-1
kruler21.12.0.r715.ga94386c-121.12.0.r717.gd81b7fb-1
krunner5.88.0.r699.gdb49ba9-15.89.0.r706.g955bb1d-1
kscreen5.23.4.r1404.gbbc2d2a-15.23.4.r1415.g9aebf99-1
kscreenlocker5.23.4.r889.g1f092a8-15.23.4.r891.g084e6ab-1
kservice5.88.0.r968.gd667e5b-15.89.0.r976.gbc52d3d-1
kshisen21.12.0.r1215.ga8c407e-121.12.0.r1217.g38f9e1f-1
ksmtp21.12.0.r410.g9691e4a-121.12.0.r412.gb145213-1
ksnakeduel21.12.0.r824.gb4e5dbb-121.12.0.r825.g6811d23-1
kspaceduel21.12.0.r651.gced4dae-121.12.0.r654.g0630633-1
ksquares21.12.0.r535.gdd92485-121.12.0.r537.g91adb89-1
ksudoku21.12.0.r1077.g8787e2f-121.12.0.r1079.gc399b0a-1
ksysguard5.23.4.r3519.g6a3c7e8a-15.23.4.r3522.g267933a4-1
ksystemlog21.12.0.r680.ge50f627-121.12.0.r683.gb7a1734-1
ksystemstats5.23.4.r210.g03fa8a7-15.23.4.r212.g399afab-1
kteatime21.12.0.r732.g4e97433-121.12.0.r735.g7c7f252-1
ktexteditor5.88.0.r3009.g85faeac6-15.89.0.r3014.g1b9bbc51-1
ktextwidgets5.88.0.r427.gb4aa1e2-15.89.0.r429.gb09962f-1
ktimer21.12.0.r483.g6bbc628-121.12.0.r489.g0041e27-1
ktnef21.12.0.r690.g832e475-121.12.0.r692.geada534-1
ktorrent21.12.0.r2794.g85f73ce6-121.12.0.r2797.g97398417-1
ktrip 21.12.r0.g1000251-1 21.12.r3.gdd83cfe-1
ktuberling21.12.0.r1027.gc34f5e7-121.12.0.r1028.g909494e-1
kturtle21.12.0.r1136.g2904f2a-121.12.0.r1141.g8d051eb-1
kubrick21.12.0.r383.gcc18542-121.12.0.r385.g9938bec-1
kunitconversion5.88.0.r392.ged7c211-15.89.0.r395.g61487e6-1
kwallet5.88.0.r1103.g724a590-15.89.0.r1107.g2da9b6b-1
kwallet-pam5.23.4.r259.g1d65ed8-15.23.4.r260.g32d6ead-1
kwalletmanager21.12.0.r1221.g12290f1-121.12.0.r1223.g5b40fe6-1
kwayland5.88.0.r1125.gbc0d375-15.89.0.r1127.gaeefdb6-1
kwayland-integration5.23.4.r194.g8cd4f71-15.23.4.r196.g56771c0-1
kwayland-server5.23.4.r1429.gfab63da-15.23.4.r1434.g3c6264d-1
kweather 21.12.r5.gc0e639d-1 21.12.r7.gc69b931-1
kweathercore 0.5.r3.g21d7195-1 0.5.r4.gc983d1f-1
kwidgetsaddons5.88.0.r896.g0bf15291-15.89.0.r899.gdd13b793-1
kwin5.23.4.r20475.g92d334531-15.23.4.r20532.g4f2c3a00c-1
kwindowsystem5.88.0.r642.ge895381-15.89.0.r648.g9d5cf1a-1
kwinft5.23.3.r19902.g2a4211c3b-15.23.3.r19942.g83004fd51-1
kwordquiz21.12.0.r1160.g294106f-121.12.0.r1162.gf222613-1
kwrite21.12.0.r18485.g7af8ed574-121.12.0.r18504.g33a748a44-1
kwrited5.23.4.r491.ga74515e-15.23.4.r493.gf80898d-1
kxmlgui5.88.0.r827.g11c9cc80-15.89.0.r832.g207e15c5-1
kxmlrpcclient5.88.0.r467.g7da4928e7-15.89.0.r469.g16510e720-1
libakonadi21.12.0.r12666.g22f7a3c08-121.12.0.r12669.g798401bbe-1
libgravatar21.12.0.r392.g4e7e0df-121.12.0.r394.gb7c6625-1
libkcompactdisc21.12.0.r389.g4f2835f-121.12.0.r391.ge62b8ec-1
libkdegames21.12.0.r2200.g547e5ce3-121.12.0.r2201.g186856e6-1
libkdepim21.12.0.r876.g95970c5-121.12.0.r878.g49da121-1
libkeduvocdocument21.12.0.r1798.ge8b0d15-121.12.0.r1800.g84cf675-1
libkgapi21.12.0.r1325.g36eaa86-121.12.0.r1328.g110c199-1
libkipi21.12.0.r1257.gcf973e4-121.12.0.r1258.g86845ff-1
libkleo21.12.0.r1038.g11cb536-121.12.0.r1046.geefdd28-1
libksane21.12.0.r577.g1560d47-121.12.0.r585.ged7d424-1
libkscreen5.23.4.r1609.gcf0921f-15.23.4.r1614.g45c724c-1
libksieve21.12.0.r1635.g1ec2a153-121.12.0.r1637.gf63a2eeb-1
libksysguard5.23.4.r2331.ga0d7092-15.23.4.r2335.g973aa3e-1
lskat21.12.0.r829.gc7639a1-121.12.0.r830.gef9ccaf-1
mailcommon21.12.0.r1165.g3bda971-121.12.0.r1177.g0b5c49e-1
mailimporter21.12.0.r492.g5662d97-121.12.0.r494.g6b6fea1-1
maliit-keyboard r2128.gd842b36a-1 r2132.g08c6e629-1
marble21.12.0.r13375.gdb5957820-121.12.0.r13379.g6f7a6a324-1
marble-common21.12.0.r13375.gdb5957820-121.12.0.r13379.g6f7a6a324-1
marble-qt21.12.0.r13375.gdb5957820-121.12.0.r13379.g6f7a6a324-1
maui-pix 2.1.0.r3.g4c77aba-2 2.1.0.r4.gfaf7c6c-1
mauikit2.1.0.r17.ge932ac27-22.1.0.r21.g01b824cf-1
mauikit-accounts 2.1.0.r1.g709da19-2 2.1.0.r2.g2bab928-1
mauikit-filebrowsing 2.1.0.r9.g7c06d8a-1 2.1.0.r13.gddab09e-1
mauikit-imagetools 2.1.0.r7.geb592bd-2 2.1.0.r8.gcc1235c-1
mauikit-texteditor 2.1.0.r1.ge150080-2 2.1.0.r2.g265aa2a-1
mbox-importer21.12.0.r538.g3b830ba-121.12.0.r542.gbd11994-1
messagelib21.12.0.r6311.ga8e46dc5-121.12.0.r6317.g7a0799f6-1
milou5.23.4.r756.gb458f34-15.23.4.r757.gc120a0b-1
modemmanager-qt5.88.0.r533.g80ddbd1-15.89.0.r536.gfeaa1ad-1
mycroft-skill-installer r86.a59a02e-1 r86.a59a02e-2
neochat 21.12.r2.gd0e04e0c-121.12.r28.g67bc66ee-1
networkmanager-qt5.88.0.r1129.gbc00557-15.89.0.r1132.gfe57e1a-1
okular21.12.0.r9550.g09a2b506e-121.12.0.r9554.g3792d8d56-1
oxygen5.23.4.r4441.g1ae0dd85-15.23.4.r4443.gca7d43f1-1
oxygen-icons1:5.88.0.r5.gbff159d-11:5.89.0.r5.gbff159d-1
oxygen-icons-svg1:5.88.0.r5.gbff159d-11:5.89.0.r5.gbff159d-1
partitionmanager21.12.0.r1545.gdffa270-121.12.0.r1546.g4f17fc5-1
picmi21.12.0.r542.ge72c031-121.12.0.r543.g6299ea6-1
pico-wizard-bigscreen-configs-git r2.1be7fb2-1 r3.c10252e-1
pim-data-exporter21.12.0.r2531.g2e40c66c-121.12.0.r2537.gfc6dca52-1
pim-sieve-editor21.12.0.r1543.ge9820f1-121.12.0.r1547.g89d1ef1-1
pimcommon21.07.80.r1155.g3a041b1-121.07.80.r1157.g3aa13d7-1
plasma-bigscreen r421.g2ca0e4f-1 r427.g362d2c0-1
plasma-browser-integration5.23.4.r1295.g51649511-15.23.4.r1297.g30590ecb-1
plasma-camera 1.0.r108.g54c9966-1 1.0.r109.gf202cf0-1
plasma-desktop5.23.4.r8865.gd8fe26740-15.23.4.r8923.g2cef3c07b-1
plasma-dialer 21.12.r4.g7f08493-1 21.12.r7.gd097b9b-1
plasma-disks5.23.4.r243.g840dc45-15.23.4.r245.g6bc2dfb-1
plasma-firewall5.23.4.r553.ge3c549a-15.23.4.r558.g3401766-1
plasma-framework5.88.0.r16126.g7feec7ce6-15.89.0.r16134.g83b82a4a7-1
plasma-integration5.23.4.r541.g64eabb7-15.23.4.r544.gfd9a07e-1
plasma-mobile-nm5.23.4.r3151.g8e782601-15.23.4.r3155.g086fab2d-1
plasma-nano5.23.4.r170.g4ea8ecc-15.23.4.r172.g3fb52ce-1
plasma-nm5.23.4.r3151.g8e782601-15.23.4.r3155.g086fab2d-1
plasma-pa5.23.4.r1008.g1af7aad-15.23.4.r1013.g275fdcd-1
plasma-phone-components5.23.4.r1534.g2b1e6f12-15.23.4.r1556.g54f10f9f-1
plasma-phonebook 21.12.r0.gc57726b-1 21.12.r1.g287a539-1
plasma-sdk5.23.4.r2292.gb13a413a-15.23.4.r2293.gdbc2222c-1
plasma-settings 21.12.r0.gad3d85a-1 21.12.r5.g7a8be38-1
plasma-systemmonitor5.23.4.r526.gca879c1-15.23.4.r533.g85db72e-1
plasma-thunderbolt5.23.4.r159.g2d98206-15.23.4.r161.gd4afb3d-1
plasma-vault5.23.4.r357.g730fde2-15.23.4.r361.g64d604d-1
plasma-wayland-session5.23.4.r11042.g25d581060-15.23.4.r11154.ga1fdb95d8-1
plasma-workspace5.23.4.r11042.g25d581060-15.23.4.r11154.ga1fdb95d8-1
plasma-workspace-wallpapers5.23.4.r301.g6419f26-15.23.4.r303.gcb62f13-1
powerdevil5.23.4.r2501.g0569b6a2-15.23.4.r2509.g9b8a9dfd-1
poxml21.12.0.r279.g7b9c282-121.12.0.r281.g183b2c7-1
print-manager21.12.0.r1080.g2b27d68-121.12.0.r1086.gb8e53b2-1
prison5.88.0.r346.g8c0686f-15.89.0.r350.ge7c2eab-1
pulseaudio-qt 1.3.0.r15.g73ca791-1 1.3.0.r16.g162fb4e-1
purpose5.88.0.r921.g9ff6577-15.89.0.r932.g2c1b6c8-1
qcoro0.3.0.r174.g817dad2-1 -
qmlkonsole 21.12.r0.gaebc895-1 21.12.r9.g06ba226-1
qqc2-breeze-style5.23.4.r233.g94298f3-15.23.4.r235.g05a8d95-1
qqc2-desktop-style5.88.0.r550.g7c97810-15.89.0.r552.g8d0e1b6-1
rocs21.12.0.r3052.g5a4aaed3-121.12.0.r3053.g97a1f41c-1
sddm-kcm5.23.4.r628.gfd8b2e9-15.23.4.r630.g129e84a-1
solid5.88.0.r729.gc44f590-15.89.0.r735.gb5a7e81-1
sonnet5.88.0.r660.gc662d58-15.89.0.r663.gb7d61e2-1
spacebar 21.12.r2.g4567548-1 21.12.r4.ge7c577f-1
spectacle21.12.0.r1247.g67ea15c-121.12.0.r1263.g3d4bbe9-1
svgpart21.12.0.r189.g4d20cfd-121.12.0.r191.gec70167-1
sweeper21.12.0.r545.ged4e95e-121.12.0.r547.g1c1dcfb-1
syndication5.88.0.r850.gccb1905-15.89.0.r853.ge72415c-1
syntax-highlighting5.88.0.r1761.g720099c7-15.89.0.r1777.gaef89153-1
systemsettings5.23.4.r2575.g2a64b6d8-15.23.4.r2588.ge9ea12f2-1
telepathy-kde-accounts-kcm21.12.0.r1201.g092e874-121.12.0.r1206.g3ce3bd2-1
threadweaver5.88.0.r522.g6a723eb-15.89.0.r524.g392e211-1
tokodon 21.12.r0.g821832d-1 21.12.r15.g751c2da-1
umbrello21.12.0.r8280.gaa7932073-121.12.0.r8281.g5b860d44d-1
vakzination 21.12.r0.g8484ef7-1 21.12.r1.g6a66058-1
vvave 2.1.0.r7.g4f75712-1 2.1.0.r8.ga09a705-1
xdg-desktop-portal-kde5.23.4.r410.g5c7d8ff-15.23.4.r415.g13cd59f-1
yakuake21.12.0.r744.ga9abf3d-121.12.0.r759.g6bbf2e4-1
kwin-hybris -5.23.4.r20505.gda8925d7e-1
lottie-qml - r24.0db824c-1
mycroft-bigscreen -21.2.2.r4874.g3d963cee40-1
mycroft-gui - r715.cceee1c-2
pico-wizard-bigscreen-configs - r3.c10252e-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #manjaro-arm:arm-testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
Donation
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Poll
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
